I updated my orin jetson AGX to ubuntu 22.04 on accident. now i can’t get into recovery mode to reflash. I tried the method listed in the documentation. such as holding the middle button then plugging in the power. I also tried pressing the middle button, then the reset button while the power is on.
When I do lsusb i don’t see anything while the usb-c next to the 40 pin is connected. When I plugin the micro usb and do lsusb I see Bus 001 Device 009: ID 0955:7045 NVIDIA Corp. Tegra On-Platform Operator
I am also able to get logs with minicom such as the ones below, but don’t know what to make of them
[0000.065] I> MB1 (version: 1.2.0.0-t234-54845784-562369e5)
[0000.070] I> t234-A01-1-Silicon (0x12347) Prod
[0000.074] I> Boot-mode : Coldboot
[0000.078] I> Entry timestamp: 0x00000000
[0000.081] I> last_boot_error: 0x0
[0000.084] I> BR-BCT: preprod_dev_sign: 0
[0000.088] I> rst_source: 0x0, rst_level: 0x0
[0000.092] I> Task: SE error check
[0000.095] I> Task: Bootchain select WAR set
[0000.099] I> Task: Enable SLCG
[0000.102] I> Task: CRC check
[0000.105] I> Task: Initialize MB2 params
[0000.109] I> MB2-params @ 0x40060000
[0000.113] I> Task: Crypto init
[0000.116] I> Task: Perform MB1 KAT tests
[0000.120] I> Task: NVRNG health check
[0000.123] I> NVRNG: Health check success
[0000.127] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0000.133] I> Task: Enabling and initialization of Bandwidth limiter
[0000.139] I> No request to configure MBWT settings for any PC!
[0000.145] I> Task: Secure debug controls
[0000.149] I> Task: strap war set
[0000.152] I> Task: Initialize SOC Therm
[0000.155] I> Task: Program NV master stream id
[0000.160] I> Task: Verify boot mode
[0000.165] I> Task: Alias fuses
[0000.169] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.176] I> Task: Print SKU type
[0000.179] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x00000000
[0000.185] I> FUSE_OPT_GPC_DISABLE = 0x00000000
[0000.189] I> FUSE_OPT_TPC_DISABLE = 0x00000000
[0000.193] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0000.197] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0000.202] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0000.206] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0000.211] I> FUSE_OPT_FSI_DISABLE = 0x00000000
[0000.215] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0000.219] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.223] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.227] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.231] I> FUSE_SKU_INFO_0 = 0xd0
[0000.235] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.239] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.243] I> SKU: Prod
[0000.245] I> Task: Boost clocks
[0000.248] I> Initializing PLLC2 for AXI_CBB.
[0000.252] I> AXI_CBB : src = 35, divisor = 0
[0000.256] I> Task: Voltage monitor
[0000.259] I> VMON: Vmon re-calibration and fine tuning done
[0000.265] I> Task: UPHY init
[0000.270] I> HSIO UPHY init done
[0000.273] W> Skipping GBE UPHY config
[0000.276] I> Task: Boot device init
[0000.280] I> Boot_device: QSPI_FLASH instance: 0
[0000.284] I> Qspi clock source : pllc_out0
[0000.288] I> QSPI Flash: Macronix 64MB
[0000.292] I> QSPI-0l initialized successfully
[0000.296] I> Task: TSC init
[0000.299] I> Task: Load membct
[0000.302] I> RAM_CODE 0x4000431
[0000.305] I> Loading MEMBCT
[0000.308] I> Slot: 0
[0000.310] I> Binary[0] block-3840 (partition size: 0x40000)
[0000.315] I> Binary name: MEM-BCT-0
[0000.318] I> Size of crypto header is 8192
[0000.322] I> Size of crypto header is 8192
[0000.326] I> strt_pg_num(3840) num_of_pgs(16) read_buf(0x40050000)
[0000.333] I> BCH of MEM-BCT-0 read from storage
[0000.337] I> BCH address is : 0x40050000
[0000.341] I> MEM-BCT-0 header integrity check is success
[0000.346] I> Binary magic in BCH component 0 is MEM0
[0000.351] I> component binary type is 0
[0000.355] I> strt_pg_num(3856) num_of_pgs(115) read_buf(0x40040000)
[0000.361] I> MEM-BCT-0 binary is read from storage
[0000.366] I> MEM-BCT-0 binary integrity check is success
[0000.371] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0000.378] I> RAM_CODE 0x4000431
[0000.383] I> RAM_CODE 0x4000431
[0000.387] I> Task: Load Page retirement list
[0000.391] I> Task: SDRAM params override
[0000.395] I> Task: Save mem-bct info
[0000.399] I> Task: Carveout allocate
[0000.402] I> RCM blob carveout will not be allocated
[0000.407] I> Update CCPLEX IST carveout from MB1-BCT
[0000.412] I> ECC region[0]: Start:0x0, End:0x0
[0000.416] I> ECC region[1]: Start:0x0, End:0x0
[0000.420] I> ECC region[2]: Start:0x0, End:0x0
[0000.424] I> ECC region[3]: Start:0x0, End:0x0
[0000.429] I> ECC region[4]: Start:0x0, End:0x0
[0000.433] I> Non-ECC region[0]: Start:0x80000000, End:0x1080000000
[0000.439] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.444] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.448] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.453] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.464] I> allocated(CO:44) base:0x1049800000 size:0x36800000 align: 0x100000
[0000.471] I> allocated(CO:31) base:0x1040000000 size:0x8000000 align: 0x8000000
[0000.478] I> allocated(CO:43) base:0x103c000000 size:0x4000000 align: 0x200000
[0000.485] I> allocated(CO:39) base:0x1039e00000 size:0x2200000 align: 0x10000
[0000.492] I> allocated(CO:20) base:0x1036000000 size:0x2000000 align: 0x2000000
[0000.499] I> allocated(CO:24) base:0x1034000000 size:0x2000000 align: 0x2000000
[0000.507] I> allocated(CO:28) base:0x1032000000 size:0x2000000 align: 0x2000000
[0000.514] I> allocated(CO:29) base:0x1030000000 size:0x2000000 align: 0x2000000
[0000.521] I> allocated(CO:22) base:0x1048000000 size:0x1000000 align: 0x1000000
[0000.528] I> allocated(CO:41) base:0x1038e00000 size:0x1000000 align: 0x100000
[0000.535] I> allocated(CO:35) base:0x1038000000 size:0xe00000 align: 0x10000
[0000.542] I> allocated(CO:02) base:0x1049000000 size:0x800000 align: 0x800000
[0000.549] I> allocated(CO:03) base:0x102f800000 size:0x800000 align: 0x800000
[0000.556] I> allocated(CO:06) base:0x102f000000 size:0x800000 align: 0x800000
[0000.563] I> allocated(CO:56) base:0x102e800000 size:0x800000 align: 0x200000
[0000.571] I> allocated(CO:07) base:0x102e400000 size:0x400000 align: 0x400000
[0000.578] I> allocated(CO:33) base:0x102e000000 size:0x400000 align: 0x200000
[0000.585] I> allocated(CO:23) base:0x102de00000 size:0x200000 align: 0x200000
[0000.592] I> allocated(CO:01) base:0x102dd00000 size:0x100000 align: 0x100000
[0000.599] I> allocated(CO:04) base:0x102dc00000 size:0x100000 align: 0x100000
[0000.606] I> allocated(CO:05) base:0x102db00000 size:0x100000 align: 0x100000
[0000.613] I> allocated(CO:08) base:0x102da00000 size:0x100000 align: 0x100000
[0000.620] I> allocated(CO:09) base:0x102d900000 size:0x100000 align: 0x100000
[0000.627] I> allocated(CO:15) base:0x102d800000 size:0x100000 align: 0x100000
[0000.634] I> allocated(CO:17) base:0x102d700000 size:0x100000 align: 0x100000
[0000.641] I> allocated(CO:27) base:0x102d600000 size:0x100000 align: 0x100000
[0000.648] I> allocated(CO:42) base:0x102d500000 size:0x100000 align: 0x100000
[0000.655] I> allocated(CO:54) base:0x102d480000 size:0x80000 align: 0x80000
[0000.662] I> allocated(CO:34) base:0x102d470000 size:0x10000 align: 0x10000
[0000.669] I> allocated(CO:72) base:0x102d270000 size:0x200000 align: 0x10000
[0000.676] I> allocated(CO:47) base:0x102ce00000 size:0x400000 align: 0x200000
[0000.683] I> allocated(CO:48) base:0x102d250000 size:0x20000 align: 0x10000
[0000.689] I> allocated(CO:69) base:0x102d230000 size:0x20000 align: 0x10000
[0000.696] I> allocated(CO:49) base:0x102d220000 size:0x10000 align: 0x10000
[0000.703] I> allocated(CO:50) base:0x102d210000 size:0x10000 align: 0x10000
[0000.710] I> allocated(CO:52) base:0x102d200000 size:0x10000 align: 0x10000
[0000.717] I> NSDRAM base: 0x80000000, end: 0x102d270000, size: 0xfad270000
[0000.724] I> Task: Thermal check
[0000.727] I> max_chip_limit = 105
[0000.730] I> min_chip_limit = -28
[0000.733] I> max temp read = 36
[0000.736] I> min temp read = 35
[0000.739] I> Task: Update FSI SCR with thermal fuse data
[0000.744] I> Task: Enable WDT 5th expiry
[0000.748] I> Task: I2C register
[0000.751] I> Task: Set I2C bus freq
[0000.754] I> Task: Reset FSI
[0000.757] I> Task: Pinmux init
[0000.760] I> Task: Prod config init
[0000.764] I> Task: Pad voltage init
[0000.767] I> Task: Prod init
[0000.770] I> Task: Program rst req config reg
[0000.774] I> Task: Common rail init
[0000.777] I> DONE: Thermal config
[0000.781] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0000.789] I> DONE: SOC rail config
[0000.793] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0000.800] I> DONE: MEMIO rail config
[0000.803] I> DONE: GPU rail info
[0000.806] I> DONE: CV rail info
[0000.809] I> Task: Mem clock src
[0000.812] I> Task: Misc. board config
[0000.816] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0000.822] I> Task: SDRAM init
[0000.824] I> MemoryType: 4 MemBctRevision: 8
[0000.831] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 8
[0000.838] I> MSS CAR: Init PLLM
[0000.842] I> MSS CAR: Init PLLHUB
[0000.846] I> Encryption: MTS: en, TX: en, VPR: en, GSC: en
[0000.858] I> SDRAM initialized!
[0000.861] I> SDRAM Size in Total 0x1000000000
[0000.865] I> Task: Dram Ecc scrub
[0000.868] I> Task: DRAM alias check
[0000.897] I> Task: Program NSDRAM carveout
[0000.901] I> NSDRAM carveout encryption is enabled
[0000.906] I> Program NSDRAM carveout
[0000.911] I> Task: Register checker
[0000.917] I> Task: Enable clock-mon
[0000.932] I> FMON: Fmon re-programming done
[0000.936] I> Task: Mapper init
[0000.940] I> Task: SC7 Context Init
[0000.944] I> Task: CCPLEX IST init
[0000.948] I> Task: CPU WP0
[0000.951] I> Loading MCE
[0000.954] I> Slot: 0
[0000.956] I> Binary[8] block-22784 (partition size: 0x80000)
[0000.963] I> Binary name: MCE
[0000.966] I> Size of crypto header is 8192
[0000.970] I> Size of crypto header is 8192
[0000.975] I> strt_pg_num(22784) num_of_pgs(16) read_buf(0x4003e000)
[0000.983] I> BCH of MCE read from storage
[0000.987] I> BCH address is : 0x4003e000
[0000.992] I> MCE header integrity check is success
[0000.997] I> Binary magic in BCH component 0 is MTSM
[0001.002] I> component binary type is 8
[0001.006] I> Size of crypto header is 8192
[0001.011] I> strt_pg_num(22800) num_of_pgs(357) read_buf(0x40000000)
[0001.021] I> MCE binary is read from storage
[0001.026] I> MCE binary integrity check is success
[0001.031] I> Binary MCE loaded successfully at 0x40000000 (0x2c880)
[0001.039] I> Size of crypto header is 8192
[0001.054] I> Size of crypto header is 8192
[0001.059] I> Sending WP0 mailbox command to PSC
[0001.068] I> Task: XUSB Powergate
[0001.072] I> Skipping powergate XUSB.
[0001.075] I> Task: MB1 fixed firewalls
[0001.092] W> Firewall readback mismatch
[0001.102] I> Task: Load bpmp-fw
[0001.106] I> Slot: 0
[0001.108] I> Binary[15] block-9984 (partition size: 0x180000)
[0001.115] I> Binary name: BPMP_FW
[0001.119] I> Size of crypto header is 8192
[0001.123] I> Size of crypto header is 8192
[0001.128] I> strt_pg_num(9984) num_of_pgs(16) read_buf(0x807fe000)
[0001.135] I> BCH of BPMP_FW read from storage
[0001.140] I> BCH address is : 0x807fe000
[0001.145] I> BPMP_FW header integrity check is success
[0001.151] I> Binary magic in BCH component 0 is BPMF
[0001.156] I> component binary type is 15
[0001.160] I> Size of crypto header is 8192
[0001.165] I> strt_pg_num(10000) num_of_pgs(2037) read_buf(0x80000000)
[0001.183] I> BPMP_FW binary is read from storage
[0001.191] I> BPMP_FW binary integrity check is success
[0001.196] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xfea00)
[0001.204] I> Slot: 0
[0001.206] I> Binary[16] block-13056 (partition size: 0x400000)
[0001.213] I> Binary name: BPMP_FW_DTB
[0001.217] I> Size of crypto header is 8192
[0001.222] I> Size of crypto header is 8192
[0001.226] I> strt_pg_num(13056) num_of_pgs(16) read_buf(0x807fc000)
[0001.234] I> BCH of BPMP_FW_DTB read from storage
[0001.239] I> BCH address is : 0x807fc000
[0001.244] I> BPMP_FW_DTB header integrity check is success
[0001.250] I> Binary magic in BCH component 0 is BPMD
[0001.255] I> component binary type is 16
[0001.260] I> Size of crypto header is 8192
[0001.264] I> strt_pg_num(13072) num_of_pgs(259) read_buf(0x807db9f0)
[0001.273] I> BPMP_FW_DTB binary is read from storage
[0001.279] I> BPMP_FW_DTB binary integrity check is success
[0001.285] I> Binary BPMP_FW_DTB loaded successfully at 0x807db9f0 (0x20480)
[0001.294] I> Task: Load psc-fw
[0001.298] I> Slot: 0
[0001.300] I> Binary[17] block-21248 (partition size: 0xc0000)
[0001.307] I> Binary name: PSC_FW
[0001.310] I> Size of crypto header is 8192
[0001.315] I> Size of crypto header is 8192
[0001.319] I> strt_pg_num(21248) num_of_pgs(16) read_buf(0x80ffe000)
[0001.327] I> BCH of PSC_FW read from storage
[0001.332] I> BCH address is : 0x80ffe000
[0001.337] I> PSC_FW header integrity check is success
[0001.342] I> Binary magic in BCH component 0 is PFWP
[0001.348] I> component binary type is 17
[0001.352] I> Size of crypto header is 8192
[0001.356] I> strt_pg_num(21264) num_of_pgs(717) read_buf(0x80fa4600)
[0001.368] I> PSC_FW binary is read from storage
[0001.374] I> PSC_FW binary integrity check is success
[0001.379] I> Binary PSC_FW loaded successfully at 0x80fa4600 (0x59980)
[0001.388] I> Task: Load nvdec-fw
[0001.391] I> Slot: 0
[0001.394] I> Binary[7] block-6400 (partition size: 0x100000)
[0001.400] I> Binary name: NVDEC
[0001.404] I> Size of crypto header is 8192
[0001.408] I> Size of crypto header is 8192
[0001.413] I> strt_pg_num(6400) num_of_pgs(16) read_buf(0x800fe000)
[0001.420] I> BCH of NVDEC read from storage
[0001.425] I> BCH address is : 0x800fe000
[0001.430] I> NVDEC header integrity check is success
[0001.435] I> Binary magic in BCH component 0 is NDEC
[0001.441] I> component binary type is 7
[0001.445] I> Size of crypto header is 8192
[0001.449] I> strt_pg_num(6416) num_of_pgs(560) read_buf(0x80000000)
[0001.460] I> NVDEC binary is read from storage
[0001.466] I> NVDEC binary integrity check is success
[0001.471] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
[0001.479] I> Size of crypto header is 8192
[0001.500] I> Task: Load tsec-fw
[0001.503] I> TSEC-FW load support not enabled
[0001.508] I> Task: GPIO interrupt map
[0001.512] I> Task: SC7 context save
[0001.516] I> Slot: 0
[0001.518] I> Binary[27] block-0 (partition size: 0x100000)
[0001.524] I> Binary name: BR_BCT
[0001.528] I> Size of crypto header is 8192
[0001.532] I> Size of crypto header is 8192
[0001.537] I> strt_pg_num(0) num_of_pgs(16) read_buf(0xa0000000)
[0001.544] I> BR_BCT binary is read from storage
[0001.549] I> BR_BCT binary integrity check is success
[0001.555] I> Binary BR_BCT loaded successfully at 0xa0000000 (0x2000)
[0001.562] I> Slot: 0
[0001.565] I> Binary[13] block-23808 (partition size: 0x30000)
[0001.571] I> Binary name: SC7-FW
[0001.575] I> Size of crypto header is 8192
[0001.579] I> Size of crypto header is 8192
[0001.584] I> Size of crypto header is 8192
[0001.588] I> strt_pg_num(23808) num_of_pgs(16) read_buf(0xa0002000)
[0001.596] I> BCH of SC7-FW read from storage
[0001.601] I> BCH address is : 0xa0002000
[0001.606] I> SC7-FW header integrity check is success
[0001.611] I> Binary magic in BCH component 0 is WB0B
[0001.617] I> component binary type is 13
[0001.621] I> Size of crypto header is 8192
[0001.626] I> strt_pg_num(23824) num_of_pgs(345) read_buf(0xa0004000)
[0001.635] I> SC7-FW binary is read from storage
[0001.641] I> SC7-FW binary integrity check is success
[0001.646] I> Binary SC7-FW loaded successfully at 0xa0004000 (0x2b0e0)
[0001.654] I> Slot: 0
[0001.656] I> Binary[22] block-24192 (partition size: 0x30000)
[0001.663] I> Binary name: PSC_RF
[0001.667] I> Size of crypto header is 8192
[0001.671] I> Size of crypto header is 8192
[0001.676] I> Size of crypto header is 8192
[0001.680] I> strt_pg_num(24192) num_of_pgs(16) read_buf(0xa002f0e0)
[0001.688] I> BCH of PSC_RF read from storage
[0001.693] I> BCH address is : 0xa002f0e0
[0001.698] I> PSC_RF header integrity check is success
[0001.703] I> Binary magic in BCH component 0 is PSCR
[0001.709] I> component binary type is 22
[0001.713] I> Size of crypto header is 8192
[0001.717] I> strt_pg_num(24208) num_of_pgs(223) read_buf(0xa00310e0)
[0001.726] I> PSC_RF binary is read from storage
[0001.732] I> PSC_RF binary integrity check is success
[0001.737] I> Binary PSC_RF loaded successfully at 0xa00310e0 (0x1bdd0)
[0001.761] I> Task: Save WP0 payload to SC7 ctx
[0001.765] I> Task: Load MB2rf binary to SC7 ctx
[0001.770] I> Slot: 0
[0001.773] I> Binary[14] block-24576 (partition size: 0x20000)
[0001.779] I> Binary name: MB2_RF
[0001.783] I> Size of crypto header is 8192
[0001.787] I> Size of crypto header is 8192
[0001.792] I> Size of crypto header is 8192
[0001.796] I> strt_pg_num(24576) num_of_pgs(16) read_buf(0xa00d6a88)
[0001.804] I> BCH of MB2_RF read from storage
[0001.809] I> BCH address is : 0xa00d6a88
[0001.814] I> MB2_RF header integrity check is success
[0001.819] I> Binary magic in BCH component 0 is MB2R
[0001.825] I> component binary type is 14
[0001.829] I> Size of crypto header is 8192
[0001.833] I> strt_pg_num(24592) num_of_pgs(224) read_buf(0xa00d8a88)
[0001.843] I> MB2_RF binary is read from storage
[0001.848] I> MB2_RF binary integrity check is success
[0001.853] I> Binary MB2_RF loaded successfully at 0xa00d8a88 (0x1bf80)
[0001.861] I> Task: Save fuse alias data to SC7 ctx
[0001.866] I> Task: Save PMIC data to SC7 ctx
[0001.871] I> Task: Save Pinmux data to SC7 ctx
[0001.876] I> Task: Save Pad Voltage data to SC7 ctx
[0001.881] I> Task: Save controller prod data to SC7 ctx
[0001.887] I> Task: Save prod cfg data to SC7 ctx
[0001.891] I> Task: Save I2C bus freq data to SC7 ctx
[0001.897] I> Task: Save SOCTherm data to SC7 ctx
[0001.902] I> Task: Save FMON data to SC7 ctx
[0001.906] I> Task: Save VMON data to SC7 ctx
[0001.911] I> Task: Save TZDRAM data to SC7 ctx
[0001.915] I> Task: Save GPIO int data to SC7 ctx
[0001.921] I> Task: Save clock data to SC7 ctx
[0001.925] I> Task: Save debug data to SC7 ctx
[0001.930] I> Task: Save MBWT data to SC7 ctx
[0001.939] I> SC7 context save done
[0001.943] I> Task: Load MB2/Applet/FSKP
[0001.947] I> Loading MB2
[0001.950] I> Slot: 0
[0001.952] I> Binary[6] block-8448 (partition size: 0x80000)
[0001.958] I> Binary name: MB2
[0001.962] I> Size of crypto header is 8192
[0001.966] I> Size of crypto header is 8192
[0001.971] I> strt_pg_num(8448) num_of_pgs(16) read_buf(0x8007e000)
[0001.979] I> BCH of MB2 read from storage
[0001.983] I> BCH address is : 0x8007e000
[0001.988] I> MB2 header integrity check is success
[0001.993] I> Binary magic in BCH component 0 is MB2B
[0001.998] I> component binary type is 6
[0002.003] I> Size of crypto header is 8192
[0002.007] I> strt_pg_num(8464) num_of_pgs(841) read_buf(0x80000000)
[0002.019] I> MB2 binary is read from storage
[0002.025] I> MB2 binary integrity check is success
[0002.030] I> Binary MB2 loaded successfully at 0x80000000 (0x691f0)
[0002.038] I> Task: Map CCPLEX SHARED carveout
[0002.043] I> Task: Prepare MB2 params
[0002.048] I> BR-BCT Boot Chain Fields
[0002.052] I> u32_non_gpio_select_boot_chain : 0
[0002.057] I> u32_num_boot_chains : 2
[0002.062] I> bf_bl_gpio_select_boot_chain_1b : 0
[0002.068] I> Task: Dram ecc test
[0002.071] I> Task: Misc NV security settings
[0002.076] I> NVDEC sticky bits programming done
[0002.081] I> Successfully powergated NVDEC
[0002.085] I> Task: Disable/Reload WDT
[0002.089] I> Task: Program misc carveouts
[0002.093] I> Program IPC carveouts
[0002.101] I> SLCG Global override status := 0x0
[0002.106] I> MB1: MSS reconfig completed
I> MB2 (version: 0.0.0.0-t234-54845784-4d0906e6)
I> Emulation:
I> Entry timestamp: 0x0020a5ef
I> Regular heap: [base:0x40040000, size:0x10000]
I> DMA heap: [base:0x102e800000, size:0x800000]
I> Task: ARI update carveout TZDRAM (0x50002034)
I> Task: Enable hot-plug capability (0x50028064)
I> Task: PSC mailbox init (0x500178b0)
I> Task: Crypto init (0x5000675c)
I> Task: Enable GP-SE clock (0x50002198)
I> Task: DICE Identity init (0x5001af00)
I> DICE is not enabled.
I> Task: Measured Boot init (0x5001b674)
I> Task: OEM SC7 context save init (0x5001a600)
I> Task: I2C register (0x50001ff8)
I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout (0x50001fe0)
I> Task: Program CBB PCIE AMAP regions (0x5001ac14)
I> Task: Boot device init (0x50001f28)
I> Task: Partition Manager Init (0x50001f24)
I> Found 57 partitions in QSPI_FLASH (instance 0)
W> Cannot find any partition table for 00000003
> PARTITION_MANAGER: Failed to publish partition.
I> Found 15 partitions in SDMMC_USER (instance 3)
I> Task: Load and authenticate registered FWs (0x5001e198)
I> Task: Load AUXP FWs (0x50027c04)
I> Successfully register SPE FW load task with MB2 loader
I> Skipping SCE FW load
I> Successfully register RCE FW load task with MB2 loader
I> Successfully register DCE FW load task with MB2 loader
I> Unpowergating APE
I> Unpowergate done
I> Successfully register APE FW load task with MB2 loader
I> Skipping FSI FW load
I> Successfully register XUSB FW load task with MB2 loader
I> Partition name: A_spe-fw
I> Size of partition: 589824
I> Binary@ device:3/0 block-55040 (partition size: 0x90000), name: A_spe-fw
I> Partition name: A_rce-fw
I> Size of partition: 1048576
I> Binary@ device:3/0 block-56192 (partition size: 0x100000), name: A_rce-fw
I> spe: Authentication Finalize Done
I> Binary spe loaded successfully at 0x102da00000
I> Partition name: A_dce-fw
I> Size of partition: 5242880
I> Binary@ device:3/0 block-44800 (partition size: 0x500000), name: A_dce-fw
I> rce: Authentication Finalize Done
I> Binary rce loaded successfully at 0x102d700000
I> dce : oem authentication of header done
I> dce : meta-blob integrity check is success.
I> dce : will be decompressed at 0x1036000000
I> version 1 Bin 1 BCheckSum 0 content_size 0 Content ChkSum 1 reserved_00 0
I> Reserved10 0 BlockMaxSize 5 Reserved11 0
I> dce : decompressed to 9528912 bytes
I> dce: plain binary integrity check is success
I> Partition name: A_adsp-fw
I> Size of partition: 2097152
I> Binary@ device:3/0 block-58240 (partition size: 0x200000), name: A_adsp-fw
I> dce: Authentication Finalize Done
I> Binary dce loaded successfully at 0x1036000000
I> Partition name: A_xusb-fw
I> Size of partition: 262144
I> Binary@ device:3/0 block-9472 (partition size: 0x40000), name: A_xusb-fw
I> ape: Authentication Finalize Done
I> Binary ape loaded successfully at 0x102e400000
I> xusb: Authentication Finalize Done
I> Binary xusb loaded successfully at 0x102db00000
I> Task: Carveout setup (0x500208f8)
I> Program remaining OEM carveouts
I> Task: Enable FSITHERM (0x50017784)
I> Task: Enable FSI VMON (0x50017280)
I> FSI VMON: FSI Vmon re-calibration and fine tuning done
I> Task: Validate FSI Therm readings (0x50017364)
I> FSITHERM max temp = 36
I> FSITHERM min temp = 35
I> Task: Restore XUSB sec (0x50001ef8)
I> Task: Enable FSI SE clock (0x50017d0c)
I> Enable FSI-SE clock and 10ms delay...
I> Task: Initialize SBSA UART CAR (0x500020fc)
I> Task: Initialize CPUBL Params (0x50018cf8)
I> CPUBL-params @ 0x1032000000
I> Task: Ratchet update (0x50029100)
W> Skip ratchet update - OPTIN fuse not set
I> Task: Prepare eeprom data (0x50018ac4)
I> Task: Revoke PKC fuse (0x50001d44)
I> PKC revoke fuse burn not requested
I> Task: FSI padctl context save (0x5001a790)
I> Task: Unpowergate APE (0x50018474)
W> mb2_unpowergate_ape: skip! APE is in unpowergated state
I> Task: OEM firewalls (0x50024d68)
I> OEM firewalls configured
I> Task: Powergate APE (0x500185e8)
I> Powergating APE
I> Powergate done
I> Task: OEM firewall restore saved settings (0x500251bc)
I> Task: Unhalt AUXPs (0x50027e6c)
I> Unhalting SPE..
I> Enabling combined UART
����spe: early_init
����vic initialized
�Ḹ��tsc initialized
����aon lic initialized
�ุ��spe: tag is 5243985d1b1eb3f06fac6d36bd7e74ac
����spe: SafeRTOS v8.4
�ุ��spe: init
����scheduler initialized
�ุ��aon hsp initialized
����tag initialized
�ุ��tcu initialized
����bpmp ipc initialized
�ุ��spe: late init
����cpu_nic clock initialized
�ุ��apb clock initialized
����pm initialized
�ุ��bpmp hsp initialized
����top1 hsp initialized
�ุ��ccplex ipc initialized
����spe: start scheduler
I> Task: Trigger mailbox for PSC-BL1 exit (0x50017930)
I> Sending opcode 0x4d420802 to psc
��INFO: Entering psc_monitor_init!
INFO: GSC22 BOM:0x1048002000 SIZE:0x1000000 CLIENT_ACCESS1:00180000
INFO: PSCFW BUILD VERSION: 8a33b23-73b589c-8a15f76-rel-t234
INFO: mstatus:0xa00000808
INFO: Supervisor entry_point:c108c00
��I> Received ACK from psc
I> Tas��INFO: MONITOR: user task addr:0x1048022000, blob offset:0x00020000
INFO: MONITOR: populated user images:13
bpmp: socket 0
bpmp: base binary md5 is 925eece486b7c46d91aa449178b5d322
bpmp: combined binary md5 is 6969245516d6bf7e0f2306a6a1fbec5c
bpmp: firmware tag ��INFO: mret to Supervisor!
INFO: psc supervisor init.
��is 6969245516d6bf7e0f23-925eece486b
initialized vwdt
��INFO: psc_irq_init...
INFO: enter idle task��initialized mail_early
initialized fuse
initialized vfrel
initialized hwwdt
initialized adc
fmon_populate_monitors: found 199 monitors
initialized fmon
initialized mc
initialized reset
initialized uphy_early
initialized emc_early
471 clocks registered
initialized clk_mach
initialized clk_cal_early
initialized clk_mach_early_config
initialized io_dpd
initialized soctherm
initialized regime
initialized i2c
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
initialized vrmon
initialized regulator
��k: Start secure NOR provision (0x5001aa2c)
I> Task: Load FSI keyblob (0x50017d54)
I> Skipping FSI key blob copy
��initialized avfs_clk_platform
initialized powergate
��I> Task: Unhalt AUXPs (0x50027e74)
I> SCE unhalt skipped
I> Unhalting RCE
I> RCE unhalt success��initialized dvs
��ful��initialized clk_mach_config
initialized pm
initialized suspend
initialized strap
initialized mce_dbell
I> DCE��[ 2.572532] Camera-FW on t234-rce-safe started
�� un��TCU early console enabled.
��halt successful
I> APE unhalt skipped
I> FSI unhalt skipped
I> Task: Load CPUBL (0x50018e1c)
I> Task: Load TOS (0x50019580)
I> Partition name: A_cpu-bootloader
I> Size of partition: 3670016
I> Binary@ device:3/0 block-24832 (partition size: 0x380000), name: A_cpu-bootloader
��initialized emc
initialized emc_mrq
initialized clk_cal
initialized uphy_dt
initialized uphy_mrq
HSIO UPHY reset has been de-asserted 0x0
initialized uphy
��I> Partition name: A_secure-os
I> Size of partition: 41943��initialized pg_late
��04��initialized pg_mrq_init
swdtimer_init: reg polling start w period 47 ms
initialized swdtimer
initialized hwwdt_late
initialized bwmgr
initialized thermal_host_trip
initialized thermal_mrq
initialized oc_mrq
initialized reset_mrq
initialized mail_mrq
initialized fmon_mrq
initialized clk_mrq
initialized avfs_mrq
initialized i2c_mrq
initialized tag_mrq
initialized bwmgr_mrq
initialized console_mrq
I> ��missing prod DT calibration data for 199 fmons
initialized clk_sync_fmon_post
��Binary@ device:3/0 block-32000 (partition size: 0x400000), name: A_secure-os
I> cpubl_params: nsdram: carveout: 1, encryption: 1
I> NSDRAM carveout base: 0x80000000, size: 0xfad270000
I> cpubl: Authe��initialized clk_cal_late
initialized noc_late
initialized cvc
��ntication Finalize Done
I> Binary cpubl��initialized avfs_clk_mach_post
initialized avfs_clk_platform_post
initialized cvc_late
initialized rm
initialized console_late
handling unreferenced clks
enable can1_core
enable can1_host
enable can2_core
enable can2_host
enable pwm3
enable mss_encrypt
enable maud
enable pllg_ref
enable dsi_core
enable aza_2xbit
enable pllc4_muxed
enable xusb_ss
enable xusb_fs
enable xusb_falcon
enable xusb_core_mux
enable dsi_lp
enable sdmmc_legacy_tm
initialized clk_mach_post
initialized pg_post
initialized regu��[ 2.746080] Camera-FW on t234-rce-safe ready SHA1=8676d22a (crt 12.962 ms,��lator_post
initialized profile
initialized mrq
�� total boot 187.568 ms)er
initialized cactmon
initialized extras_post
bpmp: init complete
�� loaded successfully at 0x102ce00000
I> tos: Authentication Finalize Done
I> Binary tos loaded successfully at 0x103fdee000
I> Relocating OP-TEE dtb from: 0x103fefec50 to 0x103c000020, size: 0x2106
I> [0] START: 0x80000000, SIZE: 0xfad270000
I> [1] START: 0x1032000000, SIZE: 0x2000000
I> Setting NS memory ranges to OP-TEE dtb finished.
I> Partition name: A_eks
I> Binary@ device:3/0 block-44288 (partition size: 0x40000), name: A_eks
I> eks: Authentication Finalize Done
I> Binary eks loaded successfully at 0x102e800400
I> EKB detected (length: 0x410) @ VA:0x102e800400
I> Task: Prepare TOS params (0x500194f8)
I> Setting EKB blob info to OPTEE dtb finished.
I> Setting OPTEE arg3: 0x103c000020
I> Task: OEM SC7 context save (0x5001a88c)
I> OEM sc7 context saved
I> Task: Disable MSS perf stats (0x50027f00)
I> Task: Program display sticky bits (0x50027e7c)
I> Task: Storage device deinit (0x500020a0)
I> Task: SMMU external bypass disable (0x50017894)
I> Task: SMMU init (0x500177b0)
I> Task: Program GICv3 registers (0x50027fa0)
I> Task: Audit firewall settings (0x50024fbc)
I> Task: Bootchain failure check (0x500025e8)
I> Current Boot-Chain Slot: 0
I> BR-BCT Boot-Chain is 0, and status is 1. Set UPDATE_BRBCT bit to 0
I> MB2 finished
��NOTICE: BL31: v2.6(release):346877e39
NOTICE: BL31: Built : 12:32:40, Aug 1 2023
I/TC: Physical secure memory base 0x103c040000 size 0x3fc0000
��DCE: FW Boot Done
��I/TC:
I/TC: Non-secure external DT found
I/TC: OP-TEE version: 3.21 (gcc version 9.3.0 (Buildroot 2020.08)) #2 Tue Aug 1 19:39:55 UTC 2023 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: Test OEM keys are being used. This is insecure for shipping products!
I/TC: Primary CPU switching to normal world boot
Jetson UEFI firmware (version 4.1-33958178 built on 2023-08-01T19:34:02+00:00)
ESC to enter Setup.
F11 to enter Boot Manager Menu.
Enter to continue boot.
** WARNING: Test Key is used. **
L4TLauncher: Attempting GRUB Boot
L4TLauncher: Attempting Direct Boot
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services and installing virtual address map...
��I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 4 initializing
I/TC: Secondary CPU 4 switching to normal world boot
I/TC: Secondary CPU 5 initializing
I/TC: Secondary CPU 5 switching to normal world boot
I/TC: Secondary CPU 6 initializing
I/TC: Secondary CPU 6 switching to normal world boot
I/TC: Secondary CPU 7 initializing
I/TC: Secondary CPU 7 switching to normal world boot
I/TC: Secondary CPU 8 initializing
I/TC: Secondary CPU 8 switching to normal world boot
I/TC: Secondary CPU 9 initializing
I/TC: Secondary CPU 9 switching to normal world boot
I/TC: Secondary CPU 10 initializing
I/TC: Secondary CPU 10 switching to normal world boot
I/TC: Secondary CPU 11 initializing
I/TC: Secondary CPU 11 switching to normal world boot
��[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 5.10.120-tegra (buildbrain@mobile-u64-6422-d7000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld3
[ 0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,
[ 0.000000] OF: fdt: - 80000000 , c0000000
[ 0.000000] Machine model: Jetson AGX Orin Developer Kit
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x102531df98 SMBIOS=0xffff0000 SMBIOS 3.0=0x1004ed0000 MEMATTR=0x1006824018 ESRT=0x1005255518 RNG=0x1006d2f198 MEMRESERVE=0x10
[ 0.000000] efi: seeding entropy pool
[ 0.000000] esrt: Reserving ESRT space from 0x0000001005255518 to 0x0000001005255550.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000001008c00000, size 512 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x0000001033ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000fffdffff]
[ 0.000000] node 0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x0000001004a49fff]
[ 0.000000] node 0: [mem 0x0000001004a4a000-0x0000001004e16fff]
[ 0.000000] node 0: [mem 0x0000001004e17000-0x0000001004e1ffff]
[ 0.000000] node 0: [mem 0x0000001004e20000-0x0000001004edffff]
[ 0.000000] node 0: [mem 0x0000001004ee0000-0x00000010066dffff]
[ 0.000000] node 0: [mem 0x00000010066e0000-0x000000100677ffff]
[ 0.000000] node 0: [mem 0x0000001006780000-0x00000010067effff]
[ 0.000000] node 0: [mem 0x00000010067f0000-0x000000100681ffff]
[ 0.000000] node 0: [mem 0x0000001006820000-0x000000100683ffff]
[ 0.000000] node 0: [mem 0x0000001006840000-0x000000100685ffff]
[ 0.000000] node 0: [mem 0x0000001006860000-0x000000100693ffff]
[ 0.000000] node 0: [mem 0x0000001006940000-0x000000100695ffff]
[ 0.000000] node 0: [mem 0x0000001006960000-0x000000100698ffff]
[ 0.000000] node 0: [mem 0x0000001006990000-0x0000001006b6ffff]
[ 0.000000] node 0: [mem 0x0000001006b70000-0x0000001006c3ffff]
[ 0.000000] node 0: [mem 0x0000001006c40000-0x0000001006cdffff]
[ 0.000000] node 0: [mem 0x0000001006ce0000-0x0000001006d1ffff]
[ 0.000000] node 0: [mem 0x0000001006d20000-0x0000001006faffff]
[ 0.000000] node 0: [mem 0x0000001006fb0000-0x00000010070affff]
[ 0.000000] node 0: [mem 0x00000010070b0000-0x000000100714ffff]
[ 0.000000] node 0: [mem 0x0000001007150000-0x000000100719ffff]
[ 0.000000] node 0: [mem 0x00000010071a0000-0x000000100723ffff]
[ 0.000000] node 0: [mem 0x0000001007240000-0x000000100775ffff]
[ 0.000000] node 0: [mem 0x0000001007760000-0x000000100793ffff]
[ 0.000000] node 0: [mem 0x0000001007940000-0x0000001028faffff]
[ 0.000000] node 0: [mem 0x0000001028fb0000-0x0000001028ffffff]
[ 0.000000] node 0: [mem 0x0000001029000000-0x000000102d1fffff]
[ 0.000000] node 0: [mem 0x000000102d210000-0x000000102d21ffff]
[ 0.000000] node 0: [mem 0x0000001032000000-0x0000001033ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000001033ffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 32 pages/cpu s90328 r8192 d32552 u131072
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 16188688
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 conso
[ 0.000000] Dentry cache hash table entries: 8388608 (order: 14, 67108864 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000effe0000-0x00000000fffe0000] (256MB)
[ 0.000000] Memory: 63769964K/65783872K available (18560K kernel code, 3166K rwdata, 7196K rodata, 3968K init, 1416K bss, 1489620K reserved, 524288K c)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=12, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=12.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=12
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[ 0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)
[ 0.000000] GICv2m: range[mem 0x0f410000-0x0f41ffff], SPI[608:677]
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000725] Console: colour dummy device 80x25
[ 0.000902] printk: console [tty0] enabled
[ 0.000949] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.000959] pid_max: default: 32768 minimum: 301
[ 0.001061] LSM: Security Framework initializing
[ 0.001091] Yama: becoming mindful.
[ 0.001114] SELinux: Initializing.
[ 0.001267] Mount-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.001356] Mountpoint-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.003966] rcu: Hierarchical SRCU implementation.
[ 0.004087] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.004843] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t23x/concs
[ 0.004852] DTB Build time: Aug 1 2023 12:44:17
[ 0.006354] Tegra Revision: A01 SKU: 0xd0 CPU Process: 0 SoC Process: 0
[ 0.006655] Remapping and enabling EFI services.
[ 0.007240] smp: Bringing up secondary CPUs ...
[ 0.035985] Detected PIPT I-cache on CPU1
[ 0.036032] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[ 0.036066] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[ 0.064740] Detected PIPT I-cache on CPU2
[ 0.064750] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[ 0.064763] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[ 0.093394] Detected PIPT I-cache on CPU3
[ 0.093403] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[ 0.093417] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[ 0.124107] Detected PIPT I-cache on CPU4
[ 0.124129] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c0000
[ 0.124157] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[ 0.152847] Detected PIPT I-cache on CPU5
[ 0.152856] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e0000
[ 0.152872] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[ 0.181515] Detected PIPT I-cache on CPU6
[ 0.181525] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f500000
[ 0.181540] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[ 0.210190] Detected PIPT I-cache on CPU7
[ 0.210201] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f520000
[ 0.210216] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
[ 0.240919] Detected PIPT I-cache on CPU8
[ 0.240944] GICv3: CPU8: found redistributor 20000 region 0:0x000000000f540000
[ 0.240973] CPU8: Booted secondary processor 0x0000020000 [0x410fd421]
[ 0.269651] Detected PIPT I-cache on CPU9
[ 0.269661] GICv3: CPU9: found redistributor 20100 region 0:0x000000000f560000
[ 0.269676] CPU9: Booted secondary processor 0x0000020100 [0x410fd421]
[ 0.298946] Detected PIPT I-cache on CPU10
[ 0.298958] GICv3: CPU10: found redistributor 20200 region 0:0x000000000f580000
[ 0.298972] CPU10: Booted secondary processor 0x0000020200 [0x410fd421]
[ 0.328222] Detected PIPT I-cache on CPU11
[ 0.328233] GICv3: CPU11: found redistributor 20300 region 0:0x000000000f5a0000
[ 0.328248] CPU11: Booted secondary processor 0x0000020300 [0x410fd421]
[ 0.328308] smp: Brought up 1 node, 12 CPUs
[ 0.328376] SMP: Total of 12 processors activated.
[ 0.328380] CPU features: detected: Privileged Access Never
[ 0.328383] CPU features: detected: LSE atomic instructions
[ 0.328386] CPU features: detected: User Access Override
[ 0.328388] CPU features: detected: 32-bit EL0 Support
[ 0.328392] CPU features: detected: Common not Private translations
[ 0.328395] CPU features: detected: RAS Extension Support
[ 0.328397] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.328401] CPU features: detected: CRC32 instructions
[ 0.328404] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.347766] spectre-bhb mitigation disabled by command line option
[ 0.347769] spectre-bhb mitigation disabled by command line option
[ 0.347773] spectre-bhb mitigation disabled by command line option
[ 0.347774] spectre-bhb mitigation disabled by command line option
[ 0.347775] spectre-bhb mitigation disabled by command line option
[ 0.347777] spectre-bhb mitigation disabled by command line option
[ 0.347780] spectre-bhb mitigation disabled by command line option
[ 0.347783] spectre-bhb mitigation disabled by command line option
[ 0.366544] CPU: All CPU(s) started at EL2
[ 0.370116] devtmpfs: initialized
[ 0.391716] Registered cp15_barrier emulation handler
[ 0.391728] Registered setend emulation handler
[ 0.391735] KASLR enabled
[ 0.391860] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.391879] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[ 0.394973] pinctrl core: initialized pinctrl subsystem
[ 0.395449] SMBIOS 3.0.0 present.
[ 0.395459] DMI: Unknown Jetson AGX Orin Developer Kit/Jetson AGX Orin Developer Kit, BIOS 4.1-33958178 08/01/2023
[ 0.395796] NET: Registered protocol family 16
[ 0.396709] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.396914] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.397111] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.397137] audit: initializing netlink subsys (disabled)
[ 0.397234] audit: type=2000 audit(0.396:1): state=initialized audit_enabled=0 res=1
[ 0.397433] thermal_sys: Registered thermal governor 'step_wise'
[ 0.397434] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.397439] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[ 0.400120] cpuidle: using governor menu
[ 0.400240] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.400360] ASID allocator initialised with 32768 entries
[ 0.400459] Serial: AMBA PL011 UART driver
[ 0.402548] tegra234_mc_sid_probe(): tegra234 mc-sid probe successful
[ 0.402577] Tegra reboot handler registered.
[ 0.422075] mc: mapped MMIO address: 0xffff8000111f0000 -> 0x2c10000
[ 0.422096] mc: mapped MMIO address: 0xffff800011210000 -> 0x2c20000
[ 0.422104] mc: mapped MMIO address: 0xffff800011230000 -> 0x2c30000
[ 0.422110] mc: mapped MMIO address: 0xffff800011250000 -> 0x2c40000
[ 0.422117] mc: mapped MMIO address: 0xffff800011270000 -> 0x2c50000
[ 0.422124] mc: mapped MMIO address: 0xffff800011290000 -> 0x2b80000
[ 0.422130] mc: mapped MMIO address: 0xffff8000112b0000 -> 0x2b90000
[ 0.422136] mc: mapped MMIO address: 0xffff8000112d0000 -> 0x2ba0000
[ 0.422143] mc: mapped MMIO address: 0xffff8000112f0000 -> 0x2bb0000
[ 0.422151] mc: mapped MMIO address: 0xffff800011310000 -> 0x1700000
[ 0.422157] mc: mapped MMIO address: 0xffff800011330000 -> 0x1710000
[ 0.422163] mc: mapped MMIO address: 0xffff800011350000 -> 0x1720000
[ 0.422171] mc: mapped MMIO address: 0xffff800011370000 -> 0x1730000
[ 0.422178] mc: mapped MMIO address: 0xffff800011390000 -> 0x1740000
[ 0.422184] mc: mapped MMIO address: 0xffff8000113b0000 -> 0x1750000
[ 0.422190] mc: mapped MMIO address: 0xffff8000113d0000 -> 0x1760000
[ 0.422198] mc: mapped MMIO address: 0xffff8000113f0000 -> 0x1770000
[ 0.422209] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.422257] mc-err: mcerr ops are set to t23x
[ 0.422962] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 80, base_baud = 0) is a SBSA
[ 1.687413] printk: console [ttyAMA0] enabled
[ 1.696138] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 1.702851] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 1.709551] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 1.716249] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 1.725156] ACPI: Interpreter disabled.
[ 1.730203] vdd-av1v1-hub: supplied by vdd-5v-sys
[ 1.735068] vbusA-cvb: supplied by vdd-5v-sys
[ 1.739554] vbusB-cvb: supplied by vdd-5v-sys
[ 1.744038] vdd-usbc1-vbus: supplied by vdd-5v-sys
[ 1.748952] vdd-usbc2-vbus: supplied by vdd-5v-sys
[ 1.754332] iommu: Default domain type: Translated
[ 1.759259] eventlib_kernel: keventlib is initialized, test id: 0
[ 1.765543] SCSI subsystem initialized
[ 1.769368] usbcore: registered new interface driver usbfs
[ 1.774862] usbcore: registered new interface driver hub
[ 1.780186] usbcore: registered new device driver usb
[ 1.785425] mc: Linux media interface: v0.10
[ 1.789704] videodev: Linux video capture interface: v2.00
[ 1.795326] pps_core: LinuxPPS API ver. 1 registered
[ 1.800290] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.809428] PTP clock support registered
[ 1.813568] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec
[ 1.820725] tegra_wdt_t18x 2190000.watchdog: Registered successfully
[ 1.828368] Registered efivars operations
[ 1.832523] FPGA manager framework
[ 1.835968] Advanced Linux Sound Architecture Driver Initialized.
[ 1.842339] Bluetooth: Core ver 2.22
[ 1.845921] NET: Registered protocol family 31
[ 1.850363] Bluetooth: HCI device and connection manager initialized
[ 1.856722] Bluetooth: HCI socket layer initialized
[ 1.861599] Bluetooth: L2CAP socket layer initialized
[ 1.866657] Bluetooth: SCO socket layer initialized
[ 1.871997] camchar: rtcpu character device driver loaded
[ 1.877626] clocksource: Switched to clocksource arch_sys_counter
[ 2.046496] VFS: Disk quotas dquot_6.6.0
[ 2.050469] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 2.057663] pnp: PnP ACPI: disabled
[ 2.063208] la/ptsa driver initialized.
[ 2.067113] NET: Registered protocol family 2
[ 2.071681] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 2.081435] tcp_listen_portaddr_hash hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 2.090220] TCP established hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 2.098773] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 2.106670] TCP: Hash tables configured (established 524288 bind 65536)
[ 2.113398] UDP hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 2.120461] UDP-Lite hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 2.128055] NET: Registered protocol family 1
[ 2.132703] RPC: Registered named UNIX socket transport module.
[ 2.138633] RPC: Registered udp transport module.
[ 2.143334] RPC: Registered tcp transport module.
[ 2.148034] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 2.154486] PCI: CLS 0 bytes, default 64
[ 2.158549] Trying to unpack rootfs image as initramfs...
[ 2.293005] Freeing initrd memory: 9552K
[ 2.299068] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 2.307011] kvm [1]: IPA Size Limit: 48 bits
[ 2.311305] kvm [1]: GICv3: no GICV resource entry
[ 2.316097] kvm [1]: disabling GICv2 emulation
[ 2.320554] kvm [1]: GIC system register CPU interface enabled
[ 2.326492] kvm [1]: vgic interrupt IRQ9
[ 2.330568] kvm [1]: VHE mode initialized successfully
[ 2.336421] Initialise system trusted keyrings
[ 2.340952] workingset: timestamp_bits=46 max_order=24 bucket_order=0
[ 2.349810] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.355953] NFS: Registering the id_resolver key type
[ 2.361025] Key type id_resolver registered
[ 2.365206] Key type id_legacy registered
[ 2.369247] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 2.375953] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 2.383361] ntfs: driver 2.1.32 [Flags: R/W].
[ 2.399430] NET: Registered protocol family 38
[ 2.403879] Key type asymmetric registered
[ 2.407974] Asymmetric key parser 'x509' registered
[ 2.412869] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 239)
[ 2.420335] io scheduler mq-deadline registered
[ 2.424870] io scheduler kyber registered
[ 2.433112] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 2.438717] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 2.444304] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 2.449893] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 2.457957] tegra_dc_assign_hw_data: no matching compatible node
[ 2.463969] tegradccommon module_init failed
[ 2.468238] tegradc module_init failed
[ 2.472243] EINJ: ACPI disabled.
[ 2.477044] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 2.483940] tegra-pmc: ### PMC reset source: SYS_RESET_N
[ 2.489251] tegra-pmc: ### PMC reset level: L0
[ 2.493693] tegra-pmc: ### PMC reset status reg: 0x0
[ 2.499936] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 4.171360] printk: console [ttyTCU0] enabled
[ 4.180525] arm-smmu 12000000.iommu: probing hardware configuration...
[ 4.188554] arm-smmu 12000000.iommu: SMMUv2 with:
[ 4.193397] arm-smmu 12000000.iommu: stage 1 translation
[ 4.198959] arm-smmu 12000000.iommu: stage 2 translation
[ 4.204508] arm-smmu 12000000.iommu: nested translation
[ 4.209964] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 4.217376] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
[ 4.226543] arm-smmu 12000000.iommu: Supported page sizes: 0x00001000
[ 4.233237] arm-smmu 12000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 4.239928] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 4.247461] arm-smmu 10000000.iommu: probing hardware configuration...
[ 4.254153] arm-smmu 10000000.iommu: SMMUv2 with:
[ 4.258987] arm-smmu 10000000.iommu: stage 1 translation
[ 4.264532] arm-smmu 10000000.iommu: stage 2 translation
[ 4.270071] arm-smmu 10000000.iommu: nested translation
[ 4.275522] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 4.282932] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 only)
[ 4.291969] arm-smmu 10000000.iommu: Supported page sizes: 0x00001000
[ 4.298667] arm-smmu 10000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 4.305363] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 4.312488] arm-smmu 8000000.iommu: probing hardware configuration...
[ 4.319114] arm-smmu 8000000.iommu: SMMUv2 with:
[ 4.323859] arm-smmu 8000000.iommu: stage 1 translation
[ 4.329310] arm-smmu 8000000.iommu: stage 2 translation
[ 4.334760] arm-smmu 8000000.iommu: nested translation
[ 4.340120] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 4.347446] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 4.356393] arm-smmu 8000000.iommu: Supported page sizes: 0x00001000
[ 4.363004] arm-smmu 8000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 4.369620] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 4.376977] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[ 4.387385] tegra_profiler: version: 1.151, samples/io: 51/30
[ 4.393367] tegra_profiler: auth: init
[ 4.397518] nvsciipc: loaded module
[ 4.402703] tun: Universal TUN/TAP device driver, 1.6
[ 4.408342] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 4.415763] hns3: Copyright (c) 2017 Huawei Corporation.
[ 4.421269] e1000e: Intel(R) PRO/1000 Network Driver
[ 4.426357] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 4.432448] igb: Intel(R) Gigabit Ethernet Network Driver
[ 4.437982] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 4.443848] PPP generic driver version 2.4.2
[ 4.448281] PPP BSD Compression module registered
[ 4.453114] PPP Deflate Compression module registered
[ 4.458312] PPP MPPE Compression module registered
[ 4.463266] usbcore: registered new interface driver r8152
[ 4.468909] usbcore: registered new interface driver asix
[ 4.474461] usbcore: registered new interface driver ax88179_178a
[ 4.480728] usbcore: registered new interface driver cdc_ether
[ 4.486732] usbcore: registered new interface driver net1080
[ 4.492550] usbcore: registered new interface driver cdc_subset
[ 4.498625] usbcore: registered new interface driver zaurus
[ 4.504362] usbcore: registered new interface driver cdc_ncm
[ 4.510178] usbcore: registered new interface driver aqc111
[ 4.516025] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 4.522383] ohci-pci: OHCI PCI platform driver
[ 4.526955] ohci-platform: OHCI generic platform driver
[ 4.532612] tegra-xusb 3610000.xhci: Adding to iommu group 0
[ 4.538936] usbcore: registered new interface driver uas
[ 4.544417] usbcore: registered new interface driver usb-storage
[ 4.550727] tegra-xudc 3550000.xudc: Adding to iommu group 1
[ 4.556871] mousedev: PS/2 mouse device common for all mice
[ 4.562614] usbcore: registered new interface driver xpad
[ 4.570021] tegra_rtc c2a0000.rtc: registered as rtc1
[ 4.575480] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:27 UTC (27)
[ 4.583708] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 4.590130] i2c /dev entries driver
[ 4.593783] tegra-i2c 3160000.i2c: Adding to iommu group 2
[ 4.599629] tegra-i2c c240000.i2c: Adding to iommu group 2
[ 4.605354] tegra-i2c 3180000.i2c: Adding to iommu group 2
[ 4.611139] tegra-i2c 3190000.i2c: Adding to iommu group 2
[ 4.616843] tegra-i2c 31c0000.i2c: Adding to iommu group 2
[ 4.622525] tegra-i2c c250000.i2c: Adding to iommu group 2
[ 4.628211] tegra-i2c 31e0000.i2c: Adding to iommu group 2
[ 4.633981] tegra-i2c 31b0000.i2c: Adding to iommu group 2
[ 4.642297] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[ 4.650869] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[ 4.660350] device-mapper: uevent: version 1.0.3
[ 4.665199] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[ 4.675081] sdhci: Secure Digital Host Controller Interface driver
[ 4.681422] sdhci: Copyright(c) Pierre Ossman
[ 4.685888] Synopsys Designware Multimedia Card Interface Driver
[ 4.692123] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.698123] sdhci-tegra 3460000.sdhci: Adding to iommu group 3
[ 4.698656] sdhci-tegra 3400000.sdhci: Adding to iommu group 4
[ 4.698676] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401
[ 4.710353] tegra-bpmp bpmp: firmware: 6969245516d6bf7e0f23-925eece486b
[ 4.725660] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9
[ 4.731280] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x82
[ 4.741435] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[ 4.747365] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful
��debugfs initialized
��[ 5.981831] hid: raw HID events driver (C) Jiri Kosina
[ 5.988007] usbcore: registered new interface driver usbhid
[ 5.993792] usbhid: USB HID core driver
[ 5.999064] tegra-dce d800000.dce: Adding to iommu group 5
[ 6.006328] dce: dce_ipc_channel_init:319 Invalid Channel State [0x0] for ch_type [2]
[ 6.014934] tegra234-aon c000000.aon: Adding to iommu group 6
[ 6.021651] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x5]
[ 6.026698] c000000.aon:hsp: probed
[ 6.030669] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [0]. Ignored...
[ 6.030680] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [0]. Ignored...
[ 6.043150] tegra234-aon c000000.aon: init done
[ 6.043543] tegra23x-psc e860000.psc: Adding to iommu group 7
[ 6.051945] dce: dce_admin_send_cmd_ver:424 version : [0x2] err : [0x0]
[ 6.057115] tegra23x-psc e860000.psc: ext_cfg base:(____ptrval____)
[ 6.063077] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x1]
[ 6.069467] tegra23x-psc e860000.psc: init done
[ 6.069673] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 8
[ 6.075952] dce: dce_admin_setup_clients_ipc:553 Channel Reset Complete for Type [1] ...
[ 6.075954] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [1]. Ignored...
[ 6.075974] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [1]. Ignored...
[ 6.085549] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 6.089621] dce: dce_admin_setup_clients_ipc:529 Get queue info failed for [2]
[ 6.090210] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x2]
[ 6.099940] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[ 6.104745] dce: dce_admin_setup_clients_ipc:553 Channel Reset Complete for Type [3] ...
[ 6.104747] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [3]. Ignored...
[ 6.104775] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [3]. Ignored...
[ 6.113589] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 6.122824] dce: dce_start_boot_flow:173 DCE_BOOT_DONE
[ 6.131036] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[ 6.211459] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[ 6.223296] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[ 6.235929] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[ 6.248752] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[ 6.261827] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (119)
[ 6.268694] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 6.280059] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=8676d22a01443bdbc66581b7dde3b6d6828cc925
[ 6.293885] t19x_cache tegra-cache: probed
[ 6.298319] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[ 6.316435] optee: probing for conduit method.
��I/TC: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
��[ 6.321042] optee: revision 3.21 (d8269f24)
[ 6.379820] optee: dynamic shared memory is enabled
[ 6.389256] optee: initialized driver
[ 6.406530] nvpmodel: initialized successfully
[ 6.411232] tegra_hv: get_hvd: not initialized yet
[ 6.416178] user_ivc_mempool: hypervisor not present
[ 6.422149] usbcore: registered new interface driver snd-usb-audio
[ 6.429333] u32 classifier
[ 6.432133] input device check on
[ 6.435915] Actions configured
[ 6.439576] Initializing XFRM netlink socket
[ 6.444443] NET: Registered protocol family 10
[ 6.450484] Segment Routing with IPv6
[ 6.454313] NET: Registered protocol family 17
[ 6.458897] NET: Registered protocol family 15
[ 6.463523] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 6.477706] Bluetooth: RFCOMM socket layer initialized
[ 6.483049] Bluetooth: RFCOMM ver 1.11
[ 6.486933] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 6.493039] Bluetooth: HIDP socket layer initialized
[ 6.498756] 9pnet: Installing 9P2000 support
[ 6.503236] Key type dns_resolver registered
[ 6.508434] registered taskstats version 1
[ 6.512701] Loading compiled-in X.509 certificates
[ 6.527589] Loaded X.509 cert 'Build time autogenerated kernel key: d94b64a20d69a5a32183bad4f211c4cae67041a9'
[ 6.538329] tegra194-pcie 14100000.pcie: Adding to iommu group 9
[ 6.551242] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 6.559288] tegra194-pcie 14160000.pcie: Adding to iommu group 10
[ 6.571927] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 6.578899] tegra194-pcie 141a0000.pcie: Adding to iommu group 11
[ 6.591141] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 6.624194] tegra-soc-hwpm f100000.tegra_soc_hwpm: Adding to iommu group 12
[ 6.637496] host1x 13e40000.host1x: Adding to iommu group 13
[ 6.670203] host1x 13e40000.host1x: initialized
[ 6.675316] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu group 14
[ 6.683495] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (streamid=53, iommu=smmu.0x0000000012000000)
[ 6.695562] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu group 15
[ 6.703670] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (streamid=54, iommu=smmu.0x0000000012000000)
[ 6.715676] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu group 16
[ 6.723781] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (streamid=55, iommu=smmu.0x0000000012000000)
[ 6.735804] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu group 17
[ 6.743946] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[ 6.755957] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu group 18
[ 6.764080] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[ 6.776089] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu group 19
[ 6.784201] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[ 6.796244] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu group 20
[ 6.804367] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[ 6.816374] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu group 21
[ 6.824476] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[ 6.836488] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu group 22
[ 6.844642] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (streamid=53, iommu=smmu.0x0000000008000000)
[ 6.856674] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu group 23
[ 6.864839] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (streamid=54, iommu=smmu.0x0000000008000000)
[ 6.876814] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu group 24
[ 6.884950] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (streamid=55, iommu=smmu.0x0000000008000000)
[ 6.896959] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu group 25
[ 6.905087] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (streamid=56, iommu=smmu.0x0000000008000000)
[ 6.917110] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu group 26
[ 6.925211] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (streamid=57, iommu=smmu.0x0000000008000000)
[ 6.937221] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu group 27
[ 6.945319] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (streamid=58, iommu=smmu.0x0000000008000000)
[ 6.957319] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu group 28
[ 6.965407] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (streamid=59, iommu=smmu.0x0000000008000000)
[ 6.977404] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu group 29
[ 6.985515] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (streamid=60, iommu=smmu.0x0000000008000000)
[ 6.997582] falcon 15340000.vic: Adding to iommu group 30
[ 7.008332] falcon 15340000.vic: initialized
[ 7.013087] falcon 15380000.nvjpg: Adding to iommu group 31
[ 7.022246] falcon 15380000.nvjpg: initialized
[ 7.026974] falcon 15540000.nvjpg1: Adding to iommu group 32
[ 7.035630] falcon 15540000.nvjpg1: initialized
[ 7.040437] falcon 154c0000.nvenc: Adding to iommu group 33
[ 7.050774] falcon 154c0000.nvenc: initialized
[ 7.055503] falcon 15a50000.ofa: Adding to iommu group 34
[ 7.064078] falcon 15a50000.ofa: initialized
[ 7.068626] nvdec 15480000.nvdec: Adding to iommu group 35
[ 7.080815] nvdec 15480000.nvdec: initialized
[ 7.085437] tsec 15500000.tsec: Adding to iommu group 36
[ 7.095581] tsec 15500000.tsec: initialized
[ 7.103354] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 7.120258] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 7.137024] gpio-394 (camera-control-output-low): hogged as output/low
[ 7.143773] gpio-397 (camera-control-output-low): hogged as output/low
[ 7.150537] gpio-487 (camera-control-output-low): hogged as output/low
[ 7.157292] gpio-486 (camera-control-output-low): hogged as output/low
[ 7.165074] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio
[ 7.172591] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon
[ 7.179592] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 7.186344] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 7.192861] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 7.199113] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 7.207232] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 7.215803] tegra194-isp5 14800000.isp: Adding to iommu group 37
[ 7.225108] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[ 7.234876] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized
[ 7.241484] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group 38
[ 7.249686] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group 39
[ 7.257795] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: context isolation disabled due to no IOMMU
[ 7.267755] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized
[ 7.274581] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: context isolation disabled due to no IOMMU
[ 7.284534] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized
[ 7.291351] scare-pigeon 13e40000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[ 7.301333] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized
[ 7.308192] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: Adding to iommu group 40
[ 7.316939] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: initialized (streamid=18, iommu=smmu.0x0000000008000000)
[ 7.328314] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: Adding to iommu group 41
[ 7.337079] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: initialized (streamid=19, iommu=smmu.0x0000000008000000)
[ 7.348457] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: Adding to iommu group 42
[ 7.357159] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: initialized (streamid=20, iommu=smmu.0x0000000008000000)
[ 7.368538] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: Adding to iommu group 43
[ 7.377250] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: initialized (streamid=21, iommu=smmu.0x0000000008000000)
[ 7.388616] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: Adding to iommu group 44
[ 7.397331] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: initialized (streamid=22, iommu=smmu.0x0000000008000000)
[ 7.408716] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: Adding to iommu group 45
[ 7.417467] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: initialized (streamid=23, iommu=smmu.0x0000000008000000)
[ 7.428826] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: Adding to iommu group 46
[ 7.437592] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: initialized (streamid=24, iommu=smmu.0x0000000008000000)
[ 7.448967] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: Adding to iommu group 47
[ 7.457697] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: initialized (streamid=25, iommu=smmu.0x0000000008000000)
[ 7.469090] pva 16000000.pva0: Adding to iommu group 48
[ 7.494776] pva 16000000.pva0: initialized
[ 7.509927] nvdla 15880000.nvdla0: Adding to iommu group 49
[ 7.525210] nvdla 15880000.nvdla0: initialized
[ 7.531545] nvdla 158c0000.nvdla1: Adding to iommu group 50
[ 7.546283] nvdla 158c0000.nvdla1: initialized
[ 7.552568] tegra-gpcdma 2600000.gpcdma: Adding to iommu group 2
[ 7.559616] tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels
[ 7.567172] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[ 7.573815] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[ 7.580587] serial-tegra 3100000.serial: Adding to iommu group 2
[ 7.587220] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 26, base_baud = 0) is a TEGRA_UART
[ 7.596968] serial-tegra 3110000.serial: Adding to iommu group 2
[ 7.603486] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 78, base_baud = 0) is a TEGRA_UART
[ 7.613129] serial-tegra 3130000.serial: Adding to iommu group 2
[ 7.619727] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 79, base_baud = 0) is a TEGRA_UART
[ 7.646577] tegra-xusb 3610000.xhci: Firmware timestamp: 2023-02-10 03:48:10 UTC, Version: 80.05 release
[ 7.656352] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 7.661940] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 7.670607] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000050810
[ 7.680220] tegra-xusb 3610000.xhci: irq 236, io mem 0x03610000
[ 7.686663] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 7.695170] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.702609] usb usb1: Product: xHCI Host Controller
[ 7.707638] usb usb1: Manufacturer: Linux 5.10.120-tegra xhci-hcd
[ 7.713908] usb usb1: SerialNumber: 3610000.xhci
[ 7.719409] hub 1-0:1.0: USB hub found
[ 7.723302] hub 1-0:1.0: 4 ports detected
[ 7.727696] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 7.733256] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 7.741051] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 7.748604] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 7.757129] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.764570] usb usb2: Product: xHCI Host Controller
[ 7.769584] usb usb2: Manufacturer: Linux 5.10.120-tegra xhci-hcd
[ 7.775866] usb usb2: SerialNumber: 3610000.xhci
[ 7.781127] hub 2-0:1.0: USB hub found
[ 7.785010] hub 2-0:1.0: 4 ports detected
[ 7.810216] tegra23x-oc-event soctherm-oc-event: Finished tegra23x overcurrent event probing
[ 7.835591] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 2009000 KHz, changing to: 2035200 KHz
[ 7.848497] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 1950000 KHz, changing to: 1958400 KHz
[ 7.860291] cpufreq: cpu4,cur:2114000,set:1958400,set ndiv:153
[ 7.867559] cpufreq: cpufreq_online: CPU8: Running at unlisted initial frequency: 2010000 KHz, changing to: 2035200 KHz
[ 7.879480] tegra194-cpufreq e000000.ccplex: probed with ICC, cl:3
[ 7.886980] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 7.895660] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 7.901146] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[ 7.904820] mmc0: CQHCI version 5.10
[ 7.908330] tegra194-pcie 14100000.pcie: IO 0x0030100000..0x00301fffff -> 0x0030100000
[ 7.920698] tegra194-pcie 14100000.pcie: MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[ 7.929413] tegra194-pcie 14100000.pcie: MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[ 7.942291] irq: IRQ303: trimming hierarchy from :interrupt-controller@f400000-1
[ 7.949954] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 303
[ 7.952575] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit
[ 7.993624] usb 1-3: new full-speed USB device number 2 using tegra-xusb
[ 8.045623] tegra194-pcie 14100000.pcie: Link up
[ 8.051362] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[ 8.058208] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 8.063859] pci_bus 0001:00: root bus resource [io 0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[ 8.073715] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[ 8.084555] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[ 8.092497] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[ 8.098852] pci 0001:00:00.0: PME# supported from D0 D3hot
[ 8.109455] pci 0001:01:00.0: [10ec:c822] type 00 class 0x028000
[ 8.115791] pci 0001:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 8.121733] pci 0001:01:00.0: reg 0x18: [mem 0x20a8000000-0x20a800ffff 64bit]
[ 8.130191] pci 0001:01:00.0: supports D1 D2
[ 8.134585] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 8.141632] mmc0: Command Queue Engine enabled
[ 8.146156] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff]
[ 8.146209] mmc0: periodic cache flush enabled
[ 8.153628] pci 0001:00:00.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 8.158200] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 8.164568] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8000000-0x20a800ffff 64bit]
[ 8.171814] mmcblk0: mmc0:0001 G1M15M 59.3 GiB
[ 8.179131] pci 0001:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 8.183893] mmcblk0rpmb: mmc0:0001 G1M15M partition 3 4.00 MiB, chardev (510:0)
[ 8.190128] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 8.202842] pci 0001:00:00.0: bridge window [io 0x1000-0x1fff]
[ 8.209138] pci 0001:00:00.0: bridge window [mem 0x20a8000000-0x20a80fffff]
[ 8.216520] pci 0001:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 8.225299] pci 0001:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 8.234149] usb 1-3: New USB device found, idVendor=13d3, idProduct=3549, bcdDevice= 0.00
[ 8.234342] pcieport 0001:00:00.0: Adding to iommu group 9
[ 8.242594] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 8.248535] pcieport 0001:00:00.0: PME: Signaling with IRQ 64
[ 8.255562] usb 1-3: Product: Bluetooth Radio
[ 8.262059] pcieport 0001:00:00.0: AER: enabled with IRQ 64
[ 8.268020] usb 1-3: Manufacturer: Realtek
[ 8.272448] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 8.275889] usb 1-3: SerialNumber: 00e04c000001
[ 8.288570] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[ 8.295780] tegra194-pcie 14160000.pcie: IO 0x0036100000..0x00361fffff -> 0x0036100000
[ 8.304512] tegra194-pcie 14160000.pcie: MEM 0x2428000000..0x242fffffff -> 0x0040000000
[ 8.313233] tegra194-pcie 14160000.pcie: MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[ 8.323023] usb 2-3: new SuperSpeedPlus Gen 2 USB device number 2 using tegra-xusb
[ 8.330867] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[ 8.367456] usb 2-3: New USB device found, idVendor=0bda, idProduct=0420, bcdDevice= 1.40
[ 8.375880] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8.383223] usb 2-3: Product: 4-Port USB 3.0 Hub
[ 8.387971] usb 2-3: Manufacturer: Generic
[ 8.403064] hub 2-3:1.0: USB hub found
[ 8.409187] hub 2-3:1.0: 4 ports detected
[ 8.485622] usb 1-4: new high-speed USB device number 3 using tegra-xusb
[ 8.664002] usb 1-4: New USB device found, idVendor=0bda, idProduct=5420, bcdDevice= 1.40
[ 8.672425] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8.679766] usb 1-4: Product: 4-Port USB 2.0 Hub
[ 8.684517] usb 1-4: Manufacturer: Generic
[ 8.690040] hub 1-4:1.0: USB hub found
[ 8.695077] hub 1-4:1.0: 4 ports detected
[ 9.421627] tegra194-pcie 14160000.pcie: Phy link never came up
[ 9.427780] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 9.434605] usb 1-4.4: new full-speed USB device number 4 using tegra-xusb
[ 9.441695] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 9.447347] pci_bus 0004:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[ 9.457482] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[ 9.468354] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[ 9.476287] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[ 9.482620] pci 0004:00:00.0: PME# supported from D0 D3hot
[ 9.496769] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 9.502166] pci 0004:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 9.511144] pcieport 0004:00:00.0: Adding to iommu group 10
[ 9.517136] pcieport 0004:00:00.0: PME: Signaling with IRQ 66
[ 9.523828] pcieport 0004:00:00.0: AER: enabled with IRQ 66
[ 9.529806] pci_bus 0004:01: busn_res: [bus 01-ff] is released
[ 9.535885] pci 0004:00:00.0: Removing from iommu group 10
[ 9.541531] pci_bus 0004:00: busn_res: [bus 00-ff] is released
[ 9.548864] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 9.555456] vdd-3v3-pcie: supplied by vdd-3v3-sys
[ 9.560509] avdd-cam-2v8: supplied by vdd-3v3-sys
[ 9.565449] vdd-dp: supplied by vdd-3v3-sys
[ 9.569912] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 9.574988] dsi-vdd-1v8-bl-en: supplied by vdd-1v8-sys
[ 9.582182] tegra194-isp5 14800000.isp: initialized
[ 9.591889] usb 1-4.4: New USB device found, idVendor=25a7, idProduct=fa67, bcdDevice= 7.00
[ 9.600494] usb 1-4.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 9.608030] usb 1-4.4: Product: 2.4G Receiver
[ 9.612528] usb 1-4.4: Manufacturer: CX
[ 9.623121] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized
[ 9.629610] (NULL device *): fops function table already registered
[ 9.636315] input: CX 2.4G Receiver as /devices/platform/3610000.xhci/usb1/1-4/1-4.4/1-4.4:1.0/0003:25A7:FA67.0001/input/input0
[ 9.649519] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized
[ 9.656359] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 9.661702] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 9.678487] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 303
[ 9.705858] hid-generic 0003:25A7:FA67.0001: input,hidraw0: USB HID v1.10 Keyboard [CX 2.4G Receiver] on usb-3610000.xhci-4.4/input0
[ 9.722245] input: CX 2.4G Receiver Mouse as /devices/platform/3610000.xhci/usb1/1-4/1-4.4/1-4.4:1.1/0003:25A7:FA67.0002/input/input1
[ 9.734829] input: CX 2.4G Receiver as /devices/platform/3610000.xhci/usb1/1-4/1-4.4/1-4.4:1.1/0003:25A7:FA67.0002/input/input2
[ 9.746688] input: CX 2.4G Receiver Consumer Control as /devices/platform/3610000.xhci/usb1/1-4/1-4.4/1-4.4:1.1/0003:25A7:FA67.0002/input/input3
[ 9.774179] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[ 9.781355] tegra194-pcie 141a0000.pcie: IO 0x003a100000..0x003a1fffff -> 0x003a100000
[ 9.790042] tegra194-pcie 141a0000.pcie: MEM 0x2b28000000..0x2b2fffffff -> 0x0040000000
[ 9.798726] tegra194-pcie 141a0000.pcie: MEM 0x2740000000..0x2b27ffffff -> 0x2740000000
[ 9.817839] input: CX 2.4G Receiver System Control as /devices/platform/3610000.xhci/usb1/1-4/1-4.4/1-4.4:1.1/0003:25A7:FA67.0002/input/input4
[ 9.831584] hid-generic 0003:25A7:FA67.0002: input,hiddev96,hidraw1: USB HID v1.10 Mouse [CX 2.4G Receiver] on usb-3610000.xhci-4.4/input1
[ 10.738027] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit
[ 10.915059] tegra194-pcie 141a0000.pcie: Phy link never came up
[ 10.921218] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[ 10.928036] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 10.933669] pci_bus 0005:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x3a100000-0x3a1fffff])
[ 10.943765] pci_bus 0005:00: root bus resource [mem 0x2b28000000-0x2b2fffffff] (bus address [0x40000000-0x47ffffff])
[ 10.954599] pci_bus 0005:00: root bus resource [mem 0x2740000000-0x2b27ffffff pref]
[ 10.962531] pci 0005:00:00.0: [10de:229a] type 01 class 0x060400
[ 10.968866] pci 0005:00:00.0: PME# supported from D0 D3hot
[ 10.982918] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 10.988317] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 10.997285] pcieport 0005:00:00.0: Adding to iommu group 11
[ 11.003264] pcieport 0005:00:00.0: PME: Signaling with IRQ 68
[ 11.009686] pcieport 0005:00:00.0: AER: enabled with IRQ 68
[ 11.015649] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[ 11.021726] pci 0005:00:00.0: Removing from iommu group 11
[ 11.027373] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[ 11.034995] nvethernet 6810000.ethernet: Adding to iommu group 51
[ 11.041583] nvethernet 6810000.ethernet: failed to read skip mac reset flag, default 0
[ 11.049766] nvethernet 6810000.ethernet: failed to read MDIO address
[ 11.056315] nvethernet 6810000.ethernet: setting to default DMA bit mask
[ 11.063223] nvethernet 6810000.ethernet: failed to read UPHY GBE mode- default to 10G
[ 11.459483] nvethernet 6810000.ethernet: Ethernet MAC address: 48:b0:2d:fd:c9:dc
[ 11.467492] nvethernet 6810000.ethernet: macsec param in DT is missing or disabled
[ 11.475287] nvethernet 6810000.ethernet: Macsec not supported/Not enabled in DT
[ 11.484801] nvethernet 6810000.ethernet: eth0 (HW ver: 31) created with 10 DMA channels
[ 11.493537] irq: IRQ305: trimming hierarchy from :pmc@c360000
[ 11.499510] irq: IRQ306: trimming hierarchy from :interrupt-controller@f400000-1
[ 11.507190] irq: IRQ307: trimming hierarchy from :pmc@c360000
[ 11.513165] input: gpio-keys as /devices/platform/gpio-keys/input/input6
[ 11.520488] tegra-se-nvhost 15810000.se: Adding to iommu group 52
[ 11.527091] tegra-se-nvhost 15810000.se: initialized
[ 11.543078] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 11.549453] tegra-se-nvhost 15820000.se: Adding to iommu group 53
[ 11.556008] tegra-se-nvhost 15820000.se: initialized
[ 11.563548] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 11.569910] tegra-se-nvhost 15840000.se: Adding to iommu group 54
[ 11.576462] tegra-se-nvhost 15840000.se: initialized
[ 11.583394] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 11.590272] tegra_actmon d230000.actmon: in actmon_register()...
[ 11.596588] tegra_actmon d230000.actmon: bwmgr_disable = 1
[ 11.602621] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[ 11.611019] hvc_sysfs: hypervisor is not present
��WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpusysclk
WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpc1clk
WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpc0clk
��[ 11.741864] ALSA device list:
[ 11.744936] No soundcards found.
[ 11.749026] Freeing unused kernel memory: 3968K
[ 11.753748] Run /init as init process
[ 11.769075] Root device found: mmcblk0p1
[ 11.777239] Found dev node: /dev/mmcblk0p1
[ 11.903136] EXT4-fs (mmcblk0p1): recovery complete
[ 11.908700] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 11.919416] Rootfs mounted over mmcblk0p1
[ 11.933625] Switching from initrd to actual rootfs
[ 12.037090] systemd[1]: System time before build time, advancing clock.
[ 12.086407] systemd[1]: systemd 249.11-0ubuntu3.12 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSS)
[ 12.087189] random: crng init done
[ 12.118871] systemd[1]: Detected architecture arm64.
[ 12.137003] systemd[1]: Hostname set to <AI-Commenth>.
[ 12.332297] systemd[1]: Configuration file /run/systemd/system/netplan-ovs-cleanup.service is marked world-inaccessible. This has no effect as configu.
[ 12.411129] systemd[1]: /etc/systemd/system/nvs-service.service:38: Standard output type syslog is obsolete, automatically updating to journal. Please.
[ 12.441631] systemd[1]: /etc/systemd/system/nvargus-daemon.service:40: Standard output type syslog is obsolete, automatically updating to journal. Ple.
[ 12.517787] systemd[1]: Queued start job for default target Graphical Interface.
[ 12.526578] systemd[1]: Created slice Slice /system/modprobe.
[ 12.533069] systemd[1]: Created slice Slice /system/serial-getty.
[ 12.539676] systemd[1]: Created slice User and Session Slice.
[ 12.545753] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 12.553875] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 12.563675] systemd[1]: Reached target Slice Units.
[ 12.568759] systemd[1]: Reached target Mounting snaps.
[ 12.574131] systemd[1]: Reached target Swaps.
[ 12.578685] systemd[1]: Reached target Local Verity Protected Volumes.
[ 12.593405] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 12.600343] systemd[1]: Listening on Syslog Socket.
[ 12.605537] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 12.612577] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 12.619605] systemd[1]: Listening on Journal Audit Socket.
[ 12.625403] systemd[1]: Listening on Journal Socket (/dev/log).
[ 12.631682] systemd[1]: Listening on Journal Socket.
[ 12.637017] systemd[1]: Listening on udev Control Socket.
[ 12.642718] systemd[1]: Listening on udev Kernel Socket.
[ 12.649147] systemd[1]: Mounting Huge Pages File System...
[ 12.655712] systemd[1]: Mounting POSIX Message Queue File System...
[ 12.663059] systemd[1]: Mounting Kernel Debug File System...
[ 12.669717] systemd[1]: Mounting Kernel Trace File System...
[ 12.675855] systemd[1]: systemd-journald.service: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 12.689129] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 12.698593] systemd[1]: Starting Journal Service...
[ 12.703795] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[ 12.714433] systemd[1]: Starting Set the console keyboard layout...
[ 12.722064] systemd[1]: Starting Create List of Static Device Nodes...
[ 12.729769] systemd[1]: Starting Load Kernel Module configfs...
[ 12.737542] systemd[1]: Starting Load Kernel Module drm...
[ 12.744238] systemd[1]: Starting Load Kernel Module efi_pstore...
[ 12.751920] systemd[1]: Starting Load Kernel Module fuse...
[ 12.758929] systemd[1]: Starting NVIDIA specific first-boot udev script...
[ 12.760626] fuse: init (API version 7.32)
[ 12.771778] systemd[1]: Started Nameserver information manager.
[ 12.778230] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 12.789340] systemd[1]: Starting Load Kernel Modules...
[ 12.795703] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 12.802071] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 12.809096] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 12.809220] systemd[1]: Starting Coldplug All udev Devices...
[ 12.816023] tegra-carveouts tegra-carveouts: fsi :dma coherent mem declare 0x0000001038e00000,16777216
[ 12.831333] tegra-carveouts tegra-carveouts: assigned reserved memory node fsi-carveout
[ 12.831341] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x0000001049800000,914358272
[ 12.849227] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 12.849233] nvmap_page_pool_init: Total RAM pages: 16076943
[ 12.863211] nvmap_page_pool_init: nvmap page pool size: 2009617 pages (3754 MB)
[ 12.863264] nvmap_background_zero_thread: PP zeroing thread starting.
[ 12.863359] misc nvmap: created heap vpr base 0x0000001049800000 size (892928KiB)
[ 12.866437] misc nvmap: created heap fsi base 0x0000001038e00000 size (16384KiB)
[ 12.894418] systemd[1]: Started Journal Service.
[ 12.919613] systemd-journald[319]: Received client request to flush runtime journal.
[ 12.928332] nvgpu: 17000000.ga10b nvgpu_nvhost_syncpt_init:135 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[ 12.928332]
[ 13.243299] nvidia: loading out-of-tree module taints kernel.
[ 13.472472] OF: graph: no port node found in /i2c@c240000/ucsi_ccg@8/connector@0
[ 13.564477] OF: graph: no port node found in /i2c@c240000/ucsi_ccg@8/connector@0
[ 13.573218] OF: graph: no port node found in /i2c@c240000/ucsi_ccg@8/connector@0
[ 13.831527] using random self ethernet address
[ 13.836131] using random host ethernet address
[ 14.391467] using random self ethernet address
[ 14.396083] using random host ethernet address
[ 14.789949] CPU8: shutdown
[ 14.970212] CPU9: shutdown
[ 15.066395] CPU10: shutdown
[ 15.170763] IRQ 124: no longer affine to CPU11
[ 15.175835] CPU11: shutdown
Ubuntu 22.04.4 LTS AI-Commenth ttyTCU0
