I’m using sdkmanager-1.9.2.10888 to flash my Jetson-AGX-Orin-32G carrier board,but flash fail. The error is “ERROR: might be timeout in USB write.”.
- My host PC is “Ubuntu 20.04.6 LTS”
- lsusb | grep NVIDIA
Bus 003 Device 006: ID 0955:7223 NVIDIA Corp. APX - Here is the sdkmanager flash error message.
17:24:31 ERROR: Flash Jetson Linux - flash: [ 0.2356 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
17:24:31 ERROR: Flash Jetson Linux - flash: [ 0.2363 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
17:24:31 ERROR: Flash Jetson Linux - flash: [ 0.2366 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
17:24:31 ERROR: Flash Jetson Linux - flash: [ 0.2370 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
17:24:31 ERROR: Flash Jetson Linux - flash: [ 0.2373 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
17:24:31 ERROR: Flash Jetson Linux - flash: [ 0.2377 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
17:24:31 ERROR: Flash Jetson Linux - flash: [ 0.2380 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
17:24:31 ERROR: Flash Jetson Linux - flash: [ 0.2380 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
17:24:31 ERROR: Flash Jetson Linux - flash: [ 0.2380 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
17:24:31 ERROR: Flash Jetson Linux - flash: [ 0.2380 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
17:24:31 ERROR: Flash Jetson Linux - flash: [ 0.2380 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
17:24:31 ERROR: Flash Jetson Linux - flash: [ 0.2380 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
17:24:31 ERROR: Flash Jetson Linux - flash: [ 0.2380 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
17:24:31 ERROR: Flash Jetson Linux - flash: [ 0.2380 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
17:24:31 ERROR: Flash Jetson Linux - flash: [ 0.2380 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
17:24:31 ERROR: Flash Jetson Linux - flash: [ 0.2380 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
17:24:31 ERROR: Flash Jetson Linux - flash: [ 0.2380 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
17:24:31 INFO: Flash Jetson Linux - flash: [ 0.2380 ]
17:24:31 INFO: Flash Jetson Linux - flash: [ 0.2380 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
17:24:31 INFO: Flash Jetson Linux - flash: [ 0.2380 ] Added Platform Config 9 data with size :- 100
17:24:31 INFO: Flash Jetson Linux - flash: [ 0.2381 ] Updating mb1-bct with firmware information
17:24:31 INFO: Flash Jetson Linux - flash: [ 0.2395 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
17:24:31 INFO: Flash Jetson Linux - flash: [ 0.2423 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
17:24:31 INFO: Flash Jetson Linux - flash: [ 0.2446 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
17:24:31 INFO: Flash Jetson Linux - flash: [ 0.2459 ] adding BCH for mb1_bct_MB1_aligned.bct
17:24:31 INFO: Flash Jetson Linux - flash: [ 0.2565 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
17:24:31 INFO: Flash Jetson Linux - flash: [ 0.2567 ] Assuming zero filled SBK key
17:24:31 INFO: Flash Jetson Linux - flash: [ 0.2589 ] Warning: pub_key.key is not found
17:24:31 INFO: Flash Jetson Linux - flash: [ 0.2512 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
17:24:31 ERROR: Flash Jetson Linux - flash: [ 0.2535 ] Error: Skip generating mem_bct because sdram_config is not defined
17:24:31 INFO: Flash Jetson Linux - flash: [ 0.2535 ] Copying signatures
17:24:31 INFO: Flash Jetson Linux - flash: [ 0.2548 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
17:24:31 INFO: Flash Jetson Linux - flash: [ 0.2615 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
17:24:31 INFO: Flash Jetson Linux - flash: [ 0.2617 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
17:24:31 INFO: Flash Jetson Linux - flash: [ 0.2617 ] Boot Rom communication
17:24:31 INFO: Flash Jetson Linux - flash: [ 0.2636 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
17:24:31 INFO: Flash Jetson Linux - flash: [ 0.2678 ] BR_CID: 0x80012344705DD5D1740000000CFD81C0
17:24:32 INFO: Flash Jetson Linux - flash: [ 0.5082 ] Sending bct_br
17:24:37 ERROR: Flash Jetson Linux - flash: [ 0.8275 ] ERROR: might be timeout in USB write.
17:24:37 ERROR: Flash Jetson Linux - flash: Error: Return value 3
17:24:37 INFO: Flash Jetson Linux - flash: Command tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
17:24:37 ERROR: Flash Jetson Linux - flash: --- Error: Reading board information failed.
17:24:37 INFO: Flash Jetson Linux - flash: [ Component Install Finished with Error ]
17:24:37 INFO: Flash Jetson Linux - flash: [host] [ 6.73 MB released. Disk Avail: 386.27 GB ]
17:24:37 INFO: Flash Jetson Linux - flash: [ NV_L4T_FLASH_JETSON_LINUX_COMP Install took 6s ]
17:24:37 ERROR: Flash Jetson Linux - flash: command terminated with error
17:24:37 SUMMARY: Flash Jetson Linux - flash: First Error: Installation failed.
- And then I run ./flash.sh in terminal, the error message is below:
# L4T BSP Information:
# R35 , REVISION: 3.1
# User release: 0.0
# Target Board Information:
# Name: jetson-agx-orin-devkit, Board Family: t186ref, SoC: Tegra 234,
# OpMode: production, Boot Authentication: NS,
# Disk encryption: disabled ,
copying emc_fuse_dev_params(/home/oem/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct-diag-boot.dts)... done.
copying device_config(/home/oem/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-device-p3701-0000.dts)... done.
copying misc_config(/home/oem/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-misc-p3701-0000.dts)... done.
./tegraflash.py --chip 0x23 --applet "/home/oem/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/mb1_t234_prod.bin" --skipuid --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3701-0000.dts --misc_config tegra234-mb1-bct-misc-p3701-0000.dts --bins "mb2_applet applet_t234.bin" --cmd "dump eeprom cvm cvm.bin; dump custinfo custinfo_out.bin; reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0229 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.0241 ] File rcm_state open failed
[ 0.0245 ] ERROR: failed to read rcm_state
[ 0.0245 ]
[ 0.0266 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0269 ] Assuming zero filled SBK key
[ 0.0250 ] Pre-processing config: tegra234-mb1-bct-device-p3701-0000.dts
[ 0.0358 ] Pre-processing config: tegra234-mb1-bct-misc-p3701-0000.dts
[ 0.0466 ] Parsing partition layout
[ 0.0479 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0504 ] Kernel DTB used: None
[ 0.0505 ] WARNING: dce base dtb is not provided
[ 0.0505 ] Parsing partition layout
[ 0.0518 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0531 ] Creating list of images to be signed
[ 0.0541 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[ 0.0551 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0564 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0567 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0630 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0635 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.0698 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.0702 ] adding BCH for mb2_t234_aligned.bin
[ 0.0731 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.0885 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.0891 ] adding BCH for mb2_t234_aligned.bin
[ 0.1071 ] Filling MB1 storage info
[ 0.1072 ] Parsing dev params for multi chains
[ 0.1200 ] Generating br-bct
[ 0.1216 ] Updating dev and MSS params in BR BCT
[ 0.1217 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.1235 ] Updating bl info
[ 0.1252 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin
[ 0.1267 ] WARNING: boot chain is not completed. set to 0
[ 0.1279 ] Generating signatures
[ 0.1300 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1302 ] Assuming zero filled SBK key
[ 0.1436 ] Warning: pub_key.key is not found
[ 0.1419 ] Parsing dev params for multi chains
[ 0.1419 ] Generating br-bct
[ 0.1430 ] Updating dev and MSS params in BR BCT
[ 0.1430 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.1448 ] Updating bl info
[ 0.1460 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.1474 ] WARNING: boot chain is not completed. set to 0
[ 0.1492 ] Get Signed section of bct
[ 0.1506 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[ 0.1535 ] Signing BCT
[ 0.1556 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1560 ] Assuming zero filled SBK key
[ 0.1613 ] Sha saved in br_bct_BR.sha
[ 0.1619 ] Warning: pub_key.key is not found
[ 0.1599 ] Updating BCT with signature
[ 0.1610 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[ 0.1620 ] Offset :4608 Len :3584
[ 0.1625 ] Generating SHA2 Hash
[ 0.1646 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[ 0.1648 ] Assuming zero filled SBK key
[ 0.1649 ] Assuming zero filled SBK key
[ 0.1682 ] Sha saved in br_bct_BR.sha
[ 0.1666 ] Updating BCT with SHA2 Hash
[ 0.1678 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[ 0.1689 ] Offset :4608 Len :3584
[ 0.1693 ] Offset :68 Len :8124
[ 0.1695 ] Generating coldboot mb1-bct
[ 0.1706 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.1718 ] MB1-BCT version: 0.10
[ 0.1721 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.1730 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.1733 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.1736 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.1740 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.1743 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.1747 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[ 0.1749 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[ 0.1753 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[ 0.1756 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[ 0.1758 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[ 0.1758 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[ 0.1758 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[ 0.1758 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[ 0.1758 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[ 0.1758 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[ 0.1758 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[ 0.1758 ]
[ 0.1758 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.1759 ] Added Platform Config 9 data with size :- 100
[ 0.1759 ]
[ 0.1759 ] Updating mb1-bct with firmware information
[ 0.1769 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.1805 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 0.1850 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 0.1862 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 0.1896 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1899 ] Assuming zero filled SBK key
[ 0.1931 ] Warning: pub_key.key is not found
[ 0.1927 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.1947 ] Generating recovery mb1-bct
[ 0.1959 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.1973 ] MB1-BCT version: 0.10
[ 0.1976 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.1985 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.1990 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.1994 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.1999 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.2004 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.2009 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[ 0.2012 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[ 0.2014 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[ 0.2014 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[ 0.2014 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[ 0.2014 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[ 0.2014 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[ 0.2015 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[ 0.2015 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[ 0.2015 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[ 0.2015 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[ 0.2015 ]
[ 0.2015 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.2015 ] Added Platform Config 9 data with size :- 100
[ 0.2015 ]
[ 0.2015 ] Updating mb1-bct with firmware information
[ 0.2028 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.2059 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[ 0.2087 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[ 0.2098 ] adding BCH for mb1_bct_MB1_aligned.bct
[ 0.2132 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.2135 ] Assuming zero filled SBK key
[ 0.2159 ] Warning: pub_key.key is not found
[ 0.2151 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.2169 ] Error: Skip generating mem_bct because sdram_config is not defined
[ 0.2170 ] Error: Skip generating mem_bct because sdram_config is not defined
[ 0.2170 ] Copying signatures
[ 0.2184 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.2256 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.2258 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.2259 ] Boot Rom communication
[ 0.2270 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 0.2282 ] BR_CID: 0x80012344705DD5D1740000000CFD81C0
[ 0.5555 ] Sending bct_br
[ 0.9308 ] ERROR: might be timeout in USB write.
Anyone can help me?
