No longer able to flash AGX Orin Devkit
It appears that suddenly I’m no longer able to flash the AGX Orin, neither with L4T 35.2.1 nor with L4T 35.1.0. Last time I flashed it was a couple months ago, but today I’m no longer able to flash it anymore. I’m getting these logs on the Host and on the Device:
L4T 35.2.1
# L4T BSP Information:
# R35 , REVISION: 2.1
# User release: 0.0
./flash.sh: line 1703: /tmp/Linux_for_Tegra/rootfs/etc/user_release_version: No such file or directory
# Target Board Information:
# Name: jetson-agx-orin-devkit, Board Family: t186ref, SoC: Tegra 234,
# OpMode: production, Boot Authentication: NS,
# Disk encryption: disabled ,
copying emc_fuse_dev_params(/tmp/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct-diag-boot.dts)... done.
copying device_config(/tmp/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-device-p3701-0000.dts)... done.
copying misc_config(/tmp/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-misc-p3701-0000.dts)... done.
./tegraflash.py --chip 0x23 --applet "/tmp/Linux_for_Tegra/bootloader/mb1_t234_prod.bin" --skipuid --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3701-0000.dts --misc_config tegra234-mb1-bct-misc-p3701-0000.dts --bins "mb2_applet applet_t234.bin" --cmd "dump eeprom cvm cvm.bin; dump custinfo custinfo_out.bin; reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[   0.0482 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.0497 ] File rcm_state open failed
[   0.0502 ] ERROR: failed to read rcm_state
[   0.0502 ]
[   0.0732 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0735 ] Assuming zero filled SBK key
[   0.0508 ] Pre-processing config: tegra234-mb1-bct-device-p3701-0000.dts
[   0.1348 ] Pre-processing config: tegra234-mb1-bct-misc-p3701-0000.dts
[   0.1519 ] Parsing partition layout
[   0.1556 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.1628 ] Kernel DTB used: None
[   0.1628 ] WARNING: dce base dtb is not provided
[   0.1629 ] Parsing partition layout
[   0.1653 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.1681 ] Creating list of images to be signed
[   0.1707 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[   0.1738 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.1755 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.1759 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.1811 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.1816 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.1863 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.1872 ] adding BCH for mb2_t234_aligned.bin
[   0.1924 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.2033 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.2037 ] adding BCH for mb2_t234_aligned.bin
[   0.2192 ] Filling MB1 storage info
[   0.2192 ] Parsing dev params for multi chains
[   0.2304 ] Generating br-bct
[   0.2320 ] Updating dev and MSS params in BR BCT
[   0.2321 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   0.2340 ] Updating bl info
[   0.2357 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin
[   0.2374 ] WARNING: boot chain is not completed. set to 0
[   0.2386 ] Generating signatures
[   0.2617 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.2620 ] Assuming zero filled SBK key
[   0.2862 ] Warning: pub_key.key is not found
[   0.2637 ] Parsing dev params for multi chains
[   0.2637 ] Generating br-bct
[   0.2652 ] Updating dev and MSS params in BR BCT
[   0.2653 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   0.2674 ] Updating bl info
[   0.2691 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.2706 ] WARNING: boot chain is not completed. set to 0
[   0.2720 ] Get Signed section of bct
[   0.2738 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   0.2766 ] Signing BCT
[   0.2997 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.3000 ] Assuming zero filled SBK key
[   0.3043 ] Sha saved in br_bct_BR.sha
[   0.3049 ] Warning: pub_key.key is not found
[   0.2819 ] Updating BCT with signature
[   0.2842 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   0.2863 ] Offset :4608 Len :3584
[   0.2870 ] Generating SHA2 Hash
[   0.3101 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   0.3107 ] Assuming zero filled SBK key
[   0.3175 ] Sha saved in br_bct_BR.sha
[   0.2953 ] Updating BCT with SHA2 Hash
[   0.2969 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[   0.2986 ] Offset :4608 Len :3584
[   0.2991 ] Offset :68 Len :8124
[   0.3001 ] Generating coldboot mb1-bct
[   0.3020 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   0.3044 ] MB1-BCT version: 0.9
[   0.3046 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[   0.3059 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[   0.3065 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[   0.3068 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[   0.3073 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[   0.3078 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[   0.3085 ]
[   0.3085 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   0.3085 ] Added Platform Config 9 data with size :- 100
[   0.3085 ]
[   0.3086 ] Updating mb1-bct with firmware information
[   0.3104 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.3154 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   0.3218 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   0.3243 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   0.3507 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.3510 ] Assuming zero filled SBK key
[   0.3548 ] Warning: pub_key.key is not found
[   0.3346 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.3376 ] Generating recovery mb1-bct
[   0.3399 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   0.3420 ] MB1-BCT version: 0.9
[   0.3426 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[   0.3440 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[   0.3454 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[   0.3465 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[   0.3467 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[   0.3468 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[   0.3468 ]
[   0.3468 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   0.3468 ] Added Platform Config 9 data with size :- 100
[   0.3468 ]
[   0.3469 ] Updating mb1-bct with firmware information
[   0.3509 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.3572 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[   0.3626 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[   0.3644 ] adding BCH for mb1_bct_MB1_aligned.bct
[   0.3888 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.3891 ] Assuming zero filled SBK key
[   0.3921 ] Warning: pub_key.key is not found
[   0.3713 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.3742 ] Error: Skip generating mem_bct because sdram_config is not defined
[   0.3743 ] Error: Skip generating mem_bct because sdram_config is not defined
[   0.3743 ] Copying signatures
[   0.3759 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.3848 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[   0.3850 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[   0.3850 ] Boot Rom communication
[   0.3865 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[   0.3881 ] BR_CID: 0x80012344705DD5C5880000000A010280
[   0.5160 ] Sending bct_br
[   0.6912 ] Sending mb1
[   0.6923 ] Sending psc_bl1
[   0.7014 ] Sending bct_mb1
[   0.7072 ] Boot Rom communication completed
[   0.7123 ] tegrahost_v2 --chip 0x23 0 --align applet_t234_aligned.bin
[   0.7203 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --appendsigheader applet_t234_aligned.bin zerosbk
[   0.7232 ] adding BCH for applet_t234_aligned.bin
[   0.7677 ] tegrasign_v3.py --key None --list applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.7683 ] Assuming zero filled SBK key
[   0.7769 ] Warning: pub_key.key is not found
[   0.7572 ] tegrahost_v2 --chip 0x23 0 --updatesigheader applet_t234_aligned_sigheader.bin.encrypt applet_t234_aligned_sigheader.bin.hash zerosbk
[   0.7667 ] Sending mb2_applet...
[   0.7699 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download applet applet_t234_sigheader.bin.encrypt
[   0.7730 ] BL: version 0.28.0.0-t234-54845784-ec016368 last_boot_error: 3273821720
[   0.9103 ] ERROR: failed to open USB
Error: Return value 8
Command tegrarcm_v2 --chip 0x23 0 --pollbl --download applet applet_t234_sigheader.bin.encrypt
Reading board information failed.
on the target:
[0093.517] I> MB1 (version: 0.28.0.0-t234-54845784-ec016368)
[0093.523] I> t234-A01-0-Silicon (0x12347) Prod
[0093.527] I> Boot-mode : BPMP Diagnostic
[0093.531] I> Emulation:
[0093.533] I> Entry timestamp: 0x00000000
[0093.537] I> last_boot_error: 0xc3228e18
[0093.541] I> BR-BCT: preprod_dev_sign: 0
[0093.544] I> rst_source: 0xb, rst_level: 0x1
[0093.549] I> Task: Initialize MB2 params (0x5000d78d)
[0093.554] I> MB2-params @ 0x40060000
[0093.557] I> Task: Crypto init (0x5001cb8d)
[0093.561] I> Task: Secure debug controls (0x5000cd21)
[0093.566] I> Task: strap war set (0x5000c70d)
[0093.571] I> strap value(0x4000401) set to 0x4000401
[0093.575] I> Task: Program NV master stream id (0x5000ccd5)
[0093.581] I> Task: Verify boot mode (0xd482021)
[0093.587] I> Task: Alias fuses (0x500109cd)
[0093.591] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0093.598] I> Task: Print SKU type (0x5000fee1)
[0093.603] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x00000000
[0093.608] I> FUSE_OPT_GPC_DISABLE = 0x00000000
[0093.612] I> FUSE_OPT_TPC_DISABLE = 0x00000000
[0093.616] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0093.621] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0093.625] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0093.629] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0093.633] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0093.637] I> FUSE_SKU_INFO_0 = 0xd0
[0093.641] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0093.645] I> FUSE_PACKAGE_INFO_0 = 0x2
[0093.648] I> SKU: Prod
[0093.650] I> Task: Boost clocks (0x5001462d)
[0093.655] I> Initializing PLLC2 for AXI_CBB.
[0093.659] I> AXI_CBB : src = 35, divisor = 0
[0093.663] I> Task: Voltage monitor (0x50014639)
[0093.667] I> VMON: Vmon re-calibration and fine tuning done
[0093.673] I> Task: UPHY init (0x5000dced)
[0093.677] W> UPHY: UPHY lane info table is empty in MB1 BCT.
[0093.682] I> Task: Boot device init (0x50000b39)
[0093.687] I> Boot_device: RCM
[0093.690] I> USB configuration success
[0093.699] I> Task: TSC init (0x5001fa6d)
[0093.703] I> Task: Enable WDT 5th expiry (0x50020699)
[0093.708] I> Task: I2C register (0x50000ad9)
[0093.712] I> Task: Reset FSI (0x50014635)
[0093.716] I> Task: Enable clock-mon (0x5001fa5d)
[0093.731] I> FMON: Fmon re-programming done
[0093.735] I> Task: MB1 fixed firewalls (0x5001f0d9)
[0093.744] I> Task: Load MB2/Applet/FSKP (0x5000d691)
[0093.749] I> Loading MB2 Applet
[0093.752] I> Active chain: 1
[0093.755] I> Slot: 1
[0093.757] E> BLOCK_DEV: Failed to open blockdev.
[0093.762] E> LOADER: Failed to open blockdev 0(0).
[0093.767] E> LOADER: Failed to get storage info for binary 21 from loader.
[0093.774] C> LOADER: Could not read binary 21.
[0093.779] E> Failed to load MB2
[0093.782] C> Task 0x0 failed (err: 0x27228311)
[0093.786] E> Top caller module: MB2_PARAMS, error module: LOADER, reason: 0x11, aux_info: 0x83
[0093.794] C> Boot Info Table status dump :
1
L4T 35.1.0
# R35 , REVISION: 1.0
version 1.0.0
[   0.0298 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.0313 ] File rcm_state open failed
[   0.0318 ] ERROR: failed to read rcm_state
[   0.0318 ]
[   0.0395 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0399 ] Assuming zero filled SBK key
[   0.0325 ] Pre-processing config: tegra234-mb1-bct-device-p3701-0000.dts
[   0.1788 ] Pre-processing config: tegra234-mb1-bct-misc-p3701-0000.dts
[   0.1993 ] Parsing partition layout
[   0.2014 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.2046 ] Parsing partition layout
[   0.2078 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.2108 ] Creating list of images to be signed
[   0.2131 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[   0.2148 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.2165 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.2170 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.2224 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.2821 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.3471 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.3498 ] adding BCH for mb2_t234_aligned.bin
[   0.3645 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.3936 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.4091 ] adding BCH for mb2_t234_aligned.bin
[   0.5282 ] Generating signatures
[   0.5359 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.5365 ] Assuming zero filled SBK key
[   0.7789 ] Warning: pub_key.key is not found
[   0.7729 ] Parsing dev params for multi chains
[   0.8041 ] Generating br-bct
[   0.8091 ] Updating dev and MSS params in BR BCT
[   0.8097 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   0.8156 ] Updating bl info
[   0.8213 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.8265 ] WARNING: boot chain is not completed. set to 0
[   0.8669 ] Get Signed section of bct
[   0.8735 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   0.9005 ] Signing BCT
[   0.9098 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.9123 ] Assuming zero filled SBK key
[   0.9315 ] Sha saved in br_bct_BR.sha
[   0.9336 ] Warning: pub_key.key is not found
[   0.9262 ] Updating BCT with signature
[   0.9324 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   0.9389 ] Offset :4608 Len :3584
[   0.9506 ] Generating SHA2 Hash
[   0.9591 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   0.9603 ] Assuming zero filled SBK key
[   0.9604 ] Assuming zero filled SBK key
[   1.0243 ] Sha saved in br_bct_BR.sha
[   1.0733 ] Updating BCT with SHA2 Hash
[   1.0789 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[   1.0839 ] Offset :4608 Len :3584
[   1.0858 ] Offset :68 Len :8124
[   1.1407 ] Generating coldboot mb1-bct
[   1.1463 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   1.1511 ] MB1-BCT version: 0.9
[   1.1579 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   1.1595 ] Added Platform Config 9 data with size :- 80
[   1.1595 ]
[   1.1599 ] Updating mb1-bct with firmware information
[   1.1655 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[   1.2175 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   1.2354 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   1.2505 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   1.2689 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   1.2694 ] Assuming zero filled SBK key
[   1.2753 ] Warning: pub_key.key is not found
[   1.2704 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   1.2747 ] Generating recovery mb1-bct
[   1.2770 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   1.2815 ] MB1-BCT version: 0.9
[   1.2843 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   1.2851 ] Added Platform Config 9 data with size :- 80
[   1.2851 ]
[   1.2852 ] Updating mb1-bct with firmware information
[   1.2876 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[   1.3105 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[   1.3220 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[   1.3240 ] adding BCH for mb1_bct_MB1_aligned.bct
[   1.3329 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   1.3332 ] Assuming zero filled SBK key
[   1.3371 ] Warning: pub_key.key is not found
[   1.3329 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   1.3355 ] Error: Skip generating mem_bct because sdram_config is not defined
[   1.3356 ] Error: Skip generating mem_bct because sdram_config is not defined
[   1.3356 ] Copying signatures
[   1.3370 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   1.5052 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[   1.5065 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[   1.5065 ] Boot Rom communication
[   1.5120 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[   1.5175 ] BR_CID: 0x80012344705DD5C5880000000A010280
[   1.6522 ] Sending bct_br
[   1.8298 ] Sending mb1
[   1.8307 ] Sending psc_bl1
[   1.8387 ] Sending bct_mb1
[   1.8664 ] Boot Rom communication completed
[   1.8739 ] tegrahost_v2 --chip 0x23 0 --align applet_t234_aligned.bin
[   1.8835 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --appendsigheader applet_t234_aligned.bin zerosbk
[   1.8882 ] adding BCH for applet_t234_aligned.bin
[   1.9338 ] tegrasign_v3.py --key None --list applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   1.9343 ] Assuming zero filled SBK key
[   1.9431 ] Warning: pub_key.key is not found
[   1.9394 ] tegrahost_v2 --chip 0x23 0 --updatesigheader applet_t234_aligned_sigheader.bin.encrypt applet_t234_aligned_sigheader.bin.hash zerosbk
[   1.9437 ] Sending mb2_applet...
[   1.9459 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download applet applet_t234_sigheader.bin.encrypt
[   1.9480 ] BL: version 0.23.0.0-t234-54845784-92215740 last_boot_error: 656573201
[   2.0868 ] ERROR: failed to open USB
Target:
[0487.914] I> MB1 (version: 0.23.0.0-t234-54845784-92215740)
[0487.920] I> t234-A01-0-Silicon (0x12347) Prod
[0487.924] I> Boot-mode : BPMP Diagnostic
[0487.928] I> Emulation:
[0487.930] I> Entry timestamp: 0x00000000
[0487.934] I> last_boot_error: 0x27228311
[0487.937] I> BR-BCT: preprod_dev_sign: 0
[0487.941] I> rst_source: 0xb, rst_level: 0x1
[0487.945] I> Task: Crypto init (0x5001c0d9)
[0487.949] I> Task: Secure debug controls (0x5000cb19)
[0487.954] I> Task: strap war set (0x5000b739)
[0487.959] I> strap value(0x4000401) set to 0x4000401
[0487.963] I> Task: Program NV master stream id (0x5000cad1)
[0487.969] I> Task: Verify boot mode (0xd482021)
[0487.975] I> Task: Alias fuses (0x50010749)
[0487.979] E> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0487.986] I> Task: Print SKU type (0x5000fba9)
[0487.991] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x00000000
[0487.996] I> FUSE_OPT_GPC_DISABLE = 0x00000000
[0488.000] I> FUSE_OPT_TPC_DISABLE = 0x00000000
[0488.004] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0488.009] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0488.013] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0488.017] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0488.021] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0488.025] I> FUSE_SKU_INFO_0 = 0xd0
[0488.029] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0488.033] I> FUSE_PACKAGE_INFO_0 = 0x2
[0488.036] I> SKU: Prod
[0488.038] I> Task: Boost clocks (0x50013db1)
[0488.043] I> Initializing PLLC2 for AXI_CBB.
[0488.047] I> AXI_CBB : src = 35, divisor = 0
[0488.051] I> Task: Voltage monitor (0x50013dbd)
[0488.055] I> VMON: Vmon re-calibration and fine tuning done
[0488.061] I> Task: UPHY init (0x5000da39)
[0488.065] E> UPHY: UPHY lane info table is empty in MB1 BCT.
[0488.070] I> Task: Boot device init (0x50000a3d)
[0488.075] I> Boot_device: RCM
[0488.078] I> USB configuration success
[0488.112] I> Task: TSC init (0x5001ed35)
[0488.116] I> Task: Enable WDT 5th expiry (0x5001f929)
[0488.121] I> Task: Disable WDT globally (0x5001f965)
[0488.126] I> Task: I2C register (0x50000a31)
[0488.130] I> Task: Reset FSI (0x50013db9)
[0488.134] I> Task: Enable clock-mon (0x5001ed25)
[0488.149] I> FMON: Fmon re-programming done
[0488.153] I> Task: MB1 fixed firewalls (0x5001e55d)
[0488.161] I> Task: Load MB2/Applet/FSKP (0x5000d451)
[0488.166] I> Loading MB2 Applet
[0488.169] I> Scratch RSV109: 0x00000013    active chain: 1
[0488.174] I> Slot: 1
[0488.176] E> Blockdev open: exit error
[0488.180] E> LOADER: Failed to open blockdev 0(0).
[0488.185] E> LOADER: Failed to get storage info for binary 21 from loader.
[0488.192] C> LOADER: Could not read binary 21.
[0488.196] E> Failed to load MB2
[0488.199] C> Task 0x0 failed (err: 0x27228311)
[0488.204] E> Top caller module: MB2_PARAMS, error module: LOADER, reason: 0x11, aux_info: 0x83
I’ve changed USB ports and USB cables, same thing. What should I do to be able to flash this device again?
Thank you
Could you also try rel-35.3.1?
Hi @WayneWWW
Same thing with 35.3.1 unfortunately:
# R35 , REVISION: 3.1
# User release: 0.0
./flash.sh: line 1705: /tmp/Linux_for_Tegra/rootfs/etc/user_release_version: No such file or directory
version 1.0.0
[   0.0480 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.0490 ] File rcm_state open failed
[   0.0495 ] ERROR: failed to read rcm_state
[   0.0495 ]
[   0.2142 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.2145 ] Assuming zero filled SBK key
[   0.0501 ] Pre-processing config: tegra234-mb1-bct-device-p3701-0000.dts
[   0.2694 ] Pre-processing config: tegra234-mb1-bct-misc-p3701-0000.dts
[   0.3037 ] Parsing partition layout
[   0.3058 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.3093 ] Kernel DTB used: None
[   0.3094 ] WARNING: dce base dtb is not provided
[   0.3094 ] Parsing partition layout
[   0.3112 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.3129 ] Creating list of images to be signed
[   0.3145 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[   0.3158 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.3173 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.3178 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.3226 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.3589 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.4553 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.4581 ] adding BCH for mb2_t234_aligned.bin
[   0.4727 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.4965 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.5168 ] adding BCH for mb2_t234_aligned.bin
[   0.5664 ] Filling MB1 storage info
[   0.5664 ] Parsing dev params for multi chains
[   0.5756 ] Generating br-bct
[   0.5771 ] Updating dev and MSS params in BR BCT
[   0.5772 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   0.5789 ] Updating bl info
[   0.5805 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin
[   0.5819 ] WARNING: boot chain is not completed. set to 0
[   0.5830 ] Generating signatures
[   0.7478 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.7481 ] Assuming zero filled SBK key
[   0.9492 ] Warning: pub_key.key is not found
[   0.7858 ] Parsing dev params for multi chains
[   0.7860 ] Generating br-bct
[   0.7910 ] Updating dev and MSS params in BR BCT
[   0.7916 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   0.8097 ] Updating bl info
[   0.8152 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.8202 ] WARNING: boot chain is not completed. set to 0
[   0.9094 ] Get Signed section of bct
[   0.9156 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   0.9421 ] Signing BCT
[   1.1071 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   1.1082 ] Assuming zero filled SBK key
[   1.1234 ] Sha saved in br_bct_BR.sha
[   1.1253 ] Warning: pub_key.key is not found
[   0.9609 ] Updating BCT with signature
[   0.9665 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   0.9724 ] Offset :4608 Len :3584
[   1.0072 ] Generating SHA2 Hash
[   1.1720 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   1.1729 ] Assuming zero filled SBK key
[   1.1730 ] Assuming zero filled SBK key
[   1.5001 ] Sha saved in br_bct_BR.sha
[   1.3696 ] Updating BCT with SHA2 Hash
[   1.3768 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[   1.3831 ] Offset :4608 Len :3584
[   1.4049 ] Offset :68 Len :8124
[   1.4359 ] Generating coldboot mb1-bct
[   1.4384 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   1.4403 ] MB1-BCT version: 0.10
[   1.4407 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[   1.4415 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[   1.4424 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[   1.4429 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[   1.4433 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[   1.4434 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[   1.4434 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[   1.4434 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[   1.4434 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[   1.4434 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[   1.4434 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[   1.4434 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[   1.4434 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[   1.4435 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[   1.4435 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[   1.4435 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[   1.4435 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[   1.4435 ]
[   1.4435 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   1.4435 ] Added Platform Config 9 data with size :- 100
[   1.4435 ]
[   1.4436 ] Updating mb1-bct with firmware information
[   1.4455 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[   1.4706 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   1.4734 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   1.4747 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   1.6404 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   1.6407 ] Assuming zero filled SBK key
[   1.6433 ] Warning: pub_key.key is not found
[   1.4804 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   1.4825 ] Generating recovery mb1-bct
[   1.4838 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   1.4848 ] MB1-BCT version: 0.10
[   1.4850 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[   1.4856 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[   1.4861 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[   1.4865 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[   1.4870 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[   1.4870 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[   1.4870 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[   1.4870 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[   1.4871 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[   1.4871 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[   1.4871 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[   1.4871 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[   1.4871 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[   1.4871 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[   1.4871 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[   1.4871 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[   1.4871 ]
[   1.4871 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   1.4871 ] Added Platform Config 9 data with size :- 100
[   1.4871 ]
[   1.4872 ] Updating mb1-bct with firmware information
[   1.4885 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[   1.5749 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[   1.5855 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[   1.5896 ] adding BCH for mb1_bct_MB1_aligned.bct
[   1.7569 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   1.7574 ] Assuming zero filled SBK key
[   1.7618 ] Warning: pub_key.key is not found
[   1.5994 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   1.6023 ] Error: Skip generating mem_bct because sdram_config is not defined
[   1.6023 ] Copying signatures
[   1.6041 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   1.7994 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[   1.8005 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[   1.8005 ] Boot Rom communication
[   1.8065 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[   1.8116 ] BR_CID: 0x80012344705DD5C5880000000A010280
[   2.0209 ] Sending bct_br
[   2.1646 ] Sending mb1
[   2.1663 ] Sending psc_bl1
[   2.1752 ] Sending bct_mb1
[   2.2347 ] Boot Rom communication completed
[   2.2423 ] tegrahost_v2 --chip 0x23 0 --align applet_t234_aligned.bin
[   2.2546 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --appendsigheader applet_t234_aligned.bin zerosbk
[   2.2595 ] adding BCH for applet_t234_aligned.bin
[   2.4424 ] tegrasign_v3.py --key None --list applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   2.4429 ] Assuming zero filled SBK key
[   2.4473 ] Warning: pub_key.key is not found
[   2.2845 ] tegrahost_v2 --chip 0x23 0 --updatesigheader applet_t234_aligned_sigheader.bin.encrypt applet_t234_aligned_sigheader.bin.hash zerosbk
[   2.2874 ] Sending mb2_applet...
[   2.2888 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download applet applet_t234_sigheader.bin.encrypt
[   2.2900 ] BL: version 0.32.0.0-t234-54845784-57325615 last_boot_error: 656573201
[   2.4221 ] ERROR: failed to open USB
and on the device side I get this when flash.sh runs:
[1069.747] I> MB1 (version: 0.32.0.0-t234-54845784-57325615)
[1069.753] I> t234-A01-0-Silicon (0x12347) Prod
[1069.757] I> Boot-mode : BPMP Diagnostic
[1069.761] I> Emulation:
[1069.763] I> Entry timestamp: 0x00000000
[1069.767] I> last_boot_error: 0x27228311
[1069.771] I> BR-BCT: preprod_dev_sign: 0
[1069.774] I> rst_source: 0xb, rst_level: 0x1
[1069.778] I> Task: Initialize MB2 params (0x5000cb51)
[1069.784] I> MB2-params @ 0x40060000
[1069.787] I> Task: Crypto init (0x5001d981)
[1069.791] I> Task: Secure debug controls (0x5000c0a9)
[1069.796] I> Task: strap war set (0x5000ba2d)
[1069.801] I> Task: Program NV master stream id (0x5000c05d)
[1069.806] I> Task: Verify boot mode (0xd4820f1)
[1069.812] I> Task: Alias fuses (0x5001095d)
[1069.816] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[1069.824] I> Task: Print SKU type (0x5000f5f1)
[1069.828] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x00000000
[1069.833] I> FUSE_OPT_GPC_DISABLE = 0x00000000
[1069.837] I> FUSE_OPT_TPC_DISABLE = 0x00000000
[1069.842] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[1069.846] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[1069.850] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[1069.855] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[1069.859] I> FUSE_OPT_FSI_DISABLE = 0x00000000
[1069.863] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[1069.868] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[1069.872] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[1069.876] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[1069.880] I> FUSE_SKU_INFO_0 = 0xd0
[1069.883] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[1069.887] I> FUSE_PACKAGE_INFO_0 = 0x2
[1069.891] I> SKU: Prod
[1069.893] I> Task: Boost clocks (0x500148a1)
[1069.897] I> Initializing PLLC2 for AXI_CBB.
[1069.902] I> AXI_CBB : src = 35, divisor = 0
[1069.906] I> Task: Voltage monitor (0x50014b49)
[1069.910] I> VMON: Vmon re-calibration and fine tuning done
[1069.916] I> Task: UPHY init (0x5000d065)
[1069.920] W> UPHY: UPHY lane info table is empty in MB1 BCT.
[1069.926] I> Task: Boot device init (0x50000be9)
[1069.930] I> Boot_device: RCM
[1069.933] I> USB configuration success
[1069.944] I> Task: TSC init (0x50020a4d)
[1069.948] I> Task: Enable WDT 5th expiry (0x50021a41)
[1069.953] I> Task: I2C register (0x50000b85)
[1069.957] I> Task: Reset FSI (0x500148b1)
[1069.961] I> Task: Enable clock-mon (0x50020a35)
[1069.977] I> FMON: Fmon re-programming done
[1069.981] I> Task: MB1 fixed firewalls (0x5002006d)
[1069.987] W> Firewall readback mismatch
[1069.990] W> Firewall readback mismatch
[1069.995] W> Firewall readback mismatch
[1070.000] I> Task: Load MB2/Applet/FSKP (0x5000ca55)
[1070.005] I> Loading MB2 Applet
[1070.008] I> Slot: 1
[1070.011] E> BLOCK_DEV: Failed to open blockdev.
[1070.016] E> LOADER: Failed to open blockdev 0(0).
[1070.022] E> LOADER: Failed to get storage info for binary 21 from loader.
[1070.029] C> LOADER: Could not read binary 21.
[1070.033] E> Failed to load MB2
[1070.036] C> Task 0x0 failed (err: 0x27228311)
[1070.040] E> Top caller module: MB2_PARAMS, error module: LOADER, reason: 0x11, aux_info: 0x83
[1070.049] C> Boot Info Table status dump :
If I boot the device normally, i.e press the reset button I’m getting:
[0000.063] I> MB1 (version: 0.28.0.0-t234-54845784-ec016368)
[0000.068] I> t234-A01-0-Silicon (0x12347) Prod
[0000.072] I> Boot-mode : Coldboot
[0000.075] I> Emulation:
[0000.078] I> Entry timestamp: 0x00000000
[0000.082] I> last_boot_error: 0xc3228e18
[0000.085] I> BR-BCT: preprod_dev_sign: 0
[0000.089] I> rst_source: 0xb, rst_level: 0x1
[0000.093] I> Task: Bootchain select WAR set (0x5000c741)
[0000.098] I> Active chain: 1
[0000.101] I> Task: CRC check (0x5001dab5)
[0000.105] I> Skip CRC check as records_integrity fuse is not burned
[0000.111] I> Task: Initialize MB2 params (0x5000d78d)
[0000.116] I> MB2-params @ 0x40060000
[0000.120] I> Task: Crypto init (0x5001cb8d)
[0000.124] I> Task: Secure debug controls (0x5000cd21)
[0000.129] I> Task: strap war set (0x5000c70d)
[0000.133] I> strap value(0x4000401) set to 0x4000401
[0000.138] I> Task: Initialize SOC Therm (0x5001af85)
[0000.143] I> Task: Program NV master stream id (0x5000ccd5)
[0000.148] I> Task: Verify boot mode (0xd482021)
[0000.154] I> Task: Alias fuses (0x500109cd)
[0000.159] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.166] I> Task: Print SKU type (0x5000fee1)
[0000.170] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x00000000
[0000.175] I> FUSE_OPT_GPC_DISABLE = 0x00000000
[0000.180] I> FUSE_OPT_TPC_DISABLE = 0x00000000
[0000.184] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0000.188] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0000.192] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.197] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.201] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.205] I> FUSE_SKU_INFO_0 = 0xd0
[0000.208] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.212] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.216] I> SKU: Prod
[0000.218] I> Task: Boost clocks (0x5001462d)
[0000.222] I> Initializing PLLC2 for AXI_CBB.
[0000.226] I> AXI_CBB : src = 35, divisor = 0
[0000.230] I> Task: Voltage monitor (0x50014639)
[0000.235] I> VMON: Vmon re-calibration and fine tuning done
[0000.240] I> Task: UPHY init (0x5000dced)
[0000.245] W> UPHY: UPHY lane info table is empty in MB1 BCT.
[0000.250] I> Task: Boot device init (0x50000b39)
[0000.255] I> Boot_device: QSPI_FLASH instance: 0
[0000.259] I> Qspi clock source : pllc_out0
[0000.263] I> QSPI Flash: Macronix 64MB
[0000.267] I> QSPI-0l initialized successfully
[0000.271] I> Task: TSC init (0x5001fa6d)
[0000.275] I> Task: Load membct (0x50011fb9)
[0000.279] I> RAM_CODE 0x4000401
[0000.282] I> Loading MEMBCT
[0000.285] I> Active chain: 1
[0000.288] I> Slot: 1
[0000.290] I> Binary[0] block-0 (partition size: 0x40000)
[0000.295] I>  get_binary_info: Binary name: MEM-BCT-0
[0000.300] I> Size of crypto header is 8192
[0000.304] I> BCH load address is : 0x40050000
[0000.308] I> Size of crypto header is 8192
[0000.312] I> BCH of MEM-BCT-0 read from storage
[0000.316] I> BCH address is : 0x40050000
[0000.320] I> MEM-BCT-0 header integrity check is success
[0000.325] I> Binary magic in BCH component 0 is MEM0
[0000.330] I> component binary type is 0
[0000.334] I> MEM-BCT-0 binary is read from storage
[0000.339] I> MEM-BCT-0 binary integrity check is success
[0000.344] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0000.351] I> RAM_CODE 0x4000401
[0000.356] I> RAM_CODE 0x4000401
[0000.360] I> Task: Load Page retirement list (0x50011601)
[0000.365] I> Task: SDRAM params override (0x50011f95)
[0000.370] I> Task: Save mem-bct info (0x500147fd)
[0000.375] I> Task: Carveout allocate (0x50014861)
[0000.379] I> RCM blob carveout will not be allocated
[0000.384] I> ECC region[0]: Start:0x0, End:0x0
[0000.389] I> ECC region[1]: Start:0x0, End:0x0
[0000.393] I> ECC region[2]: Start:0x0, End:0x0
[0000.397] I> ECC region[3]: Start:0x0, End:0x0
[0000.401] I> ECC region[4]: Start:0x0, End:0x0
[0000.406] I> Non-ECC region[0]: Start:0x80000000, End:0x880000000
[0000.412] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.416] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.421] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.425] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.435] I> allocated(CO:44) base:0x849800000 size:0x36800000 align: 0x100000
[0000.442] I> allocated(CO:31) base:0x840000000 size:0x8000000 align: 0x8000000
[0000.449] I> allocated(CO:43) base:0x83c000000 size:0x4000000 align: 0x200000
[0000.456] I> allocated(CO:20) base:0x83a000000 size:0x2000000 align: 0x2000000
[0000.463] I> allocated(CO:24) base:0x838000000 size:0x2000000 align: 0x2000000
[0000.471] I> allocated(CO:28) base:0x836000000 size:0x2000000 align: 0x2000000
[0000.478] I> allocated(CO:29) base:0x834000000 size:0x2000000 align: 0x2000000
[0000.485] I> allocated(CO:22) base:0x848000000 size:0x1000000 align: 0x1000000
[0000.492] I> allocated(CO:41) base:0x833000000 size:0x1000000 align: 0x100000
[0000.499] I> allocated(CO:35) base:0x832200000 size:0xe00000 align: 0x10000
[0000.506] I> allocated(CO:02) base:0x849000000 size:0x800000 align: 0x800000
[0000.513] I> allocated(CO:03) base:0x831800000 size:0x800000 align: 0x800000
[0000.520] I> allocated(CO:06) base:0x831000000 size:0x800000 align: 0x800000
[0000.526] I> allocated(CO:10) base:0x830800000 size:0x800000 align: 0x800000
[0000.533] I> allocated(CO:56) base:0x830000000 size:0x800000 align: 0x200000
[0000.540] I> allocated(CO:07) base:0x82fc00000 size:0x400000 align: 0x400000
[0000.547] I> allocated(CO:33) base:0x82f800000 size:0x400000 align: 0x200000
[0000.554] I> allocated(CO:01) base:0x832100000 size:0x100000 align: 0x100000
[0000.561] I> allocated(CO:04) base:0x832000000 size:0x100000 align: 0x100000
[0000.568] I> allocated(CO:05) base:0x82f700000 size:0x100000 align: 0x100000
[0000.575] I> allocated(CO:08) base:0x82f600000 size:0x100000 align: 0x100000
[0000.582] I> allocated(CO:09) base:0x82f500000 size:0x100000 align: 0x100000
[0000.589] I> allocated(CO:15) base:0x82f400000 size:0x100000 align: 0x100000
[0000.596] I> allocated(CO:17) base:0x82f300000 size:0x100000 align: 0x100000
[0000.603] I> allocated(CO:23) base:0x82f200000 size:0x100000 align: 0x100000
[0000.610] I> allocated(CO:27) base:0x82f100000 size:0x100000 align: 0x100000
[0000.616] I> allocated(CO:42) base:0x82f000000 size:0x100000 align: 0x100000
[0000.623] I> allocated(CO:54) base:0x82ef80000 size:0x80000 align: 0x80000
[0000.630] I> allocated(CO:34) base:0x82ef70000 size:0x10000 align: 0x10000
[0000.637] I> allocated(CO:47) base:0x82ea00000 size:0x400000 align: 0x200000
[0000.644] I> allocated(CO:72) base:0x82e800000 size:0x200000 align: 0x10000
[0000.651] I> allocated(CO:48) base:0x82ef50000 size:0x20000 align: 0x10000
[0000.657] I> allocated(CO:69) base:0x82ef30000 size:0x20000 align: 0x10000
[0000.664] I> allocated(CO:49) base:0x82ef20000 size:0x10000 align: 0x10000
[0000.671] I> allocated(CO:50) base:0x82ef10000 size:0x10000 align: 0x10000
[0000.678] I> allocated(CO:52) base:0x82ef00000 size:0x10000 align: 0x10000
[0000.684] I> NSDRAM base: 0x80000000, end: 0x82ef70000
[0000.689] I> Task: Thermal check (0x500208f9)
[0000.694] I> max_chip_limit = 105
[0000.697] I> min_chip_limit = -28
[0000.700] I> max temp read = 35
[0000.703] I> min temp read = 35
[0000.706] I> Task: Update FSI SCR with thermal fuse data (0x50020a05)
[0000.712] I> Task: Enable WDT 5th expiry (0x50020699)
[0000.717] I> Task: I2C register (0x50000ad9)
[0000.721] I> Task: Reset FSI (0x50014635)
[0000.725] I> Task: Pinmux init (0x500137bd)
[0000.730] I> Task: Prod config init (0x50013c09)
[0000.734] I> Task: Pad voltage init (0x50013859)
[0000.738] I> Task: Prod init (0x50013c4d)
[0000.742] I> Task: Common rail init (0x50014305)
[0000.747] W> PMIC_CONFIG: Rail: Thermal config not found in MB1 BCT.
[0000.753] I> DONE: Thermal config
[0000.757] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0000.765] I> DONE: SOC rail config
[0000.769] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0000.775] I> DONE: MEMIO rail config
[0000.779] I> DONE: GPU rail info
[0000.782] I> DONE: CV rail info
[0000.785] I> Task: Mem clock src (0x50011de5)
[0000.789] I> Task: Misc. board config (0x500143ad)
[0000.794] W> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0000.800] I> Task: SDRAM init (0x50011de9)
[0000.807] I> SDRAM-params @ 0xd485000
[0000.810] I> MSS code-drop: NvBootSdramInit
[0000.814] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 9
[0000.822] I> Encryption:   MTS: en, TX: en, VPR: en, GSC: en
[0000.833] I> mb1_sdram_init Done !
[0000.836] I> SDRAM Size in Total 0x800000000
[0000.840] I> Task: Dram Ecc scrub (0x50011729)
[0000.845] I> Task: DRAM alias check (0x50011f8d)
[0000.892] I> Task: Program NSDRAM carveout (0x50015171)
[0000.899] I> NSDRAM carveout encryption is enabled
[0000.904] I> Program NSDRAM carveout
[0000.909] I> Task: Register checker (0x50011f91)
[0000.921] I> Task: Enable clock-mon (0x5001fa5d)
[0000.939] I> FMON: Fmon re-programming done
[0000.943] I> Task: Mapper init (0x5001dfed)
[0000.950] I> Task: SC7 Context Init (0x5001fd5d)
[0000.957] I> Task: CCPLEX IST init (0x5000d561)
[0000.964] I> Task: CPU WP0 (0x5000c7a9)
[0000.971] I> Loading MCE
[0000.974] I> Active chain: 1
[0000.977] I> Slot: 1
[0000.980] I> Binary[8] block-0 (partition size: 0x80000)
[0000.986] I>  get_binary_info: Binary name: MCE
[0000.991] I> Size of crypto header is 8192
[0000.996] I> BCH load address is : 0x4003e000
[0001.003] I> Size of crypto header is 8192
[0001.008] I> BCH of MCE read from storage
[0001.013] I> BCH address is : 0x4003e000
[0001.019] I> MCE header integrity check is success
[0001.025] I> Binary magic in BCH component 0 is MTSM
[0001.031] I> component binary type is 8
[0001.035] I> Size of crypto header is 8192
[0001.042] I> MCE binary is read from storage
[0001.048] I> MCE binary integrity check is success
[0001.054] I> Binary MCE loaded successfully at 0x40000000 (0x2c880)
[0001.063] I> Size of crypto header is 8192
[0001.086] I> Size of crypto header is 8192
[0001.092] I> Sending WP0 mailbox command to PSC
[0001.104] I> Task: XUSB Powergate (0x50000ae5)
[0001.110] I> Skipping powergate XUSB.
[0001.114] I> Task: MB1 fixed firewalls (0x5001f0d9)
[0001.146] I> Task: Load bpmp-fw (0x5001f41d)
[0001.153] I> Active chain: 1
[0001.156] I> Slot: 1
[0001.159] I> Binary[15] block-0 (partition size: 0x180000)
[0001.166] I>  get_binary_info: Binary name: BPMP_FW
[0001.171] I> Size of crypto header is 8192
[0001.176] I> BCH load address is : 0x807fe000
[0001.182] I> Size of crypto header is 8192
[0001.188] I> BCH of BPMP_FW read from storage
[0001.193] I> BCH address is : 0x807fe000
[0001.200] I> BPMP_FW header integrity check is success
[0001.206] I> Binary magic in BCH component 0 is BPMF
[0001.211] I> component binary type is 15
[0001.216] I> Size of crypto header is 8192
[0001.232] I> BPMP_FW binary is read from storage
[0001.240] I> BPMP_FW binary integrity check is success
[0001.246] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xfdc40)
[0001.255] I> Active chain: 1
[0001.259] I> Slot: 1
[0001.261] I> Binary[16] block-72976 (partition size: 0x400000)
[0001.269] I>  get_binary_info: Binary name: BPMP_FW_DTB
[0001.275] I> Size of crypto header is 8192
[0001.280] I> BCH load address is : 0x807fc000
[0001.287] I> Size of crypto header is 8192
[0001.292] I> BCH of BPMP_FW_DTB read from storage
[0001.298] I> BCH address is : 0x807fc000
[0001.304] I> BPMP_FW_DTB header integrity check is success
[0001.311] I> Binary magic in BCH component 0 is BPMD
[0001.316] I> component binary type is 16
[0001.321] I> Size of crypto header is 8192
[0001.328] I> BPMP_FW_DTB binary is read from storage
[0001.334] I> BPMP_FW_DTB binary integrity check is success
[0001.341] I> Binary BPMP_FW_DTB loaded successfully at 0x807db9f0 (0x20480)
[0001.351] I> Task: Load psc-fw (0x5001f5a5)
[0001.358] I> Active chain: 1
[0001.361] I> Slot: 1
[0001.364] I> Binary[17] block-0 (partition size: 0xc0000)
[0001.371] I>  get_binary_info: Binary name: PSC_FW
[0001.376] I> Size of crypto header is 8192
[0001.381] I> BCH load address is : 0x80ffe000
[0001.388] I> Size of crypto header is 8192
[0001.393] I> BCH of PSC_FW read from storage
[0001.398] I> BCH address is : 0x80ffe000
[0001.406] C> LOADER: Could not read binary 17.
[0001.411] C> Task 0x0 failed (err: 0xc3228e18)
[0001.418] E> Top caller module: PSC_FW, error module: LOADER, reason: 0x18, aux_info: 0x8e
[0001.427] C> Boot Info Table status dump :
1
please RMA this module then.
