Hi, Nvidia
On the Orin circuit board I designed myself, I can see that the monitor displays the UEFI image and outputs a few seconds of logs, then the screen goes black. Here are my debug UART logs
[0000.064] I> MB1 (version: 1.4.0.4-t234-54845784-e89ea9bc)
[0000.069] I> t234-A01-1-Silicon (0x12347) Prod
[0000.073] I> Boot-mode : Coldboot
[0000.076] I> Entry timestamp: 0x00000000
[0000.080] I> last_boot_error: 0x0
[0000.083] I> BR-BCT: preprod_dev_sign: 0
[0000.087] I> rst_source: 0x0, rst_level: 0x0
[0000.091] I> Task: SE error check
[0000.094] I> Task: Bootchain select WAR set
[0000.098] I> Task: Enable SLCG
[0000.101] I> Task: CRC check
[0000.104] I> Task: Initialize MB2 params
[0000.108] I> MB2-params @ 0x40060000
[0000.112] I> Task: Crypto init
[0000.115] I> Task: Perform MB1 KAT tests
[0000.119] I> Task: NVRNG health check
[0000.122] I> NVRNG: Health check success
[0000.126] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0000.132] I> Task: Enabling and initialization of Bandwidth limiter
[0000.138] I> No request to configure MBWT settings for any PC!
[0000.144] I> Task: Secure debug controls
[0000.148] I> Task: strap war set
[0000.151] I> Task: Initialize SOC Therm
[0000.154] I> Task: Program NV master stream id
[0000.159] I> Task: Verify boot mode
[0000.164] I> Task: Alias fuses
[0000.168] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.175] I> Task: Print SKU type
[0000.178] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x00000007
[0000.183] I> FUSE_OPT_GPC_DISABLE = 0x00000000
[0000.188] I> FUSE_OPT_TPC_DISABLE = 0x00000080
[0000.192] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0000.196] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0000.200] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0000.205] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0000.209] I> FUSE_OPT_FSI_DISABLE = 0x00000000
[0000.214] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0000.218] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.222] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.226] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.230] I> FUSE_SKU_INFO_0 = 0xd2
[0000.234] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.238] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.241] I> SKU: Prod
[0000.244] I> Task: Boost clocks
[0000.247] I> Initializing PLLC2 for AXI_CBB.
[0000.251] I> AXI_CBB : src = 35, divisor = 0
[0000.255] I> Task: Voltage monitor
[0000.258] I> VMON: Vmon re-calibration and fine tuning done
[0000.264] I> Task: UPHY init
[0000.268] I> HSIO UPHY init done
[0000.272] W> Skipping GBE UPHY config
[0000.275] I> Task: Boot device init
[0000.278] I> Boot_device: QSPI_FLASH instance: 0
[0000.283] I> Qspi clock source : pllc_out0
[0000.287] I> QSPI Flash: Macronix 64MB
[0000.291] I> QSPI-0l initialized successfully
[0000.295] I> Task: TSC init
[0000.298] I> Task: Load membct
[0000.301] I> RAM_CODE 0x4000411
[0000.304] I> Loading MEMBCT
[0000.307] I> Slot: 0
[0000.309] I> Binary[0] block-3840 (partition size: 0x40000)
[0000.314] I> Binary name: MEM-BCT-0
[0000.317] I> Size of crypto header is 8192
[0000.321] I> Size of crypto header is 8192
[0000.325] I> strt_pg_num(3840) num_of_pgs(16) read_buf(0x40050000)
[0000.331] I> BCH of MEM-BCT-0 read from storage
[0000.336] I> BCH address is : 0x40050000
[0000.340] I> MEM-BCT-0 header integrity check is success
[0000.345] I> Binary magic in BCH component 0 is MEM0
[0000.350] I> component binary type is 0
[0000.353] I> strt_pg_num(3856) num_of_pgs(115) read_buf(0x40040000)
[0000.360] I> MEM-BCT-0 binary is read from storage
[0000.365] I> MEM-BCT-0 binary integrity check is success
[0000.370] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0000.377] I> RAM_CODE 0x4000411
[0000.382] I> RAM_CODE 0x4000411
[0000.386] I> Task: Load Page retirement list
[0000.390] I> Task: SDRAM params override
[0000.394] I> Task: Save mem-bct info
[0000.397] I> Task: Carveout allocate
[0000.401] I> RCM blob carveout will not be allocated
[0000.406] I> Update CCPLEX IST carveout from MB1-BCT
[0000.410] I> ECC region[0]: Start:0x0, End:0x0
[0000.415] I> ECC region[1]: Start:0x0, End:0x0
[0000.419] I> ECC region[2]: Start:0x0, End:0x0
[0000.423] I> ECC region[3]: Start:0x0, End:0x0
[0000.428] I> ECC region[4]: Start:0x0, End:0x0
[0000.432] I> Non-ECC region[0]: Start:0x80000000, End:0x880000000
[0000.438] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.442] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.447] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.452] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.462] I> allocated(CO:44) base:0x849800000 size:0x36800000 align: 0x100000
[0000.470] I> allocated(CO:31) base:0x840000000 size:0x8000000 align: 0x8000000
[0000.477] I> allocated(CO:43) base:0x83c000000 size:0x4000000 align: 0x200000
[0000.484] I> allocated(CO:39) base:0x839e00000 size:0x2200000 align: 0x10000
[0000.491] I> allocated(CO:20) base:0x836000000 size:0x2000000 align: 0x2000000
[0000.498] I> allocated(CO:24) base:0x834000000 size:0x2000000 align: 0x2000000
[0000.505] I> allocated(CO:28) base:0x832000000 size:0x2000000 align: 0x2000000
[0000.512] I> allocated(CO:29) base:0x830000000 size:0x2000000 align: 0x2000000
[0000.519] I> allocated(CO:22) base:0x848000000 size:0x1000000 align: 0x1000000
[0000.526] I> allocated(CO:41) base:0x838e00000 size:0x1000000 align: 0x100000
[0000.533] I> allocated(CO:35) base:0x838000000 size:0xe00000 align: 0x10000
[0000.540] I> allocated(CO:02) base:0x849000000 size:0x800000 align: 0x800000
[0000.547] I> allocated(CO:03) base:0x82f800000 size:0x800000 align: 0x800000
[0000.554] I> allocated(CO:06) base:0x82f000000 size:0x800000 align: 0x800000
[0000.561] I> allocated(CO:56) base:0x82e800000 size:0x800000 align: 0x200000
[0000.568] I> allocated(CO:07) base:0x82e400000 size:0x400000 align: 0x400000
[0000.575] I> allocated(CO:33) base:0x82e000000 size:0x400000 align: 0x200000
[0000.582] I> allocated(CO:23) base:0x82de00000 size:0x200000 align: 0x200000
[0000.589] I> allocated(CO:01) base:0x82dd00000 size:0x100000 align: 0x100000
[0000.596] I> allocated(CO:05) base:0x82dc00000 size:0x100000 align: 0x100000
[0000.603] I> allocated(CO:08) base:0x82db00000 size:0x100000 align: 0x100000
[0000.610] I> allocated(CO:09) base:0x82da00000 size:0x100000 align: 0x100000
[0000.617] I> allocated(CO:15) base:0x82d900000 size:0x100000 align: 0x100000
[0000.623] I> allocated(CO:17) base:0x82d800000 size:0x100000 align: 0x100000
[0000.630] I> allocated(CO:27) base:0x82d700000 size:0x100000 align: 0x100000
[0000.637] I> allocated(CO:42) base:0x82d600000 size:0x100000 align: 0x100000
[0000.644] I> allocated(CO:54) base:0x82d580000 size:0x80000 align: 0x80000
[0000.651] I> allocated(CO:34) base:0x82d570000 size:0x10000 align: 0x10000
[0000.658] I> allocated(CO:72) base:0x82d370000 size:0x200000 align: 0x10000
[0000.665] I> allocated(CO:47) base:0x82ce00000 size:0x400000 align: 0x200000
[0000.672] I> allocated(CO:48) base:0x82d350000 size:0x20000 align: 0x10000
[0000.678] I> allocated(CO:69) base:0x82d330000 size:0x20000 align: 0x10000
[0000.685] I> allocated(CO:49) base:0x82d320000 size:0x10000 align: 0x10000
[0000.692] I> allocated(CO:50) base:0x82d310000 size:0x10000 align: 0x10000
[0000.699] I> allocated(CO:52) base:0x82d300000 size:0x10000 align: 0x10000
[0000.705] I> NSDRAM base: 0x80000000, end: 0x82d370000, size: 0x7ad370000
[0000.712] I> Task: Thermal check
[0000.715] I> Using min_chip_limit as min_tmon_limit
[0000.720] I> Using max_chip_limit as max_tmon_limit
[0000.725] I> BCT max_tmon_limit = 105
[0000.728] I> BCT min_tmon_limit = -28
[0000.732] I> BCT max_tmon_limit = 105
[0000.735] I> BCT min_tmon_limit = -28
[0000.739] I> SKU specific max_chip_limit = 105
[0000.743] I> SKU specific min_chip_limit = -28
[0000.747] I> BCT max_chip_limit = 105
[0000.751] I> BCT min_chip_limit = -28
[0000.754] I> enable_soctherm_polling = 0
[0000.758] I> max temp read = 29
[0000.761] I> min temp read = 27
[0000.764] I> Enabling thermtrip
[0000.767] I> Task: Update FSI SCR with thermal fuse data
[0000.772] I> Task: Enable WDT 5th expiry
[0000.776] I> Task: I2C register
[0000.779] I> Task: Set I2C bus freq
[0000.782] I> Task: Reset FSI
[0000.785] I> Task: Pinmux init
[0000.788] I> Task: Prod config init
[0000.791] I> Task: Pad voltage init
[0000.795] I> Task: Prod init
[0000.798] I> Task: Program rst req config reg
[0000.802] I> Task: Common rail init
[0000.805] I> DONE: Thermal config
[0000.809] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0000.818] I> DONE: SOC rail config
[0000.821] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0000.828] I> DONE: MEMIO rail config
[0000.831] I> DONE: GPU rail info
[0000.836] I> DONE: CV rail info
[0000.839] I> Task: Mem clock src
[0000.842] I> Task: Misc. board config
[0000.846] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0000.852] I> Task: SDRAM init
[0000.854] I> MemoryType: 4 MemBctRevision: 9
[0000.861] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 9
[0000.868] I> MSS CAR: Init PLLM
[0000.872] I> MSS CAR: Init PLLHUB
[0000.876] I> Encryption: MTS: en, TX: en, VPR: en, GSC: en
[0000.888] I> SDRAM initialized!
[0000.891] I> SDRAM Size in Total 0x800000000
[0000.895] I> Task: Dram Ecc scrub
[0000.898] I> Task: DRAM alias check
[0000.908] I> Task: Program NSDRAM carveout
[0000.912] I> NSDRAM carveout encryption is enabled
[0000.917] I> Program NSDRAM carveout
[0000.920] I> Task: Register checker
[0000.924] I> Task: Enable clock-mon
[0000.938] I> FMON: Fmon re-programming done
[0000.942] I> Task: Mapper init
[0000.945] I> Task: SC7 Context Init
[0000.948] I> Task: CCPLEX IST init
[0000.952] I> Task: CPU WP0
[0000.956] I> Loading MCE
[0000.958] I> Slot: 0
[0000.960] I> Binary[8] block-22784 (partition size: 0x80000)
[0000.965] I> Binary name: MCE
[0000.968] I> Size of crypto header is 8192
[0000.972] I> Size of crypto header is 8192
[0000.976] I> strt_pg_num(22784) num_of_pgs(16) read_buf(0x4003e000)
[0000.982] I> BCH of MCE read from storage
[0000.986] I> BCH address is : 0x4003e000
[0000.990] I> MCE header integrity check is success
[0000.995] I> Binary magic in BCH component 0 is MTSM
[0001.000] I> component binary type is 8
[0001.003] I> Size of crypto header is 8192
[0001.007] I> strt_pg_num(22800) num_of_pgs(357) read_buf(0x40000000)
[0001.016] I> MCE binary is read from storage
[0001.020] I> MCE binary integrity check is success
[0001.025] I> Binary MCE loaded successfully at 0x40000000 (0x2c880)
[0001.031] I> Size of crypto header is 8192
[0001.042] I> Size of crypto header is 8192
[0001.046] I> Sending WP0 mailbox command to PSC
[0001.055] I> Task: XUSB Powergate
[0001.058] I> Skipping powergate XUSB.
[0001.062] I> Task: MB1 fixed firewalls
[0001.068] W> Firewall readback mismatch
[0001.073] I> Task: Load bpmp-fw
[0001.076] I> Slot: 0
[0001.078] I> Binary[15] block-9984 (partition size: 0x180000)
[0001.084] I> Binary name: BPMP_FW
[0001.087] I> Size of crypto header is 8192
[0001.091] I> Size of crypto header is 8192
[0001.095] I> strt_pg_num(9984) num_of_pgs(16) read_buf(0x807fe000)
[0001.101] I> BCH of BPMP_FW read from storage
[0001.105] I> BCH address is : 0x807fe000
[0001.109] I> BPMP_FW header integrity check is success
[0001.114] I> Binary magic in BCH component 0 is BPMF
[0001.119] I> component binary type is 15
[0001.122] I> Size of crypto header is 8192
[0001.126] I> strt_pg_num(10000) num_of_pgs(1990) read_buf(0x80000000)
[0001.144] I> BPMP_FW binary is read from storage
[0001.150] I> BPMP_FW binary integrity check is success
[0001.155] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xf8bc0)
[0001.162] I> Slot: 0
[0001.164] I> Binary[16] block-13056 (partition size: 0x400000)
[0001.169] I> Binary name: BPMP_FW_DTB
[0001.173] I> Size of crypto header is 8192
[0001.177] I> Size of crypto header is 8192
[0001.181] I> strt_pg_num(13056) num_of_pgs(16) read_buf(0x807fc000)
[0001.187] I> BCH of BPMP_FW_DTB read from storage
[0001.192] I> BCH address is : 0x807fc000
[0001.195] I> BPMP_FW_DTB header integrity check is success
[0001.201] I> Binary magic in BCH component 0 is BPMD
[0001.206] I> component binary type is 16
[0001.209] I> Size of crypto header is 8192
[0001.213] I> strt_pg_num(13072) num_of_pgs(726) read_buf(0x807a13f0)
[0001.224] I> BPMP_FW_DTB binary is read from storage
[0001.229] I> BPMP_FW_DTB binary integrity check is success
[0001.234] I> Binary BPMP_FW_DTB loaded successfully at 0x807a13f0 (0x5abc0)
[0001.241] I> Task: BPMP fw ast config
[0001.245] I> Task: Load psc-fw
[0001.248] I> Slot: 0
[0001.250] I> Binary[17] block-21248 (partition size: 0xc0000)
[0001.255] I> Binary name: PSC_FW
[0001.258] I> Size of crypto header is 8192
[0001.262] I> Size of crypto header is 8192
[0001.266] I> strt_pg_num(21248) num_of_pgs(16) read_buf(0x80ffe000)
[0001.273] I> BCH of PSC_FW read from storage
[0001.277] I> BCH address is : 0x80ffe000
[0001.281] I> PSC_FW header integrity check is success
[0001.285] I> Binary magic in BCH component 0 is PFWP
[0001.290] I> component binary type is 17
[0001.294] I> Size of crypto header is 8192
[0001.298] I> strt_pg_num(21264) num_of_pgs(717) read_buf(0x80fa4600)
[0001.308] I> PSC_FW binary is read from storage
[0001.313] I> PSC_FW binary integrity check is success
[0001.318] I> Binary PSC_FW loaded successfully at 0x80fa4600 (0x59980)
[0001.325] I> Task: Load nvdec-fw
[0001.328] I> Slot: 0
[0001.330] I> Binary[7] block-6400 (partition size: 0x100000)
[0001.335] I> Binary name: NVDEC
[0001.338] I> Size of crypto header is 8192
[0001.342] I> Size of crypto header is 8192
[0001.346] I> strt_pg_num(6400) num_of_pgs(16) read_buf(0x800fe000)
[0001.352] I> BCH of NVDEC read from storage
[0001.356] I> BCH address is : 0x800fe000
[0001.360] I> NVDEC header integrity check is success
[0001.365] I> Binary magic in BCH component 0 is NDEC
[0001.370] I> component binary type is 7
[0001.373] I> Size of crypto header is 8192
[0001.377] I> strt_pg_num(6416) num_of_pgs(560) read_buf(0x80000000)
[0001.387] I> NVDEC binary is read from storage
[0001.391] I> NVDEC binary integrity check is success
[0001.396] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
[0001.403] I> Size of crypto header is 8192
[0001.414] I> Task: Load tsec-fw
[0001.417] I> TSEC-FW load support not enabled
[0001.421] I> Task: GPIO interrupt map
[0001.425] I> Task: SC7 context save
[0001.428] I> Slot: 0
[0001.430] I> Binary[27] block-0 (partition size: 0x100000)
[0001.436] I> Binary name: BR_BCT
[0001.439] I> Size of crypto header is 8192
[0001.443] I> Size of crypto header is 8192
[0001.446] I> Size of crypto header is 8192
[0001.450] I> strt_pg_num(0) num_of_pgs(16) read_buf(0xa0000000)
[0001.456] I> BR_BCT binary is read from storage
[0001.461] I> BR_BCT binary integrity check is success
[0001.466] I> Binary BR_BCT loaded successfully at 0xa0000000 (0x2000)
[0001.472] I> Slot: 0
[0001.474] I> Binary[13] block-23808 (partition size: 0x30000)
[0001.480] I> Binary name: SC7-FW
[0001.483] I> Size of crypto header is 8192
[0001.487] I> Size of crypto header is 8192
[0001.491] I> Size of crypto header is 8192
[0001.494] I> Size of crypto header is 8192
[0001.498] I> strt_pg_num(23808) num_of_pgs(16) read_buf(0xa0002000)
[0001.505] I> BCH of SC7-FW read from storage
[0001.509] I> BCH address is : 0xa0002000
[0001.513] I> SC7-FW header integrity check is success
[0001.517] I> Binary magic in BCH component 0 is WB0B
[0001.522] I> component binary type is 13
[0001.526] I> Size of crypto header is 8192
[0001.530] I> strt_pg_num(23824) num_of_pgs(349) read_buf(0xa0004000)
[0001.538] I> SC7-FW binary is read from storage
[0001.543] I> SC7-FW binary integrity check is success
[0001.548] I> Binary SC7-FW loaded successfully at 0xa0004000 (0x2ba00)
[0001.554] I> Slot: 0
[0001.556] I> Binary[22] block-24192 (partition size: 0x30000)
[0001.562] I> Binary name: PSC_RF
[0001.565] I> Size of crypto header is 8192
[0001.569] I> Size of crypto header is 8192
[0001.573] I> Size of crypto header is 8192
[0001.577] I> Size of crypto header is 8192
[0001.581] I> strt_pg_num(24192) num_of_pgs(16) read_buf(0xa002fa00)
[0001.587] I> BCH of PSC_RF read from storage
[0001.591] I> BCH address is : 0xa002fa00
[0001.595] I> PSC_RF header integrity check is success
[0001.600] I> Binary magic in BCH component 0 is PSCR
[0001.605] I> component binary type is 22
[0001.608] I> Size of crypto header is 8192
[0001.612] I> strt_pg_num(24208) num_of_pgs(256) read_buf(0xa0031a00)
[0001.620] I> PSC_RF binary is read from storage
[0001.625] I> PSC_RF binary integrity check is success
[0001.629] I> Binary PSC_RF loaded successfully at 0xa0031a00 (0x20000)
[0001.639] I> Task: Save WP0 payload to SC7 ctx
[0001.643] I> Task: Load MB2rf binary to SC7 ctx
[0001.648] I> Slot: 0
[0001.650] I> Binary[14] block-24576 (partition size: 0x20000)
[0001.655] I> Binary name: MB2_RF
[0001.658] I> Size of crypto header is 8192
[0001.662] I> Size of crypto header is 8192
[0001.666] I> Size of crypto header is 8192
[0001.670] I> Size of crypto header is 8192
[0001.674] I> strt_pg_num(24576) num_of_pgs(16) read_buf(0xa00d6aa0)
[0001.680] I> BCH of MB2_RF read from storage
[0001.684] I> BCH address is : 0xa00d6aa0
[0001.688] I> MB2_RF header integrity check is success
[0001.693] I> Binary magic in BCH component 0 is MB2R
[0001.698] I> component binary type is 14
[0001.702] I> Size of crypto header is 8192
[0001.706] I> strt_pg_num(24592) num_of_pgs(223) read_buf(0xa00d8aa0)
[0001.713] I> MB2_RF binary is read from storage
[0001.718] I> MB2_RF binary integrity check is success
[0001.723] I> Binary MB2_RF loaded successfully at 0xa00d8aa0 (0x1bcc0)
[0001.729] I> Task: Save fuse alias data to SC7 ctx
[0001.734] I> Task: Save PMIC data to SC7 ctx
[0001.738] I> Task: Save Pinmux data to SC7 ctx
[0001.742] I> Task: Save Pad Voltage data to SC7 ctx
[0001.747] I> Task: Save controller prod data to SC7 ctx
[0001.752] I> Task: Save prod cfg data to SC7 ctx
[0001.756] I> Task: Save I2C bus freq data to SC7 ctx
[0001.761] I> Task: Save SOCTherm data to SC7 ctx
[0001.765] I> Task: Save FMON data to SC7 ctx
[0001.770] I> Task: Save VMON data to SC7 ctx
[0001.774] I> Task: Save TZDRAM data to SC7 ctx
[0001.778] I> Task: Save GPIO int data to SC7 ctx
[0001.782] I> Task: Save clock data to SC7 ctx
[0001.787] I> Task: Save debug data to SC7 ctx
[0001.791] I> Task: Save MBWT data to SC7 ctx
[0001.799] I> SC7 context save done
[0001.802] I> Task: Load MB2/Applet/FSKP
[0001.806] I> Loading MB2
[0001.808] I> Slot: 0
[0001.810] I> Binary[6] block-8448 (partition size: 0x80000)
[0001.816] I> Binary name: MB2
[0001.818] I> Size of crypto header is 8192
[0001.822] I> Size of crypto header is 8192
[0001.826] I> strt_pg_num(8448) num_of_pgs(16) read_buf(0x8007e000)
[0001.833] I> BCH of MB2 read from storage
[0001.836] I> BCH address is : 0x8007e000
[0001.840] I> MB2 header integrity check is success
[0001.845] I> Binary magic in BCH component 0 is MB2B
[0001.850] I> component binary type is 6
[0001.853] I> Size of crypto header is 8192
[0001.857] I> strt_pg_num(8464) num_of_pgs(839) read_buf(0x80000000)
[0001.868] I> MB2 binary is read from storage
[0001.873] I> MB2 binary integrity check is success
[0001.878] I> Binary MB2 loaded successfully at 0x80000000 (0x68c10)
[0001.884] I> Task: Map CCPLEX SHARED carveout
[0001.888] I> Task: Prepare MB2 params
[0001.892] I> Task: Dram ecc test
[0001.895] I> Task: Misc NV security settings
[0001.899] I> NVDEC sticky bits programming done
[0001.904] I> Successfully powergated NVDEC
[0001.908] I> Task: Disable/Reload WDT
[0001.911] I> Task: Program misc carveouts
[0001.915] I> Program IPC carveouts
[0001.918] I> Task: Disable SCPM/POD reset
[0001.922] I> SLCG Global override status := 0x0
[0001.927] I> MB1: MSS reconfig completed
I> MB2 (version: 0.0.0.0-t234-54845784-7f6f63a6)
I> Emulation:
I> Entry timestamp: 0x001dc5c4
I> Regular heap: [base:0x40040000, size:0x10000]
I> DMA heap: [base:0x82e800000, size:0x800000]
I> Task: ARI update carveout TZDRAM (0x50002050)
I> Task: Check MC errors (0x5000204c)
I> Task: SMMU external bypass disable (0x500184fc)
I> Task: Enable hot-plug capability (0x50028dec)
I> Task: TZDRAM heap init (0x50019de0)
I> Task: PSC mailbox init (0x50018548)
I> Task: Crypto init (0x50006888)
I> Task: Enable GP-SE clock (0x500021b4)
I> Task: Measured Boot init (0x5001bd30)
I> Task: fTPM silicon identity init (0x5001bedc)
I> fTPM is not enabled.
I> Task: OEM SC7 context save init (0x5001b27c)
I> Task: I2C register (0x50002010)
I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout (0x50001ff8)
I> Task: Program CBB PCIE AMAP regions (0x5001b9dc)
I> Task: Boot device init (0x50001f40)
I> Task: Partition Manager Init (0x50001f20)
I> Active chain: 0
I> Found 57 partitions in QSPI_FLASH (instance 0)
I> Active chain: 0
W> Cannot find any partition table for 00000003
> PARTITION_MANAGER: Failed to publish partition.
I> Active chain: 0
I> Found 15 partitions in SDMMC_USER (instance 3)
I> Task: Load and authenticate registered FWs (0x5001ed44)
I> Task: Load AUXP FWs (0x50028970)
I> Successfully register SPE FW load task with MB2 loader
I> Skipping SCE FW load
I> Successfully register RCE FW load task with MB2 loader
I> Successfully register DCE FW load task with MB2 loader
I> Unpowergating APE
I> Unpowergate done
I> Successfully register APE FW load task with MB2 loader
I> Skipping FSI FW load
I> Successfully register XUSB FW load task with MB2 loader
I> Active chain: 0
I> Partition name: A_spe-fw
I> Size of partition: 589824
I> Binary@ device:3/0 block-55040 (partition size: 0x90000), name: A_spe-fw
I> Active chain: 0
I> Partition name: A_rce-fw
I> Size of partition: 1048576
I> Binary@ device:3/0 block-56192 (partition size: 0x100000), name: A_rce-fw
I> spe: Authentication Finalize Done
I> Binary spe loaded successfully at 0x82db00000
I> Active chain: 0
I> Partition name: A_dce-fw
I> Size of partition: 5242880
I> Binary@ device:3/0 block-44800 (partition size: 0x500000), name: A_dce-fw
I> rce: Authentication Finalize Done
I> Binary rce loaded successfully at 0x82d800000
I> Successfully register RCE FW context save task with MB2 loader
I> dce : oem authentication of header done
I> dce : meta-blob integrity check is success.
I> dce : will be decompressed at 0x836000000
I> version 1 Bin 1 BCheckSum 0 content_size 0 Content ChkSum 1 reserved_00 0
I> Reserved10 0 BlockMaxSize 5 Reserved11 0
I> dce : decompressed to 9532896 bytes
I> dce: plain binary integrity check is success
I> Active chain: 0
I> Partition name: A_adsp-fw
I> Size of partition: 2097152
I> Binary@ device:3/0 block-58240 (partition size: 0x200000), name: A_adsp-fw
I> dce: Authentication Finalize Done
I> Binary dce loaded successfully at 0x836000000
I> Active chain: 0
I> Partition name: A_xusb-fw
I> Size of partition: 262144
I> Binary@ device:3/0 block-9472 (partition size: 0x40000), name: A_xusb-fw
I> ape: Authentication Finalize Done
I> Binary ape loaded successfully at 0x82e400000
I> Successfully register APE FW context save task with MB2 loader
I> xusb: Authentication Finalize Done
I> Binary xusb loaded successfully at 0x82dc00000
I> Successfully register XUSB FW context save task with MB2 loader
I> Task: Carveout setup (0x500214d0)
I> Program remaining OEM carveouts
I> Task: Enable FSITHERM (0x500183cc)
I> Task: Enable FSI VMON (0x50017ec8)
I> FSI VMON: FSI Vmon re-calibration and fine tuning done
I> Task: Validate FSI Therm readings (0x50017fac)
I> FSITHERM max temp = 28
I> FSITHERM min temp = 27
I> Task: Restore XUSB sec (0x50001ef4)
I> Task: Enable FSI SE clock (0x500189a4)
I> Enable FSI-SE clock and 10ms delay...
I> Task: Initialize SBSA UART CAR (0x50002118)
I> Task: Initialize CPUBL Params (0x50019990)
I> CPUBL-params @ 0x832000000
I> Task: Ratchet update (0x50029e88)
W> Skip ratchet update - OPTIN fuse not set
I> Task: Prepare eeprom data (0x5001975c)
I> Task: Revoke PKC fuse (0x50001d40)
I> PKC revoke fuse burn not requested
I> Task: FSI padctl context save (0x5001b558)
I> Task: Unpowergate APE (0x5001910c)
W> mb2_unpowergate_ape: skip! APE is in unpowergated state
I> Task: OEM firewalls (0x500259e4)
I> OEM firewalls configured
I> Task: Powergate APE (0x50019280)
I> Powergating APE
I> Powergate done
I> Task: OEM firewall restore saved settings (0x50025e38)
I> Task: Unhalt AUXPs (0x50028bf4)
I> Unhalting SPE..
I> Enabling combined UART
▒▒▒▒spe: early_init
▒▒▒▒vic initialized
▒▒▒▒tsc initialized
▒▒▒▒aon lic initialized
▒▒▒▒spe: tag is 5243985d1b1eb3f06fac6d36bd7e74ac
▒▒▒▒spe: SafeRTOS v8.4
▒▒▒▒spe: init
▒▒▒▒scheduler initialized
▒▒▒▒aon hsp initialized
▒▒▒▒tag initialized
▒▒▒▒tcu initialized
▒▒▒▒bpmp ipc initialized
▒▒▒▒spe: late init
▒▒▒▒cpu_nic clock initialized
▒▒▒▒apb clock initialized
▒▒▒▒pm initialized
▒▒▒▒bpmp hsp initialized
▒▒▒▒top1 hsp initialized
▒▒▒▒ccplex ipc initialized
▒▒▒▒spe: start scheduler
I> Task: Trigger mailbox for PSC-BL1 exit (0x500185c8)
I> Sending opcode 0x4d420802 to psc
▒▒INFO: Entering psc_monitor_init!
INFO: GSC22 BOM:0x848002000 SIZE:0x1000000 CLIENT_ACCESS1:00180000
INFO: PSCFW BUILD VERSION: 8a33b23-73b589c-8a15f76-rel-t234
INFO: mstatus:0xa00000808
INFO: Supervisor entry_point:c108c00
▒▒I> Received ACK from psc
I> Tas▒▒INFO: MONITOR: user task addr:0x848022000, blob offset:0x00020000
INFO: MONITOR: populated user images:13
INFO: mret to Supervisor!
INFO: psc supervisor init.
INFO: psc_irq_init...
INFO: enter idle task.
hwwdt_init: WDT boot cfg 0x710010 sts 0x10
bpmp: socket 0
bpmp: base binary md5 is da583751bbfe2b7f6e204562d97ff39e
bpmp: combined binary md5 is 39f77b2baaf3f0522607569dd3ae9a48
bpmp: firmware tag is 39f77b2baaf3f0522607-da583751bbf
Control register check for CBB_CENTRAL_CBB_FIREWALL_MCB_BLF failed, expected value: 80030000 != actual value: 00000000 address: 13a159d0
Write control check for CBB_CENTRAL_CBB_FIREWALL_MCB_BLF failed, expected value: 0f18000b != actual value: 00000000 address: 13a159c8
initialized vwdt
initialized mail_early
initialized fuse
initialized vfrel
initialized adc
fmon_populate_monitors: found 199 monitors
initialized fmon
initialized mc
initialized reset
initialized uphy_early
initialized emc_early
initialized pm
465 clocks registered
initialized clk_mach
initialized clk_cal_early
initialized clk_mach_early_config
initialized io_dpd
initialized soctherm
initialized regime
initialized i2c
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
initialized vrmon
initialized regulator
▒▒k: Start secure NOR provision (0x5001b7f4)
I> Task: Load FSI keyblob (0x500189ec)
I> Skipping FSI key blob copy
I> ▒▒initialized avfs_clk_platform
initialized powergate
▒▒Task: Unhalt AUXPs (0x50028bfc)
I> SCE unhalt skipped
I> Unhalting RCE
I> RCE unhalt s▒▒initialized dvs
initialized clk_mach_config
initialized suspend
initialized strap
initialized mce_dbell
▒▒uccessful
I> DCE unhalt successful
▒▒[ 2.639377] Camera-FW on t234-rce-safe started
▒▒I> APE unhalt skipped
I> FSI unhalt skipped▒▒TCU early console enabled.
I> Task: Load CPUBL (0x50019ab4)
I> Task: Load TOS (0x5001a244)
I> Active chain: 0
I> Partition name: A_cpu-bootloader
I> Size of partition: 3670016
I> Binary@ device:3/0 block-24832 (partition size: ▒▒initialized emc
initialized emc_mrq
▒▒0x380000), name: A_cpu-bootloader
▒▒I> cpubl : o▒▒initialized clk_cal
initialized uphy_dt
initialized uphy_mrq
HSIO UPHY reset has been de-asserted 0x0
▒▒em aut▒▒initialized uphy
▒▒hentication of header done▒▒initialized pg_late
initialized pg_mrq_init
swdtimer_init: reg polling start w period 47 ms
initialized swdtimer
initialized hwwdt_late
initialized bwmgr
initialized thermal_host_trip
initialized thermal_mrq
initialized oc_mrq
initialized reset_mrq
initialized mail_mrq
initialized fmon_mrq
initialized clk_mrq
initialized avfs_mrq
initialized i2c_mrq
initialized tag_mrq
initialized bwmgr_mrq
initialized console_mrq
missing prod DT calibration data for 199 fmons
initialized clk_sync_fmon_post
I> cpubl : meta-blob integrity check is success.
▒▒initialized clk_cal_late
initialized noc_late
initialized cvc
▒▒I> cpubl : will be decompressed at 0x82ce00000
I> ver▒▒initialized avfs_clk_mach_post
initialized avfs_clk_platform_post
initialized cvc_late
initialized rm
initialized console_late
handling unreferenced clks
enable can1_core
enable can1_host
enable can2_core
enable can2_host
enable pwm3
enable mss_encrypt
enable maud
enable pllg_ref
enable dsi_core
enable aza_2xbit
enable pllc4_muxed
enable sdmmc4_axicif
enable xusb_ss
enable xusb_fs
enable xusb_falcon
enable xusb_core_mux
enable dsi_lp
enable sdmmc_legacy_tm
initialized clk_mach_post
initialized pg_post
initialized regulator_post
initialized profile
initializ▒▒[ 2.801294] Camera-FW on t234-rce-safe ready SHA1=07158d6a (crt 12.976 ms,▒▒ed mrq
initialized patrol_scrubber
initialized cactmon
initialized extras_post
bpmp: init complete
▒▒ total boot 175.951 ms)
▒▒sion 1 Bin 1 BCheckSum 0 content_size 0 Content ChkSum 1 reserved_00 0
I> cpubl : decompressed to 3416192 bytes
I> cpubl: plain binary integrity check is success
I> Active chain: 0
I> Partition name: A_secure-os
I> Size of partition: 4194304
I> Binary@ device:3/0 block-32000 (partition size: 0x400000), name: A_secure-os
I> cpubl_params: nsdram: carveout: 1, encryption: 1
I> NSDRAM carveout base: 0x80000000, size: 0x7ad370000
I> cpubl: Authentication Finalize Done
I> Binary cpubl loaded successfully at 0x82ce00000
I> tos: Authentication Finalize Done
I> Binary tos loaded successfully at 0x83fdc7000
I> Relocating OP-TEE dtb from: 0x83fefec50 to 0x83c000860, size: 0x2886
I> [0] START: 0x80000000, SIZE: 0x7ad370000
I> [1] START: 0x832000000, SIZE: 0x2000000
I> Setting NS memory ranges to OP-TEE dtb finished.
I> Active chain: 0
I> Partition name: A_eks
I> Binary@ device:3/0 block-44288 (partition size: 0x40000), name: A_eks
I> eks: Authentication Finalize Done
I> Binary eks loaded successfully at 0x82e800400
I> EKB detected (length: 0x410) @ VA:0x82e800400
I> Task: Prepare TOS params (0x5001a1bc)
I> Setting EKB blob info to OPTEE dtb finished.
I> Setting OPTEE arg3: 0x83c000860
I> Task: OEM SC7 context save (0x5001b654)
I> OEM sc7 context saved
I> Task: Disable MSS perf stats (0x50028c88)
I> Task: Program display sticky bits (0x50028c04)
I> Task: Storage device deinit (0x500020bc)
I> Task: SMMU init (0x500183f8)
I> Task: Program GICv3 registers (0x50028d28)
I> Task: Audit firewall settings (0x50025c38)
I> Task: Bootchain failure check (0x500025dc)
I> Current Boot-Chain Slot: 0
I> BR-BCT Boot-Chain is 0, and status is 1. Set UPDATE_BRBCT bit to 0
▒▒DCE: FW Boot Done
▒▒I> MB2 finished
▒▒NOTICE: BL31: v2.6(release):5e1f8b33d
NOTICE: BL31: Built : 01:34:51, Mar 4 2025
I/TC: Physical secure memory base 0x83c040000 size 0x3fc0000
I/TC:
I/TC: Non-secure external DT found
I/TC: OP-TEE version: 3.22 (gcc version 9.3.0 (Buildroot 2020.08)) #2 Tue Mar 4 09:47:00 UTC 2025 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: Test OEM keys are being used. This is insecure for shipping products!
I/TC: Primary CPU switching to normal world boot
Jetson UEFI firmware (version 6.1-39721438 built on 2025-03-04T09:36:16+00:00)
▒▒I/TC: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
I/TC: WARNING: Test UEFI variable auth key is being used !
I/TC: WARNING: UEFI variable protection is not fully enabled !
▒▒E/TC:?? 00 get_rpc_alloc_res:645 RPC allocation failed. Non-secure world result: ret=0xffff0000 ret_origin=0
E/LD: init_elf:486 sys_open_ta_bin(bc50d971-d4c9-42c4-82cb-343fb7f37896)
E/TC:?? 00 ldelf_init_with_ldelf:131 ldelf failed with res: 0xffff000c
▒'▒▒0#▒▒3▒'▒▒▒$▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒ꪢ▒▒▒2)▒▒▒!V ▒I▒▒▒s▒▒▒ T)▒/▒▒k▒▒0▒▒▒f▒▒0▒▒U▒ ▒▒▒▒I▒V▒▒▒▒▒1 ▒▒▒▒I ▒/▒▒▒▒▒▒յU.+2▒▒▒.K▒+ ▒/s-▒*▒
2▒▒▒▒4▒ʠ͵V$▒*▒▒▒,▒▒5▒▒▒▒4+-▒▒U2▒▒▒K▒%J▒F5▒ൖ▒$ ▒▒▒▒.J▒▒!K/▒
▒2▒)▒▒▒▒"▒▒▒)▒▒▒T !C-U▒▒F5▒▒%)K▒▒▒▒▒▒▒i▒.)▒)▒▒$&▒-▒▒
,▒▒▒ɫ!▒▒$V▒▒0▒▒▒?▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒0喣,#5000▒00▒8▒0"4▒▒ .00▒ ▒▒ +▒▒/▒▒▒.▒▒▒ ▒▒%▒▒▒▒▒▒▒▒; .00▒ ▒/K▒▒▒
▒r▒▒4.$?V!▒▒-▒▒▒▒22.▒▒▒▒▒r5,▒r5▒▒▒)▒ ▒!6(▒-T)▒▒/k▒▒
2▒汁▒▒00V▒▒▒+ U,11▒81▒F ▒k▒ .00▒▒▒&▒:▒j/▒▒6!▒▒*▒▒▒▒8000,▒:▒▒▒1c-▒ 0▒00=/▒ "4▒▒0000,▒000-▒ 0▒00=▒#▒▒▒▒▒骢▒▒▒ ▒ʁ*▒b/%▒▒K▒ .00▒▒2)%J ▒▒▒ ▒▒"+▒▒▒ 0▒00=%J:2▒▒▒82▒▒▒8▒▒▒▒82&▒00▒▒▒▒3▒82600▒j!▒▒08&$
▒8▒&▒08&▒¡82▒81
7▒8▒j▒▒%f▒0▒▒V▒8-▒ 0▒00=▒.z-#▒')▒▒▒▒▒ .00▒▒▒2▒ V▒▒▒▒▒&43▒T ▒▒▒80008&▒¡8▒▒80008&▒¡▒▒▒ .00▒ V▒▒▒"▒▒▒▒N▒$▒▒"▒▒!▒j/▒ ▒▒!000000▒000▒▒▒▒▒▒▒Ԫ .00▒▒▒▒▒%f%▒j:)▒▒!▒▒-!K"▒)3▒V▒▒+-▒▒K▒ .00▒ ▒▒▒*3ת .00▒ j! ▒ץ▒80000000▒▒0000&2&2&▒-▒ 0▒00= ▒▒& ▒▒▒-▒ 0▒00= ▒▒+, ▒▒
0000▒0000-8000▒6&2&2▒▒ .00▒▒▒
"▒▒▒ 3
2▒ɥ#▒▒*-▒ 0▒00=▒2▒j/▒ ▒* ▒*▒▒ .00▒ ▒* :▒▒
000008000-800002&2&2▒▒ .00▒ ▒* :▒▒
00000&2%0▒▒0000&2&2&▒-▒ 0▒00= ▒▒ 0▒▒
0000▒0000-8000▒▒▒62▒-▒ 0▒00= ▒▒ 0▒▒
00000▒570-8000▒▒▒"2▒-▒ 0▒00= ▒▒ 0▒▒
00000▒7#0-80008f#3&2▒▒ .00▒ ▒* :▒▒
0000020▒▒00002▒&2▒-▒ 0▒00= ▒▒ 0▒▒
000002"0▒▒00002▒&2&▒-▒ 0▒00= ▒▒ 0▒▒
000002▒10▒▒00002▒12&▒-▒ 0▒00= ▒▒ 0▒▒
00000300▒▒0000▒f&2&▒-▒ 0▒00=)▒k▒▒V▒▒ ▒* ▒ץ▒80000000▒▒0000▒f&2&▒-▒ 0▒00=/▒▒* ,▒▒ ▒▒+,1▒▒▒▒▒5▒
)▒▒%▒▒*▒▒ .00▒▒▒▒▒ 0▒▒▒▒+,2F ▒*3)▒ͅ
)▒▒%▒▒*▒▒ .00▒ ▒▒:0▒▒ɣ▒▒)▒▒▒▒&▒-$s-▒ 0▒00=▒6)▒6)▒▒ *▒▒"▒▒▒▒▒!V▒▒ .00▒ ▒▒:▒▒▒3
2▒6)6.▒s#K/▒▒▒▒ .00▒ ▒▒:4V3+$▒▒▒▒▒▒▒▒▒▒ɉ-▒ 0▒00=▒6)▒▒▒,▒▒▒▒+.K/▒▒.֪ .00▒ %6▒Ӡj▒"▒"▒& ▒*▒▒5▒▒▒22▒2▒&48▒▒▒▒-▒ 0▒00=▒▒▒D%▒▒▒▒h▒/▒5-▒ 0▒00=#5▒
▒▒▒▒ *▒▒":▒▒▒3+-▒:▒F%#5)▒I▒▒j▒ .00▒▒5▒
▒▒▒▒ *▒▒":▒ɫ!▒▒▒▒▒F▒´r▒▒▒K▒ .00▒▒5▒
▒▒▒▒▒U2▒▒▒*
"▒▒▒▒z▒T$/▒▒▒3▒K▒ .00▒▒5▒
▒▒▒▒ *▒▒":▒▒▒b ▒*
"▒▒▒▒▒▒▒K▒ .00▒▒5▒
▒▒▒▒ *▒▒":3▒D▒j6k▒ .00▒▒5▒
▒▒▒▒ *▒▒":3▒D▒j"▒K▒ .00▒▒,+2▒K▒▒:▒▒▒)▒▒▒▒b▒▒j▒ .00▒ T)▒1▒▒▒▒F3▒뉊▒ˠ▒▒▒)▒/▒ {▒,▒▒▒:▒▒4▒▒ .00▒▒U2▒▒▒▒▒I ▒/▒2▒▒▒▒▒3▒3j"▒k4▒5▒3¶▒3▒t0▒▒▒▒▒Ѳ▒33˰▒%4▒▒▒▒+▒4▒▒▒▒4˴T0Ŭ20▒▒▒▒4ˡ▒▒▒▒0▒▒▒▒4▒0▒▒▒!V▒ġ6.!C▒▒▒▒H%&4/▒+0 ▒s)r▒▒▒0▒ͥD▒▒"▒-▒ 0▒00=▒r4▒▒#▒▒3▒
"▒%і▒▒ ▒9▒0▒▒*2▒Ơ6▒▒▒& ▒▒▒,▒▒)▒▒▒ 0▒00=)▒*▒#▒▒3▒
"▒%і▒▒ ▒▒5▒▒*21Ơ▒▒76▒▒▒,▒▒)▒▒▒ 0▒00=▒j▒5{▒▒▒:3
▒▒/2,▒
0!▒▒▒&b ▒▒▒/2-▒ 0▒00=▒▒▒!V▒▒4▒▒0%▒▒
00000%2%0▒▒0000&2%0▒ ▒▒-▒-▒ 0▒00=▒j/▒:▒▒6▒&▒▒&34▒+!
)▒▒%▒8˶▒▒▒b▒▒b▒7+▒#!
,7▒▒▒▒!▒▒6+)▒c▒▒▒▒6,▒V2▒▒▒%f%b f▒4[▒ԡ▒i%f%J-▒ 0▒00=3դ ݈▒r=▒,/F%ְ́+▒▒U#▒=,#▒▒8▒▒*▒▒▒ .00▒ 650V▒▒K"▒▒▒▒▒▒,▒T▒▒▒j%ш▒▒▒▒ 0▒00=▒T:)65%+.4▒▒▒%▒▒%r-▒ 0▒00=▒T:)65▒▒4▒#K▒#▒&▒-.▒#▒ֲ▒ { ▒#▒)▒=▒▒ .00▒▒▒-/▒▒▒▒▒▒/▒▒5 65%▒▒%r-▒ 0▒00=)V▒▒▒▒▒/▒▒5 65%▒▒%r-▒ 0▒00=)▒▒▒▒▒▒▒▒/▒▒5 65%▒▒%r-▒ 0▒00=▒T:▒T▒▒T▒▒"
▒+▒▒▒▒%▒▒▒▒r▒▒k%Ѥb▒▒Ͳ▒▒J▒▒-▒ 0▒00=▒T:!R▒F)▒▒z▒▒▒ z2▒T?
▒1c ▒#▒)▒=-▒ 0▒00=.▒)36c ▒)36c ▒
,▒▒"▒▒l:▒▒ .00▒▒J#▒:▒▒▒▒▒3▒ѥ▒▒)#K▒▒▒▒▒▒ .00▒▒J#▒:9▒▒▒▒▒▒.+▒▒ .00▒▒J#▒:0%▒r▒"▒▒▒▒▒.+▒▒ .00▒▒J#▒:▒͓)T▒ɨ3▒▒▒*▒V▒▒ɳ▒▒▒k▒ .00▒▒J#▒:10▒▒▒▒.+▒▒ .00▒▒J#▒:#5:▒Ց▒"▒F▒▒▒/100▒:▒▒080000&0-▒ 0▒00=▒▒▒-$/+2▒▒▒6֠▒괰▒ ▒h%g0,▒k▒▒▒▒ .00▒▒J#▒-▒▒*▒▒
00▒10▒▒0▒12&▒,3▒g0:▒▒-▒ 0▒00=!6▒▒▒I:#▒▒▒I▒▒ V.▒▒!▒.V-▒(▒▒▒K▒ .00▒▒į▒▒▒6%!6▒▒▒▒▒▒I:▒▒▒ 82&2&2&2&2▒▒▒▒#▒▒ ▒▒▒▒0▒,▒▒)b▒▒▒ ▒▒0▒▒4▒֪ .00▒▒6▒"▒į▒:5▒▒!▒-▒V▒▒▒▒▒3▒3▒▒!3%+▒ ▒90▒▒18▒֪ .0▒▒▒▒▒Ҡ▒▒▒k▒ *▒▒ 88V-▒ 0▒0▒=0▒.[:▒▒▒;▒9=%▒▒%j▒ .08▒▒▒▒▒▒▒b▒ ▒▒▒)▒")▒
▒+▒▒T▒▒"▒▒)▒▒▒I ▒▒▒r▒.▒▒▒▒ ▒
3(▒▒1V0▒▒▒ 0▒0▒=▒▒▒8▒2▒c43v6▒▒:▒▒▒▒▒▒ʝ▒▒ 0▒1▒֠▒▒▒k▒▒%▒3▒)▒K!▒▒▒j▒ .0▒▒=▒▒:▒▒▒▒▒▒25▒K▒ .0▒▒▒V▒▒
"▒%і▒▒ ▒▒f ▒F%▒▒c▒▒4▒8▒▒▒,▒▒)▒▒▒ 0▒3=▒▒ѯ▒k▒#▒▒3▒
"▒%і▒▒ ▒▒f ▒F%▒▒c▒▒4▒8▒▒▒,▒▒)▒▒▒ 0▒3▒ 65▒▒▒▒▒,365▒▒▒.
▒▒▒K▒ .▒▒▒ ▒.'▒r/V▒j0ˠ$*▒;
"▒)▒▒J▒▒▒▒▒▒▒▒▒ ▒K,j▒ .▒▒6▒ ▒3▒▒ ▒▒Ҡ▒▒▒▒▒i+{▒▒▒//▒▒?z▒▒:▒▒▒56▒▒M▒▒▒I▒b▒U2▒▒▒ů▒▒▒▒▒{▒▒{$▒/▒▒▒▒▒▒▒▒▒▒F▒▒z.K▒▒▒3/▒/▒3▒▒▒2z▒▒▒b-▒▒▒鲲F-▒▒▒▒k▒;▒▒▒▒-▒ 0▒37=$ T)▒▒▒I U,12▒1:▒:f-▒ 0▒5▒▒ +' V▒▒▒!1▒U:0$#50▒30▒▒0▒3▒▒ .▒▒▒=▒j!▒▒!▒%▒▒)▒%J▒V2K▒▒▒▒ .0▒▒▒▒0"▒▒J▒5▒V▒▒
▒▒▒.▒K▒ .▒▒5▒ *▒▒" )4▒▒h▒/▒▒-▒ 0▒V▒▒▒J#▒:#▒:▒Ց▒"▒F▒▒▒/110▒:▒▒080000&+00-▒ 0▒V▒=#▒:▒▒+$▒/▒H90▒▒000▒▒0▒8▒0"4▒▒ .6▒▒▒ *▒▒" )4▒▒h▒/▒5֪ .6▒8▒J#▒:#5▒ z5▒▒"▒F▒▒▒/120▒:▒▒080000▒▒00-▒ 0▒▒▒▒5▒ ▒/+$▒/▒H90▒▒000▒00;8▒0"4▒▒ .9v0=▒▒▒D%▒▒▒▒h▒/▒▒֪ .9v1=▒▒▒:#▒▒ z5▒▒"▒F▒▒▒/130▒:▒▒080000▒▒00-▒ 0▒N7F=#▒▒ ▒/+$▒/▒H90▒▒000▒▒0;8▒0"4▒▒ ▒▒6▒=▒▒▒D%▒▒▒▒h▒/▒5k▒ ▒▒F0=▒▒▒:#5▒ z5▒▒"▒F▒▒▒/200▒:▒▒080000▒▒00-▒ 0▒64V=#5▒ ▒/+$▒/▒H90▒▒000000;8▒0"4▒▒ ▒5▒▒ *▒▒" )4▒▒h▒/▒▒k▒ ▒58▒J#▒:#▒▒ z5▒▒"▒F▒▒▒/210▒:▒▒080000▒▒00-▒ 0▒M1▒▒▒▒ ▒/+$▒/▒H90▒▒000010;8▒0"4▒▒ ▒▒3=▒▒▒D%▒▒▒▒h▒/▒5k▒ ▒▒▒=▒▒▒:#5▒ z5▒▒"▒F▒▒▒/220▒:▒▒080000▒▒00-▒ 0űF▒▒5▒ ▒/+$▒/▒H90▒▒000020;8▒0"4▒▒ .▒▒▒ *▒▒" )4▒▒h▒/▒▒k▒ .▒ö▒J#▒:#▒▒ z5▒▒"▒F▒▒▒/230▒:▒▒080000▒
00-▒ 0▒
6▒▒▒▒ ▒/+$▒/▒H90▒▒000030;8▒0"4▒▒ .0▒▒▒▒0"▒B45▒ ▒*,8#▒֪ .▒▒▒▒▒0▒ш▒▒80▒▒▒D)
▒"▒▒ .▒▒▒▒5▒
▒▒▒▒ *▒▒":0▒▒▒▒%▒4▒6 ▒+▒▒ .▒▒▒▒5▒
▒▒▒▒ *▒▒":▒V▒▒▒j▒▒F▒▒▒K▒ .▒▒▒▒5▒
▒▒▒▒ *▒▒":▒V2▒4▒6▒▒I▒▒▒▒ .▒▒▒▒5▒
▒▒▒▒ *▒▒":3֢▒%▒▒▒▒k▒ .▒▒▒▒5▒
▒▒▒▒ *▒▒":▒▒빮▒0▒▒▒4▒▒!K/▒K▒ .▒▒▒▒5▒
▒▒▒▒ *▒▒":▒3%▒r▒▒▒V0/F-▒ 0▒
76=#5▒
▒▒▒▒ *▒▒":▒▒▒#▒#▒ȁ{ C%▒ծѲ▒▒ɉ z2▒▒▒▒I%▒▒▒ .▒▒▒▒5▒
▒▒▒▒ *▒▒":#63)͓▒D▒▒֪ .▒▒▒▒5▒
▒▒▒▒ *▒▒":3▒T▒▒▒ 3{▒▒▒▒▒▒▒▒▒6▒▒-▒ 0Ɇ1▒▒▒D▒j"▒▒▒▒!K/▒J▒"▒▒▒▒▒▒ /▒▒▒▒ 0ɣ▒▒=#5!▒#5▒
3
2+$!%▒K▒ .F▒õ *6k0▒:)▒K!▒W▒▒ .f5▒֠3▒%▒▒%j▒ .f▒▒▒į▒▒▒6%▒▒J▒▒▒▒▒:0&2&2&▒▒▒#▒▒ 82&2&2,▒▒)b▒▒▒▒▒▒▒▒7▒000▒֪ .f▒▒=▒▒% ▒▒
"▒%і▒▒ 4 ▒F%▒▒c▒▒▒▒ ▒▒▒,▒▒)▒▒▒ 0ɻ3▒=▒▒D2▒▒Ҡ▒▒▒▒▒ )▒▒,▒▒3+▒▒ .f73▒֢▒3▒▒0V▒r4▒▒ 0ɻ8▒=▒▒.K▒▒▒▒▒▒▒ ▒ʁ*▒b/%▒ѩ▒▒▒▒▒▒6▒k▒▒1▒8▒▒0{2▒k▒ .f▒1▒ ▒▒ V▒▒+▒" ▒э▒▒▒▒1k▒ .f▒▒▒ j!0V!▒▒▒%49▒▒'▒▒U2▒▒▒▒▒▒!{▒▒!▒▒▒▒▒֪ .f▒5▒ j!0V!▒▒▒%49▒▒'▒▒U2▒▒2▒▒▒▒▒▒z2!{▒▒!▒▒▒▒▒֪ .f▒▒=▒▒0V!▒▒▒%49▒▒'▒▒U2▒▒2▒▒▒& ▒▒▒▒!{▒▒!▒▒▒▒▒֪ .f▒▒=▒#)Ӡ▒▒▒▒▒ʝ▒▒▒▒▒▒3(J▒"▒J-▒ 0▒▒2▒=▒#)▒ ˰▒20▒5J4▒▒ú)3
▒▒)▒K!▒W$▒#)▒%▒▒%▒0▒▒▒-▒ 0▒˴▒=4▒▒!▒3▒:▒F%V$4▒▒!▒z▒▒▒ɧF%▒K▒:-▒ 0▒˴▒=4▒▒!▒3▒:▒F%V$4▒▒!▒z▒▒▒▒'▒+▒!▒▒▒/v-▒ 0▒▒4▒=4▒▒!▒3▒:▒F%V$4▒▒!▒z▒▒▒▒')▒4▒▒!▒z▒j▒ .v29=#▒▒▒▒▒▒▒▒I▒ɭr▒▒ .v2▒ ▒K▒
+▒▒▒ z5▒6"V▒▒▒!▒4▒▒▒▒▒Ѳ:▒F%6▒▒ .v2▒▒▒▒▒!▒▒▒/)▒K!▒V$▒с&7àr4▒▒֪ .v▒▒▒▒V▒▒ 0▒,▒
2$▒▒▒-▒ 0ɣ4=▒:▒▒F▒▒▒▒0▒B)▒:▒▒F▒▒k)0▒▒▒3▒▒▒ .v4▒▒ +' V▒▒▒.b%▒:▒F%V$▒▒ 0▒n▒▒=▒▒▒▒▒"▒▒ꁈ$V▒▒ 82&▒0▒▒100- 8610▒▒ .▒3˵▒▒▒0%▒▒▒▒$V▒▒ 82&▒0▒▒300- 8620▒▒ .▒▒▒▒▒▒▒0%▒▒▒▒$V▒▒ 82&▒0▒▒500- 8630▒▒ .▒▒▒▒▒▒▒0%▒▒▒▒$V▒▒ 82&▒0▒▒700- 8640▒▒ .▒▒▒▒▒▒▒0%▒▒▒▒$V▒▒ 82&▒0▒▒900- 8650▒▒ .▒▒▒▒▒▒▒0%▒▒▒▒$V▒▒ 82&▒0▒▒"00- 8&80▒▒ .▒▒▒▒▒▒▒0%▒▒▒▒$V▒▒ 82&▒0▒▒$00- 8&90▒▒ .▒▒▒▒▒▒▒0%▒▒▒▒$V▒▒ 82&▒0▒▒&00- 8&!0▒▒ .▒▒▒▒▒▒▒0%▒▒▒▒$V▒▒ 82&▒0▒100▒▒02$00-▒ 0▒n5▒=▒▒▒▒▒"▒▒ꁈ$V▒▒ 82&▒0▒1600▒▒0▒▒00-▒ 0▒n▒▒=▒▒▒▒▒"▒▒ꁈ$V▒▒ 82&▒0▒1V00▒▒0▒▒00-▒ 0▒n5▒=▒▒▒▒▒"▒▒ꁈ$V▒▒ 82&▒0▒1v00▒▒0▒▒00-▒ 0▒n5▒=▒▒▒▒▒"▒▒ꁈ$V▒▒ 82&▒0▒1▒00▒▒0▒▒00-▒ 0▒n▒▒=▒▒▒▒▒"▒▒ꁈ$V▒▒ 82&▒0▒1&00▒▒0▒▒00-▒ 0▒n5▒▒▒▒0%▒▒▒▒$V▒▒ 82&▒0▒1F00▒▒0▒▒00-▒ 0▒n▒▒▒▒▒0%▒▒▒▒$V▒▒ 82&▒0▒1f00▒▒0▒▒00-▒ 0▒n▒▒▒▒▒0%▒▒▒▒$V▒▒ 82&▒0▒▒00▒▒0▒▒00-▒ 0▒n6▒ ً▒▒▒▒▒00▒▒▒▒k3٥▒▒▒▒▒ .▒3▒▒▒▒▒2▒▒▒I2/3!V▒V4▒▒▒3-▒ 0Ɏ3▒=▒$00▒I▒,4ˡ▒▒4▒▒▒▒$00▒▒
=7,▒▒▒5=▒▒j▒▒&▒-▒ 1▒▒ ▒▒[:▒▒▒;▒▒▒▒▒r!▒%j▒ ▒▒7v▒ ▒*4▒▒:▒F%V$1▒J"▒▒▒鉁▒j!▒▒▒%0▒▒▒-▒ 1▒69▒ ▒*4▒▒:▒F%V$3▒0▒▒▒▒▒鉁▒j!▒▒▒%0▒▒▒-▒ 1▒▒▒ ▒*4▒▒:▒F%V$2▒▒▒▒▒鉁▒j!▒▒▒%0▒▒F=6"▒▒▒-դ▒V0▒▒▒ #▒▒k▒▒▒ ▒▒V5▒▒ ▒▒d"▒▒0▒▒ ▒ #▒▒k▒▒▒ ▒▒f▒&▒ ▒&▒d"▒▒0▒▒ ▒ #▒▒k▒▒▒ ▒▒f4▒▒ #▒▒&▒-▒▒▒V0▒▒▒ #▒▒k▒▒▒ ▒▒f▒▒▒ #▒▒&#▒6T3▒▒0▒▒ ▒ #▒▒k▒▒▒ ▒▒v4▒=▒▒▒:▒2▒c4▒▒(▒▒▒▒ ▒!ͅ+$-▒ 1▒˷▒=%+.c)▒b:▒▒%ѥ▒)▒K!▒W$▒+3)▒ -▒ 1▒63֠6▒▒V▒▒3+-)▒K!▒W▒▒ ▒▒▒9▒렛▒▒▒ V▒▒+▒" ▒)▒I▒▒$▒▒▒▒▒"▒-▒ 1ͮ▒▒=▒&▒▒I V▒▒+▒" ▒)▒I▒▒$▒▒▒ ▒Ԫ ▒.▒0▒▒▒▒▒▒▒ V▒▒+▒" ▒▒▒▒ K▒z▒0▒▒)▒I▒▒▒ ▒.▒▒ ▒.▒51▒ ▒▒▒I ▒▒03!)▒▒.1▒:▒F%V▒▒ ▒.▒▒▒▒ ▒▒▒I▒▒&▒!V +2▒▒▒▒-▒▒N▒▒▒-▒ 1і▒▒ 4▒į▒▒V0/F V▒▒+▒"-▒ 1▒F0▒=▒:▒▒#▒▒8 900݈#▒▒▒:▒▒#4)▒▒▒▒▒=1▒V▒▒ ▒.▒1▒ +'▒#▒▒8 900݈#▒▒▒:▒F%V$▒▒3▒,▒K▒ ▒.▒8▒▒ V▒▒+▒"▒2)
▒/%▒▒▒K▒ ▒.▒3˳ ▒▒▒▒▒*2&▒▒/▒-▒ 1▒▒9▒=!▒!▒▒ ▒ՠ▒5▒!6▒▒i▒▒%$▒▒▒▒▒▒▒▒鉮▒ ▒.▒▒▒ ĵ▒▒▒▒▒ ▒▒ ▒2֪ ▒.▒68▒ ▒▒ V▒▒+▒" ▒э▒▒▒▒▒-▒ 1ы3v="Չ▒▒騔 *▒▒ !▒▒▒▒D▒▒▒▒▒▒▒▒▒▒▒▒-▒ 1ѻ6▒ ĵ▒▒▒騔▒▒U4▒▒▒▒▒▒▒▒▒-▒ 1Ѳ▒▒ ĵ▒▒▒▒,6!▒▒U4▒▒▒▒▒▒▒▒▒-▒ 1▒7▒▒ ĵ▒▒▒▒▒▒U4▒▒▒▒▒▒▒▒▒-▒ 1▒N▒▒▒▒▒!▒ F#5#▒#+2▒▒▒T ▒)+2▒▒=6▒:▒▒▒{▒3▒▒▒6▒▒K▒ ▒.▒▒▒▒ 33▒▒▒k▒▒%▒3▒I-▒ 1▒
"▒%і▒▒▒▒2▒▒*20▒▒9▒▒▒▒▒ ▒.▒9▒▒ .:0▒)▒▒H▒"-▒ 1٫▒▒ ▒▒!$▒▒▒▒▒▒▒▒鉮▒ ▒.▒▒0▒ ▒▒ V▒▒+▒" ▒э▒▒▒▒▒▒ ▒.▒3▒▒▒▒)*.▒ ▒▒
"▒%і▒▒ f▒4▒▒*29▒▒▒5▒▒▒,▒▒)▒▒▒ 1▒n2▒ ▒▒+▒▒▒
"▒%і▒▒▒▒▒4▒▒*26▒f▒4▒▒▒,▒▒)▒▒▒ 1ݱ5▒ ▒F!ĩ▒%▒3▒
2▒=▒ ▒.▒3▒
"▒%і▒▒ ▒▒f ▒F%▒ ,14▒▒ ▒▒▒,▒▒)▒▒▒ 1▒
1▒=▒:▒3▒
"▒▒▒J▒▒%▒▒▒"▒▒%2▒1▒ ▒.▒▒3K-▒ 1▒F▒▒=5▒ ▒▒
"▒%і▒▒▒▒▒4▒▒*27▒M4▒8▒▒▒,▒▒)▒▒▒ 1▒7▒▒#▒▒▒%▒3▒
"▒%і▒▒▒▒▒4▒▒*27▒M4▒8▒▒▒,▒▒)▒▒▒ 1ݖ▒=▒▒:▒:▒F%V$0▒▒▒▒▒▒ ▒▒▒3▒=2#▒:▒F%V$▒▒"▒s)▒▒U44▒/F▒▒▒▒r-▒ 1▒˸=2#▒:▒F%V$5▒ ▒!▒/F▒▒▒▒r-▒ 1ݍ▒6=2#▒:▒F%V$▒ ▒!▒/F▒▒▒▒r-▒ 1▒-▒v=2#▒:▒F%V$▒ ▒f4Ţ▒5▒.▒▒▒!▒/F▒▒▒▒r-▒ 1ݫ6▒ ▒▒#▒0▒▒▒,▒2▒c46k▒ ▒▒▒▒▒▒ ▒▒▒▒▒▒▒h+▒▒33▒▒*▒3)▒▒▒▒▒.▒▒ 1▒3▒▒ ▒▒J▒)▒▒$▒j/▒:▒▒▒ժ ▒▒▒4▒=▒▒▒▒▒%Ѧ▒r!▒%▒сH-▒?▒▒3▒▒$▒▒▒,7▒▒▒I3!
)▒ĥ▒ ▒▒▒▒6=+k▒=)!▒▒ ▒▒▒:4 ▒▒֪ ▒▒▒6▒▒e-▒=▒▒▒:▒▒J#▒▒▒▒▒%і-▒ 1▒f▒▒=+k▒=▒▒H▒▒▒▒▒▒j5▒K/▒▒ 1▒▒6=+k▒=▒▒▒3+-▒:▒F%#5)▒I▒▒%▒▒%j▒ ▒▒3▒3=+k▒=▒J#)▒I▒▒4)▒▒ ▒▒4▒▒=+k▒=6▒▒▒ )▒K!▒W$▒▒3▒,▒K▒ ▒▒4▒▒=)▒K!▒V▒▒3+-4V3+$▒ʲ▒▒-▒ 1▒-▒V=▒ɕ▒▒%▒ K▒▒▒-?▒▒▒4▒▒/F%ֲ▒▒▒▒*▒▒▒ ▒▒▒▒▒=▒▒3▒▒ +▒▒/▒s0(▒/▒▒,▒▒▒▒ ▒▒-▒ 1▒0&=.▒:▒:▒F%▒▒4▒)▒/▒I▒U9▒▒j▒ ▒▒▒▒▒▒U9▒▒)▒/▒I V▒▒+▒"-▒ 1▒2▒▒U9▒▒)▒:▒▒ V▒▒+▒"-▒ 1▒▒36=.▒4J▒b▒▒▒▒▒▒:.▒6▒▒▒▒▒$▒▒▒ V▒▒+▒▒r.▒▒ 1▒63=.▒4b%▒▒▒▒▒▒▒)▒▒ ▒f4&▒▒▒ ▒▒▒$▒▒▒ V▒▒+▒▒r.▒▒ 1▒n4▒=.33$▒▒▒ ▒1▒;b▒▒:▒▒ϵ▒ 2▒9▒▒ ▒▒ V▒▒+▒" ▒э▒▒▒▒3-▒ 2▒l▒▒▒U9▒▒▒▒▒▒▒▒▒:▒F%V▒▒ 氷▒=▒▒▒▒▒▒▒▒ !6%'5▒▒:▒F%V▒▒ ▒0&8▒ į▒ ▒▒2▒4)▒r%▒#(4▒▒▒)+2▒▒▒▒▒.▒▒*$▒▒▒2▒▒▒▒ ▒3▒=▒▒6▒"5▒▒-*!b)▒▒:▒F%V▒▒ ▒F▒▒=▒▒6▒"5▒▒▒▒ V▒▒+▒"-▒ 2▒3▒ +'-▒▒&800▒k:▒k▒▒+▒.3▒ ▒▒/▒▒ ▒0▒9▒ +'-▒▒&!00▒k:▒k▒▒+▒.3▒ ▒▒/▒▒ 氣▒▒ +'-▒▒�▒k:▒k▒▒+▒.3▒ ▒▒/▒▒ ▒0▒▒▒=▒:▒-▒▒&&00▒k:▒k▒▒+▒.3▒ ▒▒/▒▒ ▒0▒4▒=%J&▒ ▒▒ʝ▒▒%J&Ԫ 氃▒▒=%J&▒ ▒▒▒T&*2!0▒▒%00,▒▒▒8▒▒▒ {▒,8▒▒ժ 氳▒▒=%J&▒▒▒*▒ͱ2▒003▒ ▒▒▒▒C=▒2▒▒*▒▒▒ ▒0▒▒▒▒2):▒$/▒ʝ▒"▒▒▒ ▒0▒6▒▒2):4V▒▒▒▒▒8▒::,3▒▒=F▒6▒:-▒ 2▒8▒=▒▒▒Ҡv)▒▒▒▒▒&▒▒3▒▒ *▒▒ 2▒8▒-▒ 2▒3▒▒ 0%J ;!&▒▒3▒▒ *▒▒▒▒ ▒1▒▒▒ +'?▒▒▒'▒ݤ▒:▒▒+▒▒)▒▒▒!K"▒▒▒▒▒ 汵4=▒:▒▒4▒▒▒▒▒▒▒)▒▒)▒j▒ ▒1▒▒ +'▒▒▒▒▒)▒▒)▒j▒ ▒1F▒▒=▒▒▒▒#)▒▒H▒"▒▒ ▒1▒▒▒=▒:▒-▒▒f00.▒▒▒6▒▒▒ V'/2▒▒ ▒3▒▒ ▒0V▒r▒▒ ▒V▒▒=▒:▒-▒▒▒4#▒▒▒▒%▒▒6%▒▒▒▒%▒ ▒1▒▒▒ +'-▒▒▒4#▒▒▒▒%▒▒%▒,-▒ 2ū7▒=▒:▒-▒▒▒4#▒▒▒▒%3
▒▒ V'0▒▒ 汋9▒▒V▒▒▒8V▒ū5 ▒)+2▒▒ɛ,)▒▒!▒▒%▒▒%j▒ ▒汫5▒=0▒.[:▒▒▒;▒9=%▒▒%j▒ ▒▒13▒▒▒▒▒֭1000▒▒▒:0▒▒2▒!V▒▒.J▒▒!K/▒▒K▒ ▒汰▒֠▒▒֭1000▒▒▒:▒▒▒2▒▒▒K▒ ▒汴▒=!֭֭1000▒▒▒:▒F▒*▒ ▒!ͅK/▒▒ 3ɰ▒▒▒▒▒֭1000▒▒▒:▒F▒* 4▒▒!K/▒▒ 3ɶ0=!֭֭1000▒▒▒:)▒F%4▒▒!K/▒▒ 3▒,▒▒=!֭֭1000▒▒▒:▒F▒
-▒▒▒)▒▒сL8▒:▒F%'▒5▒▒ ▒▒9▒=!֭֭1000▒▒▒:▒2▒▒.+8▒▒5 ▒3
▒j2/▒.▒▒ 3▒v▒▒▒▒▒֭1000▒▒▒:▒V0/F%▒▒▒▒i:00010-▒ 3▒F▒&=!֭֭1000▒▒▒:▒F▒*▒:4-▒4▒▒▒4-▒4)▒▒ ▒▒2▒▒▒=!֭֭1000▒▒▒:▒F▒*-▒ ▒-▒4)!- ▒-▒4▒-▒ 3▒ø▒=!֭֭1000▒▒▒▒0▒▒2▒!V▒▒.J▒▒!K/▒▒K▒ ▒沫5▒▒▒▒֭1000▒▒▒▒▒▒▒2▒▒▒K▒ ▒▒2▒▒▒▒▒▒֭1000▒▒▒▒▒F▒*▒ ▒!ͅK/▒▒ 3ɫ9▒=!֭֭1000▒▒▒▒▒F▒* 4▒▒!K/▒▒ 3ɋ▒▒▒▒▒֭1000▒▒▒▒)▒F%4▒▒!K/▒▒ 3ɳ▒▒=!֭֭1000▒▒▒▒▒F▒
-▒▒▒)▒▒сL8▒:▒F%'▒5▒▒ ▒▒24▒▒▒▒▒֭1000▒▒▒▒▒2▒▒.+8▒▒5 ▒3
▒j2/▒.▒▒ 3▒n3▒▒▒▒֭1000▒▒▒▒▒V0/F%▒▒▒▒i:00010-▒ 3▒0▒렲▒֭1000▒▒▒▒▒F▒*▒:4-▒4▒▒▒4-▒4)▒▒ ▒▒3▒▒▒▒▒▒֭1000▒▒▒▒▒F▒*-▒ ▒-▒4)!- ▒-▒4▒-▒ 3▒l▒▒▒▒▒֭8000▒▒▒:0▒▒2▒!V▒▒.J▒▒!K/▒▒K▒ ▒▒3▒▒▒▒▒֭8000▒▒▒:▒▒▒2▒▒▒K▒ ▒▒3V▒▒=!֭֭8000▒▒▒:▒F▒*▒ ▒!ͅK/▒▒ 3▒▒▒=!֭֭8000▒▒▒:▒F▒* 4▒▒!K/▒▒ 3▒f2▒▒▒▒֭8000▒▒▒:)▒F%4▒▒!K/▒▒ 3͋▒▒=!֭֭8000▒▒▒:▒F▒
-▒▒▒)▒▒сL8▒:▒F%'▒5▒▒ ▒▒3▒9&=!֭֭8000▒▒▒:▒2▒▒.+8▒▒5 ▒3
▒j2/▒.▒▒; ▒泻6▒▒▒▒֭8000▒▒▒:▒V0/F%▒▒▒▒i:00010-▒; ▒▒3▒▒▒▒▒▒֭8000▒▒▒:▒F▒*▒:4-▒4▒▒▒4-▒4)▒▒; ▒泃▒▒=!֭֭8000▒▒▒:▒F▒*-▒ ▒-▒4)!- ▒-▒4▒-▒; ▒▒▒2▒▒▒▒֭k▒▒▒r$1000ͫճ▒▒r$!ֿ֭▒r$0▒▒▒3▒▒▒; ▒▒3▒▒▒ +'?▒▒▒▒▒ +▒▒/▒1▒-,▒-▒▒▒▒▒▒-▒; ▒泵▒ +'?▒▒▒▒▒▒5C:)▒k▒; ▒▒402=.▒▒▒#▒▒*$▒▒▒▒K▒; ▒▒45÷ ▒.5▒+▒,▒s/
0▒▒▒T ▒)+2▒▒▒K▒; ▒▒1▒▒ ▒6:▒͊▒▒.%C%▒%▒▒▒▒$▒▒▒ z2▒▒8▒▒▒-▒▒▒▒▒▒; ▒▒95▒ ▒6:▒▒N▒B4▒▒ ▒▒
▒J▒▒2/▒▒▒K▒; ▒▒4V8▒▒▒0▒Ҡ▒+,▒
0▒00▒▒▒▒$▒▒▒-▒; ▒▒▒▒=▒0▒Ҡ▒э
▒▒▒▒▒)щ▒▒2/▒▒▒K▒; ▒洆▒▒▒▒▒▒▒+,▒
▒▒H)%C%▒%▒▒▒▒$▒▒▒-▒; ▒▒4▒▒▒▒▒▒▒▒Ѩ▒ ▒k21)щ▒▒2/▒▒▒K▒; ▒洃▒&=00▒r%▒#$▒▒▒ +▒▒/▒▒4▒K▒; ▒洫▒▒ 0 4$▒▒▒▒▒▒▒둍▒▒:▒F%V▒▒; ▒▒4▒1▒ 0 *&▒+▒▒-▒▒▒▒▒둍▒▒:▒F%V▒▒; ▒▒4▒8▒=00-▒▒▒▒▒▒▒▒둍▒▒:▒F%V▒▒; ▒洓▒▒=▒&▒▒I V▒▒+▒" ▒)▒I▒▒$▒▒▒ ▒▒▒-▒; ▒▒▒5▒=▒&▒▒I V▒▒+▒" ▒)▒I▒▒$▒▒▒▒▒▒K▒; ▒▒44▒▒▒▒▒▒▒ V▒▒+▒" ▒)▒I▒▒$▒▒▒▒8▒▒▒7▒▒; ▒▒1▒▒▒▒▒▒▒ V▒▒+▒" ▒)▒I▒▒$▒▒▒▒D▒%C%▒▒; ▒▒8▒=▒&▒▒I V▒▒+▒" ▒)▒I▒▒$▒▒▒ ▒▒0▒▒; ▒▒5▒v▒▒▒▒▒▒ V▒▒+▒" ▒)▒I▒▒$▒▒▒▒D▒▒▒▒-▒; ▒▒11֠▒▒▒▒ V▒▒+▒" ▒)▒I▒▒$▒▒▒ 5V▒▒; ▒▒7▒▒▒▒▒▒▒ V▒▒+▒" ▒)▒I▒▒$▒▒▒▒D▒▒▒-▒; ▒▒566▒=▒&▒▒I V▒▒+▒" ▒)▒I▒▒$▒▒▒▒▒▒-▒; ▒▒0▒▒▒▒?▒Ҡ▒"1ŧ▒ɝ▒▒▒▒▒/▒I ▒▒*▒▒)+▒▒; ▒▒f8▒▒▒▒-▒▒/▒
▒▒ ▒4z▒▒▒)+▒▒; ▒▒5▒▒▒▒▒▒-▒4z▒▒/▒
▒r%▒#0▒3/▒ ▒)+▒▒; ▒▒5ñ▒=▒:▒-▒&▒f100▒J▒$J▒▒▒굫▒▒▒▒ -▒; ▒浣▒&=▒&▒▒I V▒▒+▒" ▒)▒I▒▒$▒▒▒▒
▒▒; ▒▒5▒▒&=▒&▒▒I V▒▒+▒" ▒)▒I▒▒$▒▒▒▒▒▒▒{▒▒j▒; ▒▒5▒8=▒▒V▒▒:▒▒2▒▒V *▒▒ ▒▒빦▒!▒▒▒▒▒; ▒浣0▒▒▒▒▒▒ V▒▒+▒" ▒)▒I▒▒$▒▒▒ ▒▒▒; ▒▒522▒ +'?F##00.F#▒:▒F%V$▒2▒; ▒▒581=▒:▒?F##00.F#▒▒▒▒▒3+-#▒▒ {▒▒▒-▒▒0:0'15,▒▒; ▒浶õ +'?F##00.F#▒:▒▒▒+2▒▒V!▒K▒#▒▒-▒; ▒▒6▒▒▒▒▒/*6%і▒$▒▒▒-▒; ▒▒6▒1=▒:▒▒▒▒600▒6:!")▒▒▒굫▒▒▒▒▒-▒; ▒▒4&▒ +'▒▒#F00▒ɤ▒$J▒▒▒굫▒▒▒▒▒-▒; ▒▒64▒=▒:▒▒▒▒800▒6:!")▒▒▒굫▒▒▒▒▒-▒; ▒▒6f▒▒ +'▒▒▒900▒6:!")▒▒▒굫▒▒▒▒▒-▒; ▒▒&9▒ +'▒▒▒#00▒6:!")▒▒▒굫▒▒▒▒▒-▒; ▒涖1▒ +'▒▒#V00▒ɤ▒$J▒▒▒굫▒▒▒▒▒-▒; ▒▒6▒▒▒ +'▒▒▒%00▒6:!")▒▒▒굫▒▒▒▒▒-▒; ▒涋5▒=▒:▒▒▒▒"00▒6:!")▒▒▒굫▒▒▒▒▒-▒; ▒▒6▒0▒ ▒03:▒▒ ▒▒▒6%+K▒▒-▒; ▒▒6▒8▒ ▒03:+K▒▒ ▒▒▒6%▒:▒F%V▒▒; ▒涋▒6=0▒,J▒▒ ▒▒▒ ▒͔0▒▒▒:▒F%V▒▒; ▒涻0▒ ▒▒'▒▒▒▒
)▒▒▒V▒+303'▒▒▒; ▒▒62˰ ▒▒'▒▒0▒/03▒)▒▒сI▒▒-&-▒; ▒▒69˳ *▒▒▒▒▒:▒▒%▒▒▒▒▒▒▒▒▒K▒; ▒▒4▒▒ *▒▒▒▒▒:▒▒c:4▒氥▒c ▒2▒▒▒,▒ʥK!▒V$▒▒*▒b V$▒s▒▒K▒; ▒▒7▒▒=3B▒▒5V J▒ш▒▒F▒▒.▒/▒I▒▒+2
▒$▒▒▒-▒; ▒▒25=3B▒▒▒N▒B4▒
▒▒&%▒6▒▒▒; ▒▒7▒=▒▒▒3▒▒▒r▒▒▒c▒▒▒▒▒2)▒I▒▒$▒▒▒-▒; ▒▒76▒6=3B▒▒,3-3B▒▒▒4z▒▒ȑ/$▒▒▒ ▒▒I-▒; ▒▒3▒=3B▒▒+'▒F600▒B▒▒!")▒▒▒굫▒▒▒▒ ▒▒; ▒▒▒▒=▒▒4:▒▒)Ҡ▒=▒▒163:06 V▒▒▒=0000▒▒▒; ▒▒7▒▒▒ +'-- -:▒▒▒!V:▒▒▒"&▒▒f▒▒2▒▒▒▒▒v▒"d-▒; ▒淣7▒=.▒▒▒V1▒▒▒ ٓ3▒r▒▒)▒ ▒▒▒; ▒▒7▒0▒ ٓ▒▒V1▒▒▒ ٓ3▒▒▒▒V60▒-▒; ▒淣▒▒=.▒▒ְV▒▒▒▒▒V▒▒▒:▒F%V$▒2▒; ▒▒7▒▒▒ ٓ▒▒V1▒▒▒ ٓ3▒V10▒▒▒3▒▒▒?D%T'▒▒▒▒▒▒▒-▒; s9▒1=▒▒▒7▒▒%+.▒ ▒)+2▒▒ ▒▒▒▒▒; s▒2v▒▒▒▒▒▒ V▒▒+▒" ▒)▒I▒▒$▒▒▒▒▒"▒j▒; s▒▒▒▒▒▒"▒Ҡ▒"▒▒▒▒ $▒▒▒-▒; s968▒=▒:▒-%$000▒T:!")▒▒▒굫▒▒▒▒▒▒▒; s▒▒▒ %▒T▒▒▒#▒▒▒▒ʥӳ9▒▒
▒▒#▒▒▒▒F!+▒8=▒▒#▒˰;▒-▒; s9▒2v=▒:▒▒F▒/▒000▒▒!")▒▒▒굫▒▒▒▒ k▒; s9▒2▒=▒T:▒T▒▒▒▒᳢?▒,▒▒▒I▒▒4▒▒▒▒ ▒4▒▒▒▒▒
▒▒▒i z2-:;▒▒-▒; s▒▒5▒=▒000▒▒▒3:0▒"-▒; s▒▒▒▒ %▒T▒▒▒▒V.▒:▒4 +▒▒/▒;8֠▒2:;8▒▒; s9õ▒=▒:▒▒F▒/▒000▒▒)▒▒▒▒▒; s9˰▒ +'▒▒-▒%600▒6:!")▒▒▒굫▒▒▒▒▒k▒; s▒▒▒=▒T:▒T▒▒▒▒᳢?▒,▒▒▒I▒▒4▒▒▒▒ ▒4▒▒▒▒▒
▒▒▒i z2-:;▒▒▒; s9▒▒▒ +'▒▒-▒%600▒6:%▒#: ▒▒0000▒D▒9j▒; s99▒=▒T:▒T▒▒▒▒V▒▒▒ĩr▒▒)#W▒▒▒!▒▒▒V▒▒▒▒-▒▒%▒ɴ▒▒=.▒K▒; s▒66=▒:▒▒▒-▒%600▒6:)▒▒▒▒▒; ▒s057=▒T:▒T▒▒▒▒V▒▒▒ĩr▒▒)#W▒ ▒▒▒▒▒%)▒▒
)▒▒▒;▒-▒; ▒s▒▒V▒ +'1▒▒▒▒F#5▒00.F#5!")▒▒▒굫▒▒▒▒ k▒; ▒s▒▒f▒ %▒T▒▒▒▒᳢?▒,▒▒▒I▒▒4▒▒▒▒ ▒4▒▒▒▒▒
▒▒▒i z2-:;8▒-▒; ▒s0v0▒=▒:▒1▒▒▒▒F#5▒00.F#54▒▒3▒▒▒▒.J▒▒%!▒٨0"200▒▒; ▒s▒f▒▒=▒T:▒T▒▒▒▒V▒▒▒ĩr▒▒)#W▒▒▒!▒▒▒V▒▒▒▒-▒▒%▒ɴ▒▒▒ ▒▒▒; ▒s▒▒2▒ %▒T▒F!F?▒/▒&▒ӱ▒ ▒T?▒/▒; ▒s0▒2▒ +'▒▒Ԣ▒ 4000▒▒)3▒:▒▒0▒٨0"*#0▒▒"*%12▒▒▒▒5▒▒; ▒s▒▒0▒=▒:▒▒▒Ԣ▒ 4000▒▒)3W#▒0▒▒/▒▒=▒▒▒12▒66▒=▒0▒▒1▒04▒66▒=▒4▒▒0-▒; ▒s05F▒ +'▒▒Ԣ▒ 4000▒▒)3G▒1$t:▒▒=▒▒▒12▒8▒▒=▒9▒▒1D04▒8▒▒=▒"▒-▒$▒▒; ▒s▒7v▒ +'▒▒Ԣ▒ 4000▒▒)3G▒2$t:▒▒=▒▒▒12▒8▒▒=▒$▒▒▒04▒8▒▒=▒V0-▒+8-▒; ▒s19ñ +'▒▒Ԣ▒ 4000▒▒)3▒▒4/▒▒,3)▒▒/鶒=▒▒▒12;▒▒&▒=▒+8-▒&04;▒▒&▒=▒&▒▒&°▒; ▒s1&9F=▒:▒▒▒Ԣ▒ 4000▒▒)3▒▒4!▒▒%4)0▒▒▒ +▒0'▒ ▒▒▒26▒=828-▒80 û▒26▒=▒80-80▒▒; ▒s▒f4▒=▒:▒▒▒Ԣ▒ 4000▒▒)3G▒'5▒▒▒ +▒0'▒ ▒▒8▒▒020▒▒21▒ û8▒▒021▒-82▒▒; ▒s1▒4▒=▒:▒1▒▒▒▒F#5▒00.F#5▒▒▒▒-2) ▒̩▒; ▒s▒▒9▒ +'1▒▒▒▒F#5▒00.F#5▒:▒▒-F▒▒▒#V!+▒ͳ▒3▒▒▒; ▒s1▒9▒=▒:▒1▒▒▒▒F#5▒00.F#5▒▒▒!V +▒▒/▒▒▒T▒Ԥ63▒▒▒▒5$
2▒$▒2▒
%65▒▒"▒▒$0-▒; ▒s1▒1▒ ▒9▒#▒▒:▒▒#▒0▒"-▒; ▒s15F▒▒6▒▒-▒6▒d-▒▒ V▒▒+▒" ▒3▒6&5▒▒ ▒▒K▒; ▒s▒▒▒▒▒+%0▒▒ɣ▒▒)▒▒▒▒▒▒?▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒; ▒s22▒▒▒▒+%▒▒▒▒/▒▒2▒▒3▒K-▒; ▒s2▒0▒▒▒+%▒▒▒▒3▒V$▒j/▒▒▒%▒▒%j▒; ▒s▒▒9▒▒▒+%)▒K!▒W$$▒▒▒-▒; ▒s▒1▒▒ ٭▒▒▒)▒K!▒W$▒▒3▒,▒K▒; ▒s▒▒0▒ +'?▒▒▒?▒▒ ▒)▒K!▒W$▒▒-▒; ▒s3▒▒▒▒▒%▒)▒
▒▒▒▒▒▒▒ɮ▒0V▒r▒▒; ▒s3▒f▒▒▒▒▒▒ V▒▒+▒" ▒)▒I▒▒$▒▒▒▒▒▒&▒5J▒▒; ▒s▒▒▒▒▒2#▒6)J%▒▒; ▒s38▒= )▒ *▒▒ #▒▒▒▒K▒; ▒s3V▒▒= ▒D▒▒▒▒J▒▒%j▒; ▒s3▒7=)▒K!▒▒▒8▒-▒▒▒▒▒▒U▒▒; ▒s▒V▒▒=▒▒:▒:▒F%V$0▒▒▒▒1-▒; ▒s3▒9▒=▒:▒r4▒▒K▒▒с
6k▒; ▒s3▒5▒=▒▒:▒:▒F%V$0▒▒▒▒▒k▒; ▒s▒▒▒▒ ▒▒ V▒▒+▒" ▒э▒▒▒▒▒k▒; ▒s▒▒2▒ $):%▒▒+▒▒▒▒!▒▒6
▒▒▒▒▒$)▒▒▒▒▒ $?▒3)▒I▒▒▒ծ*$4▒▒-▒; ▒s▒▒▒▒ ĵ▒▒▒▒2▒▒▒▒U4▒▒▒▒▒▒▒▒▒-▒; ▒s▒ö▒="Չ▒▒▒2▒▒▒▒▒▒▒▒; ▒s3▒6▒ ĵ▒▒▒騑 ▒▒▒▒▒▒I▒▒▒ՅK/▒▒▒▒.▒▒; ▒s▒0F▒ ĵ▒▒▒騑▒▒U4▒▒▒▒▒▒▒▒▒-▒; ▒s▒▒F▒▒0▒Ӡ▒F!▒ʝ920▒V0/F-▒; ▒s4▒˷▒U9▒▒$Ͳ▒/▒I V▒▒+▒"-▒; ▒s4▒▒=▒:▒F%V$▒▒5▒▒▒▒▒▒▒▒▒; ▒s▒▒4▒ ▒▒)▒▒▒)▒j)▒▒▒9▒▒▒▒j!+▒▒; ▒s4▒▒▒ ▒▒%8▒9▒▒4'T)▒▒▒ ▒▒▒*▒▒!+$▒▒▒b▒U9▒▒▒▒▒f▒▒▒f%*▒3▒54▒▒▒▒&▒▒v-▒; ▒s4▒4▒ +'▒▒▒%1▒600▒%!")▒▒▒굫▒▒▒▒▒k▒; ▒s▒▒9▒=▒:▒▒▒▒%1▒600▒%▒▒▒▒▒▒-▒▒▒,▒▒▒K▒; ▒s4▒9▒=▒:▒▒▒▒%1▒!00▒%!")▒▒▒굫▒▒▒▒ -▒; ▒s▒▒▒=▒:▒▒▒▒%1▒!00▒%▒▒▒▒▒▒-▒▒▒,▒▒▒K▒; ▒s5▒▒▒ +'▒▒-▒000▒鲿▒-!")▒▒▒굫▒▒▒▒▒-▒; ▒s5&2▒=▒▒▒j&▒52%#▒V.g▒▒52%▒ ▒▒▒T&*2!0▒▒%00,0▒▒00▒▒▒,▒0%▒▒8000▒▒▒2&j▒; ▒s▒F▒▒▒▒-▒j&▒52%#▒V.g▒▒52%▒ z▒▒▒82'",▒▒▒▒2▒003▒ ▒▒▒▒C=▒▒▒; ▒s5▒▒▒ 0▒K▒▒)▒▒▒▒-▒&▒-%J ;▒▒; ▒s▒▒▒=▒▒▒Ҡv)▒▒▒▒▒▒k▒ *▒▒ 88V-▒; ▒s5▒0▒▒▒▒Ҡv)▒▒▒▒▒&▒▒3▒▒ *▒▒ 2▒8▒-▒; ▒s5˱▒▒▒-▒j&▒52%#▒V.g▒▒52%▒ 0▒▒▒2"▒:▒F%V▒-▒; ▒s▒▒7▒=▒͋8▒V400▒͋8!")▒▒▒굫▒▒▒▒▒▒▒; ▒s64▒▒ ▒F1▒▒▒00.▒F1:)▒K!▒W▒▒; ▒s6▒▒▒▒▒▒գ▒+8▒▒00.▒F1:▒▒#▒0!")▒▒▒굫▒▒▒▒▒▒▒; ▒s▒7▒▒▒▒▒գ▒+8▒▒00.▒F1:▒▒#▒0)▒K!▒W$▒F▒
▒▒▒3▒굫▒֭s00000100▒▒▒; ▒s6▒6▒=▒▒▒▒▒.+8▒▒00.▒F1:▒▒#▒1!")▒▒▒굫▒▒▒▒▒▒▒; ▒s▒f▒▒=▒▒▒▒▒.+8▒▒00.▒F1:▒▒#▒1)▒K!▒W$▒F▒
▒▒▒4▒굫▒֭s00000100▒▒▒; ▒s6▒6▒=▒▒▒▒▒.+8▒▒00.▒F1:▒▒#▒2!")▒▒▒굫▒▒▒▒▒▒▒; ▒s▒▒6▒=▒▒▒▒▒.+8▒▒00.▒F1:▒▒#▒2)▒K!▒W$▒F▒
▒▒▒5▒굫▒֭s00000100▒▒▒; ▒s6▒5▒▒▒▒գ▒+8▒▒00.▒F1:▒▒#▒3!")▒▒▒굫▒▒▒▒▒▒▒; ▒s▒▒6▒▒▒▒գ▒+8▒▒00.▒F1:▒▒#▒3)▒K!▒W$▒F▒
▒▒▒6▒굫▒֭s00000100▒▒▒; ▒s6▒▒▒▒▒▒գ▒+8▒▒00.▒F1:▒▒#▒4!")▒▒▒굫▒▒▒▒▒▒▒; ▒s▒▒ù▒▒▒գ▒+8▒▒00.▒F1:▒▒#▒4)▒K!▒W$▒F▒
▒▒▒7▒굫▒֭s00000100▒▒▒; ▒s7▒▒▒▒▒▒գ▒+8▒▒00.▒F1:▒▒#▒5!")▒▒▒굫▒▒▒▒▒▒▒; ▒s▒▒▒▒▒▒▒գ▒+8▒▒00.▒F1:▒▒#▒5)▒K!▒W$▒F▒
▒▒▒8▒굫▒֭s00000100▒▒▒; ▒s765▒▒▒▒գ▒+8▒▒00.▒F1:▒▒#▒6!")▒▒▒굫▒▒▒▒▒▒▒; ▒s▒5▒▒▒▒գ▒+8▒▒00.▒F1:▒▒#▒6)▒K!▒W$▒F▒
▒▒▒9▒굫▒֭s00000100▒▒▒; ▒s7▒▒▒=▒▒▒▒▒.+8▒▒00.▒F1:▒▒#▒7!")▒▒▒굫▒▒▒▒▒▒▒; ▒s▒▒▒▒=▒▒▒▒▒.+8▒▒00.▒F1:▒▒#▒7)▒K!▒W$▒F▒
▒▒▒0▒굫▒֭s00000100▒▒▒; ▒s7▒4▒=▒▒▒▒▒.+8▒▒00.▒F1:▒▒#▒0!")▒▒▒굫▒▒▒▒▒▒▒; ▒s7▒4▒▒▒▒գ▒+8▒▒00.▒F1:▒▒#▒0)▒K!▒W$▒F▒
▒▒▒3▒굫▒֭s000000000▒▒; ▒s70▒▒▒▒▒գ▒+8▒▒00.▒F1:▒▒#▒1!")▒▒▒굫▒▒▒▒ -▒; ▒s78▒▒▒▒▒գ▒+8▒▒00.▒F1:▒▒#▒1)▒K!▒W$▒F▒
▒▒▒4▒굫▒֭s000000000▒▒; ▒s▒▒v▒▒▒▒գ▒+8▒▒00.▒F1:▒▒#▒2!")▒▒▒굫▒▒▒▒ -▒; ▒s8▒f▒▒▒▒գ▒+8▒▒00.▒F1:▒▒#▒2)▒K!▒W$▒F▒
▒▒▒5▒굫▒֭s000000000▒▒; ▒s▒▒&▒▒▒▒գ▒+8▒▒00.▒F1:▒▒#▒3!")▒▒▒굫▒▒▒▒ &-▒; ▒s8f3▒=▒▒▒▒▒.+8▒▒00.▒F1:▒▒#▒3)▒K!▒W$▒F▒
▒▒▒6▒굫▒֭s000000000▒▒; ▒s▒v▒▒=▒▒▒▒▒.+8▒▒00.▒F1:▒▒#▒4!")▒▒▒굫▒▒▒▒ 6-▒; ▒s8▒▒▒▒▒▒գ▒+8▒▒00.▒F1:▒▒#▒4)▒K!▒W$▒F▒
▒▒▒7▒굫▒֭s000000000▒▒; ▒s▒▒▒▒=▒▒▒▒▒.+8▒▒00.▒F1:▒▒#▒5!")▒▒▒굫▒▒▒▒ F-▒; ▒s8▒▒v=▒▒▒▒▒.+8▒▒00.▒F1:▒▒#▒5)▒K!▒W$▒F▒
▒▒▒8▒굫▒֭s000000000▒▒; ▒s▒▒▒▒=▒▒▒▒▒.+8▒▒00.▒F1:▒▒#▒6!")▒▒▒굫▒▒▒▒ V-▒; ▒s837֠▒▒գ▒+8▒▒00.▒F1:▒▒#▒6)▒K!▒W$▒F▒
▒▒▒9▒굫▒֭s000000000▒▒; ▒s▒41=▒▒▒▒▒.+8▒▒00.▒F1:▒▒#▒7!")▒▒▒굫▒▒▒▒ f-▒; ▒s92▒֠▒▒գ▒+8▒▒00.▒F1:▒▒#▒7)▒K!▒W$▒F▒
▒▒▒0▒굫▒֭s000000000▒▒; ▒s▒3▒▒
▒▒.▒▒400▒j:!")▒▒▒굫▒▒▒▒ v-▒; ▒s9v▒▒
▒▒.▒▒400▒j:)▒K!▒W▒▒; ▒s▒▒▒=▒▒▒.▒▒800▒S▒Ҡ$J▒▒▒굫▒▒▒▒ ▒-▒; ▒s9▒8▒=▒▒▒.▒▒800▒S▒Ҡ▒▒▒▒▒-▒; ▒s9▒▒▒=▒▒▒.▒▒400▒S▒▒:!")▒▒▒굫▒▒▒▒ ▒-▒; ▒s▒▒8▒=▒▒▒.▒▒400▒S▒▒:)▒K!▒W▒▒; ▒s9▒▒▒
▒▒.▒▒#00▒+▒▒▒$J▒▒▒굫▒▒▒▒▒-▒; ▒s▒▒1▒=▒▒▒.▒▒#00▒+▒▒▒▒▒▒▒▒-▒; ▒s90▒▒
500▒
:!")▒▒▒굫▒▒▒▒▒-▒; ▒s▒0▒▒
500▒
:)▒K!▒W▒▒; ▒s▒▒▒▒ ▒*#▒▒800▒#▒▒▒$J▒▒▒굫▒▒▒▒▒&-▒; s0▒▒▒ ▒*#▒▒800▒#▒▒▒▒▒▒▒▒-▒; s▒4▒▒ ▒▒▒▒000▒V#!")▒▒▒굫▒▒▒▒▒6-▒; s0V9▒ ▒▒▒▒000▒V#)▒K!▒W▒▒; s▒6▒▒=▒▒▒▒00▒J▒▒▒▒/▒I:▒▒)▒▒.▒/▒I V▒▒+▒"-▒; s▒▒5▒=▒:▒▒▒▒▒D▒▒▒▒D ▒00▒:▒▒▒▒▒D T3▒:▒F%V▒▒; s0▒▒▒▒▒▒▒▒6▒▒▒▒▒▒▒/▒Ճ5k▒▒J ▒:%▒▒▒▒▒/▒k▒; s▒▒▒▒='▒▒▒9▒▒▒▒▒▒▒/▒Ճ5k▒▒J ▒:%▒▒▒▒▒/▒k▒; s02▒▒▒▒▒▒▒0▒:▒F%V$'▒▒3▒ {▒▒1/▒+'▒F▒▒▒▒▒; s▒18렂▒▒▒1▒:▒F%V$'▒ͳ6▒▒F7/▒+'▒F▒▒▒▒▒K▒; s▒▒ø +'-▒▒&800▒k:▒k▒▒+▒.3▒ ▒▒/▒▒; s16ñ +'-▒▒&!00▒k:▒k▒▒+▒.3▒ ▒▒/▒▒; s▒48=▒:▒-▒▒�▒k:▒k▒▒+▒.3▒ ▒▒/▒▒; s11F=▒:▒-▒▒&&00▒k:▒k▒▒+▒.3▒ ▒▒/▒▒; s▒▒▒▒▒6 +'▒▒▒▒#▒,▒:▒▒▒▒▒▒▒?V▒▒+24▒▒▒▒▒1▒0+4-▒; s▒▒3▒=▒:▒▒▒▒51▒000▒:!")▒▒▒굫▒▒▒▒▒F-▒; s1▒76=▒9k.▒l%▒00▒͋8▒4)▒
000▒▒+8▒▒▒J▒"▒▒+ { ▒▒▒▒-▒; s1▒▒&=▒9k.▒l%▒00▒͋8▒4)▒
000)▒K!▒W▒▒; s1▒▒▒ +'▒-F▒▒▒▒▒
▒:▒▒0▒▒j▒鳤▒▒▒▒00.▒F1:▒4)▒
00▒▒▒5▒K▒; s▒▒▒▒=▒:▒▒-F▒▒▒▒▒
00▒▒▒5▒K▒; s17f▒ +'▒-F▒▒▒▒▒
00▒▒▒5▒K▒; s▒▒9=▒:▒▒-F▒▒▒▒▒
00▒▒▒5▒K▒; s2▒2=▒:▒▒-F▒▒▒▒▒
00▒▒▒5▒K▒; s▒7▒▒ +'▒-F▒▒▒▒▒
00▒▒▒5▒K▒; s2f9▒ +'▒-F▒▒▒▒▒
00▒▒▒5▒K▒; s▒f7▒ +'▒-F▒▒▒▒▒
00▒▒▒5▒K▒; s2▒▒▒ +'▒▒٪▒▒▒00.▒F1:K0▒00!")▒▒▒굫▒▒▒▒▒V-▒; s▒▒9▒ +'▒▒٪▒▒▒00.▒F1:K1100!")▒▒▒굫▒▒▒▒▒f-▒; s2▒5▒=▒▒j▒▒鹱V400▒͋8g)-C)▒3000!")▒▒▒굫▒▒▒▒▒V-▒; s▒▒▒▒▒6!V-▒*/▒l%▒00▒͋8g)-C)▒3000)▒K!▒W▒▒; s2▒▒▒6!V-▒*/▒l%▒00▒͋8g▒-C)13000!")▒▒▒굫▒▒▒▒▒f-▒; s▒▒&▒▒6!V-▒*/▒l%▒00▒͋8g▒-C)13000)▒K!▒W▒▒; s▒▒▒=▒▒j▒▒鹱V400▒͋8▒3-C)1000!")▒▒▒굫▒▒▒▒▒F-▒; s3▒6▒6!V-▒*/▒l%▒00▒͋8▒3-C)1000)▒K!▒W▒▒; s▒4▒▒ ▒▒▒▒գ▒+8▒6000▒
0▒▒▒▒▒#▒0!")▒▒▒굫▒▒▒▒▒v-▒; s36▒f=0
▒▒▒գ▒+8▒6000▒
0▒▒▒▒▒#▒0)▒K!▒W$▒F▒
▒▒/8▒굫▒֭s000000000▒▒; s▒V▒&=0
▒▒▒գ▒+8▒6000▒
0▒▒▒▒▒#▒1!")▒▒▒굫▒▒▒▒▒▒-▒; s3▒0▒ ▒▒▒▒գ▒+8▒6000▒
0▒▒▒▒▒#▒1)▒K!▒W$▒F▒
▒▒/9▒굫▒֭s000000000▒▒; s▒▒0▒=0
▒▒▒գ▒+8▒6000▒
0▒▒▒▒▒#▒2!")▒▒▒굫▒▒▒▒▒▒-▒; s3▒▒▒ ▒▒▒▒գ▒+8▒6000▒
0▒▒▒▒▒#▒2)▒K!▒W$▒F▒
▒▒O0▒굫▒֭s000000000▒▒; s▒▒2▒ ▒▒▒▒գ▒+8▒6000▒
0▒▒▒▒▒#▒3!")▒▒▒굫▒▒▒▒ ▒-▒; s3▒▒▒ ▒▒▒▒գ▒+8▒6000▒
0▒▒▒▒▒#▒3)▒K!▒W$▒F▒
▒▒O1▒굫▒֭s000000000▒▒; s▒▒▒▒ ▒▒▒▒գ▒+8▒6000▒
0▒▒▒▒▒#▒4!")▒▒▒굫▒▒▒▒ ▒-▒; s4▒▒▒ ▒▒▒▒գ▒+8▒6000▒
0▒▒▒▒▒#▒4)▒K!▒W$▒F▒
▒▒O2▒굫▒֭s000000000▒▒; s47▒=0
▒▒▒գ▒+8▒6000▒
0▒▒▒▒▒#▒5!")▒▒▒굫▒▒▒▒ ▒-▒; s▒0v=0
▒▒▒գ▒+8▒6000▒
0▒▒▒▒▒#▒5)▒K!▒W$▒F▒
▒▒O3▒굫▒֭s000000000▒▒; s4▒0▒ ▒▒▒▒գ▒+8▒6000▒
0▒▒▒▒▒#▒6!")▒▒▒굫▒▒▒▒ ▒-▒; s▒▒▒▒=0
▒▒▒գ▒+8▒6000▒
0▒▒▒▒▒#▒6)▒K!▒W$▒F▒
▒▒O4▒굫▒֭s000000000▒▒; s4▒▒=0
▒▒▒գ▒+8▒6000▒
0▒▒▒▒▒#▒7!")▒▒▒굫▒▒▒▒ ▒-▒; s▒▒4▒=0
▒▒▒գ▒+8▒6000▒
0▒▒▒▒▒#▒7)▒K!▒W$▒F▒
▒▒O5▒굫▒֭s000000000▒▒; s44▒▒ ▒▒6000▒
0!")▒▒▒굫▒▒▒▒ ▒-▒; s▒▒˰ ▒▒6000▒
0)▒K!▒W▒▒; s5▒▒=.#▒▒5800▒#▒0!")▒▒▒굫▒▒▒▒ ▒-▒; s▒▒▒▒ ▒b!▒▒800▒#▒0)▒K!▒W▒▒; s5▒▒=.#▒▒5#00▒#▒1!")▒▒▒굫▒▒▒▒ ▒-▒; s▒˵▒ ▒b!▒▒#00▒#▒1)▒K!▒W▒▒; s5▒▒▒=▒:▒▒▒#j!2▒00▒▒#j!!")▒▒▒굫▒▒▒▒▒-▒; s▒▒▒▒ +'▒▒#j!2▒00▒▒#j!'#▒▒$▒▒▒ V▒▒+2▒▒▒!▒▒▒K▒; s5▒3=▒:▒-▒▒j▒▒.%▒▒j▒▒.3▒#▒s ▒+▒#▒▒ J▒"▒j▒; s5▒3=▒:▒-▒▒j▒▒.%▒▒j▒▒.▒▒%▒▒.$▒▒▒▒▒▒▒▒▒-▒; s▒▒3▒V▒▒▒+'▒000▒I▒,!")▒▒▒굫▒▒▒▒▒-▒; s6▒▒֠000▒I▒,4▒4͠4▒▒▒▒000▒▒
=▒c ▒▒5=▒▒j▒ +'▒
2k▒; s▒▒▒▒▒V▒▒▒+'▒100▒I▒,!")▒▒▒굫▒▒▒▒▒-▒; s67▒▒100▒I▒,4▒4▒
!▒▒▒▒100▒▒
=7▒ ▒▒5=▒▒j▒ +'▒
2k▒; s▒▒▒▒V▒▒▒+'▒$800▒I▒,!")▒▒▒굫▒▒▒▒▒-▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒g▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒>▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒w▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒w▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒w▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒?▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒o▒>▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒o▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒g▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒o▒▒▒▒>▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒>▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒?▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒?▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒w▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒
