Flash problem
I download the r36.3 sdk and I prepare everything to flash the orin.
First I use this sdk to flash agx orin use cmd : sudo ./flash.sh jetson-agx-orin-devkit mmcblk0p1
It flash successfully.
Then I flash the agx orin industrial use cmd : sudo ./flash.sh jetson-agx-orin-devkit-industrial mmcblk0p1
I flash falied.The detail log is attached below:
sq@sq-virtual-machine:~/orinsdk363/Linux_for_Tegra$ sudo ./flash.sh jetson-agx-orin-devkit-industrial mmcblk0p1
L4T BSP Information:
R36 , REVISION: 3.0
User release: 0.0
ECID is 0x80012344705DF0CA2800000016FD8140
Target Board Information:
Name: jetson-agx-orin-devkit-industrial, Board Family: generic, SoC: Tegra 234,
OpMode: production, Boot Authentication: NS,
Disk encryption: disabled ,
Existing emcfuse(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/fuse_t234.xml) reused.
copying emc_fuse_dev_params(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/generic/BCT/tegra234-br-bct-diag-boot.dts)… done.
copying device_config(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-device-p3701-0000.dts)… done.
copying misc_config(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-misc-p3701-0008-flash.dts)… done.
./tegraflash.py --chip “0x23” --applet “/home/sq/orinsdk363/Linux_for_Tegra/bootloader/mb1_t234_prod.bin” --skipuid --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3701-0000.dts --misc_config tegra234-mb1-bct-misc-p3701-0008-flash.dts --bins “mb2_applet applet_t234.bin” --cmd “readfuses fuse_t234.bin fuse_t234.xml; dump eeprom cvm cvm.bin; dump try_custinfo custinfo_out.bin; reboot recovery”
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0172 ] Reading fuses
[ 0.0176 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.0180 ] File rcm_state open failed
[ 0.0182 ] ERROR: failed to read rcm_state
[ 0.0183 ]
[ 0.0189 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0191 ] Assuming zero filled SBK key
[ 0.0188 ] Pre-processing config: tegra234-mb1-bct-device-p3701-0000.dts
[ 0.0248 ] Pre-processing config: tegra234-mb1-bct-misc-p3701-0008-flash.dts
[ 0.0333 ] Parsing partition layout
[ 0.0337 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0346 ] Kernel DTB used: None
[ 0.0346 ] WARNING: dce base dtb is not provided
[ 0.0347 ] Parsing partition layout
[ 0.0351 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0358 ] Creating list of images to be signed
[ 0.0361 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[ 0.0365 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0377 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0383 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0429 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0434 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.0474 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.0478 ] adding BCH for mb2_t234_aligned.bin
[ 0.0501 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.0614 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.0619 ] adding BCH for mb2_t234_aligned.bin
[ 0.0746 ] Filling MB1 storage info
[ 0.0747 ] Parsing dev params for multi chains
[ 0.0807 ] Generating br-bct
[ 0.0811 ] Updating dev and MSS params in BR BCT
[ 0.0811 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.0818 ] Updating bl info
[ 0.0822 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin
[ 0.0826 ] WARNING: boot chain is not completed. set to 0
[ 0.0834 ] Generating signatures
[ 0.0841 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.0843 ] Assuming zero filled SBK key
[ 0.0929 ] Warning: pub_key.key is not found
[ 0.0926 ] Parsing dev params for multi chains
[ 0.0926 ] Generating br-bct
[ 0.0931 ] Updating dev and MSS params in BR BCT
[ 0.0931 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.0938 ] Updating bl info
[ 0.0942 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.0945 ] WARNING: boot chain is not completed. set to 0
[ 0.0957 ] Generating SHA2 Hash
[ 0.0971 ] Sha saved in br_bct_BR.sha
[ 0.0967 ] Get Signed section of bct
[ 0.0970 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[ 0.0977 ] Signing BCT
[ 0.0984 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.0985 ] Assuming zero filled SBK key
[ 0.1004 ] Sha saved in br_bct_BR.sha
[ 0.1007 ] Warning: pub_key.key is not found
[ 0.1001 ] Updating BCT with signature
[ 0.1005 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[ 0.1008 ] Offset :4608 Len :3584
[ 0.1016 ] Generating SHA2 Hash
[ 0.1022 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[ 0.1024 ] Assuming zero filled SBK key
[ 0.1045 ] Sha saved in br_bct_BR.sha
[ 0.1042 ] Updating BCT with SHA2 Hash
[ 0.1045 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[ 0.1049 ] Offset :4608 Len :3584
[ 0.1058 ] Offset :68 Len :8124
[ 0.1058 ]
[ 0.1060 ] Generating coldboot mb1-bct
[ 0.1064 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0008-flash_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.1067 ] MB1-BCT version: 0.13
[ 0.1073 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_TEMP_QB_DATA/ is not supported
[ 0.1103 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_TEMP_QB_IO_BUFFER/ is not supported
[ 0.1105 ]
[ 0.1105 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.1105 ] Added Platform Config 9 data with size :- 100
[ 0.1105 ]
[ 0.1106 ] Updating mb1-bct with firmware information
[ 0.1110 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.1120 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 0.1124 ] Generating SHA2 Hash for mb1bct
[ 0.1140 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[ 0.1149 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[ 0.1147 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 0.1150 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 0.1169 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1170 ] Assuming zero filled SBK key
[ 0.1183 ] Warning: pub_key.key is not found
[ 0.1181 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.1191 ] Generating recovery mb1-bct
[ 0.1195 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0008-flash_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.1199 ] MB1-BCT version: 0.13
[ 0.1201 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_TEMP_QB_DATA/ is not supported
[ 0.1216 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_TEMP_QB_IO_BUFFER/ is not supported
[ 0.1221 ]
[ 0.1221 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.1221 ] Added Platform Config 9 data with size :- 100
[ 0.1221 ]
[ 0.1222 ] Updating mb1-bct with firmware information
[ 0.1226 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.1237 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[ 0.1241 ] Generating SHA2 Hash for mb1bct
[ 0.1256 ] Sha saved in mb1_bct_MB1_aligned.sha
[ 0.1265 ] Sha saved in mb1_bct_MB1.sha
[ 0.1264 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[ 0.1267 ] adding BCH for mb1_bct_MB1_aligned.bct
[ 0.1280 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1282 ] Assuming zero filled SBK key
[ 0.1294 ] Warning: pub_key.key is not found
[ 0.1292 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.1300 ] Info: Skip generating mem_bct because sdram_config is not defined
[ 0.1301 ] Copying signatures
[ 0.1305 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.1346 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.1348 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.1348 ] Boot Rom communication
[ 0.1353 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 0.1356 ] BR_CID: 0x80012344705DF0CA2800000016FD8140
[ 0.2426 ] Sending bct_br
[ 0.3445 ] ERROR: might be timeout in USB write.
Error: Return value 3
Command tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 10.4580 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 10.4620 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 10.4660 ] Retrieving board information
[ 10.4678 ] tegrarcm_v2 --chip 0x23 0 --oem platformdetails chip chip_info.bin
[ 10.4706 ] Retrieving EEPROM data
[ 10.4708 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/sq/orinsdk363/Linux_for_Tegra/bootloader/cvm.bin --chip 0x23 0
[ 10.4745 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 10.4782 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 10.4805 ] Dumping customer Info
[ 10.4820 ] tegrarcm_v2 --chip 0x23 0 --oem dump bct tmp.bct
[ 10.4857 ] tegrabct_v2 --brbct tmp.bct --chip 0x23 0 --custinfo /home/sq/orinsdk363/Linux_for_Tegra/bootloader/custinfo_out.bin
[ 10.4871 ] File tmp.bct open failed
[ 10.4879 ] Error: try getting custinfo fail. Moving on
[ 10.4881 ] Rebooting to recovery mode
[ 10.4895 ] tegrarcm_v2 --chip 0x23 0 --ismb2
[ 10.4918 ] Rebooting to recovery mode
[ 10.4935 ] tegrarcm_v2 --chip 0x23 0 --reboot recovery
Board ID(3701) version(500) sku(0000) revision(L.0)
Chip SKU(00:00:00:D0) ramcode(00:00:00:00) fuselevel(fuselevel_production) board_FAB(500)
reusing existing /home/sq/orinsdk363/Linux_for_Tegra/bootloader/badpage.bin
16+0 records in
16+0 records out
8192 bytes (8.2 kB, 8.0 KiB) copied, 0.00017052 s, 48.0 MB/s
Copy /home/sq/orinsdk363/Linux_for_Tegra/kernel/dtb/tegra234-p3737-0000+p3701-0008-nv.dtb to /home/sq/orinsdk363/Linux_for_Tegra/kernel/dtb/tegra234-p3737-0000+p3701-0008-nv.dtb.rec
copying bctfile(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/generic/BCT/tegra234-p3701-0000-sdram-l4t.dts)… done.
copying minratchet_config(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-ratchet-p3701-0000.dts)… done.
copying misc_cold_boot_config(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-misc-p3701-0008.dts)… done.
copying pinmux_config(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-pinmux-p3701-0000-a04.dtsi)… done.
copying gpioint_config(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-gpioint-p3701-0000.dts)… done.
copying pmic_config(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-pmic-p3701-0000.dts)… done.
copying pmc_config(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-padvoltage-p3701-0000-a04.dtsi)… done.
copying deviceprod_config(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-cprod-p3701-0000.dts)… done.
copying prod_config(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-prod-p3701-0000.dts)… done.
copying scr_config(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb2-bct-scr-p3701-0000.dts)… done.
copying wb0sdram(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/generic/BCT/tegra234-p3701-0000-wb0sdram-l4t.dts)… done.
copying bootrom_config(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-reset-p3701-0000.dts)… done.
Existing uphylane_config(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/tegra234-mb1-bct-uphylane-si.dtsi) reused.
copying dev_params(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/generic/BCT/tegra234-br-bct-p3701-0000.dts)… done.
copying dev_params_b(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/generic/BCT/tegra234-br-bct_b-p3701-0000.dts)… done.
copying mb2bct_cfg(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb2-bct-misc-p3701-0008.dts)… done.
Existing pscfwfile(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/pscfw_t234_prod.bin) reused.
Existing pscbl1file(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/psc_bl1_t234_prod.bin) reused.
Existing mtsmcefile(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/mce_flash_o10_cr_prod.bin) reused.
Existing tscfwfile(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/tsec_t234.bin) reused.
Existing mb2applet(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/applet_t234.bin) reused.
Existing bootloader(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
copying initrd(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/l4t_initrd.img)… done.
bl is uefi
Making Boot image… done.
Not signing of boot.img
Making recovery ramdisk for recovery image…
Re-generating recovery ramdisk for recovery image…
/home/sq/orinsdk363/Linux_for_Tegra/bootloader/ramdisk_tmp /home/sq/orinsdk363/Linux_for_Tegra/bootloader /home/sq/orinsdk363/Linux_for_Tegra
53899 blocks
gzip: /home/sq/orinsdk363/Linux_for_Tegra/kernel/Image: not in gzip format
_BASE_KERNEL_VERSION=5.15.136-tegra
77459 blocks
Making Recovery image…
copying recdtbfile(/home/sq/orinsdk363/Linux_for_Tegra/kernel/dtb/tegra234-p3737-0000+p3701-0008-nv.dtb.rec)… done.
20+0 records in
20+0 records out
20 bytes copied, 0.000246875 s, 81.0 kB/s
Existing sosfile(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing tegraboot(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing cpu_bootloader(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing mb2blfile(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing xusbfile(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/xusb_t234_prod.bin) reused.
Existing pvafile(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/nvpva_020.fw) reused.
Existing dcefile(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/display-t234-dce.bin) reused.
Existing nvdecfile(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/nvdec_t234_prod.fw) reused.
Existing psc_rf(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/psc_rf_t234_prod.bin) reused.
Existing mb2_rf(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/mb2rf_t234.bin) reused.
Existing mb1file(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing bpffile(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/bpmp_t234-TE990M-A1_prod.bin) reused.
Existing fsifwfile(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/fsi-fw-ecc.bin) reused.
copying bpfdtbfile(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/generic/tegra234-bpmp-3701-0008-3737-0000.dtb)… done.
Existing camerafw(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/camera-rtcpu-t234-rce.img) reused.
Existing apefile(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/adsp-fw.bin) reused.
Existing spefile(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/spe_t234.bin) reused.
Existing badpagefile(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/badpage.bin) reused.
Existing wb0boot(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/sc7_t234_prod.bin) reused.
Existing tosfile(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/tos-optee_t234.img) reused.
Existing eksfile(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/eks_t234.img) reused.
copying dtbfile(/home/sq/orinsdk363/Linux_for_Tegra/kernel/dtb/tegra234-p3737-0000+p3701-0008-nv.dtb)… done.
Copying nv_boot_control.conf to rootfs
populating kernel to rootfs… done.
populating initrd to rootfs… done.
populating kernel_tegra234-p3737-0000+p3701-0008-nv.dtb to rootfs… done.
Making system.img…
populating rootfs from /home/sq/orinsdk363/Linux_for_Tegra/rootfs … populating /boot/extlinux/extlinux.conf … done.
Sync’ing system.img … done.
Converting RAW image to Sparse image… done.
system.img built successfully.
Not signing of kernel-dtb
Existing tbcfile(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/uefi_jetson.bin) reused.
131072+0 records in
131072+0 records out
67108864 bytes (67 MB, 64 MiB) copied, 0.193458 s, 347 MB/s
Sync’ing esp.img … done.
copying tbcdtbfile(/home/sq/orinsdk363/Linux_for_Tegra/kernel/dtb/tegra234-p3737-0000+p3701-0008-nv.dtb)… done.
copying cfgfile(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/generic/cfg/flash_t234_qspi_sdmmc_industrial.xml) to flash.xml… done.
Existing flashapp(/home/sq/orinsdk363/Linux_for_Tegra/bootloader/tegraflash.py) reused.
copying overlay_dtb(/home/sq/orinsdk363/Linux_for_Tegra/kernel/dtb/L4TConfiguration.dtbo)… done.
copying overlay_dtb(/home/sq/orinsdk363/Linux_for_Tegra/kernel/dtb/tegra234-p3737-0000+p3701-0000-dynamic.dtbo)… done.
copying overlay_dtb(/home/sq/orinsdk363/Linux_for_Tegra/kernel/dtb/tegra234-carveouts.dtbo)… done.
copying overlay_dtb(/home/sq/orinsdk363/Linux_for_Tegra/kernel/dtb/tegra-optee.dtbo)… done.
copying overlay_dtb(/home/sq/orinsdk363/Linux_for_Tegra/kernel/dtb/tegra234-p3737-camera-dual-imx274-overlay.dtbo)… done.
copying overlay_dtb(/home/sq/orinsdk363/Linux_for_Tegra/kernel/dtb/tegra234-p3737-camera-e3331-overlay.dtbo)… done.
copying overlay_dtb(/home/sq/orinsdk363/Linux_for_Tegra/kernel/dtb/tegra234-p3737-camera-e3333-overlay.dtbo)… done.
copying overlay_dtb(/home/sq/orinsdk363/Linux_for_Tegra/kernel/dtb/tegra234-p3737-camera-imx185-overlay.dtbo)… done.
/home/sq/orinsdk363/Linux_for_Tegra/bootloader/L4TConfiguration_updated.dts: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
/home/sq/orinsdk363/Linux_for_Tegra/bootloader/L4TConfiguration.dtbo: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
./tegraflash.py --bl uefi_jetson_with_dtb.bin --odmdata gbe-uphy-config-22,hsstp-lane-map-3,nvhs-uphy-config-0,hsio-uphy-config-0,gbe0-enable-10g --overlay_dtb L4TConfiguration.dtbo,tegra234-p3737-0000+p3701-0000-dynamic.dtbo,tegra234-carveouts.dtbo,tegra-optee.dtbo,tegra234-p3737-camera-dual-imx274-overlay.dtbo,tegra234-p3737-camera-e3331-overlay.dtbo,tegra234-p3737-camera-e3333-overlay.dtbo,tegra234-p3737-camera-imx185-overlay.dtbo, --bldtb tegra234-p3737-0000+p3701-0008-nv.dtb --applet mb1_t234_prod.bin --cmd “flash; reboot” --cfg flash.xml --chip “0x23” --concat_cpubl_bldtb --cpubl uefi_jetson.bin --minratchet_config tegra234-mb1-bct-ratchet-p3701-0000.dts --device_config tegra234-mb1-bct-device-p3701-0000.dts --misc_cold_boot_config tegra234-mb1-bct-misc-p3701-0008.dts --misc_config tegra234-mb1-bct-misc-p3701-0008-flash.dts --pinmux_config tegra234-mb1-bct-pinmux-p3701-0000-a04.dtsi --gpioint_config tegra234-mb1-bct-gpioint-p3701-0000.dts --pmic_config tegra234-mb1-bct-pmic-p3701-0000.dts --pmc_config tegra234-mb1-bct-padvoltage-p3701-0000-a04.dtsi --deviceprod_config tegra234-mb1-bct-cprod-p3701-0000.dts --prod_config tegra234-mb1-bct-prod-p3701-0000.dts --scr_config tegra234-mb2-bct-scr-p3701-0000.dts --wb0sdram_config tegra234-p3701-0000-wb0sdram-l4t.dts --br_cmd_config tegra234-mb1-bct-reset-p3701-0000.dts --uphy tegra234-mb1-bct-uphylane-si.dtsi --dev_params tegra234-br-bct-p3701-0000.dts,tegra234-br-bct_b-p3701-0000.dts --mb2bct_cfg tegra234-mb2-bct-misc-p3701-0008.dts --bins “psc_fw pscfw_t234_prod.bin; mts_mce mce_flash_o10_cr_prod.bin; tsec_fw tsec_t234.bin; mb2_applet applet_t234.bin; mb2_bootloader mb2_t234.bin; xusb_fw xusb_t234_prod.bin; pva_fw nvpva_020.fw; dce_fw display-t234-dce.bin; nvdec nvdec_t234_prod.fw; bpmp_fw bpmp_t234-TE990M-A1_prod.bin; fsi_fw fsi-fw-ecc.bin; bpmp_fw_dtb tegra234-bpmp-3701-0008-3737-0000.dtb; rce_fw camera-rtcpu-t234-rce.img; ape_fw adsp-fw.bin; spe_fw spe_t234.bin; tos tos-optee_t234.img; eks eks_t234.img” --sdram_config tegra234-p3701-0000-sdram-l4t.dts --cust_info custinfo_out.bin --bct_backup --boot_chain A
saving flash command in /home/sq/orinsdk363/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/sq/orinsdk363/Linux_for_Tegra/bootloader/flash_win.bat
*** Flashing target device started. ***
version 1.0.0
[ 0.0810 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0814 ] Assuming zero filled SBK key
[ 0.0781 ] Parsing partition layout
[ 0.0803 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.1012 ] Change tegra234-bpmp-3701-0008-3737-0000.dtb to tegra234-bpmp-3701-0008-3737-0000_with_odm.dtb
[ 0.1013 ] Change tegra234-bpmp-3701-0008-3737-0000.dtb to tegra234-bpmp-3701-0008-3737-0000_with_odm.dtb
[ 0.3662 ] /usr/bin/python3 dtbcheck.py -c t234 -o tegra234-bpmp-3701-0008-3737-0000_with_odm.dtb tegra234-bpmp-3701-0008-3737-0000_with_odm_tmp.dtb
[ 0.5988 ] Concatenating L4TConfiguration.dtbo,tegra234-p3737-0000+p3701-0000-dynamic.dtbo,tegra234-carveouts.dtbo,tegra-optee.dtbo,tegra234-p3737-camera-dual-imx274-overlay.dtbo,tegra234-p3737-camera-e3331-overlay.dtbo,tegra234-p3737-camera-e3333-overlay.dtbo,tegra234-p3737-camera-imx185-overlay.dtbo to tegra234-p3737-0000+p3701-0008-nv_with_odm_overlay.dtb.updated
[ 0.5994 ] Concatenating bl dtb to cpubl binary
[ 0.6031 ] MB2 binary: mb2_t234.bin
[ 0.6032 ] Pre-processing mb2bct config: tegra234-mb2-bct-misc-p3701-0008.dts
[ 0.6156 ] Pre-processing mb2bct config: tegra234-mb2-bct-scr-p3701-0000.dts
[ 0.9685 ] Generating coldboot mb2-bct
[ 0.9685 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_cold_boot_bct.cfg --mb2bctcfg tegra234-mb2-bct-misc-p3701-0008_cpp.dtb --scr tegra234-mb2-bct-scr-p3701-0000_cpp.dtb
[ 0.9691 ] ERROR: value 0x31 is out of range
[ 0.9782 ] ERROR: value 0x31 is out of range
[ 0.9808 ] ERROR: value 0x31 is out of range
[ 0.9836 ] ERROR: value 0x31 is out of range
[ 0.9861 ] WARNING: unknown property ‘tfc_version’
[ 0.9877 ] WARNING: unknown property ‘addr_header_version’
[ 0.9877 ]
[ 0.9879 ] Updating mb2-bct with storage information
[ 0.9885 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_cold_boot_bct_MB2.bct --updatestorageinfo flash.xml.bin
[ 0.9895 ] Concatenating mb2-bct to mb2 binary
[ 0.9895 ] mb2_bin_file = mb2_t234.bin
[ 0.9897 ] mb2_bct_file = mb2_cold_boot_bct_MB2.bct
[ 0.9931 ] DCE binary: display-t234-dce.bin
[ 0.9932 ] Kernel DTB used: kernel_tegra234-p3737-0000+p3701-0008-nv.dtb
[ 0.9932 ] Concatenating kernel-dtb to dce-fw binary
[ 0.9935 ] dce_bin = display-t234-dce.bin
[ 0.9936 ] kernel_dtb = kernel_tegra234-p3737-0000+p3701-0008-nv.dtb
[ 0.9936 ] dce_with_dtb = display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0008-nv.bin
[ 1.0103 ] Update display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0008-nv.bin to dce_fw partitions
[ 1.0127 ] Parsing partition layout
[ 1.0133 ] tegraparser_v2 --pt flash.xml.tmp
[ 1.0144 ] Creating list of images to be signed
[ 1.0150 ] Generating ratchet blob
[ 1.0150 ] Pre-processing config: tegra234-mb1-bct-reset-p3701-0000.dts
[ 1.0216 ] Pre-processing config: tegra234-mb1-bct-device-p3701-0000.dts
[ 1.0277 ] Pre-processing config: tegra234-mb1-bct-cprod-p3701-0000.dts
[ 1.0334 ] Pre-processing config: tegra234-mb1-bct-gpioint-p3701-0000.dts
[ 1.0399 ] Pre-processing config: tegra234-mb1-bct-misc-p3701-0008.dts
[ 1.0501 ] Pre-processing config: tegra234-mb1-bct-misc-p3701-0008-flash.dts
[ 1.0594 ] Pre-processing config: tegra234-mb1-bct-pinmux-p3701-0000-a04.dtsi
[ 1.0711 ] Pre-processing config: tegra234-mb1-bct-padvoltage-p3701-0000-a04.dtsi
[ 1.0769 ] Pre-processing config: tegra234-mb1-bct-pmic-p3701-0000.dts
[ 1.0832 ] Pre-processing config: tegra234-mb1-bct-prod-p3701-0000.dts
[ 1.0891 ] Pre-processing config: tegra234-p3701-0000-sdram-l4t.dts
[ 2.7285 ] Pre-processing config: tegra234-mb1-bct-uphylane-si.dtsi
[ 2.7358 ] Pre-processing config: tegra234-p3701-0000-wb0sdram-l4t.dts
[ 4.3766 ] Pre-processing config: tegra234-mb1-bct-ratchet-p3701-0000.dts
[ 4.3891 ] Generating coldboot mb1-bct
[ 4.3896 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0008_cpp.dtb --wb0sdram tegra234-p3701-0000-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3701-0000-a04_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3701-0000-a04_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3701-0000_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3701-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3701-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3701-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[ 4.3901 ] MB1-BCT version: 0.13
[ 4.3914 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_TEMP_QB_DATA/ is not supported
[ 4.3963 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_TEMP_QB_IO_BUFFER/ is not supported
[ 4.3963 ]
[ 4.3963 ] Parsing config file :tegra234-mb1-bct-pinmux-p3701-0000-a04_cpp.dtb
[ 4.3963 ] Added Platform Config 0 data with size :- 2936
[ 4.3963 ]
[ 4.3963 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3701-0000-a04_cpp.dtb
[ 4.3963 ] WARNING: unknown node ‘g2’
[ 4.3963 ] WARNING: unknown node ‘g9’
[ 4.3963 ] Added Platform Config 2 data with size :- 24
[ 4.3963 ]
[ 4.3963 ] Parsing config file :tegra234-mb1-bct-pmic-p3701-0000_cpp.dtb
[ 4.3963 ] Added Platform Config 4 data with size :- 532
[ 4.3964 ]
[ 4.3964 ] Parsing config file :tegra234-mb1-bct-reset-p3701-0000_cpp.dtb
[ 4.3964 ] Added Platform Config 3 data with size :- 52
[ 4.3964 ]
[ 4.3964 ] Parsing config file :tegra234-mb1-bct-prod-p3701-0000_cpp.dtb
[ 4.3966 ] WARNING: unknown property ‘major’
[ 4.3966 ] WARNING: unknown property ‘minor’
[ 4.3966 ] Added Platform Config 5 data with size :- 524
[ 4.3966 ]
[ 4.3966 ] Parsing config file :tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb
[ 4.3966 ] Added Platform Config 7 data with size :- 380
[ 4.3966 ]
[ 4.3966 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[ 4.3966 ] Added Platform Config 8 data with size :- 24
[ 4.3968 ]
[ 4.3969 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 4.3971 ] Added Platform Config 9 data with size :- 100
[ 4.3971 ]
[ 4.3972 ] Parsing config file :tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb
[ 4.3972 ] ModuleCount 0 NumProdNames 0
[ 4.3972 ] Added Platform Config 6 data with size :- 16
[ 4.3972 ]
[ 4.3972 ] Parsing config file :tegra234-mb1-bct-ratchet-p3701-0000_cpp.dtb
[ 4.3974 ]
[ 4.3976 ] Updating mb1-bct with firmware information
[ 4.3981 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 4.3993 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 4.3998 ] Generating SHA2 Hash for mb1bct
[ 4.4055 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[ 4.4065 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[ 4.4029 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 4.4033 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 4.4087 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 4.4090 ] Assuming zero filled SBK key
[ 4.4102 ] Warning: pub_key.key is not found
[ 4.4066 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 4.4075 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --ratchet_blob ratchet_blob.bin --list images_list.xml zerosbk
[ 4.4079 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 4.4126 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 4.4161 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 4.4193 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 4.4229 ] Header already present for tsec_t234_aligned.bin
[ 4.4256 ] Header already present for nvdec_t234_prod_aligned.fw
[ 4.4286 ] adding BCH for mb2_t234_with_mb2_cold_boot_bct_MB2_aligned.bin
[ 4.4320 ] adding BCH for xusb_t234_prod_aligned.bin
[ 4.4390 ] Header already present for bpmp_t234-TE990M-A1_prod_aligned.bin
[ 4.4459 ] adding BCH for tegra234-bpmp-3701-0008-3737-0000_with_odm_aligned.dtb
[ 4.4603 ] Header already present for pscfw_t234_prod_aligned.bin
[ 4.4650 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[ 4.4699 ] Header already present for sc7_t234_prod.bin
[ 4.4723 ] Header already present for psc_rf_t234_prod_aligned.bin
[ 4.4759 ] adding BCH for mb2rf_t234_aligned.bin
[ 4.4780 ] INFO: compressing uefi_jetson_with_dtb_aligned.bin
[ 4.5339 ] INFO: complete compression, uefi_jetson_with_dtb_aligned.bin, ratio = 89%
[ 4.5425 ] adding BCH for uefi_jetson_with_dtb_aligned_blob_w_bin_aligned.bin
[ 4.5890 ] adding BCH for tos-optee_t234_aligned.img
[ 4.6443 ] adding BCH for eks_t234_aligned.img
[ 4.6881 ] INFO: compressing display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0008-nv_aligned.bin
[ 4.8609 ] INFO: complete compression, display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0008-nv_aligned.bin, ratio = 6%
[ 4.8806 ] adding BCH for display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0008-nv_aligned_blob_w_bin_aligned.bin
[ 4.8959 ] adding BCH for fsi-fw-ecc_aligned.bin
[ 4.9254 ] adding BCH for spe_t234_aligned.bin
[ 5.0758 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[ 5.0834 ] adding BCH for adsp-fw_aligned.bin
[ 5.0963 ] INFO: compressing nvpva_020_aligned.fw
[ 5.1443 ] INFO: complete compression, nvpva_020_aligned.fw, ratio = 2%
[ 5.1473 ] adding BCH for nvpva_020_aligned_blob_w_bin_aligned.fw
[ 5.1510 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 5.1552 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 5.1597 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 5.1636 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 5.1671 ] Header already present for tsec_t234_aligned.bin
[ 5.1701 ] Header already present for nvdec_t234_prod_aligned.fw
[ 5.1731 ] adding BCH for mb2_t234_with_mb2_cold_boot_bct_MB2_aligned.bin
[ 5.1764 ] adding BCH for xusb_t234_prod_aligned.bin
[ 5.1801 ] Header already present for bpmp_t234-TE990M-A1_prod_aligned.bin
[ 5.1886 ] adding BCH for tegra234-bpmp-3701-0008-3737-0000_with_odm_aligned.dtb
[ 5.2025 ] Header already present for pscfw_t234_prod_aligned.bin
[ 5.2074 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[ 5.2126 ] Header already present for sc7_t234_prod.bin
[ 5.2151 ] Header already present for psc_rf_t234_prod_aligned.bin
[ 5.2180 ] adding BCH for mb2rf_t234_aligned.bin
[ 5.2203 ] INFO: compressing uefi_jetson_with_dtb_aligned.bin
[ 5.2771 ] INFO: complete compression, uefi_jetson_with_dtb_aligned.bin, ratio = 89%
[ 5.2826 ] adding BCH for uefi_jetson_with_dtb_aligned_blob_w_bin_aligned.bin
[ 5.3373 ] adding BCH for tos-optee_t234_aligned.img
[ 5.3833 ] adding BCH for eks_t234_aligned.img
[ 5.4275 ] INFO: compressing display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0008-nv_aligned.bin
[ 5.6064 ] INFO: complete compression, display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0008-nv_aligned.bin, ratio = 6%
[ 5.6288 ] adding BCH for display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0008-nv_aligned_blob_w_bin_aligned.bin
[ 5.6470 ] adding BCH for fsi-fw-ecc_aligned.bin
[ 5.6648 ] adding BCH for spe_t234_aligned.bin
[ 5.8162 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[ 5.8274 ] adding BCH for adsp-fw_aligned.bin
[ 5.8729 ] INFO: compressing nvpva_020_aligned.fw
[ 5.9214 ] INFO: complete compression, nvpva_020_aligned.fw, ratio = 2%
[ 5.9246 ] adding BCH for nvpva_020_aligned_blob_w_bin_aligned.fw
[ 5.9273 ] Filling MB1 storage info
[ 5.9273 ] Parsing dev params for multi chains
[ 5.9339 ] Generating br-bct
[ 5.9344 ] Updating dev and MSS params in BR BCT
[ 5.9344 ] tegrabct_v2 --dev_param tegra234-br-bct-p3701-0000_cpp.dtb --sdram tegra234-p3701-0000-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 6.0289 ] Updating bl info
[ 6.0296 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin
[ 6.0409 ] Generating br-bct
[ 6.0415 ] Updating dev and MSS params in BR BCT
[ 6.0416 ] tegrabct_v2 --dev_param tegra234-br-bct_b-p3701-0000_cpp.dtb --sdram tegra234-p3701-0000-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 6.1371 ] Updating bl info
[ 6.1377 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin
[ 6.1391 ] Generating BCT backup image
[ 6.1391 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[ 6.1399 ] 32768+0 records in
[ 6.1772 ] 32768+0 records out
[ 6.1774 ] 32768 bytes (33 kB, 32 KiB) copied, 0.0364321 s, 899 kB/s
[ 6.1774 ]
[ 6.1777 ] Concatenating BCT for chain A to bct_backup.img
[ 6.1777 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[ 6.1785 ] 8192+0 records in
[ 6.1847 ] 8192+0 records out
[ 6.1849 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.00559192 s, 1.5 MB/s
[ 6.1850 ]
[ 6.1852 ] Concatenating BCT for chain B to bct_backup.img
[ 6.1854 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[ 6.1860 ] 8192+0 records in
[ 6.1925 ] 8192+0 records out
[ 6.1926 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.0057405 s, 1.4 MB/s
[ 6.1928 ]
[ 6.1929 ] Generating signatures
[ 6.1972 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[ 6.1975 ] Assuming zero filled SBK key
[ 6.2927 ] Warning: pub_key.key is not found
[ 6.2915 ] Parsing dev params for multi chains
[ 6.2916 ] Generating br-bct
[ 6.2921 ] Updating dev and MSS params in BR BCT
[ 6.2923 ] tegrabct_v2 --dev_param tegra234-br-bct-p3701-0000_cpp.dtb --sdram tegra234-p3701-0000-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 6.3906 ] Updating customer data section
[ 6.3913 ] tegrabct_v2 --chip 0x23 0 --brbct br_bct_BR.bct --update_custinfo custinfo_out.bin
[ 6.3923 ] Updating bl info
[ 6.3928 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 6.3948 ] Generating SHA2 Hash
[ 6.4000 ] Sha saved in br_bct_BR.sha
[ 6.3961 ] Get Signed section of bct
[ 6.3965 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[ 6.3972 ] Signing BCT
[ 6.4015 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 6.4018 ] Assuming zero filled SBK key
[ 6.4038 ] Sha saved in br_bct_BR.sha
[ 6.4042 ] Warning: pub_key.key is not found
[ 6.4002 ] Updating BCT with signature
[ 6.4007 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[ 6.4011 ] Offset :4608 Len :3584
[ 6.4017 ] Generating SHA2 Hash
[ 6.4060 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[ 6.4063 ] Assuming zero filled SBK key
[ 6.4064 ] Assuming zero filled SBK key
[ 6.4087 ] Sha saved in br_bct_BR.sha
[ 6.4049 ] Updating BCT with SHA2 Hash
[ 6.4055 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[ 6.4059 ] Offset :4608 Len :3584
[ 6.4066 ] Offset :68 Len :8124
[ 6.4068 ]
[ 6.4070 ] Generating br-bct
[ 6.4075 ] Updating dev and MSS params in BR BCT
[ 6.4077 ] tegrabct_v2 --dev_param tegra234-br-bct_b-p3701-0000_cpp.dtb --sdram tegra234-p3701-0000-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 6.5020 ] Updating customer data section
[ 6.5025 ] tegrabct_v2 --chip 0x23 0 --brbct br_bct_BR.bct --update_custinfo custinfo_out.bin
[ 6.5035 ] Updating bl info
[ 6.5040 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 6.5059 ] Generating SHA2 Hash
[ 6.5111 ] Sha saved in br_bct_BR.sha
[ 6.5071 ] Get Signed section of bct
[ 6.5076 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[ 6.5084 ] Signing BCT
[ 6.5126 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 6.5129 ] Assuming zero filled SBK key
[ 6.5151 ] Sha saved in br_bct_BR.sha
[ 6.5155 ] Warning: pub_key.key is not found
[ 6.5115 ] Updating BCT with signature
[ 6.5119 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[ 6.5124 ] Offset :4608 Len :3584
[ 6.5130 ] Generating SHA2 Hash
[ 6.5173 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[ 6.5175 ] Assuming zero filled SBK key
[ 6.5176 ] Assuming zero filled SBK key
[ 6.5198 ] Sha saved in br_bct_BR.sha
[ 6.5160 ] Updating BCT with SHA2 Hash
[ 6.5165 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[ 6.5170 ] Offset :4608 Len :3584
[ 6.5178 ] Offset :68 Len :8124
[ 6.5179 ]
[ 6.5183 ] Generating BCT backup image
[ 6.5184 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[ 6.5191 ] 32768+0 records in
[ 6.5569 ] 32768+0 records out
[ 6.5570 ] 32768 bytes (33 kB, 32 KiB) copied, 0.0367805 s, 891 kB/s
[ 6.5571 ]
[ 6.5574 ] Concatenating BCT for chain A to bct_backup.img
[ 6.5576 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[ 6.5584 ] 8192+0 records in
[ 6.5655 ] 8192+0 records out
[ 6.5656 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.0061927 s, 1.3 MB/s
[ 6.5658 ]
[ 6.5660 ] Concatenating BCT for chain B to bct_backup.img
[ 6.5660 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[ 6.5668 ] 8192+0 records in
[ 6.5728 ] 8192+0 records out
[ 6.5730 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.00546229 s, 1.5 MB/s
[ 6.5733 ]
[ 6.5734 ] Generating coldboot mb1-bct
[ 6.5739 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0008_cpp.dtb --wb0sdram tegra234-p3701-0000-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3701-0000-a04_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3701-0000-a04_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3701-0000_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3701-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3701-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3701-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[ 6.5743 ] MB1-BCT version: 0.13
[ 6.5761 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_TEMP_QB_DATA/ is not supported
[ 6.5794 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_TEMP_QB_IO_BUFFER/ is not supported
[ 6.5804 ] Parsing config file :tegra234-mb1-bct-pinmux-p3701-0000-a04_cpp.dtb
[ 6.5812 ] Added Platform Config 0 data with size :- 2936
[ 6.5822 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3701-0000-a04_cpp.dtb
[ 6.5831 ] WARNING: unknown node ‘g2’
[ 6.5833 ] WARNING: unknown node ‘g2’
[ 6.5836 ] WARNING: unknown node ‘g9’
[ 6.5840 ] WARNING: unknown node ‘g9’
[ 6.5842 ] Added Platform Config 2 data with size :- 24
[ 6.5845 ] Parsing config file :tegra234-mb1-bct-pmic-p3701-0000_cpp.dtb
[ 6.5847 ] Added Platform Config 4 data with size :- 532
[ 6.5847 ]
[ 6.5847 ] Parsing config file :tegra234-mb1-bct-reset-p3701-0000_cpp.dtb
[ 6.5847 ] Added Platform Config 3 data with size :- 52
[ 6.5847 ]
[ 6.5848 ] Parsing config file :tegra234-mb1-bct-prod-p3701-0000_cpp.dtb
[ 6.5848 ] WARNING: unknown property ‘major’
[ 6.5848 ] WARNING: unknown property ‘minor’
[ 6.5848 ] Added Platform Config 5 data with size :- 524
[ 6.5848 ]
[ 6.5848 ] Parsing config file :tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb
[ 6.5848 ] Added Platform Config 7 data with size :- 380
[ 6.5848 ]
[ 6.5848 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[ 6.5848 ] Added Platform Config 8 data with size :- 24
[ 6.5848 ]
[ 6.5848 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 6.5848 ] Added Platform Config 9 data with size :- 100
[ 6.5848 ]
[ 6.5848 ] Parsing config file :tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb
[ 6.5849 ] ModuleCount 0 NumProdNames 0
[ 6.5849 ] Added Platform Config 6 data with size :- 16
[ 6.5849 ]
[ 6.5849 ] Parsing config file :tegra234-mb1-bct-ratchet-p3701-0000_cpp.dtb
[ 6.5849 ]
[ 6.5849 ] Updating mb1-bct with firmware information
[ 6.5852 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 6.5865 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 6.5870 ] Generating SHA2 Hash for mb1bct
[ 6.5922 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[ 6.5932 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[ 6.5894 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 6.5897 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 6.5952 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 6.5953 ] Assuming zero filled SBK key
[ 6.5967 ] Warning: pub_key.key is not found
[ 6.5929 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 6.5938 ] Generating recovery mb1-bct
[ 6.5942 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0008-flash_cpp.dtb --wb0sdram tegra234-p3701-0000-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3701-0000-a04_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3701-0000-a04_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3701-0000_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3701-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3701-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3701-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[ 6.5945 ] MB1-BCT version: 0.13
[ 6.5947 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_TEMP_QB_DATA/ is not supported
[ 6.5961 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_TEMP_QB_IO_BUFFER/ is not supported
[ 6.5975 ] Parsing config file :tegra234-mb1-bct-pinmux-p3701-0000-a04_cpp.dtb
[ 6.5979 ] Added Platform Config 0 data with size :- 2936
[ 6.6005 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3701-0000-a04_cpp.dtb
[ 6.6009 ] WARNING: unknown node ‘g2’
[ 6.6011 ] WARNING: unknown node ‘g2’
[ 6.6012 ] WARNING: unknown node ‘g9’
[ 6.6014 ] WARNING: unknown node ‘g9’
[ 6.6015 ] Added Platform Config 2 data with size :- 24
[ 6.6017 ] Parsing config file :tegra234-mb1-bct-pmic-p3701-0000_cpp.dtb
[ 6.6022 ] Added Platform Config 4 data with size :- 532
[ 6.6026 ] Parsing config file :tegra234-mb1-bct-reset-p3701-0000_cpp.dtb
[ 6.6030 ] Added Platform Config 3 data with size :- 52
[ 6.6032 ] Parsing config file :tegra234-mb1-bct-prod-p3701-0000_cpp.dtb
[ 6.6037 ] WARNING: unknown property ‘major’
[ 6.6038 ] WARNING: unknown property ‘minor’
[ 6.6040 ] Added Platform Config 5 data with size :- 524
[ 6.6043 ] Parsing config file :tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb
[ 6.6048 ] WARNING: unknown property ‘major’
[ 6.6049 ] WARNING: unknown property ‘minor’
[ 6.6051 ] Added Platform Config 7 data with size :- 380
[ 6.6056 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[ 6.6060 ] Added Platform Config 8 data with size :- 24
[ 6.6062 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 6.6066 ] Added Platform Config 9 data with size :- 100
[ 6.6068 ] Parsing config file :tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb
[ 6.6073 ] ModuleCount 0 NumProdNames 0
[ 6.6075 ] Added Platform Config 6 data with size :- 16
[ 6.6078 ] Parsing config file :tegra234-mb1-bct-ratchet-p3701-0000_cpp.dtb
[ 6.6083 ] Updating mb1-bct with firmware information
[ 6.6086 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo flash.xml.bin
[ 6.6097 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[ 6.6102 ] Generating SHA2 Hash for mb1bct
[ 6.6153 ] Sha saved in mb1_bct_MB1_aligned.sha
[ 6.6163 ] Sha saved in mb1_bct_MB1.sha
[ 6.6125 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[ 6.6128 ] adding BCH for mb1_bct_MB1_aligned.bct
[ 6.6180 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 6.6182 ] Assuming zero filled SBK key
[ 6.6194 ] Warning: pub_key.key is not found
[ 6.6156 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 6.6165 ] Generating coldboot mem-bct
[ 6.6168 ] tegrabct_v2 --chip 0x23 0 --sdram tegra234-p3701-0000-sdram-l4t_cpp.dtb --wb0sdram tegra234-p3701-0000-wb0sdram-l4t_cpp.dtb --membct tegra234-p3701-0000-sdram-l4t_cpp_1.bct tegra234-p3701-0000-sdram-l4t_cpp_2.bct tegra234-p3701-0000-sdram-l4t_cpp_3.bct tegra234-p3701-0000-sdram-l4t_cpp_4.bct
[ 6.6171 ] packing sdram params with Wb0 file tegra234-p3701-0000-wb0sdram-l4t_cpp.dtb
[ 6.7111 ] Packing sdram param for instance[0]
[ 6.7113 ] Packing sdram param for instance[1]
[ 6.7116 ] Packing sdram param for instance[2]
[ 6.7118 ] Packing sdram param for instance[3]
[ 6.7120 ] Packing sdram param for instance[4]
[ 6.7122 ] Packing sdram param for instance[5]
[ 6.7126 ] Packing sdram param for instance[6]
[ 6.7129 ] Packing sdram param for instance[7]
[ 6.7133 ] Packing sdram param for instance[8]
[ 6.7137 ] Packing sdram param for instance[9]
[ 6.7141 ] Packing sdram param for instance[10]
[ 6.7145 ] Packing sdram param for instance[11]
[ 6.7148 ] Packing sdram param for instance[12]
[ 6.7153 ] Packing sdram param for instance[13]
[ 6.7156 ] Packing sdram param for instance[14]
[ 6.7160 ] Packing sdram param for instance[15]
[ 6.8108 ] Getting sector size from pt
[ 6.8114 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[ 6.8119 ] BlockSize read from layout is 0x200
[ 6.8123 ] tegrahost_v2 --chip 0x23 0 --blocksize 512 --magicid MEMB --addsigheader_multi tegra234-p3701-0000-sdram-l4t_cpp_1.bct tegra234-p3701-0000-sdram-l4t_cpp_2.bct tegra234-p3701-0000-sdram-l4t_cpp_3.bct tegra234-p3701-0000-sdram-l4t_cpp_4.bct
[ 6.8126 ] Binary 0 length is 58752
[ 6.8129 ] Binary 0 align length is 58880
[ 6.8136 ] Binary 1 length is 58752
[ 6.8138 ] Binary 1 align length is 58880
[ 6.8148 ] Binary 2 length is 58752
[ 6.8154 ] Binary 2 align length is 58880
[ 6.8160 ] Binary 3 length is 58752
[ 6.8165 ] Binary 3 align length is 58880
[ 6.8169 ] Buffer length is 235520
[ 6.8170 ] adding BCH for tegra234-p3701-0000-sdram-l4t_cpp_1.bct
[ 6.8170 ] new length is 243712
[ 6.8170 ]
[ 6.8177 ] tegrahost_v2 --chip 0x23 0 --align mem_coldboot_aligned.bct
[ 6.8185 ] tegrahost_v2 --chip 0x23 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_coldboot_aligned.bct zerosbk
[ 6.8190 ] Header already present for mem_coldboot_aligned.bct
[ 6.8240 ] tegrasign_v3.py --key None --list mem_coldboot_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 6.8242 ] Assuming zero filled SBK key
[ 6.8257 ] Warning: pub_key.key is not found
[ 6.8221 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_coldboot_aligned_sigheader.bct.encrypt mem_coldboot_aligned_sigheader.bct.hash zerosbk
[ 6.8235 ] Generating recovery mem-bct
[ 6.8239 ] tegrabct_v2 --chip 0x23 0 --sdram tegra234-p3701-0000-sdram-l4t_cpp.dtb --wb0sdram tegra234-p3701-0000-wb0sdram-l4t_cpp.dtb --membct tegra234-p3701-0000-sdram-l4t_cpp_1.bct tegra234-p3701-0000-sdram-l4t_cpp_2.bct tegra234-p3701-0000-sdram-l4t_cpp_3.bct tegra234-p3701-0000-sdram-l4t_cpp_4.bct
[ 6.8243 ] packing sdram params with Wb0 file tegra234-p3701-0000-wb0sdram-l4t_cpp.dtb
[ 6.9189 ] Packing sdram param for instance[0]
[ 6.9193 ] Packing sdram param for instance[1]
[ 6.9197 ] Packing sdram param for instance[2]
[ 6.9201 ] Packing sdram param for instance[3]
[ 6.9203 ] Packing sdram param for instance[4]
[ 6.9206 ] Packing sdram param for instance[5]
[ 6.9210 ] Packing sdram param for instance[6]
[ 6.9217 ] Packing sdram param for instance[7]
[ 6.9221 ] Packing sdram param for instance[8]
[ 6.9225 ] Packing sdram param for instance[9]
[ 6.9228 ] Packing sdram param for instance[10]
[ 6.9232 ] Packing sdram param for instance[11]
[ 6.9235 ] Packing sdram param for instance[12]
[ 6.9239 ] Packing sdram param for instance[13]
[ 6.9246 ] Packing sdram param for instance[14]
[ 6.9251 ] Packing sdram param for instance[15]
[ 7.0175 ] Reading ramcode from backup chip_info.bin file
[ 7.0176 ] RAMCODE Read from Device: 0
[ 7.0176 ] Using ramcode 0
[ 7.0176 ] Disabled BPMP dtb trim, using default dtb
[ 7.0176 ]
[ 7.0184 ] tegrahost_v2 --chip 0x23 0 --align mem_rcm_aligned.bct
[ 7.0192 ] tegrahost_v2 --chip 0x23 0 --magicid MEM0 --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_aligned.bct zerosbk
[ 7.0195 ] adding BCH for mem_rcm_aligned.bct
[ 7.0259 ] tegrasign_v3.py --key None --list mem_rcm_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 7.0261 ] Assuming zero filled SBK key
[ 7.0275 ] Warning: pub_key.key is not found
[ 7.0239 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_rcm_aligned_sigheader.bct.encrypt mem_rcm_aligned_sigheader.bct.hash zerosbk
[ 7.0248 ] Copying signatures
[ 7.0252 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 7.0976 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 7.0983 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 7.0983 ] Boot Rom communication
[ 7.0990 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 7.0994 ] BR_CID: 0x80012344705DF0CA2800000016FD8140
[ 8.0119 ] Sending bct_br
[ 8.1073 ] ERROR: might be timeout in USB write.
Failed flashing generic.
Looks like your VM is incomplete (the kernel and environment lack what is needed to flash).
FYI, if you flash on command line you can easily create a log by appending this to the end of the command line:
2>&1 | tee log_flash.txt
(attaching a log to the forum is much easier to read)
If you flash with JetPack/SDK Manager, then there is an export logs button to package it all up (and this too can be attached to the forum thread).
The flash software has no control over the VM, it is beyond the scope to try and figure all of that out. I know it seems like a pain, but I recommend getting a second hard drive and dual booting to this. A VM can be made to work, but there isn’t much of a possibility of debugging this flash on the VM itself. I suspect a native flash would just have all of the issues go away.
