I am using a third party carrier board.
I reinstalled the drivers using jetpack, the ip address is visible but i cannot use the net but i was able to ping the DNS server.
Here is the ifconfig o/p
eth0 Link encap:Ethernet HWaddr 00:04:4b:8c:b7:52
inet addr:192.168.50.6 Bcast:192.168.50.255 Mask:255.255.255.0
inet6 addr: fe80::bbfc:a6a3:b69e:dcb1/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:1721 errors:0 dropped:0 overruns:0 frame:0
TX packets:253 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:141791 (141.7 KB) TX bytes:21752 (21.7 KB)
Interrupt:42
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:1009 errors:0 dropped:0 overruns:0 frame:0
TX packets:1009 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:72158 (72.1 KB) TX bytes:72158 (72.1 KB)
wlan0 Link encap:Ethernet HWaddr 00:04:4b:8c:b7:50
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
[code][ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.38-tegra (buildbrain@mobile-u64-553) (gcc version 4.8.5 (GCC) ) #1 SMP PREEMPT Thu Jul 20 00:49:07 PDT 2017
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] earlycon: Early serial console at MMIO32 0x3100000 (options ‘’)
[ 0.000000] bootconsole [uart0] enabled
[ 0.000000] Reserved memory: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] On node 0 totalpages: 2051072
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519408 pages, LIFO batch:31
[ 0.000000] Normal zone: 23933 pages used for memmap
[ 0.000000] Normal zone: 1531664 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] PERCPU: Embedded 17 pages/cpu @ffffffc1f5cf3000 s31232 r8192 d30208 u69632
[ 0.000000] pcpu-alloc: s31232 r8192 d30208 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2018947
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 nvdumper_reserved=0x2772e0000 gpt tegraid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 androidboot.serialno=0321917026139 bl_prof_dataptr=0x10000@0x277240000 sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7972328K/8204288K available (10976K kernel code, 1817K rwdata, 5712K rodata, 1164K init, 682K bss, 166424K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000 ( 246 GB)
vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
0xffffffbdc2000000 - 0xffffffbdc9d7c400 ( 125 MB actual)
fixed : 0xffffffbffa7fd000 - 0xffffffbffac00000 ( 4108 KB)
PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000 ( 16 MB)
modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
memory : 0xffffffc000000000 - 0xffffffc1f5f10000 ( 8031 MB)
.init : 0xffffffc0010cd000 - 0xffffffc0011f0000 ( 1164 KB)
.text : 0xffffffc000080000 - 0xffffffc0010cd000 ( 16692 KB)
.data : 0xffffffc001211000 - 0xffffffc0013d7430 ( 1818 KB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000002] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.009858] Console: colour dummy device 80x25
[ 0.014515] console [tty0] enabled
[ 0.018070] bootconsole [uart0] disabled
[ 0.022172] kmemleak: Kernel memory leak detector disabled
[ 0.022183] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.022194] pid_max: default: 32768 minimum: 301
[ 0.022236] Security Framework initialized
[ 0.022264] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022273] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022623] Initializing cgroup subsys freezer
[ 0.022635] Initializing cgroup subsys debug
[ 0.022771] CPU0 ipc=752
[ 0.022779] CPU1 ipc=1024
[ 0.022786] CPU2 ipc=1024
[ 0.022794] CPU3 ipc=752
[ 0.022802] CPU4 ipc=752
[ 0.022811] CPU5 ipc=752
[ 0.022842] ASID allocator initialised with 65536 entries
[ 0.046220] tegra-id: chipid=21817.
[ 0.046232] tegra-id: opt_subrevision=1.
[ 0.046241] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
[ 0.046855] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.4/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.046875] DTB Build time: Jul 20 2017 00:50:45
[ 0.062589] CPU1: Booted secondary processor [4e0f0030]
[ 0.074113] CPU2: Booted secondary processor [4e0f0030]
[ 0.085794] CPU3: Booted secondary processor [411fd073]
[ 0.097801] CPU4: Booted secondary processor [411fd073]
[ 0.109798] CPU5: Booted secondary processor [411fd073]
[ 0.109859] Brought up 6 CPUs
[ 0.109907] SMP: Total of 6 processors activated.
[ 0.109918] CPU: All CPU(s) started at EL2
[ 0.110340] devtmpfs: initialized
[ 0.137273] Initilizing CustomIPI irq domain
[ 0.137481] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.138386] pinctrl core: initialized pinctrl subsystem
[ 0.138554] OS set in device tree is L4T.
[ 0.138750] regulator-dummy: no parameters
[ 0.138852] Initializing plugin-manager
[ 0.138906] Plugin module not found
[ 0.139316] node /plugin-manager/soc-prod-a02-fragment match with chip-id A02P
[ 0.139657] node /plugin-manager/fragement@0 match with odm-data enable-denver-wdt
[ 0.140263] node /plugin-manager/fragement@4 match with odm-data enable-denver-wdt
[ 0.141447] node /plugin-manager/fragment-sdwake-p3310-1000-300 match with board >=3310-1000-300
[ 0.141798] node /plugin-manager/fragement-pmon-p3310-1000-300 match with board >=3310-1000-300
[ 0.142052] node /plugin-manager/fragement-pmon-p3310-1000-800 match with board >=3310-1000-800
[ 0.142273] node /plugin-manager/fragment-devslp@0 match with board >=3310-1000-200
[ 0.142696] node /plugin-manager/fragment-500-pcie-config match with board >=3310-1000-500
[ 0.143134] node /plugin-manager/fragment-500-xusb-config match with board >=3310-1000-500
[ 0.143412] node /plugin-manager/fragment-500-e3325-pcie match with board >=3310-1000-500
[ 0.143788] node /plugin-manager/fragment-p3310-c00-comm match with board >=3310-1000-800
[ 0.144032] node /plugin-manager/fragment-p3310-c00-pmic match with board >=3310-1000-800
[ 0.144254] node /plugin-manager/fragment-p3310-c01 match with board >=3310-1000-900
[ 0.144509] node /plugin-manager/fragment-p3310-c03 match with board >=3310-1000-B00
[ 0.146450] node /plugin-manager/fragment-p3310-c00-camera match with board >=3310-1000-800
[ 0.148209] Adding domain adsp-pd to PM domain ape-pd
[ 0.150554] NET: Registered protocol family 16
[ 0.151198] console [pstore-1] enabled
[ 0.151209] pstore: Registered ramoops as persistent store backend
[ 0.151221] ramoops: attached 0x200000@0x96080000, ecc: 0/0
[ 0.161353] cpuidle: using governor ladder
[ 0.165793] cpuidle: using governor menu
[ 0.166933] bpmp: waiting for handshake
[ 0.166947] bpmp: handshake completed
[ 0.166987] bpmp: synchronizing channels
[ 0.167012] bpmp: channels synchronized
[ 0.167021] bpmp: mail init ok
[ 0.167342] vdso: 2 pages (1 code @ ffffffc001219000, 1 data @ ffffffc001218000)
[ 0.167372] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.168293] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.169752] tegra_powergate_init: DONE
[ 0.169771] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.4/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.169806] DTB Build time: Jul 20 2017 00:50:45
[ 0.170695] Tegra reboot handler registered.
[ 0.171724] Registering Tegra186 clocks (this may take a while)…done
[ 0.173854] arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.173870] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.173882] arm-smmu 12000000.iommu: stage 1 translation
[ 0.173893] arm-smmu 12000000.iommu: stage 2 translation
[ 0.173903] arm-smmu 12000000.iommu: nested translation
[ 0.173916] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.173933] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.173950] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.173963] arm-smmu 12000000.iommu: Stage-1: 39-bit VA → 48-bit IPA
[ 0.173974] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA → 48-bit PA
[ 0.222535] arm-smmu 12000000.iommu: registered 67 master devices
[ 0.228102] iommu: Adding device 3460000.sdhci to group 0
[ 0.228926] iommu: Adding device 3400000.sdhci to group 1
[ 0.232510] iommu: Adding device 3507000.ahci-sata to group 2
[ 0.232940] iommu: Adding device 3160000.i2c to group 3
[ 0.233328] iommu: Adding device c240000.i2c to group 4
[ 0.233650] iommu: Adding device 3180000.i2c to group 5
[ 0.234008] iommu: Adding device 3190000.i2c to group 6
[ 0.234467] iommu: Adding device 31b0000.i2c to group 7
[ 0.234839] iommu: Adding device 31c0000.i2c to group 8
[ 0.235197] iommu: Adding device c250000.i2c to group 9
[ 0.235511] iommu: Adding device 31e0000.i2c to group 10
[ 0.237469] iommu: Adding device 3210000.spi to group 11
[ 0.237767] iommu: Adding device c260000.spi to group 12
[ 0.238074] iommu: Adding device 3240000.spi to group 13
[ 0.238903] iommu: Adding device 3100000.serial to group 14
[ 0.239258] iommu: Adding device 3110000.serial to group 15
[ 0.239549] iommu: Adding device c280000.serial to group 16
[ 0.239871] iommu: Adding device 3130000.serial to group 17
[ 0.241089] iommu: Adding device 2490000.ether_qos to group 18
[ 0.241705] iommu: Adding device b000000.rtcpu to group 19
[ 0.242176] iommu: Adding device c1a0000.aon to group 20
[ 0.243028] Wake73 for irq=42
[ 0.243346] iommu: Adding device smmu_test to group 21
[ 0.243852] mc: mapped MMIO address: 0xffffff8000560000 → 0x2c10000
[ 0.243889] mc: mapped MMIO address: 0xffffff8000640000 → 0x2c20000
[ 0.243957] mc: mapped MMIO address: 0xffffff8000660000 → 0x2c30000
[ 0.243990] mc: mapped MMIO address: 0xffffff8000fa0000 → 0x2c40000
[ 0.244021] mc: mapped MMIO address: 0xffffff8000fc0000 → 0x2c50000
[ 0.244052] mc-err: Set intmask: 0xf3140
[ 0.244321] dram-ecc: DRAM ECC disabled-MC_ECC_CONTROL:0x0000000c
[ 0.245115] Wake76 for irq=199
[ 0.245138] Wake77 for irq=199
[ 0.245156] Wake78 for irq=199
[ 0.245172] Wake79 for irq=199
[ 0.245189] Wake80 for irq=199
[ 0.245205] Wake81 for irq=199
[ 0.245222] Wake82 for irq=199
[ 0.245363] iommu: Adding device 3530000.xhci to group 22
[ 0.245726] iommu: Adding device 3550000.xudc to group 23
[ 0.246525] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.246566] tegra-pmc: ### PMC reset source: Power on reset
[ 0.246610] tegra-pmc: ### PMC reset level: L0
[ 0.246629] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.246914] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.246950] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.247114] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.247141] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 320
[ 0.247614] iommu: Adding device 13e10000.host1x to group 24
[ 0.247856] iommu: Adding device 13e10000.host1x:ctx0 to group 25
[ 0.248067] iommu: Adding device 13e10000.host1x:ctx1 to group 26
[ 0.248316] iommu: Adding device 13e10000.host1x:ctx2 to group 27
[ 0.248555] iommu: Adding device 13e10000.host1x:ctx3 to group 28
[ 0.248756] iommu: Adding device 13e10000.host1x:ctx4 to group 29
[ 0.248988] iommu: Adding device 13e10000.host1x:ctx5 to group 30
[ 0.249200] iommu: Adding device 13e10000.host1x:ctx6 to group 31
[ 0.249408] iommu: Adding device 13e10000.host1x:ctx7 to group 32
[ 0.249844] iommu: Adding device 150c0000.nvcsi to group 33
[ 0.250323] iommu: Adding device 15700000.vi to group 34
[ 0.250703] iommu: Adding device 15600000.isp to group 35
[ 0.251014] iommu: Adding device 15210000.nvdisplay to group 36
[ 0.251211] iommu: Adding device 15340000.vic to group 37
[ 0.251419] iommu: Adding device 154c0000.nvenc to group 38
[ 0.251674] iommu: Adding device 15480000.nvdec to group 39
[ 0.251987] iommu: Adding device 15380000.nvjpg to group 40
[ 0.252195] iommu: Adding device 15500000.tsec to group 41
[ 0.252400] iommu: Adding device 15100000.tsecb to group 42
[ 0.253058] iommu: Adding device 15810000.se to group 43
[ 0.253270] iommu: Adding device 15820000.se to group 44
[ 0.253455] iommu: Adding device 15830000.se to group 45
[ 0.253630] iommu: Adding device 15840000.se to group 46
[ 0.254140] iommu: Adding device 17000000.gp10b to group 47
[ 0.255506] tegra-reset 5000000.clock: registered 193 resets.
[ 0.257513] iommu: Adding device d000000.bpmp to group 48
[ 0.257760] bpmp: ping status is 0
[ 0.257951] bpmp d000000.bpmp: firmware tag is 0705d30e2bb4ef1fcf63b70c5fc3deef
[ 0.258333] bpmp d000000.bpmp: probe ok
[ 0.261128] iommu: Adding device 2600000.dma to group 49
[ 0.261973] GPIO line 461 (cam0-rst) hogged as output/low
[ 0.262032] GPIO line 456 (cam0-pwdn) hogged as output/low
[ 0.262108] GPIO line 457 (cam1-rst) hogged as output/low
[ 0.262158] GPIO line 426 (cam1-pwdn) hogged as output/low
[ 0.262212] GPIO line 424 (wifi-enable) hogged as output/high
[ 0.262266] GPIO line 445 (sdmmc-wake-input) hogged as input
[ 0.262319] GPIO line 446 (sdmmc-wake-output) hogged as output/low
[ 0.262449] gpiochip_add_data: registered GPIOs 320 to 511 on device: tegra-gpio
[ 0.264348] GPIO line 315 (wifi-wake-ap) hogged as input
[ 0.264458] gpiochip_add_data: registered GPIOs 256 to 319 on device: tegra-gpio-aon
[ 0.265346] iommu: Adding device 10003000.pcie-controller to group 50
[ 0.265593] iommu: Adding device sound to group 51
[ 0.267375] iommu: Adding device 3510000.hda to group 52
[ 0.268523] iommu: Adding device adsp_audio to group 53
[ 0.269999] iommu: Adding device 2993000.adsp to group 54
[ 0.279271] vdd-ac-bat: 5000 mV
[ 0.281329] vdd-1v8-ap: 1800 mV
[ 0.282458] gpio tegra-gpio-aon wake30 for gpio=60(FF:4)
[ 0.282845] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 0.300703] SCSI subsystem initialized
[ 0.300919] libata version 3.00 loaded.
[ 0.301092] usbcore: registered new interface driver usbfs
[ 0.301149] usbcore: registered new interface driver hub
[ 0.301256] usbcore: registered new device driver usb
[ 0.305167] GPIO line 241 (touch-rail-1) hogged as output/high
[ 0.305610] GPIO line 242 (touch-rail-2) hogged as output/high
[ 0.305714] gpiochip_add_data: registered GPIOs 240 to 255 on device: tca9539
[ 0.307076] GPIO line 228 (lcd-bias-en-rail) hogged as output/high
[ 0.307165] gpiochip_add_data: registered GPIOs 224 to 239 on device: tca9539
[ 0.319484] media: Linux media interface: v0.10
[ 0.319630] Linux video capture interface: v2.00
[ 0.323638] pps_core: LinuxPPS API ver. 1 registered
[ 0.323680] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.323728] PTP clock support registered
[ 0.324599] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.324640] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.326089] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ 0.328070] GPIO line 221 (spmic_gpio_input_5) hogged as input
[ 0.328265] GPIO line 222 (spmic_gpio_input_6) hogged as input
[ 0.328353] gpiochip_add_data: registered GPIOs 216 to 223 on device: max77620-gpio
[ 0.334765] vddio-ddr: at 1125 mV
[ 0.338599] avdd_dsi_csi: 1200 mV
[ 0.342599] vdd-1v8: 1800 mV
[ 0.346600] vdd-3v3-sys: 3300 mV
[ 0.347634] spmic-ldo0: at 1800 mV
[ 0.348391] spmic-ldo1: at 800 mV
[ 0.354597] vddio-3v3: 3300 mV
[ 0.355208] vddio-sdmmc1: 1800 <–> 3300 mV at 3300 mV
[ 0.357350] vdd-rtc: at 800 mV
[ 0.358055] avdd-ts-hv: 1800 <–> 3300 mV at 1800 mV
[ 0.361347] spmic-ldo6: at 1500 mV
[ 0.365347] vdd-pex-1v05: 1000 mV
[ 0.365894] dvdd-pex: 1000 mV
[ 0.366159] max77620 4-003c: max77620 probe successful
[ 0.366402] Advanced Linux Sound Architecture Driver Initialized.
[ 0.367351] en-vdd-sd: 3300 mV
[ 0.367977] en-vdd-cam: 1800 mV
[ 0.369799] vdd-hdmi: 5000 mV
[ 0.369987] vdd-usb0-5v: 5000 mV
[ 0.370153] vdd-usb1-5v: 5000 mV
[ 0.373799] en-vdd-ts-1v8: 1800 mV
[ 0.377797] en-vdd-ts-hv-3v3: 3300 mV
[ 0.378313] en-vdd-disp-3v3: 3300 mV
[ 0.378821] en-mdm-pwr-3v7: 3700 mV
[ 0.379343] en-vdd-disp-1v8: 1800 mV
[ 0.379863] en-vdd-cam-hv-2v8: 2800 mV
[ 0.380384] en-vdd-cam-1v2: 1200 mV
[ 0.380900] vdd-fan: 5000 mV
[ 0.381006] vdd-3v3: 3300 mV
[ 0.381736] dis-vdd-1v2: 1200 mV
[ 0.381869] en-vdd-vcm-2v8: 2800 mV
[ 0.382396] vdd-usb2-5v: 5000 mV
[ 0.382503] vdd-sys-bl: 3300 mV
[ 0.383027] en-vdd-sys: 1200 mV
[ 0.384712] gpio tegra-gpio wake53 for gpio=159(X:7)
[ 0.386338] extcon-gpio-states external-connection:extcon@1: Cable state 1
[ 0.386712] clocksource: Switched to clocksource arch_sys_counter
[ 0.405778] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.406088] nvmap: nvmap_override_cache_ops() set roc flush ops to replace cache ops by set/ways
[ 0.406560] nvmap_page_pool_init: Total RAM pages: 2009466
[ 0.406575] nvmap_page_pool_init: nvmap page pool size: 251183 pages (981 MB)
[ 0.406782] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.411194] Wake76 for irq=199
[ 0.411206] Wake77 for irq=199
[ 0.411216] Wake78 for irq=199
[ 0.411225] Wake79 for irq=199
[ 0.411234] Wake80 for irq=199
[ 0.411242] Wake81 for irq=199
[ 0.411251] Wake82 for irq=199
[ 0.411976] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 0.412175] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 0.412290] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.412366] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.412755] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type AO-therm
[ 0.412896] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tboard_tegra
[ 0.413039] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tdiode_tegra
[ 0.413188] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type PMIC-Die
[ 0.413481] isomgr_init(): iso emc max clk=1866000KHz
[ 0.413492] isomgr_init(): max_iso_bw=26870400KB
[ 0.413571] NET: Registered protocol family 2
[ 0.413873] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.414095] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.414388] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.414443] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.414495] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.414653] NET: Registered protocol family 1
[ 0.414884] RPC: Registered named UNIX socket transport module.
[ 0.414898] RPC: Registered udp transport module.
[ 0.414908] RPC: Registered tcp transport module.
[ 0.414918] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.414937] PCI: CLS 0 bytes, default 128
[ 0.415034] Trying to unpack rootfs image as initramfs…
[ 0.428875] host1x 13e10000.host1x: initialized
[ 0.429710] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.431598] futex hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.431693] audit: initializing netlink subsys (disabled)
[ 0.431721] audit: type=2000 audit(0.420:1): initialized
[ 0.437899] io scheduler noop registered (default)
[ 0.440792] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.441947] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 0.442988] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.444014] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 0.447384] tsec 15500000.tsec: initialized
[ 0.448489] tsec 15100000.tsecb: initialized
[ 0.450791] nvdec 15480000.nvdec: initialized
[ 0.454390] falcon 15340000.vic: initialized
[ 0.455385] falcon 154c0000.nvenc: initialized
[ 0.456357] falcon 15380000.nvjpg: initialized
[ 0.457124] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 0.457628] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 0.458121] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 0.458614] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 0.459127] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 0.459621] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 0.460114] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 0.460607] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 0.463156] DC OR NODE connected to /host1x/sor1
[ 0.463297] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.463362] tegradc 15210000.nvdisplay: DT parsed successfully
[ 0.463392] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 0.463404] tegradc 15210000.nvdisplay: Display dc.ffffff8002320000 registered with id=0
[ 0.463423] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=1500000, max_bw=4687500
[ 0.471098] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[ 0.471118] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[ 0.471134] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[ 0.471180] tegradc 15210000.nvdisplay: vblank syncpt # 7 for dc 1
[ 0.471194] tegradc 15210000.nvdisplay: vpulse3 syncpt # 8 for dc 1
[ 0.471413] tegra-adma 2930000.adma: Tegra ADMA driver register 10 channels
[ 0.473591] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 0.473713] tegradc 15210000.nvdisplay: hdmi: no prod_list_hdmi_board, use default range
[ 0.473734] PD DISP0 index2 UP
[ 0.474613] PD DISP1 index3 UP
[ 0.474776] kfuse 3830000.kfuse: initialized
[ 0.474825] PD DISP2 index4 UP
[ 0.476015] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.476403] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.478261] console [ttyS0] disabled
[ 0.478303] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 37, base_baud = 25500000) is a Tegra
[ 0.501070] PD DISP2 index4 DOWN
[ 0.501228] PD DISP1 index3 DOWN
[ 0.501371] PD DISP0 index2 DOWN
[ 0.503344] tegradc 15210000.nvdisplay: probed
[ 2.557998] console [ttyS0] enabled
[ 2.560020] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 2.561080] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 39, base_baud = 0) is a TEGRA_UART
[ 2.561307] serial-tegra 3130000.serial: RX in PIO mode
[ 2.562199] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 40, base_baud = 0) is a TEGRA_UART
[ 2.572215] brd: module loaded
[ 2.576601] loop: module loaded
[ 2.576839] gpio tegra-gpio-aon wake35 for gpio=16(V:0)
[ 2.576857] nct1008_nct72 7-004c: find device tree node, parsing dt
[ 2.576861] nct1008_nct72 7-004c: starting parse dt
[ 2.576950] nct1008_nct72 7-004c: success parsing dt
[ 2.577065] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 2.590203] gk20a 17000000.gp10b: failed to allocate secure buffer -12
[ 2.613832] tmp451: Enabled overheat logging at 104.00C
[ 2.613951] gpio tegra-gpio-aon wake35 for gpio=16(V:0)
[ 2.613998] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 2.614270] Console: switching to colour frame buffer device 480x135
[ 2.616497] THERMAL EST: found 3 subdevs
[ 2.616501] THERMAL EST num_resources: 0
[ 2.616505] [THERMAL EST subdev 0]
[ 2.616509] [THERMAL EST subdev 1]
[ 2.616513] [THERMAL EST subdev 2]
[ 2.616791] thermal thermal_zone8: Registering thermal zone thermal_zone8 for type thermal-fan-est
[ 2.616793] THERMAL EST: thz register success.
[ 2.616982] THERMAL EST: end of probe, return err: 0
[ 2.617200] tegra_profiler: Branch: Dev
[ 2.617203] tegra_profiler: Version: 1.109
[ 2.617205] tegra_profiler: Samples version: 37
[ 2.617207] tegra_profiler: IO version: 21
[ 2.617214] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.617218] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.617222] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.617225] armv8_pmu: [1] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2
[ 2.617229] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.617231] armv8_pmu: [2] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2
[ 2.617234] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.617237] armv8_pmu: [3] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.617240] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.617243] armv8_pmu: [4] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.617246] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.617249] armv8_pmu: [5] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.617436] tegra_profiler: auth: init
[ 2.620806] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 2.620817] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 2.621785] scsi host0: tegra_ahci
[ 2.622154] scsi host1: tegra_ahci
[ 2.622313] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 25
[ 2.622316] ata2: DUMMY
[ 2.623257] spi-tegra114 3210000.spi: Static pin configuration used
[ 2.623743] spi-tegra114 c260000.spi: Static pin configuration used
[ 2.624144] spi-tegra114 3240000.spi: Static pin configuration used
[ 2.624952] tun: Universal TUN/TAP device driver, 1.6
[ 2.624955] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 2.625115] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 2.625117] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.625152] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.3.0-k
[ 2.625154] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.626253] PPP generic driver version 2.4.2
[ 2.626371] PPP BSD Compression module registered
[ 2.626381] PPP Deflate Compression module registered
[ 2.626400] PPP MPPE Compression module registered
[ 2.626413] NET: Registered protocol family 24
[ 2.626457] usbcore: registered new interface driver r8152
[ 2.626493] usbcore: registered new interface driver asix
[ 2.626519] usbcore: registered new interface driver ax88179_178a
[ 2.626544] usbcore: registered new interface driver cdc_ether
[ 2.626577] usbcore: registered new interface driver smsc95xx
[ 2.626602] usbcore: registered new interface driver net1080
[ 2.626630] usbcore: registered new interface driver cdc_subset
[ 2.626658] usbcore: registered new interface driver zaurus
[ 2.626701] usbcore: registered new interface driver cdc_ncm
[ 2.627005] Wake76 for irq=199
[ 2.627008] Wake77 for irq=199
[ 2.627010] Wake78 for irq=199
[ 2.627012] Wake79 for irq=199
[ 2.627014] Wake80 for irq=199
[ 2.627016] Wake81 for irq=199
[ 2.627018] Wake82 for irq=199
[ 2.627084] tegra-xotg xotg: usb2 phy is not available yet
[ 2.627855] usbcore: registered new interface driver usb-storage
[ 2.627926] usbcore: registered new interface driver usbserial
[ 2.627958] usbcore: registered new interface driver ftdi_sio
[ 2.627984] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.628021] usbcore: registered new interface driver option
[ 2.628044] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.628088] usbcore: registered new interface driver pl2303
[ 2.628110] usbserial: USB Serial support registered for pl2303
[ 2.628335] tegra-usb-cd usb_cd: otg phy is not available yet
[ 2.629318] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b 8c b7 52
[ 2.629876] libphy: dwc_phy: probed
[ 2.630802] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 2.691749] gpio tegra-gpio wake18 for gpio=101(M:5)
[ 2.691894] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 2.760487] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 2.762520] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 2.762543] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.762681] i2c /dev entries driver
[ 2.763447] gspca_main: v2.14.0 registered
[ 2.763489] usbcore: registered new interface driver gspca_zc3xx
[ 2.763726] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 2.765507] FAN dev name: pwm-fan
[ 2.765556] FAN:gpio request success.
[ 2.765561] FAN: can’t find tach_gpio
[ 2.765584] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 2.765721] pwm_fan_driver pwm-fan: unable to request PWM, trying legacy API
[ 2.765724] pwm_fan_driver pwm-fan: got pwm for fan
[ 2.765727] pwm_fan_driver pwm-fan: tach period: 1000
[ 2.766005] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 2.766008] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 2.766011] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 2.766014] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 2.766017] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 2.766020] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 2.766023] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 2.766026] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 2.766029] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 2.766032] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 2.766741] device-mapper: uevent: version 1.0.3
[ 2.766908] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 2.767209] sdhci: Secure Digital Host Controller Interface driver
[ 2.767210] sdhci: Copyright(c) Pierre Ossman
[ 2.767214] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.767489] sdhci-tegra 3460000.sdhci: Parent select= pll_p rate=408000000
[ 2.767774] sdhci-tegra 3460000.sdhci: Parent select= pll_c4_out0 rate=196249804
[ 2.768007] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 2.768462] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 2.768572] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.769983] usbcore: registered new interface driver usbhid
[ 2.769984] usbhid: USB HID core driver
[ 2.773505] nvadsp 2993000.adsp: in probe()…
[ 2.774939] nvadsp 2993000.adsp: Registering AMC Error Interrupt
[ 2.774971] nvadsp 2993000.adsp: AMC/ARAM initialized.
[ 2.775213] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ 2.781452] Denver: backdoor interface is NOT available.
[ 2.783536] coresight-tmc 8030000.etf: TMC initialized
[ 2.785742] coresight-tmc 8050000.etr: TMC initialized
[ 2.786224] coresight-tpiu 8060000.tpiu: TPIU initialized
[ 2.786829] coresight-funnel 9010000.funnel_bccplex: FUNNEL initialized
[ 2.787350] coresight-funnel 8010000.funnel_major: FUNNEL initialized
[ 2.787864] coresight-funnel 8820000.funnel_minor: FUNNEL initialized
[ 2.788347] coresight-replicator 8040000.replicator: REPLICATOR initialized
[ 2.789051] coresight-etm4x 9840000.ptm: ETM 4.0 initialized
[ 2.789676] coresight-etm4x 9940000.ptm: ETM 4.0 initialized
[ 2.790318] coresight-etm4x 9a40000.ptm: ETM 4.0 initialized
[ 2.790962] coresight-etm4x 9b40000.ptm: ETM 4.0 initialized
[ 2.790993] Module initialized successfully
[ 2.795038] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xa0000000
[ 2.796686] tegra186-cam-rtcpu b000000.rtcpu: already unhalted
[ 2.796934] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xa0110000-0xa011957f size=38272
[ 2.797317] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 2.797375] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x1900-0x3980 TX[64x128]=0x3980-0x5a00
[ 2.797417] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x5a00-0x5ac0 TX[1x64]=0x5ac0-0x5b80
[ 2.797457] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x5b80-0x7000 TX[16x320]=0x7000-0x8480
[ 2.797499] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8480-0x8900 TX[16x64]=0x8900-0x8d80
[ 2.797538] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x8d80-0x8f80 TX[1x384]=0x8f80-0x9180
[ 2.797576] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x384]=0x9180-0x9380 TX[1x384]=0x9380-0x9580
[ 2.797726] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (52)
[ 2.797728] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 2.798419] tegra-ivc ivc-b000000.rtcpu:echo@0: ivc channel driver missing
[ 2.798421] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: ivc channel driver missing
[ 2.798424] tegra-ivc ivc-b000000.rtcpu:mods@32c0: ivc channel driver missing
[ 2.798426] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivc channel driver missing
[ 2.798428] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivc channel driver missing
[ 2.798430] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: ivc channel driver missing
[ 2.798433] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: ivc channel driver missing
[ 2.798464] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=4 sha1=a8b1ecdd9615cd817a56df035be363fce3b0b88f
[ 2.803043] tegra-ivc-cdev ivc-b000000.rtcpu:echo@0: probing /dev/camchar-echo
[ 2.803923] tegra-ivc-cdev ivc-b000000.rtcpu:dbg@7c00: probing /dev/camchar-dbg
[ 2.804022] camchar: rtcpu character device driver loaded
[ 2.808962] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 2.809366] register_ari_mca_banks: Registered MCA ROC:IOB
[ 2.809595] register_ari_mca_banks: Registered MCA ROC:CCE
[ 2.810222] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 2.810254] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 2.810280] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 2.810310] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 2.810337] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 2.810364] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 2.810392] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 2.810421] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 2.810448] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 2.810474] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 2.810504] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 2.810534] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 2.810560] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 2.810586] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 2.810612] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 2.810661] **** A57 ECC: Enabled
[ 2.810664] tegra18_a57_serr_init: on CPU 4 a A57 Core
[ 2.810840] parse_throttle_dt_data: Num cap clks = 4
[ 2.810843] parse_throttle_dt_data: clk=mcpu type=1
[ 2.810845] parse_throttle_dt_data: clk=bcpu type=2
[ 2.810853] parse_throttle_dt_data: clk=gpu type=4
[ 2.810855] parse_throttle_dt_data: clk=emc type=3
[ 2.811418] tegra_throttle_probe: probe successful. #cdevs=4
[ 2.811521] tegra18x_actmon d230000.actmon: in actmon_register()…
[ 2.814735] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.814900] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 2.814945] sdhci-tegra 3440000.sdhci: Parent select= pll_p rate=408000000
[ 2.815212] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 2.815307] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 2.854732] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.854983] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 2.855037] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 2.855121] sdhci-tegra 3400000.sdhci: Parent select= pll_p rate=408000000
[ 2.855147] sdhci-tegra 3400000.sdhci: wakeup init done, cd_irq: 256
[ 2.855376] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 2.869209] mmc0: MAN_BKOPS_EN bit is not set
[ 2.876642] mmc0: Skipping tuning since strobe enabled
[ 2.884193] mmc0: periodic cache flush enabled
[ 2.884200] mmc0: new HS400 MMC card at address 0001
[ 2.884462] mmcblk0: mmc0:0001 032G34 29.1 GiB
[ 2.884583] mmcblk0boot0: mmc0:0001 032G34 partition 1 4.00 MiB
[ 2.884696] mmcblk0boot1: mmc0:0001 032G34 partition 2 4.00 MiB
[ 2.884810] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
[ 2.885947] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17
[ 2.898770] gpio tegra-gpio wake71 for gpio=125(P:5)
[ 2.898805] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.927235] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 2.946743] ata1: SATA link down (SStatus 0 SControl 300)
[ 3.124982] mmc1 tuning done saved tap delay=60
[ 3.124985] mmc1: hw tuning done …
[ 3.124993] mmc1: tuning_window[0]: 0xffffffff
[ 3.124999] mmc1: tuning_window[1]: 0xfffffe3f
[ 3.125004] mmc1: tuning_window[2]: 0xfff8ffff
[ 3.125010] mmc1: tuning_window[3]: 0x63ffffff
[ 3.125015] mmc1: tuning_window[4]: 0x0
[ 3.125051] mmc1: tuning_window[5]: 0x0
[ 3.125056] mmc1: tuning_window[6]: 0x0
[ 3.125061] mmc1: tuning_window[7]: 0x0
[ 3.125065] sdhci: Tap value: 60 | Trim value: 5
[ 3.125069] sdhci: SDMMC_VENDOR_INTR_STATUS[0x108]: 0x40000
[ 3.131358] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 3.131403] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 4.516603] tegradc 15210000.nvdisplay: fb registered
[ 4.525090] gpio tegra-gpio wake21 for gpio=121(P:1)
[ 4.533328] PD DISP0 index2 UP
[ 4.540613] PD DISP1 index3 UP
[ 4.547066] PD DISP2 index4 UP
[ 4.559498] Parent Clock set for DC plld2
[ 4.570621] tegradc 15210000.nvdisplay: hdmi: pclk:297000K, set prod-setting:prod_c_300M
[ 4.616813] tegra-se-nvhost 15810000.se: initialized
[ 4.629140] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 4.640664] tegra-se-nvhost 15820000.se: initialized
[ 4.650970] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 4.662515] tegra-se-nvhost 15830000.se: initialized
[ 4.672594] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 4.683976] tegra-se-nvhost 15840000.se: initialized
[ 4.694144] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 4.710427] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 4.725168] cpufreq: platform driver Initialization: pass
[ 4.733058] tegra_cluster_clk e090000.cluster_clk_priv: in probe()…
[ 4.742157] tegra_cluster_clk e090000.cluster_clk_priv: passed
[ 4.750479] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 4.762177] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 4.773748] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2ca995
[ 4.782404] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 4.784284] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 4.785028] tegra186-padctl 3520000.pinctrl: VBUS over-current detection enabled
[ 4.785733] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
[ 4.788121] cpuidle: Initializing cpuidle driver init for Denver cluster
[ 4.788247] cpuidle: Initializing cpuidle driver init for A57 cluster
[ 4.789323] tachometer tegra-tachometer: Tachometer driver tegra-tachometer registered
[ 4.789327] Tachometer driver initialized with pulse_per_rev: 2 and win_len: 2
[ 4.792573] tegra210_adsp_audio_platform_probe: platform probe started
[ 4.793713] tegra210-adsp adsp_audio: Default param-type to BYTE for mp3-dec1
[ 4.795307] tegra210-adsp adsp_audio: Default param-type to BYTE for spkprot
[ 4.796356] tegra210-adsp adsp_audio: Default param-type to BYTE for src
[ 4.797156] tegra210-adsp adsp_audio: Default param-type to BYTE for aac-dec1
[ 4.798148] tegra210-adsp adsp_audio: Default param-type to BYTE for aec
[ 4.798153] tegra210-adsp adsp_audio: adma channel page address dt entry not found
[ 4.798156] tegra210-adsp adsp_audio: using adma channel page 0
[ 4.805132] tegra210_adsp_audio_platform_probe probe successfull.
[ 4.805132] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 4.805299] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 4.812537] OPE platform probe
[ 4.812637] OPE platform probe successful
[ 4.819743] tegra-snd-t186ref-mobile-rt565x sound: Failed to get HP Det GPIO, should be handled by codec
[ 4.898263] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 4.898363] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 4.898461] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 4.898552] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 4.898641] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 4.898792] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 4.898890] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 4.898982] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 4.899091] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 4.899178] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 4.899272] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 4.899362] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 4.899458] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 4.899547] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 4.899648] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 4.899739] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 4.899831] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 4.899925] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 4.900017] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 4.900147] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 4.904051] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE1 <-> ADSP PCM1 mapping ok
[ 4.904150] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE2 <-> ADSP PCM2 mapping ok
[ 4.904178] compress asoc: ADSP-FE3 <-> ADSP COMPR1 mapping ok
[ 4.904203] compress asoc: ADSP-FE4 <-> ADSP COMPR2 mapping ok
[ 4.941549] input: tegra-snd-t186ref-mobile-rt565x Headphone Jack as /devices/sound/sound/card1/input2
[ 4.942245] tegra-snd-t186ref-mobile-rt565x sound: codec-dai “dit-hifi” registered
[ 4.942249] tegra-snd-t186ref-mobile-rt565x sound: This is a dummy codec
[ 4.942793] GACT probability NOT on
[ 4.942820] Mirror/redirect action on
[ 4.942830] u32 classifier
[ 4.942831] Actions configured
[ 4.942851] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[ 4.943623] ipip: IPv4 over IPv4 tunneling driver
[ 4.943947] Initializing XFRM netlink socket
[ 4.944278] NET: Registered protocol family 10
[ 4.945040] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 4.945111] NET: Registered protocol family 17
[ 4.945125] NET: Registered protocol family 15
[ 4.945149] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 4.945155] 8021q: 802.1Q VLAN Support v1.8
[ 4.945449] Registered cp15_barrier emulation handler
[ 4.945468] Registered setend emulation handler
[ 4.946974] registered taskstats version 1
[ 4.950964] isp 15600000.isp: initialized
[ 4.955031] nvcsi 150c0000.nvcsi: initialized
[ 4.955930] Wake76 for irq=199
[ 4.955932] Wake77 for irq=199
[ 4.955932] Wake78 for irq=199
[ 4.955933] Wake79 for irq=199
[ 4.955934] Wake80 for irq=199
[ 4.955934] Wake81 for irq=199
[ 4.955935] Wake82 for irq=199
[ 4.956260] xhci-tegra 3530000.xhci: UTMI port 0 has OTG_CAP
[ 4.956261] xhci-tegra 3530000.xhci: No USB3 port has OTG_CAP
[ 4.978993] spi-tegra114 3210000.spi: Static pin configuration used
[ 4.979127] xhci-tegra 3530000.xhci: Direct firmware load for tegra18x_xusb_firmware failed with error -2
[ 4.979129] xhci-tegra 3530000.xhci: Falling back to user helper
[ 4.979646] spi-tegra114 c260000.spi: Static pin configuration used
[ 4.980277] spi-tegra114 3240000.spi: Static pin configuration used
[ 4.980881] tegra-xotg xotg: OTG rev:0200, ADP:0, SRP:1, HNP:1, RSP:0
[ 4.980915] tegra-xotg xotg: update_id_state: ID floating
[ 4.980920] tegra-xotg xotg: update_vbus_state: VBUS detected
[ 4.980932] tegra-xotg xotg: Nvidia XUSB OTG Controller
[ 4.982655] tegra-xotg xotg: otg: gadget gadget registered
[ 4.982656] tegra-xotg xotg: set gadget otg_caps from OTG controller
[ 4.982658] tegra-xotg xotg: otg: host not registered yet
[ 4.982659] tegra-xotg xotg: otg: start OTG finite state machine
[ 4.982696] tegra-xudc-new 3550000.xudc: entering ELPG
[ 4.983284] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 4.983503] gpio tegra-gpio-aon wake29 for gpio=56(FF:0)
[ 4.983586] gpio tegra-gpio-aon wake67 for gpio=57(FF:1)
[ 4.983643] gpio tegra-gpio-aon wake68 for gpio=58(FF:2)
[ 4.983779] input: gpio-keys as /devices/gpio-keys/input/input3
[ 5.017346] tegra_rtc c2a0000.rtc: setting system clock to 2018-06-26 05:49:40 UTC (1529992180)
[ 5.047449] bpmp: mounted debugfs mirror
[ 5.047944] [dram-timers] DRAM derating cdev registered.
[ 5.051976] spmic-ldo0: disabling
[ 5.052183] spmic-ldo1: disabling
[ 5.052334] en-vdd-sd: disabling
[ 5.052336] en-vdd-cam: disabling
[ 5.052338] vdd-usb0-5v: disabling
[ 5.052340] vdd-usb1-5v: disabling
[ 5.052343] en-vdd-disp-3v3: disabling
[ 5.052344] en-mdm-pwr-3v7: disabling
[ 5.052346] en-vdd-disp-1v8: disabling
[ 5.052347] en-vdd-cam-hv-2v8: disabling
[ 5.052349] en-vdd-cam-1v2: disabling
[ 5.052350] vdd-fan: disabling
[ 5.052352] vdd-3v3: disabling
[ 5.052354] en-vdd-vcm-2v8: disabling
[ 5.052356] vdd-usb2-5v: disabling
[ 5.052358] vdd-sys-bl: disabling
[ 5.052359] en-vdd-sys: disabling
[ 5.058309] ALSA device list:
[ 5.058311] #0: tegra-hda at 0x3518000 irq 400
[ 5.058312] #1: tegra-snd-t186ref-mobile-rt565x
[ 5.059667] tegra-vi4 15700000.vi: initialized
[ 5.060845] tegra-vi4 15700000.vi: all channel register failed
[ 5.146757] tegra-usb-cd usb_cd: notification status (0x0, 0x1)
[ 5.146760] tegra-usb-cd usb_cd: set current 0ma
[ 5.146766] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 5.147831] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 5.147835] tegra-xudc-new 3550000.xudc: device mode on
[ 9.826738] random: nonblocking pool is initialized
[ 12.846596] tegradc 15210000.nvdisplay: hdmi: plugged
[ 12.851327] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 12.851339] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 12.851873] devtmpfs: mounted
[ 12.852153] Freeing unused kernel memory: 1164K (ffffffc0010cd000 - ffffffc0011f0000)
[ 12.852174] Freeing alternatives memory: 96K (ffffffc0011f0000 - ffffffc001208000)
[ 12.909109] tegradc 15210000.nvdisplay: read_edid_into_buffer: extension_blocks = 1, max_ext_blocks = 3
[ 12.921200] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[ 12.933521] tegradc 15210000.nvdisplay: hdmi_recheck_edid: read_edid_into_buffer() returned 256
[ 12.933526] tegradc 15210000.nvdisplay: old edid len = 256
[ 12.933530] tegradc 15210000.nvdisplay: hdmi: No EDID change. No userspace active. Using cached mode to initialize dc!
[ 12.977794] systemd[1]: Detected architecture arm64.
[ 20.073184] tegradc 15210000.nvdisplay: hdmi: plugged
[ 20.093837] systemd[1]: Set hostname to .
[ 20.201403] systemd[1]: Listening on udev Control Socket.
[ 20.214417] systemd[1]: Created slice System Slice.
[ 20.226282] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 20.239596] systemd[1]: Reached target Remote File Systems (Pre).
[ 20.252784] systemd[1]: Listening on Syslog Socket.
[ 20.270822] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 20.283761] systemd[1]: Listening on Journal Socket.
[ 20.297410] systemd[1]: Starting Create list of required static device nodes for the current kernel…
[ 20.317562] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 20.334079] systemd[1]: Reached target Swap.
[ 20.345508] systemd[1]: Started Braille Device Support.
[ 20.359677] systemd[1]: Starting Load Kernel Modules…
[ 20.370184] gpio tegra-gpio-aon wake30 for gpio=60(FF:4)
[ 20.379752] systemd[1]: Reached target Encrypted Volumes.
[ 20.391421] systemd[1]: Listening on Journal Audit Socket.
[ 20.402969] systemd[1]: Created slice system-getty.slice.
[ 20.417356] systemd[1]: Created slice User and Session Slice.
[ 20.430294] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 20.444164] systemd[1]: Listening on Journal Socket (/dev/log).
[ 20.457349] systemd[1]: Mounting Debug File System…
[ 20.468773] systemd[1]: Reached target Slices.
[ 20.479599] systemd[1]: Listening on LVM2 metadata daemon socket.
[ 20.493072] systemd[1]: Starting Journal Service…
[ 20.504384] systemd[1]: Reached target Remote File Systems.
[ 20.516277] systemd[1]: Reached target User and Group Name Lookups.
[ 20.532409] systemd[1]: Listening on LVM2 poll daemon socket.
[ 20.544856] systemd[1]: Listening on udev Kernel Socket.
[ 20.556606] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 20.570415] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling…
[ 20.589220] systemd[1]: Mounted Debug File System.
[ 20.600826] systemd[1]: Started Journal Service.
[ 20.725835] systemd-journald[274]: Received request to flush runtime journal from PID 1
[ 20.875113] tegra-pcie 10003000.pcie-controller: 4x1, 1x1 configuration
[ 20.888320] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[ 20.901382] tegra-pcie 10003000.pcie-controller: probing port 0, using 4 lanes
[ 20.924381] xhci-tegra 3530000.xhci: cannot find firmware…retry after 1 second
[ 20.944257] tegra-pcie 10003000.pcie-controller: probing port 2, using 1 lanes
[ 21.009088] dhd_module_init in
[ 21.016874] tegra_net_perf_init: cannot get wifi sclk
[ 21.026673] found wifi platform device bcmdhd_wlan
[ 21.037325] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 21.047348] wifi_platform_get_country_code_map: could not get country_code_map
[ 21.059275] wifi_plat_dev_drv_probe:platform country code map is not available
[ 21.071196] Power-up adapter ‘DHD generic adapter’
[ 21.080679] wifi_platform_set_power = 1
[ 21.290761] wifi_platform_bus_enumerate device present 1
[ 21.308760] wifi_platform_bus_enumerate device present 0
[ 21.309215] F1 signature read @0x18000000=0x17214354
[ 21.312921] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 21.313439] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 21.313497] wifi_platform_prealloc: failed to alloc static mem section 7
[ 21.313503] wifi_platform_get_mac_addr
[ 21.314965] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[ 21.315222] wl_create_event_handler(): thread:wl_event_handler:1a3 started
[ 21.315259] CFG80211-ERROR) wl_event_handler : tsk Enter, tsk = 0xffffffc07aa21a70
[ 21.315333] dhd_attach(): thread:dhd_watchdog_thread:1a4 started
[ 21.315398] dhd_attach(): thread:dhd_dpc:1a5 started
[ 21.315439] dhd_attach(): thread:dhd_rxf:1a6 started
[ 21.315444] dhd_deferred_work_init: work queue initialized
[ 21.315600] Dongle Host Driver, version 1.201.82 (r)
Compiled in drivers/net/wireless/bcmdhd on Jul 20 2017 at 00:47:12
[ 21.315868] tegra_sysfs_register
[ 21.315894] Register interface [wlan0] MAC: 00:04:4b:8c:b7:50
[ 21.315897] dhd_prot_ioctl : bus is down. we have nothing to do
[ 21.315989] sdhci-tegra 3440000.sdhci: Tuning already done, restoring the best tap value : 60
[ 21.317029] wifi_platform_set_power = 0
[ 21.443132] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 21.846733] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 21.924682] xhci-tegra 3530000.xhci: Firmware timestamp: 2017-03-31 06:21:56 UTC, Version: 55.07 release
[ 21.926730] xhci-tegra 3530000.xhci: xHCI Host Controller
[ 21.926745] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 1
[ 21.927546] xhci-tegra 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00010810
[ 21.927567] xhci-tegra 3530000.xhci: irq 59, io mem 0x03530000
[ 21.927678] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 21.927680] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 21.927682] usb usb1: Product: xHCI Host Controller
[ 21.927684] usb usb1: Manufacturer: Linux 4.4.38-tegra xhci-hcd
[ 21.927685] usb usb1: SerialNumber: 3530000.xhci
[ 21.927954] hub 1-0:1.0: USB hub found
[ 21.927974] hub 1-0:1.0: 4 ports detected
[ 21.943079] xhci-tegra 3530000.xhci: xHCI Host Controller
[ 21.943088] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 2
[ 21.943252] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 21.943254] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 21.943256] usb usb2: Product: xHCI Host Controller
[ 21.943258] usb usb2: Manufacturer: Linux 4.4.38-tegra xhci-hcd
[ 21.943259] usb usb2: SerialNumber: 3530000.xhci
[ 21.943521] hub 2-0:1.0: USB hub found
[ 21.943540] hub 2-0:1.0: 3 ports detected
[ 21.943847] tegra-xotg xotg: otg: host 3530000.xhci registered
[ 22.238720] usb 1-2: new high-speed USB device number 2 using xhci-tegra
[ 22.250206] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 22.252221] tegra-pcie 10003000.pcie-controller: link 0 down, ignoring
[ 22.367145] usb 1-2: New USB device found, idVendor=0451, idProduct=8027
[ 22.367148] usb 1-2: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[ 22.367150] usb 1-2: SerialNumber: EC02087936CA
[ 22.367641] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 6
[ 22.367846] hub 1-2:1.0: USB hub found
[ 22.367904] hub 1-2:1.0: 2 ports detected
[ 22.548672] cfg80211: World regulatory domain updated:
[ 22.548679] cfg80211: DFS Master region: unset
[ 22.548679] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 22.548684] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 22.548687] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 22.548689] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 22.548692] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 22.548696] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 22.548699] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 22.548701] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 22.548704] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 22.646720] usb 1-2.1: new low-speed USB device number 3 using xhci-tegra
[ 22.653121] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 22.738210] usb 1-2.1: New USB device found, idVendor=093a, idProduct=2510
[ 22.738212] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 22.738214] usb 1-2.1: Product: USB Optical Mouse
[ 22.738216] usb 1-2.1: Manufacturer: PixArt
[ 22.738401] usb 1-2.1: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 22.741248] input: PixArt USB Optical Mouse as /devices/3530000.xhci/usb1/1-2/1-2.1/1-2.1:1.0/0003:093A:2510.0001/input/input4
[ 22.741375] hid-generic 0003:093A:2510.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-3530000.xhci-2.1/input0
[ 22.810721] usb 1-2.2: new low-speed USB device number 4 using xhci-tegra
[ 22.904403] usb 1-2.2: New USB device found, idVendor=046d, idProduct=c31d
[ 22.904406] usb 1-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 22.904408] usb 1-2.2: Product: USB Keyboard
[ 22.904410] usb 1-2.2: Manufacturer: Logitech
[ 22.904594] usb 1-2.2: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 22.904616] usb 1-2.2: ep 0x82 - rounding interval to 1024 microframes, ep desc says 2040 microframes
[ 22.910797] input: Logitech USB Keyboard as /devices/3530000.xhci/usb1/1-2/1-2.2/1-2.2:1.0/0003:046D:C31D.0002/input/input5
[ 22.967013] hid-generic 0003:046D:C31D.0002: input,hidraw1: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-3530000.xhci-2.2/input0
[ 22.974188] input: Logitech USB Keyboard as /devices/3530000.xhci/usb1/1-2/1-2.2/1-2.2:1.1/0003:046D:C31D.0003/input/input6
[ 23.027894] hid-generic 0003:046D:C31D.0003: input,hidraw2: USB HID v1.10 Device [Logitech USB Keyboard] on usb-3530000.xhci-2.2/input1
[ 23.162679] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 23.567282] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 23.569300] tegra-pcie 10003000.pcie-controller: link 2 down, ignoring
[ 23.569308] tegra-pcie 10003000.pcie-controller: PCIE: no end points detected
[ 23.569489] tegra-pcie 10003000.pcie-controller: PCIE: Disable power rails
[ 23.590887] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 5
[ 23.590890] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work ignore firmware MBOX_CMD_DEC_SSPI_CLOCK request
[ 24.816118] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 24.827843]
[ 24.827857] wl_android_wifi_on in
[ 24.827860] wifi_platform_set_power = 1
[ 25.002579] gk20a 17000000.gp10b: railgate is disabled.
[ 25.111530] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 25.181144] sdhci-tegra 3440000.sdhci: Tuning already done, restoring the best tap value : 60
[ 25.182040] F1 signature read @0x18000000=0x17214354
[ 25.187703] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 25.188383] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 25.312932] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 25.355590] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[ 25.356133] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 25.356233] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 25.356239] Enabling wake69
[ 25.357592] wifi_platform_get_mac_addr
[ 25.360797] Firmware up: op_mode=0x0005, MAC=00:04:4b:8c:b7:50
[ 25.370465] dhd_preinit_ioctls pspretend_threshold for HostAPD failed -23
[ 25.377970] Firmware version = wl0: May 4 2017 13:48:00 version 7.35.221.21 (r697384) FWID 01-58d9d0b3
[ 25.381823] dhd_interworking_enable: failed to set WNM info, ret=-23
[ 25.382186] tegra_sysfs_on
[ 25.460906] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 25.462618] gpio tegra-gpio wake18 for gpio=101(M:5)
[ 25.463830] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 25.633337] CFGP2P-ERROR) wl_cfgp2p_add_p2p_disc_if : P2P interface registered
[ 25.650411] WLC_E_IF: NO_IF set, event Ignored
[ 26.314832] CPU1: shutdown
[ 26.317584] psci: CPU1 killed.
[ 26.350728] CPU2: shutdown
[ 26.350731] psci: CPU2 killed.
[ 26.523911] PD DISP2 index4 DOWN
[ 26.524072] PD DISP1 index3 DOWN
[ 26.524148] PD DISP0 index2 DOWN
[ 26.540328] PD DISP0 index2 UP
[ 26.543457] PD DISP1 index3 UP
[ 26.543562] PD DISP2 index4 UP
[ 26.545854] Parent Clock set for DC plld2
[ 26.547321] tegradc 15210000.nvdisplay: hdmi: pclk:297000K, set prod-setting:prod_c_300M
[ 29.054673] fuse init (API version 7.23)
[ 30.789163] PD DISP2 index4 DOWN
[ 30.789331] PD DISP1 index3 DOWN
[ 30.789409] PD DISP0 index2 DOWN
[ 30.813386] PD DISP0 index2 UP
[ 30.814230] PD DISP1 index3 UP
[ 30.814313] PD DISP2 index4 UP
[ 30.815872] Parent Clock set for DC plld2
[ 30.818275] tegradc 15210000.nvdisplay: hdmi: pclk:74250K, set prod-setting:prod_c_75M
[ 94.319184] usb 1-2.2: USB disconnect, device number 4
[ 98.358804] usb 1-2.2: new high-speed USB device number 5 using xhci-tegra
[ 98.451612] usb 1-2.2: New USB device found, idVendor=214b, idProduct=7000
[ 98.458709] usb 1-2.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 98.466285] usb 1-2.2: Product: USB2.0 HUB
[ 98.472582] hub 1-2.2:1.0: USB hub found
[ 98.476890] hub 1-2.2:1.0: 4 ports detected
[ 107.822818] usb 1-2.2.2: new low-speed USB device number 6 using xhci-tegra
[ 107.925246] usb 1-2.2.2: New USB device found, idVendor=046d, idProduct=c31d
[ 107.932429] usb 1-2.2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 107.940206] usb 1-2.2.2: Product: USB Keyboard
[ 107.944808] usb 1-2.2.2: Manufacturer: Logitech
[ 107.951114] usb 1-2.2.2: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 107.960411] usb 1-2.2.2: ep 0x82 - rounding interval to 1024 microframes, ep de
