The Orin DevKit flashing exit with info “Parsing board information failed”。
geeking@thinkpad:~/orin/software/workspace/R35.1/Linux_for_Tegra$ sudo ./flash.sh jetson-agx-orin-devkit mmcblk0p1
# L4T BSP Information:
# R35 , REVISION: 1.0
# Target Board Information:
# Name: jetson-agx-orin-devkit, Board Family: t186ref, SoC: Tegra 234,
# OpMode: production, Boot Authentication: NS,
# Disk encryption: disabled ,
copying emc_fuse_dev_params(/data/workspace/nvidia/orin/software/workspace/R35.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct-diag-boot.dts)... done.
copying device_config(/data/workspace/nvidia/orin/software/workspace/R35.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-device-p3701-0000.dts)... done.
copying misc_config(/data/workspace/nvidia/orin/software/workspace/R35.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-misc-p3701-0000.dts)... done.
./tegraflash.py --chip 0x23 --applet "/data/workspace/nvidia/orin/software/workspace/R35.1/Linux_for_Tegra/bootloader/mb1_t234_prod.bin" --skipuid --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3701-0000.dts --misc_config tegra234-mb1-bct-misc-p3701-0000.dts --bins "mb2_applet applet_t234.bin" --cmd "dump eeprom cvm cvm.bin; dump custinfo custinfo_out.bin; reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0095 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.0102 ] File rcm_state open failed
[ 0.0103 ] ERROR: failed to read rcm_state
[ 0.0103 ]
[ 0.0119 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0120 ] Assuming zero filled SBK key
[ 0.0106 ] Pre-processing config: tegra234-mb1-bct-device-p3701-0000.dts
[ 0.0222 ] Pre-processing config: tegra234-mb1-bct-misc-p3701-0000.dts
[ 0.0289 ] Parsing partition layout
[ 0.0301 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0317 ] Parsing partition layout
[ 0.0324 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0332 ] Creating list of images to be signed
[ 0.0348 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[ 0.0355 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0370 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0374 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0413 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0417 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.0462 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.0466 ] adding BCH for mb2_t234_aligned.bin
[ 0.0497 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.0613 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.0617 ] adding BCH for mb2_t234_aligned.bin
[ 0.0756 ] Generating signatures
[ 0.0772 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.0774 ] Assuming zero filled SBK key
[ 0.0902 ] Warning: pub_key.key is not found
[ 0.0889 ] Parsing dev params for multi chains
[ 0.0931 ] Generating br-bct
[ 0.0944 ] Updating dev and MSS params in BR BCT
[ 0.0944 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.0969 ] Updating bl info
[ 0.0976 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.0982 ] WARNING: boot chain is not completed. set to 0
[ 0.0995 ] Get Signed section of bct
[ 0.1002 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[ 0.1010 ] Signing BCT
[ 0.1026 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1027 ] Assuming zero filled SBK key
[ 0.1056 ] Sha saved in br_bct_BR.sha
[ 0.1058 ] Warning: pub_key.key is not found
[ 0.1043 ] Updating BCT with signature
[ 0.1050 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[ 0.1056 ] Offset :4608 Len :3584
[ 0.1060 ] Generating SHA2 Hash
[ 0.1076 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[ 0.1078 ] Assuming zero filled SBK key
[ 0.1098 ] Sha saved in br_bct_BR.sha
[ 0.1085 ] Updating BCT with SHA2 Hash
[ 0.1091 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[ 0.1097 ] Offset :4608 Len :3584
[ 0.1100 ] Offset :68 Len :8124
[ 0.1100 ]
[ 0.1101 ] Generating coldboot mb1-bct
[ 0.1108 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.1113 ] MB1-BCT version: 0.9
[ 0.1124 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.1126 ] Added Platform Config 9 data with size :- 80
[ 0.1126 ]
[ 0.1126 ] Updating mb1-bct with firmware information
[ 0.1133 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.1148 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 0.1161 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 0.1167 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 0.1189 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1191 ] Assuming zero filled SBK key
[ 0.1203 ] Warning: pub_key.key is not found
[ 0.1195 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.1205 ] Generating recovery mb1-bct
[ 0.1212 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.1217 ] MB1-BCT version: 0.9
[ 0.1228 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.1229 ] Added Platform Config 9 data with size :- 80
[ 0.1229 ]
[ 0.1230 ] Updating mb1-bct with firmware information
[ 0.1236 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.1251 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[ 0.1264 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[ 0.1270 ] adding BCH for mb1_bct_MB1_aligned.bct
[ 0.1291 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1293 ] Assuming zero filled SBK key
[ 0.1305 ] Warning: pub_key.key is not found
[ 0.1297 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.1308 ] Error: Skip generating mem_bct because sdram_config is not defined
[ 0.1308 ] Copying signatures
[ 0.1314 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.1353 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.1354 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.1354 ] Boot Rom communication
[ 0.1361 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 0.1367 ] BR_CID: 0x80012344705DD8146C00000006FF02C0
[ 0.1654 ] Sending bct_br
[ 0.2092 ] Sending mb1
[ 0.2101 ] Sending psc_bl1
[ 0.2201 ] Sending bct_mb1
[ 0.2258 ] Boot Rom communication completed
[ 0.2311 ] tegrahost_v2 --chip 0x23 0 --align applet_t234_aligned.bin
[ 0.2368 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --appendsigheader applet_t234_aligned.bin zerosbk
[ 0.2394 ] adding BCH for applet_t234_aligned.bin
[ 0.2736 ] tegrasign_v3.py --key None --list applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.2740 ] Assuming zero filled SBK key
[ 0.2779 ] Warning: pub_key.key is not found
[ 0.2779 ] tegrahost_v2 --chip 0x23 0 --updatesigheader applet_t234_aligned_sigheader.bin.encrypt applet_t234_aligned_sigheader.bin.hash zerosbk
[ 0.2811 ] Sending mb2_applet...
[ 0.2824 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download applet applet_t234_sigheader.bin.encrypt
[ 0.2837 ] BL: version 0.23.0.0-t234-54845784-92215740 last_boot_error: 0
[ 0.4138 ] Sending applet
[ 0.5346 ] completed
[ 0.5378 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.5405 ] MB2 Applet version 01.00.0000
[ 0.7245 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.7254 ] MB2 Applet version 01.00.0000
[ 0.7565 ] Retrieving board information
[ 0.7575 ] tegrarcm_v2 --chip 0x23 0 --oem platformdetails chip chip_info.bin
[ 0.7584 ] MB2 Applet version 01.00.0000
[ 0.8034 ] Saved platform info in chip_info.bin
[ 0.8087 ] Chip minor revision: 1
[ 0.8088 ] Bootrom revision: 0x7
[ 0.8089 ] Ram code: 0x0
[ 0.8090 ] Chip sku: 0xd2
[ 0.8090 ] Chip Sample: prod
[ 0.8097 ] Retrieving EEPROM data
[ 0.8097 ] tegrarcm_v2 --oem platformdetails eeprom cvm /data/workspace/nvidia/orin/software/workspace/R35.1/Linux_for_Tegra/bootloader/cvm.bin --chip 0x23 0
[ 0.8106 ] MB2 Applet version 01.00.0000
[ 0.8552 ] Saved platform info in /data/workspace/nvidia/orin/software/workspace/R35.1/Linux_for_Tegra/bootloader/cvm.bin
[ 0.8903 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.8911 ] MB2 Applet version 01.00.0000
[ 0.9195 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.9202 ] MB2 Applet version 01.00.0000
[ 0.9673 ] Dumping customer Info
[ 0.9683 ] tegrarcm_v2 --chip 0x23 0 --oem dump bct tmp.bct
[ 0.9690 ] MB2 Applet version 01.00.0000
[ 1.0156 ] Saved bct in tmp.bct
[ 1.0257 ] tegrabct_v2 --brbct tmp.bct --chip 0x23 0 --custinfo /data/workspace/nvidia/orin/software/workspace/R35.1/Linux_for_Tegra/bootloader/custinfo_out.bin
[ 1.0283 ] C[ 1.0290 ] ustomer data saved in /data/workspace/nvidia/orin/software/workspace/R35.1/Linux_for_Tegra/bootloader/custinfo_out.bin successfully
[ 1.0292 ] Rebooting to recovery mode
[ 1.0317 ] tegrarcm_v2 --chip 0x23 0 --ismb2
[ 1.0644 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 1.0650 ] MB2 Applet version 01.00.0000
[ 1.1113 ] Booting to recovery mode
[ 1.1124 ] tegrarcm_v2 --chip 0x23 0 --reboot recovery
[ 1.1132 ] MB2 Applet version 01.00.0000
Parsing board information failed.
- What are the possible causes of this problem?
- How to fix this problem?
