Orin devkit 启动失败
hi,
我使用Orin devkit,在开机过程中失败,串口日志如下,请问一下是什么原因?
[0000.061] I> MB1 (version: 1.2.0.0-t234-54845784-562369e5)
[0000.066] I> t234-A01-0-Silicon (0x12347) Prod
[0000.071] I> Boot-mode : Coldboot
[0000.074] I> Entry timestamp: 0x00000000
[0000.078] I> last_boot_error: 0x600818
[0000.081] I> BR-BCT: preprod_dev_sign: 0
[0000.085] I> rst_source: 0x17, rst_level: 0x1
[0000.089] I> Task: SE error check
[0000.092] I> Task: Bootchain select WAR set
[0000.096] I> Task: Enable SLCG
[0000.099] I> Task: CRC check
[0000.102] I> Skip FUSE records CRC check as records_integrity fuse is not burned
[0000.109] I> Task: Initialize MB2 params
[0000.113] I> MB2-params @ 0x40060000
[0000.117] I> Task: Crypto init
[0000.120] I> Task: Perform MB1 KAT tests
[0000.124] I> Task: NVRNG health check
[0000.127] I> NVRNG: Health check success
[0000.131] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0000.137] I> Task: Enabling and initialization of Bandwidth limiter
[0000.143] I> No request to configure MBWT settings for any PC!
[0000.149] I> Task: Secure debug controls
[0000.153] I> Task: strap war set
[0000.156] I> Task: Initialize SOC Therm
[0000.159] I> Task: Program NV master stream id
[0000.164] I> Task: Verify boot mode
[0000.169] I> Task: Alias fuses
[0000.173] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.180] I> Task: Print SKU type
[0000.183] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x00000000
[0000.188] I> FUSE_OPT_GPC_DISABLE = 0x00000000
[0000.193] I> FUSE_OPT_TPC_DISABLE = 0x00000000
[0000.197] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0000.201] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0000.205] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0000.210] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0000.214] I> FUSE_OPT_FSI_DISABLE = 0x00000000
[0000.219] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0000.223] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.227] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.231] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.235] I> FUSE_SKU_INFO_0 = 0xd0
[0000.239] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.243] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.246] I> SKU: Prod
[0000.249] I> Task: Boost clocks
[0000.252] I> Initializing PLLC2 for AXI_CBB.
[0000.256] I> AXI_CBB : src = 35, divisor = 0
[0000.260] I> Task: Voltage monitor
[0000.263] I> VMON: Vmon re-calibration and fine tuning done
[0000.269] I> Task: UPHY init
[0000.274] I> HSIO UPHY init done
[0000.277] W> Skipping GBE UPHY config
[0000.280] I> Task: Boot device init
[0000.283] I> Boot_device: QSPI_FLASH instance: 0
[0000.288] I> Qspi clock source : pllc_out0
[0000.292] I> QSPI Flash: Macronix 64MB
[0000.296] I> QSPI-0l initialized successfully
[0000.300] I> Task: TSC init
[0000.303] I> Task: Load membct
[0000.306] I> RAM_CODE 0x4000401
[0000.309] I> Loading MEMBCT
[0000.312] I> Slot: 1
[0000.314] I> Binary[0] block-66816 (partition size: 0x40000)
[0000.319] I> Binary name: MEM-BCT-0
[0000.322] I> Size of crypto header is 8192
[0000.326] I> Size of crypto header is 8192
[0000.330] I> strt_pg_num(66816) num_of_pgs(16) read_buf(0x40050000)
[0000.337] I> BCH of MEM-BCT-0 read from storage
[0000.341] I> BCH address is : 0x40050000
[0000.345] I> MEM-BCT-0 header integrity check is success
[0000.350] I> Binary magic in BCH component 0 is MEM0
[0000.355] I> component binary type is 0
[0000.359] I> strt_pg_num(66832) num_of_pgs(115) read_buf(0x40040000)
[0000.365] I> MEM-BCT-0 binary is read from storage
[0000.370] I> MEM-BCT-0 binary integrity check is success
[0000.375] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0000.382] I> RAM_CODE 0x4000401
[0000.387] I> RAM_CODE 0x4000401
[0000.391] I> Task: Load Page retirement list
[0000.395] I> Task: SDRAM params override
[0000.399] I> Task: Save mem-bct info
[0000.403] I> Task: Carveout allocate
[0000.406] I> RCM blob carveout will not be allocated
[0000.411] I> Update CCPLEX IST carveout from MB1-BCT
[0000.416] I> ECC region[0]: Start:0x0, End:0x0
[0000.420] I> ECC region[1]: Start:0x0, End:0x0
[0000.424] I> ECC region[2]: Start:0x0, End:0x0
[0000.428] I> ECC region[3]: Start:0x0, End:0x0
[0000.433] I> ECC region[4]: Start:0x0, End:0x0
[0000.437] I> Non-ECC region[0]: Start:0x80000000, End:0x880000000
[0000.443] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.448] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.452] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.457] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.467] I> allocated(CO:44) base:0x849800000 size:0x36800000 align: 0x100000
[0000.475] I> allocated(CO:31) base:0x840000000 size:0x8000000 align: 0x8000000
[0000.482] I> allocated(CO:43) base:0x83c000000 size:0x4000000 align: 0x200000
[0000.489] I> allocated(CO:39) base:0x839e00000 size:0x2200000 align: 0x10000
[0000.496] I> allocated(CO:20) base:0x836000000 size:0x2000000 align: 0x2000000
[0000.503] I> allocated(CO:24) base:0x834000000 size:0x2000000 align: 0x2000000
[0000.510] I> allocated(CO:28) base:0x832000000 size:0x2000000 align: 0x2000000
[0000.517] I> allocated(CO:29) base:0x830000000 size:0x2000000 align: 0x2000000
[0000.524] I> allocated(CO:22) base:0x848000000 size:0x1000000 align: 0x1000000
[0000.531] I> allocated(CO:41) base:0x838e00000 size:0x1000000 align: 0x100000
[0000.538] I> allocated(CO:35) base:0x838000000 size:0xe00000 align: 0x10000
[0000.545] I> allocated(CO:02) base:0x849000000 size:0x800000 align: 0x800000
[0000.552] I> allocated(CO:03) base:0x82f800000 size:0x800000 align: 0x800000
[0000.559] I> allocated(CO:06) base:0x82f000000 size:0x800000 align: 0x800000
[0000.566] I> allocated(CO:56) base:0x82e800000 size:0x800000 align: 0x200000
[0000.573] I> allocated(CO:07) base:0x82e400000 size:0x400000 align: 0x400000
[0000.580] I> allocated(CO:33) base:0x82e000000 size:0x400000 align: 0x200000
[0000.587] I> allocated(CO:23) base:0x82de00000 size:0x200000 align: 0x200000
[0000.594] I> allocated(CO:01) base:0x82dd00000 size:0x100000 align: 0x100000
[0000.601] I> allocated(CO:04) base:0x82dc00000 size:0x100000 align: 0x100000
[0000.608] I> allocated(CO:05) base:0x82db00000 size:0x100000 align: 0x100000
[0000.615] I> allocated(CO:08) base:0x82da00000 size:0x100000 align: 0x100000
[0000.622] I> allocated(CO:09) base:0x82d900000 size:0x100000 align: 0x100000
[0000.629] I> allocated(CO:15) base:0x82d800000 size:0x100000 align: 0x100000
[0000.635] I> allocated(CO:17) base:0x82d700000 size:0x100000 align: 0x100000
[0000.642] I> allocated(CO:27) base:0x82d600000 size:0x100000 align: 0x100000
[0000.649] I> allocated(CO:42) base:0x82d500000 size:0x100000 align: 0x100000
[0000.656] I> allocated(CO:54) base:0x82d480000 size:0x80000 align: 0x80000
[0000.663] I> allocated(CO:34) base:0x82d470000 size:0x10000 align: 0x10000
[0000.670] I> allocated(CO:72) base:0x82d270000 size:0x200000 align: 0x10000
[0000.677] I> allocated(CO:47) base:0x82ce00000 size:0x400000 align: 0x200000
[0000.684] I> allocated(CO:48) base:0x82d250000 size:0x20000 align: 0x10000
[0000.690] I> allocated(CO:69) base:0x82d230000 size:0x20000 align: 0x10000
[0000.697] I> allocated(CO:49) base:0x82d220000 size:0x10000 align: 0x10000
[0000.704] I> allocated(CO:50) base:0x82d210000 size:0x10000 align: 0x10000
[0000.711] I> allocated(CO:52) base:0x82d200000 size:0x10000 align: 0x10000
[0000.717] I> NSDRAM base: 0x80000000, end: 0x82d270000, size: 0x7ad270000
[0000.724] I> Task: Thermal check
[0000.727] I> max_chip_limit = 105
[0000.730] I> min_chip_limit = -28
[0000.733] I> max temp read = 36
[0000.736] I> min temp read = 34
[0000.739] I> Task: Update FSI SCR with thermal fuse data
[0000.745] I> Task: Enable WDT 5th expiry
[0000.748] I> Task: I2C register
[0000.751] I> Task: Set I2C bus freq
[0000.755] I> Task: Reset FSI
[0000.757] I> Task: Pinmux init
[0000.761] I> Task: Prod config init
[0000.764] I> Task: Pad voltage init
[0000.767] I> Task: Prod init
[0000.770] I> Task: Program rst req config reg
[0000.774] I> Task: Common rail init
[0000.778] I> DONE: Thermal config
[0000.782] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0000.790] I> DONE: SOC rail config
[0000.794] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0000.801] I> DONE: MEMIO rail config
[0000.804] I> DONE: GPU rail info
[0000.807] I> DONE: CV rail info
[0000.810] I> Task: Mem clock src
[0000.813] I> Task: Misc. board config
[0000.817] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0000.823] I> Task: SDRAM init
[0000.826] I> MemoryType: 4 MemBctRevision: 9
[0000.832] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 9
[0000.840] I> MSS CAR: Init PLLM
[0000.843] I> MSS CAR: Init PLLHUB
[0000.848] I> Encryption:   MTS: en, TX: en, VPR: en, GSC: en
[0000.859] I> SDRAM initialized!
[0000.862] I> SDRAM Size in Total 0x800000000
[0000.866] I> Task: Dram Ecc scrub
[0000.869] I> Task: DRAM alias check
[0000.898] I> Task: Program NSDRAM carveout
[0000.902] I> NSDRAM carveout encryption is enabled
[0000.907] I> Program NSDRAM carveout
[0000.912] I> Task: Register checker
[0000.918] I> Task: Enable clock-mon
[0000.933] E> FMON: Failed to verify FSI low threshold fault occurrence. Calib fuse: 13. Fault reg: 0x0x4
[0000.943] E> FMON: Fault testing failed
[0000.947] C> Task 0x35 failed (err: 0x600818)
[0000.952] E> Top caller module: NONE, error module: FMON, reason: 0x18, aux_info: 0x08
[0000.960] C> Boot Info Table status dump :
01111111001110001111111111111111111111111111101110111
If the device cannot be flashed/booted, please refer to the page to get uart log from the device:
Jetson/General debug - eLinux.org
And get logs of host PC and Jetson device for reference. If you are using custom board, you can compare uart log of developer kit and custom board to get more information.
Also please check FAQs:
Jetson AGX Orin FAQ
If possible, we would suggest follow quick start in developer guide to re-flash the system:
Quick Start — NVIDIA Jetson Linux Developer Guide 1 documentation
And see if the issue still persists on a clean-flashed system.
Which BSP version is in use here? How did you flash the board?
因为现在无法进入系统,没有办法判断BSP的具体版本,但确定的是Jetpack5.1.2或者是Jetpack5.1.3版本,我之前使用的massflash的方式。出现这个问题之后flash或者massflash均无法刷机。
你好,使用flash方式重新刷机,刷机日志如下
jyh@computer:/data/nvidia/JP513/Linux_for_Tegra$ sudo  ./flash.sh -r jetson-agx-orin-devkit mmcblk0p1
# L4T BSP Information:
# R35 , REVISION: 5.0
# User release: 0.0
ECID is 0x80012344705E35E03C000000120281C0
# Target Board Information:
# Name: jetson-agx-orin-devkit, Board Family: t186ref, SoC: Tegra 234,
# OpMode: production, Boot Authentication: NS,
# Disk encryption: disabled ,
copying emc_fuse_dev_params(/data/nvidia/JP513/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct-diag-boot.dts)... done.
copying device_config(/data/nvidia/JP513/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-device-p3701-0000.dts)... done.
copying misc_config(/data/nvidia/JP513/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-misc-p3701-0000.dts)... done.
./tegraflash.py --chip 0x23 --applet "/data/nvidia/JP513/Linux_for_Tegra/bootloader/mb1_t234_prod.bin" --skipuid --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3701-0000.dts --misc_config tegra234-mb1-bct-misc-p3701-0000.dts --bins "mb2_applet applet_t234.bin" --cmd "dump eeprom cvm cvm.bin; dump custinfo custinfo_out.bin; reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[   0.0255 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.0263 ] File rcm_state open failed
[   0.0266 ] ERROR: failed to read rcm_state
[   0.0266 ]
[   0.0279 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0280 ] Assuming zero filled SBK key
[   0.0269 ] Pre-processing config: tegra234-mb1-bct-device-p3701-0000.dts
[   0.0376 ] Pre-processing config: tegra234-mb1-bct-misc-p3701-0000.dts
[   0.0579 ] Parsing partition layout
[   0.0589 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.0603 ] Kernel DTB used: None
[   0.0603 ] WARNING: dce base dtb is not provided
[   0.0603 ] Parsing partition layout
[   0.0630 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.0660 ] Creating list of images to be signed
[   0.0687 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[   0.0702 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.0714 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.0722 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.0805 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.0813 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.0853 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.0855 ] adding BCH for mb2_t234_aligned.bin
[   0.0879 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.0986 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.0988 ] adding BCH for mb2_t234_aligned.bin
[   0.1118 ] Filling MB1 storage info
[   0.1118 ] Parsing dev params for multi chains
[   0.1273 ] Generating br-bct
[   0.1299 ] Updating dev and MSS params in BR BCT
[   0.1299 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   0.1311 ] Updating bl info
[   0.1321 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin
[   0.1334 ] WARNING: boot chain is not completed. set to 0
[   0.1344 ] Generating signatures
[   0.1357 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.1359 ] Assuming zero filled SBK key
[   0.1481 ] Warning: pub_key.key is not found
[   0.1471 ] Parsing dev params for multi chains
[   0.1471 ] Generating br-bct
[   0.1480 ] Updating dev and MSS params in BR BCT
[   0.1481 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   0.1493 ] Updating bl info
[   0.1502 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.1512 ] WARNING: boot chain is not completed. set to 0
[   0.1523 ] Get Signed section of bct
[   0.1532 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   0.1544 ] Signing BCT
[   0.1557 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.1559 ] Assuming zero filled SBK key
[   0.1586 ] Sha saved in br_bct_BR.sha
[   0.1589 ] Warning: pub_key.key is not found
[   0.1577 ] Updating BCT with signature
[   0.1586 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   0.1595 ] Offset :4608 Len :3584
[   0.1600 ] Generating SHA2 Hash
[   0.1613 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   0.1614 ] Assuming zero filled SBK key
[   0.1615 ] Assuming zero filled SBK key
[   0.1641 ] Sha saved in br_bct_BR.sha
[   0.1633 ] Updating BCT with SHA2 Hash
[   0.1644 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[   0.1652 ] Offset :4608 Len :3584
[   0.1655 ] Offset :68 Len :8124
[   0.1657 ] Generating coldboot mb1-bct
[   0.1666 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   0.1676 ] MB1-BCT version: 0.12
[   0.1678 ] ERROR: /misc/enable_dram_page_blacklisting is not supported
[   0.1680 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[   0.1683 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[   0.1686 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[   0.1689 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[   0.1690 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[   0.1690 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[   0.1690 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[   0.1690 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[   0.1690 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[   0.1690 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[   0.1690 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[   0.1690 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[   0.1690 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[   0.1690 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[   0.1690 ]
[   0.1690 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   0.1690 ] Added Platform Config 9 data with size :- 100
[   0.1690 ]
[   0.1690 ] Updating mb1-bct with firmware information
[   0.1699 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.1723 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   0.1740 ] Generating SHA2 Hash for mb1bct
[   0.1768 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[   0.1779 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[   0.1785 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   0.1793 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   0.1814 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.1815 ] Assuming zero filled SBK key
[   0.1831 ] Warning: pub_key.key is not found
[   0.1829 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.1844 ] Generating recovery mb1-bct
[   0.1852 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   0.1860 ] MB1-BCT version: 0.12
[   0.1862 ] ERROR: /misc/enable_dram_page_blacklisting is not supported
[   0.1864 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[   0.1867 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[   0.1869 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[   0.1872 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[   0.1874 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[   0.1874 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[   0.1874 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[   0.1874 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[   0.1874 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[   0.1874 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[   0.1874 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[   0.1874 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[   0.1874 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[   0.1874 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[   0.1874 ]
[   0.1874 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   0.1874 ] Added Platform Config 9 data with size :- 100
[   0.1874 ]
[   0.1875 ] Updating mb1-bct with firmware information
[   0.1883 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.1907 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[   0.1916 ] Generating SHA2 Hash for mb1bct
[   0.1942 ] Sha saved in mb1_bct_MB1_aligned.sha
[   0.1966 ] Sha saved in mb1_bct_MB1.sha
[   0.1969 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[   0.1977 ] adding BCH for mb1_bct_MB1_aligned.bct
[   0.1997 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.1999 ] Assuming zero filled SBK key
[   0.2014 ] Warning: pub_key.key is not found
[   0.2011 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.2024 ] Error: Skip generating mem_bct because sdram_config is not defined
[   0.2025 ] Error: Skip generating mem_bct because sdram_config is not defined
[   0.2025 ] Copying signatures
[   0.2034 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.2109 ] Boot Rom communication
[   0.2121 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[   0.2130 ] BR_CID: 0x80012344705E35E03C000000120281C0
[   0.3330 ] Sending bct_br
[   0.4477 ] Sending mb1
[   0.4487 ] Sending psc_bl1
[   0.4581 ] Sending bct_mb1
[   0.4638 ] Boot Rom communication completed
[   0.4681 ] tegrahost_v2 --chip 0x23 0 --align applet_t234_aligned.bin
[   0.4733 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --appendsigheader applet_t234_aligned.bin zerosbk
[   0.4757 ] adding BCH for applet_t234_aligned.bin
[   0.4897 ] tegrasign_v3.py --key None --list applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.4899 ] Assuming zero filled SBK key
[   0.4941 ] Warning: pub_key.key is not found
[   0.4957 ] tegrahost_v2 --chip 0x23 0 --updatesigheader applet_t234_aligned_sigheader.bin.encrypt applet_t234_aligned_sigheader.bin.hash zerosbk
[   0.4979 ] Sending mb2_applet...
[   0.4987 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download applet applet_t234_sigheader.bin.encrypt
[   0.4995 ] BL: version 1.4.0.1-t234-54845784-08e631ca last_boot_error: 0
[   0.6674 ] Sending applet
[   0.7734 ] ERROR: might be timeout in USB write.
Error: Return value 3
Command tegrarcm_v2 --chip 0x23 0 --pollbl --download applet applet_t234_sigheader.bin.encrypt
Reading board information failed.
使用PC的串口连接devikit的串口,查看打印如下
[0016.825] I> MB1 (version: 1.4.0.1-t234-54845784-08e631ca)
[0016.830] I> t234-A01-0-Silicon (0x12347) Prod
[0016.834] I> Boot-mode : BPMP Diagnostic
[0016.838] I> Entry timestamp: 0x00000000
[0016.842] I> last_boot_error: 0x0
[0016.845] I> BR-BCT: preprod_dev_sign: 0
[0016.849] I> rst_source: 0x0, rst_level: 0x0
[0016.853] I> Task: Initialize MB2 params
[0016.857] I> MB2-params @ 0x40060000
[0016.860] I> Task: Crypto init
[0016.863] I> Task: Perform MB1 KAT tests
[0016.867] I> Task: NVRNG health check
[0016.871] I> NVRNG: Health check success
[0016.875] I> Task: Secure debug controls
[0016.878] I> Task: strap war set
[0016.881] I> Task: Program NV master stream id
[0016.886] I> Task: Verify boot mode
[0016.891] I> Task: Alias fuses
[0016.895] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0016.902] I> Task: Print SKU type
[0016.905] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x00000000
[0016.911] I> FUSE_OPT_GPC_DISABLE = 0x00000000
[0016.915] I> FUSE_OPT_TPC_DISABLE = 0x00000000
[0016.919] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0016.924] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0016.928] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0016.932] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0016.937] I> FUSE_OPT_FSI_DISABLE = 0x00000000
[0016.941] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0016.945] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0016.949] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0016.954] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0016.958] I> FUSE_SKU_INFO_0 = 0xd0
[0016.961] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0016.965] I> FUSE_PACKAGE_INFO_0 = 0x2
[0016.969] I> SKU: Prod
[0016.971] I> Task: Boost clocks
[0016.974] I> Initializing PLLC2 for AXI_CBB.
[0016.978] I> AXI_CBB : src = 35, divisor = 0
[0016.982] I> Task: Voltage monitor
[0016.986] I> VMON: Vmon re-calibration and fine tuning done
[0016.991] I> Task: UPHY init
[0016.994] W> UPHY: UPHY lane info table is empty in MB1 BCT.
[0017.000] I> Task: Boot device init
[0017.003] I> Boot_device: RCM
[0017.006] I> USB configuration success
[0017.010] I> Task: TSC init
[0017.012] I> Task: Enable WDT 5th expiry
[0017.016] I> Task: I2C register
[0017.019] I> Task: Set I2C bus freq
[0017.022] I> Task: Reset FSI
[0017.025] I> Task: Enable clock-mon
[0017.039] E> FMON: Failed to verify FSI low threshold fault occurrence. Calib fuse: 13. Fault reg: 0x0x4
[0017.049] E> FMON: Fault testing failed
[0017.052] C> Task 0x35 failed (err: 0x818)
[0017.056] E> Top caller module: NONE, error module: NONE, reason: 0x18, aux_info: 0x08
[0017.064] C> Boot Info Table status dump :
011110000011100011011111111100000001111
无法重新刷机,这是由于什么导致的?
請問你這片到底是Orin AGX industrial 還是Orin AGX?
還是說你也不確定?
是Orin AGX,这是Orin devkit开发者套件
請問這一台已經有燒錄過嗎?
之前有烧录过并且正常使用,过了一段时间就这样了
能請你用rel-36.4 sdkmanager進行燒錄看看嗎
如果有相同的問題就得RMA
我使用的JetPack5.1.3的源码L4T生成的system.img并使用flash.sh烧录,和sdkmanager是相同的方式,无法烧录的,日志log上面有
對 所以我現在想知道是不是jetpack6也有相同的問題
預期上會有, 但實際上要你測了才知道. 這樣可以嗎?
hello,我这边使用JetPack6.0快速验证了一下,仍然不幸,是相同的问题
mogo@mogo-Inspiron-7472:~/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra$ sudo  ./flash.sh  -r  jetson-agx-orin-devk
it mmcblk0p1
# R36 , REVISION: 3.0
# User release: 0.0
# Name: jetson-agx-orin-devkit, Board Family: generic, SoC: Tegra 234,
Existing emcfuse(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/fuse_t234.xml) reused.
copying emc_fuse_dev_params(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/generic/BCT/tegra234-br-bct-diag-boot.dts)... done.
copying device_config(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-device-p3701-0000.dts)... done.
copying misc_config(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-misc-p3701-0000.dts)... done.
./tegraflash.py --chip "0x23" --applet "/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/mb1_t234_prod.bin" --skipuid --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3701-0000.dts --misc_config tegra234-mb1-bct-misc-p3701-0000.dts --bins "mb2_applet applet_t234.bin" --cmd "readfuses fuse_t234.bin fuse_t234.xml; dump eeprom cvm cvm.bin; dump try_custinfo custinfo_out.bin; reboot recovery"
version 1.0.0
[   0.0292 ] Reading fuses
[   0.0313 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.0333 ] File rcm_state open failed
[   0.0334 ] ERROR: failed to read rcm_state
[   0.0334 ]
[   0.0344 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0350 ] Assuming zero filled SBK key
[   0.0344 ] Pre-processing config: tegra234-mb1-bct-device-p3701-0000.dts
[   0.0443 ] Pre-processing config: tegra234-mb1-bct-misc-p3701-0000.dts
[   0.0564 ] Parsing partition layout
[   0.0576 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.0597 ] Kernel DTB used: None
[   0.0597 ] WARNING: dce base dtb is not provided
[   0.0597 ] Parsing partition layout
[   0.0609 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.0623 ] Creating list of images to be signed
[   0.0635 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[   0.0646 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.0658 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.0662 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.0723 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.0728 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.0787 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.0790 ] adding BCH for mb2_t234_aligned.bin
[   0.0823 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.0964 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.0967 ] adding BCH for mb2_t234_aligned.bin
[   0.1190 ] Generating br-bct
[   0.1201 ] Updating dev and MSS params in BR BCT
[   0.1202 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   0.1213 ] Updating bl info
[   0.1224 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin
[   0.1233 ] WARNING: boot chain is not completed. set to 0
[   0.1244 ] Generating signatures
[   0.1253 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.1255 ] Assuming zero filled SBK key
[   0.1397 ] Warning: pub_key.key is not found
[   0.1391 ] Parsing dev params for multi chains
[   0.1392 ] Generating br-bct
[   0.1402 ] Updating dev and MSS params in BR BCT
[   0.1403 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   0.1415 ] Updating bl info
[   0.1425 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.1434 ] WARNING: boot chain is not completed. set to 0
[   0.1443 ] Generating SHA2 Hash
[   0.1468 ] Sha saved in br_bct_BR.sha
[   0.1461 ] Get Signed section of bct
[   0.1471 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   0.1483 ] Signing BCT
[   0.1492 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.1495 ] Assuming zero filled SBK key
[   0.1528 ] Sha saved in br_bct_BR.sha
[   0.1532 ] Warning: pub_key.key is not found
[   0.1524 ] Updating BCT with signature
[   0.1533 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   0.1542 ] Offset :4608 Len :3584
[   0.1546 ] Generating SHA2 Hash
[   0.1555 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   0.1558 ] Assuming zero filled SBK key
[   0.1591 ] Sha saved in br_bct_BR.sha
[   0.1587 ] Updating BCT with SHA2 Hash
[   0.1596 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[   0.1605 ] Offset :4608 Len :3584
[   0.1609 ] Offset :68 Len :8124
[   0.1609 ]
[   0.1610 ] Generating coldboot mb1-bct
[   0.1622 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   0.1631 ] MB1-BCT version: 0.13
[   0.1648 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   0.1651 ] Added Platform Config 9 data with size :- 100
[   0.1651 ]
[   0.1651 ] Updating mb1-bct with firmware information
[   0.1661 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.1687 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   0.1698 ] Generating SHA2 Hash for mb1bct
[   0.1723 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[   0.1740 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[   0.1742 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   0.1752 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   0.1770 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.1772 ] Assuming zero filled SBK key
[   0.1792 ] Warning: pub_key.key is not found
[   0.1795 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.1811 ] Generating recovery mb1-bct
[   0.1821 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   0.1831 ] MB1-BCT version: 0.13
[   0.1848 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   0.1850 ] Added Platform Config 9 data with size :- 100
[   0.1850 ]
[   0.1851 ] Updating mb1-bct with firmware information
[   0.1861 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.1885 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[   0.1895 ] Generating SHA2 Hash for mb1bct
[   0.1921 ] Sha saved in mb1_bct_MB1_aligned.sha
[   0.1937 ] Sha saved in mb1_bct_MB1.sha
[   0.1940 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[   0.1950 ] adding BCH for mb1_bct_MB1_aligned.bct
[   0.1967 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.1969 ] Assuming zero filled SBK key
[   0.1990 ] Warning: pub_key.key is not found
[   0.1993 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.2010 ] Info: Skip generating mem_bct because sdram_config is not defined
[   0.2010 ] Copying signatures
[   0.2020 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.2078 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[   0.2080 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[   0.2080 ] Boot Rom communication
[   0.2091 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[   0.2101 ] BR_CID: 0x80012344705E35E03C000000120281C0
[   0.2389 ] Sending bct_br
[   0.2825 ] Sending mb1
[   0.2837 ] Sending psc_bl1
[   0.2957 ] Sending bct_mb1
[   0.3020 ] Boot Rom communication completed
[   0.3071 ] tegrahost_v2 --chip 0x23 0 --align applet_t234_aligned.bin
[   0.3147 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --appendsigheader applet_t234_aligned.bin zerosbk
[   0.3182 ] adding BCH for applet_t234_aligned.bin
[   0.3473 ] tegrasign_v3.py --key None --list applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.3478 ] Assuming zero filled SBK key
[   0.3521 ] Warning: pub_key.key is not found
[   0.3530 ] tegrahost_v2 --chip 0x23 0 --updatesigheader applet_t234_aligned_sigheader.bin.encrypt applet_t234_aligned_sigheader.bin.hash zerosbk
[   0.3560 ] Sending mb2_applet...
[   0.3573 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download applet applet_t234_sigheader.bin.encrypt
[   0.3585 ] BL: version 1.4.0.2-t234-54845784-08a4de08 last_boot_error: 0
[   0.5265 ] Sending applet
[   0.5550 ] ERROR: might be timeout in USB write.
[  10.7618 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[  10.7644 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[  10.7672 ] Retrieving board information
[  10.7686 ] tegrarcm_v2 --chip 0x23 0 --oem platformdetails chip chip_info.bin
[  10.7704 ] Retrieving EEPROM data
[  10.7705 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/cvm.bin --chip 0x23 0
[  10.7737 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[  10.7768 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[  10.7784 ] Dumping customer Info
[  10.7800 ] tegrarcm_v2 --chip 0x23 0 --oem dump bct tmp.bct
[  10.7832 ] tegrabct_v2 --brbct tmp.bct --chip 0x23 0 --custinfo /home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/custinfo_out.bin
[  10.7847 ] File tmp.bct open failed
[  10.7849 ] Error: try getting custinfo fail. Moving on
[  10.7850 ] Rebooting to recovery mode
[  10.7866 ] tegrarcm_v2 --chip 0x23 0 --ismb2
[  10.7882 ] Rebooting to recovery mode
[  10.7898 ] tegrarcm_v2 --chip 0x23 0 --reboot recovery
Board ID(3701) version(500) sku(0005) revision(M.0)
Chip SKU(00:00:00:D0) ramcode(00:00:00:03) fuselevel(fuselevel_production) board_FAB(500)
Copy /home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/kernel/dtb/tegra234-p3737-0000+p3701-0005-nv.dtb to /home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/kernel/dtb/tegra234-p3737-0000+p3701-0005-nv.dtb.rec
copying bctfile(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/generic/BCT/tegra234-p3701-0005-sdram-l4t.dts)... done.
copying minratchet_config(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-ratchet-p3701-0000.dts)... done.
copying pinmux_config(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-pinmux-p3701-0000-a04.dtsi)... done.
copying gpioint_config(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-gpioint-p3701-0000.dts)... done.
copying pmic_config(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-pmic-p3701-0005.dts)... done.
copying pmc_config(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-padvoltage-p3701-0000-a04.dtsi)... done.
copying deviceprod_config(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-cprod-p3701-0000.dts)... done.
copying prod_config(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-prod-p3701-0000.dts)... done.
copying scr_config(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb2-bct-scr-p3701-0000.dts)... done.
copying wb0sdram(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/generic/BCT/tegra234-p3701-0005-wb0sdram-l4t.dts)... done.
copying bootrom_config(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-reset-p3701-0000.dts)... done.
Existing uphylane_config(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/tegra234-mb1-bct-uphylane-si.dtsi) reused.
copying dev_params(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/generic/BCT/tegra234-br-bct-p3701-0000.dts)... done.
copying dev_params_b(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/generic/BCT/tegra234-br-bct_b-p3701-0000.dts)... done.
copying mb2bct_cfg(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb2-bct-misc-p3701-0000.dts)... done.
Existing pscfwfile(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/pscfw_t234_prod.bin) reused.
Existing pscbl1file(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/psc_bl1_t234_prod.bin) reused.
Existing mtsmcefile(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/mce_flash_o10_cr_prod.bin) reused.
Existing tscfwfile(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/tsec_t234.bin) reused.
Existing mb2applet(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/applet_t234.bin) reused.
Existing bootloader(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
copying initrd(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
bl is uefi
Making Boot image... done.
Not signing of boot.img
Making recovery ramdisk for recovery image...
Re-generating recovery ramdisk for recovery image...
/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/ramdisk_tmp /home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader /home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra
53899 blocks
gzip: /home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/kernel/Image: not in gzip format
_BASE_KERNEL_VERSION=5.15.136-tegra
77459 blocks
Making Recovery image...
copying recdtbfile(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/kernel/dtb/tegra234-p3737-0000+p3701-0005-nv.dtb.rec)... done.
20+0 records in
20+0 records out
20 bytes copied, 0.000396356 s, 50.5 kB/s
Existing sosfile(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing tegraboot(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing cpu_bootloader(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing mb2blfile(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing xusbfile(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/xusb_t234_prod.bin) reused.
Existing pvafile(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/nvpva_020.fw) reused.
Existing dcefile(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/display-t234-dce.bin) reused.
Existing nvdecfile(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/nvdec_t234_prod.fw) reused.
Existing psc_rf(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/psc_rf_t234_prod.bin) reused.
Existing mb2_rf(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/mb2rf_t234.bin) reused.
Existing mb1file(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing bpffile(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/bpmp_t234-TE990M-A1_prod.bin) reused.
copying bpfdtbfile(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/generic/tegra234-bpmp-3701-0005-3737-0000.dtb)... done.
Existing camerafw(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/camera-rtcpu-t234-rce.img) reused.
Existing apefile(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/adsp-fw.bin) reused.
Existing spefile(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/spe_t234.bin) reused.
Existing wb0boot(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/sc7_t234_prod.bin) reused.
Existing tosfile(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/tos-optee_t234.img) reused.
Existing eksfile(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/eks_t234.img) reused.
copying dtbfile(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/kernel/dtb/tegra234-p3737-0000+p3701-0005-nv.dtb)... done.
Copying nv_boot_control.conf to rootfs
Reusing existing system.img...
done.
Not signing of kernel-dtb
Existing tbcfile(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/uefi_jetson.bin) reused.
Skip generating EFI system partition image.
copying tbcdtbfile(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/kernel/dtb/tegra234-p3737-0000+p3701-0005-nv.dtb)... done.
copying cfgfile(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/generic/cfg/flash_t234_qspi_sdmmc.xml) to flash.xml... done.
Existing flashapp(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py) reused.
copying overlay_dtb(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/kernel/dtb/L4TConfiguration.dtbo)... done.
copying overlay_dtb(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/kernel/dtb/tegra234-p3737-0000+p3701-0000-dynamic.dtbo)... done.
copying overlay_dtb(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/kernel/dtb/tegra234-carveouts.dtbo)... done.
copying overlay_dtb(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/kernel/dtb/tegra-optee.dtbo)... done.
copying overlay_dtb(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/kernel/dtb/tegra234-p3737-camera-dual-imx274-overlay.dtbo)... done.
copying overlay_dtb(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/kernel/dtb/tegra234-p3737-camera-e3331-overlay.dtbo)... done.
copying overlay_dtb(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/kernel/dtb/tegra234-p3737-camera-e3333-overlay.dtbo)... done.
copying overlay_dtb(/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/kernel/dtb/tegra234-p3737-camera-imx185-overlay.dtbo)... done.
/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/L4TConfiguration_updated.dts: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
/home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/L4TConfiguration.dtbo: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
./tegraflash.py  --bl uefi_jetson_with_dtb.bin  --odmdata gbe-uphy-config-22,hsstp-lane-map-3,nvhs-uphy-config-0,hsio-uphy-config-0,gbe0-enable-10g  --overlay_dtb L4TConfiguration.dtbo,tegra234-p3737-0000+p3701-0000-dynamic.dtbo,tegra234-carveouts.dtbo,tegra-optee.dtbo,tegra234-p3737-camera-dual-imx274-overlay.dtbo,tegra234-p3737-camera-e3331-overlay.dtbo,tegra234-p3737-camera-e3333-overlay.dtbo,tegra234-p3737-camera-imx185-overlay.dtbo,  --bldtb tegra234-p3737-0000+p3701-0005-nv.dtb --applet mb1_t234_prod.bin --cmd "flash; reboot"  --cfg flash.xml --chip "0x23" --concat_cpubl_bldtb --cpubl uefi_jetson.bin --minratchet_config tegra234-mb1-bct-ratchet-p3701-0000.dts --device_config tegra234-mb1-bct-device-p3701-0000.dts --misc_config tegra234-mb1-bct-misc-p3701-0000.dts --pinmux_config tegra234-mb1-bct-pinmux-p3701-0000-a04.dtsi --gpioint_config tegra234-mb1-bct-gpioint-p3701-0000.dts --pmic_config tegra234-mb1-bct-pmic-p3701-0005.dts --pmc_config tegra234-mb1-bct-padvoltage-p3701-0000-a04.dtsi --deviceprod_config tegra234-mb1-bct-cprod-p3701-0000.dts --prod_config tegra234-mb1-bct-prod-p3701-0000.dts --scr_config tegra234-mb2-bct-scr-p3701-0000.dts --wb0sdram_config tegra234-p3701-0005-wb0sdram-l4t.dts --br_cmd_config tegra234-mb1-bct-reset-p3701-0000.dts --uphy tegra234-mb1-bct-uphylane-si.dtsi --dev_params tegra234-br-bct-p3701-0000.dts,tegra234-br-bct_b-p3701-0000.dts --mb2bct_cfg tegra234-mb2-bct-misc-p3701-0000.dts  --bins "psc_fw pscfw_t234_prod.bin; mts_mce mce_flash_o10_cr_prod.bin; tsec_fw tsec_t234.bin; mb2_applet applet_t234.bin; mb2_bootloader mb2_t234.bin; xusb_fw xusb_t234_prod.bin; pva_fw nvpva_020.fw; dce_fw display-t234-dce.bin; nvdec nvdec_t234_prod.fw; bpmp_fw bpmp_t234-TE990M-A1_prod.bin; bpmp_fw_dtb tegra234-bpmp-3701-0005-3737-0000.dtb; rce_fw camera-rtcpu-t234-rce.img; ape_fw adsp-fw.bin; spe_fw spe_t234.bin; tos tos-optee_t234.img; eks eks_t234.img"  --sdram_config tegra234-p3701-0005-sdram-l4t.dts  --cust_info custinfo_out.bin  --bct_backup  --boot_chain A
saving flash command in /home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/mogo/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/flash_win.bat
*** Flashing target device started. ***
version 1.0.0
[   0.0267 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0268 ] Assuming zero filled SBK key
[   0.0261 ] Parsing partition layout
[   0.0272 ] tegraparser_v2 --pt flash.xml.tmp
[   0.0335 ] Change tegra234-bpmp-3701-0005-3737-0000.dtb to tegra234-bpmp-3701-0005-3737-0000_with_odm.dtb
[   0.0336 ] Change tegra234-bpmp-3701-0005-3737-0000.dtb to tegra234-bpmp-3701-0005-3737-0000_with_odm.dtb
[   0.0879 ] /usr/bin/python3 dtbcheck.py -c t234 -o tegra234-bpmp-3701-0005-3737-0000_with_odm.dtb tegra234-bpmp-3701-0005-3737-0000_with_odm_tmp.dtb
[   0.3760 ] Concatenating L4TConfiguration.dtbo,tegra234-p3737-0000+p3701-0000-dynamic.dtbo,tegra234-carveouts.dtbo,tegra-optee.dtbo,tegra234-p3737-camera-dual-imx274-overlay.dtbo,tegra234-p3737-camera-e3331-overlay.dtbo,tegra234-p3737-camera-e3333-overlay.dtbo,tegra234-p3737-camera-imx185-overlay.dtbo to tegra234-p3737-0000+p3701-0005-nv_with_odm_overlay.dtb.updated
[   0.3765 ] Concatenating bl dtb to cpubl binary
[   0.3801 ] MB2 binary: mb2_t234.bin
[   0.3802 ] Pre-processing mb2bct config: tegra234-mb2-bct-misc-p3701-0000.dts
[   0.3920 ] Pre-processing mb2bct config: tegra234-mb2-bct-scr-p3701-0000.dts
[   0.7920 ] Generating coldboot mb2-bct
[   0.7921 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_cold_boot_bct.cfg --mb2bctcfg tegra234-mb2-bct-misc-p3701-0000_cpp.dtb --scr tegra234-mb2-bct-scr-p3701-0000_cpp.dtb
[   0.7932 ] ERROR: value 0x31 is out of range
[   0.7943 ] ERROR: value 0x31 is out of range
[   0.7946 ] ERROR: value 0x31 is out of range
[   0.7948 ] ERROR: value 0x31 is out of range
[   0.7951 ] WARNING: unknown property 'tfc_version'
[   0.7954 ] WARNING: unknown property 'addr_header_version'
[   0.8063 ] Updating mb2-bct with storage information
[   0.8075 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_cold_boot_bct_MB2.bct --updatestorageinfo flash.xml.bin
[   0.8128 ] Concatenating mb2-bct to mb2 binary
[   0.8128 ] mb2_bin_file = mb2_t234.bin
[   0.8128 ] mb2_bct_file = mb2_cold_boot_bct_MB2.bct
[   0.8167 ] DCE binary: display-t234-dce.bin
[   0.8168 ] Kernel DTB used: kernel_tegra234-p3737-0000+p3701-0005-nv.dtb
[   0.8168 ] Concatenating kernel-dtb to dce-fw binary
[   0.8168 ] dce_bin = display-t234-dce.bin
[   0.8168 ] kernel_dtb = kernel_tegra234-p3737-0000+p3701-0005-nv.dtb
[   0.8168 ] dce_with_dtb = display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0005-nv.bin
[   0.8250 ] Update display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0005-nv.bin to dce_fw partitions
[   0.8278 ] Parsing partition layout
[   0.8292 ] tegraparser_v2 --pt flash.xml.tmp
[   0.8310 ] Creating list of images to be signed
[   0.8322 ] Generating ratchet blob
[   0.8322 ] Pre-processing config: tegra234-mb1-bct-reset-p3701-0000.dts
[   0.8393 ] Pre-processing config: tegra234-mb1-bct-device-p3701-0000.dts
[   0.8464 ] Pre-processing config: tegra234-mb1-bct-cprod-p3701-0000.dts
[   0.8535 ] Pre-processing config: tegra234-mb1-bct-gpioint-p3701-0000.dts
[   0.8614 ] Pre-processing config: tegra234-mb1-bct-misc-p3701-0000.dts
[   0.8719 ] Pre-processing config: tegra234-mb1-bct-pinmux-p3701-0000-a04.dtsi
[   0.8850 ] Pre-processing config: tegra234-mb1-bct-padvoltage-p3701-0000-a04.dtsi
[   0.8922 ] Pre-processing config: tegra234-mb1-bct-pmic-p3701-0005.dts
[   0.8999 ] Pre-processing config: tegra234-mb1-bct-prod-p3701-0000.dts
[   0.9070 ] Pre-processing config: tegra234-p3701-0005-sdram-l4t.dts
[   2.0874 ] Pre-processing config: tegra234-mb1-bct-uphylane-si.dtsi
[   2.0948 ] Pre-processing config: tegra234-p3701-0005-wb0sdram-l4t.dts
[   3.2758 ] Pre-processing config: tegra234-mb1-bct-ratchet-p3701-0000.dts
[   3.2833 ] Generating coldboot mb1-bct
[   3.2845 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --wb0sdram tegra234-p3701-0005-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3701-0000-a04_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3701-0000-a04_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3701-0005_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3701-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3701-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3701-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[   3.2857 ] MB1-BCT version: 0.13
[   3.2873 ] Parsing config file :tegra234-mb1-bct-pinmux-p3701-0000-a04_cpp.dtb
[   3.2878 ] Added Platform Config 0 data with size :- 2936
[   3.2903 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3701-0000-a04_cpp.dtb
[   3.2910 ] WARNING: unknown node 'g2'
[   3.2910 ] WARNING: unknown node 'g9'
[   3.2910 ] Added Platform Config 2 data with size :- 24
[   3.2910 ]
[   3.2910 ] Parsing config file :tegra234-mb1-bct-pmic-p3701-0005_cpp.dtb
[   3.2910 ] Added Platform Config 4 data with size :- 580
[   3.2910 ]
[   3.2910 ] Parsing config file :tegra234-mb1-bct-reset-p3701-0000_cpp.dtb
[   3.2910 ] Added Platform Config 3 data with size :- 52
[   3.2910 ]
[   3.2910 ] Parsing config file :tegra234-mb1-bct-prod-p3701-0000_cpp.dtb
[   3.2910 ] WARNING: unknown property 'major'
[   3.2910 ] WARNING: unknown property 'minor'
[   3.2910 ] Added Platform Config 5 data with size :- 524
[   3.2911 ]
[   3.2911 ] Parsing config file :tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb
[   3.2911 ] WARNING: unknown property 'major'
[   3.2911 ] WARNING: unknown property 'minor'
[   3.2911 ] Added Platform Config 7 data with size :- 380
[   3.2911 ]
[   3.2911 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[   3.2911 ] Added Platform Config 8 data with size :- 24
[   3.2911 ]
[   3.2911 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   3.2911 ] Added Platform Config 9 data with size :- 100
[   3.2911 ]
[   3.2911 ] Parsing config file :tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb
[   3.2911 ] ModuleCount 0 NumProdNames 0
[   3.2911 ] Added Platform Config 6 data with size :- 16
[   3.2911 ]
[   3.2911 ] Parsing config file :tegra234-mb1-bct-ratchet-p3701-0000_cpp.dtb
[   3.2911 ]
[   3.2912 ] Updating mb1-bct with firmware information
[   3.2924 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[   3.2990 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   3.3002 ] Generating SHA2 Hash for mb1bct
[   3.3029 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[   3.3047 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[   3.3051 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   3.3062 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   3.3080 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   3.3083 ] Assuming zero filled SBK key
[   3.3105 ] Warning: pub_key.key is not found
[   3.3110 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   3.3128 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --ratchet_blob ratchet_blob.bin --list images_list.xml zerosbk
[   3.3138 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   3.3148 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   3.3151 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   3.3198 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   3.3201 ] Header already present for tsec_t234_aligned.bin
[   3.3221 ] Header already present for nvdec_t234_prod_aligned.fw
[   3.3254 ] adding BCH for mb2_t234_with_mb2_cold_boot_bct_MB2_aligned.bin
[   3.3312 ] adding BCH for xusb_t234_prod_aligned.bin
[   3.3447 ] Header already present for bpmp_t234-TE990M-A1_prod_aligned.bin
[   3.3522 ] adding BCH for tegra234-bpmp-3701-0005-3737-0000_with_odm_aligned.dtb
[   3.3684 ] Header already present for pscfw_t234_prod_aligned.bin
[   3.3767 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[   3.3818 ] Header already present for sc7_t234_prod.bin
[   3.3848 ] Header already present for psc_rf_t234_prod_aligned.bin
[   3.3880 ] adding BCH for mb2rf_t234_aligned.bin
[   3.3900 ] INFO: compressing uefi_jetson_with_dtb_aligned.bin
[   3.4566 ] INFO: complete compression, uefi_jetson_with_dtb_aligned.bin, ratio = 89%
[   3.4634 ] adding BCH for uefi_jetson_with_dtb_aligned_blob_w_bin_aligned.bin
[   3.5227 ] adding BCH for tos-optee_t234_aligned.img
[   3.5793 ] adding BCH for eks_t234_aligned.img
[   3.6298 ] INFO: compressing display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0005-nv_aligned.bin
[   3.8377 ] INFO: complete compression, display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0005-nv_aligned.bin, ratio = 6%
[   3.8611 ] adding BCH for display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0005-nv_aligned_blob_w_bin_aligned.bin
[   3.8813 ] adding BCH for spe_t234_aligned.bin
[   3.8939 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[   3.9027 ] adding BCH for adsp-fw_aligned.bin
[   3.9174 ] INFO: compressing nvpva_020_aligned.fw
[   3.9670 ] INFO: complete compression, nvpva_020_aligned.fw, ratio = 2%
[   3.9702 ] adding BCH for nvpva_020_aligned_blob_w_bin_aligned.fw
[   3.9724 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   3.9741 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   3.9744 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   3.9791 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   3.9794 ] Header already present for tsec_t234_aligned.bin
[   3.9816 ] Header already present for nvdec_t234_prod_aligned.fw
[   3.9848 ] adding BCH for mb2_t234_with_mb2_cold_boot_bct_MB2_aligned.bin
[   3.9906 ] adding BCH for xusb_t234_prod_aligned.bin
[   4.0044 ] Header already present for bpmp_t234-TE990M-A1_prod_aligned.bin
[   4.0121 ] adding BCH for tegra234-bpmp-3701-0005-3737-0000_with_odm_aligned.dtb
[   4.0288 ] Header already present for pscfw_t234_prod_aligned.bin
[   4.0374 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[   4.0425 ] Header already present for sc7_t234_prod.bin
[   4.0457 ] Header already present for psc_rf_t234_prod_aligned.bin
[   4.0490 ] adding BCH for mb2rf_t234_aligned.bin
[   4.0511 ] INFO: compressing uefi_jetson_with_dtb_aligned.bin
[   4.1188 ] INFO: complete compression, uefi_jetson_with_dtb_aligned.bin, ratio = 89%
[   4.1256 ] adding BCH for uefi_jetson_with_dtb_aligned_blob_w_bin_aligned.bin
[   4.1869 ] adding BCH for tos-optee_t234_aligned.img
[   4.2450 ] adding BCH for eks_t234_aligned.img
[   4.2979 ] INFO: compressing display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0005-nv_aligned.bin
[   4.5292 ] INFO: complete compression, display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0005-nv_aligned.bin, ratio = 6%
[   4.5527 ] adding BCH for display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0005-nv_aligned_blob_w_bin_aligned.bin
[   4.5734 ] adding BCH for spe_t234_aligned.bin
[   4.5861 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[   4.5954 ] adding BCH for adsp-fw_aligned.bin
[   4.6105 ] INFO: compressing nvpva_020_aligned.fw
[   4.6608 ] INFO: complete compression, nvpva_020_aligned.fw, ratio = 2%
[   4.6642 ] adding BCH for nvpva_020_aligned_blob_w_bin_aligned.fw
[   4.6675 ] Filling MB1 storage info
[   4.6676 ] Parsing dev params for multi chains
[   4.6752 ] Generating br-bct
[   4.6763 ] Updating dev and MSS params in BR BCT
[   4.6764 ] tegrabct_v2 --dev_param tegra234-br-bct-p3701-0000_cpp.dtb --sdram tegra234-p3701-0005-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   4.8425 ] Updating bl info
[   4.8437 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin
[   4.8562 ] Generating br-bct
[   4.8573 ] Updating dev and MSS params in BR BCT
[   4.8574 ] tegrabct_v2 --dev_param tegra234-br-bct_b-p3701-0000_cpp.dtb --sdram tegra234-p3701-0005-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   5.0240 ] Updating bl info
[   5.0252 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin
[   5.0306 ] Generating BCT backup image
[   5.0307 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[   5.0335 ] 32768+0 records in
[   5.1174 ] 32768+0 records out
[   5.1174 ] 32768 bytes (33 kB, 32 KiB) copied, 0.0831147 s, 394 kB/s
[   5.1174 ]
[   5.1174 ] Concatenating BCT for chain A to bct_backup.img
[   5.1175 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[   5.1187 ] 8192+0 records in
[   5.1342 ] 8192+0 records out
[   5.1342 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.0151176 s, 542 kB/s
[   5.1342 ]
[   5.1343 ] Concatenating BCT for chain B to bct_backup.img
[   5.1343 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[   5.1355 ] 8192+0 records in
[   5.1510 ] 8192+0 records out
[   5.1510 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.015121 s, 542 kB/s
[   5.1511 ]
[   5.1511 ] Generating signatures
[   5.1520 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[   5.1523 ] Assuming zero filled SBK key
[   5.2768 ] Warning: pub_key.key is not found
[   5.2789 ] Parsing dev params for multi chains
[   5.2790 ] Generating br-bct
[   5.2802 ] Updating dev and MSS params in BR BCT
[   5.2803 ] tegrabct_v2 --dev_param tegra234-br-bct-p3701-0000_cpp.dtb --sdram tegra234-p3701-0005-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   5.4467 ] Updating customer data section
[   5.4480 ] tegrabct_v2 --chip 0x23 0 --brbct br_bct_BR.bct --update_custinfo custinfo_out.bin
[   5.4507 ] Updating bl info
[   5.4520 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[   5.4548 ] Generating SHA2 Hash
[   5.4575 ] Sha saved in br_bct_BR.sha
[   5.4568 ] Get Signed section of bct
[   5.4581 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   5.4595 ] Signing BCT
[   5.4605 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   5.4607 ] Assuming zero filled SBK key
[   5.4645 ] Sha saved in br_bct_BR.sha
[   5.4649 ] Warning: pub_key.key is not found
[   5.4641 ] Updating BCT with signature
[   5.4654 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   5.4665 ] Offset :4608 Len :3584
[   5.4669 ] Generating SHA2 Hash
[   5.4678 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   5.4680 ] Assuming zero filled SBK key
[   5.4681 ] Assuming zero filled SBK key
[   5.4719 ] Sha saved in br_bct_BR.sha
[   5.4715 ] Updating BCT with SHA2 Hash
[   5.4727 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[   5.4739 ] Offset :4608 Len :3584
[   5.4743 ] Offset :68 Len :8124
[   5.4743 ]
[   5.4744 ] Generating br-bct
[   5.4757 ] Updating dev and MSS params in BR BCT
[   5.4758 ] tegrabct_v2 --dev_param tegra234-br-bct_b-p3701-0000_cpp.dtb --sdram tegra234-p3701-0005-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   5.6421 ] Updating customer data section
[   5.6434 ] tegrabct_v2 --chip 0x23 0 --brbct br_bct_BR.bct --update_custinfo custinfo_out.bin
[   5.6486 ] Updating bl info
[   5.6499 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[   5.6525 ] Generating SHA2 Hash
[   5.6552 ] Sha saved in br_bct_BR.sha
[   5.6545 ] Get Signed section of bct
[   5.6557 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   5.6571 ] Signing BCT
[   5.6581 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   5.6583 ] Assuming zero filled SBK key
[   5.6622 ] Sha saved in br_bct_BR.sha
[   5.6627 ] Warning: pub_key.key is not found
[   5.6619 ] Updating BCT with signature
[   5.6632 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   5.6644 ] Offset :4608 Len :3584
[   5.6647 ] Generating SHA2 Hash
[   5.6657 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   5.6659 ] Assuming zero filled SBK key
[   5.6660 ] Assuming zero filled SBK key
[   5.6700 ] Sha saved in br_bct_BR.sha
[   5.6696 ] Updating BCT with SHA2 Hash
[   5.6708 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[   5.6720 ] Offset :4608 Len :3584
[   5.6723 ] Offset :68 Len :8124
[   5.6723 ]
[   5.6724 ] Generating BCT backup image
[   5.6725 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[   5.6739 ] 32768+0 records in
[   5.7518 ] 32768+0 records out
[   5.7518 ] 32768 bytes (33 kB, 32 KiB) copied, 0.0774872 s, 423 kB/s
[   5.7518 ]
[   5.7518 ] Concatenating BCT for chain A to bct_backup.img
[   5.7518 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[   5.7531 ] 8192+0 records in
[   5.7686 ] 8192+0 records out
[   5.7686 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.0150607 s, 544 kB/s
[   5.7686 ]
[   5.7687 ] Concatenating BCT for chain B to bct_backup.img
[   5.7687 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[   5.7699 ] 8192+0 records in
[   5.7855 ] 8192+0 records out
[   5.7855 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.0151479 s, 541 kB/s
[   5.7855 ]
[   5.7856 ] Generating coldboot mb1-bct
[   5.7868 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --wb0sdram tegra234-p3701-0005-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3701-0000-a04_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3701-0000-a04_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3701-0005_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3701-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3701-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3701-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[   5.7880 ] MB1-BCT version: 0.13
[   5.7896 ] Parsing config file :tegra234-mb1-bct-pinmux-p3701-0000-a04_cpp.dtb
[   5.7901 ] Added Platform Config 0 data with size :- 2936
[   5.7926 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3701-0000-a04_cpp.dtb
[   5.7930 ] WARNING: unknown node 'g2'
[   5.7930 ] WARNING: unknown node 'g9'
[   5.7930 ] Added Platform Config 2 data with size :- 24
[   5.7930 ]
[   5.7930 ] Parsing config file :tegra234-mb1-bct-pmic-p3701-0005_cpp.dtb
[   5.7930 ] Added Platform Config 4 data with size :- 580
[   5.7930 ]
[   5.7930 ] Parsing config file :tegra234-mb1-bct-reset-p3701-0000_cpp.dtb
[   5.7930 ] Added Platform Config 3 data with size :- 52
[   5.7930 ]
[   5.7930 ] Parsing config file :tegra234-mb1-bct-prod-p3701-0000_cpp.dtb
[   5.7930 ] WARNING: unknown property 'major'
[   5.7930 ] WARNING: unknown property 'minor'
[   5.7930 ] Added Platform Config 5 data with size :- 524
[   5.7931 ]
[   5.7931 ] Parsing config file :tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb
[   5.7931 ] WARNING: unknown property 'major'
[   5.7931 ] WARNING: unknown property 'minor'
[   5.7931 ] Added Platform Config 7 data with size :- 380
[   5.7931 ]
[   5.7931 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[   5.7931 ] Added Platform Config 8 data with size :- 24
[   5.7931 ]
[   5.7931 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   5.7931 ] Added Platform Config 9 data with size :- 100
[   5.7931 ]
[   5.7931 ] Parsing config file :tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb
[   5.7931 ] ModuleCount 0 NumProdNames 0
[   5.7931 ] Added Platform Config 6 data with size :- 16
[   5.7931 ]
[   5.7931 ] Parsing config file :tegra234-mb1-bct-ratchet-p3701-0000_cpp.dtb
[   5.7932 ]
[   5.7932 ] Updating mb1-bct with firmware information
[   5.7945 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[   5.7975 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   5.7987 ] Generating SHA2 Hash for mb1bct
[   5.8015 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[   5.8034 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[   5.8039 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   5.8050 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   5.8070 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   5.8072 ] Assuming zero filled SBK key
[   5.8095 ] Warning: pub_key.key is not found
[   5.8101 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   5.8119 ] Generating recovery mb1-bct
[   5.8132 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --wb0sdram tegra234-p3701-0005-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3701-0000-a04_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3701-0000-a04_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3701-0005_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3701-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3701-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3701-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[   5.8144 ] MB1-BCT version: 0.13
[   5.8161 ] Parsing config file :tegra234-mb1-bct-pinmux-p3701-0000-a04_cpp.dtb
[   5.8165 ] Added Platform Config 0 data with size :- 2936
[   5.8189 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3701-0000-a04_cpp.dtb
[   5.8194 ] WARNING: unknown node 'g2'
[   5.8195 ] WARNING: unknown node 'g9'
[   5.8195 ] Added Platform Config 2 data with size :- 24
[   5.8195 ]
[   5.8195 ] Parsing config file :tegra234-mb1-bct-pmic-p3701-0005_cpp.dtb
[   5.8195 ] Added Platform Config 4 data with size :- 580
[   5.8195 ]
[   5.8195 ] Parsing config file :tegra234-mb1-bct-reset-p3701-0000_cpp.dtb
[   5.8195 ] Added Platform Config 3 data with size :- 52
[   5.8195 ]
[   5.8195 ] Parsing config file :tegra234-mb1-bct-prod-p3701-0000_cpp.dtb
[   5.8195 ] WARNING: unknown property 'major'
[   5.8195 ] WARNING: unknown property 'minor'
[   5.8195 ] Added Platform Config 5 data with size :- 524
[   5.8195 ]
[   5.8195 ] Parsing config file :tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb
[   5.8195 ] Added Platform Config 7 data with size :- 380
[   5.8195 ]
[   5.8195 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[   5.8195 ] Added Platform Config 8 data with size :- 24
[   5.8196 ]
[   5.8196 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   5.8196 ] Added Platform Config 9 data with size :- 100
[   5.8196 ]
[   5.8196 ] Parsing config file :tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb
[   5.8196 ] ModuleCount 0 NumProdNames 0
[   5.8196 ] Added Platform Config 6 data with size :- 16
[   5.8196 ]
[   5.8196 ] Parsing config file :tegra234-mb1-bct-ratchet-p3701-0000_cpp.dtb
[   5.8196 ]
[   5.8197 ] Updating mb1-bct with firmware information
[   5.8209 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo flash.xml.bin
[   5.8238 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[   5.8251 ] Generating SHA2 Hash for mb1bct
[   5.8279 ] Sha saved in mb1_bct_MB1_aligned.sha
[   5.8298 ] Sha saved in mb1_bct_MB1.sha
[   5.8303 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[   5.8314 ] adding BCH for mb1_bct_MB1_aligned.bct
[   5.8333 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   5.8335 ] Assuming zero filled SBK key
[   5.8359 ] Warning: pub_key.key is not found
[   5.8365 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   5.8383 ] Generating coldboot mem-bct
[   5.8396 ] tegrabct_v2 --chip 0x23 0 --sdram tegra234-p3701-0005-sdram-l4t_cpp.dtb --wb0sdram tegra234-p3701-0005-wb0sdram-l4t_cpp.dtb --membct tegra234-p3701-0005-sdram-l4t_cpp_1.bct tegra234-p3701-0005-sdram-l4t_cpp_2.bct tegra234-p3701-0005-sdram-l4t_cpp_3.bct tegra234-p3701-0005-sdram-l4t_cpp_4.bct
[   5.8407 ]  packing sdram params with Wb0 file tegra234-p3701-0005-wb0sdram-l4t_cpp.dtb
[   6.0063 ] Packing sdram param for instance[0]
[   6.0066 ] Packing sdram param for instance[1]
[   6.0069 ] Packing sdram param for instance[2]
[   6.0071 ] Packing sdram param for instance[3]
[   6.0074 ] Packing sdram param for instance[4]
[   6.0077 ] Packing sdram param for instance[5]
[   6.0079 ] Packing sdram param for instance[6]
[   6.0082 ] Packing sdram param for instance[7]
[   6.0085 ] Packing sdram param for instance[8]
[   6.0088 ] Packing sdram param for instance[9]
[   6.0091 ] Packing sdram param for instance[10]
[   6.0094 ] Packing sdram param for instance[11]
[   6.0097 ] Packing sdram param for instance[12]
[   6.0100 ] Packing sdram param for instance[13]
[   6.0102 ] Packing sdram param for instance[14]
[   6.0105 ] Packing sdram param for instance[15]
[   6.1715 ] Getting sector size from pt
[   6.1729 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[   6.1742 ] BlockSize read from layout is 0x200
[   6.1755 ] tegrahost_v2 --chip 0x23 0 --blocksize 512 --magicid MEMB --addsigheader_multi tegra234-p3701-0005-sdram-l4t_cpp_1.bct tegra234-p3701-0005-sdram-l4t_cpp_2.bct tegra234-p3701-0005-sdram-l4t_cpp_3.bct tegra234-p3701-0005-sdram-l4t_cpp_4.bct
[   6.1766 ] Binary 0 length is 58752
[   6.1768 ] Binary 0 align length is 58880
[   6.1778 ] Binary 1 length is 58752
[   6.1779 ] Binary 1 align length is 58880
[   6.1786 ] Binary 2 length is 58752
[   6.1788 ] Binary 2 align length is 58880
[   6.1796 ] Binary 3 length is 58752
[   6.1798 ] Binary 3 align length is 58880
[   6.1805 ] Buffer length is 235520
[   6.1807 ] adding BCH for tegra234-p3701-0005-sdram-l4t_cpp_1.bct
[   6.1809 ] new length is 243712
[   6.1809 ]
[   6.1825 ] tegrahost_v2 --chip 0x23 0 --align mem_coldboot_aligned.bct
[   6.1851 ] tegrahost_v2 --chip 0x23 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_coldboot_aligned.bct zerosbk
[   6.1862 ] Header already present for mem_coldboot_aligned.bct
[   6.1880 ] tegrasign_v3.py --key None --list mem_coldboot_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   6.1883 ] Assuming zero filled SBK key
[   6.1910 ] Warning: pub_key.key is not found
[   6.1916 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_coldboot_aligned_sigheader.bct.encrypt mem_coldboot_aligned_sigheader.bct.hash zerosbk
[   6.1939 ] Generating recovery mem-bct
[   6.1951 ] tegrabct_v2 --chip 0x23 0 --sdram tegra234-p3701-0005-sdram-l4t_cpp.dtb --wb0sdram tegra234-p3701-0005-wb0sdram-l4t_cpp.dtb --membct tegra234-p3701-0005-sdram-l4t_cpp_1.bct tegra234-p3701-0005-sdram-l4t_cpp_2.bct tegra234-p3701-0005-sdram-l4t_cpp_3.bct tegra234-p3701-0005-sdram-l4t_cpp_4.bct
[   6.1963 ]  packing sdram params with Wb0 file tegra234-p3701-0005-wb0sdram-l4t_cpp.dtb
[   6.3618 ] Packing sdram param for instance[0]
[   6.3620 ] Packing sdram param for instance[1]
[   6.3623 ] Packing sdram param for instance[2]
[   6.3625 ] Packing sdram param for instance[3]
[   6.3628 ] Packing sdram param for instance[4]
[   6.3631 ] Packing sdram param for instance[5]
[   6.3634 ] Packing sdram param for instance[6]
[   6.3637 ] Packing sdram param for instance[7]
[   6.3639 ] Packing sdram param for instance[8]
[   6.3642 ] Packing sdram param for instance[9]
[   6.3645 ] Packing sdram param for instance[10]
[   6.3648 ] Packing sdram param for instance[11]
[   6.3651 ] Packing sdram param for instance[12]
[   6.3654 ] Packing sdram param for instance[13]
[   6.3657 ] Packing sdram param for instance[14]
[   6.3660 ] Packing sdram param for instance[15]
[   6.5275 ] Reading ramcode from backup chip_info.bin file
[   6.5275 ] RAMCODE Read from Device: 3
[   6.5276 ] Using ramcode 0
[   6.5276 ] Disabled BPMP dtb trim, using default dtb
[   6.5276 ]
[   6.5292 ] tegrahost_v2 --chip 0x23 0 --align mem_rcm_aligned.bct
[   6.5318 ] tegrahost_v2 --chip 0x23 0 --magicid MEM0 --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_aligned.bct zerosbk
[   6.5329 ] adding BCH for mem_rcm_aligned.bct
[   6.5363 ] tegrasign_v3.py --key None --list mem_rcm_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   6.5366 ] Assuming zero filled SBK key
[   6.5391 ] Warning: pub_key.key is not found
[   6.5397 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_rcm_aligned_sigheader.bct.encrypt mem_rcm_aligned_sigheader.bct.hash zerosbk
[   6.5416 ] Copying signatures
[   6.5429 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[   6.5958 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[   6.5965 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[   6.5965 ] Boot Rom communication
[   6.5979 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
Error: Return value 8
Command tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
Failed flashing generic.
请问这块是否可以RMA?
能請你不論何時燒錄的時候都附上uart log + host端log兩者一起嗎?
然後麻煩全部附成文字檔 不要用複製貼上
ok,log如下
flashlog.txt (55.5 KB)
uartlog.txt (2.7 KB)
hello,有进展吗
經過內部確認. 如果這是當一module+ devkit個案 應該是硬體問題
請RMA這塊device.
好的,谢谢
hello,能告知这是哪里的问题吗?因为我们这个devkit使用时间比较久,不在售后期内了,和我们国内的代理沟通后说没有办法RMA,有什么解决办法吗?
