Reproduced the issue and captured below serial logs
247 packages can be updated.
7 updates are security updates.
New release '18.04.5 LTS' available.
Run 'do-release-upgrade' to upgrade to it.
[ 15.765129] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[ 15.818678] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[ 15.847370] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
nvidia@bot-3874:~$ [ 15.879965] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[ 15.888305] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[ 15.897261] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[ 15.923970] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[ 15.932234] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[ 15.951174] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[ 16.010019] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[ 16.209674] IPVS: Creating netns size=1424 id=3
[ 684.493976] CFG80211-ERROR) wl_is_linkdown : Link down Reason : WLC_E_DEAUTH_IND
[ 684.501542] CFG80211-ERROR) wl_notify_connect_status : link down if wlan0 may call cfg80211_disconnected. event : 6, reason=7 from 00:35:1a:19:ff:3f
[ 684.532371] CFG80211-ERROR) wl_cfg80211_connect : Connectting with00:35:1a:19:ff:3f channel (48) ssid "gorwifi_2", len (9)
[ 684.547867] cfg80211: World regulatory domain updated:
[ 684.553606] cfg80211: DFS Master region: unset
[ 684.558751] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 684.569254] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 684.577691] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 684.585800] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 684.594191] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 684.596562] CFG80211-ERROR) wl_notify_connect_status : wl_bss_connect_done succeeded with 00:35:1a:19:ff:3f
[ 684.613538] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 684.620710] CFG80211-ERROR) wl_bss_connect_done : Report connect result - connection succeeded
[ 684.620718] CFG80211-ERROR) wl_notify_connect_status : wl_bss_connect_done succeeded with 00:35:1a:19:ff:3f
[ 684.641367] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 684.649546] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 684.657645] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 684.671531] cfg80211: World regulatory domain updated:
[ 684.676735] cfg80211: DFS Master region: unset
[ 684.681104] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 684.690845] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 684.698930] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 684.706966] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 684.714984] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 684.724467] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 684.733960] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 684.742090] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 684.750119] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 684.789493] cfg80211: Regulatory domain changed to country: IN
[ 684.795369] cfg80211: DFS Master region: JP
[ 684.799513] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 684.809385] cfg80211: (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 684.817415] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 684.826939] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 684.836433] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 1690.324240] CFG80211-ERROR) wl_bss_roaming_done : wl_bss_roaming_done succeeded to 00:f2:8b:d2:11:2f (ch:64)
[ 1690.334434] CFG80211-ERROR) wl_notify_connect_status : wl_bss_connect_done succeeded with 00:f2:8b:d2:11:2f
[ 1690.346033] CFG80211-ERROR) wl_bss_roaming_done : BSS already present, Skipping roamed event to upper layer
[ 1712.643975] CFG80211-ERROR) wl_bss_roaming_done : wl_bss_roaming_done succeeded to 00:35:1a:19:ff:3f (ch:48)
[ 1712.654677] CFG80211-ERROR) wl_notify_connect_status : wl_bss_connect_done succeeded with 00:35:1a:19:ff:3f
[ 1712.709666] CFG80211-ERROR) wl_bss_roaming_done : BSS already present, Skipping roamed event to upper layer
[ 1737.530513] CFG80211-ERROR) wl_bss_roaming_done : wl_bss_roaming_done succeeded to 00:f2:8b:d2:11:2f (ch:64)
[ 1737.543132] CFG80211-ERROR) wl_notify_connect_status : wl_bss_connect_done succeeded with 00:f2:8b:d2:11:2f
[ 1737.554825] CFG80211-ERROR) wl_bss_roaming_done : BSS already present, Skipping roamed event to upper layer
[ 1753.996221] CFG80211-ERROR) wl_bss_roaming_done : wl_bss_roaming_done succeeded to 00:35:1a:19:ff:3f (ch:48)
[ 1754.010738] CFG80211-ERROR) wl_notify_connect_status : wl_bss_connect_done succeeded with 00:35:1a:19:ff:3f
[ 1754.071173] CFG80211-ERROR) wl_bss_roaming_done : BSS already present, Skipping roamed event to upper layer
[ 3171.121673] Unable to handle kernel paging request at virtual address dead000000000108
[ 3171.129653] pgd = ffffffc0ce248000
[ 3171.133075] [dead000000000108] *pgd=000000014e193003, *pud=000000014e193003, *pmd=0000000000000000
[ 3171.142119] Internal error: Oops: 96000044 [#1] PREEMPT SMP
[ 3171.147711] Modules linked in: xt_addrtype br_netfilter bcmdhd e1000e ptp pps_core bluedroid_pm
[ 3171.156597] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.4.38-tegra #1
[ 3171.163050] Hardware name: jetson_tx1 (DT)
[ 3171.167166] task: ffffffc0012cb240 ti: ffffffc0012b4000 task.ti: ffffffc0012b4000
[ 3171.174692] PC is at tegra_dma_tasklet+0x44/0xcc
[ 3171.179328] LR is at tegra_dma_tasklet+0x84/0xcc
[ 3171.183961] pc : [<ffffffc0004fcfe0>] lr : [<ffffffc0004fd020>] pstate: 200001c5
[ 3171.191367] sp : ffffffc0012b7be0
[ 3171.194697] x29: ffffffc0012b7be0 x28: ffffffc0012b4000
[ 3171.200054] x27: ffffffc00128eab8 x26: ffffffc0012ba000
[ 3171.205411] x25: 0000000000000101 x24: ffffffc0302cd250
[ 3171.210766] x23: ffffffc0302cd180 x22: ffffffc0302cd208
[ 3171.216118] x21: ffffffc03031d818 x20: ffffffc00054fff0
[ 3171.221470] x19: 0000000000000000 x18: 0000000000000000
[ 3171.226822] x17: 0000000000000000 x16: 0000000000000000
[ 3171.232171] x15: 0000000000000000 x14: 0000000000000001
[ 3171.237522] x13: 00000000000162c8 x12: 0000000000000000
[ 3171.242877] x11: 0000000000002c59 x10: 0000000000000024
[ 3171.248228] x9 : 0000000000004000 x8 : 0000000000000000
[ 3171.253578] x7 : 0000000000000001 x6 : dead000000000100
[ 3171.258933] x5 : dead000000000200 x4 : 0000000000000100
[ 3171.264284] x3 : 0000000000000000 x2 : ffffffc0f07ccc70
[ 3171.269638] x1 : 0000000000000140 x0 : 0000000000000140
[ 3171.274990]
[ 3171.276505] Process swapper/0 (pid: 0, stack limit = 0xffffffc0012b4020)
[ 3171.283218] Call trace:
[ 3171.285688] [<ffffffc0004fcfe0>] tegra_dma_tasklet+0x44/0xcc
[ 3171.291382] [<ffffffc0000a806c>] tasklet_action+0x8c/0xfc
[ 3171.296801] [<ffffffc0000a74c0>] __do_softirq+0x1a0/0x3f4
[ 3171.302219] [<ffffffc0000a79e4>] irq_exit+0x74/0xe0
[ 3171.307129] [<ffffffc0000f2cf4>] __handle_domain_irq+0x90/0xb0
[ 3171.312985] [<ffffffc000080f10>] gic_handle_irq+0x68/0xbc
[ 3171.318405] [<ffffffc000083f44>] el1_irq+0x84/0x100
[ 3171.323323] [<ffffffc0007fbe54>] cpuidle_enter+0x18/0x20
[ 3171.328656] [<ffffffc0000e2518>] call_cpuidle+0x48/0x54
[ 3171.333900] [<ffffffc0000e27ec>] cpu_startup_entry+0x2c8/0x394
[ 3171.339767] [<ffffffc000b1ffe4>] rest_init+0x84/0x8c
[ 3171.344768] [<ffffffc001168998>] start_kernel+0x3ac/0x3c0
[ 3171.350185] [<0000000080b26000>] 0x80b26000
[ 3171.356359] ---[ end trace 0765fd2ddef179b0 ]---
[ 3171.369388] Kernel panic - not syncing: Fatal exception in interrupt
[ 3171.375974] CPU1: stopping
[ 3171.378755] CPU: 1 PID: 0 Comm: swapper/1 Tainted: G D 4.4.38-tegra #1
[ 3171.386421] Hardware name: jetson_tx1 (DT)
[ 3171.390531] Call trace:
[ 3171.393023] [<ffffffc000088fc8>] dump_backtrace+0x0/0xf4
[ 3171.398357] [<ffffffc0000890d0>] show_stack+0x14/0x1c
[ 3171.403444] [<ffffffc0003769ac>] dump_stack+0xac/0xe4
[ 3171.408519] [<ffffffc00008e964>] handle_IPI+0x16c/0x328
[ 3171.413761] [<ffffffc000080f3c>] gic_handle_irq+0x94/0xbc
[ 3171.419175] [<ffffffc000083f44>] el1_irq+0x84/0x100
[ 3171.424083] [<ffffffc0007fbe54>] cpuidle_enter+0x18/0x20
[ 3171.429412] [<ffffffc0000e2518>] call_cpuidle+0x48/0x54
[ 3171.434651] [<ffffffc0000e27ec>] cpu_startup_entry+0x2c8/0x394
[ 3171.440500] [<ffffffc00008e514>] secondary_start_kernel+0x15c/0x168
[ 3171.446781] [<000000008008126c>] 0x8008126c
[ 3171.450981] CPU3: stopping
[ 3171.453731] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G D 4.4.38-tegra #1
[ 3171.461396] Hardware name: jetson_tx1 (DT)
[ 3171.465505] Call trace:
[ 3171.467982] [<ffffffc000088fc8>] dump_backtrace+0x0/0xf4
[ 3171.473313] [<ffffffc0000890d0>] show_stack+0x14/0x1c
[ 3171.478386] [<ffffffc0003769ac>] dump_stack+0xac/0xe4
[ 3171.483456] [<ffffffc00008e964>] handle_IPI+0x16c/0x328
[ 3171.488696] [<ffffffc000080f3c>] gic_handle_irq+0x94/0xbc
[ 3171.494111] [<ffffffc000083f44>] el1_irq+0x84/0x100
[ 3171.499010] [<ffffffc0007fbe54>] cpuidle_enter+0x18/0x20
[ 3171.504338] [<ffffffc0000e2518>] call_cpuidle+0x48/0x54
[ 3171.509578] [<ffffffc0000e27ec>] cpu_startup_entry+0x2c8/0x394
[ 3171.515429] [<ffffffc00008e514>] secondary_start_kernel+0x15c/0x168
[ 3171.521707] [<000000008008126c>] 0x8008126c
[ 3171.525905] CPU2: stopping
[ 3171.528653] CPU: 2 PID: 0 Comm: swapper/2 Tainted: G D 4.4.38-tegra #1
[ 3171.536319] Hardware name: jetson_tx1 (DT)
[ 3171.540428] Call trace:
[ 3171.542903] [<ffffffc000088fc8>] dump_backtrace+0x0/0xf4
[ 3171.548235] [<ffffffc0000890d0>] show_stack+0x14/0x1c
[ 3171.553309] [<ffffffc0003769ac>] dump_stack+0xac/0xe4
[ 3171.558377] [<ffffffc00008e964>] handle_IPI+0x16c/0x328
[ 3171.563617] [<ffffffc000080f3c>] gic_handle_irq+0x94/0xbc
[ 3171.569032] [<ffffffc000083f44>] el1_irq+0x84/0x100
[ 3171.573931] [<ffffffc0007fbe54>] cpuidle_enter+0x18/0x20
[ 3171.579259] [<ffffffc0000e2518>] call_cpuidle+0x48/0x54
[ 3171.584500] [<ffffffc0000e27ec>] cpu_startup_entry+0x2c8/0x394
[ 3171.590349] [<ffffffc00008e514>] secondary_start_kernel+0x15c/0x168
[ 3171.596628] [<000000008008126c>] 0x8008126c
[ 3171.639763] Rebooting in 30 seconds..�[0000.194] [TegraBoot] (version 00.00.2014.50-mobile-6987b70e)
[0000.200] Processing in cold boot mode Bootloader 2
[0000.204] A02 Bootrom Patch rev = 1023
[0000.208] Power-up reason: software reset
[0000.212] No Battery Present
[0000.214] RamCode = 1
[0000.217] Platform has Ddr4 type ram
[0000.220] max77620 disabling SD1 Remote Sense
[0000.224] Setting Ddr voltage to 1125mv
[0000.228] Serial Number of Pmic Max77663: 0x428c6
[0000.236] Entering ramdump check
[0000.239] Get RamDumpCarveOut = 0xff23f000
[0000.243] RamDumpCarveOut=0xff23f000, RamDumperFlag=0x0
[0000.248] Last reboot was clean, booting normally!
[0000.252] Sdram initialization is successful
[0000.256] SecureOs Carveout Base=0xff800000 Size=0x00800000
[0000.262] GSC1 Carveout Base=0xff700000 Size=0x00100000
[0000.267] GSC2 Carveout Base=0xff600000 Size=0x00100000
[0000.272] GSC3 Carveout Base=0xff500000 Size=0x00100000
[0000.277] GSC4 Carveout Base=0xff400000 Size=0x00100000
[0000.282] GSC5 Carveout Base=0xff300000 Size=0x00100000
[0000.288] BpmpFw Carveout Base=0xff2c0000 Size=0x00040000
[0000.293] Lp0 Carveout Base=0xff2bf000 Size=0x00001000
[0000.308] RamDump Carveout Base=0xff23f000 Size=0x00080000
[0000.314] Platform-DebugCarveout: 0
[0000.317] Nck Carveout Base=0xff03f000 Size=0x00200000
[0000.322] Non secure mode, and RB not enabled.
[0000.366] Using GPT Primary to query partitions
[0000.371] Loading Tboot-CPU binary
[0000.420] Verifying TBC in OdmNonSecureSBK mode
[0000.429] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.436] Bootloader downloaded successfully.
[0000.440] Downloaded Tboot-CPU binary to 0xa0000258
[0000.445] MAX77620_GPIO1 Configured.
[0000.449] MAX77620_GPIO5 Configured.
[0000.452] CPU power rail is up
[0000.455] CPU clock enabled
[0000.459] Performing RAM repair
[0000.462] Updating A64 Warmreset Address to 0xa00002e9
[0000.467] Loading NvTbootBootloaderDTB
[0000.562] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.692] Bootloader DTB Load Address: 0x83000000
[0000.696] Loading NvTbootKernelDTB
[0000.791] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.921] Kernel DTB Load Address: 0x83100000
[0000.926] Loading cboot binary
[0001.020] Verifying EBT in OdmNonSecureSBK mode
[0001.056] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0001.063] Bootloader downloaded successfully.
[0001.067] GPT: Partition NOT found !
[0001.071] Find Partition via GPT Failed
[0001.074] Find Partition via PT Failed
[0001.078] function NvTbootGetBinaryOffsets: 0x1 error
[0001.083] Error in NvTbootLoadBinary: 0x1 !
[0001.087] Next binary entry address: 0x92c00258
[0001.091] BoardId: 2180
[0001.096] dram memory type is 3
[0001.100] WB0 init successful
[0001.126] Bpmp FW successfully loaded
[0001.130] Set NvDecSticky Bits
[0001.133] GSC1 address : ff700000
[0001.136] GSC2 address ff63fffc value c0edbbcc
[0001.141] GSC2 address : ff600000
[0001.145] GSC3 address : ff500000
[0001.149] GSC4 address : ff400000
[0001.152] GSC5 address : ff300000
[0001.156] GSC MC Settings done
[0001.159] TOS plaintext Image length 32848
[0001.163] Monitor size 32848
[0001.166] OS size 0
[0001.169] *** Secure OS image signature not verified ***
[0001.174] Loading and Validation of Secure OS Successful
[0001.179] NvTbootPackSdramParams: start.
[0001.185] NvTbootPackSdramParams: done.
[0001.188] Tegraboot started after 174477 us
[0001.192] Basic modules init took 951686 us
[0001.196] Sec Bootdevice Read Time = 355 ms, Read Size = 15785 KB
[0001.202] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.208] Next stage binary read took 805 us
[0001.212] Carveout took -6718 us
[0001.215] CPU initialization took 96982 us
[0001.219] Total time taken by TegraBoot 1042755 us
[0001.224] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.2(release):e1e4477
NOTICE: BL31: Built : 20:39:55, Mar 1 2018
NOTICE: Trusty image missing.
ERROR: Error initializing runtime service trusty_fast
[0001.364] RamCode = 1
[0001.386] LPDDR4 Training: Read DT: Number of tables = 10
[0001.391] EMC Training (SRC-freq: 204000; DST-freq: 408000)
[0001.397] EMC Training Successful
[0001.400] EMC Training (SRC-freq: 204000; DST-freq: 665600)
[0001.406] EMC Training Successful
[0001.409] EMC Training (SRC-freq: 204000; DST-freq: 800000)
[0001.421] EMC Training Successful
[0001.424] EMC Training (SRC-freq: 204000; DST-freq: 1065600)
[0001.447] EMC Training Successful
[0001.450] EMC Training (SRC-freq: 204000; DST-freq: 1331200)
[0001.471] EMC Training Successful
[0001.474] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.494] EMC Training Successful
[0001.497] Switching to 800000 KHz Success
[0001.507] RamCode = 1
[0001.511] DT Write: emc-table@40800 succeeded
[0001.517] DT Write: emc-table@68000 succeeded
[0001.523] DT Write: emc-table@102000 succeeded
[0001.529] DT Write: emc-table@204000 succeeded
[0001.535] DT Write: emc-table@408000 succeeded
[0001.541] DT Write: emc-table@665600 succeeded
[0001.547] DT Write: emc-table@800000 succeeded
[0001.553] DT Write: emc-table@1065600 succeeded
[0001.560] DT Write: emc-table@1331200 succeeded
[0001.566] DT Write: emc-table@1600000 succeeded
[0001.570] LPDDR4 Training: Write DT: Number of tables = 10
[0001.615]
[0001.616] Debug Init done
[0001.618] Marked DTB cacheable
[0001.621] Bootloader DTB loaded at 0x83000000
[0001.626] Marked DTB cacheable
[0001.629] Kernel DTB loaded at 0x83100000
[0001.633] DeviceTree Init done
[0001.652] Pinmux applied successfully
[0001.658] gicd_base: 0x50041000
[0001.663] gicc_base: 0x50042000
[0001.666] Interrupts Init done
[0001.671] Using base:0x60005008 & irq:33 for tick-timer
[0001.676] Using base:0x60005000 for delay-timer
[0001.681] platform_init_timer: DONE
[0001.684] Timer(tick) Init done
[0001.689] osc freq = 38400 khz
[0001.695]
[0001.696] welcome to cboot
[0001.698]
[0001.700] Cboot Version: 00.00.2014.50-t210-e831cf53
[0001.704] calling constructors
[0001.707] initializing heap
[0001.710] initializing threads
[0001.713] initializing timers
[0001.716] creating bootstrap completion thread
[0001.720] top of bootstrap2()
[0001.723] CPU: ARM Cortex A57
[0001.726] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.731] initializing platform
[0001.767] config for ddr50 mode completed
[0001.771] sdmmc bdev is already initialized
[0001.775] Enable APE clock
[0001.777] Un-powergate APE partition
[0001.781] of_register: registering tegra_udc to of_hal
[0001.786] of_register: registering inv20628-driver to of_hal
[0001.791] of_register: registering ads1015-driver to of_hal
[0001.797] of_register: registering lp8557-bl-driver to of_hal
[0001.803] of_register: registering bq2419x_charger to of_hal
[0001.808] of_register: registering cpc to of_hal
[0001.813] of_register: registering bq27441_fuel_gauge to of_hal
[0001.833] gpio framework initialized
[0001.836] of_register: registering tca9539_gpio to of_hal
[0001.841] of_register: registering tca9539_gpio to of_hal
[0001.847] of_register: registering i2c_bus_driver to of_hal
[0001.852] of_register: registering i2c_bus_driver to of_hal
[0001.858] of_register: registering i2c_bus_driver to of_hal
[0001.863] pmic framework initialized
[0001.867] of_register: registering max77620_pmic to of_hal
[0001.872] regulator framework initialized
[0001.876] of_register: registering tegra_xhci to of_hal
[0001.881] initializing target
[0001.890] gpio_driver_register: register 'tegra_gpio_driver' driver
[0001.902] fixed regulator driver initialized
[0001.980] initializing OF layer
[0001.983] NCK carveout not present
[0001.987] Skipping dts_overrides
[0001.991] of_children_init: Ops found for compatible string nvidia,tegra210-xhci
[0001.999] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.031] I2C Bus Init done
[0002.033] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.048] I2C Bus Init done
[0002.051] of_children_init: Ops found for compatible string ti,tca9539
[0002.065] tca9539_init: i2c bus: 2, slave addr: 0xe8
[0002.070] I2C slave not started
[0002.073] I2C write failed
[0002.076] i2c write failed
[0002.078] Slave: 0xe8, Register 0x4 Instance 2, Buffer Size: 0
[0002.084] tca9539_device_init: failed to write polar reg
[0002.089] tca9539_init: failed to init device!
[0002.094] of_children_init: Ops found for compatible string ti,tca9539
[0002.108] tca9539_init: i2c bus: 2, slave addr: 0xee
[0002.113] I2C slave not started
[0002.116] I2C write failed
[0002.119] i2c write failed
[0002.121] Slave: 0xee, Register 0x4 Instance 2, Buffer Size: 0
[0002.127] tca9539_device_init: failed to write polar reg
[0002.132] tca9539_init: failed to init device!
[0002.137] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.152] I2C Bus Init done
[0002.154] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.169] I2C Bus Init done
[0002.172] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.187] I2C Bus Init done
[0002.190] of_children_init: Ops found for compatible string maxim,max77620
[0002.205] max77620_init using irq 118
[0002.210] register 'maxim,max77620' pmic
[0002.215] gpio_driver_register: register 'max77620-gpio' driver
[0002.221] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.236] I2C Bus Init done
[0002.241] NCK carveout not present
[0002.245] shim_invoke: No NCT, Calling dts updates
[0002.266] Find /i2c@7000c000's alias i2c0
[0002.270] get eeprom at 1-a2, size 256, type 0
[0002.274] get eeprom at 1-ae, size 256, type 0
[0002.289] Find /i2c@7000c400's alias i2c1
[0002.293] get eeprom at 2-a0, size 256, type 0
[0002.309] Find /i2c@7000c500's alias i2c2
[0002.313] get eeprom at 3-a0, size 256, type 0
[0002.317] get eeprom at 3-ae, size 256, type 0
[0002.329] Find /host1x/i2c@546c0000's alias i2c6
[0002.333] get eeprom at 7-a8, size 256, type 0
[0002.338] pm_ids_update: Updating 1,a2, size 256, type 0
[0002.343] I2C slave not started
[0002.346] I2C write failed
[0002.349] Writing offset failed
[0002.352] eeprom_init: EEPROM read failed
[0002.356] pm_ids_update: eeprom init failed
[0002.360] pm_ids_update: Updating 1,ae, size 256, type 0
[0002.365] I2C slave not started
[0002.368] I2C write failed
[0002.371] Writing offset failed
[0002.374] eeprom_init: EEPROM read failed
[0002.378] pm_ids_update: eeprom init failed
[0002.382] pm_ids_update: Updating 2,a0, size 256, type 0
[0002.387] I2C slave not started
[0002.390] I2C write failed
[0002.393] Writing offset failed
[0002.396] eeprom_init: EEPROM read failed
[0002.400] pm_ids_update: eeprom init failed
[0002.404] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.434] pm_ids_update: The pm board id is 2180-1000-401
[0002.443] Adding plugin-manager/ids/2180-1000-401=/i2c@7000c500:module@0x50
[0002.453] pm_ids_update: pm id update successful
[0002.458] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.463] I2C slave not started
[0002.466] I2C write failed
[0002.469] Writing offset failed
[0002.472] eeprom_init: EEPROM read failed
[0002.476] pm_ids_update: eeprom init failed
[0002.480] pm_ids_update: Updating 7,a8, size 256, type 0
[0002.487] GPIO driver for phandle 0xe7 could not be found
[0002.493] I2C slave not started
[0002.495] I2C write failed
[0002.498] Writing offset failed
[0002.501] eeprom_init: EEPROM read failed
[0002.505] pm_ids_update: eeprom init failed
[0002.511] GPIO driver for phandle 0xe7 could not be found
[0002.544] updating /chosen/nvidia,wifi-mac node 00:04:4b:d3:d8:e3
[0002.554] updating /chosen/nvidia,bluetooth-mac node 00:04:4b:d3:d8:e4
[0002.563] updating /chosen/nvidia,ethernet-mac node 00:04:4b:d3:d8:e5
[0002.570] Plugin Manager: Parse ODM data 0x00084000
[0002.607] Find /i2c@7000c000's alias i2c0
[0002.611] get eeprom at 1-a2, size 256, type 0
[0002.616] get eeprom at 1-ae, size 256, type 0
[0002.631] Find /i2c@7000c400's alias i2c1
[0002.635] get eeprom at 2-a0, size 256, type 0
[0002.651] Find /i2c@7000c500's alias i2c2
[0002.654] get eeprom at 3-a0, size 256, type 0
[0002.659] get eeprom at 3-ae, size 256, type 0
[0002.671] Find /host1x/i2c@546c0000's alias i2c6
[0002.675] get eeprom at 7-a8, size 256, type 0
[0002.679] pm_ids_update: Updating 1,a2, size 256, type 0
[0002.685] I2C slave not started
[0002.688] I2C write failed
[0002.690] Writing offset failed
[0002.693] eeprom_init: EEPROM read failed
[0002.697] pm_ids_update: eeprom init failed
[0002.701] pm_ids_update: Updating 1,ae, size 256, type 0
[0002.707] I2C slave not started
[0002.710] I2C write failed
[0002.712] Writing offset failed
[0002.715] eeprom_init: EEPROM read failed
[0002.719] pm_ids_update: eeprom init failed
[0002.723] pm_ids_update: Updating 2,a0, size 256, type 0
[0002.729] I2C slave not started
[0002.732] I2C write failed
[0002.734] Writing offset failed
[0002.737] eeprom_init: EEPROM read failed
[0002.741] pm_ids_update: eeprom init failed
[0002.745] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.776] pm_ids_update: The pm board id is 2180-1000-401
[0002.784] Adding plugin-manager/ids/2180-1000-401=/i2c@7000c500:module@0x50
[0002.790] pm_ids_update: pm id update successful
[0002.795] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.800] I2C slave not started
[0002.803] I2C write failed
[0002.806] Writing offset failed
[0002.809] eeprom_init: EEPROM read failed
[0002.813] pm_ids_update: eeprom init failed
[0002.817] pm_ids_update: Updating 7,a8, size 256, type 0
[0002.824] GPIO driver for phandle 0xe7 could not be found
[0002.830] I2C slave not started
[0002.833] I2C write failed
[0002.835] Writing offset failed
[0002.838] eeprom_init: EEPROM read failed
[0002.842] pm_ids_update: eeprom init failed
[0002.848] GPIO driver for phandle 0xe7 could not be found
[0002.881] Chip UID is 00000001643073071000000007010500
[0002.889] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 androidboot.modem=none androidboot.serialno=04201190103290000501 androidboot.security=non-secure
[0002.912] Add serial number:04201190103290000501 as DT property
[0002.921] calling apps_init()
[0002.929] Found 20 GPT partitions in "sdmmc3_user"
[0002.933] Proceeding to Cold Boot
[0002.936] starting app android_boot_app
[0002.940] Device state: unlocked
[0002.943] display console init
[0002.962] No valid panel node found
[0002.971] enabling 'vdd-hdmi' regulator
[0002.975] GPIO driver for phandle 0xe8 could not be found
[0002.995] DT entry for leds-pwm not found
[0003.000] hdmi cable not connected
[0003.003] is_hdmi_needed: HDMI not connected, returning false
[0003.009] set_instance_and_out_type: invalid out_type
[0003.014] display_console_init: No display init
[0003.025] Gpio keyboard init success[serial.log|attachment](upload://pp7AQW6hxf9ndW7udYa3sYRBAb4.log) (133.6 KB)
