After start, Tx1 will display a lot of command lines , then it will alway remain in the black screen display.
I just input the SD card into the board and found that issue. It seems that can not recover.
so what can I do next to solve the issue?
If you type Alt-Ctl-F1, do you see again the text console with the boot output lines and login prompt, or is it black ?
If you unplug the HDMI for a few seconds and replug it (if your monitor has several inputs, select again the input where your TX1 is connected), any difference ?
after ctrl alt f1,I could see the ubuntu:$ word disply
then how can i do to recover it
So you can log in, and run dmesg to look at messages and try to look for errors related to display controler (tegradc).
You may also look if X server is running, and if not try to start it with command xinit.
Look for errors in file /home/ubuntu/.xsession-errors.
replug is no useful,hdmi is active state with black screen
how to run dmseg
Type Alt-Ctl-F1 for going to first console.
Log in (username: ubuntu, password: ubuntu by default).
Once logged in, just type dmesg (+Enter) in the shell.
Note also that serial console will allow running those commands without caring about whether video works or not (and if networking works, ssh would also work…serial console though has many advantages when only bits and pieces of a system are accessible). If interested in serial console see:
[url]http://elinux.org/Jetson/TX1_Serial_Console[/url]
Hi, I have got the log. Could find the problem for me?
After inputing command in the serial console, I could enter background picture of ubuntu and see mouse but fail to see the account login picture.
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.10.67-g458d45c (buildbrain@mobile-u64-630) (gcc version 4.9 20140514 (prerelease) (GCC) ) #1 SMP PREEMPT Mon Feb 8 17:44:18 PST 2016
[ 0.000000] CPU: Cortex A57 Processor [411fd071] revision 1
[ 0.000000] alternative: enabling workaround for ARM erratum 832075
[ 0.000000] Machine: jetson_tx1
[ 0.000000] bootconsole [earlycon0] enabled
[ 0.000000] Tegra reserved memory:
[ 0.000000] LP0: ff2bf000 - ff2bffff
[ 0.000000] Bootloader framebuffer: 00000000 - 00000000
[ 0.000000] Bootloader framebuffer2: 00000000 - 00000000
[ 0.000000] Framebuffer: f6200000 - fa9fffff
[ 0.000000] 2nd Framebuffer: faa00000 - ff1fffff
[ 0.000000] Carveout: 00000000 - 00000000
[ 0.000000] Vpr: 00000000 - 0b9fffff
[ 0.000000] Tsec: 00000000 - 00000000
[ 0.000000] Bootloader Debug Data: 00000000 - 00000000
[ 0.000000] Nvdumper: ff23f000 - ff23ffff
[ 0.000000] cma: CMA: reserved 188 MiB at ea400000
[ 0.000000] cma: CMA: reserved 16 MiB at e9400000
[ 0.000000] On node 0 totalpages: 1007616
[ 0.000000] DMA32 zone: 6608 pages used for memmap
[ 0.000000] DMA32 zone: 0 pages reserved
[ 0.000000] DMA32 zone: 483328 pages, LIFO batch:31
[ 0.000000] Normal zone: 7168 pages used for memmap
[ 0.000000] Normal zone: 524288 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv0.2 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/arch/arm64/boot/dts/tegra210-jetson-tx1-p2597-2180-a01-devkit.dts
[ 0.000000] DTB Build time: Feb 8 2016 17:38:02
[ 0.000000] Tegra21: Speedo/IDDQ fuse revision 4
[ 0.000000] Tegra21: CPU Speedo ID 7, Soc Speedo ID 0, Gpu Speedo ID 2
[ 0.000000] Tegra21: CPU Process ID 0, Soc Process ID 1, Gpu Process ID 0
[ 0.000000] Tegra21: CPU Speedo value 2073, Soc Speedo value 1983, Gpu Speedo value 2094
[ 0.000000] Tegra21: CPU IDDQ 2300, Soc IDDQ 2700, Gpu IDDQ 3395
[ 0.000000] Tegra Revision: A02 SKU: 0x17 CPU Process: 0 Core Process: 1
[ 0.000000] tegra: PLLP fixed rate: 408000000
[ 0.000000] pll_u: boot with h/w control already set
[ 0.000000] pll_x boot misc1 0x0 : expected 0x20
[ 0.000000] (comparison mask = 0xffffff)
[ 0.000000] pll_c4 rates match 204000000 max sdmmc: vco=998400000 out0=998400000 out3=998400000
[ 0.000000] Lowering vic03 maximum rate from 1000000000 to 627200000
[ 0.000000] Lowering nvjpg maximum rate from 1000000000 to 627200000
[ 0.000000] Lowering se maximum rate from 1000000000 to 627200000
[ 0.000000] Lowering tsecb maximum rate from 1000000000 to 627200000
[ 0.000000] Lowering msenc maximum rate from 1000000000 to 716800000
[ 0.000000] Lowering nvdec maximum rate from 1000000000 to 716800000
[ 0.000000] Lowering vi maximum rate from 1000000000 to 793600000
[ 0.000000] Lowering isp maximum rate from 1000000000 to 793600000
[ 0.000000] Lowering adsp_bus maximum rate from 1200000000 to 844800000
[ 0.000000] Lowering sbus maximum rate from 600000000 to 408000000
[ 0.000000] Lowering host1x maximum rate from 600000000 to 408000000
[ 0.000000] Lowering pll_c maximum rate from 1200000000 to 1130000000
[ 0.000000] Lowering pll_c2 maximum rate from 1200000000 to 1130000000
[ 0.000000] Lowering pll_c3 maximum rate from 1200000000 to 1130000000
[ 0.000000] Lowering pll_d2 maximum rate from 1500000000 to 1130000000
[ 0.000000] Lowering pll_dp maximum rate from 1500000000 to 1130000000
[ 0.000000] Lowering sor0 maximum rate from 600000000 to 540000000
[ 0.000000] Lowering sor1 maximum rate from 600000000 to 594000000
[ 0.000000] Lowering dmic1 maximum rate from 12288000 to 12190000
[ 0.000000] Lowering dmic2 maximum rate from 12288000 to 12190000
[ 0.000000] Lowering dmic3 maximum rate from 12288000 to 12190000
[ 0.000000] Lowering hda maximum rate from 102000000 to 51000000
[ 0.000000] Lowering sdmmc2 maximum rate from 266000000 to 204000000
[ 0.000000] Lowering qspi maximum rate from 133000000 to 116600000
[ 0.000000] Lowering gbus maximum rate from 1300000000 to 998400000
[ 0.000000] Lowering cpu_g maximum rate from 3000000000 to 1734000000
[ 0.000000] Lowering cpu_lp maximum rate from 1350000000 to 1132800000
[ 0.000000] tegra dvfs: vdd_cpu: nominal 1226mV, offset 708000uV, step 19200uV, scaling enabled
[ 0.000000] tegra dvfs: vdd_core: nominal 1075mV, offset 0uV, step 12500uV, scaling enabled
[ 0.000000] tegra dvfs: vdd_gpu: nominal 1090mV, offset 710000uV, step 10000uV, scaling enabled
[ 0.000000] tegra_powergate_init: DONE
[ 0.000000] tegra21_plle_clk_enable: pll_e is already enabled
[ 0.000000] PERCPU: Embedded 13 pages/cpu @ffffffc03feb3000 s21504 r8192 d23552 u53248
[ 0.000000] pcpu-alloc: s21504 r8192 d23552 u53248 alloc=13*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 993840
[ 0.000000] Kernel command line: fbcon=map:0 console=tty0 console=ttyS0,115200n8 androidboot.modem=none androidboot.serialno=P2180A00P00940c003fd androidboot.security=non-secure tegraid=21.1.2.0.0 ddr_die=2048M@2048M ddr_die=2048M@4096M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 debug_uartport=lsport,0 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff2bf000 nvdumper_reserved=0xff23f000 core_edp_mv=1125 core_edp_ma=4000 gpt android.kerneltype=normal androidboot.touch_vendor_id=0 androidboot.touch_panel_id=63 androidboot.touch_feature=0 androidboot.bootreason=pmc:software_reset,pmic:0x0 root=/dev/mmcblk0p1 rw rootwait
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 1888MB 2048MB = 3936MB total
[ 0.000000] Memory: 3736844k/3736844k available, 293620k reserved
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vmalloc : 0xffffff8000000000 - 0xffffffbbffff0000 (245759 MB)
[ 0.000000] vmemmap : 0xffffffbc01c00000 - 0xffffffbc05400000 ( 56 MB)
[ 0.000000] modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc100000000 ( 4096 MB)
[ 0.000000] .init : 0xffffffc001084000 - 0xffffffc0010f0400 ( 433 kB)
[ 0.000000] .text : 0xffffffc000080000 - 0xffffffc0010831c4 ( 16397 kB)
[ 0.000000] .data : 0xffffffc001104000 - 0xffffffc0012b2c00 ( 1723 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[ 0.000000] NR_IRQS:960 nr_irqs:960 0
[ 0.000000] the number of interrupt controllers found is 6
[ 0.000000] Architected local timer running at 19.20MHz (phys).
[ 0.000000] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 3579139424256ns
[ 0.000000] Wake16 for irq=34
[ 0.000000] Enabling wake16
[ 0.000000] Console: colour dummy device 80x25
[ 0.000000] console [tty0] enabled
[ 0.016494] Calibrating delay loop (skipped), value calculated using timer frequency… lpj=192000
[ 0.025314] pid_max: default: 32768 minimum: 301
[ 0.030027] Security Framework initialized
[ 0.034046] Mount-cache hash table entries: 256
[ 0.087684] Initializing cgroup subsys debug
[ 0.089972] Initializing cgroup subsys freezer
[ 0.094643] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available
[ 0.140392] ftrace: Allocated trace_printk buffers
[ 0.201184] Brought up 4 CPUs
[ 0.202171] SMP: Total of 4 processors activated.
[ 0.206872] alternatives: patching kernel code
[ 0.215005] devtmpfs: initialized
[ 0.234004] pinctrl core: initialized pinctrl subsystem
[ 0.237655] regulator-dummy: ; Rail ON
[ 0.245606] Initializing plugin-manager
[ 0.247802] node /plugin-manager/p2180-1000-300@0 match with board 2180-1000-100
[ 0.255341] NET: Registered protocol family 16
[ 0.262530] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.268496] console [pstore-1] enabled
[ 0.271265] ramoops: attached 0x200000@0xf6000000, ecc: 0/0
[ 0.277268] I2C first dynamic bus number based on alias = 7
[ 0.282426] cpuidle: using governor ladder
[ 0.286396] cpuidle: using governor menu
[ 0.291104] PMC: Setting PMIC interrupt active-low
[ 0.295754] tegra-pmc device create success
[ 0.299313] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.306437] Clear bootloader IO dpd settings
[ 0.310678] PMC: configuring io pad defaults
[ 0.315178] PMC: IO pad audio voltage is 1800000
[ 0.319604] PMC: IO pad cam voltage is 1800000
[ 0.324036] PMC: IO pad dbg voltage is 1800000
[ 0.328444] PMC: IO pad dmic voltage is 1800000
[ 0.332963] PMC: IO pad pex-ctrl voltage is 1800000
[ 0.337804] PMC: IO pad spi voltage is 1800000
[ 0.342236] PMC: IO pad uart voltage is 1800000
[ 0.346730] PMC: IO pad bb voltage is 1800000
[ 0.351076] PMC: IO pad audio-hv voltage is 1800000
[ 0.355917] PMC: IO pad spi-hv voltage is 1800000
[ 0.360609] PMC: IO pad gpio voltage is 1800000
[ 0.365103] PMC: IO pad sdmmc3 voltage is 1800000
[ 0.369691] PMC: IO pad pex-bias power is disable
[ 0.374382] PMC: IO pad pex-clk1 power is disable
[ 0.379050] PMC: IO pad pex-clk2 power is disable
[ 0.383733] T210 pmc padctrl driver initialized
[ 0.388304] T210 pmc config for bootrom command passed
[ 0.394811] INFO: pinmux CLAMP_INPUTS_WHEN_TRISTATED: disabled
[ 0.401615] clk_init_from_dt_table: clocks are set from t210-clk-init-table:clkinit-0
[ 0.411464] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.415766] platform bpmp.15: domain=ffffffc0ff04d698 allocates as[0]=ffffffc0ff1040a8
[ 0.423662] platform bpmp.15: IOVA linear map 0x00000000ff2c0000(40000)
[ 0.430726] bpmp bpmp.15: bpmp_connect returned 0
[ 0.435719] MC mapped MMIO address: 0xffffff800003a000
[ 0.439892] MC0 mapped MMIO address: 0xffffff8000072000
[ 0.445117] MC1 mapped MMIO address: 0xffffff8000098000
[ 0.463671] tegra210-pinctrl 700008d4.pinmux: lookup the user state drive not found
[ 0.469458] tegra210-pinctrl 700008d4.pinmux: Probed Tegra pinctrl driver
[ 0.476840] GPIO chip tegra-gpio: created GPIO range 0->245 ==> 700008d4.pinmux PIN 0->245
[ 0.484413] tegra-gpio 6000d000.gpio: Initialising GPIO state 0: name wlan-default
[ 0.491983] gpiochip_add: registered GPIOs 0 to 255 on device: tegra-gpio
[ 0.502584] Wake44 for irq=81
[ 0.503612] Wake40 for irq=53
[ 0.506507] Wake41 for irq=53
[ 0.509454] Wake42 for irq=53
[ 0.512400] Wake43 for irq=53
[ 0.516084] platform 70006000.serial: domain=ffffffc0ff125298 allocates as[0]=ffffffc0ff104110
[ 0.525387] platform sound.18: domain=ffffffc0ff125518 allocates as[0]=ffffffc0ff104178
[ 0.535121] platform tegradc.1: domain=ffffffc0ff125918 allocates as[0]=ffffffc0ff1041e0
[ 0.545285] platform tegradc.1: IOVA linear map 0x00000000f6200000(4800000)
[ 0.554303] platform tegradc.1: IOVA linear map 0x00000000faa00000(4800000)
[ 0.559465] platform tegradc.1: IOVA linear map 0x00000000ea400000(bc00000)
[ 0.569090] platform gpu.0: domain=ffffffc0ff125a98 allocates as[0]=ffffffc0ff104248
[ 0.574924] platform gpu.0: domain=ffffffc0ff125a98 allocates as[1]=ffffffc0ff1042b0
[ 0.582633] platform gpu.0: domain=ffffffc0ff125a98 allocates as[2]=ffffffc0ff104318
[ 0.590345] platform gpu.0: domain=ffffffc0ff125a98 allocates as[3]=ffffffc0ff104380
[ 0.604194] platform sdhci-tegra.3: domain=ffffffc0ff192098 allocates as[0]=ffffffc0ff1043e8
[ 0.611336] platform sdhci-tegra.0: domain=ffffffc0ff192298 allocates as[0]=ffffffc0ff104450
[ 0.619469] Wake39 for irq=52
[ 0.634967] gpio wake52 for gpio=61
[ 0.636915] gpio wake8 for gpio=58
[ 0.639896] gpio wake8 for gpio=58
[ 0.645015] irq: no irq domain found for /soctherm@0x700E2000 !
[ 0.649367] irq: no irq domain found for /soctherm@0x700E2000 !
[ 0.655250] board_info: id:sku:fab:major:minor = 0x0884:0x03e8:0x00:0x00:0x00
[ 0.662158] PMC dt information non-NULL tegra_init_suspend
[ 0.675591] Loading EMC tables…
[ 0.677018] tegra: Using EMC sequence ‘21021’ for Rev. 7 tables
[ 0.682850] tegra: emc: Derated table is valid.
[ 0.687339] Lowering emc maximum rate from 1800000000 to 1600000000
[ 0.693589] tegra: validated EMC DFS table
[ 0.713554] swapper/0 isomgr_init(): iso emc max clk=1600000KHz
[ 0.717495] swapper/0 isomgr_init(): max_iso_bw=11520000KB
[ 1.999705] vdso: 2 pages (1 code, 1 data) at base ffffffc00110a000
[ 2.004048] vdso32: 2 pages (1 code, 1 data) at base ffffffc001109000
[ 2.010459] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 2.017347] nvdumper: last reboot was unknown
[ 2.021536] nvdumper: set_dirty_state 0x2badface
[ 2.026672] Tegra restart notifier registered.
[ 2.044822] bio: create slab at 0
[ 2.049175] vdd-ac-bat: 5000 mV ; Rail ON
[ 2.051542] vdd-cpu-fixed: 1000 mV ; Rail ON
[ 2.056473] vgaarb: loaded
[ 2.058577] SCSI subsystem initialized
[ 2.062073] libata version 3.00 loaded.
[ 2.062363] usbcore: registered new interface driver usbfs
[ 2.067382] usbcore: registered new interface driver hub
[ 2.072727] usbcore: registered new device driver usb
[ 2.078479] i2c i2c-0: of_i2c: modalias failure on /i2c@7000c000/icm20628@68
[ 2.084684] i2c i2c-0: of_i2c: modalias failure on /i2c@7000c000/ak8963@0d
[ 2.091523] i2c i2c-0: of_i2c: modalias failure on /i2c@7000c000/bmp280@77
[ 2.098355] i2c i2c-0: of_i2c: modalias failure on /i2c@7000c000/cm32180@48
[ 2.105301] i2c i2c-0: of_i2c: modalias failure on /i2c@7000c000/iqs263@44
[ 2.112210] gpio wake33 for gpio=188
[ 2.117183] regulator_get() failed for (1-0074,vcc), -19
[ 2.120999] pca953x 1-0074: no regulator found for vcc. Assuming vcc is always powered
[ 2.129614] gpio wake21 for gpio=89
[ 2.132579] gpiochip_add: registered GPIOs 1008 to 1023 on device: tca9539
[ 2.139576] regulator_get() failed for (1-0077,vcc), -19
[ 2.144490] pca953x 1-0077: no regulator found for vcc. Assuming vcc is always powered
[ 2.153101] gpio wake36 for gpio=202
[ 2.156088] gpiochip_add: registered GPIOs 992 to 1007 on device: tca9539
[ 2.163378] i2c i2c-3: of_i2c: modalias failure on /i2c@7000c700/prod-settings
[ 2.171155] max77620 4-003c: CID0: 0xad
[ 2.173762] max77620 4-003c: CID1: 0x16
[ 2.177571] max77620 4-003c: CID2: 0x21
[ 2.181406] max77620 4-003c: CID3: 0x59
[ 2.185197] max77620 4-003c: CID4: 0x35
[ 2.189010] max77620 4-003c: CID5: 0x80
[ 2.192850] max77620 4-003c: MAX77620 PMIC OTP Version is 0x35
[ 2.200291] max77620-pmic max77620-pmic: Consumer c2 does not have device name
[ 2.205862] max77620-pmic max77620-pmic: Consumer c0 does not have device name
[ 2.214088] vdd_core: 600 <–> 1400 mV at 1000 mV with ramp delay 27500 uV/us ; Rail ON
[ 2.221862] vddio-ddr: at 1125 mV with ramp delay 27500 uV/us ; Rail ON
[ 2.228174] vdd-pre-reg: 1350 mV with ramp delay 27500 uV/us ; Rail ON
[ 2.235205] vdd-1v8: 1800 mV with ramp delay 27500 uV/us ; Rail ON
[ 2.241008] avdd-sys: 1200 mV with ramp delay 100000 uV/us ; Rail ON
[ 2.246532] avdd-sys: supplied by vdd-pre-reg
[ 2.251595] vdd-pex: 1050 mV with ramp delay 100000 uV/us ; Rail ON
[ 2.257091] vdd-pex: supplied by vdd-pre-reg
[ 2.261864] vddio-sdmmc1: 1800 <–> 3300 mV at 3300 mV with ramp delay 100000 uV/us ; Rail ON
[ 2.270392] vdd-cam-hv: 2800 mV with ramp delay 100000 uV/us ; Rail OFF
[ 2.277096] vdd-rtc: 850 mV with ramp delay 100000 uV/us ; Rail ON
[ 2.283127] avdd-ts-hv: 3300 mV with ramp delay 100000 uV/us ; Rail OFF
[ 2.290397] vdd-ts: 1800 mV with ramp delay 100000 uV/us ; Rail OFF
[ 2.296182] vdd-gen-pll-edp: 1050 mV with ramp delay 100000 uV/us ; Rail ON
[ 2.302355] vdd-gen-pll-edp: supplied by vdd-pre-reg
[ 2.308016] vdd-hdmi-dp: 1050 mV with ramp delay 100000 uV/us ; Rail ON
[ 2.313885] vdd-hdmi-dp: supplied by vdd-pre-reg
[ 2.319038] max77620-gpio max77620-gpio.0: Initialising GPIO state 1: name gpio_default
[ 2.326508] gpiochip_add: registered GPIOs 984 to 991 on device: max77620-gpio
[ 2.334829] max77620-gpio max77620-gpio.0: max77620 gpio successfully initialized
[ 2.345002] max77620 4-003c: max77620 probe successfully
[ 2.349180] Linux video capture interface: v2.00
[ 2.352987] pps_core: LinuxPPS API ver. 1 registered
[ 2.357860] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 2.367001] PTP clock support registered
[ 2.372999] Advanced Linux Sound Architecture Driver Initialized.
[ 2.377611] Bluetooth: Core ver 2.16
[ 2.380720] NET: Registered protocol family 31
[ 2.385076] Bluetooth: HCI device and connection manager initialized
[ 2.391430] Bluetooth: HCI socket layer initialized
[ 2.396265] Bluetooth: L2CAP socket layer initialized
[ 2.401329] Bluetooth: SCO socket layer initialized
[ 2.407712] vdd-3v3: 3300 mV ; Rail ON
[ 2.411352] max77620-gpio7: 1050 mV ; Rail ON
[ 2.414253] max77620-gpio7: supplied by vdd-gen-pll-edp
[ 2.419789] lcd-bl-en: 1800 mV ; Rail ON
[ 2.423660] en-vdd-sd: 3300 mV ; Rail OFF
[ 2.427337] en-vdd-sd: supplied by vdd-3v3
[ 2.431602] reg-fixed-sync-voltage 5.regulator: Consumer c1 does not have device name
[ 2.439632] en-vdd-cam: 1800 mV ; Rail OFF
[ 2.443293] en-vdd-cam: supplied by vdd-1v8
[ 2.454350] vdd-sys-boost: 5000 mV ; Rail ON
[ 2.457309] vdd-hdmi: 5000 mV ; Rail OFF
[ 2.460602] vdd-hdmi: supplied by vdd-3v3
[ 2.464865] aux-3v3: 3300 mV ; Rail ON
[ 2.468530] snsr_pm: 3300 mV ; Rail ON
[ 2.472770] vdd-disp-3v0: 3000 mV ; Rail ON
[ 2.476768] vdd-fan: 5000 mV ; Rail OFF
[ 2.480303] usb-vbus1: 5000 mV ; Rail OFF
[ 2.483983] usb-vbus1: supplied by vdd-3v3
[ 2.488370] usb-vbus3: 5000 mV ; Rail OFF
[ 2.492060] usb-vbus3: supplied by vdd-3v3
[ 2.496749] en-vdd-ts-1v8: 1800 mV ; Rail OFF
[ 2.501080] en-vdd-ts-hv-3v3: 3300 mV ; Rail OFF
[ 2.505773] en-vdd-disp-3v3: 3300 mV ; Rail ON
[ 2.510040] en-mdm-pwr-3v7: ; Rail OFF
[ 2.513928] en-vdd-disp-1v8: 1800 mV ; Rail ON
[ 2.518182] en-vdd-cam-hv-2v8: ; Rail OFF
[ 2.521881] rtl-5v0: ; Rail OFF
[ 2.525001] en-usb-vbus2: ; Rail OFF
[ 2.528855] en-vdd-cam-1v2: ; Rail OFF
[ 2.532957] regulator-pwm 0.pwm-regulator: PWM request deferred
[ 2.537860] platform 0.pwm-regulator: Driver regulator-pwm requests probe deferral
[ 2.546084] vdd_gpu: applied init 1000000uV constraint
[ 2.550520] vdd_gpu: 710 <–> 1320 mV at 1000 mV ; Rail OFF
[ 2.557942] vdd_cpu: applied init 1000000uV constraint
[ 2.561180] vdd_cpu: 708 <–> 1322 mV at 1000 mV normal ; Rail ON
[ 2.570202] gpio wake34 for gpio=200
[ 2.573488] extcon-gpio-states 1.extcon: Cable state 0
[ 2.579176] Switching to clocksource arch_sys_counter
[ 2.617303] No Device Node present for smmu client: tegra-carveouts !!
[ 2.621868] No Device Node present for smmu client: tegra-carveouts !!
[ 2.628544] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 2.635361] No Device Node present for smmu client: tegra-carveouts !!
[ 2.641374] dma_declare_coherent_resizable_cma_memory:278: resizable heap=vpr, base=0x0x00000000ea400000, size=0xbc00000
[ 2.652217] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (6) rem_chunk_size(0x1c00000)
[ 2.662985] cma: enabled page replacement for spfn=ea400, epfn=f6000
[ 2.669084] dma_declare_coherent_resizable_cma_memory:325: resizable cma heap=vpr create successful
[ 2.677945] nvmap_page_pool_init: Total RAM pages: 986435
[ 2.683481] nvmap_page_pool_init: nvmap page pool size: 123304 pages (481 MB)
[ 2.690656] nvmap_background_zero_thread: PP zeroing thread starting.
[ 2.690917] misc nvmap: iram :dma coherent mem declare 0x0000000040001000,258048
[ 2.691598] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 2.692087] misc nvmap: created heap vpr base 0x00000000ea400000 size (192512KiB)
[ 2.692578] nvmap:inner cache maint threshold=2097152
[ 2.692578] No Device Node present for smmu client: tegra-carveouts !!
[ 2.703250] Wake39 for irq=52
[ 2.703370] tegra-otg tegra-otg: otg transceiver registered
[ 2.703980] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 2.705242] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 2.705647] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 2.705861] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 2.706040] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 2.707278] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 2.707547] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tboard_tegra
[ 2.708672] tegra21_plle_clk_enable: pll_e hw sequencer is already on
[ 2.708696] t210_sata_uphy_pll_init: init sata uphy pll
[ 2.708711] t210_sata_uphy_pll_init SATA uses SATA Lane
[ 2.709043] tegra_xusb_padctl_phy_enable: pex uphy already enabled
[ 2.710688] tegra210-pmc-iopower pmc-iopower.20: Rail iopower-sys is having fixed voltage 1800000
[ 2.710797] tegra210-pmc-iopower pmc-iopower.20: Rail iopower-uart is having fixed voltage 1800000
[ 2.710902] tegra210-pmc-iopower pmc-iopower.20: Rail iopower-audio is having fixed voltage 1800000
[ 2.711012] tegra210-pmc-iopower pmc-iopower.20: Rail iopower-cam is having fixed voltage 1800000
[ 2.711135] tegra210-pmc-iopower pmc-iopower.20: Rail iopower-pex-ctrl is having fixed voltage 1800000
[ 2.711244] tegra210-pmc-iopower pmc-iopower.20: Rail iopower-sdmmc1 is having voltages: 1800000:3300000
[ 2.711354] tegra210-pmc-iopower pmc-iopower.20: Rail iopower-sdmmc3 is having fixed voltage 1800000
[ 2.711460] tegra210-pmc-iopower pmc-iopower.20: Rail iopower-sdmmc4 is having fixed voltage 1800000
[ 2.711568] tegra210-pmc-iopower pmc-iopower.20: Rail iopower-audio-hv is having fixed voltage 1800000
[ 2.711672] tegra210-pmc-iopower pmc-iopower.20: Rail iopower-debug is having fixed voltage 1800000
[ 2.711793] tegra210-pmc-iopower pmc-iopower.20: Rail iopower-dmic is having fixed voltage 1800000
[ 2.711899] tegra210-pmc-iopower pmc-iopower.20: Rail iopower-gpio is having fixed voltage 1800000
[ 2.712013] tegra210-pmc-iopower pmc-iopower.20: Rail iopower-spi is having fixed voltage 1800000
[ 2.712119] tegra210-pmc-iopower pmc-iopower.20: Rail iopower-spi-hv is having fixed voltage 1800000
[ 2.712224] tegra210-pmc-iopower pmc-iopower.20: Rail iopower-sdmmc2 is having fixed voltage 1800000
[ 2.712370] tegra210-pmc-iopower pmc-iopower.20: Rail iopower-dp is having fixed voltage 1800000
[ 2.712378] tegra210-pmc-iopower pmc-iopower.20: NO_IO_POWER setting 0x0
[ 2.712735] NET: Registered protocol family 2
[ 2.713566] TCP established hash table entries: 32768 (order: 7, 524288 bytes)
[ 2.713819] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 2.714074] TCP: Hash tables configured (established 32768 bind 32768)
[ 2.714177] TCP: reno registered
[ 2.714187] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 2.714230] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 2.714603] NET: Registered protocol family 1
[ 2.715028] RPC: Registered named UNIX socket transport module.
[ 2.715032] RPC: Registered udp transport module.
[ 2.715035] RPC: Registered tcp transport module.
[ 2.715038] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 2.715049] PCI: CLS 0 bytes, default 64
[ 2.715533] tegra-fuse tegra-fuse: Fuse driver initialized succesfully
[ 2.722870] host1x host1x: initialized
[ 2.735315] NTFS driver 2.1.30 [Flags: R/O].
[ 2.735605] fuse init (API version 7.22)
[ 2.736052] msgmni has been set to 7706
[ 2.737538] io scheduler noop registered (default)
[ 2.737770] Tegra cpuquiet initialized: disabled
[ 2.740432] tegra-pcie 1003000.pcie-controller: PCIE: Enable power rails
[ 2.741493] tegra-pcie 1003000.pcie-controller: probing port 0, using 4 lanes and lane map as 0x14
[ 2.743561] tegra-pcie 1003000.pcie-controller: probing port 1, using 1 lanes and lane map as 0x14
[ 3.146462] tegra-pcie 1003000.pcie-controller: link 0 down, retrying
[ 3.555549] tegra-pcie 1003000.pcie-controller: link 0 down, retrying
[ 3.965683] tegra-pcie 1003000.pcie-controller: link 0 down, retrying
[ 3.972159] tegra-pcie 1003000.pcie-controller: link 0 down, ignoring
[ 4.380010] tegra-pcie 1003000.pcie-controller: link 1 down, retrying
[ 4.790329] tegra-pcie 1003000.pcie-controller: link 1 down, retrying
[ 5.200223] tegra-pcie 1003000.pcie-controller: link 1 down, retrying
[ 5.206723] tegra-pcie 1003000.pcie-controller: link 1 down, ignoring
[ 5.211179] tegra-pcie 1003000.pcie-controller: PCIE: no ports detected
[ 5.218089] tegra-pcie 1003000.pcie-controller: PCIE: Disable power rails
[ 5.227189] tsec tsec: initialized
[ 5.229940] tsec tsecb: initialized
[ 5.234510] nvdec nvdec: initialized
[ 5.239587] falcon vic03: initialized
[ 5.243036] falcon msenc: initialized
[ 5.246414] falcon nvjpg: initialized
[ 5.250141] tegradc tegradc.1: Display dc.54240000 registered with id=0
[ 5.255305] display board info: id 0x0, fab 0x0
[ 5.260154] panel_select fail by _node_status
[ 5.264066] display board info: id 0x0, fab 0x0
[ 5.268777] panel_select fail by _node_status
[ 5.272836] parse_tmds_config: No tmds-config node
[ 5.277724] of_dc_parse_platform_data: could not find vrr-settings node
[ 5.284187] of_dc_parse_platform_data: could not find SD settings node
[ 5.290669] of_dc_parse_platform_data: could not find cmu node
[ 5.296604] of_dc_parse_platform_data: could not find cmu node for adobeRGB
[ 5.303442] tegradc tegradc.1: DT parsed successfully
[ 5.309639] display board info: id 0x0, fab 0x0
[ 5.313285] panel_select fail by _node_status
[ 5.317644] gpio wake53 for gpio=225
[ 5.322460] tegradc tegradc.1: probed
[ 5.328518] Console: switching to colour frame buffer device 80x30
[ 5.337343] tegradc tegradc.1: fb registered
[ 5.342676] tegra_camera_platform tegra-camera-platform.37: tegra_camera_probe:camera_platform_driver probe
[ 5.357961] tegra-apbdma tegra-apbdma: Tegra20 APB DMA driver register 32 channels
[ 5.368966] tegra-adma tegra210-adma: Tegra210 ADMA driver register 10 channels
[ 5.378313] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 5.384715] No Device Node present for smmu client: serial8250 !!
[ 5.390744] No Device Node present for smmu client: serial8250 !!
[ 5.397894] No Device Node present for smmu client: serial8250 !!
[ 5.403825] No Device Node present for smmu client: serial8250 !!
[ 5.410254] of_serial 70006000.serial: RX periodic polling enabled
[ 5.416561] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 68) is a Tegra
[ 5.423396] console [ttyS0] enabled, bootconsole disabled
[ 5.433434] tegradc tegradc.1: hdmi: spurious interrupt
[ 5.445150] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 69) is a SERIAL_TEGRA
[ 5.457106] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 78) is a SERIAL_TEGRA
[ 5.469179] serial-tegra 70006300.serial: RX in PIO mode
[ 5.476612] 70006300.serial: ttyTHS3 at MMIO 0x70006300 (irq = 122) is a SERIAL_TEGRA
[ 5.516275] brd: module loaded
[ 5.525213] loop: module loaded
[ 5.530937] zram: Created 1 device(s) …
[ 5.537087] nct1008_nct72 0-004c: find device tree node, parsing dt
[ 5.545409] nct1008_nct72 0-004c: starting parse dt
[ 5.552370] nct1008_nct72 0-004c: success parsing dt
[ 5.559383] nct1008_nct72 0-004c: success in enabling rail vdd_nct72
[ 5.634690] NCT72: Enabled overheat logging at 104.00C
[ 5.641769] gpio wake33 for gpio=188
[ 5.647248] nct1008_nct72 0-004c: nct1008_probe: initialized
[ 5.658251] THERMAL EST start of therm_fan_est_probe.
[ 5.665224] THERMAL EST: found 2 subdevs
[ 5.671005] THERMAL EST name: thermal-fan-est.
[ 5.677357] THERMAL EST num_resources: 0
[ 5.683141] [THERMAL EST subdev 0]
[ 5.688330] THERMAL EST subdev name: CPU-therm
[ 5.694550] THERMAL EST index 0 coeffs 50
[ 5.700282] THERMAL EST index 1 coeffs 0
[ 5.705861] THERMAL EST index 2 coeffs 0
[ 5.711328] THERMAL EST index 3 coeffs 0
[ 5.716709] THERMAL EST index 4 coeffs 0
[ 5.721980] THERMAL EST index 5 coeffs 0
[ 5.727233] THERMAL EST index 6 coeffs 0
[ 5.732366] THERMAL EST index 7 coeffs 0
[ 5.737385] THERMAL EST index 8 coeffs 0
[ 5.742380] THERMAL EST index 9 coeffs 0
[ 5.747336] [THERMAL EST subdev 1]
[ 5.751762] THERMAL EST subdev name: GPU-therm
[ 5.757235] THERMAL EST index 0 coeffs 50
[ 5.762237] THERMAL EST index 1 coeffs 0
[ 5.767146] THERMAL EST index 2 coeffs 0
[ 5.772006] THERMAL EST index 3 coeffs 0
[ 5.776801] THERMAL EST index 4 coeffs 0
[ 5.781526] THERMAL EST index 5 coeffs 0
[ 5.786200] THERMAL EST index 6 coeffs 0
[ 5.790795] THERMAL EST index 7 coeffs 0
[ 5.795362] THERMAL EST index 8 coeffs 0
[ 5.799886] THERMAL EST index 9 coeffs 0
[ 5.804404] THERMAL EST index 0: trip_temp 0, hyst 0
[ 5.809952] THERMAL EST index 1: trip_temp 51000, hyst 15000
[ 5.816197] THERMAL EST index 2: trip_temp 61000, hyst 9000
[ 5.822338] THERMAL EST index 3: trip_temp 71000, hyst 9000
[ 5.828460] THERMAL EST index 4: trip_temp 82000, hyst 10000
[ 5.834690] THERMAL EST index 5: trip_temp 140000, hyst 0
[ 5.840665] THERMAL EST index 6: trip_temp 150000, hyst 0
[ 5.846658] THERMAL EST index 7: trip_temp 160000, hyst 0
[ 5.852649] THERMAL EST index 8: trip_temp 170000, hyst 0
[ 5.858630] THERMAL EST index 9: trip_temp 180000, hyst 0
[ 5.864624] THERMAL EST index 0: trip_temps_hyst 0
[ 5.870010] THERMAL EST index 1: trip_temps_hyst 36000
[ 5.875772] THERMAL EST index 2: trip_temps_hyst 51000
[ 5.881487] THERMAL EST index 3: trip_temps_hyst 52000
[ 5.887173] THERMAL EST index 4: trip_temps_hyst 61000
[ 5.892835] THERMAL EST index 5: trip_temps_hyst 62000
[ 5.898484] THERMAL EST index 6: trip_temps_hyst 71000
[ 5.904150] THERMAL EST index 7: trip_temps_hyst 72000
[ 5.909808] THERMAL EST index 8: trip_temps_hyst 82000
[ 5.915480] THERMAL EST index 9: trip_temps_hyst 140000
[ 5.921236] THERMAL EST index 10: trip_temps_hyst 140000
[ 5.927154] THERMAL EST index 11: trip_temps_hyst 150000
[ 5.933048] THERMAL EST index 12: trip_temps_hyst 150000
[ 5.938925] THERMAL EST index 13: trip_temps_hyst 160000
[ 5.944819] THERMAL EST index 14: trip_temps_hyst 160000
[ 5.950669] THERMAL EST index 15: trip_temps_hyst 170000
[ 5.956510] THERMAL EST index 16: trip_temps_hyst 170000
[ 5.962343] THERMAL EST index 17: trip_temps_hyst 180000
[ 5.968161] THERMAL EST index 18: trip_temps_hyst 180000
[ 5.973984] THERMAL EST index 19: trip_temps_hyst 0
[ 5.979344] THERMAL EST index 20: trip_temps_hyst 0
[ 5.984722] THERMAL EST init dev[0] temp hist to 25000
[ 5.990381] THERMAL EST init dev[1] temp hist to 25000
[ 5.996052] THERMAL EST cdev_type: pwm-fan.
[ 6.000780] THERMAL EST governor name: pid_thermal_gov
[ 6.006873] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est.38
[ 6.017495] THERMAL EST: thz register success.
[ 6.022890] THERMAL EST: end of probe, return err: 0
[ 6.028809] tegra_profiler: Branch: Dev
[ 6.033535] tegra_profiler: Version: 1.104
[ 6.038520] tegra_profiler: Samples version: 34
[ 6.044008] tegra_profiler: IO version: 18
[ 6.049041] armv8_pmu: imp: 0x41, idcode: 0x1
[ 6.054383] armv8_pmu: arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 6.062227] tegra_profiler: auth: init
[ 6.067646] GPS: mt3332_gps_mod_init: platform_driver_register ret = 0
[ 6.076013] tegra-sata tegra-sata.0: version 1.0
[ 6.076696] t210_sata_uphy_pll_init: sata uphy already enabled
[ 6.084510] tegra-sata tegra-sata.0: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl TEGRA-SATA mode
[ 6.096381] tegra-sata tegra-sata.0: flags: 64bit ncq sntf pm led pmp pio slum part sadm apst
[ 6.109638] Rounding down aligned max_sectors from 4294967295 to 4294967288
[ 6.118870] spi-tegra114 7000d400.spi: Static pin configuration used
[ 6.127739] spi-tegra114 7000da00.spi: Static pin configuration used
[ 6.137199] tun: Universal TUN/TAP device driver, 1.6
[ 6.144103] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 6.152460] e1000e: Intel(R) PRO/1000 Network Driver - 2.3.2-k
[ 6.160228] e1000e: Copyright(c) 1999 - 2013 Intel Corporation.
[ 6.169095] PPP generic driver version 2.4.2
[ 6.175466] PPP BSD Compression module registered
[ 6.182025] PPP Deflate Compression module registered
[ 6.188961] PPP MPPE Compression module registered
[ 6.195630] NET: Registered protocol family 24
[ 6.201988] usbcore: registered new interface driver r8152
[ 6.209478] usbcore: registered new interface driver asix
[ 6.216832] usbcore: registered new interface driver ax88179_178a
[ 6.224879] usbcore: registered new interface driver cdc_ether
[ 6.232654] usbcore: registered new interface driver smsc95xx
[ 6.240254] usbcore: registered new interface driver net1080
[ 6.247730] usbcore: registered new interface driver cdc_subset
[ 6.255390] usbcore: registered new interface driver zaurus
[ 6.262678] usbcore: registered new interface driver cdc_ncm
[ 6.269898] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 6.278509] ehci-pci: EHCI PCI platform driver
[ 6.284772] tegra_xusb_read_usb_calib: usb_calib0 = 0x069c6c0e
[ 6.293996] tegra-xhci tegra-xhci: XUSB device id = 0xfac (T210)
[ 6.301677] usb_calib0 = 0x069c6c0e
[ 6.306536] usb_calib_ext = 0x00000004
[ 6.311715] usb_calib0 = 0x069c6c0e
[ 6.316540] usb_calib_ext = 0x00000004
[ 6.321613] usb_calib0 = 0x069c6c0e
[ 6.326341] usb_calib_ext = 0x00000004
[ 6.331361] xusb_prod port0 RX_CTLE = 0xfc
[ 6.336664] xusb_prod port0 RX_DFE = 0xc0077f1f
[ 6.342382] xusb_prod port0 RX_CDR_CTRL = 0x1c7
[ 6.348054] xusb_prod port0 RX_EQ_CTRL_H = 0xfcf01368
[ 6.354257] xusb_prod port1 RX_CTLE = 0xfc
[ 6.359448] xusb_prod port1 RX_DFE = 0xc0077f1f
[ 6.365049] xusb_prod port1 RX_CDR_CTRL = 0x1c7
[ 6.370655] xusb_prod port1 RX_EQ_CTRL_H = 0xfcf01368
[ 6.377916] usbcore: registered new interface driver cdc_acm
[ 6.384774] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 6.395343] usbcore: registered new interface driver cdc_wdm
[ 6.402475] usbcore: registered new interface driver usb-storage
[ 6.409998] usbcore: registered new interface driver usbserial
[ 6.417297] usbcore: registered new interface driver ftdi_sio
[ 6.424427] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 6.434419] usbcore: registered new interface driver option
[ 6.441399] usbserial: USB Serial support registered for GSM modem (1-port)
[ 6.449820] usbcore: registered new interface driver pl2303
[ 6.456882] usbserial: USB Serial support registered for pl2303
[ 6.464353] usbcore: registered new interface driver nvshieldled
[ 6.471892] Nvidia Tegra High-Speed USB Device Controller driver (Apr 30, 2012)
[ 6.482799] tegra USB phy - inst[0] platform info:
[ 6.489264] port_otg: yes
[ 6.493565] has_hostpc: yes
[ 6.498024] phy_interface: USB_PHY_INTF_UTMI
[ 6.504017] op_mode: TEGRA_USB_OPMODE_DEVICE
[ 6.509998] qc2_voltage: 0
[ 6.514424] vbus_pmu_irq: 0
[ 6.518926] charging: enabled
[ 6.523651] remote_wakeup: disabled
[ 6.534038] regulator_get() failed for (tegra-udc.0,usb_bat_chg), -19
[ 6.542200] tegra-udc tegra-udc.0: usb_bat_chg regulator not registered: USB charging will not be enabled
[ 6.555817] mousedev: could not register psaux device, error: -16
[ 6.563716] mousedev: PS/2 mouse device common for all mice
[ 6.571319] usbcore: registered new interface driver xpad
[ 6.578666] usbcore: registered new interface driver usb_acecad
[ 6.586477] usbcore: registered new interface driver aiptek
[ 6.593841] usbcore: registered new interface driver gtco
[ 6.600945] usbcore: registered new interface driver hanwang
[ 6.608258] usbcore: registered new interface driver kbtab
[ 6.615353] usbcore: registered new interface driver wacom
[ 6.721865] max77620-rtc max77620-rtc.1: rtc core: registered max77620-rtc as rtc0
[ 6.782616] Wake51 for irq=118
[ 6.787074] Enabling wake51
[ 6.791276] i2c /dev entries driver
[ 6.798059] i2c i2c-6: of_i2c: modalias failure on /i2c@546c0000/tca6408@21
[ 6.807022] virtual_init
[ 6.811853] [IMX135] sensor driver loading
[ 6.817550] [imx132] sensor driver loading
[ 6.823167] [ar0261] sensor driver loading
[ 6.828867] ov7695 sensor driver loading
[ 6.834297] mt9m114 sensor driver loading
[ 6.840021] pcl-generic pcl-generic: virtual_chip_add
[ 6.847966] usbcore: registered new interface driver uvcvideo
[ 6.855168] USB Video Class driver (1.1.1)
[ 6.861391] max77620-power-off max77620-power-off.4: Event recorder REG_NVERC : 0x0
[ 6.872550] FAN dev name: pwm-fan
[ 6.877266] FAN:gpio request success.
[ 6.882404] pwm_fan_driver pwm-fan.35: cap state:7, cap pwm:255
[ 6.890022] pwm_fan_driver pwm-fan.35: got pwm for fan
[ 6.896925] pwm_fan_driver pwm-fan.35: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 6.907909] pwm_fan_driver pwm-fan.35: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 6.919346] pwm_fan_driver pwm-fan.35: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 6.930940] pwm_fan_driver pwm-fan.35: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 6.942849] pwm_fan_driver pwm-fan.35: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 6.954846] pwm_fan_driver pwm-fan.35: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 6.967063] pwm_fan_driver pwm-fan.35: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 6.979614] pwm_fan_driver pwm-fan.35: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 6.992391] pwm_fan_driver pwm-fan.35: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 7.005401] pwm_fan_driver pwm-fan.35: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 7.020184] tegra_aotag tegra-aotag.21: AOTAG probe started
[ 7.028361] tegra_aotag tegra-aotag.21: nominal ft – 105
[ 7.036269] tegra_aotag tegra-aotag.21: tall – 76
[ 7.043545] tegra_aotag tegra-aotag.21: tiddq – 1
[ 7.050754] tegra_aotag tegra-aotag.21: ten-count – 16
[ 7.058384] tegra_aotag tegra-aotag.21: tsample – 9
[ 7.065667] tegra_aotag tegra-aotag.21: pdiv – 8
[ 7.072602] tegra_aotag tegra-aotag.21: nominal cp – 25
[ 7.080060] tegra_aotag tegra-aotag.21: pdiv-ate – 8
[ 7.087191] tegra_aotag tegra-aotag.21: tsamp-ate – 39
[ 7.094419] tegra_aotag tegra-aotag.21: compensation A,B – 10632,-67490
[ 7.103091] tegra_aotag tegra-aotag.21: sensor found :ID 0, Name: aotag0
[ 7.111691] tegra_aotag tegra-aotag.21: reading fuse value for sensor 0
[ 7.120156] tegra_aotag tegra-aotag.21: base-cp:23c shifted-cp:1
[ 7.127961] tegra_aotag tegra-aotag.21: base-ft:4e2 shifted-ft:ffffffff
[ 7.136303] tegra_aotag tegra-aotag.21: actual_aotag_cp 255, ft 1045
[ 7.144350] tegra_aotag tegra-aotag.21: - Tsens calib value - 0x39cbc95
[ 7.152577] tegra_aotag tegra-aotag.21: CPmask 1fff FTmask 3ffe000
[ 7.160289] tegra_aotag tegra-aotag.21: Tsense calib CP - 0x1c95
[ 7.167774] tegra_aotag tegra-aotag.21: Tsense Actual CP d.35733
[ 7.175183] tegra_aotag tegra-aotag.21: Tsense calib FT - 0x1ce5
[ 7.182518] tegra_aotag tegra-aotag.21: Tsense Actual FT d.39205
[ 7.189761] tegra_aotag tegra-aotag.21: delta ts 3472, temp 790
[ 7.196862] tegra_aotag tegra-aotag.21: thermA-858, thermB–843
[ 7.203898] tegra_aotag tegra-aotag.21: Registering sensor 0
[ 7.210649] tegra_aotag tegra-aotag.21: Bound to TZ : ID 0
[ 7.217201] tegra_aotag tegra-aotag.21: shutdown temperature - 55
[ 7.224384] tegra_aotag tegra-aotag.21: AOTAG EN 60
[ 7.230335] tegra_aotag tegra-aotag.21: Probe done [SUCCESS]:0
[ 7.237890] md: raid0 personality registered for level 0
[ 7.244679] device-mapper: uevent: version 1.0.3
[ 7.250813] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[ 7.262265] Tegra210 cpuidle driver
[ 7.268602] sdhci: Secure Digital Host Controller Interface driver
[ 7.276181] sdhci: Copyright(c) Pierre Ossman
[ 7.281904] sdhci-pltfm: SDHCI platform and OF driver helper
[ 7.289421] mmc0: sdhci_tegra_probe line=5655 runtime pm type=mmc rtpm coupled with clock gate, disable-clock-gate=0
[ 7.302952] sdhci-tegra sdhci-tegra.3: Parent select= pll_p rate=408000000
[ 7.311436] sdhci-tegra sdhci-tegra.3: Parent select= pll_c4_out2 rate=199680000
[ 7.322867] sdhci-tegra sdhci-tegra.3: Speedo value 1983
[ 7.329840] sdhci-tegra sdhci-tegra.3: Tuning constraints: nom_mv 1075, boot_mv 1075, min_or_mv 0
[ 7.342232] regulator_get() failed for (sdhci-tegra.3,vqmmc), -19
[ 7.350204] mmc0: no vqmmc regulator found
[ 7.356164] regulator_get() failed for (sdhci-tegra.3,vmmc), -19
[ 7.364086] mmc0: no vmmc regulator found
[ 7.402341] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA
[ 7.414064] mmc1: sdhci_tegra_probe line=5655 runtime pm type=mmc rtpm coupled with clock gate, disable-clock-gate=0
[ 7.428947] sdhci-tegra sdhci-tegra.1: Parent select= pll_p rate=408000000
[ 7.439041] sdhci-tegra sdhci-tegra.1: Speedo value 1983
[ 7.446633] sdhci-tegra sdhci-tegra.1: Tuning constraints: nom_mv 1075, boot_mv 1075, min_or_mv 0
[ 7.460653] regulator_get() failed for (sdhci-tegra.1,vqmmc), -19
[ 7.469010] mmc1: no vqmmc regulator found
[ 7.475329] regulator_get() failed for (sdhci-tegra.1,vmmc), -19
[ 7.483595] mmc1: no vmmc regulator found
[ 7.522346] mmc1: SDHCI controller on sdhci-tegra.1 [sdhci-tegra.1] using ADMA
[ 7.535336] mmc2: sdhci_tegra_probe line=5655 runtime pm type=mmc rtpm coupled with clock gate, disable-clock-gate=0
[ 7.550450] sdhci-tegra sdhci-tegra.0: Parent select= pll_p rate=408000000
[ 7.560702] sdhci-tegra sdhci-tegra.0: Speedo value 1983
[ 7.568410] sdhci-tegra sdhci-tegra.0: Tuning constraints: nom_mv 1075, boot_mv 1075, min_or_mv 0
[ 7.581970] regulator_get() failed for (sdhci-tegra.0,vqmmc), -19
[ 7.590387] mmc2: no vqmmc regulator found
[ 7.596805] mmc0: BKOPS_EN bit is not set
[ 7.596810] regulator_get() failed for (sdhci-tegra.0,vmmc), -19
[ 7.596819] mmc2: no vmmc regulator found
[ 7.632855] mmc2: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA
[ 7.644613] gpio wake35 for gpio=201
[ 7.653472] tegra-se tegra21-se: tegra_se_probe: complete
[ 7.661612] hidraw: raw HID events driver (C) Jiri Kosina
[ 7.671846] usbcore: registered new interface driver usbhid
[ 7.679592] usbhid: USB HID core driver
[ 7.685536] tegra_bootloader_debug: Created tegra_bootloader directory
[ 7.694204] tegra_bootloader_debug: Created sysfs interface tegra_bootloader_verify_regs in tegra_bootloader directory
[ 7.709049] tegra_bootloader_debug: Created sysfs interface tegra_bootloader_prof in tegra_bootloader directory
[ 7.723783] nvadsp 702ef000.adsp: in probe()…
[ 7.731279] nvadsp 702ef000.adsp: AMC/ARAM initialized.
[ 7.738686] nvadsp 702ef000.adsp: nvadsp_app_module_probe
[ 7.749296] tegra_throttle : init passed
[ 7.755748] mmc0: tap value and tuning window after hw tuning completion …
[ 7.756969] cpu-tegra: init EDP limit: 1224 MHz
[ 7.757462] pll_x: not ready for dynamic ramp to 614400000
[ 7.757502] pll_x: not ready for dynamic ramp to 614400000
[ 7.759386] soctherm: skipping sensor 4 programming
[ 7.759391] soctherm: skipping sensor 5 programming
[ 7.800748] mmc0: tuning_window[0]: 0xffffffff
[ 7.807179] mmc0: tuning_window[1]: 0xffffffcf
[ 7.813536] mmc0: tuning_window[2]: 0xffff8fff
[ 7.819810] mmc0: tuning_window[3]: 0x7f8fffff
[ 7.825984] mmc0: tuning_window[4]: 0x0
[ 7.831510] mmc0: tuning_window[5]: 0x0
[ 7.836968] mmc0: tuning_window[6]: 0x0
[ 7.842360] mmc0: tuning_window[7]: 0x0
[ 7.847682] sdhci: Tap value: 56 | Trim value: 8
[ 7.853787] sdhci: SDMMC Interrupt status: 0x00040000
[ 7.861517] mmc0: switch to HS400 mode is successful
[ 7.870993] usbcore: registered new interface driver snd-usb-audio
[ 7.872776] mmc0: new HS400 MMC card at address 0001
[ 7.873358] mmcblk0: mmc0:0001 016G32 14.6 GiB
[ 7.873590] mmcblk0rpmb: mmc0:0001 016G32 partition 3 4.00 MiB
[ 7.875012] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18
[ 7.905371] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 7.916095] No Device Node present for smmu client: snd-soc-dummy !!
[ 7.924049] No Device Node present for smmu client: snd-soc-dummy !!
[ 7.932370] No Device Node present for smmu client: snd-soc-dummy !!
[ 7.940189] No Device Node present for smmu client: snd-soc-dummy !!
[ 7.949290] Codec driver version 0.4 alsa 1.0.25
[ 7.960196] tegra-i2c 7000c000.i2c: no acknowledge from address 0x1b
[ 7.968198] rt5659 0-001b: Device with ID register ffffffc0 is not rt5659
[ 7.997317] tegra210-i2s tegra210-i2s.0: Missing prop fsync-width for I2S0
[ 8.007249] tegra210-i2s tegra210-i2s.2: Missing prop fsync-width for I2S2
[ 8.016211] tegra210-i2s tegra210-i2s.3: Missing prop fsync-width for I2S3
[ 8.025287] tegra210-i2s tegra210-i2s.4: Missing prop fsync-width for I2S4
[ 8.044457] OPE platform probe
[ 8.049602] OPE platform probe successful
[ 8.055393] OPE platform probe
[ 8.060551] OPE platform probe successful
[ 8.066553] tegra210_adsp_audio_platform_probe: platform probe started
[ 8.076636] tegra210-adsp adsp_audio.3: Default param-type to BYTE for mp3-dec1
[ 8.087765] tegra210-adsp adsp_audio.3: Default param-type to BYTE for spkprot
[ 8.099046] tegra210-adsp adsp_audio.3: Default param-type to BYTE for src
[ 8.108263] tegra210-adsp adsp_audio.3: Default param-type to BYTE for aac-dec1
[ 8.119706] tegra210_adsp_audio_platform_probe probe successfull.
[ 8.132890] tegra-snd-t210ref-mobile-rt565x sound.18: ASoC: CODEC (null) not registered
[ 8.146582] tegra-snd-t210ref-mobile-rt565x sound.18: snd_soc_register_card failed (-517)
[ 8.158964] platform sound.18: Driver tegra-snd-t210ref-mobile-rt565x requests probe deferral
[ 8.173115] GACT probability NOT on
[ 8.178759] Mirror/redirect action on
[ 8.184536] u32 classifier
[ 8.189344] Actions configured
[ 8.194903] Netfilter messages via NETLINK v0.30.
[ 8.201901] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 8.210773] ctnetlink v0.93: registering with nfnetlink.
[ 8.218524] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 8.227898] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 8.236638] xt_time: kernel timezone is -0000
[ 8.243578] ipip: IPv4 over IPv4 tunneling driver
[ 8.251333] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 8.259237] arp_tables: (C) 2002 David S. Miller
[ 8.266223] TCP: cubic registered
[ 8.271751] Initializing XFRM netlink socket
[ 8.278863] NET: Registered protocol family 10
[ 8.286768] mip6: Mobile IPv6
[ 8.291933] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 8.299726] sit: IPv6 over IPv4 tunneling driver
[ 8.307771] NET: Registered protocol family 17
[ 8.314355] NET: Registered protocol family 15
[ 8.320762] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 8.328656] Bluetooth: HIDP socket layer initialized
[ 8.335547] NET: Registered protocol family 35
[ 8.341923] Key type dns_resolver registered
[ 8.348059] NET: Registered protocol family 41
[ 8.357194] Registering SWP/SWPB emulation handler
[ 8.416607] mmc1: tap value and tuning window after hw tuning completion …
[ 8.421761] isp isp.0: initialized
[ 8.423498] isp isp.1: initialized
[ 8.424088] vdd_gpu: disabling
[ 8.424283] en-vdd-cam-1v2: disabling
[ 8.424472] en-vdd-cam-hv-2v8: disabling
[ 8.424652] en-vdd-disp-1v8: disabling
[ 8.424830] en-mdm-pwr-3v7: disabling
[ 8.425009] en-vdd-disp-3v3: disabling
[ 8.425187] en-vdd-ts-hv-3v3: disabling
[ 8.425366] en-vdd-ts-1v8: disabling
[ 8.425544] usb-vbus3: disabling
[ 8.425561] usb-vbus1: disabling
[ 8.425590] vdd-fan: disabling
[ 8.431971] vdd-disp-3v0: disabling
[ 8.431976] snsr_pm: disabling
[ 8.431981] aux-3v3: disabling
[ 8.431986] en-vdd-cam: disabling
[ 8.432165] lcd-bl-en: disabling
[ 8.432171] max77620-gpio7: disabling
[ 8.443846] vdd-cpu-fixed: disabling
[ 8.443852] regulator-dummy: disabling
[ 8.445496] tegra-snd-t210ref-mobile-rt565x: probe of sound.18 failed with error -16
[ 8.446969] gpio wake24 for gpio=189
[ 8.447109] gpio wake27 for gpio=192
[ 8.447218] gpio wake25 for gpio=190
[ 8.447520] input: gpio-keys as /devices/platform/gpio-keys.39/input/input0
[ 8.561938] mmc1: tuning_window[0]: 0xe7ffffff
[ 8.567676] mmc1: tuning_window[1]: 0xffffffff
[ 8.573393] mmc1: tuning_window[2]: 0xfffffff9
[ 8.579086] mmc1: tuning_window[3]: 0x7ffffe7f
[ 8.584755] mmc1: tuning_window[4]: 0x0
[ 8.589787] mmc1: tuning_window[5]: 0x0
[ 8.594790] mmc1: tuning_window[6]: 0x0
[ 8.599772] mmc1: tuning_window[7]: 0x0
[ 8.604717] sdhci: Tap value: 46 | Trim value: 8
[ 8.610518] sdhci: SDMMC Interrupt status: 0x00040000
[ 8.616840] max77620-rtc max77620-rtc.1: setting system clock to 2013-01-01 00:00:00 UTC (1356998400)
[ 8.622187] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 8.622236] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 8.644586] [dram-timers] DRAM derating cdev registered.
[ 8.651483] Disable partitions left on by BL
[ 8.657353] sata
[ 8.661227] disb
[ 8.664985] Disabling clocks left on by bootloader:
[ 8.671388] audio2_dmic
[ 8.675543] audio1_dmic
[ 8.679635] audio0_dmic
[ 8.683772] audio_2x
[ 8.687605] audio
[ 8.691077] audio4
[ 8.694820] audio3
[ 8.698283] audio2
[ 8.701739] audio1
[ 8.705212] audio0
[ 8.708986] entropy
[ 8.712560] dsi2-fixed
[ 8.716374] dsi1-fixed
[ 8.720225] sdmmc4_ddr
[ 8.732347] sdmmc1_ddr
[ 8.732400] sor1_src
[ 8.732424] cclk_lp
[ 8.733575] tegra_cl_dvfs 70110000.dfll-ovr: DT data retrieved successfully
[ 8.733807] tune_cpu_trimmers: init soctherm cpu zone LOW
[ 8.733967] tegra_cl_dvfs_init_cdev: cpu_cold cooling device registered
[ 8.734101] tegra_cl_dvfs_init_cdev: cpu_hot cooling device registered
[ 8.734642] Tegra CPU DFLL is initialized with use_dfll = 1
[ 8.734910] tegra_dvfs: 0.vdd-cpu-rail-ovr connected to regulator
[ 8.735324] tegra_dvfs: 4.vdd-core-rail-max77620 connected to regulator
[ 8.735552] tegra_dvfs: 1.vdd-gpu-rail-ovr connected to regulator
[ 8.736159] CPU rate: 614 MHz
[ 8.736584] last reset is due to power on reset
[ 8.736584]
[ 8.736587] KERNEL: PMC reset status reg: 0x0
[ 8.737268] tegra_actmon.emc: Completed initialization (0)
[ 8.737791] tegra_actmon.avp: Completed initialization (0)
[ 8.857267] tegradc tegradc.1: hdmi: plugged
[ 8.978986] tegra dvfs: tegra sysfs cap interface is initialized
[ 8.985126] tegra dvfs: tegra sysfs gpu interface is initialized
[ 8.992531] ALSA device list:
[ 8.995533] #0: HDA NVIDIA Tegra at 0x70038000 irq 113
[ 9.001166] md: Waiting for all devices to be available before autodetect
[ 9.008023] md: If you don’t use raid, use raid=noautodetect
[ 9.014109] md: Autodetecting RAID arrays.
[ 9.018239] md: Scanned 0 and added 0 devices.
[ 9.022725] md: autorun …
[ 9.025642] md: … autorun DONE.
[ 9.030255] EXT4-fs (mmcblk0p1): couldn’t mount as ext3 due to feature incompatibilities
[ 9.039376] EXT4-fs (mmcblk0p1): couldn’t mount as ext2 due to feature incompatibilities
[ 9.074246] EXT4-fs (mmcblk0p1): recovery complete
[ 9.080214] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 9.088402] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 9.096619] devtmpfs: mounted
[ 9.099738] Freeing unused kernel memory: 432K (ffffffc001084000 - ffffffc0010f0000)
[ 9.107549] Freeing alternatives memory: 52K (ffffffc0010f1000 - ffffffc0010fe000)
[ 9.270838] init: plymouth-upstart-bridge main process (129) terminated with status 1
[ 9.278824] init: plymouth-upstart-bridge main process ended, respawning
[ 9.307181] init: plymouth-upstart-bridge main process (139) terminated with status 1
[ 9.317042] init: plymouth-upstart-bridge main process ended, respawning
[ 9.327640] init: ureadahead main process (132) terminated with status 5
[ 9.346850] init: plymouth-upstart-bridge main process (143) terminated with status 1
[ 9.356800] init: plymouth-upstart-bridge main process ended, respawning
[ 9.770456] systemd-udevd[293]: starting version 204
[ 9.937860] gpio wake52 for gpio=61
[ 9.962016] vi vi: vi_probe: ++
[ 9.969254] vi vi: initialized
[ 10.082832] tegra-xhci tegra-xhci: Firmware File: tegra21x_xusb_firmware (132608 Bytes)
[ 10.083114] tegra-xhci tegra-xhci: Firmware DMA Memory: dma 0x0000000080080000 mapped 0xffffff8000641000 (132608 Bytes)
[ 10.083124] tegra-xhci tegra-xhci: num_hsic_port 0
[ 10.085261] tegra-xhci tegra-xhci: Firmware timestamp: 2016-01-07 06:59:07 UTC, Version: 50.12 release, Falcon state 0x20
[ 10.085346] tegra-xhci tegra-xhci: Nvidia xHCI Host Controller
[ 10.085365] tegra-xhci tegra-xhci: new USB bus registered, assigned bus number 1
[ 10.086160] tegra-xhci tegra-xhci: irq 71, io mem 0x70090000
[ 10.086263] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 10.086272] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 10.086279] usb usb1: Product: Nvidia xHCI Host Controller
[ 10.086287] usb usb1: Manufacturer: Linux 3.10.67-g458d45c tegra-xhci
[ 10.086294] usb usb1: SerialNumber: tegra-xhci
[ 10.086758] xHCI xhci_add_endpoint called for root hub
[ 10.086766] xHCI xhci_check_bandwidth called for root hub
[ 10.086879] hub 1-0:1.0: USB hub found
[ 10.086908] hub 1-0:1.0: 5 ports detected
[ 10.092943] cfg80211: Calling CRDA to update world regulatory domain
[ 10.099563] sdhci-tegra sdhci-tegra.1: Card already in requested state
[ 10.108978] sdhci-tegra sdhci-tegra.1: Card already in requested state
[ 10.142483] tegra-xhci tegra-xhci: Nvidia xHCI Host Controller
[ 10.142502] tegra-xhci tegra-xhci: new USB bus registered, assigned bus number 2
[ 10.142678] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 10.142687] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 10.142695] usb usb2: Product: Nvidia xHCI Host Controller
[ 10.142701] usb usb2: Manufacturer: Linux 3.10.67-g458d45c tegra-xhci
[ 10.142707] usb usb2: SerialNumber: tegra-xhci
[ 10.142984] xHCI xhci_add_endpoint called for root hub
[ 10.142992] xHCI xhci_check_bandwidth called for root hub
[ 10.143091] hub 2-0:1.0: USB hub found
[ 10.143243] hub 2-0:1.0: 4 ports detected
[ 10.182623] Wake44 for irq=81
[ 10.182650] Wake40 for irq=53
[ 10.182655] Wake41 for irq=53
[ 10.182659] Wake42 for irq=53
[ 10.182663] Wake43 for irq=53
[ 10.188154] dhd_module_init in
[ 10.189111] Power-up adapter ‘DHD generic adapter’
[ 10.189480] wifi_platform_set_power = 1
[ 10.215351] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 10.215377] Bluetooth: BNEP socket layer initialized
[ 10.222490] Bluetooth: RFCOMM TTY layer initialized
[ 10.222524] Bluetooth: RFCOMM socket layer initialized
[ 10.222531] Bluetooth: RFCOMM ver 1.11
[ 10.392350] wifi_platform_bus_enumerate device present 1
[ 10.411872] SDIO Vendor ID:02d0 and SDIO Device ID: 4354
[ 10.412036] F1 signature read @0x18000000=0x17214354
[ 10.420255] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 10.421076] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 10.421167] wifi_platform_prealloc: failed to alloc static mem section 7
[ 10.421181] wifi_platform_get_mac_addr
[ 10.422546] wl_create_event_handler(): thread:wl_event_handler:1d6 started
[ 10.422716] CFG80211-ERROR) wl_event_handler : tsk Enter, tsk = 0xffffffc0f9a219f0
[ 10.429637] dhd_attach(): thread:dhd_watchdog_thread:1d7 started
[ 10.430449] dhd_attach(): thread:dhd_dpc:1da started
[ 10.431899] dhd_attach(): thread:dhd_rxf:1db started
[ 10.431909] dhd_deferred_work_init: work queue initialized
[ 10.432758] Dongle Host Driver, version 1.201.82 (r)
[ 10.432758] Compiled in drivers/net/wireless/bcmdhd on Feb 8 2016 at 17:41:49
[ 10.433158] Register interface [wlan0] MAC: 00:04:4b:63:3d:7e
[ 10.433158]
[ 10.433163] dhd_prot_ioctl : bus is down. we have nothing to do
[ 10.434829] wifi_platform_set_power = 0
[ 10.461560] cfg80211: World regulatory domain updated:
[ 10.461570] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 10.461578] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 10.461585] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 10.461592] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 10.461598] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 10.461604] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 10.462443] usb 1-3: new full-speed USB device number 3 using tegra-xhci
[ 10.482396] tegradc tegradc.1: hdmi: unplugged
[ 10.486341] usb 1-3: New USB device found, idVendor=046d, idProduct=c534
[ 10.486354] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 10.486362] usb 1-3: Product: USB Receiver
[ 10.486370] usb 1-3: Manufacturer: Logitech
[ 10.489189] input: Logitech USB Receiver as /devices/platform/tegra-xhci/usb1/1-3/1-3:1.0/input/input1
[ 10.489542] hid-generic 0003:046D:C534.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-tegra-xhci-3/input0
[ 10.492563] input: Logitech USB Receiver as /devices/platform/tegra-xhci/usb1/1-3/1-3:1.1/input/input2
[ 10.493474] hid-generic 0003:046D:C534.0002: input,hiddev0,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-tegra-xhci-3/input1
[ 10.642327] tegra_sysfs_register
[ 10.772741] usb 2-1: new SuperSpeed USB device number 2 using tegra-xhci
[ 10.794184] usb 2-1: New USB device found, idVendor=0955, idProduct=09ff
[ 10.794194] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[ 10.794201] usb 2-1: Product: USB 10/100/1000 LAN
[ 10.794208] usb 2-1: Manufacturer: Nvidia
[ 10.794214] usb 2-1: SerialNumber: 000001000000
[ 10.800630] cdc_ether 2-1:2.0 eth0: register ‘cdc_ether’ at usb-tegra-xhci-1, CDC Ethernet Device, 00:04:4b:63:3d:80
[ 10.805740] cdc_ether 2-1:2.0 eth0: unregister ‘cdc_ether’ usb-tegra-xhci-1, CDC Ethernet Device
[ 10.973184] usb 2-1: reset SuperSpeed USB device number 2 using tegra-xhci
[ 11.030679] r8152 2-1:1.0 eth0: v2.03.3 (2015/01/29)
[ 11.030683] r8152 2-1:1.0 eth0: This product is covered by one or more of the following patents:
[ 11.030683] US6,570,884, US6,115,776, and US6,327,625.
[ 11.030683]
[ 11.059206] tegradc tegradc.1: hdmi: plugged
[ 11.142683]
[ 11.142683] Dongle Host Driver, version 1.201.82 (r)
[ 11.142683] Compiled in drivers/net/wireless/bcmdhd on Feb 8 2016 at 17:41:49
[ 11.142695] wl_android_wifi_on in
[ 11.142701] wifi_platform_set_power = 1
[ 11.420157] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 11.493563] sdhci-tegra sdhci-tegra.1: Tuning already done, restoring the best tap value : 46
[ 11.494412] SDIO Vendor ID:02d0 and SDIO Device ID: 4354
[ 11.494655] F1 signature read @0x18000000=0x17214354
[ 11.505454] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 11.507120] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 11.620197] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 11.662892] SDIO Vendor ID:02d0 and SDIO Device ID: 4354
[ 11.662934] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[ 11.663615] gpio wake8 for gpio=58
[ 11.663621] Enabling wake8
[ 11.665324] wifi_platform_get_mac_addr
[ 11.667923] Firmware up: op_mode=0x0005, MAC=00:04:4b:63:3d:7e
[ 11.675362] dhd_preinit_ioctls pspretend_threshold for HostAPD failed -23
[ 11.676521] init: plymouth-upstart-bridge main process ended, respawning
[ 11.681448] Firmware version = wl0: Jan 27 2016 22:30:13 version 7.35.221.7 (r615597) FWID 01-7ec88390
[ 11.686396] dhd_interworking_enable: failed to set WNM info, ret=-23
[ 11.686661] tegra_sysfs_on
[ 11.749710] dhd_ndo_add_ip: ndo ip addr add failed, retcode = -23
[ 11.749719] dhd_inet6_work_handler: Adding host ip for NDO failed -23
[ 11.843396] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 11.886218] gk20a gpu.0: GPCPLL initial settings: NA mode, M=1, N=34, P=3
[ 12.074868] init: Failed to obtain startpar-bridge instance: Unknown parameter: INSTANCE
[ 12.161313] tegradc tegradc.1: blank - powerdown
[ 12.161384] tegradc tegradc.1: unblank
[ 12.164094] tegradc tegradc.1: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 12.516180] tegradc tegradc.1: unblank
[ 12.532391] tegradc tegradc.1: first frame flipped [24596179]us
[ 21.163587] tegradc tegradc.1: blank - powerdown
[ 21.246625] tegradc tegradc.1: unblank
[ 21.271945] tegradc tegradc.1: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 93.675662] extcon-gpio-states 1.extcon: Cable state 2
[ 93.734776] otg state changed: SUSPEND → HOST
[ 93.734965] tegra_start_host(): enable ehci node
[ 93.737703] tegra USB phy - inst[0] platform info:
[ 93.737762] port_otg: yes
[ 93.737805] has_hostpc: yes
[ 93.737847] phy_interface: USB_PHY_INTF_UTMI
[ 93.737889] op_mode: TEGRA_USB_OPMODE_HOST
[ 93.737932] qc2_voltage: 0
[ 93.737974] hot_plug: disabled
[ 93.738015] remote_wakeup: enabled
[ 93.740008] regulator_get() failed for (tegra-ehci.0,usb_vbus), -19
[ 93.776785] usb_phy: failed regulator_get vdd_vbus_usb:-19, inst:0
[ 93.865360] extcon-gpio-states 1.extcon: Cable state 2
[ 94.799067] tegra-ehci tegra-ehci.0: Tegra EHCI Host Controller
[ 94.799219] tegra-ehci tegra-ehci.0: new USB bus registered, assigned bus number 3
[ 94.799894] tegra-ehci tegra-ehci.0: irq 52, io mem 0x7d000000
[ 94.814556] tegra-ehci tegra-ehci.0: USB 2.0 started, EHCI 1.10
[ 94.815018] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 94.815083] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 94.815139] usb usb3: Product: Tegra EHCI Host Controller
[ 94.815189] usb usb3: Manufacturer: Linux 3.10.67-g458d45c ehci_hcd
[ 94.815238] usb usb3: SerialNumber: tegra-ehci.0
[ 94.817852] hub 3-0:1.0: USB hub found
[ 94.817981] hub 3-0:1.0: 1 port detected
[ 95.744671] u
One thing I see, but am not certain of the relevance, is this:
After that it goes on to work with the USB2 driver:
From what I see it should instead be working with the USB3 xhci driver. How old is this L4T? Check release via:
head -n 1 /etc/nv_tegra_release
Regardless, it notes a physical interface error related to power (and bus powered USB devices draw power from this), and then locks once the driver does what should be enumerating on USB. It kind of looks like something plugged into USB may be causing a failure. It looks like you have serial console, so perhaps try unplugging everything USB and see what happens…see if it gets further into booting.
my version is :# R23 (release), REVISION: 2.0, GCID: 6630372, BOARD: t210ref, EABI: hard, DATE: Tue Feb 9 01:49:02 UTC 2016
After this time start up, I could enter a screen with black background but display some words,
“The system is running in low-graphics mode
your scrren graphics card, and input device setting
could not be detected correctly, you will need to configure these yourself.”
And there is a button to select some option like reconfigure, I have tried all the options but no useful.
Here is my new log:
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.10.67-g458d45c (buildbrain@mobile-u64-630) (gcc version 4.9 20140514 (prerelease) (GCC) ) #1 SMP PREEMPT Mon Feb 8 17:44:18 PST 2016
[ 0.000000] CPU: Cortex A57 Processor [411fd071] revision 1
[ 0.000000] alternative: enabling workaround for ARM erratum 832075
[ 0.000000] Machine: jetson_tx1
[ 0.000000] bootconsole [earlycon0] enabled
[ 0.000000] Tegra reserved memory:
[ 0.000000] LP0: ff2bf000 - ff2bffff
[ 0.000000] Bootloader framebuffer: 00000000 - 00000000
[ 0.000000] Bootloader framebuffer2: 00000000 - 00000000
[ 0.000000] Framebuffer: f6200000 - fa9fffff
[ 0.000000] 2nd Framebuffer: faa00000 - ff1fffff
[ 0.000000] Carveout: 00000000 - 00000000
[ 0.000000] Vpr: 00000000 - 0b9fffff
[ 0.000000] Tsec: 00000000 - 00000000
[ 0.000000] Bootloader Debug Data: 00000000 - 00000000
[ 0.000000] Nvdumper: ff23f000 - ff23ffff
[ 0.000000] cma: CMA: reserved 188 MiB at ea400000
[ 0.000000] cma: CMA: reserved 16 MiB at e9400000
[ 0.000000] On node 0 totalpages: 1007616
[ 0.000000] DMA32 zone: 6608 pages used for memmap
[ 0.000000] DMA32 zone: 0 pages reserved
[ 0.000000] DMA32 zone: 483328 pages, LIFO batch:31
[ 0.000000] Normal zone: 7168 pages used for memmap
[ 0.000000] Normal zone: 524288 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv0.2 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/arch/arm64/boot/dts/tegra210-jetson-tx1-p2597-2180-a01-devkit.dts
[ 0.000000] DTB Build time: Feb 8 2016 17:38:02
[ 0.000000] Tegra21: Speedo/IDDQ fuse revision 4
[ 0.000000] Tegra21: CPU Speedo ID 7, Soc Speedo ID 0, Gpu Speedo ID 2
[ 0.000000] Tegra21: CPU Process ID 0, Soc Process ID 1, Gpu Process ID 0
[ 0.000000] Tegra21: CPU Speedo value 2073, Soc Speedo value 1983, Gpu Speedo value 2094
[ 0.000000] Tegra21: CPU IDDQ 2300, Soc IDDQ 2700, Gpu IDDQ 3395
[ 0.000000] Tegra Revision: A02 SKU: 0x17 CPU Process: 0 Core Process: 1
[ 0.000000] tegra: PLLP fixed rate: 408000000
[ 0.000000] pll_u: boot with h/w control already set
[ 0.000000] pll_x boot misc1 0x0 : expected 0x20
[ 0.000000] (comparison mask = 0xffffff)
[ 0.000000] pll_c4 rates match 204000000 max sdmmc: vco=998400000 out0=998400000 out3=998400000
[ 0.000000] Lowering vic03 maximum rate from 1000000000 to 627200000
[ 0.000000] Lowering nvjpg maximum rate from 1000000000 to 627200000
[ 0.000000] Lowering se maximum rate from 1000000000 to 627200000
[ 0.000000] Lowering tsecb maximum rate from 1000000000 to 627200000
[ 0.000000] Lowering msenc maximum rate from 1000000000 to 716800000
[ 0.000000] Lowering nvdec maximum rate from 1000000000 to 716800000
[ 0.000000] Lowering vi maximum rate from 1000000000 to 793600000
[ 0.000000] Lowering isp maximum rate from 1000000000 to 793600000
[ 0.000000] Lowering adsp_bus maximum rate from 1200000000 to 844800000
[ 0.000000] Lowering sbus maximum rate from 600000000 to 408000000
[ 0.000000] Lowering host1x maximum rate from 600000000 to 408000000
[ 0.000000] Lowering pll_c maximum rate from 1200000000 to 1130000000
[ 0.000000] Lowering pll_c2 maximum rate from 1200000000 to 1130000000
[ 0.000000] Lowering pll_c3 maximum rate from 1200000000 to 1130000000
[ 0.000000] Lowering pll_d2 maximum rate from 1500000000 to 1130000000
[ 0.000000] Lowering pll_dp maximum rate from 1500000000 to 1130000000
[ 0.000000] Lowering sor0 maximum rate from 600000000 to 540000000
[ 0.000000] Lowering sor1 maximum rate from 600000000 to 594000000
[ 0.000000] Lowering dmic1 maximum rate from 12288000 to 12190000
[ 0.000000] Lowering dmic2 maximum rate from 12288000 to 12190000
[ 0.000000] Lowering dmic3 maximum rate from 12288000 to 12190000
[ 0.000000] Lowering hda maximum rate from 102000000 to 51000000
[ 0.000000] Lowering sdmmc2 maximum rate from 266000000 to 204000000
[ 0.000000] Lowering qspi maximum rate from 133000000 to 116600000
[ 0.000000] Lowering gbus maximum rate from 1300000000 to 998400000
[ 0.000000] Lowering cpu_g maximum rate from 3000000000 to 1734000000
[ 0.000000] Lowering cpu_lp maximum rate from 1350000000 to 1132800000
[ 0.000000] tegra dvfs: vdd_cpu: nominal 1226mV, offset 708000uV, step 19200uV, scaling enabled
[ 0.000000] tegra dvfs: vdd_core: nominal 1075mV, offset 0uV, step 12500uV, scaling enabled
[ 0.000000] tegra dvfs: vdd_gpu: nominal 1090mV, offset 710000uV, step 10000uV, scaling enabled
[ 0.000000] tegra_powergate_init: DONE
[ 0.000000] tegra21_plle_clk_enable: pll_e is already enabled
[ 0.000000] PERCPU: Embedded 13 pages/cpu @ffffffc03feb3000 s21504 r8192 d23552 u53248
[ 0.000000] pcpu-alloc: s21504 r8192 d23552 u53248 alloc=13*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 993840
[ 0.000000] Kernel command line: fbcon=map:0 console=tty0 console=ttyS0,115200n8 androidboot.modem=none androidboot.serialno=P2180A00P00940c003fd androidboot.security=non-secure tegraid=21.1.2.0.0 ddr_die=2048M@2048M ddr_die=2048M@4096M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 debug_uartport=lsport,0 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff2bf000 nvdumper_reserved=0xff23f000 core_edp_mv=1125 core_edp_ma=4000 gpt android.kerneltype=normal androidboot.touch_vendor_id=0 androidboot.touch_panel_id=63 androidboot.touch_feature=0 androidboot.bootreason=pmc:software_reset,pmic:0x0 root=/dev/mmcblk0p1 rw rootwait
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 1888MB 2048MB = 3936MB total
[ 0.000000] Memory: 3736844k/3736844k available, 293620k reserved
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vmalloc : 0xffffff8000000000 - 0xffffffbbffff0000 (245759 MB)
[ 0.000000] vmemmap : 0xffffffbc01c00000 - 0xffffffbc05400000 ( 56 MB)
[ 0.000000] modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc100000000 ( 4096 MB)
[ 0.000000] .init : 0xffffffc001084000 - 0xffffffc0010f0400 ( 433 kB)
[ 0.000000] .text : 0xffffffc000080000 - 0xffffffc0010831c4 ( 16397 kB)
[ 0.000000] .data : 0xffffffc001104000 - 0xffffffc0012b2c00 ( 1723 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[ 0.000000] NR_IRQS:960 nr_irqs:960 0
[ 0.000000] the number of interrupt controllers found is 6
[ 0.000000] Architected local timer running at 19.20MHz (phys).
[ 0.000000] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 3579139424256ns
[ 0.000000] Wake16 for irq=34
[ 0.000000] Enabling wake16
[ 0.000000] Console: colour dummy device 80x25
[ 0.000000] console [tty0] enabled
[ 0.016494] Calibrating delay loop (skipped), value calculated using timer frequency… lpj=192000
[ 0.025313] pid_max: default: 32768 minimum: 301
[ 0.030026] Security Framework initialized
[ 0.034047] Mount-cache hash table entries: 256
[ 0.087828] Initializing cgroup subsys debug
[ 0.090116] Initializing cgroup subsys freezer
[ 0.094783] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available
[ 0.140387] ftrace: Allocated trace_printk buffers
[ 0.201182] Brought up 4 CPUs
[ 0.202169] SMP: Total of 4 processors activated.
[ 0.206868] alternatives: patching kernel code
[ 0.214998] devtmpfs: initialized
[ 0.233977] pinctrl core: initialized pinctrl subsystem
[ 0.237639] regulator-dummy: ; Rail ON
[ 0.245590] Initializing plugin-manager
[ 0.247779] node /plugin-manager/p2180-1000-300@0 match with board 2180-1000-100
[ 0.255323] NET: Registered protocol family 16
[ 0.262510] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.268450] console [pstore-1] enabled
[ 0.271248] ramoops: attached 0x200000@0xf6000000, ecc: 0/0
[ 0.277243] I2C first dynamic bus number based on alias = 7
[ 0.282410] cpuidle: using governor ladder
[ 0.286375] cpuidle: using governor menu
[ 0.291095] PMC: Setting PMIC interrupt active-low
[ 0.295724] tegra-pmc device create success
[ 0.299289] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.306419] Clear bootloader IO dpd settings
[ 0.310658] PMC: configuring io pad defaults
[ 0.315151] PMC: IO pad audio voltage is 1800000
[ 0.319583] PMC: IO pad cam voltage is 1800000
[ 0.324017] PMC: IO pad dbg voltage is 1800000
[ 0.328424] PMC: IO pad dmic voltage is 1800000
[ 0.332943] PMC: IO pad pex-ctrl voltage is 1800000
[ 0.337783] PMC: IO pad spi voltage is 1800000
[ 0.342215] PMC: IO pad uart voltage is 1800000
[ 0.346710] PMC: IO pad bb voltage is 1800000
[ 0.351058] PMC: IO pad audio-hv voltage is 1800000
[ 0.355897] PMC: IO pad spi-hv voltage is 1800000
[ 0.360588] PMC: IO pad gpio voltage is 1800000
[ 0.365083] PMC: IO pad sdmmc3 voltage is 1800000
[ 0.369671] PMC: IO pad pex-bias power is disable
[ 0.374361] PMC: IO pad pex-clk1 power is disable
[ 0.379030] PMC: IO pad pex-clk2 power is disable
[ 0.383712] T210 pmc padctrl driver initialized
[ 0.388280] T210 pmc config for bootrom command passed
[ 0.394748] INFO: pinmux CLAMP_INPUTS_WHEN_TRISTATED: disabled
[ 0.401582] clk_init_from_dt_table: clocks are set from t210-clk-init-table:clkinit-0
[ 0.411313] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.415604] platform bpmp.15: domain=ffffffc0ff04d698 allocates as[0]=ffffffc0ff1040a8
[ 0.423510] platform bpmp.15: IOVA linear map 0x00000000ff2c0000(40000)
[ 0.430555] bpmp bpmp.15: bpmp_connect returned 0
[ 0.435525] MC mapped MMIO address: 0xffffff800003a000
[ 0.439733] MC0 mapped MMIO address: 0xffffff8000072000
[ 0.444955] MC1 mapped MMIO address: 0xffffff8000098000
[ 0.463453] tegra210-pinctrl 700008d4.pinmux: lookup the user state drive not found
[ 0.469246] tegra210-pinctrl 700008d4.pinmux: Probed Tegra pinctrl driver
[ 0.476625] GPIO chip tegra-gpio: created GPIO range 0->245 ==> 700008d4.pinmux PIN 0->245
[ 0.484197] tegra-gpio 6000d000.gpio: Initialising GPIO state 0: name wlan-default
[ 0.491767] gpiochip_add: registered GPIOs 0 to 255 on device: tegra-gpio
[ 0.502316] Wake44 for irq=81
[ 0.503342] Wake40 for irq=53
[ 0.506240] Wake41 for irq=53
[ 0.509185] Wake42 for irq=53
[ 0.512132] Wake43 for irq=53
[ 0.515817] platform 70006000.serial: domain=ffffffc0ff125298 allocates as[0]=ffffffc0ff104110
[ 0.525110] platform sound.18: domain=ffffffc0ff125518 allocates as[0]=ffffffc0ff104178
[ 0.534850] platform tegradc.1: domain=ffffffc0ff125918 allocates as[0]=ffffffc0ff1041e0
[ 0.544974] platform tegradc.1: IOVA linear map 0x00000000f6200000(4800000)
[ 0.553948] platform tegradc.1: IOVA linear map 0x00000000faa00000(4800000)
[ 0.559110] platform tegradc.1: IOVA linear map 0x00000000ea400000(bc00000)
[ 0.568664] platform gpu.0: domain=ffffffc0ff125a98 allocates as[0]=ffffffc0ff104248
[ 0.574496] platform gpu.0: domain=ffffffc0ff125a98 allocates as[1]=ffffffc0ff1042b0
[ 0.582206] platform gpu.0: domain=ffffffc0ff125a98 allocates as[2]=ffffffc0ff104318
[ 0.589902] platform gpu.0: domain=ffffffc0ff125a98 allocates as[3]=ffffffc0ff104380
[ 0.603596] platform sdhci-tegra.3: domain=ffffffc0ff192098 allocates as[0]=ffffffc0ff1043e8
[ 0.610726] platform sdhci-tegra.0: domain=ffffffc0ff192298 allocates as[0]=ffffffc0ff104450
[ 0.618856] Wake39 for irq=52
[ 0.634309] gpio wake52 for gpio=61
[ 0.636260] gpio wake8 for gpio=58
[ 0.639240] gpio wake8 for gpio=58
[ 0.644363] irq: no irq domain found for /soctherm@0x700E2000 !
[ 0.648711] irq: no irq domain found for /soctherm@0x700E2000 !
[ 0.654594] board_info: id:sku:fab:major:minor = 0x0884:0x03e8:0x00:0x00:0x00
[ 0.661501] PMC dt information non-NULL tegra_init_suspend
[ 0.674952] Loading EMC tables…
[ 0.676379] tegra: Using EMC sequence ‘21021’ for Rev. 7 tables
[ 0.682216] tegra: emc: Derated table is valid.
[ 0.686700] Lowering emc maximum rate from 1800000000 to 1600000000
[ 0.692950] tegra: validated EMC DFS table
[ 0.712871] swapper/0 isomgr_init(): iso emc max clk=1600000KHz
[ 0.716811] swapper/0 isomgr_init(): max_iso_bw=11520000KB
[ 1.999014] vdso: 2 pages (1 code, 1 data) at base ffffffc00110a000
[ 2.003356] vdso32: 2 pages (1 code, 1 data) at base ffffffc001109000
[ 2.009750] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 2.016677] nvdumper: last reboot was unknown
[ 2.020837] nvdumper: set_dirty_state 0x2badface
[ 2.025945] Tegra restart notifier registered.
[ 2.044052] bio: create slab at 0
[ 2.048337] vdd-ac-bat: 5000 mV ; Rail ON
[ 2.050689] vdd-cpu-fixed: 1000 mV ; Rail ON
[ 2.055576] vgaarb: loaded
[ 2.057732] SCSI subsystem initialized
[ 2.061247] libata version 3.00 loaded.
[ 2.061541] usbcore: registered new interface driver usbfs
[ 2.066546] usbcore: registered new interface driver hub
[ 2.071891] usbcore: registered new device driver usb
[ 2.077650] i2c i2c-0: of_i2c: modalias failure on /i2c@7000c000/icm20628@68
[ 2.083845] i2c i2c-0: of_i2c: modalias failure on /i2c@7000c000/ak8963@0d
[ 2.090683] i2c i2c-0: of_i2c: modalias failure on /i2c@7000c000/bmp280@77
[ 2.097515] i2c i2c-0: of_i2c: modalias failure on /i2c@7000c000/cm32180@48
[ 2.104462] i2c i2c-0: of_i2c: modalias failure on /i2c@7000c000/iqs263@44
[ 2.111370] gpio wake33 for gpio=188
[ 2.116351] regulator_get() failed for (1-0074,vcc), -19
[ 2.120137] pca953x 1-0074: no regulator found for vcc. Assuming vcc is always powered
[ 2.128800] gpio wake21 for gpio=89
[ 2.131746] gpiochip_add: registered GPIOs 1008 to 1023 on device: tca9539
[ 2.138745] regulator_get() failed for (1-0077,vcc), -19
[ 2.143645] pca953x 1-0077: no regulator found for vcc. Assuming vcc is always powered
[ 2.152258] gpio wake36 for gpio=202
[ 2.155239] gpiochip_add: registered GPIOs 992 to 1007 on device: tca9539
[ 2.162545] i2c i2c-3: of_i2c: modalias failure on /i2c@7000c700/prod-settings
[ 2.170350] max77620 4-003c: CID0: 0xad
[ 2.172925] max77620 4-003c: CID1: 0x16
[ 2.176733] max77620 4-003c: CID2: 0x21
[ 2.180562] max77620 4-003c: CID3: 0x59
[ 2.184359] max77620 4-003c: CID4: 0x35
[ 2.188172] max77620 4-003c: CID5: 0x80
[ 2.192006] max77620 4-003c: MAX77620 PMIC OTP Version is 0x35
[ 2.199444] max77620-pmic max77620-pmic: Consumer c2 does not have device name
[ 2.205055] max77620-pmic max77620-pmic: Consumer c0 does not have device name
[ 2.213249] vdd_core: 600 <–> 1400 mV at 1000 mV with ramp delay 27500 uV/us ; Rail ON
[ 2.221022] vddio-ddr: at 1125 mV with ramp delay 27500 uV/us ; Rail ON
[ 2.227346] vdd-pre-reg: 1350 mV with ramp delay 27500 uV/us ; Rail ON
[ 2.234383] vdd-1v8: 1800 mV with ramp delay 27500 uV/us ; Rail ON
[ 2.240176] avdd-sys: 1200 mV with ramp delay 100000 uV/us ; Rail ON
[ 2.245692] avdd-sys: supplied by vdd-pre-reg
[ 2.250732] vdd-pex: 1050 mV with ramp delay 100000 uV/us ; Rail ON
[ 2.256253] vdd-pex: supplied by vdd-pre-reg
[ 2.261029] vddio-sdmmc1: 1800 <–> 3300 mV at 3300 mV with ramp delay 100000 uV/us ; Rail ON
[ 2.269546] vdd-cam-hv: 2800 mV with ramp delay 100000 uV/us ; Rail OFF
[ 2.276285] vdd-rtc: 850 mV with ramp delay 100000 uV/us ; Rail ON
[ 2.282295] avdd-ts-hv: 3300 mV with ramp delay 100000 uV/us ; Rail OFF
[ 2.289569] vdd-ts: 1800 mV with ramp delay 100000 uV/us ; Rail OFF
[ 2.295375] vdd-gen-pll-edp: 1050 mV with ramp delay 100000 uV/us ; Rail ON
[ 2.301519] vdd-gen-pll-edp: supplied by vdd-pre-reg
[ 2.307194] vdd-hdmi-dp: 1050 mV with ramp delay 100000 uV/us ; Rail ON
[ 2.313039] vdd-hdmi-dp: supplied by vdd-pre-reg
[ 2.318217] max77620-gpio max77620-gpio.0: Initialising GPIO state 1: name gpio_default
[ 2.325672] gpiochip_add: registered GPIOs 984 to 991 on device: max77620-gpio
[ 2.334011] max77620-gpio max77620-gpio.0: max77620 gpio successfully initialized
[ 2.344218] max77620 4-003c: max77620 probe successfully
[ 2.348412] Linux video capture interface: v2.00
[ 2.352207] pps_core: LinuxPPS API ver. 1 registered
[ 2.357078] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 2.366219] PTP clock support registered
[ 2.372195] Advanced Linux Sound Architecture Driver Initialized.
[ 2.376799] Bluetooth: Core ver 2.16
[ 2.379892] NET: Registered protocol family 31
[ 2.384294] Bluetooth: HCI device and connection manager initialized
[ 2.390626] Bluetooth: HCI socket layer initialized
[ 2.395462] Bluetooth: L2CAP socket layer initialized
[ 2.400527] Bluetooth: SCO socket layer initialized
[ 2.406903] vdd-3v3: 3300 mV ; Rail ON
[ 2.410527] max77620-gpio7: 1050 mV ; Rail ON
[ 2.413448] max77620-gpio7: supplied by vdd-gen-pll-edp
[ 2.418981] lcd-bl-en: 1800 mV ; Rail ON
[ 2.422858] en-vdd-sd: 3300 mV ; Rail OFF
[ 2.426540] en-vdd-sd: supplied by vdd-3v3
[ 2.430803] reg-fixed-sync-voltage 5.regulator: Consumer c1 does not have device name
[ 2.438831] en-vdd-cam: 1800 mV ; Rail OFF
[ 2.442492] en-vdd-cam: supplied by vdd-1v8
[ 2.453531] vdd-sys-boost: 5000 mV ; Rail ON
[ 2.456480] vdd-hdmi: 5000 mV ; Rail OFF
[ 2.459765] vdd-hdmi: supplied by vdd-3v3
[ 2.464060] aux-3v3: 3300 mV ; Rail ON
[ 2.467714] snsr_pm: 3300 mV ; Rail ON
[ 2.471953] vdd-disp-3v0: 3000 mV ; Rail ON
[ 2.475951] vdd-fan: 5000 mV ; Rail OFF
[ 2.479468] usb-vbus1: 5000 mV ; Rail OFF
[ 2.483186] usb-vbus1: supplied by vdd-3v3
[ 2.487546] usb-vbus3: 5000 mV ; Rail OFF
[ 2.491248] usb-vbus3: supplied by vdd-3v3
[ 2.495925] en-vdd-ts-1v8: 1800 mV ; Rail OFF
[ 2.500245] en-vdd-ts-hv-3v3: 3300 mV ; Rail OFF
[ 2.504955] en-vdd-disp-3v3: 3300 mV ; Rail ON
[ 2.509223] en-mdm-pwr-3v7: ; Rail OFF
[ 2.513114] en-vdd-disp-1v8: 1800 mV ; Rail ON
[ 2.517376] en-vdd-cam-hv-2v8: ; Rail OFF
[ 2.521069] rtl-5v0: ; Rail OFF
[ 2.524184] en-usb-vbus2: ; Rail OFF
[ 2.528041] en-vdd-cam-1v2: ; Rail OFF
[ 2.532136] regulator-pwm 0.pwm-regulator: PWM request deferred
[ 2.537039] platform 0.pwm-regulator: Driver regulator-pwm requests probe deferral
[ 2.545269] vdd_gpu: applied init 1000000uV constraint
[ 2.549682] vdd_gpu: 710 <–> 1320 mV at 1000 mV ; Rail OFF
[ 2.557175] vdd_cpu: applied init 1000000uV constraint
[ 2.560360] vdd_cpu: 708 <–> 1322 mV at 1000 mV normal ; Rail ON
[ 2.569363] gpio wake34 for gpio=200
[ 2.572645] extcon-gpio-states 1.extcon: Cable state 0
[ 2.578295] Switching to clocksource arch_sys_counter
[ 2.616406] No Device Node present for smmu client: tegra-carveouts !!
[ 2.620971] No Device Node present for smmu client: tegra-carveouts !!
[ 2.627650] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 2.634451] No Device Node present for smmu client: tegra-carveouts !!
[ 2.640478] dma_declare_coherent_resizable_cma_memory:278: resizable heap=vpr, base=0x0x00000000ea400000, size=0xbc00000
[ 2.651319] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (6) rem_chunk_size(0x1c00000)
[ 2.662087] cma: enabled page replacement for spfn=ea400, epfn=f6000
[ 2.668187] dma_declare_coherent_resizable_cma_memory:325: resizable cma heap=vpr create successful
[ 2.677047] nvmap_page_pool_init: Total RAM pages: 986435
[ 2.682584] nvmap_page_pool_init: nvmap page pool size: 123304 pages (481 MB)
[ 2.689760] nvmap_background_zero_thread: PP zeroing thread starting.
[ 2.690020] misc nvmap: iram :dma coherent mem declare 0x0000000040001000,258048
[ 2.690693] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 2.691178] misc nvmap: created heap vpr base 0x00000000ea400000 size (192512KiB)
[ 2.691659] nvmap:inner cache maint threshold=2097152
[ 2.691659] No Device Node present for smmu client: tegra-carveouts !!
[ 2.702381] Wake39 for irq=52
[ 2.702501] tegra-otg tegra-otg: otg transceiver registered
[ 2.703121] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 2.704379] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 2.704771] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 2.704980] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 2.705156] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 2.706372] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 2.706632] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tboard_tegra
[ 2.707716] tegra21_plle_clk_enable: pll_e hw sequencer is already on
[ 2.707740] t210_sata_uphy_pll_init: init sata uphy pll
[ 2.707755] t210_sata_uphy_pll_init SATA uses SATA Lane
[ 2.708084] tegra_xusb_padctl_phy_enable: pex uphy already enabled
[ 2.709686] tegra210-pmc-iopower pmc-iopower.20: Rail iopower-sys is having fixed voltage 1800000
[ 2.709791] tegra210-pmc-iopower pmc-iopower.20: Rail iopower-uart is having fixed voltage 1800000
[ 2.709892] tegra210-pmc-iopower pmc-iopower.20: Rail iopower-audio is having fixed voltage 1800000
[ 2.710000] tegra210-pmc-iopower pmc-iopower.20: Rail iopower-cam is having fixed voltage 1800000
[ 2.710119] tegra210-pmc-iopower pmc-iopower.20: Rail iopower-pex-ctrl is having fixed voltage 1800000
[ 2.710224] tegra210-pmc-iopower pmc-iopower.20: Rail iopower-sdmmc1 is having voltages: 1800000:3300000
[ 2.710332] tegra210-pmc-iopower pmc-iopower.20: Rail iopower-sdmmc3 is having fixed voltage 1800000
[ 2.710433] tegra210-pmc-iopower pmc-iopower.20: Rail iopower-sdmmc4 is having fixed voltage 1800000
[ 2.710538] tegra210-pmc-iopower pmc-iopower.20: Rail iopower-audio-hv is having fixed voltage 1800000
[ 2.710638] tegra210-pmc-iopower pmc-iopower.20: Rail iopower-debug is having fixed voltage 1800000
[ 2.710755] tegra210-pmc-iopower pmc-iopower.20: Rail iopower-dmic is having fixed voltage 1800000
[ 2.710858] tegra210-pmc-iopower pmc-iopower.20: Rail iopower-gpio is having fixed voltage 1800000
[ 2.710968] tegra210-pmc-iopower pmc-iopower.20: Rail iopower-spi is having fixed voltage 1800000
[ 2.711069] tegra210-pmc-iopower pmc-iopower.20: Rail iopower-spi-hv is having fixed voltage 1800000
[ 2.711171] tegra210-pmc-iopower pmc-iopower.20: Rail iopower-sdmmc2 is having fixed voltage 1800000
[ 2.711287] tegra210-pmc-iopower pmc-iopower.20: Rail iopower-dp is having fixed voltage 1800000
[ 2.711295] tegra210-pmc-iopower pmc-iopower.20: NO_IO_POWER setting 0x0
[ 2.711670] NET: Registered protocol family 2
[ 2.712489] TCP established hash table entries: 32768 (order: 7, 524288 bytes)
[ 2.712742] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 2.712996] TCP: Hash tables configured (established 32768 bind 32768)
[ 2.713094] TCP: reno registered
[ 2.713103] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 2.713146] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 2.713505] NET: Registered protocol family 1
[ 2.713925] RPC: Registered named UNIX socket transport module.
[ 2.713929] RPC: Registered udp transport module.
[ 2.713933] RPC: Registered tcp transport module.
[ 2.713936] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 2.713946] PCI: CLS 0 bytes, default 64
[ 2.714420] tegra-fuse tegra-fuse: Fuse driver initialized succesfully
[ 2.721615] host1x host1x: initialized
[ 2.734091] NTFS driver 2.1.30 [Flags: R/O].
[ 2.734386] fuse init (API version 7.22)
[ 2.734836] msgmni has been set to 7706
[ 2.736331] io scheduler noop registered (default)
[ 2.736570] Tegra cpuquiet initialized: disabled
[ 2.739252] tegra-pcie 1003000.pcie-controller: PCIE: Enable power rails
[ 2.740311] tegra-pcie 1003000.pcie-controller: probing port 0, using 4 lanes and lane map as 0x14
[ 2.742378] tegra-pcie 1003000.pcie-controller: probing port 1, using 1 lanes and lane map as 0x14
[ 3.145576] tegra-pcie 1003000.pcie-controller: link 0 down, retrying
[ 3.551458] tegra-pcie 1003000.pcie-controller: link 0 down, retrying
[ 3.957514] tegra-pcie 1003000.pcie-controller: link 0 down, retrying
[ 3.964009] tegra-pcie 1003000.pcie-controller: link 0 down, ignoring
[ 4.371038] tegra-pcie 1003000.pcie-controller: link 1 down, retrying
[ 4.781364] tegra-pcie 1003000.pcie-controller: link 1 down, retrying
[ 5.191267] tegra-pcie 1003000.pcie-controller: link 1 down, retrying
[ 5.197765] tegra-pcie 1003000.pcie-controller: link 1 down, ignoring
[ 5.202238] tegra-pcie 1003000.pcie-controller: PCIE: no ports detected
[ 5.209119] tegra-pcie 1003000.pcie-controller: PCIE: Disable power rails
[ 5.218217] tsec tsec: initialized
[ 5.220976] tsec tsecb: initialized
[ 5.225549] nvdec nvdec: initialized
[ 5.230638] falcon vic03: initialized
[ 5.234089] falcon msenc: initialized
[ 5.237449] falcon nvjpg: initialized
[ 5.241189] tegradc tegradc.1: Display dc.54240000 registered with id=0
[ 5.246365] display board info: id 0x0, fab 0x0
[ 5.251188] panel_select fail by _node_status
[ 5.255111] display board info: id 0x0, fab 0x0
[ 5.259841] panel_select fail by _node_status
[ 5.263886] parse_tmds_config: No tmds-config node
[ 5.268772] of_dc_parse_platform_data: could not find vrr-settings node
[ 5.275234] of_dc_parse_platform_data: could not find SD settings node
[ 5.281848] of_dc_parse_platform_data: could not find cmu node
[ 5.287525] of_dc_parse_platform_data: could not find cmu node for adobeRGB
[ 5.294488] tegradc tegradc.1: DT parsed successfully
[ 5.300683] display board info: id 0x0, fab 0x0
[ 5.304336] panel_select fail by _node_status
[ 5.308693] gpio wake53 for gpio=225
[ 5.340802] tegradc tegradc.1: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 5.700093] tegradc tegradc.1: probed
[ 5.702703] tegradc tegradc.1: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 5.725223] Console: switching to colour frame buffer device 240x67
[ 5.761139] tegradc tegradc.1: fb registered
[ 5.766452] tegra_camera_platform tegra-camera-platform.37: tegra_camera_probe:camera_platform_driver probe
[ 5.779716] tegra-apbdma tegra-apbdma: Tegra20 APB DMA driver register 32 channels
[ 5.787626] tegra-adma tegra210-adma: Tegra210 ADMA driver register 10 channels
[ 5.793594] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 5.799459] No Device Node present for smmu client: serial8250 !!
[ 5.805469] No Device Node present for smmu client: serial8250 !!
[ 5.812721] No Device Node present for smmu client: serial8250 !!
[ 5.817594] No Device Node present for smmu client: serial8250 !!
[ 5.824119] of_serial 70006000.serial: RX periodic polling enabled
[ 5.830142] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 68) is a Tegra
[ 5.836791] console [ttyS0] enabled, bootconsole disabled
[ 5.848114] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 69) is a SERIAL_TEGRA
[ 5.857594] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 78) is a SERIAL_TEGRA
[ 5.865993] serial-tegra 70006300.serial: RX in PIO mode
[ 5.871480] 70006300.serial: ttyTHS3 at MMIO 0x70006300 (irq = 122) is a SERIAL_TEGRA
[ 5.897909] tegradc tegradc.1: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 5.907329] brd: module loaded
[ 5.910926] loop: module loaded
[ 5.911465] zram: Created 1 device(s) …
[ 5.911566] nct1008_nct72 0-004c: find device tree node, parsing dt
[ 5.911572] nct1008_nct72 0-004c: starting parse dt
[ 5.911694] nct1008_nct72 0-004c: success parsing dt
[ 5.911844] nct1008_nct72 0-004c: success in enabling rail vdd_nct72
[ 5.987164] tegradc tegradc.1: hdmi: plugged
[ 5.993273] NCT72: Enabled overheat logging at 104.00C
[ 5.998643] gpio wake33 for gpio=188
[ 6.002446] nct1008_nct72 0-004c: nct1008_probe: initialized
[ 6.011759] THERMAL EST start of therm_fan_est_probe.
[ 6.016967] THERMAL EST: found 2 subdevs
[ 6.020963] THERMAL EST name: thermal-fan-est.
[ 6.025506] THERMAL EST num_resources: 0
[ 6.029504] [THERMAL EST subdev 0]
[ 6.032984] THERMAL EST subdev name: CPU-therm
[ 6.037510] THERMAL EST index 0 coeffs 50
[ 6.041632] THERMAL EST index 1 coeffs 0
[ 6.050154] THERMAL EST index 2 coeffs 0
[ 6.058661] THERMAL EST index 3 coeffs 0
[ 6.067175] THERMAL EST index 4 coeffs 0
[ 6.075696] THERMAL EST index 5 coeffs 0
[ 6.084228] THERMAL EST index 6 coeffs 0
[ 6.092670] THERMAL EST index 7 coeffs 0
[ 6.101019] THERMAL EST index 8 coeffs 0
[ 6.109392] THERMAL EST index 9 coeffs 0
[ 6.117713] [THERMAL EST subdev 1]
[ 6.125506] THERMAL EST subdev name: GPU-therm
[ 6.134399] THERMAL EST index 0 coeffs 50
[ 6.142873] THERMAL EST index 1 coeffs 0
[ 6.151168] THERMAL EST index 2 coeffs 0
[ 6.159402] THERMAL EST index 3 coeffs 0
[ 6.167586] THERMAL EST index 4 coeffs 0
[ 6.175732] THERMAL EST index 5 coeffs 0
[ 6.183834] THERMAL EST index 6 coeffs 0
[ 6.191888] THERMAL EST index 7 coeffs 0
[ 6.199851] THERMAL EST index 8 coeffs 0
[ 6.207809] THERMAL EST index 9 coeffs 0
[ 6.215748] THERMAL EST index 0: trip_temp 0, hyst 0
[ 6.224756] THERMAL EST index 1: trip_temp 51000, hyst 15000
[ 6.234418] THERMAL EST index 2: trip_temp 61000, hyst 9000
[ 6.243939] THERMAL EST index 3: trip_temp 71000, hyst 9000
[ 6.253413] THERMAL EST index 4: trip_temp 82000, hyst 10000
[ 6.262942] THERMAL EST index 5: trip_temp 140000, hyst 0
[ 6.272139] THERMAL EST index 6: trip_temp 150000, hyst 0
[ 6.281224] THERMAL EST index 7: trip_temp 160000, hyst 0
[ 6.290278] THERMAL EST index 8: trip_temp 170000, hyst 0
[ 6.299227] THERMAL EST index 9: trip_temp 180000, hyst 0
[ 6.308072] THERMAL EST index 0: trip_temps_hyst 0
[ 6.316218] THERMAL EST index 1: trip_temps_hyst 36000
[ 6.324605] THERMAL EST index 2: trip_temps_hyst 51000
[ 6.332870] THERMAL EST index 3: trip_temps_hyst 52000
[ 6.341044] THERMAL EST index 4: trip_temps_hyst 61000
[ 6.349149] THERMAL EST index 5: trip_temps_hyst 62000
[ 6.357178] THERMAL EST index 6: trip_temps_hyst 71000
[ 6.365214] THERMAL EST index 7: trip_temps_hyst 72000
[ 6.373254] THERMAL EST index 8: trip_temps_hyst 82000
[ 6.381284] THERMAL EST index 9: trip_temps_hyst 140000
[ 6.389350] THERMAL EST index 10: trip_temps_hyst 140000
[ 6.397451] THERMAL EST index 11: trip_temps_hyst 150000
[ 6.405472] THERMAL EST index 12: trip_temps_hyst 150000
[ 6.413395] THERMAL EST index 13: trip_temps_hyst 160000
[ 6.421297] THERMAL EST index 14: trip_temps_hyst 160000
[ 6.429116] THERMAL EST index 15: trip_temps_hyst 170000
[ 6.436839] THERMAL EST index 16: trip_temps_hyst 170000
[ 6.444429] THERMAL EST index 17: trip_temps_hyst 180000
[ 6.451885] THERMAL EST index 18: trip_temps_hyst 180000
[ 6.459299] THERMAL EST index 19: trip_temps_hyst 0
[ 6.466262] THERMAL EST index 20: trip_temps_hyst 0
[ 6.473160] THERMAL EST init dev[0] temp hist to 25000
[ 6.480303] THERMAL EST init dev[1] temp hist to 25000
[ 6.487440] THERMAL EST cdev_type: pwm-fan.
[ 6.493626] THERMAL EST governor name: pid_thermal_gov
[ 6.501235] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est.38
[ 6.512594] THERMAL EST: thz register success.
[ 6.519258] THERMAL EST: end of probe, return err: 0
[ 6.526422] tegra_profiler: Branch: Dev
[ 6.532304] tegra_profiler: Version: 1.104
[ 6.538411] tegra_profiler: Samples version: 34
[ 6.544969] tegra_profiler: IO version: 18
[ 6.551072] armv8_pmu: imp: 0x41, idcode: 0x1
[ 6.557461] armv8_pmu: arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 6.566369] tegra_profiler: auth: init
[ 6.572811] GPS: mt3332_gps_mod_init: platform_driver_register ret = 0
[ 6.582199] tegra-sata tegra-sata.0: version 1.0
[ 6.582869] t210_sata_uphy_pll_init: sata uphy already enabled
[ 6.591698] tegra-sata tegra-sata.0: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl TEGRA-SATA mode
[ 6.603280] tegra-sata tegra-sata.0: flags: 64bit ncq sntf pm led pmp pio slum part sadm apst
[ 6.616005] Rounding down aligned max_sectors from 4294967295 to 4294967288
[ 6.626123] spi-tegra114 7000d400.spi: Static pin configuration used
[ 6.635816] spi-tegra114 7000da00.spi: Static pin configuration used
[ 6.646123] tun: Universal TUN/TAP device driver, 1.6
[ 6.653983] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 6.663238] e1000e: Intel(R) PRO/1000 Network Driver - 2.3.2-k
[ 6.671923] e1000e: Copyright(c) 1999 - 2013 Intel Corporation.
[ 6.681617] PPP generic driver version 2.4.2
[ 6.688927] PPP BSD Compression module registered
[ 6.696557] PPP Deflate Compression module registered
[ 6.704594] PPP MPPE Compression module registered
[ 6.712436] NET: Registered protocol family 24
[ 6.719991] usbcore: registered new interface driver r8152
[ 6.728694] usbcore: registered new interface driver asix
[ 6.737282] usbcore: registered new interface driver ax88179_178a
[ 6.746585] usbcore: registered new interface driver cdc_ether
[ 6.755669] usbcore: registered new interface driver smsc95xx
[ 6.764651] usbcore: registered new interface driver net1080
[ 6.773538] usbcore: registered new interface driver cdc_subset
[ 6.782670] usbcore: registered new interface driver zaurus
[ 6.791486] usbcore: registered new interface driver cdc_ncm
[ 6.800318] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 6.810623] ehci-pci: EHCI PCI platform driver
[ 6.818659] tegra_xusb_read_usb_calib: usb_calib0 = 0x069c6c0e
[ 6.829745] tegra-xhci tegra-xhci: XUSB device id = 0xfac (T210)
[ 6.839418] usb_calib0 = 0x069c6c0e
[ 6.846326] usb_calib_ext = 0x00000004
[ 6.853551] usb_calib0 = 0x069c6c0e
[ 6.860475] usb_calib_ext = 0x00000004
[ 6.867713] usb_calib0 = 0x069c6c0e
[ 6.874671] usb_calib_ext = 0x00000004
[ 6.881944] xusb_prod port0 RX_CTLE = 0xfc
[ 6.889580] xusb_prod port0 RX_DFE = 0xc0077f1f
[ 6.897690] xusb_prod port0 RX_CDR_CTRL = 0x1c7
[ 6.905813] xusb_prod port0 RX_EQ_CTRL_H = 0xfcf01368
[ 6.914538] xusb_prod port1 RX_CTLE = 0xfc
[ 6.922289] xusb_prod port1 RX_DFE = 0xc0077f1f
[ 6.930475] xusb_prod port1 RX_CDR_CTRL = 0x1c7
[ 6.938666] xusb_prod port1 RX_EQ_CTRL_H = 0xfcf01368
[ 6.948496] usbcore: registered new interface driver cdc_acm
[ 6.957943] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 6.969910] usbcore: registered new interface driver cdc_wdm
[ 6.979600] usbcore: registered new interface driver usb-storage
[ 6.989737] usbcore: registered new interface driver usbserial
[ 6.999605] usbcore: registered new interface driver ftdi_sio
[ 7.009385] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 7.020849] usbcore: registered new interface driver option
[ 7.030623] usbserial: USB Serial support registered for GSM modem (1-port)
[ 7.041913] usbcore: registered new interface driver pl2303
[ 7.051807] usbserial: USB Serial support registered for pl2303
[ 7.062120] usbcore: registered new interface driver nvshieldled
[ 7.072501] Nvidia Tegra High-Speed USB Device Controller driver (Apr 30, 2012)
[ 7.084658] tegra USB phy - inst[0] platform info:
[ 7.093833] port_otg: yes
[ 7.100702] has_hostpc: yes
[ 7.107751] phy_interface: USB_PHY_INTF_UTMI
[ 7.116314] op_mode: TEGRA_USB_OPMODE_DEVICE
[ 7.124875] qc2_voltage: 0
[ 7.131864] vbus_pmu_irq: 0
[ 7.138919] charging: enabled
[ 7.146149] remote_wakeup: disabled
[ 7.159029] regulator_get() failed for (tegra-udc.0,usb_bat_chg), -19
[ 7.169776] tegra-udc tegra-udc.0: usb_bat_chg regulator not registered: USB charging will not be enabled
[ 7.184388] mousedev: could not register psaux device, error: -16
[ 7.194856] mousedev: PS/2 mouse device common for all mice
[ 7.204935] usbcore: registered new interface driver xpad
[ 7.214681] usbcore: registered new interface driver usb_acecad
[ 7.224844] usbcore: registered new interface driver aiptek
[ 7.234569] usbcore: registered new interface driver gtco
[ 7.244158] usbcore: registered new interface driver hanwang
[ 7.253914] usbcore: registered new interface driver kbtab
[ 7.263436] usbcore: registered new interface driver wacom
[ 7.372341] max77620-rtc max77620-rtc.1: rtc core: registered max77620-rtc as rtc0
[ 7.431728] Wake51 for irq=118
[ 7.438731] Enabling wake51
[ 7.445498] i2c /dev entries driver
[ 7.454813] i2c i2c-6: of_i2c: modalias failure on /i2c@546c0000/tca6408@21
[ 7.466323] virtual_init
[ 7.473687] [IMX135] sensor driver loading
[ 7.481870] [imx132] sensor driver loading
[ 7.489986] [ar0261] sensor driver loading
[ 7.498230] ov7695 sensor driver loading
[ 7.506196] mt9m114 sensor driver loading
[ 7.514535] pcl-generic pcl-generic: virtual_chip_add
[ 7.525108] usbcore: registered new interface driver uvcvideo
[ 7.535036] USB Video Class driver (1.1.1)
[ 7.544060] max77620-power-off max77620-power-off.4: Event recorder REG_NVERC : 0x0
[ 7.556748] FAN dev name: pwm-fan
[ 7.564340] FAN:gpio request success.
[ 7.572272] pwm_fan_driver pwm-fan.35: cap state:7, cap pwm:255
[ 7.582675] pwm_fan_driver pwm-fan.35: got pwm for fan
[ 7.592281] pwm_fan_driver pwm-fan.35: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 7.604381] pwm_fan_driver pwm-fan.35: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 7.616673] pwm_fan_driver pwm-fan.35: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 7.629075] pwm_fan_driver pwm-fan.35: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 7.641460] pwm_fan_driver pwm-fan.35: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 7.653846] pwm_fan_driver pwm-fan.35: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 7.666203] pwm_fan_driver pwm-fan.35: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 7.678524] pwm_fan_driver pwm-fan.35: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 7.690842] pwm_fan_driver pwm-fan.35: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 7.703251] pwm_fan_driver pwm-fan.35: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 7.717463] tegra_aotag tegra-aotag.21: AOTAG probe started
[ 7.724340] tegradc tegradc.1: hdmi: unplugged
[ 7.724408] tegra_aotag tegra-aotag.21: nominal ft – 105
[ 7.724414] tegra_aotag tegra-aotag.21: tall – 76
[ 7.724420] tegra_aotag tegra-aotag.21: tiddq – 1
[ 7.724425] tegra_aotag tegra-aotag.21: ten-count – 16
[ 7.724432] tegra_aotag tegra-aotag.21: tsample – 9
[ 7.724437] tegra_aotag tegra-aotag.21: pdiv – 8
[ 7.724443] tegra_aotag tegra-aotag.21: nominal cp – 25
[ 7.724448] tegra_aotag tegra-aotag.21: pdiv-ate – 8
[ 7.724454] tegra_aotag tegra-aotag.21: tsamp-ate – 39
[ 7.724461] tegra_aotag tegra-aotag.21: compensation A,B – 10632,-67490
[ 7.724467] tegra_aotag tegra-aotag.21: sensor found :ID 0, Name: aotag0
[ 7.724473] tegra_aotag tegra-aotag.21: reading fuse value for sensor 0
[ 7.724479] tegra_aotag tegra-aotag.21: base-cp:23c shifted-cp:1
[ 7.724486] tegra_aotag tegra-aotag.21: base-ft:4e2 shifted-ft:ffffffff
[ 7.724492] tegra_aotag tegra-aotag.21: actual_aotag_cp 255, ft 1045
[ 7.724500] tegra_aotag tegra-aotag.21: - Tsens calib value - 0x39cbc95
[ 7.724506] tegra_aotag tegra-aotag.21: CPmask 1fff FTmask 3ffe000
[ 7.724512] tegra_aotag tegra-aotag.21: Tsense calib CP - 0x1c95
[ 7.724517] tegra_aotag tegra-aotag.21: Tsense Actual CP d.35733
[ 7.724522] tegra_aotag tegra-aotag.21: Tsense calib FT - 0x1ce5
[ 7.724528] tegra_aotag tegra-aotag.21: Tsense Actual FT d.39205
[ 7.724534] tegra_aotag tegra-aotag.21: delta ts 3472, temp 790
[ 7.724540] tegra_aotag tegra-aotag.21: thermA-858, thermB–843
[ 7.724546] tegra_aotag tegra-aotag.21: Registering sensor 0
[ 7.724590] tegra_aotag tegra-aotag.21: Bound to TZ : ID 0
[ 7.724599] tegra_aotag tegra-aotag.21: shutdown temperature - 55
[ 7.724605] tegra_aotag tegra-aotag.21: AOTAG EN 60
[ 7.724611] tegra_aotag tegra-aotag.21: Probe done [SUCCESS]:0
[ 7.725237] md: raid0 personality registered for level 0
[ 7.725570] device-mapper: uevent: version 1.0.3
[ 7.725939] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[ 7.726442] Tegra210 cpuidle driver
[ 7.728012] sdhci: Secure Digital Host Controller Interface driver
[ 7.728015] sdhci: Copyright(c) Pierre Ossman
[ 7.728018] sdhci-pltfm: SDHCI platform and OF driver helper
[ 7.728457] mmc0: sdhci_tegra_probe line=5655 runtime pm type=mmc rtpm coupled with clock gate, disable-clock-gate=0
[ 7.728484] sdhci-tegra sdhci-tegra.3: Parent select= pll_p rate=408000000
[ 7.728502] sdhci-tegra sdhci-tegra.3: Parent select= pll_c4_out2 rate=199680000
[ 7.729427] sdhci-tegra sdhci-tegra.3: Speedo value 1983
[ 7.729436] sdhci-tegra sdhci-tegra.3: Tuning constraints: nom_mv 1075, boot_mv 1075, min_or_mv 0
[ 7.729536] regulator_get() failed for (sdhci-tegra.3,vqmmc), -19
[ 7.729539] mmc0: no vqmmc regulator found
[ 7.729552] regulator_get() failed for (sdhci-tegra.3,vmmc), -19
[ 7.729555] mmc0: no vmmc regulator found
[ 8.011463] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA
[ 8.019179] mmc1: sdhci_tegra_probe line=5655 runtime pm type=mmc rtpm coupled with clock gate, disable-clock-gate=0
[ 8.029765] sdhci-tegra sdhci-tegra.1: Parent select= pll_p rate=408000000
[ 8.037654] sdhci-tegra sdhci-tegra.1: Speedo value 1983
[ 8.043066] sdhci-tegra sdhci-tegra.1: Tuning constraints: nom_mv 1075, boot_mv 1075, min_or_mv 0
[ 8.052781] regulator_get() failed for (sdhci-tegra.1,vqmmc), -19
[ 8.058899] mmc1: no vqmmc regulator found
[ 8.063028] regulator_get() failed for (sdhci-tegra.1,vmmc), -19
[ 8.069035] mmc1: no vmmc regulator found
[ 8.111463] mmc1: SDHCI controller on sdhci-tegra.1 [sdhci-tegra.1] using ADMA
[ 8.120076] mmc2: sdhci_tegra_probe line=5655 runtime pm type=mmc rtpm coupled with clock gate, disable-clock-gate=0
[ 8.130643] sdhci-tegra sdhci-tegra.0: Parent select= pll_p rate=408000000
[ 8.138615] sdhci-tegra sdhci-tegra.0: Speedo value 1983
[ 8.144074] sdhci-tegra sdhci-tegra.0: Tuning constraints: nom_mv 1075, boot_mv 1075, min_or_mv 0
[ 8.153147] regulator_get() failed for (sdhci-tegra.0,vqmmc), -19
[ 8.159266] mmc2: no vqmmc regulator found
[ 8.163390] regulator_get() failed for (sdhci-tegra.0,vmmc), -19
[ 8.169444] mmc2: no vmmc regulator found
[ 8.169456] mmc0: BKOPS_EN bit is not set
[ 8.211463] mmc2: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA
[ 8.218871] gpio wake35 for gpio=201
[ 8.225749] tegra-se tegra21-se: tegra_se_probe: complete
[ 8.231815] hidraw: raw HID events driver (C) Jiri Kosina
[ 8.239968] usbcore: registered new interface driver usbhid
[ 8.245604] usbhid: USB HID core driver
[ 8.249469] tegra_bootloader_debug: Created tegra_bootloader directory
[ 8.256041] tegra_bootloader_debug: Created sysfs interface tegra_bootloader_verify_regs in tegra_bootloader directory
[ 8.266791] tegra_bootloader_debug: Created sysfs interface tegra_bootloader_prof in tegra_bootloader directory
[ 8.277356] nvadsp 702ef000.adsp: in probe()…
[ 8.283165] nvadsp 702ef000.adsp: AMC/ARAM initialized.
[ 8.288563] nvadsp 702ef000.adsp: nvadsp_app_module_probe
[ 8.297469] tegra_throttle : init passed
[ 8.303313] cpu-tegra: init EDP limit: 1224 MHz
[ 8.308338] pll_x: not ready for dynamic ramp to 614400000
[ 8.315726] mmc0: tap value and tuning window after hw tuning completion …
[ 8.315733] mmc0: tuning_window[0]: 0xffffffff
[ 8.315739] mmc0: tuning_window[1]: 0xffffffc7
[ 8.315744] mmc0: tuning_window[2]: 0xffff8fff
[ 8.315749] mmc0: tuning_window[3]: 0x7f8fffff
[ 8.315753] mmc0: tuning_window[4]: 0x0
[ 8.315758] mmc0: tuning_window[5]: 0x0
[ 8.315762] mmc0: tuning_window[6]: 0x0
[ 8.315767] mmc0: tuning_window[7]: 0x0
[ 8.315771] sdhci: Tap value: 56 | Trim value: 8
[ 8.315775] sdhci: SDMMC Interrupt status: 0x00040000
[ 8.316366] mmc0: switch to HS400 mode is successful
[ 8.320376] mmc0: new HS400 MMC card at address 0001
[ 8.320908] mmcblk0: mmc0:0001 016G32 14.6 GiB
[ 8.321129] mmcblk0rpmb: mmc0:0001 016G32 partition 3 4.00 MiB
[ 8.321495] pll_x: not ready for dynamic ramp to 614400000
[ 8.322726] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18
[ 8.323449] soctherm: skipping sensor 4 programming
[ 8.323454] soctherm: skipping sensor 5 programming
[ 8.336462] usbcore: registered new interface driver snd-usb-audio
[ 8.336589] No Device Node present for smmu client: snd-soc-dummy !!
[ 8.336601] No Device Node present for smmu client: snd-soc-dummy !!
[ 8.337057] No Device Node present for smmu client: snd-soc-dummy !!
[ 8.337131] No Device Node present for smmu client: snd-soc-dummy !!
[ 8.338422] Codec driver version 0.4 alsa 1.0.25
[ 8.343222] tegra-i2c 7000c000.i2c: no acknowledge from address 0x1b
[ 8.343333] rt5659 0-001b: Device with ID register ffffffc0 is not rt5659
[ 8.355269] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 8.362045] tegra210-i2s tegra210-i2s.0: Missing prop fsync-width for I2S0
[ 8.363315] tegra210-i2s tegra210-i2s.2: Missing prop fsync-width for I2S2
[ 8.363699] tegra210-i2s tegra210-i2s.3: Missing prop fsync-width for I2S3
[ 8.364192] tegra210-i2s tegra210-i2s.4: Missing prop fsync-width for I2S4
[ 8.366071] tegradc tegradc.1: unblank
[ 8.374221] OPE platform probe
[ 8.374626] OPE platform probe successful
[ 8.374700] OPE platform probe
[ 8.375103] OPE platform probe successful
[ 8.375408] tegra210_adsp_audio_platform_probe: platform probe started
[ 8.377094] tegra210-adsp adsp_audio.3: Default param-type to BYTE for mp3-dec1
[ 8.377443] tegra210-adsp adsp_audio.3: Default param-type to BYTE for spkprot
[ 8.377917] tegra210-adsp adsp_audio.3: Default param-type to BYTE for src
[ 8.378298] tegra210-adsp adsp_audio.3: Default param-type to BYTE for aac-dec1
[ 8.385861] tegra210_adsp_audio_platform_probe probe successfull.
[ 8.385862] tegra-snd-t210ref-mobile-rt565x sound.18: ASoC: CODEC (null) not registered
[ 8.385914] tegra-snd-t210ref-mobile-rt565x sound.18: snd_soc_register_card failed (-517)
[ 8.385959] platform sound.18: Driver tegra-snd-t210ref-mobile-rt565x requests probe deferral
[ 8.387154] GACT probability NOT on
[ 8.387164] Mirror/redirect action on
[ 8.387171] u32 classifier
[ 8.387173] Actions configured
[ 8.387181] Netfilter messages via NETLINK v0.30.
[ 8.387264] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 8.387834] ctnetlink v0.93: registering with nfnetlink.
[ 8.387982] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 8.387985] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 8.388467] xt_time: kernel timezone is -0000
[ 8.388619] ipip: IPv4 over IPv4 tunneling driver
[ 8.388740] tegradc tegradc.1: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 8.389274] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 8.389494] arp_tables: (C) 2002 David S. Miller
[ 8.389550] TCP: cubic registered
[ 8.389554] Initializing XFRM netlink socket
[ 8.390232] NET: Registered protocol family 10
[ 8.391526] mip6: Mobile IPv6
[ 8.391576] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 8.391797] sit: IPv6 over IPv4 tunneling driver
[ 8.393070] NET: Registered protocol family 17
[ 8.393106] NET: Registered protocol family 15
[ 8.393116] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 8.393131] Bluetooth: HIDP socket layer initialized
[ 8.393165] NET: Registered protocol family 35
[ 8.393250] Key type dns_resolver registered
[ 8.393257] NET: Registered protocol family 41
[ 8.396049] Registering SWP/SWPB emulation handler
[ 8.453174] isp isp.0: initialized
[ 8.454900] isp isp.1: initialized
[ 8.455479] vdd_gpu: disabling
[ 8.456414] en-vdd-cam-1v2: disabling
[ 8.457433] en-vdd-cam-hv-2v8: disabling
[ 8.458470] en-vdd-disp-1v8: disabling
[ 8.459507] en-mdm-pwr-3v7: disabling
[ 8.460545] en-vdd-disp-3v3: disabling
[ 8.461587] en-vdd-ts-hv-3v3: disabling
[ 8.462647] en-vdd-ts-1v8: disabling
[ 8.463685] usb-vbus3: disabling
[ 8.463700] usb-vbus1: disabling
[ 8.463728] vdd-fan: disabling
[ 8.470925] vdd-disp-3v0: disabling
[ 8.470931] snsr_pm: disabling
[ 8.470935] aux-3v3: disabling
[ 8.470940] en-vdd-cam: disabling
[ 8.471927] lcd-bl-en: disabling
[ 8.471933] max77620-gpio7: disabling
[ 8.485373] vdd-cpu-fixed: disabling
[ 8.485378] regulator-dummy: disabling
[ 8.487001] tegra-snd-t210ref-mobile-rt565x: probe of sound.18 failed with error -16
[ 8.488539] gpio wake24 for gpio=189
[ 8.488678] gpio wake27 for gpio=192
[ 8.488781] gpio wake25 for gpio=190
[ 8.489086] input: gpio-keys as /devices/platform/gpio-keys.39/input/input0
[ 8.543938] max77620-rtc max77620-rtc.1: setting system clock to 2013-01-01 00:00:00 UTC (1356998400)
[ 8.544635] [dram-timers] DRAM derating cdev registered.
[ 8.544659] Disable partitions left on by BL
[ 8.544663] sata
[ 8.544805] disb
[ 8.544843] Disabling clocks left on by bootloader:
[ 8.544846] audio2_dmic
[ 8.544851] audio1_dmic
[ 8.544856] audio0_dmic
[ 8.544860] audio_2x
[ 8.544868] audio
[ 8.544873] audio4
[ 8.544877] audio3
[ 8.544882] audio2
[ 8.544886] audio1
[ 8.544891] audio0
[ 8.544982] entropy
[ 8.544999] dsi2-fixed
[ 8.545003] dsi1-fixed
[ 8.545047] sdmmc4_ddr
[ 8.545059] sdmmc1_ddr
[ 8.545129] cclk_lp
[ 8.546193] tegra_cl_dvfs 70110000.dfll-ovr: DT data retrieved successfully
[ 8.546433] tune_cpu_trimmers: init soctherm cpu zone LOW
[ 8.546983] Tegra CPU DFLL is initialized with use_dfll = 1
[ 8.547221] tegra_dvfs: 0.vdd-cpu-rail-ovr connected to regulator
[ 8.547625] tegra_cl_dvfs_init_cdev: cpu_cold cooling device registered
[ 8.547749] tegra_cl_dvfs_init_cdev: cpu_hot cooling device registered
[ 8.548129] tegra_dvfs: 4.vdd-core-rail-max77620 connected to regulator
[ 8.548364] tegra_dvfs: 1.vdd-gpu-rail-ovr connected to regulator
[ 8.552184] mmc1: tap value and tuning window after hw tuning completion …
[ 8.552193] mmc1: tuning_window[0]: 0xe7ffffff
[ 8.552199] mmc1: tuning_window[1]: 0xffffffff
[ 8.552204] mmc1: tuning_window[2]: 0xfffffff9
[ 8.552209] mmc1: tuning_window[3]: 0x7ffffe3f
[ 8.552215] mmc1: tuning_window[4]: 0x0
[ 8.552220] mmc1: tuning_window[5]: 0x0
[ 8.552226] mmc1: tuning_window[6]: 0x0
[ 8.552231] mmc1: tuning_window[7]: 0x0
[ 8.552236] sdhci: Tap value: 46 | Trim value: 8
[ 8.552240] sdhci: SDMMC Interrupt status: 0x00040000
[ 8.552388] CPU rate: 614 MHz
[ 8.552818] last reset is due to power on reset
[ 8.552818]
[ 8.552821] KERNEL: PMC reset status reg: 0x0
[ 8.553520] tegra_actmon.emc: Completed initialization (0)
[ 8.554057] tegra_actmon.avp: Completed initialization (0)
[ 8.556238] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 8.556274] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 8.739553] tegradc tegradc.1: unblank
[ 8.796651] tegra dvfs: tegra sysfs cap interface is initialized
[ 8.796706] tegra dvfs: tegra sysfs gpu interface is initialized
[ 8.797995] ALSA device list:
[ 8.797999] #0: HDA NVIDIA Tegra at 0x70038000 irq 113
[ 9.766601] tegradc tegradc.1: hdmi: plugged
[ 9.768372] md: Waiting for all devices to be available before autodetect
[ 9.768374] md: If you don’t use raid, use raid=noautodetect
[ 9.768721] md: Autodetecting RAID arrays.
[ 9.768723] md: Scanned 0 and added 0 devices.
[ 9.768725] md: autorun …
[ 9.768726] md: … autorun DONE.
[ 9.769893] EXT4-fs (mmcblk0p1): couldn’t mount as ext3 due to feature incompatibilities
[ 9.770205] EXT4-fs (mmcblk0p1): couldn’t mount as ext2 due to feature incompatibilities
[ 9.773769] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 9.773791] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 9.775423] devtmpfs: mounted
[ 9.775553] Freeing unused kernel memory: 432K (ffffffc001084000 - ffffffc0010f0000)
[ 9.775559] Freeing alternatives memory: 52K (ffffffc0010f1000 - ffffffc0010fe000)
[ 9.982259] init: plymouth-upstart-bridge main process (131) terminated with status 1
[ 9.992365] init: plymouth-upstart-bridge main process ended, respawning
[ 10.022066] init: plymouth-upstart-bridge main process (141) terminated with status 1
[ 10.031800] init: plymouth-upstart-bridge main process ended, respawning
[ 10.042177] init: ureadahead main process (134) terminated with status 5
[ 10.060894] init: plymouth-upstart-bridge main process (145) terminated with status 1
[ 10.070660] init: plymouth-upstart-bridge main process ended, respawning
[ 10.483158] systemd-udevd[296]: starting version 204
[ 10.615706] gpio wake52 for gpio=61
[ 10.647226] vi vi: vi_probe: ++
[ 10.650722] vi vi: initialized
[ 10.788331] tegra-xhci tegra-xhci: Firmware File: tegra21x_xusb_firmware (132608 Bytes)
[ 10.788550] tegra-xhci tegra-xhci: Firmware DMA Memory: dma 0x0000000080080000 mapped 0xffffff8000641000 (132608 Bytes)
[ 10.788559] tegra-xhci tegra-xhci: num_hsic_port 0
[ 10.789934] cfg80211: Calling CRDA to update world regulatory domain
[ 10.792934] tegra-xhci tegra-xhci: Firmware timestamp: 2016-01-07 06:59:07 UTC, Version: 50.12 release, Falcon state 0x20
[ 10.793064] tegra-xhci tegra-xhci: Nvidia xHCI Host Controller
[ 10.793113] tegra-xhci tegra-xhci: new USB bus registered, assigned bus number 1
[ 10.793964] tegra-xhci tegra-xhci: irq 71, io mem 0x70090000
[ 10.794092] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 10.794125] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 10.794133] usb usb1: Product: Nvidia xHCI Host Controller
[ 10.794140] usb usb1: Manufacturer: Linux 3.10.67-g458d45c tegra-xhci
[ 10.794147] usb usb1: SerialNumber: tegra-xhci
[ 10.795052] xHCI xhci_add_endpoint called for root hub
[ 10.795061] xHCI xhci_check_bandwidth called for root hub
[ 10.795193] hub 1-0:1.0: USB hub found
[ 10.795251] hub 1-0:1.0: 5 ports detected
[ 10.795822] sdhci-tegra sdhci-tegra.1: Card already in requested state
[ 10.798249] sdhci-tegra sdhci-tegra.1: Card already in requested state
[ 10.851644] tegra-xhci tegra-xhci: Nvidia xHCI Host Controller
[ 10.851667] tegra-xhci tegra-xhci: new USB bus registered, assigned bus number 2
[ 10.851842] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 10.851853] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 10.851860] usb usb2: Product: Nvidia xHCI Host Controller
[ 10.851867] usb usb2: Manufacturer: Linux 3.10.67-g458d45c tegra-xhci
[ 10.851874] usb usb2: SerialNumber: tegra-xhci
[ 10.852175] xHCI xhci_add_endpoint called for root hub
[ 10.852182] xHCI xhci_check_bandwidth called for root hub
[ 10.852291] hub 2-0:1.0: USB hub found
[ 10.852316] hub 2-0:1.0: 4 ports detected
[ 10.866879] dhd_module_init in
[ 10.867858] Power-up adapter ‘DHD generic adapter’
[ 10.870015] wifi_platform_set_power = 1
[ 10.911586] Wake44 for irq=81
[ 10.911612] Wake40 for irq=53
[ 10.911618] Wake41 for irq=53
[ 10.911623] Wake42 for irq=53
[ 10.911626] Wake43 for irq=53
[ 10.928752] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 10.928780] Bluetooth: BNEP socket layer initialized
[ 10.967514] Bluetooth: RFCOMM TTY layer initialized
[ 10.967584] Bluetooth: RFCOMM socket layer initialized
[ 10.967591] Bluetooth: RFCOMM ver 1.11
[ 11.071673] wifi_platform_bus_enumerate device present 1
[ 11.088965] SDIO Vendor ID:02d0 and SDIO Device ID: 4354
[ 11.089219] F1 signature read @0x18000000=0x17214354
[ 11.103142] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 11.104034] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 11.104120] wifi_platform_prealloc: failed to alloc static mem section 7
[ 11.104134] wifi_platform_get_mac_addr
[ 11.104754] wl_create_event_handler(): thread:wl_event_handler:1dc started
[ 11.104759] CFG80211-ERROR) wl_event_handler : tsk Enter, tsk = 0xffffffc0fa2219f0
[ 11.104929] dhd_attach(): thread:dhd_watchdog_thread:1dd started
[ 11.104978] dhd_attach(): thread:dhd_dpc:1de started
[ 11.105026] dhd_attach(): thread:dhd_rxf:1df started
[ 11.105038] dhd_deferred_work_init: work queue initialized
[ 11.105304] Dongle Host Driver, version 1.201.82 (r)
[ 11.105304] Compiled in drivers/net/wireless/bcmdhd on Feb 8 2016 at 17:41:49
[ 11.105677] Register interface [wlan0] MAC: 00:04:4b:63:3d:7e
[ 11.105677]
[ 11.105688] dhd_prot_ioctl : bus is down. we have nothing to do
[ 11.106992] wifi_platform_set_power = 0
[ 11.117131] cfg80211: World regulatory domain updated:
[ 11.117142] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 11.117151] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 11.117158] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 11.117164] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 11.117170] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 11.117176] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 11.311457] tegra_sysfs_register
[ 11.331937] usb 2-1: new SuperSpeed USB device number 2 using tegra-xhci
[ 11.353418] usb 2-1: New USB device found, idVendor=0955, idProduct=09ff
[ 11.353423] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[ 11.353426] usb 2-1: Product: USB 10/100/1000 LAN
[ 11.353428] usb 2-1: Manufacturer: Nvidia
[ 11.353431] usb 2-1: SerialNumber: 000001000000
[ 11.360167] cdc_ether 2-1:2.0 eth0: register ‘cdc_ether’ at usb-tegra-xhci-1, CDC Ethernet Device, 00:04:4b:63:3d:80
[ 11.366103] cdc_ether 2-1:2.0 eth0: unregister ‘cdc_ether’ usb-tegra-xhci-1, CDC Ethernet Device
[ 11.542304] usb 2-1: reset SuperSpeed USB device number 2 using tegra-xhci
[ 11.603902] r8152 2-1:1.0 eth0: v2.03.3 (2015/01/29)
[ 11.603914] r8152 2-1:1.0 eth0: This product is covered by one or more of the following patents:
[ 11.603914] US6,570,884, US6,115,776, and US6,327,625.
[ 11.603914]
[ 12.024574] init: failsafe main process (605) killed by TERM signal
[ 12.043376] init: Failed to obtain startpar-bridge instance: Unknown parameter: INSTANCE
[ 12.329450]
[ 12.329450] Dongle Host Driver, version 1.201.82 (r)
[ 12.329450] Compiled in drivers/net/wireless/bcmdhd on Feb 8 2016 at 17:41:49
[ 12.329462] wl_android_wifi_on in
[ 12.329468] wifi_platform_set_power = 1
[ 12.638235] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 12.701647] init: plymouth-upstart-bridge main process ended, respawning
[ 12.720464] SDIO Vendor ID:02d0 and SDIO Device ID: 4354
[ 12.721004] F1 signature read @0x18000000=0x17214354
[ 12.730652] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 12.731406] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 12.876874] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 12.878851] gk20a gpu.0: GPCPLL initial settings: NA mode, M=1, N=34, P=3
[ 12.926935] SDIO Vendor ID:02d0 and SDIO Device ID: 4354
[ 12.926983] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[ 12.927467] gpio wake8 for gpio=58
[ 12.927472] Enabling wake8
[ 12.929352] wifi_platform_get_mac_addr
[ 12.932287] Firmware up: op_mode=0x0005, MAC=00:04:4b:63:3d:7e
[ 12.939063] dhd_preinit_ioctls pspretend_threshold for HostAPD failed -23
[ 12.945135] Firmware version = wl0: Jan 27 2016 22:30:13 version 7.35.221.7 (r615597) FWID 01-7ec88390
[ 12.948053] dhd_interworking_enable: failed to set WNM info, ret=-23
[ 12.948263] tegra_sysfs_on
[ 13.015159] dhd_ndo_add_ip: ndo ip addr add failed, retcode = -23
[ 13.015170] dhd_inet6_work_handler: Adding host ip for NDO failed -23
[ 13.102114] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 13.151058] tegradc tegradc.1: blank - powerdown
[ 13.213553] tegradc tegradc.1: unblank
[ 13.242095] tegradc tegradc.1: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 13.593442] tegradc tegradc.1: unblank
[ 13.609689] tegradc tegradc.1: first frame flipped [25648035]us
[ 13.874884] tegradc tegradc.1: blank - powerdown
[ 13.940084] tegradc tegradc.1: unblank
[ 13.965323] tegradc tegradc.1: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 14.653514] tegradc tegradc.1: blank - powerdown
[ 14.723916] tegradc tegradc.1: unblank
[ 14.752468] tegradc tegradc.1: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 15.105862] tegradc tegradc.1: unblank
[ 15.405174] tegradc tegradc.1: blank - powerdown
[ 15.487225] tegradc tegradc.1: unblank
[ 15.512465] tegradc tegradc.1: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 15.882685] init: lightdm main process (919) terminated with status 1
[ 15.889551] init: plymouth-ready (startup) main process (130) terminated with status 1
[ 18.820589] tegradc tegradc.1: blank - normal
[ 18.893961] tegradc tegradc.1: unblank
[ 55.413276] usb 1-3: new full-speed USB device number 3 using tegra-xhci
[ 55.438880] usb 1-3: New USB device found, idVendor=0f39, idProduct=0825
[ 55.439006] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 55.439102] usb 1-3: Product: K82H
[ 55.439196] usb 1-3: Manufacturer: Heng Yu Technology
[ 55.442867] usb 1-3: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 55.443163] usb 1-3: ep 0x82 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 55.454579] input: Heng Yu Technology K82H as /devices/platform/tegra-xhci/usb1/1-3/1-3:1.0/input/input1
[ 55.456392] hid-generic 0003:0F39:0825.0001: input,hidraw0: USB HID v1.10 Keyboard [Heng Yu Technology K82H] on usb-tegra-xhci-3/input0
[ 55.463337]
I could see Xorg start up configure:
Seciton “Monitor”
identifier “DSI-0”
Option “ignore”
End Section
Is it right?
R23.2 is old and works only with 32-bit on user space; unless you require 32-bit user space I’d recommend flashing to R24.2.1 (this is the current release, direct flash or the most recent JetPack would both install this). Do you require some form of backwards compatibility with older 32-bit?
The DSI part looks correct (Jetsons have both HDMI and DSI/eDP available even if you only have an HDMI connector).
Have you tried yet with all USB removed? I’m still curious about the USB PHY error listed earlier in combination with USB power error.
hi,could you tell me how to reflash software
Here is the download page for flash related software (currently R24.2.1):
https://developer.nvidia.com/embedded/linux-tegra
If you download JetPack, then JetPack will handle most downloads and setup for many extras. This requires your desktop host to have Ubuntu 14.04 on it. This has instructions with it.
If you just want to flash, then your desktop host can be any 64-bit Linux. In that case you’d download the “driver package” plus the “sample rootfs”.
In the case of just flash, you’d unpack the driver package. This produces subdirectory “Linux_for_Tegra”. Within that is subdirectory “rootfs”. You’d use sudo to unpack the sample rootfs into that directory. Once sample rootfs is there, cd back to the “Linux_for_Tegra” directory and use sudo to run “./apply_binaries.sh”. At that point you can put your Jetson in recovery mode (hold down the recovery button while tapping power up or power reset). Be sure to use the supplied micro-B USB cable for this. To verify recovery mode your host will have output from the command “lsusb -d 0955:7721”.
To start the flash, use sudo:
sudo ./flash.sh -S 14580MiB jetson-tx1 mmcblk0p1
Note that this takes time, and you should probably have about 25GB or more of free disk on your host before starting flash.sh.
I have reflashed the software and enter the 16.4 version, but fail to find the wifi selection, how to install the wifi driver , is it a small demo version, is there a more complete version
Someone who knows more about WiFi will have to answer that. Mostly it is an “Ubuntu” admin topic, but there may be parts of it which are specific to a Jetson (most of what you find on the web for WiFi setup will be exactly correct on a Jetson).
Hi, found that I could not use sudo command in the system.
Could you tell me how to do it?
And I found that when I operate shut down , it will remain in the black screen for 2 minutes and power off.
Is that normal?
Is the sudo failure on the Jetson? On a Jetson, if sudo does not work, it is usually because its permissions are incorrect. This will always happen if the sample rootfs was not unpacked sudo on the host (other failures occur if apply_binaries.sh is not run sudo). On your sample rootfs “rootfs/usr/bin/sudo” should show up as having these permissions via “ls -l sudo”:
-rwsr-xr-x. 1 root root 128480 May 4 2016 sudo*
On your host a user account must be part of the administrative group(s) to get full sudo access (see “man usermod”…it’s the “-G” option for adding supplemental groups). On some systems this is group “wheel” (check “/etc/group” to see if the group exists); on other systems it may be some other combination of groups. FYI, user ubuntu on a default Ubuntu install works as admin because of being in other groups besides its normal self-name group “ubuntu”. If you are on an Ubuntu system and need to be an admin, just look at all of the “/etc/group” memberships which “ubuntu” has (except of course group “ubuntu”…this is private to ubuntu and not related to an admin role).
FYI, the black screen for 2 minutes on shutdown is not normal. Quite possibly if permissions are incorrect this would be a side-effect. A serial console would show what’s going on during that time. If you want to use a serial console see this:
http://elinux.org/Jetson/TX1_Serial_Console
