WiFi through PCIe is not working in Jetpack 4.6
Hi, I recently migrated to JetPack 4.6 from JetPack 4.4. I have built wifi driver as loadable kernel module. It was working in J4.4 but in J4.6, I am getting some PCIe errors and when I try to load the module I am getting the following error.
modprobe bcmdhd_pcie
modprobe: ERROR: could not insert 'bcmdhd_pcie': Operation not permitted
Dec 09 09:32:35 c2b5 kernel: dhd_module_init: in Dongle Host Driver, version 100.10.545.9 (r826445-20200316-8)
Dec 09 09:32:35 c2b5 kernel: ======== dhd_wlan_init_plat_data ========
Dec 09 09:32:35 c2b5 kernel: dhd_wlan_init_gpio: WL_REG_ON=-1
Dec 09 09:32:35 c2b5 kernel: dhd_wifi_platform_load: Enter
Dec 09 09:32:35 c2b5 kernel: dhdpcie_pci_probe : no mutex held. set lock
Dec 09 09:32:35 c2b5 kernel: PCI_PROBE:  bus 1, slot 0,vendor 14E4, device 43EC(good PCI location)
Dec 09 09:32:35 c2b5 kernel: dhdpcie_init: found adapter info 'DHD generic adapter'
Dec 09 09:32:35 c2b5 kernel: dhdpcie_dongle_attach: si_attach failed!
Dec 09 09:32:35 c2b5 kernel: dhdpcie_bus_attach: dhdpcie_probe_attach failed
Dec 09 09:32:35 c2b5 kernel: dhdpcie_init:dhdpcie_bus_attach() failed
Dec 09 09:32:35 c2b5 kernel: dhdpcie_pci_probe: PCIe Enumeration failed
Dec 09 09:32:35 c2b5 kernel: dhdpcie_pci_probe : the lock is released.
Dec 09 09:32:35 c2b5 kernel: dhdpcie_bus_register: dhdpcie initialize failed.
Dec 09 09:32:35 c2b5 kernel: dhd_wifi_platform_load_pcie: pcie_register_driver failed
Dec 09 09:32:35 c2b5 kernel: unregister wifi platform drivers
Dec 09 09:32:35 c2b5 kernel: wifi_platform_bus_enumerate device present 0
Dec 09 09:32:35 c2b5 kernel: ======== Card detection to remove PCIE card! ========
Dec 09 09:32:35 c2b5 kernel: ======== dhd_wlan_deinit_plat_data ========
Dec 09 09:32:35 c2b5 kernel: dhd_module_init: Failed to load the driver, try cnt 0
Dec 09 09:32:35 c2b5 kernel: Error creating socket.
Dec 09 09:32:35 c2b5 kernel: dhd_module_init: Failed to load driver max retry reached**
Dec 09 09:32:35 c2b5 kernel: dhd_module_init: Exit err=-1
My module is available though
0004:00:00.0 PCI bridge: NVIDIA Corporation Device 1ad1 (rev a1)
0004:01:00.0 Ethernet controller: Intel Corporation Device 1531 (rev 03)
0005:00:00.0 PCI bridge: NVIDIA Corporation Device 1ad0 (rev a1)
0005:01:00.0 Network controller: Broadcom Inc. and subsidiaries BCM4356 802.11ac Wireless Network Adapter (rev 02)
Here is the bootlog,
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.140-tegra (sada@rapsodo-System-Product-Name) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Wed Dec 8 16:08:31 +08 2021
[    0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[    0.000000] OF: fdt:memory scan node memory, reg size 48,
[    0.000000] OF: fdt: - 80000000 ,  2c000000
[    0.000000] OF: fdt: - ac200000 ,  44600000
[    0.000000] OF: fdt: - 100000000 ,  180000000
[    0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options '')
[    0.000000] bootconsole [tegra_comb_uart0] enabled
[    0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb3_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[    0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[    0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
[    0.000000] cma: Reserved 64 MiB at 0x00000000c2000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] percpu: Embedded 25 pages/cpu @ffffffc1ffcf7000 s61656 r8192 d32552 u102400
[    0.000000] Speculative Store Bypass Disable mitigation not required
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 2000880
[    0.000000] Kernel command line: console=ttyTCU0,115200 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1    root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[    0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[    0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[    0.000000] log_buf_len min size: 32768 bytes
[    0.000000] log_buf_len: 262144 bytes
[    0.000000] early log buf free: 29084(88%)
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.000000] Memory: 7190256K/8130560K available (15294K kernel code, 2940K rwdata, 6732K rodata, 8576K init, 611K bss, 186640K reserved, 753664K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008f70000   ( 15296 KB)
[    0.000000]     .rodata : 0xffffff8008f70000 - 0xffffff8009610000   (  6784 KB)
[    0.000000]       .init : 0xffffff8009610000 - 0xffffff8009e70000   (  8576 KB)
[    0.000000]       .data : 0xffffff8009e70000 - 0xffffff800a14f008   (  2941 KB)
[    0.000000]        .bss : 0xffffff800a14f008 - 0xffffff800a1e7fbc   (   612 KB)
[    0.000000]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 KB)
[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
[    0.000000]               0xffffffbf00000000 - 0xffffffbf08000000   (   128 MB actual)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc200000000   (  8192 MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]  Build-time adjustment of leaf fanout to 64.
[    0.000000]  RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000006] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.008939] Console: colour dummy device 80x25
[    0.012710] console [tty0] enabled
[    0.016115] bootconsole [tegra_comb_uart0] disabled
▒▒WARNING: at platform/drivers/pg/pg-cv-t194.c:73
▒▒[    0.000000] Booting Linux on physical CPU 0x0
[    0.020846] kmemleak: Kernel memory leak detector disabled
[    0.020882] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[    0.020920] pid_max: default: 32768 minimum: 301
[    0.022020] Security Framework initialized
[    0.022575] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[    0.022626] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[    0.024156] ftrace: allocating 47178 entries in 185 pages
[    0.417847] sched-energy: Sched-energy-costs installed from DT
[    0.417887] ASID allocator initialised with 65536 entries
[    0.452445] tegra-id: chipid=21917.
[    0.452474] tegra-id: opt_subrevision=1.
[    0.452512] Tegra Revision: A02 SKU: 0xde CPU Process: 0 SoC Process: 0
[    0.452563] DTS File Name: /home/sada/Repositories/ingame_release/L4T_dev/kernel_src/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dts
[    0.452627] DTB Build time: Dec  8 2021 15:58:05
[    0.500543] CPU1: Booted secondary processor [4e0f0040]
[    0.532640] CPU2: Booted secondary processor [4e0f0040]
[    0.564714] CPU3: Booted secondary processor [4e0f0040]
[    0.597021] CPU4: Booted secondary processor [4e0f0040]
[    0.629058] CPU5: Booted secondary processor [4e0f0040]
[    0.629237] Brought up 6 CPUs
[    0.629464] SMP: Total of 6 processors activated.
[    0.629494] CPU features: detected feature: Privileged Access Never
[    0.629516] CPU features: detected feature: LSE atomic instructions
[    0.629558] CPU features: detected feature: User Access Override
[    0.629584] CPU features: detected feature: 32-bit EL0 Support
[    0.631108] CPU: All CPU(s) started at EL2
[    0.631230] alternatives: patching kernel code
[    0.637721] devtmpfs: initialized
[    0.675862] Initilizing CustomIPI irq domain
[    0.676175] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.676212] futex hash table entries: 2048 (order: 5, 131072 bytes)
[    0.685835] pinctrl core: initialized pinctrl subsystem
[    0.686087] OS set in device tree is not L4T.
[    0.686329] regulator-dummy: no parameters
[    0.686551] Initializing plugin-manager
[    0.686613] Plugin module not found
[    0.686660] Plugin-manager status disabled
[    0.687723] NET: Registered protocol family 16
[    0.701049] pstore: using zlib compression
[    0.702172] console [pstore-1] enabled
[    0.702194] pstore: Registered ramoops as persistent store backend
[    0.702215] ramoops: attached 0x200000@0xf0600000, ecc: 0/0
[    0.720186] cpuidle: using governor menu
[    0.721223] bpmp: waiting for handshake
[    0.721253] bpmp: handshake completed
[    0.721286] bpmp: synchronizing channels
[    0.721333] bpmp: channels synchronized
[    0.721355] bpmp: mail init ok
[    0.723974] t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
[    0.724242] t19x-arm-smmu 12000000.iommu: probing hardware configuration...
[    0.724271] t19x-arm-smmu 12000000.iommu: SMMUv2 with:
[    0.724298] t19x-arm-smmu 12000000.iommu:    stage 1 translation
[    0.724343] t19x-arm-smmu 12000000.iommu:    stage 2 translation
[    0.724365] t19x-arm-smmu 12000000.iommu:    nested translation
[    0.724392] t19x-arm-smmu 12000000.iommu:    stream matching with 128 register groups, mask 0x7f80
[    0.724445] t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[    0.724476] t19x-arm-smmu 12000000.iommu:    64 context banks (0 stage-2 only)
[    0.724519] t19x-arm-smmu 12000000.iommu:    Stage-1: 39-bit VA -> 48-bit IPA
[    0.724544] t19x-arm-smmu 12000000.iommu:    Stage-2: 39-bit IPA -> 48-bit PA
[    0.728063] vdso: 2 pages (1 code @ ffffff8008f77000, 1 data @ ffffff8009e74000)
[    0.728129] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.730563] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[    0.731858] tegra_aon_clk_init: ok
[    0.731897] Registering BPMP clocks...
[    0.732045] tegra_bpmp_clk_init: clock init ok (400 clks)
[    0.732751] Serial: AMBA PL011 UART driver
[    0.732946] tegra_powergate_init: DONE
[    0.733055] DTS File Name: /home/sada/Repositories/ingame_release/L4T_dev/kernel_src/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dts
[    0.733106] DTB Build time: Dec  8 2021 15:58:05
[    0.735833] Tegra reboot handler registered.
[    0.744268] iommu: Adding device 14160000.pcie to group 0
[    0.745039] iommu: Adding device 141a0000.pcie to group 1
[    0.746457] iommu: Adding device 2490000.ether_qos to group 2
[    0.747028] iommu: Adding device 3100000.serial to group 3
[    0.747594] iommu: Adding device 3110000.serial to group 4
[    0.748030] iommu: Adding device 3140000.serial to group 5
[    0.748846] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[    0.749232] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[    0.749279] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[    0.749305] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L1
[    0.749346] tegra-pmc: ### PMC reset status reg: 0x2d
[    0.749429] tegra-pmc: PMC Prod config success
[    0.749685] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[    0.749755] tegra-pmc c360000.pmc: IO padctrl driver initialized
[    0.750175] iommu: Adding device 3460000.sdhci to group 6
[    0.750757] iommu: Adding device 3440000.sdhci to group 7
[    0.751345] iommu: Adding device 3210000.spi to group 8
[    0.751809] iommu: Adding device 3230000.spi to group 9
[    0.752273] iommu: Adding device 3270000.spi to group 10
[    0.753683] iommu: Adding device 3160000.i2c to group 11
[    0.754167] iommu: Adding device c240000.i2c to group 12
[    0.754640] iommu: Adding device 3180000.i2c to group 13
[    0.755118] iommu: Adding device 3190000.i2c to group 14
[    0.755716] iommu: Adding device 31b0000.i2c to group 15
[    0.756183] iommu: Adding device 31c0000.i2c to group 16
[    0.756693] iommu: Adding device c250000.i2c to group 17
[    0.757147] iommu: Adding device 31e0000.i2c to group 18
[    0.757848] iommu: Adding device sound to group 19
[    0.758470] iommu: Adding device 3510000.hda to group 20
[    0.759094] iommu: Adding device bc00000.rtcpu to group 21
[    0.761113] iommu: Adding device 13e10000.host1x to group 22
[    0.761554] iommu: Adding device 13e10000.host1x:ctx0 to group 23
[    0.762010] iommu: Adding device 13e10000.host1x:ctx1 to group 24
[    0.762442] iommu: Adding device 13e10000.host1x:ctx2 to group 25
[    0.762946] iommu: Adding device 13e10000.host1x:ctx3 to group 26
[    0.763360] iommu: Adding device 13e10000.host1x:ctx4 to group 27
[    0.763791] iommu: Adding device 13e10000.host1x:ctx5 to group 28
[    0.764207] iommu: Adding device 13e10000.host1x:ctx6 to group 29
[    0.764683] iommu: Adding device 13e10000.host1x:ctx7 to group 30
[    0.765251] iommu: Adding device 15340000.vic to group 31
[    0.765696] iommu: Adding device 15380000.nvjpg to group 32
[    0.766033] iommu: Adding device 15500000.tsec to group 33
[    0.766366] iommu: Adding device 15100000.tsecb to group 34
[    0.766692] iommu: Adding device 15480000.nvdec to group 35
[    0.767023] iommu: Adding device 15140000.nvdec1 to group 36
[    0.767409] iommu: Adding device 154c0000.nvenc to group 37
[    0.767732] iommu: Adding device 15a80000.nvenc1 to group 38
[    0.768205] iommu: Adding device 15880000.nvdla0 to group 39
[    0.768812] iommu: Adding device 158c0000.nvdla1 to group 40
[    0.769485] iommu: Adding device 15210000.nvdisplay to group 41
[    0.773577] platform 15210000.nvdisplay: IOVA linear map 0x00000000c6000000(2a000000)
[    0.773680] t19x-arm-smmu: Adding 15210000.nvdisplay to ISO SMMU client
[    0.775953] iommu: Adding device 15c10000.vi to group 42
[    0.776194] t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
[    0.776829] iommu: Adding device 14800000.isp to group 43
[    0.777927] iommu: Adding device 16000000.pva0 to group 44
[    0.778560] iommu: Adding device 16800000.pva1 to group 45
[    0.779066] iommu: Adding device 15810000.se to group 46
[    0.779525] iommu: Adding device 15820000.se to group 47
[    0.779891] iommu: Adding device 15830000.se to group 48
[    0.780258] iommu: Adding device 15840000.se to group 49
[    0.780588] iommu: Adding device c1a0000.aon to group 50
[    0.782538] iommu: Adding device d000000.bpmp to group 51
[    0.782901] bpmp: ping status is 0
[    0.783060] bpmp d000000.bpmp: firmware tag is 57f8a77779f848bf2ecf21dabee5645f
[    0.786556] bpmp d000000.bpmp: probe ok
[    0.788321] tegra-reset 0.bpmp_reset: registered 190 resets.
[    0.788954] iommu: Adding device smmu_test to group 52
[    0.790283] mc: mapped MMIO address: 0xffffff800a5c0000 -> 0x2c10000
[    0.790339] mc: mapped MMIO address: 0xffffff800a5e0000 -> 0x2c20000
[    0.790392] mc: mapped MMIO address: 0xffffff800a7b0000 -> 0x2c30000
[    0.790440] mc: mapped MMIO address: 0xffffff800a7d0000 -> 0x2c40000
[    0.790496] mc: mapped MMIO address: 0xffffff800b010000 -> 0x2c50000
[    0.790542] mc: mapped MMIO address: 0xffffff800b030000 -> 0x2b80000
[    0.790588] mc: mapped MMIO address: 0xffffff800b050000 -> 0x2b90000
[    0.790634] mc: mapped MMIO address: 0xffffff800b070000 -> 0x2ba0000
[    0.790678] mc: mapped MMIO address: 0xffffff800b090000 -> 0x2bb0000
[    0.790722] mc: mapped MMIO address: 0xffffff800b0b0000 -> 0x1700000
[    0.790766] mc: mapped MMIO address: 0xffffff800b0d0000 -> 0x1710000
[    0.790809] mc: mapped MMIO address: 0xffffff800b0f0000 -> 0x1720000
[    0.790852] mc: mapped MMIO address: 0xffffff800b110000 -> 0x1730000
[    0.790896] mc: mapped MMIO address: 0xffffff800b130000 -> 0x1740000
[    0.790955] mc: mapped MMIO address: 0xffffff800b150000 -> 0x1750000
[    0.791004] mc: mapped MMIO address: 0xffffff800b170000 -> 0x1760000
[    0.791048] mc: mapped MMIO address: 0xffffff800b190000 -> 0x1770000
[    0.791162] mc-err: mcerr ops are set to t19x
[    0.798243] iommu: Adding device 2600000.dma to group 53
[    0.804832] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 224 lines on the chip
[    0.806185] GPIO line 339 (wifi-enable) hogged as output/high
[    0.806249] GPIO line 412 (camera-control-output-low) hogged as output/low
[    0.806303] GPIO line 413 (camera-control-output-low) hogged as output/low
[    0.806358] GPIO line 414 (camera-control-output-low) hogged as output/low
[    0.806672] gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpiochip0 (tegra-gpio)
[    0.814979] gpio gpiochip1: gpio-line-names specifies 21 line names but there are 40 lines on the chip
[    0.815086] GPIO line 253 (pex-refclk-sel-low) hogged as output/low
[    0.815141] GPIO line 266 (w-disable1) hogged as output/high
[    0.815191] GPIO line 264 (w-disable2) hogged as output/high
[    0.815525] gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpiochip1 (tegra-gpio-aon)
[    0.818266] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[    0.818295] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[    0.819188] iommu: Adding device 3550000.xudc to group 54
[    0.819917] iommu: Adding device 3610000.xhci to group 55
[    0.822301] arm64_ras arm64_ras: probed
[    0.822739] ras_fhi_enable: FHI 469 enabled on CPU0
[    0.822801] ras_fhi_enable: FHI 470 enabled on CPU1
[    0.822892] ras_fhi_enable: FHI 471 enabled on CPU2
[    0.822992] ras_fhi_enable: FHI 472 enabled on CPU3
[    0.823099] ras_fhi_enable: FHI 473 enabled on CPU4
[    0.823270] ras_fhi_enable: FHI 474 enabled on CPU5
[    0.823501] carmel_ras_enable: RAS enabled on cpu0
[    0.823696] carmel_ras_enable: RAS enabled on cpu1
[    0.823926] carmel_ras_enable: RAS enabled on cpu2
[    0.824140] carmel_ras_enable: RAS enabled on cpu3
[    0.824365] carmel_ras_enable: RAS enabled on cpu4
[    0.824603] carmel_ras_enable: RAS enabled on cpu5
[    0.824706] carmel_ras carmel_ras: probed
[    0.826306] tegra-cbb 2300000.cbb-noc: noc_secure_irq = 478, noc_nonsecure_irq = 477>
[    0.826966] tegra-cbb c600000.aon-noc: noc_secure_irq = 480, noc_nonsecure_irq = 479>
[    0.828202] tegra-cbb d600000.bpmp-noc: noc_secure_irq = 482, noc_nonsecure_irq = 481>
[    0.829534] tegra-cbb be00000.rce-noc: noc_secure_irq = 484, noc_nonsecure_irq = 483>
[    0.830923] tegra-cbb b600000.sce-noc: noc_secure_irq = 486, noc_nonsecure_irq = 485>
[    0.831463] tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
[    0.832955] vdd-ac-bat: 5000 mV
[    0.833455] vdd-sdmmc1-sw: 3300 mV
[    0.833827] vdd-1v8-sd: 1800 mV
[    0.834180] vdd-3v3-cvb: 3300 mV
[    0.834531] vdd-1v8-cvb: 1800 mV
[    0.834951] vdd-epb-1v0: supplied by vdd-3v3-cvb
[    0.835014] vdd-epb-1v0: 1000 mV
[    0.835453] avdd-cam-2v8: 2800 mV
[    0.835873] vdd-fan: 5000 mV
[    0.836218] vdd-hdmi-5v0: 5000 mV
[    0.836561] vdd_sys_en: 1200 mV
[    0.870683] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.875297] eventlib_kernel: keventlib is initialized, test id: 0
[    0.875623] SCSI subsystem initialized
[    0.876200] usbcore: registered new interface driver usbfs
[    0.876288] usbcore: registered new interface driver hub
[    0.876407] usbcore: registered new device driver usb
[    0.889806] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
[    0.892971] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[    0.901485] vdd-1v0: at 1000 mV
[    0.909541] vdd-1v8-hs: at 1800 mV
[    0.917562] vdd-1v8-ls: at 1800 mV
[    0.925588] vdd-1v8-ao: at 1800 mV
[    0.933593] vddio-ddr-1v1: at 1100 mV
[    0.941377] vdd-rtc: at 800 mV
[    0.942452] spmic-ldo1: at 2375 mV
[    0.950051] vdd-ao-3v3: at 3300 mV
[    0.958084] vddio-emmc-3v3: at 3300 mV
[    0.959217] spmic-ldo4: at 1587 mV
[    0.966126] vdd-usb-3v3: at 3300 mV
[    0.974183] vddio-sdmmc1-3v3: at 3300 mV
[    0.978200] vdd-csi-1v2: at 1200 mV
[    0.979334] spmic-ldo8: at 1800 mV
[    0.983761] GPIO line 246 (gpio_default) hogged as output/high
[    0.984756] GPIO line 247 (gpio_default) hogged as output/high
[    0.985191] gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpiochip2 (max77620-gpio)
[    0.985577] max77620 4-003c: max77620 probe successful
[    0.986286] media: Linux media interface: v0.10
[    0.986409] Linux video capture interface: v2.00
[    0.988208] pps_core: LinuxPPS API ver. 1 registered
[    0.988234] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.988333] PTP clock support registered
[    0.988756] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[    0.989278] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[    0.989345] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[    0.991970] trusty trusty: trusty version: Built: 21:16:17 Jun 25 2020
[    0.992058] trusty trusty: selected api version: 3 (requested 3)
[    0.993202] Advanced Linux Sound Architecture Driver Initialized.
[    0.993755] Bluetooth: Core ver 2.22
[    0.993835] NET: Registered protocol family 31
[    0.993857] Bluetooth: HCI device and connection manager initialized
[    0.993888] Bluetooth: HCI socket layer initialized
[    0.993915] Bluetooth: L2CAP socket layer initialized
[    0.993981] Bluetooth: SCO socket layer initialized
[    0.996690] camchar: rtcpu character device driver loaded
[    0.997267] gpio tegra-gpio wake61 for gpio=201(Z:1)
[    0.997413] extcon-gpio-states external-connection:extcon@1: Cable state:0, cable id:0
[    0.998415] clocksource: Switched to clocksource arch_sys_counter
[    1.049839] VFS: Disk quotas dquot_6.6.0
[    1.050038] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.050465] nvmap_heap_init: nvmap_heap_init: created heap block cache
[    1.052212] tegra-carveouts tegra-carveouts: assigned reserved memory node grid-of-semaphores
[    1.052333] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000c6000000, size=0x2a000000
[    1.052645] cma: enabled page replacement for spfn=c6000, epfn=f0000
[    1.052686] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[    1.052723] nvmap: nvmap_select_cache_ops() nvmap cache ops set to scf
[    1.052768] nvmap_page_pool_init: Total RAM pages: 1985980
[    1.052809] nvmap_page_pool_init: nvmap page pool size: 248247 pages (969 MB)
[    1.053541] nvmap_background_zero_thread: PP zeroing thread starting.
[    1.053698] misc nvmap: created heap vpr base 0x00000000c6000000 size (688128KiB)
[    1.055249] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[    1.069706] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[    1.070061] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[    1.070339] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type AUX-therm
[    1.070615] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type AO-therm
[    1.070845] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[    1.072064] la/ptsa driver initialized.
[    1.072409] NET: Registered protocol family 2
[    1.073216] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[    1.073529] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[    1.074128] TCP: Hash tables configured (established 65536 bind 65536)
[    1.074196] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[    1.074335] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[    1.074822] NET: Registered protocol family 1
[    1.075530] RPC: Registered named UNIX socket transport module.
[    1.075554] RPC: Registered udp transport module.
[    1.075574] RPC: Registered tcp transport module.
[    1.075593] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.075817] Trying to unpack rootfs image as initramfs...
[    1.261779] Freeing initrd memory: 5432K
[    1.284395] host1x 13e10000.host1x: initialized
[    1.286090] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    1.290719] audit: initializing netlink subsys (disabled)
[    1.290808] audit: type=2000 audit(0.908:1): initialized
[    1.291732] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[    1.301838] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.303247] ntfs: driver 2.1.32 [Flags: R/W].
[    1.303945] 9p: Installing v9fs 9p2000 file system support
[    1.308942] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[    1.309160] io scheduler noop registered
[    1.309435] io scheduler cfq registered (default)
[    1.313304] gic 2a41000.agic-controller: GIC IRQ controller registered
[    1.314461] random: fast init done
[    1.348435] iommu: Adding device 2993000.adsp to group 56
[    1.455527] iommu: Adding device aconnect@2a41000:adsp_audio to group 57
[    1.456409] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[    1.469873] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    1.470303] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[    1.470924] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    1.471361] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[    1.471768] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[    1.475059] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[    1.475404] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=4500000, max_bw=4687500
[    1.478611] tsec 15500000.tsec: initialized
[    1.480589] tsec 15100000.tsecb: initialized
[    1.484334] nvdec 15480000.nvdec: initialized
[    1.487010] nvdec 15140000.nvdec1: initialized
[    1.492845] falcon 15340000.vic: initialized
[    1.494893] falcon 15380000.nvjpg: initialized
[    1.496761] falcon 154c0000.nvenc: initialized
[    1.498661] falcon 15a80000.nvenc1: initialized
[    1.502768] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[    1.504228] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[    1.505643] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[    1.507287] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[    1.508745] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[    1.510209] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[    1.511607] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[    1.513065] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[    1.517043] t194-nvcsi 15a00000.nvcsi: initialized
[    1.522381] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[    1.522767] scare-pigeon 14b00000.isp-thi: initialized
[    1.528471] pva 16000000.pva0: initialized
[    1.534212] pva 16800000.pva1: initialized
[    1.539127] nvdla 15880000.nvdla0: initialized
[    1.543964] nvdla 158c0000.nvdla1: initialized
[    1.545237] tegradccommon 15200000.dc_common: host1x channel mapped
[    1.545270] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[    1.545329] tegradccommon 15200000.dc_common: dma mapping done
[    1.545516] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=77
[    1.545559] tegra_cec 3960000.tegra_cec: Unpowergate DISP: 0.
[    1.545852] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[    1.545900] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[    1.546184] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[    1.546214] tegra_cec 3960000.tegra_cec: probed
[    1.546907] tegradc 15210000.nvdisplay: disp0 connected to head1->/host1x/sor
[    1.546967] tegradc 15210000.nvdisplay: parse_dp_settings: No dp-lt-settings node
[    1.547117] tegradc 15210000.nvdisplay: DT parsed successfully
[    1.547219] tegradc 15210000.nvdisplay: Display dc.ffffff800bce0000 registered with id=0
[    1.551900] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 7088400 KB/s
[    1.551940] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 800000000 Hz
[    1.551985] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 300000000 Hz
[    1.552283] tegradc 15210000.nvdisplay: vblank syncpt # 8 for dc 1
[    1.552311] tegradc 15210000.nvdisplay: vpulse3 syncpt # 9 for dc 1
[    1.558668] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 32 channels
[    1.559893] tegra-fuse-burn 3820000.efuse:efuse-burn: shutdown limit check disabled
[    1.559926] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[    1.560401] kfuse 3830000.kfuse: initialized
[    1.564384] tegradc 15210000.nvdisplay: probed
[    1.565091] Console: switching to colour frame buffer device 80x30
[    1.565153] tegradc 15210000.nvdisplay: fb registered
[    1.568972] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.569490] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 2
[    1.571048] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 1
[    1.571735] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 47, base_baud = 0) is a TEGRA_UART
[    1.572432] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 0
[    1.572952] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 48, base_baud = 0) is a TEGRA_UART
[    1.573812] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 49, base_baud = 0) is a TEGRA_UART
[    1.574048] tegradc 15210000.nvdisplay: dp: aux write got error (0x10000100)
[    1.574087] tegradc 15210000.nvdisplay: dp: Failed for I2C write addr:80, size:1, stat:0x10000100
[    1.574879] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[    1.575043] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[    1.575226] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[    1.577568] Parent Clock set for DC pll_d
[    1.582672] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 2
[    1.584194] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 1
[    1.585774] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 0
[    1.586984] tegradc 15210000.nvdisplay: dp: aux write got error (0x10000100)
[    1.587006] tegradc 15210000.nvdisplay: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[    1.587694] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 2
[    1.589253] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 1
[    1.590644] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 0
[    1.592157] tegradc 15210000.nvdisplay: dp: aux write got error (0x10000100)
[    1.592163] tegradc 15210000.nvdisplay: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[    1.592837] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 2
[    1.594313] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 1
[    1.595792] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 0
[    1.597268] tegradc 15210000.nvdisplay: dp: aux write got error (0x10000100)
[    1.597274] tegradc 15210000.nvdisplay: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[    1.597941] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 2
[    1.599082] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 1
[    1.600558] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 0
[    1.602034] tegradc 15210000.nvdisplay: dp: aux write got error (0x10000100)
[    1.602039] tegradc 15210000.nvdisplay: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[    1.602045] tegradc 15210000.nvdisplay: dp: failed to exit panel power save mode (0xfffffff2)
[    1.602084] hpd: state 7 (Takeover from bootloader), hpd 1, pending_hpd_evt 1
[    1.602089] hpd: switching from state 7 (Takeover from bootloader) to state 1 (Check Plug)
[    1.702498] hpd: state 1 (Check Plug), hpd 1, pending_hpd_evt 0
[    1.702509] hpd: switching from state 1 (Check Plug) to state 2 (Check EDID)
[    1.710467] hpd: state 2 (Check EDID), hpd 1, pending_hpd_evt 0
[    1.711159] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 2
[    1.712644] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 1
[    1.714130] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 0
[    1.715621] tegradc 15210000.nvdisplay: dp: aux write got error (0x10000100)
[    1.715627] tegradc 15210000.nvdisplay: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[    1.716304] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 2
[    1.717788] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 1
[    1.719277] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 0
[    1.720787] tegradc 15210000.nvdisplay: dp: aux write got error (0x10000100)
[    1.720793] tegradc 15210000.nvdisplay: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[    1.721472] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 2
[    1.722989] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 1
[    1.724475] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 0
[    1.725971] tegradc 15210000.nvdisplay: dp: aux write got error (0x10000100)
[    1.725977] tegradc 15210000.nvdisplay: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[    1.726656] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 2
[    1.728142] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 1
[    1.729627] tegradc 15210000.nvdisplay: dp: aux write retry (0x10000100) -- 0
[    1.731115] tegradc 15210000.nvdisplay: dp: aux write got error (0x10000100)
[    1.731120] tegradc 15210000.nvdisplay: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[    1.731126] tegradc 15210000.nvdisplay: dp: failed to exit panel power save mode (0xfffffff2)
[    1.731132] hpd: edid read prepare failed
[    1.731133] hpd: DC from connected to disconnected
[    2.554460] tegra_cec 3960000.tegra_cec: Can't find physical addresse.
[    2.554466] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[    2.751862] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[    2.752074] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[    2.753419] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[    4.509061] tegradc 15210000.nvdisplay: blank - powerdown
[    4.509075] console [ttyTCU0] enabled
[    4.509632] tegradc 15210000.nvdisplay: dp: aux read retry (0x10000100) -- 2
[    4.510009] [drm] Initialized
[    4.511188] tegradc 15210000.nvdisplay: dp: aux read retry (0x10000100) -- 1
[    4.512836] tegradc 15210000.nvdisplay: dp: aux read retry (0x10000100) -- 0
[    4.514363] tegradc 15210000.nvdisplay: dp: aux read got error (0x10000100)
[    4.514377] tegradc 15210000.nvdisplay: dp: Failed to read DPCD data. CMD 0x1, Status 0x10000100
[    4.514386] tegradc 15210000.nvdisplay: dp: NV_DPCD_MAX_LINK_BANDWIDTH read failed
[    4.515156] tegradc 15210000.nvdisplay: dp: aux read retry (0x10000100) -- 2
[    4.516692] tegradc 15210000.nvdisplay: dp: aux read retry (0x10000100) -- 1
[    4.518090] tegradc 15210000.nvdisplay: dp: aux read retry (0x10000100) -- 0
[    4.519455] tegradc 15210000.nvdisplay: dp: aux read got error (0x10000100)
[    4.519466] tegradc 15210000.nvdisplay: dp: Failed to read DPCD data. CMD 0x2, Status 0x10000100
[    4.519472] tegradc 15210000.nvdisplay: dp: NV_DPCD_MAX_LANE_COUNT read failed
[    4.519480] tegradc 15210000.nvdisplay: dp: Invalid link rate (0) or lane count (0)
[    4.520158] tegradc 15210000.nvdisplay: dp: aux read retry (0x10000100) -- 2
[    4.521951] tegradc 15210000.nvdisplay: dp: aux read retry (0x10000100) -- 1
[    4.523297] tegradc 15210000.nvdisplay: dp: aux read retry (0x10000100) -- 0
[    4.525275] tegradc 15210000.nvdisplay: dp: aux read got error (0x10000100)
[    4.525284] tegradc 15210000.nvdisplay: dp: Failed to read DPCD data. CMD 0x1, Status 0x10000100
[    4.525290] tegradc 15210000.nvdisplay: dp: NV_DPCD_MAX_LINK_BANDWIDTH read failed
[    4.526510] tegradc 15210000.nvdisplay: dp: aux read retry (0x10000100) -- 2
[    4.528324] tegradc 15210000.nvdisplay: dp: aux read retry (0x10000100) -- 1
[    4.530056] tegradc 15210000.nvdisplay: dp: aux read retry (0x10000100) -- 0
[    4.531590] tegradc 15210000.nvdisplay: dp: aux read got error (0x10000100)
[    4.531600] tegradc 15210000.nvdisplay: dp: Failed to read DPCD data. CMD 0x2, Status 0x10000100
[    4.531606] tegradc 15210000.nvdisplay: dp: NV_DPCD_MAX_LANE_COUNT read failed
[    4.531612] tegradc 15210000.nvdisplay: dp: Invalid link rate (0) or lane count (0)
[    4.539840] brd: module loaded
[    4.563085] loop: module loaded
[    4.563246] tegra_profiler: version: 1.141, samples/io: 48/28
[    4.563518] tegra_profiler: auth: init
[    4.567443] THERMAL EST: found 3 subdevs
[    4.567456] THERMAL EST num_resources: 0
[    4.567464] [THERMAL EST subdev 0]
[    4.567473] [THERMAL EST subdev 1]
[    4.567479] [THERMAL EST subdev 2]
[    4.567501] THERMAL EST: Found 2 profiles, default profile is quiet
[    4.568049] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[    4.568052] THERMAL EST: thz register success.
[    4.568326] THERMAL EST: end of probe, return err: 0
[    4.569640] sd: No Scsi addr parsed to reserve index
[    4.569693] hisi_sas: driver version v1.6
[    4.589616] qspi_mtd spi6.0: s25fs256s SSG 8 0 1000 2000000
[    4.589630] qspi_mtd spi6.0: s25fs256s (32768 Kbytes)
[    4.589674] qspi_mtd spi6.0: mtd .name = spi6.0, .size = 0x2000000 (32MiB) .erasesize = 0x00010000 (64KiB) .numeraseregions = 0
[    4.590167] 1 ofpart partitions found on MTD device spi6.0
[    4.590192] Creating 1 MTD partitions on "spi6.0":
[    4.590236] 0x000000000000-0x000002000000 : "Whole_flash0"
[    4.595268] libphy: Fixed MDIO Bus: probed
[    4.596189] tun: Universal TUN/TAP device driver, 1.6
[    4.596193] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    4.598596] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    4.598600] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    4.598660] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[    4.598664] igb: Copyright (c) 2007-2014 Intel Corporation.
[    4.598707] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[    4.598710] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    4.598811] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[    4.598818] Copyright(c) 1999 - 2017 Intel Corporation.
[    4.845174] eqos 2490000.ether_qos: Setting local MAC: 48 b0 2d 15 c2 b5
[    4.845674] libphy: dwc_phy: probed
[    4.851208] PPP generic driver version 2.4.2
[    4.851888] PPP BSD Compression module registered
[    4.851895] PPP Deflate Compression module registered
[    4.851965] PPP MPPE Compression module registered
[    4.851977] NET: Registered protocol family 24
[    4.852224] usbcore: registered new interface driver r8152
[    4.852359] usbcore: registered new interface driver asix
[    4.852515] usbcore: registered new interface driver ax88179_178a
[    4.852673] usbcore: registered new interface driver cdc_ether
[    4.852840] usbcore: registered new interface driver net1080
[    4.852965] usbcore: registered new interface driver cdc_subset
[    4.853094] usbcore: registered new interface driver zaurus
[    4.853281] usbcore: registered new interface driver cdc_ncm
[    4.853854] VFIO - User Level meta-driver version: 0.3
[    4.856429] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    4.856472] ehci-pci: EHCI PCI platform driver
[    4.856633] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    4.856658] ohci-pci: OHCI PCI platform driver
[    4.856826] ohci-platform: OHCI generic platform driver
[    4.864837] tegra-xusb 3610000.xhci: No USB port has OTG_CAP
[    4.869925] usbcore: registered new interface driver uas
[    4.870017] usbcore: registered new interface driver usb-storage
[    4.870163] usbcore: registered new interface driver usbserial
[    4.870212] usbcore: registered new interface driver option
[    4.870255] usbserial: USB Serial support registered for GSM modem (1-port)
[    4.870548] tegra-xusb 3610000.xhci: Firmware timestamp: 2019-07-24 05:47:34 UTC, Version: 60.06 release
[    4.870632] tegra-xusb 3610000.xhci: xHCI Host Controller
[    4.870676] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[    4.871578] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x00050810
[    4.871706] tegra-xusb 3610000.xhci: irq 464, io mem 0x03610000
[    4.872297] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    4.872333] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.872341] usb usb1: Product: xHCI Host Controller
[    4.872346] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[    4.872350] usb usb1: SerialNumber: 3610000.xhci
[    4.873363] hub 1-0:1.0: USB hub found
[    4.873448] hub 1-0:1.0: 4 ports detected
[    4.874291] tegra-xusb 3610000.xhci: xHCI Host Controller
[    4.874314] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[    4.874330] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[    4.874830] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[    4.874837] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.874842] usb usb2: Product: xHCI Host Controller
[    4.874847] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[    4.874853] usb usb2: SerialNumber: 3610000.xhci
[    4.875821] hub 2-0:1.0: USB hub found
[    4.875882] hub 2-0:1.0: 4 ports detected
[    4.880057] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[    4.880190] tegra-xudc-new 3550000.xudc: device count: 1
[    4.881898] tegra-xudc-new 3550000.xudc: vbus state: 0
[    4.881916] tegra-xudc-new 3550000.xudc: Initialize boost_cpufreq work
[    4.882053] tegra-xudc-new 3550000.xudc: entering ELPG
[    4.882593] tegra-xudc-new 3550000.xudc: entering ELPG done
[    4.884035] mousedev: PS/2 mouse device common for all mice
[    4.884477] usbcore: registered new interface driver xpad
[    4.886841] sensor_parse_dt prox_threshold = 400
[    4.886847] sensor_parse_dt prox_hsyteresis_threshold = 300
[    4.886852] sensor_parse_dt als_lux_factor = 300
[    4.886863] sensor_parse_dt: rgb coefficients
[    4.886871] -31 340 72
[    4.886874] -31 340 72
[    4.886879] m_adh=3743, n_adh=1590
[    4.886884] m_cu=3319, n_cu=1714
[    4.886886] ir_factor = 24
[    4.888038] APDS9999
[    4.895003] input: light as /devices/virtual/input/input0
[    4.895674] input: proximity as /devices/virtual/input/input1
[    4.896072] apds9999_probe support ver. 1.0.0 enabled
[    5.031101] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[    5.034753] Wake73 for irq=42
[    5.036412] rtc rtc1: alarm rtc device
[    5.036440] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[    5.036550] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    5.036874] i2c /dev entries driver
[    5.041556] i2c i2c-2: Added multiplexed i2c bus 9
[    5.042491] i2c i2c-2: Added multiplexed i2c bus 10
[    5.043272] i2c i2c-2: Added multiplexed i2c bus 11
[    5.043285] i2c-mux-gpio cam_i2cmux: 3 port mux on 3180000.i2c adapter
[    5.043952] pca954x 0-0070: pca954x_probe: forcing device bus number, start 31.
[    5.043959] pca954x 0-0070: device detect skipped.
[    5.044860] i2c i2c-31: Failed to register i2c client apds9999 at 0x52 (-16)
[    5.044872] i2c i2c-31: of_i2c: Failure registering /i2c@3160000/i2cswitch@70/channel@0/avago1@52
[    5.044878] i2c i2c-31: Failed to create I2C device for /i2c@3160000/i2cswitch@70/channel@0/avago1@52
[    5.044915] i2c i2c-0: Added multiplexed i2c bus 31
[    5.045383] i2c i2c-32: Failed to register i2c client apds9999 at 0x52 (-16)
[    5.045389] i2c i2c-32: of_i2c: Failure registering /i2c@3160000/i2cswitch@70/channel@1/avago2@52
[    5.045395] i2c i2c-32: Failed to create I2C device for /i2c@3160000/i2cswitch@70/channel@1/avago2@52
[    5.045421] i2c i2c-0: Added multiplexed i2c bus 32
[    5.045768] i2c i2c-33: Failed to register i2c client apds9999 at 0x52 (-16)
[    5.045773] i2c i2c-33: of_i2c: Failure registering /i2c@3160000/i2cswitch@70/channel@2/avago3@52
[    5.045777] i2c i2c-33: Failed to create I2C device for /i2c@3160000/i2cswitch@70/channel@2/avago3@52
[    5.045793] i2c i2c-0: Added multiplexed i2c bus 33
[    5.046178] i2c i2c-34: Failed to register i2c client apds9999 at 0x52 (-16)
[    5.046186] i2c i2c-34: of_i2c: Failure registering /i2c@3160000/i2cswitch@70/channel@3/avago4@52
[    5.046191] i2c i2c-34: Failed to create I2C device for /i2c@3160000/i2cswitch@70/channel@3/avago4@52
[    5.046213] i2c i2c-0: Added multiplexed i2c bus 34
[    5.046227] pca954x 0-0070: registered 4 multiplexed busses for I2C switch pca9545
[    5.047179] pca954x 1-0070: pca954x_probe: forcing device bus number, start 35.
[    5.047185] pca954x 1-0070: device detect skipped.
[    5.048123] PROBE function calling for i2c client addr=31 name=kx122
[    5.108627] kx122 35-001f: Kionix kx023 detected
[    5.113126] input: kx023-accel as /devices/c240000.i2c/i2c-1/i2c-35/35-001f/input/input2
[    5.114041] sdata->accel_poll_rate = 320
[    5.119339] i2c i2c-1: Added multiplexed i2c bus 35
[    5.120780] PROBE function calling for i2c client addr=31 name=kx122
[    5.179105] tegra-i2c c240000.i2c: no acknowledge from address 0x1f
[    5.179435] kx122 36-001f: sensor not recognized
[    5.179527] kx122: probe of 36-001f failed with error -121
[    5.179669] i2c i2c-1: Added multiplexed i2c bus 36
[    5.180815] PROBE function calling for i2c client addr=31 name=kx122
[    5.194531] usb 1-3: new high-speed USB device number 2 using tegra-xusb
[    5.239560] kx122 37-001f: Kionix kx023 detected
[    5.243876] input: kx023-accel as /devices/c240000.i2c/i2c-1/i2c-37/37-001f/input/input3
[    5.244714] sdata->accel_poll_rate = 320
[    5.249683] i2c i2c-1: Added multiplexed i2c bus 37
[    5.250894] i2c i2c-1: Added multiplexed i2c bus 38
[    5.250911] pca954x 1-0070: registered 4 multiplexed busses for I2C switch pca9545
[    5.255631] max77620-power max20024-power: Event recorder REG_NVERC : 0x0
[    5.257589] ina2xx 0-0041: power monitor ina219 (Rshunt = 500 uOhm)
[    5.258744] ina2xx 0-0044: power monitor ina219 (Rshunt = 500 uOhm)
[    5.259484] ina2xx 0-0045: power monitor ina219 (Rshunt = 250 uOhm)
[    5.274272] tegra-thermal-throttle bthrot_cdev: clk:cpu max:1907200000, min:115200000 steps:24
[    5.281118] tegra-thermal-throttle bthrot_cdev: clk:gpu max:1109250000, min:114750000 steps:10
[    5.281199] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:0:cpu off:0 slope-adj:200
[    5.281205] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:1:gpu off:0 slope-adj:400
[    5.281441] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced max_state:48 cutoff:0
[    5.281560] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:0:cpu off:0 slope-adj:400
[    5.281567] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:1:gpu off:0 slope-adj:400
[    5.282124] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced max_state:40 cutoff:1
[    5.282261] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:0:cpu off:0 slope-adj:200
[    5.282269] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:1:gpu off:365500000 slope-adj:300
[    5.282782] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced max_state:48 cutoff:0
[    5.282895] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:0:cpu off:38400000 slope-adj:10
[    5.282902] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:1:gpu off:25500000 slope-adj:10
[    5.283638] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced max_state:2 cutoff:0
[    5.283918] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:0:cpu off:0 slope-adj:400
[    5.283926] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:1:gpu off:0 slope-adj:400
[    5.284673] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced max_state:40 cutoff:1
[    5.286124] FAN dev name: pwm-fan
[    5.286196] FAN:gpio request success.
[    5.286208] FAN: can't find tach_gpio
[    5.286228] pwm_fan_driver pwm-fan: Found 2 profiles, default profile is quiet
[    5.286295] pwm_fan_driver pwm-fan: cap state:4, cap pwm:255
[    5.286736] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[    5.286743] pwm_fan_driver pwm-fan: tach period: 1000
[    5.288486] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[    5.288491] pwm_fan_driver pwm-fan: index 1: pwm=130, rpm=1000, rru=2, rrd=2, state:2
[    5.288497] pwm_fan_driver pwm-fan: index 2: pwm=160, rpm=2000, rru=1, rrd=1, state:2
[    5.288502] pwm_fan_driver pwm-fan: index 3: pwm=200, rpm=3000, rru=1, rrd=1, state:2
[    5.288507] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[    5.288512] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[    5.288517] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[    5.288521] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[    5.288526] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[    5.288531] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[    5.290872] device-mapper: uevent: version 1.0.3
[    5.291685] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[    5.315171] tegra194_cpufreq_probe: platform driver Initialization: pass
[    5.321973] cpuidle: Initializing cpuidle driver
[    5.334663] sdhci: Secure Digital Host Controller Interface driver
[    5.334665] sdhci: Copyright(c) Pierre Ossman
[    5.334668] sdhci-pltfm: SDHCI platform and OF driver helper
[    5.335903] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[    5.338123] CMDQ: cmdq_platfm_init successful
[    5.338658] sdhci-tegra 3440000.sdhci: Got CD GPIO
[    5.339397] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[    5.342140] sdhci-tegra 3440000.sdhci: wakeup init done, cdirq 320
[    5.378438] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[    5.388708] lp5523x 0-0032: lp5523 Programmable led chip found
[    5.390503] gpio tegra-gpio wake51 for gpio=130(Q:2)
[    5.390552] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[    5.393908] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[    5.395306] tegra-se-nvhost 15810000.se: initialized
[    5.396657] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[    5.397642] tegra-se-nvhost 15820000.se: initialized
[    5.398722] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[    5.399356] tegra-se-nvhost 15830000.se: initialized
[    5.400090] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[    5.400668] tegra-se-nvhost 15840000.se: initialized
[    5.401581] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[    5.401816] hidraw: raw HID events driver (C) Jiri Kosina
[    5.403029] usbcore: registered new interface driver usbhid
[    5.403032] usbhid: USB HID core driver
[    5.406827] tegra186-cam-rtcpu bc00000.rtcpu: deferring, 14800000.isp is not probed
[    5.407948] tegra_aon c1a0000.aon: tegra aon driver probe OK
[    5.408392] tegra186-aondbg aondbg: aondbg driver probe() OK
[    5.408988] denver_knobs_init:MTS_VERSION:50168445
[    5.409144] tegra19x_actmon d230000.actmon: in actmon_register()...
[    5.409703] tegra19x_actmon d230000.actmon: initialization Completed for the device mc_all
[    5.410116] t19x_cache tegra-cache: probed
[    5.412613] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[    5.412621] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[    5.413170] carmel-pmu-drv carmel-pmu: Registered Carmel PMU
[    5.413525] PLL_AON clock registered
[    5.414822] Clocks initialized successfully
[    5.416261] nvpmodel: initialized successfully
[    5.421953] mmc1: host does not support reading read-only switch, assuming write-enable
[    5.424114] trusty-virtio trusty:virtio: initializing
[    5.424352] trusty_ipc virtio0: vring0: va(pa)  ffffffc1f20f4000(0) qsz 32 notifyid 1
[    5.424362] trusty_ipc virtio0: vring1: va(pa)  ffffffc1f20f6000(0) qsz 32 notifyid 2
[    5.424523] trusty-virtio trusty:virtio: initializing done
[    5.425208] trusty_ipc virtio0: is online
[    5.425842] mmc1: new high speed SDXC card at address 0001
[    5.426264] mmcblk1: mmc1:0001 EC2QT 59.6 GiB
[    5.426355] usbcore: registered new interface driver snd-usb-audio
[    5.427959] tegra-hda 3510000.hda: Override SDO lines to 4
[    5.428293]  mmcblk1: p1
[    5.428750] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[    5.439451] hdaudio hdaudioC0D3: Unable to bind the codec
[    5.439658] hdaudio hdaudioC0D4: Unable to bind the codec
[    5.440026] hdaudio hdaudioC0D5: Unable to bind the codec
[    5.440349] hdaudio hdaudioC0D6: Unable to bind the codec
[    5.440644] mmc0: periodic cache flush enabled
[    5.440656] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[    5.441221] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[    5.441451] mmcblk0boot0: mmc0:0001 DG4016 partition 1 4.00 MiB
[    5.441648] mmcblk0boot1: mmc0:0001 DG4016 partition 2 4.00 MiB
[    5.441848] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB
[    5.444825]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
[    5.507910] OPE platform probe
[    5.508060] OPE platform probe successful
[    5.592289] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[    5.592481] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[    5.592662] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[    5.592797] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[    5.592894] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[    5.592985] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[    5.593085] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[    5.593176] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[    5.593265] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[    5.593362] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[    5.593465] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[    5.593568] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[    5.593674] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[    5.593765] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[    5.593865] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[    5.593959] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[    5.594049] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[    5.594146] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[    5.594241] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[    5.594355] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[    5.624143] u32 classifier
[    5.624147]     Actions configured
[    5.624210] Initializing XFRM netlink socket
[    5.624786] NET: Registered protocol family 10
[    5.625551] NET: Registered protocol family 17
[    5.625565] NET: Registered protocol family 15
[    5.625618] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    5.625704] Bluetooth: RFCOMM socket layer initialized
[    5.625729] Bluetooth: RFCOMM ver 1.11
[    5.625739] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    5.625745] Bluetooth: HIDP socket layer initialized
[    5.625762] 9pnet: Installing 9P2000 support
[    5.625801] Key type dns_resolver registered
[    5.629961] Registered cp15_barrier emulation handler
[    5.629980] Registered setend emulation handler
[    5.631824] registered taskstats version 1
[    5.632315] tegra-pcie-dw 14160000.pcie: Setting init speed to max speed
[    5.633436] OF: PCI: host bridge /pcie@14160000 ranges:
[    5.633492] OF: PCI:    IO 0x36100000..0x361fffff -> 0x36100000
[    5.633510] OF: PCI:   MEM 0x1740000000..0x17ffffffff -> 0x40000000
[    5.633525] OF: PCI:   MEM 0x1400000000..0x173fffffff -> 0x1400000000
[    5.694740] FAN rising trip_level:2 cur_temp:61100 trip_temps[3]:68000
[    5.734438] tegra-pcie-dw 14160000.pcie: link is up
[    5.734723] tegra-pcie-dw 14160000.pcie: PCI host bridge to bus 0004:00
[    5.734730] pci_bus 0004:00: root bus resource [bus 00-ff]
[    5.734750] pci_bus 0004:00: root bus resource [io  0x0000-0xfffff] (bus address [0x36100000-0x361fffff])
[    5.734761] pci_bus 0004:00: root bus resource [mem 0x1740000000-0x17ffffffff] (bus address [0x40000000-0xffffffff])
[    5.734765] pci_bus 0004:00: root bus resource [mem 0x1400000000-0x173fffffff pref]
[    5.735161] iommu: Adding device 0004:00:00.0 to group 58
[    5.735871] pci 0004:01:00.0: reg 0x18: initial BAR value 0x00000000 invalid
[    5.737077] iommu: Adding device 0004:01:00.0 to group 59
[    5.747597] pci 0004:00:00.0: BAR 14: assigned [mem 0x1740000000-0x1740bfffff]
[    5.747603] pci 0004:00:00.0: BAR 13: assigned [io  0x1000-0x1fff]
[    5.747609] pci 0004:01:00.0: BAR 0: assigned [mem 0x1740000000-0x17407fffff]
[    5.747636] pci 0004:01:00.0: BAR 3: assigned [mem 0x1740800000-0x1740803fff]
[    5.747662] pci 0004:01:00.0: BAR 2: assigned [io  0x1000-0x101f]
[    5.747688] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[    5.747693] pci 0004:00:00.0:   bridge window [io  0x1000-0x1fff]
[    5.747700] pci 0004:00:00.0:   bridge window [mem 0x1740000000-0x1740bfffff]
[    5.747720] pci 0004:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[    5.747779] pci 0004:01:00.0: Max Payload Size set to  256/ 512 (was  128), Max Read Rq  512
[    5.748076] pcieport 0004:00:00.0: Signaling PME through PCIe PME interrupt
[    5.748080] pci 0004:01:00.0: Signaling PME through PCIe PME interrupt
[    5.748803] tegra-pcie-dw 141a0000.pcie: Setting init speed to max speed
[    5.749908] OF: PCI: host bridge /pcie@141a0000 ranges:
[    5.749948] OF: PCI:    IO 0x3a100000..0x3a1fffff -> 0x3a100000
[    5.749958] OF: PCI:   MEM 0x1f40000000..0x1fffffffff -> 0x40000000
[    5.749966] OF: PCI:   MEM 0x1c00000000..0x1f3fffffff -> 0x1c00000000
[    5.858449] tegra-pcie-dw 141a0000.pcie: link is up
[    5.858704] tegra-pcie-dw 141a0000.pcie: PCI host bridge to bus 0005:00
[    5.858711] pci_bus 0005:00: root bus resource [bus 00-ff]
[    5.858718] pci_bus 0005:00: root bus resource [io  0x100000-0x1fffff] (bus address [0x3a100000-0x3a1fffff])
[    5.858723] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[    5.858726] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[    5.859082] iommu: Adding device 0005:00:00.0 to group 60
[    5.860892] iommu: Adding device 0005:01:00.0 to group 61
[    5.871469] pci 0005:00:00.0: BAR 14: assigned [mem 0x1f40000000-0x1f405fffff]
[    5.871477] pci 0005:01:00.0: BAR 2: assigned [mem 0x1f40000000-0x1f403fffff 64bit]
[    5.871550] pci 0005:01:00.0: BAR 0: assigned [mem 0x1f40400000-0x1f40407fff 64bit]
[    5.871622] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[    5.871630] pci 0005:00:00.0:   bridge window [mem 0x1f40000000-0x1f405fffff]
[    5.871646] pci 0005:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[    5.871698] pci 0005:01:00.0: Max Payload Size set to  256/ 256 (was  128), Max Read Rq  512
[    5.871955] pcieport 0005:00:00.0: Signaling PME through PCIe PME interrupt
[    5.871959] pci 0005:01:00.0: Signaling PME through PCIe PME interrupt
[    5.882846] tegra-cbb 14040000.cv-noc: noc_secure_irq = 89, noc_nonsecure_irq = 88>
[    5.885595] i2c i2c-8: of_i2c: invalid reg on /i2c@31e0000/battery
[    5.885599] i2c i2c-8: Failed to create I2C device for /i2c@31e0000/battery
[    5.885927] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type bq34z100-0
[    5.885945] bq27xxx-battery 8-0055: support ver. 1.2.0 enabled chip=9 name=bq34z100-0
[    5.886128] tegra-i2c 31e0000.i2c: no acknowledge from address 0x55
[    5.888102] tegra194-isp5 14800000.isp: initialized
[    5.895386] tegra194-vi5 15c10000.vi: using default number of vi channels, 36
[    5.897955] tegra194-vi5 15c10000.vi: initialized
[    5.902356] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi--3 bound
[    5.902459] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi--2 bound
[    5.902537] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi--1 bound
[    5.903332] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[    5.985276] tegra-ivc ivc-bc00000.rtcpu: region 0: iova=0xbfee0000-0xbfefffff size=131072
[    5.985656] tegra-ivc ivc-bc00000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[    5.985868] tegra-ivc ivc-bc00000.rtcpu:dbg@1: dbg: ver=0 grp=1 RX[1x384]=0x1900-0x1b00 TX[1x384]=0x1b00-0x1d00
[    5.986043] tegra-ivc ivc-bc00000.rtcpu:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d00-0x3d80 TX[1x8192]=0x3d80-0x5e00
[    5.986526] tegra-ivc ivc-bc00000.rtcpu:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e00-0xae80 TX[64x320]=0xae80-0xff00
[    5.986604] tegra-ivc ivc-bc00000.rtcpu:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff00-0x17f80 TX[512x64]=0x17f80-0x20000
[    5.986816] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (66)
[    5.986819] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[    5.988182] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=5 sha1=cf2bef3ad10e437272857b76308abef8ffb80bda
[    5.988713] gpio tegra-gpio wake67 for gpio=48(G:0)
[    5.988784] gpio tegra-gpio-aon wake29 for gpio=36(EE:4)
[    5.988931] input: gpio-keys as /devices/gpio-keys/input/input4
[    6.024757] tegra_rtc c2a0000.rtc: setting system clock to 2021-12-09 09:27:54 UTC (1639042074)
[    6.025245] mmcblk mmc1:0001: Card claimed for testing.
[    6.025256] mmcblk mmc0:0001: Card claimed for testing.
[    6.068064] bpmp: mounted debugfs mirror
[    6.074237] vdd-1v8-sd: disabling
[    6.074242] vdd-1v8-cvb: disabling
[    6.074244] vdd-epb-1v0: disabling
[    6.074246] avdd-cam-2v8: disabling
[    6.074250] vdd_sys_en: disabling
[    6.074275] ALSA device list:
[    6.074277]   #0: tegra-hda-xnx at 0x3518000 irq 65
[    6.074297]   #1: jetson-xaviernx-ape
[    6.207089] usb 1-3: Device not responding to setup address.
[    7.018868] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[    7.018872] Extcon DP: HPD disabled
[    7.018881] hpd: hpd_switch 0
[    7.018884] hpd: switching from state 2 (Check EDID) to state 3 (Disabled)
[    7.043595] Freeing unused kernel memory: 8576K
[    7.083611] Root device found: mmcblk0p1
[    7.084947] Found dev node: /dev/mmcblk0p1
[    7.108890] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[    7.109953] Rootfs mounted over mmcblk0p1
▒▒WARNING: pll_d has no dyn ramp
WARNING: at platform/drivers/pg/pg-gpu-t194.c:185
▒▒[    7.132761] Switching from initrd to actual rootfs
[    7.257426] ip_tables: (C) 2000-2006 Netfilter Core Team
[    7.261242] cgroup: cgroup2: unknown option "nsdelegate"
[    7.270676] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    7.271630] systemd[1]: Detected architecture arm64.
[    7.282169] systemd[1]: Set hostname to <INGAME_48b02d15c2b5>.
[    7.362740] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[    7.363068] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[    7.430904] usb 1-3: Device not responding to setup address.
[    7.441430] systemd[1]: Configuration file /etc/systemd/system/rap_nx_sd_card.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[    7.442242] systemd[1]: Configuration file /etc/systemd/system/rap_nx_process_manager.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[    7.443035] systemd[1]: Configuration file /etc/systemd/system/rap_network.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[    7.443871] systemd[1]: Configuration file /etc/systemd/system/rap_load_nw_driver.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[    7.505533] random: systemd: uninitialized urandom read (16 bytes read)
[    7.506341] systemd[1]: Created slice System Slice.
[    7.506900] random: systemd: uninitialized urandom read (16 bytes read)
[    7.507956] random: systemd: uninitialized urandom read (16 bytes read)
[    7.545710] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[    7.638484] usb 1-3: device not accepting address 2, error -71
[    7.758456] usb 1-3: new high-speed USB device number 3 using tegra-xusb
[    7.804204] systemd-journald[2286]: Received request to flush runtime journal from PID 1
[    8.026855] nvgpu: 17000000.gv11b          nvgpu_nvhost_syncpt_init:291  [INFO]  syncpt_unit_base 60000000 syncpt_unit_size 400000 size 1000
[    8.026855]
▒▒WARNING: at platform/drivers/pg/pg-gpu-t194.c:185
▒▒[    8.710096] random: crng init done
[    8.710207] random: 7 urandom warning(s) missed due to ratelimiting
[    8.712689] using random self ethernet address
[    8.712806] using random host ethernet address
[    8.771592] usb 1-3: Device not responding to setup address.
[    9.215146] tegradc 15210000.nvdisplay: dp: aux read got error (0x10000100)
[    9.215154] tegradc 15210000.nvdisplay: dp: Failed to read DPCD data. CMD 0x1, Status 0x10000100
[    9.215157] tegradc 15210000.nvdisplay: dp: NV_DPCD_MAX_LINK_BANDWIDTH read failed
[    9.222010] tegradc 15210000.nvdisplay: dp: aux read got error (0x10000100)
[    9.222016] tegradc 15210000.nvdisplay: dp: Failed to read DPCD data. CMD 0x2, Status 0x10000100
[    9.222020] tegradc 15210000.nvdisplay: dp: NV_DPCD_MAX_LANE_COUNT read failed
[    9.222024] tegradc 15210000.nvdisplay: dp: Invalid link rate (0) or lane count (0)
[    9.228502] tegradc 15210000.nvdisplay: dp: aux read got error (0x10000100)
[    9.228508] tegradc 15210000.nvdisplay: dp: Failed to read DPCD data. CMD 0x1, Status 0x10000100
[    9.228511] tegradc 15210000.nvdisplay: dp: NV_DPCD_MAX_LINK_BANDWIDTH read failed
[    9.236029] tegradc 15210000.nvdisplay: dp: aux read got error (0x10000100)
[    9.236035] tegradc 15210000.nvdisplay: dp: Failed to read DPCD data. CMD 0x2, Status 0x10000100
[    9.236038] tegradc 15210000.nvdisplay: dp: NV_DPCD_MAX_LANE_COUNT read failed
[    9.236048] tegradc 15210000.nvdisplay: dp: Invalid link rate (0) or lane count (0)
[    9.259972] tegradc 15210000.nvdisplay: dp: aux read got error (0x10000100)
[    9.259980] tegradc 15210000.nvdisplay: dp: Failed to read DPCD data. CMD 0x1, Status 0x10000100
[    9.259983] tegradc 15210000.nvdisplay: dp: NV_DPCD_MAX_LINK_BANDWIDTH read failed
[    9.265129] tegradc 15210000.nvdisplay: dp: aux read got error (0x10000100)
[    9.265135] tegradc 15210000.nvdisplay: dp: Failed to read DPCD data. CMD 0x2, Status 0x10000100
[    9.265138] tegradc 15210000.nvdisplay: dp: NV_DPCD_MAX_LANE_COUNT read failed
[    9.265143] tegradc 15210000.nvdisplay: dp: Invalid link rate (0) or lane count (0)
[    9.303135] tegradc 15210000.nvdisplay: dp: aux read got error (0x10000100)
[    9.303141] tegradc 15210000.nvdisplay: dp: Failed to read DPCD data. CMD 0x1, Status 0x10000100
[    9.303144] tegradc 15210000.nvdisplay: dp: NV_DPCD_MAX_LINK_BANDWIDTH read failed
[    9.309217] tegradc 15210000.nvdisplay: dp: aux read got error (0x10000100)
[    9.309223] tegradc 15210000.nvdisplay: dp: Failed to read DPCD data. CMD 0x2, Status 0x10000100
[    9.309227] tegradc 15210000.nvdisplay: dp: NV_DPCD_MAX_LANE_COUNT read failed
[    9.309231] tegradc 15210000.nvdisplay: dp: Invalid link rate (0) or lane count (0)
[    9.437064] using random self ethernet address
[    9.437195] using random host ethernet address
How did you “migrate” to jetpack4.6? Is your environment a pure BSP from sdkmanager?
Is this a custom carrier board or devkit?
Why do you suspect the bootloader is related to this issue?
