I am running Jetson L4T 23.1 Ubuntu 14.0.4 On boot, the boot process freezes. To recover, I power off, wait 10 minutes or so and then it may boot the next time. Attached is Serial console log. Any ideas would be appreciated.
Scanning mmc 0:1…
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
948 bytes read in 149 ms (5.9 KiB/s)
p2371-2180 eMMC boot options
1: primary kernel
Enter choice: 1: primary kernel
Retrieving file: /boot/Image
19082528 bytes read in 483 ms (37.7 MiB/s)
append: fbcon=map:0 console=tty0 console=ttyS0,115200n8 androidboot.modem=none androidboot.serialno=P2180A00P00940c003fd androidboot.security=non-secure tegraid=21.1.2.0.0 ddr_die=2048M@2048M ddr_die=2048M@4096M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 debug_uartport=lsport,0 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff2bf000 nvdumper_reserved=0xff23f000 core_edp_mv=1125 core_edp_ma=4000 gpt android.kerneltype=normal androidboot.touch_vendor_id=0 androidboot.touch_panel_id=63 androidboot.touch_feature=0 androidboot.bootreason=pmc:software_reset,pmic:0x0 root=/dev/mmcblk0p1 rw rootwait
Retrieving file: /boot/tegra210-jetson-tx1-p2597-2180-a01-devkit.dtb
250567 bytes read in 190 ms (1.3 MiB/s)
Flattened Device Tree blob at 82000000
Booting using the fdt blob at 0x82000000
reserving fdt memory region: addr=80000000 size=20000
Using Device Tree in place at 0000000082000000, end 00000000820402c6
i2c_read of GPIO expander reg 5 failed: -121
ERROR: Cannot read board ID EEPROM
WARNING: failed to read board EEPROM
Starting kernel …
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.10.67-g458d45c (buildbrain@mobile-u64-630) (gcc version 4.9 20140514 (prerelease) (GCC) ) #1 SMP PREEMPT Mon Feb 8 17:44:18 PST 2016
[ 0.000000] CPU: Cortex A57 Processor [411fd071] revision 1
[ 0.000000] alternative: enabling workaround for ARM erratum 832075
[ 0.000000] Machine: jetson_tx1
[ 0.000000] bootconsole [earlycon0] enabled
[ 0.000000] Tegra reserved memory:
[ 0.000000] LP0: ff2bf000 - ff2bffff
[ 0.000000] Bootloader framebuffer: 00000000 - 00000000
[ 0.000000] Bootloader framebuffer2: 00000000 - 00000000
[ 0.000000] Framebuffer: f5e00000 - fa5fffff
[ 0.000000] 2nd Framebuffer: fa600000 - fedfffff
[ 0.000000] Carveout: 00000000 - 00000000
[ 0.000000] Vpr: 00000000 - 0b9fffff
[ 0.000000] Tsec: 00000000 - 00000000
[ 0.000000] Bootloader Debug Data: 00000000 - 00000000
[ 0.000000] Nvdumper: ff23f000 - ff23ffff
[ 0.000000] cma: CMA: reserved 188 MiB at ea000000
[ 0.000000] cma: CMA: reserved 16 MiB at e9000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv0.2 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/arch/arm64/boot/dts/tegra210-jetson-tx1-p2597-2180-a01-devkit.dts
[ 0.000000] DTB Build time: Feb 8 2016 17:38:02
[ 0.000000] Tegra21: Speedo/IDDQ fuse revision 4
[ 0.000000] Tegra21: CPU Speedo ID 7, Soc Speedo ID 0, Gpu Speedo ID 2
[ 0.000000] Tegra21: CPU Process ID 0, Soc Process ID 0, Gpu Process ID 0
[ 0.000000] Tegra21: CPU Speedo value 2020, Soc Speedo value 1919, Gpu Speedo value 2022
[ 0.000000] Tegra21: CPU IDDQ 1892, Soc IDDQ 2156, Gpu IDDQ 2690
[ 0.000000] Tegra Revision: A02 SKU: 0x17 CPU Process: 0 Core Process: 0
[ 0.000000] tegra: PLLP fixed rate: 408000000
[ 0.000000] pll_u: boot with h/w control already set
[ 0.000000] pll_x boot misc1 0x0 : expected 0x20
[ 0.000000] (comparison mask = 0xffffff)
[ 0.000000] pll_c4 rates match 204000000 max sdmmc: vco=998400000 out0=998400000 out3=998400000
[ 0.000000] Lowering vic03 maximum rate from 1000000000 to 627200000
[ 0.000000] Lowering nvjpg maximum rate from 1000000000 to 627200000
[ 0.000000] Lowering se maximum rate from 1000000000 to 627200000
[ 0.000000] Lowering tsecb maximum rate from 1000000000 to 627200000
[ 0.000000] Lowering msenc maximum rate from 1000000000 to 716800000
[ 0.000000] Lowering nvdec maximum rate from 1000000000 to 716800000
[ 0.000000] Lowering vi maximum rate from 1000000000 to 793600000
[ 0.000000] Lowering isp maximum rate from 1000000000 to 793600000
[ 0.000000] Lowering adsp_bus maximum rate from 1200000000 to 844800000
[ 0.000000] Lowering sbus maximum rate from 600000000 to 408000000
[ 0.000000] Lowering host1x maximum rate from 600000000 to 408000000
[ 0.000000] Lowering pll_c maximum rate from 1200000000 to 1130000000
[ 0.000000] Lowering pll_c2 maximum rate from 1200000000 to 1130000000
[ 0.000000] Lowering pll_c3 maximum rate from 1200000000 to 1130000000
[ 0.000000] Lowering pll_d2 maximum rate from 1500000000 to 1130000000
[ 0.000000] Lowering pll_dp maximum rate from 1500000000 to 1130000000
[ 0.000000] Lowering sor0 maximum rate from 600000000 to 540000000
[ 0.000000] Lowering sor1 maximum rate from 600000000 to 594000000
[ 0.000000] Lowering dmic1 maximum rate from 12288000 to 12190000
[ 0.000000] Lowering dmic2 maximum rate from 12288000 to 12190000
[ 0.000000] Lowering dmic3 maximum rate from 12288000 to 12190000
[ 0.000000] Lowering hda maximum rate from 102000000 to 51000000
[ 0.000000] Lowering sdmmc2 maximum rate from 266000000 to 204000000
[ 0.000000] Lowering qspi maximum rate from 133000000 to 116600000
[ 0.000000] Lowering gbus maximum rate from 1300000000 to 998400000
[ 0.000000] Lowering cpu_g maximum rate from 3000000000 to 1734000000
[ 0.000000] Lowering cpu_lp maximum rate from 1350000000 to 1132800000
[ 0.000000] tegra dvfs: vdd_cpu: nominal 1226mV, offset 708000uV, step 19200uV, scaling enabled
[ 0.000000] tegra dvfs: vdd_core: nominal 1125mV, offset 0uV, step 12500uV, scaling enabled
[ 0.000000] tegra dvfs: vdd_gpu: nominal 1120mV, offset 710000uV, step 10000uV, scaling enabled
[ 0.000000] tegra_powergate_init: DONE
[ 0.000000] tegra21_plle_clk_enable: pll_e is already enabled
[ 0.000000] PERCPU: Embedded 13 pages/cpu @ffffffc03feb3000 s21504 r8192 d23552 u53248
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 992830
[ 0.000000] Kernel command line: fbcon=map:0 console=tty0 console=ttyS0,115200n8 androidboot.modem=none androidboot.serialno=P2180A00P00940c003fd androidboot.security=non-secure tegraid=21.1.2.0.0 ddr_die=2048M@2048M ddr_die=2048M@4096M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 debug_uartport=lsport,0 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff2bf000 nvdumper_reserved=0xff23f000 core_edp_mv=1125 core_edp_ma=4000 gpt android.kerneltype=normal androidboot.touch_vendor_id=0 androidboot.touch_panel_id=63 androidboot.touch_feature=0 androidboot.bootreason=pmc:software_reset,pmic:0x0 root=/dev/mmcblk0p1 rw rootwait
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 1884MB 2048MB = 3932MB total
[ 0.000000] Memory: 3732748k/3732748k available, 293620k reserved
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vmalloc : 0xffffff8000000000 - 0xffffffbbffff0000 (245759 MB)
[ 0.000000] vmemmap : 0xffffffbc01c00000 - 0xffffffbc05400000 ( 56 MB)
[ 0.000000] modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc100000000 ( 4096 MB)
[ 0.000000] .init : 0xffffffc001084000 - 0xffffffc0010f0400 ( 433 kB)
[ 0.000000] .text : 0xffffffc000080000 - 0xffffffc0010831c4 ( 16397 kB)
[ 0.000000] .data : 0xffffffc001104000 - 0xffffffc0012b2c00 ( 1723 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[ 0.000000] NR_IRQS:960 nr_irqs:960 0
[ 0.000000] the number of interrupt controllers found is 6
[ 0.000000] Architected local timer running at 19.20MHz (phys).
[ 0.000000] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 3579139424256ns
[ 0.000000] Wake16 for irq=34
[ 0.000000] Enabling wake16
[ 0.000000] Console: colour dummy device 80x25
[ 0.000000] console [tty0] enabled
[ 0.016486] Calibrating delay loop (skipped), value calculated using timer frequency.. lpj=192000
[ 0.025311] pid_max: default: 32768 minimum: 301
[ 0.029991] Security Framework initialized
[ 0.034027] Mount-cache hash table entries: 256
[ 0.071889] Initializing cgroup subsys debug
[ 0.074173] Initializing cgroup subsys freezer
[ 0.078764] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available
[ 0.120274] ftrace: Allocated trace_printk buffers
[ 0.180839] Brought up 4 CPUs
[ 0.181819] SMP: Total of 4 processors activated.
[ 0.186512] alternatives: patching kernel code
[ 0.193758] devtmpfs: initialized
[ 0.207050] pinctrl core: initialized pinctrl subsystem
[ 0.210598] regulator-dummy: ; Rail ON
[ 0.217166] Initializing plugin-manager
[ 0.219615] NET: Registered protocol family 16
[ 0.225716] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.231407] console [pstore-1] enabled
[ 0.234418] ramoops: attached 0x200000@0xf5c00000, ecc: 0/0
[ 0.240306] I2C first dynamic bus number based on alias = 7
[ 0.245558] cpuidle: using governor ladder
[ 0.249575] cpuidle: using governor menu
[ 0.254025] PMC: Setting PMIC interrupt active-low
[ 0.258703] tegra-pmc device create success
[ 0.262477] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.269599] Clear bootloader IO dpd settings
[ 0.273855] PMC: configuring io pad defaults
[ 0.278301] PMC: IO pad audio voltage is 1800000
[ 0.282793] PMC: IO pad cam voltage is 1800000
[ 0.287203] PMC: IO pad dbg voltage is 1800000
[ 0.291632] PMC: IO pad dmic voltage is 1800000
[ 0.296129] PMC: IO pad pex-ctrl voltage is 1800000
[ 0.300992] PMC: IO pad spi voltage is 1800000
[ 0.305403] PMC: IO pad uart voltage is 1800000
[ 0.309909] PMC: IO pad bb voltage is 1800000
[ 0.314251] PMC: IO pad audio-hv voltage is 1800000
[ 0.319096] PMC: IO pad spi-hv voltage is 1800000
[ 0.323785] PMC: IO pad gpio voltage is 1800000
[ 0.328283] PMC: IO pad sdmmc3 voltage is 1800000
[ 0.332879] PMC: IO pad pex-bias power is disable
[ 0.337550] PMC: IO pad pex-clk1 power is disable
[ 0.342238] PMC: IO pad pex-clk2 power is disable
[ 0.346901] T210 pmc padctrl driver initialized
[ 0.351466] T210 pmc config for bootrom command passed
[ 0.357514] INFO: pinmux CLAMP_INPUTS_WHEN_TRISTATED: disabled
[ 0.364192] clk_init_from_dt_table: clocks are set from t210-clk-init-table:clkinit-0
[ 0.372834] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.377037] platform bpmp.15: domain=ffffffc0ff04d698 allocates as[0]=ffffffc0ff1040a8
[ 0.384970] platform bpmp.15: IOVA linear map 0x00000000ff2c0000(40000)
[ 0.391833] bpmp bpmp.15: bpmp_connect returned 0
[ 0.396715] MC mapped MMIO address: 0xffffff800003a000
[ 0.401224] MC0 mapped MMIO address: 0xffffff8000072000
[ 0.406409] MC1 mapped MMIO address: 0xffffff8000098000
[ 0.411714] mc-err: [mcerr] (255) csr_mpcorer: non secure access to secure region
[ 0.418975] mc-err: [mcerr] status = 0x30007027; addr = 0xffffffc0
[ 0.419967] tegra210-pinctrl 700008d4.pinmux: lookup the user state drive not found
[ 0.419973] tegra210-pinctrl 700008d4.pinmux: lookup the user state unused not found
[ 0.419977] tegra210-pinctrl 700008d4.pinmux: Probed Tegra pinctrl driver
[ 0.420506] GPIO chip tegra-gpio: created GPIO range 0->245 ==> 700008d4.pinmux PIN 0->245
[ 0.420553] tegra-gpio 6000d000.gpio: Initialising GPIO state 0: name wlan-default
[ 0.420618] gpiochip_add: registered GPIOs 0 to 255 on device: tegra-gpio
[ 0.423221] Wake44 for irq=81
[ 0.423255] Wake40 for irq=53
[ 0.423257] Wake41 for irq=53
[ 0.423258] Wake42 for irq=53
[ 0.423260] Wake43 for irq=53
[ 0.423734] platform 70006000.serial: domain=ffffffc0ff125298 allocates as[0]=ffffffc0ff104110
[ 0.424669] platform sound.18: domain=ffffffc0ff125518 allocates as[0]=ffffffc0ff104178
[ 0.426775] platform tegradc.1: domain=ffffffc0ff125918 allocates as[0]=ffffffc0ff1041e0
[ 0.430148] platform tegradc.1: IOVA linear map 0x00000000f5e00000(4800000)
[ 0.433503] platform tegradc.1: IOVA linear map 0x00000000fa600000(4800000)
[ 0.433665] platform tegradc.1: IOVA linear map 0x00000000ea000000(bc00000)
[ 0.435589] platform gpu.0: domain=ffffffc0ff125a98 allocates as[0]=ffffffc0ff104248
[ 0.435628] platform gpu.0: domain=ffffffc0ff125a98 allocates as[1]=ffffffc0ff1042b0
[ 0.435669] platform gpu.0: domain=ffffffc0ff125a98 allocates as[2]=ffffffc0ff104318
[ 0.435708] platform gpu.0: domain=ffffffc0ff125a98 allocates as[3]=ffffffc0ff104380
[ 0.439826] platform sdhci-tegra.3: domain=ffffffc0ff192098 allocates as[0]=ffffffc0ff1043e8
[ 0.440300] platform sdhci-tegra.0: domain=ffffffc0ff192298 allocates as[0]=ffffffc0ff104450
[ 0.440592] Wake39 for irq=52
[ 0.449428] gpio wake52 for gpio=61
[ 0.449730] gpio wake8 for gpio=58
[ 0.449767] gpio wake8 for gpio=58
[ 0.451010] irq: no irq domain found for /soctherm@0x700E2000 !
[ 0.451175] irq: no irq domain found for /soctherm@0x700E2000 !
[ 0.451330] board_info: id:sku:fab:major:minor = 0x0884:0x03e8:0x00:0x00:0x00
[ 0.451345] PMC dt information non-NULL tegra_init_suspend
[ 0.456920] Loading EMC tables…
[ 0.457002] tegra: Using EMC sequence ‘21021’ for Rev. 7 tables
[ 0.457016] tegra: emc: Derated table is valid.
[ 0.457029] Lowering emc maximum rate from 1800000000 to 1600000000
[ 0.457041] tegra: validated EMC DFS table
[ 0.467242] swapper/0 isomgr_init(): iso emc max clk=1600000KHz
[ 0.467246] swapper/0 isomgr_init(): max_iso_bw=11520000KB
[ 0.650664] mc-err: [mcerr] secure: no, access-type: read, SMMU fault: none
[ 1.720353] vdso: 2 pages (1 code, 1 data) at base ffffffc00110a000
[ 1.724642] vdso32: 2 pages (1 code, 1 data) at base ffffffc001109000
[ 1.731105] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 1.737932] nvdumper: last reboot was unknown
[ 1.742159] nvdumper: set_dirty_state 0x2badface
[ 1.747148] Tegra restart notifier registered.
[ 1.760856] bio: create slab at 0
[ 1.764461] vdd-ac-bat: 5000 mV ; Rail ON
[ 1.767065] vdd-cpu-fixed: 1000 mV ; Rail ON
[ 1.771819] vgaarb: loaded
[ 1.774109] SCSI subsystem initialized
[ 1.777860] usbcore: registered new interface driver usbfs
[ 1.783034] usbcore: registered new interface driver hub
[ 1.788337] usbcore: registered new device driver usb
[ 1.793924] i2c i2c-0: of_i2c: modalias failure on /i2c@7000c000/icm20628@68
[ 1.800335] i2c i2c-0: of_i2c: modalias failure on /i2c@7000c000/ak8963@0d
[ 1.807166] i2c i2c-0: of_i2c: modalias failure on /i2c@7000c000/bmp280@77
[ 1.814020] i2c i2c-0: of_i2c: modalias failure on /i2c@7000c000/cm32180@48
[ 1.820954] i2c i2c-0: of_i2c: modalias failure on /i2c@7000c000/iqs263@44
[ 1.827838] gpio wake33 for gpio=188
[ 1.832636] regulator_get() failed for (1-0074,vcc), -19
[ 1.836635] pca953x 1-0074: no regulator found for vcc. Assuming vcc is always powered
[ 1.844607] tegra-i2c 7000c400.i2c: no acknowledge from address 0x74
[ 1.850897] pca953x 1-0074: failed reading register
[ 1.855703] pca953x: probe of 1-0074 failed with error -121
[ 1.861530] regulator_get() failed for (1-0077,vcc), -19
[ 1.866529] pca953x 1-0077: no regulator found for vcc. Assuming vcc is always powered
[ 1.874496] tegra-i2c 7000c400.i2c: no acknowledge from address 0x77
[ 1.880794] pca953x 1-0077: failed reading register
[ 1.885600] pca953x: probe of 1-0077 failed with error -121
[ 1.891654] i2c i2c-3: of_i2c: modalias failure on /i2c@7000c700/prod-settings
[ 1.899274] max77620 4-003c: CID0: 0xaf
[ 1.902251] max77620 4-003c: CID1: 0x1f
[ 1.906045] max77620 4-003c: CID2: 0x0c
[ 1.909857] max77620 4-003c: CID3: 0x59
[ 1.913685] max77620 4-003c: CID4: 0x3c
[ 1.917484] max77620 4-003c: CID5: 0x80
[ 1.921310] max77620 4-003c: MAX77620 PMIC OTP Version is 0x3C
[ 1.928412] max77620-pmic max77620-pmic: Consumer c2 does not have device name
[ 1.934319] max77620-pmic max77620-pmic: Consumer c0 does not have device name
[ 1.942369] vdd_core: 600 ↔ 1400 mV at 1000 mV with ramp delay 27500 uV/us ; Rail ON
[ 1.950211] vddio-ddr: at 1125 mV with ramp delay 27500 uV/us ; Rail ON
[ 1.956532] vdd-pre-reg: 1350 mV with ramp delay 27500 uV/us ; Rail ON
[ 1.963550] vdd-1v8: 1800 mV with ramp delay 27500 uV/us ; Rail ON
[ 1.969362] avdd-sys: 1200 mV with ramp delay 100000 uV/us ; Rail ON
[ 1.975023] avdd-sys: supplied by vdd-pre-reg
[ 1.979910] vdd-pex: 1050 mV with ramp delay 100000 uV/us ; Rail ON
[ 1.985573] vdd-pex: supplied by vdd-pre-reg
[ 1.990211] vddio-sdmmc1: 1800 ↔ 3300 mV at 3300 mV with ramp delay 100000 uV/us ; Rail ON
[ 1.998739] vdd-cam-hv: 2800 mV with ramp delay 100000 uV/us ; Rail OFF
[ 2.005464] vdd-rtc: 850 mV with ramp delay 100000 uV/us ; Rail ON
[ 2.011496] avdd-ts-hv: 3300 mV with ramp delay 100000 uV/us ; Rail OFF
[ 2.018751] vdd-ts: 1800 mV with ramp delay 100000 uV/us ; Rail OFF
[ 2.024566] vdd-gen-pll-edp: 1050 mV with ramp delay 100000 uV/us ; Rail ON
[ 2.030822] vdd-gen-pll-edp: supplied by vdd-pre-reg
[ 2.036387] vdd-hdmi-dp: 1050 mV with ramp delay 100000 uV/us ; Rail ON
[ 2.042339] vdd-hdmi-dp: supplied by vdd-pre-reg
[ 2.047366] max77620-gpio max77620-gpio.0: Initialising GPIO state 1: name gpio_default
[ 2.054960] gpiochip_add: registered GPIOs 1016 to 1023 on device: max77620-gpio
[ 2.063333] max77620-gpio max77620-gpio.0: max77620 gpio successfully initialized
[ 2.072967] max77620 4-003c: max77620 probe successfully
[ 2.076917] Linux video capture interface: v2.00
[ 2.080925] pps_core: LinuxPPS API ver. 1 registered
[ 2.085817] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 2.094947] PTP clock support registered
[ 2.100377] Advanced Linux Sound Architecture Driver Initialized.
[ 2.105244] Bluetooth: Core ver 2.16
[ 2.108464] NET: Registered protocol family 31
[ 2.112873] Bluetooth: HCI device and connection manager initialized
[ 2.119192] Bluetooth: HCI socket layer initialized
[ 2.124053] Bluetooth: L2CAP socket layer initialized
[ 2.129085] Bluetooth: SCO socket layer initialized
[ 2.135190] vdd-3v3: 3300 mV ; Rail ON
[ 2.138889] max77620-gpio7: 1050 mV ; Rail ON
[ 2.142023] max77620-gpio7: supplied by vdd-gen-pll-edp
[ 2.147451] lcd-bl-en: 1800 mV ; Rail ON
[ 2.151324] en-vdd-sd: 3300 mV ; Rail OFF
[ 2.155104] en-vdd-sd: supplied by vdd-3v3
[ 2.159285] reg-fixed-sync-voltage 5.regulator: Consumer c1 does not have device name
[ 2.166984] platform 5.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 2.181603] vdd-sys-boost: 5000 mV ; Rail ON
[ 2.184032] platform 7.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 2.191996] aux-3v3: 3300 mV ; Rail ON
[ 2.195774] snsr_pm: 3300 mV ; Rail ON
[ 2.199998] vdd-disp-3v0: 3000 mV ; Rail ON
[ 2.203632] platform d.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 2.211618] usb-vbus1: 5000 mV ; Rail OFF
[ 2.215480] usb-vbus1: supplied by vdd-3v3
[ 2.219753] usb-vbus3: 5000 mV ; Rail OFF
[ 2.223530] usb-vbus3: supplied by vdd-3v3
[ 2.227731] platform c9.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 2.235719] platform ca.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 2.243782] platform cb.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 2.251838] platform cc.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 2.259886] platform cd.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 2.267956] platform ce.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 2.276092] rtl-5v0: ; Rail OFF
[ 2.279273] en-usb-vbus2: ; Rail OFF
[ 2.282755] platform d1.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 2.291333] regulator-pwm 0.pwm-regulator: PWM request deferred
[ 2.296557] platform 0.pwm-regulator: Driver regulator-pwm requests probe deferral
[ 2.304634] vdd_gpu: applied init 1000000uV constraint
[ 2.309204] vdd_gpu: 710 ↔ 1320 mV at 1000 mV ; Rail OFF
[ 2.316073] vdd_cpu: applied init 1000000uV constraint
[ 2.319864] vdd_cpu: 708 ↔ 1322 mV at 1000 mV normal ; Rail ON
[ 2.328122] gpio wake34 for gpio=200
[ 2.331055] extcon-gpio-states 1.extcon: Cable state 2
[ 2.336367] Switching to clocksource arch_sys_counter
[ 2.363502] No Device Node present for smmu client: tegra-carveouts !!
[ 2.368056] No Device Node present for smmu client: tegra-carveouts !!
[ 2.374683] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 2.381430] No Device Node present for smmu client: tegra-carveouts !!
[ 2.387558] dma_declare_coherent_resizable_cma_memory:278: resizable heap=vpr, base=0x0x00000000ea000000, size=0xbc00000
[ 2.398397] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (6) rem_chunk_size(0x1c00000)
[ 2.409114] cma: enabled page replacement for spfn=ea000, epfn=f5c00
[ 2.415289] dma_declare_coherent_resizable_cma_memory:325: resizable cma heap=vpr create successful
[ 2.424124] nvmap_page_pool_init: Total RAM pages: 985411
[ 2.429657] nvmap_page_pool_init: nvmap page pool size: 123176 pages (481 MB)
[ 2.436831] nvmap_background_zero_thread: PP zeroing thread starting.
[ 2.437004] misc nvmap: iram :dma coherent mem declare 0x0000000040001000,258048
[ 2.437475] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 2.437862] misc nvmap: created heap vpr base 0x00000000ea000000 size (192512KiB)
[ 2.438163] nvmap:inner cache maint threshold=2097152
[ 2.438163] No Device Node present for smmu client: tegra-carveouts !!
[ 2.445742] Wake39 for irq=52
[ 2.445833] tegra-otg tegra-otg: otg transceiver registered
[ 2.446281] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 2.447142] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 2.447407] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 2.447557] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 2.447674] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 2.448509] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 2.448687] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tboard_tegra
[ 2.449511] t210_sata_uphy_pll_init: init sata uphy pll
[ 2.449523] t210_sata_uphy_pll_init SATA uses SATA Lane
[ 2.449839] tegra_xusb_padctl_phy_enable: init pex uphy pll
[ 2.451331] tegra210-pmc-iopower pmc-iopower.20: Rail iopower-sys is having fixed voltage 1800000
[ 2.451404] tegra210-pmc-iopower pmc-iopower.20: Rail iopower-uart is having fixed voltage 1800000
[ 2.451474] tegra210-pmc-iopower pmc-iopower.20: Rail iopower-audio is having fixed voltage 1800000
[ 2.451546] tegra210-pmc-iopower pmc-iopower.20: Rail iopower-cam is having fixed voltage 1800000
[ 2.451629] tegra210-pmc-iopower pmc-iopower.20: Rail iopower-pex-ctrl is having fixed voltage 1800000
[ 2.451705] tegra210-pmc-iopower pmc-iopower.20: Rail iopower-sdmmc1 is having voltages: 1800000:3300000
[ 2.451779] tegra210-pmc-iopower pmc-iopower.20: Rail iopower-sdmmc3 is having fixed voltage 1800000
[ 2.451852] tegra210-pmc-iopower pmc-iopower.20: Rail iopower-sdmmc4 is having fixed voltage 1800000
[ 2.451918] tegra210-pmc-iopower pmc-iopower.20: Rail iopower-audio-hv is having fixed voltage 1800000
[ 2.451987] tegra210-pmc-iopower pmc-iopower.20: Rail iopower-debug is having fixed voltage 1800000
[ 2.452068] tegra210-pmc-iopower pmc-iopower.20: Rail iopower-dmic is having fixed voltage 1800000
[ 2.452143] tegra210-pmc-iopower pmc-iopower.20: Rail iopower-gpio is having fixed voltage 1800000
[ 2.452214] tegra210-pmc-iopower pmc-iopower.20: Rail iopower-spi is having fixed voltage 1800000
[ 2.452283] tegra210-pmc-iopower pmc-iopower.20: Rail iopower-spi-hv is having fixed voltage 1800000
[ 2.452353] tegra210-pmc-iopower pmc-iopower.20: Rail iopower-sdmmc2 is having fixed voltage 1800000
[ 2.452422] tegra210-pmc-iopower pmc-iopower.20: Rail iopower-dp is having fixed voltage 1800000
[ 2.452427] tegra210-pmc-iopower pmc-iopower.20: NO_IO_POWER setting 0x0
[ 2.452667] NET: Registered protocol family 2
[ 2.453239] TCP established hash table entries: 32768 (order: 7, 524288 bytes)
[ 2.453411] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 2.453601] TCP: Hash tables configured (established 32768 bind 32768)
[ 2.453669] TCP: reno registered
[ 2.453676] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 2.453705] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 2.453962] NET: Registered protocol family 1
[ 2.454263] RPC: Registered named UNIX socket transport module.
[ 2.454266] RPC: Registered udp transport module.
[ 2.454268] RPC: Registered tcp transport module.
[ 2.454271] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 2.454623] tegra-fuse tegra-fuse: Fuse driver initialized succesfully
[ 2.459693] host1x host1x: initialized
[ 2.468285] NTFS driver 2.1.30 [Flags: R/O].
[ 2.468485] fuse init (API version 7.22)
[ 2.468796] msgmni has been set to 7698
[ 2.469825] io scheduler noop registered (default)
[ 2.470031] Tegra cpuquiet initialized: disabled
[ 2.471900] tegra-pcie 1003000.pcie-controller: PCIE: Enable power rails
[ 2.472839] tegra-pcie 1003000.pcie-controller: probing port 0, using 4 lanes and lane map as 0x14
[ 2.474893] tegra-pcie 1003000.pcie-controller: probing port 1, using 1 lanes and lane map as 0x14
[ 2.909896] tegra-pcie 1003000.pcie-controller: link 1 down, retrying
[ 3.315942] tegra-pcie 1003000.pcie-controller: link 1 down, retrying
[ 3.721981] tegra-pcie 1003000.pcie-controller: link 1 down, retrying
[ 3.728441] tegra-pcie 1003000.pcie-controller: link 1 down, ignoring
[ 3.733048] tegra-pcie 1003000.pcie-controller: PCI host bridge to bus 0000:00
[ 3.740099] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 3.746933] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 3.754239] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 3.759666] pci_bus 0000:00: root bus resource [io 0x1000-0xffff]
[ 3.766204] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 3.789992] pci 0000:00:01.0: BAR 8: assigned [mem 0x13000000-0x130fffff]
[ 3.794786] pci 0000:00:01.0: BAR 7: assigned [io 0x1000-0x1fff]
[ 3.800879] pci 0000:01:00.0: BAR 0: assigned [mem 0x13000000-0x1301ffff]
[ 3.807618] pci 0000:01:00.0: BAR 3: assigned [mem 0x13020000-0x13023fff]
[ 3.814388] pci 0000:01:00.0: BAR 2: assigned [io 0x1000-0x101f]
[ 3.820455] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 3.825377] pci 0000:00:01.0: bridge window [io 0x1000-0x1fff]
[ 3.831454] pci 0000:00:01.0: bridge window [mem 0x13000000-0x130fffff]
[ 3.838212] PCI: enabling device 0000:00:01.0 (0140 → 0143)
[ 3.844011] pcieport 0000:00:01.0: Signaling PME through PCIe PME interrupt
[ 3.850783] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 3.857357] tegra-pcie 1003000.pcie-controller: PCIE: No Link speed change happened
[ 3.867037] tsec tsec: initialized
[ 3.869500] tsec tsecb: initialized
[ 3.873832] nvdec nvdec: initialized
[ 3.878186] falcon vic03: initialized
[ 3.881238] falcon msenc: initialized
[ 3.884641] falcon nvjpg: initialized
[ 3.888252] tegradc tegradc.1: Display dc.54240000 registered with id=0
[ 3.893872] display board info: id 0x0, fab 0x0
[ 3.898626] panel_select fail by _node_status
[ 3.902628] display board info: id 0x0, fab 0x0
[ 3.907284] panel_select fail by _node_status
[ 3.911419] parse_tmds_config: No tmds-config node
[ 3.916270] of_dc_parse_platform_data: could not find vrr-settings node
[ 3.922769] of_dc_parse_platform_data: could not find SD settings node
[ 3.929258] of_dc_parse_platform_data: could not find cmu node
[ 3.935159] of_dc_parse_platform_data: could not find cmu node for adobeRGB
[ 3.942023] tegradc tegradc.1: DT parsed successfully
[ 3.947217] hdmi: couldn’t get regulator vdd_hdmi_5v0
[ 3.952226] display board info: id 0x0, fab 0x0
[ 3.956787] panel_select fail by _node_status
[ 3.961173] gpio wake53 for gpio=225
[ 3.992225] tegradc tegradc.1: nominal-pclk:74250000 parent:74250000 div:1.0 pclk:74250000 73507500~80932500
[ 4.350898] tegradc tegradc.1: probed
[ 4.353221] tegradc tegradc.1: nominal-pclk:74250000 parent:74250000 div:1.0 pclk:74250000 73507500~80932500
[ 4.360098] Console: switching to colour frame buffer device 160x45
[ 4.380631] tegradc tegradc.1: fb registered
[ 4.385620] tegra_camera_platform tegra-camera-platform.37: tegra_camera_probe:camera_platform_driver probe
[ 4.397758] tegra-apbdma tegra-apbdma: Tegra20 APB DMA driver register 32 channels
[ 4.404959] tegra-adma tegra210-adma: Tegra210 ADMA driver register 10 channels
[ 4.411052] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 4.417065] No Device Node present for smmu client: serial8250 !!
[ 4.423090] No Device Node present for smmu client: serial8250 !!
[ 4.429981] No Device Node present for smmu client: serial8250 !!
[ 4.435218] No Device Node present for smmu client: serial8250 !!
[ 4.441618] of_serial 70006000.serial: RX periodic polling enabled
[ 4.447675] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 68) is a Tegra
[ 4.454402] console [ttyS0] enabled, bootconsole disabled
[ 4.465309] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 69) is a SERIAL_TEGRA
[ 4.475091] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 78) is a SERIAL_TEGRA
[ 4.485164] serial-tegra 70006300.serial: RX in PIO mode
[ 4.492505] 70006300.serial: ttyTHS3 at MMIO 0x70006300 (irq = 122) is a SERIAL_TEGRA
[ 4.520725] tegradc tegradc.1: nominal-pclk:74250000 parent:74250000 div:1.0 pclk:74250000 73507500~80932500
[ 4.521533] brd: module loaded
[ 4.523997] loop: module loaded
