Onboard camera open command no longer working with L4T 28.1 on TX1 board. OpneCV with onboard camera
This command no longer open onboard camera view:
gst-launch-1.0 nvcamerasrc fpsRange="30.0 30.0" ! 'video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)I420, framerate=(fraction)30/1' ! nvtee ! nvvidconv flip-method=2 ! 'video/x-raw(memory:NVMM), format=(string)I420' ! nvoverlaysink -e
here is the error command line output:
nvidia@tegra-ubuntu:~$ gst-launch-1.0 nvcamerasrc fpsRange="30.0 30.0" ! 'video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)I420, framerate=(fraction)30/1' ! nvtee ! nvvidconv flip-method=2 ! 'video/x-raw(memory:NVMM), format=(string)I420' ! nvoverlaysink -e
Setting pipeline to PAUSED ...
Socket read error. Camera Daemon stopped functioning.....
gst_nvcamera_open() failed ret=0
ERROR: Pipeline doesn't want to pause.
ERROR: from element /GstPipeline:pipeline0/GstNvCameraSrc:nvcamerasrc0: GStreamer error: state change failed and some element failed to post a proper error message with the reason for the failure.
Additional debug info:
gstbasesrc.c(3354): gst_base_src_start (): /GstPipeline:pipeline0/GstNvCameraSrc:nvcamerasrc0:
Failed to start
Setting pipeline to NULL ...
Freeing pipeline ...
how to make it work again?
With previous version of L4T it worked fine.
Also how to integrate onboard camera with OpenCV ? Do I still need opencv v3.2 to make it work? With OpenCV for tegra will not work?
do I need to do it like this if I use OpenCV 3.x:
cv::VideoCapture cap("nvcamerasrc ! video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)I420, framerate=(fraction)24/1 ! nvvidconv flip-method=2 ! video/x-raw, format=(string)I420 ! videoconvert ! video/x-raw, format=(string)BGR ! appsink");
HI pavlobuidenkov,
Yes, you still need opencv3.x to enable gstreamer pipeline.
hello pavlobuidenkov,
is your camera sensor works with previous JetPack version?
also, could you please taking the 3rdparty tool, v4l2-compliance to verify v4l devices. thanks
[url]https://www.mankier.com/1/v4l2-compliance[/url]
Hi pavlobuidenkov,
Have you clarified the cause and resolved this issue?
Any result can be shared?
Hey guys. Recently I got the camera OV5693 with the same pinout and connector for default TX1 camera PCB, so I changed the default OV5640 to the new OC5693 camera and on L4T 24.x it worked by default fantastic, no additional drivers needed to be installed. But I still can’t use neither OV5640 nor OV5693 with the new L4T 28
but I’ve got new error result
the /dev/video0 is missing from the system so I can’t check it with the v4l2-compliance
could you please check this forum topic, [url]https://devtalk.nvidia.com/default/topic/1019986/[/url]
did you also missing sensor probing at the kernel init stage?
I did dmesg > klog.txt and viewed the kernel 4.4 load log, it has nothing saying about ov5693 cameras.
But with L4T 24.1 I could find this message.
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpu
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.38-tegra (buildbrain@mobile-u64-1576) (gcc version 4.8.5 (GCC) ) #1 SMP PREEMPT Thu Jul 20 00:41:06 PDT 2017
[    0.000000] Boot CPU: AArch64 Processor [411fd071]
[    0.000000] Reserved memory: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[    0.000000] Reserved memory: initialized node iram-carveout, compatible id nvidia,iram-carveout
[    0.000000] Reserved memory: initialized node ramoops_carveout, compatible id nvidia,ramoops
[    0.000000] cma: Reserved 16 MiB at 0x00000000fdc00000
[    0.000000] On node 0 totalpages: 1043456
[    0.000000]   DMA zone: 8192 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 519168 pages, LIFO batch:31
[    0.000000]   Normal zone: 8192 pages used for memmap
[    0.000000]   Normal zone: 524288 pages, LIFO batch:31
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] PERCPU: Embedded 17 pages/cpu @ffffffc0ffe40000 s31360 r8192 d30080 u69632
[    0.000000] pcpu-alloc: s31360 r8192 d30080 u69632 alloc=17*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] CPU features: enabling workaround for ARM erratum 832075
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 1027072
[    0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 androidboot.modem=none androidboot.serialno=03243162380480c08305 androidboot.security=non-secure tegraid=21.1.2.0.0 ddr_die=2048M@2048M ddr_die=2048M@4096M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 debug_uartport=lsport,0 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff2bf000 nvdumper_reserved=0xff23f000 core_edp_mv=1075 core_edp_ma=4000 gpt android.kerneltype=normal androidboot.touch_vendor_id=0 androidboot.touch_panel_id=63 androidboot.touch_feature=0 androidboot.bootloader=00.00.2014.50-t210-fadd1be5 androidboot.verifiedbootstate=orange root=/dev/mmcblk0p1 rw rootwait
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] Memory: 3372572K/4173824K available (11009K kernel code, 1816K rwdata, 6352K rodata, 1208K init, 644K bss, 96740K reserved, 704512K cma-reserved)
[    0.000000] Virtual kernel memory layout:
                   vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000   (   246 GB)
                   vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000   (     8 GB maximum)
                             0xffffffbdc2000000 - 0xffffffbdc6000000   (    64 MB actual)
                   fixed   : 0xffffffbffa7fd000 - 0xffffffbffac00000   (  4108 KB)
                   PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000   (    16 MB)
                   modules : 0xffffffbffc000000 - 0xffffffc000000000   (    64 MB)
                   memory  : 0xffffffc000000000 - 0xffffffc100000000   (  4096 MB)
                     .init : 0xffffffc001175000 - 0xffffffc0012a3000   (  1208 KB)
                     .text : 0xffffffc000080000 - 0xffffffc001174c04   ( 17364 KB)
                     .data : 0xffffffc0012bd000 - 0xffffffc001483230   (  1817 KB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] 	Build-time adjustment of leaf fanout to 64.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[    0.000000] enable_t210_agic_clks:106 ape clocked & reset cleared
[    0.000000] clk_cbus_recalc_rate: no gbus parent
[    0.000000] kmemleak: Kernel memory leak detector disabled
[    0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[    0.000005] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[    0.001694] Console: colour dummy device 80x25
[    0.002563] console [tty0] enabled
[    0.002594] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
[    0.002630] pid_max: default: 32768 minimum: 301
[    0.002718] Security Framework initialized
[    0.002738] SELinux:  Initializing.
[    0.002811] SELinux:  Starting in permissive mode
[    0.002850] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.002874] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.003535] Initializing cgroup subsys freezer
[    0.003565] Initializing cgroup subsys debug
[    0.003827] CPU0 ipc=1024
[    0.003861] CPU1 ipc=1024
[    0.003892] CPU2 ipc=1024
[    0.003923] CPU3 ipc=1024
[    0.003989] ASID allocator initialised with 65536 entries
[    0.026983] tegra-id: chipid=22117.
[    0.027013] tegra-id: opt_subrevision=0.
[    0.027043] Tegra Speedo/IDDQ fuse revision 4
[    0.027064] Tegra: CPU Speedo ID 7, SoC Speedo ID 0, GPU Speedo ID 2
[    0.027084] Tegra: CPU Process ID 0, SoC Process ID 1, GPU Process ID 0
[    0.027105] Tegra: CPU Speedo Value 2032, SoC Speedo Value 1950, GPU Speedo Value 2059
[    0.027133] Tegra: CPU IDDQ Value 1916, SoC IDDQ Value 2260, GPU IDDQ Value 2735
[    0.027175] Tegra Revision: A02 SKU: 0x17 CPU Process: 0 SoC Process: 1
[    0.028568] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.4/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-devkit.dts
[    0.028616] DTB Build time: Jul 20 2017 00:41:47
[    0.044787] CPU1: Booted secondary processor [411fd071]
[    0.056757] CPU2: Booted secondary processor [411fd071]
[    0.068756] CPU3: Booted secondary processor [411fd071]
[    0.068842] Brought up 4 CPUs
[    0.068908] SMP: Total of 4 processors activated.
[    0.068931] CPU: All CPU(s) started at EL2
[    0.068971] alternatives: patching kernel code
[    0.071398] devtmpfs: initialized
[    0.143240] Initilizing CustomIPI irq domain
[    0.143588] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.156544] pinctrl core: initialized pinctrl subsystem
[    0.156773] OS set in device tree is L4T.
[    0.157163] regulator-dummy: no parameters
[    0.157380] Initializing plugin-manager
[    0.157452] Plugin module not found
[    0.158395] node /plugin-manager/fragement@0 match with board >=2180-1000-300
[    0.159173] node /plugin-manager/fragement@4 match with odm-data l4t
[    0.159304] Removing Prop nvidia,pmc-wakeup from target /bcmdhd_wlan
[    0.159803] Adding domain ape-pd to PM domain mc-clk-pd
[    0.159851] Adding domain adsp-pd to PM domain ape-pd
[    0.164750] NET: Registered protocol family 16
[    0.179881] console [pstore-1] enabled
[    0.179904] pstore: Registered ramoops as persistent store backend
[    0.179928] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[    0.192239] cpuidle: using governor ladder
[    0.204229] cpuidle: using governor menu
[    0.204598] bpmp: mail init ok
[    0.205721] vdso: 2 pages (1 code @ ffffffc0012c5000, 1 data @ ffffffc0012c4000)
[    0.205780] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.208126] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atomic allocations
[    0.209077] tegra_powergate_init: DONE
[    0.209119] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.4/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-devkit.dts
[    0.209168] DTB Build time: Jul 20 2017 00:41:47
[    0.210191] Error: Driver 'tegra-mc' is already registered, aborting...
[    0.211854] platform tegra-carveouts: SMMU isn't ready yet
[    0.212628] platform tegra-carveouts: domain=ffffffc0fa139318 allocates as[0]=ffffffc0fa14c0a8
[    0.212698] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[    0.212943] platform smmu_test: domain=ffffffc0fa139618 allocates as[0]=ffffffc0fa14c110
[    0.213283] platform 70016000.bpmp: domain=ffffffc0fa139918 allocates as[0]=ffffffc0fa14c178
[    0.213998] bpmp: ping status is 0
[    0.214105] bpmp 70016000.bpmp: firmware tag is 1e4b302fc0f866f97885165cf8b395ac
[    0.214364] bpmp 70016000.bpmp: probe ok
[    0.215035] mc: mapped MMIO address: 0xffffff800007e000 -> 0x70019000
[    0.215140] mc: mapped MMIO address: 0xffffff80000b6000 -> 0x7001c000
[    0.215239] mc: mapped MMIO address: 0xffffff80000dc000 -> 0x7001d000
[    0.215327] mc-err: Set intmask: 0x23d40
[    0.226985] GPIO line 58 (wlan-default-input-h2) hogged as input
[    0.227034] GPIO line 65 (wlan-default-input-i1) hogged as input
[    0.227079] GPIO line 56 (wlan-default-output-high-h0) hogged as output/high
[    0.227128] GPIO line 64 (wlan-default-output-high-i0) hogged as output/high
[    0.227172] GPIO line 148 (cam0-rst) hogged as output/low
[    0.227211] GPIO line 151 (cam0-pwdn) hogged as output/low
[    0.227249] GPIO line 149 (cam1-rst) hogged as output/low
[    0.227288] GPIO line 152 (cam1-pwdn) hogged as output/low
[    0.227404] gpiochip_add_data: registered GPIOs 0 to 255 on device: tegra-gpio
[    0.229951] platform 70006000.serial: domain=ffffffc0fa1e6e18 allocates as[0]=ffffffc0fa14c1e0
[    0.231092] platform sound: domain=ffffffc0fa201718 allocates as[0]=ffffffc0fa14c248
[    0.233590] platform tegradc.1: domain=ffffffc0fa244918 allocates as[0]=ffffffc0fa14c2b0
[    0.234217] platform tegradc.1: IOVA linear map 0x00000000c6000000(2a000000)
[    0.237007] platform 57000000.gpu: domain=ffffffc0fa253d18 allocates as[0]=ffffffc0fa14c318
[    0.237085] platform 57000000.gpu: domain=ffffffc0fa253d18 allocates as[1]=ffffffc0fa14c380
[    0.237158] platform 57000000.gpu: domain=ffffffc0fa253d18 allocates as[2]=ffffffc0fa14c3e8
[    0.237228] platform 57000000.gpu: domain=ffffffc0fa253d18 allocates as[3]=ffffffc0fa14c450
[    0.237999] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[    0.238043] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[    0.238068] tegra-pmc: ### PMC reset source: Power on reset
[    0.238088] tegra-pmc: ### PMC reset status reg: 0x0
[    0.238467] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[    0.238501] tegra-pmc: Clear bootloader IO dpd settings
[    0.240343] tegra-pmc 7000e400.pmc: PMC: IO pad audio voltage is 1800000
[    0.244321] tegra-pmc 7000e400.pmc: PMC: IO pad cam voltage is 1800000
[    0.248319] tegra-pmc 7000e400.pmc: PMC: IO pad dbg voltage is 1800000
[    0.252319] tegra-pmc 7000e400.pmc: PMC: IO pad dmic voltage is 1800000
[    0.252349] tegra-pmc 7000e400.pmc: PMC: IO pad pex-ctrl voltage is 1800000
[    0.256318] tegra-pmc 7000e400.pmc: PMC: IO pad spi voltage is 1800000
[    0.260321] tegra-pmc 7000e400.pmc: PMC: IO pad uart voltage is 1800000
[    0.264319] tegra-pmc 7000e400.pmc: PMC: IO pad audio-hv voltage is 1800000
[    0.264349] tegra-pmc 7000e400.pmc: PMC: IO pad spi-hv voltage is 1800000
[    0.268318] tegra-pmc 7000e400.pmc: PMC: IO pad gpio voltage is 1800000
[    0.272318] tegra-pmc 7000e400.pmc: PMC: IO pad sdmmc3 voltage is 1800000
[    0.272344] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[    0.272414] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[    0.275585] platform 1003000.pcie-controller: domain=ffffffc0fa25be18 allocates as[0]=ffffffc0fa14c4b8
[    0.277956] platform sdhci-tegra.3: domain=ffffffc0fa282f18 allocates as[0]=ffffffc0fa14c520
[    0.278569] platform sdhci-tegra.0: domain=ffffffc0fa289318 allocates as[0]=ffffffc0fa14c588
[    0.284177] vdd-ac-bat: 5000 mV
[    0.285431] vdd-cpu-fixed: 1000 mV
[    0.289310] irq: no irq domain found for /soctherm@0x700E2000 !
[    0.289659] irq: no irq domain found for /soctherm@0x700E2000 !
[    0.313450] ACPI: Interpreter disabled.
[    0.314285] SCSI subsystem initialized
[    0.314353] libata version 3.00 loaded.
[    0.314573] usbcore: registered new interface driver usbfs
[    0.314645] usbcore: registered new interface driver hub
[    0.314748] usbcore: registered new device driver usb
[    0.318025] gpiochip_add_data: registered GPIOs 496 to 511 on device: tca9539
[    0.319511] gpiochip_add_data: registered GPIOs 480 to 495 on device: tca9539
[    0.322649] max77620 4-003c: PMIC Version OTP:0x3C and ES:0x8
[    0.324438] GPIO line 474 (spmic-default-output-high) hogged as output/high
[    0.324558] gpiochip_add_data: registered GPIOs 472 to 479 on device: max77620-gpio
[    0.328352] vdd-core: 600 <--> 1400 mV at 1075 mV
[    0.332345] vddio-ddr: at 1125 mV
[    0.333185] vdd-pre-reg: 1350 mV
[    0.336222] vdd-1v8: 1800 mV
[    0.340223] avdd-sys: 1200 mV
[    0.344223] vdd-pex: 1050 mV
[    0.344841] vddio-sdmmc1: 1800 <--> 3300 mV at 3300 mV
[    0.345668] vdd-cam-hv: 2800 mV
[    0.348221] vdd-rtc: 850 mV
[    0.349085] avdd-ts-hv: 3300 mV
[    0.349937] vdd-ts: 1800 mV
[    0.352223] vdd-gen-pll-edp: 1050 mV
[    0.356223] vdd-hdmi-dp: 1050 mV
[    0.356861] max77620 4-003c: max77620 probe successful
[    0.358774] media: Linux media interface: v0.10
[    0.358853] Linux video capture interface: v2.00
[    0.366583] tegra210-emc 7001b000.memory-controller: validated EMC DFS table
[    0.366913] Advanced Linux Sound Architecture Driver Initialized.
[    0.370417] tegra210_dvfs: no clock found for sdmmc2_ddr
[    0.370471] tegra210_dvfs: no clock found for sdmmc4_ddr
[    0.370572] tegra210_dvfs: no clock found for sdmmc1_ddr
[    0.370617] tegra210_dvfs: no clock found for sdmmc3_ddr
[    0.373644] regulator_get() failed for (dvfs,vdd-cpu), -19
[    0.373671] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[    0.376228] vdd-3v3: 3300 mV
[    0.380223] max77620-gpio7: 1050 mV
[    0.380545] lcd-bl-en: 1800 mV
[    0.380852] en-vdd-sd: 3300 mV
[    0.381525] en-vdd-cam: 1800 mV
[    0.384223] vdd-sys-boost: 5000 mV
[    0.384892] vdd-hdmi: 5000 mV
[    0.385150] aux-3v3: 3300 mV
[    0.385385] snsr_pm: 3300 mV
[    0.388225] vdd-disp-3v0: 3000 mV
[    0.388905] vdd-fan: 5000 mV
[    0.389204] usb-vbus1: 5000 mV
[    0.389858] en-vdd-ts-1v8: 1800 mV
[    0.390532] en-vdd-ts-hv-3v3: 3300 mV
[    0.391373] en-vdd-disp-3v3: 3300 mV
[    0.392026] en-mdm-pwr-3v7: 3700 mV
[    0.392888] en-vdd-disp-1v8: 1800 mV
[    0.393548] en-vdd-cam-hv-2v8: 2800 mV
[    0.393841] rtl-5v0: 5000 mV
[    0.394146] en-usb-vbus2: 5000 mV
[    0.394814] en-vdd-cam-1v2: 1200 mV
[    0.395104] en-vdd-vcm-2v8: 2800 mV
[    0.397918] extcon-gpio-states extcon:extcon@1: Cable state 0
[    0.399261] clocksource: Switched to clocksource arch_sys_counter
[    0.438468] nvmap_heap_init: nvmap_heap_init: created heap block cache
[    0.438845] dma_declare_coherent_resizable_cma_memory:290: resizable heap=vpr, base=0x00000000c6000000, size=0x2a000000
[    0.439030] cma: enabled page replacement for spfn=c6000, epfn=f0000
[    0.439056] dma_declare_coherent_resizable_cma_memory:337: resizable cma heap=vpr create successful
[    0.439087] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[    0.439146] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[    0.439179] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[    0.439517] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[    0.440240] misc nvmap: created heap vpr base 0x00000000c6000000 size (688128KiB)
[    0.440984] pnp: PnP ACPI: disabled
[    0.452797] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[    0.454625] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[    0.455033] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[    0.455230] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[    0.456884] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tdiode_tegra
[    0.457142] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type PMIC-Die
[    0.457373] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tboard_tegra
[    0.458582] isomgr_init(): iso emc max clk=1600000KHz
[    0.458604] isomgr_init(): max_iso_bw=11520000KB
[    0.458740] NET: Registered protocol family 2
[    0.459354] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[    0.459540] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[    0.459812] TCP: Hash tables configured (established 32768 bind 32768)
[    0.459914] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[    0.459979] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[    0.460223] NET: Registered protocol family 1
[    0.460544] RPC: Registered named UNIX socket transport module.
[    0.460570] RPC: Registered udp transport module.
[    0.460590] RPC: Registered tcp transport module.
[    0.460611] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.460648] PCI: CLS 0 bytes, default 128
[    0.460860] Trying to unpack rootfs image as initramfs...
[    0.472016] host1x 50000000.host1x: initialized
[    0.473729] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    0.477027] futex hash table entries: 1024 (order: 5, 131072 bytes)
[    0.477148] audit: initializing netlink subsys (disabled)
[    0.477206] audit: type=2000 audit(0.467:1): initialized
[    0.489095] ntfs: driver 2.1.32 [Flags: R/O].
[    0.489596] fuse init (API version 7.23)
[    0.490122] SELinux:  Registering netfilter hooks
[    0.492306] io scheduler noop registered (default)
[    0.492339] io scheduler deadline registered
[    0.492664] io scheduler cfq registered
[    0.498147] tegra21x-padctl-uphy 7009f000.pinctrl: padctl mmio start 0x000000007009f000 end 0x000000007009ffff
[    0.498193] tegra21x-padctl-uphy 7009f000.pinctrl: TEGRA_FUSE_SKU_CALIB_0 0x79e8c10
[    0.498227] tegra21x-padctl-uphy 7009f000.pinctrl: TEGRA_FUSE_USB_CALIB_EXT_0 0x4
[    0.499691] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-0 is used by XUSB
[    0.499726] tegra21x-padctl-uphy 7009f000.pinctrl: using UTMI port 0 for otg
[    0.499754] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-2 is used by XUSB
[    0.499790] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 5, set usb3_lanes = 0x20
[    0.499833] tegra21x-padctl-uphy 7009f000.pinctrl: USB3 port 1 maps to USB2 port 2
[    0.499867] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-1 is used by XUSB
[    0.499902] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 6, set usb3_lanes = 0x60
[    0.499944] tegra21x-padctl-uphy 7009f000.pinctrl: USB3 port 0 maps to USB2 port 1
[    0.499990] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 1, set pcie_lanes = 0x2
[    0.500038] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 2, set pcie_lanes = 0x6
[    0.500085] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 3, set pcie_lanes = 0xe
[    0.500130] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 4, set pcie_lanes = 0x1e
[    0.500176] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 0, set pcie_lanes = 0x1f
[    0.500224] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 7, set sata_lanes = 0x80
[    0.500664] tegra21x-padctl-uphy 7009f000.pinctrl: mailbox is not ready yet
[    0.501703] tegra-pwm 7000a000.pwm: PWM clk can sleep in ops
[    0.502789] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[    0.503557] Adding domain pcie-pd to PM domain mc-clk-pd
[    0.508178] tegra-pcie 1003000.pcie-controller: 4x1, 1x1 configuration
[    0.508247] tegra-pcie 1003000.pcie-controller: failed to get PHY: -517
[    0.508274] tegra-pcie 1003000.pcie-controller: failed to get PHYs: -517
[    0.511793] tsec 54500000.tsec: initialized
[    0.513135] tsec 54100000.tsecb: initialized
[    0.516114] nvdec 54480000.nvdec: initialized
[    0.522124] falcon 54340000.vic: initialized
[    0.524025] falcon 544c0000.nvenc: initialized
[    0.525192] falcon 54380000.nvjpg: initialized
[    0.527185] DC OR NODE connected to /host1x/sor1
[    0.527303] display board info: id 0xffff, fab 0x0
[    0.527359] panel_select fail by _node_status
[    0.527417] display board info: id 0xffff, fab 0x0
[    0.527463] panel_select fail by _node_status
[    0.527645] tegradc tegradc.1: DT parsed successfully
[    0.527703] tegradc tegradc.1: Display dc.ffffff8000980000 registered with id=0
[    0.528565] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[    0.528765] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1020000, vi_iso_bw=750000, max_bw=1020000
[    0.529597] display board info: id 0xffff, fab 0x0
[    0.529648] panel_select fail by _node_status
[    0.534604] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[    0.536669] tegra-adma 702e2000.adma: Tegra ADMA driver register 10 channels
[    0.538148] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[    0.538455] kfuse 7000fc00.kfuse: initialized
[    0.540405] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[    0.541386] clk_cbus_round_rate: no gbus parent
[    0.541413] tegra_gpu_edp gpu_edp: unable to get max GPU freq
[    0.541929] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[    0.541961] vdd-cpu: 708 <--> 1322 mV at 708 mV
[    0.542023] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[    0.543194] vdd-gpu: applied init 1000000uV constraint
[    0.543223] vdd-gpu: 710 <--> 1320 mV at 1000 mV
[    0.543315] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[    0.543706] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    0.543838] No Device Node present for smmu client: serial8250 !!
[    0.543867] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[    0.543903] No Device Node present for smmu client: serial8250 !!
[    0.543927] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[    0.545000] No Device Node present for smmu client: serial8250 !!
[    0.545030] serial8250 serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[    0.545077] No Device Node present for smmu client: serial8250 !!
[    0.545102] serial8250 serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[    0.545753] console [ttyS0] disabled
[    0.545817] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 320, base_baud = 25500000) is a Tegra
[    0.555893] Unsupported HDMI VIC 24, ignoring
[    0.555897] Unsupported HDMI VIC 113, ignoring
[    0.555900] Unsupported HDMI VIC 56, ignoring
[    0.555902] Unsupported HDMI VIC 45, ignoring
[    0.556981] tegradc tegradc.1: probed
[    2.590166] console [ttyS0] enabled
[    2.591535] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 321, base_baud = 0) is a TEGRA_UART
[    2.592006] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 322, base_baud = 0) is a TEGRA_UART
[    2.592351] serial-tegra 70006300.serial: RX in PIO mode
[    2.592452] 70006300.serial: ttyTHS3 at MMIO 0x70006300 (irq = 323, base_baud = 0) is a TEGRA_UART
[    2.598832] gk20a 57000000.gpu: platform probe failed
[    2.605487] brd: module loaded
[    2.611035] loop: module loaded
[    2.611695] zram: Added device: zram0
[    2.611705] Silicon Labs C2 port support v. 0.51.0 - (C) 2007 Rodolfo Giometti
[    2.611915] nct1008_nct72 0-004c: find device tree node, parsing dt
[    2.611921] nct1008_nct72 0-004c: starting parse dt
[    2.611996] nct1008_nct72 0-004c: success parsing dt
[    2.612237] nct1008_nct72 0-004c: success in enabling tmp451 VDD rail
[    2.633906] Console: switching to colour frame buffer device 320x90
[    2.647055] tmp451: Enabled overheat logging at 102.00C
[    2.651226] nct1008_nct72 0-004c: nct1008_probe: initialized
[    2.654014] THERMAL EST: found 2 subdevs
[    2.654019] THERMAL EST num_resources: 0
[    2.654023] [THERMAL EST subdev 0]
[    2.654030] [THERMAL EST subdev 1]
[    2.654376] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[    2.654378] THERMAL EST: thz register success.
[    2.654518] THERMAL EST: end of probe, return err: 0
[    2.654597] tegra_profiler: Branch: Dev
[    2.654599] tegra_profiler: Version: 1.109
[    2.654602] tegra_profiler: Samples version: 37
[    2.654604] tegra_profiler: IO version: 21
[    2.654610] armv8_pmu: imp: 0x41, idcode: 0x1
[    2.654615] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[    2.654619] armv8_pmu: imp: 0x41, idcode: 0x1
[    2.654623] armv8_pmu: [1] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[    2.654627] armv8_pmu: imp: 0x41, idcode: 0x1
[    2.654631] armv8_pmu: [2] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[    2.654635] armv8_pmu: imp: 0x41, idcode: 0x1
[    2.654639] armv8_pmu: [3] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[    2.654845] tegra_profiler: auth: init
[    2.655381] tegra-ahci 70027000.sata: Missing devslp-active state
[    2.656307] Rounding down aligned max_sectors from 4294967295 to 4294967288
[    2.656814] spi-tegra114 7000d400.spi: Static pin configuration used
[    2.657621] spi-tegra114 7000da00.spi: Static pin configuration used
[    2.659031] tun: Universal TUN/TAP device driver, 1.6
[    2.659035] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    2.659485] PPP generic driver version 2.4.2
[    2.659659] PPP BSD Compression module registered
[    2.659668] PPP Deflate Compression module registered
[    2.659690] PPP MPPE Compression module registered
[    2.659705] NET: Registered protocol family 24
[    2.659791] usbcore: registered new interface driver r8152
[    2.659850] usbcore: registered new interface driver asix
[    2.659901] usbcore: registered new interface driver ax88179_178a
[    2.659947] usbcore: registered new interface driver cdc_ether
[    2.660007] usbcore: registered new interface driver smsc95xx
[    2.660053] usbcore: registered new interface driver net1080
[    2.660098] usbcore: registered new interface driver cdc_subset
[    2.660148] usbcore: registered new interface driver zaurus
[    2.660223] usbcore: registered new interface driver cdc_ncm
[    2.660355] usbcore: registered new interface driver usb-storage
[    2.660461] usbcore: registered new interface driver usbserial
[    2.660502] usbcore: registered new interface driver ftdi_sio
[    2.660534] usbserial: USB Serial support registered for FTDI USB Serial Device
[    2.660574] usbcore: registered new interface driver option
[    2.660604] usbserial: USB Serial support registered for GSM modem (1-port)
[    2.660643] usbcore: registered new interface driver pl2303
[    2.660672] usbserial: USB Serial support registered for pl2303
[    2.661699] tegra-xudc-new 700d0000.xudc: usb2 phy is not available yet
[    2.836327] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc1
[    2.853467] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc0
[    2.853495] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[    2.853965] i2c /dev entries driver
[    2.855985] IR NEC protocol handler initialized
[    2.855992] IR Sharp protocol handler initialized
[    2.855999] IR XMP protocol handler initialized
[    2.856074] usbcore: registered new interface driver uvcvideo
[    2.856076] USB Video Class driver (1.1.1)
[    2.859298] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[    2.901559] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[    2.901566] tegra_soctherm 700e2000.soctherm: pllx_offset tz:1 max:8, min:4
[    2.902081] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[    2.902091] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[    2.902307] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    2.902318] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[    2.902327] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[    2.902581] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    2.902587] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature 2147483647 forced to 127000
[    2.902596] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[    2.902603] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[    2.903009] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[    2.913685] tegra_aotag tegra-aotag: Registering sensor 0
[    2.913756] tegra_aotag tegra-aotag: Invalid temp readout
[    2.913764] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[    2.913771] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[    2.914588] FAN dev name: pwm-fan
[    2.914634] FAN:gpio request success.
[    2.914697] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[    2.914985] pwm_fan_driver pwm-fan: unable to request PWM, trying legacy API
[    2.914993] pwm_fan_driver pwm-fan: got pwm for fan
[    2.916929] pwm_fan_driver pwm-fan: fan tach request irq success
[    2.916938] pwm_fan_driver pwm-fan: tach period: 1000
[    2.917049] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[    2.917057] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[    2.917063] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[    2.917070] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[    2.917077] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[    2.917083] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[    2.917089] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[    2.917096] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[    2.917102] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[    2.917108] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[    2.921783] tegra-wdt 60005100.watchdog: Tegra WDT enabled on probe. Timeout = 120 seconds.
[    2.922096] tegra-wdt 60005100.watchdog: initialized (timeout = 120 sec, nowayout = 1)
[    2.922425] device-mapper: uevent: version 1.0.3
[    2.922746] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[    2.934940] sdhci: Secure Digital Host Controller Interface driver
[    2.934943] sdhci: Copyright(c) Pierre Ossman
[    2.934951] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.935625] sdhci-tegra sdhci-tegra.3: Parent select= pll_p rate=408000000
[    2.935677] sdhci-tegra sdhci-tegra.3: Parent select= pll_c4_out2 rate=199680000
[    2.935702] sdhci-tegra sdhci-tegra.3: Client registration for eMC Successful
[    3.008259] tegra-se 70012000.se: tegra_se_probe: complete
[    3.009034] hidraw: raw HID events driver (C) Jiri Kosina
[    3.012256] usbcore: registered new interface driver usbhid
[    3.012259] usbhid: USB HID core driver
[    3.015309] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA 64-bit with 64 bit addr
[    3.015708] sdhci-tegra sdhci-tegra.1: Parent select= pll_p rate=408000000
[    3.015732] sdhci-tegra sdhci-tegra.1: Client registration for eMC Successful
[    3.101510] parse_throttle_dt_data: Num cap clks = 6
[    3.101516] parse_throttle_dt_data: clk=cclk_g type=2
[    3.101524] parse_throttle_dt_data: clk=gpu type=4
[    3.101566] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[    3.101601] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[    3.101641] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[    3.101645] parse_throttle_dt_data: clk=emc type=3
[    3.128275] tegra_throttle_probe: probe successful. #cdevs=4
[    3.128547] tegra21x_actmon 6000c800.actmon: in actmon_register()...
[    3.138268] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[    3.139813] tegra124-dfll 70110000.clock: config PMU interface as PWM
[    3.142903] No Device Node present for smmu client: snd-soc-dummy !!
[    3.142911] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[    3.142919] No Device Node present for smmu client: snd-soc-dummy !!
[    3.142924] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[    3.143164] No Device Node present for smmu client: snd-soc-dummy !!
[    3.143170] snd-soc-dummy snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[    3.143200] No Device Node present for smmu client: snd-soc-dummy !!
[    3.143205] snd-soc-dummy snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[    3.147367] mmc1: SDHCI controller on sdhci-tegra.1 [sdhci-tegra.1] using ADMA 64-bit with 64 bit addr
[    3.148091] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[    3.148141] sdhci-tegra sdhci-tegra.0: Got WP GPIO
[    3.148221] sdhci-tegra sdhci-tegra.0: Parent select= pll_p rate=408000000
[    3.148275] sdhci-tegra sdhci-tegra.0: wakeup init done, cd_irq: 262
[    3.148298] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[    3.150234] en-vdd-sd: supplied by vdd-3v3
[    3.159597] tegra210-i2s tegra210-i2s.0: Missing prop fsync-width for I2S0
[    3.160635] tegra210-i2s tegra210-i2s.2: Missing prop fsync-width for I2S2
[    3.160954] tegra210-i2s tegra210-i2s.3: Missing prop fsync-width for I2S3
[    3.161628] tegra210-i2s tegra210-i2s.4: Missing prop fsync-width for I2S4
[    3.167059] OPE platform probe
[    3.168352] OPE platform probe successful
[    3.168412] OPE platform probe
[    3.168599] OPE platform probe successful
[    3.170399] tegra-snd-t210ref-mobile-rt565x sound: Failed to get HP Det GPIO, should be handled by codec
[    3.206609] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF1 <-> ADMAIF1 mapping ok
[    3.206848] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF2 <-> ADMAIF2 mapping ok
[    3.207074] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF3 <-> ADMAIF3 mapping ok
[    3.207323] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF4 <-> ADMAIF4 mapping ok
[    3.207553] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF5 <-> ADMAIF5 mapping ok
[    3.207779] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF6 <-> ADMAIF6 mapping ok
[    3.208013] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF7 <-> ADMAIF7 mapping ok
[    3.208242] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF8 <-> ADMAIF8 mapping ok
[    3.208471] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF9 <-> ADMAIF9 mapping ok
[    3.210822] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF10 <-> ADMAIF10 mapping ok
[    3.222451] mmc2: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[    3.234121] input: tegra-snd-t210ref-mobile-rt565x Headphone Jack as /devices/sound/sound/card1/input0
[    3.235228] tegra-snd-t210ref-mobile-rt565x sound: codec-dai "dit-hifi" registered
[    3.235234] tegra-snd-t210ref-mobile-rt565x sound: This is a dummy codec
[    3.236139] GACT probability NOT on
[    3.236150] Mirror/redirect action on
[    3.236166] u32 classifier
[    3.236168]     Actions configured
[    3.236179] Netfilter messages via NETLINK v0.30.
[    3.236230] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[    3.236664] ctnetlink v0.93: registering with nfnetlink.
[    3.237240] xt_time: kernel timezone is -0000
[    3.237392] ipip: IPv4 over IPv4 tunneling driver
[    3.238039] ip_tables: (C) 2000-2006 Netfilter Core Team
[    3.238175] arp_tables: (C) 2002 David S. Miller
[    3.238247] Initializing XFRM netlink socket
[    3.239082] NET: Registered protocol family 10
[    3.251890] mip6: Mobile IPv6
[    3.251917] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    3.252110] sit: IPv6 over IPv4 tunneling driver
[    3.253194] NET: Registered protocol family 17
[    3.253221] NET: Registered protocol family 15
[    3.253260] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[    3.253297] Key type dns_resolver registered
[    3.266708] Registered cp15_barrier emulation handler
[    3.329121] mmc0: MAN_BKOPS_EN bit is not set
[    3.375118] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input1
[    3.453199] mmc0: Skipping tuning since strobe enabled
[    3.622542] mmc0: new HS400 MMC card at address 0001
[    3.623226] mmcblk0: mmc0:0001 016G32 14.7 GiB
[    3.623626] mmcblk0rpmb: mmc0:0001 016G32 partition 3 4.00 MiB
[    3.650067]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18
[    4.242678] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[    4.849819] tegradc tegradc.1: fb registered
[    4.885630] tegradc tegradc.1: nominal-pclk:241699200 parent:241696875 div:1.0 pclk:241696875 239282208~263452128
[    4.903849] tegradc tegradc.1: hdmi: pclk:241699K, set prod-setting:prod_c_hdmi_150m_300m
[    4.921750] isp 54600000.isp: initialized
[    4.934166] isp 54680000.isp: initialized
[    4.951498] clk_cbus_recalc_rate: no gbus parent
[    4.962842] clk_cbus_round_rate: no gbus parent
[    4.974232] clk_cbus_round_rate: no gbus parent
[    4.985554] clk_cbus_recalc_rate: no gbus parent
[    4.997618] clk_cbus_recalc_rate: no gbus parent
[    5.008899] clk_cbus_round_rate: no gbus parent
[    5.020403] clk_cbus_round_rate: no gbus parent
[    5.031801] clk_cbus_recalc_rate: no gbus parent
[    5.043321] tegra_dvfs: GPU-cap: registered
[    5.054566] tegra dvfs: vdd-cpu: nominal 1226mV, offset 708000uV, step 19200uV, scaling enabled
[    5.070408] tegra dvfs: vdd-core: nominal 1075mV, offset 600000uV, step 12500uV, scaling enabled
[    5.086236] Unsupported HDMI VIC 24, ignoring
[    5.097535] tegra dvfs: vdd-gpu: nominal 1100mV, offset 710000uV, step 10000uV, scaling enabled
[    5.113269] Unsupported HDMI VIC 113, ignoring
[    5.124673] Unsupported HDMI VIC 56, ignoring
[    5.135901] Unsupported HDMI VIC 45, ignoring
[    5.148981] tegra_dvfs: vdd-gpu-vts: registered
[    5.151009] xhci-tegra 70090000.xusb: can't get usb3-0 phy (-517)
[    5.151733] tegra21x-padctl-uphy 7009f000.pinctrl: padctl mmio start 0x000000007009f000 end 0x000000007009ffff
[    5.151744] tegra21x-padctl-uphy 7009f000.pinctrl: TEGRA_FUSE_SKU_CALIB_0 0x79e8c10
[    5.151752] tegra21x-padctl-uphy 7009f000.pinctrl: TEGRA_FUSE_USB_CALIB_EXT_0 0x4
[    5.153108] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-0 is used by XUSB
[    5.153118] tegra21x-padctl-uphy 7009f000.pinctrl: using UTMI port 0 for otg
[    5.153126] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-2 is used by XUSB
[    5.153141] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 5, set usb3_lanes = 0x20
[    5.153157] tegra21x-padctl-uphy 7009f000.pinctrl: USB3 port 1 maps to USB2 port 2
[    5.153164] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-1 is used by XUSB
[    5.153178] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 6, set usb3_lanes = 0x60
[    5.153192] tegra21x-padctl-uphy 7009f000.pinctrl: USB3 port 0 maps to USB2 port 1
[    5.153208] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 1, set pcie_lanes = 0x2
[    5.153227] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 2, set pcie_lanes = 0x6
[    5.153245] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 3, set pcie_lanes = 0xe
[    5.153262] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 4, set pcie_lanes = 0x1e
[    5.153279] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 0, set pcie_lanes = 0x1f
[    5.153298] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 7, set sata_lanes = 0x80
[    5.154016] usb-vbus1: supplied by vdd-3v3
[    5.156426] tegra21x-padctl-uphy 7009f000.pinctrl: Done tegra21x_padctl_uphy_probe
[    5.159129] tegra-pcie 1003000.pcie-controller: 4x1, 1x1 configuration
[    5.159399] tegra-pcie 1003000.pcie-controller: PCIE: Enable power rails
[    5.160134] clk_cbus_round_rate: no gbus parent
[    5.160140] tegra_gpu_edp gpu_edp: unable to get max GPU freq
[    5.160500] tegra-pcie 1003000.pcie-controller: probing port 0, using 4 lanes
[    5.160721] tegra-ahci 70027000.sata: Missing devslp-active state
[    5.161677] tegra-ahci 70027000.sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[    5.161689] tegra-ahci 70027000.sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[    5.162611] tegra-pcie 1003000.pcie-controller: probing port 1, using 1 lanes
[    5.163894] gk20a 57000000.gpu: GPCPLL initial settings: NA mode, M=1, N=34, P=3
[    5.167003] scsi host0: tegra_ahci
[    5.167742] scsi host1: tegra_ahci
[    5.167991] ata1: SATA max UDMA/133 mmio [mem 0x70027000-0x70028fff] port 0x100 irq 370
[    5.167996] ata2: DUMMY
[    5.169675] tegradc tegradc.1: nominal-pclk:241545000 parent:241696875 div:1.0 pclk:241696875 239129550~263284050
[    5.171175] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[    5.171745] tegra-xudc-new 700d0000.xudc: entering ELPG
[    5.172785] tegra21x-padctl-uphy 7009f000.pinctrl: trying to assert IDDQ while XUSB partitions are on
[    5.173168] tegra-xudc-new 700d0000.xudc: entering ELPG done
[    5.173207] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS 'floor cooling device' registered
[    5.175702] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS 'cap cooling device' registered
[    5.176169] tegra_dfll_action dfll-cdev-cap: Tegra DFLL 'cap cooling device' registered
[    5.176910] tegra_dfll_action dfll-cdev-floor: Tegra DFLL 'floor cooling device' registered
[    5.181930] xhci-tegra 70090000.xusb: UTMI port 0 has OTG_CAP
[    5.181932] xhci-tegra 70090000.xusb: No USB3 port has OTG_CAP
[    5.185718] xhci-tegra 70090000.xusb: Direct firmware load for tegra21x_xusb_firmware failed with error -2
[    5.185720] xhci-tegra 70090000.xusb: Falling back to user helper
[    5.187302] input: gpio-keys as /devices/gpio-keys/input/input2
[    5.221147] tegra_rtc 7000e000.rtc: setting system clock to 2017-08-16 10:05:26 UTC (1502877926)
[    5.221993] vi 54080000.vi: vi_probe: ++
[    5.227368] vi 54080000.vi: initialized
[    5.229582] vi 54080000.vi: all channel register failed
[    5.230449] Disable partitions left on by BL
[    5.230451]   disb
[    5.244296] DRAM derating cdev registered.
[    5.245169] vdd-cpu-fixed: disabling
[    5.245178] vdd-cam-hv: disabling
[    5.253049] avdd-ts-hv: disabling
[    5.265774] vdd-ts: disabling
[    5.276199] max77620-gpio7: disabling
[    5.295935] lcd-bl-en: disabling
[    5.295940] en-vdd-cam: disabling
[    5.295943] aux-3v3: disabling
[    5.295945] snsr_pm: disabling
[    5.295946] vdd-disp-3v0: disabling
[    5.295949] vdd-fan: disabling
[    5.295950] usb-vbus1: disabling
[    5.295952] en-vdd-ts-1v8: disabling
[    5.295954] en-vdd-ts-hv-3v3: disabling
[    5.295956] en-vdd-disp-3v3: disabling
[    5.305669] en-mdm-pwr-3v7: disabling
[    5.305671] en-vdd-disp-1v8: disabling
[    5.315090] en-vdd-cam-hv-2v8: disabling
[    5.315092] rtl-5v0: disabling
[    5.315093] en-usb-vbus2: disabling
[    5.315095] en-vdd-cam-1v2: disabling
[    5.315097] en-vdd-vcm-2v8: disabling
[    5.356096] ALSA device list:
[    5.356098]   #0: tegra-hda at 0x70038000 irq 348
[    5.356100]   #1: tegra-snd-t210ref-mobile-rt565x
[    5.494746] ata1: SATA link down (SStatus 0 SControl 300)
[    5.598695] tegra-pcie 1003000.pcie-controller: link 0 down, retrying
[    5.841275] mmc1 tuning done saved tap delay=44
[    5.841276] mmc1: hw tuning done ...
[    5.841280] mmc1: tuning_window[0]: 0xf9ffffff
[    5.841283] mmc1: tuning_window[1]: 0x7fffffff
[    5.841286] mmc1: tuning_window[2]: 0xfffffffe
[    5.841289] mmc1: tuning_window[3]: 0x7fffffcf
[    5.841293] mmc1: tuning_window[4]: 0x0
[    5.841296] mmc1: tuning_window[5]: 0x0
[    5.841299] mmc1: tuning_window[6]: 0x0
[    5.841302] mmc1: tuning_window[7]: 0x0
[    5.841304] sdhci: Tap value: 44 | Trim value: 8
[    5.841306] sdhci: SDMMC_VENDOR_INTR_STATUS[0x108]: 0x40000
[    6.016915] tegra-pcie 1003000.pcie-controller: link 0 down, retrying
[    6.031509] tegradc tegradc.1: hdmi: plugged
[    6.035671] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[    6.035704] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[    6.056399] EXT4-fs (mmcblk0p1): couldn't mount as ext3 due to feature incompatibilities
[    6.067932] EXT4-fs (mmcblk0p1): couldn't mount as ext2 due to feature incompatibilities
[    6.142113] EXT4-fs (mmcblk0p1): 8 orphan inodes deleted
[    6.149867] EXT4-fs (mmcblk0p1): recovery complete
[    6.163913] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[    6.174399] VFS: Mounted root (ext4 filesystem) on device 179:1.
[    6.185859] devtmpfs: mounted
[    6.191606] Freeing unused kernel memory: 1208K (ffffffc001175000 - ffffffc0012a3000)
[    6.202047] Freeing alternatives memory: 76K (ffffffc0012a3000 - ffffffc0012b6000)
[    6.286729] random: systemd: uninitialized urandom read (16 bytes read, 86 bits of entropy available)
[    6.303715] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[    6.324936] systemd[1]: Detected architecture arm64.
[    6.344489] systemd[1]: Set hostname to <tegra-ubuntu>.
[    6.361122] random: systemd: uninitialized urandom read (16 bytes read, 88 bits of entropy available)
[    6.374060] random: systemd: uninitialized urandom read (16 bytes read, 88 bits of entropy available)
[    6.386967] random: systemd: uninitialized urandom read (16 bytes read, 88 bits of entropy available)
[    6.407756] random: systemd-cryptse: uninitialized urandom read (16 bytes read, 88 bits of entropy available)
[    6.425375] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 90 bits of entropy available)
[    6.438478] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 91 bits of entropy available)
[    6.451317] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 91 bits of entropy available)
[    6.464043] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 91 bits of entropy available)
[    6.476848] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 91 bits of entropy available)
[    6.493282] tegra-pcie 1003000.pcie-controller: link 0 down, retrying
[    6.504575] tegra-pcie 1003000.pcie-controller: link 0 down, ignoring
[    6.639336] systemd[1]: Listening on udev Control Socket.
[    6.650590] systemd[1]: Reached target Remote File Systems (Pre).
[    6.662360] systemd[1]: Listening on Journal Socket.
[    6.672876] systemd[1]: Reached target User and Group Name Lookups.
[    6.684696] systemd[1]: Reached target Swap.
[    6.694509] systemd[1]: Listening on Syslog Socket.
[    6.704929] systemd[1]: Reached target Remote File Systems.
[    6.716052] systemd[1]: Created slice User and Session Slice.
[    6.727386] systemd[1]: Created slice System Slice.
[    6.737886] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    6.749841] systemd[1]: Created slice system-getty.slice.
[    6.765613] systemd[1]: Starting Load Kernel Modules...
[    6.778852] systemd[1]: Reached target Slices.
[    6.789875] systemd[1]: Started Braille Device Support.
[    6.802746] systemd[1]: Mounting Debug File System...
[    6.813931] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    6.826995] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[    6.839787] systemd[1]: Listening on Journal Audit Socket.
[    6.852242] systemd[1]: Starting Remount Root and Kernel File Systems...
[    6.866161] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[    6.882299] systemd[1]: Listening on Journal Socket (/dev/log).
[    6.895543] systemd[1]: Starting Journal Service...
[    6.907478] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    6.921963] systemd[1]: Listening on udev Kernel Socket.
[    6.929278] tegra-pcie 1003000.pcie-controller: link 1 down, retrying
[    6.943759] systemd[1]: Listening on LVM2 poll daemon socket.
[    6.956564] systemd[1]: Reached target Encrypted Volumes.
[    6.969110] systemd[1]: Listening on LVM2 metadata daemon socket.
[    6.983118] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[    7.002896] systemd[1]: Mounted Debug File System.
[    7.015415] systemd[1]: Started Journal Service.
[    7.138094] systemd-journald[217]: Received request to flush runtime journal from PID 1
[    7.348000] xhci-tegra 70090000.xusb: cannot find firmware....retry after 1 second
[    7.371202] tegra-pcie 1003000.pcie-controller: link 1 down, retrying
[    7.424080] random: nonblocking pool is initialized
[    7.525467] dhd_module_init in
[    7.536423] found wifi platform device bcmdhd_wlan
[    7.558446] Power-up adapter 'DHD generic adapter'
[    7.579584] wifi_platform_set_power = 1
[    7.791274] wifi_platform_bus_enumerate device present 1
[    7.805379] tegra-pcie 1003000.pcie-controller: link 1 down, retrying
[    7.807276] tegra-pcie 1003000.pcie-controller: link 1 down, ignoring
[    7.807298] tegra-pcie 1003000.pcie-controller: PCIE: no end points detected
[    7.808783] tegra-pcie 1003000.pcie-controller: PCIE: Disable power rails
[    7.819392] wifi_platform_bus_enumerate device present 0
[    7.861673] F1 signature read @0x18000000=0x17214354
[    7.879788] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[    7.890807] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[    7.903396] wifi_platform_prealloc: failed to alloc static mem section 7
[    7.903403] wifi_platform_get_mac_addr
[    7.904524] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[    7.935392] wl_create_event_handler(): thread:wl_event_handler:19f started
[    7.935619] CFG80211-ERROR) wl_event_handler : tsk Enter, tsk = 0xffffffc0f1881a70
[    7.935637] dhd_attach(): thread:dhd_watchdog_thread:1a0 started
[    7.935671] dhd_attach(): thread:dhd_dpc:1a1 started
[    7.935721] dhd_attach(): thread:dhd_rxf:1a2 started
[    7.935728] dhd_deferred_work_init: work queue initialized
[    7.935933] Dongle Host Driver, version 1.201.82 (r)
               Compiled in drivers/net/wireless/bcmdhd on Jul 20 2017 at 00:39:01
[    7.936266] tegra_sysfs_register
[    7.936300] Register interface [wlan0]  MAC: 00:04:4b:79:46:51
[    7.936303] dhd_prot_ioctl : bus is down. we have nothing to do
[    7.936384] sdhci-tegra sdhci-tegra.1: Tuning already done, restoring the best tap value : 44
[    7.937425] wifi_platform_set_power = 0
[    8.362338] xhci-tegra 70090000.xusb: Firmware timestamp: 2016-11-24 02:31:08 UTC, Version: 50.18 release
[    8.405757] xhci-tegra 70090000.xusb: xHCI Host Controller
[    8.421763] xhci-tegra 70090000.xusb: new USB bus registered, assigned bus number 1
[    8.438404] xhci-tegra 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00010810
[    8.438435] xhci-tegra 70090000.xusb: irq 319, io mem 0x70090000
[    8.442161] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    8.442165] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    8.442168] usb usb1: Product: xHCI Host Controller
[    8.442171] usb usb1: Manufacturer: Linux 4.4.38-tegra xhci-hcd
[    8.442173] usb usb1: SerialNumber: 70090000.xusb
[    8.453278] hub 1-0:1.0: USB hub found
[    8.453308] hub 1-0:1.0: 5 ports detected
[    8.479353] xhci-tegra 70090000.xusb: xHCI Host Controller
[    8.479362] xhci-tegra 70090000.xusb: new USB bus registered, assigned bus number 2
[    8.479535] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[    8.479538] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    8.479540] usb usb2: Product: xHCI Host Controller
[    8.479543] usb usb2: Manufacturer: Linux 4.4.38-tegra xhci-hcd
[    8.479544] usb usb2: SerialNumber: 70090000.xusb
[    8.479888] hub 2-0:1.0: USB hub found
[    8.479915] hub 2-0:1.0: 4 ports detected
[    8.792135] usb 2-1: new SuperSpeed USB device number 2 using xhci-tegra
[    8.820539] usb 2-1: New USB device found, idVendor=0955, idProduct=09ff
[    8.821728] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[    8.821829]
[    8.821831] wl_android_wifi_on in
[    8.821833] wifi_platform_set_power = 1
[    8.877490] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[    8.887538] usb 2-1: Product: USB 10/100/1000 LAN
[    8.895111] usb 2-1: Manufacturer: Nvidia
[    8.901943] usb 2-1: SerialNumber: 000001000000
[    8.910539] xhci-tegra 70090000.xusb: tegra_xhci_mbox_work mailbox command 6
[    8.924192] xhci-tegra 70090000.xusb: tegra_xhci_mbox_work mailbox command 6
[    8.934471] xhci-tegra 70090000.xusb: tegra_xhci_mbox_work mailbox command 6
[    9.036543] usb 2-1: reset SuperSpeed USB device number 2 using xhci-tegra
[    9.094144] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[    9.187548] sdhci-tegra sdhci-tegra.1: Tuning already done, restoring the best tap value : 44
[    9.196685] F1 signature read @0x18000000=0x17214354
[    9.205732] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[    9.212819] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[    9.280388] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[    9.321892] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[    9.323097] wifi_platform_get_mac_addr
[    9.324494] Firmware up: op_mode=0x0005, MAC=00:04:4b:79:46:51
[    9.329751] dhd_preinit_ioctls pspretend_threshold for HostAPD failed  -23
[    9.333942] Firmware version = wl0: Sep 14 2016 11:38:27 version 7.35.221.18 (r657725) FWID 01-9001dfb5
[    9.336125] dhd_interworking_enable: failed to set WNM info, ret=-23
[    9.336294] tegra_sysfs_on
[    9.385539] r8152 2-1:1.0 eth0: v2.03.3 (2015/01/29)
[    9.385542] r8152 2-1:1.0 eth0: This product is covered by one or more of the following patents:
               		US6,570,884, US6,115,776, and US6,327,625.
[    9.492945] tegradc tegradc.1: nominal-pclk:241699200 parent:241696875 div:1.0 pclk:241696875 239282208~263452128
[    9.493889] tegradc tegradc.1: hdmi: pclk:241699K, set prod-setting:prod_c_hdmi_150m_300m
[    9.646986] CFGP2P-ERROR) wl_cfgp2p_add_p2p_disc_if : P2P interface registered
[    9.665305] WLC_E_IF: NO_IF set, event Ignored
[    9.951751] cfg80211: World regulatory domain updated:
[    9.957009] cfg80211:  DFS Master region: unset
[    9.961519] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[    9.971276] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[    9.979360] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[    9.987370] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[    9.995420] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[   10.005081] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[   10.014698] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[   10.022979] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[   10.031045] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[   10.503494] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   10.583479] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   12.464550] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[   12.504043] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[   12.532825] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[   12.543712] tegradc tegradc.1: nominal-pclk:241699200 parent:241696875 div:1.0 pclk:241696875 239282208~263452128
[   12.545055] tegradc tegradc.1: hdmi: pclk:241699K, set prod-setting:prod_c_hdmi_150m_300m
[   12.563536] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[   12.565503] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[   12.568149] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[   12.590414] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[   12.592679] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[   12.604030] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[   12.638003] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[   22.642674] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   26.265217] nf_conntrack: automatic helper assignment is deprecated and it will be removed soon. Use the iptables CT target to attach helpers instead.
[   67.319830] extcon-gpio-states extcon:extcon@1: Cable state 2
[   67.435508] extcon-gpio-states extcon:extcon@1: Cable state 2
[   67.551268] usb 1-1: new high-speed USB device number 2 using xhci-tegra
[   67.576704] usb 1-1: feature bit otg_vbus_off set
[   67.581559] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101
[   67.589148] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[   67.597368] usb 1-1: Product: USB 2.0 Hub
[   67.603565] hub 1-1:1.0: USB hub found
[   67.607479] hub 1-1:1.0: 4 ports detected
[   67.899211] usb 1-1.1: new full-speed USB device number 3 using xhci-tegra
[   67.933077] usb 1-1.1: New USB device found, idVendor=046d, idProduct=c52f
[   67.940269] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   67.949146] usb 1-1.1: Product: USB Receiver
[   67.954068] usb 1-1.1: Manufacturer: Logitech
[   67.964554] input: Logitech USB Receiver as /devices/70090000.xusb/usb1/1-1/1-1.1/1-1.1:1.0/0003:046D:C52F.0001/input/input3
[   67.976381] hid-generic 0003:046D:C52F.0001: input,hidraw0: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-70090000.xusb-1.1/input0
[   67.992260] input: Logitech USB Receiver as /devices/70090000.xusb/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C52F.0002/input/input4
[   68.076112] hid-generic 0003:046D:C52F.0002: input,hiddev0,hidraw1: USB HID v1.11 Device [Logitech USB Receiver] on usb-70090000.xusb-1.1/input1
[   68.179304] usb 1-1.3: new full-speed USB device number 4 using xhci-tegra
[   68.213624] usb 1-1.3: New USB device found, idVendor=248a, idProduct=8367
[   68.220898] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   68.229466] usb 1-1.3: Product: Wireless Receiver
[   68.234659] usb 1-1.3: Manufacturer: Telink
[   68.240847] usb 1-1.3: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[   68.256876] input: Telink Wireless Receiver as /devices/70090000.xusb/usb1/1-1/1-1.3/1-1.3:1.0/0003:248A:8367.0003/input/input5
[   68.330538] hid-generic 0003:248A:8367.0003: input,hidraw2: USB HID v1.11 Mouse [Telink Wireless Receiver] on usb-70090000.xusb-1.3/input0
[   68.356444] input: Telink Wireless Receiver as /devices/70090000.xusb/usb1/1-1/1-1.3/1-1.3:1.1/0003:248A:8367.0004/input/input6
[   68.440136] hid-generic 0003:248A:8367.0004: input,hidraw3: USB HID v1.11 Keyboard [Telink Wireless Receiver] on usb-70090000.xusb-1.3/input1
could you please try following this topic to replace cboot.bin,
[url]https://devtalk.nvidia.com/default/topic/1019986/jetson-tx1/getting-errors-in-using-onboard-camera-jetpack-3-1-/post/5203796/#5203796[/url]
Ok I’ll try it, and I have question. Do I have to do it for emmc only if I have the main os on SD card with a lot of compiled software? Do I need to flash the ad card as well?
And why you didn’t include this cboot.bin in your main L4T release if you know that you provide such hardware ov5693, but you leave it unfunctional ?
also if I have a lot of stuff compiled and installed in system on SD card can I put all it contents from
to the
64_TX1/Linux_for_Tegra_64_tx1/rootfs
and instead of flashing emmc can I flash sd card directly with this ? :
sudo ./flash.sh -r -k EBT jetson-tx1 mmcblk1p1
also what is jetson-tx1 ? is it the name of the module of kernel? If I have new module name can I change this
jetson-tx1
to my module name?
after reflashing with new cboot.bin here is error log when I run
gst-launch-1.0 nvcamerasrc fpsRange="30.0 30.0" ! 'video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)I420, framerate=(fraction)30/1' ! nvtee ! nvvidconv flip-method=2 ! 'video/x-raw(memory:NVMM), format=(string)I420' ! nvoverlaysink -e
Setting pipeline to PAUSED ...
ERROR: Pipeline doesn't want to pause.
Setting pipeline to NULL ...
Freeing pipeline ...
ok now the camera is working with this command:
gst-launch-1.0 nvcamerasrc fpsRange="30.0 30.0" ! 'video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)I420, framerate=(fraction)30/1' ! nvtee ! nvvidconv flip-method=0 ! 'video/x-raw(memory:NVMM), format=(string)I420' ! nvoverlaysink -e
cboot.bin reflashing helped a lot and I still have all data on SD card, so I just needed to connect the board to host machine with micro Usb cable and put the board to recovery mode
