HDMI Display is not responding when Jetson Tx1 boot ups
I am new to jetson tx1 board. I flashed the jetson 3.0 to my tx1. At first there is no problem for the display. But now when I power on the board there is no response from the monitor. I reflashed the jetson full pack, again there is no display response. Then I reflashed again OS only using this link:
https://devtalk.nvidia.com/default/topic/1000253/jetson-tx1/jetpack-not-able-to-load-on-tx1/post/5158540/#5158540
Again no response!. But I ssh the board using the host pc from which I flashed the jetpack. Please help me to solve this problem.
The flash and Jetson are probably working correctly for the most part, but video configuration is likely failing. You can check if you can ping the Jetson or ssh in, plus a serial console would be quite useful if you can’t ssh. For serial console see:
[url]http://elinux.org/Jetson/TX1_Serial_Console[/url]
[url]http://www.jetsonhacks.com/2015/12/01/serial-console-nvidia-jetson-tx1/[/url]
If you can log in via ssh, please post the content of “/var/log/Xorg.0.log”. If ssh fails a serial console may be necessary.
Hi linuxdev,
Here is the contents in the “Xorg.0.log” file:
[ 11.294]
X.Org X Server 1.18.4
Release Date: 2016-07-19
[ 11.295] X Protocol Version 11, Revision 0
[ 11.295] Build Operating System: Linux 4.4.0-45-generic aarch64 Ubuntu
[ 11.295] Current Operating System: Linux tegra-ubuntu 3.10.96-tegra #1 SMP PREEMPT Wed Nov 9 19:42:57 PST 2016 aarch64
[ 11.295] Kernel command line: fbcon=map:0 console=tty0 console=ttyS0,115200n8 androidboot.modem=none androidboot.serialno=P2180A00P00940c003fd androidboot.security=non-secure tegraid=21.1.2.0.0 ddr_die=2048M@2048M ddr_die=2048M@4096M section=256M memtype=0 usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 debug_uartport=lsport,0 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff2bf000 nvdumper_reserved=0xff23f000 core_edp_mv=1125 core_edp_ma=4000 gpt android.kerneltype=normal androidboot.touch_vendor_id=0 androidboot.touch_panel_id=63 androidboot.touch_feature=0 androidboot.bootreason=pmc:software_reset,pmic:0x0 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait
[ 11.295] Build Date: 02 November 2016 10:05:28PM
[ 11.295] xorg-server 2:1.18.4-0ubuntu0.2 (For technical support please see Enterprise open source support | Ubuntu)
[ 11.295] Current version of pixman: 0.33.6
[ 11.295] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 11.295] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 11.296] (==) Log file: “/var/log/Xorg.0.log”, Time: Fri Jul 7 03:58:19 2017
[ 11.297] (==) Using config file: “/etc/X11/xorg.conf”
[ 11.297] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 11.301] (==) No Layout section. Using the first Screen section.
[ 11.301] (==) No screen section available. Using defaults.
[ 11.301] (
) |–>Screen “Default Screen Section” (0)
[ 11.301] () | |–>Monitor “”
[ 11.301] (==) No device specified for screen “Default Screen Section”.
Using the first device section listed.
[ 11.301] (
) | |–>Device “Tegra0”
[ 11.301] (==) No monitor specified for screen “Default Screen Section”.
Using a default monitor configuration.
[ 11.301] (==) Automatically adding devices
[ 11.301] (==) Automatically enabling devices
[ 11.301] (==) Automatically adding GPU devices
[ 11.301] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 11.304] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 11.304] Entry deleted from font path.
[ 11.304] (WW) The directory “/usr/share/fonts/X11/100dpi/” does not exist.
[ 11.304] (WW) The directory “/usr/share/fonts/X11/75dpi/” does not exist.
[ 11.308] (WW) The directory “/usr/share/fonts/X11/100dpi” does not exist.
[ 11.308] Entry deleted from font path.
[ 11.308] (WW) The directory “/usr/share/fonts/X11/75dpi” does not exist.
[ 11.309] Entry deleted from font path.
[ 11.309] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 11.309] (==) ModulePath set to “/usr/lib/aarch64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules”
[ 11.309] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 11.309] (II) Loader magic: 0x5594ebfd80
[ 11.309] (II) Module ABI versions:
[ 11.309] X.Org ANSI C Emulation: 0.4
[ 11.309] X.Org Video Driver: 20.0
[ 11.309] X.Org XInput driver : 22.1
[ 11.309] X.Org Server Extension : 9.0
[ 11.312] (++) using VT number 7
[ 11.313] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 11.313] (II) no primary bus or device found
[ 11.313] (WW) “dri” will not be loaded unless you’ve specified it to be loaded elsewhere.
[ 11.314] (II) “glx” will be loaded by default.
[ 11.314] (II) LoadModule: “extmod”
[ 11.314] (II) Module “extmod” already built-in
[ 11.314] (II) LoadModule: “glx”
[ 11.315] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 11.412] (II) Module glx: vendor=“NVIDIA Corporation”
[ 11.412] compiled for 4.0.2, module version = 1.0.0
[ 11.412] Module class: X.Org Server Extension
[ 11.412] (II) NVIDIA GLX Module 24.2.1 Release Build (integ_stage_rel) (buildbrain@mobile-u64-1072) Wed Nov 9 19:45:00 PST 2016
[ 11.420] (II) LoadModule: “nvidia”
[ 11.423] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 11.443] (II) Module nvidia: vendor=“NVIDIA Corporation”
[ 11.443] compiled for 4.0.2, module version = 1.0.0
[ 11.443] Module class: X.Org Video Driver
[ 11.443] (II) NVIDIA dlloader X Driver 24.2.1 Release Build (integ_stage_rel) (buildbrain@mobile-u64-1072) Wed Nov 9 19:46:25 PST 2016
[ 11.443] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 11.445] (WW) Falling back to old probe method for NVIDIA
[ 11.445] (II) Loading sub module “fb”
[ 11.445] (II) LoadModule: “fb”
[ 11.446] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 11.448] (II) Module fb: vendor=“X.Org Foundation”
[ 11.448] compiled for 1.18.4, module version = 1.0.0
[ 11.448] ABI class: X.Org ANSI C Emulation, version 0.4
[ 11.448] (II) Loading sub module “wfb”
[ 11.448] (II) LoadModule: “wfb”
[ 11.448] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 11.449] (II) Module wfb: vendor=“X.Org Foundation”
[ 11.449] compiled for 1.18.4, module version = 1.0.0
[ 11.449] ABI class: X.Org ANSI C Emulation, version 0.4
[ 11.449] (II) Loading sub module “ramdac”
[ 11.449] (II) LoadModule: “ramdac”
[ 11.449] (II) Module “ramdac” already built-in
[ 11.450] (II) NVIDIA(0): Creating default Display subsection in Screen section
“Default Screen Section” for depth/fbbpp 24/32
[ 11.450] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 11.450] (==) NVIDIA(0): RGB weight 888
[ 11.450] (==) NVIDIA(0): Default visual is TrueColor
[ 11.450] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 11.450] () NVIDIA(0): Option “AllowEmptyInitialConfiguration” “true”
[ 11.451] (
) NVIDIA(0): Enabling 2D acceleration
[ 11.506] (–) NVIDIA(0): Valid display device(s) on GPU-0 at SoC
[ 11.507] (–) NVIDIA(0): DFP-0
[ 11.507] (II) NVIDIA(GPU-0): Found DRM driver drm-nvdc (0)
[ 11.507] (WW) NVIDIA(GPU-0): Unexpected DRM driver drm-nvdc found: ignoring
[ 11.507] (II) NVIDIA(0): NVIDIA GPU NVIDIA Tegra X1 (nvgpu) (NVIDIA Tegra X1) at SoC
[ 11.507] (II) NVIDIA(0): (GPU-0)
[ 11.507] (–) NVIDIA(0): Memory: 4090604 kBytes
[ 11.507] (–) NVIDIA(0): VideoBIOS:
[ 11.507] (==) NVIDIA(0):
[ 11.507] (==) NVIDIA(0): No modes were requested; the default mode “nvidia-auto-select”
[ 11.507] (==) NVIDIA(0): will be used as the requested mode.
[ 11.507] (–) NVIDIA(0): No enabled display devices found; starting anyway because
[ 11.507] (–) NVIDIA(0): AllowEmptyInitialConfiguration is enabled
[ 11.507] (II) NVIDIA(0): Validated MetaModes:
[ 11.507] (II) NVIDIA(0): “NULL”
[ 11.507] (II) NVIDIA(0): Virtual screen size determined to be 640 x 480
[ 11.507] (WW) NVIDIA(0): Unable to get display device for DPI computation.
[ 11.507] (==) NVIDIA(0): DPI set to (75, 75); computed from built-in default
[ 11.508] (–) Depth 24 pixmap format is 32 bpp
[ 11.508] (II) NVIDIA: Reserving 3072.00 MB of virtual memory for indirect memory
[ 11.508] (II) NVIDIA: access.
[ 11.508] (WW) NVIDIA(GPU-0): Failed to enter interactive mode.
[ 11.515] (EE) NVIDIA(0): Failed to allocate NVIDIA Error Handler
[ 11.515] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 11.515] (II) NVIDIA(0): may not be running or the “AcpidSocketPath” X
[ 11.515] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 11.515] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 11.515] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 11.515] (II) NVIDIA(0): details, please see the “ConnectToAcpid” and
[ 11.515] (II) NVIDIA(0): “AcpidSocketPath” X configuration options in Appendix B: X
[ 11.515] (II) NVIDIA(0): Config Options in the README.
[ 11.552] (II) NVIDIA(0): Built-in logo is bigger than the screen.
[ 11.553] (II) NVIDIA(0): Setting mode “NULL”
[ 11.558] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 11.558] (==) NVIDIA(0): Backing store enabled
[ 11.558] (==) NVIDIA(0): Silken mouse enabled
[ 11.559] (==) NVIDIA(0): DPMS enabled
[ 11.563] (EE) NVIDIA(0): Failed to allocate NVIDIA Damage Manager
[ 11.563] (II) Loading sub module “dri2”
[ 11.563] (II) LoadModule: “dri2”
[ 11.563] (II) Module “dri2” already built-in
[ 11.563] (II) NVIDIA(0): [DRI2] Setup complete
[ 11.563] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 11.563] (–) RandR disabled
[ 11.573] (II) SELinux: Disabled on system
[ 11.574] (II) Initializing extension GLX
[ 11.574] (II) Indirect GLX disabled.
[ 11.680] (II) config/udev: Adding input device gpio-keys (/dev/input/event1)
[ 11.680] () gpio-keys: Applying InputClass “evdev keyboard catchall”
[ 11.680] (II) LoadModule: “evdev”
[ 11.681] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 11.684] (II) Module evdev: vendor=“X.Org Foundation”
[ 11.684] compiled for 1.18.1, module version = 2.10.1
[ 11.684] Module class: X.Org XInput Driver
[ 11.684] ABI class: X.Org XInput driver, version 22.1
[ 11.684] (II) Using input driver ‘evdev’ for ‘gpio-keys’
[ 11.684] (
) gpio-keys: always reports core events
[ 11.684] () evdev: gpio-keys: Device: “/dev/input/event1”
[ 11.685] (–) evdev: gpio-keys: Vendor 0x1 Product 0x1
[ 11.685] (–) evdev: gpio-keys: Found keys
[ 11.685] (II) evdev: gpio-keys: Configuring as keyboard
[ 11.685] (
) Option “config_info” “udev:/sys/devices/platform/gpio-keys.47/input/input1/event1”
[ 11.685] (II) XINPUT: Adding extended input device “gpio-keys” (type: KEYBOARD, id 6)
[ 11.685] () Option “xkb_rules” “evdev”
[ 11.685] (
) Option “xkb_model” “pc105”
[ 11.685] () Option “xkb_layout” “us”
[ 11.686] (II) config/udev: Adding input device tegra-snd-t210ref-mobile-rt565x Headphone Jack (/dev/input/event0)
[ 11.686] (
) tegra-snd-t210ref-mobile-rt565x Headphone Jack: Applying InputClass “evdev keyboard catchall”
[ 11.686] (II) Using input driver ‘evdev’ for ‘tegra-snd-t210ref-mobile-rt565x Headphone Jack’
[ 11.686] () tegra-snd-t210ref-mobile-rt565x Headphone Jack: always reports core events
[ 11.686] (
) evdev: tegra-snd-t210ref-mobile-rt565x Headphone Jack: Device: “/dev/input/event0”
[ 11.687] (–) evdev: tegra-snd-t210ref-mobile-rt565x Headphone Jack: Vendor 0 Product 0
[ 11.687] (–) evdev: tegra-snd-t210ref-mobile-rt565x Headphone Jack: Found keys
[ 11.687] (II) evdev: tegra-snd-t210ref-mobile-rt565x Headphone Jack: Configuring as keyboard
[ 11.687] () Option “config_info” “udev:/sys/devices/platform/sound.27/sound/card1/input0/event0”
[ 11.687] (II) XINPUT: Adding extended input device “tegra-snd-t210ref-mobile-rt565x Headphone Jack” (type: KEYBOARD, id 7)
[ 11.687] (
[ 11.687] () Option “xkb_model” “pc105”
[ 11.687] (
What is the output from:
sudo cat /sys/kernel/debug/tegradc.1/edid
In a log where the monitor is found I’d expect to see this excerpt:
[    12.461] (--) NVIDIA(0): VideoBIOS:
[    12.461] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
This is followed by the “No modes were requested” comment (which is normal), but you are missing the refresh ranges from EDID in between. The edid file should tell us if the information is available and rejected, or if the information is missing.
You can get additional mode information if the EDID file is not empty. If that file is not empty, then add this to your “/etc/X11/xorg.conf” file in the “Driver” section:
Option      "ModeDebug"
…once that option is in place reboot and post the new Xorg.0.log.
FYI, if you highlight the pasted log or edid file content with the mouse, and then click on the “code” icon in the upper right (looks like “</>”), it’ll keep some of the formatting and add scroll bars.
Hello linuxdev,
The command
gives this:
NO EDID
Without EDID there is no possibility of automatic configuration, so this seems to be the problem. EDID is provided on a wire in the video cable. On older 15-pin D-sub VGA this wire does not exist. Does your cabling include a 15-pin D-sub at any point? If not, then the cable needs to be inspected for bent/broken pins, or perhaps if DVI, some cheaper DVI cables or adapters are for analog only and leave out the EDID/DDC line (this is rare, most DVI cables have EDID/DDC).
No I just used the HDMI cable only.
Check for bent pins. If you have an alternate HDMI cable, try that. It’s odd that EDID is missing…it isn’t uncommon for the video driver to not like something in that data, but it is rare for the data to be missing when the cable is the correct type.
NOTE: If you ssh in, don’t use the “-Y” or “-X” forwarding options…possibly this would get in the way (though it shouldn’t matter for “cat”).
Hi linuxdev,
I have tried that. i don’t what happened to this board. It was working last week and hdmi is not responding in next morning. Sounds like a comedy right?. Please help me to solve this issue. Do I hav to recompile linux kernel?
Yadu,
What kind of display do you use? I guess it is HDMI? Is it a 4k@60 monitor?
Please use command “dmesg” after tegra boot up and paste kernel log.
Hi Wayne,
I am using an LG 3D LED Monitor. Here is the log for “dmesg” command:
[code][ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.10.96-tegra (buildbrain@mobile-u64-1072) (gcc version 4.8.2 (GCC) ) #1 SMP PREEMPT Wed Nov 9 19:42:57 PST 2016
[ 0.000000] CPU: Cortex A57 Processor [411fd071] revision 1
[ 0.000000] alternative: enabling workaround for ARM erratum 832075
[ 0.000000] Machine: jetson_tx1
[ 0.000000] bootconsole [earlycon0] enabled
[ 0.000000] Reserved memory: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] Tegra reserved memory:
LP0: ff2bf000 - ff2bffff
Bootloader framebuffer: 00000000 - 00000000
Bootloader framebuffer2: 00000000 - 00000000
Framebuffer: 00000000 - 00000000
2nd Framebuffer: 00000000 - 00000000
Carveout: 00000000 - 00000000
Vpr: 00000000 - 00000000
Tsec: 00000000 - 00000000
Bootloader Debug Data: 00000000 - 00000000
[ 0.000000] Nvdumper: ff23f000 - ff23ffff
[ 0.000000] cma: CMA: reserved 16 MiB at fdc00000
[ 0.000000] On node 0 totalpages: 1043968
[ 0.000000] DMA32 zone: 7168 pages used for memmap
[ 0.000000] DMA32 zone: 0 pages reserved
[ 0.000000] DMA32 zone: 519680 pages, LIFO batch:31
[ 0.000000] Normal zone: 7168 pages used for memmap
[ 0.000000] Normal zone: 524288 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv0.2 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/arch/arm64/boot/dts/tegra210-jetson-tx1-p2597-2180-a01-devkit.dts
[ 0.000000] DTB Build time: Nov 9 2016 19:40:03
[ 0.000000] Tegra21: Speedo/IDDQ fuse revision 4
[ 0.000000] Tegra21: CPU Speedo ID 7, Soc Speedo ID 0, Gpu Speedo ID 2
[ 0.000000] Tegra21: CPU Process ID 0, Soc Process ID 1, Gpu Process ID 0
[ 0.000000] Tegra21: CPU Speedo value 2064, Soc Speedo value 1965, Gpu Speedo value 2082
[ 0.000000] Tegra21: CPU IDDQ 2376, Soc IDDQ 2576, Gpu IDDQ 3335
[ 0.000000] Tegra Revision: A02 SKU: 0x17 CPU Process: 0 Core Process: 1 Bootrom patch v0x3f
[ 0.000000] tegra: PLLP fixed rate: 408000000
[ 0.000000] pll_u: boot with h/w control already set
[ 0.000000] pll_x boot misc1 0x0 : expected 0x20
[ 0.000000] (comparison mask = 0xffffff)
[ 0.000000] pll_c4 rates match 204000000 max sdmmc: vco=998400000 out0=998400000 out3=998400000
[ 0.000000] Lowering vic03 maximum rate from 1000000000 to 627200000
[ 0.000000] Lowering nvjpg maximum rate from 1000000000 to 627200000
[ 0.000000] Lowering se maximum rate from 1000000000 to 627200000
[ 0.000000] Lowering tsecb maximum rate from 1000000000 to 627200000
[ 0.000000] Lowering msenc maximum rate from 1000000000 to 716800000
[ 0.000000] Lowering nvdec maximum rate from 1000000000 to 716800000
[ 0.000000] Lowering vi maximum rate from 1000000000 to 793600000
[ 0.000000] Lowering isp maximum rate from 1000000000 to 793600000
[ 0.000000] Lowering adsp_bus maximum rate from 1200000000 to 844800000
[ 0.000000] Lowering sbus maximum rate from 600000000 to 408000000
[ 0.000000] Lowering host1x maximum rate from 600000000 to 408000000
[ 0.000000] Lowering pll_c maximum rate from 1200000000 to 1130000000
[ 0.000000] Lowering pll_c2 maximum rate from 1200000000 to 1130000000
[ 0.000000] Lowering pll_c3 maximum rate from 1200000000 to 1130000000
[ 0.000000] Lowering pll_d2 maximum rate from 1500000000 to 1130000000
[ 0.000000] Lowering pll_dp maximum rate from 1500000000 to 1130000000
[ 0.000000] Lowering sor0 maximum rate from 600000000 to 540000000
[ 0.000000] Lowering sor1 maximum rate from 600000000 to 594000000
[ 0.000000] Lowering dmic1 maximum rate from 12288000 to 12190000
[ 0.000000] Lowering dmic2 maximum rate from 12288000 to 12190000
[ 0.000000] Lowering dmic3 maximum rate from 12288000 to 12190000
[ 0.000000] Lowering hda maximum rate from 102000000 to 51000000
[ 0.000000] Lowering sdmmc2 maximum rate from 266000000 to 204000000
[ 0.000000] Lowering qspi maximum rate from 163200000 to 116600000
[ 0.000000] Lowering gbus maximum rate from 1300000000 to 998400000
[ 0.000000] Lowering cpu_g maximum rate from 3000000000 to 1734000000
[ 0.000000] Lowering cpu_lp maximum rate from 1350000000 to 1132800000
[ 0.000000] tegra dvfs: vdd_cpu: nominal 1226mV, offset 708000uV, step 19200uV, scaling enabled
[ 0.000000] tegra dvfs: vdd_core: nominal 1075mV, offset 0uV, step 12500uV, scaling enabled
[ 0.000000] tegra dvfs: vdd_gpu: nominal 1100mV, offset 710000uV, step 10000uV, scaling enabled
[ 0.000000] Tegra reset control registration success
[ 0.000000] tegra_powergate_init: DONE
[ 0.000000] PERCPU: Embedded 13 pages/cpu @ffffffc01fecf000 s20800 r8192 d24256 u53248
[ 0.000000] pcpu-alloc: s20800 r8192 d24256 u53248 alloc=134096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1029632
[ 0.000000] Kernel command line: fbcon=map:0 console=tty0 console=ttyS0,115200n8 androidboot.modem=none androidboot.serialno=P2180A00P00940c003fd androidboot.security=non-secure tegraid=21.1.2.0.0 ddr_die=2048M@2048M ddr_die=2048M@4096M section=256M memtype=0 usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 debug_uartport=lsport,0 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff2bf000 nvdumper_reserved=0xff23f000 core_edp_mv=1125 core_edp_ma=4000 gpt android.kerneltype=normal androidboot.touch_vendor_id=0 androidboot.touch_panel_id=63 androidboot.touch_feature=0 androidboot.bootreason=pmc:software_reset,pmic:0x0 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 2030MB 2048MB = 4078MB total
[ 0.000000] Memory: 4067000k/4067000k available, 108872k reserved
[ 0.000000] Virtual kernel memory layout:
vmalloc : 0xffffff8000000000 - 0xffffffbbffff0000 (245759 MB)
vmemmap : 0xffffffbc01c00000 - 0xffffffbc05400000 ( 56 MB)
modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
memory : 0xffffffc000000000 - 0xffffffc100000000 ( 4096 MB)
.init : 0xffffffc00114f000 - 0xffffffc0011ba140 ( 429 kB)
.text : 0xffffffc000080000 - 0xffffffc00114e3a4 ( 17209 kB)
.data : 0xffffffc0011ce000 - 0xffffffc00139e7f0 ( 1858 kB)
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[ 0.000000] NR_IRQS:704 nr_irqs:704 0
[ 0.000000] the number of interrupt controllers found is 6
[ 0.000000] Architected local timer running at 19.20MHz (phys).
[ 0.000000] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 3579139424256ns
[ 0.000000] Console: colour dummy device 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] allocated 16777216 bytes of page_cgroup
[ 0.000000] please try ‘cgroup_disable=memory’ option if you don’t want memory cgroups
[ 0.023457] Calibrating delay loop (skipped), value calculated using timer frequency… lpj=192000
[ 0.032265] pid_max: default: 32768 minimum: 301
[ 0.036957] Security Framework initialized
[ 0.040990] Mount-cache hash table entries: 256
[ 0.099550] Initializing cgroup subsys debug
[ 0.101855] Initializing cgroup subsys memory
[ 0.106193] Initializing cgroup subsys devices
[ 0.110592] Initializing cgroup subsys freezer
[ 0.115001] Initializing cgroup subsys net_cls
[ 0.119420] Initializing cgroup subsys blkio
[ 0.123674] Initializing cgroup subsys perf_event
[ 0.128541] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available
[ 0.170269] ftrace: Allocated trace_printk buffers
[ 0.230801] Brought up 4 CPUs
[ 0.231779] SMP: Total of 4 processors activated.
[ 0.236471] alternatives: patching kernel code
[ 0.243431] devtmpfs: initialized
[ 0.253806] pinctrl core: initialized pinctrl subsystem
[ 0.257266] regulator-dummy: ; Rail ON
[ 0.261106] Initializing plugin-manager
[ 0.264949] node /plugin-manager/fragment-e3326@0 match with board 3326-
[ 0.272011] node /plugin-manager/fragement@0 match with board >=2180-1000-300
[ 0.279001] NET: Registered protocol family 16
[ 0.284812] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.290627] console [pstore-1] enabled
[ 0.293529] ramoops: attached 0x200000@0xff03f000, ecc: 0/0
[ 0.299340] I2C first dynamic bus number based on alias = 7
[ 0.304669] cpuidle: using governor ladder
[ 0.308689] cpuidle: using governor menu
[ 0.313373] PMC: Setting PMIC interrupt active-low
[ 0.318058] tegra-pmc device create success
[ 0.321580] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.328712] Clear bootloader IO dpd settings
[ 0.332968] PMC: configuring io pad defaults
[ 0.337382] PMC: IO pad audio voltage is 1800000
[ 0.341906] PMC: IO pad cam voltage is 1800000
[ 0.346316] PMC: IO pad dbg voltage is 1800000
[ 0.350745] PMC: IO pad dmic voltage is 1800000
[ 0.355244] PMC: IO pad pex-ctrl voltage is 1800000
[ 0.360096] PMC: IO pad spi voltage is 1800000
[ 0.364524] PMC: IO pad uart voltage is 1800000
[ 0.369023] PMC: IO pad bb voltage is 1800000
[ 0.373365] PMC: IO pad audio-hv voltage is 1800000
[ 0.378210] PMC: IO pad spi-hv voltage is 1800000
[ 0.382898] PMC: IO pad gpio voltage is 1800000
[ 0.387397] PMC: IO pad sdmmc3 voltage is 1800000
[ 0.391993] PMC: IO pad pex-bias power is disable
[ 0.396663] PMC: IO pad pex-clk1 power is disable
[ 0.401351] PMC: IO pad pex-clk2 power is disable
[ 0.406014] T210 pmc padctrl driver initialized
[ 0.410562] T210 pmc config for bootrom command passed
[ 0.416536] INFO: pinmux CLAMP_INPUTS_WHEN_TRISTATED: disabled
[ 0.423205] clk_init_from_dt_table: clocks are set from t210-clk-init-table:clkinit-0
[ 0.431334] platform tegra-carveouts.23: SMMU isn’t ready yet
[ 0.435581] platform tegra-carveouts.23: domain=ffffffc0fe239e58 allocates as[0]=ffffffc0fe1e80a8
[ 0.443975] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.450535] bpmp: connect returned 0
[ 0.453900] mapped MMIO address: 0xffffff8000038000 → 0x70019000
[ 0.459582] mapped MMIO address: 0xffffff800005e000 → 0x7001c000
[ 0.465662] mapped MMIO address: 0xffffff8000096000 → 0x7001d000
[ 0.472557] Wake16 for irq=34
[ 0.479917] tegra210-pinctrl 700008d4.pinmux: lookup the user state drive not found
[ 0.485597] tegra210-pinctrl 700008d4.pinmux: lookup the user state unused not found
[ 0.493299] tegra210-pinctrl 700008d4.pinmux: Probed Tegra pinctrl driver
[ 0.500415] GPIO chip tegra-gpio: created GPIO range 0->245 ==> 700008d4.pinmux PIN 0->245
[ 0.508323] tegra-gpio 6000d000.gpio: Initialising GPIO state 0: name wlan-default
[ 0.515851] tegra-gpio 6000d000.gpio: Initialising GPIO state 1: name camera_control
[ 0.523571] tegra-gpio 6000d000.gpio: Initialising GPIO state 2: name camera-control
[ 0.531315] gpiochip_add: registered GPIOs 0 to 255 on device: tegra-gpio
[ 0.540770] Wake44 for irq=81
[ 0.541767] Wake40 for irq=53
[ 0.544687] Wake41 for irq=53
[ 0.547634] Wake42 for irq=53
[ 0.550580] Wake43 for irq=53
[ 0.553894] platform 70006000.serial: domain=ffffffc0fe20b158 allocates as[0]=ffffffc0fe1e8110
[ 0.562803] platform sound.27: domain=ffffffc0fe28ddd8 allocates as[0]=ffffffc0fe1e8178
[ 0.571563] platform tegradc.1: domain=ffffffc0fe28d9d8 allocates as[0]=ffffffc0fe1e81e0
[ 0.579636] platform gpu.0: domain=ffffffc0fe28d758 allocates as[0]=ffffffc0fe1e8248
[ 0.585913] platform gpu.0: domain=ffffffc0fe28d758 allocates as[1]=ffffffc0fe1e82b0
[ 0.593619] platform gpu.0: domain=ffffffc0fe28d758 allocates as[2]=ffffffc0fe1e8318
[ 0.601327] platform gpu.0: domain=ffffffc0fe28d758 allocates as[3]=ffffffc0fe1e8380
[ 0.610425] platform 1003000.pcie-controller: domain=ffffffc0fe28d558 allocates as[0]=ffffffc0fe1e83e8
[ 0.619598] platform sdhci-tegra.3: domain=ffffffc0fe28d0d8 allocates as[0]=ffffffc0fe1e8450
[ 0.627017] platform sdhci-tegra.0: domain=ffffffc0fe2f9dd8 allocates as[0]=ffffffc0fe1e84b8
[ 0.635293] Wake39 for irq=52
[ 0.643882] gpio wake52 for gpio=61
[ 0.645584] gpio wake8 for gpio=58
[ 0.648785] gpio wake8 for gpio=58
[ 0.653011] irq: no irq domain found for /soctherm@0x700E2000 !
[ 0.658150] irq: no irq domain found for /soctherm@0x700E2000 !
[ 0.664088] board_info: id:sku:fab:major:minor = 0x0884:0x03e8:0x00:0x00:0x00
[ 0.671059] PMC dt information non-NULL tegra_init_suspend
[ 0.681470] Loading EMC tables…
[ 0.682870] tegra: Using EMC sequence ‘21021’ for Rev. 7 tables
[ 0.688696] tegra: emc: Derated table is valid.
[ 0.693212] Lowering emc maximum rate from 1800000000 to 1600000000
[ 0.699444] tegra: validated EMC DFS table
[ 0.709240] swapper/0 isomgr_init(): iso emc max clk=1600000KHz
[ 0.713196] swapper/0 isomgr_init(): max_iso_bw=11520000KB
[ 0.718804] vdso: 2 pages (1 code, 1 data) at base ffffffc0011d6000
[ 0.724891] vdso32: 2 pages (1 code, 1 data) at base ffffffc0011d5000
[ 0.731314] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.738204] nvdumper: last reboot was unknown
[ 0.742391] nvdumper: set_dirty_state 0x2badface
[ 0.747312] Tegra restart notifier registered.
[ 0.758547] bio: create slab at 0
[ 0.761878] vdd-ac-bat: 5000 mV ; Rail ON
[ 0.764698] vdd-cpu-fixed: 1000 mV ; Rail ON
[ 0.769243] vgaarb: loaded
[ 0.771782] SCSI subsystem initialized
[ 0.775240] libata version 3.00 loaded.
[ 0.775365] usbcore: registered new interface driver usbfs
[ 0.780713] usbcore: registered new interface driver hub
[ 0.786020] usbcore: registered new device driver usb
[ 0.791597] gpio wake33 for gpio=188
[ 0.796011] regulator_get() failed for (1-0074,vcc), -19
[ 0.799830] pca953x 1-0074: no regulator found for vcc. Assuming vcc is always powered
[ 0.807803] tegra-i2c 7000c400.i2c: no acknowledge from address 0x74
[ 0.814091] pca953x 1-0074: failed reading register
[ 0.818895] pca953x: probe of 1-0074 failed with error -121
[ 0.824686] regulator_get() failed for (1-0077,vcc), -19
[ 0.829727] pca953x 1-0077: no regulator found for vcc. Assuming vcc is always powered
[ 0.838302] gpio wake36 for gpio=202
[ 0.841291] gpiochip_add: registered GPIOs 1008 to 1023 on device: tca9539
[ 0.848411] i2c i2c-3: of_i2c: modalias failure on /i2c@7000c700/prod-settings
[ 0.856032] max77620 4-003c: CID0: 0xaf
[ 0.859101] max77620 4-003c: CID1: 0x03
[ 0.862927] max77620 4-003c: CID2: 0x04
[ 0.866725] max77620 4-003c: CID3: 0x59
[ 0.870550] max77620 4-003c: CID4: 0x3c
[ 0.874351] max77620 4-003c: CID5: 0x80
[ 0.878164] max77620 4-003c: MAX77620 PMIC OTP Version is 0x3C
[ 0.885313] max77620-pmic max77620-pmic: Consumer c2 does not have device name
[ 0.891994] vdd_core: 600 <–> 1400 mV at 1000 mV with ramp delay 27500 uV/us ; Rail ON
[ 0.899761] vddio-ddr: at 1125 mV with ramp delay 27500 uV/us ; Rail ON
[ 0.906094] vdd-pre-reg: 1350 mV with ramp delay 27500 uV/us ; Rail ON
[ 0.913081] vdd-1v8: 1800 mV with ramp delay 27500 uV/us ; Rail ON
[ 0.918900] avdd-sys: 1200 mV with ramp delay 100000 uV/us ; Rail ON
[ 0.924695] avdd-sys: supplied by vdd-pre-reg
[ 0.929398] vdd-pex: 1050 mV with ramp delay 100000 uV/us ; Rail ON
[ 0.935251] vdd-pex: supplied by vdd-pre-reg
[ 0.939810] vddio-sdmmc1: 1800 <–> 3300 mV at 3300 mV with ramp delay 100000 uV/us ; Rail ON
[ 0.948306] vdd-cam-hv: 2800 mV with ramp delay 100000 uV/us ; Rail OFF
[ 0.954929] vdd-rtc: 850 mV with ramp delay 100000 uV/us ; Rail ON
[ 0.961042] avdd-ts-hv: 3300 mV with ramp delay 100000 uV/us ; Rail OFF
[ 0.968289] vdd-ts: 1800 mV with ramp delay 100000 uV/us ; Rail OFF
[ 0.974116] vdd-gen-pll-edp: 1050 mV with ramp delay 100000 uV/us ; Rail ON
[ 0.980493] vdd-gen-pll-edp: supplied by vdd-pre-reg
[ 0.985942] vdd-hdmi-dp: 1050 mV with ramp delay 100000 uV/us ; Rail ON
[ 0.992016] vdd-hdmi-dp: supplied by vdd-pre-reg
[ 0.996883] max77620-gpio max77620-gpio.0: Initialising GPIO state 1: name gpio_default
[ 1.004606] gpiochip_add: registered GPIOs 1000 to 1007 on device: max77620-gpio
[ 1.012996] max77620-gpio max77620-gpio.0: max77620 gpio successfully initialized
[ 1.022149] max77620 4-003c: max77620 probe successfully
[ 1.025985] media: Linux media interface: v0.10
[ 1.029998] Linux video capture interface: v2.00
[ 1.034976] pps_core: LinuxPPS API ver. 1 registered
[ 1.039505] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 1.048632] PTP clock support registered
[ 1.052831] Tegra WDT enabled on probe. Timeout = 120 seconds.
[ 1.058503] tegra_wdt 60005100.watchdog: tegra_wdt_probe done
[ 1.065243] Advanced Linux Sound Architecture Driver Initialized.
[ 1.070428] Bluetooth: Core ver 2.16
[ 1.073672] NET: Registered protocol family 31
[ 1.078070] Bluetooth: HCI device and connection manager initialized
[ 1.084417] Bluetooth: HCI socket layer initialized
[ 1.089255] Bluetooth: L2CAP socket layer initialized
[ 1.094300] Bluetooth: SCO socket layer initialized
[ 1.100171] vdd-3v3: 3300 mV ; Rail ON
[ 1.103919] max77620-gpio7: 1050 mV ; Rail ON
[ 1.107229] max77620-gpio7: supplied by vdd-gen-pll-edp
[ 1.112606] lcd-bl-en: 1800 mV ; Rail ON
[ 1.116467] en-vdd-sd: 3300 mV ; Rail OFF
[ 1.120335] en-vdd-sd: supplied by vdd-3v3
[ 1.124458] reg-fixed-sync-voltage 5.regulator: Consumer c1 does not have device name
[ 1.132520] en-vdd-cam: 1800 mV ; Rail OFF
[ 1.142869] vdd-sys-boost: 5000 mV ; Rail ON
[ 1.145275] platform 7.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 1.153227] aux-3v3: 3300 mV ; Rail ON
[ 1.156979] snsr_pm: 3300 mV ; Rail ON
[ 1.161210] vdd-disp-3v0: 3000 mV ; Rail ON
[ 1.164838] platform d.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 1.172849] usb-vbus1: 5000 mV ; Rail OFF
[ 1.176726] usb-vbus1: supplied by vdd-3v3
[ 1.180956] usb-vbus3: 5000 mV ; Rail OFF
[ 1.184784] usb-vbus3: supplied by vdd-3v3
[ 1.188942] platform c9.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 1.196967] platform ca.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 1.205024] platform cb.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 1.213081] platform cc.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 1.221142] platform cd.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 1.229173] reg-fixed-sync-voltage ce.regulator: Consumer c0 does not have device name
[ 1.237051] platform ce.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 1.245200] rtl-5v0: ; Rail OFF
[ 1.248352] en-usb-vbus2: ; Rail OFF
[ 1.252183] en-vdd-cam-1v2: ; Rail OFF
[ 1.255505] en-vdd-cam-1v2: supplied by vdd-3v3
[ 1.260146] en-vdd-vcm-2v8: ; Rail ON
[ 1.263650] en-vdd-vcm-2v8: supplied by vdd-3v3
[ 1.268557] en-vdd-cam-1v2-alt: ; Rail OFF
[ 1.272701] regulator-pwm 0.pwm-regulator: PWM request deferred
[ 1.278098] platform 0.pwm-regulator: Driver regulator-pwm requests probe deferral
[ 1.286021] vdd_gpu: applied init 1000000uV constraint
[ 1.290761] vdd_gpu: 710 <–> 1320 mV at 1000 mV ; Rail OFF
[ 1.296722] vdd_cpu: applied init 1000000uV constraint
[ 1.301420] vdd_cpu: 708 <–> 1322 mV at 1000 mV normal ; Rail ON
[ 1.308032] gpio wake34 for gpio=200
[ 1.312220] extcon-gpio-states 1.extcon: Cable state 1
[ 1.317452] Switching to clocksource arch_sys_counter
[ 1.335435] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 1.340155] tegra-carveouts tegra-carveouts.23: iram :dma coherent mem declare 0x0000000040001000,258048
[ 1.349452] tegra-carveouts tegra-carveouts.23: assigned reserved memory node iram-carveout
[ 1.357749] nvmap_page_pool_init: Total RAM pages: 1020846
[ 1.363204] nvmap_page_pool_init: nvmap page pool size: 127605 pages (498 MB)
[ 1.370395] nvmap_background_zero_thread: PP zeroing thread starting.
[ 1.377298] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 1.384142] nvmap:inner cache maint threshold=2097152
[ 1.395567] Wake39 for irq=52
[ 1.396729] Could not add tegra-otg to power domain using device tree
[ 1.403184] tegra-otg tegra-otg: otg transceiver registered
[ 1.408968] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 1.417790] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 1.425637] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 1.433932] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 1.442316] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 1.451308] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 1.459328] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tboard_tegra
[ 1.468478] tegra21_plle_clk_enable: pll_e is already enabled
[ 1.473615] t210_sata_uphy_pll_init: init sata uphy pll
[ 1.478792] t210_sata_uphy_pll_init SATA uses SATA Lane
[ 1.484307] tegra_xusb_padctl_phy_enable: init pex uphy pll
[ 1.490755] tegra210-pmc-iopower pmc-iopower.29: Rail iopower-sys is having fixed voltage 1800000
[ 1.498457] tegra210-pmc-iopower pmc-iopower.29: Rail iopower-uart is having fixed voltage 1800000
[ 1.507373] tegra210-pmc-iopower pmc-iopower.29: Rail iopower-audio is having fixed voltage 1800000
[ 1.516389] tegra210-pmc-iopower pmc-iopower.29: Rail iopower-cam is having fixed voltage 1800000
[ 1.525222] tegra210-pmc-iopower pmc-iopower.29: Rail iopower-pex-ctrl is having fixed voltage 1800000
[ 1.534502] tegra210-pmc-iopower pmc-iopower.29: Rail iopower-sdmmc1 is having voltages: 1800000:3300000
[ 1.543949] tegra210-pmc-iopower pmc-iopower.29: Rail iopower-sdmmc3 is having fixed voltage 1800000
[ 1.553040] tegra210-pmc-iopower pmc-iopower.29: Rail iopower-sdmmc4 is having fixed voltage 1800000
[ 1.562143] tegra210-pmc-iopower pmc-iopower.29: Rail iopower-audio-hv is having fixed voltage 1800000
[ 1.571420] tegra210-pmc-iopower pmc-iopower.29: Rail iopower-debug is having fixed voltage 1800000
[ 1.580417] tegra210-pmc-iopower pmc-iopower.29: Rail iopower-dmic is having fixed voltage 1800000
[ 1.589353] tegra210-pmc-iopower pmc-iopower.29: Rail iopower-gpio is having fixed voltage 1800000
[ 1.598284] tegra210-pmc-iopower pmc-iopower.29: Rail iopower-spi is having fixed voltage 1800000
[ 1.607127] tegra210-pmc-iopower pmc-iopower.29: Rail iopower-spi-hv is having fixed voltage 1800000
[ 1.616221] tegra210-pmc-iopower pmc-iopower.29: Rail iopower-sdmmc2 is having fixed voltage 1800000
[ 1.625322] tegra210-pmc-iopower pmc-iopower.29: Rail iopower-dp is having fixed voltage 1800000
[ 1.634026] tegra210-pmc-iopower pmc-iopower.29: NO_IO_POWER setting 0x0
[ 1.640874] NET: Registered protocol family 2
[ 1.645637] TCP established hash table entries: 32768 (order: 7, 524288 bytes)
[ 1.652396] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 1.658981] TCP: Hash tables configured (established 32768 bind 32768)
[ 1.665368] TCP: reno registered
[ 1.668502] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 1.674516] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 1.681149] NET: Registered protocol family 1
[ 1.685519] RPC: Registered named UNIX socket transport module.
[ 1.691121] RPC: Registered udp transport module.
[ 1.695814] RPC: Registered tcp transport module.
[ 1.700477] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.706905] PCI: CLS 0 bytes, default 64
[ 1.707219] tegra-fuse tegra-fuse: Fuse driver initialized succesfully
[ 1.713766] Trying to unpack rootfs image as initramfs…
[ 1.951614] Freeing initrd memory: 6740K (ffffffc003100000 - ffffffc003795000)
[ 1.960500] host1x host1x: initialized
[ 1.966045] NTFS driver 2.1.30 [Flags: R/O].
[ 1.968482] fuse init (API version 7.22)
[ 1.972374] msgmni has been set to 7988
[ 1.977106] io scheduler noop registered (default)
[ 1.980935] Tegra cpuquiet initialized: disabled
[ 1.987003] tegra-pcie 1003000.pcie-controller: PCIE: Enable power rails
[ 1.993008] tegra-pcie 1003000.pcie-controller: probing port 0, using 4 lanes and lane map as 0x14
[ 2.003052] tegra-pcie 1003000.pcie-controller: probing port 1, using 1 lanes and lane map as 0x14
[ 2.033174] tegra-pcie 1003000.pcie-controller: link 0 down, ignoring
[ 2.037619] tegra-pcie 1003000.pcie-controller: link 1 down, ignoring
[ 2.044058] tegra-pcie 1003000.pcie-controller: PCIE: no ports detected
[ 2.050813] tegra-pcie 1003000.pcie-controller: PCIE: Disable power rails
[ 2.059213] tsec tsec: initialized
[ 2.061828] tsec tsecb: initialized
[ 2.066004] nvdec nvdec: initialized
[ 2.070459] falcon vic03: initialized
[ 2.073519] falcon msenc: initialized
[ 2.076886] falcon nvjpg: initialized
[ 2.080253] tegradc tegradc.1: Display dc.54240000 registered with id=0
[ 2.086035] of_dc_parse_platform_data: DC OR node is connected to /host1x/sor1
[ 2.093353] display board info: id 0x0, fab 0x0
[ 2.098345] display board info: id 0x0, fab 0x0
[ 2.102604] invalid panel compatible
[ 2.105758] parse_tmds_config: No tmds-config node
[ 2.110619] of_dc_parse_platform_data: could not find vrr-settings node
[ 2.117125] of_dc_parse_platform_data: nvidia,hdmi-vrr-caps not present
[ 2.123787] of_dc_parse_platform_data: could not find SD settings node
[ 2.130194] of_dc_parse_platform_data: could not find cmu node
[ 2.136012] of_dc_parse_platform_data: could not find cmu node for adobeRGB
[ 2.142967] tegradc tegradc.1: DT parsed successfully
[ 2.148183] hdmi: couldn’t get regulator vdd_hdmi_5v0
[ 2.153155] display board info: id 0x0, fab 0x0
[ 2.158064] gpio wake53 for gpio=225
[ 2.162049] tegradc tegradc.1: probed
[ 2.246807] Console: switching to colour frame buffer device 80x30
[ 2.254379] tegradc tegradc.1: fb registered
[ 2.259217] tegra_camera_platform tegra-camera-platform.45: tegra_camera_probe:camera_platform_driver probe
[ 2.269691] misc tegra_camera_ctrl: tegra_camera_isomgr_register camera’s max_iso_bw 3600000
[ 2.280971] tegra-apbdma tegra-apbdma: Tegra20 APB DMA driver register 32 channels
[ 2.290452] tegra-adma tegra210-adma: Tegra210 ADMA driver register 10 channels
[ 2.298701] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 2.305484] of_serial 70006000.serial: RX periodic polling enabled
[ 2.311315] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 68) is a Tegra
[ 2.318102] console [ttyS0] enabled, bootconsole disabled
[ 2.328976] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 69) is a SERIAL_TEGRA
[ 2.340254] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 78) is a SERIAL_TEGRA
[ 2.351368] serial-tegra 70006300.serial: RX in PIO mode
[ 2.358359] 70006300.serial: ttyTHS3 at MMIO 0x70006300 (irq = 122) is a SERIAL_TEGRA
[ 2.371497] (null): coherent DMA mask is unset
[ 2.377723] gk20a gpu.0: failed to allocate secure buffer -12
[ 2.390253] brd: module loaded
[ 2.397477] loop: module loaded
[ 2.402679] zram: Created 1 device(s) …
[ 2.408397] nct1008_nct72 0-004c: find device tree node, parsing dt
[ 2.416353] nct1008_nct72 0-004c: starting parse dt
[ 2.422954] nct1008_nct72 0-004c: success parsing dt
[ 2.429581] nct1008_nct72 0-004c: success in enabling rail vdd_nct72
[ 2.437520] tegra-i2c 7000c000.i2c: arb lost in communicate to add 0x4c
[ 2.445764] tegra-i2c 7000c000.i2c: Un-recovered Arbitration lost
[ 2.453391] tegra-i2c 7000c000.i2c: arb lost in communicate to add 0x4c
[ 2.461542] tegra-i2c 7000c000.i2c: Un-recovered Arbitration lost
[ 2.469084] tegra-i2c 7000c000.i2c: arb lost in communicate to add 0x4c
[ 2.477156] tegra-i2c 7000c000.i2c: Un-recovered Arbitration lost
[ 2.484672] tegra-i2c 7000c000.i2c: arb lost in communicate to add 0x4c
[ 2.492699] tegra-i2c 7000c000.i2c: Un-recovered Arbitration lost
[ 2.500113] nct1008_nct72 0-004c: nct1008_read_reg: err -11
[ 2.506999] NCT72: ERR: remote sensor circuit is open (0xfffffff5)
[ 2.514493] tegra-i2c 7000c000.i2c: arb lost in communicate to add 0x4c
[ 2.522468] tegra-i2c 7000c000.i2c: Un-recovered Arbitration lost
[ 2.529834] tegra-i2c 7000c000.i2c: arb lost in communicate to add 0x4c
[ 2.537741] tegra-i2c 7000c000.i2c: Un-recovered Arbitration lost
[ 2.545083] tegra-i2c 7000c000.i2c: arb lost in communicate to add 0x4c
[ 2.552928] tegra-i2c 7000c000.i2c: Un-recovered Arbitration lost
[ 2.560206] tegra-i2c 7000c000.i2c: arb lost in communicate to add 0x4c
[ 2.568052] tegra-i2c 7000c000.i2c: Un-recovered Arbitration lost
[ 2.575295] nct1008_nct72 0-004c: nct1008_write_reg: err -11
[ 2.582128] nct1008_nct72 0-004c:
exit nct1008_configure_sensor, err=-11
[ 2.592730] nct1008_nct72 0-004c:
error file: /dvs/git/dirty/git-master_linux/kernel/drivers/misc/nct1008.c : nct1008_probe(), line=1634
[ 2.610155] nct1008_nct72 0-004c:
exit nct1008_probe, err=-11
[ 2.619907] nct1008_nct72 0-004c: success in disabling rail vdd_nct72
[ 2.627631] nct1008_nct72: probe of 0-004c failed with error -11
[ 2.635510] THERMAL EST start of therm_fan_est_probe.
[ 2.641899] THERMAL EST: found 2 subdevs
[ 2.647033] THERMAL EST name: thermal-fan-est.
[ 2.652692] THERMAL EST num_resources: 0
[ 2.657798] [THERMAL EST subdev 0]
[ 2.662381] THERMAL EST subdev name: CPU-therm
[ 2.667968] THERMAL EST index 0 coeffs 50
[ 2.673094] THERMAL EST index 1 coeffs 0
[ 2.678084] THERMAL EST index 2 coeffs 0
[ 2.683064] THERMAL EST index 3 coeffs 0
[ 2.687985] THERMAL EST index 4 coeffs 0
[ 2.692882] THERMAL EST index 5 coeffs 0
[ 2.697734] THERMAL EST index 6 coeffs 0
[ 2.702576] THERMAL EST index 7 coeffs 0
[ 2.707365] THERMAL EST index 8 coeffs 0
[ 2.712111] THERMAL EST index 9 coeffs 0
[ 2.716824] [THERMAL EST subdev 1]
[ 2.721003] THERMAL EST subdev name: GPU-therm
[ 2.726256] THERMAL EST index 0 coeffs 50
[ 2.731008] THERMAL EST index 1 coeffs 0
[ 2.735612] THERMAL EST index 2 coeffs 0
[ 2.740172] THERMAL EST index 3 coeffs 0
[ 2.744734] THERMAL EST index 4 coeffs 0
[ 2.749220] THERMAL EST index 5 coeffs 0
[ 2.753671] THERMAL EST index 6 coeffs 0
[ 2.758063] THERMAL EST index 7 coeffs 0
[ 2.762449] THERMAL EST index 8 coeffs 0
[ 2.766792] THERMAL EST index 9 coeffs 0
[ 2.771116] THERMAL EST index 0: trip_temp 0, hyst 0
[ 2.776496] THERMAL EST index 1: trip_temp 51000, hyst 15000
[ 2.782575] THERMAL EST index 2: trip_temp 61000, hyst 9000
[ 2.788529] THERMAL EST index 3: trip_temp 71000, hyst 9000
[ 2.794488] THERMAL EST index 4: trip_temp 82000, hyst 10000
[ 2.800533] THERMAL EST index 5: trip_temp 140000, hyst 0
[ 2.806356] THERMAL EST index 6: trip_temp 150000, hyst 0
[ 2.812169] THERMAL EST index 7: trip_temp 160000, hyst 0
[ 2.817972] THERMAL EST index 8: trip_temp 170000, hyst 0
[ 2.823800] THERMAL EST index 9: trip_temp 180000, hyst 0
[ 2.829607] THERMAL EST index 0: trip_temps_hyst 0
[ 2.834824] THERMAL EST index 1: trip_temps_hyst 36000
[ 2.840387] THERMAL EST index 2: trip_temps_hyst 51000
[ 2.845955] THERMAL EST index 3: trip_temps_hyst 52000
[ 2.851477] THERMAL EST index 4: trip_temps_hyst 61000
[ 2.856968] THERMAL EST index 5: trip_temps_hyst 62000
[ 2.862480] THERMAL EST index 6: trip_temps_hyst 71000
[ 2.867974] THERMAL EST index 7: trip_temps_hyst 72000
[ 2.873477] THERMAL EST index 8: trip_temps_hyst 82000
[ 2.878974] THERMAL EST index 9: trip_temps_hyst 140000
[ 2.884584] THERMAL EST index 10: trip_temps_hyst 140000
[ 2.890283] THERMAL EST index 11: trip_temps_hyst 150000
[ 2.895993] THERMAL EST index 12: trip_temps_hyst 150000
[ 2.901714] THERMAL EST index 13: trip_temps_hyst 160000
[ 2.907415] THERMAL EST index 14: trip_temps_hyst 160000
[ 2.913106] THERMAL EST index 15: trip_temps_hyst 170000
[ 2.918773] THERMAL EST index 16: trip_temps_hyst 170000
[ 2.924456] THERMAL EST index 17: trip_temps_hyst 180000
[ 2.930118] THERMAL EST index 18: trip_temps_hyst 180000
[ 2.935786] THERMAL EST index 19: trip_temps_hyst 0
[ 2.940992] THERMAL EST index 20: trip_temps_hyst 0
[ 2.946226] THERMAL EST init dev[0] temp hist to 25000
[ 2.951735] THERMAL EST init dev[1] temp hist to 25000
[ 2.957229] THERMAL EST cdev_type: pwm-fan.
[ 2.961808] THERMAL EST governor name: pid_thermal_gov
[ 2.967548] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est.46
[ 2.977742] THERMAL EST: thz register success.
[ 2.982864] THERMAL EST: end of probe, return err: 0
[ 2.988469] tegra_profiler: Branch: Dev
[ 2.992928] tegra_profiler: Version: 1.107
[ 2.997642] tegra_profiler: Samples version: 36
[ 3.002835] tegra_profiler: IO version: 20
[ 3.007589] armv8_pmu: imp: 0x41, idcode: 0x1
[ 3.012639] armv8_pmu: arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 3.019980] armv8_pmu: imp: 0x41, idcode: 0x1
[ 3.025107] armv8_pmu: arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 3.032549] armv8_pmu: imp: 0x41, idcode: 0x1
[ 3.037741] armv8_pmu: arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 3.045341] armv8_pmu: imp: 0x41, idcode: 0x1
[ 3.050621] armv8_pmu: arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 3.058361] tegra_profiler: auth: init
[ 3.063444] GPS: mt3332_gps_mod_init: platform_driver_register ret = 0
[ 3.071440] tegra-sata tegra-sata.0: version 1.0
[ 3.071834] t210_sata_uphy_pll_init: sata uphy already enabled
[ 3.079450] tegra-sata tegra-sata.0: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl TEGRA-SATA mode
[ 3.091023] tegra-sata tegra-sata.0: flags: 64bit ncq sntf pm led pmp pio slum part sadm apst
[ 3.103002] Rounding down aligned max_sectors from 4294967295 to 4294967288
[ 3.111642] spi-tegra114 7000d400.spi: /spi@7000d400/prod-settings has no reg property
[ 3.122437] spi-tegra114 7000d400.spi: Static pin configuration used
[ 3.130464] spi_master spi0: cannot find modalias for /spi@7000d400/prod-settings
[ 3.140928] spi-tegra114 7000da00.spi: /spi@7000da00/prod-settings has no reg property
[ 3.152076] spi-tegra114 7000da00.spi: Static pin configuration used
[ 3.160307] spi_master spi3: cannot find modalias for /spi@7000da00/prod-settings
[ 3.171720] tun: Universal TUN/TAP device driver, 1.6
[ 3.178460] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 3.186537] e1000e: Intel(R) PRO/1000 Network Driver - 2.3.2-k
[ 3.194115] e1000e: Copyright(c) 1999 - 2013 Intel Corporation.
[ 3.202188] PPP generic driver version 2.4.2
[ 3.208249] PPP BSD Compression module registered
[ 3.214662] PPP Deflate Compression module registered
[ 3.221406] PPP MPPE Compression module registered
[ 3.227842] NET: Registered protocol family 24
[ 3.233981] usbcore: registered new interface driver r8152
[ 3.241124] usbcore: registered new interface driver asix
[ 3.248147] usbcore: registered new interface driver ax88179_178a
[ 3.255795] usbcore: registered new interface driver cdc_ether
[ 3.263122] usbcore: registered new interface driver smsc95xx
[ 3.270270] usbcore: registered new interface driver net1080
[ 3.277306] usbcore: registered new interface driver cdc_subset
[ 3.284524] usbcore: registered new interface driver zaurus
[ 3.291369] usbcore: registered new interface driver cdc_ncm
[ 3.298196] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 3.306165] ehci-pci: EHCI PCI platform driver
[ 3.311928] tegra_xusb_read_usb_calib: usb_calib0 = 0x0a22a414
[ 3.320239] tegra-xhci tegra-xhci: XUSB device id = 0xfac (T210)
[ 3.327933] tegra-xhci tegra-xhci: Firmware File: tegra21x_xusb_firmware (124416 Bytes)
[ 3.338254] tegra-xhci tegra-xhci: Firmware DMA Memory: dma 0x0000000080040000 mapped 0xffffff8000339000 (124416 Bytes)
[ 3.338424] usbcore: registered new interface driver cdc_acm
[ 3.338427] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 3.338454] usbcore: registered new interface driver cdc_wdm
[ 3.338489] usbcore: registered new interface driver usb-storage
[ 3.338570] usbcore: registered new interface driver usbserial
[ 3.338595] usbcore: registered new interface driver ftdi_sio
[ 3.338617] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 3.338637] usbcore: registered new interface driver option
[ 3.338654] usbserial: USB Serial support registered for GSM modem (1-port)
[ 3.338674] usbcore: registered new interface driver pl2303
[ 3.338691] usbserial: USB Serial support registered for pl2303
[ 3.338714] usbcore: registered new interface driver nvshieldled
[ 3.338717] Nvidia Tegra High-Speed USB Device Controller driver (Apr 30, 2012)
[ 3.338977] tegra USB phy - inst[0] platform info:
[ 3.338979] port_otg: yes
[ 3.338981] has_hostpc: yes
[ 3.338982] phy_interface: USB_PHY_INTF_UTMI
[ 3.338984] op_mode: TEGRA_USB_OPMODE_DEVICE
[ 3.338985] qc2_voltage: 0
[ 3.338987] vbus_pmu_irq: 0
[ 3.338988] charging: enabled
[ 3.338990] remote_wakeup: disabled
[ 3.343747] regulator_get() failed for (tegra-udc.0,usb_bat_chg), -19
[ 3.343753] tegra-udc tegra-udc.0: usb_bat_chg regulator not registered: USB charging will not be enabled
[ 3.344111] usbcore: registered new interface driver xpad
[ 3.344136] usbcore: registered new interface driver usb_acecad
[ 3.344159] usbcore: registered new interface driver aiptek
[ 3.344181] usbcore: registered new interface driver gtco
[ 3.344207] usbcore: registered new interface driver hanwang
[ 3.344232] usbcore: registered new interface driver kbtab
[ 3.344256] usbcore: registered new interface driver wacom
[ 3.391229] otg state changed: SUSPEND → PERIPHERAL
[ 3.566389] tegra-xhci tegra-xhci: num_hsic_port 0
[ 3.574301] tegra-xhci tegra-xhci: Firmware timestamp: 2016-06-16 13:21:43 UTC, Version: 50.16 release, Falcon state 0x20
[ 3.587285] tegra-xhci tegra-xhci: Nvidia xHCI Host Controller
[ 3.594133] tegra-xhci tegra-xhci: new USB bus registered, assigned bus number 1
[ 3.604225] tegra-xhci tegra-xhci: irq 71, io mem 0x70090000
[ 3.611016] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.618917] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.628351] usb usb1: Product: Nvidia xHCI Host Controller
[ 3.635029] usb usb1: Manufacturer: Linux 3.10.96-tegra tegra-xhci
[ 3.642433] usb usb1: SerialNumber: tegra-xhci
[ 3.648332] xHCI xhci_add_endpoint called for root hub
[ 3.648339] xHCI xhci_check_bandwidth called for root hub
[ 3.648427] hub 1-0:1.0: USB hub found
[ 3.653406] hub 1-0:1.0: 5 ports detected
[ 3.691094] max77620-rtc max77620-rtc.1: rtc core: registered max77620-rtc as rtc1
[ 3.731243] tegra-xhci tegra-xhci: Nvidia xHCI Host Controller
[ 3.738315] tegra-xhci tegra-xhci: new USB bus registered, assigned bus number 2
[ 3.748402] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 3.756606] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.766724] usb usb2: Product: Nvidia xHCI Host Controller
[ 3.773757] usb usb2: Manufacturer: Linux 3.10.96-tegra tegra-xhci
[ 3.781469] usb usb2: SerialNumber: tegra-xhci
[ 3.787427] Wake51 for irq=118
[ 3.787603] xHCI xhci_add_endpoint called for root hub
[ 3.787606] xHCI xhci_check_bandwidth called for root hub
[ 3.787684] hub 2-0:1.0: USB hub found
[ 3.787700] hub 2-0:1.0: 4 ports detected
[ 3.802429] Enabling wake51
[ 3.806858] Wake16 for irq=34
[ 3.811110] Enabling wake16
[ 3.815820] tegra-rtc 7000e000.rtc: rtc core: registered tegra-rtc as rtc0
[ 3.824245] i2c /dev entries driver
[ 3.830581] [OV5693]: probing v4l2 sensor.
[ 3.831299] Wake44 for irq=81
[ 3.831316] Wake40 for irq=53
[ 3.831318] Wake41 for irq=53
[ 3.831320] Wake42 for irq=53
[ 3.831321] Wake43 for irq=53
[ 3.856694] ov5693 6-0036: camera_common_regulator_get vana ERR: fffffffffffffdfb
[ 3.866492] i2c 6-0036: Driver ov5693 requests probe deferral
[ 3.873586] virtual_init
[ 3.877643] [IMX135] sensor driver loading
[ 3.882826] [imx132] sensor driver loading
[ 3.887957] [ar0261] sensor driver loading
[ 3.893066] ov7695 sensor driver loading
[ 3.897931] mt9m114 sensor driver loading
[ 3.902882] [ov10823] sensor driver loading
[ 3.908134] usbcore: registered new interface driver uvcvideo
[ 3.914826] USB Video Class driver (1.1.1)
[ 3.922234] max77620-power-off max77620-power-off.4: Event recorder REG_NVERC : 0x0
[ 3.932333] FAN: coudln’t get the regulator
[ 3.938864] tegra_aotag tegra-aotag.30: AOTAG probe started
[ 3.945709] tegra_aotag tegra-aotag.30: nominal ft – 105
[ 3.952210] tegra_aotag tegra-aotag.30: tall – 76
[ 3.958005] tegra_aotag tegra-aotag.30: tiddq – 1
[ 3.963807] tegra_aotag tegra-aotag.30: ten-count – 16
[ 3.970004] tegra_aotag tegra-aotag.30: tsample – 9
[ 3.975958] tegra_aotag tegra-aotag.30: pdiv – 8
[ 3.981674] tegra_aotag tegra-aotag.30: nominal cp – 25
[ 3.987999] tegra_aotag tegra-aotag.30: pdiv-ate – 8
[ 3.994086] tegra_aotag tegra-aotag.30: tsamp-ate – 39
[ 4.000292] tegra_aotag tegra-aotag.30: compensation A,B – 10632,-67490
[ 4.008003] tegra_aotag tegra-aotag.30: sensor found :ID 0, Name: aotag0
[ 4.015650] tegra_aotag tegra-aotag.30: reading fuse value for sensor 0
[ 4.023204] tegra_aotag tegra-aotag.30: base-cp:246 shifted-cp:1
[ 4.030120] tegra_aotag tegra-aotag.30: base-ft:4f7 shifted-ft:fffffffc
[ 4.037675] tegra_aotag tegra-aotag.30: actual_aotag_cp 255, ft 1030
[ 4.045024] tegra_aotag tegra-aotag.30: - Tsens calib value - 0x3e5dee5
[ 4.052604] tegra_aotag tegra-aotag.30: CPmask 1fff FTmask 3ffe000
[ 4.059735] tegra_aotag tegra-aotag.30: Tsense calib CP - 0x1ee5
[ 4.066706] tegra_aotag tegra-aotag.30: Tsense Actual CP d.36965
[ 4.071245] usb 1-3: new high-speed USB device number 3 using tegra-xhci
[ 4.081292] tegra_aotag tegra-aotag.30: Tsense calib FT - 0x1f2e
[ 4.088254] tegra_aotag tegra-aotag.30: Tsense Actual FT d.40462
[ 4.095132] tegra_aotag tegra-aotag.30: delta ts 3497, temp 775
[ 4.101956] tegra_aotag tegra-aotag.30: thermA-835, thermB–849
[ 4.108729] tegra_aotag tegra-aotag.30: Registering sensor 0
[ 4.115292] tegra_aotag tegra-aotag.30: Bound to TZ : ID 0
[ 4.121659] tegra_aotag tegra-aotag.30: shutdown temperature - 110
[ 4.128720] tegra_aotag tegra-aotag.30: AOTAG EN 60
[ 4.134482] tegra_aotag tegra-aotag.30: Probe done [SUCCESS]:0
[ 4.134486] usb 1-3: New USB device found, idVendor=05e3, idProduct=0608
[ 4.134492] usb 1-3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 4.134497] usb 1-3: Product: USB2.0 Hub
[ 4.162035] md: raid0 personality registered for level 0
[ 4.168445] device-mapper: uevent: version 1.0.3
[ 4.174189] hub 1-3:1.0: USB hub found
[ 4.179029] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[ 4.189591] hub 1-3:1.0: 4 ports detected
[ 4.194960] Tegra210 cpuidle driver
[ 4.221684] sdhci: Secure Digital Host Controller Interface driver
[ 4.229018] sdhci: Copyright(c) Pierre Ossman
[ 4.234528] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.241681] mmc0: sdhci_tegra_probe line=5737 runtime pm type=mmc rtpm coupled with clock gate, disable-clock-gate=0
[ 4.254637] sdhci-tegra sdhci-tegra.3: Parent select= pll_p rate=408000000
[ 4.262792] sdhci-tegra sdhci-tegra.3: Parent select= pll_c4_out2 rate=199680000
[ 4.272661] Could not add sdhci-tegra.3 to power domain using device tree
[ 4.281435] sdhci-tegra sdhci-tegra.3: Speedo value 1965
[ 4.288111] sdhci-tegra sdhci-tegra.3: Tuning constraints: nom_mv 1075, boot_mv 1075, min_or_mv 0
[ 4.299841] regulator_get() failed for (sdhci-tegra.3,vqmmc), -19
[ 4.307423] mmc0: no vqmmc regulator found
[ 4.313005] regulator_get() failed for (sdhci-tegra.3,vmmc), -19
[ 4.320492] mmc0: no vmmc regulator found
[ 4.361249] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA
[ 4.371666] mmc1: sdhci_tegra_probe line=5737 runtime pm type=mmc rtpm coupled with clock gate, disable-clock-gate=0
[ 4.385334] sdhci-tegra sdhci-tegra.1: Parent select= pll_p rate=408000000
[ 4.393821] Could not add sdhci-tegra.1 to power domain using device tree
[ 4.402843] sdhci-tegra sdhci-tegra.1: Speedo value 1965
[ 4.409931] sdhci-tegra sdhci-tegra.1: Tuning constraints: nom_mv 1075, boot_mv 1075, min_or_mv 0
[ 4.425985] regulator_get() failed for (sdhci-tegra.1,vqmmc), -19
[ 4.433756] mmc1: no vqmmc regulator found
[ 4.439498] regulator_get() failed for (sdhci-tegra.1,vmmc), -19
[ 4.447207] mmc1: no vmmc regulator found
[ 4.485715] mmc0: BKOPS_EN bit is not set
[ 4.491345] mmc1: SDHCI controller on sdhci-tegra.1 [sdhci-tegra.1] using ADMA
[ 4.503839] mmc2: sdhci_tegra_probe line=5737 runtime pm type=mmc rtpm coupled with clock gate, disable-clock-gate=0
[ 4.517697] sdhci-tegra sdhci-tegra.0: Parent select= pll_p rate=408000000
[ 4.526538] Could not add sdhci-tegra.0 to power domain using device tree
[ 4.535084] usb 2-1: new SuperSpeed USB device number 2 using tegra-xhci
[ 4.535609] sdhci-tegra sdhci-tegra.0: Speedo value 1965
[ 4.535616] sdhci-tegra sdhci-tegra.0: Tuning constraints: nom_mv 1075, boot_mv 1075, min_or_mv 0
[ 4.535686] regulator_get() failed for (sdhci-tegra.0,vqmmc), -19
[ 4.535688] mmc2: no vqmmc regulator found
[ 4.535695] regulator_get() failed for (sdhci-tegra.0,vmmc), -19
[ 4.535697] mmc2: no vmmc regulator found
[ 4.571816] mmc2: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA
[ 4.571927] gpio wake35 for gpio=201
[ 4.584216] tegra-se tegra21-se: tegra_se_probe: complete
[ 4.584796] hidraw: raw HID events driver (C) Jiri Kosina
[ 4.619992] usbcore: registered new interface driver usbhid
[ 4.627117] usbhid: USB HID core driver
[ 4.632504] tegra_bootloader_debug: Created tegra_bootloader directory
[ 4.640600] tegra_bootloader_debug: Created sysfs interface tegra_bootloader_verify_regs in tegra_bootloader directory
[ 4.654351] tegra_bootloader_debug: Created sysfs interface tegra_bootloader_prof in tegra_bootloader directory
[ 4.655537] usb 2-1: New USB device found, idVendor=0955, idProduct=09ff
[ 4.655542] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[ 4.655547] usb 2-1: Product: USB 10/100/1000 LAN
[ 4.655550] usb 2-1: Manufacturer: Nvidia
[ 4.655554] usb 2-1: SerialNumber: 000001000000
[ 4.673547] mmc0: tap value and tuning window after hw tuning completion …
[ 4.673553] mmc0: tuning_window[0]: 0xffffffff
[ 4.673557] mmc0: tuning_window[1]: 0xfffffc3f
[ 4.673561] mmc0: tuning_window[2]: 0xfff1ffff
[ 4.673565] mmc0: tuning_window[3]: 0x7ffffff
[ 4.673568] mmc0: tuning_window[4]: 0x0
[ 4.673572] mmc0: tuning_window[5]: 0x0
[ 4.673575] mmc0: tuning_window[6]: 0x0
[ 4.673578] mmc0: tuning_window[7]: 0x0
[ 4.673582] sdhci: Tap value: 61 | Trim value: 8
[ 4.673585] sdhci: SDMMC Interrupt status: 0x00040000
[ 4.674160] mmc0: switch to HS400 mode is successful
[ 4.678027] mmc0: new HS400 MMC card at address 0001
[ 4.678417] mmcblk0: mmc0:0001 016G32 14.6 GiB
[ 4.678613] mmcblk0rpmb: mmc0:0001 016G32 partition 3 4.00 MiB
[ 4.789666] nvadsp 702ef000.adsp: in probe()…
[ 4.790531] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18
[ 4.805696] nvadsp 702ef000.adsp: AMC/ARAM initialized.
[ 4.812041] nvadsp 702ef000.adsp: nvadsp_app_module_probe
[ 4.820461] tegra_throttle : init passed
[ 4.821575] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 4.832761] cpu-tegra: init EDP limit: 1224 MHz
[ 4.838740] pll_x: not ready for dynamic ramp to 921600000
[ 4.845274] pll_x: not ready for dynamic ramp to 921600000
[ 4.856744] soctherm: prog thresholds
[ 4.861425] soctherm: prog thresholds
[ 4.866080] soctherm: tz:2 not found, skip thresh prog
[ 4.872264] soctherm: prog thresholds
[ 4.876989] soctherm: skipping sensor 4 programming
[ 4.882972] soctherm: skipping sensor 5 programming
[ 4.888948] soctherm: trip_point temp 127500 forced to 127000
[ 4.903898] usbcore: registered new interface driver snd-usb-audio
[ 4.914363] usb 2-1: reset SuperSpeed USB device number 2 using tegra-xhci
[ 5.021518] usb 1-3.3: new low-speed USB device number 4 using tegra-xhci
[ 5.026885] mmc1: tap value and tuning window after hw tuning completion …
[ 5.026891] mmc1: tuning_window[0]: 0xe3ffffff
[ 5.026895] mmc1: tuning_window[1]: 0x7fffffff
[ 5.026899] mmc1: tuning_window[2]: 0xfffffffe
[ 5.026903] mmc1: tuning_window[3]: 0x7fffffcf
[ 5.026907] mmc1: tuning_window[4]: 0x0
[ 5.026911] mmc1: tuning_window[5]: 0x0
[ 5.026914] mmc1: tuning_window[6]: 0x0
[ 5.026918] mmc1: tuning_window[7]: 0x0
[ 5.026921] sdhci: Tap value: 82 | Trim value: 8
[ 5.026924] sdhci: SDMMC Interrupt status: 0x00040000
[ 5.029548] r8152 2-1:1.0 eth0: v2.03.3 (2015/01/29)
[ 5.029554] r8152 2-1:1.0 eth0: This product is covered by one or more of the following patents:
US6,570,884, US6,115,776, and US6,327,625.
[ 5.032186] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 5.145700] usb 1-3.3: New USB device found, idVendor=0461, idProduct=4e54
[ 5.153736] usb 1-3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.163365] usb 1-3.3: Product: Tiger USB Optical Mouse
[ 5.169807] usb 1-3.3: Manufacturer: PixArt
[ 5.175444] usb 1-3.3: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 5.189286] input: PixArt Tiger USB Optical Mouse as /devices/platform/tegra-xhci/usb1/1-3/1-3.3/1-3.3:1.0/input/input0
[ 5.202827] hid-generic 0003:0461:4E54.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt Tiger USB Optical Mouse] on usb-tegra-xhci-3.3/input0
[ 5.265560] tegra-i2c 7000c000.i2c: arb lost in communicate to add 0x1b
[ 5.273752] tegra-i2c 7000c000.i2c: Un-recovered Arbitration lost
[ 5.281425] tegra-i2c 7000c000.i2c: arb lost in communicate to add 0x1b
[ 5.289652] tegra-i2c 7000c000.i2c: Un-recovered Arbitration lost
[ 5.297412] tegra-i2c 7000c000.i2c: arb lost in communicate to add 0x1b
[ 5.305719] usb 1-3.4: new low-speed USB device number 5 using tegra-xhci
[ 5.305787] tegra-i2c 7000c000.i2c: Un-recovered Arbitration lost
[ 5.305843] tegra-i2c 7000c000.i2c: arb lost in communicate to add 0x1b
[ 5.305921] tegra-i2c 7000c000.i2c: Un-recovered Arbitration lost
[ 5.305948] rt5659 0-001b: Device with ID register fdc93400 is not rt5659
[ 5.315040] tegra210-i2s tegra210-i2s.0: Missing prop fsync-width for I2S0
[ 5.315744] tegra210-i2s tegra210-i2s.2: Missing prop fsync-width for I2S2
[ 5.315931] tegra210-i2s tegra210-i2s.3: Missing prop fsync-width for I2S3
[ 5.316181] tegra210-i2s tegra210-i2s.4: Missing prop fsync-width for I2S4
[ 5.320727] OPE platform probe
[ 5.320894] OPE platform probe successful
[ 5.320928] OPE platform probe
[ 5.321107] OPE platform probe successful
[ 5.321343] tegra210_adsp_audio_platform_probe: platform probe started
[ 5.322619] tegra210-adsp adsp_audio.3: Default param-type to BYTE for mp3-dec1
[ 5.322872] tegra210-adsp adsp_audio.3: Default param-type to BYTE for spkprot
[ 5.323212] tegra210-adsp adsp_audio.3: Default param-type to BYTE for src
[ 5.323486] tegra210-adsp adsp_audio.3: Default param-type to BYTE for aac-dec1
[ 5.323836] tegra210-adsp adsp_audio.3: Default param-type to BYTE for aec
[ 5.325198] tegra210_adsp_audio_platform_probe probe successfull.
[ 5.325198] tegra-snd-t210ref-mobile-rt565x sound.27: Failed to get HP Det GPIO,should be handled by codec
[ 5.386737] tegra210-ape-admaif tegra210-admaif: ASoC: Failed to create codec debugfs directory
[ 5.388184] tegra210-adsp adsp_audio.3: ASoC: Failed to create platform debugfs directory
[ 5.420212] tegra-snd-t210ref-mobile-rt565x sound.27: ADMAIF1 <-> ADMAIF1 mapping ok
[ 5.421413] tegra-snd-t210ref-mobile-rt565x sound.27: ADMAIF2 <-> ADMAIF2 mapping ok
[ 5.422536] tegra-snd-t210ref-mobile-rt565x sound.27: ADMAIF3 <-> ADMAIF3 mapping ok
[ 5.423645] tegra-snd-t210ref-mobile-rt565x sound.27: ADMAIF4 <-> ADMAIF4 mapping ok
[ 5.424758] tegra-snd-t210ref-mobile-rt565x sound.27: ADMAIF5 <-> ADMAIF5 mapping ok
[ 5.425877] tegra-snd-t210ref-mobile-rt565x sound.27: ADMAIF6 <-> ADMAIF6 mapping ok
[ 5.427001] tegra-snd-t210ref-mobile-rt565x sound.27: ADMAIF7 <-> ADMAIF7 mapping ok
[ 5.428119] tegra-snd-t210ref-mobile-rt565x sound.27: ADMAIF8 <-> ADMAIF8 mapping ok
[ 5.429244] tegra-snd-t210ref-mobile-rt565x sound.27: ADMAIF9 <-> ADMAIF9 mapping ok
[ 5.430356] tegra-snd-t210ref-mobile-rt565x sound.27: ADMAIF10 <-> ADMAIF10 mapping ok
[ 5.481789] tegra-snd-t210ref-mobile-rt565x sound.27: ADSP-FE1 <-> ADSP PCM1 mapping ok
[ 5.482233] tegra-snd-t210ref-mobile-rt565x sound.27: ADSP-FE2 <-> ADSP PCM2 mapping ok
[ 5.482556] compress asoc: ADSP-FE3 <-> ADSP COMPR1 mapping ok
[ 5.482891] compress asoc: ADSP-FE4 <-> ADSP COMPR2 mapping ok
[ 5.493200] tegra-snd-t210ref-mobile-rt565x sound.27: ASoC: no source widget found for x HPO L Playback
[ 5.493207] tegra-snd-t210ref-mobile-rt565x sound.27: ASoC: Failed to add route x HPO L Playback → direct → x Headphone Jack
[ 5.493235] tegra-snd-t210ref-mobile-rt565x sound.27: ASoC: no source widget found for x HPO R Playback
[ 5.493239] tegra-snd-t210ref-mobile-rt565x sound.27: ASoC: Failed to add route x HPO R Playback → direct → x Headphone Jack
[ 5.493267] tegra-snd-t210ref-mobile-rt565x sound.27: ASoC: no sink widget found for x MICBIAS1
[ 5.493271] tegra-snd-t210ref-mobile-rt565x sound.27: ASoC: Failed to add route x Mic Jack → direct → x MICBIAS1
[ 5.493298] tegra-snd-t210ref-mobile-rt565x sound.27: ASoC: no sink widget found for x IN1P
[ 5.493302] tegra-snd-t210ref-mobile-rt565x sound.27: ASoC: Failed to add route x Mic Jack → direct → x IN1P
[ 5.493329] tegra-snd-t210ref-mobile-rt565x sound.27: ASoC: no sink widget found for x Mic Det Power
[ 5.493334] tegra-snd-t210ref-mobile-rt565x sound.27: ASoC: Failed to add route x Mic Jack → direct → x Mic Det Power
[ 5.493361] tegra-snd-t210ref-mobile-rt565x sound.27: ASoC: no source widget found for x SPO Playback
[ 5.493366] tegra-snd-t210ref-mobile-rt565x sound.27: ASoC: Failed to add route x SPO Playback → direct → x Int Spk
[ 5.493393] tegra-snd-t210ref-mobile-rt565x sound.27: ASoC: no sink widget found for x DMIC L1
[ 5.493397] tegra-snd-t210ref-mobile-rt565x sound.27: ASoC: Failed to add route x Int Mic → direct → x DMIC L1
[ 5.493424] tegra-snd-t210ref-mobile-rt565x sound.27: ASoC: no sink widget found for x DMIC L2
[ 5.493428] tegra-snd-t210ref-mobile-rt565x sound.27: ASoC: Failed to add route x Int Mic → direct → x DMIC L2
[ 5.493454] tegra-snd-t210ref-mobile-rt565x sound.27: ASoC: no sink widget found for x DMIC R1
[ 5.493458] tegra-snd-t210ref-mobile-rt565x sound.27: ASoC: Failed to add route x Int Mic → direct → x DMIC R1
[ 5.493485] tegra-snd-t210ref-mobile-rt565x sound.27: ASoC: no sink widget found for x DMIC R2
[ 5.493489] tegra-snd-t210ref-mobile-rt565x sound.27: ASoC: Failed to add route x Int Mic → direct → x DMIC R2
[ 5.499569] input: tegra-snd-t210ref-mobile-rt565x Headphone Jack as /devices/platform/sound.27/sound/card1/input1
[ 5.502524] tegra-snd-t210ref-mobile-rt565x sound.27: codec-dai “dit-hifi” registered
[ 5.502529] tegra-snd-t210ref-mobile-rt565x sound.27: This is a dummy codec
[ 5.966800] GACT probability NOT on
[ 5.972484] Mirror/redirect action on
[ 5.978224] u32 classifier
[ 5.982949] Actions configured
[ 5.988307] Netfilter messages via NETLINK v0.30.
[ 5.995039] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 6.003354] ctnetlink v0.93: registering with nfnetlink.
[ 6.010763] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 6.019688] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 6.027727] xt_time: kernel timezone is -0000
[ 6.034071] ipip: IPv4 over IPv4 tunneling driver
[ 6.040630] usb 1-3.4: New USB device found, idVendor=413c, idProduct=2107
[ 6.040996] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 6.041144] arp_tables: (C) 2002 David S. Miller
[ 6.041194] TCP: cubic registered
[ 6.041198] Initializing XFRM netlink socket
[ 6.073701] usb 1-3.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.084275] usb 1-3.4: Product: Dell USB Entry Keyboard
[ 6.091119] usb 1-3.4: Manufacturer: Dell
[ 6.096688] NET: Registered protocol family 10
[ 6.096977] usb 1-3.4: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 6.115390] mip6: Mobile IPv6
[ 6.119865] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 6.126890] sit: IPv6 over IPv4 tunneling driver
[ 6.127383] input: Dell Dell USB Entry Keyboard as /devices/platform/tegra-xhci/usb1/1-3/1-3.4/1-3.4:1.0/input/input2
[ 6.127621] hid-generic 0003:413C:2107.0002: input,hidraw1: USB HID v1.10 Keyboard [Dell Dell USB Entry Keyboard] on usb-tegra-xhci-3.4/input0
[ 6.163344] NET: Registered protocol family 17
[ 6.169438] NET: Registered protocol family 15
[ 6.175513] Bridge firewalling registered
[ 6.181061] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 6.188585] Bluetooth: HIDP socket layer initialized
[ 6.195132] NET: Registered protocol family 35
[ 6.201166] Key type dns_resolver registered
[ 6.206957] NET: Registered protocol family 41
[ 6.214635] Registering SWP/SWPB emulation handler
[ 6.244302] isp isp.0: initialized
[ 6.250543] isp isp.1: initialized
[ 6.255712] vdd_gpu: disabling
[ 6.260127] en-vdd-cam-1v2-alt: disabling
[ 6.265527] en-vdd-vcm-2v8: disabling
[ 6.270523] en-vdd-cam-1v2: disabling
[ 6.275500] usb-vbus3: disabling
[ 6.279983] usb-vbus1: disabling
[ 6.284414] vdd-disp-3v0: disabling
[ 6.289078] snsr_pm: disabling
[ 6.293293] aux-3v3: disabling
[ 6.297454] en-vdd-cam: disabling
[ 6.301858] en-vdd-sd: disabling
[ 6.310962] lcd-bl-en: disabling
[ 6.315133] max77620-gpio7: disabling
[ 6.331251] vdd-cpu-fixed: disabling
[ 6.335670] regulator-dummy: disabling
[ 6.340595] platform 7.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 6.350875] platform d.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 6.361101] platform c9.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 6.371549] platform ca.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 6.382143] platform cb.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 6.392985] platform cc.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 6.404034] platform cd.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 6.415319] reg-fixed-sync-voltage ce.regulator: Consumer c0 does not have device name
[ 6.426545] platform ce.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 6.438312] [OV5693]: probing v4l2 sensor.
[ 6.444415] ov5693 6-0036: camera_common_regulator_get vana ERR: fffffffffffffdfb
[ 6.455829] i2c 6-0036: Driver ov5693 requests probe deferral
[ 6.464355] gpio wake24 for gpio=189
[ 6.470008] gpio wake27 for gpio=192
[ 6.475621] gpio wake25 for gpio=190
[ 6.481287] input: gpio-keys as /devices/platform/gpio-keys.47/input/input3
[ 6.490490] platform 7.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 6.502527] platform d.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 6.514301] tegra-rtc 7000e000.rtc: setting system clock to 2017-07-11 12:39:00 UTC (1499776740)
[ 6.514513] platform c9.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 6.514710] platform ca.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 6.514906] platform cb.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 6.515097] platform cc.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 6.515291] platform cd.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 6.515460] reg-fixed-sync-voltage ce.regulator: Consumer c0 does not have device name
[ 6.515493] platform ce.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 6.515647] [OV5693]: probing v4l2 sensor.
[ 6.515800] ov5693 6-0036: camera_common_regulator_get vana ERR: fffffffffffffdfb
[ 6.515918] i2c 6-0036: Driver ov5693 requests probe deferral
[ 6.635213] vi vi: vi_probe: ++
[ 6.642476] vi vi: initialized
[ 6.647896] vi vi: parsing node /host1x/vi
[ 6.653971] vi vi: handling endpoint /host1x/vi/ports/port@0/endpoint
[ 6.662398] vi vi: handling endpoint /host1x/vi/ports/port@1/endpoint
[ 6.670726] vi vi: handling endpoint /host1x/vi/ports/port@2/endpoint
[ 6.679003] vi vi: handling endpoint /host1x/vi/ports/port@3/endpoint
[ 6.687188] vi vi: handling endpoint /host1x/vi/ports/port@4/endpoint
[ 6.695306] vi vi: handling endpoint /host1x/vi/ports/port@5/endpoint
[ 6.703332] vi vi: parsing node /host1x/i2c@546c0000/ov5693_c@36
[ 6.710860] vi vi: handling endpoint /host1x/i2c@546c0000/ov5693_c@36/ports/port@0/endpoint
[ 6.722523] platform 7.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 6.722981] [dram-timers] DRAM derating cdev registered.
[ 6.722989] Disable partitions left on by BL
[ 6.722992] sata
[ 6.723120] disb
[ 6.723143] Disabling clocks left on by bootloader:
[ 6.723144] audio2_dmic
[ 6.723148] audio1_dmic
[ 6.723151] audio0_dmic
[ 6.723154] audio_2x
[ 6.723159] audio
[ 6.723162] audio4
[ 6.723165] audio3
[ 6.723168] audio2
[ 6.723171] audio1
[ 6.723173] audio0
[ 6.723229] entropy
[ 6.723238] dsi2-fixed
[ 6.723240] dsi1-fixed
[ 6.723255] sdmmc4_ddr
[ 6.723263] sdmmc1_ddr
[ 6.723284] sor1_src
[ 6.723297] cclk_lp
[ 6.723913] tegra_cl_dvfs 70110000.dfll-ovr: DT data retrieved successfully
[ 6.724064] tune_cpu_trimmers: init soctherm cpu zone LOW
[ 6.724168] tegra_cl_dvfs_init_cdev: cpu_cold cooling device registered
[ 6.724235] tegra_cl_dvfs_init_cdev: cpu_hot cooling device registered
[ 6.724493] Tegra CPU DFLL is initialized with use_dfll = 1
[ 6.724612] tegra_dvfs: 0.vdd-cpu-rail-ovr connected to regulator
[ 6.724840] tegra_dvfs: 4.vdd-core-rail-max77620 connected to regulator
[ 6.724955] tegra_dvfs: 1.vdd-gpu-rail-ovr connected to regulator
[ 6.725430] CPU rate: 921 MHz
[ 6.725693] last reset is due to software reset
[ 6.725695] KERNEL: PMC reset status reg: 0x3
[ 6.726309] tegra_actmon.emc: Completed initialization (0)
[ 6.726683] tegra_actmon.avp: Completed initialization (0)
[ 6.888491] platform d.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 6.897986] platform c9.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 6.901569] tegra dvfs: tegra sysfs cap interface is initialized
[ 6.901622] tegra dvfs: tegra sysfs gpu & emc interface is initialized
[ 6.901891] Set maximum possible CPU frequency 1734000
[ 6.901927] ALSA device list:
[ 6.901929] #0: HDA NVIDIA Tegra at 0x70038000 irq 113
[ 6.901931] #1: tegra-snd-t210ref-mobile-rt565x
[ 6.943908] platform ca.regulator: Driver reg-fixed-sync-v
Normally I would have some saved logs to look at, but just lost my home partition and need to rebuild everything. Some errors are actually normal, but I did see a number of i2c arbitration errors. The DDC/EDID data uses i2c protocol, so possibly this is why your EDID file in “/sys” was unable to get monitor specifications. One thing I’d suggest is to just see if the monitor works with that same cable on another computer…or if the same monitor on same Jetson works with a new cable. Bottom line though is that without EDID responding there is no possibility of autoconfiguration to succeed (it is always possible the default video mode works, but that is just a matter of luck). Can someone see if the i2c arbitration errors are normal? If not, suspect it is from video EDID.
I don’t see error logs directly related to display controller in dmesg…
Do other display work or not?
No, I tried 3 displays that support HDMI.None of them doesn’t worked…
I finally recovered my home partition (still spending a lot of time rearranging things though). What I see in the Xorg.0.log worth noting:
[ 11.506] (--) NVIDIA(0): Valid display device(s) on GPU-0 at SoC
[ 11.507] (--) NVIDIA(0): DFP-0
[ 11.507] (II) NVIDIA(GPU-0): Found DRM driver drm-nvdc (0)
Normally there is a list of GPUs, monitors attached to GPUs, and then it goes on to the “Found DRM driver…”. In my case it lists my ViewSonic monitor right after the DFP-0. Yours does not see any monitors at all. This again points to missing DDC/EDID channel response. This also results in no data from “VideoBIOS” regarding HorizSync/VertRefresh.
DDC/EDID uses i2c communications. If i2c has something misconfigured in the device tree it is possible it is a software issue, but you’ve flashed, and unless there was something special about flash, then it won’t be an i2c configuration problem. Is anything customized, especially device tree?
If not a software issue, then I’d say you have a hardware failure. This could be in the cable itself, or a connector might have a bent/broken pin, or some sort of adapter on the cable could be a problem (e.g., anything 15-pin VGA D-sub is a guaranteed EDID failure). Since you tried multiple monitors, and those monitors work on other computers, I’d say it has to be something on the Jetson itself which failed (if you used the same cable or adapter though then it still leaves the cable/adapter as an issue). If you have different cables and no adapters in the HDMI, and if the original failing monitor works on another computer, then I’d say it is time to RMA.
Do closely check for bent or broken pins in the relevant connectors. Not all pins are always used, but a bent/broken pin will look different than one not factory installed.
What is the exact cable arrangement, along with any adapters? If you need RMA, see the top of this:
https://devtalk.nvidia.com/default/topic/793798/embedded-systems/some-jetson-web-links/
Hi linuxdev,
I use only HDMI cables, not any adapters. At first I used I used a D-sub adapter and it worked!. In the next morning display is not reponding. Then I flashed again and use an HDMI cable then it works. IN the next morning the same comedy repeates, display is not responding!!!. I think there is any problem with the hardware.
Could you give more description of how the problem hits?
Do you boot up with the display connected or hot-plug? Does any log added in dmesg when you plugged in a HDMI after bootup?
No I HDMI cable is always connected to the tx1 board. I don’t see any line is added in the dmesg when I plugged in aHDMI after bootup.
In one reply it is indicated that there is no EDID/DDC communications…the i2c fails:
[url]https://devtalk.nvidia.com/default/topic/1017176/jetson-tx1/hdmi-display-is-not-responding-when-jetson-tx1-boot-ups/post/5181653/#5181653[/url]
Without that it isn’t possible to auto configure, although hitting a working default mode would do the job…but it’s just luck when that happens unless you’ve manually set it to a working mode, or something with EDID which did work last set to a working mode which the newest monitor has available. This is why I think it is hardware failure. It is very common for EDID to give something the driver does not like, but it is very uncommon for EDID to fail when cables are HDMI.
Yadu,
If you don’t mind rebuilding the kernel, please try to set use_fallback = true in edid.c.
This would hack a 720p edid. If this could work, then i2c seems fail…
