AGX Orin fails to detect any USB devices (even USB hubs)
I tried powering my AGX directly with a 3S Li battery yesterday, because the original power wasn’t enough. It worked fine at first, but after one reboot, it couldn’t detect any USB devices. I could still use USB keyboar in BIOS and re-flash it via SDK Manager, but even after re-flashing, no USB devices show up. Could this be because I hooked up the battery without a voltage regulator? What should I do?
Here’s the kernel log from boot:
(base) qejyu@ubuntu:~$ sudo dmesg
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[    0.000000] Linux version 5.15.148-tegra (buildbrain@mobile-u64-6262-d8000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2022.08) 11.3.0, GNU ld (GNU Binutils) 2.38) #1 SMP PREEMPT Mon Jun 16 08:24:48 PDT 2025 ()
[    0.000000] Machine model: NVIDIA Jetson AGX Orin Developer Kit
[    0.000000] efi: EFI v2.70 by EDK II
[    0.000000] efi: RTPROP=0x1027f8f198 TPMFinalLog=0x1018b50000 SMBIOS=0xffff0000 SMBIOS 3.0=0x1027980000 MEMATTR=0x1021a67018 ESRT=0x1021a6af98 TPMEventLog=0x1018b68018 RNG=0x10150f0018 MEMRESERVE=0x1018b6ac18
[    0.000000] random: crng init done
[    0.000000] secureboot: Secure boot disabled
[    0.000000] esrt: Reserving ESRT space from 0x0000001021a6af98 to 0x0000001021a6afd0.
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000ff4000000, size 512 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000080000000-0x0000001033ffffff]
[    0.000000] NUMA: NODE_DATA [mem 0x1022d14800-0x1022d16fff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x0000001033ffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x00000000fffdffff]
[    0.000000]   node   0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x00000010189effff]
[    0.000000]   node   0: [mem 0x00000010189f0000-0x0000001018b5ffff]
[    0.000000]   node   0: [mem 0x0000001018b60000-0x0000001018b6afff]
[    0.000000]   node   0: [mem 0x0000001018b6b000-0x0000001018b6bfff]
[    0.000000]   node   0: [mem 0x0000001018b6c000-0x000000102604ffff]
[    0.000000]   node   0: [mem 0x0000001026050000-0x0000001027f8ffff]
[    0.000000]   node   0: [mem 0x0000001027f90000-0x000000102c5fffff]
[    0.000000]   node   0: [mem 0x000000102c600000-0x000000102c7fffff]
[    0.000000]   node   0: [mem 0x000000102c800000-0x000000102cd6ffff]
[    0.000000]   node   0: [mem 0x000000102d700000-0x000000102d7fffff]
[    0.000000]   node   0: [mem 0x0000001032000000-0x0000001033ffffff]
[    0.000000] mminit::pageflags_layout_widths Section 0 Node 4 Zone 2 Lastcpupid 16 Kasantag 0 Flags 24
[    0.000000] mminit::pageflags_layout_shifts Section 21 Node 4 Zone 2 Lastcpupid 16 Kasantag 0
[    0.000000] mminit::pageflags_layout_pgshifts Section 0 Node 60 Zone 58 Lastcpupid 42 Kasantag 0
[    0.000000] mminit::pageflags_layout_nodezoneid Node/Zone ID: 64 -> 58
[    0.000000] mminit::pageflags_layout_usage location: 64 -> 42 layout 42 -> 24 unused 24 -> 0 page-flags
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000001033ffffff]
[    0.000000] mminit::memmap_init Initialising map node 0 zone 0 pfns 524288 -> 1048576
[    0.000000] mminit::memmap_init Initialising map node 0 zone 2 pfns 1048576 -> 16990208
[    0.000000] On node 0, zone Normal: 2448 pages in unavailable ranges
[    0.000000] On node 0, zone Normal: 18432 pages in unavailable ranges
[    0.000000] On node 0, zone Normal: 16384 pages in unavailable ranges
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 29 pages/cpu s80408 r8192 d30184 u118784
[    0.000000] pcpu-alloc: s80408 r8192 d30184 u118784 alloc=29*4096
[    0.000000] pcpu-alloc: [0] 00 [0] 01 [0] 02 [0] 03 [0] 04 [0] 05 [0] 06 [0] 07
[    0.000000] pcpu-alloc: [0] 08 [0] 09 [0] 10 [0] 11
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: Address authentication (architected algorithm)
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: detected: Hardware dirty bit management
[    0.000000] CPU features: detected: Spectre-v4
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] alternatives: patching kernel code
[    0.000000] mminit::zonelist general 0:DMA = 0:DMA
[    0.000000] mminit::zonelist general 0:Normal = 0:Normal 0:DMA
[    0.000000] mminit::zonelist thisnode 0:DMA = 0:DMA
[    0.000000] mminit::zonelist thisnode 0:Normal = 0:Normal 0:DMA
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 16187760
[    0.000000] Policy zone: Normal
[    0.000000] Kernel command line: root=PARTUUID=6be57015-f728-4392-b9e7-ec57eb448bcd rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 firmware_class.path=/etc/firmware fbcon=map:0 video=efifb:off console=tty0 nv-auto-config bl_prof_dataptr=2031616@0x102C610000 bl_prof_ro_ptr=65536@0x102C600000
[    0.000000] Unknown kernel command line parameters "nv-auto-config bl_prof_dataptr=2031616@0x102C610000 bl_prof_ro_ptr=65536@0x102C600000", will be passed to user space.
[    0.000000] Dentry cache hash table entries: 8388608 (order: 14, 67108864 bytes, linear)
[    0.000000] Inode-cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000fbfe0000-0x00000000fffe0000] (64MB)
[    0.000000] Memory: 63801524K/65780160K available (20160K kernel code, 4064K rwdata, 10056K rodata, 7680K init, 529K bss, 1454348K reserved, 524288K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=12, Nodes=1
[    0.000000] trace event string verifier disabled
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=12.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Rude variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=12
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[    0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000005] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.000587] Console: colour dummy device 80x25
[    0.000607] printk: console [tty0] enabled
[    0.000744] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[    0.000761] pid_max: default: 32768 minimum: 301
[    0.000819] LSM: Security Framework initializing
[    0.000868] Yama: becoming mindful.
[    0.000907] SELinux:  Initializing.
[    0.001292] Mount-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.001555] Mountpoint-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.005299] rcu: Hierarchical SRCU implementation.
[    0.009730] Tegra Revision: A01 SKU: 208 CPU Process: 0 SoC Process: 0
[    0.010105] Remapping and enabling EFI services.
[    0.011397] smp: Bringing up secondary CPUs ...
[    0.012294] Detected PIPT I-cache on CPU1
[    0.012409] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[    0.012517] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[    0.013325] Detected PIPT I-cache on CPU2
[    0.013338] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[    0.013363] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[    0.014024] Detected PIPT I-cache on CPU3
[    0.014035] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[    0.014054] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[    0.016775] Detected PIPT I-cache on CPU4
[    0.016801] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c0000
[    0.016834] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[    0.017566] Detected PIPT I-cache on CPU5
[    0.017578] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e0000
[    0.017599] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[    0.018271] Detected PIPT I-cache on CPU6
[    0.018283] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f500000
[    0.018302] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[    0.018977] Detected PIPT I-cache on CPU7
[    0.018990] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f520000
[    0.019012] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
[    0.021734] Detected PIPT I-cache on CPU8
[    0.021764] GICv3: CPU8: found redistributor 20000 region 0:0x000000000f540000
[    0.021797] CPU8: Booted secondary processor 0x0000020000 [0x410fd421]
[    0.022525] Detected PIPT I-cache on CPU9
[    0.022541] GICv3: CPU9: found redistributor 20100 region 0:0x000000000f560000
[    0.022562] CPU9: Booted secondary processor 0x0000020100 [0x410fd421]
[    0.023293] Detected PIPT I-cache on CPU10
[    0.023308] GICv3: CPU10: found redistributor 20200 region 0:0x000000000f580000
[    0.023329] CPU10: Booted secondary processor 0x0000020200 [0x410fd421]
[    0.024033] Detected PIPT I-cache on CPU11
[    0.024049] GICv3: CPU11: found redistributor 20300 region 0:0x000000000f5a0000
[    0.024068] CPU11: Booted secondary processor 0x0000020300 [0x410fd421]
[    0.024161] smp: Brought up 1 node, 12 CPUs
[    0.024169] SMP: Total of 12 processors activated.
[    0.024176] CPU features: detected: 32-bit EL0 Support
[    0.024181] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.024188] CPU features: detected: Common not Private translations
[    0.024190] CPU features: detected: CRC32 instructions
[    0.024191] CPU features: detected: Data cache clean to Point of Persistence
[    0.024195] CPU features: detected: Generic authentication (architected algorithm)
[    0.024196] CPU features: detected: RCpc load-acquire (LDAPR)
[    0.024197] CPU features: detected: LSE atomic instructions
[    0.024201] CPU features: detected: Privileged Access Never
[    0.024204] CPU features: detected: RAS Extension Support
[    0.024210] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.080803] CPU: All CPU(s) started at EL2
[    0.089449] devtmpfs: initialized
[    0.112616] KASLR enabled
[    0.112824] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.112856] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[    0.122427] pinctrl core: initialized pinctrl subsystem
[    0.123476] SMBIOS 3.6.0 present.
[    0.123488] DMI: NVIDIA NVIDIA Jetson AGX Orin Developer Kit/Jetson, BIOS 36.4.4-gcid-41062509 06/16/2025
[    0.124095] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.126625] DMA: preallocated 8192 KiB GFP_KERNEL pool for atomic allocations
[    0.127309] DMA: preallocated 8192 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.127967] DMA: preallocated 8192 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.128035] audit: initializing netlink subsys (disabled)
[    0.128201] audit: type=2000 audit(0.124:1): state=initialized audit_enabled=0 res=1
[    0.130232] thermal_sys: Registered thermal governor 'step_wise'
[    0.130235] thermal_sys: Registered thermal governor 'user_space'
[    0.130236] thermal_sys: Registered thermal governor 'power_allocator'
[    0.135126] cpuidle: using governor menu
[    0.135325] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.135496] ASID allocator initialised with 32768 entries
[    0.137748] Serial: AMBA PL011 UART driver
[    0.149714] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 118, base_baud = 0) is a SBSA
[    0.149758] printk: console [ttyAMA0] enabled
[    0.161265] platform bpmp: Fixing up cyclic dependency with 2c60000.external-memory-controller
[    0.170599] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.170608] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.170609] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.170610] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.171751] cryptd: max_cpu_qlen set to 1000
[    0.173904] ACPI: Interpreter disabled.
[    0.175925] iommu: Default domain type: Translated
[    0.175931] iommu: DMA domain TLB invalidation policy: strict mode
[    0.176291] SCSI subsystem initialized
[    0.176393] libata version 3.00 loaded.
[    0.176481] vgaarb: loaded
[    0.176660] usbcore: registered new interface driver usbfs
[    0.176682] usbcore: registered new interface driver hub
[    0.176703] usbcore: registered new device driver usb
[    0.177138] pps_core: LinuxPPS API ver. 1 registered
[    0.177143] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.177155] PTP clock support registered
[    0.177229] EDAC MC: Ver: 3.0.0
[    0.178596] Registered efivars operations
[    0.179201] FPGA manager framework
[    0.179278] Advanced Linux Sound Architecture Driver Initialized.
[    0.179955] Bluetooth: Core ver 2.22
[    0.179986] NET: Registered PF_BLUETOOTH protocol family
[    0.179988] Bluetooth: HCI device and connection manager initialized
[    0.179998] Bluetooth: HCI socket layer initialized
[    0.180002] Bluetooth: L2CAP socket layer initialized
[    0.180016] Bluetooth: SCO socket layer initialized
[    0.180460] clocksource: Switched to clocksource arch_sys_counter
[    0.219531] VFS: Disk quotas dquot_6.6.0
[    0.219622] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.219855] pnp: PnP ACPI: disabled
[    0.222967] NET: Registered PF_INET protocol family
[    0.223517] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.225804] tcp_listen_portaddr_hash hash table entries: 32768 (order: 7, 524288 bytes, linear)
[    0.226471] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.226517] TCP established hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.226921] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    0.228254] TCP: Hash tables configured (established 524288 bind 65536)
[    0.228525] UDP hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[    0.228662] UDP-Lite hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[    0.229022] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.229542] RPC: Registered named UNIX socket transport module.
[    0.229546] RPC: Registered udp transport module.
[    0.229547] RPC: Registered tcp transport module.
[    0.229549] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.229568] PCI: CLS 0 bytes, default 64
[    0.229845] Unpacking initramfs...
[    0.237484] hw perfevents: enabled with armv8_cortex_a78 PMU driver, 7 counters available
[    0.237849] kvm [1]: IPA Size Limit: 48 bits
[    0.237892] kvm [1]: GICv3: no GICV resource entry
[    0.237900] kvm [1]: disabling GICv2 emulation
[    0.237918] kvm [1]: GIC system register CPU interface enabled
[    0.238044] kvm [1]: vgic interrupt IRQ9
[    0.238261] kvm [1]: VHE mode initialized successfully
[    0.241699] Initialise system trusted keyrings
[    0.241745] Key type blacklist registered
[    0.241859] workingset: timestamp_bits=42 max_order=24 bucket_order=0
[    0.245824] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.246325] NFS: Registering the id_resolver key type
[    0.246362] Key type id_resolver registered
[    0.246365] Key type id_legacy registered
[    0.246429] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.246445] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.246472] ntfs: driver 2.1.32 [Flags: R/O].
[    0.246704] 9p: Installing v9fs 9p2000 file system support
[    0.247378] integrity: Platform Keyring initialized
[    0.258426] Key type asymmetric registered
[    0.258433] Asymmetric key parser 'x509' registered
[    0.258573] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    0.258583] io scheduler mq-deadline registered
[    0.258591] io scheduler kyber registered
[    0.269484] EINJ: ACPI disabled.
[    0.281702] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.283537] SuperH (H)SCI(F) driver initialized
[    0.283894] msm_serial: driver initialized
[    0.284524] printk: console [ttyTCU0] enabled
[    0.285486] arm-smmu 8000000.iommu: probing hardware configuration...
[    0.285492] arm-smmu 8000000.iommu: SMMUv2 with:
[    0.285499] arm-smmu 8000000.iommu:  stage 1 translation
[    0.285501] arm-smmu 8000000.iommu:  stage 2 translation
[    0.285503] arm-smmu 8000000.iommu:  nested translation
[    0.285510] arm-smmu 8000000.iommu:  stream matching with 128 register groups
[    0.285514] arm-smmu 8000000.iommu:  128 context banks (0 stage-2 only)
[    0.285529] arm-smmu 8000000.iommu:  Supported page sizes: 0x61311000
[    0.285533] arm-smmu 8000000.iommu:  Stage-1: 48-bit VA -> 48-bit IPA
[    0.285536] arm-smmu 8000000.iommu:  Stage-2: 48-bit IPA -> 48-bit PA
[    0.286548] arm-smmu 10000000.iommu: probing hardware configuration...
[    0.286552] arm-smmu 10000000.iommu: SMMUv2 with:
[    0.286555] arm-smmu 10000000.iommu:         stage 1 translation
[    0.286557] arm-smmu 10000000.iommu:         stage 2 translation
[    0.286557] arm-smmu 10000000.iommu:         nested translation
[    0.286562] arm-smmu 10000000.iommu:         stream matching with 128 register groups
[    0.286563] arm-smmu 10000000.iommu:         128 context banks (0 stage-2 only)
[    0.286576] arm-smmu 10000000.iommu:         Supported page sizes: 0x61311000
[    0.286578] arm-smmu 10000000.iommu:         Stage-1: 48-bit VA -> 48-bit IPA
[    0.286578] arm-smmu 10000000.iommu:         Stage-2: 48-bit IPA -> 48-bit PA
[    0.286938] arm-smmu 12000000.iommu: probing hardware configuration...
[    0.286941] arm-smmu 12000000.iommu: SMMUv2 with:
[    0.286943] arm-smmu 12000000.iommu:         stage 1 translation
[    0.286944] arm-smmu 12000000.iommu:         stage 2 translation
[    0.286945] arm-smmu 12000000.iommu:         nested translation
[    0.286948] arm-smmu 12000000.iommu:         stream matching with 128 register groups
[    0.286949] arm-smmu 12000000.iommu:         128 context banks (0 stage-2 only)
[    0.286955] arm-smmu 12000000.iommu:         Supported page sizes: 0x61311000
[    0.286955] arm-smmu 12000000.iommu:         Stage-1: 48-bit VA -> 48-bit IPA
[    0.286957] arm-smmu 12000000.iommu:         Stage-2: 48-bit IPA -> 48-bit PA
[    0.297913] loop: module loaded
[    0.298960] megasas: 07.717.02.00-rc1
[    0.303101] tun: Universal TUN/TAP device driver, 1.6
[    0.303697] thunder_xcv, ver 1.0
[    0.303727] thunder_bgx, ver 1.0
[    0.303758] nicpf, ver 1.0
[    0.304653] hclge is initializing
[    0.304687] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    0.304695] hns3: Copyright (c) 2017 Huawei Corporation.
[    0.304737] e1000: Intel(R) PRO/1000 Network Driver
[    0.304743] e1000: Copyright (c) 1999-2006 Intel Corporation.
[    0.304771] e1000e: Intel(R) PRO/1000 Network Driver
[    0.304775] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    0.304801] igb: Intel(R) Gigabit Ethernet Network Driver
[    0.304807] igb: Copyright (c) 2007-2014 Intel Corporation.
[    0.304824] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    0.304830] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.305053] sky2: driver version 1.30
[    0.305745] VFIO - User Level meta-driver version: 0.3
[    0.307209] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.307220] ehci-pci: EHCI PCI platform driver
[    0.307244] ehci-platform: EHCI generic platform driver
[    0.307330] ehci-orion: EHCI orion driver
[    0.307398] ehci-exynos: EHCI Exynos driver
[    0.307456] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.307485] ohci-pci: OHCI PCI platform driver
[    0.307513] ohci-platform: OHCI generic platform driver
[    0.307590] ohci-exynos: OHCI Exynos driver
[    0.308028] usbcore: registered new interface driver usb-storage
[    0.309924] i2c_dev: i2c /dev entries driver
[    0.311264] pps pps0: new PPS source ktimer
[    0.311275] pps pps0: ktimer PPS source registered
[    0.311286] pps_ldisc: PPS line discipline registered
[    0.313405] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[    0.315537] sdhci: Secure Digital Host Controller Interface driver
[    0.315542] sdhci: Copyright(c) Pierre Ossman
[    0.316023] Synopsys Designware Multimedia Card Interface Driver
[    0.316679] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.318379] ledtrig-cpu: registered to indicate activity on CPUs
[    0.319409] SMCCC: SOC_ID: ID = jep106:036b:0234 Revision = 0x00000401
[    0.319981] tegra-bpmp bpmp: Adding to iommu group 0
[    0.322036] tegra-bpmp bpmp: firmware: 39f77b2baaf3f0522607-da583751bbf
[    0.478801] Freeing initrd memory: 15492K
[    4.024602] clocksource: tsc: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    4.024620] clocksource: osc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 49772407460 ns
[    4.024623] clocksource: usec: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[    4.024815] hid: raw HID events driver (C) Jiri Kosina
[    4.025196] usbcore: registered new interface driver usbhid
[    4.025202] usbhid: USB HID core driver
[    4.030138] optee: probing for conduit method.
[    4.030200] optee: revision 4.2 (d78bc5fa)
[    4.089533] optee: dynamic shared memory is enabled
[    4.089816] optee: initialized driver
[    4.092429] usbcore: registered new interface driver snd-usb-audio
[    4.094032] NET: Registered PF_PACKET protocol family
[    4.095089] Bluetooth: RFCOMM TTY layer initialized
[    4.095102] Bluetooth: RFCOMM socket layer initialized
[    4.095124] Bluetooth: RFCOMM ver 1.11
[    4.095308] 9pnet: Installing 9P2000 support
[    4.095389] Key type dns_resolver registered
[    4.096725] printk: console [tty0]: printing thread started
[    4.097368] printk: console [ttyTCU0]: printing thread started
[    4.098472] printk: console [ttyAMA0]: printing thread started
[    4.098565] Loading compiled-in X.509 certificates
[    4.101191] Loaded X.509 cert 'Build time autogenerated kernel key: 7f1e7893f24e1cf3b68affc169b61dbde0fdceaa'
[    4.191305] gpio-394 (camera-control-output-low): hogged as output/low
[    4.191340] gpio-397 (camera-control-output-low): hogged as output/low
[    4.191368] gpio-487 (camera-control-output-low): hogged as output/low
[    4.191386] gpio-486 (camera-control-output-low): hogged as output/low
[    4.194961] tegra-gpcdma 2600000.dma-controller: Adding to iommu group 1
[    4.196853] tegra-gpcdma 2600000.dma-controller: GPC DMA driver register 31 channels
[    4.198690] serial-tegra 3100000.serial: RX in PIO mode
[    4.198693] serial-tegra 3100000.serial: TX in PIO mode
[    4.198754] 3100000.serial: ttyTHS1 at MMIO 0x3100000 (irq = 112, base_baud = 0) is a TEGRA_UART
[    4.199254] serial-tegra 3110000.serial: RX in PIO mode
[    4.199259] serial-tegra 3110000.serial: TX in PIO mode
[    4.199288] 3110000.serial: ttyTHS2 at MMIO 0x3110000 (irq = 206, base_baud = 0) is a TEGRA_UART
[    4.201641] tegra_rtc c2a0000.rtc: registered as rtc1
[    4.201648] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    4.202088] tegra-i2c 3160000.i2c: Adding to iommu group 1
[    4.209901] tegra-i2c 3180000.i2c: Adding to iommu group 1
[    4.213134] tegra-i2c 3190000.i2c: Adding to iommu group 1
[    4.218756] tegra-i2c 31b0000.i2c: Adding to iommu group 1
[    4.224198] tegra-i2c 31c0000.i2c: Adding to iommu group 1
[    4.227402] tegra-i2c 31e0000.i2c: Adding to iommu group 1
[    4.230652] tegra-i2c c240000.i2c: Adding to iommu group 1
[    4.233985] tegra-i2c c250000.i2c: Adding to iommu group 1
[    4.265554] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 2009000 KHz, changing to: 2035200 KHz
[    4.268104] cpufreq: cpufreq_online: CPU8: Running at unlisted initial frequency: 2010000 KHz, changing to: 2035200 KHz
[    4.271052] sdhci-tegra 3460000.mmc: Adding to iommu group 2
[    4.272079] sdhci-tegra 3400000.mmc: Adding to iommu group 3
[    4.273116] irq: IRQ233: trimming hierarchy from :bus@0:pmc@c360000
[    4.273170] irq: IRQ234: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[    4.273214] irq: IRQ235: trimming hierarchy from :bus@0:pmc@c360000
[    4.273264] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    4.715186] ALSA device list:
[    4.715193]   No soundcards found.
[    4.717041] mmc0: CQHCI version 5.10
[    4.717131] sdhci-tegra 3400000.mmc: Got CD GPIO
[    4.752688] mmc0: SDHCI controller on 3460000.mmc [3460000.mmc] using ADMA 64-bit
[    4.763550] irq: IRQ236: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[    4.763856] mmc1: SDHCI controller on 3400000.mmc [3400000.mmc] using ADMA 64-bit
[    4.764981] Freeing unused kernel memory: 7680K
[    4.765048] Run /init as init process
[    4.765050]   with arguments:
[    4.765050]     /init
[    4.765051]     nv-auto-config
[    4.765051]   with environment:
[    4.765052]     HOME=/
[    4.765052]     TERM=linux
[    4.765053]     bl_prof_dataptr=2031616@0x102C610000
[    4.765053]     bl_prof_ro_ptr=65536@0x102C600000
[    4.780564] Checking overlayfs setting...
[    4.790040] Overlayfs is disabled...
[    4.796491] Root device found: PARTUUID=6be57015-f728-4392-b9e7-ec57eb448bcd
[    4.858352] mmc0: Command Queue Engine enabled
[    4.858362] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[    4.858790] mmcblk0: mmc0:0001 DG4064 59.2 GiB
[    4.863033]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[    4.863550] mmcblk0boot0: mmc0:0001 DG4064 4.00 MiB
[    4.863987] mmcblk0boot1: mmc0:0001 DG4064 4.00 MiB
[    4.864371] mmcblk0rpmb: mmc0:0001 DG4064 4.00 MiB, chardev (511:0)
[    7.952023] tegra194-pcie 14100000.pcie: Adding to iommu group 4
[    7.955383] tegra194-pcie 14100000.pcie: host bridge /bus@0/pcie@14100000 ranges:
[    7.955407] tegra194-pcie 14100000.pcie:      MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[    7.955412] tegra194-pcie 14100000.pcie:      MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[    7.955415] tegra194-pcie 14100000.pcie:       IO 0x0030100000..0x00301fffff -> 0x0030100000
[    7.955721] tegra194-pcie 14100000.pcie: iATU unroll: enabled
[    7.955724] tegra194-pcie 14100000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[    8.024908] irq: IRQ237: trimming hierarchy from :bus@0:pmc@c360000
[    8.026500] tegra-i2c c240000.i2c: un-recovered arbitration lost
[    8.026504] ucsi_ccg 1-0008: i2c_transfer failed -5
[    8.026506] ucsi_ccg 1-0008: ucsi_ccg_init failed - -5
[    8.026509] ucsi_ccg: probe of 1-0008 failed with error -5
[    8.060456] tegra194-pcie 14100000.pcie: Link up
[    8.063665] tegra194-pcie 14100000.pcie: Link up
[    8.063826] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[    8.063830] pci_bus 0001:00: root bus resource [io  0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[    8.063833] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[    8.063835] pci_bus 0001:00: root bus resource [bus 00-ff]
[    8.063836] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[    8.063886] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[    8.064051] pci 0001:00:00.0: PME# supported from D0 D3hot
[    8.067878] pci 0001:01:00.0: [10ec:c822] type 00 class 0x028000
[    8.068051] pci 0001:01:00.0: reg 0x10: [io  0x0000-0x00ff]
[    8.068251] pci 0001:01:00.0: reg 0x18: [mem 0x20a8000000-0x20a800ffff 64bit]
[    8.069310] pci 0001:01:00.0: supports D1 D2
[    8.069312] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    8.083383] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff]
[    8.083387] pci 0001:00:00.0: BAR 13: assigned [io  0x1000-0x1fff]
[    8.083391] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8000000-0x20a800ffff 64bit]
[    8.083492] pci 0001:01:00.0: BAR 0: assigned [io  0x1000-0x10ff]
[    8.083524] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[    8.083528] pci 0001:00:00.0:   bridge window [io  0x1000-0x1fff]
[    8.083532] pci 0001:00:00.0:   bridge window [mem 0x20a8000000-0x20a80fffff]
[    8.083647] pcieport 0001:00:00.0: Adding to iommu group 4
[    8.083750] pcieport 0001:00:00.0: PME: Signaling with IRQ 200
[    8.084040] pcieport 0001:00:00.0: AER: enabled with IRQ 200
[    8.084859] tegra194-pcie 14160000.pcie: Adding to iommu group 5
[    8.087773] tegra194-pcie 14160000.pcie: host bridge /bus@0/pcie@14160000 ranges:
[    8.087794] tegra194-pcie 14160000.pcie:      MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[    8.087800] tegra194-pcie 14160000.pcie:      MEM 0x2428000000..0x242fffffff -> 0x0040000000
[    8.087803] tegra194-pcie 14160000.pcie:       IO 0x0036100000..0x00361fffff -> 0x0036100000
[    8.088299] tegra194-pcie 14160000.pcie: iATU unroll: enabled
[    8.088303] tegra194-pcie 14160000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[    8.196629] tegra194-pcie 14160000.pcie: Link up
[    8.199343] tegra194-pcie 14160000.pcie: Link up
[    8.199397] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[    8.199400] pci_bus 0004:00: root bus resource [io  0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[    8.199403] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[    8.199406] pci_bus 0004:00: root bus resource [bus 00-ff]
[    8.199407] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[    8.199449] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[    8.199594] pci 0004:00:00.0: PME# supported from D0 D3hot
[    8.203109] pci 0004:01:00.0: [1e4b:1202] type 00 class 0x010802
[    8.203297] pci 0004:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[    8.204514] pci 0004:01:00.0: PME# supported from D0 D3hot D3cold
[    8.219393] pci 0004:00:00.0: BAR 14: assigned [mem 0x2428000000-0x24280fffff]
[    8.219398] pci 0004:01:00.0: BAR 0: assigned [mem 0x2428000000-0x2428003fff 64bit]
[    8.219481] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[    8.219486] pci 0004:00:00.0:   bridge window [mem 0x2428000000-0x24280fffff]
[    8.219581] pcieport 0004:00:00.0: Adding to iommu group 5
[    8.219664] pcieport 0004:00:00.0: PME: Signaling with IRQ 202
[    8.219947] pcieport 0004:00:00.0: AER: enabled with IRQ 202
[    8.220113] nvme 0004:01:00.0: Adding to iommu group 5
[    8.220583] nvme nvme0: pci function 0004:01:00.0
[    8.220644] nvme 0004:01:00.0: enabling device (0000 -> 0002)
[    8.221234] tegra194-pcie 141a0000.pcie: Adding to iommu group 6
[    8.226249] nvme nvme0: allocated 8 MiB host memory buffer.
[    8.229791] nvme nvme0: 8/0/0 default/read/poll queues
[    8.230871] nvme nvme0: Ignoring bogus Namespace Identifiers
[    8.329792] tegra194-pcie 141a0000.pcie: host bridge /bus@0/pcie@141a0000 ranges:
[    8.329816] tegra194-pcie 141a0000.pcie:      MEM 0x2800000000..0x2b27ffffff -> 0x2800000000
[    8.329822] tegra194-pcie 141a0000.pcie:      MEM 0x2b28000000..0x2b2fffffff -> 0x0040000000
[    8.329824] tegra194-pcie 141a0000.pcie:       IO 0x003a100000..0x003a1fffff -> 0x003a100000
[    8.330348] tegra194-pcie 141a0000.pcie: iATU unroll: enabled
[    8.330351] tegra194-pcie 141a0000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[    8.538801] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[    8.546097] Rootfs mounted over PARTUUID=6be57015-f728-4392-b9e7-ec57eb448bcd
[    8.565550] Switching from initrd to actual rootfs
[    8.700197] SELinux:  Permission setdisplay in class process2 not defined in policy.
[    8.700327] SELinux:  Class mctp_socket not defined in policy.
[    8.700331] SELinux:  Class anon_inode not defined in policy.
[    8.700332] SELinux: the above unknown classes and permissions will be allowed
[    8.704221] SELinux:  policy capability network_peer_controls=1
[    8.704227] SELinux:  policy capability open_perms=1
[    8.704228] SELinux:  policy capability extended_socket_class=1
[    8.704229] SELinux:  policy capability always_check_network=0
[    8.704229] SELinux:  policy capability cgroup_seclabel=1
[    8.704230] SELinux:  policy capability nnp_nosuid_transition=1
[    8.704230] SELinux:  policy capability genfs_seclabel_symlinks=0
[    8.704231] SELinux:  policy capability ioctl_skip_cloexec=0
[    8.756653] audit: type=1403 audit(8.752:2): auid=4294967295 ses=4294967295 lsm=selinux res=1
[    8.761051] systemd[1]: Successfully loaded SELinux policy in 95.415ms.
[    8.802661] systemd[1]: System time before build time, advancing clock.
[    8.824652] audit: type=1400 audit(1749046663.020:3): avc:  denied  { module_load } for  pid=1 comm="systemd" path="/usr/lib/modules/5.15.148-tegra/kernel/net/ipv6/ipv6.ko" dev="mmcblk0p1" ino=165282 scontext=system_u:system_r:kernel_t:s0 tcontext=system_u:object_r:unlabeled_t:s0 tclass=system permissive=1
[    8.858433] NET: Registered PF_INET6 protocol family
[    8.859238] Segment Routing with IPv6
[    8.859244] In-situ OAM (IOAM) with IPv6
[    8.894977] systemd[1]: Relabelled /dev, /dev/shm, /run, /sys/fs/cgroup in 11.665ms.
[    8.905029] systemd[1]: systemd 249.11-0ubuntu3.16 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[    8.905424] systemd[1]: Detected architecture arm64.
[    8.946973] systemd[1]: Hostname set to <ubuntu>.
[    8.960708] systemd[1]: Using hardware watchdog 'NVIDIA Tegra186 WDT', version 0, device /dev/watchdog
[    8.960726] systemd[1]: Set hardware watchdog to 2min.
[    9.333836] systemd[1]: /lib/systemd/system/snapd.service:23: Unknown key name 'RestartMode' in section 'Service', ignoring.
[    9.343333] systemd[1]: /etc/systemd/system/nvs-service.service:41: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    9.347890] systemd[1]: /etc/systemd/system/nvargus-daemon.service:42: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    9.415111] systemd[1]: Queued start job for default target Graphical Interface.
[    9.417347] systemd[1]: Created slice Slice /system/modprobe.
[    9.432023] systemd[1]: Created slice Slice /system/serial-getty.
[    9.432761] systemd[1]: Created slice Slice /system/systemd-fsck.
[    9.436824] tegra194-pcie 141a0000.pcie: Phy link never came up
[    9.452981] systemd[1]: Created slice User and Session Slice.
[    9.453224] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    9.454221] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    9.454415] systemd[1]: Reached target Slice Units.
[    9.454468] systemd[1]: Reached target Mounting snaps.
[    9.454510] systemd[1]: Reached target Mounted snaps.
[    9.454559] systemd[1]: Reached target Swaps.
[    9.454607] systemd[1]: Reached target Local Verity Protected Volumes.
[    9.455067] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[    9.455803] systemd[1]: Listening on LVM2 poll daemon socket.
[    9.465781] systemd[1]: Listening on RPCbind Server Activation Socket.
[    9.516997] systemd[1]: Listening on Syslog Socket.
[    9.534995] systemd[1]: Listening on fsck to fsckd communication Socket.
[    9.535276] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    9.536036] systemd[1]: Listening on Journal Audit Socket.
[    9.536211] audit: type=1400 audit(1749046663.728:4): avc:  denied  { audit_read } for  pid=1 comm="systemd" capability=37  scontext=system_u:system_r:kernel_t:s0 tcontext=system_u:system_r:kernel_t:s0 tclass=capability2 permissive=1
[    9.536278] systemd[1]: Listening on Journal Socket (/dev/log).
[    9.536621] systemd[1]: Listening on Journal Socket.
[    9.592672] systemd[1]: Listening on udev Control Socket.
[    9.592910] systemd[1]: Listening on udev Kernel Socket.
[    9.594632] systemd[1]: Mounting Huge Pages File System...
[    9.596538] systemd[1]: Mounting POSIX Message Queue File System...
[    9.622980] systemd[1]: Mounting Kernel Debug File System...
[    9.625077] systemd[1]: Mounting Kernel Trace File System...
[    9.641651] systemd[1]: Starting Journal Service...
[    9.641938] systemd[1]: Finished Availability of block devices.
[    9.644394] systemd[1]: Starting Set the console keyboard layout...
[    9.653297] systemd[1]: Starting Create List of Static Device Nodes...
[    9.673615] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[    9.675419] systemd[1]: Starting Load Kernel Module configfs...
[    9.677296] systemd[1]: Starting Load Kernel Module drm...
[    9.702107] systemd[1]: Starting Load Kernel Module efi_pstore...
[    9.703949] systemd[1]: Starting Load Kernel Module fuse...
[    9.706512] systemd[1]: Starting NVIDIA specific first-boot udev script...
[    9.718654] fuse: init (API version 7.34)
[    9.730979] systemd[1]: Started Nameserver information manager.
[    9.731358] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    9.734561] systemd[1]: Starting Load Kernel Modules...
[    9.756073] systemd[1]: Starting Remount Root and Kernel File Systems...
[    9.758582] systemd[1]: Starting Coldplug All udev Devices...
[    9.764005] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null). Quota mode: none.
[    9.777472] audit: type=1400 audit(1749046663.972:5): avc:  denied  { module_load } for  pid=318 comm="systemd-modules" path="/usr/lib/modules/5.15.148-tegra/kernel/drivers/usb/serial/pl2303.ko" dev="mmcblk0p1" ino=131150 scontext=system_u:system_r:kernel_t:s0 tcontext=system_u:object_r:unlabeled_t:s0 tclass=system permissive=1
[    9.778020] pl2303: loading out-of-tree module taints kernel.
[    9.778062] pl2303: module verification failed: signature and/or required key missing - tainting kernel
[    9.778449] usbcore: registered new interface driver pl2303
[    9.778461] usbserial: USB Serial support registered for pl2303
[    9.778974] systemd[1]: Started Journal Service.
[    9.810595] nvsciipc: loaded module
[    9.848250] nvmap_heap_init: nvmap_heap_init: created heap block cache
[    9.848883] nvmap_co_device_init: vpr :dma coherent mem declare 0x0000001049800000,914358272
[    9.848890] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[    9.848902] nvmap_page_pool_init: Total RAM pages: 16087246
[    9.848903] nvmap_page_pool_init: nvmap page pool size: 2010905 pages (3759 MB)
[    9.849318] nvmap_background_zero_thread: PP zeroing thread starting.
[    9.849335] nvmap_heap_create: created heap vpr base 0x0000001049800000 size (892928KiB)
[    9.849366] nvmap_heap_create: fsi :dma coherent mem declare 0x000000102f000000,16777216
[    9.849368] nvmap_heap_create: created heap fsi base 0x000000102f000000 size (16384KiB)
[    9.921574] tegra-host1x 13e00000.host1x: Adding to iommu group 7
[    9.923004] host1x-context host1x-ctx.0: Adding to iommu group 8
[    9.923144] host1x-context host1x-ctx.1: Adding to iommu group 9
[    9.923270] host1x-context host1x-ctx.2: Adding to iommu group 10
[    9.923397] host1x-context host1x-ctx.3: Adding to iommu group 11
[    9.923543] host1x-context host1x-ctx.4: Adding to iommu group 12
[    9.923700] host1x-context host1x-ctx.5: Adding to iommu group 13
[    9.923852] host1x-context host1x-ctx.6: Adding to iommu group 14
[    9.923995] host1x-context host1x-ctx.7: Adding to iommu group 15
[    9.924137] host1x-context host1x-ctx.8: Adding to iommu group 16
[    9.924258] host1x-context host1x-ctx.9: Adding to iommu group 17
[    9.924387] host1x-context host1x-ctx.10: Adding to iommu group 18
[    9.924556] host1x-context host1x-ctx.11: Adding to iommu group 19
[    9.924682] host1x-context host1x-ctx.12: Adding to iommu group 20
[    9.924837] host1x-context host1x-ctx.13: Adding to iommu group 21
[    9.924969] host1x-context host1x-ctx.14: Adding to iommu group 22
[    9.925118] host1x-context host1x-ctx.15: Adding to iommu group 23
[    9.997945] nvgpu: 17000000.gpu          nvgpu_nvhost_syncpt_init:122  [INFO]  syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[   10.039380] systemd-journald[296]: Received client request to flush runtime journal.
[   10.050551] tegra-i2c c240000.i2c: un-recovered arbitration lost
[   10.050559] ina3221 1-0040: Unable to reset device
[   10.050589] ina3221: probe of 1-0040 failed with error -5
[   10.051184] tegra-i2c c240000.i2c: un-recovered arbitration lost
[   10.051186] ina3221 1-0041: Unable to reset device
[   10.051203] ina3221: probe of 1-0041 failed with error -5
[   10.436473] tegra194-pcie 141a0000.pcie: Phy link never came up
[   10.436579] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[   10.436584] pci_bus 0005:00: root bus resource [io  0x200000-0x2fffff] (bus address [0x3a100000-0x3a1fffff])
[   10.436588] pci_bus 0005:00: root bus resource [mem 0x2b28000000-0x2b2fffffff] (bus address [0x40000000-0x47ffffff])
[   10.436592] pci_bus 0005:00: root bus resource [bus 00-ff]
[   10.436593] pci_bus 0005:00: root bus resource [mem 0x2800000000-0x2b27ffffff pref]
[   10.436650] pci 0005:00:00.0: [10de:229a] type 01 class 0x060400
[   10.436822] pci 0005:00:00.0: PME# supported from D0 D3hot
[   10.484802] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[   10.491626] pcieport 0005:00:00.0: Adding to iommu group 6
[   10.495885] pcieport 0005:00:00.0: PME: Signaling with IRQ 204
[   10.500094] pcieport 0005:00:00.0: AER: enabled with IRQ 204
[   10.615721] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[   10.616294] pci 0005:00:00.0: Removing from iommu group 6
[   10.616312] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[   10.617951] mc: Linux media interface: v0.10
[   10.618121] Inserting ivc_ext.ko module
[   10.618537] nvvrs11 4-0020: NVVRS11 Vendor ID: 0x11
[   10.618835] nvvrs11 4-0020: NVVRS11 Model Rev: 0xE1
[   10.618839] nvvrs11 4-0020: NVVRS11 probe successful
[   10.622456] tsec 15500000.tsec: Adding to iommu group 24
[   10.622602] thermal-trip-event cpu-throttle-alert: cooling device registered.
[   10.623053] nvvrs11 4-0022: NVVRS11 Vendor ID: 0x11
[   10.625752] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9
[   10.626462] nvvrs11 4-0022: NVVRS11 Model Rev: 0xE1
[   10.626467] nvvrs11 4-0022: NVVRS11 probe successful
[   10.627106] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x81
[   10.627225] scare-pigeon 13e00000.host1x:vi0-thi@15f00000: Adding to iommu group 25
[   10.628242] tegra-soc-hwpm f100000.hwpm: Adding to iommu group 26
[   10.628631] thermal-trip-event gpu-throttle-alert: cooling device registered.
[   10.628704] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful
[   10.628866] thermal-trip-event cv0-throttle-alert: cooling device registered.
[   10.629733] thermal-trip-event cv1-throttle-alert: cooling device registered.
[   10.630320] thermal-trip-event cv2-throttle-alert: cooling device registered.
[   10.630615] videodev: Linux video capture interface: v2.00
[   10.632925] hwmon hwmon1: temp1_input not attached to any thermal zone
[   10.633282] hwmon hwmon1: temp2_input not attached to any thermal zone
[   10.633700] tegra-dce d800000.dce: Adding to iommu group 27
[   10.634235] tegra-se 15820000.crypto: Adding to iommu group 28
[   10.634379] dce: dce_ipc_channel_init:311  Invalid Channel State [0x0] for ch_type [2]
[   10.634688] dce: tegra_dce_probe:245  Found display consumer device
[   10.635138] dce: dce_mailbox_set_full_interrupt:157  Intr bit set multiple times for MB : [0x5]
[   10.635147] dce: dce_mailbox_set_full_interrupt:157  Intr bit set multiple times for MB : [0x5]
[   10.635411] dce: dce_admin_send_cmd_ver:456  version : [0x3] err : [0x0]
[   10.635603] dce: dce_mailbox_set_full_interrupt:157  Intr bit set multiple times for MB : [0x1]
[   10.635609] dce: dce_admin_setup_clients_ipc:585  Channel Reset Complete for Type [1] ...
[   10.635611] dce: dce_admin_setup_clients_ipc:561  Get queue info failed for [2]
[   10.635799] dce: dce_mailbox_set_full_interrupt:157  Intr bit set multiple times for MB : [0x2]
[   10.635804] dce: dce_admin_setup_clients_ipc:585  Channel Reset Complete for Type [3] ...
[   10.636782] dce: dce_start_boot_flow:166  DCE_BOOT_DONE
[   10.639106] scare-pigeon 13e00000.host1x:vi0-thi@15f00000: syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[   10.642525] tegra-se 15840000.crypto: Adding to iommu group 29
[   10.643123] thermal-trip-event soc0-throttle-alert: cooling device registered.
[   10.643297] scare-pigeon 13e00000.host1x:vi1-thi@14f00000: Adding to iommu group 30
[   10.643435] nvdla 15880000.nvdla0: Adding to iommu group 31
[   10.648011] scare-pigeon 13e00000.host1x:vi1-thi@14f00000: syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[   10.648255] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 32
[   10.650274] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[   10.652765] scare-pigeon 13e00000.host1x:isp-thi@14b00000: Adding to iommu group 33
[   10.653090] thermal-trip-event soc1-throttle-alert: cooling device registered.
[   10.657564] thermal-trip-event soc2-throttle-alert: cooling device registered.
[   10.658665] thermal-trip-event hot-surface-alert: cooling device registered.
[   10.660551] nvdla 15880000.nvdla0: syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[   10.660739] nvdla 158c0000.nvdla1: Adding to iommu group 34
[   10.664992] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee027f size=131712
[   10.666060] pva 16000000.pva0: Adding to iommu group 35
[   10.666489] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[   10.666927] scare-pigeon 13e00000.host1x:isp-thi@14b00000: syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[   10.669200] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x512]=0x1900-0x1b80 TX[1x512]=0x1b80-0x1e00
[   10.669594] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1e00-0x3e80 TX[1x8192]=0x3e80-0x5f00
[   10.669912] nvdla 158c0000.nvdla1: syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[   10.670662] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5f00-0xaf80 TX[64x320]=0xaf80-0x10000
[   10.670710] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0x10000-0x18080 TX[512x64]=0x18080-0x20100
[   10.670781] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20100-0x201c0 TX[1x64]=0x201c0-0x20280
[   10.670934] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (231)
[   10.670938] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[   10.671230] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=e2238c99959d2df9350d393f04e1f44e5bef98cb
[   10.671359] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: ivc channel driver missing
[   10.671360] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: ivc channel driver missing
[   10.671361] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: ivc channel driver missing
[   10.671362] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivc channel driver missing
[   10.671364] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivc channel driver missing
[   10.671365] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: ivc channel driver missing
[   10.671375] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[   10.671382] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[   10.671391] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[   10.671392] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[   10.671393] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[   10.671394] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[   10.671816] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: Adding to iommu group 36
[   10.671989] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: initialized (streamid=18, iommu=smmu.0x0000000008000000)
[   10.672212] nv_platform 13800000.display: Adding to iommu group 37
[   10.678383] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: Adding to iommu group 38
[   10.681096] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: initialized (streamid=19, iommu=smmu.0x0000000008000000)
[   10.683163] tegra-vic 15340000.vic: Adding to iommu group 39
[   10.691332] platform 13800000.display:nvdisplay-niso: Adding to iommu group 40
[   10.698362] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: Adding to iommu group 41
[   10.699019] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: initialized (streamid=20, iommu=smmu.0x0000000008000000)
[   10.699493] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[   10.701517] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: Adding to iommu group 42
[   10.703205] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: initialized (streamid=21, iommu=smmu.0x0000000008000000)
[   10.704474] [RCE] TCU debug prints will be routed to traces.
[   10.704684] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: Adding to iommu group 43
[   10.705219] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: initialized (streamid=22, iommu=smmu.0x0000000008000000)
[   10.712820] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: Adding to iommu group 44
[   10.712958] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: initialized (streamid=23, iommu=smmu.0x0000000008000000)
[   10.713050] tegra-nvdec 15480000.nvdec: Adding to iommu group 45
[   10.714314] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: Adding to iommu group 46
[   10.714429] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: initialized (streamid=24, iommu=smmu.0x0000000008000000)
[   10.715422] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: Adding to iommu group 47
[   10.715519] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: initialized (streamid=25, iommu=smmu.0x0000000008000000)
[   10.715541] pva 16000000.pva0: pdata->version is HW_GEN2
[   10.721735] pva 16000000.pva0: Completed nvhost_client_device_init
[   10.722908] pva 16000000.pva0: syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[   10.728053] tegra-nvenc 154c0000.nvenc: Adding to iommu group 48
[   10.743343] tsec 15500000.tsec: tsec fw req success in 100 ms
[   10.748144] tegra-nvjpg 15380000.nvjpg: Adding to iommu group 49
[   10.750140] tsec 15500000.tsec: RISC-V boot using kernel allocated Mem
[   10.756464] tsec 15500000.tsec: RISC-V boot success
[   10.756975] tegra-nvjpg 15540000.nvjpg: Adding to iommu group 50
[   10.761775] tegra-ofa 15a50000.ofa: Adding to iommu group 51
[   10.762950] drm drm: [drm] Cannot find any crtc or sizes
[   10.764244] [drm] Initialized tegra 1.0.99 20120330 for drm on minor 0
[   10.777165] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[   10.777175] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[   10.777177] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[   10.777178] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[   10.777179] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[   10.777180] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[   10.780259] tegra194-vi5 13e00000.host1x:vi0@15c00000: Adding to iommu group 25
[   10.780386] tegra194-isp5 14800000.isp: Adding to iommu group 33
[   10.782007] tegra194-vi5 13e00000.host1x:vi1@14c00000: Adding to iommu group 30
[   10.782071] (NULL device *): fops function table already registered
[   10.831774] spi-tegra114 3210000.spi: Adding to iommu group 1
[   10.889594] tegra-hda 3510000.hda: Adding to iommu group 52
[   10.912550] spi-tegra114 3230000.spi: Adding to iommu group 1
[   10.994105] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   10.994553] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   10.994713] cfg80211: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[   11.010828] nvpps c6a0000.nvpps: nvpps_probe
[   11.010888] nvpps c6a0000.nvpps: primary-emac found ethernet@6800000
[   11.010900] nvpps c6a0000.nvpps: primary emac base address 0x6810000
[   11.010903] nvpps c6a0000.nvpps: using ptp notifier method on emac ethernet@6800000
[   11.010904] nvpps c6a0000.nvpps: tsc_res_ns(32)
[   11.010910] nvpps c6a0000.nvpps: PPS GPIO not provided in DT, only Timer mode available
[   11.011127] nvpps c6a0000.nvpps: nvpps cdev(488:0)
[   11.011147] at24 0-0050: 256 byte 24c02 EEPROM, read-only
[   11.011161] nvpps c6a0000.nvpps: TSC config ptx 0x113
[   11.031487] at24 0-0056: 256 byte 24c02 EEPROM, read-only
[   11.048568] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=3 as /devices/platform/bus@0/3510000.hda/sound/card0/input1
[   11.062574] tegra234-aon c000000.aon: Adding to iommu group 53
[   11.063587] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=7 as /devices/platform/bus@0/3510000.hda/sound/card0/input2
[   11.063798] nvethernet 6800000.ethernet: Adding to iommu group 54
[   11.064412]  c000000.aon:hsp: probed
[   11.064981] nvethernet 6800000.ethernet: failed to read skip mac reset flag, default 0
[   11.064988] nvethernet 6800000.ethernet: setting to default DMA bit mask
[   11.064996] nvethernet 6800000.ethernet: failed to read UPHY GBE mode- default to 10G
[   11.066561] tegra234-aon c000000.aon: init done
[   11.070281] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=8 as /devices/platform/bus@0/3510000.hda/sound/card0/input3
[   11.073627] CAN device driver interface
[   11.075899] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=9 as /devices/platform/bus@0/3510000.hda/sound/card0/input4
[   11.077209] gic 2a41000.interrupt-controller: GIC IRQ controller registered
[   11.079692] tegra-aconnect bus@0:aconnect@2900000: Tegra ACONNECT bus registered
[   11.080091] rtl88x2ce 0001:01:00.0: Adding to iommu group 4
[   11.080932] rtl88x2ce 0001:01:00.0: enabling device (0000 -> 0003)
[   11.113900] TT CAN feature is not supported
[   11.114662]   Message RAM Configuration
                | base addr   |0x0c312000|
                | sidfc_flssa |0x00000000|
                | xidfc_flesa |0x00000040|
                | rxf0c_f0sa  |0x000000c0|
                | rxf1c_f1sa  |0x000009c0|
                | rxbc_rbsa   |0x000009c0|
                | txefc_efsa  |0x000009c0|
                | txbc_tbsa   |0x00000a40|
                | tmc_tmsa    |0x00000ec0|
                | mram size   |0x00001000|
[   11.116154] Release 3.2.3 from 09.06.2018
[   11.142487] net can0: mttcan device registered (regs=000000001dbc0bce, irq=211)
[   11.145635] TT CAN feature is not supported
[   11.146053]   Message RAM Configuration
                | base addr   |0x0c322000|
[   11.147383] Release 3.2.3 from 09.06.2018
[   11.255439] net can1: mttcan device registered (regs=00000000242f862e, irq=212)
[   11.299143] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[   11.302817] nvvrs-pseq-rtc nvvrs-pseq-rtc: setting system clock to 1970-01-01T00:00:36 UTC (36)
[   11.352672] tegra-adma 2930000.dma-controller: Tegra210 ADMA driver registered 32 channels
[   11.354173] rtl88x2ce 0001:01:00.0 wlP1p1s0: renamed from wlan0
[   11.363830] platform 2901000.i2s: Fixing up cyclic dependency with 8-001c
[   11.409430] irq: IRQ296: trimming hierarchy from :bus@0:pmc@c360000
[   11.457925] nvethernet 6800000.ethernet: Ethernet MAC address: 3c:6d:66:4e:7b:3f
[   11.460637] -->macsec_probe()
[   11.460703] nvethernet 6800000.ethernet: macsec parameter is missing or disabled
[   11.460706] <--macsec_probe()
[   11.460707] nvethernet 6800000.ethernet: Macsec not supported/Not enabled
[   11.461348] tegra210-admaif 290f000.admaif: Adding to iommu group 55
[   11.464787] nvethernet 6800000.ethernet: eth0 (HW ver: 31) created with 10 DMA channels
[   11.474793] nvethernet 6800000.ethernet eno1: renamed from eth0
[   11.542548] EXT4-fs (nvme0n1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[   11.599567] input: NVIDIA Jetson AGX Orin APE Headset Jack as /devices/platform/sound/sound/card1/input5
[   13.837897] audit: type=1400 audit(1755607899.074:6): avc:  denied  { mounton } for  pid=599 comm="(s-daemon)" path="/run/systemd/unit-root/proc/599/loginuid" dev="proc" ino=37169 scontext=system_u:system_r:kernel_t:s0 tcontext=system_u:system_r:kernel_t:s0 tclass=file permissive=1
[   13.940142] audit: type=1107 audit(1755607899.174:7): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:kernel_t:s0 msg='avc:  denied  { status } for auid=n/a uid=0 gid=0 path="/etc/init.d/kexec" cmdline="" scontext=system_u:system_r:kernel_t:s0 tcontext=system_u:object_r:unlabeled_t:s0 tclass=service permissive=1
                exe="/usr/lib/systemd/systemd" sauid=0 hostname=? addr=? terminal=?'
[   14.009420] nv_nvsciipc_init.sh[677]: found /dev/nvsciipc
[   14.018796] nvsciipc: set_db start
[   14.018822] nvsciipc: set_db done
[   14.059286] loop0: detected capacity change from 0 to 8
[   14.059478] SELinux: security_context_str_to_sid(system_u:object_r:snappy_snap_t:s0) failed for (dev ?, type ?) errno=-22
[   14.059725] SELinux: security_context_str_to_sid(system_u:object_r:snappy_snap_t:s0) failed for (dev loop0, type squashfs) errno=-22
[   14.065906] audit: type=1107 audit(1755607899.302:8): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:kernel_t:s0 msg='avc:  denied  { start } for auid=n/a uid=0 gid=0 path="/lib/systemd/system/user@.service" cmdline="/lib/systemd/systemd-logind" scontext=system_u:system_r:kernel_t:s0 tcontext=system_u:object_r:unlabeled_t:s0 tclass=service permissive=1
[   14.330425] nvgpu: 17000000.gpu                 tpc_pg_mask_store:1116 [INFO]  no value change, same mask already set
[   14.333849] pstore: Using crash dump compression: deflate
[   14.333950] printk: console [ramoops-1]: printing thread started
[   14.333973] printk: console [ramoops-1] enabled
[   14.333975] pstore: Registered ramoops as persistent store backend
[   14.333977] ramoops: using 0x200000@0x102cdf0000, ecc: 0
[   14.573152] nvgpu: 17000000.gpu                  gk20a_scale_init:541  [INFO]  enabled scaling for GPU
[   14.998680] irq: IRQ297: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[   14.999445] hwmon hwmon4: temp1_input not attached to any thermal zone
[   15.811951] zram: Added device: zram0
[   15.812293] zram: Added device: zram1
[   15.813152] zram: Added device: zram2
[   15.813961] zram: Added device: zram3
[   15.815972] zram: Added device: zram4
[   15.816179] zram: Added device: zram5
[   15.816982] zram: Added device: zram6
[   15.817369] zram: Added device: zram7
[   15.819972] zram: Added device: zram8
[   15.820572] zram: Added device: zram9
[   15.820847] zram: Added device: zram10
[   15.821058] zram: Added device: zram11
[   15.873162] Aquantia AQR113C 6800000.ethernet:00: No AQR phy_mode setting in DT
[   15.885939] zram0: detected capacity change from 0 to 5362416
[   15.968953] Adding 2681204k swap on /dev/zram0.  Priority:5 extents:1 across:2681204k SS
[   15.973747] zram1: detected capacity change from 0 to 5362416
[   15.983134] Adding 2681204k swap on /dev/zram1.  Priority:5 extents:1 across:2681204k SS
[   15.986842] zram2: detected capacity change from 0 to 5362416
[   15.994741] Adding 2681204k swap on /dev/zram2.  Priority:5 extents:1 across:2681204k SS
[   15.998359] zram3: detected capacity change from 0 to 5362416
[   16.005939] Adding 2681204k swap on /dev/zram3.  Priority:5 extents:1 across:2681204k SS
[   16.009457] zram4: detected capacity change from 0 to 5362416
[   16.016905] Adding 2681204k swap on /dev/zram4.  Priority:5 extents:1 across:2681204k SS
[   16.020712] zram5: detected capacity change from 0 to 5362416
[   16.028381] Adding 2681204k swap on /dev/zram5.  Priority:5 extents:1 across:2681204k SS
[   16.032065] zram6: detected capacity change from 0 to 5362416
[   16.040020] Adding 2681204k swap on /dev/zram6.  Priority:5 extents:1 across:2681204k SS
[   16.043757] zram7: detected capacity change from 0 to 5362416
[   16.051728] Adding 2681204k swap on /dev/zram7.  Priority:5 extents:1 across:2681204k SS
[   16.055271] zram8: detected capacity change from 0 to 5362416
[   16.063778] Adding 2681204k swap on /dev/zram8.  Priority:5 extents:1 across:2681204k SS
[   16.067500] zram9: detected capacity change from 0 to 5362416
[   16.075213] Adding 2681204k swap on /dev/zram9.  Priority:5 extents:1 across:2681204k SS
[   16.078662] zram10: detected capacity change from 0 to 5362416
[   16.086020] Adding 2681204k swap on /dev/zram10.  Priority:5 extents:1 across:2681204k SS
[   16.089628] zram11: detected capacity change from 0 to 5362416
[   16.098105] Adding 2681204k swap on /dev/zram11.  Priority:5 extents:1 across:2681204k SS
[   16.166059] audit: type=1400 audit(1755607901.402:9): avc:  denied  { execmem } for  pid=840 comm="java" scontext=system_u:system_r:kernel_t:s0 tcontext=system_u:system_r:kernel_t:s0 tclass=process permissive=1
[   16.219546] audit: type=1107 audit(1755607901.454:10): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:kernel_t:s0 msg='avc:  denied  { start } for auid=n/a uid=0 gid=0 path="/run/systemd/transient/session-c1.scope" cmdline="/lib/systemd/systemd-logind" scontext=system_u:system_r:kernel_t:s0 tcontext=system_u:object_r:systemd_unit_t:s0 tclass=service permissive=1
[   16.971519] audit: type=1107 audit(1755607902.206:11): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:kernel_t:s0 msg='avc:  denied  { status } for auid=n/a uid=0 gid=0 path="/run/systemd/transient/session-c1.scope" cmdline="/lib/systemd/systemd-logind" scontext=system_u:system_r:kernel_t:s0 tcontext=system_u:object_r:systemd_unit_t:s0 tclass=service permissive=1
[   17.386644] nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for aarch64  540.4.0  Release Build  (buildbrain@mobile-u64-6262-d8000)  Mon Jun 16 08:47:15 PDT 2025
[   17.393944] [drm] [nvidia-drm] [GPU ID 0x00020000] Loading driver
[   17.455544] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[   17.822254] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
[   18.083442] [drm] Initialized nvidia-drm 0.0.0 20160202 for 13800000.display on minor 1
[   18.220466] Console: switching to colour frame buffer device 240x67
[   18.220484] nv_platform 13800000.display: [drm] fb0: nvidia-drmdrmfb frame buffer device
[   18.353829] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   18.353840] Bluetooth: BNEP filters: protocol multicast
[   18.353851] Bluetooth: BNEP socket layer initialized
[   19.616639] docker0: port 1(veth44af49c) entered blocking state
[   19.616660] docker0: port 1(veth44af49c) entered disabled state
[   19.616831] device veth44af49c entered promiscuous mode
[   19.639607] eth0: renamed from vethfd8d329
[   19.686318] IPv6: ADDRCONF(NETDEV_CHANGE): veth44af49c: link becomes ready
[   19.686408] docker0: port 1(veth44af49c) entered blocking state
[   19.686414] docker0: port 1(veth44af49c) entered forwarding state
[   19.686499] IPv6: ADDRCONF(NETDEV_CHANGE): docker0: link becomes ready
[   20.706344] ACK 04 d4
[   20.712046] ACK 04 d4
[   20.728276] docker0: port 2(vethee798d3) entered blocking state
[   20.728298] docker0: port 2(vethee798d3) entered disabled state
[   20.728683] device vethee798d3 entered promiscuous mode
[   20.733365] docker0: port 2(vethee798d3) entered blocking state
[   20.733383] docker0: port 2(vethee798d3) entered forwarding state
[   20.740391] eth0: renamed from veth76e90a6
[   20.766310] IPv6: ADDRCONF(NETDEV_CHANGE): vethee798d3: link becomes ready
[   20.776268] IPv6: ADDRCONF(NETDEV_CHANGE): wlP1p1s0: link becomes ready
[   22.029973] rfkill: input handler disabled
[   34.636817] nvethernet 6800000.ethernet: [xpcs_lane_bring_up][477][type:0x4][loga-0x0] PCS block lock SUCCESS
[   34.636901] IPv6: ADDRCONF(NETDEV_CHANGE): eno1: link becomes ready
[   34.637282] nvethernet 6800000.ethernet eno1: Link is Up - 1Gbps/Full - flow control off
[   75.778068] audit: type=1107 audit(1755651907.785:12): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:kernel_t:s0 msg='avc:  denied  { stop } for auid=n/a uid=0 gid=0 path="/lib/systemd/system/serial-getty@.service" cmdline="" scontext=system_u:system_r:kernel_t:s0 tcontext=system_u:object_r:unlabeled_t:s0 tclass=service permissive=1
I’d be happy to help you troubleshoot the issue with your Jetson AGX Orin.
Initial Assessment
Based on your description, it seems that you’ve encountered a problem with USB device detection after powering your Jetson AGX Orin directly with a 3S Li battery without a voltage regulator. You’ve tried reflashing the device via SDK Manager, but the issue persists.
Possible Causes
  1. Voltage Regulator: As you’ve suspected, not using a voltage regulator might be the culprit. The Jetson AGX Orin requires a stable and regulated power supply to function correctly. Without a voltage regulator, the voltage from the battery might be fluctuating, causing instability in the system.
  2. Power Sequencing: The Jetson AGX Orin has a specific power sequencing requirement, which might not be met when powering it directly from a battery. This could lead to issues with the USB controllers or other peripherals.
  3. Voltage Levels: The 3S Li battery might not be providing the required voltage levels for the Jetson AGX Orin. The recommended input voltage for the Jetson AGX Orin is 12V, and the battery might not be able to provide a stable voltage within this range.
Comparison with Recommended Powering Method
The recommended powering method for the Jetson AGX Orin involves using a power adapter or a power supply that provides a stable and regulated 12V output. This ensures that the system receives a consistent power supply, which is essential for proper functioning.
Troubleshooting Steps
  1. Use a Voltage Regulator: Try using a voltage regulator to stabilize the power supply from the battery. This will help ensure that the Jetson AGX Orin receives a consistent and regulated power supply.
  2. Check Power Sequencing: Verify that the power sequencing requirements for the Jetson AGX Orin are met. You can refer to the Jetson AGX Orin documentation for more information on power sequencing.
  3. Monitor Voltage Levels: Use a multimeter to monitor the voltage levels from the battery and ensure that they are within the recommended range for the Jetson AGX Orin.
  4. Reflash the Device: If you haven’t already, try reflashing the device again using the SDK Manager. This will ensure that the system is running with the latest software and firmware.
Kernel Log Analysis
The kernel log you provided might contain clues about the issue. Look for any error messages or warnings related to USB device detection or power management. You can also try searching for specific keywords like “USB” or “power” to see if there are any relevant messages.
Conclusion
In conclusion, the issue you’re experiencing with USB device detection on your Jetson AGX Orin is likely related to the powering method you’re using. By using a voltage regulator, checking power sequencing, and monitoring voltage levels, you should be able to resolve the issue. If the problem persists, you can try reflashing the device and analyzing the kernel log for more clues.
Were this device able to detect USB before you tried that battery?
Before using the battery, everything worked fine. I even successfully tested it multiple times with the battery before the USB detection failure occurred.​​
I tried re-flashing it to JetPack 5 (Ubuntu 20.04) via SDK Manager using the Type-C port. After this, ​​Type-A ports recovered​​ and could detect USB hubs, but ​​Type-C remained non-functional​​. However, after flashing back to JetPack 6, ​​all USB ports stopped being detected again​​.
Could you flash Jetpack5 again and share me the dmesg?
Here is Jetpack5’s dmesg log. Type-c still wrong.
dmesg.txt (135.3 KB)
Sorry, this it totally not a log from Jetson. This is your host PC’s log… I don’t know why are you sharing this.
Sorry, my mistake. I think I’ve already SSH into the Jetson. Here is true log.
dmesg_1.txt (74.3 KB)
[   12.087458] ucsi_ccg 1-0008: i2c_transfer failed -5
[   12.092490] ucsi_ccg 1-0008: ucsi_ccg_init failed - -5
[   12.092847] tegra-asoc: sound: Adding to iommu group 58
Looks like a hardware problem happened.
Consider do the RMA.
Oh… Thanks for your help. Maybe I should add a voltage regulator between the Jetson and the battery?
Could you explain original power wasn’t enough? Assuming you are using our AGX Orin DevKit, please retry with the original power supply included with the AGX Orin DevKit and reflash, if necessary.
Sorry, I didn’t explain it clearly. The ‘original power’ refers to the power supply interface on my robotdog’s back—it only provides 36W output, so I need another power . Now I couldn’t use the AGX Orin DevKit’s power supply because the type-c port is broken.
There are two USBC ports, please try the other one to power the AGX Orin DevKit or the DC Power Jack
Thanks, but the other type-c port is dead too. Now I can only boot the Jetson via the dcin port.​​
Here’s what I think happened:
I directly hooked up a ​​3S lithium battery to the dcin port​​ (I know its a dumb idea—I just didn’t realize howdumb). The ​​electrical noise​​ (like voltage surges) from the battery messed with the circuitry. The main board and dc port have decent isolation, so most components survived. But ​​type-c ports can also act as power inputs​​, so their isolation from dcin isn’t as robust. That’s probably why they fried (maybe other components too). In ​​Jetppack 6​​, the ​​device tree​​ seems to tie the whole usb hub to the type-c ports. So if type-c is dead, the entire usb hub fails to mount. With ​​Jetpack 5​​, at least the ​​type-a ports still work​​.
I think i need RMA and add proper ​​isolation between the battery and Jetson to avoid this.
Not sure if RMA would be supported in this case, as damage due to use case factors which are beyond our recommendations and outside our control.
I get it, but I still wanna try to fix it. Most of its functions are still working fine anyway. All that stuff I said earlier was just guessing — I still don’t get why I can reflash it via type-c but can’t power it or connect devices through it. Maybe my guess was totally off?
Anyway, thanks for your help. Have a good one.
Flashing is in recovery mode and kind of device mode only and does not need VBUS. Connecting USB devices will be Host mode and does need VBUS to be available. Most likely the Power Delivery (PD) path components are damaged. You can debug and probably fix it using the carrier board design files available in the Jetson Download Center.
