“Reading board information failed” when emulating back to default configuration Jetson Orin AGX
I have a Jetson AGX Orin Devkit 32GB and I successfully emulated it to AGX Orin Nano. Here is the current info:
NVIDIA Jetson AGX Orin as Nano 8GB
 L4T 35.1.0 [ JetPack 5.0.2 ]
   Ubuntu 20.04.4 LTS
   Kernel Version: 5.10.104-tegra
 CUDA 11.4.239
   CUDA Architecture: 8.7
 OpenCV version: 4.5.4
   OpenCV Cuda: NO
 CUDNN: 8.6.0.166
 TensorRT: 8.5.2.2
 Vision Works: NOT_INSTALLED
 VPI: 2.4.8
 Vulcan: 1.3.203
I tried to flash and reinstall Jetpack using the SDK Manager; however, it’s still the same. I attempted to revert back to normal by following similar steps, but when I tried these commands:
sudo ./flash.sh jetson-agx-orin-devkit mmcblk0p1
sudo ./flash.sh jetson-agx-orin-devkit-as-nx-16gb mmcblk0p1
This error is showed.
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[   0.0093 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.0110 ] File rcm_state open failed
[   0.0113 ] ERROR: failed to read rcm_state
[   0.0113 ]
[   0.0124 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0126 ] Assuming zero filled SBK key
[   0.0117 ] Pre-processing config: tegra234-mb1-bct-device-p3701-0000.dts
[   0.0242 ] Pre-processing config: tegra234-mb1-bct-misc-p3701-0000.dts
[   0.0436 ] Parsing partition layout
[   0.0458 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.0497 ] Parsing partition layout
[   0.0518 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.0545 ] Creating list of images to be signed
[   0.0566 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[   0.0588 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.0604 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.0610 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.0726 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.0731 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.0834 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.0839 ] adding BCH for mb2_t234_aligned.bin
[   0.0894 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.1124 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.1130 ] adding BCH for mb2_t234_aligned.bin
[   0.1332 ] Generating signatures
[   0.1343 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.1347 ] Assuming zero filled SBK key
[   0.1593 ] Warning: pub_key.key is not found
[   0.1589 ] Parsing dev params for multi chains
[   0.1725 ] Generating br-bct
[   0.1745 ] Updating dev and MSS params in BR BCT
[   0.1747 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   0.1774 ] Updating bl info
[   0.1794 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.1817 ] WARNING: boot chain is not completed. set to 0
[   0.1832 ] Get Signed section of bct
[   0.1852 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   0.1880 ] Signing BCT
[   0.1891 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.1894 ] Assuming zero filled SBK key
[   0.1955 ] Sha saved in br_bct_BR.sha
[   0.1962 ] Warning: pub_key.key is not found
[   0.1953 ] Updating BCT with signature
[   0.1974 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   0.1995 ] Offset :4608 Len :3584
[   0.2002 ] Generating SHA2 Hash
[   0.2013 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   0.2017 ] Assuming zero filled SBK key
[   0.2077 ] Sha saved in br_bct_BR.sha
[   0.2074 ] Updating BCT with SHA2 Hash
[   0.2094 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[   0.2115 ] Offset :4608 Len :3584
[   0.2120 ] Offset :68 Len :8124
[   0.2125 ] Generating coldboot mb1-bct
[   0.2145 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   0.2166 ] MB1-BCT version: 0.9
[   0.2208 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   0.2213 ] Added Platform Config 9 data with size :- 80
[   0.2213 ]
[   0.2214 ] Updating mb1-bct with firmware information
[   0.2233 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.2285 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   0.2328 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   0.2348 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   0.2376 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.2380 ] Assuming zero filled SBK key
[   0.2416 ] Warning: pub_key.key is not found
[   0.2429 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.2463 ] Generating recovery mb1-bct
[   0.2484 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   0.2506 ] MB1-BCT version: 0.9
[   0.2548 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   0.2552 ] Added Platform Config 9 data with size :- 80
[   0.2552 ]
[   0.2553 ] Updating mb1-bct with firmware information
[   0.2575 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.2627 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[   0.2669 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[   0.2689 ] adding BCH for mb1_bct_MB1_aligned.bct
[   0.2717 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.2720 ] Assuming zero filled SBK key
[   0.2757 ] Warning: pub_key.key is not found
[   0.2770 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.2803 ] Error: Skip generating mem_bct because sdram_config is not defined
[   0.2803 ] Copying signatures
[   0.2824 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.2940 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[   0.2944 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[   0.2944 ] Boot Rom communication
[   0.2964 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[   0.2985 ] BR_CID: 0x80012344705DD3C5240000000E0201C0
[   0.4257 ] Sending bct_br
[   0.5529 ] ERROR: might be timeout in USB write.
Error: Return value 3
Command tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
Reading board information failed.
I would really appreciate it if anyone knows how to revert back to the default configuration.
Here is the sdkmanager flash error message when I tried to flash by SDKManager. Is there anything else I should provide?
17:25:02 SUMMARY: CUDA on Host - host: Install completed successfully.
17:25:02 SUMMARY: CUDA Cross Compile Package on Host - host: Install completed successfully.
17:25:02 SUMMARY: NvSci - host: Install completed successfully.
17:25:02 SUMMARY: VPI on Host - host: Install completed successfully.
17:25:02 SUMMARY: Nsight Systems - host: Install completed successfully.
17:25:02 SUMMARY: Nsight Graphics - host: Install completed successfully.
17:25:02 SUMMARY: Nsight Compute - host: Install completed successfully.
17:25:02 SUMMARY: Nsight Perf SDK - host: Install completed successfully.
17:25:02 SUMMARY: Drivers for Jetson - target_image: Install completed successfully.
17:25:02 SUMMARY: File System and OS - target_image: Install completed successfully.
17:25:15 ERROR: Flash Jetson Linux - flash: [ 0.0243 ] ERROR: failed to read rcm_state
17:25:15 ERROR: Flash Jetson Linux - flash: [ 0.2472 ] ERROR: /misc/enable_dram_page_blacklisting is not supported
17:25:15 ERROR: Flash Jetson Linux - flash: [ 0.2475 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
17:25:15 ERROR: Flash Jetson Linux - flash: [ 0.2481 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
17:25:15 ERROR: Flash Jetson Linux - flash: [ 0.2485 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
17:25:15 ERROR: Flash Jetson Linux - flash: [ 0.2490 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
17:25:15 ERROR: Flash Jetson Linux - flash: [ 0.2495 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
17:25:15 ERROR: Flash Jetson Linux - flash: [ 0.2499 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
17:25:15 ERROR: Flash Jetson Linux - flash: [ 0.2503 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
17:25:15 ERROR: Flash Jetson Linux - flash: [ 0.2507 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
17:25:15 ERROR: Flash Jetson Linux - flash: [ 0.2511 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
17:25:15 ERROR: Flash Jetson Linux - flash: [ 0.2515 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
17:25:15 ERROR: Flash Jetson Linux - flash: [ 0.2519 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
17:25:15 ERROR: Flash Jetson Linux - flash: [ 0.2523 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
17:25:15 ERROR: Flash Jetson Linux - flash: [ 0.2527 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
17:25:15 ERROR: Flash Jetson Linux - flash: [ 0.2527 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
17:25:15 ERROR: Flash Jetson Linux - flash: [ 0.2878 ] ERROR: /misc/enable_dram_page_blacklisting is not supported
17:25:15 ERROR: Flash Jetson Linux - flash: [ 0.2881 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
17:25:15 ERROR: Flash Jetson Linux - flash: [ 0.2887 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
17:25:15 ERROR: Flash Jetson Linux - flash: [ 0.2891 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
17:25:15 ERROR: Flash Jetson Linux - flash: [ 0.2895 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
17:25:15 ERROR: Flash Jetson Linux - flash: [ 0.2900 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
17:25:15 ERROR: Flash Jetson Linux - flash: [ 0.2904 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
17:25:15 ERROR: Flash Jetson Linux - flash: [ 0.2908 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
17:25:15 ERROR: Flash Jetson Linux - flash: [ 0.2912 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
17:25:15 ERROR: Flash Jetson Linux - flash: [ 0.2916 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
17:25:15 ERROR: Flash Jetson Linux - flash: [ 0.2920 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
17:25:15 ERROR: Flash Jetson Linux - flash: [ 0.2924 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
17:25:15 ERROR: Flash Jetson Linux - flash: [ 0.2928 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
17:25:15 ERROR: Flash Jetson Linux - flash: [ 0.2932 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
17:25:15 ERROR: Flash Jetson Linux - flash: [ 0.2932 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
17:25:16 ERROR: Flash Jetson Linux - flash: [ 0.3240 ] Error: Skip generating mem_bct because sdram_config is not defined
17:25:21 ERROR: Flash Jetson Linux - flash: [ 0.5973 ] ERROR: might be timeout in USB write.
17:25:21 ERROR: Flash Jetson Linux - flash: Error: Return value 3
17:25:21 ERROR: Flash Jetson Linux - flash: --- Error: Reading board information failed.
17:25:21 ERROR: Flash Jetson Linux - flash: [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_FLASH_JETSON_LINUX_COMP.asilla.sh; [error]: --- Error: Reading board information failed.
17:25:21 ERROR: Flash Jetson Linux - flash: command terminated with error
17:25:21 SUMMARY: Flash Jetson Linux - flash: First Error: Installation failed.```
Put the zip file here.
[   0.4700 ] Sending bct_br
It’s still the same, dude.
Did you try steps in the link I posted earlier?
We now have Orin Nano developer kit on market. Please consider get a real device rather than using emulation config.
Thank you for your support. I was able to successfully install it using a different host machine, Ubuntu 18.04 instead of 20.04.
@DaneLLL Thanks for your suggestion. I plan to use that for benchmarking before making a purchase.
