Jetson TX1 stuck on book after updating
I recently started using my jetson after forgetting about it for a year. I booted it up and ubuntu asked me to update so not thinking I did. Now when I try to boot up it gets stuck on
systemd[1]: Started Journal Service.
but I can still SSH into it and access everything. Not really sure what to do
A serial console boot log would be nice, but given ssh works, the output of “dmesg” would also be useful. You can either highlight the log and then click on the “code” icon “</>”, or attach it as a file (requires hovering the mouse over the quote icon in an existing post, and then using the paper clip icon which will show up during mouse hover).
Also, what do you see from “df -H -T” and “lsblk -f”?
dmesg
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 3.10.96-tegra (buildbrain@mobile-u64-886) (gcc version 4.8.2 (GCC) ) #1 SMP PREEMPT Sat Jan 14 13:20:56 PST 2017
[    0.000000] CPU: Cortex A57 Processor [411fd071] revision 1
[    0.000000] alternative: enabling workaround for ARM erratum 832075
[    0.000000] Machine: jetson_tx1
[    0.000000] bootconsole [earlycon0] enabled
[    0.000000] Reserved memory: initialized node iram-carveout, compatible id nvidia,iram-carveout
[    0.000000] Tegra reserved memory:
               LP0:                    ff2bf000 - ff2bffff
               Bootloader framebuffer: 00000000 - 00000000
               Bootloader framebuffer2: 00000000 - 00000000
               Framebuffer:            00000000 - 00000000
               2nd Framebuffer:        00000000 - 00000000
               Carveout:               00000000 - 00000000
               Vpr:                    00000000 - 00000000
               Tsec:                   00000000 - 00000000
               Bootloader Debug Data:  00000000 - 00000000
[    0.000000] Nvdumper:               ff23f000 - ff23ffff
[    0.000000] cma: CMA: reserved 16 MiB at fdc00000
[    0.000000] On node 0 totalpages: 1043968
[    0.000000]   DMA32 zone: 7168 pages used for memmap
[    0.000000]   DMA32 zone: 0 pages reserved
[    0.000000]   DMA32 zone: 519680 pages, LIFO batch:31
[    0.000000]   Normal zone: 7168 pages used for memmap
[    0.000000]   Normal zone: 524288 pages, LIFO batch:31
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv0.2 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/arch/arm64/boot/dts/tegra210-jetson-tx1-p2597-2180-a01-devkit.dts
[    0.000000] DTB Build time: Jan 14 2017 13:16:31
[    0.000000] Tegra21: Speedo/IDDQ fuse revision 4
[    0.000000] Tegra21: CPU Speedo ID 7, Soc Speedo ID 0, Gpu Speedo ID 2
[    0.000000] Tegra21: CPU Process ID 0, Soc Process ID 0, Gpu Process ID 0
[    0.000000] Tegra21: CPU Speedo value 2029, Soc Speedo value 1933, Gpu Speedo value 2031
[    0.000000] Tegra21: CPU IDDQ 1684, Soc IDDQ 1888, Gpu IDDQ 2210
[    0.000000] Tegra Revision: A02 SKU: 0x17 CPU Process: 0 Core Process: 0 Bootrom patch v0x3f
[    0.000000] tegra: PLLP fixed rate: 408000000
[    0.000000] pll_u: boot with h/w control already set
[    0.000000] pll_x boot misc1 0x0 : expected 0x20
[    0.000000]  (comparison mask = 0xffffff)
[    0.000000] pll_c4 rates match 204000000 max sdmmc: vco=998400000 out0=998400000 out3=998400000
[    0.000000] Lowering vic03 maximum rate from 1000000000 to 627200000
[    0.000000] Lowering nvjpg maximum rate from 1000000000 to 627200000
[    0.000000] Lowering se maximum rate from 1000000000 to 627200000
[    0.000000] Lowering tsecb maximum rate from 1000000000 to 627200000
[    0.000000] Lowering msenc maximum rate from 1000000000 to 716800000
[    0.000000] Lowering nvdec maximum rate from 1000000000 to 716800000
[    0.000000] Lowering vi maximum rate from 1000000000 to 793600000
[    0.000000] Lowering isp maximum rate from 1000000000 to 793600000
[    0.000000] Lowering adsp_bus maximum rate from 1200000000 to 844800000
[    0.000000] Lowering sbus maximum rate from 600000000 to 408000000
[    0.000000] Lowering host1x maximum rate from 600000000 to 408000000
[    0.000000] Lowering pll_c maximum rate from 1200000000 to 1130000000
[    0.000000] Lowering pll_c2 maximum rate from 1200000000 to 1130000000
[    0.000000] Lowering pll_c3 maximum rate from 1200000000 to 1130000000
[    0.000000] Lowering pll_d2 maximum rate from 1500000000 to 1130000000
[    0.000000] Lowering pll_dp maximum rate from 1500000000 to 1130000000
[    0.000000] Lowering sor0 maximum rate from 600000000 to 540000000
[    0.000000] Lowering sor1 maximum rate from 600000000 to 594000000
[    0.000000] Lowering dmic1 maximum rate from 12288000 to 12190000
[    0.000000] Lowering dmic2 maximum rate from 12288000 to 12190000
[    0.000000] Lowering dmic3 maximum rate from 12288000 to 12190000
[    0.000000] Lowering hda maximum rate from 102000000 to 51000000
[    0.000000] Lowering sdmmc2 maximum rate from 266000000 to 204000000
[    0.000000] Lowering qspi maximum rate from 163200000 to 116600000
[    0.000000] Lowering gbus maximum rate from 1300000000 to 998400000
[    0.000000] Lowering cpu_g maximum rate from 3000000000 to 1734000000
[    0.000000] Lowering cpu_lp maximum rate from 1350000000 to 1132800000
[    0.000000] tegra dvfs: vdd_cpu: nominal 1226mV, offset 708000uV, step 19200uV, scaling enabled
[    0.000000] tegra dvfs: vdd_core: nominal 1125mV, offset 0uV, step 12500uV, scaling enabled
[    0.000000] tegra dvfs: vdd_gpu: nominal 1110mV, offset 710000uV, step 10000uV, scaling enabled
[    0.000000] Tegra reset control registration success
[    0.000000] tegra_powergate_init: DONE
[    0.000000] PERCPU: Embedded 13 pages/cpu @ffffffc01fecf000 s20800 r8192 d24256 u53248
[    0.000000] pcpu-alloc: s20800 r8192 d24256 u53248 alloc=13*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 1029632
[    0.000000] Kernel command line: fbcon=map:0 console=tty0 console=ttyS0,115200n8 androidboot.modem=none androidboot.serialno=P2180A00P00940c003fd androidboot.security=non-secure tegraid=21.1.2.0.0 ddr_die=2048M@2048M ddr_die=2048M@4096M section=256M memtype=0 usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 debug_uartport=lsport,0 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff2bf000 nvdumper_reserved=0xff23f000 core_edp_mv=1125 core_edp_ma=4000 gpt android.kerneltype=normal androidboot.touch_vendor_id=0 androidboot.touch_panel_id=63 androidboot.touch_feature=0 androidboot.bootreason=pmc:software_reset,pmic:0x0 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] Memory: 2030MB 2048MB = 4078MB total
[    0.000000] Memory: 4061648k/4061648k available, 114224k reserved
[    0.000000] Virtual kernel memory layout:
                   vmalloc : 0xffffff8000000000 - 0xffffffbbffff0000   (245759 MB)
                   vmemmap : 0xffffffbc01c00000 - 0xffffffbc05400000   (    56 MB)
                   modules : 0xffffffbffc000000 - 0xffffffc000000000   (    64 MB)
                   memory  : 0xffffffc000000000 - 0xffffffc100000000   (  4096 MB)
                     .init : 0xffffffc00114f000 - 0xffffffc0011ba140   (   429 kB)
                     .text : 0xffffffc000080000 - 0xffffffc00114e3a4   ( 17209 kB)
                     .data : 0xffffffc0011ce000 - 0xffffffc00139e7f0   (  1858 kB)
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000] NR_IRQS:704 nr_irqs:704 0
[    0.000000] the number of interrupt controllers found is 6
[    0.000000] Architected local timer running at 19.20MHz (phys).
[    0.000000] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 3579139424256ns
[    0.000000] Console: colour dummy device 80x25
[    0.000000] console [tty0] enabled
[    0.000000] allocated 16777216 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[    0.023567] Calibrating delay loop (skipped), value calculated using timer frequency.. lpj=192000
[    0.032375] pid_max: default: 32768 minimum: 301
[    0.037066] Security Framework initialized
[    0.041096] Mount-cache hash table entries: 256
[    0.099637] Initializing cgroup subsys debug
[    0.101943] Initializing cgroup subsys memory
[    0.106279] Initializing cgroup subsys devices
[    0.110679] Initializing cgroup subsys freezer
[    0.115088] Initializing cgroup subsys net_cls
[    0.119507] Initializing cgroup subsys blkio
[    0.123762] Initializing cgroup subsys perf_event
[    0.128625] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available
[    0.170263] ftrace: Allocated trace_printk buffers
[    0.230800] Brought up 4 CPUs
[    0.231778] SMP: Total of 4 processors activated.
[    0.236469] alternatives: patching kernel code
[    0.243417] devtmpfs: initialized
[    0.253631] pinctrl core: initialized pinctrl subsystem
[    0.257085] regulator-dummy: ; Rail ON
[    0.260934] Initializing plugin-manager
[    0.265173] node /plugin-manager/fragement@0 match with board >=2180-1000-300
[    0.272093] NET: Registered protocol family 16
[    0.277859] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.283439] console [pstore-1] enabled
[    0.286594] ramoops: attached 0x200000@0xff03f000, ecc: 0/0
[    0.292420] I2C first dynamic bus number based on alias = 7
[    0.297718] cpuidle: using governor ladder
[    0.301767] cpuidle: using governor menu
[    0.306393] PMC: Setting PMIC interrupt active-low
[    0.311135] tegra-pmc device create success
[    0.314632] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[    0.321790] Clear bootloader IO dpd settings
[    0.326023] PMC: configuring io pad defaults
[    0.330453] PMC: IO pad audio voltage is 1800000
[    0.334962] PMC: IO pad cam voltage is 1800000
[    0.339381] PMC: IO pad dbg voltage is 1800000
[    0.343811] PMC: IO pad dmic voltage is 1800000
[    0.348309] PMC: IO pad pex-ctrl voltage is 1800000
[    0.353170] PMC: IO pad spi voltage is 1800000
[    0.357582] PMC: IO pad uart voltage is 1800000
[    0.362097] PMC: IO pad bb voltage is 1800000
[    0.366421] PMC: IO pad audio-hv voltage is 1800000
[    0.371283] PMC: IO pad spi-hv voltage is 1800000
[    0.375955] PMC: IO pad gpio voltage is 1800000
[    0.380470] PMC: IO pad sdmmc3 voltage is 1800000
[    0.385050] PMC: IO pad pex-bias power is disable
[    0.389729] PMC: IO pad pex-clk1 power is disable
[    0.394416] PMC: IO pad pex-clk2 power is disable
[    0.399080] T210 pmc padctrl driver initialized
[    0.403629] T210 pmc config for bootrom command passed
[    0.409599] INFO: pinmux CLAMP_INPUTS_WHEN_TRISTATED: disabled
[    0.416270] clk_init_from_dt_table: clocks are set from t210-clk-init-table:clkinit-0
[    0.424387] platform tegra-carveouts.23: SMMU isn't ready yet
[    0.428631] platform tegra-carveouts.23: domain=ffffffc0fe238ed8 allocates as[0]=ffffffc0fe23c0a8
[    0.437031] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[    0.443584] bpmp: connect returned 0
[    0.446952] mapped MMIO address: 0xffffff8000038000 -> 0x70019000
[    0.452654] mapped MMIO address: 0xffffff800005e000 -> 0x7001c000
[    0.458698] mapped MMIO address: 0xffffff8000096000 -> 0x7001d000
[    0.465614] Wake16 for irq=34
[    0.472951] tegra210-pinctrl 700008d4.pinmux: lookup the user state drive not found
[    0.478613] tegra210-pinctrl 700008d4.pinmux: lookup the user state unused not found
[    0.486337] tegra210-pinctrl 700008d4.pinmux: Probed Tegra pinctrl driver
[    0.493449] GPIO chip tegra-gpio: created GPIO range 0->245 ==> 700008d4.pinmux PIN 0->245
[    0.501370] tegra-gpio 6000d000.gpio: Initialising GPIO state 0: name wlan-default
[    0.508873] tegra-gpio 6000d000.gpio: Initialising GPIO state 1: name camera_control
[    0.516605] tegra-gpio 6000d000.gpio: Initialising GPIO state 2: name camera-control
[    0.524346] gpiochip_add: registered GPIOs 0 to 255 on device: tegra-gpio
[    0.533800] Wake44 for irq=81
[    0.534797] Wake40 for irq=53
[    0.537718] Wake41 for irq=53
[    0.540664] Wake42 for irq=53
[    0.543610] Wake43 for irq=53
[    0.546924] platform 70006000.serial: domain=ffffffc0fe20a1d8 allocates as[0]=ffffffc0fe23c110
[    0.555827] platform sound.27: domain=ffffffc0fe26ce58 allocates as[0]=ffffffc0fe23c178
[    0.564596] platform tegradc.1: domain=ffffffc0fe26ca58 allocates as[0]=ffffffc0fe23c1e0
[    0.572681] platform gpu.0: domain=ffffffc0fe26c7d8 allocates as[0]=ffffffc0fe23c248
[    0.578930] platform gpu.0: domain=ffffffc0fe26c7d8 allocates as[1]=ffffffc0fe23c2b0
[    0.586653] platform gpu.0: domain=ffffffc0fe26c7d8 allocates as[2]=ffffffc0fe23c318
[    0.594358] platform gpu.0: domain=ffffffc0fe26c7d8 allocates as[3]=ffffffc0fe23c380
[    0.603458] platform 1003000.pcie-controller: domain=ffffffc0fe26c5d8 allocates as[0]=ffffffc0fe23c3e8
[    0.612651] platform sdhci-tegra.3: domain=ffffffc0fe26c158 allocates as[0]=ffffffc0fe23c450
[    0.620029] platform sdhci-tegra.0: domain=ffffffc0fe2d9e58 allocates as[0]=ffffffc0fe23c4b8
[    0.628319] Wake39 for irq=52
[    0.636871] gpio wake52 for gpio=61
[    0.638571] gpio wake8 for gpio=58
[    0.641793] gpio wake8 for gpio=58
[    0.645969] irq: no irq domain found for /soctherm@0x700E2000 !
[    0.651160] irq: no irq domain found for /soctherm@0x700E2000 !
[    0.657060] board_info: id:sku:fab:major:minor = 0x0884:0x03e8:0x00:0x00:0x00
[    0.664047] PMC dt information non-NULL tegra_init_suspend
[    0.674454] Loading EMC tables...
[    0.675859] tegra: Using EMC sequence '21021' for Rev. 7 tables
[    0.681697] tegra: emc: Derated table is valid.
[    0.686185] Lowering emc maximum rate from 1800000000 to 1600000000
[    0.692434] tegra: validated EMC DFS table
[    0.702245] swapper/0 isomgr_init(): iso emc max clk=1600000KHz
[    0.706173] swapper/0 isomgr_init(): max_iso_bw=11520000KB
[    0.711828] vdso: 2 pages (1 code, 1 data) at base ffffffc0011d6000
[    0.717887] vdso32: 2 pages (1 code, 1 data) at base ffffffc0011d5000
[    0.724321] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.731217] nvdumper: last reboot was unknown
[    0.735381] nvdumper: set_dirty_state 0x2badface
[    0.740329] Tegra restart notifier registered.
[    0.751567] bio: create slab <bio-0> at 0
[    0.754870] vdd-ac-bat: 5000 mV ; Rail ON
[    0.757720] vdd-cpu-fixed: 1000 mV ; Rail ON
[    0.762294] vgaarb: loaded
[    0.764784] SCSI subsystem initialized
[    0.768260] libata version 3.00 loaded.
[    0.768385] usbcore: registered new interface driver usbfs
[    0.773731] usbcore: registered new interface driver hub
[    0.779051] usbcore: registered new device driver usb
[    0.784600] gpio wake33 for gpio=188
[    0.789024] regulator_get() failed for (1-0074,vcc), -19
[    0.792866] pca953x 1-0074: no regulator found for vcc. Assuming vcc is always powered
[    0.801427] gpio wake21 for gpio=89
[    0.804307] gpiochip_add: registered GPIOs 1008 to 1023 on device: tca9539
[    0.811314] regulator_get() failed for (1-0077,vcc), -19
[    0.816332] pca953x 1-0077: no regulator found for vcc. Assuming vcc is always powered
[    0.824898] gpio wake36 for gpio=202
[    0.827854] gpiochip_add: registered GPIOs 992 to 1007 on device: tca9539
[    0.834952] i2c i2c-3: of_i2c: modalias failure on /i2c@7000c700/prod-settings
[    0.842560] max77620 4-003c: CID0: 0xa8
[    0.845621] max77620 4-003c: CID1: 0x17
[    0.849431] max77620 4-003c: CID2: 0x0a
[    0.853259] max77620 4-003c: CID3: 0x59
[    0.857057] max77620 4-003c: CID4: 0x3c
[    0.860883] max77620 4-003c: CID5: 0x81
[    0.864684] max77620 4-003c: MAX77620 PMIC OTP Version is 0x3C
[    0.871815] max77620-pmic max77620-pmic: Consumer c2 does not have device name
[    0.878584] vdd_core: 600 <--> 1400 mV at 1000 mV with ramp delay 27500 uV/us ; Rail ON
[    0.886369] vddio-ddr: at 1125 mV with ramp delay 27500 uV/us ; Rail ON
[    0.892689] vdd-pre-reg: 1350 mV with ramp delay 27500 uV/us ; Rail ON
[    0.899651] vdd-1v8: 1800 mV with ramp delay 27500 uV/us ; Rail ON
[    0.905509] avdd-sys: 1200 mV with ramp delay 100000 uV/us ; Rail ON
[    0.911214] avdd-sys: supplied by vdd-pre-reg
[    0.916055] vdd-pex: 1050 mV with ramp delay 100000 uV/us ; Rail ON
[    0.921771] vdd-pex: supplied by vdd-pre-reg
[    0.926328] vddio-sdmmc1: 1800 <--> 3300 mV at 3300 mV with ramp delay 100000 uV/us ; Rail ON
[    0.934897] vdd-cam-hv: 2800 mV with ramp delay 100000 uV/us ; Rail OFF
[    0.941603] vdd-rtc: 850 mV with ramp delay 100000 uV/us ; Rail ON
[    0.947624] avdd-ts-hv: 3300 mV with ramp delay 100000 uV/us ; Rail OFF
[    0.954893] vdd-ts: 1800 mV with ramp delay 100000 uV/us ; Rail OFF
[    0.960696] vdd-gen-pll-edp: 1050 mV with ramp delay 100000 uV/us ; Rail ON
[    0.967000] vdd-gen-pll-edp: supplied by vdd-pre-reg
[    0.972535] vdd-hdmi-dp: 1050 mV with ramp delay 100000 uV/us ; Rail ON
[    0.978523] vdd-hdmi-dp: supplied by vdd-pre-reg
[    0.983482] max77620-gpio max77620-gpio.0: Initialising GPIO state 1: name gpio_default
[    0.991127] gpiochip_add: registered GPIOs 984 to 991 on device: max77620-gpio
[    0.999267] max77620-gpio max77620-gpio.0: max77620 gpio successfully initialized
[    1.008624] max77620 4-003c: max77620 probe successfully
[    1.012481] media: Linux media interface: v0.10
[    1.016471] Linux video capture interface: v2.00
[    1.021460] pps_core: LinuxPPS API ver. 1 registered
[    1.025980] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.035105] PTP clock support registered
[    1.039283] Tegra WDT enabled on probe. Timeout = 120 seconds.
[    1.044995] tegra_wdt 60005100.watchdog: tegra_wdt_probe done
[    1.051780] Advanced Linux Sound Architecture Driver Initialized.
[    1.056889] Bluetooth: Core ver 2.16
[    1.060165] NET: Registered protocol family 31
[    1.064544] Bluetooth: HCI device and connection manager initialized
[    1.070888] Bluetooth: HCI socket layer initialized
[    1.075729] Bluetooth: L2CAP socket layer initialized
[    1.080774] Bluetooth: SCO socket layer initialized
[    1.086737] vdd-3v3: 3300 mV ; Rail ON
[    1.090475] max77620-gpio7: 1050 mV ; Rail ON
[    1.093703] max77620-gpio7: supplied by vdd-gen-pll-edp
[    1.099075] lcd-bl-en: 1800 mV ; Rail ON
[    1.102948] en-vdd-sd: 3300 mV ; Rail OFF
[    1.106794] en-vdd-sd: supplied by vdd-3v3
[    1.110943] reg-fixed-sync-voltage 5.regulator: Consumer c1 does not have device name
[    1.118977] en-vdd-cam: 1800 mV ; Rail OFF
[    1.129356] vdd-sys-boost: 5000 mV ; Rail ON
[    1.132085] vdd-hdmi: 5000 mV ; Rail OFF
[    1.135569] vdd-hdmi: supplied by vdd-3v3
[    1.139670] aux-3v3: 3300 mV ; Rail ON
[    1.143383] snsr_pm: 3300 mV ; Rail ON
[    1.147606] vdd-disp-3v0: 3000 mV ; Rail ON
[    1.151574] vdd-fan: 5000 mV ; Rail OFF
[    1.155108] usb-vbus1: 5000 mV ; Rail OFF
[    1.158964] usb-vbus1: supplied by vdd-3v3
[    1.163197] usb-vbus3: 5000 mV ; Rail OFF
[    1.167025] usb-vbus3: supplied by vdd-3v3
[    1.171524] en-vdd-ts-1v8: 1800 mV ; Rail OFF
[    1.175823] en-vdd-ts-hv-3v3: 3300 mV ; Rail OFF
[    1.180554] en-vdd-disp-3v3: 3300 mV ; Rail ON
[    1.184827] en-mdm-pwr-3v7: ; Rail OFF
[    1.188684] en-vdd-disp-1v8: 1800 mV ; Rail ON
[    1.192657] reg-fixed-sync-voltage ce.regulator: Consumer c0 does not have device name
[    1.200800] en-vdd-cam-hv-2v8: ; Rail OFF
[    1.204607] rtl-5v0: ; Rail OFF
[    1.207707] en-usb-vbus2: ; Rail OFF
[    1.211535] en-vdd-cam-1v2: ; Rail OFF
[    1.214866] en-vdd-cam-1v2: supplied by vdd-3v3
[    1.219497] en-vdd-vcm-2v8: ; Rail ON
[    1.223024] en-vdd-vcm-2v8: supplied by vdd-3v3
[    1.227925] en-vdd-cam-1v2-alt: ; Rail OFF
[    1.232071] regulator-pwm 0.pwm-regulator: PWM request deferred
[    1.237460] platform 0.pwm-regulator: Driver regulator-pwm requests probe deferral
[    1.245465] vdd_gpu: applied init 1000000uV constraint
[    1.250109] vdd_gpu: 710 <--> 1320 mV at 1000 mV ; Rail OFF
[    1.256094] vdd_cpu: applied init 1000000uV constraint
[    1.260781] vdd_cpu: 708 <--> 1322 mV at 1000 mV normal ; Rail ON
[    1.267385] gpio wake34 for gpio=200
[    1.271590] extcon-gpio-states 1.extcon: Cable state 0
[    1.276798] Switching to clocksource arch_sys_counter
[    1.294795] nvmap_heap_init: nvmap_heap_init: created heap block cache
[    1.299504] tegra-carveouts tegra-carveouts.23: iram :dma coherent mem declare 0x0000000040001000,258048
[    1.308815] tegra-carveouts tegra-carveouts.23: assigned reserved memory node iram-carveout
[    1.317109] nvmap_page_pool_init: Total RAM pages: 1019508
[    1.322565] nvmap_page_pool_init: nvmap page pool size: 127438 pages (497 MB)
[    1.329757] nvmap_background_zero_thread: PP zeroing thread starting.
[    1.336660] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[    1.343511] nvmap:inner cache maint threshold=2097152
[    1.354930] Wake39 for irq=52
[    1.356093] Could not add tegra-otg to power domain using device tree
[    1.362551] tegra-otg tegra-otg: otg transceiver registered
[    1.368333] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[    1.377158] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[    1.384998] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[    1.393290] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[    1.401702] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[    1.410667] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[    1.418684] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tboard_tegra
[    1.427833] tegra21_plle_clk_enable: pll_e is already enabled
[    1.432980] t210_sata_uphy_pll_init: init sata uphy pll
[    1.438155] t210_sata_uphy_pll_init SATA uses SATA Lane
[    1.443670] tegra_xusb_padctl_phy_enable: init pex uphy pll
[    1.450124] tegra210-pmc-iopower pmc-iopower.29: Rail iopower-sys is having fixed voltage 1800000
[    1.457816] tegra210-pmc-iopower pmc-iopower.29: Rail iopower-uart is having fixed voltage 1800000
[    1.466730] tegra210-pmc-iopower pmc-iopower.29: Rail iopower-audio is having fixed voltage 1800000
[    1.475749] tegra210-pmc-iopower pmc-iopower.29: Rail iopower-cam is having fixed voltage 1800000
[    1.484591] tegra210-pmc-iopower pmc-iopower.29: Rail iopower-pex-ctrl is having fixed voltage 1800000
[    1.493860] tegra210-pmc-iopower pmc-iopower.29: Rail iopower-sdmmc1 is having voltages: 1800000:3300000
[    1.503313] tegra210-pmc-iopower pmc-iopower.29: Rail iopower-sdmmc3 is having fixed voltage 1800000
[    1.512407] tegra210-pmc-iopower pmc-iopower.29: Rail iopower-sdmmc4 is having fixed voltage 1800000
[    1.521509] tegra210-pmc-iopower pmc-iopower.29: Rail iopower-audio-hv is having fixed voltage 1800000
[    1.530776] tegra210-pmc-iopower pmc-iopower.29: Rail iopower-debug is having fixed voltage 1800000
[    1.539785] tegra210-pmc-iopower pmc-iopower.29: Rail iopower-dmic is having fixed voltage 1800000
[    1.548721] tegra210-pmc-iopower pmc-iopower.29: Rail iopower-gpio is having fixed voltage 1800000
[    1.557646] tegra210-pmc-iopower pmc-iopower.29: Rail iopower-spi is having fixed voltage 1800000
[    1.566488] tegra210-pmc-iopower pmc-iopower.29: Rail iopower-spi-hv is having fixed voltage 1800000
[    1.575588] tegra210-pmc-iopower pmc-iopower.29: Rail iopower-sdmmc2 is having fixed voltage 1800000
[    1.584687] tegra210-pmc-iopower pmc-iopower.29: Rail iopower-dp is having fixed voltage 1800000
[    1.593389] tegra210-pmc-iopower pmc-iopower.29: NO_IO_POWER setting 0x0
[    1.600243] NET: Registered protocol family 2
[    1.604996] TCP established hash table entries: 32768 (order: 7, 524288 bytes)
[    1.611759] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[    1.618345] TCP: Hash tables configured (established 32768 bind 32768)
[    1.624732] TCP: reno registered
[    1.627866] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[    1.633881] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[    1.640520] NET: Registered protocol family 1
[    1.644871] RPC: Registered named UNIX socket transport module.
[    1.650483] RPC: Registered udp transport module.
[    1.655175] RPC: Registered tcp transport module.
[    1.659840] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.666267] PCI: CLS 0 bytes, default 64
[    1.666582] tegra-fuse tegra-fuse: Fuse driver initialized succesfully
[    1.673110] Trying to unpack rootfs image as initramfs...
[    1.960986] Freeing initrd memory: 12092K (ffffffc003100000 - ffffffc003ccf000)
[    1.970008] host1x host1x: initialized
[    1.975426] NTFS driver 2.1.30 [Flags: R/O].
[    1.977869] fuse init (API version 7.22)
[    1.981759] msgmni has been set to 7988
[    1.986483] io scheduler noop registered (default)
[    1.990323] Tegra cpuquiet initialized: disabled
[    1.996404] tegra-pcie 1003000.pcie-controller: PCIE: Enable power rails
[    2.002318] tegra-pcie 1003000.pcie-controller: probing port 0, using 4 lanes and lane map as 0x14
[    2.012436] tegra-pcie 1003000.pcie-controller: probing port 1, using 1 lanes and lane map as 0x14
[    2.042556] tegra-pcie 1003000.pcie-controller: link 0 down, ignoring
[    2.047002] tegra-pcie 1003000.pcie-controller: link 1 down, ignoring
[    2.053441] tegra-pcie 1003000.pcie-controller: PCIE: no ports detected
[    2.060196] tegra-pcie 1003000.pcie-controller: PCIE: Disable power rails
[    2.068571] tsec tsec: initialized
[    2.071219] tsec tsecb: initialized
[    2.075340] nvdec nvdec: initialized
[    2.079837] falcon vic03: initialized
[    2.082810] falcon msenc: initialized
[    2.086260] falcon nvjpg: initialized
[    2.089635] tegradc tegradc.1: Display dc.54240000 registered with id=0
[    2.095411] of_dc_parse_platform_data: DC OR node is connected to /host1x/sor1
[    2.102736] display board info: id 0x0, fab 0x0
[    2.107749] display board info: id 0x0, fab 0x0
[    2.111981] invalid panel compatible
[    2.115135] parse_tmds_config: No tmds-config node
[    2.119998] of_dc_parse_platform_data: could not find vrr-settings node
[    2.126502] of_dc_parse_platform_data: nvidia,hdmi-vrr-caps not present
[    2.133167] of_dc_parse_platform_data: could not find SD settings node
[    2.139572] of_dc_parse_platform_data: could not find cmu node
[    2.145390] of_dc_parse_platform_data: could not find cmu node for adobeRGB
[    2.152345] tegradc tegradc.1: DT parsed successfully
[    2.158347] display board info: id 0x0, fab 0x0
[    2.162437] gpio wake53 for gpio=225
[    2.166325] tegradc tegradc.1: probed
[    2.251302] Console: switching to colour frame buffer device 80x30
[    2.258827] tegradc tegradc.1: fb registered
[    2.263746] tegra_camera_platform tegra-camera-platform.45: tegra_camera_probe:camera_platform_driver probe
[    2.274154] misc tegra_camera_ctrl: tegra_camera_isomgr_register camera's max_iso_bw 3600000
[    2.285368] tegra-apbdma tegra-apbdma: Tegra20 APB DMA driver register 32 channels
[    2.294815] tegra-adma tegra210-adma: Tegra210 ADMA driver register 10 channels
[    2.303118] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    2.309850] of_serial 70006000.serial: RX periodic polling enabled
[    2.315648] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 68) is a Tegra
[    2.322470] console [ttyS0] enabled, bootconsole disabled
[    2.333328] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 69) is a SERIAL_TEGRA
[    2.344626] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 78) is a SERIAL_TEGRA
[    2.355679] serial-tegra 70006300.serial: RX in PIO mode
[    2.362667] 70006300.serial: ttyTHS3 at MMIO 0x70006300 (irq = 122) is a SERIAL_TEGRA
[    2.375801]  (null): coherent DMA mask is unset
[    2.382053] gk20a gpu.0: failed to allocate secure buffer -12
[    2.394576] brd: module loaded
[    2.401839] loop: module loaded
[    2.407014] zram: Created 1 device(s) ...
[    2.412771] nct1008_nct72 0-004c: find device tree node, parsing dt
[    2.420725] nct1008_nct72 0-004c: starting parse dt
[    2.427303] nct1008_nct72 0-004c: success parsing dt
[    2.433959] nct1008_nct72 0-004c: success in enabling rail vdd_nct72
[    2.512038] NCT72: Enabled overheat logging at 104.00C
[    2.518775] gpio wake33 for gpio=188
[    2.523877] nct1008_nct72 0-004c: nct1008_probe: initialized
[    2.533475] THERMAL EST start of therm_fan_est_probe.
[    2.540000] THERMAL EST: found 2 subdevs
[    2.545318] THERMAL EST name: thermal-fan-est.
[    2.551144] THERMAL EST num_resources: 0
[    2.556380] [THERMAL EST subdev 0]
[    2.561060] THERMAL EST subdev name: CPU-therm
[    2.566752] THERMAL EST index 0 coeffs 50
[    2.571980] THERMAL EST index 1 coeffs 0
[    2.577029] THERMAL EST index 2 coeffs 0
[    2.582019] THERMAL EST index 3 coeffs 0
[    2.586948] THERMAL EST index 4 coeffs 0
[    2.591837] THERMAL EST index 5 coeffs 0
[    2.596637] THERMAL EST index 6 coeffs 0
[    2.601401] THERMAL EST index 7 coeffs 0
[    2.606112] THERMAL EST index 8 coeffs 0
[    2.610800] THERMAL EST index 9 coeffs 0
[    2.615446] [THERMAL EST subdev 1]
[    2.619568] THERMAL EST subdev name: GPU-therm
[    2.624732] THERMAL EST index 0 coeffs 50
[    2.629438] THERMAL EST index 1 coeffs 0
[    2.634070] THERMAL EST index 2 coeffs 0
[    2.638650] THERMAL EST index 3 coeffs 0
[    2.643199] THERMAL EST index 4 coeffs 0
[    2.647684] THERMAL EST index 5 coeffs 0
[    2.652145] THERMAL EST index 6 coeffs 0
[    2.656535] THERMAL EST index 7 coeffs 0
[    2.660904] THERMAL EST index 8 coeffs 0
[    2.665243] THERMAL EST index 9 coeffs 0
[    2.669566] THERMAL EST index 0: trip_temp 0, hyst 0
[    2.674955] THERMAL EST index 1: trip_temp 51000, hyst 15000
[    2.681022] THERMAL EST index 2: trip_temp 61000, hyst 9000
[    2.686974] THERMAL EST index 3: trip_temp 71000, hyst 9000
[    2.692946] THERMAL EST index 4: trip_temp 82000, hyst 10000
[    2.698991] THERMAL EST index 5: trip_temp 140000, hyst 0
[    2.704797] THERMAL EST index 6: trip_temp 150000, hyst 0
[    2.710622] THERMAL EST index 7: trip_temp 160000, hyst 0
[    2.716423] THERMAL EST index 8: trip_temp 170000, hyst 0
[    2.722237] THERMAL EST index 9: trip_temp 180000, hyst 0
[    2.728041] THERMAL EST index 0: trip_temps_hyst 0
[    2.733269] THERMAL EST index 1: trip_temps_hyst 36000
[    2.738832] THERMAL EST index 2: trip_temps_hyst 51000
[    2.744379] THERMAL EST index 3: trip_temps_hyst 52000
[    2.749888] THERMAL EST index 4: trip_temps_hyst 61000
[    2.755399] THERMAL EST index 5: trip_temps_hyst 62000
[    2.760901] THERMAL EST index 6: trip_temps_hyst 71000
[    2.766393] THERMAL EST index 7: trip_temps_hyst 72000
[    2.771910] THERMAL EST index 8: trip_temps_hyst 82000
[    2.777408] THERMAL EST index 9: trip_temps_hyst 140000
[    2.783006] THERMAL EST index 10: trip_temps_hyst 140000
[    2.788704] THERMAL EST index 11: trip_temps_hyst 150000
[    2.794430] THERMAL EST index 12: trip_temps_hyst 150000
[    2.800132] THERMAL EST index 13: trip_temps_hyst 160000
[    2.805847] THERMAL EST index 14: trip_temps_hyst 160000
[    2.811554] THERMAL EST index 15: trip_temps_hyst 170000
[    2.817222] THERMAL EST index 16: trip_temps_hyst 170000
[    2.822893] THERMAL EST index 17: trip_temps_hyst 180000
[    2.828555] THERMAL EST index 18: trip_temps_hyst 180000
[    2.834233] THERMAL EST index 19: trip_temps_hyst 0
[    2.839445] THERMAL EST index 20: trip_temps_hyst 0
[    2.844682] THERMAL EST init dev[0] temp hist to 25000
[    2.850181] THERMAL EST init dev[1] temp hist to 25000
[    2.855703] THERMAL EST cdev_type: pwm-fan.
[    2.860264] THERMAL EST governor name: pid_thermal_gov
[    2.866007] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est.46
[    2.876225] THERMAL EST: thz register success.
[    2.881323] THERMAL EST: end of probe, return err: 0
[    2.886934] tegra_profiler: Branch: Dev
[    2.891417] tegra_profiler: Version: 1.107
[    2.896137] tegra_profiler: Samples version: 36
[    2.901318] tegra_profiler: IO version: 20
[    2.906070] armv8_pmu: imp: 0x41, idcode: 0x1
[    2.911132] armv8_pmu: arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[    2.918475] armv8_pmu: imp: 0x41, idcode: 0x1
[    2.923588] armv8_pmu: arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[    2.931044] armv8_pmu: imp: 0x41, idcode: 0x1
[    2.936236] armv8_pmu: arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[    2.943764] armv8_pmu: imp: 0x41, idcode: 0x1
[    2.949044] armv8_pmu: arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[    2.956786] tegra_profiler: auth: init
[    2.961855] GPS: mt3332_gps_mod_init: platform_driver_register ret = 0
[    2.969820] tegra-sata tegra-sata.0: version 1.0
[    2.970232] t210_sata_uphy_pll_init: sata uphy already enabled
[    2.977890] tegra-sata tegra-sata.0: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl TEGRA-SATA mode
[    2.989452] tegra-sata tegra-sata.0: flags: 64bit ncq sntf pm led pmp pio slum part sadm apst
[    3.001471] Rounding down aligned max_sectors from 4294967295 to 4294967288
[    3.010100] spi-tegra114 7000d400.spi: /spi@7000d400/prod-settings has no reg property
[    3.020969] spi-tegra114 7000d400.spi: Static pin configuration used
[    3.029016] spi_master spi0: cannot find modalias for /spi@7000d400/prod-settings
[    3.039493] spi-tegra114 7000da00.spi: /spi@7000da00/prod-settings has no reg property
[    3.050606] spi-tegra114 7000da00.spi: Static pin configuration used
[    3.058844] spi_master spi3: cannot find modalias for /spi@7000da00/prod-settings
[    3.070240] tun: Universal TUN/TAP device driver, 1.6
[    3.077001] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    3.085088] e1000e: Intel(R) PRO/1000 Network Driver - 2.3.2-k
[    3.092646] e1000e: Copyright(c) 1999 - 2013 Intel Corporation.
[    3.100731] PPP generic driver version 2.4.2
[    3.106799] PPP BSD Compression module registered
[    3.113200] PPP Deflate Compression module registered
[    3.119927] PPP MPPE Compression module registered
[    3.126375] NET: Registered protocol family 24
[    3.132500] usbcore: registered new interface driver r8152
[    3.139637] usbcore: registered new interface driver asix
[    3.146627] usbcore: registered new interface driver ax88179_178a
[    3.154256] usbcore: registered new interface driver cdc_ether
[    3.161570] usbcore: registered new interface driver smsc95xx
[    3.168719] usbcore: registered new interface driver net1080
[    3.175733] usbcore: registered new interface driver cdc_subset
[    3.182949] usbcore: registered new interface driver zaurus
[    3.189765] usbcore: registered new interface driver cdc_ncm
[    3.196601] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.204559] ehci-pci: EHCI PCI platform driver
[    3.210295] tegra_xusb_read_usb_calib: usb_calib0 = 0x069a7c0e
[    3.218642] tegra-xhci tegra-xhci: XUSB device id = 0xfac (T210)
[    3.226353] tegra-xhci tegra-xhci: Firmware File: tegra21x_xusb_firmware (124416 Bytes)
[    3.236666] tegra-xhci tegra-xhci: Firmware DMA Memory: dma 0x0000000080040000 mapped 0xffffff8000339000 (124416 Bytes)
[    3.236849] usbcore: registered new interface driver cdc_acm
[    3.236851] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    3.236876] usbcore: registered new interface driver cdc_wdm
[    3.236908] usbcore: registered new interface driver usb-storage
[    3.236991] usbcore: registered new interface driver usbserial
[    3.237018] usbcore: registered new interface driver ftdi_sio
[    3.237038] usbserial: USB Serial support registered for FTDI USB Serial Device
[    3.237062] usbcore: registered new interface driver option
[    3.237079] usbserial: USB Serial support registered for GSM modem (1-port)
[    3.237104] usbcore: registered new interface driver pl2303
[    3.237121] usbserial: USB Serial support registered for pl2303
[    3.237145] usbcore: registered new interface driver nvshieldled
[    3.237148] Nvidia Tegra High-Speed USB Device Controller driver (Apr 30, 2012)
[    3.237408] tegra USB phy - inst[0] platform info:
[    3.237410] port_otg: yes
[    3.237412] has_hostpc: yes
[    3.237413] phy_interface: USB_PHY_INTF_UTMI
[    3.237415] op_mode: TEGRA_USB_OPMODE_DEVICE
[    3.237416] qc2_voltage: 0
[    3.237418] vbus_pmu_irq: 0
[    3.237419] charging: enabled
[    3.237421] remote_wakeup: disabled
[    3.242169] regulator_get() failed for (tegra-udc.0,usb_bat_chg), -19
[    3.242177] tegra-udc tegra-udc.0: usb_bat_chg regulator not registered: USB charging will not be enabled
[    3.242538] usbcore: registered new interface driver xpad
[    3.242562] usbcore: registered new interface driver usb_acecad
[    3.242585] usbcore: registered new interface driver aiptek
[    3.242609] usbcore: registered new interface driver gtco
[    3.242631] usbcore: registered new interface driver hanwang
[    3.242655] usbcore: registered new interface driver kbtab
[    3.242678] usbcore: registered new interface driver wacom
[    3.324573] max77620-rtc max77620-rtc.1: rtc core: registered max77620-rtc as rtc1
[    3.468390] tegra-xhci tegra-xhci: num_hsic_port 0
[    3.476335] tegra-xhci tegra-xhci: Firmware timestamp: 2016-06-16 13:21:43 UTC, Version: 50.16 release, Falcon state 0x20
[    3.489381] tegra-xhci tegra-xhci: Nvidia xHCI Host Controller
[    3.496274] tegra-xhci tegra-xhci: new USB bus registered, assigned bus number 1
[    3.506513] tegra-xhci tegra-xhci: irq 71, io mem 0x70090000
[    3.513392] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    3.520769] Wake51 for irq=118
[    3.520771] Enabling wake51
[    3.521041] Wake16 for irq=34
[    3.521043] Enabling wake16
[    3.521764] tegra-rtc 7000e000.rtc: rtc core: registered tegra-rtc as rtc0
[    3.521962] i2c /dev entries driver
[    3.523378] virtual_init
[    3.523806] [IMX135] sensor driver loading
[    3.523833] [imx132] sensor driver loading
[    3.523865] [ar0261] sensor driver loading
[    3.523920] ov7695 sensor driver loading
[    3.523946] mt9m114 sensor driver loading
[    3.523975] [ov10823] sensor driver loading
[    3.524116] usbcore: registered new interface driver uvcvideo
[    3.524117] USB Video Class driver (1.1.1)
[    3.526541] max77620-power-off max77620-power-off.4: Event recorder REG_NVERC : 0x0
[    3.526927] FAN dev name: pwm-fan
[    3.526938] FAN:gpio request success.
[    3.526971] pwm_fan_driver pwm-fan.43: cap state:7, cap pwm:255
[    3.527087] pwm_fan_driver pwm-fan.43: got pwm for fan
[    3.527157] pwm_fan_driver pwm-fan.43: fan tach request irq: 360. success
[    3.527163] pwm_fan_driver pwm-fan.43: tach period: 1000
[    3.527231] pwm_fan_driver pwm-fan.43: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[    3.527236] pwm_fan_driver pwm-fan.43: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[    3.527241] pwm_fan_driver pwm-fan.43: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[    3.527246] pwm_fan_driver pwm-fan.43: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[    3.527251] pwm_fan_driver pwm-fan.43: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[    3.527255] pwm_fan_driver pwm-fan.43: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[    3.527259] pwm_fan_driver pwm-fan.43: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[    3.527264] pwm_fan_driver pwm-fan.43: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[    3.527268] pwm_fan_driver pwm-fan.43: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[    3.527272] pwm_fan_driver pwm-fan.43: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[    3.528579] tegra_aotag tegra-aotag.30: AOTAG probe started
[    3.528643] tegra_aotag tegra-aotag.30: nominal ft -- 105
[    3.528646] tegra_aotag tegra-aotag.30: tall -- 76
[    3.528650] tegra_aotag tegra-aotag.30: tiddq -- 1
[    3.528654] tegra_aotag tegra-aotag.30: ten-count -- 16
[    3.528658] tegra_aotag tegra-aotag.30: tsample -- 9
[    3.528661] tegra_aotag tegra-aotag.30: pdiv -- 8
[    3.528665] tegra_aotag tegra-aotag.30: nominal cp -- 25
[    3.528668] tegra_aotag tegra-aotag.30: pdiv-ate -- 8
[    3.528671] tegra_aotag tegra-aotag.30: tsamp-ate -- 39
[    3.528675] tegra_aotag tegra-aotag.30: compensation A,B -- 10632,-67490
[    3.528679] tegra_aotag tegra-aotag.30: sensor found :ID 0, Name: aotag0
[    3.528684] tegra_aotag tegra-aotag.30: reading fuse value for sensor 0
[    3.528688] tegra_aotag tegra-aotag.30: base-cp:22d shifted-cp:1
[    3.528692] tegra_aotag tegra-aotag.30: base-ft:4bd shifted-ft:fffffffb
[    3.528696] tegra_aotag tegra-aotag.30: actual_aotag_cp 255, ft 1025
[    3.528702] tegra_aotag tegra-aotag.30: - Tsens calib value - 0x39f1cdf
[    3.528705] tegra_aotag tegra-aotag.30: CPmask 1fff FTmask 3ffe000
[    3.528709] tegra_aotag tegra-aotag.30: Tsense calib CP - 0x1cdf
[    3.528712] tegra_aotag tegra-aotag.30: Tsense Actual CP d.34847
[    3.528716] tegra_aotag tegra-aotag.30: Tsense calib FT - 0x1cf8
[    3.528719] tegra_aotag tegra-aotag.30: Tsense Actual FT d.38040
[    3.528723] tegra_aotag tegra-aotag.30: delta ts 3193, temp 770
[    3.528727] tegra_aotag tegra-aotag.30: thermA-910, thermB--872
[    3.528731] tegra_aotag tegra-aotag.30: Registering sensor 0
[    3.528762] tegra_aotag tegra-aotag.30: Bound to TZ : ID 0
[    3.528768] tegra_aotag tegra-aotag.30: shutdown temperature - 110
[    3.528773] tegra_aotag tegra-aotag.30: AOTAG EN 60
[    3.528776] tegra_aotag tegra-aotag.30: Probe done [SUCCESS]:0
[    3.529026] md: raid0 personality registered for level 0
[    3.958872] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.967701] device-mapper: uevent: version 1.0.3
[    3.967709] usb usb1: Product: Nvidia xHCI Host Controller
[    3.967714] usb usb1: Manufacturer: Linux 3.10.96-tegra tegra-xhci
[    3.967718] usb usb1: SerialNumber: tegra-xhci
[    3.967959] xHCI xhci_add_endpoint called for root hub
[    3.967962] xHCI xhci_check_bandwidth called for root hub
[    3.968049] hub 1-0:1.0: USB hub found
[    3.968072] hub 1-0:1.0: 5 ports detected
[    4.001785] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[    4.012529] Tegra210 cpuidle driver
[    4.017772] sdhci: Secure Digital Host Controller Interface driver
[    4.020593] tegra-xhci tegra-xhci: Nvidia xHCI Host Controller
[    4.020607] tegra-xhci tegra-xhci: new USB bus registered, assigned bus number 2
[    4.020692] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[    4.020697] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.020701] usb usb2: Product: Nvidia xHCI Host Controller
[    4.020705] usb usb2: Manufacturer: Linux 3.10.96-tegra tegra-xhci
[    4.020708] usb usb2: SerialNumber: tegra-xhci
[    4.020932] xHCI xhci_add_endpoint called for root hub
[    4.020934] xHCI xhci_check_bandwidth called for root hub
[    4.021016] hub 2-0:1.0: USB hub found
[    4.021033] hub 2-0:1.0: 4 ports detected
[    4.089693] sdhci: Copyright(c) Pierre Ossman
[    4.095382] sdhci-pltfm: SDHCI platform and OF driver helper
[    4.102655] mmc0: sdhci_tegra_probe line=5737 runtime pm type=mmc rtpm coupled with clock gate, disable-clock-gate=0
[    4.115842] sdhci-tegra sdhci-tegra.3: Parent select= pll_p rate=408000000
[    4.124134] sdhci-tegra sdhci-tegra.3: Parent select= pll_c4_out2 rate=199680000
[    4.130627] Wake44 for irq=81
[    4.130644] Wake40 for irq=53
[    4.130646] Wake41 for irq=53
[    4.130648] Wake42 for irq=53
[    4.130650] Wake43 for irq=53
[    4.155292] Could not add sdhci-tegra.3 to power domain using device tree
[    4.163962] sdhci-tegra sdhci-tegra.3: Speedo value 1933
[    4.170478] sdhci-tegra sdhci-tegra.3: Tuning constraints: nom_mv 1125, boot_mv 1125, min_or_mv 0
[    4.181819] regulator_get() failed for (sdhci-tegra.3,vqmmc), -19
[    4.189145] mmc0: no vqmmc regulator found
[    4.194448] regulator_get() failed for (sdhci-tegra.3,vmmc), -19
[    4.201658] mmc0: no vmmc regulator found
[    4.240604] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA
[    4.250476] mmc1: sdhci_tegra_probe line=5737 runtime pm type=mmc rtpm coupled with clock gate, disable-clock-gate=0
[    4.263673] sdhci-tegra sdhci-tegra.1: Parent select= pll_p rate=408000000
[    4.271970] Could not add sdhci-tegra.1 to power domain using device tree
[    4.280878] sdhci-tegra sdhci-tegra.1: Speedo value 1933
[    4.287609] sdhci-tegra sdhci-tegra.1: Tuning constraints: nom_mv 1125, boot_mv 1125, min_or_mv 0
[    4.299744] regulator_get() failed for (sdhci-tegra.1,vqmmc), -19
[    4.307276] mmc1: no vqmmc regulator found
[    4.312749] regulator_get() failed for (sdhci-tegra.1,vmmc), -19
[    4.320157] mmc1: no vmmc regulator found
[    4.360608] mmc1: SDHCI controller on sdhci-tegra.1 [sdhci-tegra.1] using ADMA
[    4.371673] mmc2: sdhci_tegra_probe line=5737 runtime pm type=mmc rtpm coupled with clock gate, disable-clock-gate=0
[    4.385550] sdhci-tegra sdhci-tegra.0: Parent select= pll_p rate=408000000
[    4.394178] Could not add sdhci-tegra.0 to power domain using device tree
[    4.403277] sdhci-tegra sdhci-tegra.0: Speedo value 1933
[    4.410330] sdhci-tegra sdhci-tegra.0: Tuning constraints: nom_mv 1125, boot_mv 1125, min_or_mv 0
[    4.422719] regulator_get() failed for (sdhci-tegra.0,vqmmc), -19
[    4.430560] mmc2: no vqmmc regulator found
[    4.436374] regulator_get() failed for (sdhci-tegra.0,vmmc), -19
[    4.444114] mmc2: no vmmc regulator found
[    4.449821] mmc0: BKOPS_EN bit is not set
[    4.481176] mmc2: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA
[    4.492665] gpio wake35 for gpio=201
[    4.510959] usb 2-1: new SuperSpeed USB device number 2 using tegra-xhci
[    4.511029] tegra-se tegra21-se: tegra_se_probe: complete
[    4.511630] hidraw: raw HID events driver (C) Jiri Kosina
[    4.534646] usbcore: registered new interface driver usbhid
[    4.541789] usbhid: USB HID core driver
[    4.547167] tegra_bootloader_debug: Created tegra_bootloader directory
[    4.555304] tegra_bootloader_debug: Created sysfs interface tegra_bootloader_verify_regs in tegra_bootloader directory
[    4.569098] tegra_bootloader_debug: Created sysfs interface tegra_bootloader_prof in tegra_bootloader directory
[    4.582546] nvadsp 702ef000.adsp: in probe()...
[    4.583397] usb 2-1: New USB device found, idVendor=0955, idProduct=09ff
[    4.583403] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[    4.583407] usb 2-1: Product: USB 10/100/1000 LAN
[    4.583411] usb 2-1: Manufacturer: Nvidia
[    4.583415] usb 2-1: SerialNumber: 000001000000
[    4.612749] mmc0: tap value and tuning window after hw tuning completion ...
[    4.612754] mmc0: tuning_window[0]: 0xffffffff
[    4.612758] mmc0: tuning_window[1]: 0xffffffc7
[    4.612762] mmc0: tuning_window[2]: 0xffffe3ff
[    4.612766] mmc0: tuning_window[3]: 0x7fe3ffff
[    4.612769] mmc0: tuning_window[4]: 0x0
[    4.612772] mmc0: tuning_window[5]: 0x0
[    4.612776] mmc0: tuning_window[6]: 0x0
[    4.612779] mmc0: tuning_window[7]: 0x0
[    4.612782] sdhci: Tap value: 95 | Trim value: 8
[    4.612785] sdhci: SDMMC Interrupt status: 0x00040000
[    4.613361] mmc0: switch to HS400 mode is successful
[    4.616696] mmc0: new HS400 MMC card at address 0001
[    4.697696] mmcblk0: mmc0:0001 016G32 14.6 GiB
[    4.698380] nvadsp 702ef000.adsp: AMC/ARAM initialized.
[    4.698503] nvadsp 702ef000.adsp: nvadsp_app_module_probe
[    4.700474] tegra_throttle : init passed
[    4.701478] cpu-tegra: init EDP limit: 1122 MHz
[    4.701947] pll_x: not ready for dynamic ramp to 921600000
[    4.701982] pll_x: not ready for dynamic ramp to 921600000
[    4.703211] soctherm: prog thresholds
[    4.703215] soctherm: prog thresholds
[    4.703217] soctherm: tz:2 not found, skip thresh prog
[    4.703218] soctherm: prog thresholds
[    4.703230] soctherm: skipping sensor 4 programming
[    4.703233] soctherm: skipping sensor 5 programming
[    4.703238] soctherm: trip_point temp 127500 forced to 127000
[    4.777428] mmcblk0rpmb: mmc0:0001 016G32 partition 3 4.00 MiB
[    4.785957]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18
[    4.798062] usbcore: registered new interface driver snd-usb-audio
[    4.823412] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[    4.901178] usb 2-1: reset SuperSpeed USB device number 2 using tegra-xhci
[    4.968234] r8152 2-1:1.0 eth0: v2.03.3 (2015/01/29)
[    4.974461] r8152 2-1:1.0 eth0: This product is covered by one or more of the following patents:
               		US6,570,884, US6,115,776, and US6,327,625.
[    5.023977] mmc1: tap value and tuning window after hw tuning completion ...
[    5.032421] mmc1: tuning_window[0]: 0xf9ffffff
[    5.038226] mmc1: tuning_window[1]: 0x9fffffff
[    5.043998] mmc1: tuning_window[2]: 0xffffffff
[    5.049724] mmc1: tuning_window[3]: 0x7ffffff9
[    5.055419] mmc1: tuning_window[4]: 0x0
[    5.060500] mmc1: tuning_window[5]: 0x0
[    5.065545] mmc1: tuning_window[6]: 0x0
[    5.070598] mmc1: tuning_window[7]: 0x0
[    5.075611] sdhci: Tap value: 43 | Trim value: 8
[    5.081430] sdhci: SDMMC Interrupt status: 0x00040000
[    5.091303] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[    5.159678] tegra-i2c 7000c000.i2c: no acknowledge from address 0x1b
[    5.167440] rt5659 0-001b: Device with ID register fdc72400 is not rt5659
[    5.184537] tegra210-i2s tegra210-i2s.0: Missing prop fsync-width for I2S0
[    5.193475] tegra210-i2s tegra210-i2s.2: Missing prop fsync-width for I2S2
[    5.201824] tegra210-i2s tegra210-i2s.3: Missing prop fsync-width for I2S3
[    5.210138] tegra210-i2s tegra210-i2s.4: Missing prop fsync-width for I2S4
[    5.222736] OPE platform probe
[    5.227076] OPE platform probe successful
[    5.232189] OPE platform probe
[    5.236407] OPE platform probe successful
[    5.241547] tegra210_adsp_audio_platform_probe: platform probe started
[    5.250347] tegra210-adsp adsp_audio.3: Default param-type to BYTE for mp3-dec1
[    5.259862] tegra210-adsp adsp_audio.3: Default param-type to BYTE for spkprot
[    5.269463] tegra210-adsp adsp_audio.3: Default param-type to BYTE for src
[    5.277783] tegra210-adsp adsp_audio.3: Default param-type to BYTE for aac-dec1
[    5.287772] tegra210-adsp adsp_audio.3: Default param-type to BYTE for aec
[    5.296017] tegra210_adsp_audio_platform_probe probe successfull.
[    5.303328] tegra-snd-t210ref-mobile-rt565x sound.27: Failed to get HP Det GPIO,should be handled by codec
[    5.379206] tegra210-ape-admaif tegra210-admaif: ASoC: Failed to create codec debugfs directory
[    5.392393] tegra210-adsp adsp_audio.3: ASoC: Failed to create platform debugfs directory
[    5.435319] tegra-snd-t210ref-mobile-rt565x sound.27:  ADMAIF1 <-> ADMAIF1 mapping ok
[    5.447456] tegra-snd-t210ref-mobile-rt565x sound.27:  ADMAIF2 <-> ADMAIF2 mapping ok
[    5.459832] tegra-snd-t210ref-mobile-rt565x sound.27:  ADMAIF3 <-> ADMAIF3 mapping ok
[    5.472375] tegra-snd-t210ref-mobile-rt565x sound.27:  ADMAIF4 <-> ADMAIF4 mapping ok
[    5.485178] tegra-snd-t210ref-mobile-rt565x sound.27:  ADMAIF5 <-> ADMAIF5 mapping ok
[    5.498106] tegra-snd-t210ref-mobile-rt565x sound.27:  ADMAIF6 <-> ADMAIF6 mapping ok
[    5.511083] tegra-snd-t210ref-mobile-rt565x sound.27:  ADMAIF7 <-> ADMAIF7 mapping ok
[    5.524054] tegra-snd-t210ref-mobile-rt565x sound.27:  ADMAIF8 <-> ADMAIF8 mapping ok
[    5.537184] tegra-snd-t210ref-mobile-rt565x sound.27:  ADMAIF9 <-> ADMAIF9 mapping ok
[    5.550348] tegra-snd-t210ref-mobile-rt565x sound.27:  ADMAIF10 <-> ADMAIF10 mapping ok
[    5.624678] tegra-snd-t210ref-mobile-rt565x sound.27:  ADSP-FE1 <-> ADSP PCM1 mapping ok
[    5.637515] tegra-snd-t210ref-mobile-rt565x sound.27:  ADSP-FE2 <-> ADSP PCM2 mapping ok
[    5.650219] compress asoc: ADSP-FE3 <-> ADSP COMPR1 mapping ok
[    5.658529] compress asoc: ADSP-FE4 <-> ADSP COMPR2 mapping ok
[    5.676835] tegra-snd-t210ref-mobile-rt565x sound.27: ASoC: no source widget found for x HPO L Playback
[    5.690327] tegra-snd-t210ref-mobile-rt565x sound.27: ASoC: Failed to add route x HPO L Playback -> direct -> x Headphone Jack
[    5.705850] tegra-snd-t210ref-mobile-rt565x sound.27: ASoC: no source widget found for x HPO R Playback
[    5.719322] tegra-snd-t210ref-mobile-rt565x sound.27: ASoC: Failed to add route x HPO R Playback -> direct -> x Headphone Jack
[    5.734839] tegra-snd-t210ref-mobile-rt565x sound.27: ASoC: no sink widget found for x MICBIAS1
[    5.747611] tegra-snd-t210ref-mobile-rt565x sound.27: ASoC: Failed to add route x Mic Jack -> direct -> x MICBIAS1
[    5.762074] tegra-snd-t210ref-mobile-rt565x sound.27: ASoC: no sink widget found for x IN1P
[    5.774493] tegra-snd-t210ref-mobile-rt565x sound.27: ASoC: Failed to add route x Mic Jack -> direct -> x IN1P
[    5.788604] tegra-snd-t210ref-mobile-rt565x sound.27: ASoC: no sink widget found for x Mic Det Power
[    5.801818] tegra-snd-t210ref-mobile-rt565x sound.27: ASoC: Failed to add route x Mic Jack -> direct -> x Mic Det Power
[    5.816723] tegra-snd-t210ref-mobile-rt565x sound.27: ASoC: no source widget found for x SPO Playback
[    5.830024] tegra-snd-t210ref-mobile-rt565x sound.27: ASoC: Failed to add route x SPO Playback -> direct -> x Int Spk
[    5.844864] tegra-snd-t210ref-mobile-rt565x sound.27: ASoC: no sink widget found for x DMIC L1
[    5.857758] tegra-snd-t210ref-mobile-rt565x sound.27: ASoC: Failed to add route x Int Mic -> direct -> x DMIC L1
[    5.872253] tegra-snd-t210ref-mobile-rt565x sound.27: ASoC: no sink widget found for x DMIC L2
[    5.885153] tegra-snd-t210ref-mobile-rt565x sound.27: ASoC: Failed to add route x Int Mic -> direct -> x DMIC L2
[    5.899646] tegra-snd-t210ref-mobile-rt565x sound.27: ASoC: no sink widget found for x DMIC R1
[    5.912536] tegra-snd-t210ref-mobile-rt565x sound.27: ASoC: Failed to add route x Int Mic -> direct -> x DMIC R1
[    5.927028] tegra-snd-t210ref-mobile-rt565x sound.27: ASoC: no sink widget found for x DMIC R2
[    5.939916] tegra-snd-t210ref-mobile-rt565x sound.27: ASoC: Failed to add route x Int Mic -> direct -> x DMIC R2
[    5.960961] input: tegra-snd-t210ref-mobile-rt565x Headphone Jack as /devices/platform/sound.27/sound/card1/input0
[    5.979229] tegra-snd-t210ref-mobile-rt565x sound.27: codec-dai "dit-hifi" registered
[    5.992771] tegra-snd-t210ref-mobile-rt565x sound.27: This is a dummy codec
[    6.002784] GACT probability NOT on
[    6.008406] Mirror/redirect action on
[    6.014157] u32 classifier
[    6.018870]     Actions configured
[    6.024242] Netfilter messages via NETLINK v0.30.
[    6.030943] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[    6.039210] ctnetlink v0.93: registering with nfnetlink.
[    6.046527] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[    6.055422] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[    6.063429] xt_time: kernel timezone is -0000
[    6.069723] ipip: IPv4 over IPv4 tunneling driver
[    6.076638] ip_tables: (C) 2000-2006 Netfilter Core Team
[    6.083903] arp_tables: (C) 2002 David S. Miller
[    6.090292] TCP: cubic registered
[    6.095307] Initializing XFRM netlink socket
[    6.101352] NET: Registered protocol family 10
[    6.108142] mip6: Mobile IPv6
[    6.112707] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    6.119778] sit: IPv6 over IPv4 tunneling driver
[    6.126529] NET: Registered protocol family 17
[    6.132474] NET: Registered protocol family 15
[    6.138350] Bridge firewalling registered
[    6.143719] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    6.150983] Bluetooth: HIDP socket layer initialized
[    6.157236] NET: Registered protocol family 35
[    6.163018] Key type dns_resolver registered
[    6.168538] NET: Registered protocol family 41
[    6.176011] Registering SWP/SWPB emulation handler
[    6.205632] isp isp.0: initialized
[    6.211714] isp isp.1: initialized
[    6.216648] vdd_gpu: disabling
[    6.220906] en-vdd-cam-1v2-alt: disabling
[    6.226067] en-vdd-vcm-2v8: disabling
[    6.230854] en-vdd-cam-1v2: disabling
[    6.235586] en-vdd-cam-hv-2v8: disabling
[    6.240556] en-vdd-disp-1v8: disabling
[    6.245502] en-mdm-pwr-3v7: disabling
[    6.250181] en-vdd-disp-3v3: disabling
[    6.255101] en-vdd-ts-hv-3v3: disabling
[    6.259920] en-vdd-ts-1v8: disabling
[    6.264464] usb-vbus3: disabling
[    6.268638] usb-vbus1: disabling
[    6.272790] vdd-fan: disabling
[    6.282911] vdd-disp-3v0: disabling
[    6.287257] snsr_pm: disabling
[    6.291211] aux-3v3: disabling
[    6.295108] en-vdd-cam: disabling
[    6.299237] en-vdd-sd: disabling
[    6.308150] lcd-bl-en: disabling
[    6.312168] max77620-gpio7: disabling
[    6.328162] vdd-cpu-fixed: disabling
[    6.332517] regulator-dummy: disabling
[    6.337846] gpio wake24 for gpio=189
[    6.342239] gpio wake27 for gpio=192
[    6.346584] gpio wake25 for gpio=190
[    6.351049] input: gpio-keys as /devices/platform/gpio-keys.47/input/input1
[    6.376473] tegra-rtc 7000e000.rtc: setting system clock to 2013-01-01 00:00:00 UTC (1356998400)
[    6.387071] vi vi: vi_probe: ++
[    6.393238] vi vi: initialized
[    6.397546] vi vi: parsing node /host1x/vi
[    6.402538] vi vi: handling endpoint /host1x/vi/ports/port@0/endpoint
[    6.409939] vi vi: handling endpoint /host1x/vi/ports/port@1/endpoint
[    6.417349] vi vi: handling endpoint /host1x/vi/ports/port@2/endpoint
[    6.424717] vi vi: handling endpoint /host1x/vi/ports/port@3/endpoint
[    6.432075] vi vi: handling endpoint /host1x/vi/ports/port@4/endpoint
[    6.439403] vi vi: handling endpoint /host1x/vi/ports/port@5/endpoint
[    6.446720] vi vi: warning: no subdev found in graph
[    6.453287] [dram-timers] DRAM derating cdev registered.
[    6.459496] Disable partitions left on by BL
[    6.464694]     sata
[    6.467904]     disb
[    6.471034] Disabling clocks left on by bootloader:
[    6.476863]    audio2_dmic
[    6.480507]    audio1_dmic
[    6.484137]    audio0_dmic
[    6.487728]    audio_2x
[    6.491069]    audio
[    6.494111]    audio4
[    6.497237]    audio3
[    6.500291]    audio2
[    6.503289]    audio1
[    6.506197]    audio0
[    6.509127]    entropy
[    6.512118]    dsi2-fixed
[    6.515328]    dsi1-fixed
[    6.518491]    sdmmc4_ddr
[    6.521667]    sdmmc1_ddr
[    6.524850]    sor1_src
[    6.527854]    cclk_lp
[    6.531426] tegra_cl_dvfs 70110000.dfll-ovr: DT data retrieved successfully
[    6.539211] tune_cpu_trimmers: init soctherm cpu zone LOW
[    6.545385] tegra_cl_dvfs_init_cdev: cpu_cold cooling device registered
[    6.552785] tegra_cl_dvfs_init_cdev: cpu_hot cooling device registered
[    6.552994] Tegra CPU DFLL is initialized with use_dfll = 1
[    6.553121] tegra_dvfs: 0.vdd-cpu-rail-ovr connected to regulator
[    6.573232] tegra_dvfs: 4.vdd-core-rail-max77620 connected to regulator
[    6.580824] tegra_dvfs: 1.vdd-gpu-rail-ovr connected to regulator
[    6.588188] CPU rate: 921 MHz
[    6.592020] last reset is due to power on reset
[    6.599219] KERNEL: PMC reset status reg: 0x0
[    6.604879] tegra_actmon.emc: Completed initialization (0)
[    6.611526] tegra_actmon.avp: Completed initialization (0)
[    6.808860] tegra dvfs: tegra sysfs cap interface is initialized
[    6.815665] tegra dvfs: tegra sysfs gpu & emc interface is initialized
[    6.823920] Set maximum possible CPU frequency 1734000
[    6.829922] ALSA device list:
[    6.833522]   #0: HDA NVIDIA Tegra at 0x70038000 irq 113
[    6.839445]   #1: tegra-snd-t210ref-mobile-rt565x
[    6.845057] Freeing unused kernel memory: 428K (ffffffc00114f000 - ffffffc0011ba000)
[    6.854190] Freeing alternatives memory: 52K (ffffffc0011bb000 - ffffffc0011c8000)
[    6.900199] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[    7.008302] systemd[1]: System time before build time, advancing clock.
[    7.046338] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    7.071247] systemd[1]: Detected architecture arm64.
[    7.103368] systemd[1]: Set hostname to <tegra-ubuntu>.
[    7.223316] systemd[1]: File /lib/systemd/system/systemd-udevd.service:35 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[    7.242778] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[    7.321027] systemd[1]: Created slice User and Session Slice.
[    7.340852] systemd[1]: Created slice System Slice.
[    7.360678] systemd[1]: Reached target Slices.
[    7.380788] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    7.410805] systemd[1]: Listening on udev Control Socket.
[    7.430764] systemd[1]: Listening on Journal Socket (/dev/log).
[    7.450760] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    7.480679] systemd[1]: Reached target Swap.
[    7.500881] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    7.530943] systemd[1]: Listening on Journal Socket.
[    7.551765] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[    7.581810] systemd[1]: Mounting Kernel Debug File System...
[    7.601967] systemd[1]: Mounting POSIX Message Queue File System...
[    7.631787] systemd[1]: Started Read required files in advance.
[    7.663621] systemd[1]: Starting Remount Root and Kernel File Systems...
[    7.692353] systemd[1]: Listening on RPCbind Server Activation Socket.
[    7.720772] systemd[1]: Listening on Syslog Socket.
[    7.741742] systemd[1]: Starting Journal Service...
[    7.762091] systemd[1]: Starting Set the console keyboard layout...
[    7.801494] systemd[1]: Starting Load Kernel Modules...
[    7.820703] systemd[1]: Reached target User and Group Name Lookups.
[    7.833383] gpio wake52 for gpio=61
[    7.841841] systemd[1]: Starting Uncomplicated firewall...
[    7.860965] systemd[1]: Listening on udev Kernel Socket.
[    7.881795] systemd[1]: Starting udev Coldplug all Devices...
[    7.901922] systemd[1]: Started Journal Service.
[    8.343701] systemd-journald[186]: Received request to flush runtime journal from PID 1
[    8.348340] systemd-journald[186]: File /var/log/journal/ae15719763c84b35196c20a95728b806/system.journal corrupted or uncleanly shut down, renaming and replacing.
[    8.939193] cfg80211: Calling CRDA to update world regulatory domain
[    8.962443] sdhci-tegra sdhci-tegra.1: Card already in requested state
[    8.962446] sdhci-tegra sdhci-tegra.1: Card already in requested state
[    9.089410] dhd_module_init in
[    9.090195] Power-up adapter 'DHD generic adapter'
[    9.095254] wifi_platform_set_power = 1
[    9.300596] wifi_platform_bus_enumerate device present 1
[    9.317489] wifi_platform_bus_enumerate device present 0
[    9.318241] SDIO Vendor ID:02d0 and SDIO Device ID: 4354
[    9.318494] F1 signature read @0x18000000=0x17214354
[    9.327831] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[    9.329109] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[    9.329258] wifi_platform_prealloc: failed to alloc static mem section 7
[    9.329268] wifi_platform_get_mac_addr
[    9.329571] of_get_mac_address: checking /chosen dtb node for mac address property nvidia,wifi-mac
[    9.329661] wifi_get_mac_addr: 00:04:4b:79:bd:35
[    9.330965]  wl_setup_wiphy : Registering Vendor80211
[    9.336687] wl_create_event_handler(): thread:wl_event_handler:215 started
[    9.336816]  wl_event_handler : tsk Enter, tsk = 0xffffffc0efd019f0
[    9.338054] dhd_attach(): thread:dhd_watchdog_thread:217 started
[    9.346319] dhd_attach(): thread:dhd_dpc:218 started
[    9.351006] dhd_attach(): thread:dhd_rxf:222 started
[    9.351022] dhd_deferred_work_init: work queue initialized
[    9.352815] Dongle Host Driver, version 1.201.82 (r)
               Compiled in drivers/net/wireless/bcmdhd on Jan 14 2017 at 13:19:23
[    9.353114] Register interface [wlan0]  MAC: 00:04:4b:79:bd:35
[    9.353123] dhd_prot_ioctl : bus is down. we have nothing to do
[    9.357575] wifi_platform_set_power = 0
[    9.407706] cfg80211: World regulatory domain updated:
[    9.407716] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[    9.407722] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[    9.407726] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[    9.407730] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[    9.407734] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[    9.407737] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[    9.407741] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[    9.407744] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[    9.407747] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[    9.560594] tegra_sysfs_register
Continue of dmesg
[   11.181148] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   11.213040]
[   11.213051] wl_android_wifi_on in
[   11.213056] wifi_platform_set_power = 1
[   11.304693] systemd-journald[186]: File /var/log/journal/ae15719763c84b35196c20a95728b806/user-1001.journal corrupted or uncleanly shut down, renaming and replacing.
[   11.487869] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[   11.555414] sdhci-tegra sdhci-tegra.1: Tuning already done, restoring the best tap value : 43
[   11.556265] SDIO Vendor ID:02d0 and SDIO Device ID: 4354
[   11.556568] F1 signature read @0x18000000=0x17214354
[   11.565890] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[   11.567219] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[   11.669428] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[   11.711776] SDIO Vendor ID:02d0 and SDIO Device ID: 4354
[   11.711830] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[   11.712328] gpio wake8 for gpio=58
[   11.712333] Enabling wake8
[   11.714533] wifi_platform_get_mac_addr
[   11.714823] wifi_get_mac_addr: 00:04:4b:79:bd:35
[   11.717109] Firmware up: op_mode=0x0005, MAC=00:04:4b:79:bd:35
[   11.726281] dhd_preinit_ioctls pspretend_threshold for HostAPD failed  -23
[   11.733484] Firmware version = wl0: Mar  8 2016 12:52:17 version 7.35.221.11 (r623264) FWID 01-b55daaf2
[   11.737196] dhd_interworking_enable: failed to set WNM info, ret=-23
[   11.737539] tegra_sysfs_on
[   11.964739] CFGP2P-ERROR) wl_cfgp2p_add_p2p_disc_if : P2P interface registered
[   11.972061] WLC_E_IF: NO_IF set, event Ignored
[   12.022476] Setting clk_rate = 44100 Hz pll_a_out0 = 45158400 Hz clk_out = 11289600 Hz
[   12.064150] Setting clk_rate = 44100 Hz pll_a_out0 = 45158400 Hz clk_out = 11289600 Hz
[   12.082756] Setting clk_rate = 44100 Hz pll_a_out0 = 45158400 Hz clk_out = 11289600 Hz
[   12.098248] Setting clk_rate = 44100 Hz pll_a_out0 = 45158400 Hz clk_out = 11289600 Hz
[   12.149334] Setting clk_rate = 44100 Hz pll_a_out0 = 45158400 Hz clk_out = 11289600 Hz
[   12.214428] HDA: No HDMI device connected
[   12.214880] HDA: No HDMI device connected
[   12.215308] HDA: No HDMI device connected
[   12.437926] HDA: No HDMI device connected
[   13.702726] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   15.467789] systemd-journald[186]: File /var/log/journal/ae15719763c84b35196c20a95728b806/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
[   17.262221] Setting clk_rate = 44100 Hz pll_a_out0 = 45158400 Hz clk_out = 11289600 Hz
[   17.313136] Setting clk_rate = 44100 Hz pll_a_out0 = 45158400 Hz clk_out = 11289600 Hz
[   17.331728] Setting clk_rate = 44100 Hz pll_a_out0 = 45158400 Hz clk_out = 11289600 Hz
[   17.349326] Setting clk_rate = 44100 Hz pll_a_out0 = 45158400 Hz clk_out = 11289600 Hz
[   17.747850] Setting clk_rate = 44100 Hz pll_a_out0 = 45158400 Hz clk_out = 11289600 Hz
[   33.055243] Setting clk_rate = 44100 Hz pll_a_out0 = 45158400 Hz clk_out = 11289600 Hz
[   33.056511] Setting clk_rate = 44100 Hz pll_a_out0 = 45158400 Hz clk_out = 11289600 Hz
df -H -T
Filesystem     Type      Size  Used Avail Use% Mounted on
/dev/mmcblk0p1 ext4       15G   13G  1.8G  88% /
none           devtmpfs  2.1G     0  2.1G   0% /dev
tmpfs          tmpfs     2.1G     0  2.1G   0% /dev/shm
tmpfs          tmpfs     2.1G  5.0M  2.1G   1% /run
tmpfs          tmpfs     5.3M  4.1k  5.3M   1% /run/lock
tmpfs          tmpfs     2.1G     0  2.1G   0% /sys/fs/cgroup
tmpfs          tmpfs     419M  4.1k  419M   1% /run/user/1001
tmpfs          tmpfs     419M  4.1k  419M   1% /run/user/1000
lsblk -f
NAME         FSTYPE LABEL UUID                                 MOUNTPOINT
mmcblk0
├─mmcblk0p1  ext4         bd450650-b1bf-4c55-be8e-98a04c8040da /
├─mmcblk0p2
├─mmcblk0p3
├─mmcblk0p4
├─mmcblk0p5
├─mmcblk0p6
├─mmcblk0p7
├─mmcblk0p8
├─mmcblk0p9
├─mmcblk0p10
├─mmcblk0p11
├─mmcblk0p12
├─mmcblk0p13
├─mmcblk0p14
├─mmcblk0p15
├─mmcblk0p16
├─mmcblk0p17
└─mmcblk0p18
mmcblk0rpmb
It’s strange because I don’t see any outright errors related to anything which would stop normal access. I do see fairly normal output after “Started Journal Service”. Do you get anything other than “ok” from “sha1sum -c /etc/nv_tegra_release”? Is there anything unusual about the monitor itself, e.g., adapter cables versus native HDMI? Is it correct that you just performed a normal package update, and not a full release upgrade?
“sha1sum -c /etc/nv_tegra_release” was all ok’s.
I have tried 3 different monitors now. Just regular hdmi.
Ubuntu asked me to do a system update and I clicked yes it downloaded and then restarted and when it restarted this started happening
Since you have access, I’m wondering if perhaps the update is just long and blocking other activities. How fast is your network access, and have you allowed the unit to sit with network access for at least several hours? Does this command succeed, does it block, or does it give an error?
sudo apt update
If this works, then does this also work?
sudo apt --fix-broken install
If that works, then what happens when you issue these two commands:
sudo systemctl isolate multi-user.target
sudo systemctl isolate graphical.target
Its been on a network connection for a couple days.
sudo apt update
Hit:1 http://ports.ubuntu.com/ubuntu-ports bionic InRelease
Get:2 http://ports.ubuntu.com/ubuntu-ports bionic-updates InRelease [88.7 kB]
Get:3 http://ports.ubuntu.com/ubuntu-ports bionic-security InRelease [88.7 kB]
Get:4 http://ports.ubuntu.com/ubuntu-ports bionic-updates/universe Sources [278 kB]
Get:5 http://ports.ubuntu.com/ubuntu-ports bionic-updates/multiverse Sources [5,840 B]
Get:6 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main Sources [310 kB]
Get:7 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main arm64 Packages [630 kB]
Get:8 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main Translation-en [303 kB]
Get:9 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main arm64 DEP-11 Metadata [302 kB]
Get:10 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main DEP-11 48x48 Icons [73.8 kB]
Get:11 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main DEP-11 64x64 Icons [140 kB]
Get:12 http://ports.ubuntu.com/ubuntu-ports bionic-updates/universe arm64 Packages [942 kB]
Get:13 http://ports.ubuntu.com/ubuntu-ports bionic-updates/universe Translation-en [326 kB]
Get:14 http://ports.ubuntu.com/ubuntu-ports bionic-updates/universe arm64 DEP-11 Metadata [259 kB]
Get:15 http://ports.ubuntu.com/ubuntu-ports bionic-updates/universe DEP-11 48x48 Icons [193 kB]
Get:16 http://ports.ubuntu.com/ubuntu-ports bionic-updates/universe DEP-11 64x64 Icons [440 kB]
Get:17 http://ports.ubuntu.com/ubuntu-ports bionic-updates/multiverse Translation-en [4,636 B]
Get:18 http://ports.ubuntu.com/ubuntu-ports bionic-security/main Sources [142 kB]
Get:19 http://ports.ubuntu.com/ubuntu-ports bionic-security/multiverse Sources [3,180 B]
Get:20 http://ports.ubuntu.com/ubuntu-ports bionic-security/universe Sources [167 kB]
Get:21 http://ports.ubuntu.com/ubuntu-ports bionic-security/main arm64 Packages [427 kB]
Get:22 http://ports.ubuntu.com/ubuntu-ports bionic-security/main Translation-en [211 kB]
Get:23 http://ports.ubuntu.com/ubuntu-ports bionic-security/main arm64 DEP-11 Metadata [32.3 kB]
Get:24 http://ports.ubuntu.com/ubuntu-ports bionic-security/main DEP-11 48x48 Icons [17.6 kB]
Get:25 http://ports.ubuntu.com/ubuntu-ports bionic-security/main DEP-11 64x64 Icons [41.5 kB]
Get:26 http://ports.ubuntu.com/ubuntu-ports bionic-security/universe arm64 Packages [578 kB]
Get:27 http://ports.ubuntu.com/ubuntu-ports bionic-security/universe Translation-en [218 kB]
Get:28 http://ports.ubuntu.com/ubuntu-ports bionic-security/universe arm64 DEP-11 Metadata [36.9 kB]
Get:29 http://ports.ubuntu.com/ubuntu-ports bionic-security/universe DEP-11 48x48 Icons [16.4 kB]
Get:30 http://ports.ubuntu.com/ubuntu-ports bionic-security/universe DEP-11 64x64 Icons [111 kB]
Get:31 http://ports.ubuntu.com/ubuntu-ports bionic-security/multiverse Translation-en [2,700 B]
Fetched 6,388 kB in 6s (1,007 kB/s)
Reading package lists... Done
Building dependency tree
Reading state information... Done
All packages are up to date.
The following package was automatically installed and is no longer required:
  libnih-dbus1
Use 'sudo apt autoremove' to remove it.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Then the last 2 commands just didnt return anything but made the screen go black with a cursor
None of the “apt” commands should cause a screen to go black, but it is possible some sort of energy saving mode kicked in when no activity is detected at the local keyboard (ssh and serial console do not trigger keeping the GUI awake). It is probably time to look at the GUI logs.
Edit the file “/etc/X11/xorg.conf”. In section “Device”, add “ModeDebug”:
Section "Device"
   <s>ModeDebug</s>
   Option   "ModeDebug"
EndSection
…then reboot.
Once the problem occurs save a copy of “/var/log/Xorg.0.log”, and add that to this thread (if you hover your mouse over the quote icon in the upper right, then other icons should show up…the “paper clip” icon is for attaching files…you might need to rename file suffix to “.txt”). Or you can paste the log in if it is surrounded by the “code” tags (icon looks like “</>”).
The log should tell us what the driver itself is thinking.
I didnt mean the Apt commands gave the blank screen it was the last 2 commands.
I attached the log like you said.
Xorg.0.txt (14.4 KB)
That log did not include the “ModeDebug” content. Looks like I should have shown it as follows for the xorg.conf content:
Section "Device"
    Option      "ModeDebug"
EndSection
(I will correct my original which was missing the “Option” key word)
I attached the new log to this comment
This is odd, I still don’t see the ModeDebug content. The log understands through EDID that the monitor is a BenQ RL2455, but none of the extended debug content on the EDID is present (and if ModeDebug is used, then that information should be there). If you run this command, what is the last file named?
ls -ltr /var/log/Xorg.*
The last entry should be Xorg.0.log. If it is instead something like Xorg.1.log, then this would explain why the log does not contain the ModeDebug information (there should be a “mode pool” near the end, and a number of accepted/valid modes listed, along with rejected modes).
I think I added the options wrong. There was already an options tag so I think the mode debug didnt work. I have attached what I think has the mode debug in it now.
Also ls -ltr /var/log/Xorg.* last file was Xorg.0.log
Something odd is still going on, and the log lacks the extended information. Can you post the content of your “/etc/X11/xorg.conf”? You could just rename it “xorg.conf.txt” and then attach it here.
Also, the output of “head -n 1 /etc/nv_tegra_release”?
Make sure that upon booting up the timestamp from “ls -l /var/log/Xorg.0.log” coincides with the “date” command (making sure the timestamp of the current system matches a recently written log).
I attached the xorg.conf
The output for head -n 1 /etc/nv_tegra_release
# R24 (release), REVISION: 2.1, GCID: 8222915, BOARD: t210ref, EABI: aarch64, DATE: Sat Jan 14 21:31:05 UTC 2017
xorg.txt (720 Bytes)
That is a major revelation…R24.2.1 is extraordinarily old. I say this not just because it was old, but instead because this was a time of transition from 64-bit kernel with 32-bit user space to being truly 64-bit in both kernel space and user space. Much of what applies to debugging and drivers is completely different in that and earlier releases. It is quite possible the GPU driver did not respond to the ‘Option “ModeDebug”’ in that release, although I could not guarantee this.
There were also a number of updates, that if they mixed the incorrect 32-bit/64-bit user space applications, then either it wouldn’t run or it would run incorrectly. This is what I would call a “fragile” time since just months before no 64-bit ARM even existed in the wild. It was all an experiment at that time. There have been many releases since then, and even releases considered “old” are much newer than R24.x. I suspect some of the updates may have been unaware of the mix of 32-bit and 64-bit.
Do you have a specific need to stick to this release? Is it possible you could flash with the most recent release? FYI, the most recent JetPack/SDK Manager release is available here:
https://developer.nvidia.com/embedded/jetpack
(you might need to go there, log in, and then click the link again if redirect fails)
I dont need to stick to any version. I have nothing on it, I just started using it when this all happened. Are there directions to flash it with a newer version?
Do you have an Ubuntu 18.04 host PC available? If so, then it is fairly simple since you can just go to the URL in #17, log in, go to that URL again (redirect doesn’t work, otherwise you could just go there and log in), and then download the SDK Manager. The URL for the actual steps are there as well, found here:
https://docs.nvidia.com/sdk-manager/install-with-sdkm-jetson/index.html
It probably isn’t necessary, but you might run this on the PC before installing the SDKM on the host (or run this only if you run into some dependency issue during the “.deb” install on the host):
sudo apt update
sudo apt-get install libgconf-2-4 libcanberra-gtk-module
sudo apt-get install python
The file downloaded is (at this time) “sdkmanager_1.0.1-5538_amd64.deb”. You could install this on the host PC via “sudo dpkg -i sdkmanager_1.0.1-5538_amd64.deb” (there is more than one possible command to do this). Once this is installed you would start the app as a regular user via “sdkmanager” on the command line (you will be asked for a password at some point so that sudo can be used selectively by SDKM). The GUI starts, and you have several options for picking what you want to do. You could pick to just flash (and I would recommend not running any kind of extra package install until flash is verified…extra package install can be done at a later time). You will want to have a keyboard/mouse/monitor attached to the recovery mode Jetson, and the micro-B USB between the Jetson and host PC. Typing “sdkmanager” should start the app.
Note that you don’t need any IP address or networking from the Jetson during flash…this is only for adding extra packages after the Jetson is up and running normally. However, the host PC will need internet access to download various content before flash can start. Once the Jetson is flashed and booted it is good to have internet for updates, and so it doesn’t hurt if the Jetson has internet access. During extra package install the fully booted Jetson requires direct networking between host PC and Jetson. This can be done via either ethernet through a common router, or else through the micro-B USB since the fully booted Jetson default configuration provides a virtual wired ethernet adapter over the micro-B USB. If you have disabled the flash step, then you can repeat extra package management at any time without flashing again.
After you have flashed once with SDKM you will have access to the command line tools as well if you wish. On the host PC this will be at:
~/nvidia/nvidia_sdk/JetPack_<b><SomeVersion></b>_Linux_P2180/Linux_for_Tegra/
(and “SomeVersion” will probably be “4.3.1”…the “P2180” is a reference to the TX1 dev kit)
What if I dont have a ubuntu host computer?
