On every boot of Jetson AGX Orin, the following error message is thrown up:
" The current input timing is not supported by the monitor display. Please change your input timing to 1920x1080,60 hz or any other monitor listed as per the monitor specifications."
The dmesg dump displays the following:
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 5.10.120-tegra (buildbrain@mobile-u64-6422-d7000) ( aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU B inutils) 2.33.1) #1 SMP PREEMPT Tue Aug 1 12:32:50 PDT 2023
[ 0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,
[ 0.000000] OF: fdt: - 80000000 , c0000000
[ 0.000000] Machine model: Jetson AGX Orin Developer Kit
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x102531df98 SMBIOS=0xffff0000 SMBIOS 3.0=0x100515000 0 MEMATTR=0x100681f018 ESRT=0x10050ef698 RNG=0x1006d2f198 MEMRESERVE=0x1006829f1 8
[ 0.000000] efi: seeding entropy pool
[ 0.000000] esrt: Reserving ESRT space from 0x00000010050ef698 to 0x000000100 50ef6d0.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000001008c00000, s ize 512 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id share d-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x0000001033ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000fffdffff]
[ 0.000000] node 0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x0000001003f13fff]
[ 0.000000] node 0: [mem 0x0000001003f14000-0x000000100431ffff]
[ 0.000000] node 0: [mem 0x0000001004320000-0x000000100513ffff]
[ 0.000000] node 0: [mem 0x0000001005140000-0x00000010051fffff]
[ 0.000000] node 0: [mem 0x0000001005200000-0x00000010066dffff]
[ 0.000000] node 0: [mem 0x00000010066e0000-0x000000100677ffff]
[ 0.000000] node 0: [mem 0x0000001006780000-0x00000010067cffff]
[ 0.000000] node 0: [mem 0x00000010067d0000-0x00000010067fffff]
[ 0.000000] node 0: [mem 0x0000001006800000-0x000000100683ffff]
[ 0.000000] node 0: [mem 0x0000001006840000-0x000000100685ffff]
[ 0.000000] node 0: [mem 0x0000001006860000-0x000000100693ffff]
[ 0.000000] node 0: [mem 0x0000001006940000-0x000000100695ffff]
[ 0.000000] node 0: [mem 0x0000001006960000-0x000000100698ffff]
[ 0.000000] node 0: [mem 0x0000001006990000-0x0000001006b6ffff]
[ 0.000000] node 0: [mem 0x0000001006b70000-0x0000001006c3ffff]
[ 0.000000] node 0: [mem 0x0000001006c40000-0x0000001006cdffff]
[ 0.000000] node 0: [mem 0x0000001006ce0000-0x0000001006d1ffff]
[ 0.000000] node 0: [mem 0x0000001006d20000-0x0000001006faffff]
[ 0.000000] node 0: [mem 0x0000001006fb0000-0x00000010070affff]
[ 0.000000] node 0: [mem 0x00000010070b0000-0x000000100714ffff]
[ 0.000000] node 0: [mem 0x0000001007150000-0x000000100719ffff]
[ 0.000000] node 0: [mem 0x00000010071a0000-0x000000100723ffff]
[ 0.000000] node 0: [mem 0x0000001007240000-0x000000100775ffff]
[ 0.000000] node 0: [mem 0x0000001007760000-0x000000100793ffff]
[ 0.000000] node 0: [mem 0x0000001007940000-0x0000001028faffff]
[ 0.000000] node 0: [mem 0x0000001028fb0000-0x0000001028ffffff]
[ 0.000000] node 0: [mem 0x0000001029000000-0x000000102d1fffff]
[ 0.000000] node 0: [mem 0x000000102d210000-0x000000102d21ffff]
[ 0.000000] node 0: [mem 0x0000001032000000-0x0000001033ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000001033ffffff]
[ 0.000000] On node 0 totalpages: 16445968
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 524288 pages, LIFO batch:63
[ 0.000000] Normal zone: 249088 pages used for memmap
[ 0.000000] Normal zone: 15921680 pages, LIFO batch:63
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 32 pages/cpu s90328 r8192 d32552 u131072
[ 0.000000] pcpu-alloc: s90328 r8192 d32552 u131072 alloc=32*4096
[ 0.000000] pcpu-alloc: [0] 00 [0] 01 [0] 02 [0] 03 [0] 04 [0] 05 [0] 06 [0] 07
[ 0.000000] pcpu-alloc: [0] 08 [0] 09 [0] 10 [0] 11
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 16188688
[ 0.000000] Kernel command line: root=/dev/nvme0n1p1 rw rootwait rootfstype=e xt4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 console=tty0 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb nv-au to-config
[ 0.000000] Dentry cache hash table entries: 8388608 (order: 14, 67108864 byt es, linear)
[ 0.000000] Inode-cache hash table entries: 4194304 (order: 13, 33554432 byte s, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000effe0000-0x00000000fffe000 0] (256MB)
[ 0.000000] Memory: 63769708K/65783872K available (18560K kernel code, 3166K rwdata, 7196K rodata, 3968K init, 1416K bss, 1489876K reserved, 524288K cma-rese rved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=12, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=12.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jif fies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=12
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[ 0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)
[ 0.000000] GICv2m: range[mem 0x0f410000-0x0f41ffff], SPI[608:677]
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 43980 46511088ns
[ 0.000736] Console: colour dummy device 80x25
[ 0.000915] printk: console [tty0] enabled
[ 0.000960] Calibrating delay loop (skipped), value calculated using timer fr equency.. 62.50 BogoMIPS (lpj=125000)
[ 0.000970] pid_max: default: 32768 minimum: 301
[ 0.001075] LSM: Security Framework initializing
[ 0.001106] Yama: becoming mindful.
[ 0.001129] SELinux: Initializing.
[ 0.001292] Mount-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.001378] Mountpoint-cache hash table entries: 131072 (order: 8, 1048576 by tes, linear)
[ 0.003922] rcu: Hierarchical SRCU implementation.
[ 0.004048] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.004803] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-5.10 /arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t23x/concord/ker nel-dts/tegra234-p3701-0005-p3737-0000.dts
[ 0.004812] DTB Build time: Aug 1 2023 12:44:17
[ 0.006481] Tegra Revision: A01 SKU: 0xd0 CPU Process: 0 SoC Process: 0
[ 0.006800] Remapping and enabling EFI services.
[ 0.007400] smp: Bringing up secondary CPUs ...
[ 0.036149] Detected PIPT I-cache on CPU1
[ 0.036192] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[ 0.036233] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[ 0.064904] Detected PIPT I-cache on CPU2
[ 0.064914] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[ 0.064927] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[ 0.093555] Detected PIPT I-cache on CPU3
[ 0.093564] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[ 0.093577] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[ 0.124261] Detected PIPT I-cache on CPU4
[ 0.124281] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c000 0
[ 0.124307] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[ 0.152985] Detected PIPT I-cache on CPU5
[ 0.152994] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e000 0
[ 0.153008] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[ 0.181644] Detected PIPT I-cache on CPU6
[ 0.181654] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f50000 0
[ 0.181669] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[ 0.210312] Detected PIPT I-cache on CPU7
[ 0.210322] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f52000 0
[ 0.210336] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
[ 0.241025] Detected PIPT I-cache on CPU8
[ 0.241048] GICv3: CPU8: found redistributor 20000 region 0:0x000000000f54000 0
[ 0.241075] CPU8: Booted secondary processor 0x0000020000 [0x410fd421]
[ 0.269744] Detected PIPT I-cache on CPU9
[ 0.269755] GICv3: CPU9: found redistributor 20100 region 0:0x000000000f56000 0
[ 0.269769] CPU9: Booted secondary processor 0x0000020100 [0x410fd421]
[ 0.299029] Detected PIPT I-cache on CPU10
[ 0.299040] GICv3: CPU10: found redistributor 20200 region 0:0x000000000f5800 00
[ 0.299054] CPU10: Booted secondary processor 0x0000020200 [0x410fd421]
[ 0.328294] Detected PIPT I-cache on CPU11
[ 0.328304] GICv3: CPU11: found redistributor 20300 region 0:0x000000000f5a00 00
[ 0.328319] CPU11: Booted secondary processor 0x0000020300 [0x410fd421]
[ 0.328375] smp: Brought up 1 node, 12 CPUs
[ 0.328441] SMP: Total of 12 processors activated.
[ 0.328445] CPU features: detected: Privileged Access Never
[ 0.328448] CPU features: detected: LSE atomic instructions
[ 0.328450] CPU features: detected: User Access Override
[ 0.328453] CPU features: detected: 32-bit EL0 Support
[ 0.328456] CPU features: detected: Common not Private translations
[ 0.328459] CPU features: detected: RAS Extension Support
[ 0.328461] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.328465] CPU features: detected: CRC32 instructions
[ 0.328468] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.345964] spectre-bhb mitigation disabled by command line option
[ 0.362191] CPU: All CPU(s) started at EL2
[ 0.365778] devtmpfs: initialized
[ 0.387463] Registered cp15_barrier emulation handler
[ 0.387476] Registered setend emulation handler
[ 0.387482] KASLR enabled
[ 0.387620] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma x_idle_ns: 7645041785100000 ns
[ 0.387635] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[ 0.390781] pinctrl core: initialized pinctrl subsystem
[ 0.391258] SMBIOS 3.0.0 present.
[ 0.391267] DMI: Unknown Jetson AGX Orin Developer Kit/Jetson AGX Orin Develo per Kit, BIOS 4.1-33958178 08/01/2023
[ 0.391606] NET: Registered protocol family 16
[ 0.392416] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.392618] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic all ocations
[ 0.392816] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic a llocations
[ 0.392847] audit: initializing netlink subsys (disabled)
[ 0.392934] audit: type=2000 audit(0.392:1): state=initialized audit_enabled= 0 res=1
[ 0.393144] thermal_sys: Registered thermal governor 'step_wise'
[ 0.393146] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.393151] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[ 0.395831] cpuidle: using governor menu
[ 0.395959] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.396080] ASID allocator initialised with 32768 entries
[ 0.396183] Serial: AMBA PL011 UART driver
[ 0.398195] tegra234_mc_sid_probe(): tegra234 mc-sid probe successful
[ 0.398218] Tegra reboot handler registered.
[ 0.417740] mc: mapped MMIO address: 0xffff8000111f0000 -> 0x2c10000
[ 0.417760] mc: mapped MMIO address: 0xffff800011210000 -> 0x2c20000
[ 0.417767] mc: mapped MMIO address: 0xffff800011230000 -> 0x2c30000
[ 0.417774] mc: mapped MMIO address: 0xffff800011250000 -> 0x2c40000
[ 0.417780] mc: mapped MMIO address: 0xffff800011270000 -> 0x2c50000
[ 0.417787] mc: mapped MMIO address: 0xffff800011290000 -> 0x2b80000
[ 0.417793] mc: mapped MMIO address: 0xffff8000112b0000 -> 0x2b90000
[ 0.417800] mc: mapped MMIO address: 0xffff8000112d0000 -> 0x2ba0000
[ 0.417806] mc: mapped MMIO address: 0xffff8000112f0000 -> 0x2bb0000
[ 0.417812] mc: mapped MMIO address: 0xffff800011310000 -> 0x1700000
[ 0.417819] mc: mapped MMIO address: 0xffff800011330000 -> 0x1710000
[ 0.417826] mc: mapped MMIO address: 0xffff800011350000 -> 0x1720000
[ 0.417832] mc: mapped MMIO address: 0xffff800011370000 -> 0x1730000
[ 0.417840] mc: mapped MMIO address: 0xffff800011390000 -> 0x1740000
[ 0.417846] mc: mapped MMIO address: 0xffff8000113b0000 -> 0x1750000
[ 0.417852] mc: mapped MMIO address: 0xffff8000113d0000 -> 0x1760000
[ 0.417859] mc: mapped MMIO address: 0xffff8000113f0000 -> 0x1770000
[ 0.417868] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.417912] mc-err: mcerr ops are set to t23x
[ 0.418612] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 80, base_baud = 0) is a SBSA
[ 1.641133] printk: console [ttyAMA0] enabled
[ 1.649889] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 1.656601] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 1.663301] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 1.670000] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 1.679002] ACPI: Interpreter disabled.
[ 1.684052] vdd-av1v1-hub: supplied by vdd-5v-sys
[ 1.688903] vbusA-cvb: supplied by vdd-5v-sys
[ 1.693368] vbusB-cvb: supplied by vdd-5v-sys
[ 1.697836] vdd-usbc1-vbus: supplied by vdd-5v-sys
[ 1.702770] vdd-usbc2-vbus: supplied by vdd-5v-sys
[ 1.708296] iommu: Default domain type: Translated
[ 1.713261] eventlib_kernel: keventlib is initialized, test id: 0
[ 1.719626] SCSI subsystem initialized
[ 1.723442] usbcore: registered new interface driver usbfs
[ 1.728936] usbcore: registered new interface driver hub
[ 1.734255] usbcore: registered new device driver usb
[ 1.739591] mc: Linux media interface: v0.10
[ 1.743869] videodev: Linux video capture interface: v2.00
[ 1.749491] pps_core: LinuxPPS API ver. 1 registered
[ 1.754453] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome tti <giometti@linux.it>
[ 1.763588] PTP clock support registered
[ 1.767730] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec
[ 1.774887] tegra_wdt_t18x 2190000.watchdog: Registered successfully
[ 1.782545] Registered efivars operations
[ 1.787120] FPGA manager framework
[ 1.790581] Advanced Linux Sound Architecture Driver Initialized.
[ 1.796954] Bluetooth: Core ver 2.22
[ 1.800537] NET: Registered protocol family 31
[ 1.804979] Bluetooth: HCI device and connection manager initialized
[ 1.811334] Bluetooth: HCI socket layer initialized
[ 1.816210] Bluetooth: L2CAP socket layer initialized
[ 1.821267] Bluetooth: SCO socket layer initialized
[ 1.826675] camchar: rtcpu character device driver loaded
[ 1.832311] clocksource: Switched to clocksource arch_sys_counter
[ 1.994983] VFS: Disk quotas dquot_6.6.0
[ 1.998950] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 2.006391] pnp: PnP ACPI: disabled
[ 2.011913] la/ptsa driver initialized.
[ 2.015825] NET: Registered protocol family 2
[ 2.020399] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, li near)
[ 2.030153] tcp_listen_portaddr_hash hash table entries: 32768 (order: 7, 524 288 bytes, linear)
[ 2.038929] TCP established hash table entries: 524288 (order: 10, 4194304 by tes, linear)
[ 2.047540] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, line ar)
[ 2.055449] TCP: Hash tables configured (established 524288 bind 65536)
[ 2.062167] UDP hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 2.069228] UDP-Lite hash table entries: 32768 (order: 8, 1048576 bytes, line ar)
[ 2.076821] NET: Registered protocol family 1
[ 2.081414] RPC: Registered named UNIX socket transport module.
[ 2.087341] RPC: Registered udp transport module.
[ 2.092043] RPC: Registered tcp transport module.
[ 2.096747] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 2.103194] PCI: CLS 0 bytes, default 64
[ 2.107269] Trying to unpack rootfs image as initramfs...
[ 2.241828] Freeing initrd memory: 9552K
[ 2.247692] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters av ailable
[ 2.255595] kvm [1]: IPA Size Limit: 48 bits
[ 2.259920] kvm [1]: GICv3: no GICV resource entry
[ 2.264714] kvm [1]: disabling GICv2 emulation
[ 2.269176] kvm [1]: GIC system register CPU interface enabled
[ 2.275118] kvm [1]: vgic interrupt IRQ9
[ 2.279194] kvm [1]: VHE mode initialized successfully
[ 2.285017] Initialise system trusted keyrings
[ 2.289552] workingset: timestamp_bits=46 max_order=24 bucket_order=0
[ 2.298345] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.304503] NFS: Registering the id_resolver key type
[ 2.309573] Key type id_resolver registered
[ 2.313756] Key type id_legacy registered
[ 2.317806] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 2.324513] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering ...
[ 2.331922] ntfs: driver 2.1.32 [Flags: R/W].
[ 2.348066] NET: Registered protocol family 38
[ 2.352527] Key type asymmetric registered
[ 2.356623] Asymmetric key parser 'x509' registered
[ 2.361514] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2 39)
[ 2.368971] io scheduler mq-deadline registered
[ 2.373506] io scheduler kyber registered
[ 2.381682] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 2.387288] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 2.392876] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 2.398465] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 2.404811] efifb: probing for efifb
[ 2.408422] efifb: framebuffer at 0x1039e00000, using 8640k, total 8640k
[ 2.415134] efifb: mode is 1920x1080x32, linelength=8192, pages=1
[ 2.421229] efifb: scrolling: redraw
[ 2.424802] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 2.433358] Console: switching to colour frame buffer device 240x67
[ 2.442346] fb0: EFI VGA frame buffer device
[ 2.448353] tegra_dc_assign_hw_data: no matching compatible node
[ 2.454377] tegradccommon module_init failed
[ 2.458654] tegradc module_init failed
[ 2.462662] EINJ: ACPI disabled.
[ 2.467466] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 2.474361] tegra-pmc: ### PMC reset source: SYS_RESET_N
[ 2.479685] tegra-pmc: ### PMC reset level: L0
[ 2.484133] tegra-pmc: ### PMC reset status reg: 0x0
[ 2.490336] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 4.155764] printk: console [ttyTCU0] enabled
[ 4.164819] arm-smmu 12000000.iommu: probing hardware configuration...
[ 4.172866] arm-smmu 12000000.iommu: SMMUv2 with:
[ 4.177716] arm-smmu 12000000.iommu: stage 1 translation
[ 4.183288] arm-smmu 12000000.iommu: stage 2 translation
[ 4.188842] arm-smmu 12000000.iommu: nested translation
[ 4.194320] arm-smmu 12000000.iommu: stream matching with 128 registe r groups
[ 4.201748] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 onl y)
[ 4.210839] arm-smmu 12000000.iommu: Supported page sizes: 0x00001000
[ 4.217556] arm-smmu 12000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 4.224271] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 4.231850] arm-smmu 10000000.iommu: probing hardware configuration...
[ 4.238579] arm-smmu 10000000.iommu: SMMUv2 with:
[ 4.243430] arm-smmu 10000000.iommu: stage 1 translation
[ 4.248978] arm-smmu 10000000.iommu: stage 2 translation
[ 4.254530] arm-smmu 10000000.iommu: nested translation
[ 4.259992] arm-smmu 10000000.iommu: stream matching with 128 registe r groups
[ 4.267422] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 onl y)
[ 4.276490] arm-smmu 10000000.iommu: Supported page sizes: 0x00001000
[ 4.283203] arm-smmu 10000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 4.289918] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 4.297063] arm-smmu 8000000.iommu: probing hardware configuration...
[ 4.303689] arm-smmu 8000000.iommu: SMMUv2 with:
[ 4.308436] arm-smmu 8000000.iommu: stage 1 translation
[ 4.313893] arm-smmu 8000000.iommu: stage 2 translation
[ 4.319357] arm-smmu 8000000.iommu: nested translation
[ 4.324731] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 4.332072] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 4.341028] arm-smmu 8000000.iommu: Supported page sizes: 0x00001000
[ 4.347658] arm-smmu 8000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 4.354278] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 4.361650] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe su ccessful
[ 4.372706] tegra_profiler: version: 1.151, samples/io: 51/30
[ 4.379316] tegra_profiler: auth: init
[ 4.384036] nvsciipc: loaded module
[ 4.389756] tun: Universal TUN/TAP device driver, 1.6
[ 4.395961] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - versio n
[ 4.403957] hns3: Copyright (c) 2017 Huawei Corporation.
[ 4.409992] e1000e: Intel(R) PRO/1000 Network Driver
[ 4.415644] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 4.422301] igb: Intel(R) Gigabit Ethernet Network Driver
[ 4.428408] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 4.434856] PPP generic driver version 2.4.2
[ 4.439838] PPP BSD Compression module registered
[ 4.445215] PPP Deflate Compression module registered
[ 4.450975] PPP MPPE Compression module registered
[ 4.456467] usbcore: registered new interface driver r8152
[ 4.462657] usbcore: registered new interface driver asix
[ 4.468758] usbcore: registered new interface driver ax88179_178a
[ 4.475586] usbcore: registered new interface driver cdc_ether
[ 4.482147] usbcore: registered new interface driver net1080
[ 4.488518] usbcore: registered new interface driver cdc_subset
[ 4.495145] usbcore: registered new interface driver zaurus
[ 4.501420] usbcore: registered new interface driver cdc_ncm
[ 4.507767] usbcore: registered new interface driver aqc111
[ 4.514123] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 4.521014] ohci-pci: OHCI PCI platform driver
[ 4.526107] ohci-platform: OHCI generic platform driver
[ 4.532304] tegra-xusb 3610000.xhci: Adding to iommu group 0
[ 4.539137] usbcore: registered new interface driver uas
[ 4.545159] usbcore: registered new interface driver usb-storage
[ 4.552020] tegra-xudc 3550000.xudc: Adding to iommu group 1
[ 4.558682] mousedev: PS/2 mouse device common for all mice
[ 4.564958] usbcore: registered new interface driver xpad
[ 4.572904] tegra_rtc c2a0000.rtc: registered as rtc1
[ 4.578908] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:2 3 UTC (23)
[ 4.587681] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 4.594625] i2c /dev entries driver
[ 4.598811] tegra-i2c 3160000.i2c: Adding to iommu group 2
[ 4.605191] tegra-i2c c240000.i2c: Adding to iommu group 2
[ 4.611464] tegra-i2c 3180000.i2c: Adding to iommu group 2
[ 4.617690] tegra-i2c 3190000.i2c: Adding to iommu group 2
[ 4.623896] tegra-i2c 31c0000.i2c: Adding to iommu group 2
[ 4.630087] tegra-i2c c250000.i2c: Adding to iommu group 2
[ 4.636275] tegra-i2c 31e0000.i2c: Adding to iommu group 2
[ 4.642528] tegra-i2c 31b0000.i2c: Adding to iommu group 2
[ 4.650948] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not ena bled endpoint.
[ 4.660036] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not ena bled endpoint.
[ 4.670023] device-mapper: uevent: version 1.0.3
[ 4.675392] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-d evel@redhat.com
[ 4.685806] sdhci: Secure Digital Host Controller Interface driver
[ 4.692700] sdhci: Copyright(c) Pierre Ossman
[ 4.697716] Synopsys Designware Multimedia Card Interface Driver
[ 4.704507] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.711009] sdhci-tegra 3460000.sdhci: Adding to iommu group 3
[ 4.711333] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401
[ 4.711387] sdhci-tegra 3400000.sdhci: Adding to iommu group 4
[ 4.732754] tegra-bpmp bpmp: firmware: 6969245516d6bf7e0f23-925eece486b
[ 4.742420] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9
[ 4.748927] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x81
[ 4.761122] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[ 4.767666] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful
[ 5.971479] hid: raw HID events driver (C) Jiri Kosina
[ 5.977939] usbcore: registered new interface driver usbhid
[ 5.984275] usbhid: USB HID core driver
[ 5.989660] tegra-dce d800000.dce: Adding to iommu group 5
[ 5.996923] dce: dce_ipc_channel_init:319 Invalid Channel State [0x0] for ch _type [2]
[ 6.006051] tegra234-aon c000000.aon: Adding to iommu group 6
[ 6.013322] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple ti mes for MB : [0x5]
[ 6.022938] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [0]. Ignored...
[ 6.024123] c000000.aon:hsp: probed
[ 6.032428] dce: dce_admin_send_cmd_ver:424 version : [0x2] err : [0x0]
[ 6.036992] tegra234-aon c000000.aon: init done
[ 6.044433] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple ti mes for MB : [0x1]
[ 6.050025] tegra23x-psc e860000.psc: Adding to iommu group 7
[ 6.059212] dce: dce_admin_setup_clients_ipc:553 Channel Reset Complete for Type [1] ...
[ 6.059215] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [1]. Ignored...
[ 6.059226] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [1]. Ignored...
[ 6.066433] tegra23x-psc e860000.psc: ext_cfg base:(____ptrval____)
[ 6.074852] dce: dce_admin_setup_clients_ipc:529 Get queue info failed for [ 2]
[ 6.074978] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple ti mes for MB : [0x2]
[ 6.084390] tegra23x-psc e860000.psc: init done
[ 6.093923] dce: dce_admin_setup_clients_ipc:553 Channel Reset Complete for Type [3] ...
[ 6.093925] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [3]. Ignored...
[ 6.093935] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [3]. Ignored...
[ 6.101367] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 8
[ 6.109544] dce: dce_start_boot_flow:173 DCE_BOOT_DONE
[ 6.119614] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA =0xbff00000
[ 6.182721] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0x bfee01ff size=131584
[ 6.192625] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[ 16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 6.204986] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x 448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[ 6.217179] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x 8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[ 6.229620] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver =0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[ 6.242964] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver =0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[ 6.256553] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[ 1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[ 6.269564] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (119)
[ 6.277142] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is succ essful
[ 6.287736] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=8676d22a01443bdbc66581b7dde3b6d6828cc925
[ 6.302046] t19x_cache tegra-cache: probed
[ 6.307248] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[ 6.321219] optee: probing for conduit method.
[ 6.326585] optee: revision 3.21 (d8269f24)
[ 6.385354] optee: dynamic shared memory is enabled
[ 6.396307] optee: initialized driver
[ 6.415947] nvpmodel: initialized successfully
[ 6.421390] tegra_hv: get_hvd: not initialized yet
[ 6.427090] user_ivc_mempool: hypervisor not present
[ 6.433769] usbcore: registered new interface driver snd-usb-audio
[ 6.441736] u32 classifier
[ 6.445315] input device check on
[ 6.449870] Actions configured
[ 6.454310] Initializing XFRM netlink socket
[ 6.459949] NET: Registered protocol family 10
[ 6.466605] Segment Routing with IPv6
[ 6.471234] NET: Registered protocol family 17
[ 6.476610] NET: Registered protocol family 15
[ 6.482009] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 6.497319] Bluetooth: RFCOMM socket layer initialized
[ 6.503562] Bluetooth: RFCOMM ver 1.11
[ 6.508231] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 6.515126] Bluetooth: HIDP socket layer initialized
[ 6.521694] 9pnet: Installing 9P2000 support
[ 6.526959] Key type dns_resolver registered
[ 6.532899] registered taskstats version 1
[ 6.537913] Loading compiled-in X.509 certificates
[ 6.554155] Loaded X.509 cert 'Build time autogenerated kernel key: d94b64a20 d69a5a32183bad4f211c4cae67041a9'
[ 6.565689] tegra194-pcie 14100000.pcie: Adding to iommu group 9
[ 6.579604] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 6.588674] tegra194-pcie 14160000.pcie: Adding to iommu group 10
[ 6.602361] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 6.610090] tegra194-pcie 141a0000.pcie: Adding to iommu group 11
[ 6.623288] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 6.630582] tegra194-pcie 141a0000.pcie: Failed to get slot regulators: -517
[ 6.656110] tegra-soc-hwpm f100000.tegra_soc_hwpm: Adding to iommu group 12
[ 6.670831] simple-framebuffer chosen:framebuffer: framebuffer at 0x1039e0000 0, 0x870000 bytes, mapped to 0x(____ptrval____)
[ 6.683202] simple-framebuffer chosen:framebuffer: format=x8r8g8b8, mode=1920 x1080x32, linelength=8192
[ 6.693596] checking generic (1039e00000 870000) vs hw (1039e00000 870000)
[ 6.693597] fb0: switching to simple from EFI VGA
[ 6.699597] Console: switching to colour dummy device 80x25
[ 6.708385] Console: switching to colour frame buffer device 240x67
[ 6.717576] simple-framebuffer chosen:framebuffer: fb0: simplefb registered!
[ 6.725135] host1x 13e40000.host1x: Adding to iommu group 13
[ 6.753416] host1x 13e40000.host1x: initialized
[ 6.758510] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu gro up 14
[ 6.766702] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (stream id=53, iommu=smmu.0x0000000012000000)
[ 6.778724] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu gro up 15
[ 6.786872] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (stream id=54, iommu=smmu.0x0000000012000000)
[ 6.798857] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu gro up 16
[ 6.806976] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (stream id=55, iommu=smmu.0x0000000012000000)
[ 6.818967] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu gro up 17
[ 6.827080] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (stream id=56, iommu=smmu.0x0000000012000000)
[ 6.839062] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu gro up 18
[ 6.847229] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (stream id=57, iommu=smmu.0x0000000012000000)
[ 6.859268] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu gro up 19
[ 6.867389] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (stream id=58, iommu=smmu.0x0000000012000000)
[ 6.879391] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu gro up 20
[ 6.887541] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (stream id=59, iommu=smmu.0x0000000012000000)
[ 6.899574] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu gro up 21
[ 6.907720] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (stream id=60, iommu=smmu.0x0000000012000000)
[ 6.919763] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu gro up 22
[ 6.927923] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (stream id=53, iommu=smmu.0x0000000008000000)
[ 6.939902] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu gro up 23
[ 6.948021] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (stream id=54, iommu=smmu.0x0000000008000000)
[ 6.960095] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu gro up 24
[ 6.968245] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (stream id=55, iommu=smmu.0x0000000008000000)
[ 6.980265] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu gro up 25
[ 6.988444] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (stream id=56, iommu=smmu.0x0000000008000000)
dmesg dump[contd]:
[ 7.000469] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu group 26
[ 7.008582] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (streamid=57, iommu=smmu.0x0000000008000000)
[ 7.020597] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu group 27
[ 7.028730] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (streamid=58, iommu=smmu.0x0000000008000000)
[ 7.040745] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu group 28
[ 7.048874] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (streamid=59, iommu=smmu.0x0000000008000000)
[ 7.060897] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu group 29
[ 7.069038] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (streamid=60, iommu=smmu.0x0000000008000000)
[ 7.081049] falcon 15340000.vic: Adding to iommu group 30
[ 7.091918] falcon 15340000.vic: initialized
[ 7.096667] falcon 15380000.nvjpg: Adding to iommu group 31
[ 7.106142] falcon 15380000.nvjpg: initialized
[ 7.110889] falcon 15540000.nvjpg1: Adding to iommu group 32
[ 7.119851] falcon 15540000.nvjpg1: initialized
[ 7.124682] falcon 154c0000.nvenc: Adding to iommu group 33
[ 7.135557] falcon 154c0000.nvenc: initialized
[ 7.141028] falcon 15a50000.ofa: Adding to iommu group 34
[ 7.150835] falcon 15a50000.ofa: initialized
[ 7.156088] nvdec 15480000.nvdec: Adding to iommu group 35
[ 7.168720] nvdec 15480000.nvdec: initialized
[ 7.174025] tsec 15500000.tsec: Adding to iommu group 36
[ 7.184634] tsec 15500000.tsec: initialized
[ 7.192397] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 7.209825] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 7.227294] gpio-394 (camera-control-output-low): hogged as output/low
[ 7.234778] gpio-397 (camera-control-output-low): hogged as output/low
[ 7.242249] gpio-487 (camera-control-output-low): hogged as output/low
[ 7.249684] gpio-486 (camera-control-output-low): hogged as output/low
[ 7.258087] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio
[ 7.265981] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon
[ 7.273653] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 7.280847] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 7.288085] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 7.295103] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 7.304089] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 7.313359] tegra194-isp5 14800000.isp: Adding to iommu group 37
[ 7.323088] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[ 7.333512] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized
[ 7.340808] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group 38
[ 7.349693] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group 39
[ 7.358505] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: context isolation disabled due to no IOMMU
[ 7.369185] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized
[ 7.376673] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: context isolation disabled due to no IOMMU
[ 7.387309] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized
[ 7.394793] scare-pigeon 13e40000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[ 7.405437] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized
[ 7.412949] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: Adding to iommu group 40
[ 7.422426] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: initialized (streamid=18, iommu=smmu.0x0000000008000000)
[ 7.434502] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: Adding to iommu group 41
[ 7.443926] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: initialized (streamid=19, iommu=smmu.0x0000000008000000)
[ 7.455973] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: Adding to iommu group 42
[ 7.465415] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: initialized (streamid=20, iommu=smmu.0x0000000008000000)
[ 7.477476] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: Adding to iommu group 43
[ 7.486926] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: initialized (streamid=21, iommu=smmu.0x0000000008000000)
[ 7.498983] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: Adding to iommu group 44
[ 7.508425] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: initialized (streamid=22, iommu=smmu.0x0000000008000000)
[ 7.520473] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: Adding to iommu group 45
[ 7.529917] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: initialized (streamid=23, iommu=smmu.0x0000000008000000)
[ 7.541996] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: Adding to iommu group 46
[ 7.551427] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: initialized (streamid=24, iommu=smmu.0x0000000008000000)
[ 7.563485] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: Adding to iommu group 47
[ 7.572933] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: initialized (streamid=25, iommu=smmu.0x0000000008000000)
[ 7.585020] pva 16000000.pva0: Adding to iommu group 48
[ 7.610732] pva 16000000.pva0: initialized
[ 7.629134] nvdla 15880000.nvdla0: Adding to iommu group 49
[ 7.644553] nvdla 15880000.nvdla0: initialized
[ 7.651540] nvdla 158c0000.nvdla1: Adding to iommu group 50
[ 7.667074] nvdla 158c0000.nvdla1: initialized
[ 7.674008] tegra-gpcdma 2600000.gpcdma: Adding to iommu group 2
[ 7.681716] tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels
[ 7.689874] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[ 7.697173] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[ 7.704614] serial-tegra 3100000.serial: Adding to iommu group 2
[ 7.711934] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 26, base_baud = 0) is a TEGRA_UART
[ 7.722358] serial-tegra 3110000.serial: Adding to iommu group 2
[ 7.729512] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 78, base_baud = 0) is a TEGRA_UART
[ 7.739803] serial-tegra 3130000.serial: Adding to iommu group 2
[ 7.747055] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 79, base_baud = 0) is a TEGRA_UART
[ 7.774372] tegra-xusb 3610000.xhci: Firmware timestamp: 2023-02-10 03:48:10 UTC, Version: 80.05 release
[ 7.784832] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 7.791108] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 7.800471] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000050810
[ 7.810794] tegra-xusb 3610000.xhci: irq 236, io mem 0x03610000
[ 7.818012] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 7.827250] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.835416] usb usb1: Product: xHCI Host Controller
[ 7.841159] usb usb1: Manufacturer: Linux 5.10.120-tegra xhci-hcd
[ 7.848153] usb usb1: SerialNumber: 3610000.xhci
[ 7.854414] hub 1-0:1.0: USB hub found
[ 7.859039] hub 1-0:1.0: 4 ports detected
[ 7.864141] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 7.870431] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 7.878958] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 7.887252] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 7.896513] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.904690] usb usb2: Product: xHCI Host Controller
[ 7.910460] usb usb2: Manufacturer: Linux 5.10.120-tegra xhci-hcd
[ 7.917495] usb usb2: SerialNumber: 3610000.xhci
[ 7.923486] hub 2-0:1.0: USB hub found
[ 7.928134] hub 2-0:1.0: 4 ports detected
[ 7.956091] tegra23x-oc-event soctherm-oc-event: Finished tegra23x overcurrent event probing
[ 7.982123] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 2005000 KHz, changing to: 2035200 KHz
[ 7.995649] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 2010000 KHz, changing to: 2035200 KHz
[ 8.009514] cpufreq: cpufreq_online: CPU8: Running at unlisted initial frequency: 1955000 KHz, changing to: 1958400 KHz
[ 8.022144] tegra194-cpufreq e000000.ccplex: probed with ICC, cl:3
[ 8.030437] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 8.039210] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 8.040454] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[ 8.052819] tegra194-pcie 14100000.pcie: IO 0x0030100000..0x00301fffff -> 0x0030100000
[ 8.062235] tegra194-pcie 14100000.pcie: MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[ 8.071634] tegra194-pcie 14100000.pcie: MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[ 8.076050] mmc0: CQHCI version 5.10
[ 8.089752] irq: IRQ303: trimming hierarchy from :interrupt-controller@f400000-1
[ 8.098140] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 303
[ 8.119782] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit
[ 8.120314] usb 1-3: new full-speed USB device number 2 using tegra-xusb
[ 8.188315] tegra194-pcie 14100000.pcie: Link up
[ 8.194913] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[ 8.202422] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 8.208750] pci_bus 0001:00: root bus resource [io 0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[ 8.219306] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[ 8.230841] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[ 8.239466] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[ 8.246509] pci 0001:00:00.0: PME# supported from D0 D3hot
[ 8.257687] pci 0001:01:00.0: [10ec:c822] type 00 class 0x028000
[ 8.264771] pci 0001:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 8.271418] pci 0001:01:00.0: reg 0x18: [mem 0x20a8000000-0x20a800ffff 64bit]
[ 8.280576] pci 0001:01:00.0: supports D1 D2
[ 8.285649] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 8.296584] usb 1-3: New USB device found, idVendor=13d3, idProduct=3549, bcdDevice= 0.00
[ 8.298077] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff]
[ 8.305700] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 8.305701] usb 1-3: Product: Bluetooth Radio
[ 8.305702] usb 1-3: Manufacturer: Realtek
[ 8.305703] usb 1-3: SerialNumber: 00e04c000001
[ 8.332141] mmc0: Command Queue Engine enabled
[ 8.337436] pci 0001:00:00.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 8.342717] mmc0: periodic cache flush enabled
[ 8.342723] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 8.343071] mmcblk0: mmc0:0001 G1M15M 59.3 GiB
[ 8.349838] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8000000-0x20a800ffff 64bit]
[ 8.355341] mmcblk0rpmb: mmc0:0001 G1M15M partition 3 4.00 MiB, chardev (510:0)
[ 8.362554] pci 0001:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 8.391636] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 8.397676] pci 0001:00:00.0: bridge window [io 0x1000-0x1fff]
[ 8.404597] pci 0001:00:00.0: bridge window [mem 0x20a8000000-0x20a80fffff]
[ 8.412608] pci 0001:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 8.422039] pci 0001:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 8.422145] usb 2-3: new SuperSpeedPlus Gen 2 USB device number 2 using tegra-xusb
[ 8.431697] pcieport 0001:00:00.0: Adding to iommu group 9
[ 8.446511] pcieport 0001:00:00.0: PME: Signaling with IRQ 64
[ 8.453318] pcieport 0001:00:00.0: AER: enabled with IRQ 64
[ 8.460561] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 8.468759] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[ 8.476620] tegra194-pcie 14160000.pcie: IO 0x0036100000..0x00361fffff -> 0x0036100000
[ 8.476778] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[ 8.485985] tegra194-pcie 14160000.pcie: MEM 0x2428000000..0x242fffffff -> 0x0040000000
[ 8.503047] tegra194-pcie 14160000.pcie: MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[ 8.516522] usb 2-3: New USB device found, idVendor=0bda, idProduct=0420, bcdDevice= 1.40
[ 8.525659] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8.533663] usb 2-3: Product: 4-Port USB 3.0 Hub
[ 8.539068] usb 2-3: Manufacturer: Generic
[ 8.554415] hub 2-3:1.0: USB hub found
[ 8.561490] hub 2-3:1.0: 4 ports detected
[ 8.620460] usb 1-4: new high-speed USB device number 3 using tegra-xusb
[ 8.620476] tegra194-pcie 14160000.pcie: Link up
[ 8.634046] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 8.641537] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 8.647813] pci_bus 0004:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[ 8.658581] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[ 8.670055] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[ 8.678619] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[ 8.685593] pci 0004:00:00.0: PME# supported from D0 D3hot
[ 8.696553] pci 0004:01:00.0: [144d:a80a] type 00 class 0x010802
[ 8.703549] pci 0004:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 8.717031] pci 0004:00:00.0: BAR 14: assigned [mem 0x2428000000-0x24280fffff]
[ 8.725114] pci 0004:01:00.0: BAR 0: assigned [mem 0x2428000000-0x2428003fff 64bit]
[ 8.733730] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 8.739751] pci 0004:00:00.0: bridge window [mem 0x2428000000-0x24280fffff]
[ 8.747761] pci 0004:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 8.757151] pci 0004:01:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 512
[ 8.766748] pcieport 0004:00:00.0: Adding to iommu group 10
[ 8.773405] pcieport 0004:00:00.0: PME: Signaling with IRQ 66
[ 8.780250] pcieport 0004:00:00.0: AER: enabled with IRQ 66
[ 8.786933] nvme 0004:01:00.0: Adding to iommu group 10
[ 8.793405] nvme nvme0: pci function 0004:01:00.0
[ 8.799129] nvme 0004:01:00.0: enabling device (0000 -> 0002)
[ 8.799588] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 8.812890] tegra194-pcie 141a0000.pcie: Failed to get slot regulators: -517
[ 8.812986] vdd-3v3-pcie: supplied by vdd-3v3-sys
[ 8.818640] nvme nvme0: Shutdown timeout set to 10 seconds
[ 8.818671] avdd-cam-2v8: supplied by vdd-3v3-sys
[ 8.830619] vdd-dp: supplied by vdd-3v3-sys
[ 8.835722] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 8.841199] usb 1-4: New USB device found, idVendor=0bda, idProduct=5420, bcdDevice= 1.40
[ 8.841441] dsi-vdd-1v8-bl-en: supplied by vdd-1v8-sys
[ 8.850304] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8.850306] usb 1-4: Product: 4-Port USB 2.0 Hub
[ 8.850310] usb 1-4: Manufacturer: Generic
[ 8.857731] nvme nvme0: 12/0/0 default/read/poll queues
[ 8.858364] tegra194-isp5 14800000.isp: initialized
[ 8.866978] hub 1-4:1.0: USB hub found
[ 8.867557] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized
[ 8.867625] (NULL device *): fops function table already registered
[ 8.868361] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized
[ 8.868856] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 8.869148] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 8.874168] nvme0n1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[ 8.875914] hub 1-4:1.0: 4 ports detected
[ 8.878942] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 303
[ 8.976884] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[ 8.984727] tegra194-pcie 141a0000.pcie: IO 0x003a100000..0x003a1fffff -> 0x003a100000
[ 8.994047] tegra194-pcie 141a0000.pcie: MEM 0x2b28000000..0x2b2fffffff -> 0x0040000000
[ 9.003362] tegra194-pcie 141a0000.pcie: MEM 0x2740000000..0x2b27ffffff -> 0x2740000000
[ 9.664313] usb 1-4.4: new full-speed USB device number 4 using tegra-xusb
[ 9.783545] usb 1-4.4: New USB device found, idVendor=046d, idProduct=c534, bcdDevice=29.01
[ 9.792769] usb 1-4.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 9.800918] usb 1-4.4: Product: USB Receiver
[ 9.805935] usb 1-4.4: Manufacturer: Logitech
[ 9.816739] input: Logitech USB Receiver as /devices/platform/3610000.xhci/usb1/1-4/1-4.4/1-4.4:1.0/0003:046D:C534.0001/input/input0
[ 9.888532] hid-generic 0003:046D:C534.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-3610000.xhci-4.4/input0
[ 9.905983] input: Logitech USB Receiver Mouse as /devices/platform/3610000.xhci/usb1/1-4/1-4.4/1-4.4:1.1/0003:046D:C534.0002/input/input1
[ 9.919534] input: Logitech USB Receiver Consumer Control as /devices/platform/3610000.xhci/usb1/1-4/1-4.4/1-4.4:1.1/0003:046D:C534.0002/input/input2
[ 9.923563] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit
[ 9.992529] input: Logitech USB Receiver System Control as /devices/platform/3610000.xhci/usb1/1-4/1-4.4/1-4.4:1.1/0003:046D:C534.0002/input/input3
[ 10.006988] hid-generic 0003:046D:C534.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-3610000.xhci-4.4/input1
[ 10.120834] tegra194-pcie 141a0000.pcie: Phy link never came up
[ 10.127708] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[ 10.135248] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 10.141598] pci_bus 0005:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x3a100000-0x3a1fffff])
[ 10.152428] pci_bus 0005:00: root bus resource [mem 0x2b28000000-0x2b2fffffff] (bus address [0x40000000-0x47ffffff])
[ 10.163997] pci_bus 0005:00: root bus resource [mem 0x2740000000-0x2b27ffffff pref]
[ 10.172650] pci 0005:00:00.0: [10de:229a] type 01 class 0x060400
[ 10.179715] pci 0005:00:00.0: PME# supported from D0 D3hot
[ 10.194637] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 10.200764] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 10.210492] pcieport 0005:00:00.0: Adding to iommu group 11
[ 10.217224] pcieport 0005:00:00.0: PME: Signaling with IRQ 68
[ 10.224606] pcieport 0005:00:00.0: AER: enabled with IRQ 68
[ 10.231293] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[ 10.238093] pci 0005:00:00.0: Removing from iommu group 11
[ 10.244458] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[ 10.252840] nvethernet 6810000.ethernet: Adding to iommu group 51
[ 10.260172] nvethernet 6810000.ethernet: failed to read skip mac reset flag, default 0
[ 10.269051] nvethernet 6810000.ethernet: failed to read MDIO address
[ 10.276326] nvethernet 6810000.ethernet: setting to default DMA bit mask
[ 10.283953] nvethernet 6810000.ethernet: failed to read UPHY GBE mode- default to 10G
[ 10.682653] nvethernet 6810000.ethernet: Ethernet MAC address: 48:b0:2d:e2:a6:1b
[ 10.691384] -->macsec_probe()
[ 10.691406] nvethernet 6810000.ethernet: macsec param in DT is missing or disabled
[ 10.699920] <--macsec_probe()
[ 10.699921] nvethernet 6810000.ethernet: Macsec not supported/Not enabled in DT
[ 10.710123] nvethernet 6810000.ethernet: eth0 (HW ver: 31) created with 10 DMA channels
[ 10.719589] irq: IRQ318: trimming hierarchy from :pmc@c360000
[ 10.726284] irq: IRQ319: trimming hierarchy from :interrupt-controller@f400000-1
[ 10.734689] irq: IRQ320: trimming hierarchy from :pmc@c360000
[ 10.741398] input: gpio-keys as /devices/platform/gpio-keys/input/input6
[ 10.749736] tegra-se-nvhost 15810000.se: Adding to iommu group 52
[ 10.757218] tegra-se-nvhost 15810000.se: initialized
[ 10.773739] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 10.780821] tegra-se-nvhost 15820000.se: Adding to iommu group 53
[ 10.788079] tegra-se-nvhost 15820000.se: initialized
[ 10.796081] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 10.803153] tegra-se-nvhost 15840000.se: Adding to iommu group 54
[ 10.810403] tegra-se-nvhost 15840000.se: initialized
[ 10.820720] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 10.828403] tegra_actmon d230000.actmon: in actmon_register()...
[ 10.835535] tegra_actmon d230000.actmon: bwmgr_disable = 1
[ 10.842609] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[ 10.851804] hvc_sysfs: hypervisor is not present
[ 10.983983] ALSA device list:
[ 10.987728] No soundcards found.
[ 10.992498] Freeing unused kernel memory: 3968K
[ 10.997886] Run /init as init process
[ 11.002337] with arguments:
[ 11.002338] /init
[ 11.002339] nv-auto-config
[ 11.002339] with environment:
[ 11.002340] HOME=/
[ 11.002341] TERM=linux
[ 11.002342] mminit_loglevel=4
[ 11.014230] Root device found: nvme0n1p1
[ 11.024609] Found dev node: /dev/nvme0n1p1
[ 11.081777] EXT4-fs (nvme0n1p1): recovery complete
[ 11.091949] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. Opts: (null)
[ 11.103007] Rootfs mounted over nvme0n1p1
[ 11.113567] Switching from initrd to actual rootfs
[ 11.152560] systemd[1]: System time before build time, advancing clock.
[ 11.160639] random: crng init done
[ 11.183471] systemd[1]: systemd 245.4-4ubuntu3.22 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 11.208661] systemd[1]: Detected architecture arm64.
[ 11.243471] systemd[1]: Set hostname to <ubuntu>.
[ 11.344967] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 11.358782] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 11.369193] systemd[1]: Created slice system-modprobe.slice.
[ 11.376929] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 11.385199] systemd[1]: Created slice User and Session Slice.
[ 11.392625] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 11.402094] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 11.413323] systemd[1]: Reached target User and Group Name Lookups.
[ 11.421290] systemd[1]: Reached target Slices.
[ 11.427366] systemd[1]: Reached target Swap.
[ 11.433264] systemd[1]: Reached target System Time Set.
[ 11.440377] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 11.448744] systemd[1]: Listening on Syslog Socket.
[ 11.455399] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 11.463922] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 11.472400] systemd[1]: Listening on Journal Audit Socket.
[ 11.479705] systemd[1]: Listening on Journal Socket (/dev/log).
[ 11.487483] systemd[1]: Listening on Journal Socket.
[ 11.494286] systemd[1]: Listening on udev Control Socket.
[ 11.501533] systemd[1]: Listening on udev Kernel Socket.
[ 11.509754] systemd[1]: Mounting Huge Pages File System...
[ 11.518095] systemd[1]: Mounting POSIX Message Queue File System...
[ 11.527180] systemd[1]: Mounting RPC Pipe File System...
[ 11.535334] systemd[1]: Mounting Kernel Debug File System...
[ 11.543909] systemd[1]: Mounting Kernel Trace File System...
[ 11.552680] systemd[1]: Starting Journal Service...
[ 11.560703] systemd[1]: Starting Set the console keyboard layout...
[ 11.569928] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 11.581564] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[ 11.590207] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[ 11.600443] systemd[1]: Starting Load Kernel Module efi_pstore...
[ 11.609390] systemd[1]: Starting Load Kernel Module pstore_blk...
[ 11.618402] systemd[1]: Starting Load Kernel Module pstore_zone...
[ 11.627353] systemd[1]: Starting Load Kernel Module ramoops...
[ 11.636184] systemd[1]: Starting NVIDIA specific first-boot udev script...
[ 11.645926] systemd[1]: Started Nameserver information manager.
[ 11.653826] systemd[1]: Reached target Network (Pre).
[ 11.661105] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 11.671252] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 11.682753] systemd[1]: Starting Load Kernel Modules...
[ 11.690663] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 11.697640] EXT4-fs (nvme0n1p1): re-mounted. Opts: (null)
[ 11.705695] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 11.706567] systemd[1]: Starting udev Coldplug all Devices...
[ 11.713395] tegra-carveouts tegra-carveouts: fsi :dma coherent mem declare 0x0000001038e00000,16777216
[ 11.730282] tegra-carveouts tegra-carveouts: assigned reserved memory node fsi-carveout
[ 11.730292] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x0000001049800000,914358272
[ 11.749784] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 11.749790] nvmap_page_pool_init: Total RAM pages: 16076879
[ 11.765348] nvmap_page_pool_init: nvmap page pool size: 2009609 pages (3754 MB)
[ 11.765509] nvmap_background_zero_thread: PP zeroing thread starting.
[ 11.765598] misc nvmap: created heap vpr base 0x0000001049800000 size (892928KiB)
[ 11.768741] misc nvmap: created heap fsi base 0x0000001038e00000 size (16384KiB)
[ 11.800426] systemd[1]: Started Journal Service.
[ 11.808732] nvgpu: 17000000.ga10b nvgpu_nvhost_syncpt_init:135 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[ 11.851123] systemd-journald[312]: Received client request to flush runtime journal.
[ 12.043526] using random self ethernet address
[ 12.048851] using random host ethernet address
[ 12.129843] nvidia: loading out-of-tree module taints kernel.
[ 12.141319] nv_platform 13800000.display: Adding to iommu group 55
[ 12.142921] platform 13800000.display:nvdisplay-niso: Adding to iommu group 56
[ 12.145161] NVRM: loading NVIDIA UNIX Open Kernel Module for aarch64 35.4.1 Release Build (buildbrain@mobile-u64-6422-d7000) Tue Aug 1 12:45:41 PDT 2023
[ 12.205888] tegra-hda 3510000.hda: Adding to iommu group 57
[ 12.213458] spi-tegra114 3210000.spi: Adding to iommu group 2
[ 12.217764] spi-tegra114 3230000.spi: Adding to iommu group 2
[ 12.228414] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=3 as /devices/platform/3510000.hda/sound/card0/input7
[ 12.228860] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=7 as /devices/platform/3510000.hda/sound/card0/input8
[ 12.229250] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=8 as /devices/platform/3510000.hda/sound/card0/input9
[ 12.230207] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=9 as /devices/platform/3510000.hda/sound/card0/input10
[ 12.230567] nvadsp 2993000.adsp: Adding to iommu group 58
[ 12.230703] nvadsp 2993000.adsp: in probe()...
[ 12.232619] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ 12.249961] nvvrs11 4-0020: NVVRS11 Vendor ID: 0x11
[ 12.250955] nvvrs11 4-0020: NVVRS11 Model Rev: 0x81
[ 12.250961] nvvrs11 4-0020: NVVRS11 probe successful
[ 12.251002] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 16 channels
[ 12.252372] cdi_tsc c6a0000.tsc_sig_gen: CDI TSC probing...
[ 12.252441] cdi_tsc_probe: Initializing the driver
[ 12.252524] nvvrs11 4-0022: NVVRS11 Vendor ID: 0x11
[ 12.252525] cdi_tsc_probe: Successfully initialized the tsc char driver
[ 12.252904] nvvrs11 4-0022: NVVRS11 Model Rev: 0x81
[ 12.252907] nvvrs11 4-0022: NVVRS11 probe successful
[ 12.253170] cpu-throttle-alert cooling device registered.
[ 12.253480] gpu-throttle-alert cooling device registered.
[ 12.257737] irq: IRQ321: trimming hierarchy from :pmc@c360000
[ 12.262144] irq: IRQ322: trimming hierarchy from :pmc@c360000
[ 12.262186] cv0-throttle-alert cooling device registered.
[ 12.263029] cv1-throttle-alert cooling device registered.
[ 12.263440] cv2-throttle-alert cooling device registered.
[ 12.263843] soc0-throttle-alert cooling device registered.
[ 12.264159] soc1-throttle-alert cooling device registered.
[ 12.279955] soc2-throttle-alert cooling device registered.
[ 12.280159] tegra210-adsp aconnect@2a41000:adsp_audio: Adding to iommu group 58
[ 12.280204] tegra210_adsp_audio_probe: platform probe started
[ 12.281390] tegra210-adsp tegra210-adsp: Default param-type to BYTE for mp3-dec1
[ 12.281621] tegra210-adsp tegra210-adsp: Default param-type to BYTE for spkprot
[ 12.281842] tegra210-adsp tegra210-adsp: Default param-type to BYTE for src
[ 12.282060] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aac-dec1
[ 12.282276] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aec
[ 12.282489] tegra210-adsp tegra210-adsp: Default param-type to BYTE for wire
[ 12.282491] tegra210-adsp tegra210-adsp: adma channel page address dt entry not found
[ 12.282492] tegra210-adsp tegra210-adsp: using adma channel page 0
[ 12.282540] nvadsp 2993000.adsp: ADSP OS firmware already loaded
[ 12.284174] hot-surface-alert cooling device registered.
[ 12.288561] irq: IRQ323: trimming hierarchy from :pmc@c360000
[ 12.288578] nct1008_nct72 4-004c: starting parse dt
[ 12.288645] nct1008_nct72 4-004c: !!!Found deprecated property!!!
[ 12.288648] nct1008_nct72 4-004c: success parsing dt
[ 12.288742] nct1008_nct72 4-004c: success in enabling tmp451 VDD rail
[ 12.294452] OF: graph: no port node found in /i2c@c240000/ucsi_ccg@8/connector@0
[ 12.302697] ucsi_ccg 1-0008: Port-0: no role switch found
[ 12.324563] nct1008_nct72 4-004c: LOC shutdown limit 107
[ 12.325177] nct1008_nct72 4-004c: EXT shutdown limit 107
[ 12.359765] loop: module loaded
[ 12.360905] nct1008_nct72 4-004c: initial LOC temp: 36000
[ 12.361390] nct1008_nct72 4-004c: initial EXT temp: 42500
[ 12.362317] nct1008_nct72 4-004c: hi_b:-4, lo_b:0
[ 12.362925] tegra-asoc: sound: Adding to iommu group 58
[ 12.363331] nct1008_nct72 4-004c: nct1008_probe: initialized
[ 12.373175] usbcore: registered new interface driver btusb
[ 12.377195] rtk_btusb: Realtek Bluetooth USB driver ver 3.1
[ 12.377200] rtk_btcoex: rtk_btcoex_init: version: 1.2
[ 12.377201] rtk_btcoex: create workqueue
[ 12.377540] rtk_btcoex: alloc buffers 1792, 2432 for ev and l2
[ 12.377584] rtk_btusb: btusb_probe intf->cur_altsetting->desc.bInterfaceNumber 0
[ 12.377586] rtk_btusb: btusb_probe can_wakeup 1, may wakeup 0
[ 12.377588] rtk_btusb: patch_add
[ 12.377590] rtk_btusb: auto suspend is disabled
[ 12.377592] rtk_btusb: pid = 0x3549
[ 12.377594] rtk_btusb: patch_add: Reset gEVersion to 0xff
[ 12.377601] rtk_btusb: set_bit(HCI_QUIRK_RESET_ON_CLOSE, &hdev->quirks);
[ 12.377746] rtk_btusb: btusb_probe: done
[ 12.377777] usbcore: registered new interface driver rtk_btusb
[ 12.377794] rtk_btusb: btusb_open start
[ 12.377796] rtk_btusb: btusb_open hdev->promisc ==0
[ 12.377797] rtk_btusb: download_patch start
[ 12.377799] rtk_btusb: chip type value: 0x73
[ 12.377801] rtk_btusb: HCI reset.
[ 12.389186] rtk_btusb: read_ver_rsp->lmp_subver = 0x8822
[ 12.389191] rtk_btusb: read_ver_rsp->hci_rev = 0xc
[ 12.389192] rtk_btusb: patch_entry->lmp_sub = 0x8822
[ 12.389193] rtk_btusb: load_firmware start
[ 12.389195] rtk_btusb: lmp_version = 0x8822
[ 12.389196] rtk_btusb: config filename rtl8822cu_config
[ 12.389766] rtk_btusb: no bdaddr file /opt/bdaddr
[ 12.389770] rtk_btusb: 55 ab 23 87 00 00
[ 12.389775] rtk_btusb: Config file length 6, new length 6
[ 12.389776] rtk_btusb: fw name is rtl8822cu_fw
[ 12.389972] rtk_btusb: This is not 8723a, use new patch style!
[ 12.389974] rtk_btusb: rtk_get_eversion: gEVersion 255
[ 12.390350] OF: graph: no port node found in /i2c@c240000/ucsi_ccg@8/connector@0
[ 12.398806] OF: graph: no port node found in /i2c@c240000/ucsi_ccg@8/connector@0
[ 12.407031] rtk_btusb: eversion->status = 0x0, eversion->version = 0x3
[ 12.407035] rtk_btusb: load_firmware: New gEVersion 3
[ 12.407037] rtk_btusb: rtk_get_fw_project_id: opcode 0, len 1, data 13
[ 12.407039] rtk_btusb: lmp_version is 8822, project_id is 8822, match!
[ 12.407042] rtk_btusb: fw_version = 0x9a8cbc9
[ 12.407045] rtk_btusb: number_of_total_patch = 3
[ 12.407050] rtk_btusb: chipID 4
[ 12.407053] rtk_btusb: patch_length 0x8590
[ 12.407054] rtk_btusb: start_offset 0x00005d00
[ 12.407056] rtk_btusb: Svn version: 1940234490
[ 12.407058] rtk_btusb: Coexistence: BTCOEX_20210106-2020
[ 12.407058] rtk_btusb: buf_len = 0x8596
[ 12.407070] rtk_btusb: fw: exists, config file: exists
[ 12.407073] rtk_btusb: load_firmware done
[ 12.407091] rtk_btusb: download_data start
[ 12.420645] cryptd: max_cpu_qlen set to 1000
[ 12.478631] Mass Storage Function, version: 2009/09/11
[ 12.478636] LUN: removable file: (no medium)
[ 12.480887] using random self ethernet address
[ 12.486209] using random host ethernet address
[ 12.555261] logitech-djreceiver 0003:046D:C534.0001: hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-3610000.xhci-4.4/input0
[ 12.583188] rtk_btusb: download_data done
[ 12.583192] rtk_btusb: HCI reset.
[ 12.586201] tegra210-adsp tegra210-adsp: Loaded app wire
[ 12.586205] tegra210-adsp tegra210-adsp: Loaded app apm
[ 12.586206] tegra210-adsp tegra210-adsp: Loaded app adma
[ 12.586208] tegra210-adsp tegra210-adsp: Loaded app adma_tx
[ 12.586210] nvadsp_set_adma_dump_reg: callback for adma reg dump is sent to 0000000004c72ce1
[ 12.594174] rtk_btusb: read_ver_rsp->lmp_subver = 0xcbc9
[ 12.594176] rtk_btusb: read_ver_rsp->hci_rev = 0x9a8
[ 12.594177] rtk_btusb: patch_entry->lmp_sub = 0x8822
[ 12.594183] rtk_btusb: Rtk patch end 0
[ 12.594185] rtk_btusb: btusb_open set HCI_RUNNING
[ 12.594203] rtk_btcoex: Open BTCOEX
[ 12.594204] rtk_btusb: btusb_open end
[ 12.596183] rtk_btcoex: BTCOEX hci_rev 0x09a8
[ 12.596185] rtk_btcoex: BTCOEX lmp_subver 0xcbc9
[ 12.606269] tegra210-adsp tegra210-adsp: Tegra210 ADSP driver successfully registered
[ 12.616177] rtk_btusb: btusb_notify: hci0 evt 3
[ 12.683346] irq: IRQ325: trimming hierarchy from :interrupt-controller@f400000-1
[ 12.683775] hwmon hwmon6: temp1_input not attached to any thermal zone
[ 12.709289] input: NVIDIA Jetson AGX Orin APE Headset Jack as /devices/platform/sound/sound/card1/input11
[ 12.836697] logitech-djreceiver 0003:046D:C534.0002: hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-3610000.xhci-4.4/input1
[ 12.899295] logitech-djreceiver 0003:046D:C534.0002: device of type eQUAD nano Lite (0x0a) connected on slot 1
[ 12.899856] input: Logitech Wireless Keyboard PID:4023 Keyboard as /devices/platform/3610000.xhci/usb1/1-4/1-4.4/1-4.4:1.1/0003:046D:C534.0002/0003:046D:4023.0003/input/input12
[ 12.900012] input: Logitech Wireless Keyboard PID:4023 Consumer Control as /devices/platform/3610000.xhci/usb1/1-4/1-4.4/1-4.4:1.1/0003:046D:C534.0002/0003:046D:4023.0003/input/input13
[ 12.900135] input: Logitech Wireless Keyboard PID:4023 System Control as /devices/platform/3610000.xhci/usb1/1-4/1-4.4/1-4.4:1.1/0003:046D:C534.0002/0003:046D:4023.0003/input/input14
[ 12.900229] hid-generic 0003:046D:4023.0003: input,hidraw2: USB HID v1.11 Keyboard [Logitech Wireless Keyboard PID:4023] on usb-3610000.xhci-4.4/input1:1
[ 12.901289] logitech-djreceiver 0003:046D:C534.0002: device of type eQUAD nano Lite (0x0a) connected on slot 2
[ 12.901584] input: Logitech Wireless Mouse PID:4058 Mouse as /devices/platform/3610000.xhci/usb1/1-4/1-4.4/1-4.4:1.1/0003:046D:C534.0002/0003:046D:4058.0004/input/input19
[ 12.901748] hid-generic 0003:046D:4058.0004: input,hidraw3: USB HID v1.11 Mouse [Logitech Wireless Mouse PID:4058] on usb-3610000.xhci-4.4/input1:2
[ 13.204651] nvgpu: 17000000.ga10b tpc_pg_mask_store:1070 [INFO] no value change, same mask already set
[ 13.205111] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 13.205124] Bluetooth: BNEP socket layer initialized
[ 13.205474] pstore: Using crash dump compression: deflate
[ 13.205910] printk: console [ramoops-1] enabled
[ 13.205914] pstore: Registered ramoops as persistent store backend
[ 13.205917] ramoops: using 0x200000@0x102d270000, ecc: 0
[ 13.291439] input: Logitech Wireless Keyboard PID:4023 as /devices/platform/3610000.xhci/usb1/1-4/1-4.4/1-4.4:1.1/0003:046D:C534.0002/0003:046D:4023.0003/input/input23
[ 13.291665] logitech-hidpp-device 0003:046D:4023.0003: input,hidraw2: USB HID v1.11 Keyboard [Logitech Wireless Keyboard PID:4023] on usb-3610000.xhci-4.4/input1:1
[ 13.367368] input: Logitech Wireless Mouse as /devices/platform/3610000.xhci/usb1/1-4/1-4.4/1-4.4:1.1/0003:046D:C534.0002/0003:046D:4058.0004/input/input24
[ 13.367531] logitech-hidpp-device 0003:046D:4058.0004: input,hidraw3: USB HID v1.11 Mouse [Logitech Wireless Mouse] on usb-3610000.xhci-4.4/input1:2
[ 13.381046] nvgpu: 17000000.ga10b gk20a_scale_init:541 [INFO] enabled scaling for GPU
[ 13.404151] Aquantia AQR113C 6810000.ethernet:00: No AQR phy_mode setting in DT
[ 13.404154] rtl88x2ce 0001:01:00.0: Adding to iommu group 9
[ 13.404593] rtl88x2ce 0001:01:00.0: enabling device (0000 -> 0003)
[ 13.408586] rndis0: HOST MAC ee:65:c0:6c:ea:48
[ 13.408590] rndis0: MAC ee:65:c0:6c:ea:49
[ 13.408954] usb0: HOST MAC ee:65:c0:6c:ea:4a
[ 13.408956] usb0: MAC ee:65:c0:6c:ea:4b
[ 13.432532] tegra-xudc 3550000.xudc: EP 0 (type: ctrl, dir: out) enabled
[ 13.434781] l4tbr0: port 1(rndis0) entered blocking state
[ 13.434792] l4tbr0: port 1(rndis0) entered disabled state
[ 13.434911] device rndis0 entered promiscuous mode
[ 13.439507] l4tbr0: port 2(usb0) entered blocking state
[ 13.439518] l4tbr0: port 2(usb0) entered disabled state
[ 13.439633] device usb0 entered promiscuous mode
[ 14.527046] zram: Added device: zram0
[ 14.527565] zram: Added device: zram1
[ 14.527948] zram: Added device: zram2
[ 14.530458] zram: Added device: zram3
[ 14.531069] zram: Added device: zram4
[ 14.531999] zram: Added device: zram5
[ 14.532868] zram: Added device: zram6
[ 14.533057] zram: Added device: zram7
[ 14.533351] zram: Added device: zram8
[ 14.533513] zram: Added device: zram9
[ 14.533635] zram: Added device: zram10
[ 14.533802] zram: Added device: zram11
[ 14.549875] zram0: detected capacity change from 0 to 2743787520
[ 14.596374] Adding 2679476k swap on /dev/zram0. Priority:5 extents:1 across:2679476k SS
[ 14.598527] zram1: detected capacity change from 0 to 2743787520
[ 14.628377] Adding 2679476k swap on /dev/zram1. Priority:5 extents:1 across:2679476k SS
[ 14.630200] zram2: detected capacity change from 0 to 2743787520
[ 14.680611] Adding 2679476k swap on /dev/zram2. Priority:5 extents:1 across:2679476k SS
[ 14.683032] zram3: detected capacity change from 0 to 2743787520
[ 14.740363] Adding 2679476k swap on /dev/zram3. Priority:5 extents:1 across:2679476k SS
[ 14.742657] zram4: detected capacity change from 0 to 2743787520
[ 14.796449] Adding 2679476k swap on /dev/zram4. Priority:5 extents:1 across:2679476k SS
[ 14.798748] zram5: detected capacity change from 0 to 2743787520
[ 14.848417] Adding 2679476k swap on /dev/zram5. Priority:5 extents:1 across:2679476k SS
[ 14.850752] zram6: detected capacity change from 0 to 2743787520
[ 14.912453] Adding 2679476k swap on /dev/zram6. Priority:5 extents:1 across:2679476k SS
[ 14.914785] zram7: detected capacity change from 0 to 2743787520
[ 14.976413] Adding 2679476k swap on /dev/zram7. Priority:5 extents:1 across:2679476k SS
[ 14.978890] zram8: detected capacity change from 0 to 2743787520
[ 15.024375] Adding 2679476k swap on /dev/zram8. Priority:5 extents:1 across:2679476k SS
[ 15.026961] zram9: detected capacity change from 0 to 2743787520
[ 15.044942] Bridge firewalling registered
[ 15.060363] Adding 2679476k swap on /dev/zram9. Priority:5 extents:1 across:2679476k SS
[ 15.063193] zram10: detected capacity change from 0 to 2743787520
[ 15.088362] Adding 2679476k swap on /dev/zram10. Priority:5 extents:1 across:2679476k SS
[ 15.091404] zram11: detected capacity change from 0 to 2743787520
[ 15.140432] Adding 2679476k swap on /dev/zram11. Priority:5 extents:1 across:2679476k SS
[ 17.677162] tegra-xudc 3550000.xudc: EP 5 (type: intr, dir: in) enabled
[ 17.677179] tegra-xudc 3550000.xudc: EP 3 (type: bulk, dir: in) enabled
[ 17.677191] tegra-xudc 3550000.xudc: EP 2 (type: bulk, dir: out) enabled
[ 17.677245] tegra-xudc 3550000.xudc: EP 9 (type: intr, dir: in) enabled
[ 17.677257] tegra-xudc 3550000.xudc: EP 7 (type: bulk, dir: in) enabled
[ 17.677268] tegra-xudc 3550000.xudc: EP 4 (type: bulk, dir: out) enabled
[ 17.677338] tegra-xudc 3550000.xudc: EP 15 (type: intr, dir: in) enabled
[ 17.677362] tegra-xudc 3550000.xudc: EP 11 (type: bulk, dir: in) enabled
[ 17.677383] tegra-xudc 3550000.xudc: EP 6 (type: bulk, dir: out) enabled
[ 17.677424] IPv6: ADDRCONF(NETDEV_CHANGE): rndis0: link becomes ready
[ 18.326592] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 18.474576] l4tbr0: port 1(rndis0) entered blocking state
[ 18.474584] l4tbr0: port 1(rndis0) entered forwarding state
[ 18.684323] IPv6: ADDRCONF(NETDEV_CHANGE): l4tbr0: link becomes ready
[ 28.085159] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[ 42.436369] vdd-12v-sys: disabling
[ 42.436384] vdd-3v3-ftdi: disabling
[ 574.826106] fuse: init (API version 7.32)
Learn to put log with
THIS IS HOW IT SHOULD BE LIKE
Or it’s hella hard to read.
Is it a custom carrier board or a DevKit?
Is it L4T 35.4.1/JetPack 5.1.2?
Is the driver being loaded? What do you get with lsmod | grep nv?
Also show me contents of /var/log/Xorg.0.log.
It is a DevKit.
Yes, it is L4T 35.4.1.
The output from lsmod | grep nv is as follows
i2c_nvvrs11 16384 0
nvadsp 110592 1 snd_soc_tegra210_adsp
nv_hawk_owl 36864 1 cam_cdi_tsc
max96712 20480 1 nv_hawk_owl
nvidia 1327104 0
nvgpu 2514944 0
nvmap 192512 2 nvgpu
The contents of /var/log/Xorg.0.log are the following
[ 14.458] (--) Log file renamed from "/var/log/Xorg.pid-1912.log" to "/var/log/Xorg.0.log"
[ 14.459]
X.Org X Server 1.20.13
X Protocol Version 11, Revision 0
[ 14.459] Build Operating System: linux Ubuntu
[ 14.459] Current Operating System: Linux ubuntu 5.10.120-tegra #1 SMP PREEMPT Tue Aug 1 12:32:50 PDT 2023 aarch64
[ 14.459] Kernel command line: root=/dev/nvme0n1p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 console=tty0 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb nv-auto-config
[ 14.459] Build Date: 29 March 2023 12:53:02PM
[ 14.459] xorg-server 2:1.20.13-1ubuntu1~20.04.8 (For technical support please see http://www.ubuntu.com/support)
[ 14.459] Current version of pixman: 0.38.4
[ 14.459] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 14.459] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 14.459] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Mar 27 13:54:09 2023
[ 14.460] (==) Using config file: "/etc/X11/xorg.conf"
[ 14.460] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 14.460] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 14.461] (==) No Layout section. Using the first Screen section.
[ 14.461] (==) No screen section available. Using defaults.
[ 14.461] (**) |-->Screen "Default Screen Section" (0)
[ 14.461] (**) | |-->Monitor "<default monitor>"
[ 14.461] (==) No device specified for screen "Default Screen Section".
Using the first device section listed.
[ 14.461] (**) | |-->Device "Tegra0"
[ 14.461] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 14.461] (==) Automatically adding devices
[ 14.461] (==) Automatically enabling devices
[ 14.461] (==) Automatically adding GPU devices
[ 14.461] (==) Automatically binding GPU devices
[ 14.461] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 14.462] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 14.462] Entry deleted from font path.
[ 14.462] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 14.462] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 14.462] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 14.462] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 14.462] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 14.462] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 14.462] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 14.462] (II) Loader magic: 0xaaaacf07a010
[ 14.462] (II) Module ABI versions:
[ 14.462] X.Org ANSI C Emulation: 0.4
[ 14.462] X.Org Video Driver: 24.1
[ 14.462] X.Org XInput driver : 24.1
[ 14.462] X.Org Server Extension : 10.0
[ 14.463] (++) using VT number 1
[ 14.465] (II) systemd-logind: took control of session /org/freedesktop/login1/session/c1
[ 14.466] (II) no primary bus or device found
[ 14.466] (WW) "dri" will not be loaded unless you've specified it to be loaded elsewhere.
[ 14.466] (II) "glx" will be loaded by default.
[ 14.466] (II) LoadModule: "extmod"
[ 14.466] (II) Module "extmod" already built-in
[ 14.466] (II) LoadModule: "glx"
[ 14.467] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 14.470] (II) Module glx: vendor="X.Org Foundation"
[ 14.470] compiled for 1.20.13, module version = 1.0.0
[ 14.470] ABI class: X.Org Server Extension, version 10.0
[ 14.470] (II) LoadModule: "nvidia"
[ 14.470] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 14.476] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 14.476] compiled for 1.6.99.901, module version = 1.0.0
[ 14.476] Module class: X.Org Video Driver
[ 14.477] (II) NVIDIA dlloader X Driver 35.4.1 Release Build (bugfix_main) (buildbrain@mobile-u64-6422-d7000) Tue Aug 1 12:40:10 PDT 2023
[ 14.477] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 14.477] (WW) Falling back to old probe method for NVIDIA
[ 14.478] (II) Loading sub module "fb"
[ 14.478] (II) LoadModule: "fb"
[ 14.478] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 14.478] (II) Module fb: vendor="X.Org Foundation"
[ 14.479] compiled for 1.20.13, module version = 1.0.0
[ 14.479] ABI class: X.Org ANSI C Emulation, version 0.4
[ 14.479] (II) Loading sub module "wfb"
[ 14.479] (II) LoadModule: "wfb"
[ 14.479] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 14.479] (II) Module wfb: vendor="X.Org Foundation"
[ 14.479] (II) Loading sub module "ramdac"
[ 14.479] (II) LoadModule: "ramdac"
[ 14.479] (II) Module "ramdac" already built-in
[ 14.481] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 14.481] (II) NVIDIA(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 14.481] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 14.481] (==) NVIDIA(0): RGB weight 888
[ 14.481] (==) NVIDIA(0): Default visual is TrueColor
[ 14.481] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 14.481] (DB) xf86MergeOutputClassOptions unsupported bus type 0
[ 14.481] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration" "true"
[ 14.481] (**) NVIDIA(0): Enabling 2D acceleration
[ 14.481] (II) Loading sub module "glxserver_nvidia"
[ 14.481] (II) LoadModule: "glxserver_nvidia"
[ 14.481] (II) Loading /usr/lib/xorg/modules/extensions/libglxserver_nvidia.so
[ 14.496] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 14.496] compiled for 1.6.99.901, module version = 1.0.0
[ 14.496] Module class: X.Org Server Extension
[ 14.496] (II) NVIDIA GLX Module 35.4.1 Release Build (bugfix_main) (buildbrain@mobile-u64-6422-d7000) Tue Aug 1 12:38:45 PDT 2023
[ 14.497] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 14.915] (--) NVIDIA(0): Valid display device(s) on GPU-0 at SoC
[ 14.915] (--) NVIDIA(0): DFP-0
[ 14.915] (--) NVIDIA(0): DFP-1
[ 14.916] (WW) NVIDIA: No DRM device: No direct render devices found.
[ 14.918] (II) NVIDIA(0): NVIDIA GPU Orin (nvgpu) (GA10B) at SoC (GPU-0)
[ 14.918] (--) NVIDIA(0): Memory: 64307512 kBytes
[ 14.918] (--) NVIDIA(0): VideoBIOS:
[ 14.921] (--) NVIDIA(GPU-0): DELL P2722H (DFP-0): connected
[ 14.921] (--) NVIDIA(GPU-0): DELL P2722H (DFP-0): Internal DisplayPort
[ 14.921] (--) NVIDIA(GPU-0): DELL P2722H (DFP-0): 2380.0 MHz maximum pixel clock
[ 14.924] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 14.924] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 14.924] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 14.946] (==) NVIDIA(0):
[ 14.946] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 14.946] (==) NVIDIA(0): will be used as the requested mode.
[ 14.950] (II) NVIDIA(0): Validated MetaModes:
[ 14.950] (II) NVIDIA(0): "DFP-0:nvidia-auto-select"
[ 14.950] (II) NVIDIA(0): Virtual screen size determined to be 1920 x 1080
[ 15.036] (--) NVIDIA(0): DPI set to (81, 80); computed from "UseEdidDpi" X config
[ 15.037] (--) NVIDIA(0): option
[ 15.037] (II) NVIDIA: Reserving 24576.00 MB of virtual memory for indirect memory
[ 15.037] (II) NVIDIA: access.
[ 15.037] (WW) NVIDIA(GPU-0): Failed to enter interactive mode.
[ 15.047] (EE) NVIDIA(0): Failed to allocate NVIDIA Error Handler
[ 15.047] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 15.047] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 15.047] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 15.047] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 15.047] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 15.047] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 15.047] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 15.047] (II) NVIDIA(0): Config Options in the README.
[ 15.074] (II) NVIDIA(0): Setting mode "DFP-0:nvidia-auto-select"
[ 15.232] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 15.232] (==) NVIDIA(0): Backing store enabled
[ 15.232] (==) NVIDIA(0): Silken mouse enabled
[ 15.233] (==) NVIDIA(0): DPMS enabled
[ 15.233] (II) Loading sub module "dri2"
[ 15.233] (II) LoadModule: "dri2"
[ 15.233] (II) Module "dri2" already built-in
[ 15.233] (II) NVIDIA(0): [DRI2] Setup complete
[ 15.233] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 15.234] (II) Initializing extension Generic Event Extension
[ 15.234] (II) Initializing extension SHAPE
[ 15.234] (II) Initializing extension MIT-SHM
[ 15.234] (II) Initializing extension XInputExtension
[ 15.234] (II) Initializing extension XTEST
[ 15.235] (II) Initializing extension BIG-REQUESTS
[ 15.235] (II) Initializing extension SYNC
[ 15.235] (II) Initializing extension XKEYBOARD
[ 15.235] (II) Initializing extension XC-MISC
[ 15.235] (II) Initializing extension SECURITY
[ 15.235] (II) Initializing extension XFIXES
[ 15.235] (II) Initializing extension RENDER
[ 15.235] (II) Initializing extension RANDR
[ 15.236] (II) Initializing extension COMPOSITE
[ 15.236] (II) Initializing extension DAMAGE
[ 15.236] (II) Initializing extension MIT-SCREEN-SAVER
[ 15.236] (II) Initializing extension DOUBLE-BUFFER
[ 15.236] (II) Initializing extension RECORD
[ 15.236] (II) Initializing extension DPMS
[ 15.236] (II) Initializing extension Present
[ 15.236] (II) Initializing extension DRI3
[ 15.236] (II) Initializing extension X-Resource
[ 15.237] (II) Initializing extension XVideo
[ 15.237] (II) Initializing extension XVideo-MotionCompensation
[ 15.237] (II) Initializing extension SELinux
[ 15.237] (II) SELinux: Disabled on system
[ 15.237] (II) Initializing extension GLX
[ 15.237] (II) Indirect GLX disabled.
[ 15.237] (II) GLX: Another vendor is already registered for screen 0
[ 15.237] (II) Initializing extension XFree86-VidModeExtension
[ 15.237] (II) Initializing extension XFree86-DGA
[ 15.237] (II) Initializing extension XFree86-DRI
[ 15.237] (II) Initializing extension DRI2
[ 15.237] (II) Initializing extension NV-GLX
[ 15.238] (II) Initializing extension NV-CONTROL
[ 15.238] (II) Initializing extension XINERAMA
[ 15.282] (II) config/udev: Adding input device NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=9 (/dev/input/event8)
[ 15.282] (II) No input driver specified, ignoring this device.
[ 15.282] (II) This device may have been added with another device file.
[ 15.282] (II) config/udev: Adding input device NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=3 (/dev/input/event5)
[ 15.283] (II) config/udev: Adding input device NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=7 (/dev/input/event6)
[ 15.283] (II) No input driver specified, ignoring this device.
[ 15.283] (II) This device may have been added with another device file.
[ 15.283] (II) config/udev: Adding input device NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=8 (/dev/input/event7)
[ 15.284] (II) config/udev: Adding input device Logitech Wireless Keyboard PID:4023 (/dev/input/event1)
[ 15.284] (**) Logitech Wireless Keyboard PID:4023: Applying InputClass "libinput keyboard catchall"
[ 15.284] (II) LoadModule: "libinput"
[ 15.284] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 15.287] (II) Module libinput: vendor="X.Org Foundation"
[ 15.287] compiled for 1.20.4, module version = 0.29.0
[ 15.287] Module class: X.Org XInput Driver
[ 15.287] ABI class: X.Org XInput driver, version 24.1
[ 15.287] (II) Using input driver 'libinput' for 'Logitech Wireless Keyboard PID:4023'
[ 15.288] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 33 paused 0
[ 15.288] (**) Logitech Wireless Keyboard PID:4023: always reports core events
[ 15.288] (**) Option "Device" "/dev/input/event1"
[ 15.288] (**) Option "_source" "server/udev"
[ 15.295] (II) event1 - Logitech Wireless Keyboard PID:4023: is tagged by udev as: Keyboard
[ 15.295] (II) event1 - Logitech Wireless Keyboard PID:4023: device is a keyboard
[ 15.295] (II) event1 - Logitech Wireless Keyboard PID:4023: device removed
[ 15.295] (II) libinput: Logitech Wireless Keyboard PID:4023: needs a virtual subdevice
[ 15.295] (**) Option "config_info" "udev:/sys/devices/platform/3610000.xhci/usb1/1-4/1-4.4/1-4.4:1.1/0003:046D:C534.0002/0003:046D:4023.0003/input/input23/event1"
[ 15.295] (II) XINPUT: Adding extended input device "Logitech Wireless Keyboard PID:4023" (type: MOUSE, id 6)
[ 15.295] (**) Option "AccelerationScheme" "none"
[ 15.295] (**) Logitech Wireless Keyboard PID:4023: (accel) selected scheme none/0
[ 15.295] (**) Logitech Wireless Keyboard PID:4023: (accel) acceleration factor: 2.000
[ 15.295] (**) Logitech Wireless Keyboard PID:4023: (accel) acceleration threshold: 4
[ 15.297] (II) event1 - Logitech Wireless Keyboard PID:4023: is tagged by udev as: Keyboard
[ 15.297] (II) event1 - Logitech Wireless Keyboard PID:4023: device is a keyboard
[ 15.298] (II) config/udev: Adding input device Logitech Wireless Mouse (/dev/input/event2)
[ 15.298] (**) Logitech Wireless Mouse: Applying InputClass "libinput pointer catchall"
[ 15.298] (II) Using input driver 'libinput' for 'Logitech Wireless Mouse'
[ 15.299] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 36 paused 0
[ 15.299] (**) Logitech Wireless Mouse: always reports core events
[ 15.299] (**) Option "Device" "/dev/input/event2"
[ 15.299] (**) Option "_source" "server/udev"
[ 15.301] (II) event2 - Logitech Wireless Mouse: is tagged by udev as: Mouse
[ 15.301] (II) event2 - Logitech Wireless Mouse: device is a pointer
[ 15.301] (II) event2 - Logitech Wireless Mouse: device removed
[ 15.301] (**) Option "config_info" "udev:/sys/devices/platform/3610000.xhci/usb1/1-4/1-4.4/1-4.4:1.1/0003:046D:C534.0002/0003:046D:4058.0004/input/input24/event2"
[ 15.301] (II) XINPUT: Adding extended input device "Logitech Wireless Mouse" (type: MOUSE, id 7)
[ 15.301] (**) Option "AccelerationScheme" "none"
[ 15.301] (**) Logitech Wireless Mouse: (accel) selected scheme none/0
[ 15.301] (**) Logitech Wireless Mouse: (accel) acceleration factor: 2.000
[ 15.301] (**) Logitech Wireless Mouse: (accel) acceleration threshold: 4
[ 15.303] (II) event2 - Logitech Wireless Mouse: is tagged by udev as: Mouse
[ 15.303] (II) event2 - Logitech Wireless Mouse: device is a pointer
[ 15.304] (II) config/udev: Adding input device Logitech Wireless Mouse (/dev/input/mouse0)
[ 15.304] (II) No input driver specified, ignoring this device.
[ 15.304] (II) This device may have been added with another device file.
[ 15.304] (II) config/udev: Adding input device gpio-keys (/dev/input/event4)
[ 15.304] (**) gpio-keys: Applying InputClass "libinput keyboard catchall"
[ 15.304] (II) Using input driver 'libinput' for 'gpio-keys'
[ 15.305] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 37 paused 0
[ 15.305] (**) gpio-keys: always reports core events
[ 15.305] (**) Option "Device" "/dev/input/event4"
[ 15.305] (**) Option "_source" "server/udev"
[ 15.306] (II) event4 - gpio-keys: is tagged by udev as: Keyboard
[ 15.306] (II) event4 - gpio-keys: device is a keyboard
[ 15.306] (II) event4 - gpio-keys: device removed
[ 15.306] (**) Option "config_info" "udev:/sys/devices/platform/gpio-keys/input/input6/event4"
[ 15.306] (II) XINPUT: Adding extended input device "gpio-keys" (type: KEYBOARD, id 8)
[ 15.306] (**) Option "xkb_model" "pc105"
[ 15.306] (**) Option "xkb_layout" "us"
[ 15.307] (II) event4 - gpio-keys: is tagged by udev as: Keyboard
[ 15.307] (II) event4 - gpio-keys: device is a keyboard
[ 15.308] (II) config/udev: Adding input device NVIDIA Jetson AGX Orin APE Headset Jack (/dev/input/event0)
[ 15.308] (**) NVIDIA Jetson AGX Orin APE Headset Jack: Applying InputClass "libinput keyboard catchall"
[ 15.308] (II) Using input driver 'libinput' for 'NVIDIA Jetson AGX Orin APE Headset Jack'
[ 15.308] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 38 paused 0
[ 15.308] (**) NVIDIA Jetson AGX Orin APE Headset Jack: always reports core events
[ 15.308] (**) Option "Device" "/dev/input/event0"
[ 15.308] (**) Option "_source" "server/udev"
[ 15.309] (II) event0 - NVIDIA Jetson AGX Orin APE Headset Jack: is tagged by udev as: Keyboard Switch
[ 15.309] (II) event0 - NVIDIA Jetson AGX Orin APE Headset Jack: device is a keyboard
[ 15.309] (II) event0 - NVIDIA Jetson AGX Orin APE Headset Jack: device removed
[ 15.309] (**) Option "config_info" "udev:/sys/devices/platform/sound/sound/card1/input11/event0"
[ 15.309] (II) XINPUT: Adding extended input device "NVIDIA Jetson AGX Orin APE Headset Jack" (type: KEYBOARD, id 9)
[ 15.309] (**) Option "xkb_model" "pc105"
[ 15.309] (**) Option "xkb_layout" "us"
[ 15.310] (II) event0 - NVIDIA Jetson AGX Orin APE Headset Jack: is tagged by udev as: Keyboard Switch
[ 15.310] (II) event0 - NVIDIA Jetson AGX Orin APE Headset Jack: device is a keyboard
[ 15.317] (**) Logitech Wireless Keyboard PID:4023: Applying InputClass "libinput keyboard catchall"
[ 15.317] (II) Using input driver 'libinput' for 'Logitech Wireless Keyboard PID:4023'
[ 15.317] (II) systemd-logind: returning pre-existing fd for /dev/input/event1 13:65
[ 15.317] (**) Logitech Wireless Keyboard PID:4023: always reports core events
[ 15.317] (**) Option "Device" "/dev/input/event1"
[ 15.317] (**) Option "_source" "_driver/libinput"
[ 15.317] (II) libinput: Logitech Wireless Keyboard PID:4023: is a virtual subdevice
[ 15.317] (**) Option "config_info" "udev:/sys/devices/platform/3610000.xhci/usb1/1-4/1-4.4/1-4.4:1.1/0003:046D:C534.0002/0003:046D:4023.0003/input/input23/event1"
[ 15.317] (II) XINPUT: Adding extended input device "Logitech Wireless Keyboard PID:4023" (type: KEYBOARD, id 10)
[ 15.317] (**) Option "xkb_model" "pc105"
[ 15.317] (**) Option "xkb_layout" "us"
[ 15.320] (--) NVIDIA(GPU-0): DELL P2722H (DFP-0): connected
[ 15.320] (--) NVIDIA(GPU-0): DELL P2722H (DFP-0): Internal DisplayPort
[ 15.320] (--) NVIDIA(GPU-0): DELL P2722H (DFP-0): 2380.0 MHz maximum pixel clock
[ 16.274] (--) NVIDIA(GPU-0): DELL P2722H (DFP-0): connected
[ 16.274] (--) NVIDIA(GPU-0): DELL P2722H (DFP-0): Internal DisplayPort
[ 16.274] (--) NVIDIA(GPU-0): DELL P2722H (DFP-0): 2380.0 MHz maximum pixel clock
[ 16.278] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 16.278] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 16.278] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 40.837] (**) Option "fd" "33"
[ 40.838] (**) Option "fd" "36"
[ 40.839] (II) event2 - Logitech Wireless Mouse: device removed
[ 40.839] (**) Option "fd" "37"
[ 40.840] (II) event4 - gpio-keys: device removed
[ 40.840] (**) Option "fd" "38"
[ 40.841] (II) event0 - NVIDIA Jetson AGX Orin APE Headset Jack: device removed
[ 40.841] (**) Option "fd" "33"
[ 40.841] (II) event1 - Logitech Wireless Keyboard PID:4023: device removed
[ 40.917] (II) systemd-logind: got pause for 13:65
[ 40.917] (II) systemd-logind: got pause for 13:68
[ 40.917] (II) systemd-logind: got pause for 13:64
[ 40.917] (II) systemd-logind: got pause for 13:66
[ 19448.189] (II) UnloadModule: "libinput"
[ 19448.189] (II) systemd-logind: not releasing fd for 13:65, still in use
[ 19448.189] (II) systemd-logind: releasing fd for 13:64
[ 19448.268] (II) UnloadModule: "libinput"
[ 19448.268] (II) systemd-logind: releasing fd for 13:68
[ 19448.288] (II) UnloadModule: "libinput"
[ 19448.288] (II) systemd-logind: releasing fd for 13:66
[ 19448.317] (II) UnloadModule: "libinput"
[ 19448.317] (II) systemd-logind: releasing fd for 13:65
[ 19448.402] (II) NVIDIA(GPU-0): Deleting GPU-0
[ 19448.403] (WW) xf86CloseConsole: KDSETMODE failed: Input/output error
[ 19448.403] (WW) xf86CloseConsole: VT_GETMODE failed: Input/output error
[ 19448.403] (WW) xf86CloseConsole: VT_ACTIVATE failed: Input/output error
[ 19448.404] (II) Server terminated successfully (0). Closing log file.
You may also need nvidia_modeset.
sudo modprobe nvidia_modeset
I have executed the command. Still the issue stands.
Can you please re-flash the device?
Was it working fine before?
Yes, it was working fine before.
Then I’d say please re-flash it.
I tried to reflash it, but everytime it throws up an error of no device detected, even though at the start of the process, it is able to detect the hardware.
I tried using different usb ports as well as different hosts.
Are you using a native Ubuntu host?
Dump the log from SDK Manager and also serial console:
The SDK Manager output is as follows:
SDKM_logs_JetPack_5.1.2_Linux_for_Jetson_AGX_Orin_modules_2023-12-01_11-26-46.zip (229.5 KB)
This is a typical issue on Orin series:
[ 0.2617 ] Sending bct_br
[ 0.2617 ] ERROR: might be timeout in USB write.
Error: Return value 3
Please refer to the solution here:
Even after I disabled the autosuspend, I am running through the same issue. To be clear, I am trying to flash the Agx Orin 64gb DevKit, with the SDK manager and NVMe SSD as the storage medium.
I am attaching the log files.
SDKM_logs_JetPack_5.1.2_Linux_for_Jetson_AGX_Orin_modules_2023-12-04_11-27-58.zip (474.5 KB)
The issue is now different.
Dump serial console log to know the real cause.
I am sharing the new log files and the serial console logs
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 5.10.120-tegra (buildbrain@mobile-u64-6422-d7000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #1 SMP PREEMPT Tue Aug 1 3
[ 0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,
[ 0.000000] OF: fdt: - 80000000 , c0000000
[ 0.000000] Machine model: Jetson AGX Orin Developer Kit
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x102531df98 SMBIOS=0xffff0000 SMBIOS 3.0=0x1005200000 MEMATTR=0x1006822018 ESRT=0x1006861a18 RNG=0x1006d2f398 MEMRESERVE=0x1006824f18
[ 0.000000] efi: seeding entropy pool
[ 0.000000] esrt: Reserving ESRT space from 0x0000001006861a18 to 0x0000001006861a50.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000001008c00000, size 512 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x0000001033ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000fffdffff]
[ 0.000000] node 0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x0000001004626fff]
[ 0.000000] node 0: [mem 0x0000001004627000-0x00000010049fefff]
[ 0.000000] node 0: [mem 0x00000010049ff000-0x0000001004daffff]
[ 0.000000] node 0: [mem 0x0000001004db0000-0x0000001004e4ffff]
[ 0.000000] node 0: [mem 0x0000001004e50000-0x00000010051effff]
[ 0.000000] node 0: [mem 0x00000010051f0000-0x000000100520ffff]
[ 0.000000] node 0: [mem 0x0000001005210000-0x00000010066dffff]
[ 0.000000] node 0: [mem 0x00000010066e0000-0x000000100677ffff]
[ 0.000000] node 0: [mem 0x0000001006780000-0x00000010067cffff]
[ 0.000000] node 0: [mem 0x00000010067d0000-0x00000010067fffff]
[ 0.000000] node 0: [mem 0x0000001006800000-0x000000100683ffff]
[ 0.000000] node 0: [mem 0x0000001006840000-0x000000100685ffff]
[ 0.000000] node 0: [mem 0x0000001006860000-0x000000100693ffff]
[ 0.000000] node 0: [mem 0x0000001006940000-0x000000100695ffff]
[ 0.000000] node 0: [mem 0x0000001006960000-0x000000100698ffff]
[ 0.000000] node 0: [mem 0x0000001006990000-0x0000001006b6ffff]
[ 0.000000] node 0: [mem 0x0000001006b70000-0x0000001006c3ffff]
[ 0.000000] node 0: [mem 0x0000001006c40000-0x0000001006cdffff]
[ 0.000000] node 0: [mem 0x0000001006ce0000-0x0000001006d1ffff]
[ 0.000000] node 0: [mem 0x0000001006d20000-0x0000001006faffff]
[ 0.000000] node 0: [mem 0x0000001006fb0000-0x00000010070affff]
[ 0.000000] node 0: [mem 0x00000010070b0000-0x000000100714ffff]
[ 0.000000] node 0: [mem 0x0000001007150000-0x000000100719ffff]
[ 0.000000] node 0: [mem 0x00000010071a0000-0x000000100723ffff]
[ 0.000000] node 0: [mem 0x0000001007240000-0x000000100775ffff]
[ 0.000000] node 0: [mem 0x0000001007760000-0x000000100793ffff]
[ 0.000000] node 0: [mem 0x0000001007940000-0x0000001028faffff]
[ 0.000000] node 0: [mem 0x0000001028fb0000-0x0000001028ffffff]
[ 0.000000] node 0: [mem 0x0000001029000000-0x000000102d1fffff]
[ 0.000000] node 0: [mem 0x000000102d210000-0x000000102d21ffff]
[ 0.000000] node 0: [mem 0x0000001032000000-0x0000001033ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000001033ffffff]
[ 0.000000] On node 0 totalpages: 16445968
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 524288 pages, LIFO batch:63
[ 0.000000] Normal zone: 249088 pages used for memmap
[ 0.000000] Normal zone: 15921680 pages, LIFO batch:63
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 32 pages/cpu s90328 r8192 d32552 u131072
[ 0.000000] pcpu-alloc: s90328 r8192 d32552 u131072 alloc=32*4096
[ 0.000000] pcpu-alloc: [0] 00 [0] 01 [0] 02 [0] 03 [0] 04 [0] 05 [0] 06 [0] 07
[ 0.000000] pcpu-alloc: [0] 08 [0] 09 [0] 10 [0] 11
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 16188688
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 console=tty0 firmware_class.path=/etc/firmware fbcon=m
[ 0.000000] Dentry cache hash table entries: 8388608 (order: 14, 67108864 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000effe0000-0x00000000fffe0000] (256MB)
[ 0.000000] Memory: 63769900K/65783872K available (18560K kernel code, 3166K rwdata, 7196K rodata, 3968K init, 1416K bss, 1489684K reserved, 524288K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=12, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=12.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=12
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[ 0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)
[ 0.000000] GICv2m: range[mem 0x0f410000-0x0f41ffff], SPI[608:677]
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000004] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000743] Console: colour dummy device 80x25
[ 0.000929] printk: console [tty0] enabled
[ 0.000976] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.000986] pid_max: default: 32768 minimum: 301
[ 0.001096] LSM: Security Framework initializing
[ 0.001128] Yama: becoming mindful.
[ 0.001149] SELinux: Initializing.
[ 0.001308] Mount-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.001395] Mountpoint-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.003789] rcu: Hierarchical SRCU implementation.
[ 0.003910] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.004680] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t23x/concord/kernel-dts/tegra234-p3701-0005-p3737-0000.dts
[ 0.004690] DTB Build time: Aug 1 2023 12:44:17
[ 0.006293] Tegra Revision: A01 SKU: 0xd0 CPU Process: 0 SoC Process: 0
[ 0.006603] Remapping and enabling EFI services.
[ 0.007172] smp: Bringing up secondary CPUs ...
[ 0.035919] Detected PIPT I-cache on CPU1
[ 0.035969] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[ 0.036011] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[ 0.064683] Detected PIPT I-cache on CPU2
[ 0.064694] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[ 0.064708] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[ 0.093336] Detected PIPT I-cache on CPU3
[ 0.093345] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[ 0.093359] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[ 0.124046] Detected PIPT I-cache on CPU4
[ 0.124068] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c0000
[ 0.124096] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[ 0.152786] Detected PIPT I-cache on CPU5
[ 0.152796] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e0000
[ 0.152811] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[ 0.181455] Detected PIPT I-cache on CPU6
[ 0.181465] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f500000
[ 0.181481] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[ 0.210133] Detected PIPT I-cache on CPU7
[ 0.210143] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f520000
[ 0.210158] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
[ 0.240854] Detected PIPT I-cache on CPU8
[ 0.240877] GICv3: CPU8: found redistributor 20000 region 0:0x000000000f540000
[ 0.240905] CPU8: Booted secondary processor 0x0000020000 [0x410fd421]
[ 0.269579] Detected PIPT I-cache on CPU9
[ 0.269590] GICv3: CPU9: found redistributor 20100 region 0:0x000000000f560000
[ 0.269607] CPU9: Booted secondary processor 0x0000020100 [0x410fd421]
[ 0.298874] Detected PIPT I-cache on CPU10
[ 0.298885] GICv3: CPU10: found redistributor 20200 region 0:0x000000000f580000
[ 0.298900] CPU10: Booted secondary processor 0x0000020200 [0x410fd421]
[ 0.328149] Detected PIPT I-cache on CPU11
[ 0.328161] GICv3: CPU11: found redistributor 20300 region 0:0x000000000f5a0000
[ 0.328177] CPU11: Booted secondary processor 0x0000020300 [0x410fd421]
[ 0.328235] smp: Brought up 1 node, 12 CPUs
[ 0.328304] SMP: Total of 12 processors activated.
[ 0.328309] CPU features: detected: Privileged Access Never
[ 0.328312] CPU features: detected: LSE atomic instructions
[ 0.328315] CPU features: detected: User Access Override
[ 0.328318] CPU features: detected: 32-bit EL0 Support
[ 0.328322] CPU features: detected: Common not Private translations
[ 0.328324] CPU features: detected: RAS Extension Support
[ 0.328327] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.328330] CPU features: detected: CRC32 instructions
[ 0.328333] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.347622] spectre-bhb mitigation disabled by command line option
[ 0.347624] spectre-bhb mitigation disabled by command line option
[ 0.347625] spectre-bhb mitigation disabled by command line option
[ 0.347627] spectre-bhb mitigation disabled by command line option
[ 0.347629] spectre-bhb mitigation disabled by command line option
[ 0.366433] CPU: All CPU(s) started at EL2
[ 0.369924] devtmpfs: initialized
[ 0.391727] Registered cp15_barrier emulation handler
[ 0.391738] Registered setend emulation handler
[ 0.391745] KASLR enabled
[ 0.391872] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.391887] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[ 0.395009] pinctrl core: initialized pinctrl subsystem
[ 0.395502] SMBIOS 3.0.0 present.
[ 0.395511] DMI: Unknown Jetson AGX Orin Developer Kit/Jetson AGX Orin Developer Kit, BIOS 4.1-33958178 08/01/2023
[ 0.395850] NET: Registered protocol family 16
[ 0.396764] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.396966] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.397163] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.397195] audit: initializing netlink subsys (disabled)
[ 0.397292] audit: type=2000 audit(0.396:1): state=initialized audit_enabled=0 res=1
[ 0.397485] thermal_sys: Registered thermal governor 'step_wise'
[ 0.397487] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.397491] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[ 0.400133] cpuidle: using governor menu
[ 0.400240] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.400361] ASID allocator initialised with 32768 entries
[ 0.400462] Serial: AMBA PL011 UART driver
[ 0.402439] tegra234_mc_sid_probe(): tegra234 mc-sid probe successful
[ 0.402462] Tegra reboot handler registered.
[ 0.422067] mc: mapped MMIO address: 0xffff8000111f0000 -> 0x2c10000
[ 0.422083] mc: mapped MMIO address: 0xffff800011210000 -> 0x2c20000
[ 0.422096] mc: mapped MMIO address: 0xffff800011230000 -> 0x2c30000
[ 0.422103] mc: mapped MMIO address: 0xffff800011250000 -> 0x2c40000
[ 0.422109] mc: mapped MMIO address: 0xffff800011270000 -> 0x2c50000
[ 0.422118] mc: mapped MMIO address: 0xffff800011290000 -> 0x2b80000
[ 0.422125] mc: mapped MMIO address: 0xffff8000112b0000 -> 0x2b90000
[ 0.422133] mc: mapped MMIO address: 0xffff8000112d0000 -> 0x2ba0000
[ 0.422143] mc: mapped MMIO address: 0xffff8000112f0000 -> 0x2bb0000
[ 0.422149] mc: mapped MMIO address: 0xffff800011310000 -> 0x1700000
[ 0.422157] mc: mapped MMIO address: 0xffff800011330000 -> 0x1710000
[ 0.422164] mc: mapped MMIO address: 0xffff800011350000 -> 0x1720000
[ 0.422172] mc: mapped MMIO address: 0xffff800011370000 -> 0x1730000
[ 0.422179] mc: mapped MMIO address: 0xffff800011390000 -> 0x1740000
[ 0.422185] mc: mapped MMIO address: 0xffff8000113b0000 -> 0x1750000
[ 0.422192] mc: mapped MMIO address: 0xffff8000113d0000 -> 0x1760000
[ 0.422200] mc: mapped MMIO address: 0xffff8000113f0000 -> 0x1770000
[ 0.422208] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.422250] mc-err: mcerr ops are set to t23x
[ 0.422948] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 80, base_baud = 0) is a SBSA
[ 1.681392] printk: console [ttyAMA0] enabled
[ 1.690098] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 1.696811] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 1.703510] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 1.710210] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 1.719155] ACPI: Interpreter disabled.
[ 1.724220] vdd-av1v1-hub: supplied by vdd-5v-sys
[ 1.729078] vbusA-cvb: supplied by vdd-5v-sys
[ 1.733552] vbusB-cvb: supplied by vdd-5v-sys
[ 1.738027] vdd-usbc1-vbus: supplied by vdd-5v-sys
[ 1.742984] vdd-usbc2-vbus: supplied by vdd-5v-sys
[ 1.748566] iommu: Default domain type: Translated
[ 1.753506] eventlib_kernel: keventlib is initialized, test id: 0
[ 1.759803] SCSI subsystem initialized
[ 1.763632] usbcore: registered new interface driver usbfs
[ 1.769130] usbcore: registered new interface driver hub
[ 1.774449] usbcore: registered new device driver usb
[ 1.779684] mc: Linux media interface: v0.10
[ 1.783959] videodev: Linux video capture interface: v2.00
[ 1.789586] pps_core: LinuxPPS API ver. 1 registered
[ 1.794548] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.803686] PTP clock support registered
[ 1.807828] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec
[ 1.814991] tegra_wdt_t18x 2190000.watchdog: Registered successfully
[ 1.822654] Registered efivars operations
[ 1.826814] FPGA manager framework
[ 1.830258] Advanced Linux Sound Architecture Driver Initialized.
[ 1.836614] Bluetooth: Core ver 2.22
[ 1.840195] NET: Registered protocol family 31
[ 1.844637] Bluetooth: HCI device and connection manager initialized
[ 1.850994] Bluetooth: HCI socket layer initialized
[ 1.855872] Bluetooth: L2CAP socket layer initialized
[ 1.860928] Bluetooth: SCO socket layer initialized
[ 1.866282] camchar: rtcpu character device driver loaded
[ 1.871922] clocksource: Switched to clocksource arch_sys_counter
[ 2.032839] VFS: Disk quotas dquot_6.6.0
[ 2.036803] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 2.043929] pnp: PnP ACPI: disabled
[ 2.049446] la/ptsa driver initialized.
[ 2.053354] NET: Registered protocol family 2
[ 2.057929] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 2.067669] tcp_listen_portaddr_hash hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 2.076442] TCP established hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 2.085051] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 2.092943] TCP: Hash tables configured (established 524288 bind 65536)
[ 2.099652] UDP hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 2.106711] UDP-Lite hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 2.114295] NET: Registered protocol family 1
[ 2.118940] RPC: Registered named UNIX socket transport module.
[ 2.124871] RPC: Registered udp transport module.
[ 2.129573] RPC: Registered tcp transport module.
[ 2.134275] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 2.140724] PCI: CLS 0 bytes, default 64
[ 2.144786] Trying to unpack rootfs image as initramfs...
[ 2.279318] Freeing initrd memory: 9552K
[ 2.285320] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 2.293263] kvm [1]: IPA Size Limit: 48 bits
[ 2.297556] kvm [1]: GICv3: no GICV resource entry
[ 2.302346] kvm [1]: disabling GICv2 emulation
[ 2.306802] kvm [1]: GIC system register CPU interface enabled
[ 2.312738] kvm [1]: vgic interrupt IRQ9
[ 2.316811] kvm [1]: VHE mode initialized successfully
[ 2.322590] Initialise system trusted keyrings
[ 2.327120] workingset: timestamp_bits=46 max_order=24 bucket_order=0
[ 2.335974] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.342128] NFS: Registering the id_resolver key type
[ 2.347198] Key type id_resolver registered
[ 2.351378] Key type id_legacy registered
[ 2.355426] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 2.362133] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 2.369544] ntfs: driver 2.1.32 [Flags: R/W].
[ 2.385628] NET: Registered protocol family 38
[ 2.390075] Key type asymmetric registered
[ 2.394171] Asymmetric key parser 'x509' registered
[ 2.399065] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 239)
[ 2.406523] io scheduler mq-deadline registered
[ 2.411060] io scheduler kyber registered
[ 2.419256] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 2.424861] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 2.430449] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 2.436032] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 2.444071] tegra_dc_assign_hw_data: no matching compatible node
[ 2.450084] tegradccommon module_init failed
[ 2.454351] tegradc module_init failed
[ 2.458359] EINJ: ACPI disabled.
[ 2.463157] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 2.470049] tegra-pmc: ### PMC reset source: SYS_RESET_N
[ 2.475361] tegra-pmc: ### PMC reset level: L0
[ 2.479801] tegra-pmc: ### PMC reset status reg: 0x0
[ 2.485996] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 4.151397] printk: console [ttyTCU0] enabled
[ 4.160556] arm-smmu 12000000.iommu: probing hardware configuration...
[ 4.168588] arm-smmu 12000000.iommu: SMMUv2 with:
[ 4.173447] arm-smmu 12000000.iommu: stage 1 translation
[ 4.179010] arm-smmu 12000000.iommu: stage 2 translation
[ 4.184559] arm-smmu 12000000.iommu: nested translation
[ 4.190013] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 4.197433] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
[ 4.206546] arm-smmu 12000000.iommu: Supported page sizes: 0x00001000
[ 4.213246] arm-smmu 12000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 4.219938] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 4.227469] arm-smmu 10000000.iommu: probing hardware configuration...
[ 4.234175] arm-smmu 10000000.iommu: SMMUv2 with:
[ 4.239000] arm-smmu 10000000.iommu: stage 1 translation
[ 4.244538] arm-smmu 10000000.iommu: stage 2 translation
[ 4.250081] arm-smmu 10000000.iommu: nested translation
[ 4.255534] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 4.262952] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 only)
[ 4.272006] arm-smmu 10000000.iommu: Supported page sizes: 0x00001000
[ 4.278700] arm-smmu 10000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 4.285392] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 4.292518] arm-smmu 8000000.iommu: probing hardware configuration...
[ 4.299130] arm-smmu 8000000.iommu: SMMUv2 with:
[ 4.303868] arm-smmu 8000000.iommu: stage 1 translation
[ 4.309327] arm-smmu 8000000.iommu: stage 2 translation
[ 4.314774] arm-smmu 8000000.iommu: nested translation
[ 4.320129] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 4.327458] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 4.336369] arm-smmu 8000000.iommu: Supported page sizes: 0x00001000
[ 4.342982] arm-smmu 8000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 4.349590] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 4.356889] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[ 4.367393] tegra_profiler: version: 1.151, samples/io: 51/30
[ 4.373386] tegra_profiler: auth: init
[ 4.377534] nvsciipc: loaded module
[ 4.382668] tun: Universal TUN/TAP device driver, 1.6
[ 4.388303] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 4.395726] hns3: Copyright (c) 2017 Huawei Corporation.
[ 4.401200] e1000e: Intel(R) PRO/1000 Network Driver
[ 4.406293] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 4.412381] igb: Intel(R) Gigabit Ethernet Network Driver
[ 4.417918] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 4.423805] PPP generic driver version 2.4.2
[ 4.428238] PPP BSD Compression module registered
[ 4.433065] PPP Deflate Compression module registered
[ 4.438268] PPP MPPE Compression module registered
[ 4.443213] usbcore: registered new interface driver r8152
[ 4.448851] usbcore: registered new interface driver asix
[ 4.454410] usbcore: registered new interface driver ax88179_178a
[ 4.460673] usbcore: registered new interface driver cdc_ether
[ 4.466672] usbcore: registered new interface driver net1080
[ 4.472487] usbcore: registered new interface driver cdc_subset
[ 4.478576] usbcore: registered new interface driver zaurus
[ 4.484306] usbcore: registered new interface driver cdc_ncm
[ 4.490124] usbcore: registered new interface driver aqc111
[ 4.495970] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 4.502326] ohci-pci: OHCI PCI platform driver
[ 4.506907] ohci-platform: OHCI generic platform driver
[ 4.512560] tegra-xusb 3610000.xhci: Adding to iommu group 0
[ 4.518870] usbcore: registered new interface driver uas
[ 4.524340] usbcore: registered new interface driver usb-storage
[ 4.530646] tegra-xudc 3550000.xudc: Adding to iommu group 1
[ 4.536783] mousedev: PS/2 mouse device common for all mice
[ 4.542529] usbcore: registered new interface driver xpad
[ 4.549894] tegra_rtc c2a0000.rtc: registered as rtc1
[ 4.555364] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:27 UTC (27)
[ 4.563586] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 4.570006] i2c /dev entries driver
[ 4.573654] tegra-i2c 3160000.i2c: Adding to iommu group 2
[ 4.579501] tegra-i2c c240000.i2c: Adding to iommu group 2
[ 4.585294] tegra-i2c 3180000.i2c: Adding to iommu group 2
[ 4.590984] tegra-i2c 3190000.i2c: Adding to iommu group 2
[ 4.596655] tegra-i2c 31c0000.i2c: Adding to iommu group 2
[ 4.602323] tegra-i2c c250000.i2c: Adding to iommu group 2
[ 4.608015] tegra-i2c 31e0000.i2c: Adding to iommu group 2
[ 4.613766] tegra-i2c 31b0000.i2c: Adding to iommu group 2
[ 4.622002] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[ 4.630589] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[ 4.640082] device-mapper: uevent: version 1.0.3
[ 4.644928] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[ 4.654841] sdhci: Secure Digital Host Controller Interface driver
[ 4.661180] sdhci: Copyright(c) Pierre Ossman
[ 4.665643] Synopsys Designware Multimedia Card Interface Driver
[ 4.671873] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.678106] sdhci-tegra 3460000.sdhci: Adding to iommu group 3
[ 4.678165] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401
[ 4.678489] sdhci-tegra 3400000.sdhci: Adding to iommu group 4
[ 4.697694] tegra-bpmp bpmp: firmware: 6969245516d6bf7e0f23-925eece486b
[ 4.705493] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9
[ 4.711111] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x81
[ 4.724615] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[ 4.730533] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful
[ 5.963426] hid: raw HID events driver (C) Jiri Kosina
[ 5.969388] usbcore: registered new interface driver usbhid
[ 5.975162] usbhid: USB HID core driver
[ 5.980474] tegra-dce d800000.dce: Adding to iommu group 5
[ 5.987928] dce: dce_ipc_channel_init:319 Invalid Channel State [0x0] for ch_type [2]
[ 5.996721] tegra234-aon c000000.aon: Adding to iommu group 6
[ 6.003400] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x5]
[ 6.005537] c000000.aon:hsp: probed
[ 6.012431] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [0]. Ignored...
[ 6.024856] tegra234-aon c000000.aon: init done
[ 6.025209] tegra23x-psc e860000.psc: Adding to iommu group 7
[ 6.029547] dce: dce_admin_send_cmd_ver:424 version : [0x2] err : [0x0]
[ 6.035987] tegra23x-psc e860000.psc: ext_cfg base:(____ptrval____)
[ 6.042960] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x1]
[ 6.048822] tegra23x-psc e860000.psc: init done
[ 6.048977] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 8
[ 6.057830] dce: dce_admin_setup_clients_ipc:553 Channel Reset Complete for Type [1] ...
[ 6.057832] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [1]. Ignored...
[ 6.057849] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [1]. Ignored...
[ 6.063081] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 6.069123] dce: dce_admin_setup_clients_ipc:529 Get queue info failed for [2]
[ 6.069713] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x2]
[ 6.081310] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[ 6.086376] dce: dce_admin_setup_clients_ipc:553 Channel Reset Complete for Type [3] ...
[ 6.086378] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [3]. Ignored...
[ 6.086405] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [3]. Ignored...
[ 6.095227] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 6.104110] dce: dce_start_boot_flow:173 DCE_BOOT_DONE
[ 6.111318] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[ 6.183328] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[ 6.195124] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[ 6.207728] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[ 6.220565] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[ 6.233649] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (119)
[ 6.240487] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 6.253231] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=8676d22a01443bdbc66581b7dde3b6d6828cc925
[ 6.267144] t19x_cache tegra-cache: probed
[ 6.271603] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[ 6.286326] optee: probing for conduit method.
[ 6.290930] optee: revision 3.21 (d8269f24)
[ 6.349661] optee: dynamic shared memory is enabled
[ 6.359099] optee: initialized driver
[ 6.378048] nvpmodel: initialized successfully
[ 6.382728] tegra_hv: get_hvd: not initialized yet
[ 6.387669] user_ivc_mempool: hypervisor not present
[ 6.393511] usbcore: registered new interface driver snd-usb-audio
[ 6.400552] u32 classifier
[ 6.403346] input device check on
[ 6.407117] Actions configured
[ 6.410763] Initializing XFRM netlink socket
[ 6.415557] NET: Registered protocol family 10
[ 6.422101] Segment Routing with IPv6
[ 6.425965] NET: Registered protocol family 17
[ 6.430563] NET: Registered protocol family 15
[ 6.435223] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 6.449393] Bluetooth: RFCOMM socket layer initialized
[ 6.454701] Bluetooth: RFCOMM ver 1.11
[ 6.458574] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 6.464671] Bluetooth: HIDP socket layer initialized
[ 6.470632] 9pnet: Installing 9P2000 support
[ 6.475095] Key type dns_resolver registered
[ 6.480246] registered taskstats version 1
[ 6.484482] Loading compiled-in X.509 certificates
[ 6.499795] Loaded X.509 cert 'Build time autogenerated kernel key: d94b64a20d69a5a32183bad4f211c4cae67041a9'
[ 6.510618] tegra194-pcie 14100000.pcie: Adding to iommu group 9
[ 6.523819] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 6.531967] tegra194-pcie 14160000.pcie: Adding to iommu group 10
[ 6.544827] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 6.551730] tegra194-pcie 141a0000.pcie: Adding to iommu group 11
[ 6.564071] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 6.570585] tegra194-pcie 141a0000.pcie: Failed to get slot regulators: -517
[ 6.595436] tegra-soc-hwpm f100000.tegra_soc_hwpm: Adding to iommu group 12
[ 6.607553] host1x 13e40000.host1x: Adding to iommu group 13
[ 6.638468] host1x 13e40000.host1x: initialized
[ 6.643550] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu group 14
[ 6.651708] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (streamid=53, iommu=smmu.0x0000000012000000)
[ 6.663753] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu group 15
[ 6.671881] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (streamid=54, iommu=smmu.0x0000000012000000)
[ 6.683892] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu group 16
[ 6.692021] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (streamid=55, iommu=smmu.0x0000000012000000)
[ 6.704069] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu group 17
[ 6.712198] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[ 6.724216] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu group 18
[ 6.732326] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[ 6.744370] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu group 19
[ 6.752495] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[ 6.764536] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu group 20
[ 6.772635] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[ 6.784640] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu group 21
[ 6.792738] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[ 6.804769] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu group 22
[ 6.812920] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (streamid=53, iommu=smmu.0x0000000008000000)
[ 6.824922] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu group 23
[ 6.833026] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (streamid=54, iommu=smmu.0x0000000008000000)
[ 6.845064] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu group 24
[ 6.853169] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (streamid=55, iommu=smmu.0x0000000008000000)
[ 6.865166] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu group 25
[ 6.873264] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (streamid=56, iommu=smmu.0x0000000008000000)
[ 6.885266] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu group 26
[ 6.893402] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (streamid=57, iommu=smmu.0x0000000008000000)
[ 6.905414] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu group 27
[ 6.913501] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (streamid=58, iommu=smmu.0x0000000008000000)
[ 6.925504] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu group 28
[ 6.933606] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (streamid=59, iommu=smmu.0x0000000008000000)
[ 6.945621] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu group 29
[ 6.953734] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (streamid=60, iommu=smmu.0x0000000008000000)
[ 6.965772] falcon 15340000.vic: Adding to iommu group 30
[ 6.976812] falcon 15340000.vic: initialized
[ 6.981582] falcon 15380000.nvjpg: Adding to iommu group 31
[ 6.990858] falcon 15380000.nvjpg: initialized
[ 6.995572] falcon 15540000.nvjpg1: Adding to iommu group 32
[ 7.004758] falcon 15540000.nvjpg1: initialized
[ 7.009563] falcon 154c0000.nvenc: Adding to iommu group 33
[ 7.020142] falcon 154c0000.nvenc: initialized
[ 7.024867] falcon 15a50000.ofa: Adding to iommu group 34
[ 7.033049] falcon 15a50000.ofa: initialized
[ 7.037620] nvdec 15480000.nvdec: Adding to iommu group 35
[ 7.050441] nvdec 15480000.nvdec: initialized
[ 7.055071] tsec 15500000.tsec: Adding to iommu group 36
[ 7.065231] tsec 15500000.tsec: initialized
[ 7.072845] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 7.089752] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 7.106143] gpio-394 (camera-control-output-low): hogged as output/low
[ 7.112902] gpio-397 (camera-control-output-low): hogged as output/low
[ 7.119664] gpio-487 (camera-control-output-low): hogged as output/low
[ 7.126418] gpio-486 (camera-control-output-low): hogged as output/low
[ 7.134161] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio
[ 7.141688] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon
[ 7.148685] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 7.155255] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 7.161731] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 7.167958] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 7.176172] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 7.184741] tegra194-isp5 14800000.isp: Adding to iommu group 37
[ 7.194077] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[ 7.203703] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized
[ 7.210306] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group 38
[ 7.218514] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group 39
[ 7.226592] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: context isolation disabled due to no IOMMU
[ 7.236575] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized
[ 7.243389] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: context isolation disabled due to no IOMMU
[ 7.253353] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized
[ 7.260172] scare-pigeon 13e40000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[ 7.270117] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized
[ 7.276960] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: Adding to iommu group 40
[ 7.285738] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: initialized (streamid=18, iommu=smmu.0x0000000008000000)
[ 7.297108] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: Adding to iommu group 41
[ 7.305882] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: initialized (streamid=19, iommu=smmu.0x0000000008000000)
[ 7.317255] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: Adding to iommu group 42
[ 7.325995] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: initialized (streamid=20, iommu=smmu.0x0000000008000000)
[ 7.337382] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: Adding to iommu group 43
[ 7.346112] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: initialized (streamid=21, iommu=smmu.0x0000000008000000)
[ 7.357480] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: Adding to iommu group 44
[ 7.366218] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: initialized (streamid=22, iommu=smmu.0x0000000008000000)
[ 7.377598] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: Adding to iommu group 45
[ 7.386328] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: initialized (streamid=23, iommu=smmu.0x0000000008000000)
[ 7.397699] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: Adding to iommu group 46
[ 7.406440] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: initialized (streamid=24, iommu=smmu.0x0000000008000000)
[ 7.417797] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: Adding to iommu group 47
[ 7.426526] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: initialized (streamid=25, iommu=smmu.0x0000000008000000)
[ 7.437912] pva 16000000.pva0: Adding to iommu group 48
[ 7.463857] pva 16000000.pva0: initialized
[ 7.481154] nvdla 15880000.nvdla0: Adding to iommu group 49
[ 7.496744] nvdla 15880000.nvdla0: initialized
[ 7.503024] nvdla 158c0000.nvdla1: Adding to iommu group 50
[ 7.516726] nvdla 158c0000.nvdla1: initialized
[ 7.523025] tegra-gpcdma 2600000.gpcdma: Adding to iommu group 2
[ 7.530125] tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels
[ 7.537645] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[ 7.544283] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[ 7.551053] serial-tegra 3100000.serial: Adding to iommu group 2
[ 7.557740] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 26, base_baud = 0) is a TEGRA_UART
[ 7.567534] serial-tegra 3110000.serial: Adding to iommu group 2
[ 7.574039] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 78, base_baud = 0) is a TEGRA_UART
[ 7.583637] serial-tegra 3130000.serial: Adding to iommu group 2
[ 7.590242] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 79, base_baud = 0) is a TEGRA_UART
[ 7.616950] tegra-xusb 3610000.xhci: Firmware timestamp: 2023-02-10 03:48:10 UTC, Version: 80.05 release
[ 7.626722] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 7.632299] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 7.640967] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000050810
[ 7.650572] tegra-xusb 3610000.xhci: irq 236, io mem 0x03610000
[ 7.657068] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 7.665577] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.673010] usb usb1: Product: xHCI Host Controller
[ 7.678026] usb usb1: Manufacturer: Linux 5.10.120-tegra xhci-hcd
[ 7.684295] usb usb1: SerialNumber: 3610000.xhci
[ 7.689774] hub 1-0:1.0: USB hub found
[ 7.693669] hub 1-0:1.0: 4 ports detected
[ 7.698075] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 7.703647] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 7.711445] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 7.718993] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 7.727508] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.734948] usb usb2: Product: xHCI Host Controller
[ 7.739966] usb usb2: Manufacturer: Linux 5.10.120-tegra xhci-hcd
[ 7.746232] usb usb2: SerialNumber: 3610000.xhci
[ 7.751908] hub 2-0:1.0: USB hub found
[ 7.755828] hub 2-0:1.0: 4 ports detected
[ 7.782830] tegra23x-oc-event soctherm-oc-event: Finished tegra23x overcurrent event probing
[ 7.808255] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 2008000 KHz, changing to: 2035200 KHz
[ 7.819894] cpufreq: cpu0,cur:2190000,set:2035200,set ndiv:159
[ 7.827011] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 2012000 KHz, changing to: 2035200 KHz
[ 7.840005] cpufreq: cpufreq_online: CPU8: Running at unlisted initial frequency: 2105000 KHz, changing to: 2112000 KHz
[ 7.851943] tegra194-cpufreq e000000.ccplex: probed with ICC, cl:3
[ 7.859699] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 7.867775] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 7.868145] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[ 7.879886] tegra194-pcie 14100000.pcie: IO 0x0030100000..0x00301fffff -> 0x0030100000
[ 7.888574] tegra194-pcie 14100000.pcie: MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[ 7.897263] tegra194-pcie 14100000.pcie: MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[ 7.910193] mmc0: CQHCI version 5.10
[ 7.914652] irq: IRQ303: trimming hierarchy from :interrupt-controller@f400000-1
[ 7.922310] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 303
[ 7.941962] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit
[ 7.963920] usb 1-3: new full-speed USB device number 2 using tegra-xusb
[ 8.011918] tegra194-pcie 14100000.pcie: Link up
[ 8.017866] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[ 8.024712] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 8.030354] pci_bus 0001:00: root bus resource [io 0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[ 8.040195] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[ 8.051041] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[ 8.058984] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[ 8.065355] pci 0001:00:00.0: PME# supported from D0 D3hot
[ 8.076066] pci 0001:01:00.0: [10ec:c822] type 00 class 0x028000
[ 8.082428] pci 0001:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 8.088381] pci 0001:01:00.0: reg 0x18: [mem 0x20a8000000-0x20a800ffff 64bit]
[ 8.096895] pci 0001:01:00.0: supports D1 D2
[ 8.101304] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 8.112859] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff]
[ 8.120302] pci 0001:00:00.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 8.126732] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8000000-0x20a800ffff 64bit]
[ 8.134753] mmc0: Command Queue Engine enabled
[ 8.134773] pci 0001:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 8.139321] mmc0: periodic cache flush enabled
[ 8.139327] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 8.139865] mmcblk0: mmc0:0001 G1M15M 59.3 GiB
[ 8.145681] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 8.150241] mmcblk0rpmb: mmc0:0001 G1M15M partition 3 4.00 MiB, chardev (510:0)
[ 8.156770] pci 0001:00:00.0: bridge window [io 0x1000-0x1fff]
[ 8.161434] usb 1-3: New USB device found, idVendor=13d3, idProduct=3549, bcdDevice= 0.00
[ 8.166808] pci 0001:00:00.0: bridge window [mem 0x20a8000000-0x20a80fffff]
[ 8.174314] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 8.174315] usb 1-3: Product: Bluetooth Radio
[ 8.174317] usb 1-3: Manufacturer: Realtek
[ 8.174318] usb 1-3: SerialNumber: 00e04c000001
[ 8.217216] pci 0001:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 8.225993] pci 0001:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 8.235010] pcieport 0001:00:00.0: Adding to iommu group 9
[ 8.240983] pcieport 0001:00:00.0: PME: Signaling with IRQ 64
[ 8.247450] pcieport 0001:00:00.0: AER: enabled with IRQ 64
[ 8.254020] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 8.260940] usb 2-3: new SuperSpeedPlus Gen 2 USB device number 2 using tegra-xusb
[ 8.261698] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[ 8.261969] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[ 8.261976] tegra194-pcie 14160000.pcie: IO 0x0036100000..0x00361fffff -> 0x0036100000
[ 8.261982] tegra194-pcie 14160000.pcie: MEM 0x2428000000..0x242fffffff -> 0x0040000000
[ 8.261984] tegra194-pcie 14160000.pcie: MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[ 8.307245] usb 2-3: New USB device found, idVendor=0bda, idProduct=0420, bcdDevice= 1.40
[ 8.317285] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8.324631] usb 2-3: Product: 4-Port USB 3.0 Hub
[ 8.329379] usb 2-3: Manufacturer: Generic
[ 8.344051] hub 2-3:1.0: USB hub found
[ 8.349989] hub 2-3:1.0: 4 ports detected
[ 8.367920] tegra194-pcie 14160000.pcie: Link up
[ 8.373222] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 8.380036] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 8.385669] pci_bus 0004:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[ 8.395774] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[ 8.406610] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[ 8.414524] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[ 8.420854] pci 0004:00:00.0: PME# supported from D0 D3hot
[ 8.423927] usb 1-4: new high-speed USB device number 3 using tegra-xusb
[ 8.431193] pci 0004:01:00.0: [144d:a80a] type 00 class 0x010802
[ 8.439750] pci 0004:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 8.452630] pci 0004:00:00.0: BAR 14: assigned [mem 0x2428000000-0x24280fffff]
[ 8.460070] pci 0004:01:00.0: BAR 0: assigned [mem 0x2428000000-0x2428003fff 64bit]
[ 8.468035] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 8.473410] pci 0004:00:00.0: bridge window [mem 0x2428000000-0x24280fffff]
[ 8.480775] pci 0004:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 8.489516] pci 0004:01:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 512
[ 8.498521] pcieport 0004:00:00.0: Adding to iommu group 10
[ 8.504516] pcieport 0004:00:00.0: PME: Signaling with IRQ 66
[ 8.510715] pcieport 0004:00:00.0: AER: enabled with IRQ 66
[ 8.516773] nvme 0004:01:00.0: Adding to iommu group 10
[ 8.522601] nvme nvme0: pci function 0004:01:00.0
[ 8.527665] nvme 0004:01:00.0: enabling device (0000 -> 0002)
[ 8.528188] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 8.540066] tegra194-pcie 141a0000.pcie: Failed to get slot regulators: -517
[ 8.540171] vdd-3v3-pcie: supplied by vdd-3v3-sys
[ 8.545055] nvme nvme0: Shutdown timeout set to 10 seconds
[ 8.545288] avdd-cam-2v8: supplied by vdd-3v3-sys
[ 8.555641] vdd-dp: supplied by vdd-3v3-sys
[ 8.560105] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 8.565326] dsi-vdd-1v8-bl-en: supplied by vdd-1v8-sys
[ 8.571663] nvme nvme0: 12/0/0 default/read/poll queues
[ 8.572484] tegra194-isp5 14800000.isp: initialized
[ 8.583098] nvme0n1: p1
[ 8.584456] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized
[ 8.592161] (NULL device *): fops function table already registered
[ 8.600867] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized
[ 8.607853] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 8.607969] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 8.622061] usb 1-4: New USB device found, idVendor=0bda, idProduct=5420, bcdDevice= 1.40
[ 8.629452] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 303
[ 8.630492] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8.644195] usb 1-4: Product: 4-Port USB 2.0 Hub
[ 8.648946] usb 1-4: Manufacturer: Generic
[ 8.655474] hub 1-4:1.0: USB hub found
[ 8.660576] hub 1-4:1.0: 4 ports detected
[ 8.721004] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[ 8.728193] tegra194-pcie 141a0000.pcie: IO 0x003a100000..0x003a1fffff -> 0x003a100000
[ 8.736885] tegra194-pcie 141a0000.pcie: MEM 0x2b28000000..0x2b2fffffff -> 0x0040000000
[ 8.745560] tegra194-pcie 141a0000.pcie: MEM 0x2740000000..0x2b27ffffff -> 0x2740000000
[ 9.388075] usb 1-4.4: new full-speed USB device number 4 using tegra-xusb
[ 9.506540] usb 1-4.4: New USB device found, idVendor=046d, idProduct=c534, bcdDevice=29.01
[ 9.515134] usb 1-4.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 9.522656] usb 1-4.4: Product: USB Receiver
[ 9.527047] usb 1-4.4: Manufacturer: Logitech
[ 9.537474] input: Logitech USB Receiver as /devices/platform/3610000.xhci/usb1/1-4/1-4.4/1-4.4:1.0/0003:046D:C534.0001/input/input0
[ 9.608144] hid-generic 0003:046D:C534.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-3610000.xhci-4.4/input0
[ 9.625234] input: Logitech USB Receiver Mouse as /devices/platform/3610000.xhci/usb1/1-4/1-4.4/1-4.4:1.1/0003:046D:C534.0002/input/input1
[ 9.638130] input: Logitech USB Receiver Consumer Control as /devices/platform/3610000.xhci/usb1/1-4/1-4.4/1-4.4:1.1/0003:046D:C534.0002/input/input2
[ 9.682480] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit
[ 9.711974] input: Logitech USB Receiver System Control as /devices/platform/3610000.xhci/usb1/1-4/1-4.4/1-4.4:1.1/0003:046D:C534.0002/input/input3
[ 9.725655] hid-generic 0003:046D:C534.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-3610000.xhci-4.4/input1
[ 9.861180] tegra194-pcie 141a0000.pcie: Phy link never came up
[ 9.867352] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[ 9.874170] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 9.879812] pci_bus 0005:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x3a100000-0x3a1fffff])
[ 9.889930] pci_bus 0005:00: root bus resource [mem 0x2b28000000-0x2b2fffffff] (bus address [0x40000000-0x47ffffff])
[ 9.900767] pci_bus 0005:00: root bus resource [mem 0x2740000000-0x2b27ffffff pref]
[ 9.908699] pci 0005:00:00.0: [10de:229a] type 01 class 0x060400
[ 9.915053] pci 0005:00:00.0: PME# supported from D0 D3hot
[ 9.929593] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 9.934991] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 9.943966] pcieport 0005:00:00.0: Adding to iommu group 11
[ 9.949955] pcieport 0005:00:00.0: PME: Signaling with IRQ 68
[ 9.956445] pcieport 0005:00:00.0: AER: enabled with IRQ 68
[ 9.962412] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[ 9.968517] pci 0005:00:00.0: Removing from iommu group 11
[ 9.974168] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[ 9.982009] nvethernet 6810000.ethernet: Adding to iommu group 51
[ 9.988609] nvethernet 6810000.ethernet: failed to read skip mac reset flag, default 0
[ 9.996767] nvethernet 6810000.ethernet: failed to read MDIO address
[ 10.003319] nvethernet 6810000.ethernet: setting to default DMA bit mask
[ 10.010230] nvethernet 6810000.ethernet: failed to read UPHY GBE mode- default to 10G
[ 10.407406] nvethernet 6810000.ethernet: Ethernet MAC address: 48:b0:2d:e2:a6:1b
[ 10.415388] -->macsec_probe()
[ 10.415404] nvethernet 6810000.ethernet: macsec param in DT is missing or disabled
[ 10.423204] <--macsec_probe()
[ 10.423206] nvethernet 6810000.ethernet: Macsec not supported/Not enabled in DT
[ 10.435103] nvethernet 6810000.ethernet: eth0 (HW ver: 31) created with 10 DMA channels
[ 10.443835] irq: IRQ318: trimming hierarchy from :pmc@c360000
[ 10.449815] irq: IRQ319: trimming hierarchy from :interrupt-controller@f400000-1
[ 10.457484] irq: IRQ320: trimming hierarchy from :pmc@c360000
[ 10.463436] input: gpio-keys as /devices/platform/gpio-keys/input/input6
[ 10.471017] tegra-se-nvhost 15810000.se: Adding to iommu group 52
[ 10.477751] tegra-se-nvhost 15810000.se: initialized
[ 10.493637] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 10.500028] tegra-se-nvhost 15820000.se: Adding to iommu group 53
[ 10.506584] tegra-se-nvhost 15820000.se: initialized
[ 10.513673] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 10.520048] tegra-se-nvhost 15840000.se: Adding to iommu group 54
[ 10.526567] tegra-se-nvhost 15840000.se: initialized
[ 10.535315] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 10.542192] tegra_actmon d230000.actmon: in actmon_register()...
[ 10.548536] tegra_actmon d230000.actmon: bwmgr_disable = 1
[ 10.554664] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[ 10.563036] hvc_sysfs: hypervisor is not present
[ 10.694877] ALSA device list:
[ 10.697934] No soundcards found.
[ 10.702015] Freeing unused kernel memory: 3968K
[ 10.706745] Run /init as init process
[ 10.710509] with arguments:
[ 10.710510] /init
[ 10.710511] with environment:
[ 10.710511] HOME=/
[ 10.710512] TERM=linux
[ 10.710513] mminit_loglevel=4
[ 10.721656] Root device found: mmcblk0p1
[ 10.729914] Found dev node: /dev/mmcblk0p1
[ 10.788155] EXT4-fs (mmcblk0p1): recovery complete
[ 10.793722] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 10.804980] Rootfs mounted over mmcblk0p1
[ 10.814980] Switching from initrd to actual rootfs
[ 10.921414] systemd[1]: System time before build time, advancing clock.
[ 10.969854] systemd[1]: systemd 245.4-4ubuntu3.21 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELF)
[ 10.993504] systemd[1]: Detected architecture arm64.
[ 11.031719] systemd[1]: Set hostname to <magna>.
[ 11.211542] random: crng init done
[ 11.218928] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 11.231962] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 11.241550] systemd[1]: Created slice system-modprobe.slice.
[ 11.247758] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 11.254495] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 11.261286] systemd[1]: Created slice User and Session Slice.
[ 11.267316] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 11.275393] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 11.285234] systemd[1]: Reached target User and Group Name Lookups.
[ 11.291752] systemd[1]: Reached target Slices.
[ 11.296377] systemd[1]: Reached target Mounting snaps.
[ 11.301722] systemd[1]: Reached target Swap.
[ 11.306377] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 11.313246] systemd[1]: Listening on Syslog Socket.
[ 11.318412] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 11.325425] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 11.332386] systemd[1]: Listening on Journal Audit Socket.
[ 11.338168] systemd[1]: Listening on Journal Socket (/dev/log).
[ 11.344430] systemd[1]: Listening on Journal Socket.
[ 11.349688] systemd[1]: Listening on udev Control Socket.
[ 11.355372] systemd[1]: Listening on udev Kernel Socket.
[ 11.361821] systemd[1]: Mounting Huge Pages File System...
[ 11.368560] systemd[1]: Mounting POSIX Message Queue File System...
[ 11.375897] systemd[1]: Mounting RPC Pipe File System...
[ 11.382311] systemd[1]: Mounting Kernel Debug File System...
[ 11.389106] systemd[1]: Mounting Kernel Trace File System...
[ 11.396288] systemd[1]: Starting Journal Service...
[ 11.402376] systemd[1]: Starting Set the console keyboard layout...
[ 11.409837] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 11.419735] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[ 11.427198] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[ 11.436637] systemd[1]: Starting Load Kernel Module efi_pstore...
[ 11.443984] systemd[1]: Starting Load Kernel Module pstore_blk...
[ 11.451276] systemd[1]: Starting Load Kernel Module pstore_zone...
[ 11.458678] systemd[1]: Starting Load Kernel Module ramoops...
[ 11.465859] systemd[1]: Starting NVIDIA specific first-boot udev script...
[ 11.473978] systemd[1]: Started Nameserver information manager.
[ 11.480275] systemd[1]: Reached target Network (Pre).
[ 11.487436] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 11.498503] systemd[1]: Starting Load Kernel Modules...
[ 11.504853] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 11.512448] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 11.512714] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 11.513102] systemd[1]: Starting udev Coldplug all Devices...
[ 11.530845] tegra-carveouts tegra-carveouts: fsi :dma coherent mem declare 0x0000001038e00000,16777216
[ 11.532753] systemd[1]: Started Journal Service.
[ 11.540443] tegra-carveouts tegra-carveouts: assigned reserved memory node fsi-carveout
[ 11.553457] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x0000001049800000,914358272
[ 11.553459] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 11.571385] nvmap_page_pool_init: Total RAM pages: 16076927
[ 11.571386] nvmap_page_pool_init: nvmap page pool size: 2009615 pages (3754 MB)
[ 11.571441] nvmap_background_zero_thread: PP zeroing thread starting.
[ 11.571533] misc nvmap: created heap vpr base 0x0000001049800000 size (892928KiB)
[ 11.574600] misc nvmap: created heap fsi base 0x0000001038e00000 size (16384KiB)
[ 11.630498] systemd-journald[318]: Received client request to flush runtime journal.
[ 11.630861] nvgpu: 17000000.ga10b nvgpu_nvhost_syncpt_init:135 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[ 11.923659] nvidia: loading out-of-tree module taints kernel.
[ 11.941258] nv_platform 13800000.display: Adding to iommu group 55
[ 11.946165] platform 13800000.display:nvdisplay-niso: Adding to iommu group 56
[ 11.949989] NVRM: loading NVIDIA UNIX Open Kernel Module for aarch64 35.4.1 Release Build (buildbrain@mobile-u64-6422-d7000) Tue Aug 1 12:45:41 PDT 2023
[ 11.952115] spi-tegra114 3210000.spi: Adding to iommu group 2
[ 11.962289] spi-tegra114 3230000.spi: Adding to iommu group 2
[ 11.992020] cpu-throttle-alert cooling device registered.
[ 11.992096] gpu-throttle-alert cooling device registered.
[ 11.992140] cv0-throttle-alert cooling device registered.
[ 11.992171] cv1-throttle-alert cooling device registered.
[ 11.992212] cv2-throttle-alert cooling device registered.
[ 11.992266] soc0-throttle-alert cooling device registered.
[ 11.992304] soc1-throttle-alert cooling device registered.
[ 11.992399] soc2-throttle-alert cooling device registered.
[ 11.992597] hot-surface-alert cooling device registered.
[ 11.995832] nvvrs11 4-0020: NVVRS11 Vendor ID: 0x11
[ 11.996295] nvvrs11 4-0020: NVVRS11 Model Rev: 0x81
[ 11.996297] nvvrs11 4-0020: NVVRS11 probe successful
[ 11.996807] nvvrs11 4-0022: NVVRS11 Vendor ID: 0x11
[ 11.996992] irq: IRQ321: trimming hierarchy from :pmc@c360000
[ 11.996997] nct1008_nct72 4-004c: starting parse dt
[ 11.997038] nct1008_nct72 4-004c: !!!Found deprecated property!!!
[ 11.997040] nct1008_nct72 4-004c: success parsing dt
[ 11.997120] nct1008_nct72 4-004c: success in enabling tmp451 VDD rail
[ 11.997210] nvvrs11 4-0022: NVVRS11 Model Rev: 0x81
[ 11.997213] nvvrs11 4-0022: NVVRS11 probe successful
[ 12.006985] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 16 channels
[ 12.014771] irq: IRQ322: trimming hierarchy from :pmc@c360000
[ 12.026197] rtl88x2ce 0001:01:00.0: Adding to iommu group 9
[ 12.026591] rtl88x2ce 0001:01:00.0: enabling device (0000 -> 0003)
[ 12.033802] nct1008_nct72 4-004c: LOC shutdown limit 107
[ 12.034423] nct1008_nct72 4-004c: EXT shutdown limit 107
[ 12.048003] nvadsp 2993000.adsp: Adding to iommu group 57
[ 12.048150] nvadsp 2993000.adsp: in probe()...
[ 12.048699] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ 12.070874] nct1008_nct72 4-004c: initial LOC temp: 33000
[ 12.071349] nct1008_nct72 4-004c: initial EXT temp: 39500
[ 12.072746] nct1008_nct72 4-004c: hi_b:-4, lo_b:0
[ 12.073445] nct1008_nct72 4-004c: nct1008_probe: initialized
[ 12.092867] loop: module loaded
[ 12.166653] tegra-asoc: sound: Adding to iommu group 57
[ 12.181192] irq: IRQ325: trimming hierarchy from :pmc@c360000
[ 12.181303] tegra-hda 3510000.hda: Adding to iommu group 58
[ 12.191477] tegra210-adsp aconnect@2a41000:adsp_audio: Adding to iommu group 57
[ 12.191501] tegra210_adsp_audio_probe: platform probe started
[ 12.191811] tegra210-adsp tegra210-adsp: Default param-type to BYTE for mp3-dec1
[ 12.192055] tegra210-adsp tegra210-adsp: Default param-type to BYTE for spkprot
[ 12.192283] tegra210-adsp tegra210-adsp: Default param-type to BYTE for src
[ 12.192509] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aac-dec1
[ 12.192741] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aec
[ 12.192964] tegra210-adsp tegra210-adsp: Default param-type to BYTE for wire
[ 12.192971] tegra210-adsp tegra210-adsp: adma channel page address dt entry not found
[ 12.192972] tegra210-adsp tegra210-adsp: using adma channel page 0
[ 12.193039] nvadsp 2993000.adsp: ADSP OS firmware already loaded
[ 12.193322] cdi_tsc c6a0000.tsc_sig_gen: CDI TSC probing...
[ 12.193427] cdi_tsc_probe: Initializing the driver
[ 12.194543] cdi_tsc_probe: Successfully initialized the tsc char driver
[ 12.200641] usbcore: registered new interface driver btusb
[ 12.213884] OF: graph: no port node found in /i2c@c240000/ucsi_ccg@8/connector@0
[ 12.221870] ucsi_ccg 1-0008: Port-0: no role switch found
[ 12.225567] cryptd: max_cpu_qlen set to 1000
[ 12.225794] rtk_btusb: Realtek Bluetooth USB driver ver 3.1
[ 12.225798] rtk_btcoex: rtk_btcoex_init: version: 1.2
[ 12.225799] rtk_btcoex: create workqueue
[ 12.225858] rtk_btcoex: alloc buffers 1792, 2432 for ev and l2
[ 12.225896] rtk_btusb: btusb_probe intf->cur_altsetting->desc.bInterfaceNumber 0
[ 12.225898] rtk_btusb: btusb_probe can_wakeup 1, may wakeup 0
[ 12.225900] rtk_btusb: patch_add
[ 12.225902] rtk_btusb: auto suspend is disabled
[ 12.225904] rtk_btusb: pid = 0x3549
[ 12.225906] rtk_btusb: patch_add: Reset gEVersion to 0xff
[ 12.225915] rtk_btusb: set_bit(HCI_QUIRK_RESET_ON_CLOSE, &hdev->quirks);
[ 12.226075] rtk_btusb: btusb_probe: done
[ 12.226111] usbcore: registered new interface driver rtk_btusb
[ 12.226423] rtk_btusb: btusb_open start
[ 12.226426] rtk_btusb: btusb_open hdev->promisc ==0
[ 12.226427] rtk_btusb: download_patch start
[ 12.226429] rtk_btusb: chip type value: 0x73
[ 12.226431] rtk_btusb: HCI reset.
[ 12.237934] rtk_btusb: read_ver_rsp->lmp_subver = 0x8822
[ 12.237939] rtk_btusb: read_ver_rsp->hci_rev = 0xc
[ 12.237940] rtk_btusb: patch_entry->lmp_sub = 0x8822
[ 12.237941] rtk_btusb: load_firmware start
[ 12.237942] rtk_btusb: lmp_version = 0x8822
[ 12.237943] rtk_btusb: config filename rtl8822cu_config
[ 12.242595] rtk_btusb: no bdaddr file /opt/bdaddr
[ 12.242601] rtk_btusb: 55 ab 23 87 00 00
[ 12.242608] rtk_btusb: Config file length 6, new length 6
[ 12.242610] rtk_btusb: fw name is rtl8822cu_fw
[ 12.243273] rtk_btusb: This is not 8723a, use new patch style!
[ 12.243277] rtk_btusb: rtk_get_eversion: gEVersion 255
[ 12.244937] rtk_btusb: eversion->status = 0x0, eversion->version = 0x3
[ 12.244942] rtk_btusb: load_firmware: New gEVersion 3
[ 12.244945] rtk_btusb: rtk_get_fw_project_id: opcode 0, len 1, data 13
[ 12.244947] rtk_btusb: lmp_version is 8822, project_id is 8822, match!
[ 12.244948] rtk_btusb: fw_version = 0x9a8cbc9
[ 12.244950] rtk_btusb: number_of_total_patch = 3
[ 12.244951] rtk_btusb: chipID 4
[ 12.244952] rtk_btusb: patch_length 0x8590
[ 12.244954] rtk_btusb: start_offset 0x00005d00
[ 12.244955] rtk_btusb: Svn version: 1940234490
[ 12.244957] rtk_btusb: Coexistence: BTCOEX_20210106-2020
[ 12.244958] rtk_btusb: buf_len = 0x8596
[ 12.244968] rtk_btusb: fw: exists, config file: exists
[ 12.244969] rtk_btusb: load_firmware done
[ 12.244981] rtk_btusb: download_data start
[ 12.252918] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=3 as /devices/platform/3510000.hda/sound/card0/input7
[ 12.316441] OF: graph: no port node found in /i2c@c240000/ucsi_ccg@8/connector@0
[ 12.324204] OF: graph: no port node found in /i2c@c240000/ucsi_ccg@8/connector@0
[ 12.356714] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=7 as /devices/platform/3510000.hda/sound/card0/input8
[ 12.356790] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=8 as /devices/platform/3510000.hda/sound/card0/input9
[ 12.356835] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=9 as /devices/platform/3510000.hda/sound/card0/input10
[ 12.357840] logitech-djreceiver 0003:046D:C534.0001: hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-3610000.xhci-4.4/input0
[ 12.413837] input: NVIDIA Jetson AGX Orin APE Headset Jack as /devices/platform/sound/sound/card1/input11
[ 12.414938] rtk_btusb: download_data done
[ 12.414942] rtk_btusb: HCI reset.
[ 12.426928] rtk_btusb: read_ver_rsp->lmp_subver = 0xcbc9
[ 12.426932] rtk_btusb: read_ver_rsp->hci_rev = 0x9a8
[ 12.426934] rtk_btusb: patch_entry->lmp_sub = 0x8822
[ 12.426940] rtk_btusb: Rtk patch end 0
[ 12.426943] rtk_btusb: btusb_open set HCI_RUNNING
[ 12.426962] rtk_btcoex: Open BTCOEX
[ 12.426963] rtk_btusb: btusb_open end
[ 12.429951] rtk_btcoex: BTCOEX hci_rev 0x09a8
[ 12.429957] rtk_btcoex: BTCOEX lmp_subver 0xcbc9
[ 12.449922] rtk_btusb: btusb_notify: hci0 evt 3
[ 12.501497] tegra210-adsp tegra210-adsp: Loaded app wire
[ 12.501503] tegra210-adsp tegra210-adsp: Loaded app apm
[ 12.501504] tegra210-adsp tegra210-adsp: Loaded app adma
[ 12.501505] tegra210-adsp tegra210-adsp: Loaded app adma_tx
[ 12.501508] nvadsp_set_adma_dump_reg: callback for adma reg dump is sent to 00000000949e6d14
[ 12.521558] tegra210-adsp tegra210-adsp: Tegra210 ADSP driver successfully registered
[ 12.624955] logitech-djreceiver 0003:046D:C534.0002: hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-3610000.xhci-4.4/input1
[ 12.687035] logitech-djreceiver 0003:046D:C534.0002: device of type eQUAD nano Lite (0x0a) connected on slot 1
[ 12.687550] input: Logitech Wireless Keyboard PID:4023 Keyboard as /devices/platform/3610000.xhci/usb1/1-4/1-4.4/1-4.4:1.1/0003:046D:C534.0002/0003:046D:4023.0003/input/input12
[ 12.687845] input: Logitech Wireless Keyboard PID:4023 Consumer Control as /devices/platform/3610000.xhci/usb1/1-4/1-4.4/1-4.4:1.1/0003:046D:C534.0002/0003:046D:4023.0003/input/input13
[ 12.688075] input: Logitech Wireless Keyboard PID:4023 System Control as /devices/platform/3610000.xhci/usb1/1-4/1-4.4/1-4.4:1.1/0003:046D:C534.0002/0003:046D:4023.0003/input/input14
[ 12.688233] hid-generic 0003:046D:4023.0003: input,hidraw2: USB HID v1.11 Keyboard [Logitech Wireless Keyboard PID:4023] on usb-3610000.xhci-4.4/input1:1
[ 12.689029] logitech-djreceiver 0003:046D:C534.0002: device of type eQUAD nano Lite (0x0a) connected on slot 2
[ 12.689303] input: Logitech Wireless Mouse PID:4058 Mouse as /devices/platform/3610000.xhci/usb1/1-4/1-4.4/1-4.4:1.1/0003:046D:C534.0002/0003:046D:4058.0004/input/input19
[ 12.689429] hid-generic 0003:046D:4058.0004: input,hidraw3: USB HID v1.11 Mouse [Logitech Wireless Mouse PID:4058] on usb-3610000.xhci-4.4/input1:2
[ 13.027159] input: Logitech Wireless Keyboard PID:4023 as /devices/platform/3610000.xhci/usb1/1-4/1-4.4/1-4.4:1.1/0003:046D:C534.0002/0003:046D:4023.0003/input/input23
[ 13.027347] logitech-hidpp-device 0003:046D:4023.0003: input,hidraw2: USB HID v1.11 Keyboard [Logitech Wireless Keyboard PID:4023] on usb-3610000.xhci-4.4/input1:1
[ 13.095100] input: Logitech Wireless Mouse as /devices/platform/3610000.xhci/usb1/1-4/1-4.4/1-4.4:1.1/0003:046D:C534.0002/0003:046D:4058.0004/input/input24
[ 13.095222] logitech-hidpp-device 0003:046D:4058.0004: input,hidraw3: USB HID v1.11 Mouse [Logitech Wireless Mouse] on usb-3610000.xhci-4.4/input1:2
[ 13.846155] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. Opts: (null)
[ 14.092908] using random self ethernet address
[ 14.097611] using random host ethernet address
[ 14.397922] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 14.397937] Bluetooth: BNEP socket layer initialized
[ 14.463368] Mass Storage Function, version: 2009/09/11
[ 14.463375] LUN: removable file: (no medium)
[ 14.465665] using random self ethernet address
[ 14.470305] using random host ethernet address
[ 14.498319] rndis0: HOST MAC ee:65:c0:6c:ea:48
[ 14.498326] rndis0: MAC ee:65:c0:6c:ea:49
[ 14.498622] usb0: HOST MAC ee:65:c0:6c:ea:4a
[ 14.498625] usb0: MAC ee:65:c0:6c:ea:4b
[ 14.499342] tegra-xudc 3550000.xudc: EP 0 (type: ctrl, dir: out) enabled
[ 14.502120] l4tbr0: port 1(rndis0) entered blocking state
[ 14.502132] l4tbr0: port 1(rndis0) entered disabled state
[ 14.502345] device rndis0 entered promiscuous mode
[ 14.508037] l4tbr0: port 2(usb0) entered blocking state
[ 14.508049] l4tbr0: port 2(usb0) entered disabled state
[ 14.508194] device usb0 entered promiscuous mode
[ 14.692350] nvgpu: 17000000.ga10b tpc_pg_mask_store:1070 [INFO] no value change, same mask already set
[ 14.693859] pstore: Using crash dump compression: deflate
[ 14.693894] printk: console [ramoops-1] enabled
[ 14.693896] pstore: Registered ramoops as persistent store backend
[ 14.693898] ramoops: using 0x200000@0x102d270000, ecc: 0
[ 14.887341] nvgpu: 17000000.ga10b gk20a_scale_init:541 [INFO] enabled scaling for GPU
[ 15.162525] irq: IRQ326: trimming hierarchy from :interrupt-controller@f400000-1
[ 15.163408] hwmon hwmon6: temp1_input not attached to any thermal zone
[ 15.687345] Aquantia AQR113C 6810000.ethernet:00: No AQR phy_mode setting in DT
[ 16.417857] zram: Added device: zram0
[ 16.418669] zram: Added device: zram1
[ 16.419501] zram: Added device: zram2
[ 16.419856] zram: Added device: zram3
[ 16.422409] zram: Added device: zram4
[ 16.422667] zram: Added device: zram5
[ 16.422880] zram: Added device: zram6
[ 16.423060] zram: Added device: zram7
[ 16.423248] zram: Added device: zram8
[ 16.423417] zram: Added device: zram9
[ 16.423565] zram: Added device: zram10
[ 16.430175] zram: Added device: zram11
[ 16.479455] zram0: detected capacity change from 0 to 2743795712
[ 16.516064] Adding 2679484k swap on /dev/zram0. Priority:5 extents:1 across:2679484k SS
[ 16.520700] zram1: detected capacity change from 0 to 2743795712
[ 16.564150] Adding 2679484k swap on /dev/zram1. Priority:5 extents:1 across:2679484k SS
[ 16.566579] zram2: detected capacity change from 0 to 2743795712
[ 16.619977] Adding 2679484k swap on /dev/zram2. Priority:5 extents:1 across:2679484k SS
[ 16.622408] zram3: detected capacity change from 0 to 2743795712
[ 16.672094] Adding 2679484k swap on /dev/zram3. Priority:5 extents:1 across:2679484k SS
[ 16.674496] zram4: detected capacity change from 0 to 2743795712
[ 16.731957] Adding 2679484k swap on /dev/zram4. Priority:5 extents:1 across:2679484k SS
[ 16.734453] zram5: detected capacity change from 0 to 2743795712
[ 16.784025] Adding 2679484k swap on /dev/zram5. Priority:5 extents:1 across:2679484k SS
[ 16.786290] zram6: detected capacity change from 0 to 2743795712
[ 16.832001] Adding 2679484k swap on /dev/zram6. Priority:5 extents:1 across:2679484k SS
[ 16.834286] zram7: detected capacity change from 0 to 2743795712
[ 16.903934] Adding 2679484k swap on /dev/zram7. Priority:5 extents:1 across:2679484k SS
[ 16.906474] zram8: detected capacity change from 0 to 2743795712
[ 16.947991] Adding 2679484k swap on /dev/zram8. Priority:5 extents:1 across:2679484k SS
[ 16.950369] zram9: detected capacity change from 0 to 2743795712
[ 16.980085] Adding 2679484k swap on /dev/zram9. Priority:5 extents:1 across:2679484k SS
[ 16.982599] zram10: detected capacity change from 0 to 2743795712
[ 17.040033] Adding 2679484k swap on /dev/zram10. Priority:5 extents:1 across:2679484k SS
[ 17.042417] zram11: detected capacity change from 0 to 2743795712
[ 17.087987] Adding 2679484k swap on /dev/zram11. Priority:5 extents:1 across:2679484k SS
[ 17.261730] fuse: init (API version 7.32)
[ 17.538748] nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for aarch64 35.4.1 Release Build (buildbrain@mobile-u64-6422-d7000) Tue Aug 1 12:45:42 PDT 2023
[ 17.736690] tegra-xudc 3550000.xudc: EP 5 (type: intr, dir: in) enabled
[ 17.736712] tegra-xudc 3550000.xudc: EP 3 (type: bulk, dir: in) enabled
[ 17.736726] tegra-xudc 3550000.xudc: EP 2 (type: bulk, dir: out) enabled
[ 17.736801] tegra-xudc 3550000.xudc: EP 9 (type: intr, dir: in) enabled
[ 17.736817] tegra-xudc 3550000.xudc: EP 7 (type: bulk, dir: in) enabled
[ 17.736830] tegra-xudc 3550000.xudc: EP 4 (type: bulk, dir: out) enabled
[ 17.736923] tegra-xudc 3550000.xudc: EP 15 (type: intr, dir: in) enabled
[ 17.736945] tegra-xudc 3550000.xudc: EP 11 (type: bulk, dir: in) enabled
[ 17.736963] tegra-xudc 3550000.xudc: EP 6 (type: bulk, dir: out) enabled
[ 17.737012] IPv6: ADDRCONF(NETDEV_CHANGE): rndis0: link becomes ready
[ 17.746481] tegra-xudc 3550000.xudc: EP 13 (type: bulk, dir: in) enabled
[ 17.746501] tegra-xudc 3550000.xudc: EP 8 (type: bulk, dir: out) enabled
[ 17.746743] IPv6: ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready
[ 17.747444] tegra-xudc 3550000.xudc: ep 13 disabled
[ 17.747534] tegra-xudc 3550000.xudc: ep 8 disabled
[ 17.765355] tegra-xudc 3550000.xudc: EP 13 (type: bulk, dir: in) enabled
[ 17.765368] tegra-xudc 3550000.xudc: EP 8 (type: bulk, dir: out) enabled
[ 17.790240] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
[ 18.272654] audit: type=1326 audit(1701726248.276:2): auid=4294967295 uid=0 gid=0 ses=4294967295 subj=kernel pid=2184 comm="cupsd" exe="/snap/cups/981/sbin/cupsd" sig=0 arch=c00000b7 syscall=55 compa0
[ 18.324531] l4tbr0: port 2(usb0) entered blocking state
[ 18.324539] l4tbr0: port 2(usb0) entered forwarding state
[ 18.324592] l4tbr0: port 1(rndis0) entered blocking state
[ 18.324594] l4tbr0: port 1(rndis0) entered forwarding state
[ 18.582308] audit: type=1326 audit(1701726248.584:3): auid=4294967295 uid=0 gid=0 ses=4294967295 subj=kernel pid=2184 comm="cupsd" exe="/snap/cups/981/sbin/cupsd" sig=0 arch=c00000b7 syscall=55 compa0
[ 18.603634] audit: type=1326 audit(1701726248.600:4): auid=4294967295 uid=0 gid=0 ses=4294967295 subj=kernel pid=2255 comm="cups-browsed" exe="/snap/cups/981/sbin/cups-browsed" sig=0 arch=c00000b7 sy0
[ 18.768141] IPv6: ADDRCONF(NETDEV_CHANGE): l4tbr0: link becomes ready
[ 42.448001] vdd-12v-sys: disabling
[ 42.448017] vdd-3v3-ftdi: disabling
SDKM_logs_JetPack_5.1.2_Linux_for_Jetson_AGX_Orin_modules_2023-12-04_16-48-48.zip (269.5 KB)
The issue is on your host PC, but not the device.
Do you have nfs-server enabled on your host PC?
sudo systemctl status nfs-server.service
Or are they even enabled in kernel config?
cat /proc/filesystems | grep nfs
Also maybe check the firewall setting.
If you don’t know what I’m taking about, or all of the above does not work, then please find another host PC for flashing.
