Jetpack 6 Flash Failed
Hi all,
I tried flashing an Orin AGX Industrial on a custom board with the latest Jetpack6 release using the SDKManager on an Ubuntu system. The OS itself appeared to flash fine but could not reconnect to the board through the default IP or through the previously applied IPv4 addresses (that wasn’t entirely unexpected). Console logs attached;
[0000.063] I> MB1 (version: 1.4.0.2-t234-54845784-08a4de08)
[0000.068] I> t234-A01-1-Silicon (0x12347) Prod
[0000.072] I> Boot-mode : Coldboot
[0000.076] I> Entry timestamp: 0x00000000
[0000.079] I> last_boot_error: 0x0
[0000.082] I> BR-BCT: preprod_dev_sign: 0
[0000.086] I> rst_source: 0x0, rst_level: 0x0
[0000.090] I> Task: SE error check
[0000.093] I> Task: Bootchain select WAR set
[0000.098] I> Task: Enable SLCG
[0000.100] I> Task: CRC check
[0000.103] I> Skip FUSE records CRC check as records_integrity fuse is not burne        d
[0000.110] I> Task: Initialize MB2 params
[0000.115] I> MB2-params @ 0x40060000
[0000.118] I> Task: Crypto init
[0000.121] I> Task: Perform MB1 KAT tests
[0000.125] I> Task: NVRNG health check
[0000.128] I> NVRNG: Health check success
[0000.132] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0000.138] I> Task: Enabling and initialization of Bandwidth limiter
[0000.144] I> No request to configure MBWT settings for any PC!
[0000.150] I> Task: Secure debug controls
[0000.154] I> Task: strap war set
[0000.157] I> Task: Initialize SOC Therm
[0000.161] I> Task: Program NV master stream id
[0000.165] I> Task: Verify boot mode
[0000.171] I> Task: Alias fuses
[0000.174] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.181] I> Task: Print SKU type
[0000.184] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x00000000
[0000.189] I> FUSE_OPT_GPC_DISABLE = 0x00000000
[0000.193] I> FUSE_OPT_TPC_DISABLE = 0x00000000
[0000.198] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0000.202] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0000.206] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0000.211] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0000.215] I> FUSE_OPT_FSI_DISABLE = 0x00000000
[0000.219] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0000.224] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.228] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.232] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.236] I> FUSE_SKU_INFO_0 = 0x90
[0000.239] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.243] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.247] I> SKU: Prod
[0000.249] I> Task: Boost clocks
[0000.252] I> Initializing NAFLL for BPMP_CPU_NIC.
[0000.257] I> BPMP NAFLL: fll_lock = 1, dvco_min_reached = 0
[0000.263] I> BPMP NAFLL lock success.
[0000.266] I> BPMP_CPU_NIC : src = 42, divisor = 0
[0000.271] I> Initializing PLLC2 for AXI_CBB.
[0000.275] I> AXI_CBB : src = 35, divisor = 0
[0000.279] I> Task: Voltage monitor
[0000.282] I> VMON: Vmon re-calibration and fine tuning done
[0000.288] I> Task: UPHY init
[0000.293] I> HSIO UPHY init done
[0000.296] W> Skipping GBE UPHY config
[0000.299] I> Task: Boot device init
[0000.303] I> Boot_device: QSPI_FLASH instance: 0
[0000.307] I> Qspi clock source : pllc_out0
[0000.311] I> QSPI Flash: Macronix 64MB
[0000.315] I> QSPI-0l initialized successfully
[0000.319] I> Task: TSC init
[0000.322] I> Task: Load membct
[0000.325] I> RAM_CODE 0x4000441
[0000.328] I> Loading MEMBCT
[0000.331] I> Slot: 0
[0000.333] I> Binary[1] block-3840 (partition size: 0x40000)
[0000.338] I> Binary name: MEM-BCT-1
[0000.341] I> Size of crypto header is 8192
[0000.345] I> Size of crypto header is 8192
[0000.349] I> strt_pg_num(3840) num_of_pgs(16) read_buf(0x40050000)
[0000.356] I> BCH of MEM-BCT-1 read from storage
[0000.360] I> BCH address is : 0x40050000
[0000.364] I> MEM-BCT-1 header integrity check is success
[0000.369] I> Binary magic in BCH component 1 is MEM1
[0000.374] I> component binary type is 1
[0000.377] I> strt_pg_num(3971) num_of_pgs(115) read_buf(0x40040000)
[0000.384] I> MEM-BCT-1 binary is read from storage
[0000.389] I> MEM-BCT-1 binary integrity check is success
[0000.394] I> Binary MEM-BCT-1 loaded successfully at 0x40040000 (0xe580)
[0000.401] I> RAM_CODE 0x4000441
[0000.406] I> RAM_CODE 0x4000441
[0000.410] I> Task: Load Page retirement list
[0000.414] I> Slot: 0
[0000.416] I> Binary[4] block-125952 (partition size: 0x80000)
[0000.422] I> Binary name: DRAM bad page list (P)
[0000.426] I> Size of crypto header is 8192
[0000.430] I> Size of crypto header is 8192
[0000.434] I> strt_pg_num(125952) num_of_pgs(16) read_buf(0x40050000)
[0000.440] I> BCH of DRAM bad page list (P) read from storage
[0000.446] I> BCH address is : 0x40050000
[0000.450] I> component binary type is 4
[0000.454] I> DRAM bad page list (P) header integrity check is success
[0000.460] I> Binary magic in BCH component 0 is BINF
[0000.465] I> component binary type is 4
[0000.468] I> component binary type is 4
[0000.472] I> Size of crypto header is 8192
[0000.476] I> component binary type is 4
[0000.480] I> strt_pg_num(125968) num_of_pgs(8) read_buf(0x40040000)
[0000.486] I> DRAM bad page list (P) binary is read from storage
[0000.492] I> DRAM bad page list (P) binary integrity check is success
[0000.498] I> Binary DRAM bad page list (P) loaded successfully at 0x40040000 (0        x1000)
[0000.508] I> Task: SDRAM params override
[0000.512] I> Task: Save mem-bct info
[0000.515] I> Task: Carveout allocate
[0000.519] I> RCM blob carveout will not be allocated
[0000.524] I> Update CCPLEX IST carveout from MB1-BCT
[0000.529] I> ECC region[0]: Start:0x80000000, End:0xe80000000
[0000.534] I> ECC region[1]: Start:0x0, End:0x0
[0000.538] I> ECC region[2]: Start:0x0, End:0x0
[0000.543] I> ECC region[3]: Start:0x0, End:0x0
[0000.547] I> ECC region[4]: Start:0x0, End:0x0
[0000.551] I> Non-ECC region[0]: Start:0x0, End:0x0
[0000.556] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.560] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.565] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.570] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.580] I> allocated(CO:44) base:0xe49800000 size:0x36800000 align: 0x100000
[0000.588] I> allocated(CO:31) base:0xe40000000 size:0x8000000 align: 0x8000000
[0000.595] I> allocated(CO:43) base:0xe3c000000 size:0x4000000 align: 0x200000
[0000.602] I> allocated(CO:39) base:0xe39e00000 size:0x2200000 align: 0x10000
[0000.609] I> allocated(CO:20) base:0xe36000000 size:0x2000000 align: 0x2000000
[0000.616] I> allocated(CO:24) base:0xe34000000 size:0x2000000 align: 0x2000000
[0000.623] I> allocated(CO:28) base:0xe32000000 size:0x2000000 align: 0x2000000
[0000.630] I> allocated(CO:29) base:0xe30000000 size:0x2000000 align: 0x2000000
[0000.637] I> allocated(CO:22) base:0xe48000000 size:0x1000000 align: 0x1000000
[0000.644] I> allocated(CO:35) base:0xe38e00000 size:0x1000000 align: 0x100000
[0000.651] I> allocated(CO:41) base:0xe2f000000 size:0x1000000 align: 0x100000
[0000.658] I> allocated(CO:02) base:0xe49000000 size:0x800000 align: 0x800000
[0000.665] I> allocated(CO:03) base:0xe38000000 size:0x800000 align: 0x800000
[0000.672] I> allocated(CO:06) base:0xe2e800000 size:0x800000 align: 0x800000
[0000.679] I> allocated(CO:56) base:0xe2e000000 size:0x800000 align: 0x200000
[0000.686] I> allocated(CO:07) base:0xe38800000 size:0x400000 align: 0x400000
[0000.693] I> allocated(CO:33) base:0xe2dc00000 size:0x400000 align: 0x200000
[0000.700] I> allocated(CO:19) base:0xe2d980000 size:0x280000 align: 0x10000
[0000.707] I> allocated(CO:23) base:0xe38c00000 size:0x200000 align: 0x200000
[0000.714] I> allocated(CO:01) base:0xe2d800000 size:0x100000 align: 0x100000
[0000.721] I> allocated(CO:05) base:0xe2d700000 size:0x100000 align: 0x100000
[0000.728] I> allocated(CO:08) base:0xe2d600000 size:0x100000 align: 0x100000
[0000.735] I> allocated(CO:09) base:0xe2d500000 size:0x100000 align: 0x100000
[0000.742] I> allocated(CO:12) base:0xe2d400000 size:0x100000 align: 0x100000
[0000.749] I> allocated(CO:15) base:0xe2d300000 size:0x100000 align: 0x100000
[0000.755] I> allocated(CO:17) base:0xe2d200000 size:0x100000 align: 0x100000
[0000.762] I> allocated(CO:27) base:0xe2d100000 size:0x100000 align: 0x100000
[0000.769] I> allocated(CO:42) base:0xe2d000000 size:0x100000 align: 0x100000
[0000.776] I> allocated(CO:54) base:0xe2d900000 size:0x80000 align: 0x80000
[0000.783] I> allocated(CO:34) base:0xe2cff0000 size:0x10000 align: 0x10000
[0000.790] I> allocated(CO:72) base:0xe2cdf0000 size:0x200000 align: 0x10000
[0000.797] I> allocated(CO:47) base:0xe2c800000 size:0x400000 align: 0x200000
[0000.804] I> allocated(CO:50) base:0xe2c600000 size:0x200000 align: 0x100000
[0000.811] I> allocated(CO:52) base:0xe2cdc0000 size:0x30000 align: 0x10000
[0000.817] I> allocated(CO:48) base:0xe2cda0000 size:0x20000 align: 0x10000
[0000.824] I> allocated(CO:69) base:0xe2cd80000 size:0x20000 align: 0x10000
[0000.831] I> allocated(CO:49) base:0xe2cd70000 size:0x10000 align: 0x10000
[0000.838] I> NSDRAM base: 0x80000000, end: 0xe2cdf0000, size: 0xdacdf0000
[0000.844] I> Task: Thermal check
[0000.847] I> Using min_chip_limit as min_tmon_limit
[0000.852] I> Using max_chip_limit as max_tmon_limit
[0000.857] I> BCT max_tmon_limit = 118
[0000.860] I> BCT min_tmon_limit = -43
[0000.864] I> BCT max_tmon_limit = 118
[0000.867] I> BCT min_tmon_limit = -43
[0000.871] I> SKU specific max_chip_limit = 125
[0000.875] I> SKU specific min_chip_limit = -43
[0000.879] I> BCT max_chip_limit = 118
[0000.883] I> BCT min_chip_limit = -43
[0000.886] I> enable_soctherm_polling = 0
[0000.890] I> max temp read = 34
[0000.893] I> min temp read = 33
[0000.896] I> Enabling thermtrip
[0000.899] I> Task: Update FSI SCR with thermal fuse data
[0000.904] I> Task: Enable WDT 5th expiry
[0000.908] I> Task: I2C register
[0000.911] I> Task: Set I2C bus freq
[0000.914] I> Task: Reset FSI
[0000.917] I> Task: Pinmux init
[0000.920] I> Task: Prod config init
[0000.924] I> Task: Pad voltage init
[0000.927] I> Task: Prod init
[0000.930] I> Task: Program rst req config reg
[0000.934] I> Task: Common rail init
[0000.937] I> DONE: Thermal config
[0000.941] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0000.949] I> DONE: SOC rail config
[0000.953] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0000.959] I> DONE: MEMIO rail config
[0000.963] I> DONE: GPU rail info
[0000.966] I> DONE: CV rail info
[0000.969] I> Task: Mem clock src
[0000.972] I> Task: Misc. board config
[0000.976] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0000.982] I> Task: SDRAM init
[0000.985] I> MemoryType: 4 MemBctRevision: 8
[0000.991] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision        : 8
[0000.999] I> MSS CAR: Init PLLM
[0001.002] I> MSS CAR: Init PLLHUB
[0001.007] I> Encryption:   MTS: en, TX: en, VPR: en, GSC: en
[0001.018] I> SDRAM initialized!
[0001.021] I> SDRAM Size in Total 0xe00000000
[0001.025] I> Task: Dram Ecc scrub
[0001.028] I> DRAM ECC Scrub Mode: full
[0002.750] I> SDRAM scrub successful
[0002.753] I> Task: DRAM alias check
[0002.770] I> Task: Program NSDRAM carveout
[0002.774] I> NSDRAM carveout encryption is enabled
[0002.779] I> Program NSDRAM carveout
[0002.782] I> Task: Register checker
[0002.786] I> Task: Enable clock-mon
[0002.800] I> FMON: Fmon re-programming done
[0002.804] I> Task: Mapper init
[0002.807] I> Task: SC7 Context Init
[0002.810] I> Task: CCPLEX IST init
[0002.813] I> Task: CPU WP0
[0002.816] I> Loading MCE
[0002.818] I> Slot: 0
[0002.820] I> Binary[8] block-20736 (partition size: 0x80000)
[0002.826] I> Binary name: MCE
[0002.829] I> Size of crypto header is 8192
[0002.833] I> Size of crypto header is 8192
[0002.837] I> strt_pg_num(20736) num_of_pgs(16) read_buf(0x4003e000)
[0002.843] I> BCH of MCE read from storage
[0002.847] I> BCH address is : 0x4003e000
[0002.851] I> MCE header integrity check is success
[0002.855] I> Binary magic in BCH component 0 is MTSM
[0002.860] I> component binary type is 8
[0002.864] I> Size of crypto header is 8192
[0002.868] I> strt_pg_num(20752) num_of_pgs(350) read_buf(0x40000000)
[0002.876] I> MCE binary is read from storage
[0002.880] I> MCE binary integrity check is success
[0002.885] I> Binary MCE loaded successfully at 0x40000000 (0x2baf0)
[0002.891] I> Size of crypto header is 8192
[0002.902] I> Size of crypto header is 8192
[0002.906] I> Sending WP0 mailbox command to PSC
[0002.915] I> Task: XUSB Powergate
[0002.918] I> Skipping powergate XUSB.
[0002.922] I> Task: MB1 fixed firewalls
[0002.928] W> Firewall readback mismatch
[0002.933] I> Task: Load bpmp-fw
[0002.936] I> Slot: 0
[0002.938] I> Binary[15] block-9984 (partition size: 0x180000)
[0002.944] I> Binary name: BPMP_FW
[0002.947] I> Size of crypto header is 8192
[0002.951] I> Size of crypto header is 8192
[0002.955] I> strt_pg_num(9984) num_of_pgs(16) read_buf(0x807fe000)
[0002.961] I> BCH of BPMP_FW read from storage
[0002.965] I> BCH address is : 0x807fe000
[0002.969] I> BPMP_FW header integrity check is success
[0002.974] I> Binary magic in BCH component 0 is BPMF
[0002.979] I> component binary type is 15
[0002.983] I> Size of crypto header is 8192
[0002.987] I> strt_pg_num(10000) num_of_pgs(2028) read_buf(0x80000000)
[0003.004] I> BPMP_FW binary is read from storage
[0003.011] I> BPMP_FW binary integrity check is success
[0003.016] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xfd640)
[0003.022] I> Slot: 0
[0003.024] I> Binary[16] block-13056 (partition size: 0x300000)
[0003.030] I> Binary name: BPMP_FW_DTB
[0003.033] I> Size of crypto header is 8192
[0003.037] I> Size of crypto header is 8192
[0003.041] I> strt_pg_num(13056) num_of_pgs(16) read_buf(0x807fc000)
[0003.048] I> BCH of BPMP_FW_DTB read from storage
[0003.052] I> BCH address is : 0x807fc000
[0003.056] I> BPMP_FW_DTB header integrity check is success
[0003.061] I> Binary magic in BCH component 0 is BPMD
[0003.066] I> component binary type is 16
[0003.070] I> Size of crypto header is 8192
[0003.074] I> strt_pg_num(13072) num_of_pgs(289) read_buf(0x807d7df0)
[0003.082] I> BPMP_FW_DTB binary is read from storage
[0003.087] I> BPMP_FW_DTB binary integrity check is success
[0003.092] I> Binary BPMP_FW_DTB loaded successfully at 0x807d7df0 (0x241c0)
[0003.099] I> Task: BPMP fw ast config
[0003.103] I> Task: Load psc-fw
[0003.105] I> Slot: 0
[0003.107] I> Binary[17] block-19200 (partition size: 0xc0000)
[0003.113] I> Binary name: PSC_FW
[0003.116] I> Size of crypto header is 8192
[0003.120] I> Size of crypto header is 8192
[0003.124] I> strt_pg_num(19200) num_of_pgs(16) read_buf(0x80ffe000)
[0003.130] I> BCH of PSC_FW read from storage
[0003.134] I> BCH address is : 0x80ffe000
[0003.138] I> PSC_FW header integrity check is success
[0003.143] I> Binary magic in BCH component 0 is PFWP
[0003.148] I> component binary type is 17
[0003.152] I> Size of crypto header is 8192
[0003.156] I> strt_pg_num(19216) num_of_pgs(591) read_buf(0x80fb4200)
[0003.165] I> PSC_FW binary is read from storage
[0003.170] I> PSC_FW binary integrity check is success
[0003.175] I> Binary PSC_FW loaded successfully at 0x80fb4200 (0x49df0)
[0003.181] I> Task: Load nvdec-fw
[0003.185] I> Slot: 0
[0003.187] I> Binary[7] block-6400 (partition size: 0x100000)
[0003.192] I> Binary name: NVDEC
[0003.195] I> Size of crypto header is 8192
[0003.199] I> Size of crypto header is 8192
[0003.203] I> strt_pg_num(6400) num_of_pgs(16) read_buf(0x800fe000)
[0003.209] I> BCH of NVDEC read from storage
[0003.213] I> BCH address is : 0x800fe000
[0003.217] I> NVDEC header integrity check is success
[0003.222] I> Binary magic in BCH component 0 is NDEC
[0003.227] I> component binary type is 7
[0003.230] I> Size of crypto header is 8192
[0003.234] I> strt_pg_num(6416) num_of_pgs(560) read_buf(0x80000000)
[0003.243] I> NVDEC binary is read from storage
[0003.248] I> NVDEC binary integrity check is success
[0003.253] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
[0003.259] I> Size of crypto header is 8192
[0003.271] I> Task: Load tsec-fw
[0003.274] I> TSEC-FW load support not enabled
[0003.278] I> Task: GPIO interrupt map
[0003.282] I> Task: SC7 context save
[0003.285] I> Slot: 0
[0003.287] I> Binary[27] block-0 (partition size: 0x100000)
[0003.293] I> Binary name: BR_BCT
[0003.296] I> Size of crypto header is 8192
[0003.300] I> Size of crypto header is 8192
[0003.304] I> Size of crypto header is 8192
[0003.307] I> strt_pg_num(0) num_of_pgs(16) read_buf(0xa0000000)
[0003.313] I> BR_BCT binary is read from storage
[0003.318] I> BR_BCT binary integrity check is success
[0003.323] I> Binary BR_BCT loaded successfully at 0xa0000000 (0x2000)
[0003.329] I> Slot: 0
[0003.331] I> Binary[13] block-21760 (partition size: 0x30000)
[0003.337] I> Binary name: SC7-FW
[0003.340] I> Size of crypto header is 8192
[0003.344] I> Size of crypto header is 8192
[0003.348] I> Size of crypto header is 8192
[0003.351] I> Size of crypto header is 8192
[0003.355] I> strt_pg_num(21760) num_of_pgs(16) read_buf(0xa0002000)
[0003.362] I> BCH of SC7-FW read from storage
[0003.366] I> BCH address is : 0xa0002000
[0003.370] I> SC7-FW header integrity check is success
[0003.375] I> Binary magic in BCH component 0 is WB0B
[0003.379] I> component binary type is 13
[0003.383] I> Size of crypto header is 8192
[0003.387] I> strt_pg_num(21776) num_of_pgs(349) read_buf(0xa0004000)
[0003.395] I> SC7-FW binary is read from storage
[0003.400] I> SC7-FW binary integrity check is success
[0003.405] I> Binary SC7-FW loaded successfully at 0xa0004000 (0x2b920)
[0003.411] I> Slot: 0
[0003.413] I> Binary[22] block-22144 (partition size: 0x30000)
[0003.419] I> Binary name: PSC_RF
[0003.422] I> Size of crypto header is 8192
[0003.426] I> Size of crypto header is 8192
[0003.430] I> Size of crypto header is 8192
[0003.434] I> Size of crypto header is 8192
[0003.438] I> strt_pg_num(22144) num_of_pgs(16) read_buf(0xa002f920)
[0003.444] I> BCH of PSC_RF read from storage
[0003.448] I> BCH address is : 0xa002f920
[0003.452] I> PSC_RF header integrity check is success
[0003.457] I> Binary magic in BCH component 0 is PSCR
[0003.462] I> component binary type is 22
[0003.465] I> Size of crypto header is 8192
[0003.469] I> strt_pg_num(22160) num_of_pgs(224) read_buf(0xa0031920)
[0003.477] I> PSC_RF binary is read from storage
[0003.481] I> PSC_RF binary integrity check is success
[0003.486] I> Binary PSC_RF loaded successfully at 0xa0031920 (0x1be60)
[0003.496] I> Task: Save WP0 payload to SC7 ctx
[0003.500] I> Task: Load MB2rf binary to SC7 ctx
[0003.504] I> Slot: 0
[0003.506] I> Binary[14] block-22528 (partition size: 0x20000)
[0003.512] I> Binary name: MB2_RF
[0003.515] I> Size of crypto header is 8192
[0003.519] I> Size of crypto header is 8192
[0003.523] I> Size of crypto header is 8192
[0003.527] I> Size of crypto header is 8192
[0003.531] I> strt_pg_num(22528) num_of_pgs(16) read_buf(0xa00d5d10)
[0003.537] I> BCH of MB2_RF read from storage
[0003.541] I> BCH address is : 0xa00d5d10
[0003.545] I> MB2_RF header integrity check is success
[0003.550] I> Binary magic in BCH component 0 is MB2R
[0003.555] I> component binary type is 14
[0003.558] I> Size of crypto header is 8192
[0003.562] I> strt_pg_num(22544) num_of_pgs(224) read_buf(0xa00d7d10)
[0003.570] I> MB2_RF binary is read from storage
[0003.574] I> MB2_RF binary integrity check is success
[0003.579] I> Binary MB2_RF loaded successfully at 0xa00d7d10 (0x1bf30)
[0003.586] I> Task: Save fuse alias data to SC7 ctx
[0003.590] I> Task: Save PMIC data to SC7 ctx
[0003.595] I> Task: Save Pinmux data to SC7 ctx
[0003.599] I> Task: Save Pad Voltage data to SC7 ctx
[0003.604] I> Task: Save controller prod data to SC7 ctx
[0003.609] I> Task: Save prod cfg data to SC7 ctx
[0003.613] I> Task: Save I2C bus freq data to SC7 ctx
[0003.618] I> Task: Save SOCTherm data to SC7 ctx
[0003.622] I> Task: Save FMON data to SC7 ctx
[0003.626] I> Task: Save VMON data to SC7 ctx
[0003.631] I> Task: Save TZDRAM data to SC7 ctx
[0003.635] I> Task: Save GPIO int data to SC7 ctx
[0003.639] I> Task: Save clock data to SC7 ctx
[0003.643] I> Task: Save debug data to SC7 ctx
[0003.648] I> Task: Save MBWT data to SC7 ctx
[0003.656] I> SC7 context save done
[0003.659] I> Task: Load MB2/Applet/FSKP
[0003.663] I> Loading MB2
[0003.665] I> Slot: 0
[0003.667] I> Binary[6] block-8448 (partition size: 0x80000)
[0003.672] I> Binary name: MB2
[0003.675] I> Size of crypto header is 8192
[0003.679] I> Size of crypto header is 8192
[0003.683] I> strt_pg_num(8448) num_of_pgs(16) read_buf(0x8007e000)
[0003.689] I> BCH of MB2 read from storage
[0003.693] I> BCH address is : 0x8007e000
[0003.697] I> MB2 header integrity check is success
[0003.702] I> Binary magic in BCH component 0 is MB2B
[0003.706] I> component binary type is 6
[0003.710] I> Size of crypto header is 8192
[0003.714] I> strt_pg_num(8464) num_of_pgs(844) read_buf(0x80000000)
[0003.725] I> MB2 binary is read from storage
[0003.730] I> MB2 binary integrity check is success
[0003.735] I> Binary MB2 loaded successfully at 0x80000000 (0x696a0)
[0003.741] I> Task: Map CCPLEX SHARED carveout
[0003.745] I> Task: Prepare MB2 params
[0003.749] I> Task: Dram ecc test
[0003.752] I> Task: Misc NV security settings
[0003.756] I> NVDEC sticky bits programming done
[0003.760] I> Successfully powergated NVDEC
[0003.764] I> Task: Disable/Reload WDT
[0003.768] I> Task: Program misc carveouts
[0003.772] I> Program IPC carveouts
[0003.775] I> Task: Disable SCPM/POD reset
[0003.779] I> SLCG Global override status := 0x0
[0003.784] I> MB1: MSS reconfig completed
I> MB2 (version: 0.0.0.0-t234-54845784-af79ed0a)
I> Emulation:
I> Entry timestamp: 0x003a2d7d
I> Regular heap: [base:0x40040000, size:0x10000]
I> DMA heap: [base:0xe2e000000, size:0x800000]
I> Task: MB2 Params integrity check
I> Task: Enable CCPLEX WDT 5th expiry
I> Task: ARI update carveout TZDRAM
I> Task: Configure OEM set LA/PTSA values
I> Task: Check MC errors
I> Task: Enable hot-plug capability
I> Task: PSC mailbox init
I> Task: Enable clock for external modules
I> Task: Measured Boot init
I> Task: fTPM silicon identity init
I> fTPM is not enabled.
I> Task: OEM SC7 context save init
I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout
I> Task: Program CBB PCIE AMAP regions
I> Secondary storage device: QSPI_FLASH instance: 0
I> Secondary storage device: SDMMC_USER instance: 3
I> sdmmc HS400 mode enabled
I> Task: Partition Manager Init
I> strt_pg_num(1) num_of_pgs(1) read_buf(0xe2e001000)
I> strt_pg_num(131071) num_of_pgs(1) read_buf(0xe2e001000)
I> strt_pg_num(131039) num_of_pgs(32) read_buf(0xe2e001200)
I> Found 61 partitions in QSPI_FLASH (instance 0)
W> Cannot find any partition table for 00000003
W> PARTITION_MANAGER: Failed to publish partition.
I> Found 15 partitions in SDMMC_USER (instance 3)
I> Task: Pass DRAM ECC PRL Flag to FSI
I> Task: Load and authenticate registered FWs
I> Task: Load AUXP FWs
I> Successfully register SPE FW load task with MB2 loader
I> Successfully register RCE FW load task with MB2 loader
I> Successfully register DCE FW load task with MB2 loader
I> Unpowergating APE
I> Unpowergate done
I> Successfully register APE FW load task with MB2 loader
I> Successfully register FSI FW load task with MB2 loader
I> Successfully register XUSB FW load task with MB2 loader
I> Successfully register PVA FW load task with MB2 loader
I> Partition name: A_spe-fw
I> Size of partition: 589824
I> Binary@ device:3/0 block-55040 (partition size: 0x90000), name: A_spe-fw
I> strt_pg_num(55040) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(55056) num_of_pgs(512) read_buf(0xe2d600000)
I> Partition name: A_rce-fw
I> Size of partition: 1048576
I> Binary@ device:3/0 block-56192 (partition size: 0x100000), name: A_rce-fw
I> strt_pg_num(56192) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(56208) num_of_pgs(880) read_buf(0xe2d200000)
I> spe: Authentication Finalize Done
I> Binary spe loaded successfully at 0xe2d600000
I> Partition name: A_dce-fw
I> Size of partition: 2097152
I> Binary@ device:3/0 block-38656 (partition size: 0x200000), name: A_dce-fw
I> strt_pg_num(38656) num_of_pgs(16) read_buf(0x40066880)
I> rce: Authentication Finalize Done
I> Binary rce loaded successfully at 0xe2d200000
I> Successfully register RCE FW context save task with MB2 loader
I> dce : oem authentication of header done
I> strt_pg_num(38672) num_of_pgs(1) read_buf(0xe2e1403d8)
I> strt_pg_num(38672) num_of_pgs(8) read_buf(0xe2e1403d8)
I> dce : meta-blob integrity check is success.
I> strt_pg_num(38680) num_of_pgs(512) read_buf(0xe2e0003c0)
I> strt_pg_num(39192) num_of_pgs(512) read_buf(0xe2e0403c0)
I> dce : will be decompressed at 0xe36000000
I> version 1 Bin 1 BCheckSum 0 content_size 0 Content ChkSum 1 reserved_00  0
I> Reserved10 0 BlockMaxSize 5 Reserved11 0
I> strt_pg_num(39704) num_of_pgs(512) read_buf(0xe2e0803c0)
I> dce : decompressed to 12062560 bytes
I> dce: plain binary integrity check is success
I> Partition name: A_adsp-fw
I> Binary@ device:3/0 block-58240 (partition size: 0x200000), name: A_adsp-fw
I> strt_pg_num(58240) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(58256) num_of_pgs(800) read_buf(0xe38800000)
I> dce: Authentication Finalize Done
I> Binary dce loaded successfully at 0xe36000000
I> Partition name: A_fsi-fw
I> Size of partition: 6291456
I> Binary@ device:3/0 block-42752 (partition size: 0x600000), name: A_fsi-fw
I> FSI load addr: 0xe30000000
I> strt_pg_num(42752) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(42768) num_of_pgs(11208) read_buf(0xe30000000)
I> ape: Authentication Finalize Done
I> Binary ape loaded successfully at 0xe38800000
I> Successfully register APE FW context save task with MB2 loader
I> Partition name: A_xusb-fw
I> Size of partition: 262144
I> Binary@ device:3/0 block-9472 (partition size: 0x40000), name: A_xusb-fw
I> strt_pg_num(9472) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(9488) num_of_pgs(312) read_buf(0xe2d700000)
I> fsi: Authentication Finalize Done
I> Binary fsi loaded successfully at 0xe30000000
I> Successfully register FSI FW context save task with MB2 loader
I> Configuring FSI PLL
W> PLLFSI init is not supported
I> FSI_CHSM_ATCM DMA xfer done
I> FSI_CHSM_BTCM DMA xfer done
I> FSI_CPU0_ATCM DMA xfer done
I> FSI_CPU0_BTCM DMA xfer done
I> FSI_CPU0_CTCM DMA xfer done
I> FSI_CPU1_ATCM DMA xfer done
I> FSI_CPU1_BTCM DMA xfer done
I> FSI_CPU1_CTCM DMA xfer done
I> FSI_CPU2_ATCM DMA xfer done
I> FSI_CPU2_BTCM DMA xfer done
I> FSI_CPU2_CTCM DMA xfer done
I> FSI_CPU3_ATCM DMA xfer done
I> FSI_CPU3_BTCM DMA xfer done
I> FSI_CPU3_CTCM DMA xfer done
I> FSI_SRAM DMA xfer done
I> Partition name: A_pva-fw
I> Binary@ device:3/0 block-62336 (partition size: 0x40000), name: A_pva-fw
I> strt_pg_num(62336) num_of_pgs(16) read_buf(0x40066880)
I> xusb: Authentication Finalize Done
I> Binary xusb loaded successfully at 0xe2d700000
I> Successfully register XUSB FW context save task with MB2 loader
I> pva-fw : oem authentication of header done
I> strt_pg_num(62352) num_of_pgs(1) read_buf(0xe2e1403d8)
I> strt_pg_num(62352) num_of_pgs(8) read_buf(0xe2e1403d8)
I> pva-fw : meta-blob integrity check is success.
I> strt_pg_num(62360) num_of_pgs(512) read_buf(0xe2e0003c0)
I> pva-fw : will be decompressed at 0xe2d980000
I> pva-fw : decompressed to 2156512 bytes
I> pva-fw: plain binary integrity check is success
I> pva-fw: Authentication Finalize Done
I> Binary pva-fw loaded successfully at 0xe2d980000
I> Successfully register PVA FW context save task with MB2 loader
I> Task: Carveout setup
I> Program remaining OEM carveouts
I> Task: Enable FSITHERM
I> Task: Enable FSI VMON
I> FSI VMON: FSI Vmon re-calibration and fine tuning done
I> Task: Validate FSI Therm readings
I> Task: Restore XUSB sec
I> Task: Enable FSI SE clock
I> Enable FSI-SE clock...
I> Task: Initialize SBSA UART CAR
I> Task: Initialize CPUBL Params
I> CPUBL-params @ 0xe32000000
I> Task: Ratchet update
W> Skip ratchet update - OPTIN fuse not set
I> Task: Prepare eeprom data
E> I2C: slave not found in slaves.
E> I2C: Could not write 0 bytes to slave: 0x00ac with repeat start true.
E> I2C_DEV: Failed to send register address 0x00000000.
E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xac at 0x00000000        via instance 0.
E> eeprom: Retry to read I2C slave device.
E> eeprom: Failed to read I2C slave device
C> Task 0x0 failed (err: 0x1f1e050d)
E> Top caller module: I2C_DEV, error module: I2C, reason: 0x0d, aux_info: 0x05
I> Busy Spin
[0000.064] I> MB1 (version: 1.4.0.2-t234-54845784-08a4de08)
[0000.069] I> t234-A01-1-Silicon (0x12347) Prod
[0000.073] I> Boot-mode : Coldboot
[0000.077] I> Entry timestamp: 0x00000000
[0000.080] I> last_boot_error: 0x0
[0000.083] I> BR-BCT: preprod_dev_sign: 0
[0000.087] I> rst_source: 0x16, rst_level: 0x1
[0000.091] I> Task: SE error check
[0000.095] I> Task: Bootchain select WAR set
[0000.099] I> Task: Enable SLCG
[0000.101] I> Task: CRC check
[0000.104] I> Skip FUSE records CRC check as records_integrity fuse is not burned
[0000.111] I> Task: Initialize MB2 params
[0000.116] I> MB2-params @ 0x40060000
[0000.119] I> Task: Crypto init
[0000.122] I> Task: Perform MB1 KAT tests
[0000.126] I> Task: NVRNG health check
[0000.129] I> NVRNG: Health check success
[0000.133] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0000.139] I> Task: Enabling and initialization of Bandwidth limiter
[0000.145] I> No request to configure MBWT settings for any PC!
[0000.151] I> Task: Secure debug controls
[0000.155] I> Task: strap war set
[0000.158] I> Task: Initialize SOC Therm
[0000.162] I> Task: Program NV master stream id
[0000.166] I> Task: Verify boot mode
[0000.172] I> Task: Alias fuses
[0000.175] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.182] I> Task: Print SKU type
[0000.185] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x00000000
[0000.190] I> FUSE_OPT_GPC_DISABLE = 0x00000000
[0000.194] I> FUSE_OPT_TPC_DISABLE = 0x00000000
[0000.199] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0000.203] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0000.207] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0000.212] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0000.216] I> FUSE_OPT_FSI_DISABLE = 0x00000000
[0000.220] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0000.225] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.229] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.233] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.237] I> FUSE_SKU_INFO_0 = 0x90
[0000.240] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.245] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.248] I> SKU: Prod
[0000.250] I> Task: Boost clocks
[0000.253] I> Initializing NAFLL for BPMP_CPU_NIC.
[0000.258] I> BPMP NAFLL: fll_lock = 1, dvco_min_reached = 0
[0000.264] I> BPMP NAFLL lock success.
[0000.267] I> BPMP_CPU_NIC : src = 42, divisor = 0
[0000.272] I> Initializing PLLC2 for AXI_CBB.
[0000.276] I> AXI_CBB : src = 35, divisor = 0
[0000.280] I> Task: Voltage monitor
[0000.283] I> VMON: Vmon re-calibration and fine tuning done
[0000.289] I> Task: UPHY init
[0000.294] I> HSIO UPHY init done
[0000.297] W> Skipping GBE UPHY config
[0000.300] I> Task: Boot device init
[0000.304] I> Boot_device: QSPI_FLASH instance: 0
[0000.308] I> Qspi clock source : pllc_out0
[0000.312] I> QSPI Flash: Macronix 64MB
[0000.316] I> QSPI-0l initialized successfully
[0000.320] I> Task: TSC init
[0000.323] I> Task: Load membct
[0000.326] I> RAM_CODE 0x4000441
[0000.329] I> Loading MEMBCT
[0000.332] I> Slot: 1
[0000.334] I> Binary[1] block-65792 (partition size: 0x40000)
[0000.339] I> Binary name: MEM-BCT-1
[0000.343] I> Size of crypto header is 8192
[0000.347] I> Size of crypto header is 8192
[0000.351] I> strt_pg_num(65792) num_of_pgs(16) read_buf(0x40050000)
[0000.357] I> BCH of MEM-BCT-1 read from storage
[0000.361] I> BCH address is : 0x40050000
[0000.365] I> MEM-BCT-1 header integrity check is success
[0000.370] I> Binary magic in BCH component 1 is MEM1
[0000.375] I> component binary type is 1
[0000.379] I> strt_pg_num(65923) num_of_pgs(115) read_buf(0x40040000)
[0000.386] I> MEM-BCT-1 binary is read from storage
[0000.391] I> MEM-BCT-1 binary integrity check is success
[0000.396] I> Binary MEM-BCT-1 loaded successfully at 0x40040000 (0xe580)
[0000.402] I> RAM_CODE 0x4000441
[0000.408] I> RAM_CODE 0x4000441
[0000.411] I> Task: Load Page retirement list
[0000.416] I> Slot: 1
[0000.418] I> Binary[4] block-125952 (partition size: 0x80000)
[0000.423] I> Binary name: DRAM bad page list (P)
[0000.428] I> Size of crypto header is 8192
[0000.432] I> Size of crypto header is 8192
[0000.435] I> strt_pg_num(125952) num_of_pgs(16) read_buf(0x40050000)
[0000.442] I> BCH of DRAM bad page list (P) read from storage
[0000.447] I> BCH address is : 0x40050000
[0000.451] I> component binary type is 4
[0000.455] I> DRAM bad page list (P) header integrity check is success
[0000.461] I> Binary magic in BCH component 0 is BINF
[0000.466] I> component binary type is 4
[0000.470] I> component binary type is 4
[0000.473] I> Size of crypto header is 8192
[0000.477] I> component binary type is 4
[0000.481] I> strt_pg_num(125968) num_of_pgs(8) read_buf(0x40040000)
[0000.487] I> DRAM bad page list (P) binary is read from storage
[0000.493] I> DRAM bad page list (P) binary integrity check is success
[0000.499] I> Binary DRAM bad page list (P) loaded successfully at 0x40040000 (0x1000)
[0000.510] I> Task: SDRAM params override
[0000.513] I> Task: Save mem-bct info
[0000.517] I> Task: Carveout allocate
[0000.520] I> RCM blob carveout will not be allocated
[0000.525] I> Update CCPLEX IST carveout from MB1-BCT
[0000.530] I> ECC region[0]: Start:0x80000000, End:0xe80000000
[0000.535] I> ECC region[1]: Start:0x0, End:0x0
[0000.540] I> ECC region[2]: Start:0x0, End:0x0
[0000.544] I> ECC region[3]: Start:0x0, End:0x0
[0000.548] I> ECC region[4]: Start:0x0, End:0x0
[0000.553] I> Non-ECC region[0]: Start:0x0, End:0x0
[0000.557] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.562] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.566] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.571] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.582] I> allocated(CO:44) base:0xe49800000 size:0x36800000 align: 0x100000
[0000.589] I> allocated(CO:31) base:0xe40000000 size:0x8000000 align: 0x8000000
[0000.596] I> allocated(CO:43) base:0xe3c000000 size:0x4000000 align: 0x200000
[0000.603] I> allocated(CO:39) base:0xe39e00000 size:0x2200000 align: 0x10000
[0000.610] I> allocated(CO:20) base:0xe36000000 size:0x2000000 align: 0x2000000
[0000.617] I> allocated(CO:24) base:0xe34000000 size:0x2000000 align: 0x2000000
[0000.624] I> allocated(CO:28) base:0xe32000000 size:0x2000000 align: 0x2000000
[0000.631] I> allocated(CO:29) base:0xe30000000 size:0x2000000 align: 0x2000000
[0000.639] I> allocated(CO:22) base:0xe48000000 size:0x1000000 align: 0x1000000
[0000.646] I> allocated(CO:35) base:0xe38e00000 size:0x1000000 align: 0x100000
[0000.653] I> allocated(CO:41) base:0xe2f000000 size:0x1000000 align: 0x100000
[0000.660] I> allocated(CO:02) base:0xe49000000 size:0x800000 align: 0x800000
[0000.667] I> allocated(CO:03) base:0xe38000000 size:0x800000 align: 0x800000
[0000.674] I> allocated(CO:06) base:0xe2e800000 size:0x800000 align: 0x800000
[0000.681] I> allocated(CO:56) base:0xe2e000000 size:0x800000 align: 0x200000
[0000.687] I> allocated(CO:07) base:0xe38800000 size:0x400000 align: 0x400000
[0000.694] I> allocated(CO:33) base:0xe2dc00000 size:0x400000 align: 0x200000
[0000.701] I> allocated(CO:19) base:0xe2d980000 size:0x280000 align: 0x10000
[0000.708] I> allocated(CO:23) base:0xe38c00000 size:0x200000 align: 0x200000
[0000.715] I> allocated(CO:01) base:0xe2d800000 size:0x100000 align: 0x100000
[0000.722] I> allocated(CO:05) base:0xe2d700000 size:0x100000 align: 0x100000
[0000.729] I> allocated(CO:08) base:0xe2d600000 size:0x100000 align: 0x100000
[0000.736] I> allocated(CO:09) base:0xe2d500000 size:0x100000 align: 0x100000
[0000.743] I> allocated(CO:12) base:0xe2d400000 size:0x100000 align: 0x100000
[0000.750] I> allocated(CO:15) base:0xe2d300000 size:0x100000 align: 0x100000
[0000.757] I> allocated(CO:17) base:0xe2d200000 size:0x100000 align: 0x100000
[0000.764] I> allocated(CO:27) base:0xe2d100000 size:0x100000 align: 0x100000
[0000.771] I> allocated(CO:42) base:0xe2d000000 size:0x100000 align: 0x100000
[0000.778] I> allocated(CO:54) base:0xe2d900000 size:0x80000 align: 0x80000
[0000.784] I> allocated(CO:34) base:0xe2cff0000 size:0x10000 align: 0x10000
[0000.791] I> allocated(CO:72) base:0xe2cdf0000 size:0x200000 align: 0x10000
[0000.798] I> allocated(CO:47) base:0xe2c800000 size:0x400000 align: 0x200000
[0000.805] I> allocated(CO:50) base:0xe2c600000 size:0x200000 align: 0x100000
[0000.812] I> allocated(CO:52) base:0xe2cdc0000 size:0x30000 align: 0x10000
[0000.819] I> allocated(CO:48) base:0xe2cda0000 size:0x20000 align: 0x10000
[0000.825] I> allocated(CO:69) base:0xe2cd80000 size:0x20000 align: 0x10000
[0000.832] I> allocated(CO:49) base:0xe2cd70000 size:0x10000 align: 0x10000
[0000.839] I> NSDRAM base: 0x80000000, end: 0xe2cdf0000, size: 0xdacdf0000
[0000.846] I> Task: Thermal check
[0000.849] I> Using min_chip_limit as min_tmon_limit
[0000.853] I> Using max_chip_limit as max_tmon_limit
[0000.858] I> BCT max_tmon_limit = 118
[0000.862] I> BCT min_tmon_limit = -43
[0000.865] I> BCT max_tmon_limit = 118
[0000.869] I> BCT min_tmon_limit = -43
[0000.872] I> SKU specific max_chip_limit = 125
[0000.876] I> SKU specific min_chip_limit = -43
[0000.881] I> BCT max_chip_limit = 118
[0000.884] I> BCT min_chip_limit = -43
[0000.888] I> enable_soctherm_polling = 0
[0000.891] I> max temp read = 34
[0000.894] I> min temp read = 34
[0000.897] I> Enabling thermtrip
[0000.900] I> Task: Update FSI SCR with thermal fuse data
[0000.906] I> Task: Enable WDT 5th expiry
[0000.909] I> Task: I2C register
[0000.912] I> Task: Set I2C bus freq
[0000.916] I> Task: Reset FSI
[0000.918] I> Task: Pinmux init
[0000.922] I> Task: Prod config init
[0000.925] I> Task: Pad voltage init
[0000.928] I> Task: Prod init
[0000.931] I> Task: Program rst req config reg
[0000.935] I> Task: Common rail init
[0000.939] I> DONE: Thermal config
[0000.943] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0000.951] I> DONE: SOC rail config
[0000.955] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0000.962] I> DONE: MEMIO rail config
[0000.965] I> DONE: GPU rail info
[0000.968] I> DONE: CV rail info
[0000.971] I> Task: Mem clock src
[0000.974] I> Task: Misc. board config
[0000.978] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0000.984] I> Task: SDRAM init
[0000.987] I> MemoryType: 4 MemBctRevision: 8
[0000.993] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 8
[0001.001] I> MSS CAR: Init PLLM
[0001.004] I> MSS CAR: Init PLLHUB
[0001.009] I> Encryption:   MTS: en, TX: en, VPR: en, GSC: en
[0001.020] I> SDRAM initialized!
[0001.023] I> SDRAM Size in Total 0xe00000000
[0001.027] I> Task: Dram Ecc scrub
[0001.031] I> DRAM ECC Scrub Mode: full
[0002.752] I> SDRAM scrub successful
[0002.755] I> Task: DRAM alias check
[0002.772] I> Task: Program NSDRAM carveout
[0002.776] I> NSDRAM carveout encryption is enabled
[0002.781] I> Program NSDRAM carveout
[0002.784] I> Task: Register checker
[0002.788] I> Task: Enable clock-mon
[0002.802] I> FMON: Fmon re-programming done
[0002.806] I> Task: Mapper init
[0002.809] I> Task: SC7 Context Init
[0002.812] I> Task: CCPLEX IST init
[0002.816] I> Task: CPU WP0
[0002.818] I> Loading MCE
[0002.821] I> Slot: 1
[0002.823] I> Binary[8] block-82688 (partition size: 0x80000)
[0002.828] I> Binary name: MCE
[0002.831] I> Size of crypto header is 8192
[0002.835] I> Size of crypto header is 8192
[0002.839] I> strt_pg_num(82688) num_of_pgs(16) read_buf(0x4003e000)
[0002.845] I> BCH of MCE read from storage
[0002.849] I> BCH address is : 0x4003e000
[0002.853] I> MCE header integrity check is success
[0002.858] I> Binary magic in BCH component 0 is MTSM
[0002.862] I> component binary type is 8
[0002.866] I> Size of crypto header is 8192
[0002.870] I> strt_pg_num(82704) num_of_pgs(350) read_buf(0x40000000)
[0002.878] I> MCE binary is read from storage
[0002.883] I> MCE binary integrity check is success
[0002.887] I> Binary MCE loaded successfully at 0x40000000 (0x2baf0)
[0002.893] I> Size of crypto header is 8192
[0002.904] I> Size of crypto header is 8192
[0002.908] I> Sending WP0 mailbox command to PSC
[0002.918] I> Task: XUSB Powergate
[0002.921] I> Skipping powergate XUSB.
[0002.924] I> Task: MB1 fixed firewalls
[0002.930] W> Firewall readback mismatch
[0002.936] I> Task: Load bpmp-fw
[0002.939] I> Slot: 1
[0002.941] I> Binary[15] block-71936 (partition size: 0x180000)
[0002.946] I> Binary name: BPMP_FW
[0002.949] I> Size of crypto header is 8192
[0002.953] I> Size of crypto header is 8192
[0002.957] I> strt_pg_num(71936) num_of_pgs(16) read_buf(0x807fe000)
[0002.964] I> BCH of BPMP_FW read from storage
[0002.968] I> BCH address is : 0x807fe000
[0002.972] I> BPMP_FW header integrity check is success
[0002.977] I> Binary magic in BCH component 0 is BPMF
[0002.981] I> component binary type is 15
[0002.985] I> Size of crypto header is 8192
[0002.989] I> strt_pg_num(71952) num_of_pgs(2028) read_buf(0x80000000)
[0003.007] I> BPMP_FW binary is read from storage
[0003.013] I> BPMP_FW binary integrity check is success
[0003.018] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xfd640)
[0003.025] I> Slot: 1
[0003.027] I> Binary[16] block-75008 (partition size: 0x300000)
[0003.032] I> Binary name: BPMP_FW_DTB
[0003.036] I> Size of crypto header is 8192
[0003.040] I> Size of crypto header is 8192
[0003.044] I> strt_pg_num(75008) num_of_pgs(16) read_buf(0x807fc000)
[0003.050] I> BCH of BPMP_FW_DTB read from storage
[0003.055] I> BCH address is : 0x807fc000
[0003.058] I> BPMP_FW_DTB header integrity check is success
[0003.064] I> Binary magic in BCH component 0 is BPMD
[0003.068] I> component binary type is 16
[0003.072] I> Size of crypto header is 8192
[0003.076] I> strt_pg_num(75024) num_of_pgs(289) read_buf(0x807d7df0)
[0003.084] I> BPMP_FW_DTB binary is read from storage
[0003.089] I> BPMP_FW_DTB binary integrity check is success
[0003.095] I> Binary BPMP_FW_DTB loaded successfully at 0x807d7df0 (0x241c0)
[0003.101] I> Task: BPMP fw ast config
[0003.105] I> Task: Load psc-fw
[0003.108] I> Slot: 1
[0003.110] I> Binary[17] block-81152 (partition size: 0xc0000)
[0003.115] I> Binary name: PSC_FW
[0003.119] I> Size of crypto header is 8192
[0003.122] I> Size of crypto header is 8192
[0003.126] I> strt_pg_num(81152) num_of_pgs(16) read_buf(0x80ffe000)
[0003.133] I> BCH of PSC_FW read from storage
[0003.137] I> BCH address is : 0x80ffe000
[0003.141] I> PSC_FW header integrity check is success
[0003.145] I> Binary magic in BCH component 0 is PFWP
[0003.150] I> component binary type is 17
[0003.154] I> Size of crypto header is 8192
[0003.158] I> strt_pg_num(81168) num_of_pgs(591) read_buf(0x80fb4200)
[0003.168] I> PSC_FW binary is read from storage
[0003.173] I> PSC_FW binary integrity check is success
[0003.177] I> Binary PSC_FW loaded successfully at 0x80fb4200 (0x49df0)
[0003.184] I> Task: Load nvdec-fw
[0003.187] I> Slot: 1
[0003.189] I> Binary[7] block-68352 (partition size: 0x100000)
[0003.195] I> Binary name: NVDEC
[0003.198] I> Size of crypto header is 8192
[0003.201] I> Size of crypto header is 8192
[0003.205] I> strt_pg_num(68352) num_of_pgs(16) read_buf(0x800fe000)
[0003.212] I> BCH of NVDEC read from storage
[0003.216] I> BCH address is : 0x800fe000
[0003.219] I> NVDEC header integrity check is success
[0003.224] I> Binary magic in BCH component 0 is NDEC
[0003.229] I> component binary type is 7
[0003.233] I> Size of crypto header is 8192
[0003.237] I> strt_pg_num(68368) num_of_pgs(560) read_buf(0x80000000)
[0003.246] I> NVDEC binary is read from storage
[0003.251] I> NVDEC binary integrity check is success
[0003.256] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
[0003.262] I> Size of crypto header is 8192
[0003.274] I> Task: Load tsec-fw
[0003.277] I> TSEC-FW load support not enabled
[0003.281] I> Task: GPIO interrupt map
[0003.285] I> Task: SC7 context save
[0003.288] I> Slot: 1
[0003.290] I> Binary[27] block-0 (partition size: 0x100000)
[0003.295] I> Binary name: BR_BCT
[0003.298] I> Size of crypto header is 8192
[0003.302] I> Size of crypto header is 8192
[0003.306] I> Size of crypto header is 8192
[0003.310] I> strt_pg_num(0) num_of_pgs(16) read_buf(0xa0000000)
[0003.316] I> BR_BCT binary is read from storage
[0003.320] I> BR_BCT binary integrity check is success
[0003.325] I> Binary BR_BCT loaded successfully at 0xa0000000 (0x2000)
[0003.332] I> Slot: 1
[0003.334] I> Binary[13] block-83712 (partition size: 0x30000)
[0003.339] I> Binary name: SC7-FW
[0003.342] I> Size of crypto header is 8192
[0003.346] I> Size of crypto header is 8192
[0003.350] I> Size of crypto header is 8192
[0003.354] I> Size of crypto header is 8192
[0003.358] I> strt_pg_num(83712) num_of_pgs(16) read_buf(0xa0002000)
[0003.364] I> BCH of SC7-FW read from storage
[0003.368] I> BCH address is : 0xa0002000
[0003.372] I> SC7-FW header integrity check is success
[0003.377] I> Binary magic in BCH component 0 is WB0B
[0003.382] I> component binary type is 13
[0003.386] I> Size of crypto header is 8192
[0003.390] I> strt_pg_num(83728) num_of_pgs(349) read_buf(0xa0004000)
[0003.398] I> SC7-FW binary is read from storage
[0003.403] I> SC7-FW binary integrity check is success
[0003.408] I> Binary SC7-FW loaded successfully at 0xa0004000 (0x2b920)
[0003.414] I> Slot: 1
[0003.416] I> Binary[22] block-84096 (partition size: 0x30000)
[0003.422] I> Binary name: PSC_RF
[0003.425] I> Size of crypto header is 8192
[0003.428] I> Size of crypto header is 8192
[0003.432] I> Size of crypto header is 8192
[0003.436] I> Size of crypto header is 8192
[0003.440] I> strt_pg_num(84096) num_of_pgs(16) read_buf(0xa002f920)
[0003.447] I> BCH of PSC_RF read from storage
[0003.451] I> BCH address is : 0xa002f920
[0003.454] I> PSC_RF header integrity check is success
[0003.459] I> Binary magic in BCH component 0 is PSCR
[0003.464] I> component binary type is 22
[0003.468] I> Size of crypto header is 8192
[0003.472] I> strt_pg_num(84112) num_of_pgs(224) read_buf(0xa0031920)
[0003.479] I> PSC_RF binary is read from storage
[0003.484] I> PSC_RF binary integrity check is success
[0003.489] I> Binary PSC_RF loaded successfully at 0xa0031920 (0x1be60)
[0003.498] I> Task: Save WP0 payload to SC7 ctx
[0003.503] I> Task: Load MB2rf binary to SC7 ctx
[0003.507] I> Slot: 1
[0003.509] I> Binary[14] block-84480 (partition size: 0x20000)
[0003.515] I> Binary name: MB2_RF
[0003.518] I> Size of crypto header is 8192
[0003.522] I> Size of crypto header is 8192
[0003.526] I> Size of crypto header is 8192
[0003.529] I> Size of crypto header is 8192
[0003.533] I> strt_pg_num(84480) num_of_pgs(16) read_buf(0xa00d5d10)
[0003.540] I> BCH of MB2_RF read from storage
[0003.544] I> BCH address is : 0xa00d5d10
[0003.548] I> MB2_RF header integrity check is success
[0003.553] I> Binary magic in BCH component 0 is MB2R
[0003.557] I> component binary type is 14
[0003.561] I> Size of crypto header is 8192
[0003.565] I> strt_pg_num(84496) num_of_pgs(224) read_buf(0xa00d7d10)
[0003.573] I> MB2_RF binary is read from storage
[0003.577] I> MB2_RF binary integrity check is success
[0003.582] I> Binary MB2_RF loaded successfully at 0xa00d7d10 (0x1bf30)
[0003.588] I> Task: Save fuse alias data to SC7 ctx
[0003.593] I> Task: Save PMIC data to SC7 ctx
[0003.597] I> Task: Save Pinmux data to SC7 ctx
[0003.601] I> Task: Save Pad Voltage data to SC7 ctx
[0003.606] I> Task: Save controller prod data to SC7 ctx
[0003.611] I> Task: Save prod cfg data to SC7 ctx
[0003.616] I> Task: Save I2C bus freq data to SC7 ctx
[0003.621] I> Task: Save SOCTherm data to SC7 ctx
[0003.625] I> Task: Save FMON data to SC7 ctx
[0003.629] I> Task: Save VMON data to SC7 ctx
[0003.633] I> Task: Save TZDRAM data to SC7 ctx
[0003.637] I> Task: Save GPIO int data to SC7 ctx
[0003.642] I> Task: Save clock data to SC7 ctx
[0003.646] I> Task: Save debug data to SC7 ctx
[0003.650] I> Task: Save MBWT data to SC7 ctx
[0003.658] I> SC7 context save done
[0003.662] I> Task: Load MB2/Applet/FSKP
[0003.665] I> Loading MB2
[0003.668] I> Slot: 1
[0003.670] I> Binary[6] block-70400 (partition size: 0x80000)
[0003.675] I> Binary name: MB2
[0003.678] I> Size of crypto header is 8192
[0003.682] I> Size of crypto header is 8192
[0003.686] I> strt_pg_num(70400) num_of_pgs(16) read_buf(0x8007e000)
[0003.692] I> BCH of MB2 read from storage
[0003.696] I> BCH address is : 0x8007e000
[0003.700] I> MB2 header integrity check is success
[0003.704] I> Binary magic in BCH component 0 is MB2B
[0003.709] I> component binary type is 6
[0003.713] I> Size of crypto header is 8192
[0003.717] I> strt_pg_num(70416) num_of_pgs(844) read_buf(0x80000000)
[0003.728] I> MB2 binary is read from storage
[0003.733] I> MB2 binary integrity check is success
[0003.737] I> Binary MB2 loaded successfully at 0x80000000 (0x696a0)
[0003.744] I> Task: Map CCPLEX SHARED carveout
[0003.748] I> Task: Prepare MB2 params
[0003.752] I> Task: Dram ecc test
[0003.755] I> Task: Misc NV security settings
[0003.759] I> NVDEC sticky bits programming done
[0003.763] I> Successfully powergated NVDEC
[0003.767] I> Task: Disable/Reload WDT
[0003.771] I> Task: Program misc carveouts
[0003.775] I> Program IPC carveouts
[0003.778] I> Task: Disable SCPM/POD reset
[0003.782] I> SLCG Global override status := 0x0
[0003.786] I> MB1: MSS reconfig completed
I> Emulation:
I> Entry timestamp: 0x003a2fa7
I> strt_pg_num(130592) num_of_pgs(1) read_buf(0xe2e001000)
I> strt_pg_num(130560) num_of_pgs(32) read_buf(0xe2e001200)
I> Unpowergate done
I> Partition name: B_spe-fw
I> Binary@ device:3/0 block-116992 (partition size: 0x90000), name: B_spe-fw
I> strt_pg_num(116992) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(117008) num_of_pgs(512) read_buf(0xe2d600000)
I> Partition name: B_rce-fw
I> Binary@ device:3/0 block-118144 (partition size: 0x100000), name: B_rce-fw
I> strt_pg_num(118144) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(118160) num_of_pgs(880) read_buf(0xe2d200000)
I> Partition name: B_dce-fw
I> Binary@ device:3/0 block-100608 (partition size: 0x200000), name: B_dce-fw
I> strt_pg_num(100608) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(100624) num_of_pgs(1) read_buf(0xe2e1403d8)
I> strt_pg_num(100624) num_of_pgs(8) read_buf(0xe2e1403d8)
I> strt_pg_num(100632) num_of_pgs(512) read_buf(0xe2e0003c0)
I> strt_pg_num(101144) num_of_pgs(512) read_buf(0xe2e0403c0)
I> strt_pg_num(101656) num_of_pgs(512) read_buf(0xe2e0803c0)
I> Partition name: B_adsp-fw
I> Binary@ device:3/0 block-120192 (partition size: 0x200000), name: B_adsp-fw
I> strt_pg_num(120192) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(120208) num_of_pgs(800) read_buf(0xe38800000)
I> Partition name: B_fsi-fw
I> Binary@ device:3/0 block-104704 (partition size: 0x600000), name: B_fsi-fw
I> strt_pg_num(104704) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(104720) num_of_pgs(11208) read_buf(0xe30000000)
I> Partition name: B_xusb-fw
I> Binary@ device:3/0 block-71424 (partition size: 0x40000), name: B_xusb-fw
I> strt_pg_num(71424) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(71440) num_of_pgs(312) read_buf(0xe2d700000)
I> Partition name: B_pva-fw
I> Binary@ device:3/0 block-124288 (partition size: 0x40000), name: B_pva-fw
I> strt_pg_num(124288) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(124304) num_of_pgs(1) read_buf(0xe2e1403d8)
I> strt_pg_num(124304) num_of_pgs(8) read_buf(0xe2e1403d8)
I> strt_pg_num(124312) num_of_pgs(512) read_buf(0xe2e0003c0)
I> Busy Spin
Any help with this would be great. I tried to reflash using both the SDK manager and the flash.sh scripts and wind up getting “Parsing Board Information Failed”. Hopefully there’s a relatively easy solution and I’m just missing something silly. I already attempted to change the eeprom read size from 0x100 to 0x0 in tegra234-mb2-bct-common.dtsi so that the final eeprom reads as;
eeprom {
            cvm_eeprom_i2c_instance = <0>;
            cvm_eeprom_i2c_slave_address = <0xa0>;
            cvm_eeprom_read_size = <0x100>;
            cvb_eeprom_i2c_instance = <0x0>;
            cvb_eeprom_i2c_slave_address = <0xac>;
            cvb_eeprom_read_size = <0x0>;
But flashing with sudo ./flash.sh jetson-agx-orin-devkit-industrial mmcblk0p1 still leads to the “Parsing board information failed” return. Output from that command below;
# L4T BSP Information:
# R36 , REVISION: 3.0
# User release: 0.0
ECID is 0x80012344705DE35D2400000019010040
# Target Board Information:
# Name: jetson-agx-orin-devkit-industrial, Board Family: generic, SoC: Tegra 234,
# OpMode: production, Boot Authentication: NS,
# Disk encryption: disabled ,
Existing emcfuse(/home/logan.weiss@spx.local/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/fuse_t234.xml) reused.
copying emc_fuse_dev_params(/home/logan.weiss@spx.local/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/generic/BCT/tegra234-br-bct-diag-boot.dts)... done.
copying device_config(/home/logan.weiss@spx.local/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-device-p3701-0000.dts)... done.
copying misc_config(/home/logan.weiss@spx.local/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-misc-p3701-0008-flash.dts)... done.
./tegraflash.py --chip "0x23" --applet "/home/logan.weiss@spx.local/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/mb1_t234_prod.bin" --skipuid --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3701-0000.dts --misc_config tegra234-mb1-bct-misc-p3701-0008-flash.dts --bins "mb2_applet applet_t234.bin" --cmd "readfuses fuse_t234.bin fuse_t234.xml; dump eeprom cvm cvm.bin; dump try_custinfo custinfo_out.bin; reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[   0.0168 ] Reading fuses
[   0.0202 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.0244 ] File rcm_state open failed
[   0.0251 ] ERROR: failed to read rcm_state
[   0.0251 ]
[   0.0262 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0267 ] Assuming zero filled SBK key
[   0.0263 ] Pre-processing config: tegra234-mb1-bct-device-p3701-0000.dts
[   0.0444 ] Pre-processing config: tegra234-mb1-bct-misc-p3701-0008-flash.dts
[   0.0747 ] Parsing partition layout
[   0.0793 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.0857 ] Kernel DTB used: None
[   0.0858 ] WARNING: dce base dtb is not provided
[   0.0858 ] Parsing partition layout
[   0.0900 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.0957 ] Creating list of images to be signed
[   0.1001 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[   0.1045 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.1069 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.1078 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.1216 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.1226 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.1319 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.1329 ] adding BCH for mb2_t234_aligned.bin
[   0.1363 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.1499 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.1509 ] adding BCH for mb2_t234_aligned.bin
[   0.1622 ] Filling MB1 storage info
[   0.1623 ] Parsing dev params for multi chains
[   0.1838 ] Generating br-bct
[   0.1875 ] Updating dev and MSS params in BR BCT
[   0.1876 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   0.1924 ] Updating bl info
[   0.1968 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin
[   0.2014 ] WARNING: boot chain is not completed. set to 0
[   0.2035 ] Generating signatures
[   0.2045 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.2050 ] Assuming zero filled SBK key
[   0.2544 ] Warning: pub_key.key is not found
[   0.2545 ] Parsing dev params for multi chains
[   0.2545 ] Generating br-bct
[   0.2588 ] Updating dev and MSS params in BR BCT
[   0.2590 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   0.2646 ] Updating bl info
[   0.2690 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.2738 ] WARNING: boot chain is not completed. set to 0
[   0.2763 ] Generating SHA2 Hash
[   0.2837 ] Sha saved in br_bct_BR.sha
[   0.2834 ] Get Signed section of bct
[   0.2875 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   0.2929 ] Signing BCT
[   0.2939 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.2945 ] Assuming zero filled SBK key
[   0.3073 ] Sha saved in br_bct_BR.sha
[   0.3085 ] Warning: pub_key.key is not found
[   0.3077 ] Updating BCT with signature
[   0.3121 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   0.3179 ] Offset :4608 Len :3584
[   0.3192 ] Generating SHA2 Hash
[   0.3202 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   0.3207 ] Assuming zero filled SBK key
[   0.3208 ] Assuming zero filled SBK key
[   0.3306 ] Sha saved in br_bct_BR.sha
[   0.3309 ] Updating BCT with SHA2 Hash
[   0.3351 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[   0.3399 ] Offset :4608 Len :3584
[   0.3409 ] Offset :68 Len :8124
[   0.3416 ] Generating coldboot mb1-bct
[   0.3460 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0008-flash_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   0.3511 ] MB1-BCT version: 0.13
[   0.3516 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_TEMP_QB_DATA/ is not supported
[   0.3560 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_TEMP_QB_IO_BUFFER/ is not supported
[   0.3585 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   0.3593 ] Added Platform Config 9 data with size :- 100
[   0.3593 ]
[   0.3594 ] Updating mb1-bct with firmware information
[   0.3638 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.3749 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   0.3807 ] Generating SHA2 Hash for mb1bct
[   0.3880 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[   0.3945 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[   0.3987 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   0.4033 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   0.4067 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.4073 ] Assuming zero filled SBK key
[   0.4158 ] Warning: pub_key.key is not found
[   0.4197 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.4266 ] Generating recovery mb1-bct
[   0.4311 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0008-flash_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   0.4364 ] MB1-BCT version: 0.13
[   0.4369 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_TEMP_QB_DATA/ is not supported
[   0.4402 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_TEMP_QB_IO_BUFFER/ is not supported
[   0.4418 ]
[   0.4419 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   0.4419 ] Added Platform Config 9 data with size :- 100
[   0.4419 ]
[   0.4420 ] Updating mb1-bct with firmware information
[   0.4468 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.4576 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[   0.4628 ] Generating SHA2 Hash for mb1bct
[   0.4703 ] Sha saved in mb1_bct_MB1_aligned.sha
[   0.4775 ] Sha saved in mb1_bct_MB1.sha
[   0.4815 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[   0.4864 ] adding BCH for mb1_bct_MB1_aligned.bct
[   0.4896 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.4901 ] Assuming zero filled SBK key
[   0.4976 ] Warning: pub_key.key is not found
[   0.5020 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.5085 ] Info: Skip generating mem_bct because sdram_config is not defined
[   0.5086 ] Info: Skip generating mem_bct because sdram_config is not defined
[   0.5086 ] Copying signatures
[   0.5132 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.5298 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[   0.5302 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[   0.5303 ] Boot Rom communication
[   0.5349 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[   0.5404 ] BR_CID: 0x80012344705DE35D2400000019010040
[   0.5973 ] Sending bct_br
[   0.6526 ] Sending mb1
[   0.6533 ] Sending psc_bl1
[   0.6628 ] Sending bct_mb1
[   0.6680 ] Boot Rom communication completed
[   0.6741 ] tegrahost_v2 --chip 0x23 0 --align applet_t234_aligned.bin
[   0.6837 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --appendsigheader applet_t234_aligned.bin zerosbk
[   0.6886 ] adding BCH for applet_t234_aligned.bin
[   0.7107 ] tegrasign_v3.py --key None --list applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.7113 ] Assuming zero filled SBK key
[   0.7203 ] Warning: pub_key.key is not found
[   0.7231 ] tegrahost_v2 --chip 0x23 0 --updatesigheader applet_t234_aligned_sigheader.bin.encrypt applet_t234_aligned_sigheader.bin.hash zerosbk
[   0.7307 ] Sending mb2_applet...
[   0.7355 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download applet applet_t234_sigheader.bin.encrypt
[   0.7398 ] BL: version 1.4.0.2-t234-54845784-08a4de08 last_boot_error: 656573201
[   0.8939 ] Sending applet
[   0.9490 ] ERROR: might be timeout in USB write.
Error: Return value 3
Command tegrarcm_v2 --chip 0x23 0 --pollbl --download applet applet_t234_sigheader.bin.encrypt
[   1.0045 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   1.0151 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   1.0250 ] Retrieving board information
[   1.0299 ] tegrarcm_v2 --chip 0x23 0 --oem platformdetails chip chip_info.bin
[   1.0356 ] Retrieving EEPROM data
[   1.0358 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/logan.weiss@spx.local/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/cvm.bin --chip 0x23 0
[   1.0456 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   1.0551 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   1.0600 ] Dumping customer Info
[   1.0658 ] tegrarcm_v2 --chip 0x23 0 --oem dump bct tmp.bct
[   1.0757 ] tegrabct_v2 --brbct tmp.bct --chip 0x23 0 --custinfo /home/logan.weiss@spx.local/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/custinfo_out.bin
[   1.0806 ] File tmp.bct open failed
[   1.0806 ]
[   1.0807 ] Error: try getting custinfo fail. Moving on
[   1.0808 ] Rebooting to recovery mode
[   1.0851 ] tegrarcm_v2 --chip 0x23 0 --ismb2
[   1.0897 ] Rebooting to recovery mode
[   1.0941 ] tegrarcm_v2 --chip 0x23 0 --reboot recovery
Parsing board information failed.
Is the above log you shared already after you disable cvb eeprom or not?
Just ensure you have compiled DTB, kernel etc and followed the build steps in the kernel customisation section correctly before flashing…
