Dear:
dmesg log
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 5.10.65-tegra-tegra (ubuntu@cztek-ubuntu) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #12 SMP PREEMPT Sun Apr 24 11:20:03 CST 2022
[ 0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,
[ 0.000000] OF: fdt: - 80000000 , c0000000
[ 0.000000] Machine model: NVIDIA Orin Jetson-Small Developer Kit
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x8548b1118 SMBIOS=0xbabc0000 SMBIOS 3.0=0x853310000 MEMATTR=0x852f4a018 ESRT=0x853268f18 RNG=0x85435ff18 MEMRESERVE=0x852f4bf18
[ 0.000000] efi: seeding entropy pool
[ 0.000000] esrt: Reserving ESRT space from 0x0000000853268f18 to 0x0000000853268f50.
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000086b800000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] OF: reserved mem: initialized node fsi-carveout, compatible id nvidia,fsi-carveout
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x000000087fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x0000000087ffffff]
[ 0.000000] node 0: [mem 0x0000000088000000-0x00000000b9ccffff]
[ 0.000000] node 0: [mem 0x00000000ba800000-0x00000000ba9affff]
[ 0.000000] node 0: [mem 0x00000000babb0000-0x00000000babcffff]
[ 0.000000] node 0: [mem 0x00000000babd0000-0x00000000babfffff]
[ 0.000000] node 0: [mem 0x00000000c2000000-0x00000000c3ffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x000000084fffffff]
[ 0.000000] node 0: [mem 0x0000000850000000-0x0000000851faffff]
[ 0.000000] node 0: [mem 0x0000000851fb0000-0x0000000852d00fff]
[ 0.000000] node 0: [mem 0x0000000852d01000-0x0000000852e62fff]
[ 0.000000] node 0: [mem 0x0000000852e63000-0x0000000852f1ffff]
[ 0.000000] node 0: [mem 0x0000000852f20000-0x0000000852f3ffff]
[ 0.000000] node 0: [mem 0x0000000852f40000-0x000000085317ffff]
[ 0.000000] node 0: [mem 0x0000000853180000-0x000000085319ffff]
[ 0.000000] node 0: [mem 0x00000008531a0000-0x000000085326ffff]
[ 0.000000] node 0: [mem 0x0000000853270000-0x000000085327ffff]
[ 0.000000] node 0: [mem 0x0000000853280000-0x000000085330ffff]
[ 0.000000] node 0: [mem 0x0000000853310000-0x000000085331ffff]
[ 0.000000] node 0: [mem 0x0000000853320000-0x0000000853cfffff]
[ 0.000000] node 0: [mem 0x0000000853d00000-0x0000000853f2ffff]
[ 0.000000] node 0: [mem 0x0000000853f30000-0x0000000853feffff]
[ 0.000000] node 0: [mem 0x0000000853ff0000-0x000000085412ffff]
[ 0.000000] node 0: [mem 0x0000000854130000-0x000000085418ffff]
[ 0.000000] node 0: [mem 0x0000000854190000-0x000000085424ffff]
[ 0.000000] node 0: [mem 0x0000000854250000-0x000000085425ffff]
[ 0.000000] node 0: [mem 0x0000000854260000-0x00000008542fffff]
[ 0.000000] node 0: [mem 0x0000000854300000-0x000000085434ffff]
[ 0.000000] node 0: [mem 0x0000000854350000-0x000000085435ffff]
[ 0.000000] node 0: [mem 0x0000000854360000-0x00000008543affff]
[ 0.000000] node 0: [mem 0x00000008543b0000-0x000000085464ffff]
[ 0.000000] node 0: [mem 0x0000000854650000-0x000000085469ffff]
[ 0.000000] node 0: [mem 0x00000008546a0000-0x000000085473ffff]
[ 0.000000] node 0: [mem 0x0000000854740000-0x000000085485ffff]
[ 0.000000] node 0: [mem 0x0000000854860000-0x00000008548affff]
[ 0.000000] node 0: [mem 0x00000008548b0000-0x000000085493ffff]
[ 0.000000] node 0: [mem 0x0000000854940000-0x000000085498ffff]
[ 0.000000] node 0: [mem 0x0000000854990000-0x00000008549affff]
[ 0.000000] node 0: [mem 0x00000008549b0000-0x0000000854a4ffff]
[ 0.000000] node 0: [mem 0x0000000854a50000-0x0000000854aaffff]
[ 0.000000] node 0: [mem 0x0000000854ab0000-0x0000000854b9ffff]
[ 0.000000] node 0: [mem 0x0000000854ba0000-0x000000085537ffff]
[ 0.000000] node 0: [mem 0x0000000855380000-0x000000085555ffff]
[ 0.000000] node 0: [mem 0x0000000855560000-0x000000087b8bffff]
[ 0.000000] node 0: [mem 0x000000087b8c0000-0x000000087b90ffff]
[ 0.000000] node 0: [mem 0x000000087b910000-0x000000087fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000087fffffff]
[ 0.000000] On node 0 totalpages: 8109776
[ 0.000000] DMA zone: 3836 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 245456 pages, LIFO batch:63
[ 0.000000] Normal zone: 122880 pages used for memmap
[ 0.000000] Normal zone: 7864320 pages, LIFO batch:63
[ 0.000000] On node 0, zone DMA: 304 pages in unavailable ranges
[ 0.000000] On node 0, zone DMA: 80 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 31 pages/cpu s90008 r8192 d28776 u126976
[ 0.000000] pcpu-alloc: s90008 r8192 d28776 u126976 alloc=31*4096
[ 0.000000] pcpu-alloc: [0] 00 [0] 01 [0] 02 [0] 03 [0] 04 [0] 05 [0] 06 [0] 07
[ 0.000000] pcpu-alloc: [0] 08 [0] 09 [0] 10 [0] 11
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: kernel page table isolation disabled by kernel configuration
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 7983060
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=tty0 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nv-auto-config
[ 0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000a9cd0000-0x00000000b9cd0000] (256MB)
[ 0.000000] Memory: 31083432K/32439104K available (18432K kernel code, 3212K rwdata, 7072K rodata, 3968K init, 1072K bss, 1093528K reserved, 262144K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=12, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=12.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=12
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[ 0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)
[ 0.000000] GICv2m: range[mem 0x0f410000-0x0f41ffff], SPI[608:677]
[ 0.000000] random: get_random_bytes called from start_kernel+0x378/0x4f4 with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000600] Console: colour dummy device 80x25
[ 0.000805] printk: console [tty0] enabled
[ 0.000846] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.000856] pid_max: default: 32768 minimum: 301
[ 0.000903] LSM: Security Framework initializing
[ 0.000970] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.001015] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.002759] rcu: Hierarchical SRCU implementation.
[ 0.002850] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.003222] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-5.10/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t23x/concord/kernel-dts/tegra234-p3701-0000-p3737-0000.dts
[ 0.003231] DTB Build time: Apr 6 2022 11:59:11
[ 0.004288] Tegra Revision: A01 SKU: 0xd0 CPU Process: 0 SoC Process: 0
[ 0.004399] Remapping and enabling EFI services.
[ 0.005567] smp: Bringing up secondary CPUs …
[ 0.005965] Detected PIPT I-cache on CPU1
[ 0.005995] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[ 0.006028] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[ 0.006380] Detected PIPT I-cache on CPU2
[ 0.006389] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[ 0.006403] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[ 0.006717] Detected PIPT I-cache on CPU3
[ 0.006726] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[ 0.006740] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[ 0.009066] Detected PIPT I-cache on CPU4
[ 0.009087] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c0000
[ 0.009114] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[ 0.009481] Detected PIPT I-cache on CPU5
[ 0.009490] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e0000
[ 0.009504] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[ 0.009835] Detected PIPT I-cache on CPU6
[ 0.009845] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f500000
[ 0.009861] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[ 0.010204] Detected PIPT I-cache on CPU7
[ 0.010214] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f520000
[ 0.010226] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
[ 0.012560] Detected PIPT I-cache on CPU8
[ 0.012583] GICv3: CPU8: found redistributor 20000 region 0:0x000000000f540000
[ 0.012612] CPU8: Booted secondary processor 0x0000020000 [0x410fd421]
[ 0.012979] Detected PIPT I-cache on CPU9
[ 0.012990] GICv3: CPU9: found redistributor 20100 region 0:0x000000000f560000
[ 0.013005] CPU9: Booted secondary processor 0x0000020100 [0x410fd421]
[ 0.013345] Detected PIPT I-cache on CPU10
[ 0.013356] GICv3: CPU10: found redistributor 20200 region 0:0x000000000f580000
[ 0.013369] CPU10: Booted secondary processor 0x0000020200 [0x410fd421]
[ 0.013705] Detected PIPT I-cache on CPU11
[ 0.013715] GICv3: CPU11: found redistributor 20300 region 0:0x000000000f5a0000
[ 0.013729] CPU11: Booted secondary processor 0x0000020300 [0x410fd421]
[ 0.013782] smp: Brought up 1 node, 12 CPUs
[ 0.013847] SMP: Total of 12 processors activated.
[ 0.013852] CPU features: detected: Privileged Access Never
[ 0.013854] CPU features: detected: LSE atomic instructions
[ 0.013857] CPU features: detected: User Access Override
[ 0.013860] CPU features: detected: 32-bit EL0 Support
[ 0.013863] CPU features: detected: Common not Private translations
[ 0.013866] CPU features: detected: RAS Extension Support
[ 0.013868] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.013872] CPU features: detected: CRC32 instructions
[ 0.013874] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.047591] CPU: All CPU(s) started at EL2
[ 0.049795] devtmpfs: initialized
[ 0.059054] Registered cp15_barrier emulation handler
[ 0.059070] Registered setend emulation handler
[ 0.059076] KASLR enabled
[ 0.059210] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.059224] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[ 0.060768] pinctrl core: initialized pinctrl subsystem
[ 0.061228] SMBIOS 3.0.0 present.
[ 0.061235] DMI: /, BIOS r34.1-975eef6 04/06/2022
[ 0.061475] NET: Registered protocol family 16
[ 0.062358] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.062567] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.062761] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.062816] audit: initializing netlink subsys (disabled)
[ 0.062918] audit: type=2000 audit(0.060:1): state=initialized audit_enabled=0 res=1
[ 0.063581] printk: console [ramoops-1] enabled
[ 0.063588] pstore: Registered ramoops as persistent store backend
[ 0.063595] ramoops: using 0x200000@0xba9b0000, ecc: 0
[ 0.063772] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.063774] thermal_sys: Registered thermal governor ‘power_allocator’
[ 0.063780] thermal_sys: Registered thermal governor ‘pid_thermal_gov’
[ 0.065150] cpuidle: using governor menu
[ 0.065281] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.065398] ASID allocator initialised with 65536 entries
[ 0.065539] Serial: AMBA PL011 UART driver
[ 0.066891] tegra234_mc_sid_probe(): tegra234 mc-sid probe successful
[ 0.066917] Tegra reboot handler registered.
[ 0.066993] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-5.10/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t23x/concord/kernel-dts/tegra234-p3701-0000-p3737-0000.dts
[ 0.067002] DTB Build time: Apr 6 2022 11:59:11
[ 0.080963] mc: mapped MMIO address: 0x(ptrval) → 0x2c10000
[ 0.080985] mc: mapped MMIO address: 0x(ptrval) → 0x2c20000
[ 0.080995] mc: mapped MMIO address: 0x(ptrval) → 0x2c30000
[ 0.081006] mc: mapped MMIO address: 0x(ptrval) → 0x2c40000
[ 0.081015] mc: mapped MMIO address: 0x(ptrval) → 0x2c50000
[ 0.081023] mc: mapped MMIO address: 0x(ptrval) → 0x2b80000
[ 0.081032] mc: mapped MMIO address: 0x(ptrval) → 0x2b90000
[ 0.081040] mc: mapped MMIO address: 0x(ptrval) → 0x2ba0000
[ 0.081049] mc: mapped MMIO address: 0x(ptrval) → 0x2bb0000
[ 0.081057] mc: mapped MMIO address: 0x(ptrval) → 0x1700000
[ 0.081065] mc: mapped MMIO address: 0x(ptrval) → 0x1710000
[ 0.081073] mc: mapped MMIO address: 0x(ptrval) → 0x1720000
[ 0.081081] mc: mapped MMIO address: 0x(ptrval) → 0x1730000
[ 0.081089] mc: mapped MMIO address: 0x(ptrval) → 0x1740000
[ 0.081097] mc: mapped MMIO address: 0x(ptrval) → 0x1750000
[ 0.081105] mc: mapped MMIO address: 0x(ptrval) → 0x1760000
[ 0.081113] mc: mapped MMIO address: 0x(ptrval) → 0x1770000
[ 0.081123] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.081142] mc-err: mcerr ops are set to t23x
[ 0.081422] tegra23x-cbb 13a00000.cbb-en: secure_irq = 21
[ 0.081474] tegra23x-cbb c600000.aon-en: secure_irq = 22
[ 0.081511] tegra23x-cbb de00000.dce-en: secure_irq = 23
[ 0.081545] tegra23x-cbb be00000.rce-en: secure_irq = 24
[ 0.081580] tegra23x-cbb b600000.sce-en: secure_irq = 25
[ 0.085199] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.085210] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.085215] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.085220] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.086554] ACPI: Interpreter disabled.
[ 0.087604] vdd-av1v1-hub: supplied by vdd-5v-sys
[ 0.087743] vbusA-cvb: supplied by vdd-5v-sys
[ 0.087839] vbusB-cvb: supplied by vdd-5v-sys
[ 0.087940] vdd-usbc1-vbus: supplied by vdd-5v-sys
[ 0.088030] vdd-usbc2-vbus: supplied by vdd-5v-sys
[ 0.088321] iommu: Default domain type: Translated
[ 0.088357] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.088515] SCSI subsystem initialized
[ 0.088574] usbcore: registered new interface driver usbfs
[ 0.088592] usbcore: registered new interface driver hub
[ 0.088608] usbcore: registered new device driver usb
[ 0.088767] mc: Linux media interface: v0.10
[ 0.088778] videodev: Linux video capture interface: v2.00
[ 0.088910] pps_core: LinuxPPS API ver. 1 registered
[ 0.088917] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.088925] PTP clock support registered
[ 0.089115] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.089136] tegra_wdt_t18x 2190000.watchdog: Registered successfully
[ 0.090396] Registered efivars operations
[ 0.090785] FPGA manager framework
[ 0.090876] Advanced Linux Sound Architecture Driver Initialized.
[ 0.091122] Bluetooth: Core ver 2.22
[ 0.091139] NET: Registered protocol family 31
[ 0.091145] Bluetooth: HCI device and connection manager initialized
[ 0.091154] Bluetooth: HCI socket layer initialized
[ 0.091160] Bluetooth: L2CAP socket layer initialized
[ 0.091169] Bluetooth: SCO socket layer initialized
[ 0.091791] camchar: rtcpu character device driver loaded
[ 0.092040] clocksource: Switched to clocksource arch_sys_counter
[ 0.249107] VFS: Disk quotas dquot_6.6.0
[ 0.249154] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.249276] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.249579] tegra-carveouts tegra-carveouts: fsi :dma coherent mem declare 0x00000000bf000000,16777216
[ 0.249590] tegra-carveouts tegra-carveouts: assigned reserved memory node fsi-carveout
[ 0.249603] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x00000000d6000000,704643072
[ 0.249605] pnp: PnP ACPI: disabled
[ 0.249611] nvmap_page_pool_init: Total RAM pages: 7836394
[ 0.249619] nvmap_page_pool_init: nvmap page pool size: 979549 pages (3826 MB)
[ 0.249667] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.249750] misc nvmap: created heap vpr base 0x00000000d6000000 size (688128KiB)
[ 0.251234] la/ptsa driver initialized.
[ 0.251284] NET: Registered protocol family 2
[ 0.251517] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.253354] misc nvmap: created heap fsi base 0x00000000bf000000 size (16384KiB)
[ 0.253669] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[ 0.253711] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.253932] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.254403] TCP: Hash tables configured (established 262144 bind 65536)
[ 0.254476] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.254534] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.254669] NET: Registered protocol family 1
[ 0.254942] RPC: Registered named UNIX socket transport module.
[ 0.254955] RPC: Registered udp transport module.
[ 0.254960] RPC: Registered tcp transport module.
[ 0.254964] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.254977] PCI: CLS 0 bytes, default 64
[ 0.255082] Trying to unpack rootfs image as initramfs…
[ 0.364260] Freeing initrd memory: 8196K
[ 0.365883] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.366033] kvm [1]: IPA Size Limit: 48 bits
[ 0.366198] kvm [1]: VHE mode initialized successfully
[ 0.366796] workingset: timestamp_bits=46 max_order=23 bucket_order=0
[ 0.368191] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.368389] NFS: Registering the id_resolver key type
[ 0.368410] Key type id_resolver registered
[ 0.368416] Key type id_legacy registered
[ 0.368442] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 0.368454] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 0.368468] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.379794] NET: Registered protocol family 38
[ 0.379816] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 239)
[ 0.379873] io scheduler mq-deadline registered
[ 0.379880] io scheduler kyber registered
[ 0.383179] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.383208] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.383225] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 0.383243] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 0.385285] tegra_dc_assign_hw_data: no matching compatible node
[ 0.385293] tegradccommon module_init failed
[ 0.385299] tegradc module_init failed
[ 0.385510] EINJ: ACPI disabled.
[ 0.386647] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.386657] tegra-pmc: ### PMC reset source: MAINSWRST
[ 0.386664] tegra-pmc: ### PMC reset level: L1
[ 0.386669] tegra-pmc: ### PMC reset status reg: 0x2d
[ 0.387682] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.392191] random: fast init done
[ 0.392712] printk: console [ttyTCU0] enabled
[ 2.207317] arm-smmu 12000000.iommu: probing hardware configuration…
[ 2.213239] arm-smmu 12000000.iommu: SMMUv2 with:
[ 2.217798] arm-smmu 12000000.iommu: stage 1 translation
[ 2.223112] arm-smmu 12000000.iommu: stage 2 translation
[ 2.228622] arm-smmu 12000000.iommu: nested translation
[ 2.233787] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 2.240960] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
[ 2.249200] arm-smmu 12000000.iommu: Supported page sizes: 0x00001000
[ 2.254083] arm-smmu 12000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 2.260471] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 2.267595] arm-smmu 10000000.iommu: probing hardware configuration…
[ 2.273510] arm-smmu 10000000.iommu: SMMUv2 with:
[ 2.278234] arm-smmu 10000000.iommu: stage 1 translation
[ 2.283746] arm-smmu 10000000.iommu: stage 2 translation
[ 2.289170] arm-smmu 10000000.iommu: nested translation
[ 2.294597] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 2.301772] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 only)
[ 2.310079] arm-smmu 10000000.iommu: Supported page sizes: 0x00001000
[ 2.314985] arm-smmu 10000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 2.321546] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 2.328474] arm-smmu 8000000.iommu: probing hardware configuration…
[ 2.334673] arm-smmu 8000000.iommu: SMMUv2 with:
[ 2.339396] arm-smmu 8000000.iommu: stage 1 translation
[ 2.344907] arm-smmu 8000000.iommu: stage 2 translation
[ 2.350334] arm-smmu 8000000.iommu: nested translation
[ 2.355499] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 2.362670] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 2.370969] arm-smmu 8000000.iommu: Supported page sizes: 0x00001000
[ 2.375887] arm-smmu 8000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 2.382445] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 2.389515] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[ 2.398369] tegra_profiler: version: 1.146, samples/io: 49/28
[ 2.402646] tegra_profiler: auth: init
[ 2.407379] tegra23x-qspi 3270000.spi: Adding to iommu group 0
[ 2.412988] libphy: Fixed MDIO Bus: probed
[ 2.416400] tun: Universal TUN/TAP device driver, 1.6
[ 2.421952] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 2.428738] hns3: Copyright (c) 2017 Huawei Corporation.
[ 2.434265] e1000e: Intel(R) PRO/1000 Network Driver
[ 2.439059] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.445021] igb: Intel(R) Gigabit Ethernet Network Driver
[ 2.450436] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.456266] PPP generic driver version 2.4.2
[ 2.460634] PPP BSD Compression module registered
[ 2.465312] PPP Deflate Compression module registered
[ 2.470570] PPP MPPE Compression module registered
[ 2.475388] usbcore: registered new interface driver r8152
[ 2.480716] usbcore: registered new interface driver asix
[ 2.486141] usbcore: registered new interface driver ax88179_178a
[ 2.492268] usbcore: registered new interface driver cdc_ether
[ 2.498218] usbcore: registered new interface driver net1080
[ 2.503815] usbcore: registered new interface driver cdc_subset
[ 2.509852] usbcore: registered new interface driver zaurus
[ 2.515542] usbcore: registered new interface driver cdc_ncm
[ 2.521228] usbcore: registered new interface driver aqc111
[ 2.526739] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 2.532953] ohci-pci: OHCI PCI platform driver
[ 2.537248] ohci-platform: OHCI generic platform driver
[ 2.542556] tegra-xusb 3610000.xhci: Adding to iommu group 1
[ 2.548430] usbcore: registered new interface driver uas
[ 2.553527] usbcore: registered new interface driver usb-storage
[ 2.559484] tegra-xudc 3550000.xudc: Adding to iommu group 2
[ 2.565340] mousedev: PS/2 mouse device common for all mice
[ 2.570675] usbcore: registered new interface driver xpad
[ 2.577912] tegra_rtc c2a0000.rtc: registered as rtc1
[ 2.581439] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:18 UTC (18)
[ 2.589221] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.595423] i2c /dev entries driver
[ 2.599011] tegra-i2c 3160000.i2c: Adding to iommu group 3
[ 2.604593] tegra-i2c c240000.i2c: Adding to iommu group 3
[ 2.609991] tegra-i2c 3180000.i2c: Adding to iommu group 3
[ 2.615409] tegra-i2c 3190000.i2c: Adding to iommu group 3
[ 2.620746] tegra-i2c 31b0000.i2c: Adding to iommu group 3
[ 2.626254] tegra-i2c 31c0000.i2c: Adding to iommu group 3
[ 2.631681] tegra-i2c c250000.i2c: Adding to iommu group 3
[ 2.637032] tegra-i2c 31e0000.i2c: Adding to iommu group 3
[ 2.644131] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[ 2.650639] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[ 2.659665] device-mapper: uevent: version 1.0.3
[ 2.663569] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[ 2.672806] sdhci: Secure Digital Host Controller Interface driver
[ 2.678286] sdhci: Copyright(c) Pierre Ossman
[ 2.682748] Synopsys Designware Multimedia Card Interface Driver
[ 2.688850] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.694721] sdhci-tegra 3460000.sdhci: Adding to iommu group 4
[ 2.694837] sdhci-tegra 3400000.sdhci: Adding to iommu group 5
[ 2.695527] pstore: ignoring unexpected backend ‘efi’
[ 2.695593] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401
[ 2.696958] tegra-bpmp bpmp: firmware: 43f75b5aad2b8e1992e4-f0425a554b3
[ 4.484752] hid: raw HID events driver (C) Jiri Kosina
[ 4.485327] usbcore: registered new interface driver usbhid
[ 4.485497] usbhid: USB HID core driver
[ 4.485803] tegra-dce d800000.dce: Adding to iommu group 6
[ 4.487130] dce: dce_ipc_channel_init:314 Invalid Channel State [0x0] for ch_type [2]
[ 4.488583] dce: dce_wait_boot_complete:100 dce is ready to receive bootstrap commands
[ 4.488701] tegra234-aon c000000.aon: Adding to iommu group 7
[ 4.489198] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x5]
[ 4.489548] dce: dce_admin_send_cmd_ver:424 version : [0x2] err : [0x0]
[ 4.489824] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x1]
[ 4.489886] c000000.aon:hsp: probed
[ 4.490089] dce: dce_admin_setup_clients_ipc:480 Channel Reset Complete for Type [1] …
[ 4.490402] tegra234-aon c000000.aon: init done
[ 4.490525] dce: dce_admin_setup_clients_ipc:456 Get queue info failed for [2]
[ 4.490639] tegra23x-psc e860000.psc: Adding to iommu group 8
[ 4.490819] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x2]
[ 4.491155] tegra23x-psc e860000.psc: ext_cfg base:(ptrval)
[ 4.498098] dce: dce_admin_setup_clients_ipc:480 Channel Reset Complete for Type [3] …
[ 4.504384] tegra23x-psc e860000.psc: init done
[ 4.512772] dce: dce_worker:209 DCE_BOOT_DONE
[ 4.517356] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 9
[ 4.529149] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 4.540764] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[ 4.545272] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 4.556583] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[ 4.567383] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[ 4.578423] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[ 4.590065] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[ 4.602580] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[ 4.614562] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (115)
[ 4.620663] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 4.628920] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=e4da4cf5a29dccddc6d8f65bbd5202381ca3db13
[ 4.641496] t19x_cache tegra-cache: probed
[ 4.644016] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[ 4.665260] nvpmodel: initialized successfully
[ 4.665629] tegra_hv: get_hvd: not initialized yet
[ 4.665774] user_ivc_mempool: hypervisor not present
[ 4.666439] usbcore: registered new interface driver snd-usb-audio
[ 4.671031] u32 classifier
[ 4.673338] input device check on
[ 4.677010] Actions configured
[ 4.680460] Initializing XFRM netlink socket
[ 4.685081] NET: Registered protocol family 10
[ 4.690335] Segment Routing with IPv6
[ 4.692804] NET: Registered protocol family 17
[ 4.697063] NET: Registered protocol family 15
[ 4.701554] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 4.714916] Bluetooth: RFCOMM socket layer initialized
[ 4.719562] Bluetooth: RFCOMM ver 1.11
[ 4.723486] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.728069] random: crng init done
[ 4.729341] Bluetooth: HIDP socket layer initialized
[ 4.738361] 9pnet: Installing 9P2000 support
[ 4.741984] Key type dns_resolver registered
[ 4.747300] registered taskstats version 1
[ 4.750784] pstore: Using crash dump compression: deflate
[ 4.756204] tegra194-pcie 14100000.pcie: Adding to iommu group 10
[ 4.767344] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 4.769019] tegra194-pcie 14160000.pcie: Adding to iommu group 11
[ 4.779682] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 4.781355] tegra194-pcie 141a0000.pcie: Adding to iommu group 12
[ 4.791773] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 4.793632] tegra194-pcie 141a0000.pcie: Failed to get slot regulators: -517
[ 4.813633] tegra-gpcdma 2600000.gpcdma: Adding to iommu group 3
[ 4.814842] tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels
[ 4.815188] host1x 13e40000.host1x: Adding to iommu group 13
[ 4.823175] t23x_init_gating_regs: *** 20220419 ***
[ 5.823173] t23x_init_gating_regs: Timed out waiting for syncpt ram init!
[ 5.832375] host1x 13e40000.host1x: initialized
[ 5.832801] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu group 14
[ 5.833321] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (streamid=53, iommu=smmu.0x0000000012000000)
[ 5.834907] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu group 15
[ 5.835324] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (streamid=54, iommu=smmu.0x0000000012000000)
[ 5.836879] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu group 16
[ 5.837287] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (streamid=55, iommu=smmu.0x0000000012000000)
[ 5.838833] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu group 17
[ 5.839284] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[ 5.840832] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu group 18
[ 5.841233] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[ 5.842753] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu group 19
[ 5.843144] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[ 5.854439] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu group 20
[ 5.860997] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[ 5.872465] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu group 21
[ 5.879018] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[ 5.890541] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu group 22
[ 5.897063] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (streamid=53, iommu=smmu.0x0000000008000000)
[ 5.908509] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu group 23
[ 5.915082] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (streamid=54, iommu=smmu.0x0000000008000000)
[ 5.926528] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu group 24
[ 5.933122] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (streamid=55, iommu=smmu.0x0000000008000000)
[ 5.944570] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu group 25
[ 5.951113] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (streamid=56, iommu=smmu.0x0000000008000000)
[ 5.962582] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu group 26
[ 5.969139] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (streamid=57, iommu=smmu.0x0000000008000000)
[ 5.980616] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu group 27
[ 5.987163] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (streamid=58, iommu=smmu.0x0000000008000000)
[ 5.998633] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu group 28
[ 6.005210] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (streamid=59, iommu=smmu.0x0000000008000000)
[ 6.016675] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu group 29
[ 6.023218] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (streamid=60, iommu=smmu.0x0000000008000000)
[ 6.034698] falcon 15340000.vic: Adding to iommu group 30
[ 6.043359] falcon 15340000.vic: initialized
[ 6.043697] falcon 15380000.nvjpg: Adding to iommu group 31
[ 6.052263] falcon 15380000.nvjpg: initialized
[ 6.053644] falcon 15540000.nvjpg1: Adding to iommu group 32
[ 6.062509] falcon 15540000.nvjpg1: initialized
[ 6.064062] falcon 154c0000.nvenc: Adding to iommu group 33
[ 6.073975] falcon 154c0000.nvenc: initialized
[ 6.074209] falcon 15a50000.ofa: Adding to iommu group 34
[ 6.082201] falcon 15a50000.ofa: initialized
[ 6.084198] nvdec 15480000.nvdec: Adding to iommu group 35
[ 6.095830] nvdec 15480000.nvdec: initialized
[ 6.096069] tsec 15500000.tsec: Adding to iommu group 36
[ 6.104142] tsec 15500000.tsec: initialized
[ 6.106301] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 6.115888] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 6.123804] gpio-394 (camera-control-output-low): hogged as output/low
[ 6.123994] gpio-397 (camera-control-output-low): hogged as output/low
[ 6.129936] gpio-487 (camera-control-output-low): hogged as output/low
[ 6.136148] gpio-486 (camera-control-output-low): hogged as output/low
[ 6.143565] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio
[ 6.149610] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon
[ 6.155699] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 6.161788] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 6.167432] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 6.173038] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 6.180365] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 6.186727] tegra194-isp5 14800000.isp: Adding to iommu group 37
[ 6.195160] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[ 6.202040] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized
[ 6.208062] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group 38
[ 6.215732] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group 39
[ 6.222815] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: context isolation disabled due to no IOMMU
[ 6.232116] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized
[ 6.238086] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: grid-of-semaphores not supported
[ 6.246186] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: context isolation disabled due to no IOMMU
[ 6.255804] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized
[ 6.261966] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: grid-of-semaphores not supported
[ 6.270429] scare-pigeon 13e40000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[ 6.280129] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized
[ 6.286290] scare-pigeon 13e40000.host1x:isp-thi@14b00000: grid-of-semaphores not supported
[ 6.294789] pva 16000000.pva0: Adding to iommu group 40
[ 6.318867] pva 16000000.pva0: initialized
[ 6.326522] nvdla 15880000.nvdla0: Adding to iommu group 41
[ 6.335245] nvdla 15880000.nvdla0: initialized
[ 6.336968] nvdla 158c0000.nvdla1: Adding to iommu group 42
[ 6.345658] nvdla 158c0000.nvdla1: initialized
[ 6.347335] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[ 6.347513] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[ 6.347848] serial-tegra 3100000.serial: Adding to iommu group 3
[ 6.348313] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 13, base_baud = 0) is a TEGRA_UART
[ 6.352820] serial-tegra 3130000.serial: Adding to iommu group 3
[ 6.358717] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 6.390066] tegra-xusb 3610000.xhci: Firmware timestamp: 2021-12-01 05:27:10 UTC, Version: 80.03 release
[ 6.390330] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 6.390498] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 6.391494] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000050810
[ 6.398921] tegra-xusb 3610000.xhci: irq 232, io mem 0x03610000
[ 6.405042] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 6.413165] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.420334] usb usb1: Product: xHCI Host Controller
[ 6.425321] usb usb1: Manufacturer: Linux 5.10.65-tegra-tegra xhci-hcd
[ 6.431883] usb usb1: SerialNumber: 3610000.xhci
[ 6.437029] hub 1-0:1.0: USB hub found
[ 6.440401] hub 1-0:1.0: 4 ports detected
[ 6.444575] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 6.449830] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 6.457448] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 6.464872] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 6.473014] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.480271] usb usb2: Product: xHCI Host Controller
[ 6.485259] usb usb2: Manufacturer: Linux 5.10.65-tegra-tegra xhci-hcd
[ 6.491645] usb usb2: SerialNumber: 3610000.xhci
[ 6.496820] hub 2-0:1.0: USB hub found
[ 6.500326] hub 2-0:1.0: 4 ports detected
[ 6.505584] bwmgr API not supported
[ 6.505588] tegra-xusb 3610000.xhci: can’t register EMC bwmgr (-22)
[ 6.538979] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 2059000 KHz, changing to: 2112000 KHz
[ 6.541886] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 2007000 KHz, changing to: 2035200 KHz
[ 6.544922] cpufreq: cpufreq_online: CPU8: Running at unlisted initial frequency: 2006000 KHz, changing to: 2035200 KHz
[ 6.550624] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 6.555120] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 6.555340] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[ 6.557873] mmc0: CQHCI version 5.10
[ 6.568483] tegra194-pcie 14100000.pcie: IO 0x0030100000…0x00301fffff → 0x0030100000
[ 6.576807] tegra194-pcie 14100000.pcie: MEM 0x20a8000000…0x20afffffff → 0x0040000000
[ 6.585449] tegra194-pcie 14100000.pcie: MEM 0x2080000000…0x20a7ffffff → 0x2080000000
[ 6.602372] irq: IRQ290: trimming hierarchy from :pmc@c360000
[ 6.602585] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 290
[ 6.608557] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit
[ 6.700041] tegra194-pcie 14100000.pcie: Link up
[ 6.701224] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[ 6.701408] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 6.701554] pci_bus 0001:00: root bus resource [io 0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[ 6.701807] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[ 6.702080] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[ 6.702320] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[ 6.702586] pci 0001:00:00.0: PME# supported from D0 D3hot
[ 6.705782] mmc0: Command Queue Engine enabled
[ 6.705898] mmc0: periodic cache flush enabled
[ 6.705931] pci 0001:01:00.0: [10ec:c822] type 00 class 0x028000
[ 6.706020] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 6.706285] pci 0001:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 6.706626] pci 0001:01:00.0: reg 0x18: [mem 0x20a8000000-0x20a800ffff 64bit]
[ 6.706765] mmcblk0: mmc0:0001 G1M15M 59.3 GiB
[ 6.707530] pci 0001:01:00.0: supports D1 D2
[ 6.708744] mmcblk0rpmb: mmc0:0001 G1M15M partition 3 4.00 MiB, chardev (510:0)
[ 6.713020] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 6.724038] usb 1-3: new full-speed USB device number 2 using tegra-xusb
[ 6.729902] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff]
[ 6.741039] pci 0001:00:00.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 6.747352] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8000000-0x20a800ffff 64bit]
[ 6.755265] pci 0001:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 6.761342] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 6.766398] pci 0001:00:00.0: bridge window [io 0x1000-0x1fff]
[ 6.772524] pci 0001:00:00.0: bridge window [mem 0x20a8000000-0x20a80fffff]
[ 6.779530] pci 0001:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 6.788232] pci 0001:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 6.796875] pcieport 0001:00:00.0: Adding to iommu group 10
[ 6.802556] pcieport 0001:00:00.0: PME: Signaling with IRQ 50
[ 6.808397] pcieport 0001:00:00.0: AER: enabled with IRQ 50
[ 6.814487] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 6.821062] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[ 6.826786] tegra194-pcie 14160000.pcie: IO 0x0036100000…0x00361fffff → 0x0036100000
[ 6.835442] tegra194-pcie 14160000.pcie: MEM 0x2428000000…0x242fffffff → 0x0040000000
[ 6.835598] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
[ 6.843920] tegra194-pcie 14160000.pcie: MEM 0x2140000000…0x2427ffffff → 0x2140000000
[ 6.900222] usb 1-3: New USB device found, idVendor=13d3, idProduct=3549, bcdDevice= 0.00
[ 6.900478] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 6.900690] usb 1-3: Product: Bluetooth Radio
[ 6.900817] usb 1-3: Manufacturer: Realtek
[ 6.900945] usb 1-3: SerialNumber: 00e04c000001
[ 7.025331] usb 2-3: new SuperSpeedPlus Gen 2 USB device number 2 using tegra-xusb
[ 7.062967] usb 2-3: New USB device found, idVendor=0bda, idProduct=0420, bcdDevice= 1.40
[ 7.063213] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 7.063439] usb 2-3: Product: 4-Port USB 3.0 Hub
[ 7.063593] usb 2-3: Manufacturer: Generic
[ 7.073903] hub 2-3:1.0: USB hub found
[ 7.076246] hub 2-3:1.0: 4 ports detected
[ 7.180037] usb 1-4: new high-speed USB device number 3 using tegra-xusb
[ 7.347969] usb 1-4: New USB device found, idVendor=0bda, idProduct=5420, bcdDevice= 1.40
[ 7.348239] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 7.348477] usb 1-4: Product: 4-Port USB 2.0 Hub
[ 7.348632] usb 1-4: Manufacturer: Generic
[ 7.349936] hub 1-4:1.0: USB hub found
[ 7.351321] hub 1-4:1.0: 4 ports detected
[ 7.952709] tegra194-pcie 14160000.pcie: Phy link never came up
[ 7.952933] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 7.953117] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 7.953271] pci_bus 0004:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[ 7.953551] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[ 7.953851] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[ 7.954092] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[ 7.954366] pci 0004:00:00.0: PME# supported from D0 D3hot
[ 7.959901] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 7.960053] pci 0004:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 7.960477] pcieport 0004:00:00.0: Adding to iommu group 11
[ 7.960779] pcieport 0004:00:00.0: PME: Signaling with IRQ 52
[ 7.961262] pcieport 0004:00:00.0: AER: enabled with IRQ 52
[ 7.961612] pci_bus 0004:01: busn_res: [bus 01-ff] is released
[ 7.961841] pci 0004:00:00.0: Removing from iommu group 11
[ 7.961987] pci_bus 0004:00: busn_res: [bus 00-ff] is released
[ 7.968624] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 7.973591] tegra194-pcie 141a0000.pcie: Failed to get slot regulators: -517
[ 7.973660] vdd-3v3-pcie: supplied by vdd-3v3-sys
[ 7.978269] avdd-cam-2v8: supplied by vdd-3v3-sys
[ 7.982907] vdd-dp: supplied by vdd-3v3-sys
[ 7.987168] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 7.992041] dsi-vdd-1v8-bl-en: supplied by vdd-1v8-sys
[ 7.998354] tegra194-isp5 14800000.isp: initialized
[ 8.003798] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized
[ 8.008039] (NULL device *): fops function table already registered
[ 8.015147] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized
[ 8.020913] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 8.021014] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 8.044319] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 290
[ 8.084039] usb 1-4.3: new full-speed USB device number 4 using tegra-xusb
[ 8.132520] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[ 8.132730] tegra194-pcie 141a0000.pcie: IO 0x003a100000…0x003a1fffff → 0x003a100000
[ 8.132959] tegra194-pcie 141a0000.pcie: MEM 0x2b28000000…0x2b2fffffff → 0x0040000000
[ 8.133180] tegra194-pcie 141a0000.pcie: MEM 0x2740000000…0x2b27ffffff → 0x2740000000
[ 8.192417] usb 1-4.3: New USB device found, idVendor=1ea7, idProduct=0066, bcdDevice= 2.00
[ 8.192655] usb 1-4.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 8.192856] usb 1-4.3: Product: 2.4G Mouse
[ 8.199249] input: 2.4G Mouse as /devices/platform/3610000.xhci/usb1/1-4/1-4.3/1-4.3:1.0/0003:1EA7:0066.0001/input/input0
[ 8.256626] hid-generic 0003:1EA7:0066.0001: input,hidraw0: USB HID v1.10 Keyboard [2.4G Mouse] on usb-3610000.xhci-4.3/input0
[ 8.262403] input: 2.4G Mouse as /devices/platform/3610000.xhci/usb1/1-4/1-4.3/1-4.3:1.1/0003:1EA7:0066.0002/input/input1
[ 8.262917] input: 2.4G Mouse as /devices/platform/3610000.xhci/usb1/1-4/1-4.3/1-4.3:1.1/0003:1EA7:0066.0002/input/input2
[ 8.263695] input: 2.4G Mouse Consumer Control as /devices/platform/3610000.xhci/usb1/1-4/1-4.3/1-4.3:1.1/0003:1EA7:0066.0002/input/input3
[ 8.324375] input: 2.4G Mouse System Control as /devices/platform/3610000.xhci/usb1/1-4/1-4.3/1-4.3:1.1/0003:1EA7:0066.0002/input/input4
[ 8.325251] hid-generic 0003:1EA7:0066.0002: input,hiddev96,hidraw1: USB HID v1.10 Mouse [2.4G Mouse] on usb-3610000.xhci-4.3/input1
[ 9.097516] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit
[ 9.241109] tegra194-pcie 141a0000.pcie: Phy link never came up
[ 9.241332] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[ 9.241521] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 9.241672] pci_bus 0005:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x3a100000-0x3a1fffff])
[ 9.241949] pci_bus 0005:00: root bus resource [mem 0x2b28000000-0x2b2fffffff] (bus address [0x40000000-0x47ffffff])
[ 9.242246] pci_bus 0005:00: root bus resource [mem 0x2740000000-0x2b27ffffff pref]
[ 9.242494] pci 0005:00:00.0: [10de:229a] type 01 class 0x060400
[ 9.242768] pci 0005:00:00.0: PME# supported from D0 D3hot
[ 9.248450] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 9.248607] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 9.249027] pcieport 0005:00:00.0: Adding to iommu group 12
[ 9.249325] pcieport 0005:00:00.0: PME: Signaling with IRQ 54
[ 9.249819] pcieport 0005:00:00.0: AER: enabled with IRQ 54
[ 9.250155] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[ 9.250376] pci 0005:00:00.0: Removing from iommu group 12
[ 9.250528] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[ 9.257183] nvethernet 6810000.ethernet: Adding to iommu group 43
[ 9.262217] nvethernet 6810000.ethernet: failed to read skip mac reset flag, default 0
[ 9.269930] nvethernet 6810000.ethernet: failed to read MDIO address
[ 9.276491] nvethernet 6810000.ethernet: setting to default DMA bit mask
[ 9.283323] nvethernet 6810000.ethernet: failed to read UPHY GBE mode- default to 10G
[ 9.291065] nvethernet 6810000.ethernet: failed to get phy reset gpio error: -2
[ 9.302512] nvethernet 6810000.ethernet: Ethernet MAC address: 48:b0:2d:78:83:aa
[ 9.305690] -->macsec_probe()
[ 9.305697] -->macsec_get_platform_res()
[ 9.305712] <–macsec_get_platform_res()
[ 9.305713] -->macsec_enable_car()
[ 9.305929] <–macsec_enable_car()
[ 9.305945] <–macsec_probe()
[ 9.305947] nvethernet 6810000.ethernet: Macsec not enabled
[ 9.311229] nvethernet 6810000.ethernet: Macsec: Reduced MTU: 1466 Max: 16383
[ 9.320792] nvethernet 6810000.ethernet: eth0 (HW ver: 31) created with 10 DMA channels
[ 9.326843] irq: IRQ292: trimming hierarchy from :pmc@c360000
[ 9.332199] irq: IRQ293: trimming hierarchy from :interrupt-controller@f400000-1
[ 9.339608] irq: IRQ294: trimming hierarchy from :pmc@c360000
[ 9.345224] input: gpio-keys as /devices/platform/gpio-keys/input/input6
[ 9.352552] tegra-se-nvhost 15810000.se: Adding to iommu group 44
[ 9.358569] tegra-se-nvhost 15810000.se: initialized
[ 9.369720] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 9.369976] tegra-se-nvhost 15820000.se: Adding to iommu group 45
[ 9.375957] tegra-se-nvhost 15820000.se: initialized
[ 9.382480] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 9.386649] tegra-se-nvhost 15840000.se: Adding to iommu group 46
[ 9.393066] tegra-se-nvhost 15840000.se: initialized
[ 9.401281] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 9.404529] tegra_actmon d230000.actmon: in actmon_register()…
[ 9.410066] tegra_actmon d230000.actmon: bwmgr_disable = 1
[ 9.415882] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[ 9.423625] hvc_sysfs: hypervisor is not present
[ 9.459828] ALSA device list:
[ 9.459912] No soundcards found.
[ 9.460560] Freeing unused kernel memory: 3968K
[ 9.460720] Run /init as init process
[ 9.460815] with arguments:
[ 9.460815] /init
[ 9.460816] nv-auto-config
[ 9.460817] with environment:
[ 9.460818] HOME=/
[ 9.460819] TERM=linux
[ 9.460820] mminit_loglevel=4
[ 9.471223] Root device found: mmcblk0p1
[ 9.471804] Found dev node: /dev/mmcblk0p1
[ 9.497535] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 9.498517] Rootfs mounted over mmcblk0p1
[ 9.511146] Switching from initrd to actual rootfs
[ 9.622667] systemd[1]: System time before build time, advancing clock.
[ 9.645982] systemd[1]: systemd 245.4-4ubuntu3.15 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 9.647084] systemd[1]: Detected architecture arm64.
[ 9.688183] systemd[1]: Set hostname to .
[ 9.867157] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 9.867524] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 9.868571] systemd[1]: Created slice system-modprobe.slice.
[ 9.869167] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 9.869666] systemd[1]: Created slice User and Session Slice.
[ 9.869920] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 9.870368] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 9.870694] systemd[1]: Reached target User and Group Name Lookups.
[ 9.870912] systemd[1]: Reached target Slices.
[ 9.871074] systemd[1]: Reached target Swap.
[ 9.871407] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 9.871698] systemd[1]: Listening on Syslog Socket.
[ 9.871946] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 9.872242] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 9.872679] systemd[1]: Listening on Journal Audit Socket.
[ 9.876758] systemd[1]: Listening on Journal Socket (/dev/log).
[ 9.882863] systemd[1]: Listening on Journal Socket.
[ 9.887858] systemd[1]: Listening on udev Control Socket.
[ 9.893313] systemd[1]: Listening on udev Kernel Socket.
[ 9.899760] systemd[1]: Mounting Huge Pages File System…
[ 9.905240] systemd[1]: Mounting POSIX Message Queue File System…
[ 9.911399] systemd[1]: Mounting RPC Pipe File System…
[ 9.916912] systemd[1]: Mounting Kernel Debug File System…
[ 9.922647] systemd[1]: Mounting Kernel Trace File System…
[ 9.928473] systemd[1]: Starting Journal Service…
[ 9.933315] systemd[1]: Starting Set the console keyboard layout…
[ 9.938648] systemd[1]: Condition check resulted in Create list of static device nodes for the current kernel being skipped.
[ 9.949763] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[ 9.959076] systemd[1]: Started Nameserver information manager.
[ 9.964258] systemd[1]: Reached target Network (Pre).
[ 9.971686] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 9.978411] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 9.980108] systemd[1]: Starting Load Kernel Modules…
[ 9.993663] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 10.000370] systemd[1]: Starting udev Coldplug all Devices…
[ 10.004210] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 10.011910] systemd[1]: Mounted Huge Pages File System.
[ 10.015947] systemd[1]: Mounted POSIX Message Queue File System.
[ 10.022009] systemd[1]: Mounted RPC Pipe File System.
[ 10.027019] systemd[1]: Mounted Kernel Debug File System.
[ 10.032457] systemd[1]: Started Journal Service.
[ 10.049398] systemd-journald[302]: Received client request to flush runtime journal.
[ 10.413126] using random self ethernet address
[ 10.413265] using random host ethernet address
[ 13.550875] libphy: nvethernet_mdio_bus: probed
[ 13.561680] irq: IRQ295: trimming hierarchy from :pmc@c360000
[ 16.699860] nvethernet 6810000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 16.700122] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
