Boot failed many times, A small probability can be initiated
I> DCEÿ䙠 2.568957] Camera-FW on t234-rce-safe started
ÿ󿟵nÿ䓃U early console enabled.
ÿৡlt successful
I> APE unhalt skipped
I> FSI unhalt skipped
I> Task: Load CPUBL (0x50018e1c)
I> Task: Load TOS (0x50019580)
I> Task: Load and authenticate registered FWs (0x5001e198)
I> Partition name: A_cpu-bootloader
I> Size of partition: 3670016
I> Binary@ device:3/0 block-24832 (partition size: 0x380000), name: A_cpu-bootloader
ÿ
ꀢinitialized emc
initialized emc_mrq
initialized clk_cal
initialized uphy_dt
initialized uphy_mrq
HSIO UPHY reset has been de-asserted 0x0
initialized uphy
ÿǾ Partition name: A_secure-os
I> Size of partition: 41ÿᨮitialized pg_late
ÿ󿷴3ÿᨮitialized pg_mrq_init
swdtimer_init: reg polling start w period 47 ms
initialized swdtimer
initialized hwwdt_late
initialized bwmgr
initialized thermal_host_trip
initialized thermal_mrq
initialized oc_mrq
initialized reset_mrq
initialized mail_mrq
initialized fmon_mrq
initialized clk_mrq
initialized avfs_mrq
initialized i2c_mrq
initialized tag_mrq
initialized bwmgr_mrq
initialized console_mrq
ÿ󿮴
I> ÿᬩssing prod DT calibration data for 199 fmons
initialized clk_sync_fmon_post
ÿinary@ device:3/0 block-32000 (partition size: 0x400000), name: A_secure-os
I> MB2-params @ 0x40060000
I> cpubl_params: nsdram: carveout: 1, encryption: 1
I> NSDRAM carveout base: 0x80000000, size: 0xfad270000
I> cpubl: Authentiÿᨮitialized clk_cal_late
initialized noc_late
initialized cvc
ÿࢡtion Finalize Done
I> Binary cpubl loÿᨮitialized avfs_clk_mach_post
initialized avfs_clk_platform_post
initialized cvc_late
initialized rm
initialized console_late
handling unreferenced clks
enable can1_core
enable can1_host
enable can2_core
enable can2_host
enable pwm3
enable mss_encrypt
enable maud
enable pllg_ref
enable dsi_core
enable aza_2xbit
enable pllc4_muxed
enable xusb_ss
enable xusb_fs
enable xusb_falcon
enable xusb_core_mux
enable dsi_lp
enable sdmmc_legacy_tm
initialized clk_mach_post
initialized pg_post
initialized regulator_post
initialized profile
initialized mrq
initialized patrol_scrubber
initialized cactmon
initialized extras_post
bpmp: init complete
ÿ䙠 2.742779] Camera-FW on t234-rce-safe ready SHA1=8676d22a (crt 12.963 ms, total boot 187.843 ms)
ÿࠤed successfully at 0x102ce00000
I> tos: Authentication Finalize Done
I> Binary tos loaded successfully at 0x103fdee000
I> Relocating OP-TEE dtb from: 0x103fefec50 to 0x103c000020, size: 0x2106
I> [0] START: 0x80000000, SIZE: 0xfad270000
I> [1] START: 0x1032000000, SIZE: 0x2000000
I> Setting NS memory ranges to OP-TEE dtb finished.
I> Partition name: A_eks
I> Size of partition: 262144
I> Binary@ device:3/0 block-44288 (partition size: 0x40000), name: A_eks
I> eks: Authentication Finalize Done
I> Binary eks loaded successfully at 0x102e800400
I> EKB detected (length: 0x410) @ VA:0x102e800400
I> Task: Prepare TOS params (0x500194f8)
I> Setting EKB blob info to OPTEE dtb finished.
I> Setting OPTEE arg3: 0x103c000020
I> Task: OEM SC7 context save (0x5001a88c)
I> OEM sc7 context saved
I> Task: Disable MSS perf stats (0x50027f00)
I> Task: Program display sticky bits (0x50027e7c)
I> Task: Storage device deinit (0x500020a0)
I> Task: SMMU external bypass disable (0x50017894)
I> Task: SMMU init (0x500177b0)
I> Task: Program GICv3 registers (0x50027fa0)
I> Task: Audit firewall settings (0x50024fbc)
I> Task: Bootchain failure check (0x500025e8)
I> Current Boot-Chain Slot: 0
I> BR-BCT Boot-Chain is 0, and status is 1. Set UPDATE_BRBCT bit to 0
I> MB2 finished
ÿ㍏TICE: BL31: v2.6(release):346877e39
NOTICE: BL31: Built : 12:32:40, Aug 1 2023
I/TC: Physical secure memory base 0x103c040000 size 0x3fc0000
ÿ烃E: FW Boot Done
ÿ㇯TC:
I/TC: Non-secure external DT found
I/TC: OP-TEE version: 3.21 (gcc version 9.3.0 (Buildroot 2020.08)) #2 Tue Aug 1 19:39:55 UTC 2023 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check Porting guidelines — OP-TEE documentation documentation
I/TC: Primary CPU initializing
I/TC: Test OEM keys are being used. This is insecure for shipping products!
I/TC: Primary CPU switching to normal world boot
ÿ
ɥtson UEFI firmware (version 4.1-33958178 built on 2023-08-01T19:34:02+00:00)
ÿ㇯TC: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
ÿ
〤E/TC:?? 00 get_rpc_alloc_res:645 RPC allocation failed. Non-secure world result: ret=0xffff0000 ret_origin=0
E/LD: init_elf:486 sys_open_ta_bin(bc50d971-d4c9-42c4-82cb-343fb7f37896)
E/TC:?? 00 ldelf_init_with_ldelf:131 ldelf failed with res: 0xffff000c
ÿ
Jetson UEFI firmware (version 4.1-33958178 built on 2023-08-01T19:34:02+00:00)
ESC to enter Setup.
F11 to enter Boot Manager Menu.
Enter to continue boot.
** WARNING: Test Key is used. **
L4TLauncher: Attempting Direct Boot
EFI stub: Booting Linux Kernel…
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services and installing virtual address map…
ÿ㇯TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 4 initializing
I/TC: Secondary CPU 4 switching to normal world boot
I/TC: Secondary CPU 5 initializing
I/TC: Secondary CPU 5 switching to normal world boot
I/TC: Secondary CPU 6 initializing
I/TC: Secondary CPU 6 switching to normal world boot
I/TC: Secondary CPU 7 initializing
I/TC: Secondary CPU 7 switching to normal world boot
I/TC: Secondary CPU 8 initializing
I/TC: Secondary CPU 8 switching to normal world boot
I/TC: Secondary CPU 9 initializing
I/TC: Secondary CPU 9 switching to normal world boot
I/TC: Secondary CPU 10 initializing
I/TC: Secondary CPU 10 switching to normal world boot
I/TC: Secondary CPU 11 initializing
I/TC: Secondary CPU 11 switching to normal world boot
ÿ٠ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 5.10.120-tegra (root@zelos) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #8 SMP PREEMPT Wed Aug 16 21:37:23 CST 2023
[ 0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,
[ 0.000000] OF: fdt: - 80000000 , c0000000
[ 0.000000] Machine model: Jetson AGX Orin Developer Kit
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x102531e718 SMBIOS=0xffff0000 SMBIOS 3.0=0x1006070000 MEMATTR=0x1006824018 ESRT=0x1006081c98 RNG=0x1028fff118 MEMRESERVE=0x1006826c18
[ 0.000000] efi: seeding entropy pool
[ 0.000000] esrt: Reserving ESRT space from 0x0000001006081c98 to 0x0000001006081cd0.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000001008c00000, size 512 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x0000001033ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000fffdffff]
[ 0.000000] node 0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x00000010045ebfff]
[ 0.000000] node 0: [mem 0x00000010045ec000-0x00000010047cefff]
[ 0.000000] node 0: [mem 0x00000010047cf000-0x000000100498ffff]
[ 0.000000] node 0: [mem 0x0000001004990000-0x0000001004a2ffff]
[ 0.000000] node 0: [mem 0x0000001004a30000-0x000000100605ffff]
[ 0.000000] node 0: [mem 0x0000001006060000-0x000000100607ffff]
[ 0.000000] node 0: [mem 0x0000001006080000-0x00000010066dffff]
[ 0.000000] node 0: [mem 0x00000010066e0000-0x000000100677ffff]
[ 0.000000] node 0: [mem 0x0000001006780000-0x00000010067fffff]
[ 0.000000] node 0: [mem 0x0000001006800000-0x000000100681ffff]
[ 0.000000] node 0: [mem 0x0000001006820000-0x000000100683ffff]
[ 0.000000] node 0: [mem 0x0000001006840000-0x000000100685ffff]
[ 0.000000] node 0: [mem 0x0000001006860000-0x000000100693ffff]
[ 0.000000] node 0: [mem 0x0000001006940000-0x000000100695ffff]
[ 0.000000] node 0: [mem 0x0000001006960000-0x000000100698ffff]
[ 0.000000] node 0: [mem 0x0000001006990000-0x0000001006b6ffff]
[ 0.000000] node 0: [mem 0x0000001006b70000-0x0000001006c3ffff]
[ 0.000000] node 0: [mem 0x0000001006c40000-0x0000001006cdffff]
[ 0.000000] node 0: [mem 0x0000001006ce0000-0x0000001006d1ffff]
[ 0.000000] node 0: [mem 0x0000001006d20000-0x0000001006faffff]
[ 0.000000] node 0: [mem 0x0000001006fb0000-0x00000010070affff]
[ 0.000000] node 0: [mem 0x00000010070b0000-0x000000100714ffff]
[ 0.000000] node 0: [mem 0x0000001007150000-0x000000100719ffff]
[ 0.000000] node 0: [mem 0x00000010071a0000-0x000000100723ffff]
[ 0.000000] node 0: [mem 0x0000001007240000-0x000000100775ffff]
[ 0.000000] node 0: [mem 0x0000001007760000-0x000000100793ffff]
[ 0.000000] node 0: [mem 0x0000001007940000-0x0000001028faffff]
[ 0.000000] node 0: [mem 0x0000001028fb0000-0x0000001028ffffff]
[ 0.000000] node 0: [mem 0x0000001029000000-0x000000102d1fffff]
[ 0.000000] node 0: [mem 0x000000102d210000-0x000000102d21ffff]
[ 0.000000] node 0: [mem 0x0000001032000000-0x0000001033ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000001033ffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 32 pages/cpu s90328 r8192 d32552 u131072
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 16188688
[ 0.000000] Kernel command line: root=PARTUUID=3f637458-9482-40f4-bee0-eeb146aa5cca rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 console=tty0 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb
[ 0.000000] Dentry cache hash table entries: 8388608 (order: 14, 67108864 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000effe0000-0x00000000fffe0000] (256MB)
[ 0.000000] Memory: 63772368K/65783872K available (18496K kernel code, 3152K rwdata, 7152K rodata, 3968K init, 1418K bss, 1487216K reserved, 524288K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=12, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=12.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=12
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[ 0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)
[ 0.000000] GICv2m: range[mem 0x0f410000-0x0f41ffff], SPI[608:677]
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000748] Console: colour dummy device 80x25
[ 0.000933] printk: console [tty0] enabled
[ 0.000983] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.000995] pid_max: default: 32768 minimum: 301
[ 0.001103] LSM: Security Framework initializing
[ 0.001133] Yama: becoming mindful.
[ 0.001154] SELinux: Initializing.
[ 0.001313] Mount-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.001400] Mountpoint-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.003680] rcu: Hierarchical SRCU implementation.
[ 0.003854] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.004482] DTS File Name: /home/lizh/orin_jp512/src/kernel/kernel-5.10/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t23x/concord/kernel-dts/tegra234-p3701-0005-p3737-0000.dts
[ 0.004491] DTB Build time: Aug 17 2023 22:23:04
[ 0.005964] Tegra Revision: A01 SKU: 0xd0 CPU Process: 0 SoC Process: 0
[ 0.006193] Remapping and enabling EFI services.
[ 0.006771] smp: Bringing up secondary CPUs …
[ 0.035524] Detected PIPT I-cache on CPU1
[ 0.035567] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[ 0.035613] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[ 0.064301] Detected PIPT I-cache on CPU2
[ 0.064312] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[ 0.064327] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[ 0.092959] Detected PIPT I-cache on CPU3
[ 0.092969] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[ 0.092982] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[ 0.123675] Detected PIPT I-cache on CPU4
[ 0.123696] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c0000
[ 0.123723] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[ 0.152414] Detected PIPT I-cache on CPU5
[ 0.152426] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e0000
[ 0.152443] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[ 0.181087] Detected PIPT I-cache on CPU6
[ 0.181096] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f500000
[ 0.181112] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[ 0.209761] Detected PIPT I-cache on CPU7
[ 0.209771] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f520000
[ 0.209786] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
[ 0.240487] Detected PIPT I-cache on CPU8
[ 0.240512] GICv3: CPU8: found redistributor 20000 region 0:0x000000000f540000
[ 0.240541] CPU8: Booted secondary processor 0x0000020000 [0x410fd421]
[ 0.269225] Detected PIPT I-cache on CPU9
[ 0.269235] GICv3: CPU9: found redistributor 20100 region 0:0x000000000f560000
[ 0.269251] CPU9: Booted secondary processor 0x0000020100 [0x410fd421]
[ 0.298518] Detected PIPT I-cache on CPU10
[ 0.298528] GICv3: CPU10: found redistributor 20200 region 0:0x000000000f580000
[ 0.298544] CPU10: Booted secondary processor 0x0000020200 [0x410fd421]
[ 0.327799] Detected PIPT I-cache on CPU11
[ 0.327810] GICv3: CPU11: found redistributor 20300 region 0:0x000000000f5a0000
[ 0.327826] CPU11: Booted secondary processor 0x0000020300 [0x410fd421]
[ 0.327884] smp: Brought up 1 node, 12 CPUs
[ 0.327957] SMP: Total of 12 processors activated.
[ 0.327962] CPU features: detected: Privileged Access Never
[ 0.327964] CPU features: detected: LSE atomic instructions
[ 0.327967] CPU features: detected: User Access Override
[ 0.327970] CPU features: detected: 32-bit EL0 Support
[ 0.327973] CPU features: detected: Common not Private translations
[ 0.327976] CPU features: detected: RAS Extension Support
[ 0.327978] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.327984] CPU features: detected: CRC32 instructions
[ 0.327986] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.347064] spectre-bhb mitigation disabled by command line option
[ 0.347065] spectre-bhb mitigation disabled by command line option
[ 0.347067] spectre-bhb mitigation disabled by command line option
[ 0.365772] CPU: All CPU(s) started at EL2
[ 0.369245] devtmpfs: initialized
[ 0.387499] Registered cp15_barrier emulation handler
[ 0.387511] Registered setend emulation handler
[ 0.387518] KASLR enabled
[ 0.387647] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.387663] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[ 0.390904] pinctrl core: initialized pinctrl subsystem
[ 0.391382] SMBIOS 3.0.0 present.
[ 0.391392] DMI: Unknown Jetson AGX Orin Developer Kit/Jetson AGX Orin Developer Kit, BIOS 4.1-33958178 08/01/2023
[ 0.391730] NET: Registered protocol family 16
[ 0.392560] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.392765] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.392962] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.392990] audit: initializing netlink subsys (disabled)
[ 0.393072] audit: type=2000 audit(0.392:1): state=initialized audit_enabled=0 res=1
[ 0.393263] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.393264] thermal_sys: Registered thermal governor ‘power_allocator’
[ 0.393269] thermal_sys: Registered thermal governor ‘pid_thermal_gov’
[ 0.395825] cpuidle: using governor menu
[ 0.395956] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.396079] ASID allocator initialised with 32768 entries
[ 0.396175] Serial: AMBA PL011 UART driver
[ 0.398006] tegra234_mc_sid_probe(): tegra234 mc-sid probe successful
[ 0.398034] Tegra reboot handler registered.
[ 0.418641] mc: mapped MMIO address: 0xffff8000111f0000 → 0x2c10000
[ 0.418656] mc: mapped MMIO address: 0xffff800011210000 → 0x2c20000
[ 0.418663] mc: mapped MMIO address: 0xffff800011230000 → 0x2c30000
[ 0.418669] mc: mapped MMIO address: 0xffff800011250000 → 0x2c40000
[ 0.418676] mc: mapped MMIO address: 0xffff800011270000 → 0x2c50000
[ 0.418682] mc: mapped MMIO address: 0xffff800011290000 → 0x2b80000
[ 0.418688] mc: mapped MMIO address: 0xffff8000112b0000 → 0x2b90000
[ 0.418694] mc: mapped MMIO address: 0xffff8000112d0000 → 0x2ba0000
[ 0.418701] mc: mapped MMIO address: 0xffff8000112f0000 → 0x2bb0000
[ 0.418707] mc: mapped MMIO address: 0xffff800011310000 → 0x1700000
[ 0.418713] mc: mapped MMIO address: 0xffff800011330000 → 0x1710000
[ 0.418719] mc: mapped MMIO address: 0xffff800011350000 → 0x1720000
[ 0.418727] mc: mapped MMIO address: 0xffff800011370000 → 0x1730000
[ 0.418733] mc: mapped MMIO address: 0xffff800011390000 → 0x1740000
[ 0.418739] mc: mapped MMIO address: 0xffff8000113b0000 → 0x1750000
[ 0.418745] mc: mapped MMIO address: 0xffff8000113d0000 → 0x1760000
[ 0.418753] mc: mapped MMIO address: 0xffff8000113f0000 → 0x1770000
[ 0.418763] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.418807] mc-err: mcerr ops are set to t23x
[ 0.419532] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 88, base_baud = 0) is a SBSA
[ 1.665990] printk: console [ttyAMA0] enabled
[ 1.674790] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 1.681506] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 1.688209] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 1.694907] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 1.704016] ACPI: Interpreter disabled.
[ 1.709048] vdd-3v3-pcie: supplied by vdd-3v3-sys
[ 1.714161] vdd-av1v1-hub: supplied by vdd-5v-sys
[ 1.719001] vbusA-cvb: supplied by vdd-5v-sys
[ 1.723454] vbusB-cvb: supplied by vdd-5v-sys
[ 1.727966] vdd-usbc1-vbus: supplied by vdd-5v-sys
[ 1.732887] vdd-usbc2-vbus: supplied by vdd-5v-sys
[ 1.738046] iommu: Default domain type: Translated
[ 1.742969] eventlib_kernel: keventlib is initialized, test id: 0
[ 1.749264] SCSI subsystem initialized
[ 1.753116] usbcore: registered new interface driver usbfs
[ 1.758625] usbcore: registered new interface driver hub
[ 1.763950] usbcore: registered new device driver usb
[ 1.769192] mc: Linux media interface: v0.10
[ 1.773468] videodev: Linux video capture interface: v2.00
[ 1.779108] pps_core: LinuxPPS API ver. 1 registered
[ 1.784071] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 1.793209] PTP clock support registered
[ 1.797371] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec
[ 1.804530] tegra_wdt_t18x 2190000.watchdog: Registered successfully
[ 1.812191] Registered efivars operations
[ 1.816330] FPGA manager framework
[ 1.819761] Advanced Linux Sound Architecture Driver Initialized.
[ 1.826135] Bluetooth: Core ver 2.22
[ 1.829715] NET: Registered protocol family 31
[ 1.834157] Bluetooth: HCI device and connection manager initialized
[ 1.840512] Bluetooth: HCI socket layer initialized
[ 1.845391] Bluetooth: L2CAP socket layer initialized
[ 1.850447] Bluetooth: SCO socket layer initialized
[ 1.855838] camchar: rtcpu character device driver loaded
[ 1.861487] clocksource: Switched to clocksource arch_sys_counter
[ 2.025153] VFS: Disk quotas dquot_6.6.0
[ 2.029119] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 2.036316] pnp: PnP ACPI: disabled
[ 2.042175] la/ptsa driver initialized.
[ 2.046078] NET: Registered protocol family 2
[ 2.050647] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 2.060435] tcp_listen_portaddr_hash hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 2.069212] TCP established hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 2.077801] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 2.085725] TCP: Hash tables configured (established 524288 bind 65536)
[ 2.092443] UDP hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 2.099511] UDP-Lite hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 2.107106] NET: Registered protocol family 1
[ 2.111753] RPC: Registered named UNIX socket transport module.
[ 2.117682] RPC: Registered udp transport module.
[ 2.122385] RPC: Registered tcp transport module.
[ 2.127085] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 2.133537] PCI: CLS 0 bytes, default 64
[ 2.137607] Trying to unpack rootfs image as initramfs…
[ 2.272488] Freeing initrd memory: 9552K
[ 2.278648] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 2.286613] kvm [1]: IPA Size Limit: 48 bits
[ 2.290906] kvm [1]: GICv3: no GICV resource entry
[ 2.295699] kvm [1]: disabling GICv2 emulation
[ 2.300159] kvm [1]: GIC system register CPU interface enabled
[ 2.306099] kvm [1]: vgic interrupt IRQ9
[ 2.310174] kvm [1]: VHE mode initialized successfully
[ 2.316003] Initialise system trusted keyrings
[ 2.320535] workingset: timestamp_bits=46 max_order=24 bucket_order=0
[ 2.329393] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.335579] NFS: Registering the id_resolver key type
[ 2.340649] Key type id_resolver registered
[ 2.344828] Key type id_legacy registered
[ 2.348875] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 2.355583] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 2.362992] ntfs: driver 2.1.32 [Flags: R/W].
[ 2.379164] NET: Registered protocol family 38
[ 2.383611] Key type asymmetric registered
[ 2.387705] Asymmetric key parser ‘x509’ registered
[ 2.392597] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 239)
[ 2.400057] io scheduler mq-deadline registered
[ 2.404589] io scheduler kyber registered
[ 2.412743] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 2.418346] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 2.423935] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 2.429522] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 2.437634] tegra_dc_assign_hw_data: no matching compatible node
[ 2.443642] tegradccommon module_init failed
[ 2.447912] tegradc module_init failed
[ 2.451921] EINJ: ACPI disabled.
[ 2.456767] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 2.463648] tegra-pmc: ### PMC reset source: SYS_RESET_N
[ 2.468960] tegra-pmc: ### PMC reset level: L0
[ 2.473399] tegra-pmc: ### PMC reset status reg: 0x0
[ 2.479772] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 4.137922] printk: console [ttyTCU0] enabled
[ 4.147100] arm-smmu 12000000.iommu: probing hardware configuration…
[ 4.155108] arm-smmu 12000000.iommu: SMMUv2 with:
[ 4.159956] arm-smmu 12000000.iommu: stage 1 translation
[ 4.165498] arm-smmu 12000000.iommu: stage 2 translation
[ 4.171036] arm-smmu 12000000.iommu: nested translation
[ 4.176494] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 4.183901] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
[ 4.192972] arm-smmu 12000000.iommu: Supported page sizes: 0x00001000
[ 4.199671] arm-smmu 12000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 4.206354] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 4.213895] arm-smmu 10000000.iommu: probing hardware configuration…
[ 4.220594] arm-smmu 10000000.iommu: SMMUv2 with:
[ 4.225411] arm-smmu 10000000.iommu: stage 1 translation
[ 4.230943] arm-smmu 10000000.iommu: stage 2 translation
[ 4.236484] arm-smmu 10000000.iommu: nested translation
[ 4.241944] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 4.249360] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 only)
[ 4.258412] arm-smmu 10000000.iommu: Supported page sizes: 0x00001000
[ 4.265114] arm-smmu 10000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 4.271805] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 4.278927] arm-smmu 8000000.iommu: probing hardware configuration…
[ 4.285540] arm-smmu 8000000.iommu: SMMUv2 with:
[ 4.290269] arm-smmu 8000000.iommu: stage 1 translation
[ 4.295721] arm-smmu 8000000.iommu: stage 2 translation
[ 4.301171] arm-smmu 8000000.iommu: nested translation
[ 4.306528] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 4.313847] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 4.322744] arm-smmu 8000000.iommu: Supported page sizes: 0x00001000
[ 4.329360] arm-smmu 8000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 4.335973] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 4.343451] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[ 4.353770] tegra_profiler: version: 1.151, samples/io: 51/30
[ 4.359725] tegra_profiler: auth: init
[ 4.363907] nvsciipc: loaded module
[ 4.369131] tun: Universal TUN/TAP device driver, 1.6
[ 4.374808] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 4.382241] hns3: Copyright (c) 2017 Huawei Corporation.
[ 4.387727] e1000e: Intel(R) PRO/1000 Network Driver
[ 4.392817] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 4.398922] igb: Intel(R) Gigabit Ethernet Network Driver
[ 4.404457] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 4.410368] PPP generic driver version 2.4.2
[ 4.414806] PPP BSD Compression module registered
[ 4.419643] PPP Deflate Compression module registered
[ 4.424840] PPP MPPE Compression module registered
[ 4.429775] usbcore: registered new interface driver r8152
[ 4.435413] usbcore: registered new interface driver asix
[ 4.440957] usbcore: registered new interface driver ax88179_178a
[ 4.447228] usbcore: registered new interface driver cdc_ether
[ 4.453224] usbcore: registered new interface driver net1080
[ 4.459044] usbcore: registered new interface driver cdc_subset
[ 4.465124] usbcore: registered new interface driver zaurus
[ 4.470869] usbcore: registered new interface driver cdc_ncm
[ 4.476685] usbcore: registered new interface driver aqc111
[ 4.482524] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 4.488875] ohci-pci: OHCI PCI platform driver
[ 4.493445] ohci-platform: OHCI generic platform driver
[ 4.499118] tegra-xusb 3610000.xhci: Adding to iommu group 0
[ 4.505477] usbcore: registered new interface driver uas
[ 4.510957] usbcore: registered new interface driver usb-storage
[ 4.517272] tegra-xudc 3550000.xudc: Adding to iommu group 1
[ 4.523410] mousedev: PS/2 mouse device common for all mice
[ 4.529156] usbcore: registered new interface driver xpad
[ 4.536562] tegra_rtc c2a0000.rtc: registered as rtc1
[ 4.542029] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:25 UTC (25)
[ 4.550256] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 4.556678] i2c /dev entries driver
[ 4.560316] tegra-i2c 3160000.i2c: Adding to iommu group 2
[ 4.566185] tegra-i2c c240000.i2c: Adding to iommu group 2
[ 4.571892] tegra-i2c 3180000.i2c: Adding to iommu group 2
[ 4.577560] tegra-i2c 3190000.i2c: Adding to iommu group 2
[ 4.583238] tegra-i2c 31c0000.i2c: Adding to iommu group 2
[ 4.588914] tegra-i2c c250000.i2c: Adding to iommu group 2
[ 4.594592] tegra-i2c 31e0000.i2c: Adding to iommu group 2
[ 4.600339] tegra-i2c 31b0000.i2c: Adding to iommu group 2
[ 4.610657] device-mapper: uevent: version 1.0.3
[ 4.615504] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[ 4.625398] sdhci: Secure Digital Host Controller Interface driver
[ 4.631747] sdhci: Copyright(c) Pierre Ossman
[ 4.636212] Synopsys Designware Multimedia Card Interface Driver
[ 4.642449] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.648436] sdhci-tegra 3460000.sdhci: Adding to iommu group 3
[ 4.648663] sdhci-tegra 3400000.sdhci: Adding to iommu group 4
[ 4.648873] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401
[ 4.650383] tegra-bpmp bpmp: firmware: 6969245516d6bf7e0f23-925eece486b
[ 4.652084] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9
[ 4.652872] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x81
[ 4.659335] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[ 4.689999] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful
ÿᣥbugfs initialized
ÿ٠ 5.944384] hid: raw HID events driver (C) Jiri Kosina
[ 5.950223] usbcore: registered new interface driver usbhid
[ 5.956008] usbhid: USB HID core driver
[ 5.960775] tegra-dce d800000.dce: Adding to iommu group 5
[ 5.969510] dce: dce_ipc_channel_init:319 Invalid Channel State [0x0] for ch_type [2]
[ 5.978817] tegra234-aon c000000.aon: Adding to iommu group 6
[ 5.985254] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x5]
[ 5.994298] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [0]. Ignored…
[ 5.994301] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x5]
[ 5.996188] c000000.aon:hsp: probed
[ 6.003077] tegra234-aon c000000.aon: init done
[ 6.012076] dce: dce_admin_send_cmd_ver:424 version : [0x2] err : [0x0]
[ 6.016118] tegra23x-psc e860000.psc: Adding to iommu group 7
[ 6.020926] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x1]
[ 6.027856] tegra23x-psc e860000.psc: ext_cfg base:(ptrval)
[ 6.033264] dce: dce_admin_setup_clients_ipc:553 Channel Reset Complete for Type [1] …
[ 6.033267] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [1]. Ignored…
[ 6.033281] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [1]. Ignored…
[ 6.042241] tegra23x-psc e860000.psc: init done
[ 6.048678] dce: dce_admin_setup_clients_ipc:529 Get queue info failed for [2]
[ 6.057648] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 8
[ 6.066054] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x2]
[ 6.075558] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 6.079430] dce: dce_admin_setup_clients_ipc:553 Channel Reset Complete for Type [3] …
[ 6.079433] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [3]. Ignored…
[ 6.079444] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [3]. Ignored…
[ 6.137066] dce: dce_start_boot_flow:173 DCE_BOOT_DONE
[ 6.139055] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[ 6.151683] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 6.163449] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[ 6.174885] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[ 6.186640] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[ 6.199265] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[ 6.212111] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[ 6.223986] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (127)
[ 6.230836] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 6.239231] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=8676d22a01443bdbc66581b7dde3b6d6828cc925
[ 6.239234] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 6.239247] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 6.252674] t19x_cache tegra-cache: probed
[ 6.257585] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 6.257588] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 6.283042] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[ 6.298651] optee: probing for conduit method.
ÿ٠ 6.303263] optee: revision 3.21 (d8269f24)
[ 6.362058] optee: dynamic shared memory is enabled
[ 6.371500] optee: initialized driver
[ 6.390285] nvpmodel: initialized successfully
[ 6.394979] tegra_hv: get_hvd: not initialized yet
[ 6.399920] user_ivc_mempool: hypervisor not present
[ 6.405768] usbcore: registered new interface driver snd-usb-audio
[ 6.412925] u32 classifier
[ 6.415738] input device check on
[ 6.419516] Actions configured
[ 6.423170] Initializing XFRM netlink socket
[ 6.428038] NET: Registered protocol family 10
[ 6.434763] Segment Routing with IPv6
[ 6.438595] NET: Registered protocol family 17
[ 6.443189] NET: Registered protocol family 15
[ 6.447820] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 6.462348] Bluetooth: RFCOMM socket layer initialized
[ 6.467695] Bluetooth: RFCOMM ver 1.11
[ 6.471575] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 6.477717] Bluetooth: HIDP socket layer initialized
[ 6.484277] 9pnet: Installing 9P2000 support
[ 6.488769] Key type dns_resolver registered
[ 6.494451] registered taskstats version 1
[ 6.498701] Loading compiled-in X.509 certificates
[ 6.515897] Loaded X.509 cert ‘Build time autogenerated kernel key: 7709df064423cb7bb9cc370db4278f98ce05cf32’
[ 6.526672] tegra194-pcie 14100000.pcie: Adding to iommu group 9
[ 6.539545] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 6.546816] tegra194-pcie 14160000.pcie: Adding to iommu group 10
[ 6.559592] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 6.566602] tegra194-pcie 141a0000.pcie: Adding to iommu group 11
[ 6.579098] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 6.612944] tegra-soc-hwpm f100000.tegra_soc_hwpm: Adding to iommu group 12
[ 6.625267] host1x 13e40000.host1x: Adding to iommu group 13
[ 6.654732] host1x 13e40000.host1x: initialized
[ 6.659877] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu group 14
[ 6.668091] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (streamid=53, iommu=smmu.0x0000000012000000)
[ 6.680134] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu group 15
[ 6.688277] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (streamid=54, iommu=smmu.0x0000000012000000)
[ 6.700297] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu group 16
[ 6.708395] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (streamid=55, iommu=smmu.0x0000000012000000)
[ 6.720421] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu group 17
[ 6.728561] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[ 6.740647] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu group 18
[ 6.748746] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[ 6.760756] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu group 19
[ 6.768860] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[ 6.780926] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu group 20
[ 6.789075] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[ 6.801107] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu group 21
[ 6.809298] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[ 6.821354] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu group 22
[ 6.829525] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (streamid=53, iommu=smmu.0x0000000008000000)
[ 6.841563] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu group 23
[ 6.849743] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (streamid=54, iommu=smmu.0x0000000008000000)
[ 6.861792] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu group 24
[ 6.869899] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (streamid=55, iommu=smmu.0x0000000008000000)
[ 6.881918] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu group 25
[ 6.890024] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (streamid=56, iommu=smmu.0x0000000008000000)
[ 6.902032] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu group 26
[ 6.910162] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (streamid=57, iommu=smmu.0x0000000008000000)
[ 6.922182] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu group 27
[ 6.930328] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (streamid=58, iommu=smmu.0x0000000008000000)
[ 6.942376] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu group 28
[ 6.950512] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (streamid=59, iommu=smmu.0x0000000008000000)
[ 6.962562] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu group 29
[ 6.970674] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (streamid=60, iommu=smmu.0x0000000008000000)
[ 6.982761] falcon 15340000.vic: Adding to iommu group 30
[ 6.993541] falcon 15340000.vic: initialized
[ 6.998256] falcon 15380000.nvjpg: Adding to iommu group 31
[ 7.007407] falcon 15380000.nvjpg: initialized
[ 7.012110] falcon 15540000.nvjpg1: Adding to iommu group 32
[ 7.021818] falcon 15540000.nvjpg1: initialized
[ 7.026620] falcon 154c0000.nvenc: Adding to iommu group 33
[ 7.037751] falcon 154c0000.nvenc: initialized
[ 7.042475] falcon 15a50000.ofa: Adding to iommu group 34
[ 7.051429] falcon 15a50000.ofa: initialized
[ 7.055983] nvdec 15480000.nvdec: Adding to iommu group 35
[ 7.068492] nvdec 15480000.nvdec: initialized
[ 7.073116] tsec 15500000.tsec: Adding to iommu group 36
[ 7.083696] tsec 15500000.tsec: initialized
[ 7.091017] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 7.108450] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 7.128750] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio
[ 7.136096] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon
[ 7.143105] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 7.149617] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 7.156082] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 7.162530] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 7.170978] tegra194-isp5 14800000.isp: Adding to iommu group 37
[ 7.180469] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[ 7.190206] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized
[ 7.196781] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[ 7.206042] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[ 7.215290] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[ 7.224575] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[ 7.233860] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[ 7.243117] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[ 7.252365] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[ 7.261627] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[ 7.270889] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[ 7.280173] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[ 7.289435] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[ 7.298693] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[ 7.308145] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group 38
[ 7.316430] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group 39
[ 7.324512] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: context isolation disabled due to no IOMMU
[ 7.334555] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized
[ 7.341393] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: context isolation disabled due to no IOMMU
[ 7.351383] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized
[ 7.358192] scare-pigeon 13e40000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[ 7.368161] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized
[ 7.375018] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: Adding to iommu group 40
[ 7.383801] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: initialized (streamid=18, iommu=smmu.0x0000000008000000)
[ 7.395215] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: Adding to iommu group 41
[ 7.403986] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: initialized (streamid=19, iommu=smmu.0x0000000008000000)
[ 7.415389] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: Adding to iommu group 42
[ 7.424128] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: initialized (streamid=20, iommu=smmu.0x0000000008000000)
[ 7.435554] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: Adding to iommu group 43
[ 7.444312] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: initialized (streamid=21, iommu=smmu.0x0000000008000000)
[ 7.455687] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: Adding to iommu group 44
[ 7.464455] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: initialized (streamid=22, iommu=smmu.0x0000000008000000)
[ 7.475877] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: Adding to iommu group 45
[ 7.484608] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: initialized (streamid=23, iommu=smmu.0x0000000008000000)
[ 7.495981] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: Adding to iommu group 46
[ 7.504764] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: initialized (streamid=24, iommu=smmu.0x0000000008000000)
[ 7.516184] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: Adding to iommu group 47
[ 7.524931] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: initialized (streamid=25, iommu=smmu.0x0000000008000000)
[ 7.536339] pva 16000000.pva0: Adding to iommu group 48
[ 7.561332] pva 16000000.pva0: initialized
[ 7.570716] nvdla 15880000.nvdla0: Adding to iommu group 49
[ 7.586168] nvdla 15880000.nvdla0: initialized
[ 7.592565] nvdla 158c0000.nvdla1: Adding to iommu group 50
[ 7.606746] nvdla 158c0000.nvdla1: initialized
[ 7.613056] tegra-gpcdma 2600000.gpcdma: Adding to iommu group 2
[ 7.620146] tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels
[ 7.627726] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[ 7.634389] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[ 7.641176] serial-tegra 3100000.serial: Adding to iommu group 2
[ 7.647864] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 26, base_baud = 0) is a TEGRA_UART
[ 7.657655] serial-tegra 3110000.serial: Adding to iommu group 2
[ 7.664290] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 85, base_baud = 0) is a TEGRA_UART
[ 7.674023] serial-tegra 3130000.serial: Adding to iommu group 2
[ 7.680534] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 86, base_baud = 0) is a TEGRA_UART
[ 7.690179] serial-tegra 3140000.serial: Adding to iommu group 2
[ 7.696680] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 87, base_baud = 0) is a TEGRA_UART
[ 7.723497] tegra-xusb 3610000.xhci: Firmware timestamp: 2023-02-10 03:48:10 UTC, Version: 80.05 release
[ 7.733279] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 7.738884] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 7.747546] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000050810
[ 7.757192] tegra-xusb 3610000.xhci: irq 244, io mem 0x03610000
[ 7.763700] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 7.772254] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.779735] usb usb1: Product: xHCI Host Controller
[ 7.784784] usb usb1: Manufacturer: Linux 5.10.120-tegra xhci-hcd
[ 7.791079] usb usb1: SerialNumber: 3610000.xhci
[ 7.796585] hub 1-0:1.0: USB hub found
[ 7.800501] hub 1-0:1.0: 4 ports detected
[ 7.804923] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 7.810482] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 7.818310] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 7.825836] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 7.834373] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.841836] usb usb2: Product: xHCI Host Controller
[ 7.846891] usb usb2: Manufacturer: Linux 5.10.120-tegra xhci-hcd
[ 7.853179] usb usb2: SerialNumber: 3610000.xhci
[ 7.858506] hub 2-0:1.0: USB hub found
[ 7.862392] hub 2-0:1.0: 4 ports detected
[ 7.868690] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 7.898736] tegra23x-oc-event soctherm-oc-event: Finished tegra23x overcurrent event probing
[ 7.924499] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 2008000 KHz, changing to: 2035200 KHz
[ 7.937232] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 2009000 KHz, changing to: 2035200 KHz
[ 7.949971] cpufreq: cpufreq_online: CPU8: Running at unlisted initial frequency: 2009000 KHz, changing to: 2035200 KHz
[ 7.961829] tegra194-cpufreq e000000.ccplex: probed with ICC, cl:3
[ 7.969201] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 7.974618] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 7.976378] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[ 7.981321] mmc0: CQHCI version 5.10
[ 7.987758] tegra194-pcie 14100000.pcie: IO 0x0030100000…0x00301fffff → 0x0030100000
[ 7.987763] tegra194-pcie 14100000.pcie: MEM 0x20a8000000…0x20afffffff → 0x0040000000
[ 7.989935] irq: IRQ311: trimming hierarchy from :interrupt-controller@f400000-1
[ 7.989974] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 311
[ 8.020724] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit
[ 8.022781] tegra194-pcie 14100000.pcie: MEM 0x2080000000…0x20a7ffffff → 0x2080000000
[ 8.127510] mmc0: Command Queue Engine enabled
[ 8.132083] mmc0: periodic cache flush enabled
[ 8.136659] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 8.143761] mmcblk0: mmc0:0001 G1M15M 59.3 GiB
[ 8.148638] mmcblk0rpmb: mmc0:0001 G1M15M partition 3 4.00 MiB, chardev (510:0)
[ 8.166380] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[ 9.131036] tegra194-pcie 14100000.pcie: Phy link never came up
[ 9.137199] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[ 9.144017] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 9.149664] pci_bus 0001:00: root bus resource [io 0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[ 9.159514] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[ 9.170354] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[ 9.178288] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[ 9.184644] pci 0001:00:00.0: PME# supported from D0 D3hot
[ 9.197805] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 9.203194] pci 0001:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 9.212156] pcieport 0001:00:00.0: Adding to iommu group 9
[ 9.218024] pcieport 0001:00:00.0: PME: Signaling with IRQ 64
[ 9.224405] pcieport 0001:00:00.0: AER: enabled with IRQ 64
[ 9.230530] pci_bus 0001:01: busn_res: [bus 01-ff] is released
[ 9.236617] pci 0001:00:00.0: Removing from iommu group 9
[ 9.242174] pci_bus 0001:00: busn_res: [bus 00-ff] is released
[ 9.249991] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 9.257418] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[ 9.264602] tegra194-pcie 14160000.pcie: IO 0x0036100000…0x00361fffff → 0x0036100000
[ 9.273299] tegra194-pcie 14160000.pcie: MEM 0x2428000000…0x242fffffff → 0x0040000000
[ 9.281994] tegra194-pcie 14160000.pcie: MEM 0x2140000000…0x2427ffffff → 0x2140000000
[ 9.397627] tegra194-pcie 14160000.pcie: Link up
[ 9.405739] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 9.412540] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 9.418171] pci_bus 0004:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[ 9.428291] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[ 9.439121] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[ 9.447047] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[ 9.453362] pci 0004:00:00.0: PME# supported from D0 D3hot
[ 9.463102] pci 0004:01:00.0: [144d:a808] type 00 class 0x010802
[ 9.469450] pci 0004:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 9.481737] pci 0004:00:00.0: BAR 14: assigned [mem 0x2428000000-0x24280fffff]
[ 9.489169] pci 0004:01:00.0: BAR 0: assigned [mem 0x2428000000-0x2428003fff 64bit]
[ 9.497138] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 9.502518] pci 0004:00:00.0: bridge window [mem 0x2428000000-0x24280fffff]
[ 9.509882] pci 0004:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 9.518618] pci 0004:01:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 512
[ 9.527544] pcieport 0004:00:00.0: Adding to iommu group 10
[ 9.533513] pcieport 0004:00:00.0: PME: Signaling with IRQ 66
[ 9.539669] pcieport 0004:00:00.0: AER: enabled with IRQ 66
[ 9.545704] nvme 0004:01:00.0: Adding to iommu group 10
[ 9.551503] nvme nvme0: pci function 0004:01:00.0
[ 9.556572] nvme 0004:01:00.0: enabling device (0000 → 0002)
[ 9.557134] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 9.569345] avdd-cam-2v8: supplied by vdd-3v3-sys
[ 9.574310] vdd-dp: supplied by vdd-3v3-sys
[ 9.578788] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 9.583803] dsi-vdd-1v8-bl-en: supplied by vdd-1v8-sys
[ 9.591340] tegra194-isp5 14800000.isp: initialized
[ 9.600423] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized
[ 9.606876] (NULL device *): fops function table already registered
[ 9.615259] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized
[ 9.621858] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 9.628806] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 9.628995] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 9.642852] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 311
[ 9.747293] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[ 9.754465] tegra194-pcie 141a0000.pcie: IO 0x003a100000…0x003a1fffff → 0x003a100000
[ 9.763149] tegra194-pcie 141a0000.pcie: MEM 0x2b28000000…0x2b2fffffff → 0x0040000000
[ 9.771827] tegra194-pcie 141a0000.pcie: MEM 0x2740000000…0x2b27ffffff → 0x2740000000
[ 10.376866] random: crng init done
[ 10.380673] tegra-xusb 3610000.xhci: entering ELPG done
[ 10.702715] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit
[ 10.891040] tegra194-pcie 141a0000.pcie: Phy link never came up
[ 10.897193] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[ 10.904010] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 10.909656] pci_bus 0005:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x3a100000-0x3a1fffff])
[ 10.919777] pci_bus 0005:00: root bus resource [mem 0x2b28000000-0x2b2fffffff] (bus address [0x40000000-0x47ffffff])
[ 10.930615] pci_bus 0005:00: root bus resource [mem 0x2740000000-0x2b27ffffff pref]
[ 10.938540] pci 0005:00:00.0: [10de:229a] type 01 class 0x060400
[ 10.944874] pci 0005:00:00.0: PME# supported from D0 D3hot
[ 10.957993] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 10.963381] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 10.972324] pcieport 0005:00:00.0: Adding to iommu group 11
[ 10.978271] pcieport 0005:00:00.0: PME: Signaling with IRQ 68
[ 10.984656] pcieport 0005:00:00.0: AER: enabled with IRQ 68
[ 10.990602] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[ 10.996688] pci 0005:00:00.0: Removing from iommu group 11
[ 11.002354] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[ 11.009625] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 11.016317] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 11.023245] nvethernet 2310000.ethernet: Adding to iommu group 51
[ 11.029678] nvethernet 2310000.ethernet: failed to read skip mac reset flag, default 0
[ 11.037845] nvethernet 2310000.ethernet: failed to read MDIO address
[ 11.044398] nvethernet 2310000.ethernet: setting to default DMA bit mask
[ 11.051332] nvethernet 2310000.ethernet: missing nvidia,pad_auto_cal_pu_offset, setting default 0
[ 11.060463] nvethernet 2310000.ethernet: missing nvidia,pad_auto_cal_pd_offset, setting default 0
[ 11.318797] nvethernet 2310000.ethernet: Ethernet MAC address: 48:b0:2d:e4:e0:e3
[ 11.326722] nvethernet 2310000.ethernet: macsec param in DT is missing or disabled
[ 11.334520] nvethernet 2310000.ethernet: Macsec not supported/Not enabled in DT
[ 11.344612] nvethernet 2310000.ethernet: eth0 (HW ver: 53) created with 8 DMA channels
[ 11.353017] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 11.359523] nvethernet 6810000.ethernet: Adding to iommu group 52
[ 11.366124] nvethernet 6810000.ethernet: failed to read skip mac reset flag, default 0
[ 11.374280] nvethernet 6810000.ethernet: failed to read MDIO address
[ 11.380834] nvethernet 6810000.ethernet: setting to default DMA bit mask
[ 11.387746] nvethernet 6810000.ethernet: failed to read UPHY GBE mode- default to 10G
[ 11.621479] [RCE] WARNING: core/hsp/hsp-vm.c:283 [camrtc_hsp_full_ss_isr] “VM0 issued IVC in inactive state.”
[ 11.631667] [RCE] WARNING: core/hsp/hsp-vm.c:283 [camrtc_hsp_full_ss_isr] “VM0 issued IVC in inactive state.”
[ 11.641875] [RCE] WARNING: core/hsp/hsp-vm.c:283 [camrtc_hsp_full_ss_isr] “VM0 issued IVC in inactive state.”
[ 11.786679] nvethernet 6810000.ethernet: Ethernet MAC address: 48:b0:2d:e4:e0:e3
[ 11.794614] nvethernet 6810000.ethernet: macsec param in DT is missing or disabled
[ 11.802399] nvethernet 6810000.ethernet: Macsec not supported/Not enabled in DT
[ 11.814860] nvethernet 6810000.ethernet: eth1 (HW ver: 31) created with 10 DMA channels
[ 11.823658] irq: IRQ314: trimming hierarchy from :pmc@c360000
[ 11.829635] irq: IRQ315: trimming hierarchy from :interrupt-controller@f400000-1
[ 11.837315] irq: IRQ316: trimming hierarchy from :pmc@c360000
[ 11.843369] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 11.845564] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 11.857040] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 11.862070] tegra-se-nvhost 15810000.se: Adding to iommu group 53
[ 11.869952] tegra-se-nvhost 15810000.se: initialized
[ 11.886096] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 11.892584] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 11.897659] tegra-se-nvhost 15820000.se: Adding to iommu group 54
[ 11.905415] tegra-se-nvhost 15820000.se: initialized
[ 11.911582] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 11.918118] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 11.924503] tegra-se-nvhost 15840000.se: Adding to iommu group 55
[ 11.931083] tegra-se-nvhost 15840000.se: initialized
[ 11.939023] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 11.945511] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 11.946212] tegra_actmon d230000.actmon: in actmon_register()…
[ 11.958267] tegra_actmon d230000.actmon: bwmgr_disable = 1
[ 11.964629] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[ 11.973058] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 11.977620] hvc_sysfs: hypervisor is not present
[ 11.987160] nvme nvme0: Shutdown timeout set to 8 seconds
ÿᖁRNING: clock_disable: clk_power_ungate on gated domain 35 for gpusysclk
ÿ٠ 12.013924] nvme nvme0: 12/0/0 default/read/poll queues
[ 12.028442] nvme0n1: p1
ÿᖁRNING: clock_disable: clk_power_ungate on gated domain 35 for gpc1clk
WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpc0clk
ÿ٠ 12.114688] ALSA device list:
[ 12.117750] No soundcards found.
[ 12.121838] Freeing unused kernel memory: 3968K
[ 12.126571] Run /init as init process
[ 12.141841] Root device found: PARTUUID=3f637458-9482-40f4-bee0-eeb146aa5cca
[ 12.645308] EXT4-fs (mmcblk0p1): 2 orphan inodes deleted
[ 12.650813] EXT4-fs (mmcblk0p1): recovery complete
[ 12.660789] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 12.674458] Rootfs mounted over PARTUUID=3f637458-9482-40f4-bee0-eeb146aa5cca
[ 12.693228] Switching from initrd to actual rootfs
[ 12.817629] systemd[1]: System time before build time, advancing clock.
[ 12.842673] x_tables: module verification failed: signature and/or required key missing - tainting kernel
[ 12.877316] systemd[1]: systemd 245.4-4ubuntu3.21 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 12.900996] systemd[1]: Detected architecture arm64.
[ 12.942171] systemd[1]: Set hostname to .
[ 13.132433] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 13.145508] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 13.155254] systemd[1]: Created slice system-modprobe.slice.
[ 13.161587] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 13.168421] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 13.175341] systemd[1]: Created slice User and Session Slice.
[ 13.181387] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 13.189536] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 13.199349] systemd[1]: Reached target User and Group Name Lookups.
[ 13.205864] systemd[1]: Reached target Slices.
[ 13.210490] systemd[1]: Reached target Swap.
[ 13.215167] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 13.222040] systemd[1]: Listening on Syslog Socket.
[ 13.227203] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 13.234214] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 13.241165] systemd[1]: Listening on Journal Audit Socket.
[ 13.246942] systemd[1]: Listening on Journal Socket (/dev/log).
[ 13.253210] systemd[1]: Listening on Journal Socket.
[ 13.258475] systemd[1]: Listening on udev Control Socket.
[ 13.264143] systemd[1]: Listening on udev Kernel Socket.
[ 13.270697] systemd[1]: Mounting Huge Pages File System…
[ 13.277453] systemd[1]: Mounting POSIX Message Queue File System…
[ 13.284923] systemd[1]: Mounting NFSD configuration filesystem…
[ 13.292235] systemd[1]: Mounting RPC Pipe File System…
[ 13.298845] systemd[1]: Mounting Kernel Debug File System…
[ 13.299090] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 13.312441] systemd[1]: Mounting Kernel Trace File System…
[ 13.319622] systemd[1]: Starting Journal Service…
[ 13.324787] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[ 13.342477] systemd[1]: Starting Set the console keyboard layout…
[ 13.350061] systemd[1]: Starting Create list of static device nodes for the current kernel…
[ 13.360228] systemd[1]: Starting Load Kernel Module chromeos_pstore…
[ 13.367142] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[ 13.376609] systemd[1]: Starting Load Kernel Module efi_pstore…
[ 13.383935] systemd[1]: Starting Load Kernel Module pstore_blk…
[ 13.391376] systemd[1]: Starting Load Kernel Module pstore_zone…
[ 13.398711] systemd[1]: Starting Load Kernel Module ramoops…
[ 13.405985] systemd[1]: Starting NVIDIA specific first-boot udev script…
[ 13.414123] systemd[1]: Started Nameserver information manager.
[ 13.420422] systemd[1]: Reached target Network (Pre).
[ 13.426654] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 13.436027] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 13.453523] systemd[1]: Starting Load Kernel Modules…
[ 13.460165] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 13.468147] systemd[1]: Starting udev Coldplug all Devices…
[ 13.468439] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 13.468661] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 13.468816] tegra-carveouts tegra-carveouts: fsi :dma coherent mem declare 0x0000001038e00000,16777216
[ 13.468819] tegra-carveouts tegra-carveouts: assigned reserved memory node fsi-carveout
[ 13.468824] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x0000001049800000,914358272
[ 13.468826] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 13.468833] nvmap_page_pool_init: Total RAM pages: 16077544
[ 13.468834] nvmap_page_pool_init: nvmap page pool size: 2009693 pages (3754 MB)
[ 13.468882] nvmap_background_zero_thread: PP zeroing thread starting.
[ 13.468981] misc nvmap: created heap vpr base 0x0000001049800000 size (892928KiB)
[ 13.472155] misc nvmap: created heap fsi base 0x0000001038e00000 size (16384KiB)
[ 13.472504] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 13.539691] nvgpu: 17000000.ga10b nvgpu_nvhost_syncpt_init:135 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[ 13.539691]
[ 13.580139] systemd[1]: Started Journal Service.
[ 13.610817] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 13.611894] systemd-journald[327]: Received client request to flush runtime journal.
[ 13.627477] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 13.636555] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 13.643098] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 13.877068] nvidia: loading out-of-tree module taints kernel.
[ 13.896756] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 13.923603] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 13.930305] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 13.954149] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 13.960835] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 13.975078] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 13.981864] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 13.988696] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 14.003867] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 14.017139] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 14.025179] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 14.032099] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 14.079451] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 14.095548] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 14.103151] ucsi_ccg 1-0008: i2c_transfer failed -121
[ 14.108376] ucsi_ccg 1-0008: ucsi_ccg_init failed - -121
[ 14.109386] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 14.115988] ucsi_ccg: probe of 1-0008 failed with error -121
[ 14.172357] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 14.180240] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 14.202311] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 14.224791] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 14.240379] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 14.429131] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 14.497053] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 15.133528] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 15.276406] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 15.977051] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 17.357227] Bridge firewalling registered
[ 17.477741] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 17.484799] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 17.492653] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 17.501147] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 17.507548] debugfs: Directory ‘imx185_e’ with parent ‘/’ already present!
[ 17.516575] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 17.524954] debugfs: Directory ‘imx185_d’ with parent ‘/’ already present!
[ 17.524988] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 17.539904] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 17.548031] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 17.554523] debugfs: Directory ‘imx185_c’ with parent ‘/’ already present!
[ 17.563261] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 17.571248] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 17.577711] debugfs: Directory ‘imx185_a’ with parent ‘/’ already present!
[ 17.586466] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 17.594330] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 17.600746] debugfs: Directory ‘imx185_g’ with parent ‘/’ already present!
[ 17.609524] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 17.617390] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
[ 17.623747] debugfs: Directory ‘imx185_b’ with parent ‘/’ already present!
[ 17.632517] tegra-xudc 3550000.xudc: failed to get usbphy-0: -517
Ubuntu 20.04.6 LTS xxk ttyTCU0
xxk login: [ 71.905471] rcu: INFO: rcu_preempt self-detected stall on CPU
[ 71.911388] rcu: 0-…: (1 GPs behind) idle=0a6/1/0x4000000000000008 softirq=3230/3231 fqs=1851
[ 71.920734] rcu: ====For debug only: Start Printing Blocked Tasks====<print_cpu_stall>
[ 71.928979] task:jbd2/mmcblk0p1- state:D stack: 0 pid: 285 ppid: 2 flags:0x00000028
[ 71.937559] Call trace:
[ 71.940086] __switch_to+0xc8/0x120
[ 71.943674] __schedule+0x3d0/0x910
[ 71.947259] schedule+0x78/0x110
[ 71.950584] jbd2_journal_commit_transaction+0x230/0x1e10
[ 71.956128] kjournald2+0xc4/0x270
[ 71.959622] kthread+0x148/0x170
[ 71.962944] ret_from_fork+0x10/0x24
[ 71.966646] task:rs:main Q:Reg state:D stack: 0 pid: 750 ppid: 1 flags:0x00000000
[ 71.975224] Call trace:
[ 71.977750] __switch_to+0xc8/0x120
[ 71.981338] __schedule+0x3d0/0x910
[ 71.984926] schedule+0x78/0x110
[ 71.988246] wait_transaction_locked+0x88/0xe0
[ 71.992804] add_transaction_credits+0x58/0x310
[ 71.997456] start_this_handle+0xf4/0x4a0
[ 72.001578] jbd2__journal_start+0x128/0x260
[ 72.005973] __ext4_journal_start_sb+0x184/0x1b0
[ 72.010723] ext4_da_write_begin+0x188/0x470
[ 72.015115] generic_perform_write+0xb4/0x1d0
[ 72.019595] ext4_buffered_write_iter+0xa4/0x180
[ 72.024343] ext4_file_write_iter+0x64/0x7a0
[ 72.028735] new_sync_write+0xfc/0x1a0
[ 72.032588] vfs_write+0x25c/0x390
[ 72.036085] ksys_write+0x7c/0x110
[ 72.039581] __arm64_sys_write+0x28/0x40
[ 72.043614] el0_svc_common.constprop.0+0x80/0x1d0
[ 72.048536] do_el0_svc+0x38/0xb0
[ 72.051945] el0_svc+0x1c/0x30
[ 72.055087] el0_sync_handler+0xa8/0xb0
[ 72.059032] el0_sync+0x16c/0x180
[ 72.062467] task:proxy-main state:D stack: 0 pid: 1673 ppid: 1362 flags:0x00000000
[ 72.071047] Call trace:
[ 72.073560] __switch_to+0xc8/0x120
[ 72.077146] __schedule+0x3d0/0x910
[ 72.080732] schedule+0x78/0x110
[ 72.084053] wait_transaction_locked+0x88/0xe0
[ 72.088619] add_transaction_credits+0x58/0x310
[ 72.093271] start_this_handle+0xf4/0x4a0
[ 72.097394] jbd2__journal_start+0x128/0x260
[ 72.101786] __ext4_journal_start_sb+0x184/0x1b0
[ 72.106530] ext4_dirty_inode+0x50/0xa0
[ 72.110473] __mark_inode_dirty+0x1d8/0x4b0
[ 72.114766] generic_update_time+0x74/0x100
[ 72.119066] inode_update_time+0x58/0x70
[ 72.123094] file_update_time+0xe0/0x120
[ 72.127121] file_modified+0x38/0x50
[ 72.130800] ext4_buffered_write_iter+0x6c/0x180
[ 72.130801] ext4_file_write_iter+0x64/0x7a0
[ 72.130807] new_sync_write+0xfc/0x1a0
[ 72.143800] vfs_write+0x25c/0x390
[ 72.143801] ksys_write+0x7c/0x110
[ 72.143802] __arm64_sys_write+0x28/0x40
[ 72.143805] el0_svc_common.constprop.0+0x80/0x1d0
[ 72.143806] do_el0_svc+0x38/0xb0
[ 72.143807] el0_svc+0x1c/0x30
[ 72.143808] el0_sync_handler+0xa8/0xb0
[ 72.143809] el0_sync+0x16c/0x180
[ 72.143832] task:pulseaudio state:D stack: 0 pid: 3287 ppid: 3278 flags:0x00000800
[ 72.173642] Call trace:
[ 72.184727] __switch_to+0xc8/0x120
[ 72.188316] __schedule+0x3d0/0x910
[ 72.191904] schedule+0x78/0x110
[ 72.195225] io_schedule+0x24/0xd0
[ 72.198720] wait_on_page_bit_common+0x170/0x3d0
[ 72.203467] generic_file_buffered_read+0x488/0xa40
[ 72.208481] generic_file_read_iter+0xf0/0x170
[ 72.213045] ext4_file_read_iter+0x5c/0x150
[ 72.217341] new_sync_read+0xfc/0x1a0
[ 72.221103] vfs_read+0x130/0x1c0
[ 72.224511] ksys_read+0x7c/0x110
[ 72.227920] __arm64_sys_read+0x28/0x40
[ 72.231863] el0_svc_common.constprop.0+0x80/0x1d0
[ 72.236789] do_el0_svc+0x38/0xb0
[ 72.240198] el0_svc+0x1c/0x30
[ 72.243339] el0_sync_handler+0xa8/0xb0
[ 72.247281] el0_sync+0x16c/0x180
[ 72.250692] task:tracker-miner-f state:D stack: 0 pid: 3289 ppid: 3278 flags:0x00000000
[ 72.259274] Call trace:
[ 72.261781] __switch_to+0xc8/0x120
[ 72.265369] __schedule+0x3d0/0x910
[ 72.268957] schedule+0x78/0x110
[ 72.272278] io_schedule+0x24/0xd0
[ 72.275761] bit_wait_io+0x20/0x60
[ 72.279257] __wait_on_bit_lock+0x88/0x190
[ 72.283473] out_of_line_wait_on_bit_lock+0xa8/0xe0
[ 72.288483] __lock_buffer+0x3c/0x80
[ 72.292155] do_get_write_access+0x78/0x4a0
[ 72.296447] jbd2_journal_get_write_access+0x6c/0xc0
[ 72.301543] __ext4_journal_get_write_access+0x80/0x130
[ 72.306909] ext4_reserve_inode_write+0x98/0xf0
[ 72.311565] __ext4_mark_inode_dirty+0x84/0x2d0
[ 72.316218] ext4_dirty_inode+0x78/0xa0
[ 72.320158] __mark_inode_dirty+0x1d8/0x4b0
[ 72.324454] generic_update_time+0x74/0x100
[ 72.328750] inode_update_time+0x58/0x70
[ 72.332780] touch_atime+0x1c0/0x260
[ 72.336455] generic_file_buffered_read+0x64c/0xa40
[ 72.341467] generic_file_read_iter+0xf0/0x170
[ 72.346031] ext4_file_read_iter+0x5c/0x150
[ 72.350322] new_sync_read+0xfc/0x1a0
[ 72.354084] vfs_read+0x130/0x1c0
[ 72.357493] ksys_pread64+0x88/0xd0
[ 72.361081] __arm64_sys_pread64+0x2c/0x40
[ 72.365295] el0_svc_common.constprop.0+0x80/0x1d0
[ 72.370223] do_el0_svc+0x38/0xb0
[ 72.373629] el0_svc+0x1c/0x30
[ 72.376772] el0_sync_handler+0xa8/0xb0
[ 72.380714] el0_sync+0x16c/0x180
[ 72.384156] task:kworker/u24:4 state:D stack: 0 pid: 3421 ppid: 2 flags:0x00000028
[ 72.392733] Workqueue: writeback wb_workfn (flush-179:0)
[ 72.398195] Call trace:
[ 72.400721] __switch_to+0xc8/0x120
[ 72.404308] __schedule+0x3d0/0x910
[ 72.407896] schedule+0x78/0x110
[ 72.411215] io_schedule+0x24/0xd0
[ 72.414711] bit_wait_io+0x20/0x60
[ 72.418207] __wait_on_bit_lock+0x88/0x190
[ 72.422412] out_of_line_wait_on_bit_lock+0xa8/0xe0
[ 72.427421] __lock_buffer+0x3c/0x80
[ 72.431096] do_get_write_access+0x78/0x4a0
[ 72.435388] jbd2_journal_get_write_access+0x6c/0xc0
[ 72.440484] __ext4_journal_get_write_access+0x80/0x130
[ 72.445848] ext4_reserve_inode_write+0x98/0xf0
[ 72.450504] __ext4_mark_inode_dirty+0x84/0x2d0
[ 72.455164] __ext4_ext_dirty.isra.0+0xac/0xf0
[ 72.459728] ext4_ext_insert_extent+0x47c/0x1430
[ 72.464471] ext4_ext_map_blocks+0x53c/0x1020
[ 72.468948] ext4_map_blocks+0x194/0x5d0
[ 72.472975] ext4_writepages+0x814/0xdc0
[ 72.477004] do_writepages+0x5c/0x110
[ 72.480763] __writeback_single_inode+0x4c/0x510
[ 72.485511] writeback_sb_inodes+0x210/0x4b0
[ 72.489901] __writeback_inodes_wb+0x58/0x110
[ 72.494379] wb_writeback+0x26c/0x410
[ 72.498140] wb_workfn+0x2d8/0x600
[ 72.501637] process_one_work+0x1c4/0x4a0
[ 72.505764] worker_thread+0x54/0x430
[ 72.509530] kthread+0x148/0x170
[ 72.512852] ret_from_fork+0x10/0x24
[ 72.516526] task:gnome-shell state:D stack: 0 pid: 3440 ppid: 3404 flags:0x00000000
[ 72.525106] Call trace:
[ 72.527633] __switch_to+0xc8/0x120
[ 72.531222] __schedule+0x3d0/0x910
[ 72.534808] schedule+0x78/0x110
[ 72.538127] io_schedule+0x24/0xd0
[ 72.541621] bit_wait_io+0x20/0x60
[ 72.545115] __wait_on_bit+0x80/0xf0
[ 72.548790] out_of_line_wait_on_bit+0xa8/0xe0
[ 72.553356] __wait_on_buffer+0x40/0x50
[ 72.557298] __ext4_find_entry+0x2c8/0x400
[ 72.561514] ext4_lookup+0x94/0x240
[ 72.565103] path_openat+0x3d4/0xde0
[ 72.568778] do_filp_open+0x88/0x110
[ 72.572458] do_sys_openat2+0x1fc/0x2b0
[ 72.576397] do_sys_open+0x80/0xd0
[ 72.579893] __arm64_sys_openat+0x30/0x40
[ 72.584020] el0_svc_common.constprop.0+0x80/0x1d0
[ 72.588942] do_el0_svc+0x38/0xb0
[ 72.592350] el0_svc+0x1c/0x30
[ 72.595493] el0_sync_handler+0xa8/0xb0
[ 72.599436] el0_sync+0x16c/0x180
[ 72.602848] task:cat state:D stack: 0 pid: 3606 ppid: 3101 flags:0x00000000
[ 72.611432] Call trace:
[ 72.613945] __switch_to+0xc8/0x120
[ 72.617532] __schedule+0x3d0/0x910
[ 72.621118] schedule+0x78/0x110
[ 72.624438] schedule_timeout+0x2dc/0x340
[ 72.628556] wait_for_completion+0x8c/0x120
[ 72.632849] __flush_work.isra.0+0x108/0x220
[ 72.632850] flush_work+0x24/0x30
[ 72.632852] tegra194_get_speed+0x8c/0x1c0
[ 72.632855] cpufreq_verify_current_freq+0x4c/0x100
[ 72.632860] __cpufreq_get+0x40/0x60
[ 72.653562] show_cpuinfo_cur_freq+0x28/0x80
[ 72.653564] show+0x50/0x80
[ 72.653565] sysfs_kf_seq_show+0x90/0x130
[ 72.653566] kernfs_seq_show+0x48/0x60
[ 72.653568] seq_read_iter+0x1d4/0x490
[ 72.653569] kernfs_fop_read_iter+0x154/0x1d0
[ 72.653570] new_sync_read+0xfc/0x1a0
[ 72.653571] vfs_read+0x130/0x1c0
[ 72.653572] ksys_read+0x7c/0x110
[ 72.653573] __arm64_sys_read+0x28/0x40
[ 72.653577] el0_svc_common.constprop.0+0x80/0x1d0
[ 72.696597] do_el0_svc+0x38/0xb0
[ 72.696598] el0_svc+0x1c/0x30
[ 72.696599] el0_sync_handler+0xa8/0xb0
[ 72.696602] el0_sync+0x16c/0x180
[ 72.710505] rcu: ====For debug only: End Printing Blocked Tasks====<print_cpu_stall>
[ 96.501470] watchdog: BUG: soft lockup - CPU#0 stuck for 22s! [swapper/0:0]
[ 96.508639] Modules linked in: fuse(E) nvidia_modeset(OE) xt_conntrack(E) xt_MASQUERADE(E) nf_conntrack_netlink(E) nfnetlink(E) nv_imx185(E) tztek_camera_driver(E) tztek_max9296(E) max9296_class(E) iptable_nat(E) nf_nat(E) nf_conntrack(E) nf_defrag_ipv6(E) nf_defrag_ipv4(E) libcrc32c(E) xt_addrtype(E) iptable_filter(E) br_netfilter(E) lzo_rle(E) lzo_compress(E) zram(E) overlay(E) ramoops(E) reed_solomon(E) loop(E) snd_soc_tegra186_asrc(E) snd_soc_tegra186_dspk(E) snd_soc_tegra210_ope(E) snd_soc_tegra210_iqc(E) snd_soc_tegra186_arad(E) snd_soc_tegra210_mvc(E) snd_soc_tegra210_afc(E) snd_soc_tegra210_amx(E) snd_soc_tegra210_dmic(E) snd_soc_tegra210_adx(E) snd_soc_tegra210_i2s(E) snd_soc_tegra210_mixer(E) snd_soc_tegra210_admaif(E) snd_soc_tegra_pcm(E) snd_soc_tegra210_sfc(E) aes_ce_blk(E) crypto_simd(E) cryptd(E) snd_soc_tegra210_adsp(E) aes_ce_cipher(E) ghash_ce(E) ucsi_ccg(E) snd_soc_tegra_machine_driver(E) cam_cdi_tsc(E) typec_ucsi(E) snd_soc_tegra_utils(E) sha2_ce(E) binfmt_misc(E)
[ 96.508696] sha256_arm64(E) sha1_ce(E) snd_soc_simple_card_utils(E) snd_soc_spdif_tx(E) typec(E) snd_hda_codec_hdmi(E) nct1008(E) nv_hawk_owl(E) nvadsp(E) max96712(E) i2c_nvvrs11(E) userspace_alert(E) snd_soc_tegra210_ahub(E) tegra210_adma(E) tegra_bpmp_thermal(E) snd_hda_tegra(E) snd_soc_rt5640(E) snd_hda_codec(E) snd_hda_core(E) snd_soc_rl6231(E) spi_tegra114(E) nvidia(OE) ina3221(E) pwm_fan(E) nvgpu(E) nvmap(E) nfsd(E) ip_tables(E) x_tables(E) [last unloaded: mtd]
[ 96.642755] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G OE 5.10.120-tegra #8
[ 96.642757] Hardware name: Unknown Jetson AGX Orin Developer Kit/Jetson AGX Orin Developer Kit, BIOS 4.1-33958178 08/01/2023
[ 96.642763] pstate: 60400009 (nZCv daif +PAN -UAO -TCO BTYPE=–)
[ 96.668704] pc : ip_protocol_deliver_rcu+0x6c/0x210
[ 96.668706] lr : ip_protocol_deliver_rcu+0x60/0x210
[ 96.668707] sp : ffff800010003920
[ 96.668708] x29: ffff800010003920 x28: ffff7f81c1042180
[ 96.668711] x27: ffff800010003a78 x26: ffff7f81c1042180
[ 96.687606] x25: ffff7f81c0fefc00 x24: ffff800010003b18
[ 96.698529] x23: 0000000000000001 x22: ffffa16193a13300
[ 96.703986] x21: ffffa1619377f598 x20: ffff7f81c0fef800
[ 96.709443] x19: ffffa16193a20a10 x18: 0000000000000000
[ 96.714910] x17: 0000000000000000 x16: ffffa16191b8d9f0
[ 96.720367] x15: 0000000000000000 x14: 011f43001ecd0121
[ 96.725825] x13: 000000000000000a x12: 0000000000000004
[ 96.731282] x11: ffff7f81d713e0d8 x10: ffff7f81d713e140
[ 96.736744] x9 : 0000000000000001 x8 : 0000000000000000
[ 96.742201] x7 : ffff000000000000 x6 : ffff7f8224b4e54e
[ 96.747661] x5 : ffff7f8224b4e500 x4 : 0000000000000000
[ 96.753119] x3 : 000000000000004e x2 : 0000000000000000
[ 96.758580] x1 : 0000000000000000 x0 : 0000000000000003
[ 96.764038] Call trace:
[ 96.766553] ip_protocol_deliver_rcu+0x6c/0x210
[ 96.771210] ip_local_deliver_finish+0x6c/0x90
[ 96.775774] ip_local_deliver+0x11c/0x130
[ 96.779896] ip_sublist_rcv_finish+0x50/0x70
[ 96.784287] ip_sublist_rcv+0x178/0x1f0
[ 96.788228] ip_list_rcv+0x10c/0x1b0
[ 96.791906] __netif_receive_skb_list_core+0x18c/0x220
[ 96.797186] netif_receive_skb_list_internal+0x194/0x2b0
[ 96.802643] gro_normal_list.part.0+0x28/0x40
[ 96.807126] gro_normal_one+0x70/0x80
[ 96.810888] napi_gro_receive+0x228/0x260
[ 96.815016] osd_receive_packet+0x164/0x2b0
[ 96.819317] osi_process_rx_completions+0x2ac/0x4b0
[ 96.824332] ether_napi_poll_rx+0x5c/0xe0
[ 96.828461] net_rx_action+0x124/0x440
[ 96.832320] __do_softirq+0x140/0x3e8
[ 96.836083] irq_exit+0xc0/0xe0
[ 96.839315] __handle_domain_irq+0x74/0xd0
[ 96.843524] gic_handle_irq+0x68/0x134
[ 96.847378] el1_irq+0xd0/0x180
[ 96.850611] cpuidle_enter_state+0xb8/0x410
[ 96.854903] cpuidle_enter+0x40/0x60
[ 96.858578] call_cpuidle+0x44/0x80
[ 96.862167] do_idle+0x208/0x270
[ 96.865490] cpu_startup_entry+0x2c/0x70
[ 96.869516] rest_init+0xdc/0xe8
[ 96.872840] arch_call_rest_init+0x18/0x20
[ 96.877045] start_kernel+0x500/0x538
[ 96.880807] watchdog: ====For debug only: Start Printing Blocked Tasks====<watchdog_timer_fn>
[ 96.889591] task:kworker/4:0 state:D stack: 0 pid: 35 ppid: 2 flags:0x00000028
[ 96.898180] Workqueue: events rt5640_sel_asrc_clk_src [snd_soc_rt5640]
[ 96.904881] Call trace:
[ 96.907393] __switch_to+0xc8/0x120
[ 96.910979] __schedule+0x3d0/0x910
[ 96.914566] schedule+0x78/0x110
[ 96.917886] schedule_timeout+0x184/0x340
[ 96.922004] wait_for_completion_timeout+0x8c/0x110
[ 96.927021] tegra_i2c_wait_completion+0x74/0xb0
[ 96.931767] tegra_i2c_xfer_msg.part.0+0x42c/0x6d0
[ 96.936691] tegra_i2c_xfer+0x84/0x2c0
[ 96.940556] __i2c_transfer+0x154/0x680
[ 96.944497] i2c_transfer+0x9c/0x110
[ 96.948174] regmap_i2c_read+0x7c/0xd0
[ 96.952032] _regmap_raw_read+0xe4/0x310
[ 96.956063] _regmap_bus_read+0x58/0x90
[ 96.960004] _regmap_read+0x6c/0x1b0
[ 96.963680] regmap_read+0x54/0x80
[ 96.967178] soc_component_read_no_lock+0x4c/0xf0
[ 96.972013] snd_soc_component_read+0x3c/0x60
[ 96.976495] rt5640_sel_asrc_clk_src+0x1bb4/0x22a8 [snd_soc_rt5640]
[ 96.982934] process_one_work+0x1c4/0x4a0
[ 96.987061] worker_thread+0x54/0x430
[ 96.990825] kthread+0x148/0x170
[ 96.994148] ret_from_fork+0x10/0x24
[ 96.997863] task:jbd2/mmcblk0p1- state:D stack: 0 pid: 285 ppid: 2 flags:0x00000028
[ 97.006443] Call trace:
[ 97.008951] __switch_to+0xc8/0x120
[ 97.012540] __schedule+0x3d0/0x910
[ 97.016125] schedule+0x78/0x110
[ 97.019448] jbd2_journal_commit_transaction+0x230/0x1e10
[ 97.024990] kjournald2+0xc4/0x270
[ 97.028487] kthread+0x148/0x170
[ 97.031809] ret_from_fork+0x10/0x24
[ 97.035499] task:rs:main Q:Reg state:D stack: 0 pid: 750 ppid: 1 flags:0x00000000
[ 97.044078] Call trace:
[ 97.046594] __switch_to+0xc8/0x120
[ 97.050181] __schedule+0x3d0/0x910
[ 97.053768] schedule+0x78/0x110
[ 97.057079] wait_transaction_locked+0x88/0xe0
[ 97.061646] add_transaction_credits+0x58/0x310
[ 97.066303] start_this_handle+0xf4/0x4a0
[ 97.070423] jbd2__journal_start+0x128/0x260
[ 97.074810] __ext4_journal_start_sb+0x184/0x1b0
[ 97.079556] ext4_da_write_begin+0x188/0x470
[ 97.083952] generic_perform_write+0xb4/0x1d0
[ 97.088437] ext4_buffered_write_iter+0xa4/0x180
[ 97.093182] ext4_file_write_iter+0x64/0x7a0
[ 97.097576] new_sync_write+0xfc/0x1a0
[ 97.101429] vfs_write+0x25c/0x390
[ 97.104925] ksys_write+0x7c/0x110
[ 97.108421] __arm64_sys_write+0x28/0x40
[ 97.112454] el0_svc_common.constprop.0+0x80/0x1d0
[ 97.117377] do_el0_svc+0x38/0xb0
[ 97.120786] el0_svc+0x1c/0x30
[ 97.123918] el0_sync_handler+0xa8/0xb0
[ 97.127863] el0_sync+0x16c/0x180
[ 97.131281] task:nvfancontrol state:D stack: 0 pid: 774 ppid: 1 flags:0x00000000
[ 97.139866] Call trace:
[ 97.139868] __switch_to+0xc8/0x120
[ 97.139869] __schedule+0x3d0/0x910
[ 97.139870] schedule+0x78/0x110
[ 97.139871] schedule_timeout+0x184/0x340
[ 97.139873] wait_for_completion_timeout+0x8c/0x110
[ 97.139875] tegra_bpmp_transfer+0x198/0x370
[ 97.139877] 0xffffa1611af4b3ac
[ 97.139879] of_thermal_get_temp+0x40/0x60
[ 97.139884] thermal_zone_get_temp+0x78/0x160
[ 97.178329] temp_show+0x40/0x90
[ 97.178332] dev_attr_show+0x40/0x80
[ 97.178335] sysfs_kf_seq_show+0x90/0x130
[ 97.189451] kernfs_seq_show+0x48/0x60
[ 97.193306] seq_read_iter+0x1d4/0x490
[ 97.197162] kernfs_fop_read_iter+0x154/0x1d0
[ 97.201641] new_sync_read+0xfc/0x1a0
[ 97.205403] vfs_read+0x130/0x1c0
[ 97.208810] ksys_read+0x7c/0x110
[ 97.212219] __arm64_sys_read+0x28/0x40
[ 97.216164] el0_svc_common.constprop.0+0x80/0x1d0
[ 97.221087] do_el0_svc+0x38/0xb0
[ 97.224495] el0_svc+0x1c/0x30
[ 97.227626] el0_sync_handler+0xa8/0xb0
[ 97.231570] el0_sync+0x16c/0x180
[ 97.234989] task:proxy-main state:D stack: 0 pid: 1673 ppid: 1362 flags:0x00000000
[ 97.243573] Call trace:
[ 97.246099] __switch_to+0xc8/0x120
[ 97.249685] __schedule+0x3d0/0x910
[ 97.253271] schedule+0x78/0x110
[ 97.256580] wait_transaction_locked+0x88/0xe0
[ 97.261147] add_transaction_credits+0x58/0x310
[ 97.265804] start_this_handle+0xf4/0x4a0
[ 97.269927] jbd2__journal_start+0x128/0x260
[ 97.274319] __ext4_journal_start_sb+0x184/0x1b0
[ 97.279062] ext4_dirty_inode+0x50/0xa0
[ 97.283007] __mark_inode_dirty+0x1d8/0x4b0
[ 97.287308] generic_update_time+0x74/0x100
[ 97.291602] inode_update_time+0x58/0x70
[ 97.295633] file_update_time+0xe0/0x120
[ 97.299660] file_modified+0x38/0x50
[ 97.303335] ext4_buffered_write_iter+0x6c/0x180
[ 97.308080] ext4_file_write_iter+0x64/0x7a0
[ 97.312470] new_sync_write+0xfc/0x1a0
[ 97.316324] vfs_write+0x25c/0x390
[ 97.319821] ksys_write+0x7c/0x110
[ 97.323317] __arm64_sys_write+0x28/0x40
[ 97.327354] el0_svc_common.constprop.0+0x80/0x1d0
[ 97.332276] do_el0_svc+0x38/0xb0
[ 97.335687] el0_svc+0x1c/0x30
[ 97.338830] el0_sync_handler+0xa8/0xb0
[ 97.342772] el0_sync+0x16c/0x180
[ 97.346195] task:pulseaudio state:D stack: 0 pid: 3287 ppid: 3278 flags:0x00000800
[ 97.354777] Call trace:
[ 97.357291] __switch_to+0xc8/0x120
[ 97.360875] __schedule+0x3d0/0x910
[ 97.364460] schedule+0x78/0x110
[ 97.367781] io_schedule+0x24/0xd0
[ 97.371277] wait_on_page_bit_common+0x170/0x3d0
[ 97.376027] generic_file_buffered_read+0x488/0xa40
[ 97.381037] generic_file_read_iter+0xf0/0x170
[ 97.385594] ext4_file_read_iter+0x5c/0x150
[ 97.389890] new_sync_read+0xfc/0x1a0
[ 97.393652] vfs_read+0x130/0x1c0
[ 97.397061] ksys_read+0x7c/0x110
[ 97.400470] __arm64_sys_read+0x28/0x40
[ 97.404414] el0_svc_common.constprop.0+0x80/0x1d0
[ 97.409339] do_el0_svc+0x38/0xb0
[ 97.412747] el0_svc+0x1c/0x30
[ 97.415890] el0_sync_handler+0xa8/0xb0
[ 97.419833] el0_sync+0x16c/0x180
[ 97.423243] task:tracker-miner-f state:D stack: 0 pid: 3289 ppid: 3278 flags:0x00000000
[ 97.431828] Call trace:
[ 97.434336] __switch_to+0xc8/0x120
[ 97.437923] __schedule+0x3d0/0x910
[ 97.441511] schedule+0x78/0x110
[ 97.444833] io_schedule+0x24/0xd0
[ 97.448327] bit_wait_io+0x20/0x60
[ 97.451822] __wait_on_bit_lock+0x88/0x190
[ 97.456027] out_of_line_wait_on_bit_lock+0xa8/0xe0
[ 97.461037] __lock_buffer+0x3c/0x80
[ 97.464709] do_get_write_access+0x78/0x4a0
[ 97.469001] jbd2_journal_get_write_access+0x6c/0xc0
[ 97.474097] __ext4_journal_get_write_access+0x80/0x130
[ 97.479462] ext4_reserve_inode_write+0x98/0xf0
[ 97.484119] __ext4_mark_inode_dirty+0x84/0x2d0
[ 97.488775] ext4_dirty_inode+0x78/0xa0
[ 97.492717] __mark_inode_dirty+0x1d8/0x4b0
[ 97.497013] generic_update_time+0x74/0x100
[ 97.501309] inode_update_time+0x58/0x70
[ 97.505337] touch_atime+0x1c0/0x260
[ 97.509010] generic_file_buffered_read+0x64c/0xa40
[ 97.514016] generic_file_read_iter+0xf0/0x170
[ 97.518580] ext4_file_read_iter+0x5c/0x150
[ 97.522875] new_sync_read+0xfc/0x1a0
[ 97.526637] vfs_read+0x130/0x1c0
[ 97.530046] ksys_pread64+0x88/0xd0
[ 97.533633] __arm64_sys_pread64+0x2c/0x40
[ 97.537847] el0_svc_common.constprop.0+0x80/0x1d0
[ 97.542770] do_el0_svc+0x38/0xb0
[ 97.546179] el0_svc+0x1c/0x30
[ 97.549321] el0_sync_handler+0xa8/0xb0
[ 97.553262] el0_sync+0x16c/0x180
[ 97.556686] task:tracker-store state:D stack: 0 pid: 3406 ppid: 3278 flags:0x00000000
[ 97.565269] Call trace:
[ 97.567786] __switch_to+0xc8/0x120
[ 97.571372] __schedule+0x3d0/0x910
[ 97.574960] schedule+0x78/0x110
[ 97.578284] wait_transaction_locked+0x88/0xe0
[ 97.582843] add_transaction_credits+0x58/0x310
[ 97.587500] start_this_handle+0xf4/0x4a0
[ 97.591622] jbd2__journal_start+0x128/0x260
[ 97.596012] __ext4_journal_start_sb+0x184/0x1b0
[ 97.600755] ext4_dirty_inode+0x50/0xa0
[ 97.604700] __mark_inode_dirty+0x1d8/0x4b0
[ 97.608996] generic_update_time+0x74/0x100
[ 97.613292] inode_update_time+0x58/0x70
[ 97.617321] touch_atime+0x1c0/0x260
[ 97.620996] generic_file_buffered_read+0x64c/0xa40
[ 97.626008] generic_file_read_iter+0xf0/0x170
[ 97.630575] ext4_file_read_iter+0x5c/0x150
[ 97.630576] new_sync_read+0xfc/0x1a0
[ 97.630578] vfs_read+0x130/0x1c0
[ 97.630581] ksys_pread64+0x88/0xd0
[ 97.645638] __arm64_sys_pread64+0x2c/0x40
[ 97.645640] el0_svc_common.constprop.0+0x80/0x1d0
[ 97.645641] do_el0_svc+0x38/0xb0
[ 97.645642] el0_svc+0x1c/0x30
[ 97.645643] el0_sync_handler+0xa8/0xb0
[ 97.645644] el0_sync+0x16c/0x180
[ 97.645646] task:kworker/u24:4 state:D stack: 0 pid: 3421 ppid: 2 flags:0x00000028
[ 97.677270] Workqueue: writeback wb_workfn (flush-179:0)
[ 97.682732] Call trace:
[ 97.685247] __switch_to+0xc8/0x120
[ 97.688842] __schedule+0x3d0/0x910
[ 97.692430] schedule+0x78/0x110
[ 97.695750] io_schedule+0x24/0xd0
[ 97.699244] bit_wait_io+0x20/0x60
[ 97.702736] __wait_on_bit_lock+0x88/0x190
[ 97.706949] out_of_line_wait_on_bit_lock+0xa8/0xe0
[ 97.711959] __lock_buffer+0x3c/0x80
[ 97.715638] do_get_write_access+0x78/0x4a0
[ 97.719930] jbd2_journal_get_write_access+0x6c/0xc0
[ 97.725030] __ext4_journal_get_write_access+0x80/0x130
[ 97.730395] ext4_reserve_inode_write+0x98/0xf0
[ 97.735051] __ext4_mark_inode_dirty+0x84/0x2d0
[ 97.739707] __ext4_ext_dirty.isra.0+0xac/0xf0
[ 97.744273] ext4_ext_insert_extent+0x47c/0x1430
[ 97.749022] ext4_ext_map_blocks+0x53c/0x1020
[ 97.753500] ext4_map_blocks+0x194/0x5d0
[ 97.757528] ext4_writepages+0x814/0xdc0
[ 97.761557] do_writepages+0x5c/0x110
[ 97.765317] __writeback_single_inode+0x4c/0x510
[ 97.770061] writeback_sb_inodes+0x210/0x4b0
[ 97.774455] __writeback_inodes_wb+0x58/0x110
[ 97.778935] wb_writeback+0x26c/0x410
[ 97.782697] wb_workfn+0x2d8/0x600
[ 97.786191] process_one_work+0x1c4/0x4a0
[ 97.790309] worker_thread+0x54/0x430
[ 97.794071] kthread+0x148/0x170
[ 97.797394] ret_from_fork+0x10/0x24
[ 97.801067] task:gnome-shell state:D stack: 0 pid: 3440 ppid: 3404 flags:0x00000000
[ 97.809637] Call trace:
[ 97.812144] __switch_to+0xc8/0x120
[ 97.815729] __schedule+0x3d0/0x910
[ 97.819315] schedule+0x78/0x110
[ 97.822637] io_schedule+0x24/0xd0
[ 97.826130] bit_wait_io+0x20/0x60
[ 97.829624] __wait_on_bit+0x80/0xf0
[ 97.833299] out_of_line_wait_on_bit+0xa8/0xe0
[ 97.837865] __wait_on_buffer+0x40/0x50
[ 97.841807] __ext4_find_entry+0x2c8/0x400
[ 97.846016] ext4_lookup+0x94/0x240
[ 97.849605] path_openat+0x3d4/0xde0
[ 97.853278] do_filp_open+0x88/0x110
[ 97.856954] do_sys_openat2+0x1fc/0x2b0
[ 97.860897] do_sys_open+0x80/0xd0
[ 97.864393] __arm64_sys_openat+0x30/0x40
[ 97.868512] el0_svc_common.constprop.0+0x80/0x1d0
[ 97.873439] do_el0_svc+0x38/0xb0
[ 97.876847] el0_svc+0x1c/0x30
[ 97.879990] el0_sync_handler+0xa8/0xb0
[ 97.883933] el0_sync+0x16c/0x180
[ 97.887344] task:cat state:D stack: 0 pid: 3606 ppid: 3101 flags:0x00000000
[ 97.895923] Call trace:
[ 97.898430] __switch_to+0xc8/0x120
[ 97.902018] __schedule+0x3d0/0x910
[ 97.905606] schedule+0x78/0x110
[ 97.908928] schedule_timeout+0x2dc/0x340
[ 97.913044] wait_for_completion+0x8c/0x120
[ 97.917335] __flush_work.isra.0+0x108/0x220
[ 97.921728] flush_work+0x24/0x30
[ 97.925138] tegra194_get_speed+0x8c/0x1c0
[ 97.929345] cpufreq_verify_current_freq+0x4c/0x100
[ 97.934354] __cpufreq_get+0x40/0x60
[ 97.938027] show_cpuinfo_cur_freq+0x28/0x80
[ 97.942416] show+0x50/0x80
[ 97.945292] sysfs_kf_seq_show+0x90/0x130
[ 97.949414] kernfs_seq_show+0x48/0x60
[ 97.953272] seq_read_iter+0x1d4/0x490
[ 97.957126] kernfs_fop_read_iter+0x154/0x1d0
[ 97.961605] new_sync_read+0xfc/0x1a0
[ 97.965367] vfs_read+0x130/0x1c0
[ 97.968775] ksys_read+0x7c/0x110
[ 97.972183] __arm64_sys_read+0x28/0x40
[ 97.976128] el0_svc_common.constprop.0+0x80/0x1d0
[ 97.981050] do_el0_svc+0x38/0xb0
[ 97.984456] el0_svc+0x1c/0x30
[ 97.987598] el0_sync_handler+0xa8/0xb0
[ 97.991538] el0_sync+0x16c/0x180
[ 97.994948] task:(-stop.sh) state:D stack: 0 pid: 3784 ppid: 1 flags:0x00000000
[ 98.003533] Call trace:
[ 98.006046] __switch_to+0xc8/0x120
[ 98.009633] __schedule+0x3d0/0x910
[ 98.013219] schedule+0x78/0x110
[ 98.016538] io_schedule+0x24/0xd0
[ 98.020033] wait_on_page_bit_common+0x170/0x3d0
[ 98.024780] generic_file_buffered_read+0x488/0xa40
[ 98.029790] generic_file_read_iter+0xf0/0x170
[ 98.034355] ext4_file_read_iter+0x5c/0x150
[ 98.038651] __kernel_read+0x110/0x2c0
[ 98.042505] kernel_read+0x60/0x70
[ 98.046001] bprm_execve+0x240/0x660
[ 98.049676] do_execveat_common.isra.0+0x1c4/0x240
[ 98.054602] __arm64_sys_execve+0x48/0x60
[ 98.058725] el0_svc_common.constprop.0+0x80/0x1d0
[ 98.063652] do_el0_svc+0x38/0xb0
[ 98.067061] el0_svc+0x1c/0x30
[ 98.070191] el0_sync_handler+0xa8/0xb0
[ 98.074134] el0_sync+0x16c/0x180
[ 98.077546] watchdog: ====For debug only: End Printing Blocked Tasks====<watchdog_timer_fn>
[ 98.086126] Kernel panic - not syncing: softlockup: hung tasks
[ 98.092112] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G OEL 5.10.120-tegra #8
[ 98.100339] Hardware name: Unknown Jetson AGX Orin Developer Kit/Jetson AGX Orin Developer Kit, BIOS 4.1-33958178 08/01/2023
[ 98.111848] Call trace:
[ 98.114356] dump_backtrace+0x0/0x1d0
[ 98.118116] show_stack+0x30/0x40
[ 98.121528] dump_stack+0xd8/0x138
[ 98.125024] panic+0x17c/0x384
[ 98.128168] watchdog_timer_fn+0x270/0x2b0
[ 98.132383] __hrtimer_run_queues+0x148/0x380
[ 98.132385] hrtimer_interrupt+0xf0/0x250
[ 98.132387] arch_timer_handler_phys+0x40/0x50
[ 98.132391] handle_percpu_devid_irq+0x90/0x280
[ 98.150220] generic_handle_irq+0x40/0x60
[ 98.150222] __handle_domain_irq+0x70/0xd0
[ 98.150223] gic_handle_irq+0x68/0x134
[ 98.150224] el1_irq+0xd0/0x180
[ 98.150225] ip_protocol_deliver_rcu+0x6c/0x210
[ 98.150226] ip_local_deliver_finish+0x6c/0x90
[ 98.150227] ip_local_deliver+0x11c/0x130
[ 98.150230] ip_sublist_rcv_finish+0x50/0x70
[ 98.183382] ip_sublist_rcv+0x178/0x1f0
[ 98.183383] ip_list_rcv+0x10c/0x1b0
[ 98.183385] __netif_receive_skb_list_core+0x18c/0x220
[ 98.183389] netif_receive_skb_list_internal+0x194/0x2b0
[ 98.201729] gro_normal_list.part.0+0x28/0x40
[ 98.206206] gro_normal_one+0x70/0x80
[ 98.209966] napi_gro_receive+0x228/0x260
[ 98.214094] osd_receive_packet+0x164/0x2b0
[ 98.218391] osi_process_rx_completions+0x2ac/0x4b0
[ 98.223404] ether_napi_poll_rx+0x5c/0xe0
[ 98.227531] net_rx_action+0x124/0x440
[ 98.231387] __do_softirq+0x140/0x3e8
[ 98.235150] irq_exit+0xc0/0xe0
[ 98.238381] __handle_domain_irq+0x74/0xd0
[ 98.242586] gic_handle_irq+0x68/0x134
[ 98.246439] el1_irq+0xd0/0x180
[ 98.249671] cpuidle_enter_state+0xb8/0x410
[ 98.253971] cpuidle_enter+0x40/0x60
[ 98.257646] call_cpuidle+0x44/0x80
[ 98.261232] do_idle+0x208/0x270
[ 98.264551] cpu_startup_entry+0x2c/0x70
[ 98.268577] rest_init+0xdc/0xe8
[ 98.271904] arch_call_rest_init+0x18/0x20
[ 98.276109] start_kernel+0x500/0x538
[ 98.279877] SMP: stopping secondary CPUs
[ 98.283911] Kernel Offset: 0x216181a60000 from 0xffff800010000000
[ 98.290185] PHYS_OFFSET: 0xffff807f40000000
[ 98.294481] CPU features: 0x08040006,4a80aa38
[ 98.298958] Memory Limit: none
[ 98.307547] —[ end Kernel panic - not syncing: softlockup: hung tasks ]—
[END] 2024/1/6 12:54:11
I met similar fault before. JP 5.0.2 at orin dev kit.
That fault was because of the clock set in rt-cpu (nvidia VI system) were not net correctly.
Maybe you should take a look at that one.
