Hi WayneWWW,
I’m using Jetson TX2 with Nvidia Developer Kit. I was testing gpio pins and then I rebooted the board. But I could not access to HDMI port, USB port. Now I have moved my all files to my local computer via ssh. I can also access serial console.
How do I get to access to hdmi? Is this problem seems to be permanent damage? If I remove and install everything, does it solve the issue?
Thanks a million in advance.
[ 0.000000] .data : 0xffffffc001278000 - 0xffffffc001444730 ( 1842 KB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000002] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.009869] Console: colour dummy device 80x25
[ 0.014528] console [tty0] enabled
[ 0.018086] bootconsole [uart0] disabled
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.38-tegra (buildbrain@mobile-u64-773) (gcc version 4.8.5 (GCC) ) #1 SMP PREEMPT Thu May 17 00:15:19 PDT 2018
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] earlycon: Early serial console at MMIO32 0x3100000 (options '')
[ 0.000000] bootconsole [uart0] enabled
[ 0.000000] Reserved memory: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] PERCPU: Embedded 17 pages/cpu @ffffffc1f5f9a000 s31360 r8192 d30080 u69632
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2019936
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 memtyp4
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7975976K/8208384K available (11296K kernel code, 1841K rwdata, 5796K rodata, 1168K init, 691K bss, 166872K reserved, 655)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000 ( 246 GB)
[ 0.000000] vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
[ 0.000000] 0xffffffbdc2000000 - 0xffffffbdc9da0000 ( 125 MB actual)
[ 0.000000] fixed : 0xffffffbffa7fd000 - 0xffffffbffac00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000 ( 16 MB)
[ 0.000000] modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc1f6800000 ( 8040 MB)
[ 0.000000] .init : 0xffffffc001132000 - 0xffffffc001256000 ( 1168 KB)
[ 0.000000] .text : 0xffffffc000080000 - 0xffffffc001132000 ( 17096 KB)
[ 0.022188] kmemleak: Kernel memory leak detector disabled
[ 0.022201] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.022213] pid_max: default: 32768 minimum: 301
[ 0.022261] Security Framework initialized
[ 0.022299] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022310] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022697] Initializing cgroup subsys io
[ 0.022709] Initializing cgroup subsys memory
[ 0.022727] Initializing cgroup subsys devices
[ 0.022736] Initializing cgroup subsys freezer
[ 0.022745] Initializing cgroup subsys net_cls
[ 0.022755] Initializing cgroup subsys perf_event
[ 0.022765] Initializing cgroup subsys net_prio
[ 0.022775] Initializing cgroup subsys pids
[ 0.022783] Initializing cgroup subsys debug
[ 0.022925] CPU0 ipc=752
[ 0.022934] CPU1 ipc=1024
[ 0.022942] CPU2 ipc=1024
[ 0.022951] CPU3 ipc=752
[ 0.022959] CPU4 ipc=752
[ 0.022969] CPU5 ipc=752
[ 0.023008] ASID allocator initialised with 65536 entries
[ 0.046301] tegra-id: chipid=21817.
[ 0.046318] tegra-id: opt_subrevision=1.
[ 0.046331] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
[ 0.047020] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.4/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/s
[ 0.047048] DTB Build time: May 17 2018 00:17:47
[ 0.062585] CPU1: Booted secondary processor [4e0f0030]
[ 0.074106] CPU2: Booted secondary processor [4e0f0030]
[ 0.085816] CPU3: Booted secondary processor [411fd073]
[ 0.097815] CPU4: Booted secondary processor [411fd073]
[ 0.109826] CPU5: Booted secondary processor [411fd073]
[ 0.109890] Brought up 6 CPUs
[ 0.109949] SMP: Total of 6 processors activated.
[ 0.109962] CPU: All CPU(s) started at EL2
[ 0.110388] devtmpfs: initialized
[ 0.137195] Initilizing CustomIPI irq domain
[ 0.137448] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.138203] pinctrl core: initialized pinctrl subsystem
[ 0.138376] OS set in device tree is not L4T.
[ 0.138564] regulator-dummy: no parameters
[ 0.138670] Initializing plugin-manager
[ 0.138722] Plugin module not found
[ 0.139125] node /plugin-manager/soc-prod-a02-fragment match with chip-id A02P
[ 0.139457] node /plugin-manager/fragement@0 match with odm-data enable-denver-wdt
[ 0.140057] node /plugin-manager/fragement@4 match with odm-data enable-denver-wdt
[ 0.141192] node /plugin-manager/fragment-sdwake-p3310-1000-300 match with board >=3310-1000-300
[ 0.141565] node /plugin-manager/fragement-pmon-p3310-1000-300 match with board >=3310-1000-300
[ 0.141816] node /plugin-manager/fragement-pmon-p3310-1000-800 match with board >=3310-1000-800
[ 0.142033] node /plugin-manager/fragment-devslp@0 match with board >=3310-1000-200
[ 0.142448] node /plugin-manager/fragment-500-pcie-config match with board >=3310-1000-500
[ 0.142883] node /plugin-manager/fragment-500-xusb-config match with board >=3310-1000-500
[ 0.143160] node /plugin-manager/fragment-500-e3325-pcie match with board >=3310-1000-500
[ 0.143532] node /plugin-manager/fragment-p3310-c00-comm match with board >=3310-1000-800
[ 0.143774] node /plugin-manager/fragment-p3310-c00-pmic match with board >=3310-1000-800
[ 0.143990] node /plugin-manager/fragment-p3310-c01 match with board >=3310-1000-900
[ 0.144244] node /plugin-manager/fragment-p3310-c03 match with board >=3310-1000-B00
[ 0.146152] node /plugin-manager/fragment-p3310-c00-camera match with board >=3310-1000-800
[ 0.147930] Adding domain adsp-pd to PM domain ape-pd
[ 0.150286] NET: Registered protocol family 16
[ 0.151105] console [pstore-1] enabled
[ 0.151117] pstore: Registered ramoops as persistent store backend
[ 0.151131] ramoops: attached 0x200000@0x277080000, ecc: 0/0
[ 0.161359] cpuidle: using governor ladder
[ 0.165816] cpuidle: using governor menu
[ 0.166937] bpmp: waiting for handshake
[ 0.166951] bpmp: handshake completed
[ 0.166993] bpmp: synchronizing channels
[ 0.167019] bpmp: channels synchronized
[ 0.167030] bpmp: mail init ok
[ 0.167370] vdso: 2 pages (1 code @ ffffffc00127d000, 1 data @ ffffffc00127c000)
[ 0.167404] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.168337] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.169750] tegra_powergate_init: DONE
[ 0.169771] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.4/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/s
[ 0.169797] DTB Build time: May 17 2018 00:17:47
[ 0.170736] Tegra reboot handler registered.
[ 0.171775] Registering Tegra186 clocks (this may take a while)...done
[ 0.173902] arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.173920] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.173933] arm-smmu 12000000.iommu: stage 1 translation
[ 0.173945] arm-smmu 12000000.iommu: stage 2 translation
[ 0.173957] arm-smmu 12000000.iommu: nested translation
[ 0.173972] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.173990] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.174009] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.174023] arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.174036] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.222711] arm-smmu 12000000.iommu: registered 67 master devices
[ 0.228054] iommu: Adding device 3460000.sdhci to group 0
[ 0.228910] iommu: Adding device 3400000.sdhci to group 1
[ 0.232689] iommu: Adding device 3507000.ahci-sata to group 2
[ 0.233123] iommu: Adding device 3160000.i2c to group 3
[ 0.233558] iommu: Adding device c240000.i2c to group 4
[ 0.233930] iommu: Adding device 3180000.i2c to group 5
[ 0.234311] iommu: Adding device 3190000.i2c to group 6
[ 0.234823] iommu: Adding device 31b0000.i2c to group 7
[ 0.235153] iommu: Adding device 31c0000.i2c to group 8
[ 0.235489] iommu: Adding device c250000.i2c to group 9
[ 0.235850] iommu: Adding device 31e0000.i2c to group 10
[ 0.237862] iommu: Adding device 3210000.spi to group 11
[ 0.238196] iommu: Adding device c260000.spi to group 12
[ 0.238510] iommu: Adding device 3240000.spi to group 13
[ 0.239342] iommu: Adding device 3100000.serial to group 14
[ 0.239671] iommu: Adding device 3110000.serial to group 15
[ 0.239962] iommu: Adding device c280000.serial to group 16
[ 0.240286] iommu: Adding device 3130000.serial to group 17
[ 0.241490] iommu: Adding device 2490000.ether_qos to group 18
[ 0.242205] iommu: Adding device b000000.rtcpu to group 19
[ 0.242736] iommu: Adding device c1a0000.aon to group 20
[ 0.243665] Wake73 for irq=42
[ 0.244029] iommu: Adding device smmu_test to group 21
[ 0.244574] mc: mapped MMIO address: 0xffffff8000560000 -> 0x2c10000
[ 0.244617] mc: mapped MMIO address: 0xffffff8000640000 -> 0x2c20000
[ 0.244656] mc: mapped MMIO address: 0xffffff8000660000 -> 0x2c30000
[ 0.244693] mc: mapped MMIO address: 0xffffff8000fa0000 -> 0x2c40000
[ 0.244729] mc: mapped MMIO address: 0xffffff8000fc0000 -> 0x2c50000
[ 0.244764] mc-err: Set intmask: 0xf3140
[ 0.245043] ecc-err: dram ecc disabled-MC_ECC_CONTROL:0x0000000c
[ 0.245871] Wake76 for irq=199
[ 0.245897] Wake77 for irq=199
[ 0.245919] Wake78 for irq=199
[ 0.245940] Wake79 for irq=199
[ 0.245960] Wake80 for irq=199
[ 0.245980] Wake81 for irq=199
[ 0.246022] Wake82 for irq=199
[ 0.246141] iommu: Adding device 3530000.xhci to group 22
[ 0.246483] iommu: Adding device 3550000.xudc to group 23
[ 0.247353] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.247387] tegra-pmc: ### PMC reset source: Power on reset
[ 0.247412] tegra-pmc: ### PMC reset level: L0
[ 0.247434] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.247716] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.247756] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.247921] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.247952] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 320
[ 0.248443] iommu: Adding device 13e10000.host1x to group 24
[ 0.248731] iommu: Adding device 13e10000.host1x:ctx0 to group 25
[ 0.249001] iommu: Adding device 13e10000.host1x:ctx1 to group 26
[ 0.249273] iommu: Adding device 13e10000.host1x:ctx2 to group 27
[ 0.249510] iommu: Adding device 13e10000.host1x:ctx3 to group 28
[ 0.249735] iommu: Adding device 13e10000.host1x:ctx4 to group 29
[ 0.249978] iommu: Adding device 13e10000.host1x:ctx5 to group 30
[ 0.250226] iommu: Adding device 13e10000.host1x:ctx6 to group 31
[ 0.250464] iommu: Adding device 13e10000.host1x:ctx7 to group 32
[ 0.250926] iommu: Adding device 150c0000.nvcsi to group 33
[ 0.251491] iommu: Adding device 15700000.vi to group 34
[ 0.251813] iommu: Adding device 15600000.isp to group 35
[ 0.252179] iommu: Adding device 15210000.nvdisplay to group 36
[ 0.252420] iommu: Adding device 15340000.vic to group 37
[ 0.252626] iommu: Adding device 154c0000.nvenc to group 38
[ 0.252867] iommu: Adding device 15480000.nvdec to group 39
[ 0.253183] iommu: Adding device 15380000.nvjpg to group 40
[ 0.253418] iommu: Adding device 15500000.tsec to group 41
[ 0.253619] iommu: Adding device 15100000.tsecb to group 42
[ 0.254335] iommu: Adding device 15810000.se to group 43
[ 0.254569] iommu: Adding device 15820000.se to group 44
[ 0.254795] iommu: Adding device 15830000.se to group 45
[ 0.255018] iommu: Adding device 15840000.se to group 46
[ 0.255542] iommu: Adding device 17000000.gp10b to group 47
[ 0.256869] tegra-reset 5000000.clock: registered 193 resets.
[ 0.258891] iommu: Adding device d000000.bpmp to group 48
[ 0.259155] bpmp: ping status is 0
[ 0.259338] bpmp d000000.bpmp: firmware tag is 83385b61e34297b2f37e76e0cd1ff81e
[ 0.259719] bpmp d000000.bpmp: probe ok
[ 0.262287] iommu: Adding device 2600000.dma to group 49
[ 0.263130] GPIO line 461 (cam0-rst) hogged as output/low
[ 0.263193] GPIO line 456 (cam0-pwdn) hogged as output/low
[ 0.263285] GPIO line 457 (cam1-rst) hogged as output/low
[ 0.263338] GPIO line 426 (cam1-pwdn) hogged as output/low
[ 0.263388] GPIO line 424 (wifi-enable) hogged as output/high
[ 0.263437] GPIO line 445 (sdmmc-wake-input) hogged as input
[ 0.263486] GPIO line 446 (sdmmc-wake-output) hogged as output/low
[ 0.263619] gpiochip_add_data: registered GPIOs 320 to 511 on device: tegra-gpio
[ 0.265484] GPIO line 315 (wifi-wake-ap) hogged as input
[ 0.265582] gpiochip_add_data: registered GPIOs 256 to 319 on device: tegra-gpio-aon
[ 0.266444] iommu: Adding device 10003000.pcie-controller to group 50
[ 0.266730] iommu: Adding device sound to group 51
[ 0.268421] iommu: Adding device 3510000.hda to group 52
[ 0.269564] iommu: Adding device adsp_audio to group 53
[ 0.270975] iommu: Adding device 2993000.adsp to group 54
[ 0.280519] vdd-ac-bat: 5000 mV
[ 0.282664] vdd-1v8-ap: 1800 mV
[ 0.300637] SCSI subsystem initialized
[ 0.301011] usbcore: registered new interface driver usbfs
[ 0.301073] usbcore: registered new interface driver hub
[ 0.301203] usbcore: registered new device driver usb
[ 0.303843] tegra-i2c 3160000.i2c: arb lost in communicate to add 0x74
[ 0.304101] tegra-i2c 3160000.i2c: Un-recovered Arb lost
[ 0.304158] pca953x 0-0074: failed reading register
[ 0.304230] pca953x: probe of 0-0074 failed with error -5
[ 0.304673] tegra-i2c 3160000.i2c: arb lost in communicate to add 0x77
[ 0.304915] tegra-i2c 3160000.i2c: Un-recovered Arb lost
[ 0.304942] pca953x 0-0077: failed reading register
[ 0.304997] pca953x: probe of 0-0077 failed with error -5
[ 0.315515] media: Linux media interface: v0.10
[ 0.315580] Linux video capture interface: v2.00
[ 0.319472] pps_core: LinuxPPS API ver. 1 registered
[ 0.319526] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.319574] PTP clock support registered
[ 0.320413] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.320463] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.321983] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ 0.324056] GPIO line 253 (spmic_gpio_input_5) hogged as input
[ 0.324279] GPIO line 254 (spmic_gpio_input_6) hogged as input
[ 0.324382] gpiochip_add_data: registered GPIOs 248 to 255 on device: max77620-gpio
[ 0.330278] vddio-ddr: at 1125 mV
[ 0.334117] avdd_dsi_csi: 1200 mV
[ 0.338115] vdd-1v8: 1800 mV
[ 0.342122] vdd-3v3-sys: 3300 mV
[ 0.343187] spmic-ldo0: at 1800 mV
[ 0.343954] spmic-ldo1: at 800 mV
[ 0.346127] vddio-3v3: 3300 mV
[ 0.346838] vddio-sdmmc1: 1800 <--> 3300 mV at 3300 mV
[ 0.350118] vdd-rtc: at 800 mV
[ 0.350924] avdd-ts-hv: 1800 <--> 3300 mV at 1800 mV
[ 0.354117] spmic-ldo6: at 1500 mV
[ 0.357359] vdd-pex-1v05: 1000 mV
[ 0.357930] dvdd-pex: 1000 mV
[ 0.358211] max77620 4-003c: max77620 probe successful
[ 0.358465] Advanced Linux Sound Architecture Driver Initialized.
[ 0.359423] en-vdd-sd: 3300 mV
[ 0.359688] vdd-usb0-5v: 5000 mV
[ 0.359860] vdd-usb1-5v: 5000 mV
[ 0.360217] vdd-3v3: 3300 mV
[ 0.360356] en-vdd-vcm-2v8: 2800 mV
[ 0.360493] vdd-sys-bl: 3300 mV
[ 0.363784] extcon-gpio-states external-connection:extcon@1: Cable state 0
[ 0.364175] clocksource: Switched to clocksource arch_sys_counter
[ 0.382516] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.382798] nvmap: nvmap_override_cache_ops() set roc flush ops to replace cache ops by set/ways
[ 0.383271] nvmap_page_pool_init: Total RAM pages: 2010378
[ 0.383289] nvmap_page_pool_init: nvmap page pool size: 251297 pages (981 MB)
[ 0.383364] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.388030] Wake76 for irq=199
[ 0.388044] Wake77 for irq=199
[ 0.388055] Wake78 for irq=199
[ 0.388065] Wake79 for irq=199
[ 0.388075] Wake80 for irq=199
[ 0.388085] Wake81 for irq=199
[ 0.388095] Wake82 for irq=199
[ 0.388837] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 0.389036] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 0.389417] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.389494] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.389639] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[ 0.389782] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 0.389928] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type PMIC-Die
[ 0.390220] isomgr_init(): iso emc max clk=1866000KHz
[ 0.390233] isomgr_init(): max_iso_bw=26870400KB
[ 0.390315] NET: Registered protocol family 2
[ 0.390665] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.390889] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.391180] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.391240] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.391294] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.391459] NET: Registered protocol family 1
[ 0.391640] RPC: Registered named UNIX socket transport module.
[ 0.391656] RPC: Registered udp transport module.
[ 0.391667] RPC: Registered tcp transport module.
[ 0.391678] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.391791] Trying to unpack rootfs image as initramfs...
[ 0.405525] host1x 13e10000.host1x: initialized
[ 0.406353] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.407976] futex hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.408070] audit: initializing netlink subsys (disabled)
[ 0.408114] audit: type=2000 audit(0.392:1): initialized
[ 0.416039] io scheduler noop registered
[ 0.416261] io scheduler cfq registered (default)
[ 0.419832] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.421359] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 0.422707] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.424025] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 0.428740] tsec 15500000.tsec: initialized
[ 0.430173] tsec 15100000.tsecb: initialized
[ 0.433313] nvdec 15480000.nvdec: initialized
[ 0.438075] falcon 15340000.vic: initialized
[ 0.439313] falcon 154c0000.nvenc: initialized
[ 0.440659] falcon 15380000.nvjpg: initialized
[ 0.442294] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 0.443045] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 0.443762] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 0.444535] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 0.445279] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 0.446017] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 0.446749] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 0.447485] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 0.451301] DC OR NODE connected to /host1x/sor1
[ 0.451480] generic_infoframe_type: 0x87
[ 0.451640] tegradc 15210000.nvdisplay: DT parsed successfully
[ 0.451685] tegradc 15210000.nvdisplay: Display dc.ffffff8002320000 registered with id=0
[ 0.451697] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.451888] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 0.451931] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=1500000, max_bw=4687500
[ 0.460473] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[ 0.460494] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[ 0.460511] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[ 0.460556] tegradc 15210000.nvdisplay: vblank syncpt # 7 for dc 1
[ 0.460572] tegradc 15210000.nvdisplay: vpulse3 syncpt # 8 for dc 1
[ 0.461014] hdmi: couldn't get regulator vdd_hdmi_5v0: -517
[ 0.461244] tegra-adma 2930000.adma: Tegra ADMA driver register 10 channels
[ 0.463078] tegradc 15210000.nvdisplay: hdmi: no prod_list_hdmi_board, use default range
[ 0.463593] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 0.464043] kfuse 3830000.kfuse: initialized
[ 0.465753] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.466356] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.469061] console [ttyS0] disabled
[ 0.469147] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 37, base_baud = 25500000) is a Tegra
[ 2.464165] tegra-i2c 3190000.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[ 2.464168] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 2.464171] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 2.464175] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 2.464178] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 2.464181] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 2.464184] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x7d
[ 2.464187] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x0
[ 2.464192] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 2.466146] tegradc 15210000.nvdisplay: probed
[ 2.575725] console [ttyS0] enabled
[ 2.577599] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 2.577853] Console: switching to colour frame buffer device 80x30
[ 2.578619] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 39, base_baud = 0) is a TEGRA_UART
[ 2.578849] serial-tegra 3130000.serial: RX in PIO mode
[ 2.579716] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 40, base_baud = 0) is a TEGRA_UART
[ 2.605310] brd: module loaded
[ 2.607913] gk20a 17000000.gp10b: failed to allocate secure buffer -12
[ 2.609877] loop: module loaded
[ 2.610113] nct1008_nct72 7-004c: find device tree node, parsing dt
[ 2.610117] nct1008_nct72 7-004c: starting parse dt
[ 2.610200] nct1008_nct72 7-004c: success parsing dt
[ 2.610321] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 2.647098] tmp451: Enabled overheat logging at 104.00C
[ 2.647248] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 2.649441] THERMAL EST: found 3 subdevs
[ 2.649445] THERMAL EST num_resources: 0
[ 2.649449] [THERMAL EST subdev 0]
[ 2.649454] [THERMAL EST subdev 1]
[ 2.649457] [THERMAL EST subdev 2]
[ 2.649744] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 2.649747] THERMAL EST: thz register success.
[ 2.649890] THERMAL EST: end of probe, return err: 0
[ 2.649937] tegra_profiler: Branch: Dev
[ 2.649939] tegra_profiler: Version: 1.117
[ 2.649941] tegra_profiler: Samples version: 41
[ 2.649943] tegra_profiler: IO version: 22
[ 2.649949] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.649953] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.649957] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.649960] armv8_pmu: [1] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2, pmu ver: 0x1
[ 2.649963] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.649967] armv8_pmu: [2] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2, pmu ver: 0x1
[ 2.649969] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.649972] armv8_pmu: [3] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.649975] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.649978] armv8_pmu: [4] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.649981] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.649984] armv8_pmu: [5] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.650168] tegra_profiler: auth: init
[ 2.653535] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 2.653546] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 2.654481] scsi host0: tegra_ahci
[ 2.654838] scsi host1: tegra_ahci
[ 2.655009] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 25
[ 2.655012] ata2: DUMMY
[ 2.655878] spi-tegra114 3210000.spi: Static pin configuration used
[ 2.656332] spi-tegra114 c260000.spi: Static pin configuration used
[ 2.656713] spi-tegra114 3240000.spi: Static pin configuration used
[ 2.657506] tun: Universal TUN/TAP device driver, 1.6
[ 2.657509] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 2.657668] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 2.657670] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.657711] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.3.0-k
[ 2.657713] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.658759] PPP generic driver version 2.4.2
[ 2.658900] PPP BSD Compression module registered
[ 2.658908] PPP Deflate Compression module registered
[ 2.658926] PPP MPPE Compression module registered
[ 2.658939] NET: Registered protocol family 24
[ 2.658991] usbcore: registered new interface driver r8152
[ 2.659052] usbcore: registered new interface driver asix
[ 2.659080] usbcore: registered new interface driver ax88179_178a
[ 2.659109] usbcore: registered new interface driver cdc_ether
[ 2.659143] usbcore: registered new interface driver smsc75xx
[ 2.659169] usbcore: registered new interface driver net1080
[ 2.659196] usbcore: registered new interface driver cdc_subset
[ 2.659221] usbcore: registered new interface driver zaurus
[ 2.659272] usbcore: registered new interface driver cdc_ncm
[ 2.659511] Wake76 for irq=199
[ 2.659514] Wake77 for irq=199
[ 2.659516] Wake78 for irq=199
[ 2.659518] Wake79 for irq=199
[ 2.659520] Wake80 for irq=199
[ 2.659521] Wake81 for irq=199
[ 2.659523] Wake82 for irq=199
[ 2.659577] tegra-xotg xotg: usb2 phy is not available yet
[ 2.660310] usbcore: registered new interface driver cdc_acm
[ 2.660312] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.660346] usbcore: registered new interface driver usb-storage
[ 2.660413] usbcore: registered new interface driver usbserial
[ 2.660435] usbcore: registered new interface driver cp210x
[ 2.660456] usbserial: USB Serial support registered for cp210x
[ 2.660477] usbcore: registered new interface driver ftdi_sio
[ 2.660494] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.660515] usbcore: registered new interface driver option
[ 2.660535] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.660556] usbcore: registered new interface driver pl2303
[ 2.660571] usbserial: USB Serial support registered for pl2303
[ 2.660752] tegra-usb-cd usb_cd: otg phy is not available yet
[ 2.661747] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b 8d 80 4b
[ 2.662274] libphy: dwc_phy: probed
[ 2.663033] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 2.725323] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 2.780534] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 2.782641] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 2.782666] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.782815] i2c /dev entries driver
[ 2.783585] gspca_main: v2.14.0 registered
[ 2.783627] usbcore: registered new interface driver gspca_zc3xx
[ 2.784827] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 2.786676] FAN: coudln't get the regulator
[ 2.787391] device-mapper: uevent: version 1.0.3
[ 2.787567] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 2.787911] sdhci: Secure Digital Host Controller Interface driver
[ 2.787913] sdhci: Copyright(c) Pierre Ossman
[ 2.787917] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.798071] sdhci-tegra 3460000.sdhci: Parent select= pll_p rate=408000000
[ 2.798433] sdhci-tegra 3460000.sdhci: Parent select= pll_c4_out0 rate=196249804
[ 2.798654] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 2.798718] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 2.798914] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.800385] usbcore: registered new interface driver usbhid
[ 2.800386] usbhid: USB HID core driver
[ 2.800959] tegra-i2c 3160000.i2c: arb lost in communicate to add 0x40
[ 2.801351] tegra-i2c 3160000.i2c: Un-recovered Arb lost
[ 2.801357] ina3221x 0-0040: ina3221 reset failure status: 0xfffffffb
[ 2.801493] ina3221x: probe of 0-0040 failed with error -5
[ 2.801867] tegra-i2c 3160000.i2c: arb lost in communicate to add 0x41
[ 2.802109] tegra-i2c 3160000.i2c: Un-recovered Arb lost
[ 2.802114] ina3221x 0-0041: ina3221 reset failure status: 0xfffffffb
[ 2.802209] ina3221x: probe of 0-0041 failed with error -5
[ 2.802543] tegra-i2c 3160000.i2c: arb lost in communicate to add 0x42
[ 2.802777] tegra-i2c 3160000.i2c: Un-recovered Arb lost
[ 2.802781] ina3221x 0-0042: ina3221 reset failure status: 0xfffffffb
[ 2.802876] ina3221x: probe of 0-0042 failed with error -5
[ 2.803250] tegra-i2c 3160000.i2c: arb lost in communicate to add 0x43
[ 2.803625] tegra-i2c 3160000.i2c: Un-recovered Arb lost
[ 2.803629] ina3221x 0-0043: ina3221 reset failure status: 0xfffffffb
[ 2.803726] ina3221x: probe of 0-0043 failed with error -5
[ 2.804263] nvadsp 2993000.adsp: in probe()...
[ 2.805618] nvadsp 2993000.adsp: Registering AMC Error Interrupt
[ 2.805654] nvadsp 2993000.adsp: AMC/ARAM initialized.
[ 2.805880] nvadsp 2993000.adsp: nvadsp_app_mo
[ 2.849485] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 2.849510] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 2.849537] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 2.849564] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 2.849616] ** A57 ECC: Enabled
[ 2.849618] tegra18_a57_serr_init: on CPU 3 a A57 Core
[ 2.849765] parse_throttle_dt_data: Num cap clks = 4
[ 2.849768] parse_throttle_dt_data: clk=mcpu type=1
[ 2.849770] parse_throttle_dt_data: clk=bcpu type=2
[ 2.849776] parse_throttle_dt_data: clk=gpu type=4
[ 2.849778] parse_throttle_dt_data: clk=emc type=3
[ 2.850369] tegra_throttle_probe: probe successful. #cdevs=4
[ 2.850495] tegra18x_actmon d230000.actmon: in actmon_register()...
[ 2.853630] tegra18x_actmon d230000.actmon: initialization Completedl
[ 2.856813] hw perfevents: enabled with denver15_uncore_pmu PMU drive
[ 2.884244] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] r
[ 2.884497] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 2.884549] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 2.884632] sdhci-tegra 3400000.sdhci: Parent select= pll_p rate=4080
[ 2.884661] sdhci-tegra 3400000.sdhci: wakeup init done, cd_irq: 256
[ 2.884896] sdhci-tegra 3400000.sdhci: Client registration for eMC Sl
[ 2.914252] mmc0: MAN_BKOPS_EN bit is not set
[ 2.921541] mmc0: Skipping tuning since strobe enabled
[ 2.924313] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] r
[ 2.928510] mmc0: periodic cache flush enabled
[ 2.928518] mmc0: new HS400 MMC card at address 0001
[ 2.928833] mmcblk0: mmc0:0001 032G34 29.1 GiB
[ 2.928997] mmcblk0boot0: mmc0:0001 032G34 partition 1 4.00 MiB
[ 2.929153] mmcblk0boot1: mmc0:0001 032G34 partition 2 4.00 MiB
[ 2.929307] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
[ 2.930622] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p149
[ 2.976268] ata1: SATA link down (SStatus 0 SControl 300)
[ 2.976722] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 3.174545] mmc1 tuning done saved tap delay=20
[ 3.174548] mmc1: hw tuning done ...
[ 3.174556] mmc1: tuning_window[0]: 0xffffffff
[ 3.174562] mmc1: tuning_window[1]: 0xfffff3ff
[ 3.174567] mmc1: tuning_window[2]: 0xfe3fffff
[ 3.174572] mmc1: tuning_window[3]: 0x7fffffff
[ 3.174577] mmc1: tuning_window[4]: 0x0
[ 3.174582] mmc1: tuning_window[5]: 0x0
[ 3.174615] mmc1: tuning_window[6]: 0x0
[ 3.174620] mmc1: tuning_window[7]: 0x0
[ 3.174625] sdhci: Tap value: 20 | Trim value: 5
[ 3.174629] sdhci: SDMMC_VENDOR_INTR_STATUS[0x108]: 0x40000
[ 3.180954] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 3.181002] mmc1: new ultra high speed SDR104 SDIO card at address 01
[ 4.144148] tegradc 15210000.nvdisplay: fb registered
[ 4.151098] tegra-se-nvhost 15810000.se: initialized
[ 4.157310] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 4.164538] tegra-se-nvhost 15820000.se: initialized
[ 4.170693] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 4.177848] tegra-se-nvhost 15830000.se: initialized
[ 4.183673] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 4.190784] tegra-se-nvhost 15840000.se: initialized
[ 4.196838] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 4.207766] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 chas
[ 4.218667] cpufreq: platform driver Initialization: pass
[ 4.224711] tegra_cluster_clk e090000.cluster_clk_priv: in probe()...
[ 4.231719] tegra_cluster_clk e090000.cluster_clk_priv: passed
[ 4.238260] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x000f
[ 4.248788] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000f
[ 4.259128] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x7
[ 4.266665] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x8
[ 4.275732] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for og
[ 4.284806] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not d
[ 4.292870] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 3 not d
[ 4.302370] cpuidle: Initializing cpuidle driver init for Denver clur
[ 4.309737] cpuidle: Initializing cpuidle driver init for A57 cluster
[ 4.317865] tachometer tegra-tachometer: Tachometer driver tegra-tacd
[ 4.326627] Tachometer driver initialized with pulse_per_rev: 2 and 2
[ 4.340048] tegra210_adsp_audio_platform_probe: platform probe startd
[ 4.349399] tegra210-adsp adsp_audio: Default param-type to BYTE for1
[ 4.351716] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/s0
[ 4.351896] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/s1
[ 4.375716] tegra210-adsp adsp_audio: Default param-type to BYTE fort
[ 4.383999] tegra210-adsp adsp_audio: Default param-type to BYTE forc
[ 4.391641] tegra210-adsp adsp_audio: Default param-type to BYTE for1
[ 4.399836] tegra210-adsp adsp_audio: Default param-type to BYTE forc
[ 4.407069] tegra210-adsp adsp_audio: adma channel page address dt ed
[ 4.415641] tegra210-adsp adsp_audio: using adma channel page 0
[ 4.422945] tegra210_adsp_audio_platform_probe probe successfull.
[ 4.442103] OPE platform probe
[ 4.446549] OPE platform probe successful
[ 4.547762] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF1 <-> ADMAIk
[ 4.556422] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF2 <-> ADMAIk
[ 4.565090] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF3 <-> ADMAIk
[ 4.573751] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF4 <-> ADMAIk
[ 4.582442] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF5 <-> ADMAIk
[ 4.591147] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF6 <-> ADMAIk
[ 4.599885] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF7 <-> ADMAIk
[ 4.608567] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF8 <-> ADMAIk
[ 4.617276] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF9 <-> ADMAIk
[ 4.626133] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF10 <-> ADMAk
[ 4.635183] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF11 <-> ADMAk
[ 4.644244] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF12 <-> ADMAk
[ 4.653321] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF13 <-> ADMAk
[ 4.662467] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF14 <-> ADMAk
[ 4.671613] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF15 <-> ADMAk
[ 4.680722] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF16 <-> ADMAk
[ 4.689848] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF17 <-> ADMAk
[ 4.698978] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF18 <-> ADMAk
[ 4.708104] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF19 <-> ADMAk
[ 4.717203] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF20 <-> ADMAk
[ 4.729990] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE1 <-> ADSPk
[ 4.739372] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE2 <-> ADSPk
[ 4.748509] compress asoc: ADSP-FE3 <-> ADSP COMPR1 mapping ok
[ 4.755059] compress asoc: ADSP-FE4 <-> ADSP COMPR2 mapping ok
[ 4.794452] input: tegra-snd-t186ref-mobile-rt565x Headphone Jack as2
[ 4.805773] tegra-snd-t186ref-mobile-rt565x sound: codec-dai "dit-hid
[ 4.814641] tegra-snd-t186ref-mobile-rt565x sound: This is a dummy cc
[ 4.822528] GACT probability NOT on
[ 4.826694] Mirror/redirect action on
[ 4.831043] u32 classifier
[ 4.834352] Actions configured
[ 4.838380] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[ 4.845829] IPVS: Registered protocols ()
[ 4.850470] IPVS: Connection hash table configured (size=4096, memor)
[ 4.859017] IPVS: Creating netns size=1424 id=0
[ 4.864158] IPVS: ipvs loaded.
[ 4.867761] IPVS: [rr] scheduler registered.
[ 4.872683] ipip: IPv4 over IPv4 tunneling driver
[ 4.878267] Initializing XFRM netlink socket
[ 4.883355] NET: Registered protocol family 10
[ 4.888972] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 4.894968] NET: Registered protocol family 17
[ 4.899922] NET: Registered protocol family 15
[ 4.904861] bridge: automatic filtering via arp/ip/ip6tables has bee.
[ 4.918398] 8021q: 802.1Q VLAN Support v1.8
[ 4.923353] Registered cp15_barrier emulation handler
[ 4.928888] Registered setend emulation handler
[ 4.935699] registered taskstats version 1
[ 4.944278] isp 15600000.isp: initialized
[ 4.952856] nvcsi 150c0000.nvcsi: initialized
[ 4.959660] Wake76 for irq=199
[ 4.963427] Wake77 for irq=199
[ 4.967160] Wake78 for irq=199
[ 4.970861] Wake79 for irq=199
[ 4.974531] Wake80 for irq=199
[ 4.978170] Wake81 for irq=199
[ 4.981775] Wake82 for irq=199
[ 4.985575] xhci-tegra 3530000.xhci: can't get usb3-0 phy (-517)
[ 4.992474] spi-tegra114 3210000.spi: Static pin configuration used
[ 4.999927] spi-tegra114 c260000.spi: Static pin configuration used
[ 5.007425] spi-tegra114 3240000.spi: Static pin configuration used
[ 5.014747] Wake76 for irq=199
[ 5.018285] Wake77 for irq=199
[ 5.021816] Wake78 for irq=199
[ 5.025322] Wake79 for irq=199
[ 5.028790] Wake80 for irq=199
[ 5.032260] Wake81 for irq=199
[ 5.035694] Wake82 for irq=199
[ 5.039126] tegra-xotg xotg: usb2 phy is not available yet
[ 5.045488] tegra-usb-cd usb_cd: otg phy is not available yet
[ 5.052096] tegra-xudc-new 3550000.xudc: usb2 phy is not available yt
[ 5.059124] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x000f
[ 5.069132] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000f
[ 5.078880] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x7
[ 5.086082] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x8
[ 5.093806] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for og
[ 5.103623] Wake76 for irq=199
[ 5.107026] Wake77 for irq=199
[ 5.110422] Wake78 for irq=199
[ 5.113818] Wake79 for irq=199
[ 5.117187] Wake80 for irq=199
[ 5.120535] Wake81 for irq=199
[ 5.123884] Wake82 for irq=199
[ 5.127469] xhci-tegra 3530000.xhci: can't get usb3-0 phy (-517)
[ 5.134889] input: gpio-keys as /devices/gpio-keys/input/input3
[ 5.141688] Wake76 for irq=199
[ 5.145081] Wake77 for irq=199
[ 5.148469] Wake78 for irq=199
[ 5.151857] Wake79 for irq=199
[ 5.155250] Wake80 for irq=199
[ 5.158640] Wake81 for irq=199
[ 5.162011] Wake82 for irq=199
[ 5.165464] tegra-xotg xotg: usb2 phy is not available yet
[ 5.171485] tegra-usb-cd usb_cd: otg phy is not available yet
[ 5.177557] tegra_rtc c2a0000.rtc: setting system clock to 2018-09-1)
[ 5.187438] tegra-xudc-new 3550000.xudc: usb2 phy is not available yt
[ 5.194518] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x000f
[ 5.204621] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000f
[ 5.207417] bpmp: mounted debugfs mirror
[ 5.207896] [dram-timers] DRAM derating cdev registered.
[ 5.211976] spmic-ldo0: disabling
[ 5.212147] spmic-ldo1: disabling
[ 5.212289] en-vdd-sd: disabling
[ 5.212291] vdd-usb0-5v: disabling
[ 5.212292] vdd-usb1-5v: disabling
[ 5.212293] vdd-3v3: disabling
[ 5.212295] en-vdd-vcm-2v8: disabling
[ 5.212296] vdd-sys-bl: disabling
[ 5.219107] ALSA device list:
[ 5.219109] #0: tegra-hda at 0x3518000 irq 400
[ 5.219110] #1: tegra-snd-t186ref-mobile-rt565x
[ 5.220279] tegra-vi4 15700000.vi: initialized
[ 5.221375] tegra-vi4 15700000.vi: ep of_device is not enabled /host.
[ 5.221377] tegra-vi4 15700000.vi: all channel register failed
[ 5.289247] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x7
[ 5.296554] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x8
[ 5.304453] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for og
[ 5.314280] Wake76 for irq=199
[ 5.317715] Wake77 for irq=199
[ 5.321112] Wake78 for irq=199
[ 5.324486] Wake79 for irq=199
[ 5.327838] Wake80 for irq=199
[ 5.331183] Wake81 for irq=199
[ 5.334506] Wake82 for irq=199
[ 5.338042] xhci-tegra 3530000.xhci: can't get usb3-0 phy (-517)
[ 5.344721] Wake76 for irq=199
[ 5.348066] Wake77 for irq=199
[ 5.351399] Wake78 for irq=199
[ 5.354731] Wake79 for irq=199
[ 5.358061] Wake80 for irq=199
[ 5.361387] Wake81 for irq=199
[ 5.364706] Wake82 for irq=199
[ 5.368109] tegra-xotg xotg: usb2 phy is not available yet
[ 5.374045] tegra-usb-cd usb_cd: otg phy is not available yet
[ 5.380581] tegra-xudc-new 3550000.xudc: usb2 phy is not available yt
[ 5.387601] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x000f
[ 5.397705] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000f
[ 5.406085] EXT4-fs (mmcblk0p1): 15 orphan inodes deleted
[ 5.406087] EXT4-fs (mmcblk0p1): recovery complete
[ 5.413398] EXT4-fs (mmcblk0p1): mounted filesystem with ordered dat)
[ 5.413416] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 5.413705] devtmpfs: mounted
[ 5.414003] Freeing unused kernel memory: 1168K (ffffffc001132000 - )
[ 5.414024] Freeing alternatives memory: 96K (ffffffc001256000 - fff)
[ 5.421486] btb inv war enabled
[ 5.457655] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x7
[ 5.465097] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x8
[ 5.465951] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for og
[ 5.503836] random: systemd: uninitialized urandom read (16 bytes re)
[ 5.516478] random: systemd: uninitialized urandom read (16 bytes re)
[ 5.527641] random: systemd: uninitialized urandom read (16 bytes re)
[ 5.539774] systemd[1]: systemd 229 running in system mode. (+PAM +A)
[ 5.560797] systemd[1]: Detected architecture arm64.
[ 5.575540] systemd[1]: Set hostname to <tegra-ubuntu>.
[ 5.592539] random: systemd: uninitialized urandom read (16 bytes re)
[ 5.607313] random: systemd-gpt-aut: uninitialized urandom read (16 )
[ 5.608100] random: systemd-sysv-ge: uninitialized urandom read (16 )
[ 5.612903] random: systemd-sysv-ge: uninitialized urandom read (16 )
[ 5.613320] random: systemd-cryptse: uninitialized urandom read (16 )
[ 5.614893] random: systemd: uninitialized urandom read (16 bytes re)
[ 5.643484] random: systemd-sysv-ge: uninitialized urandom read (16 )
[ 5.777524] systemd[1]: Listening on Journal Socket.
[ 5.784746] systemd[1]: Listening on udev Kernel Socket.
[ 5.792686] systemd[1]: Created slice System Slice.
[ 5.799973] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 5.809497] systemd[1]: Mounting POSIX Message Queue File System...
[ 5.819574] systemd[1]: Starting Create list of required static devi.
[ 5.843586] systemd[1]: Starting Load Kernel Modules...
[ 5.851395] systemd[1]: Reached target User and Group Name Lookups.
[ 5.860088] Wake76 for irq=199
[ 5.861469] systemd[1]: Mounting Debug File System...
[ 5.870075] Wake77 for irq=199
[ 5.870077] Wake78 for irq=199
[ 5.870077] Wake79 for irq=199
[ 5.870083] Wake80 for irq=199
[ 5.870083] Wake81 for irq=199
[ 5.870084] Wake82 for irq=199
[ 5.870513] xhci-tegra 3530000.xhci: can't get usb3-0 phy (-517)
[ 5.870992] Wake76 for irq=199
[ 5.870993] Wake77 for irq=199
[ 5.870994] Wake78 for irq=199
[ 5.870995] Wake79 for irq=199
[ 5.870995] Wake80 for irq=199
[ 5.870996] Wake81 for irq=199
[ 5.870997] Wake82 for irq=199
[ 5.871031] tegra-xotg xotg: usb2 phy is not available yet
[ 5.871177] tegra-usb-cd usb_cd: otg phy is not available yet
[ 5.871622] tegra-xudc-new 3550000.xudc: usb2 phy is not available yt
[ 5.871782] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x000f
[ 5.871787] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000f
[ 5.871825] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x7
[ 5.871828] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x8
[ 5.872554] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for og
[ 5.986890] systemd[1]: Reached target Swap.
[ 5.994607] systemd[1]: Listening on udev Control Socket.
[ 6.003313] systemd[1]: Started Braille Device Support.
[ 6.010171] systemd[1]: Listening on /dev/initctl Compatibility Name.
[ 6.018359] systemd[1]: Reached target Remote File Systems (Pre).
[ 6.025776] systemd[1]: Reached target Remote File Systems.
[ 6.032715] systemd[1]: Reached target Encrypted Volumes.
[ 6.041651] systemd[1]: Starting Remount Root and Kernel File System.
[ 6.047555] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 6.058138] systemd[1]: Starting Set console keymap...
[ 6.064876] systemd[1]: Started Forward Password Requests to Wall Di.
[ 6.075441] systemd[1]: Created slice User and Session Slice.
[ 6.082585] systemd[1]: Reached target Slices.
[ 6.088500] systemd[1]: Listening on Journal Socket (/dev/log).
[ 6.095845] systemd[1]: Listening on Syslog Socket.
[ 6.102261] systemd[1]: Listening on Journal Audit Socket.
[ 6.111300] systemd[1]: Starting Journal Service...
[ 6.121957] systemd[1]: Mounted POSIX Message Queue File System.
[ 6.129600] systemd[1]: Mounted Debug File System.
[ 6.137766] systemd[1]: Started Create list of required static devic.
[ 6.150739] systemd[1]: Started Load Kernel Modules.
[ 6.161448] systemd[1]: Started Remount Root and Kernel File Systems.
[ 6.171127] systemd[1]: Started Set console keymap.
[ 6.178378] systemd[1]: Started Journal Service.
[ 6.183659] random: nonblocking pool is initialized
[ 6.338752] systemd-journald[307]: Received request to flush runtime1
[ 6.566508] tegra-pcie 10003000.pcie-controller: 4x1, 1x1 configuratn
[ 6.574832] tegra-pcie 10003000.pcie-controller: PCIE: Enable power s
[ 6.576548] Wake76 for irq=199
[ 6.576549] Wake77 for irq=199
[ 6.576550] Wake78 for irq=199
[ 6.576551] Wake79 for irq=199
[ 6.576551] Wake80 for irq=199
[ 6.576552] Wake81 for irq=199
[ 6.576553] Wake82 for irq=199
[ 6.576769] xhci-tegra 3530000.xhci: can't get usb3-0 phy (-517)
[ 6.577171] Wake76 for irq=199
[ 6.577172] Wake77 for irq=199
[ 6.577173] Wake78 for irq=199
[ 6.577174] Wake79 for irq=199
[ 6.577174] Wake80 for irq=199
[ 6.577175] Wake81 for irq=199
[ 6.577175] Wake82 for irq=199
[ 6.577212] tegra-xotg xotg: usb2 phy is not available yet
[ 6.577384] tegra-usb-cd usb_cd: otg phy is not available yet
[ 6.577833] tegra-xudc-new 3550000.xudc: usb2 phy is not available yt
[ 6.578027] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x000f
[ 6.578031] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000f
[ 6.578067] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x7
[ 6.578070] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x8
[ 6.578828] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for og
[ 6.701204] tegra-pcie 10003000.pcie-controller: probing port 0, usis
[ 6.703359] tegra-pcie 10003000.pcie-controller: probing port 2, usis
[ 7.068355] dhd_module_init in
[ 7.072404] tegra_net_perf_init: cannot get wifi sclk
[ 7.078618] found wifi platform device bcmdhd_wlan
[ 7.086342] wifi_platform_get_country_code_map: could not get countrp
[ 7.095508] wifi_plat_dev_drv_probe:platform country code map is note
[ 7.104517] Power-up adapter 'DHD generic adapter'
[ 7.110331] wifi_platform_set_power = 1
[ 7.151338] tegra-pcie 10003000.pcie-controller: link 0 down, retryig
[ 7.316268] wifi_platform_bus_enumerate device present 1
[ 7.327001] Wake76 for irq=199
[ 7.330891] Wake77 for irq=199
[ 7.334716] Wake78 for irq=199
[ 7.338504] Wake79 for irq=199
[ 7.342518] Wake80 for irq=199
[ 7.346516] Wake81 for irq=199
[ 7.350298] Wake82 for irq=199
[ 7.354431] xhci-tegra 3530000.xhci: can't get usb3-0 phy (-517)
[ 7.354696] wifi_platform_bus_enumerate device present 0
[ 7.355057] F1 signature read @0x18000000=0x17214354
[ 7.358885] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 7.359359] DHD: dongle ram size is set to 786432(orig 786432) at 0x0
[ 7.359416] wifi_platform_prealloc: failed to alloc static mem secti7
[ 7.359422] wifi_platform_get_mac_addr
[ 7.400509] Wake76 for irq=199
[ 7.400510] Wake77 for irq=199
[ 7.400511] Wake78 for irq=199
[ 7.400512] Wake79 for irq=199
[ 7.400512] Wake80 for irq=199
[ 7.400513] Wake81 for irq=199
[ 7.400513] Wake82 for irq=199
[ 7.400563] tegra-xotg xotg: usb2 phy is not available yet
[ 7.400737] tegra-usb-cd usb_cd: otg phy is not available yet
[ 7.401185] tegra-xudc-new 3550000.xudc: usb2 phy is not available yt
[ 7.401384] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x000f
[ 7.401390] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000f
[ 7.401425] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x7
[ 7.401429] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x8
[ 7.402190] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for og
[ 7.404803] Wake76 for irq=199
[ 7.404804] Wake77 for irq=199
[ 7.404805] Wake78 for irq=199
[ 7.404806] Wake79 for irq=199
[ 7.404806] Wake80 for irq=199
[ 7.404807] Wake81 for irq=199
[ 7.404808] Wake82 for irq=199
[ 7.405025] xhci-tegra 3530000.xhci: can't get usb3-0 phy (-517)
[ 7.536237] tegra-pcie 10003000.pcie-controller: link 0 down, retryig
[ 7.591064] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[ 7.598630] wl_create_event_handler(): thread:wl_event_handler:31a sd
[ 7.598648] CFG80211-ERROR) wl_event_handler : tsk Enter, tsk = 0xff0
[ 7.615760] dhd_attach(): thread:dhd_watchdog_thread:31c started
[ 7.624161] dhd_attach(): thread:dhd_dpc:323 started
[ 7.630085] dhd_attach(): thread:dhd_rxf:325 started
[ 7.635856] dhd_deferred_work_init: work queue initialized
[ 7.637335] Dongle Host Driver, version 1.201.82 (r)
[ 7.637335] Compiled in drivers/net/wireless/bcmdhd on May 17 2018 a7
[ 7.637689] tegra_sysfs_register
[ 7.637718] Register interface [wlan0] MAC: 00:04:4b:8d:80:49
[ 7.637718]
[ 7.637720] dhd_prot_ioctl : bus is down. we have nothing to do
[ 7.637808] sdhci-tegra 3440000.sdhci: Tuning already done, restorin0
[ 7.638849] wifi_platform_set_power = 0
[ 7.841566] Wake76 for irq=199
[ 7.845707] Wake77 for irq=199
[ 7.849700] Wake78 for irq=199
[ 7.853649] Wake79 for irq=199
[ 7.857685] Wake80 for irq=199
[ 7.857686] Wake81 for irq=199
[ 7.857686] Wake82 for irq=199
[ 7.857865] tegra-xotg xotg: usb2 phy is not available yet
[ 7.858160] tegra-usb-cd usb_cd: otg phy is not available yet
[ 7.858714] tegra-xudc-new 3550000.xudc: usb2 phy is not available yt
[ 7.858933] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x000f
[ 7.858938] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000f
[ 7.858980] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x7
[ 7.858983] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x8
[ 7.859785] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for og
[ 7.862719] Wake76 for irq=199
[ 7.862720] Wake77 for irq=199
[ 7.862721] Wake78 for irq=199
[ 7.862721] Wake79 for irq=199
[ 7.862722] Wake80 for irq=199
[ 7.862723] Wake81 for irq=199
[ 7.862723] Wake82 for irq=199
[ 7.862940] xhci-tegra 3530000.xhci: can't get usb3-0 phy (-517)
[ 7.974273] tegra-pcie 10003000.pcie-controller: link 0 down, retryig
[ 7.976265] tegra-pcie 10003000.pcie-controller: link 0 down, ignorig
[ 8.374299] tegra-pcie 10003000.pcie-controller: link 2 down, retryig
[ 8.436683] IPVS: Creating netns size=1424 id=1
[ 8.664738] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 8.674337] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 8.798334] tegra-pcie 10003000.pcie-controller: link 2 down, retryig
[ 8.830463] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 8.838481]
[ 8.838481] Dongle Host Driver, version 1.201.82 (r)
[ 8.838481] Compiled in drivers/net/wireless/bcmdhd on May 17 2018 a7
[ 8.858712] wl_android_wifi_on in
[ 8.863621] wifi_platform_set_power = 1
[ 8.935291] gk20a 17000000.gp10b: railgate is disabled.
[ 9.152869] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 9.208248] tegra-pcie 10003000.pcie-controller: link 2 down, retryig
[ 9.217876] tegra-pcie 10003000.pcie-controller: link 2 down, ignorig
[ 9.225254] tegra-pcie 10003000.pcie-controller: PCIE: no end pointsd
[ 9.229686] sdhci-tegra 3440000.sdhci: Tuning already done, restorin0
[ 9.230065] F1 signature read @0x18000000=0x17214354
[ 9.233551] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 9.234039] DHD: dongle ram size is set to 786432(orig 786432) at 0x0
[ 9.267136] tegra-pcie 10003000.pcie-controller: PCIE: Disable powers
[ 9.333271] tegradc 15210000.nvdisplay: blank - powerdown
[ 9.347045] dhdsdio_write_vars: Download, Upload and compare of NVRA.
[ 9.396587] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[ 9.402659] Enabling wake69
[ 9.406128] wifi_platform_get_mac_addr
[ 9.411380] Firmware up: op_mode=0x0005, MAC=00:04:4b:8d:80:49
[ 9.422861] dhd_preinit_ioctls pspretend_threshold for HostAPD faile3
[ 9.434144] Firmware version = wl0: Dec 12 2017 15:09:35 version 7.39
[ 9.445868] dhd_interworking_enable: failed to set WNM info, ret=-23
[ 9.452527] tegra_sysfs_on
[ 9.508988] cfg80211: World regulatory domain updated:
[ 9.514204] cfg80211: DFS Master region: unset
[ 9.518697] cfg80211: (start_freq - end_freq @ bandwidth), (max_an)
[ 9.528465] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/)
[ 9.536483] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz, 9200)
[ 9.545876] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/)
[ 9.553893] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 1600)
[ 9.563378] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 1600)
[ 9.572868] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N)
[ 9.580979] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/)
[ 9.588995] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz),)
[ 9.657874] CFGP2P-ERROR) wl_cfgp2p_add_p2p_disc_if : P2P interface d
[ 9.680845] WLC_E_IF: NO_IF set, event Ignored
[ 10.293580] eqos 2490000.ether_qos eth0: Link is Up - 100Mbps/Full -x
[ 10.302881] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 10.680085] Bridge firewalling registered
[ 10.898467] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 11.562074] IPv6: ADDRCONF(NETDEV_UP): docker0: link is not ready
[ 13.031597] CFG80211-ERROR) wl_cfg80211_connect : Connectting with58)
[ 13.107773] CFG80211-ERROR) wl_notify_connect_status : wl_bss_connec4
[ 13.137190] CFG80211-ERROR) wl_bss_connect_done : Report connect resd
[ 13.195793] CFG80211-ERROR) wl_notify_connect_status : wl_bss_connec4
[ 13.222706] dhd_ndo_add_ip: ndo ip addr add failed, retcode = -23
[ 13.230834] dhd_inet6_work_handler: Adding host ip for NDO failed -23
Ubuntu 16.04.5 LTS tegra-ubuntu ttyS0
tegra-ubuntu login: nvidia (automatic login)
Last login: Thu Sep 13 11:26:25 +03 2018 on ttyS0
[ 13.947132] fuse init (API version 7.23)
Welcome to Ubuntu 16.04.5 LTS (GNU/Linux 4.4.38-tegra aarch64)
* Documentation: https://help.ubuntu.com
* Management: https://landscape.canonical.com
* Support: https://ubuntu.com/advantage
0 packages can be updated.
0 updates are security updates.
New release '18.04.1 LTS' available.
Run 'do-release-upgrade' to upgrade to it.
The programs included with the Ubuntu system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Ubuntu comes with ABSOLUTELY NO WARRANTY, to the extent permitted by
applicable law.
applicable law.
nvidia@tegra-ubuntu:~$ [ 16.085440] IPVS: Creating netns size=1424 id2
[ 17.199570] IPVS: Creating netns size=1424 id=3
