dmesg
[code]
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.38-tegra (buildbrain@mobile-u64-1576) (gcc version 4.8.5 (GCC) ) #1 SMP PREEMPT Thu Jul 20 00:41:06 PDT 2017
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] Reserved memory: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] Reserved memory: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] Reserved memory: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 16 MiB at 0x00000000fdc00000
[ 0.000000] On node 0 totalpages: 1043456
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519168 pages, LIFO batch:31
[ 0.000000] Normal zone: 8192 pages used for memmap
[ 0.000000] Normal zone: 524288 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] PERCPU: Embedded 17 pages/cpu @ffffffc0ffe40000 s31360 r8192 d30080 u69632
[ 0.000000] pcpu-alloc: s31360 r8192 d30080 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1027072
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 androidboot.modem=none androidboot.serialno=03217171339460808306 androidboot.security=non-secure tegraid=21.1.2.0.0 ddr_die=2048M@2048M ddr_die=2048M@4096M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 debug_uartport=lsport,0 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff2bf000 nvdumper_reserved=0xff23f000 core_edp_mv=1125 core_edp_ma=4000 gpt android.kerneltype=normal androidboot.touch_vendor_id=0 androidboot.touch_panel_id=63 androidboot.touch_feature=0 androidboot.bootloader=00.00.2014.50-t210-fadd1be5 androidboot.verifiedbootstate=orange root=/dev/mmcblk0p1 rw rootwait
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3372572K/4173824K available (11009K kernel code, 1816K rwdata, 6352K rodata, 1208K init, 644K bss, 96740K reserved, 704512K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000 ( 246 GB)
vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
0xffffffbdc2000000 - 0xffffffbdc6000000 ( 64 MB actual)
fixed : 0xffffffbffa7fd000 - 0xffffffbffac00000 ( 4108 KB)
PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000 ( 16 MB)
modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
memory : 0xffffffc000000000 - 0xffffffc100000000 ( 4096 MB)
.init : 0xffffffc001175000 - 0xffffffc0012a3000 ( 1208 KB)
.text : 0xffffffc000080000 - 0xffffffc001174c04 ( 17364 KB)
.data : 0xffffffc0012bd000 - 0xffffffc001483230 ( 1817 KB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] enable_t210_agic_clks:106 ape clocked & reset cleared
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] kmemleak: Kernel memory leak detector disabled
[ 0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000005] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.001700] Console: colour dummy device 80x25
[ 0.002567] console [tty0] enabled
[ 0.002600] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=76800)
[ 0.002636] pid_max: default: 32768 minimum: 301
[ 0.002725] Security Framework initialized
[ 0.002745] SELinux: Initializing.
[ 0.002818] SELinux: Starting in permissive mode
[ 0.002856] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.002881] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.003547] Initializing cgroup subsys freezer
[ 0.003578] Initializing cgroup subsys debug
[ 0.003845] CPU0 ipc=1024
[ 0.003881] CPU1 ipc=1024
[ 0.003913] CPU2 ipc=1024
[ 0.003945] CPU3 ipc=1024
[ 0.004014] ASID allocator initialised with 65536 entries
[ 0.026969] tegra-id: chipid=22117.
[ 0.026998] tegra-id: opt_subrevision=0.
[ 0.027028] Tegra Speedo/IDDQ fuse revision 4
[ 0.027047] Tegra: CPU Speedo ID 7, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.027068] Tegra: CPU Process ID 0, SoC Process ID 0, GPU Process ID 0
[ 0.027088] Tegra: CPU Speedo Value 2000, SoC Speedo Value 1919, GPU Speedo Value 2005
[ 0.027116] Tegra: CPU IDDQ Value 1544, SoC IDDQ Value 1848, GPU IDDQ Value 2120
[ 0.027158] Tegra Revision: A02 SKU: 0x17 CPU Process: 0 SoC Process: 0
[ 0.028544] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.4/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-devkit.dts
[ 0.028594] DTB Build time: Jul 20 2017 00:41:47
[ 0.044793] CPU1: Booted secondary processor [411fd071]
[ 0.056760] CPU2: Booted secondary processor [411fd071]
[ 0.068758] CPU3: Booted secondary processor [411fd071]
[ 0.068846] Brought up 4 CPUs
[ 0.068912] SMP: Total of 4 processors activated.
[ 0.068936] CPU: All CPU(s) started at EL2
[ 0.068978] alternatives: patching kernel code
[ 0.071402] devtmpfs: initialized
[ 0.143227] Initilizing CustomIPI irq domain
[ 0.143578] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.156512] pinctrl core: initialized pinctrl subsystem
[ 0.156737] OS set in device tree is L4T.
[ 0.157126] regulator-dummy: no parameters
[ 0.157345] Initializing plugin-manager
[ 0.157418] Plugin module not found
[ 0.158371] node /plugin-manager/fragement@0 match with board >=2180-1000-300
[ 0.159157] node /plugin-manager/fragement@4 match with odm-data l4t
[ 0.159285] Removing Prop nvidia,pmc-wakeup from target /bcmdhd_wlan
[ 0.159776] Adding domain ape-pd to PM domain mc-clk-pd
[ 0.159825] Adding domain adsp-pd to PM domain ape-pd
[ 0.164775] NET: Registered protocol family 16
[ 0.166613] console [pstore-1] enabled
[ 0.166635] pstore: Registered ramoops as persistent store backend
[ 0.166659] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.176241] cpuidle: using governor ladder
[ 0.188230] cpuidle: using governor menu
[ 0.188594] bpmp: mail init ok
[ 0.189716] vdso: 2 pages (1 code @ ffffffc0012c5000, 1 data @ ffffffc0012c4000)
[ 0.189773] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.192112] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.193053] tegra_powergate_init: DONE
[ 0.193094] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.4/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-devkit.dts
[ 0.193143] DTB Build time: Jul 20 2017 00:41:47
[ 0.194166] Error: Driver ‘tegra-mc’ is already registered, aborting…
[ 0.195815] platform tegra-carveouts: SMMU isn’t ready yet
[ 0.196573] platform tegra-carveouts: domain=ffffffc0fa139318 allocates as[0]=ffffffc0fa14c0a8
[ 0.196641] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.196885] platform smmu_test: domain=ffffffc0fa139618 allocates as[0]=ffffffc0fa14c110
[ 0.197220] platform 70016000.bpmp: domain=ffffffc0fa139918 allocates as[0]=ffffffc0fa14c178
[ 0.197933] bpmp: ping status is 0
[ 0.198039] bpmp 70016000.bpmp: firmware tag is 1e4b302fc0f866f97885165cf8b395ac
[ 0.198297] bpmp 70016000.bpmp: probe ok
[ 0.198974] mc: mapped MMIO address: 0xffffff800007e000 → 0x70019000
[ 0.199080] mc: mapped MMIO address: 0xffffff80000b6000 → 0x7001c000
[ 0.199181] mc: mapped MMIO address: 0xffffff80000dc000 → 0x7001d000
[ 0.199269] mc-err: Set intmask: 0x23d40
[ 0.210952] GPIO line 58 (wlan-default-input-h2) hogged as input
[ 0.211000] GPIO line 65 (wlan-default-input-i1) hogged as input
[ 0.211043] GPIO line 56 (wlan-default-output-high-h0) hogged as output/high
[ 0.211091] GPIO line 64 (wlan-default-output-high-i0) hogged as output/high
[ 0.211136] GPIO line 148 (cam0-rst) hogged as output/low
[ 0.211174] GPIO line 151 (cam0-pwdn) hogged as output/low
[ 0.211212] GPIO line 149 (cam1-rst) hogged as output/low
[ 0.211250] GPIO line 152 (cam1-pwdn) hogged as output/low
[ 0.211367] gpiochip_add_data: registered GPIOs 0 to 255 on device: tegra-gpio
[ 0.213909] platform 70006000.serial: domain=ffffffc0fa1d6e18 allocates as[0]=ffffffc0fa14c1e0
[ 0.215042] platform sound: domain=ffffffc0fa1f1718 allocates as[0]=ffffffc0fa14c248
[ 0.217533] platform tegradc.1: domain=ffffffc0fa234918 allocates as[0]=ffffffc0fa14c2b0
[ 0.218159] platform tegradc.1: IOVA linear map 0x00000000c6000000(2a000000)
[ 0.220948] platform 57000000.gpu: domain=ffffffc0fa263d18 allocates as[0]=ffffffc0fa14c318
[ 0.221024] platform 57000000.gpu: domain=ffffffc0fa263d18 allocates as[1]=ffffffc0fa14c380
[ 0.221096] platform 57000000.gpu: domain=ffffffc0fa263d18 allocates as[2]=ffffffc0fa14c3e8
[ 0.221164] platform 57000000.gpu: domain=ffffffc0fa263d18 allocates as[3]=ffffffc0fa14c450
[ 0.221929] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.221971] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.221996] tegra-pmc: ### PMC reset source: Power on reset
[ 0.222017] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.222387] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.222422] tegra-pmc: Clear bootloader IO dpd settings
[ 0.224346] tegra-pmc 7000e400.pmc: PMC: IO pad audio voltage is 1800000
[ 0.228322] tegra-pmc 7000e400.pmc: PMC: IO pad cam voltage is 1800000
[ 0.232320] tegra-pmc 7000e400.pmc: PMC: IO pad dbg voltage is 1800000
[ 0.236320] tegra-pmc 7000e400.pmc: PMC: IO pad dmic voltage is 1800000
[ 0.236350] tegra-pmc 7000e400.pmc: PMC: IO pad pex-ctrl voltage is 1800000
[ 0.240319] tegra-pmc 7000e400.pmc: PMC: IO pad spi voltage is 1800000
[ 0.244320] tegra-pmc 7000e400.pmc: PMC: IO pad uart voltage is 1800000
[ 0.248319] tegra-pmc 7000e400.pmc: PMC: IO pad audio-hv voltage is 1800000
[ 0.248348] tegra-pmc 7000e400.pmc: PMC: IO pad spi-hv voltage is 1800000
[ 0.252319] tegra-pmc 7000e400.pmc: PMC: IO pad gpio voltage is 1800000
[ 0.256319] tegra-pmc 7000e400.pmc: PMC: IO pad sdmmc3 voltage is 1800000
[ 0.256346] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.256416] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.259560] platform 1003000.pcie-controller: domain=ffffffc0fa26be18 allocates as[0]=ffffffc0fa14c4b8
[ 0.261900] platform sdhci-tegra.3: domain=ffffffc0fa272f18 allocates as[0]=ffffffc0fa14c520
[ 0.262510] platform sdhci-tegra.0: domain=ffffffc0fa279318 allocates as[0]=ffffffc0fa14c588
[ 0.268081] vdd-ac-bat: 5000 mV
[ 0.269333] vdd-cpu-fixed: 1000 mV
[ 0.273204] irq: no irq domain found for /soctherm@0x700E2000 !
[ 0.273551] irq: no irq domain found for /soctherm@0x700E2000 !
[ 0.297469] ACPI: Interpreter disabled.
[ 0.298301] SCSI subsystem initialized
[ 0.298370] libata version 3.00 loaded.
[ 0.298593] usbcore: registered new interface driver usbfs
[ 0.298664] usbcore: registered new interface driver hub
[ 0.298767] usbcore: registered new device driver usb
[ 0.302053] gpiochip_add_data: registered GPIOs 496 to 511 on device: tca9539
[ 0.303565] gpiochip_add_data: registered GPIOs 480 to 495 on device: tca9539
[ 0.306710] max77620 4-003c: PMIC Version OTP:0x3C and ES:0x8
[ 0.308480] GPIO line 474 (spmic-default-output-high) hogged as output/high
[ 0.308601] gpiochip_add_data: registered GPIOs 472 to 479 on device: max77620-gpio
[ 0.312351] vdd-core: 600 <–> 1400 mV at 1125 mV
[ 0.316346] vddio-ddr: at 1125 mV
[ 0.317186] vdd-pre-reg: 1350 mV
[ 0.320225] vdd-1v8: 1800 mV
[ 0.324226] avdd-sys: 1200 mV
[ 0.328226] vdd-pex: 1050 mV
[ 0.328839] vddio-sdmmc1: 1800 <–> 3300 mV at 3300 mV
[ 0.329660] vdd-cam-hv: 2800 mV
[ 0.332222] vdd-rtc: 850 mV
[ 0.333077] avdd-ts-hv: 3300 mV
[ 0.333936] vdd-ts: 1800 mV
[ 0.336226] vdd-gen-pll-edp: 1050 mV
[ 0.340227] vdd-hdmi-dp: 1050 mV
[ 0.340862] max77620 4-003c: max77620 probe successful
[ 0.342768] media: Linux media interface: v0.10
[ 0.342849] Linux video capture interface: v2.00
[ 0.350515] tegra210-emc 7001b000.memory-controller: validated EMC DFS table
[ 0.350849] Advanced Linux Sound Architecture Driver Initialized.
[ 0.354434] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.354489] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.354588] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.354632] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.357633] regulator_get() failed for (dvfs,vdd-cpu), -19
[ 0.357661] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.360232] vdd-3v3: 3300 mV
[ 0.364224] max77620-gpio7: 1050 mV
[ 0.364548] lcd-bl-en: 1800 mV
[ 0.364855] en-vdd-sd: 3300 mV
[ 0.365526] en-vdd-cam: 1800 mV
[ 0.368224] vdd-sys-boost: 5000 mV
[ 0.368898] vdd-hdmi: 5000 mV
[ 0.369158] aux-3v3: 3300 mV
[ 0.369392] snsr_pm: 3300 mV
[ 0.372225] vdd-disp-3v0: 3000 mV
[ 0.372915] vdd-fan: 5000 mV
[ 0.373213] usb-vbus1: 5000 mV
[ 0.373874] en-vdd-ts-1v8: 1800 mV
[ 0.374555] en-vdd-ts-hv-3v3: 3300 mV
[ 0.375407] en-vdd-disp-3v3: 3300 mV
[ 0.376067] en-mdm-pwr-3v7: 3700 mV
[ 0.376939] en-vdd-disp-1v8: 1800 mV
[ 0.377602] en-vdd-cam-hv-2v8: 2800 mV
[ 0.377893] rtl-5v0: 5000 mV
[ 0.378195] en-usb-vbus2: 5000 mV
[ 0.378864] en-vdd-cam-1v2: 1200 mV
[ 0.379156] en-vdd-vcm-2v8: 2800 mV
[ 0.381984] extcon-gpio-states extcon:extcon@1: Cable state 0
[ 0.383331] clocksource: Switched to clocksource arch_sys_counter
[ 0.422678] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.423063] dma_declare_coherent_resizable_cma_memory:290: resizable heap=vpr, base=0x00000000c6000000, size=0x2a000000
[ 0.423245] cma: enabled page replacement for spfn=c6000, epfn=f0000
[ 0.423272] dma_declare_coherent_resizable_cma_memory:337: resizable cma heap=vpr create successful
[ 0.423303] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.423396] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.423431] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.423741] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 0.424473] misc nvmap: created heap vpr base 0x00000000c6000000 size (688128KiB)
[ 0.425198] pnp: PnP ACPI: disabled
[ 0.437076] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.438900] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.439308] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.439569] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.441156] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tdiode_tegra
[ 0.441414] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type PMIC-Die
[ 0.441644] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tboard_tegra
[ 0.442798] isomgr_init(): iso emc max clk=1600000KHz
[ 0.442820] isomgr_init(): max_iso_bw=11520000KB
[ 0.442958] NET: Registered protocol family 2
[ 0.443568] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.443754] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.444025] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.444128] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.444190] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.444436] NET: Registered protocol family 1
[ 0.444753] RPC: Registered named UNIX socket transport module.
[ 0.444779] RPC: Registered udp transport module.
[ 0.444799] RPC: Registered tcp transport module.
[ 0.444819] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.444855] PCI: CLS 0 bytes, default 128
[ 0.445071] Trying to unpack rootfs image as initramfs…
[ 0.456244] host1x 50000000.host1x: initialized
[ 0.457949] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.461148] futex hash table entries: 1024 (order: 5, 131072 bytes)
[ 0.461270] audit: initializing netlink subsys (disabled)
[ 0.461328] audit: type=2000 audit(0.451:1): initialized
[ 0.473398] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.473888] fuse init (API version 7.23)
[ 0.474418] SELinux: Registering netfilter hooks
[ 0.476496] io scheduler noop registered (default)
[ 0.476530] io scheduler deadline registered
[ 0.476853] io scheduler cfq registered
[ 0.482320] tegra21x-padctl-uphy 7009f000.pinctrl: padctl mmio start 0x000000007009f000 end 0x000000007009ffff
[ 0.482367] tegra21x-padctl-uphy 7009f000.pinctrl: TEGRA_FUSE_SKU_CALIB_0 0x8a08c11
[ 0.482402] tegra21x-padctl-uphy 7009f000.pinctrl: TEGRA_FUSE_USB_CALIB_EXT_0 0x4
[ 0.483865] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-0 is used by XUSB
[ 0.483902] tegra21x-padctl-uphy 7009f000.pinctrl: using UTMI port 0 for otg
[ 0.483931] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-2 is used by XUSB
[ 0.483967] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 5, set usb3_lanes = 0x20
[ 0.484012] tegra21x-padctl-uphy 7009f000.pinctrl: USB3 port 1 maps to USB2 port 2
[ 0.484045] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-1 is used by XUSB
[ 0.484081] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 6, set usb3_lanes = 0x60
[ 0.484123] tegra21x-padctl-uphy 7009f000.pinctrl: USB3 port 0 maps to USB2 port 1
[ 0.484168] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 1, set pcie_lanes = 0x2
[ 0.484215] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 2, set pcie_lanes = 0x6
[ 0.484260] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 3, set pcie_lanes = 0xe
[ 0.484307] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 4, set pcie_lanes = 0x1e
[ 0.484352] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 0, set pcie_lanes = 0x1f
[ 0.484400] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 7, set sata_lanes = 0x80
[ 0.484844] tegra21x-padctl-uphy 7009f000.pinctrl: mailbox is not ready yet
[ 0.485883] tegra-pwm 7000a000.pwm: PWM clk can sleep in ops
[ 0.486960] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 0.487739] Adding domain pcie-pd to PM domain mc-clk-pd
[ 0.492392] tegra-pcie 1003000.pcie-controller: 4x1, 1x1 configuration
[ 0.492461] tegra-pcie 1003000.pcie-controller: failed to get PHY: -517
[ 0.492488] tegra-pcie 1003000.pcie-controller: failed to get PHYs: -517
[ 0.496027] tsec 54500000.tsec: initialized
[ 0.497396] tsec 54100000.tsecb: initialized
[ 0.500578] nvdec 54480000.nvdec: initialized
[ 0.505927] falcon 54340000.vic: initialized
[ 0.507695] falcon 544c0000.nvenc: initialized
[ 0.508882] falcon 54380000.nvjpg: initialized
[ 0.510877] DC OR NODE connected to /host1x/sor1
[ 0.510975] display board info: id 0xffff, fab 0x0
[ 0.511030] panel_select fail by _node_status
[ 0.511086] display board info: id 0xffff, fab 0x0
[ 0.511133] panel_select fail by _node_status
[ 0.511313] tegradc tegradc.1: DT parsed successfully
[ 0.511404] tegradc tegradc.1: Display dc.ffffff8000980000 registered with id=0
[ 0.511873] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.512073] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1020000, vi_iso_bw=750000, max_bw=1020000
[ 0.513425] display board info: id 0xffff, fab 0x0
[ 0.513482] panel_select fail by _node_status
[ 0.517023] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 0.519061] tegra-adma 702e2000.adma: Tegra ADMA driver register 10 channels
[ 0.520588] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 0.520888] kfuse 7000fc00.kfuse: initialized
[ 0.522778] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.523757] clk_cbus_round_rate: no gbus parent
[ 0.523784] tegra_gpu_edp gpu_edp: unable to get max GPU freq
[ 0.524299] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 0.524333] vdd-cpu: 708 <–> 1322 mV at 708 mV
[ 0.524395] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 0.525566] vdd-gpu: applied init 1000000uV constraint
[ 0.525597] vdd-gpu: 710 <–> 1320 mV at 1000 mV
[ 0.525655] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 0.526041] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.526183] No Device Node present for smmu client: serial8250 !!
[ 0.526211] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.526247] No Device Node present for smmu client: serial8250 !!
[ 0.526271] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.527424] No Device Node present for smmu client: serial8250 !!
[ 0.527456] serial8250 serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.527506] No Device Node present for smmu client: serial8250 !!
[ 0.527531] serial8250 serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.527987] tegradc tegradc.1: probed
[ 0.528238] console [ttyS0] disabled
[ 0.528315] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 320, base_baud = 25500000) is a Tegra
[ 2.555188] console [ttyS0] enabled
[ 2.556576] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 321, base_baud = 0) is a TEGRA_UART
[ 2.557040] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 322, base_baud = 0) is a TEGRA_UART
[ 2.557384] serial-tegra 70006300.serial: RX in PIO mode
[ 2.557484] 70006300.serial: ttyTHS3 at MMIO 0x70006300 (irq = 323, base_baud = 0) is a TEGRA_UART
[ 2.559792] gk20a 57000000.gpu: platform probe failed
[ 2.574444] brd: module loaded
[ 2.579289] Console: switching to colour frame buffer device 240x67
[ 2.579977] loop: module loaded
[ 2.580584] zram: Added device: zram0
[ 2.580595] Silicon Labs C2 port support v. 0.51.0 - (C) 2007 Rodolfo Giometti
[ 2.580803] nct1008_nct72 0-004c: find device tree node, parsing dt
[ 2.580809] nct1008_nct72 0-004c: starting parse dt
[ 2.580888] nct1008_nct72 0-004c: success parsing dt
[ 2.581132] nct1008_nct72 0-004c: success in enabling tmp451 VDD rail
[ 2.666936] tmp451: Enabled overheat logging at 102.00C
[ 2.667101] nct1008_nct72 0-004c: nct1008_probe: initialized
[ 2.700910] tegradc tegradc.1: fb registered
[ 2.706477] THERMAL EST: found 2 subdevs
[ 2.710506] THERMAL EST num_resources: 0
[ 2.714517] [THERMAL EST subdev 0]
[ 2.717998] [THERMAL EST subdev 1]
[ 2.721826] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 2.729739] tegradc tegradc.1: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 2.730600] tegradc tegradc.1: hdmi: pclk:148500K, set prod-setting:prod_c_hdmi_75m_150m
[ 2.749630] THERMAL EST: thz register success.
[ 2.754320] THERMAL EST: end of probe, return err: 0
[ 2.759474] tegra_profiler: Branch: Dev
[ 2.763398] tegra_profiler: Version: 1.109
[ 2.767580] tegra_profiler: Samples version: 37
[ 2.772203] tegra_profiler: IO version: 21
[ 2.776387] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.780836] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.787963] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.792415] armv8_pmu: [1] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.799508] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.803955] armv8_pmu: [2] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.811048] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.820910] armv8_pmu: [3] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.833616] tegra_profiler: auth: init
[ 2.843406] tegra-ahci 70027000.sata: Missing devslp-active state
[ 2.863571] Rounding down aligned max_sectors from 4294967295 to 4294967288
[ 2.864198] spi-tegra114 7000d400.spi: Static pin configuration used
[ 2.865099] spi-tegra114 7000da00.spi: Static pin configuration used
[ 2.866659] tun: Universal TUN/TAP device driver, 1.6
[ 2.866663] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 2.877134] tegradc tegradc.1: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 2.877703] PPP generic driver version 2.4.2
[ 2.877889] PPP BSD Compression module registered
[ 2.877898] PPP Deflate Compression module registered
[ 2.877928] PPP MPPE Compression module registered
[ 2.877944] NET: Registered protocol family 24
[ 2.878050] usbcore: registered new interface driver r8152
[ 2.878109] usbcore: registered new interface driver asix
[ 2.878156] usbcore: registered new interface driver ax88179_178a
[ 2.878200] usbcore: registered new interface driver cdc_ether
[ 2.878266] usbcore: registered new interface driver smsc95xx
[ 2.878312] usbcore: registered new interface driver net1080
[ 2.878358] usbcore: registered new interface driver cdc_subset
[ 2.878402] usbcore: registered new interface driver zaurus
[ 2.878480] usbcore: registered new interface driver cdc_ncm
[ 2.878634] usbcore: registered new interface driver usb-storage
[ 2.878744] usbcore: registered new interface driver usbserial
[ 2.878787] usbcore: registered new interface driver ftdi_sio
[ 2.878821] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.878873] usbcore: registered new interface driver option
[ 2.878903] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.878944] usbcore: registered new interface driver pl2303
[ 2.878972] usbserial: USB Serial support registered for pl2303
[ 2.880222] tegra-xudc-new 700d0000.xudc: usb2 phy is not available yet
[ 3.051845] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc1
[ 3.075412] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc0
[ 3.075446] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 3.076003] i2c /dev entries driver
[ 3.078056] IR NEC protocol handler initialized
[ 3.078064] IR Sharp protocol handler initialized
[ 3.078072] IR XMP protocol handler initialized
[ 3.078163] usbcore: registered new interface driver uvcvideo
[ 3.078165] USB Video Class driver (1.1.1)
[ 3.083603] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 3.163578] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 3.163585] tegra_soctherm 700e2000.soctherm: pllx_offset tz:1 max:8, min:4
[ 3.164161] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 3.164172] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 3.164393] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.164406] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 3.164414] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 3.164669] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.164676] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature 2147483647 forced to 127000
[ 3.164684] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 3.164690] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 3.165101] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 3.166750] tegra_aotag tegra-aotag: Registering sensor 0
[ 3.166822] tegra_aotag tegra-aotag: Invalid temp readout
[ 3.166832] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 3.166840] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 3.167735] FAN dev name: pwm-fan
[ 3.167790] FAN:gpio request success.
[ 3.167863] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 3.168175] pwm_fan_driver pwm-fan: unable to request PWM, trying legacy API
[ 3.168185] pwm_fan_driver pwm-fan: got pwm for fan
[ 3.168386] pwm_fan_driver pwm-fan: fan tach request irq success
[ 3.168397] pwm_fan_driver pwm-fan: tach period: 1000
[ 3.168524] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 3.168531] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 3.168538] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 3.168545] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 3.168551] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 3.168558] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 3.168564] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 3.168570] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 3.168577] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 3.168584] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 3.169689] tegra-wdt 60005100.watchdog: Tegra WDT enabled on probe. Timeout = 120 seconds.
[ 3.170027] tegra-wdt 60005100.watchdog: initialized (timeout = 120 sec, nowayout = 1)
[ 3.170385] device-mapper: uevent: version 1.0.3
[ 3.170746] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 3.174658] sdhci: Secure Digital Host Controller Interface driver
[ 3.174662] sdhci: Copyright(c) Pierre Ossman
[ 3.174671] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.175433] sdhci-tegra sdhci-tegra.3: Parent select= pll_p rate=408000000
[ 3.175521] sdhci-tegra sdhci-tegra.3: Parent select= pll_c4_out2 rate=199680000
[ 3.175547] sdhci-tegra sdhci-tegra.3: Client registration for eMC Successful
[ 3.188058] tegra-se 70012000.se: tegra_se_probe: complete
[ 3.188683] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.191637] usbcore: registered new interface driver usbhid
[ 3.191639] usbhid: USB HID core driver
[ 3.264726] parse_throttle_dt_data: Num cap clks = 6
[ 3.264732] parse_throttle_dt_data: clk=cclk_g type=2
[ 3.264742] parse_throttle_dt_data: clk=gpu type=4
[ 3.264783] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 3.264818] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 3.264859] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 3.264863] parse_throttle_dt_data: clk=emc type=3
[ 3.274537] tegra_throttle_probe: probe successful. #cdevs=4
[ 3.274803] tegra21x_actmon 6000c800.actmon: in actmon_register()…
[ 3.275840] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 3.277340] tegra124-dfll 70110000.clock: config PMU interface as PWM
[ 3.285722] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA 64-bit with 64 bit addr
[ 3.286052] sdhci-tegra sdhci-tegra.1: Parent select= pll_p rate=408000000
[ 3.286072] sdhci-tegra sdhci-tegra.1: Client registration for eMC Successful
[ 3.288402] No Device Node present for smmu client: snd-soc-dummy !!
[ 3.288410] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 3.288421] No Device Node present for smmu client: snd-soc-dummy !!
[ 3.288427] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 3.288667] No Device Node present for smmu client: snd-soc-dummy !!
[ 3.288675] snd-soc-dummy snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 3.288704] No Device Node present for smmu client: snd-soc-dummy !!
[ 3.288710] snd-soc-dummy snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 3.307410] tegra210-i2s tegra210-i2s.0: Missing prop fsync-width for I2S0
[ 3.311530] tegra210-i2s tegra210-i2s.2: Missing prop fsync-width for I2S2
[ 3.311820] tegra210-i2s tegra210-i2s.3: Missing prop fsync-width for I2S3
[ 3.349884] tegra210-i2s tegra210-i2s.4: Missing prop fsync-width for I2S4
[ 3.355105] OPE platform probe
[ 3.355287] OPE platform probe successful
[ 3.355373] OPE platform probe
[ 3.355554] OPE platform probe successful
[ 3.357310] tegra-snd-t210ref-mobile-rt565x sound: Failed to get HP Det GPIO, should be handled by codec
[ 3.391359] mmc1: SDHCI controller on sdhci-tegra.1 [sdhci-tegra.1] using ADMA 64-bit with 64 bit addr
[ 3.391385] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 3.391630] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 3.391865] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 3.392116] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 3.392141] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 3.392192] sdhci-tegra sdhci-tegra.0: Got WP GPIO
[ 3.392284] sdhci-tegra sdhci-tegra.0: Parent select= pll_p rate=408000000
[ 3.392341] sdhci-tegra sdhci-tegra.0: wakeup init done, cd_irq: 262
[ 3.392346] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 3.392364] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 3.392573] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 3.392809] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 3.393037] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 3.393269] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 3.393493] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 3.394341] en-vdd-sd: supplied by vdd-3v3
[ 3.415351] input: tegra-snd-t210ref-mobile-rt565x Headphone Jack as /devices/sound/sound/card1/input0
[ 3.416211] tegra-snd-t210ref-mobile-rt565x sound: codec-dai “dit-hifi” registered
[ 3.416217] tegra-snd-t210ref-mobile-rt565x sound: This is a dummy codec
[ 3.417051] GACT probability NOT on
[ 3.417062] Mirror/redirect action on
[ 3.417077] u32 classifier
[ 3.417079] Actions configured
[ 3.417090] Netfilter messages via NETLINK v0.30.
[ 3.417145] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 3.417578] ctnetlink v0.93: registering with nfnetlink.
[ 3.418162] xt_time: kernel timezone is -0000
[ 3.418314] ipip: IPv4 over IPv4 tunneling driver
[ 3.418964] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.419101] arp_tables: (C) 2002 David S. Miller
[ 3.419172] Initializing XFRM netlink socket
[ 3.420081] NET: Registered protocol family 10
[ 3.425225] mip6: Mobile IPv6
[ 3.425256] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 3.425452] sit: IPv6 over IPv4 tunneling driver
[ 3.426538] NET: Registered protocol family 17
[ 3.426565] NET: Registered protocol family 15
[ 3.426602] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 3.426628] Key type dns_resolver registered
[ 3.428958] Registered cp15_barrier emulation handler
[ 3.431572] mmc2: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[ 3.436802] isp 54600000.isp: initialized
[ 3.438209] isp 54680000.isp: initialized
[ 3.446170] clk_cbus_recalc_rate: no gbus parent
[ 3.446176] clk_cbus_round_rate: no gbus parent
[ 3.446180] clk_cbus_round_rate: no gbus parent
[ 3.446187] clk_cbus_recalc_rate: no gbus parent
[ 3.471429] clk_cbus_recalc_rate: no gbus parent
[ 3.471435] clk_cbus_round_rate: no gbus parent
[ 3.471439] clk_cbus_round_rate: no gbus parent
[ 3.471445] clk_cbus_recalc_rate: no gbus parent
[ 3.471470] tegra_dvfs: GPU-cap: registered
[ 3.471565] tegra dvfs: vdd-cpu: nominal 1226mV, offset 708000uV, step 19200uV, scaling enabled
[ 3.471570] tegra dvfs: vdd-core: nominal 1125mV, offset 600000uV, step 12500uV, scaling enabled
[ 3.471574] tegra dvfs: vdd-gpu: nominal 1120mV, offset 710000uV, step 10000uV, scaling enabled
[ 3.553257] mmc0: MAN_BKOPS_EN bit is not set
[ 3.573871] snd_hda_codec_hdmi hdaudioC0D3: HDMI: Unknown ELD version 0
[ 3.595371] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input1
[ 3.602779] tegra_dvfs: vdd-gpu-vts: registered
[ 3.623995] xhci-tegra 70090000.xusb: can’t get usb3-0 phy (-517)
[ 3.624653] tegra21x-padctl-uphy 7009f000.pinctrl: padctl mmio start 0x000000007009f000 end 0x000000007009ffff
[ 3.624665] tegra21x-padctl-uphy 7009f000.pinctrl: TEGRA_FUSE_SKU_CALIB_0 0x8a08c11
[ 3.624673] tegra21x-padctl-uphy 7009f000.pinctrl: TEGRA_FUSE_USB_CALIB_EXT_0 0x4
[ 3.626010] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-0 is used by XUSB
[ 3.626020] tegra21x-padctl-uphy 7009f000.pinctrl: using UTMI port 0 for otg
[ 3.626028] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-2 is used by XUSB
[ 3.626043] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 5, set usb3_lanes = 0x20
[ 3.626060] tegra21x-padctl-uphy 7009f000.pinctrl: USB3 port 1 maps to USB2 port 2
[ 3.626067] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-1 is used by XUSB
[ 3.626080] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 6, set usb3_lanes = 0x60
[ 3.626094] tegra21x-padctl-uphy 7009f000.pinctrl: USB3 port 0 maps to USB2 port 1
[ 3.626111] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 1, set pcie_lanes = 0x2
[ 3.626131] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 2, set pcie_lanes = 0x6
[ 3.626149] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 3, set pcie_lanes = 0xe
[ 3.626168] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 4, set pcie_lanes = 0x1e
[ 3.626187] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 0, set pcie_lanes = 0x1f
[ 3.626207] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 7, set sata_lanes = 0x80
[ 3.626915] usb-vbus1: supplied by vdd-3v3
[ 3.629302] tegra21x-padctl-uphy 7009f000.pinctrl: Done tegra21x_padctl_uphy_probe
[ 3.632013] tegra-pcie 1003000.pcie-controller: 4x1, 1x1 configuration
[ 3.632578] clk_cbus_round_rate: no gbus parent
[ 3.632584] tegra_gpu_edp gpu_edp: unable to get max GPU freq
[ 3.633079] tegra-ahci 70027000.sata: Missing devslp-active state
[ 3.633921] tegra-pcie 1003000.pcie-controller: PCIE: Enable power rails
[ 3.634737] tegra-ahci 70027000.sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 3.634749] tegra-ahci 70027000.sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 3.634964] gk20a 57000000.gpu: GPCPLL initial settings: NA mode, M=1, N=34, P=3
[ 3.636851] tegra-pcie 1003000.pcie-controller: probing port 0, using 4 lanes
[ 3.639039] tegra-pcie 1003000.pcie-controller: probing port 1, using 1 lanes
[ 3.640146] scsi host0: tegra_ahci
[ 3.644834] scsi host1: tegra_ahci
[ 3.645094] ata1: SATA max UDMA/133 mmio [mem 0x70027000-0x70028fff] port 0x100 irq 370
[ 3.645098] ata2: DUMMY
[ 3.648158] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 3.648660] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 3.649285] tegra21x-padctl-uphy 7009f000.pinctrl: trying to assert IDDQ while XUSB partitions are on
[ 3.649676] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 3.677714] tegra-pcie 1003000.pcie-controller: PCI host bridge to bus 0000:00
[ 3.677723] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 3.677729] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 3.677736] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 3.677742] pci_bus 0000:00: root bus resource [io 0x1000-0xffff]
[ 3.677778] pci 0000:00:01.0: [10de:0fae] type 01 class 0x060400
[ 3.677896] pci 0000:00:01.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 3.678240] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[ 3.678346] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 3.678659] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 3.678673] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 3.678885] pci 0000:01:00.0: [8086:1521] type 00 class 0x020000
[ 3.678946] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x0001ffff]
[ 3.678975] pci 0000:01:00.0: reg 0x18: [io 0x0000-0x001f]
[ 3.678992] pci 0000:01:00.0: reg 0x1c: [mem 0x00000000-0x00003fff]
[ 3.679163] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[ 3.679522] pci 0000:01:00.1: [8086:1521] type 00 class 0x020000
[ 3.679583] pci 0000:01:00.1: reg 0x10: [mem 0x00000000-0x0001ffff]
[ 3.679612] pci 0000:01:00.1: reg 0x18: [io 0x0000-0x001f]
[ 3.679629] pci 0000:01:00.1: reg 0x1c: [mem 0x00000000-0x00003fff]
[ 3.679791] pci 0000:01:00.1: PME# supported from D0 D3hot D3cold
[ 3.680105] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 3.680311] pci 0000:02:00.0: [1b21:0611] type 00 class 0x010185
[ 3.680364] pci 0000:02:00.0: reg 0x10: [io 0x0000-0x0007]
[ 3.680381] pci 0000:02:00.0: reg 0x14: [io 0x0000-0x0003]
[ 3.680397] pci 0000:02:00.0: reg 0x18: [io 0x0000-0x0007]
[ 3.680413] pci 0000:02:00.0: reg 0x1c: [io 0x0000-0x0003]
[ 3.680429] pci 0000:02:00.0: reg 0x20: [io 0x0000-0x000f]
[ 3.680446] pci 0000:02:00.0: reg 0x24: [mem 0x00000000-0x000001ff]
[ 3.680463] pci 0000:02:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
[ 3.680797] pci_bus 0000:02: busn_res: [bus 02-ff] end is updated to 02
[ 3.680866] pci 0000:00:01.0: BAR 8: assigned [mem 0x13000000-0x130fffff]
[ 3.680874] pci 0000:00:02.0: BAR 8: assigned [mem 0x13100000-0x131fffff]
[ 3.680881] pci 0000:00:01.0: BAR 7: assigned [io 0x1000-0x1fff]
[ 3.680888] pci 0000:00:02.0: BAR 7: assigned [io 0x2000-0x2fff]
[ 3.680900] pci 0000:01:00.0: BAR 0: assigned [mem 0x13000000-0x1301ffff]
[ 3.680912] pci 0000:01:00.1: BAR 0: assigned [mem 0x13020000-0x1303ffff]
[ 3.680923] pci 0000:01:00.0: BAR 3: assigned [mem 0x13040000-0x13043fff]
[ 3.680934] pci 0000:01:00.1: BAR 3: assigned [mem 0x13044000-0x13047fff]
[ 3.680945] pci 0000:01:00.0: BAR 2: assigned [io 0x1000-0x101f]
[ 3.680956] pci 0000:01:00.1: BAR 2: assigned [io 0x1020-0x103f]
[ 3.680968] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 3.680975] pci 0000:00:01.0: bridge window [io 0x1000-0x1fff]
[ 3.680984] pci 0000:00:01.0: bridge window [mem 0x13000000-0x130fffff]
[ 3.681002] pci 0000:02:00.0: BAR 6: assigned [mem 0x13100000-0x1310ffff pref]
[ 3.681009] pci 0000:02:00.0: BAR 5: assigned [mem 0x13110000-0x131101ff]
[ 3.681020] pci 0000:02:00.0: BAR 4: assigned [io 0x2000-0x200f]
[ 3.681031] pci 0000:02:00.0: BAR 0: assigned [io 0x2010-0x2017]
[ 3.681042] pci 0000:02:00.0: BAR 2: assigned [io 0x2018-0x201f]
[ 3.681052] pci 0000:02:00.0: BAR 1: assigned [io 0x2020-0x2023]
[ 3.681063] pci 0000:02:00.0: BAR 3: assigned [io 0x2024-0x2027]
[ 3.681073] pci 0000:00:02.0: PCI bridge to [bus 02]
[ 3.681080] pci 0000:00:02.0: bridge window [io 0x2000-0x2fff]
[ 3.681089] pci 0000:00:02.0: bridge window [mem 0x13100000-0x131fffff]
[ 3.681338] pcieport 0000:00:01.0: Signaling PME through PCIe PME interrupt
[ 3.681343] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 3.681347] pci 0000:01:00.1: Signaling PME through PCIe PME interrupt
[ 3.681356] pcie_pme 0000:00:01.0:pcie01: service driver pcie_pme loaded
[ 3.681482] aer 0000:00:01.0:pcie02: service driver aer loaded
[ 3.681742] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 3.681747] pci 0000:02:00.0: Signaling PME through PCIe PME interrupt
[ 3.681755] pcie_pme 0000:00:02.0:pcie01: service driver pcie_pme loaded
[ 3.681877] aer 0000:00:02.0:pcie02: service driver aer loaded
[ 3.682140] tegra-pcie 1003000.pcie-controller: speed change : Gen-1 → Gen-2
[ 3.683294] tegra-pcie 1003000.pcie-controller: speed change : Gen-1 → Gen-2
[ 3.714618] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS ‘floor cooling device’ registered
[ 3.714864] mmc0: Skipping tuning since strobe enabled
[ 3.740165] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS ‘cap cooling device’ registered
[ 3.740627] tegra_dfll_action dfll-cdev-cap: Tegra DFLL ‘cap cooling device’ registered
[ 3.764104] tegra_dfll_action dfll-cdev-floor: Tegra DFLL ‘floor cooling device’ registered
[ 3.767023] xhci-tegra 70090000.xusb: UTMI port 0 has OTG_CAP
[ 3.767025] xhci-tegra 70090000.xusb: No USB3 port has OTG_CAP
[ 3.769702] xhci-tegra 70090000.xusb: Direct firmware load for tegra21x_xusb_firmware failed with error -2
[ 3.769704] xhci-tegra 70090000.xusb: Falling back to user helper
[ 3.835312] input: gpio-keys as /devices/gpio-keys/input/input2
[ 3.841873] mmc0: new HS400 MMC card at address 0001
[ 3.846336] mmcblk0: mmc0:0001 016G32 14.7 GiB
[ 3.846552] mmcblk0rpmb: mmc0:0001 016G32 partition 3 4.00 MiB
[ 3.859851] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18
[ 3.891142] tegra_rtc 7000e000.rtc: setting system clock to 2017-10-05 09:28:10 UTC (1507195690)
[ 3.892049] vi 54080000.vi: vi_probe: ++
[ 3.959381] ata1: SATA link down (SStatus 0 SControl 300)
[ 4.259408] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 4.334841] vi 54080000.vi: initialized
[ 4.475505] vi 54080000.vi: all channel register failed
[ 4.482363] Disable partitions left on by BL
[ 4.482365] disb
[ 4.500668] DRAM derating cdev registered.
[ 4.501539] vdd-cpu-fixed: disabling
[ 4.501549] vdd-cam-hv: disabling
[ 4.506998] avdd-ts-hv: disabling
[ 4.513274] vdd-ts: disabling
[ 4.520170] max77620-gpio7: disabling
[ 4.533639] lcd-bl-en: disabling
[ 4.533643] en-vdd-cam: disabling
[ 4.533646] aux-3v3: disabling
[ 4.533648] snsr_pm: disabling
[ 4.533650] vdd-disp-3v0: disabling
[ 4.533652] vdd-fan: disabling
[ 4.533653] usb-vbus1: disabling
[ 4.533655] en-vdd-ts-1v8: disabling
[ 4.533657] en-vdd-ts-hv-3v3: disabling
[ 4.533659] en-vdd-disp-3v3: disabling
[ 4.540407] en-mdm-pwr-3v7: disabling
[ 4.540409] en-vdd-disp-1v8: disabling
[ 4.547153] en-vdd-cam-hv-2v8: disabling
[ 4.547155] rtl-5v0: disabling
[ 4.547156] en-usb-vbus2: disabling
[ 4.547158] en-vdd-cam-1v2: disabling
[ 4.547159] en-vdd-vcm-2v8: disabling
[ 4.573505] ALSA device list:
[ 4.573507] #0: tegra-hda at 0x70038000 irq 348
[ 4.573509] #1: tegra-snd-t210ref-mobile-rt565x
[ 5.601080] tegradc tegradc.1: hdmi: plugged
[ 5.608342] EXT4-fs (mmcblk0p1): couldn’t mount as ext3 due to feature incompatibilities
[ 5.618922] EXT4-fs (mmcblk0p1): couldn’t mount as ext2 due to feature incompatibilities
[ 5.633320] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 5.643175] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 5.653691] devtmpfs: mounted
[ 5.658793] Freeing unused kernel memory: 1208K (ffffffc001175000 - ffffffc0012a3000)
[ 5.668467] Freeing alternatives memory: 76K (ffffffc0012a3000 - ffffffc0012b6000)
[ 5.734861] random: systemd: uninitialized urandom read (16 bytes read, 52 bits of entropy available)
[ 5.741577] mmc1 tuning done saved tap delay=45
[ 5.741578] mmc1: hw tuning done …
[ 5.741582] mmc1: tuning_window[0]: 0xf3ffffff
[ 5.741585] mmc1: tuning_window[1]: 0xffffffff
[ 5.741587] mmc1: tuning_window[2]: 0xfffffffc
[ 5.741589] mmc1: tuning_window[3]: 0x7fffff3f
[ 5.741592] mmc1: tuning_window[4]: 0x0
[ 5.741594] mmc1: tuning_window[5]: 0x0
[ 5.741597] mmc1: tuning_window[6]: 0x0
[ 5.741599] mmc1: tuning_window[7]: 0x0
[ 5.741601] sdhci: Tap value: 45 | Trim value: 8
[ 5.741602] sdhci: SDMMC_VENDOR_INTR_STATUS[0x108]: 0x40000
[ 5.745510] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 5.745539] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 5.839305] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[ 5.859472] systemd[1]: Detected architecture arm64.
[ 5.877912] systemd[1]: Set hostname to .
[ 5.893505] random: systemd: uninitialized urandom read (16 bytes read, 58 bits of entropy available)
[ 5.905431] random: systemd: uninitialized urandom read (16 bytes read, 58 bits of entropy available)
[ 5.917362] random: systemd: uninitialized urandom read (16 bytes read, 58 bits of entropy available)
[ 5.931752] random: systemd-cryptse: uninitialized urandom read (16 bytes read, 59 bits of entropy available)
[ 5.938315] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 60 bits of entropy available)
[ 5.938391] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 60 bits of entropy available)
[ 5.938416] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 60 bits of entropy available)
[ 5.938539] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 60 bits of entropy available)
[ 5.938746] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 60 bits of entropy available)
[ 6.085298] systemd[1]: Listening on Syslog Socket.
[ 6.093992] systemd[1]: Reached target Remote File Systems (Pre).
[ 6.103949] systemd[1]: Listening on Journal Socket.
[ 6.112696] systemd[1]: Reached target Encrypted Volumes.
[ 6.121958] systemd[1]: Listening on udev Kernel Socket.
[ 6.131276] systemd[1]: Listening on Journal Audit Socket.
[ 6.140761] systemd[1]: Reached target Remote File Systems.
[ 6.150460] systemd[1]: Listening on udev Control Socket.
[ 6.160123] systemd[1]: Created slice User and Session Slice.
[ 6.170165] systemd[1]: Listening on LVM2 poll daemon socket.
[ 6.180297] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 6.191286] systemd[1]: Listening on LVM2 metadata daemon socket.
[ 6.201907] systemd[1]: Reached target User and Group Name Lookups.
[ 6.212874] systemd[1]: Listening on Journal Socket (/dev/log).
[ 6.223604] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 6.236048] systemd[1]: Created slice System Slice.
[ 6.245854] systemd[1]: Created slice system-getty.slice.
[ 6.256137] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 6.271391] systemd[1]: Starting Load Kernel Modules…
[ 6.282299] systemd[1]: Started Braille Device Support.
[ 6.296400] systemd[1]: Starting Journal Service…
[ 6.307407] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling…
[ 6.324110] systemd[1]: Reached target Swap.
[ 6.333991] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 6.347172] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 6.360179] systemd[1]: Mounting Debug File System…
[ 6.370692] systemd[1]: Reached target Slices.
[ 6.381177] systemd[1]: Starting Create list of required static device nodes for the current kernel…
[ 6.397375] systemd[1]: Mounted Debug File System.
[ 6.407690] systemd[1]: Started Journal Service.
[ 6.513583] systemd-journald[210]: Received request to flush runtime journal from PID 1
[ 6.700046] pps_core: LinuxPPS API ver. 1 registered
[ 6.722084] xhci-tegra 70090000.xusb: cannot find firmware…retry after 1 second
[ 6.727204] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 6.732960] PTP clock support registered
[ 6.757918] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.3.0-k
[ 6.757920] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 6.757979] igb 0000:01:00.0: enabling device (0000 → 0002)
[ 6.816524] igb 0000:01:00.0: added PHC on eth0
[ 6.827344] igb 0000:01:00.0: Intel(R) Gigabit Ethernet Network Connection
[ 6.836832] igb 0000:01:00.0: eth0: (PCIe:5.0Gb/s:Width x4) 00:a0:c9:00:00:00
[ 6.847433] igb 0000:01:00.0: eth0: PBA No: 106300-000
[ 6.855463] igb 0000:01:00.0: Using MSI-X interrupts. 4 rx queue(s), 4 tx queue(s)
[ 6.865747] igb 0000:01:00.1: enabling device (0000 → 0002)
[ 6.923787] dhd_module_init in
[ 6.929411] found wifi platform device bcmdhd_wlan
[ 6.937589] Power-up adapter ‘DHD generic adapter’
[ 6.944765] wifi_platform_set_power = 1
[ 6.956839] igb 0000:01:00.1: added PHC on eth1
[ 6.963805] igb 0000:01:00.1: Intel(R) Gigabit Ethernet Network Connection
[ 6.973672] igb 0000:01:00.1: eth1: (PCIe:5.0Gb/s:Width x4) 00:a0:c9:00:00:01
[ 6.985425] igb 0000:01:00.1: eth1: PBA No: 106300-000
[ 6.993067] igb 0000:01:00.1: Using MSI-X interrupts. 4 rx queue(s), 4 tx queue(s)
[ 7.155350] wifi_platform_bus_enumerate device present 1
[ 7.179815] wifi_platform_bus_enumerate device present 0
[ 7.188808] F1 signature read @0x18000000=0x17214354
[ 7.199553] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 7.200031] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 7.208901] wifi_platform_prealloc: failed to alloc static mem section 7
[ 7.208909] wifi_platform_get_mac_addr
[ 7.218630] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[ 7.307142] wl_create_event_handler(): thread:wl_event_handler:1a8 started
[ 7.307443] CFG80211-ERROR) wl_event_handler : tsk Enter, tsk = 0xffffffc0f2e81a70
[ 7.307455] dhd_attach(): thread:dhd_watchdog_thread:1aa started
[ 7.307490] dhd_attach(): thread:dhd_dpc:1ab started
[ 7.307546] dhd_attach(): thread:dhd_rxf:1ac started
[ 7.307553] dhd_deferred_work_init: work queue initialized
[ 7.307974] Dongle Host Driver, version 1.201.82 (r)
Compiled in drivers/net/wireless/bcmdhd on Jul 20 2017 at 00:39:01
[ 7.308325] tegra_sysfs_register
[ 7.308365] Register interface [wlan0] MAC: 00:04:4b:8f:1c:85
[ 7.308368] dhd_prot_ioctl : bus is down. we have nothing to do
[ 7.317699] sdhci-tegra sdhci-tegra.1: Tuning already done, restoring the best tap value : 45
[ 7.318734] wifi_platform_set_power = 0
[ 7.524574] random: nonblocking pool is initialized
[ 7.724466] xhci-tegra 70090000.xusb: Firmware timestamp: 2016-11-24 02:31:08 UTC, Version: 50.18 release
[ 7.795704] xhci-tegra 70090000.xusb: xHCI Host Controller
[ 7.848261] xhci-tegra 70090000.xusb: new USB bus registered, assigned bus number 1
[ 7.849089] xhci-tegra 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00010810
[ 7.850728] xhci-tegra 70090000.xusb: irq 319, io mem 0x70090000
[ 7.850842] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 7.850845] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.850848] usb usb1: Product: xHCI Host Controller
[ 7.850850] usb usb1: Manufacturer: Linux 4.4.38-tegra xhci-hcd
[ 7.850852] usb usb1: SerialNumber: 70090000.xusb
[ 7.851680] hub 1-0:1.0: USB hub found
[ 7.852658] hub 1-0:1.0: 5 ports detected
[ 7.879436] xhci-tegra 70090000.xusb: xHCI Host Controller
[ 7.879446] xhci-tegra 70090000.xusb: new USB bus registered, assigned bus number 2
[ 7.879583] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 7.879586] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.879589] usb usb2: Product: xHCI Host Controller
[ 7.879591] usb usb2: Manufacturer: Linux 4.4.38-tegra xhci-hcd
[ 7.879593] usb usb2: SerialNumber: 70090000.xusb
[ 7.880857] hub 2-0:1.0: USB hub found
[ 7.880884] hub 2-0:1.0: 4 ports detected
[ 8.163364] usb 1-3: new high-speed USB device number 2 using xhci-tegra
[ 8.188182] usb 1-3: feature bit otg_vbus_off set
[ 8.195051] usb 1-3: New USB device found, idVendor=0424, idProduct=2744
[ 8.204253] usb 2-1: new SuperSpeed USB device number 2 using xhci-tegra
[ 8.213255] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8.222647] usb 1-3: Product: USB2744
[ 8.228508] usb 1-3: Manufacturer: Microchip Tech
[ 8.236702] hub 1-3:1.0: USB hub found
[ 8.236812] hub 1-3:1.0: 5 ports detected
[ 8.236895] usb 2-1: New USB device found, idVendor=0955, idProduct=09ff
[ 8.236898] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[ 8.236900] usb 2-1: Product: USB 10/100/1000 LAN
[ 8.236902] usb 2-1: Manufacturer: Nvidia
[ 8.236904] usb 2-1: SerialNumber: 000001000000
[ 8.244428] xhci-tegra 70090000.xusb: tegra_xhci_mbox_work mailbox command 6
[ 8.252591] xhci-tegra 70090000.xusb: tegra_xhci_mbox_work mailbox command 6
[ 8.355809] usb 2-2: new SuperSpeed USB device number 3 using xhci-tegra
[ 8.380078] usb 2-2: feature bit otg_vbus_off set
[ 8.387010] usb 2-2: New USB device found, idVendor=0424, idProduct=5744
[ 8.395865] usb 2-2: New USB device strings: Mfr=2, Product=3, SerialNumber=0
[ 8.406765] usb 2-2: Product: USB5744
[ 8.412688] usb 2-2: Manufacturer: Microchip Tech
[ 8.421014] hub 2-2:1.0: USB hub found
[ 8.427101] hub 2-2:1.0: 4 ports detected
[ 8.492417] usb 2-1: reset SuperSpeed USB device number 2 using xhci-tegra
[ 8.519359] usb 1-3.1: new full-speed USB device number 3 using xhci-tegra
[ 8.533489] xhci-tegra 70090000.xusb: tegra_xhci_mbox_work mailbox command 17
[ 8.546230] xhci-tegra 70090000.xusb: tegra_xhci_mbox_work mailbox command 18
[ 8.561877] usb 1-3.1: New USB device found, idVendor=046d, idProduct=c534
[ 8.570935] usb 1-3.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8.580709] usb 1-3.1: Product: USB Receiver
[ 8.587218] usb 1-3.1: Manufacturer: Logitech
[ 8.596968] input: Logitech USB Receiver as /devices/70090000.xusb/usb1/1-3/1-3.1/1-3.1:1.0/0003:046D:C534.0001/input/input3
[ 8.616104] r8152 2-1:1.0 eth2: v2.03.3 (2015/01/29)
[ 8.624216] r8152 2-1:1.0 eth2: This product is covered by one or more of the following patents:
US6,570,884, US6,115,776, and US6,327,625.
[ 8.663977] hid-generic 0003:046D:C534.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-70090000.xusb-3.1/input0
[ 8.667498] input: Logitech USB Receiver as /devices/70090000.xusb/usb1/1-3/1-3.1/1-3.1:1.1/0003:046D:C534.0002/input/input4
[ 8.684971] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 8.723635] hid-generic 0003:046D:C534.0002: input,hiddev0,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-70090000.xusb-3.1/input1
[ 8.775617] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 8.793565] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 8.823348] usb 1-3.5: new high-speed USB device number 4 using xhci-tegra
[ 8.840381] usb 1-3.5: New USB device found, idVendor=0424, idProduct=2740
[ 8.840385] usb 1-3.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8.840387] usb 1-3.5: Product: Hub Controller
[ 8.840390] usb 1-3.5: Manufacturer: Microchip Tech
[ 8.893724] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 8.902163] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 8.902301]
[ 8.902303] wl_android_wifi_on in
[ 8.902305] wifi_platform_set_power = 1
[ 9.006377] tegradc tegradc.1: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 9.007147] tegradc tegradc.1: hdmi: pclk:148500K, set prod-setting:prod_c_hdmi_75m_150m
[ 9.172657] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 9.252871] sdhci-tegra sdhci-tegra.1: Tuning already done, restoring the best tap value : 45
[ 9.267709] F1 signature read @0x18000000=0x17214354
[ 9.278196] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 9.285302] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 9.345525] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 9.394556] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[ 9.401253] wifi_platform_get_mac_addr
[ 9.406465] Firmware up: op_mode=0x0005, MAC=00:04:4b:8f:1c:85
[ 9.417600] dhd_preinit_ioctls pspretend_threshold for HostAPD failed -23
[ 9.428447] Firmware version = wl0: Sep 14 2016 11:38:27 version 7.35.221.18 (r657725) FWID 01-9001dfb5
[ 9.440034] dhd_interworking_enable: failed to set WNM info, ret=-23
[ 9.446601] tegra_sysfs_on
[ 9.500997] cfg80211: World regulatory domain updated:
[ 9.506181] cfg80211: DFS Master region: unset
[ 9.510679] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 9.520582] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 9.528797] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 9.536858] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 9.545000] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 9.554500] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 9.564117] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 9.572230] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 9.580353] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 9.818832] CFGP2P-ERROR) wl_cfgp2p_add_p2p_disc_if : P2P interface registered
[ 9.836253] WLC_E_IF: NO_IF set, event Ignored
[ 9.927670] IPv6: ADDRCONF(NETDEV_UP): eth2: link is not ready
[ 10.011866] IPv6: ADDRCONF(NETDEV_UP): eth2: link is not ready
[ 12.318866] tegradc tegradc.1: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 12.319643] tegradc tegradc.1: hdmi: pclk:148500K, set prod-setting:prod_c_hdmi_75m_150m
[ 12.596148] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[ 12.638754] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[ 12.669042] Setting pll_a =
