My newly bought tx2 board crashed frequently after install jetpack 3.3. I tried to install jetback 3.2, it has the same issue.
In the first run after the initial installation, it can run for a while. Now it keeps crashing at 2min into the booting process :(.
Can anyone help? Thanks.
If you can use a serial console you should be able to get a log to post here. See:
[url]http://www.jetsonhacks.com/2017/03/24/serial-console-nvidia-jetson-tx2/[/url]
Otherwise there isn’t any information to go by…any detail you can provide would help.
I attache the kernel log. Thanks.
[code]
Starting kernel …
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.38-tegra (buildbrain@mobile-u64-773) (gcc ver8
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] earlycon: Early serial console at MMIO32 0x3100000 (options ‘’)
[ 0.000000] bootconsole [uart0] enabled
[ 0.000000] Reserved memory: initialized node ramoops_carveout, compatible s
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] PERCPU: Embedded 17 pages/cpu @ffffffc1f5f9a000 s31360 r8192 d32
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total p6
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=tt4
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 by)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 byte)
[ 0.000000] Memory: 7975976K/8208384K available (11296K kernel code, 1841K )
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000 ( 246)
[ 0.000000] vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8)
[ 0.000000] 0xffffffbdc2000000 - 0xffffffbdc9da0000 ( 125)
[ 0.000000] fixed : 0xffffffbffa7fd000 - 0xffffffbffac00000 ( 4108)
[ 0.000000] PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000 ( 16)
[ 0.000000] modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc1f6800000 ( 8040)
[ 0.000000] .init : 0xffffffc001132000 - 0xffffffc001256000 ( 1168)
[ 0.000000] .text : 0xffffffc000080000 - 0xffffffc001132000 ( 17096)
[ 0.000000] .data : 0xffffffc001278000 - 0xffffffc001444730 ( 1842)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles
[ 0.000002] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 439s
[ 0.009873] Console: colour dummy device 80x25
[ 0.014533] console [tty0] enabled
[ 0.018091] bootconsole [uart0] disabled
[ 0.022195] kmemleak: Kernel memory leak detector disabled
[ 0.022206] Calibrating delay loop (skipped), value calculated using timer )
[ 0.022218] pid_max: default: 32768 minimum: 301
[ 0.022266] Security Framework initialized
[ 0.022303] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022315] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 by)
[ 0.022696] Initializing cgroup subsys io
[ 0.022709] Initializing cgroup subsys memory
[ 0.022726] Initializing cgroup subsys devices
[ 0.022736] Initializing cgroup subsys freezer
[ 0.022745] Initializing cgroup subsys net_cls
[ 0.022755] Initializing cgroup subsys perf_event
[ 0.022764] Initializing cgroup subsys net_prio
[ 0.022774] Initializing cgroup subsys pids
[ 0.022783] Initializing cgroup subsys debug
[ 0.022921] CPU0 ipc=752
[ 0.022930] CPU1 ipc=1024
[ 0.022938] CPU2 ipc=1024
[ 0.022947] CPU3 ipc=752
[ 0.022956] CPU4 ipc=752
[ 0.022966] CPU5 ipc=752
[ 0.023002] ASID allocator initialised with 65536 entries
[ 0.046241] tegra-id: chipid=21817.
[ 0.046257] tegra-id: opt_subrevision=1.
[ 0.046271] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
[ 0.046968] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.s
[ 0.046995] DTB Build time: May 17 2018 00:17:47
[ 0.062585] CPU1: Booted secondary processor [4e0f0030]
[ 0.074103] CPU2: Booted secondary processor [4e0f0030]
[ 0.085832] CPU3: Booted secondary processor [411fd073]
[ 0.097818] CPU4: Booted secondary processor [411fd073]
[ 0.109815] CPU5: Booted secondary processor [411fd073]
[ 0.109878] Brought up 6 CPUs
[ 0.109936] SMP: Total of 6 processors activated.
[ 0.109948] CPU: All CPU(s) started at EL2
[ 0.110432] devtmpfs: initialized
[ 0.137001] Initilizing CustomIPI irq domain
[ 0.137193] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, s
[ 0.137946] pinctrl core: initialized pinctrl subsystem
[ 0.138119] OS set in device tree is not L4T.
[ 0.138313] regulator-dummy: no parameters
[ 0.138414] Initializing plugin-manager
[ 0.138465] Plugin module not found
[ 0.138871] node /plugin-manager/soc-prod-a02-fragment match with chip-id AP
[ 0.139199] node /plugin-manager/fragement@0 match with odm-data enable-dent
[ 0.139798] node /plugin-manager/fragement@4 match with odm-data enable-dent
[ 0.140940] node /plugin-manager/fragment-sdwake-p3310-1000-300 match with 0
[ 0.141290] node /plugin-manager/fragement-pmon-p3310-1000-300 match with b0
[ 0.141561] node /plugin-manager/fragement-pmon-p3310-1000-800 match with b0
[ 0.141780] node /plugin-manager/fragment-devslp@0 match with board >=3310-0
[ 0.142208] node /plugin-manager/fragment-500-pcie-config match with board 0
[ 0.142658] node /plugin-manager/fragment-500-xusb-config match with board 0
[ 0.142937] node /plugin-manager/fragment-500-e3325-pcie match with board >0
[ 0.143323] node /plugin-manager/fragment-p3310-c00-comm match with board >0
[ 0.143573] node /plugin-manager/fragment-p3310-c00-pmic match with board >0
[ 0.143799] node /plugin-manager/fragment-p3310-c01 match with board >=33100
[ 0.144062] node /plugin-manager/fragment-p3310-c03 match with board >=33100
[ 0.145660] node /plugin-manager/fragment-e3326@0 match with board 3326-*
[ 0.146764] node /plugin-manager/fragment-p3310-c00-camera match with board0
[ 0.148585] Adding domain adsp-pd to PM domain ape-pd
[ 0.150965] NET: Registered protocol family 16
[ 0.151808] console [pstore-1] enabled
[ 0.151820] pstore: Registered ramoops as persistent store backend
[ 0.151833] ramoops: attached 0x200000@0x277080000, ecc: 0/0
[ 0.161360] cpuidle: using governor ladder
[ 0.165832] cpuidle: using governor menu
[ 0.167003] bpmp: waiting for handshake
[ 0.167018] bpmp: handshake completed
[ 0.167059] bpmp: synchronizing channels
[ 0.167083] bpmp: channels synchronized
[ 0.167095] bpmp: mail init ok
[ 0.167444] vdso: 2 pages (1 code @ ffffffc00127d000, 1 data @ ffffffc00127)
[ 0.167477] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.168430] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atos
[ 0.169845] tegra_powergate_init: DONE
[ 0.169867] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.s
[ 0.169895] DTB Build time: May 17 2018 00:17:47
[ 0.170811] Tegra reboot handler registered.
[ 0.171867] Registering Tegra186 clocks (this may take a while)…done
[ 0.174009] arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.174027] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.174041] arm-smmu 12000000.iommu: stage 1 translation
[ 0.174054] arm-smmu 12000000.iommu: stage 2 translation
[ 0.174066] arm-smmu 12000000.iommu: nested translation
[ 0.174081] arm-smmu 12000000.iommu: stream matching with 128 regis0
[ 0.174100] arm-smmu 12000000.iommu: SMMU address space size (0x800000) dif!
[ 0.174119] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 on)
[ 0.174134] arm-smmu 12000000.iommu: Stage-1: 39-bit VA → 48-bit IA
[ 0.174148] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA → 48-bit A
[ 0.222212] arm-smmu 12000000.iommu: registered 67 master devices
[ 0.227892] iommu: Adding device 3460000.sdhci to group 0
[ 0.228708] iommu: Adding device 3400000.sdhci to group 1
[ 0.232655] iommu: Adding device 3507000.ahci-sata to group 2
[ 0.233093] iommu: Adding device 3160000.i2c to group 3
[ 0.233490] iommu: Adding device c240000.i2c to group 4
[ 0.233863] iommu: Adding device 3180000.i2c to group 5
[ 0.234259] iommu: Adding device 3190000.i2c to group 6
[ 0.234715] iommu: Adding device 31b0000.i2c to group 7
[ 0.235060] iommu: Adding device 31c0000.i2c to group 8
[ 0.235380] iommu: Adding device c250000.i2c to group 9
[ 0.235707] iommu: Adding device 31e0000.i2c to group 10
[ 0.237779] iommu: Adding device 3210000.spi to group 11
[ 0.238124] iommu: Adding device c260000.spi to group 12
[ 0.238451] iommu: Adding device 3240000.spi to group 13
[ 0.239304] iommu: Adding device 3100000.serial to group 14
[ 0.239661] iommu: Adding device 3110000.serial to group 15
[ 0.239962] iommu: Adding device c280000.serial to group 16
[ 0.240287] iommu: Adding device 3130000.serial to group 17
[ 0.241567] iommu: Adding device 2490000.ether_qos to group 18
[ 0.242215] iommu: Adding device b000000.rtcpu to group 19
[ 0.242694] iommu: Adding device c1a0000.aon to group 20
[ 0.243585] Wake73 for irq=42
[ 0.243886] iommu: Adding device smmu_test to group 21
[ 0.244460] mc: mapped MMIO address: 0xffffff8000560000 → 0x2c10000
[ 0.244502] mc: mapped MMIO address: 0xffffff8000640000 → 0x2c20000
[ 0.244539] mc: mapped MMIO address: 0xffffff8000660000 → 0x2c30000
[ 0.244580] mc: mapped MMIO address: 0xffffff8000fa0000 → 0x2c40000
[ 0.244616] mc: mapped MMIO address: 0xffffff8000fc0000 → 0x2c50000
[ 0.244674] mc-err: Set intmask: 0xf3140
[ 0.244891] ecc-err: dram ecc disabled-MC_ECC_CONTROL:0x0000000c
[ 0.245730] Wake76 for irq=199
[ 0.245757] Wake77 for irq=199
[ 0.245779] Wake78 for irq=199
[ 0.245800] Wake79 for irq=199
[ 0.245822] Wake80 for irq=199
[ 0.245843] Wake81 for irq=199
[ 0.245886] Wake82 for irq=199
[ 0.246008] iommu: Adding device 3530000.xhci to group 22
[ 0.246363] iommu: Adding device 3550000.xudc to group 23
[ 0.247208] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.247248] tegra-pmc: ### PMC reset source: Power on reset
[ 0.247281] tegra-pmc: ### PMC reset level: L0
[ 0.247309] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.247604] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registed
[ 0.247644] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.247806] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.247837] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 320
[ 0.248335] iommu: Adding device 13e10000.host1x to group 24
[ 0.248605] iommu: Adding device 13e10000.host1x:ctx0 to group 25
[ 0.248864] iommu: Adding device 13e10000.host1x:ctx1 to group 26
[ 0.249137] iommu: Adding device 13e10000.host1x:ctx2 to group 27
[ 0.249382] iommu: Adding device 13e10000.host1x:ctx3 to group 28
[ 0.249611] iommu: Adding device 13e10000.host1x:ctx4 to group 29
[ 0.249863] iommu: Adding device 13e10000.host1x:ctx5 to group 30
[ 0.250149] iommu: Adding device 13e10000.host1x:ctx6 to group 31
[ 0.250401] iommu: Adding device 13e10000.host1x:ctx7 to group 32
[ 0.250871] iommu: Adding device 150c0000.nvcsi to group 33
[ 0.251448] iommu: Adding device 15700000.vi to group 34
[ 0.251783] iommu: Adding device 15600000.isp to group 35
[ 0.252149] iommu: Adding device 15210000.nvdisplay to group 36
[ 0.252379] iommu: Adding device 15340000.vic to group 37
[ 0.252596] iommu: Adding device 154c0000.nvenc to group 38
[ 0.252819] iommu: Adding device 15480000.nvdec to group 39
[ 0.253122] iommu: Adding device 15380000.nvjpg to group 40
[ 0.253322] iommu: Adding device 15500000.tsec to group 41
[ 0.253539] iommu: Adding device 15100000.tsecb to group 42
[ 0.254231] iommu: Adding device 15810000.se to group 43
[ 0.254457] iommu: Adding device 15820000.se to group 44
[ 0.254678] iommu: Adding device 15830000.se to group 45
[ 0.254892] iommu: Adding device 15840000.se to group 46
[ 0.255372] iommu: Adding device 17000000.gp10b to group 47
[ 0.256703] tegra-reset 5000000.clock: registered 193 resets.
[ 0.259370] iommu: Adding device d000000.bpmp to group 48
[ 0.259618] bpmp: ping status is 0
[ 0.259796] bpmp d000000.bpmp: firmware tag is 83385b61e34297b2f37e76e0cd1fe
[ 0.260187] bpmp d000000.bpmp: probe ok
[ 0.262780] iommu: Adding device 2600000.dma to group 49
[ 0.263610] GPIO line 461 (cam0-rst) hogged as output/low
[ 0.263674] GPIO line 456 (cam0-pwdn) hogged as output/low
[ 0.263753] GPIO line 457 (cam1-rst) hogged as output/low
[ 0.263805] GPIO line 426 (cam1-pwdn) hogged as output/low
[ 0.263863] GPIO line 424 (wifi-enable) hogged as output/high
[ 0.263923] GPIO line 445 (sdmmc-wake-input) hogged as input
[ 0.263997] GPIO line 446 (sdmmc-wake-output) hogged as output/low
[ 0.264103] gpiochip_add_data: registered GPIOs 320 to 511 on device: tegrao
[ 0.265899] GPIO line 315 (wifi-wake-ap) hogged as input
[ 0.266036] gpiochip_add_data: registered GPIOs 256 to 319 on device: tegran
[ 0.266948] iommu: Adding device 10003000.pcie-controller to group 50
[ 0.267236] iommu: Adding device sound to group 51
[ 0.268944] iommu: Adding device 3510000.hda to group 52
[ 0.270174] iommu: Adding device adsp_audio to group 53
[ 0.271624] iommu: Adding device 2993000.adsp to group 54
[ 0.281131] vdd-ac-bat: 5000 mV
[ 0.283355] vdd-1v8-ap: 1800 mV
[ 0.300629] SCSI subsystem initialized
[ 0.301031] usbcore: registered new interface driver usbfs
[ 0.301083] usbcore: registered new interface driver hub
[ 0.301185] usbcore: registered new device driver usb
[ 0.305021] GPIO line 241 (touch-rail-1) hogged as output/high
[ 0.305468] GPIO line 242 (touch-rail-2) hogged as output/high
[ 0.305592] gpiochip_add_data: registered GPIOs 240 to 255 on device: tca959
[ 0.307003] GPIO line 228 (lcd-bias-en-rail) hogged as output/high
[ 0.307114] gpiochip_add_data: registered GPIOs 224 to 239 on device: tca959
[ 0.318159] media: Linux media interface: v0.10
[ 0.318220] Linux video capture interface: v2.00
[ 0.322240] pps_core: LinuxPPS API ver. 1 registered
[ 0.322268] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Gio>
[ 0.322312] PTP clock support registered
[ 0.323215] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sc
[ 0.323262] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.324707] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ 0.326917] GPIO line 221 (spmic_gpio_input_5) hogged as input
[ 0.327107] GPIO line 222 (spmic_gpio_input_6) hogged as input
[ 0.327198] gpiochip_add_data: registered GPIOs 216 to 223 on device: max77o
[ 0.334756] vddio-ddr: at 1125 mV
[ 0.338595] avdd_dsi_csi: 1200 mV
[ 0.342594] vdd-1v8: 1800 mV
[ 0.346595] vdd-3v3-sys: 3300 mV
[ 0.347664] spmic-ldo0: at 1800 mV
[ 0.348479] spmic-ldo1: at 800 mV
[ 0.354592] vddio-3v3: 3300 mV
[ 0.355229] vddio-sdmmc1: 1800 <–> 3300 mV at 3300 mV
[ 0.357357] vdd-rtc: at 800 mV
[ 0.358065] avdd-ts-hv: 1800 <–> 3300 mV at 1800 mV
[ 0.361355] spmic-ldo6: at 1500 mV
[ 0.365355] vdd-pex-1v05: 1000 mV
[ 0.365898] dvdd-pex: 1000 mV
[ 0.366160] max77620 4-003c: max77620 probe successful
[ 0.366409] Advanced Linux Sound Architecture Driver Initialized.
[ 0.367370] en-vdd-sd: 3300 mV
[ 0.367977] en-vdd-cam: 1800 mV
[ 0.369834] vdd-hdmi: 5000 mV
[ 0.370012] vdd-usb0-5v: 5000 mV
[ 0.370185] vdd-usb1-5v: 5000 mV
[ 0.373836] en-vdd-ts-1v8: 1800 mV
[ 0.377835] en-vdd-ts-hv-3v3: 3300 mV
[ 0.378361] en-vdd-disp-3v3: 3300 mV
[ 0.378866] en-mdm-pwr-3v7: 3700 mV
[ 0.379375] en-vdd-disp-1v8: 1800 mV
[ 0.379890] en-vdd-cam-hv-2v8: 2800 mV
[ 0.380408] en-vdd-cam-1v2: 1200 mV
[ 0.380925] vdd-fan: 5000 mV
[ 0.381046] vdd-3v3: 3300 mV
[ 0.381771] dis-vdd-1v2: 1200 mV
[ 0.381895] en-vdd-vcm-2v8: 2800 mV
[ 0.382410] vdd-usb2-5v: 5000 mV
[ 0.382518] vdd-sys-bl: 3300 mV
[ 0.383055] en-vdd-sys: 1200 mV
[ 0.386416] extcon-gpio-states external-connection:extcon@1: Cable state 0
[ 0.386795] clocksource: Switched to clocksource arch_sys_counter
[ 0.405041] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.405324] nvmap: nvmap_override_cache_ops() set roc flush ops to replace s
[ 0.405794] nvmap_page_pool_init: Total RAM pages: 2010378
[ 0.405812] nvmap_page_pool_init: nvmap page pool size: 251297 pages (981 M)
[ 0.405951] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.410472] Wake76 for irq=199
[ 0.410486] Wake77 for irq=199
[ 0.410497] Wake78 for irq=199
[ 0.410508] Wake79 for irq=199
[ 0.410518] Wake80 for irq=199
[ 0.410528] Wake81 for irq=199
[ 0.410537] Wake82 for irq=199
[ 0.411297] thermal thermal_zone0: Registering thermal zone thermal_zone0 fm
[ 0.411493] thermal thermal_zone1: Registering thermal zone thermal_zone1 fm
[ 0.411866] thermal thermal_zone2: Registering thermal zone thermal_zone2 fm
[ 0.411943] thermal thermal_zone3: Registering thermal zone thermal_zone3 fm
[ 0.412086] thermal thermal_zone4: Registering thermal zone thermal_zone4 fa
[ 0.412223] thermal thermal_zone5: Registering thermal zone thermal_zone5 fa
[ 0.412372] thermal thermal_zone6: Registering thermal zone thermal_zone6 fe
[ 0.412664] isomgr_init(): iso emc max clk=1866000KHz
[ 0.412676] isomgr_init(): max_iso_bw=26870400KB
[ 0.412761] NET: Registered protocol family 2
[ 0.413065] TCP established hash table entries: 65536 (order: 7, 524288 byt)
[ 0.413289] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.413582] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.413640] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.413695] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.413856] NET: Registered protocol family 1
[ 0.414071] RPC: Registered named UNIX socket transport module.
[ 0.414086] RPC: Registered udp transport module.
[ 0.414097] RPC: Registered tcp transport module.
[ 0.414109] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.414222] Trying to unpack rootfs image as initramfs…
[ 0.427959] host1x 13e10000.host1x: initialized
[ 0.428784] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters e
[ 0.430931] futex hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.431028] audit: initializing netlink subsys (disabled)
[ 0.431057] audit: type=2000 audit(0.420:1): initialized
[ 0.437848] io scheduler noop registered
[ 0.437951] io scheduler cfq registered (default)
[ 0.440845] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.442030] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 0.443085] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.444131] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 0.447511] tsec 15500000.tsec: initialized
[ 0.448634] tsec 15100000.tsecb: initialized
[ 0.450982] nvdec 15480000.nvdec: initialized
[ 0.454691] falcon 15340000.vic: initialized
[ 0.455727] falcon 154c0000.nvenc: initialized
[ 0.456732] falcon 15380000.nvjpg: initialized
[ 0.457502] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=5)
[ 0.457997] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=5)
[ 0.458492] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=5)
[ 0.459007] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=5)
[ 0.459501] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=6)
[ 0.459997] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=6)
[ 0.460488] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=6)
[ 0.460985] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=6)
[ 0.463610] DC OR NODE connected to /host1x/sor1
[ 0.463734] generic_infoframe_type: 0x87
[ 0.463744] tegra_camera_platform tegra-camera-platform: tegra_camera_probee
[ 0.463835] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iss
[ 0.463850] tegradc 15210000.nvdisplay: DT parsed successfully
[ 0.463867] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw0
[ 0.463882] tegradc 15210000.nvdisplay: Display dc.ffffff8002320000 registe0
[ 0.471101] tegra_nvdisp_bandwidth_register_max_config: max config iso bw =s
[ 0.471121] tegra_nvdisp_bandwidth_register_max_config: max config EMC flooz
[ 0.471138] tegra_nvdisp_bandwidth_register_max_config: max config hubclk =z
[ 0.471183] tegradc 15210000.nvdisplay: vblank syncpt # 7 for dc 1
[ 0.471199] tegradc 15210000.nvdisplay: vpulse3 syncpt # 8 for dc 1
[ 0.471335] tegra-adma 2930000.adma: Tegra ADMA driver register 10 channels
[ 0.473513] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initd
[ 0.473753] tegradc 15210000.nvdisplay: hdmi: no prod_list_hdmi_board, use e
[ 0.473869] kfuse 3830000.kfuse: initialized
[ 0.475069] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.475461] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.477311] console [ttyS0] disabled
[ 0.477356] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 37, base_baud = a
[ 0.477962] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 0.480042] tegradc 15210000.nvdisplay: probed
[ 2.570676] console [ttyS0] enabled
[ 2.572680] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 38, base_baud T
[ 2.572975] Console: switching to colour frame buffer device 80x30
[ 2.573745] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 39, base_baud T
[ 2.573953] serial-tegra 3130000.serial: RX in PIO mode
[ 2.574849] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 40, base_baud T
[ 2.600768] brd: module loaded
[ 2.603058] gk20a 17000000.gp10b: failed to allocate secure buffer -12
[ 2.605375] loop: module loaded
[ 2.605605] nct1008_nct72 7-004c: find device tree node, parsing dt
[ 2.605609] nct1008_nct72 7-004c: starting parse dt
[ 2.605696] nct1008_nct72 7-004c: success parsing dt
[ 2.605815] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 2.642674] tmp451: Enabled overheat logging at 104.00C
[ 2.642839] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 2.645167] THERMAL EST: found 3 subdevs
[ 2.645171] THERMAL EST num_resources: 0
[ 2.645174] [THERMAL EST subdev 0]
[ 2.645179] [THERMAL EST subdev 1]
[ 2.645183] [THERMAL EST subdev 2]
[ 2.645491] thermal thermal_zone7: Registering thermal zone thermal_zone7 ft
[ 2.645494] THERMAL EST: thz register success.
[ 2.645619] THERMAL EST: end of probe, return err: 0
[ 2.645669] tegra_profiler: Branch: Dev
[ 2.645671] tegra_profiler: Version: 1.117
[ 2.645674] tegra_profiler: Samples version: 41
[ 2.645675] tegra_profiler: IO version: 22
[ 2.645683] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.645688] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 01
[ 2.645692] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.645696] armv8_pmu: [1] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 1
[ 2.645699] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.645703] armv8_pmu: [2] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 1
[ 2.645706] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.645710] armv8_pmu: [3] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 01
[ 2.645713] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.645716] armv8_pmu: [4] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 01
[ 2.645720] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.645723] armv8_pmu: [5] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 01
[ 2.645911] tegra_profiler: auth: init
[ 2.649295] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3e
[ 2.649307] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp
[ 2.650278] scsi host0: tegra_ahci
[ 2.650697] scsi host1: tegra_ahci
[ 2.650865] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 05
[ 2.650868] ata2: DUMMY
[ 2.651819] spi-tegra114 3210000.spi: Static pin configuration used
[ 2.652307] spi-tegra114 c260000.spi: Static pin configuration used
[ 2.652723] spi-tegra114 3240000.spi: Static pin configuration used
[ 2.653547] tun: Universal TUN/TAP device driver, 1.6
[ 2.653549] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 2.653717] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 2.653719] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.653758] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.3.0-k
[ 2.653760] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.654872] PPP generic driver version 2.4.2
[ 2.655002] PPP BSD Compression module registered
[ 2.655010] PPP Deflate Compression module registered
[ 2.655036] PPP MPPE Compression module registered
[ 2.655049] NET: Registered protocol family 24
[ 2.655104] usbcore: registered new interface driver r8152
[ 2.655137] usbcore: registered new interface driver asix
[ 2.655165] usbcore: registered new interface driver ax88179_178a
[ 2.655190] usbcore: registered new interface driver cdc_ether
[ 2.655228] usbcore: registered new interface driver smsc75xx
[ 2.655285] usbcore: registered new interface driver net1080
[ 2.655314] usbcore: registered new interface driver cdc_subset
[ 2.655340] usbcore: registered new interface driver zaurus
[ 2.655384] usbcore: registered new interface driver cdc_ncm
[ 2.655627] Wake76 for irq=199
[ 2.655629] Wake77 for irq=199
[ 2.655631] Wake78 for irq=199
[ 2.655632] Wake79 for irq=199
[ 2.655634] Wake80 for irq=199
[ 2.655635] Wake81 for irq=199
[ 2.655637] Wake82 for irq=199
[ 2.655692] tegra-xotg xotg: usb2 phy is not available yet
[ 2.656416] usbcore: registered new interface driver cdc_acm
[ 2.656418] cdc_acm: USB Abstract Control Model driver for USB modems and Is
[ 2.656454] usbcore: registered new interface driver usb-storage
[ 2.656511] usbcore: registered new interface driver usbserial
[ 2.656535] usbcore: registered new interface driver cp210x
[ 2.656553] usbserial: USB Serial support registered for cp210x
[ 2.656578] usbcore: registered new interface driver ftdi_sio
[ 2.656595] usbserial: USB Serial support registered for FTDI USB Serial Dee
[ 2.656616] usbcore: registered new interface driver option
[ 2.656633] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.656654] usbcore: registered new interface driver pl2303
[ 2.656673] usbserial: USB Serial support registered for pl2303
[ 2.656891] tegra-usb-cd usb_cd: otg phy is not available yet
[ 2.657880] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b 8c ad f2
[ 2.658413] libphy: dwc_phy: probed
[ 2.659401] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 2.719975] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 2.788615] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as0
[ 2.790700] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 2.790714] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.790866] i2c /dev entries driver
[ 2.791599] [OV5693]: probing v4l2 sensor.
[ 2.970831] ata1: SATA link down (SStatus 0 SControl 300)
[ 3.214295] tegradc 15210000.nvdisplay: fb registered
[ 3.666426] gspca_main: v2.14.0 registered
[ 3.671706] usbcore: registered new interface driver gspca_zc3xx
[ 3.679169] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 3.689065] FAN dev name: pwm-fan
[ 3.693729] FAN:gpio request success.
[ 3.698672] FAN: can’t find tach_gpio
[ 3.703597] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 3.710662] pwm_fan_driver pwm-fan: got pwm for fan
[ 3.716672] pwm_fan_driver pwm-fan: tach period: 1000
[ 3.723117] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, 2
[ 3.732850] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=22
[ 3.742819] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=2
[ 3.752936] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=2
[ 3.763133] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=3
[ 3.772492] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=3
[ 3.781841] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=3
[ 3.791256] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=4
[ 3.800732] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd4
[ 3.810372] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd4
[ 3.821184] device-mapper: uevent: version 1.0.3
[ 3.827054] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dmm
[ 3.837847] sdhci: Secure Digital Host Controller Interface driver
[ 3.845001] sdhci: Copyright(c) Pierre Ossman
[ 3.850352] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.857236] sdhci-tegra 3460000.sdhci: Parent select= pll_p rate=408000000
[ 3.858691] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 3.858881] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.861053] usbcore: registered new interface driver usbhid
[ 3.861055] usbhid: USB HID core driver
[ 3.866723] nvadsp 2993000.adsp: in probe()…
[ 3.868841] nvadsp 2993000.adsp: Registering AMC Error Interrupt
[ 3.868880] nvadsp 2993000.adsp: AMC/ARAM initialized.
[ 3.869119] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ 3.869917] Denver: backdoor interface is NOT available.
[ 3.872372] coresight-tmc 8030000.etf: TMC initialized
[ 3.874901] coresight-tmc 8050000.etr: TMC initialized
[ 3.875455] coresight-tpiu 8060000.tpiu: TPIU initialized
[ 3.876020] coresight-funnel 9010000.funnel_bccplex: FUNNEL initialized
[ 3.876527] coresight-funnel 8010000.funnel_major: FUNNEL initialized
[ 3.877015] coresight-funnel 8820000.funnel_minor: FUNNEL initialized
[ 3.877506] coresight-replicator 8040000.replicator: REPLICATOR initialized
[ 3.878194] coresight-etm4x 9840000.ptm: ETM 4.0 initialized
[ 3.887842] coresight-etm4x 9940000.ptm: ETM 4.0 initialized
[ 3.888515] coresight-etm4x 9a40000.ptm: ETM 4.0 initialized
[ 3.889215] coresight-etm4x 9b40000.ptm: ETM 4.0 initialized
[ 3.889272] Module initialized successfully
[ 3.892634] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IO0
[ 3.894261] tegra186-cam-rtcpu b000000.rtcpu: already unhalted
[ 3.894597] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xa0110000-0xa011952
[ 3.895046] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]0
[ 3.895107] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=0
[ 3.895154] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x60
[ 3.895200] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 0
[ 3.895248] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 0
[ 3.895297] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x3840
[ 3.895342] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x3840
[ 3.895561] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (52)
[ 3.895564] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is sul
[ 3.896924] tegra-ivc ivc-b000000.rtcpu:echo@0: ivc channel driver missing
[ 3.896930] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: ivc channel driver mg
[ 3.896934] tegra-ivc ivc-b000000.rtcpu:mods@32c0: ivc channel driver missig
[ 3.896965] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivc channel driverg
[ 3.896968] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivc channel driverg
[ 3.896972] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: ivc channel driver missing
[ 3.896975] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: ivc channel driver missing
[ 3.897041] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=f
[ 3.902187] tegra-ivc-cdev ivc-b000000.rtcpu:echo@0: probing /dev/camchar-eo
[ 3.903231] tegra-ivc-cdev ivc-b000000.rtcpu:dbg@7c00: probing /dev/camcharg
[ 3.903460] camchar: rtcpu character device driver loaded
[ 3.907466] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 3.907720] register_ari_mca_banks: Registered MCA ROC:IOB
[ 3.907813] register_ari_mca_banks: Registered MCA ROC:CCE
[ 3.908165] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 3.908203] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 3.908234] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 3.908265] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 3.908298] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 3.908333] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 3.908362] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 3.908393] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 3.908423] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 3.908456] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 3.908487] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 3.908519] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 3.908585] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 3.908620] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 3.908649] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 3.908699] tegra18_a57_serr_init: on CPU 1 a Denver Core
[ 3.908837] parse_throttle_dt_data: Num cap clks = 4
[ 3.908844] parse_throttle_dt_data: clk=mcpu type=1
[ 3.908847] parse_throttle_dt_data: clk=bcpu type=2
[ 3.908854] parse_throttle_dt_data: clk=gpu type=4
[ 3.908857] parse_throttle_dt_data: clk=emc type=3
[ 3.909458] tegra_throttle_probe: probe successful. #cdevs=4
[ 3.909552] tegra18x_actmon d230000.actmon: in actmon_register()…
[ 3.910113] tegra18x_actmon d230000.actmon: initialization Completed for thl
[ 3.910454] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 ce
[ 3.913121] tegra-se-nvhost 15810000.se: initialized
[ 3.913654] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 3.914041] tegra-se-nvhost 15820000.se: initialized
[ 3.914661] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 3.915017] tegra-se-nvhost 15830000.se: initialized
[ 3.915172] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 3.915546] tegra-se-nvhost 15840000.se: initialized
[ 3.916264] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 3.921612] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 3.925675] cpufreq: platform driver Initialization: pass
[ 3.925812] tegra_cluster_clk e090000.cluster_clk_priv: in probe()…
[ 3.925897] tegra_cluster_clk e090000.cluster_clk_priv: passed
[ 3.926071] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003f
[ 3.926078] tegra186-padctl 3520000.pinctrl: ao mmio start 0x00000000035400f
[ 3.926112] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2eb095
[ 3.926117] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x8
[ 3.927609] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 3.928301] tegra186-padctl 3520000.pinctrl: VBUS over-current detection end
[ 3.928891] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supportd
[ 3.929306] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 3 not supportd
[ 3.931577] cpuidle: Initializing cpuidle driver init for Denver cluster
[ 3.931722] cpuidle: Initializing cpuidle driver init for A57 cluster
[ 3.932748] tachometer tegra-tachometer: Tachometer driver tegra-tachometerd
[ 3.932751] Tachometer driver initialized with pulse_per_rev: 2 and win_len2
[ 3.936919] tegra210_adsp_audio_platform_probe: platform probe started
[ 3.938014] tegra210-adsp adsp_audio: Default param-type to BYTE for mp3-de1
[ 3.943030] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/ca0
[ 3.943222] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/ca1
[ 3.943483] tegra210-adsp adsp_audio: Default param-type to BYTE for spkprot
[ 3.943985] tegra210-adsp adsp_audio: Default param-type to BYTE for src
[ 3.944415] tegra210-adsp adsp_audio: Default param-type to BYTE for aac-de1
[ 3.944926] tegra210-adsp adsp_audio: Default param-type to BYTE for aec
[ 3.944933] tegra210-adsp adsp_audio: adma channel page address dt entry nod
[ 3.944935] tegra210-adsp adsp_audio: using adma channel page 0
[ 3.957224] tegra210_adsp_audio_platform_probe probe successfull.
[ 3.957225] OPE platform probe
[ 3.957314] OPE platform probe successful
[ 4.049776] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF1 <-> ADMAIF1 mappk
[ 4.049872] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF2 <-> ADMAIF2 mappk
[ 4.049962] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF3 <-> ADMAIF3 mappk
[ 4.050055] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF4 <-> ADMAIF4 mappk
[ 4.050139] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF5 <-> ADMAIF5 mappk
[ 4.050225] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF6 <-> ADMAIF6 mappk
[ 4.050337] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF7 <-> ADMAIF7 mappk
[ 4.050424] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF8 <-> ADMAIF8 mappk
[ 4.050546] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF9 <-> ADMAIF9 mappk
[ 4.050634] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF10 <-> ADMAIF10 mak
[ 4.050720] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF11 <-> ADMAIF11 mak
[ 4.050835] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF12 <-> ADMAIF12 mak
[ 4.050924] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF13 <-> ADMAIF13 mak
[ 4.051009] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF14 <-> ADMAIF14 mak
[ 4.051118] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF15 <-> ADMAIF15 mak
[ 4.051202] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF16 <-> ADMAIF16 mak
[ 4.051304] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF17 <-> ADMAIF17 mak
[ 4.051393] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF18 <-> ADMAIF18 mak
[ 4.051479] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF19 <-> ADMAIF19 mak
[ 4.051580] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF20 <-> ADMAIF20 mak
[ 4.055039] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE1 <-> ADSP PCM1 mk
[ 4.055130] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE2 <-> ADSP PCM2 mk
[ 4.055154] compress asoc: ADSP-FE3 <-> ADSP COMPR1 mapping ok
[ 4.055182] compress asoc: ADSP-FE4 <-> ADSP COMPR2 mapping ok
[ 4.088904] input: tegra-snd-t186ref-mobile-rt565x Headphone Jack as /devic2
[ 4.089623] tegra-snd-t186ref-mobile-rt565x sound: codec-dai “dit-hifi” regd
[ 4.089626] tegra-snd-t186ref-mobile-rt565x sound: This is a dummy codec
[ 4.090082] GACT probability NOT on
[ 4.090091] Mirror/redirect action on
[ 4.090101] u32 classifier
[ 4.090102] Actions configured
[ 4.090119] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[ 4.090648] IPVS: Registered protocols ()
[ 4.090678] IPVS: Connection hash table configured (size=4096, memory=64Kby)
[ 4.090774] IPVS: Creating netns size=1424 id=0
[ 4.090824] IPVS: ipvs loaded.
[ 4.090830] IPVS: [rr] scheduler registered.
[ 4.090947] ipip: IPv4 over IPv4 tunneling driver
[ 4.091305] Initializing XFRM netlink socket
[ 4.091579] NET: Registered protocol family 10
[ 4.092244] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 4.092304] NET: Registered protocol family 17
[ 4.092317] NET: Registered protocol family 15
[ 4.092346] bridge: automatic filtering via arp/ip/ip6tables has been depre.
[ 4.092351] 8021q: 802.1Q VLAN Support v1.8
[ 4.103508] Registered cp15_barrier emulation handler
[ 4.115790] Registered setend emulation handler
[ 4.117509] registered taskstats version 1
[ 4.120526] isp 15600000.isp: initialized
[ 4.124130] nvcsi 150c0000.nvcsi: initialized
[ 4.125040] Wake76 for irq=199
[ 4.125041] Wake77 for irq=199
[ 4.125042] Wake78 for irq=199
[ 4.125043] Wake79 for irq=199
[ 4.125044] Wake80 for irq=199
[ 4.125044] Wake81 for irq=199
[ 4.125045] Wake82 for irq=199
[ 4.125356] xhci-tegra 3530000.xhci: UTMI port 0 has OTG_CAP
[ 4.125357] xhci-tegra 3530000.xhci: No USB3 port has OTG_CAP
[ 4.147076] spi-tegra114 3210000.spi: Static pin configuration used
[ 4.147224] xhci-tegra 3530000.xhci: Direct firmware load for tegra18x_xusb2
[ 4.147226] xhci-tegra 3530000.xhci: Falling back to user helper
[ 4.147706] spi-tegra114 c260000.spi: Static pin configuration used
[ 4.148399] spi-tegra114 3240000.spi: Static pin configuration used
[ 4.149105] tegra-xotg xotg: OTG rev:0200, ADP:0, SRP:1, HNP:1, RSP:0
[ 4.149140] tegra-xotg xotg: update_id_state: ID floating
[ 4.149144] tegra-xotg xotg: update_vbus_state: VBUS not detected
[ 4.149157] tegra-xotg xotg: Nvidia XUSB OTG Controller
[ 4.150906] tegra-xotg xotg: otg: gadget gadget registered
[ 4.150908] tegra-xotg xotg: set gadget otg_caps from OTG controller
[ 4.150910] tegra-xotg xotg: otg: host not registered yet
[ 4.150911] tegra-xotg xotg: otg: start OTG finite state machine
[ 4.150948] tegra-xudc-new 3550000.xudc: entering ELPG
[ 4.151680] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 4.152074] input: gpio-keys as /devices/gpio-keys/input/input3
[ 4.185795] tegra_rtc c2a0000.rtc: setting system clock to 2018-07-31 12:17)
[ 4.215799] bpmp: mounted debugfs mirror
[ 4.216322] [dram-timers] DRAM derating cdev registered.
[ 4.220911] spmic-ldo0: disabling
[ 4.221127] spmic-ldo1: disabling
[ 4.221273] vddio-sdmmc1: disabling
[ 4.221442] avdd-ts-hv: disabling
[ 4.221609] en-vdd-sd: disabling
[ 4.221611] en-vdd-cam: disabling
[ 4.221613] vdd-usb0-5v: disabling
[ 4.221615] vdd-usb1-5v: disabling
[ 4.221618] en-vdd-disp-3v3: disabling
[ 4.221620] en-mdm-pwr-3v7: disabling
[ 4.221621] en-vdd-disp-1v8: disabling
[ 4.221623] en-vdd-cam-hv-2v8: disabling
[ 4.221624] en-vdd-cam-1v2: disabling
[ 4.221625] vdd-fan: disabling
[ 4.221627] vdd-3v3: disabling
[ 4.221629] en-vdd-vcm-2v8: disabling
[ 4.221631] vdd-usb2-5v: disabling
[ 4.221632] vdd-sys-bl: disabling
[ 4.221634] en-vdd-sys: disabling
[ 4.229022] ALSA device list:
[ 4.229024] #0: tegra-hda at 0x3518000 irq 400
[ 4.229025] #1: tegra-snd-t186ref-mobile-rt565x
[ 4.229863] tegra-vi4 15700000.vi: initialized
[ 4.231118] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi-2 bound
[ 4.231121] tegra-vi4 15700000.vi: subdev ov5693 2-0036 bound
[ 5.330513] sdhci-tegra 3460000.sdhci: Parent select= pll_c4_out0 rate=19624
[ 5.338951] sdhci-tegra 3460000.sdhci: Client registration for eMC Successfl
[ 5.382833] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using Ar
[ 5.392958] sdhci-tegra 3440000.sdhci: Parent select= pll_p rate=408000000
[ 5.400489] sdhci-tegra 3440000.sdhci: Client registration for eMC Successfl
[ 5.442847] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using Ar
[ 5.452833] mmc0: MAN_BKOPS_EN bit is not set
[ 5.457924] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 5.460032] mmc0: Skipping tuning since strobe enabled
[ 5.467456] mmc0: periodic cache flush enabled
[ 5.467463] mmc0: new HS400 MMC card at address 0001
[ 5.467718] mmcblk0: mmc0:0001 032G34 29.1 GiB
[ 5.467842] mmcblk0boot0: mmc0:0001 032G34 partition 1 4.00 MiB
[ 5.467964] mmcblk0boot1: mmc0:0001 032G34 partition 2 4.00 MiB
[ 5.468077] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
[ 5.469293] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p19
[ 5.503216] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 5.521285] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 5.526606] sdhci-tegra 3400000.sdhci: Parent select= pll_p rate=408000000
[ 5.533975] sdhci-tegra 3400000.sdhci: wakeup init done, cd_irq: 256
[ 5.541112] sdhci-tegra 3400000.sdhci: Client registration for eMC Successfl
[ 5.590906] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using Ar
[ 5.696662] EXT4-fs (mmcblk0p1): 9 orphan inodes deleted
[ 5.700725] mmc1 tuning done saved tap delay=19
[ 5.700727] mmc1: hw tuning done …
[ 5.700733] mmc1: tuning_window[0]: 0xffffffff
[ 5.700738] mmc1: tuning_window[1]: 0xfffffc7f
[ 5.700744] mmc1: tuning_window[2]: 0xfff1ffff
[ 5.700748] mmc1: tuning_window[3]: 0x63ffffff
[ 5.700753] mmc1: tuning_window[4]: 0x0
[ 5.700757] mmc1: tuning_window[5]: 0x0
[ 5.700762] mmc1: tuning_window[6]: 0x0
[ 5.700766] mmc1: tuning_window[7]: 0x0
[ 5.700768] sdhci: Tap value: 19 | Trim value: 5
[ 5.700771] sdhci: SDMMC_VENDOR_INTR_STATUS[0x108]: 0x40000
[ 5.705410] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 5.705445] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 5.774702] EXT4-fs (mmcblk0p1): recovery complete
[ 5.785792] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode.)
[ 5.794656] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 5.803874] devtmpfs: mounted
[ 5.807593] Freeing unused kernel memory: 1168K (ffffffc001132000 - ffffffc)
[ 5.816285] Freeing alternatives memory: 96K (ffffffc001256000 - ffffffc001)
[ 5.835649] btb inv war enabled
[ 5.907390] random: systemd: uninitialized urandom read (16 bytes read, 99 )
[ 5.919111] random: systemd: uninitialized urandom read (16 bytes read, 99 )
[ 5.929718] random: systemd: uninitialized urandom read (16 bytes read, 99 )
[ 5.941421] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +S)
[ 5.962895] systemd[1]: Detected architecture arm64.
[ 5.977640] systemd[1]: Set hostname to .
[ 6.000146] random: systemd: uninitialized urandom read (16 bytes read, 102)
[ 6.002060] random: systemd-cryptse: uninitialized urandom read (16 bytes r)
[ 6.003266] random: systemd-sysv-ge: uninitialized urandom read (16 bytes r)
[ 6.017049] random: systemd-sysv-ge: uninitialized urandom read (16 bytes r)
[ 6.031129] random: systemd-sysv-ge: uninitialized urandom read (16 bytes r)
[ 6.061314] random: systemd: uninitialized urandom read (16 bytes read, 107)
[ 6.064600] random: systemd-gpt-aut: uninitialized urandom read (16 bytes r)
[ 6.155349] systemd[1]: Reached target Swap.
[ 6.161840] systemd[1]: Reached target Remote File Systems (Pre).
[ 6.169949] systemd[1]: Reached target Encrypted Volumes.
[ 6.177302] systemd[1]: Reached target Remote File Systems.
[ 6.185417] systemd[1]: Created slice User and Session Slice.
[ 6.193197] systemd[1]: Reached target User and Group Name Lookups.
[ 6.201519] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 6.210996] systemd[1]: Created slice System Slice.
[ 6.217924] systemd[1]: Started Forward Password Requests to Wall Dir
log1.txt (103 KB)
The directly pasted logs show normal other than stopping earlier than expected…but this might just be copy and paste issues. The actual attached log shows normal and indicates the system is running as expected. On the serial console do you still have the ability to interact after things seem to fail?
No I can’t interact with the system through serial con after it crashed
@linuxdev, I suspect that one of the reason for the crash has something to do with heat.
If we turn off the board keep it cool, then turn it on, it will run for about 2 hour or so before crashing. After that, if I turned it back on, it will crash immediately.
The problem is, I had check the CPU temperature it stayed constant at 36C. The fan is turned on through out.
Do you have any comment? What else I should do to diagnose this issue?
Heat issues would possibly stop even serial console, so this could be related. Is this not a dev kit? Is anything different about the fan? Is the fan running when things crash?
A very big advantage to serial console is that it typically runs longer than ssh or another method of connecting, even direct login. If serial console dies, then this is a clue, but you can still use a remote login to capture final moments since you know it runs normally until the end. So here are some suggestions on tests to run from the host PC (I would keep serial console running with “sudo dmesg --follow”, the rest can be from ssh)…
For the particular case of temperatures this should work until the moment of crash. You would probably need to add package “lm-sensors” (“sudo apt-get install lm-sensors”), but on that same terminal you could run:
watch -n 1 sensors
…the final value where the system works would be shown after crash.
Basically, anything remote displayed to your host PC should stay frozen at the final value. For example, ssh from host to Jetson would display a console terminal which would freeze at the final “good” screen. On your host you might run several ssh connections to the Jetson while it still works. Here are a suggested list of commands you might be interested in:
- watch -n 1 sensors (requires "sudo apt-get install lm-sensors"...this will show changes to "sensors" once per second)
- htop (requires "sudo apt-get install htop")
- sudo dmesg --follow
- ~ubuntu/tegrastats
Everything listed above, when run from the PC’s prompt, will have the ability of making copy and paste work on the host even after the Jetson crashes.
FYI, when you are creating a post, if you want to preserve formatting of a log or you want scroll bars added for longer content, highlight the text with the mouse and click the “</>” icon in the upper right of the new post editor…this turns it into “code”. You can click the “</>” ahead of time, and then paste your content between the two tags. Attaching also works.
I will try to capture other info. Meanwhile, this is the temps at the time of the crash collected through serial console
My board is devkit. The fan was running but stopped when it crashed. The temps did not change much through out the running period.
BCPU-therm-virtual-0
Adapter: Virtual device
temp1: +35.0°C (crit = +101.0°C)
MCPU-therm-virtual-0
GPU-therm-virtual-0
temp1: +41.0°C
AO-therm-virtual-0
temp1: +33.5°C (crit = -40.0°C)
Tboard_tegra-virtual-0
temp1: +33.0°C (crit = +107.0°C)
Tdiode_tegra-virtual-0
temp1: +33.5°C (crit = +107.0°C)
thermal-fan-est-virtual-0
temp1: +34.4°C
Temperatures can always make a difference, but it looks like those temperatures are easily within the acceptable range. If the fan stops at the time of crash, but temperature was ok, then I’d think it would get hotter after the crash if anything is still running (anything switching between 1 and 0 generates heat…it doesn’t matter if it is flawed and crashed).
Hopefully something will show up with whichever process is highest CPU usage (htop), or perhaps showing memory issues.
Note that a power line surge could also cause this, but it probably wouldn’t be so consistent.
Temperatures were ok, RAM wasn’t being overly consumed, CPU wasn’t seeing much of a load. I would expect Compiz to be about where it is on an idle system. Serial console didn’t show anything particularly interesting, but there have been some issues with ethernet, and it looks like this showed up as the lockup occurred:
[ 57.808356] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow contx
[ 57.808356] eqos 2490000.ethe[ 57.817551] IPv6: ADDRCONF(NETDEV_CHANGE): ey
r_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 57.817551] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Can you confirm the lockup started very close to the time this message came through? Can you run again and keep “dmesg --follow” running, and manually watch to see if the lockup occurs right after this message? If so, then we’ll have associated the problem with the ethernet.
Also, what USB devices are connected? Can you show the output of “lsusb -t” and “lsusb” prior to the crash? Your log shows normal content through approximately 9 seconds, and then skips up until about 57 seconds. Normally I would expect to see some USB activity notes at the point where yours stopped logging until the network eqos content. If you do have USB device attached other than simple keyboard/mouse (which don’t consume much power) you might try a powered USB HUB.
I reply on behalf of @robotdreamers
Jetson tx2 crashed frequently when I connected or not connected with ethernet, usb. I think that’s not a problem. Sometime I just provided power and do nothing, I don’t connect to any peripheral devices. But after a while (1 hour, 10 minutes, even immediately) TX2 is crashed without saving any logs in serial console. Then I tried to press and release power button, but nothing changed, jetson tx2 not booting up.
The power button requires longer than most to shut down when the system is running. Mine requires about 8 seconds of holding the power button down.
I can’t see anything outside of the Jetson causing the problem, and software isn’t pointing out anything, so it might be time to consider RMA. Normally if hardware itself is not failing there would be some sort of message on serial console.
About the only other test I can think of is to see if the Jetson is working in its most simplified way by cloning (you might want a backup of the rootfs anyway, but it is time consuming). Clone doesn’t run a full operating system, tests reading eMMC, and is very reliable if the hardware is working. See:
[url]https://devtalk.nvidia.com/default/topic/1000105/jetson-tx2/tx2-cloning/[/url]
If clone fails part way into the clone using a non-VM host it is very likely to be a hardware failure.
If you are interested in RMA there is some information near the top of this:
[url]https://devtalk.nvidia.com/default/topic/793798/embedded-systems/some-jetson-web-links/[/url]
Thank @linuxdevwhen i was running this command (sudo ./flash.sh -r -k APP -G backup.img jetson-tx2 mmcblk0p1), jetson tx2 crashed. This’s log in terminal. I think the problem is due to hardware failure.
log1.txt (68.3 KB)
then, I try again. while running that command, jetson tx2 is crashed.
log2.txt (213 KB)
The following assumes your host did not run out of disk space and that you are not using a VM. Check disk space via:
df -H /where/ever/the/clone/is/at
You may want to save the successful clone if you had anything you want, but it seems eMMC is marginal (a VM usually causes a similar failure…a non-VM should never see this). This should not have occurred in the first log:
write raw data fail - Success
Also we forgot to highlight that when we first opened the box and turned the board on, it did not turn on with pre-installed OS as promised.
But I don’t use a VM for jetpack, clone or anything, I just use Ubuntu 16.04.
I think the problem isn’t in clone process but in clone process, tx2 is crashed so it caused the error.
In this case I agree that the unit seems to be defective. eMMC read from a clone would normally be very reliable. Barring some obvious issues we already know are not causing a problem (e.g., we know it isn’t a VM and the host didn’t run out of disk space), I believe it is time to RMA. You can search for RMA near the top of this for some information:
Boards not having video are far different than boards not turning on…there are many issues with monitors not supported (e.g., all VGA monitors are unsupported, you must get lucky with a default mode). You’d need a serial console to see if turning on really failed (or perhaps something more obvious, like LEDs not going on). Under Windows the GUI mode is integrated, but under Linux you can essentially reboot just GUI while leaving the core system running (there are many annoying things in Windows needing full reboot to fix, but often under Linux subsets of the system can be restarted while leaving the core system uninterrupted). Lack of GUI mode video is usually not a reliable indicator of failure under Linux.
The original L4T release was far less reliable for video, so even if you had a valid monitor I’d say chances go up dramatically of video not configuring with that original release.
