My Orin died when trying to update to the latest jetpack from the command line via ‘apt dist-upgrade’. After reboot I can get press escape to enter a setup screen but I cannot boot. I have been attempting to flash the system but numerous failures have halted progress and I’m looking for ideas.
Things to note:
- Orin is 64GB dev kit.
- Yes, I can see the device on the USB as Bus 001 Device 014: ID 0955:7023 NVidia Corp.
- First failure is:
ERROR: Flash Jetson Linux - flash: [ 0.0986 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
- I have tried numerous host systems, Ubuntu 22.04, Ubuntu 18.04 VM on 22.04, and just Ubuntu 18.04. In all cases the failure is the same.
- I am connected to the USB port and SDK manager definitely “see’s” my Orin is in recover mode.
- I am connected to the USB/TTY port for debug and during normal boot I can see serial scrolling text. The last lines during normal boot-up attempts are:
** WARNING: Test Key is used. **
L4TLauncher: Attempting Direct Boot
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services and installing virtual address map...
Also, during recover-mode and flashing this ttyACM0 appears to be silent.
As I can get into the setup and choose the boot manager is there a way to flash onto an SD-CARD or NVME via the host and boot from that device? Using Etcher or similar tool?
Dump from SDK Manager here:
08:12:34 DEBUG: running command < /tmp/device_mode_host_setup.sh >
08:12:34 INFO: exec_command: /tmp/device_mode_host_setup.sh
08:12:34 INFO: Found route default wlp111s0, setting up device mode
08:12:34 INFO: [host] [sudo] password for apt:
08:12:34 INFO: net.ipv4.ip_forward = 1
08:12:34 INFO: Device mode on host successfully set with DNS 8.8.8.8!
08:12:34 INFO: command finished successfully
08:12:34 DEBUG: running command < true >
08:12:34 DEBUG: Flash Jetson Linux - flash: using adapter to install NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_AGX_ORIN_TARGETS to /home/apt/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_AGX_ORIN_TARGETS
08:12:34 INFO: Flash Jetson Linux - flash: current working directory is /home/apt/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra
08:12:34 INFO: Flash Jetson Linux - flash: sudo ./nvsdkmanager_flash.sh
08:12:34 INFO: Flash Jetson Linux - flash: Defaulting to autoflash
08:12:34 INFO: Flash Jetson Linux - flash: *** Checking ONLINE mode ... OK.
08:12:35 INFO: Flash Jetson Linux - flash: *** Checking target board connection ... 1 connections found.
08:12:38 INFO: Flash Jetson Linux - flash: *** Reading ECID ... FUSELEVEL=fuselevel_production hwchipid=0x23 bootauth=NS
08:12:38 INFO: Flash Jetson Linux - flash: *** Reading EEPROM ... "/home/apt/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py" --chip 0x23 --applet "/home/apt/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/mb1_t234_prod.bin" --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3701-0000.dts --misc_config tegra234-mb1-bct-misc-p3701-0000.dts --bins "mb2_applet applet_t234.bin" --skipuid --cmd "dump eeprom cvm cvm.bin; reboot recovery"
08:12:38 INFO: Flash Jetson Linux - flash: [ 0.0114 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
08:12:38 INFO: Flash Jetson Linux - flash: [ 0.0120 ] File rcm_state open failed
08:12:38 INFO: Flash Jetson Linux - flash: [ 0.0257 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
08:12:38 INFO: Flash Jetson Linux - flash: [ 0.0264 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
08:12:39 INFO: Flash Jetson Linux - flash: [ 0.0299 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
08:12:39 INFO: Flash Jetson Linux - flash: [ 0.0413 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
08:12:39 INFO: Flash Jetson Linux - flash: [ 0.0481 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
08:12:39 INFO: Flash Jetson Linux - flash: [ 0.0483 ] adding BCH for mb2_t234_aligned.bin
08:12:39 INFO: Flash Jetson Linux - flash: [ 0.0597 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
08:12:39 INFO: Flash Jetson Linux - flash: [ 0.0599 ] adding BCH for mb2_t234_aligned.bin
08:12:39 INFO: Flash Jetson Linux - flash: [ 0.0769 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin
08:12:39 INFO: Flash Jetson Linux - flash: [ 0.0791 ] Assuming zero filled SBK key
08:12:39 INFO: Flash Jetson Linux - flash: [ 0.0880 ] WARNING: boot chain is not completed. set to 0
08:12:39 INFO: Flash Jetson Linux - flash: [ 0.0909 ] Assuming zero filled SBK key
08:12:39 INFO: Flash Jetson Linux - flash: [ 0.0928 ] Offset :4608 Len :3584
08:12:39 INFO: Flash Jetson Linux - flash: [ 0.0942 ] Assuming zero filled SBK key
08:12:39 INFO: Flash Jetson Linux - flash: [ 0.0963 ] Offset :68 Len :8124
08:12:39 ERROR: Flash Jetson Linux - flash: [ 0.0986 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
08:12:39 INFO: Flash Jetson Linux - flash: [ 0.1022 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
08:12:39 INFO: Flash Jetson Linux - flash: [ 0.1040 ] Assuming zero filled SBK key
08:12:39 INFO: Flash Jetson Linux - flash: [ 0.1065 ] MB1-BCT version: 0.10
08:12:39 ERROR: Flash Jetson Linux - flash: [ 0.1075 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
08:12:39 INFO: Flash Jetson Linux - flash: [ 0.1111 ] adding BCH for mb1_bct_MB1_aligned.bct
08:12:39 INFO: Flash Jetson Linux - flash: [ 0.1128 ] Assuming zero filled SBK key
08:12:39 INFO: Flash Jetson Linux - flash: [ 0.1190 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
08:12:39 INFO: Flash Jetson Linux - flash: [ 0.1195 ] BR_CID: 0x80012344705DD5DD2C00000011FE8100
08:12:40 INFO: Flash Jetson Linux - flash: [ 0.7263 ] Sending bct_br
08:12:45 ERROR: Flash Jetson Linux - flash: [ 1.5416 ] ERROR: might be timeout in USB write.
08:12:45 INFO: Flash Jetson Linux - flash: Command tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
08:12:45 ERROR: Flash Jetson Linux - flash: --- Error: Reading board information failed.
08:12:45 ERROR: Flash Jetson Linux - flash: command terminated with error
08:12:45 SUMMARY: DateTime Target Setup - target: Depends on failed component
Dump from flash.sh here:
# L4T BSP Information:
# R35 , REVISION: 3.1
# User release: 0.0
# Target Board Information:
# Name: jetson-agx-orin-devkit, Board Family: t186ref, SoC: Tegra 234,
# OpMode: production, Boot Authentication: NS,
# Disk encryption: disabled ,
copying emc_fuse_dev_params(/home/apt/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct-diag-boot.dts)... done.
copying device_config(/home/apt/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-device-p3701-0000.dts)... done.
copying misc_config(/home/apt/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-misc-p3701-0000.dts)... done.
./tegraflash.py --chip 0x23 --applet "/home/apt/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/mb1_t234_prod.bin" --skipuid --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3701-0000.dts --misc_config tegra234-mb1-bct-misc-p3701-0000.dts --bins "mb2_applet applet_t234.bin" --cmd "dump eeprom cvm cvm.bin; dump custinfo custinfo_out.bin; reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0105 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.0110 ] File rcm_state open failed
[ 0.0112 ] ERROR: failed to read rcm_state
[ 0.0112 ]
[ 0.0120 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0122 ] Assuming zero filled SBK key
[ 0.0116 ] Pre-processing config: tegra234-mb1-bct-device-p3701-0000.dts
[ 0.0150 ] Pre-processing config: tegra234-mb1-bct-misc-p3701-0000.dts
[ 0.0201 ] Parsing partition layout
[ 0.0207 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0216 ] Kernel DTB used: None
[ 0.0217 ] WARNING: dce base dtb is not provided
[ 0.0217 ] Parsing partition layout
[ 0.0222 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0230 ] Creating list of images to be signed
[ 0.0236 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[ 0.0241 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0247 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0249 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0282 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0310 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.0344 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.0346 ] adding BCH for mb2_t234_aligned.bin
[ 0.0364 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.0455 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.0457 ] adding BCH for mb2_t234_aligned.bin
[ 0.0563 ] Filling MB1 storage info
[ 0.0563 ] Parsing dev params for multi chains
[ 0.0597 ] Generating br-bct
[ 0.0602 ] Updating dev and MSS params in BR BCT
[ 0.0603 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.0610 ] Updating bl info
[ 0.0616 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin
[ 0.0621 ] WARNING: boot chain is not completed. set to 0
[ 0.0626 ] Generating signatures
[ 0.0634 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.0635 ] Assuming zero filled SBK key
[ 0.0702 ] Warning: pub_key.key is not found
[ 0.0696 ] Parsing dev params for multi chains
[ 0.0696 ] Generating br-bct
[ 0.0701 ] Updating dev and MSS params in BR BCT
[ 0.0701 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.0708 ] Updating bl info
[ 0.0714 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.0719 ] WARNING: boot chain is not completed. set to 0
[ 0.0725 ] Get Signed section of bct
[ 0.0730 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[ 0.0737 ] Signing BCT
[ 0.0745 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.0747 ] Assuming zero filled SBK key
[ 0.0763 ] Sha saved in br_bct_BR.sha
[ 0.0766 ] Warning: pub_key.key is not found
[ 0.0758 ] Updating BCT with signature
[ 0.0763 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[ 0.0768 ] Offset :4608 Len :3584
[ 0.0771 ] Generating SHA2 Hash
[ 0.0779 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[ 0.0780 ] Assuming zero filled SBK key
[ 0.0796 ] Sha saved in br_bct_BR.sha
[ 0.0791 ] Updating BCT with SHA2 Hash
[ 0.0795 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[ 0.0800 ] Offset :4608 Len :3584
[ 0.0802 ] Offset :68 Len :8124
[ 0.0804 ] Generating coldboot mb1-bct
[ 0.0809 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.0815 ] MB1-BCT version: 0.10
[ 0.0816 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.0820 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.0823 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.0827 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.0830 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.0830 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[ 0.0830 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[ 0.0830 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[ 0.0830 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[ 0.0830 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[ 0.0830 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[ 0.0830 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[ 0.0830 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[ 0.0830 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[ 0.0831 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[ 0.0831 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[ 0.0831 ]
[ 0.0831 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.0831 ] Added Platform Config 9 data with size :- 100
[ 0.0831 ]
[ 0.0831 ] Updating mb1-bct with firmware information
[ 0.0837 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.0851 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 0.0862 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 0.0868 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 0.0882 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.0883 ] Assuming zero filled SBK key
[ 0.0893 ] Warning: pub_key.key is not found
[ 0.0891 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.0900 ] Generating recovery mb1-bct
[ 0.0906 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.0911 ] MB1-BCT version: 0.10
[ 0.0913 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.0917 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.0920 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.0922 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.0924 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.0925 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.0925 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[ 0.0925 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[ 0.0925 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[ 0.0925 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[ 0.0925 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[ 0.0925 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[ 0.0925 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[ 0.0925 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[ 0.0925 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[ 0.0925 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[ 0.0925 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[ 0.0925 ]
[ 0.0925 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.0925 ] Added Platform Config 9 data with size :- 100
[ 0.0925 ]
[ 0.0926 ] Updating mb1-bct with firmware information
[ 0.0931 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.0946 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[ 0.0956 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[ 0.0961 ] adding BCH for mb1_bct_MB1_aligned.bct
[ 0.0974 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.0975 ] Assuming zero filled SBK key
[ 0.0985 ] Warning: pub_key.key is not found
[ 0.0983 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.0992 ] Error: Skip generating mem_bct because sdram_config is not defined
[ 0.0992 ] Copying signatures
[ 0.0997 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.1034 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.1035 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.1035 ] Boot Rom communication
[ 0.1040 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 0.1045 ] BR_CID: 0x80012344705DD5DD2C00000011FE8100
[ 0.9204 ] Sending bct_br
[ 1.7356 ] ERROR: might be timeout in USB write.
Error: Return value 3
