Ok, thank you for reply.
$ sudo dmesg
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 5.10.104 (root@tegra-ubuntu) (gcc (Ubuntu 9.4.0-1ubuntu1~20.04.1) 9.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1 SMP PREEMPT Sun Apr 16 08:14:07 UTC 2023
[ 0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,
[ 0.000000] OF: fdt: - 80000000 , c0000000
[ 0.000000] Machine model: Jetson AGX Orin
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x80824f718 SMBIOS=0xffff0000 SMBIOS 3.0=0x806700000 MEMATTR=0x80710e018 ESRT=0x806788c98 RNG=0x82a9fdd18 MEMRESERVE=0x807115f18
[ 0.000000] efi: seeding entropy pool
[ 0.000000] esrt: Reserving ESRT space from 0x0000000806788c98 to 0x0000000806788cd0.
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000081a800000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x0000000837ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000fffdffff]
[ 0.000000] node 0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x0000000803ffffff]
[ 0.000000] node 0: [mem 0x0000000804000000-0x00000008061bffff]
[ 0.000000] node 0: [mem 0x00000008061c0000-0x000000080621afff]
[ 0.000000] node 0: [mem 0x000000080621b000-0x00000008063b1fff]
[ 0.000000] node 0: [mem 0x00000008063b2000-0x00000008066effff]
[ 0.000000] node 0: [mem 0x00000008066f0000-0x000000080670ffff]
[ 0.000000] node 0: [mem 0x0000000806710000-0x000000080701ffff]
[ 0.000000] node 0: [mem 0x0000000807020000-0x000000080706ffff]
[ 0.000000] node 0: [mem 0x0000000807070000-0x00000008070dffff]
[ 0.000000] node 0: [mem 0x00000008070e0000-0x00000008070fffff]
[ 0.000000] node 0: [mem 0x0000000807100000-0x000000080711ffff]
[ 0.000000] node 0: [mem 0x0000000807120000-0x000000080713ffff]
[ 0.000000] node 0: [mem 0x0000000807140000-0x00000008071cffff]
[ 0.000000] node 0: [mem 0x00000008071d0000-0x00000008072bffff]
[ 0.000000] node 0: [mem 0x00000008072c0000-0x00000008073bffff]
[ 0.000000] node 0: [mem 0x00000008073c0000-0x000000080772ffff]
[ 0.000000] node 0: [mem 0x0000000807730000-0x00000008077bffff]
[ 0.000000] node 0: [mem 0x00000008077c0000-0x000000080785ffff]
[ 0.000000] node 0: [mem 0x0000000807860000-0x0000000807d1ffff]
[ 0.000000] node 0: [mem 0x0000000807d20000-0x0000000807d6ffff]
[ 0.000000] node 0: [mem 0x0000000807d70000-0x0000000807d8ffff]
[ 0.000000] node 0: [mem 0x0000000807d90000-0x0000000807d9ffff]
[ 0.000000] node 0: [mem 0x0000000807da0000-0x000000080838ffff]
[ 0.000000] node 0: [mem 0x0000000808390000-0x000000080842ffff]
[ 0.000000] node 0: [mem 0x0000000808430000-0x000000080852ffff]
[ 0.000000] node 0: [mem 0x0000000808530000-0x00000008085cffff]
[ 0.000000] node 0: [mem 0x00000008085d0000-0x00000008086cffff]
[ 0.000000] node 0: [mem 0x00000008086d0000-0x000000080876ffff]
[ 0.000000] node 0: [mem 0x0000000808770000-0x000000080903ffff]
[ 0.000000] node 0: [mem 0x0000000809040000-0x000000080921ffff]
[ 0.000000] node 0: [mem 0x0000000809220000-0x000000082a9affff]
[ 0.000000] node 0: [mem 0x000000082a9b0000-0x000000082a9fffff]
[ 0.000000] node 0: [mem 0x000000082aa00000-0x000000082e7fffff]
[ 0.000000] node 0: [mem 0x000000082ea00000-0x000000082eefffff]
[ 0.000000] node 0: [mem 0x0000000836000000-0x0000000837ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000837ffffff]
[ 0.000000] On node 0 totalpages: 8064256
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 524288 pages, LIFO batch:63
[ 0.000000] Normal zone: 118272 pages used for memmap
[ 0.000000] Normal zone: 7539968 pages, LIFO batch:63
[ 0.000000] On node 0, zone Normal: 256 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 32 pages/cpu s90200 r8192 d32680 u131072
[ 0.000000] pcpu-alloc: s90200 r8192 d32680 u131072 alloc=32*4096
[ 0.000000] pcpu-alloc: [0] 00 [0] 01 [0] 02 [0] 03 [0] 04 [0] 05 [0] 06 [0] 07
[ 0.000000] pcpu-alloc: [0] 08 [0] 09 [0] 10 [0] 11
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 7937792
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1â\xc2\x80\xc2\x8b rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 console=tty0 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0
[ 0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000effe0000-0x00000000fffe0000] (256MB)
[ 0.000000] Memory: 31048816K/32257024K available (18176K kernel code, 3166K rwdata, 7136K rodata, 3968K init, 1108K bss, 946064K reserved, 262144K cma-reserved)
[ 0.000000] random: get_random_u64 called from __kmem_cache_create+0x38/0x418 with crng_init=0
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=12, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=12.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=12
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[ 0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)
[ 0.000000] GICv2m: range[mem 0x0f410000-0x0f41ffff], SPI[608:677]
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000824] Console: colour dummy device 80x25
[ 0.001008] printk: console [tty0] enabled
[ 0.001054] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.001065] pid_max: default: 32768 minimum: 301
[ 0.001135] LSM: Security Framework initializing
[ 0.001159] Yama: becoming mindful.
[ 0.001178] SELinux: Initializing.
[ 0.001270] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.001315] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.003408] rcu: Hierarchical SRCU implementation.
[ 0.003508] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.004215] DTS File Name: /mnt/data_HDD/kernelSource/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t23x/concord/kernel-dts/tegra234-p3701-0000-p3737-0000.dts
[ 0.004225] DTB Build time: <unknown>
[ 0.005651] Tegra Revision: A01 SKU: 0xd0 CPU Process: 0 SoC Process: 0
[ 0.005769] Remapping and enabling EFI services.
[ 0.007000] smp: Bringing up secondary CPUs ...
[ 0.035712] Detected PIPT I-cache on CPU1
[ 0.035750] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[ 0.035789] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[ 0.064434] Detected PIPT I-cache on CPU2
[ 0.064443] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[ 0.064458] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[ 0.093046] Detected PIPT I-cache on CPU3
[ 0.093055] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[ 0.093068] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[ 0.123725] Detected PIPT I-cache on CPU4
[ 0.123746] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c0000
[ 0.123773] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[ 0.152429] Detected PIPT I-cache on CPU5
[ 0.152437] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e0000
[ 0.152453] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[ 0.181070] Detected PIPT I-cache on CPU6
[ 0.181079] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f500000
[ 0.181093] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[ 0.209715] Detected PIPT I-cache on CPU7
[ 0.209724] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f520000
[ 0.209740] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
[ 0.240399] Detected PIPT I-cache on CPU8
[ 0.240421] GICv3: CPU8: found redistributor 20000 region 0:0x000000000f540000
[ 0.240449] CPU8: Booted secondary processor 0x0000020000 [0x410fd421]
[ 0.269094] Detected PIPT I-cache on CPU9
[ 0.269104] GICv3: CPU9: found redistributor 20100 region 0:0x000000000f560000
[ 0.269118] CPU9: Booted secondary processor 0x0000020100 [0x410fd421]
[ 0.298345] Detected PIPT I-cache on CPU10
[ 0.298354] GICv3: CPU10: found redistributor 20200 region 0:0x000000000f580000
[ 0.298370] CPU10: Booted secondary processor 0x0000020200 [0x410fd421]
[ 0.327591] Detected PIPT I-cache on CPU11
[ 0.327601] GICv3: CPU11: found redistributor 20300 region 0:0x000000000f5a0000
[ 0.327616] CPU11: Booted secondary processor 0x0000020300 [0x410fd421]
[ 0.327674] smp: Brought up 1 node, 12 CPUs
[ 0.327740] SMP: Total of 12 processors activated.
[ 0.327746] CPU features: detected: Privileged Access Never
[ 0.327748] CPU features: detected: LSE atomic instructions
[ 0.327751] CPU features: detected: User Access Override
[ 0.327754] CPU features: detected: 32-bit EL0 Support
[ 0.327757] CPU features: detected: Common not Private translations
[ 0.327760] CPU features: detected: RAS Extension Support
[ 0.327763] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.327767] CPU features: detected: CRC32 instructions
[ 0.327769] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.363739] CPU: All CPU(s) started at EL2
[ 0.366249] devtmpfs: initialized
[ 0.383875] Registered cp15_barrier emulation handler
[ 0.383887] Registered setend emulation handler
[ 0.383893] KASLR enabled
[ 0.384014] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.384028] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[ 0.385663] pinctrl core: initialized pinctrl subsystem
[ 0.386213] SMBIOS 3.0.0 present.
[ 0.386220] DMI: Unknown Jetson AGX Orin/Jetson AGX Orin, BIOS 2.1-32413640 01/24/2023
[ 0.386498] NET: Registered protocol family 16
[ 0.387347] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.387550] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.387747] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.387777] audit: initializing netlink subsys (disabled)
[ 0.387865] audit: type=2000 audit(0.384:1): state=initialized audit_enabled=0 res=1
[ 0.388042] thermal_sys: Registered thermal governor 'step_wise'
[ 0.388044] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.388051] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[ 0.390564] cpuidle: using governor menu
[ 0.390676] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.390793] ASID allocator initialised with 32768 entries
[ 0.390888] Serial: AMBA PL011 UART driver
[ 0.392837] tegra234_mc_sid_probe(): tegra234 mc-sid probe successful
[ 0.392859] Tegra reboot handler registered.
[ 0.411683] mc: mapped MMIO address: 0xffff8000111f0000 -> 0x2c10000
[ 0.411699] mc: mapped MMIO address: 0xffff800011210000 -> 0x2c20000
[ 0.411707] mc: mapped MMIO address: 0xffff800011230000 -> 0x2c30000
[ 0.411714] mc: mapped MMIO address: 0xffff800011250000 -> 0x2c40000
[ 0.411720] mc: mapped MMIO address: 0xffff800011270000 -> 0x2c50000
[ 0.411727] mc: mapped MMIO address: 0xffff800011290000 -> 0x2b80000
[ 0.411733] mc: mapped MMIO address: 0xffff8000112b0000 -> 0x2b90000
[ 0.411741] mc: mapped MMIO address: 0xffff8000112d0000 -> 0x2ba0000
[ 0.411748] mc: mapped MMIO address: 0xffff8000112f0000 -> 0x2bb0000
[ 0.411754] mc: mapped MMIO address: 0xffff800011310000 -> 0x1700000
[ 0.411761] mc: mapped MMIO address: 0xffff800011330000 -> 0x1710000
[ 0.411770] mc: mapped MMIO address: 0xffff800011350000 -> 0x1720000
[ 0.411776] mc: mapped MMIO address: 0xffff800011370000 -> 0x1730000
[ 0.411783] mc: mapped MMIO address: 0xffff800011390000 -> 0x1740000
[ 0.411790] mc: mapped MMIO address: 0xffff8000113b0000 -> 0x1750000
[ 0.411797] mc: mapped MMIO address: 0xffff8000113d0000 -> 0x1760000
[ 0.411805] mc: mapped MMIO address: 0xffff8000113f0000 -> 0x1770000
[ 0.411813] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.411844] mc-err: mcerr ops are set to t23x
[ 0.412526] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 67, base_baud = 0) is a SBSA
[ 1.665686] printk: console [ttyAMA0] enabled
[ 1.674180] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 1.680886] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 1.687585] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 1.694283] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 1.702721] ACPI: Interpreter disabled.
[ 1.707701] vdd-av1v1-hub: supplied by vdd-5v-sys
[ 1.712563] vbusA-cvb: supplied by vdd-5v-sys
[ 1.717039] vbusB-cvb: supplied by vdd-5v-sys
[ 1.721530] vdd-usbc1-vbus: supplied by vdd-5v-sys
[ 1.726448] vdd-usbc2-vbus: supplied by vdd-5v-sys
[ 1.731538] iommu: Default domain type: Translated
[ 1.736462] eventlib_kernel: keventlib is initialized, test id: 0
[ 1.742730] SCSI subsystem initialized
[ 1.746566] usbcore: registered new interface driver usbfs
[ 1.752063] usbcore: registered new interface driver hub
[ 1.757390] usbcore: registered new device driver usb
[ 1.762620] mc: Linux media interface: v0.10
[ 1.766896] videodev: Linux video capture interface: v2.00
[ 1.772522] pps_core: LinuxPPS API ver. 1 registered
[ 1.777486] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.786623] PTP clock support registered
[ 1.790752] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec
[ 1.797908] tegra_wdt_t18x 2190000.watchdog: Registered successfully
[ 1.805561] Registered efivars operations
[ 1.810107] FPGA manager framework
[ 1.813535] Advanced Linux Sound Architecture Driver Initialized.
[ 1.819900] Bluetooth: Core ver 2.22
[ 1.823482] NET: Registered protocol family 31
[ 1.827923] Bluetooth: HCI device and connection manager initialized
[ 1.834282] Bluetooth: HCI socket layer initialized
[ 1.839159] Bluetooth: L2CAP socket layer initialized
[ 1.844218] Bluetooth: SCO socket layer initialized
[ 1.849602] camchar: rtcpu character device driver loaded
[ 1.855238] clocksource: Switched to clocksource arch_sys_counter
[ 2.006548] VFS: Disk quotas dquot_6.6.0
[ 2.010513] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 2.017526] pnp: PnP ACPI: disabled
[ 2.022822] la/ptsa driver initialized.
[ 2.026717] NET: Registered protocol family 2
[ 2.031292] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 2.041020] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[ 2.049763] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 2.058069] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 2.065962] TCP: Hash tables configured (established 262144 bind 65536)
[ 2.072671] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 2.079602] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 2.087048] NET: Registered protocol family 1
[ 2.091674] RPC: Registered named UNIX socket transport module.
[ 2.097607] RPC: Registered udp transport module.
[ 2.102309] RPC: Registered tcp transport module.
[ 2.107014] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 2.113466] PCI: CLS 0 bytes, default 64
[ 2.117512] Trying to unpack rootfs image as initramfs...
[ 2.233216] Freeing initrd memory: 8208K
[ 2.239467] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 2.247438] kvm [1]: IPA Size Limit: 48 bits
[ 2.251883] kvm [1]: VHE mode initialized successfully
[ 2.257718] Initialise system trusted keyrings
[ 2.262251] workingset: timestamp_bits=46 max_order=23 bucket_order=0
[ 2.270747] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.276837] NFS: Registering the id_resolver key type
[ 2.281907] Key type id_resolver registered
[ 2.286089] Key type id_legacy registered
[ 2.290134] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 2.296844] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 2.304250] ntfs: driver 2.1.32 [Flags: R/W].
[ 2.320429] NET: Registered protocol family 38
[ 2.324877] Key type asymmetric registered
[ 2.328974] Asymmetric key parser 'x509' registered
[ 2.333866] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 2.341326] io scheduler mq-deadline registered
[ 2.345858] io scheduler kyber registered
[ 2.353969] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 2.359575] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 2.365163] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 2.370749] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 2.378869] tegra_dc_assign_hw_data: no matching compatible node
[ 2.384885] tegradccommon module_init failed
[ 2.389154] tegradc module_init failed
[ 2.393162] EINJ: ACPI disabled.
[ 2.397958] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 2.404839] tegra-pmc: ### PMC reset source: MAINSWRST
[ 2.409979] tegra-pmc: ### PMC reset level: L1
[ 2.414419] tegra-pmc: ### PMC reset status reg: 0x2d
[ 2.420864] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 2.433503] random: fast init done
[ 2.436854] printk: console [ttyTCU0] enabled
[ 4.073918] arm-smmu 12000000.iommu: probing hardware configuration...
[ 4.081912] arm-smmu 12000000.iommu: SMMUv2 with:
[ 4.086746] arm-smmu 12000000.iommu: stage 1 translation
[ 4.092282] arm-smmu 12000000.iommu: stage 2 translation
[ 4.097821] arm-smmu 12000000.iommu: nested translation
[ 4.103281] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 4.110696] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
[ 4.119564] arm-smmu 12000000.iommu: Supported page sizes: 0x00001000
[ 4.126268] arm-smmu 12000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 4.132972] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 4.140500] arm-smmu 10000000.iommu: probing hardware configuration...
[ 4.147201] arm-smmu 10000000.iommu: SMMUv2 with:
[ 4.152022] arm-smmu 10000000.iommu: stage 1 translation
[ 4.157555] arm-smmu 10000000.iommu: stage 2 translation
[ 4.163098] arm-smmu 10000000.iommu: nested translation
[ 4.168556] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 4.175958] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 only)
[ 4.184782] arm-smmu 10000000.iommu: Supported page sizes: 0x00001000
[ 4.191480] arm-smmu 10000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 4.198168] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 4.205302] arm-smmu 8000000.iommu: probing hardware configuration...
[ 4.211913] arm-smmu 8000000.iommu: SMMUv2 with:
[ 4.216651] arm-smmu 8000000.iommu: stage 1 translation
[ 4.222108] arm-smmu 8000000.iommu: stage 2 translation
[ 4.227556] arm-smmu 8000000.iommu: nested translation
[ 4.232921] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 4.240242] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 4.249004] arm-smmu 8000000.iommu: Supported page sizes: 0x00001000
[ 4.255609] arm-smmu 8000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 4.262220] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 4.269588] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[ 4.279966] tegra_profiler: version: 1.150, samples/io: 50/29
[ 4.285919] tegra_profiler: auth: init
[ 4.290068] nvsciipc: loaded module
[ 4.295173] tun: Universal TUN/TAP device driver, 1.6
[ 4.300791] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 4.308215] hns3: Copyright (c) 2017 Huawei Corporation.
[ 4.313693] e1000e: Intel(R) PRO/1000 Network Driver
[ 4.318789] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 4.324880] igb: Intel(R) Gigabit Ethernet Network Driver
[ 4.330431] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 4.336302] PPP generic driver version 2.4.2
[ 4.340728] PPP BSD Compression module registered
[ 4.345562] PPP Deflate Compression module registered
[ 4.350761] PPP MPPE Compression module registered
[ 4.355719] usbcore: registered new interface driver r8152
[ 4.361366] usbcore: registered new interface driver asix
[ 4.366921] usbcore: registered new interface driver ax88179_178a
[ 4.373182] usbcore: registered new interface driver cdc_ether
[ 4.379179] usbcore: registered new interface driver net1080
[ 4.384987] usbcore: registered new interface driver cdc_subset
[ 4.391074] usbcore: registered new interface driver zaurus
[ 4.396799] usbcore: registered new interface driver cdc_ncm
[ 4.402620] usbcore: registered new interface driver aqc111
[ 4.408447] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 4.414804] ohci-pci: OHCI PCI platform driver
[ 4.419379] ohci-platform: OHCI generic platform driver
[ 4.425029] tegra-xusb 3610000.xhci: Adding to iommu group 0
[ 4.431452] usbcore: registered new interface driver uas
[ 4.436929] usbcore: registered new interface driver usb-storage
[ 4.443252] tegra-xudc 3550000.xudc: Adding to iommu group 1
[ 4.449376] mousedev: PS/2 mouse device common for all mice
[ 4.455123] usbcore: registered new interface driver xpad
[ 4.462515] tegra_rtc c2a0000.rtc: registered as rtc1
[ 4.468013] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:01:48 UTC (108)
[ 4.476329] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 4.482750] i2c /dev entries driver
[ 4.486440] tegra-i2c 3160000.i2c: Adding to iommu group 2
[ 4.492264] tegra-i2c c240000.i2c: Adding to iommu group 2
[ 4.497975] tegra-i2c 3180000.i2c: Adding to iommu group 2
[ 4.503650] tegra-i2c 3190000.i2c: Adding to iommu group 2
[ 4.509324] tegra-i2c 31b0000.i2c: Adding to iommu group 2
[ 4.514995] tegra-i2c 31c0000.i2c: Adding to iommu group 2
[ 4.520671] tegra-i2c c250000.i2c: Adding to iommu group 2
[ 4.526354] tegra-i2c 31e0000.i2c: Adding to iommu group 2
[ 4.534419] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[ 4.543007] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[ 4.552466] device-mapper: uevent: version 1.0.3
[ 4.557297] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[ 4.567105] sdhci: Secure Digital Host Controller Interface driver
[ 4.573442] sdhci: Copyright(c) Pierre Ossman
[ 4.577908] Synopsys Designware Multimedia Card Interface Driver
[ 4.584139] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.590131] sdhci-tegra 3460000.sdhci: Adding to iommu group 3
[ 4.590449] sdhci-tegra 3400000.sdhci: Adding to iommu group 4
[ 4.590661] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401
[ 4.591982] tegra-bpmp bpmp: firmware: 9a7bb16aee9be45a56e6-ccd7dae126b
[ 4.593330] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9
[ 4.594058] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x81
[ 4.599225] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[ 4.631690] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful
[ 6.313037] hid: raw HID events driver (C) Jiri Kosina
[ 6.318785] usbcore: registered new interface driver usbhid
[ 6.324523] usbhid: USB HID core driver
[ 6.329181] tegra-dce d800000.dce: Adding to iommu group 5
[ 6.336239] dce: dce_ipc_channel_init:314 Invalid Channel State [0x0] for ch_type [2]
[ 6.345320] tegra234-aon c000000.aon: Adding to iommu group 6
[ 6.351790] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x5]
[ 6.355885] c000000.aon:hsp: probed
[ 6.360813] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [0]. Ignored...
[ 6.373280] tegra234-aon c000000.aon: init done
[ 6.373577] tegra23x-psc e860000.psc: Adding to iommu group 7
[ 6.377969] dce: dce_admin_send_cmd_ver:424 version : [0x2] err : [0x0]
[ 6.384210] tegra23x-psc e860000.psc: ext_cfg base:(____ptrval____)
[ 6.391310] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x1]
[ 6.397227] tegra23x-psc e860000.psc: init done
[ 6.397462] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 8
[ 6.406228] dce: dce_admin_setup_clients_ipc:553 Channel Reset Complete for Type [1] ...
[ 6.406231] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [1]. Ignored...
[ 6.406254] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [1]. Ignored...
[ 6.411595] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 6.417521] dce: dce_admin_setup_clients_ipc:529 Get queue info failed for [2]
[ 6.417936] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x2]
[ 6.429614] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[ 6.434778] dce: dce_admin_setup_clients_ipc:553 Channel Reset Complete for Type [3] ...
[ 6.434780] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [3]. Ignored...
[ 6.434806] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [3]. Ignored...
[ 6.443604] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 6.452372] dce: dce_start_boot_flow:173 DCE_BOOT_DONE
[ 6.459724] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[ 6.532089] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[ 6.543918] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[ 6.556504] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[ 6.569339] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[ 6.581329] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (117)
[ 6.588154] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 6.599376] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=10150ec03f8849d1537396903b70d4a48a255aba
[ 6.612931] t19x_cache tegra-cache: probed
[ 6.617626] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[ 6.632442] optee: probing for conduit method.
[ 6.637040] optee: revision 3.19 (18d0f61b)
[ 6.637702] optee: dynamic shared memory is enabled
[ 6.647137] optee: initialized driver
[ 6.664727] nvpmodel: initialized successfully
[ 6.669417] tegra_hv: get_hvd: not initialized yet
[ 6.674368] user_ivc_mempool: hypervisor not present
[ 6.680079] usbcore: registered new interface driver snd-usb-audio
[ 6.687267] u32 classifier
[ 6.690066] input device check on
[ 6.693839] Actions configured
[ 6.697502] Initializing XFRM netlink socket
[ 6.702363] NET: Registered protocol family 10
[ 6.708779] Segment Routing with IPv6
[ 6.712623] NET: Registered protocol family 17
[ 6.717213] NET: Registered protocol family 15
[ 6.721839] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 6.735738] Bluetooth: RFCOMM socket layer initialized
[ 6.741040] Bluetooth: RFCOMM ver 1.11
[ 6.744909] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 6.750993] Bluetooth: HIDP socket layer initialized
[ 6.756810] 9pnet: Installing 9P2000 support
[ 6.761259] Key type dns_resolver registered
[ 6.766330] registered taskstats version 1
[ 6.770563] Loading compiled-in X.509 certificates
[ 6.780285] Loaded X.509 cert 'Build time autogenerated kernel key: 393b4f411f7fae2e9e859363376cfc1cd8f0c856'
[ 6.790786] tegra194-pcie 14100000.pcie: Adding to iommu group 9
[ 6.803489] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 6.810633] tegra194-pcie 14160000.pcie: Adding to iommu group 10
[ 6.823337] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 6.830236] tegra194-pcie 141a0000.pcie: Adding to iommu group 11
[ 6.842568] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 6.849504] tegra194-pcie 141a0000.pcie: Failed to get slot regulators: -517
[ 6.874670] tegra-soc-hwpm f100000.tegra_soc_hwpm: Adding to iommu group 12
[ 6.885095] host1x 13e40000.host1x: Adding to iommu group 13
[ 7.908410] t23x_init_gating_regs: Timed out waiting for syncpt ram init!
[ 7.908749] random: crng init done
[ 7.927326] host1x 13e40000.host1x: initialized
[ 7.932357] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu group 14
[ 7.940558] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (streamid=53, iommu=smmu.0x0000000012000000)
[ 7.952528] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu group 15
[ 7.960624] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (streamid=54, iommu=smmu.0x0000000012000000)
[ 7.972604] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu group 16
[ 7.980678] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (streamid=55, iommu=smmu.0x0000000012000000)
[ 7.992639] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu group 17
[ 8.000746] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[ 8.012702] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu group 18
[ 8.020789] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[ 8.032779] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu group 19
[ 8.040880] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[ 8.052862] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu group 20
[ 8.060959] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[ 8.072933] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu group 21
[ 8.081043] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[ 8.093022] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu group 22
[ 8.101131] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (streamid=53, iommu=smmu.0x0000000008000000)
[ 8.113114] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu group 23
[ 8.121239] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (streamid=54, iommu=smmu.0x0000000008000000)
[ 8.133213] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu group 24
[ 8.141282] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (streamid=55, iommu=smmu.0x0000000008000000)
[ 8.153227] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu group 25
[ 8.161306] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (streamid=56, iommu=smmu.0x0000000008000000)
[ 8.173291] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu group 26
[ 8.181424] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (streamid=57, iommu=smmu.0x0000000008000000)
[ 8.193381] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu group 27
[ 8.201486] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (streamid=58, iommu=smmu.0x0000000008000000)
[ 8.213459] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu group 28
[ 8.221606] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (streamid=59, iommu=smmu.0x0000000008000000)
[ 8.233592] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu group 29
[ 8.241711] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (streamid=60, iommu=smmu.0x0000000008000000)
[ 8.253694] falcon 15340000.vic: Adding to iommu group 30
[ 8.268916] falcon 15340000.vic: initialized
[ 8.273621] falcon 15380000.nvjpg: Adding to iommu group 31
[ 8.285032] falcon 15380000.nvjpg: initialized
[ 8.289747] falcon 15540000.nvjpg1: Adding to iommu group 32
[ 8.300927] falcon 15540000.nvjpg1: initialized
[ 8.305727] falcon 154c0000.nvenc: Adding to iommu group 33
[ 8.317307] falcon 154c0000.nvenc: initialized
[ 8.322024] falcon 15a50000.ofa: Adding to iommu group 34
[ 8.331553] falcon 15a50000.ofa: initialized
[ 8.336075] nvdec 15480000.nvdec: Adding to iommu group 35
[ 8.348072] nvdec 15480000.nvdec: initialized
[ 8.352682] tsec 15500000.tsec: Adding to iommu group 36
[ 8.363571] tsec 15500000.tsec: initialized
[ 8.371063] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 8.387557] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 8.402679] gpio-394 (camera-control-output-low): hogged as output/low
[ 8.409440] gpio-397 (camera-control-output-low): hogged as output/low
[ 8.416186] gpio-487 (camera-control-output-low): hogged as output/low
[ 8.422926] gpio-486 (camera-control-output-low): hogged as output/low
[ 8.430629] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio
[ 8.438332] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon
[ 8.445350] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 8.452550] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 8.460117] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 8.466631] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 8.474802] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 8.483366] tegra194-isp5 14800000.isp: Adding to iommu group 37
[ 8.492493] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[ 8.502095] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized
[ 8.508653] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group 38
[ 8.516870] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group 39
[ 8.524962] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: context isolation disabled due to no IOMMU
[ 8.534933] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized
[ 8.541736] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: context isolation disabled due to no IOMMU
[ 8.551719] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized
[ 8.558503] scare-pigeon 13e40000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[ 8.568806] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized
[ 8.575749] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: Adding to iommu group 40
[ 8.584508] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: initialized (streamid=18, iommu=smmu.0x0000000008000000)
[ 8.595884] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: Adding to iommu group 41
[ 8.604588] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: initialized (streamid=19, iommu=smmu.0x0000000008000000)
[ 8.615960] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: Adding to iommu group 42
[ 8.624688] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: initialized (streamid=20, iommu=smmu.0x0000000008000000)
[ 8.636028] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: Adding to iommu group 43
[ 8.644796] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: initialized (streamid=21, iommu=smmu.0x0000000008000000)
[ 8.656155] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: Adding to iommu group 44
[ 8.664887] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: initialized (streamid=22, iommu=smmu.0x0000000008000000)
[ 8.676229] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: Adding to iommu group 45
[ 8.684933] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: initialized (streamid=23, iommu=smmu.0x0000000008000000)
[ 8.696278] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: Adding to iommu group 46
[ 8.704993] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: initialized (streamid=24, iommu=smmu.0x0000000008000000)
[ 8.716340] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: Adding to iommu group 47
[ 8.725051] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: initialized (streamid=25, iommu=smmu.0x0000000008000000)
[ 8.736430] pva 16000000.pva0: Adding to iommu group 48
[ 8.763844] pva 16000000.pva0: initialized
[ 8.776398] nvdla 15880000.nvdla0: Adding to iommu group 49
[ 8.792158] nvdla 15880000.nvdla0: initialized
[ 8.798482] nvdla 158c0000.nvdla1: Adding to iommu group 50
[ 8.813430] nvdla 158c0000.nvdla1: initialized
[ 8.819680] tegra-gpcdma 2600000.gpcdma: Adding to iommu group 2
[ 8.826769] tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels
[ 8.834301] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[ 8.840940] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[ 8.847685] serial-tegra 3100000.serial: Adding to iommu group 2
[ 8.854359] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 13, base_baud = 0) is a TEGRA_UART
[ 8.864041] serial-tegra 3110000.serial: Adding to iommu group 2
[ 8.870670] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 8.880309] serial-tegra 3130000.serial: Adding to iommu group 2
[ 8.886872] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 66, base_baud = 0) is a TEGRA_UART
[ 8.914381] tegra-xusb 3610000.xhci: Firmware timestamp: 2021-12-01 05:27:10 UTC, Version: 80.03 release
[ 8.924137] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 8.929716] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 8.938355] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000050810
[ 8.947960] tegra-xusb 3610000.xhci: irq 235, io mem 0x03610000
[ 8.954415] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 8.962913] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.970339] usb usb1: Product: xHCI Host Controller
[ 8.975358] usb usb1: Manufacturer: Linux 5.10.104 xhci-hcd
[ 8.981084] usb usb1: SerialNumber: 3610000.xhci
[ 8.986549] hub 1-0:1.0: USB hub found
[ 8.990438] hub 1-0:1.0: 4 ports detected
[ 8.994833] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 9.000392] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 9.008182] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 9.015689] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 9.024187] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 9.031623] usb usb2: Product: xHCI Host Controller
[ 9.036635] usb usb2: Manufacturer: Linux 5.10.104 xhci-hcd
[ 9.042364] usb usb2: SerialNumber: 3610000.xhci
[ 9.047584] hub 2-0:1.0: USB hub found
[ 9.051462] hub 2-0:1.0: 4 ports detected
[ 9.075951] tegra23x-oc-event soctherm-oc-event: Finished tegra23x overcurrent event probing
[ 9.098583] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 2010000 KHz, changing to: 2035200 KHz
[ 9.112820] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 2012000 KHz, changing to: 2035200 KHz
[ 9.127597] cpufreq: cpufreq_online: CPU8: Running at unlisted initial frequency: 2011000 KHz, changing to: 2035200 KHz
[ 9.140035] tegra194-cpufreq e000000.ccplex: probed with ICC
[ 9.148073] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 9.150962] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 9.155523] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[ 9.156110] mmc0: CQHCI version 5.10
[ 9.168609] irq: IRQ302: trimming hierarchy from :interrupt-controller@f400000-1
[ 9.170304] tegra194-pcie 14100000.pcie: IO 0x0030100000..0x00301fffff -> 0x0030100000
[ 9.177953] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 302
[ 9.184212] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit
[ 9.186601] tegra194-pcie 14100000.pcie: MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[ 9.209682] tegra194-pcie 14100000.pcie: MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[ 9.247382] usb 1-4: new high-speed USB device number 2 using tegra-xusb
[ 9.273371] mmc0: Command Queue Engine enabled
[ 9.277950] mmc0: periodic cache flush enabled
[ 9.282517] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 9.289537] mmcblk0: mmc0:0001 G1M15M 59.3 GiB
[ 9.294397] mmcblk0rpmb: mmc0:0001 G1M15M partition 3 4.00 MiB, chardev (511:0)
[ 9.311147] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[ 9.323237] tegra194-pcie 14100000.pcie: Link up
[ 9.329131] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[ 9.335951] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 9.341586] pci_bus 0001:00: root bus resource [io 0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[ 9.351433] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[ 9.362262] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[ 9.370186] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[ 9.376508] pci 0001:00:00.0: PME# supported from D0 D3hot
[ 9.386635] pci 0001:01:00.0: [17cb:1103] type 00 class 0x028000
[ 9.392994] pci 0001:01:00.0: reg 0x10: [mem 0x00000000-0x001fffff 64bit]
[ 9.401055] pci 0001:01:00.0: PME# supported from D0 D3hot D3cold
[ 9.407035] usb 1-4: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=60.90
[ 9.411669] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a81fffff]
[ 9.415753] usb 1-4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 9.415756] usb 1-4: Product: USB2.0 Hub
[ 9.423182] pci 0001:01:00.0: BAR 0: assigned [mem 0x20a8000000-0x20a81fffff 64bit]
[ 9.432616] hub 1-4:1.0: USB hub found
[ 9.434644] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 9.443255] hub 1-4:1.0: 4 ports detected
[ 9.446303] pci 0001:00:00.0: bridge window [mem 0x20a8000000-0x20a81fffff]
[ 9.463153] pci 0001:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 9.471895] pci 0001:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 9.480845] pcieport 0001:00:00.0: Adding to iommu group 9
[ 9.486753] pcieport 0001:00:00.0: PME: Signaling with IRQ 51
[ 9.493050] pcieport 0001:00:00.0: AER: enabled with IRQ 51
[ 9.499579] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 9.508114] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[ 9.515292] tegra194-pcie 14160000.pcie: IO 0x0036100000..0x00361fffff -> 0x0036100000
[ 9.523979] tegra194-pcie 14160000.pcie: MEM 0x2428000000..0x242fffffff -> 0x0040000000
[ 9.532656] tegra194-pcie 14160000.pcie: MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[ 9.747382] usb 1-4.1: new high-speed USB device number 3 using tegra-xusb
[ 9.871691] usb 1-4.1: New USB device found, idVendor=0b95, idProduct=772b, bcdDevice= 0.01
[ 9.880282] usb 1-4.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 9.887795] usb 1-4.1: Product: AX88772B
[ 9.891823] usb 1-4.1: Manufacturer: ASIX Elec. Corp.
[ 9.897014] usb 1-4.1: SerialNumber: 00332C
[ 10.339268] asix 1-4.1:1.0 eth0: register 'asix' at usb-3610000.xhci-4.1, ASIX AX88772B USB 2.0 Ethernet, 00:0e:c6:f1:d3:db
[ 10.648857] tegra194-pcie 14160000.pcie: Phy link never came up
[ 10.655020] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 10.661829] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 10.667464] pci_bus 0004:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[ 10.677561] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[ 10.688394] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[ 10.696315] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[ 10.702653] pci 0004:00:00.0: PME# supported from D0 D3hot
[ 10.716184] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 10.721583] pci 0004:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 10.730520] pcieport 0004:00:00.0: Adding to iommu group 10
[ 10.736503] pcieport 0004:00:00.0: PME: Signaling with IRQ 53
[ 10.742807] pcieport 0004:00:00.0: AER: enabled with IRQ 53
[ 10.748767] pci_bus 0004:01: busn_res: [bus 01-ff] is released
[ 10.754852] pci 0004:00:00.0: Removing from iommu group 10
[ 10.760503] pci_bus 0004:00: busn_res: [bus 00-ff] is released
[ 10.767935] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 10.774503] tegra194-pcie 141a0000.pcie: Failed to get slot regulators: -517
[ 10.774604] vdd-3v3-pcie: supplied by vdd-3v3-sys
[ 10.779640] avdd-cam-2v8: supplied by vdd-3v3-sys
[ 10.784563] vdd-dp: supplied by vdd-3v3-sys
[ 10.789015] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 10.793956] dsi-vdd-1v8-bl-en: supplied by vdd-1v8-sys
[ 10.800973] tegra194-isp5 14800000.isp: initialized
[ 10.809788] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized
[ 10.816236] (NULL device *): fops function table already registered
[ 10.824550] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized
[ 10.831550] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 10.831596] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 10.846527] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 302
[ 10.953056] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[ 10.960236] tegra194-pcie 141a0000.pcie: IO 0x003a100000..0x003a1fffff -> 0x003a100000
[ 10.968924] tegra194-pcie 141a0000.pcie: MEM 0x2b28000000..0x2b2fffffff -> 0x0040000000
[ 10.977591] tegra194-pcie 141a0000.pcie: MEM 0x2740000000..0x2b27ffffff -> 0x2740000000
[ 11.886618] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit
[ 12.096850] tegra194-pcie 141a0000.pcie: Phy link never came up
[ 12.103009] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[ 12.109826] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 12.115458] pci_bus 0005:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x3a100000-0x3a1fffff])
[ 12.125572] pci_bus 0005:00: root bus resource [mem 0x2b28000000-0x2b2fffffff] (bus address [0x40000000-0x47ffffff])
[ 12.136399] pci_bus 0005:00: root bus resource [mem 0x2740000000-0x2b27ffffff pref]
[ 12.144317] pci 0005:00:00.0: [10de:229a] type 01 class 0x060400
[ 12.150652] pci 0005:00:00.0: PME# supported from D0 D3hot
[ 12.164154] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 12.169544] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 12.178487] pcieport 0005:00:00.0: Adding to iommu group 11
[ 12.184456] pcieport 0005:00:00.0: PME: Signaling with IRQ 55
[ 12.190766] pcieport 0005:00:00.0: AER: enabled with IRQ 55
[ 12.196715] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[ 12.202795] pci 0005:00:00.0: Removing from iommu group 11
[ 12.208440] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[ 12.216303] nvethernet 6810000.ethernet: Adding to iommu group 51
[ 12.222908] nvethernet 6810000.ethernet: failed to read skip mac reset flag, default 0
[ 12.231059] nvethernet 6810000.ethernet: failed to read MDIO address
[ 12.237592] nvethernet 6810000.ethernet: setting to default DMA bit mask
[ 12.244506] nvethernet 6810000.ethernet: Failed to read DMA Tx ring size, using default [4096]
[ 12.253369] nvethernet 6810000.ethernet: Failed to read DMA Tx ring size, using default [4096]
[ 12.262222] nvethernet 6810000.ethernet: failed to read UPHY GBE mode- default to 10G
[ 12.664018] nvethernet 6810000.ethernet: Ethernet MAC address: 00:0e:c6:f1:d3:db
[ 12.671683] -->macsec_probe()
[ 12.671700] -->macsec_get_platform_res()
[ 12.671722] <--macsec_get_platform_res()
[ 12.671723] -->macsec_enable_car()
[ 12.672246] <--macsec_enable_car()
[ 12.672264] <--macsec_probe()
[ 12.672266] nvethernet 6810000.ethernet: Macsec not enabled
[ 12.677998] nvethernet 6810000.ethernet: Macsec: Reduced MTU: 1466 Max: 16383
[ 12.688967] nvethernet 6810000.ethernet: eth1 (HW ver: 31) created with 10 DMA channels
[ 12.697690] irq: IRQ304: trimming hierarchy from :pmc@c360000
[ 12.703662] irq: IRQ305: trimming hierarchy from :interrupt-controller@f400000-1
[ 12.711342] irq: IRQ306: trimming hierarchy from :pmc@c360000
[ 12.717322] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 12.724902] tegra-se-nvhost 15810000.se: Adding to iommu group 52
[ 12.731649] tegra-se-nvhost 15810000.se: initialized
[ 12.750564] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 12.756931] tegra-se-nvhost 15820000.se: Adding to iommu group 53
[ 12.763506] tegra-se-nvhost 15820000.se: initialized
[ 12.770763] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 12.777127] tegra-se-nvhost 15840000.se: Adding to iommu group 54
[ 12.783674] tegra-se-nvhost 15840000.se: initialized
[ 12.792519] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 12.799375] tegra_actmon d230000.actmon: in actmon_register()...
[ 12.805696] tegra_actmon d230000.actmon: bwmgr_disable = 1
[ 12.811822] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[ 12.820193] hvc_sysfs: hypervisor is not present
[ 12.943360] mmc1: new ultra high speed SDR104 SDHC card at address 59b4
[ 12.950671] mmcblk1: mmc1:59b4 SD 14.7 GiB
[ 12.962016] ALSA device list:
[ 12.965080] No soundcards found.
[ 12.969164] Freeing unused kernel memory: 3968K
[ 12.973864] Run /init as init process
[ 12.977627] with arguments:
[ 12.977628] /init
[ 12.977629] with environment:
[ 12.977630] HOME=/
[ 12.977630] TERM=linux
[ 12.977631] mminit_loglevel=4
[ 12.989340] Root device found: mmcblk0p1
[ 12.993861] Found dev node: /dev/mmcblk0p1
[ 13.023147] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 13.032266] Rootfs mounted over mmcblk0p1
[ 13.052437] Switching from initrd to actual rootfs
[ 13.168879] systemd[1]: System time before build time, advancing clock.
[ 13.234265] systemd[1]: systemd 245.4-4ubuntu3.19 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 13.257914] systemd[1]: Detected architecture arm64.
[ 13.291958] systemd[1]: Set hostname to <tegra-ubuntu>.
[ 13.479671] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 13.492706] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 13.502263] systemd[1]: Created slice system-modprobe.slice.
[ 13.508466] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 13.515184] systemd[1]: Created slice User and Session Slice.
[ 13.521248] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 13.529305] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 13.539061] systemd[1]: Reached target User and Group Name Lookups.
[ 13.545579] systemd[1]: Reached target Slices.
[ 13.550201] systemd[1]: Reached target Swap.
[ 13.554857] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 13.561731] systemd[1]: Listening on Syslog Socket.
[ 13.566904] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 13.573905] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 13.580848] systemd[1]: Listening on Journal Audit Socket.
[ 13.586621] systemd[1]: Listening on Journal Socket (/dev/log).
[ 13.592862] systemd[1]: Listening on Journal Socket.
[ 13.598123] systemd[1]: Listening on udev Control Socket.
[ 13.603794] systemd[1]: Listening on udev Kernel Socket.
[ 13.610280] systemd[1]: Mounting Huge Pages File System...
[ 13.617002] systemd[1]: Mounting POSIX Message Queue File System...
[ 13.624349] systemd[1]: Mounting RPC Pipe File System...
[ 13.630742] systemd[1]: Mounting Kernel Debug File System...
[ 13.637524] systemd[1]: Mounting Kernel Trace File System...
[ 13.644587] systemd[1]: Starting Journal Service...
[ 13.656957] systemd[1]: Starting Set the console keyboard layout...
[ 13.664365] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 13.674480] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[ 13.681737] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[ 13.691216] systemd[1]: Starting Load Kernel Module efi_pstore...
[ 13.698642] systemd[1]: Starting Load Kernel Module pstore_blk...
[ 13.706073] systemd[1]: Starting Load Kernel Module pstore_zone...
[ 13.713479] systemd[1]: Starting Load Kernel Module ramoops...
[ 13.720462] systemd[1]: Starting NVIDIA specific first-boot udev script...
[ 13.728514] systemd[1]: Started Nameserver information manager.
[ 13.734805] systemd[1]: Reached target Network (Pre).
[ 13.740769] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 13.750162] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 13.767915] systemd[1]: Starting Load Kernel Modules...
[ 13.774245] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 13.779832] mmc1: Data end bit error
[ 13.784823] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 13.784826] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00000505
[ 13.784829] mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 13.784831] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x0000003b
[ 13.811281] mmc1: sdhci: Present: 0x010b0000 | Host ctl: 0x0000001b
[ 13.811284] mmc1: sdhci: Power: 0x00000001 | Blk gap: 0x00000000
[ 13.824502] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 13.824504] mmc1: sdhci: Timeout: 0x0000000e | Int stat: 0x00000000
[ 13.824506] mmc1: sdhci: Int enab: 0x03ff000b | Sig enab: 0x03fc000b
[ 13.824508] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 13.850955] mmc1: sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18002f73
[ 13.850957] mmc1: sdhci: Cmd: 0x0000123a | Max curr: 0x00000000
[ 13.864181] mmc1: sdhci: Resp[0]: 0x00000900 | Resp[1]: 0x04804b92
[ 13.864184] mmc1: sdhci: Resp[2]: 0x374b8040 | Resp[3]: 0x00000240
[ 13.877404] mmc1: sdhci: Host ctl2: 0x0000000b
[ 13.877407] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000007ffffff20c
[ 13.883054] systemd[1]: Starting udev Coldplug all Devices...
[ 13.889321] mmc1: sdhci: ============================================
[ 13.903535] systemd[1]: Started Journal Service.
[ 13.903824] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 13.957383] systemd-journald[309]: Received client request to flush runtime journal.
[ 13.985136] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 13.991981] tegra-carveouts tegra-carveouts: fsi :dma coherent mem declare 0x0000000833000000,16777216
[ 14.001580] tegra-carveouts tegra-carveouts: assigned reserved memory node fsi-carveout
[ 14.001587] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x0000000849800000,914358272
[ 14.019479] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 14.027744] nvmap_page_pool_init: Total RAM pages: 7830784
[ 14.027745] nvmap_page_pool_init: nvmap page pool size: 978848 pages (3823 MB)
[ 14.027783] nvmap_background_zero_thread: PP zeroing thread starting.
[ 14.027869] misc nvmap: created heap vpr base 0x0000000849800000 size (892928KiB)
[ 14.030809] misc nvmap: created heap fsi base 0x0000000833000000 size (16384KiB)
[ 14.032207] mmc1: Tuning failed, falling back to fixed sampling clock
[ 14.032406] sdhci-tegra 3400000.sdhci: error -110 requesting status
[ 15.501392] spi-tegra114 3210000.spi: Adding to iommu group 2
[ 15.516695] spi-tegra114 3230000.spi: Adding to iommu group 2
[ 15.529622] cpu-throttle-alert cooling device registered.
[ 15.535741] gpu-throttle-alert cooling device registered.
[ 15.537833] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 16 channels
[ 15.542953] cv0-throttle-alert cooling device registered.
[ 15.555069] cv1-throttle-alert cooling device registered.
[ 15.561432] cv2-throttle-alert cooling device registered.
[ 15.567519] soc0-throttle-alert cooling device registered.
[ 15.573683] soc1-throttle-alert cooling device registered.
[ 15.579680] soc2-throttle-alert cooling device registered.
[ 15.586104] irq: IRQ307: trimming hierarchy from :pmc@c360000
[ 15.587145] hot-surface-alert cooling device registered.
[ 15.607183] irq: IRQ308: trimming hierarchy from :pmc@c360000
[ 15.613262] nct1008_nct72 4-004c: starting parse dt
[ 15.618587] nct1008_nct72 4-004c: !!!Found deprecated property!!!
[ 15.624989] nct1008_nct72 4-004c: success parsing dt
[ 15.630271] nct1008_nct72 4-004c: success in enabling tmp451 VDD rail
[ 15.673386] nct1008_nct72 4-004c: LOC shutdown limit 107
[ 15.680110] nct1008_nct72 4-004c: EXT shutdown limit 107
[ 15.722573] nct1008_nct72 4-004c: initial LOC temp: 44000
[ 15.728734] nct1008_nct72 4-004c: initial EXT temp: 46000
[ 15.735639] nct1008_nct72 4-004c: hi_b:-4, lo_b:0
[ 15.741226] nct1008_nct72 4-004c: nct1008_probe: initialized
[ 15.805822] nvadsp 2993000.adsp: Adding to iommu group 55
[ 15.811570] nvadsp 2993000.adsp: in probe()...
[ 15.816880] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ 15.929012] tegra-hda 3510000.hda: Adding to iommu group 56
[ 15.951497] sdhci-tegra 3400000.sdhci: error -84 requesting status
[ 15.958001] mmcblk1: recovery failed!
[ 15.961845] blk_update_request: I/O error, dev mmcblk1, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 15.962388] tegra-asoc: sound: Adding to iommu group 55
[ 15.972382] Buffer I/O error on dev mmcblk1, logical block 0, async page read
[ 15.972627] irq: IRQ310: trimming hierarchy from :pmc@c360000
[ 15.992047] ucsi_ccg 1-0008: i2c_transfer failed -121
[ 15.997264] ucsi_ccg 1-0008: ucsi_ccg_init failed - -121
[ 16.003554] tegra210-adsp aconnect@2a41000:adsp_audio: Adding to iommu group 55
[ 16.004112] ucsi_ccg: probe of 1-0008 failed with error -121
[ 16.011112] tegra210_adsp_audio_probe: platform probe started
[ 16.011446] tegra210-adsp tegra210-adsp: Default param-type to BYTE for mp3-dec1
[ 16.030903] tegra210-adsp tegra210-adsp: Default param-type to BYTE for spkprot
[ 16.033743] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=3 as /devices/platform/3510000.hda/sound/card0/input1
[ 16.038687] tegra210-adsp tegra210-adsp: Default param-type to BYTE for src
[ 16.049096] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=7 as /devices/platform/3510000.hda/sound/card0/input2
[ 16.056360] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aac-dec1
[ 16.066616] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=8 as /devices/platform/3510000.hda/sound/card0/input3
[ 16.074380] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aec
[ 16.084776] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=9 as /devices/platform/3510000.hda/sound/card0/input4
[ 16.091992] tegra210-adsp tegra210-adsp: Default param-type to BYTE for wire
[ 16.109392] tegra210-adsp tegra210-adsp: adma channel page address dt entry not found
[ 16.109394] tegra210-adsp tegra210-adsp: using adma channel page 0
[ 16.109484] nvadsp 2993000.adsp: ADSP OS firmware already loaded
[ 16.126291] cryptd: max_cpu_qlen set to 1000
[ 16.454096] tegra210-adsp tegra210-adsp: Loaded app wire
[ 16.459581] tegra210-adsp tegra210-adsp: Loaded app apm
[ 16.464958] tegra210-adsp tegra210-adsp: Loaded app adma
[ 16.470432] tegra210-adsp tegra210-adsp: Loaded app adma_tx
[ 16.476316] nvadsp_set_adma_dump_reg: callback for adma reg dump is sent to 00000000e088ecbf
[ 16.511532] tegra210-adsp tegra210-adsp: Tegra210 ADSP driver successfully registered
[ 16.680324] input: NVIDIA Jetson AGX Orin APE Headset Jack as /devices/platform/sound/sound/card1/input5
[ 16.783834] mmc1: Data end bit error
[ 16.787528] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 16.794154] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00000505
[ 16.800785] mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 16.807419] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x0000003b
[ 16.814030] mmc1: sdhci: Present: 0x010b0000 | Host ctl: 0x0000001b
[ 16.820661] mmc1: sdhci: Power: 0x00000001 | Blk gap: 0x00000000
[ 16.827291] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 16.833920] mmc1: sdhci: Timeout: 0x0000000e | Int stat: 0x00000000
[ 16.840549] mmc1: sdhci: Int enab: 0x03ff000b | Sig enab: 0x03fc000b
[ 16.847178] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 16.853807] mmc1: sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18002f73
[ 16.860441] mmc1: sdhci: Cmd: 0x0000123a | Max curr: 0x00000000
[ 16.867071] mmc1: sdhci: Resp[0]: 0x00000900 | Resp[1]: 0x04804b92
[ 16.873702] mmc1: sdhci: Resp[2]: 0x1fcb8040 | Resp[3]: 0x00000480
[ 16.880330] mmc1: sdhci: Host ctl2: 0x0000000b
[ 16.884901] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000007ffffff20c
[ 16.892257] mmc1: sdhci: ============================================
[ 17.028931] mmc1: Tuning failed, falling back to fixed sampling clock
[ 17.035759] sdhci-tegra 3400000.sdhci: error -110 requesting status
[ 17.042195] mmcblk1: recovery failed!
[ 17.045990] blk_update_request: I/O error, dev mmcblk1, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 17.056475] Buffer I/O error on dev mmcblk1, logical block 0, async page read
[ 17.063835] mmcblk1: unable to read partition table
[ 17.201662] mmc1: Tuning failed, falling back to fixed sampling clock
[ 17.312793] nvgpu: 17000000.ga10b nvgpu_nvhost_syncpt_init:135 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[ 17.338359] mmc1: Tuning failed, falling back to fixed sampling clock
[ 17.345193] sdhci-tegra 3400000.sdhci: error -110 requesting status
[ 17.351659] mmcblk1: recovery failed!
[ 17.355483] blk_update_request: I/O error, dev mmcblk1, sector 30865280 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
[ 17.479871] using random self ethernet address
[ 17.484502] using random host ethernet address
[ 17.497169] mmc1: Tuning failed, falling back to fixed sampling clock
[ 17.497390] sdhci-tegra 3400000.sdhci: error -110 requesting status
[ 17.503873] mmcblk1: recovery failed!
[ 17.507707] blk_update_request: I/O error, dev mmcblk1, sector 30865280 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 17.518841] Buffer I/O error on dev mmcblk1, logical block 3858160, async page read
[ 18.051956] loop: module loaded
[ 18.081823] pstore: Using crash dump compression: deflate
[ 18.081860] printk: console [ramoops-1] enabled
[ 18.081862] pstore: Registered ramoops as persistent store backend
[ 18.081864] ramoops: using 0x200000@0x82e800000, ecc: 0
[ 18.222126] asix 1-4.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC5E1
[ 18.319328] Mass Storage Function, version: 2009/09/11
[ 18.319336] LUN: removable file: (no medium)
[ 18.321924] using random self ethernet address
[ 18.326528] using random host ethernet address
[ 18.331863] CPU8: shutdown
[ 18.334680] psci: CPU8 killed (polled 0 ms)
[ 18.531990] CPU9: shutdown
[ 18.534857] psci: CPU9 killed (polled 0 ms)
[ 18.645340] CPU10: shutdown
[ 18.648629] psci: CPU10 killed (polled 0 ms)
[ 18.734127] IRQ 122: no longer affine to CPU11
[ 18.739476] CPU11: shutdown
[ 18.742653] psci: CPU11 killed (polled 0 ms)
[ 18.748065] nvgpu: 17000000.ga10b tpc_pg_mask_store:1067 [INFO] no value change, same mask already set
[ 18.909391] nvgpu: 17000000.ga10b gk20a_scale_init:539 [INFO] enabled scaling for GPU
[ 20.117694] zram: Added device: zram0
[ 20.117907] zram: Added device: zram1
[ 20.118085] zram: Added device: zram2
[ 20.118248] zram: Added device: zram3
[ 20.118471] zram: Added device: zram4
[ 20.118618] zram: Added device: zram5
[ 20.118857] zram: Added device: zram6
[ 20.119031] zram: Added device: zram7
[ 20.157634] zram0: detected capacity change from 0 to 2004680704
[ 20.211336] Adding 1957692k swap on /dev/zram0. Priority:5 extents:1 across:1957692k SS
[ 20.214400] zram1: detected capacity change from 0 to 2004680704
[ 20.255321] Adding 1957692k swap on /dev/zram1. Priority:5 extents:1 across:1957692k SS
[ 20.257355] zram2: detected capacity change from 0 to 2004680704
[ 20.299318] Adding 1957692k swap on /dev/zram2. Priority:5 extents:1 across:1957692k SS
[ 20.301516] zram3: detected capacity change from 0 to 2004680704
[ 20.339367] Adding 1957692k swap on /dev/zram3. Priority:5 extents:1 across:1957692k SS
[ 20.341355] zram4: detected capacity change from 0 to 2004680704
[ 20.395427] Adding 1957692k swap on /dev/zram4. Priority:5 extents:1 across:1957692k SS
[ 20.397677] zram5: detected capacity change from 0 to 2004680704
[ 20.439479] Adding 1957692k swap on /dev/zram5. Priority:5 extents:1 across:1957692k SS
[ 20.441525] zram6: detected capacity change from 0 to 2004680704
[ 20.471298] Adding 1957692k swap on /dev/zram6. Priority:5 extents:1 across:1957692k SS
[ 20.473330] zram7: detected capacity change from 0 to 2004680704
[ 20.519263] Adding 1957692k swap on /dev/zram7. Priority:5 extents:1 across:1957692k SS
[ 20.951726] fuse: init (API version 7.32)
[ 30.707253] net eth1: failed to poll MAC Software reset
[ 30.718943] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 30.738743] rndis0: HOST MAC 2e:e8:c0:7c:9f:1c
[ 30.738750] rndis0: MAC 2e:e8:c0:7c:9f:1d
[ 30.739004] usb0: HOST MAC 2e:e8:c0:7c:9f:1e
[ 30.739007] usb0: MAC 2e:e8:c0:7c:9f:1f
[ 30.739967] tegra-xudc 3550000.xudc: EP 0 (type: ctrl, dir: out) enabled
[ 30.743358] l4tbr0: port 1(rndis0) entered blocking state
[ 30.743376] l4tbr0: port 1(rndis0) entered disabled state
[ 30.743682] device rndis0 entered promiscuous mode
[ 30.757358] l4tbr0: port 2(usb0) entered blocking state
[ 30.757370] l4tbr0: port 2(usb0) entered disabled state
[ 30.757710] device usb0 entered promiscuous mode
Any help would be appreciated.
Thank you.
