Sorry for the delay to reply your response.
This is the dmesg when i plugged IMX219-160IR camera in jetson nano
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.201-tegra (buildbrain@mobile-u64-5294-d8000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Fri Feb 19 08:40:32 PST 2021
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options '')
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] On node 0 totalpages: 1039872
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519168 pages, LIFO batch:31
[ 0.000000] Normal zone: 8136 pages used for memmap
[ 0.000000] Normal zone: 520704 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 24 pages/cpu s57560 r8192 d32552 u98304
[ 0.000000] pcpu-alloc: s57560 r8192 d32552 u98304 alloc=24*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1023544
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 gpt earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29356(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3568628K/4159488K available (15294K kernel code, 2942K rwdata, 6664K rodata, 8576K init, 609K bss, 115724K reserved, 475136K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f70000 ( 15296 KB)
[ 0.000000] .rodata : 0xffffff8008f70000 - 0xffffff8009600000 ( 6720 KB)
[ 0.000000] .init : 0xffffff8009600000 - 0xffffff8009e60000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e60000 - 0xffffff800a13f808 ( 2943 KB)
[ 0.000000] .bss : 0xffffff800a13f808 - 0xffffff800a1d7cbc ( 610 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000005] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.001687] Console: colour dummy device 80x25
[ 0.001699] console [tty0] enabled
[ 0.001705] bootconsole [uart8250] disabled
[ 0.001723] kmemleak: Kernel memory leak detector disabled
[ 0.001740] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
[ 0.001754] pid_max: default: 32768 minimum: 301
[ 0.002212] Security Framework initialized
[ 0.002429] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.002438] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.003560] ftrace: allocating 47208 entries in 185 pages
[ 0.172661] sched-energy: CPU device node has no sched-energy-costs
[ 0.172694] ASID allocator initialised with 65536 entries
[ 0.211901] tegra-id: chipid=22117.
[ 0.211913] tegra-id: opt_subrevision=0.
[ 0.211932] Tegra Speedo/IDDQ fuse revision 4
[ 0.211936] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.211941] Tegra: CPU Process ID 0, SoC Process ID 0, GPU Process ID 0
[ 0.211946] Tegra: CPU Speedo Value 1952, SoC Speedo Value 1854, GPU Speedo Value 1943
[ 0.211950] Tegra: CPU IDDQ Value 1196, SoC IDDQ Value 1416, GPU IDDQ Value 1645
[ 0.211969] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 0
[ 0.211985] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
[ 0.211992] DTB Build time: Jul 26 2021 12:16:29
[ 0.261060] CPU1: Booted secondary processor [411fd071]
[ 0.292971] CPU2: Booted secondary processor [411fd071]
[ 0.324927] CPU3: Booted secondary processor [411fd071]
[ 0.325021] Brought up 4 CPUs
[ 0.325027] SMP: Total of 4 processors activated.
[ 0.325035] CPU features: detected feature: 32-bit EL0 Support
[ 0.325296] CPU: All CPU(s) started at EL2
[ 0.325314] alternatives: patching kernel code
[ 0.333401] devtmpfs: initialized
[ 0.371296] Initilizing CustomIPI irq domain
[ 0.371669] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.371691] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.382262] pinctrl core: initialized pinctrl subsystem
[ 0.382860] OS set in device tree is not L4T.
[ 0.383262] regulator-dummy: no parameters
[ 0.383520] Initializing plugin-manager
[ 0.383678] Plugin module not found
[ 0.383863] node /plugin-manager/fragement@0 match with board >=3448-0000-100
[ 0.384362] node /plugin-manager/fragment@1 match with board >=3448-0000-101
[ 0.385380] node /plugin-manager/fragement@7 match with odm-data enable-pmic-wdt
[ 0.385599] node /plugin-manager/fragement@8 match with odm-data enable-pmic-wdt
[ 0.386223] node /plugin-manager/fragement@13 match with board >=3448-0000-300
[ 0.389684] NET: Registered protocol family 16
[ 0.391045] pstore: using zlib compression
[ 0.391088] console [pstore-1] enabled
[ 0.391092] pstore: Registered ramoops as persistent store backend
[ 0.391098] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.405077] cpuidle: using governor menu
[ 0.409207] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.410865] vdso: 2 pages (1 code @ ffffff8008f77000, 1 data @ ffffff8009e64000)
[ 0.410888] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.413517] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.415804] Serial: AMBA PL011 UART driver
[ 0.416311] tegra_powergate_init: DONE
[ 0.416328] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
[ 0.416335] DTB Build time: Jul 26 2021 12:16:29
[ 0.418164] Tegra reboot handler registered.
[ 0.422598] iommu: Adding device tegra-carveouts to group 0
[ 0.422735] platform tegra-carveouts: domain=ffffffc0f9bda3d8 allocates as[0]=ffffffc0f943c0a8
[ 0.423092] iommu: Adding device smmu_test to group 1
[ 0.423139] platform smmu_test: domain=ffffffc0f9bda618 allocates as[0]=ffffffc0f943c110
[ 0.423945] mc: mapped MMIO address: 0xffffff800802e000 -> 0x70019000
[ 0.423998] mc: mapped MMIO address: 0xffffff8008065000 -> 0x7001c000
[ 0.424053] mc: mapped MMIO address: 0xffffff8008079000 -> 0x7001d000
[ 0.424062] nv-tegra-mc 70019000.mc: No mssnvlink node
[ 0.424083] mc-err: mcerr ops are set to t21x
[ 0.434651] iommu: Adding device 70090000.xusb to group 2
[ 0.434927] iommu: Adding device 70006000.serial to group 3
[ 0.435005] platform 70006000.serial: domain=ffffffc0f94bd6d8 allocates as[0]=ffffffc0f943c178
[ 0.435426] iommu: Adding device 70006040.serial to group 4
[ 0.435691] iommu: Adding device 70006200.serial to group 5
[ 0.435917] iommu: Adding device sound to group 6
[ 0.435969] platform sound: domain=ffffffc0f94bdc18 allocates as[0]=ffffffc0f943c1e0
[ 0.436518] iommu: Adding device 7000d400.spi to group 7
[ 0.436778] iommu: Adding device 7000d600.spi to group 8
[ 0.437075] iommu: Adding device 70410000.spi to group 9
[ 0.437384] iommu: Adding device 50000000.host1x to group 10
[ 0.437655] iommu: Adding device 54080000.vi to group 11
[ 0.438038] iommu: Adding device 54600000.isp to group 12
[ 0.438295] iommu: Adding device 54680000.isp to group 13
[ 0.438600] iommu: Adding device tegradc.0 to group 14
[ 0.438652] platform tegradc.0: domain=ffffffc0f94cbb58 allocates as[0]=ffffffc0f943c248
[ 0.439165] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[ 0.439485] iommu: Adding device tegradc.1 to group 15
[ 0.439530] platform tegradc.1: domain=ffffffc0f94cbd98 allocates as[0]=ffffffc0f943c2b0
[ 0.440036] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[ 0.440282] iommu: Adding device 54340000.vic to group 16
[ 0.440491] iommu: Adding device 544c0000.nvenc to group 17
[ 0.440684] iommu: Adding device 54500000.tsec to group 18
[ 0.440882] iommu: Adding device 54100000.tsecb to group 19
[ 0.441220] iommu: Adding device 54480000.nvdec to group 20
[ 0.441449] iommu: Adding device 54380000.nvjpg to group 21
[ 0.442511] iommu: Adding device 546c0000.i2c to group 22
[ 0.442840] iommu: Adding device 57000000.gpu to group 23
[ 0.442894] platform 57000000.gpu: domain=ffffffc0f94d5d98 allocates as[0]=ffffffc0f943c318
[ 0.442930] platform 57000000.gpu: domain=ffffffc0f94d5d98 allocates as[1]=ffffffc0f943c380
[ 0.442968] platform 57000000.gpu: domain=ffffffc0f94d5d98 allocates as[2]=ffffffc0f943c3e8
[ 0.443005] platform 57000000.gpu: domain=ffffffc0f94d5d98 allocates as[3]=ffffffc0f943c450
[ 0.443874] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.443886] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.443899] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.443904] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.443908] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.497154] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.497162] tegra-pmc: Clear bootloader IO dpd settings
[ 0.497180] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.497246] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.497537] iommu: Adding device 70012000.se to group 24
[ 0.498300] iommu: Adding device 7000c000.i2c to group 25
[ 0.498551] iommu: Adding device 7000c400.i2c to group 26
[ 0.498811] iommu: Adding device 7000c500.i2c to group 27
[ 0.499061] iommu: Adding device 7000c700.i2c to group 28
[ 0.499349] iommu: Adding device 7000d000.i2c to group 29
[ 0.499598] iommu: Adding device 7000d100.i2c to group 30
[ 0.499884] iommu: Adding device sdhci-tegra.0 to group 31
[ 0.499937] platform sdhci-tegra.0: domain=ffffffc0f958bf18 allocates as[0]=ffffffc0f943c4b8
[ 0.500754] iommu: Adding device 700d0000.xudc to group 32
[ 0.503954] vdd-ac-bat: 5000 mV
[ 0.504302] vdd-5v0-sys: 5000 mV
[ 0.505273] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.505346] vdd-5v0-hdmi: 5000 mV
[ 0.505769] vdd-1v8-sys: 1800 mV
[ 0.506142] vdd-fan: supplied by vdd-5v0-sys
[ 0.506180] vdd-fan: 5000 mV
[ 0.506555] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.506609] vdd-usb-vbus: 5000 mV
[ 0.507120] vdd-usb-vbus2: 5000 mV
[ 0.538259] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.540711] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[ 0.542958] GPIO line 6 (system-suspend-gpio) hogged as output/high
[ 0.542985] GPIO line 151 (camera-control-output-low) hogged as output/low
[ 0.543005] GPIO line 152 (camera-control-output-low) hogged as output/low
[ 0.543405] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[ 0.551955] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.552300] SCSI subsystem initialized
[ 0.552534] libata version 3.00 loaded.
[ 0.552816] usbcore: registered new interface driver usbfs
[ 0.552864] usbcore: registered new interface driver hub
[ 0.552937] usbcore: registered new device driver usb
[ 0.556969] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.561226] vdd-core: 600 <--> 1162 mV at 1125 mV
[ 0.562050] random: fast init done
[ 0.562263] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.565106] vdd-ddr-1v1: 1150 mV
[ 0.569071] vdd-pre-reg-1v35: 1350 mV
[ 0.573073] vdd-1v8: 1800 mV
[ 0.577071] avdd-sys-1v2: 1200 mV
[ 0.581072] vdd-pex-1v0: 1050 mV
[ 0.581742] vddio-sdmmc-ap: 1800 <--> 3300 mV at 3300 mV
[ 0.582277] max77620-ldo3: at 3100 mV
[ 0.585075] vdd-rtc: 850 <--> 1100 mV at 1000 mV
[ 0.585616] max77620-ldo5: at 3100 mV
[ 0.589074] vddio-sdmmc3-ap: 1800 <--> 3300 mV at 2800 mV
[ 0.593074] avdd-1v05-pll: 1050 mV
[ 0.597072] avdd-io-hdmi-dp: 1050 mV
[ 0.599747] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ 0.600077] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[ 0.600373] max77620 4-003c: max77620 probe successful
[ 0.603016] media: Linux media interface: v0.10
[ 0.603062] Linux video capture interface: v2.00
[ 0.603936] pps_core: LinuxPPS API ver. 1 registered
[ 0.603942] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.603968] PTP clock support registered
[ 0.607186] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[ 0.608007] Advanced Linux Sound Architecture Driver Initialized.
[ 0.608659] Bluetooth: Core ver 2.22
[ 0.608711] NET: Registered protocol family 31
[ 0.608715] Bluetooth: HCI device and connection manager initialized
[ 0.608729] Bluetooth: HCI socket layer initialized
[ 0.608738] Bluetooth: L2CAP socket layer initialized
[ 0.608762] Bluetooth: SCO socket layer initialized
[ 0.610542] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.610559] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.610607] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.610622] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.613940] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.615090] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.615155] vdd-3v3-sys: 3300 mV
[ 0.615425] vdd-1v8-sys: supplied by vdd-3v3-sys
[ 0.617068] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.617550] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.617592] vdd-3v3-sd: 3300 mV
[ 0.618660] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ 0.618704] avdd-io-edp-1v05: 1050 mV
[ 0.619145] vdd-usb-hub-en: supplied by vdd-1v8-sys
[ 0.619182] vdd-usb-hub-en: 5000 mV
[ 0.620577] camchar: rtcpu character device driver loaded
[ 0.621423] extcon-gpio-states extcon:extcon@1: Cable state:1, cable id:1
[ 0.622925] clocksource: Switched to clocksource arch_sys_counter
[ 0.663211] VFS: Disk quotas dquot_6.6.0
[ 0.663334] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.663813] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.664220] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[ 0.664240] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[ 0.664437] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ 0.664442] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.664454] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.664487] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.664494] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.664509] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.664518] nvmap_page_pool_init: Total RAM pages: 1010941
[ 0.664523] nvmap_page_pool_init: nvmap page pool size: 126367 pages (493 MB)
[ 0.664611] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.665088] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 0.666019] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600KiB)
[ 0.674420] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.674849] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.675243] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.675503] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.675692] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.675951] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.675956] pre_t19x_iso_plat_init(): max_iso_bw=11520000KB
[ 0.676384] NET: Registered protocol family 2
[ 0.677339] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.677550] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.678038] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.678181] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.678261] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.678672] NET: Registered protocol family 1
[ 0.679475] RPC: Registered named UNIX socket transport module.
[ 0.679483] RPC: Registered udp transport module.
[ 0.679486] RPC: Registered tcp transport module.
[ 0.679490] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.679505] PCI: CLS 0 bytes, default 64
[ 0.679732] Trying to unpack rootfs image as initramfs...
[ 0.982621] Freeing initrd memory: 6992K
[ 0.992436] host1x 50000000.host1x: initialized
[ 0.994237] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.997503] audit: initializing netlink subsys (disabled)
[ 0.997569] audit: type=2000 audit(0.847:1): initialized
[ 0.998316] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 1.008021] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.009467] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.010236] 9p: Installing v9fs 9p2000 file system support
[ 1.013456] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.013589] io scheduler noop registered
[ 1.013914] io scheduler cfq registered (default)
[ 1.016604] gic 702f9000.agic: GIC IRQ controller registered
[ 1.019405] iommu: Adding device 702ef000.adsp to group 33
[ 1.028145] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[ 1.028318] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ 1.028910] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x71c7c11
[ 1.028919] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 1.030491] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 1.030594] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 1.030680] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 1.030868] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 1.030984] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 1.031081] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 1.031164] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 1.031258] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 1.031337] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 1.031429] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 1.037814] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 1.039560] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 1.041441] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[ 1.042721] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[ 1.043079] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[ 1.044292] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.044511] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[ 1.044735] Adding domain tsec-pd to PM domain host1x-pd
[ 1.046801] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[ 1.047779] tsec 54500000.tsec: initialized
[ 1.049330] tsec 54100000.tsecb: initialized
[ 1.050057] Adding domain nvdec-pd to PM domain host1x-pd
[ 1.053539] nvdec 54480000.nvdec: initialized
[ 1.054597] Adding domain vic03-pd to PM domain host1x-pd
[ 1.054781] Adding domain msenc-pd to PM domain host1x-pd
[ 1.054985] Adding domain nvjpg-pd to PM domain host1x-pd
[ 1.059008] falcon 54340000.vic: initialized
[ 1.060248] falcon 544c0000.nvenc: initialized
[ 1.061555] falcon 54380000.nvjpg: initialized
[ 1.066039] tegra_cec 70015000.tegra_cec: dt=1 start=0x70015000 end=0x70015FFF irq=97
[ 1.066084] tegra_cec 70015000.tegra_cec: Enable clock result: 0.
[ 1.066119] tegra_cec 70015000.tegra_cec: tegra_cec_init started
[ 1.066284] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 1.066378] display board info: id 0x0, fab 0x0
[ 1.066415] tegra_cec 70015000.tegra_cec: cec_add_sysfs ret=0
[ 1.066422] tegra_cec 70015000.tegra_cec: probed
[ 1.066449] generic_infoframe_type: 0x87
[ 1.066592] tegradc tegradc.0: DT parsed successfully
[ 1.066639] tegradc tegradc.0: Display dc.ffffff800ab80000 registered with id=0
[ 1.070473] tegradc tegradc.0: probed
[ 1.071207] Console: switching to colour frame buffer device 80x30
[ 1.071244] tegradc tegradc.0: fb registered
[ 1.072391] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 1.072470] tegradc tegradc.1: No lt-data, using default setting
[ 1.072496] tegradc tegradc.1: No hpd-gpio in DT
[ 1.072528] tegradc tegradc.1: DT parsed successfully
[ 1.072572] tegradc tegradc.1: Display dc.ffffff800ad00000 registered with id=1
[ 1.074680] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 1.075098] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.580936] Host read timeout at address 545c00c4
[ 1.582602] tegradc tegradc.1: probed
[ 1.583038] tegradc tegradc.1: fb registered
[ 1.583236] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 22 channels
[ 1.584032] tegra-fuse-burn 7000f800.efuse:efuse-burn: shutdown limit check disabled
[ 1.584038] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 1.584333] kfuse 7000fc00.kfuse: initialized
[ 1.585268] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[ 1.586046] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.586535] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 1.586543] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 1.586551] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1.586565] tegradc tegradc.1: blank - powerdown
[ 1.586587] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[ 1.586592] Extcon DP: HPD disabled
[ 1.586596] hpd: hpd_switch 0
[ 1.586601] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.586610] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1.586617] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 1.587174] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 1.587186] vdd-cpu: 708 <--> 1322 mV at 708 mV
[ 1.587576] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 1.588878] vdd-gpu: applied init 1000000uV constraint
[ 1.588885] vdd-gpu: 708 <--> 1323 mV at 997 mV
[ 1.589263] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 1.592825] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.592932] No Device Node present for smmu client: serial8250 !!
[ 1.592943] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.592981] iommu: Adding device serial8250 to group 35
[ 1.595307] console [ttyS0] disabled
[ 1.595375] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 1.605702] console [ttyS0] enabled
[ 1.606698] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 1.607018] serial-tegra 70006200.serial: RX in PIO mode
[ 1.607119] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 1.608088] [drm] Initialized
[ 1.618598] brd: module loaded
[ 1.624130] loop: module loaded
[ 1.624248] tegra_profiler: version: 1.143, samples/io: 48/28
[ 1.624385] tegra_profiler: auth: init
[ 1.625785] THERMAL EST: found 2 subdevs
[ 1.625793] THERMAL EST num_resources: 0
[ 1.625800] [THERMAL EST subdev 0]
[ 1.625807] [THERMAL EST subdev 1]
[ 1.626255] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 1.626259] THERMAL EST: thz register success.
[ 1.626417] THERMAL EST: end of probe, return err: 0
[ 1.627687] sd: No Scsi addr parsed to reserve index
[ 1.627727] hisi_sas: driver version v1.6
[ 1.632805] tegra-qspi 70410000.spi: Prod settings list not found
[ 1.633959] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
[ 1.633970] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (4MiB) .erasesize = 0x00001000 (4KiB) .numeraseregions = 0
[ 1.637181] libphy: Fixed MDIO Bus: probed
[ 1.638041] tun: Universal TUN/TAP device driver, 1.6
[ 1.638047] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.639271] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.639276] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.639377] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.639380] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.639473] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.639477] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.639568] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 1.639571] Copyright(c) 1999 - 2017 Intel Corporation.
[ 1.640750] PPP generic driver version 2.4.2
[ 1.640957] PPP BSD Compression module registered
[ 1.640963] PPP Deflate Compression module registered
[ 1.641005] PPP MPPE Compression module registered
[ 1.641013] NET: Registered protocol family 24
[ 1.641083] usbcore: registered new interface driver r8152
[ 1.641135] usbcore: registered new interface driver asix
[ 1.641181] usbcore: registered new interface driver ax88179_178a
[ 1.641218] usbcore: registered new interface driver cdc_ether
[ 1.641255] usbcore: registered new interface driver net1080
[ 1.641294] usbcore: registered new interface driver cdc_subset
[ 1.641338] usbcore: registered new interface driver zaurus
[ 1.641391] usbcore: registered new interface driver cdc_ncm
[ 1.641555] VFIO - User Level meta-driver version: 0.3
[ 1.642814] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.642836] ehci-pci: EHCI PCI platform driver
[ 1.642880] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.642895] ohci-pci: OHCI PCI platform driver
[ 1.643002] ohci-platform: OHCI generic platform driver
[ 1.645762] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 1.646382] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 1.647630] tegra-xusb 70090000.xusb: extcon 0: ffffffc0f9228c00 id
[ 1.649884] usbcore: registered new interface driver uas
[ 1.649951] usbcore: registered new interface driver usb-storage
[ 1.650077] usbcore: registered new interface driver usbserial
[ 1.650509] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 1.650560] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.650589] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[ 1.651382] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 1.651442] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 1.651655] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.651662] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.651668] usb usb1: Product: xHCI Host Controller
[ 1.651673] usb usb1: Manufacturer: Linux 4.9.201-tegra xhci-hcd
[ 1.651677] usb usb1: SerialNumber: 70090000.xusb
[ 1.652295] hub 1-0:1.0: USB hub found
[ 1.652341] hub 1-0:1.0: 5 ports detected
[ 1.652964] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.652977] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[ 1.653056] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.653172] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.653179] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.653184] usb usb2: Product: xHCI Host Controller
[ 1.653189] usb usb2: Manufacturer: Linux 4.9.201-tegra xhci-hcd
[ 1.653193] usb usb2: SerialNumber: 70090000.xusb
[ 1.653622] hub 2-0:1.0: USB hub found
[ 1.653654] hub 2-0:1.0: 4 ports detected
[ 1.655445] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 1.655455] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 1.658036] tegra-xudc-new 700d0000.xudc: device count: 1
[ 1.659567] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 1.659583] tegra-xudc-new 700d0000.xudc: vbus state: 1
[ 1.659598] tegra-xudc-new 700d0000.xudc: device mode on: 0
[ 1.659624] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 0
[ 1.659652] tegra-xudc-new 700d0000.xudc: active: 0 => 1
[ 1.660381] mousedev: PS/2 mouse device common for all mice
[ 1.660499] usbcore: registered new interface driver xpad
[ 1.745556] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.748004] rtc rtc1: alarm rtc device
[ 1.748023] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 1.748052] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 1.748673] i2c /dev entries driver
[ 1.750628] i2c i2c-6: Added multiplexed i2c bus 7
[ 1.751046] i2c i2c-6: Added multiplexed i2c bus 8
[ 1.751054] i2c-mux-gpio cam_i2cmux: 2 port mux on Tegra I2C adapter adapter
[ 1.751853] imx219 7-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.755090] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 1.755392] usb usb2: usb_suspend_both: status 0
[ 1.775148] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 1.775245] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.783138] imx219 7-0010: board setup failed
[ 1.787602] imx219: probe of 7-0010 failed with error -121
[ 1.788174] imx219 8-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.811464] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 1.811579] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.819204] imx219 8-0010: board setup failed
[ 1.823641] imx219: probe of 8-0010 failed with error -121
[ 1.824988] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 1.827569] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 1.827576] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 1.828050] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.828067] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 1.828077] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 1.828211] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.828224] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 1.828231] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 1.828387] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.828400] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 1.828407] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 1.828581] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 1.829387] tegra_aotag tegra-aotag: Registering sensor 0
[ 1.829444] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.829471] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.829489] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 1.829499] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 1.830426] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.830447] tegra_dfll_action dfll-cdev-cap: Tegra DFLL 'cap cooling device' registered
[ 1.830655] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.830686] tegra_dfll_action dfll-cdev-floor: Tegra DFLL 'floor cooling device' registered
[ 1.831146] parse_throttle_dt_data: Num cap clks = 6
[ 1.831153] parse_throttle_dt_data: clk=cclk_g type=2
[ 1.831168] parse_throttle_dt_data: clk=gpu type=4
[ 1.831197] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 1.831223] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 1.831250] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 1.831253] parse_throttle_dt_data: clk=emc type=3
[ 1.831654] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.831759] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.831919] tegra_throttle_probe: probe successful. #cdevs=4
[ 1.832744] FAN dev name: pwm-fan
[ 1.832826] FAN:gpio request success.
[ 1.832901] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 1.833217] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 1.833405] pwm_fan_driver pwm-fan: fan tach request irq success
[ 1.833420] pwm_fan_driver pwm-fan: tach period: 1000
[ 1.833529] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 1.833535] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 1.833541] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 1.833546] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 1.833551] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 1.833556] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 1.833561] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 1.833566] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 1.833571] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 1.833576] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 1.836424] device-mapper: uevent: version 1.0.3
[ 1.836899] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 1.842228] tegra210-cpufreq cpufreq: probe()...completed
[ 1.843012] sdhci: Secure Digital Host Controller Interface driver
[ 1.843015] sdhci: Copyright(c) Pierre Ossman
[ 1.843017] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.843506] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 1.843860] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 1.843986] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 300
[ 1.846353] tegra-se 70012000.se: tegra_se_probe: complete
[ 1.846906] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.848018] usbcore: registered new interface driver usbhid
[ 1.848020] usbhid: USB HID core driver
[ 1.850187] tegra21x_actmon 6000c800.actmon: in actmon_register()...
[ 1.850350] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 1.852276] nvpmodel: initialized successfully
[ 1.853444] usbcore: registered new interface driver snd-usb-audio
[ 1.853500] No Device Node present for smmu client: snd-soc-dummy !!
[ 1.853505] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.853525] iommu: Adding device snd-soc-dummy to group 36
[ 1.858758] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 1.876925] OPE platform probe
[ 1.877012] OPE platform probe successful
[ 1.877265] OPE platform probe
[ 1.877346] OPE platform probe successful
[ 1.895226] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[ 1.900557] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 1.900688] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 1.900815] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 1.900964] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 1.901091] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 1.901222] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 1.901357] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 1.901485] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 1.901614] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 1.901744] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 1.913357] u32 classifier
[ 1.913360] Actions configured
[ 1.913433] Initializing XFRM netlink socket
[ 1.914144] NET: Registered protocol family 10
[ 1.914832] NET: Registered protocol family 17
[ 1.914843] NET: Registered protocol family 15
[ 1.914953] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.915003] Bluetooth: RFCOMM socket layer initialized
[ 1.915013] Bluetooth: RFCOMM ver 1.11
[ 1.915018] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.915023] Bluetooth: HIDP socket layer initialized
[ 1.915041] 9pnet: Installing 9P2000 support
[ 1.915078] Key type dns_resolver registered
[ 1.915494] Registered cp15_barrier emulation handler
[ 1.915508] Registered setend emulation handler
[ 1.916543] registered taskstats version 1
[ 1.917073] Adding domain ve2-pd to PM domain host1x-pd
[ 1.917329] Adding domain ve-pd to PM domain host1x-pd
[ 1.919397] isp 54600000.isp: initialized
[ 1.920361] isp 54680000.isp: initialized
[ 1.930576] last reset is due to power on reset
[ 1.930580] KERNEL: PMC reset status reg: 0x0
[ 1.930639] BL: PMC reset status reg: 0x0
[ 1.930641] BL: PMIC poweroff Event Recorder: 0x40
[ 1.932121] clk_cbus_recalc_rate: no gbus parent
[ 1.932127] clk_cbus_round_rate: no gbus parent
[ 1.932129] clk_cbus_round_rate: no gbus parent
[ 1.932134] clk_cbus_recalc_rate: no gbus parent
[ 1.932236] clk_cbus_recalc_rate: no gbus parent
[ 1.932239] clk_cbus_round_rate: no gbus parent
[ 1.932241] clk_cbus_round_rate: no gbus parent
[ 1.932245] clk_cbus_recalc_rate: no gbus parent
[ 1.932932] tegra_dvfs: GPU-cap: registered
[ 1.932990] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[ 1.932992] tegra dvfs: vdd-core: nominal 1125mV, offset 600000uV, step 12500uV, scaling enabled
[ 1.932995] tegra dvfs: vdd-gpu: nominal 1098mV, offset 708000uV, step 10000uV, scaling enabled
[ 1.934398] tegra_dvfs: vdd-gpu-vts: registered
[ 1.935135] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS 'floor cooling device' registered
[ 1.935806] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS 'cap cooling device' registered
[ 1.936310] input: gpio-keys as /devices/gpio-keys/input/input1
[ 1.969228] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:00:12 UTC (946688412)
[ 1.970301] vi 54080000.vi: vi_probe: ++
[ 1.982941] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 1.988354] vi 54080000.vi: initialized
[ 1.994639] vi 54080000.vi: subdev nvcsi--2 bound
[ 1.994744] vi 54080000.vi: subdev nvcsi--1 bound
[ 1.996238] Disable partitions left on by BL
[ 1.996242] disb
[ 1.996288] bwmgr: missing cdev-type property
[ 1.996382] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.996390] DRAM derating cdev registered.
[ 1.997241] ALSA device list:
[ 1.997245] #0: tegra-hda at 0x70038000 irq 83
[ 1.997247] #1: tegra-snd-t210ref-mobile-rt565x
[ 1.997321] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.000355] Freeing unused kernel memory: 8576K
[ 2.016797] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[ 2.016802] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.016806] usb 1-2: Product: 4-Port USB 2.1 Hub
[ 2.016810] usb 1-2: Manufacturer: Generic
[ 2.019100] hub 1-2:1.0: USB hub found
[ 2.020074] hub 1-2:1.0: 4 ports detected
[ 2.025058] Root device found: mmcblk0p1
[ 2.067814] tegra_cec 70015000.tegra_cec: Can't find physical addresse.
[ 2.067818] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[ 2.098482] mmc0: Applying tuning correction
[ 2.098497] mmc0: Tap value after applying correction 48
[ 2.098515] mmc0: hw tuning done ...
[ 2.098551] mmc0: new ultra high speed SDR104 SDXC card at address aaaa
[ 2.102994] mmcblk0: mmc0:aaaa SD128 119 GiB
[ 2.107366] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[ 2.131350] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 2.150992] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 2.163904] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[ 2.163911] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.163916] usb 2-1: Product: 4-Port USB 3.1 Hub
[ 2.163919] usb 2-1: Manufacturer: Generic
[ 2.167051] hub 2-1:1.0: USB hub found
[ 2.167836] hub 2-1:1.0: 4 ports detected
[ 2.170990] usb 1-2: usb_suspend_both: status 0
[ 2.171075] usb usb1: usb_suspend_both: status 0
[ 2.230210] Found dev node: /dev/mmcblk0p1
[ 2.271409] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 2.273569] Rootfs mounted over mmcblk0p1
[ 2.298251] Switching from initrd to actual rootfs
[ 2.318946] usb 2-1: usb_suspend_both: status 0
[ 2.319110] usb usb2: usb_suspend_both: status 0
[ 2.402828] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.497975] systemd[1]: System time before build time, advancing clock.
[ 2.522074] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.534209] cgroup: cgroup2: unknown option "nsdelegate"
[ 2.562717] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 2.563533] systemd[1]: Detected architecture arm64.
[ 2.586337] systemd[1]: Set hostname to <miniai-desktop>.
[ 2.708299] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 2.708309] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 2.810667] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.812686] tegra-pcie 1003000.pcie: link 0 down, ignoring
[ 2.871134] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.871350] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 2.871445] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.873417] systemd[1]: Created slice User and Session Slice.
[ 2.873449] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.873471] systemd[1]: Reached target User and Group Name Lookups.
[ 2.874303] systemd[1]: Created slice System Slice.
[ 2.874484] systemd[1]: Listening on udev Kernel Socket.
[ 2.918406] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[ 2.918413] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 2.918417] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 2.918421] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 2.918425] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.918447] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[ 2.918512] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.918685] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.918808] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
[ 2.918850] pci 0000:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 2.918887] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 2.918984] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 2.919125] pci 0000:01:00.0: supports D1 D2
[ 2.919129] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.931056] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 2.931088] pci 0000:00:02.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[ 2.931093] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.931100] pci 0000:01:00.0: BAR 4: assigned [mem 0x13000000-0x13003fff 64bit]
[ 2.931119] pci 0000:01:00.0: BAR 2: assigned [mem 0x13004000-0x13004fff 64bit]
[ 2.931135] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 2.931143] pci 0000:00:02.0: PCI bridge to [bus 01]
[ 2.931147] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 2.931153] pci 0000:00:02.0: bridge window [mem 0x13000000-0x130fffff]
[ 2.931492] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 2.931496] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.931502] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[ 2.931595] aer 0000:00:02.0:pcie002: service driver aer loaded
[ 2.931815] r8168 0000:01:00.0: enabling device (0000 -> 0003)
[ 2.931833] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 2.946438] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[ 2.946516] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 48:b0:2d:5c:15:e4 from device tree
[ 2.948566] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 2.948896] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 2.948913] r8168 Copyright (C) 2017 Realtek NIC software team <nicfae@realtek.com>
This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[ 3.064902] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 3.069251] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.069271] cpu-throttle-alert cooling device registered.
[ 3.069380] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.069394] gpu-throttle-alert cooling device registered.
[ 3.069529] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.069542] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.069554] hot-surface-alert cooling device registered.
[ 3.127461] systemd-journald[1907]: Received request to flush runtime journal from PID 1
[ 3.986987] tegra-xusb 70090000.xusb: entering ELPG
[ 3.988048] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 1, speed 3
[ 3.988248] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 2, speed 0
[ 3.989159] tegra-xusb 70090000.xusb: entering ELPG done
[ 4.165076] random: crng init done
[ 4.168480] random: 7 urandom warning(s) missed due to ratelimiting
[ 4.442566] using random self ethernet address
[ 4.447067] using random host ethernet address
[ 5.666095] Mass Storage Function, version: 2009/09/11
[ 5.666103] LUN: removable file: (no medium)
[ 5.676803] using random self ethernet address
[ 5.686969] using random host ethernet address
[ 5.737905] rndis0: HOST MAC aa:3e:36:ca:bc:ec
[ 5.738072] rndis0: MAC aa:3e:36:ca:bc:ed
[ 5.738658] usb0: HOST MAC aa:3e:36:ca:bc:ee
[ 5.738786] usb0: MAC aa:3e:36:ca:bc:ef
[ 5.738815] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[ 5.744410] l4tbr0: port 1(rndis0) entered blocking state
[ 5.744414] l4tbr0: port 1(rndis0) entered disabled state
[ 5.744855] device rndis0 entered promiscuous mode
[ 5.749863] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 5.754179] l4tbr0: port 2(usb0) entered blocking state
[ 5.754185] l4tbr0: port 2(usb0) entered disabled state
[ 5.754685] device usb0 entered promiscuous mode
[ 5.760849] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 5.841938] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 5.843820] eth0: 0xffffff800ab53000, 48:b0:2d:5c:15:e4, IRQ 407
[ 5.895006] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 6.334753] zram: Added device: zram0
[ 6.335617] zram: Added device: zram1
[ 6.337308] zram: Added device: zram2
[ 6.342855] zram: Added device: zram3
[ 6.388208] zram0: detected capacity change from 0 to 519593984
[ 6.427219] Adding 507412k swap on /dev/zram0. Priority:5 extents:1 across:507412k SS
[ 6.430633] zram1: detected capacity change from 0 to 519593984
[ 6.452002] Adding 507412k swap on /dev/zram1. Priority:5 extents:1 across:507412k SS
[ 6.457604] zram2: detected capacity change from 0 to 519593984
[ 6.471873] Adding 507412k swap on /dev/zram2. Priority:5 extents:1 across:507412k SS
[ 6.478377] zram3: detected capacity change from 0 to 519593984
[ 6.494573] Adding 507412k swap on /dev/zram3. Priority:5 extents:1 across:507412k SS
[ 8.001938] tegradc tegradc.0: blank - powerdown
[ 8.001948] tegradc tegradc.1: blank - powerdown
[ 8.689264] fuse init (API version 7.26)
[ 11.083566] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 11.083577] Bluetooth: BNEP socket layer initialized
[ 33.908311] vdd-fan: disabling
[ 33.908337] vdd-usb-vbus: disabling
[ 33.908353] vdd-usb-vbus2: disabling
[ 33.908413] vddio-sdmmc3-ap: disabling
[ 33.909148] avdd-io-edp-1v05: disabling
[ 33.909176] vdd-usb-hub-en: disabling
[ 48.624764] edid invalid
[ 48.638533] edid invalid
[ 48.679863] edid invalid
[ 48.819265] tegradc tegradc.0: blank - powerdown
[ 48.842267] tegradc tegradc.0: unblank
[ 48.873072] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 48.873168] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 48.874190] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 48.911954] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 48.911957] Extcon AUX1(HDMI) enable
[ 48.912134] extcon-disp-state extcon:disp-state: cable 51 state 1
[ 48.912136] Extcon HDMI: HPD enabled
[ 48.912159] tegradc tegradc.0: hdmi: plugged
[ 48.924258] tegradc tegradc.0: blank - powerdown
[ 48.957818] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 48.957822] Extcon AUX1(HDMI) disable
[ 48.978286] tegradc tegradc.1: blank - powerdown
[ 49.024954] tegradc tegradc.0: blank - powerdown
[ 49.024965] tegradc tegradc.0: unblank
[ 49.061216] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 49.061302] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 49.062391] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 49.099394] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 49.099397] Extcon AUX1(HDMI) enable
[ 49.105409] tegradc tegradc.0: unblank
[ 49.105419] tegradc tegradc.1: blank - powerdown
[ 69.406909] tegra-xusb 70090000.xusb: exiting ELPG
[ 69.407792] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 69.411608] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 69.412232] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 0
[ 69.412417] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 1
[ 69.412667] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 2
[ 69.413720] tegra-xusb 70090000.xusb: exiting ELPG done
[ 69.417830] usb usb2: usb_suspend_both: status 0
[ 69.703485] usb 1-2.3: new full-speed USB device number 3 using tegra-xusb
[ 69.734205] usb 1-2.3: New USB device found, idVendor=04ca, idProduct=009b
[ 69.734256] usb 1-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 69.734293] usb 1-2.3: Product: Wireless Device
[ 69.734328] usb 1-2.3: Manufacturer: Lite-On Technology Corp.
[ 69.743225] input: Lite-On Technology Corp. Wireless Device as /devices/70090000.xusb/usb1/1-2/1-2.3/1-2.3:1.0/0003:04CA:009B.0001/input/input2
[ 69.806426] hid-generic 0003:04CA:009B.0001: input,hidraw0: USB HID v1.11 Keyboard [Lite-On Technology Corp. Wireless Device] on usb-70090000.xusb-2.3/input0
[ 69.811208] input: Lite-On Technology Corp. Wireless Device as /devices/70090000.xusb/usb1/1-2/1-2.3/1-2.3:1.1/0003:04CA:009B.0002/input/input3
[ 69.875715] hid-generic 0003:04CA:009B.0002: input,hidraw1: USB HID v1.11 Mouse [Lite-On Technology Corp. Wireless Device] on usb-70090000.xusb-2.3/input1
[ 82.675335] r8168: eth0: link up
[ 82.675792] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 106.690156] tegradc tegradc.0: blank - powerdown
[ 106.745925] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 106.745927] Extcon AUX1(HDMI) disable
[ 106.766317] tegradc tegradc.1: blank - powerdown
[ 106.915660] tegradc tegradc.0: blank - powerdown
[ 106.915672] tegradc tegradc.0: unblank
[ 106.951805] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 106.951900] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 106.952932] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 106.987808] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 106.987810] Extcon AUX1(HDMI) enable
[ 106.993774] tegradc tegradc.0: unblank
[ 106.994185] tegradc tegradc.1: blank - powerdown
[ 111.187599] tegradc tegradc.0: unblank
[ 111.187610] tegradc tegradc.1: blank - powerdown
[ 471.458054] systemd: 34 output lines suppressed due to ratelimiting
[ 471.475252] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 471.476069] systemd[1]: Detected architecture arm64.
[ 471.562591] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 471.579977] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 472.568001] systemd[1]: Stopping Journal Service...
[ 472.570538] systemd-journald[1907]: Received SIGTERM from PID 1 (systemd).
[ 472.577942] systemd[1]: Stopped Journal Service.
[ 472.582001] systemd[1]: Starting Journal Service...
[ 472.673909] systemd[1]: Started Journal Service.
