Connecting CSI Camera IMX219-83 to Jetson Nano
I’m trying to connect IMX219-83 camera to Jetson nano using CSI interface. I can detect the camera as /dev/video0, and some commands as below:
$ v4l2-ctl -d /dev/video0 --list-formats-ext
Output:
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: ‘RG10’
Name : 10-bit Bayer RGRG/GBGB
Size: Discrete 3264x2464
Interval: Discrete 0.048s (21.000 fps)
Size: Discrete 3264x1848
Interval: Discrete 0.036s (28.000 fps)
Size: Discrete 1920x1080
Interval: Discrete 0.033s (30.000 fps)
Size: Discrete 1640x1232
Interval: Discrete 0.017s (60.000 fps)
$ v4l2-ctl -d /dev/video0 --all
Output:
Driver Info (not using libv4l2):
Driver name : tegra-video
Card type : vi-output, imx219 8-0010
Bus info : platform:54080000.vi:4
Driver version: 4.9.253
Capabilities : 0x84200001
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Priority: 2
Video input : 0 (Camera 4: no power)
Format Video Capture:
Width/Height : 3264/2464
Pixel Format : ‘RG10’
Field : None
Bytes per Line : 6528
Size Image : 16084992
Colorspace : sRGB
Transfer Function : Default (maps to sRGB)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization : Default (maps to Full Range)
Flags :
Camera Controls
                 group_hold 0x009a2003 (bool)   : default=0 value=0 flags=execute-on-write
                sensor_mode 0x009a2008 (int64)  : min=0 max=0 step=0 default=0 value=0 flags=slider
                       gain 0x009a2009 (int64)  : min=0 max=0 step=0 default=0 value=16 flags=slider
                   exposure 0x009a200a (int64)  : min=0 max=0 step=0 default=0 value=13 flags=slider
                 frame_rate 0x009a200b (int64)  : min=0 max=0 step=0 default=0 value=2000000 flags=slider
                bypass_mode 0x009a2064 (intmenu): min=0 max=1 default=0 value=0
            override_enable 0x009a2065 (intmenu): min=0 max=1 default=0 value=0
               height_align 0x009a2066 (int)    : min=1 max=16 step=1 default=1 value=1
                 size_align 0x009a2067 (intmenu): min=0 max=2 default=0 value=0
           write_isp_format 0x009a2068 (bool)   : default=0 value=0
   sensor_signal_properties 0x009a2069 (u32)    : min=0 max=0 step=0 default=0 flags=read-only, has-payload
    sensor_image_properties 0x009a206a (u32)    : min=0 max=0 step=0 default=0 flags=read-only, has-payload
  sensor_control_properties 0x009a206b (u32)    : min=0 max=0 step=0 default=0 flags=read-only, has-payload
          sensor_dv_timings 0x009a206c (u32)    : min=0 max=0 step=0 default=0 flags=read-only, has-payload
           low_latency_mode 0x009a206d (bool)   : default=0 value=0
           preferred_stride 0x009a206e (int)    : min=0 max=65535 step=1 default=0 value=0
               sensor_modes 0x009a2082 (int)    : min=0 max=30 step=1 default=30 value=6 flags=read-only
But when I tried to capture the stream, I got error:
$DISPALY=0.0 gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! ‘video/x-raw(memory:NVMM),width=3264,height=2464, framerate=21/1’ ! nvoverlaysink -e
Output:
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
New clock: GstSystemClock
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:736 Failed to create CaptureSession
Got EOS from element “pipeline0”.
Execution ended after 0:00:00.005344687
Setting pipeline to READY …
Setting pipeline to NULL …
Freeing pipeline …
Someone please help me, thank you so much!
Did you check if v4l2-ctl working well?
v4l2-ctl --set-fmt-video=width=3264,height=2464,pixelformat=RG10 --set-ctrl bypass_mode=0 --stream-mmap
Yes, I got this
$ v4l2-ctl --set-fmt-video=width=3264,height=2464,pixelformat=RG10 --set-ctrl bypass_mode=0 --stream-mmap
<<<<<<<<<<<<<<<<<<<<<<< 21.35 fps
<<<<<<<<<<<<<<<<<<<<< 21.28 fps
<<<<<<<<<<<<<<<<<<<<< 21.19 fps
<<<<<<<<<<<<<<<<<<<<< 21.20 fps
<<<<<<<<<<<<<<<<<<<<<< 21.19 fps
<<<<<<<<<<<<<<<<<<<<< 21.18 fps
<<<<<<<<<<<<<<<<<<<<<< 21.18 fps
<<<<<<<<<<<<<<<<^C
Could you try fakesink.
gst-launch-1.0 nvarguscamerasrc ! 'video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080' ! nvvidconv ! fpsdisplaysink video-sink=fakesink --verbose
I got this:
$ gst-launch-1.0 nvarguscamerasrc ! ‘video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080’ ! nvvidconv ! fpsdisplaysink video-sink=fakesink --verbose
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstFakeSink:fakesink0: sync = true
/GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0.GstGhostPad:sink.GstProxyPad:proxypad0: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay.GstPad:src: caps = video/x-raw(memory:NVMM, meta:GstVideoOverlayComposition), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstFakeSink:fakesink0.GstPad:sink: caps = video/x-raw(memory:NVMM, meta:GstVideoOverlayComposition), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay.GstPad:video_sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0.GstGhostPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
Execution ended after 0:00:00.010151198
Freeing pipeline …
Try restart daemon
sudo service nvargus-daemon restart
I restarted following your suggested command:
$ sudo service nvargus-daemon restart
but I got the same output:
Execution ended after 0:00:00.004447969
Freeing pipeline …
Get daemon log to check.
sudo service nvargus-daemon stop
sudo su
export enableCamScfLogs=5
/usr/sbin/nvargus-daemon
launch camera from another console
I tried to run the sample 10_camera_recording then I got:
./camera_recording
Set governor to performance before enabling profiler
Error generated. main.cpp, execute:512 Failed to get ICaptureSession interface
I followed your advice and here the results:
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected…
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3264 x 2464 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3264 x 1848 FR = 28.000001 fps Duration = 35714284 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1640 x 1232 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 120.000005 fps Duration = 8333333 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 2
Output Stream W = 1920 H = 1080
seconds to Run = 0
Frame Rate = 29.999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 17, dropped: 0, current: 32.64, average: 32.64
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 17, dropped: 0, current: 32.64, average: 32.64
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 33, dropped: 0, current: 30.06, average: 31.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 33, dropped: 0, current: 30.06, average: 31.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 48, dropped: 0, current: 29.92, average: 30.88
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 48, dropped: 0, current: 29.92, average: 30.88
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 63, dropped: 0, current: 29.94, average: 30.65
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 63, dropped: 0, current: 29.94, average: 30.65
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 79, dropped: 0, current: 30.13, average: 30.54
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 79, dropped: 0, current: 30.13, average: 30.54
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 95, dropped: 0, current: 30.02, average: 30.45
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 95, dropped: 0, current: 30.02, average: 30.45
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 110, dropped: 0, current: 29.98, average: 30.39
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 110, dropped: 0, current: 29.98, average: 30.39
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 126, dropped: 0, current: 30.05, average: 30.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 126, dropped: 0, current: 30.05, average: 30.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 141, dropped: 0, current: 29.85, average: 30.29
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 141, dropped: 0, current: 29.85, average: 30.29
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 157, dropped: 0, current: 30.14, average: 30.28
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 157, dropped: 0, current: 30.14, average: 30.28
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 172, dropped: 0, current: 29.99, average: 30.25
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 172, dropped: 0, current: 29.99, average: 30.25
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 187, dropped: 0, current: 30.00, average: 30.23
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 187, dropped: 0, current: 30.00, average: 30.23
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 203, dropped: 0, current: 30.01, average: 30.21
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 203, dropped: 0, current: 30.01, average: 30.21
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 219, dropped: 0, current: 30.02, average: 30.20
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 219, dropped: 0, current: 30.02, average: 30.20
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 234, dropped: 0, current: 29.97, average: 30.18
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 234, dropped: 0, current: 29.97, average: 30.18
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 249, dropped: 0, current: 29.95, average: 30.17
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 249, dropped: 0, current: 29.95, average: 30.17
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 265, dropped: 0, current: 30.07, average: 30.16
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 265, dropped: 0, current: 30.07, average: 30.16
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 281, dropped: 0, current: 30.00, average: 30.15
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 281, dropped: 0, current: 30.00, average: 30.15
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 296, dropped: 0, current: 29.93, average: 30.14
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 296, dropped: 0, current: 29.93, average: 30.14
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 312, dropped: 0, current: 30.09, average: 30.14
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 312, dropped: 0, current: 30.09, average: 30.14
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 327, dropped: 0, current: 29.97, average: 30.13
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 327, dropped: 0, current: 29.97, average: 30.13
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 343, dropped: 0, current: 30.08, average: 30.13
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 343, dropped: 0, current: 30.08, average: 30.13
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 358, dropped: 0, current: 29.98, average: 30.12
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 358, dropped: 0, current: 29.98, average: 30.12
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 373, dropped: 0, current: 29.98, average: 30.12
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 373, dropped: 0, current: 29.98, average: 30.12
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 388, dropped: 0, current: 30.00, average: 30.11
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 388, dropped: 0, current: 30.00, average: 30.11
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 403, dropped: 0, current: 29.99, average: 30.11
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 403, dropped: 0, current: 29.99, average: 30.11
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 419, dropped: 0, current: 30.01, average: 30.10
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 419, dropped: 0, current: 30.01, average: 30.10
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 435, dropped: 0, current: 30.05, average: 30.10
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 435, dropped: 0, current: 30.05, average: 30.10
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 451, dropped: 0, current: 29.98, average: 30.10
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 451, dropped: 0, current: 29.98, average: 30.10
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 467, dropped: 0, current: 29.97, average: 30.09
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 467, dropped: 0, current: 29.97, average: 30.09
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 482, dropped: 0, current: 29.95, average: 30.09
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 482, dropped: 0, current: 29.95, average: 30.09
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 498, dropped: 0, current: 30.09, average: 30.09
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 498, dropped: 0, current: 30.09, average: 30.09
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 514, dropped: 0, current: 29.98, average: 30.09
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 514, dropped: 0, current: 29.98, average: 30.09
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 530, dropped: 0, current: 29.99, average: 30.08
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 530, dropped: 0, current: 29.99, average: 30.08
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 545, dropped: 0, current: 30.00, average: 30.08
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 545, dropped: 0, current: 30.00, average: 30.08
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 561, dropped: 0, current: 30.11, average: 30.08
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 561, dropped: 0, current: 30.11, average: 30.08
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 576, dropped: 0, current: 29.95, average: 30.08
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 576, dropped: 0, current: 29.95, average: 30.08
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 591, dropped: 0, current: 29.97, average: 30.08
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 591, dropped: 0, current: 29.97, average: 30.08
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 606, dropped: 0, current: 29.95, average: 30.07
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 606, dropped: 0, current: 29.95, average: 30.07
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 622, dropped: 0, current: 30.10, average: 30.07
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 622, dropped: 0, current: 30.10, average: 30.07
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 638, dropped: 0, current: 30.01, average: 30.07
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 638, dropped: 0, current: 30.01, average: 30.07
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 653, dropped: 0, current: 29.98, average: 30.07
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 653, dropped: 0, current: 29.98, average: 30.07
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 668, dropped: 0, current: 29.94, average: 30.07
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 668, dropped: 0, current: 29.94, average: 30.07
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 684, dropped: 0, current: 30.02, average: 30.07
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 684, dropped: 0, current: 30.02, average: 30.07
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 700, dropped: 0, current: 30.08, average: 30.07
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 700, dropped: 0, current: 30.08, average: 30.07
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 716, dropped: 0, current: 29.97, average: 30.06
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 716, dropped: 0, current: 29.97, average: 30.06
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 731, dropped: 0, current: 29.96, average: 30.06
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 731, dropped: 0, current: 29.96, average: 30.06
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 747, dropped: 0, current: 30.00, average: 30.06
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 747, dropped: 0, current: 30.00, average: 30.06
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 763, dropped: 0, current: 30.04, average: 30.06
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 763, dropped: 0, current: 30.04, average: 30.06
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 779, dropped: 0, current: 30.04, average: 30.06
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 779, dropped: 0, current: 30.04, average: 30.06
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 794, dropped: 0, current: 29.99, average: 30.06
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 794, dropped: 0, current: 29.99, average: 30.06
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 809, dropped: 0, current: 29.96, average: 30.06
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 809, dropped: 0, current: 29.96, average: 30.06
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 825, dropped: 0, current: 29.90, average: 30.05
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 825, dropped: 0, current: 29.90, average: 30.05
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 841, dropped: 0, current: 30.16, average: 30.06
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 841, dropped: 0, current: 30.16, average: 30.06
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 857, dropped: 0, current: 30.04, average: 30.06
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 857, dropped: 0, current: 30.04, average: 30.06
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 872, dropped: 0, current: 29.96, average: 30.05
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 872, dropped: 0, current: 29.96, average: 30.05
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 887, dropped: 0, current: 29.89, average: 30.05
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 887, dropped: 0, current: 29.89, average: 30.05
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 903, dropped: 0, current: 30.12, average: 30.05
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 903, dropped: 0, current: 30.12, average: 30.05
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 919, dropped: 0, current: 30.00, average: 30.05
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 919, dropped: 0, current: 30.00, average: 30.05
^Chandling interrupt.
Interrupt: Stopping pipeline …
Execution ended after 0:00:31.510600405
GST_ARGUS: Cleaning up
CONSUMER: Done Success
GST_ARGUS: Done Success
Freeing pipeline …
and:
Thread 6 is waiting
Thread 5 is waiting
Session::updatePerfHints()
updatePerfHints(): guid=1ll, CaptureIntent=1
updatePerfHints(): NvCameraCoreUseCase_Preview
NvPHSSendThroughputHints: sensorId=1, m_usecase=4, m_type=1, m_value=30, m_timeout_ms=1000
NvPHSSendThroughputHints: sensorId=1, m_usecase=4, m_type=15, m_value=0, m_timeout_ms=1000
Created fiber 0x7f64000f70 for CC 1018 globalID 1018 session 1
Thread 10 is working on CC 1018 session 1 globalID 1018 step 0
CC 1018 session 1 completed step 0 in fiber 0x7f64000f70
cc 1018(918) session 1 runCount=917 runIspOut=913, latest ccId=1013
AC Stats Delay Count:5
CC 1018 session 1 completed step 1 in fiber 0x7f64000f70
NV AE and AfApply algorithms are active.
CC 1018 session 1 completed step 2 in fiber 0x7f64000f70
CC 1018 session 1 completed step 3 in fiber 0x7f64000f70
CC 1018 session 1 completed step 4 in fiber 0x7f64000f70
CC 1018 session 1 completed step 5 in fiber 0x7f64000f70
CC 1018 session 1 completed step 6 in fiber 0x7f64000f70
CC 1018 session 1 processing step 7 in fiber 0x7f64000f70
FiberScheduler: cc 1018, session 1, fiber 0x7f64000f70 in progress…
Thread 10 getting next capture
Thread 8 is waiting
Thread 10 is waiting
FiberScheduler: cc 1014, session 1, fiber 0x7f64000dd0 succeeded async operation
Thread 12 is working on CC 1014 session 1 globalID 1014 step 8
CC 1014 session 1 completed step 8 in fiber 0x7f64000dd0
CC 1014 session 1 completed step 9 in fiber 0x7f64000dd0
exposureTime=0.030000 analogGain=2.530075 digitalGain=1.000000 commonGain=0.075902 expComp=1.000000
lux in Statsupdate: isAohdrEnable=0 currentSceneLux 120.229
CC 1014 session 1 completed step 10 in fiber 0x7f64000dd0
CC 1014 session 1 completed step 11 in fiber 0x7f64000dd0
CC 1014 session 1 completed step 12 in fiber 0x7f64000dd0
CC 1014 session 1 completed step 13 in fiber 0x7f64000dd0
NV AF analysis algorithm is active.
AfAnalysis cc 1014 push FK_ISP_RUN_NUMBER=914.
CC 1014 session 1 completed step 14 in fiber 0x7f64000dd0
CC 1014 session 1 completed step 15 in fiber 0x7f64000dd0
CC 1014 session 1 completed step 16 in fiber 0x7f64000dd0
CC 1014 session 1 completed step 17 in fiber 0x7f64000dd0
CC 1014 session 1 completed step 18 in fiber 0x7f64000dd0
CC 1014 session 1 completed step 19 in fiber 0x7f64000dd0
NvPHSSendThroughputHints: sensorId=1, m_usecase=4, m_type=20, m_value=2310441374, m_timeout_ms=1000
CC 1014 session 1 completed step 20 in fiber 0x7f64000dd0
FiberScheduler: cc 1014, session 1, fiber 0x7f64000dd0 complete
FiberScheduler: fiber 0x7f64000dd0 exiting
Thread 12 getting next capture
disposing CC 1014 Session 1
Thread 4 is waiting
Thread 12 is waiting
Thread 3 is waiting
Created fiber 0x7f640021a0 for CC 1019 globalID 1019 session 1
Thread 1 is working on CC 1019 session 1 globalID 1019 step 0
CC 1019 session 1 completed step 0 in fiber 0x7f640021a0
cc 1019(919) session 1 runCount=918 runIspOut=914, latest ccId=1014
CC 1019 session 1 completed step 1 in fiber 0x7f640021a0
CC 1019 session 1 completed step 2 in fiber 0x7f640021a0
CC 1019 session 1 completed step 3 in fiber 0x7f640021a0
CC 1019 session 1 completed step 4 in fiber 0x7f640021a0
CC 1019 session 1 completed step 5 in fiber 0x7f640021a0
CC 1019 session 1 completed step 6 in fiber 0x7f640021a0
CC 1019 session 1 processing step 7 in fiber 0x7f640021a0
FiberScheduler: cc 1019, session 1, fiber 0x7f640021a0 in progress…
Thread 1 getting next capture
Thread 9 is waiting
Thread 1 is waiting
FiberScheduler: cc 1015, session 1, fiber 0x7f64002030 succeeded async operation
Thread 7 is working on CC 1015 session 1 globalID 1015 step 8
CC 1015 session 1 completed step 8 in fiber 0x7f64002030
CC 1015 session 1 completed step 9 in fiber 0x7f64002030
lux in Statsupdate: isAohdrEnable=0 currentSceneLux 120.223
CC 1015 session 1 completed step 10 in fiber 0x7f64002030
CC 1015 session 1 completed step 11 in fiber 0x7f64002030
CC 1015 session 1 completed step 12 in fiber 0x7f64002030
CC 1015 session 1 completed step 13 in fiber 0x7f64002030
AfAnalysis cc 1015 push FK_ISP_RUN_NUMBER=915.
CC 1015 session 1 completed step 14 in fiber 0x7f64002030
CC 1015 session 1 completed step 15 in fiber 0x7f64002030
CC 1015 session 1 completed step 16 in fiber 0x7f64002030
CC 1015 session 1 completed step 17 in fiber 0x7f64002030
CC 1015 session 1 completed step 18 in fiber 0x7f64002030
CC 1015 session 1 completed step 19 in fiber 0x7f64002030
NvPHSSendThroughputHints: sensorId=1, m_usecase=4, m_type=20, m_value=2312669632, m_timeout_ms=1000
CC 1015 session 1 completed step 20 in fiber 0x7f64002030
FiberScheduler: cc 1015, session 1, fiber 0x7f64002030 complete
FiberScheduler: fiber 0x7f64002030 exiting
Thread 2 is waiting
Thread 7 getting next capture
disposing CC 1015 Session 1
Thread 11 is waiting
Thread 7 is waiting
Created fiber 0x7f64001eb0 for CC 1020 globalID 1020 session 1
Thread 6 is working on CC 1020 session 1 globalID 1020 step 0
CC 1020 session 1 completed step 0 in fiber 0x7f64001eb0
cc 1020(920) session 1 runCount=919 runIspOut=915, latest ccId=1015
CC 1020 session 1 completed step 1 in fiber 0x7f64001eb0
CC 1020 session 1 completed step 2 in fiber 0x7f64001eb0
CC 1020 session 1 completed step 3 in fiber 0x7f64001eb0
CC 1020 session 1 completed step 4 in fiber 0x7f64001eb0
CC 1020 session 1 completed step 5 in fiber 0x7f64001eb0
CC 1020 session 1 completed step 6 in fiber 0x7f64001eb0
CC 1020 session 1 processing step 7 in fiber 0x7f64001eb0
FiberScheduler: cc 1020, session 1, fiber 0x7f64001eb0 in progress…
Thread 6 getting next capture
Thread 6 is waiting
Thread 5 is waiting
FiberScheduler: cc 1016, session 1, fiber 0x7f64001110 succeeded async operation
Thread 8 is working on CC 1016 session 1 globalID 1016 step 8
CC 1016 session 1 completed step 8 in fiber 0x7f64001110
CC 1016 session 1 completed step 9 in fiber 0x7f64001110
lux in Statsupdate: isAohdrEnable=0 currentSceneLux 120.242
CC 1016 session 1 completed step 10 in fiber 0x7f64001110
CC 1016 session 1 completed step 11 in fiber 0x7f64001110
CC 1016 session 1 completed step 12 in fiber 0x7f64001110
CC 1016 session 1 completed step 13 in fiber 0x7f64001110
AfAnalysis cc 1016 push FK_ISP_RUN_NUMBER=916.
CC 1016 session 1 completed step 14 in fiber 0x7f64001110
CC 1016 session 1 completed step 15 in fiber 0x7f64001110
CC 1016 session 1 completed step 16 in fiber 0x7f64001110
CC 1016 session 1 completed step 17 in fiber 0x7f64001110
CC 1016 session 1 completed step 18 in fiber 0x7f64001110
CC 1016 session 1 completed step 19 in fiber 0x7f64001110
NvPHSSendThroughputHints: sensorId=1, m_usecase=4, m_type=20, m_value=2314766817, m_timeout_ms=1000
CC 1016 session 1 completed step 20 in fiber 0x7f64001110
FiberScheduler: cc 1016, session 1, fiber 0x7f64001110 complete
FiberScheduler: fiber 0x7f64001110 exiting
Thread 8 getting next capture
disposing CC 1016 Session 1
Thread 4 is waiting
Thread 8 is waiting
Created fiber 0x7f640012b0 for CC 1021 globalID 1021 session 1
Thread 12 is working on CC 1021 session 1 globalID 1021 step 0
CC 1021 session 1 completed step 0 in fiber 0x7f640012b0
cc 1021(921) session 1 runCount=920 runIspOut=916, latest ccId=1016
CC 1021 session 1 completed step 1 in fiber 0x7f640012b0
CC 1021 session 1 completed step 2 in fiber 0x7f640012b0
CC 1021 session 1 completed step 3 in fiber 0x7f640012b0
CC 1021 session 1 completed step 4 in fiber 0x7f640012b0
CC 1021 session 1 completed step 5 in fiber 0x7f640012b0
CC 1021 session 1 completed step 6 in fiber 0x7f640012b0
CC 1021 session 1 processing step 7 in fiber 0x7f640012b0
FiberScheduler: cc 1021, session 1, fiber 0x7f640012b0 in progress…
Thread 3 is waiting
FiberScheduler: cc 1017, session 1, fiber 0x7f64001450 succeeded async operation
Thread 9 is working on CC 1017 session 1 globalID 1017 step 8
CC 1017 session 1 completed step 8 in fiber 0x7f64001450
CC 1017 session 1 completed step 9 in fiber 0x7f64001450
lux in Statsupdate: isAohdrEnable=0 currentSceneLux 120.184
CC 1017 session 1 completed step 10 in fiber 0x7f64001450
CC 1017 session 1 completed step 11 in fiber 0x7f64001450
CC 1017 session 1 completed step 12 in fiber 0x7f64001450
CC 1017 session 1 completed step 13 in fiber 0x7f64001450
AfAnalysis cc 1017 push FK_ISP_RUN_NUMBER=917.
CC 1017 session 1 completed step 14 in fiber 0x7f64001450
CC 1017 session 1 completed step 15 in fiber 0x7f64001450
CC 1017 session 1 completed step 16 in fiber 0x7f64001450
CC 1017 session 1 completed step 17 in fiber 0x7f64001450
CC 1017 session 1 completed step 18 in fiber 0x7f64001450
CC 1017 session 1 completed step 19 in fiber 0x7f64001450
PerfStatsStageStage[sensorId=1][cc=1017], sensorStart_ms=17336834, captureDone_ms=17336855, now_ms=17336859, frameDuration_ms=25, framerate=40.0
NvPHSSendThroughputHints: sensorId=1, m_usecase=4, m_type=20, m_value=2317060610, m_timeout_ms=1000
CC 1017 session 1 completed step 20 in fiber 0x7f64001450
FiberScheduler: cc 1017, session 1, fiber 0x7f64001450 complete
FiberScheduler: fiber 0x7f64001450 exiting
Thread 9 getting next capture
disposing CC 1017 Session 1
Thread 1 is waiting
Thread 2 is waiting
Thread 9 is waiting
Created fiber 0x7f64001450 for CC 1022 globalID 1022 session 1
Thread 11 is working on CC 1022 session 1 globalID 1022 step 0
CC 1022 session 1 completed step 0 in fiber 0x7f64001450
cc 1022(922) session 1 runCount=921 runIspOut=917, latest ccId=1017
CC 1022 session 1 completed step 1 in fiber 0x7f64001450
CC 1022 session 1 completed step 2 in fiber 0x7f64001450
CC 1022 session 1 completed step 3 in fiber 0x7f64001450
CC 1022 session 1 completed step 4 in fiber 0x7f64001450
CC 1022 session 1 completed step 5 in fiber 0x7f64001450
CC 1022 session 1 completed step 6 in fiber 0x7f64001450
CC 1022 session 1 processing step 7 in fiber 0x7f64001450
FiberScheduler: cc 1022, session 1, fiber 0x7f64001450 in progress…
Thread 11 getting next capture
Thread 7 is waiting
FiberScheduler: cc 1018, session 1, fiber 0x7f64000f70 succeeded async operation
Thread 6 is working on CC 1018 session 1 globalID 1018 step 8
CC 1018 session 1 completed step 8 in fiber 0x7f64000f70
CC 1018 session 1 completed step 9 in fiber 0x7f64000f70
lux in Statsupdate: isAohdrEnable=0 currentSceneLux 120.163
CC 1018 session 1 completed step 10 in fiber 0x7f64000f70
CC 1018 session 1 completed step 11 in fiber 0x7f64000f70
CC 1018 session 1 completed step 12 in fiber 0x7f64000f70
CC 1018 session 1 completed step 13 in fiber 0x7f64000f70
AfAnalysis cc 1018 push FK_ISP_RUN_NUMBER=918.
CC 1018 session 1 completed step 14 in fiber 0x7f64000f70
CC 1018 session 1 completed step 15 in fiber 0x7f64000f70
CC 1018 session 1 completed step 16 in fiber 0x7f64000f70
CC 1018 session 1 completed step 17 in fiber 0x7f64000f70
CC 1018 session 1 completed step 18 in fiber 0x7f64000f70
CC 1018 session 1 completed step 19 in fiber 0x7f64000f70
NvPHSSendThroughputHints: sensorId=1, m_usecase=4, m_type=20, m_value=2319223332, m_timeout_ms=1000
CC 1018 session 1 completed step 20 in fiber 0x7f64000f70
FiberScheduler: cc 1018, session 1, fiber 0x7f64000f70 complete
FiberScheduler: fiber 0x7f64000f70 exiting
disposing CC 1018 Session 1
Thread 4 is waiting
Thread 5 is waiting
Thread 6 is waiting
Created fiber 0x7f640015f0 for CC 1023 globalID 1023 session 1
Thread 10 is working on CC 1023 session 1 globalID 1023 step 0
CC 1023 session 1 completed step 0 in fiber 0x7f640015f0
cc 1023(923) session 1 runCount=922 runIspOut=918, latest ccId=1018
CC 1023 session 1 completed step 1 in fiber 0x7f640015f0
CC 1023 session 1 completed step 2 in fiber 0x7f640015f0
CC 1023 session 1 completed step 3 in fiber 0x7f640015f0
CC 1023 session 1 completed step 4 in fiber 0x7f640015f0
CC 1023 session 1 completed step 5 in fiber 0x7f640015f0
CC 1023 session 1 completed step 6 in fiber 0x7f640015f0
CC 1023 session 1 processing step 7 in fiber 0x7f640015f0
FiberScheduler: cc 1023, session 1, fiber 0x7f640015f0 in progress…
Thread 8 is waiting
FiberScheduler: cc 1019, session 1, fiber 0x7f640021a0 succeeded async operation
Thread 3 is working on CC 1019 session 1 globalID 1019 step 8
CC 1019 session 1 completed step 8 in fiber 0x7f640021a0
CC 1019 session 1 completed step 9 in fiber 0x7f640021a0
lux in Statsupdate: isAohdrEnable=0 currentSceneLux 120.208
CC 1019 session 1 completed step 10 in fiber 0x7f640021a0
CC 1019 session 1 completed step 11 in fiber 0x7f640021a0
CC 1019 session 1 completed step 12 in fiber 0x7f640021a0
CC 1019 session 1 completed step 13 in fiber 0x7f640021a0
AfAnalysis cc 1019 push FK_ISP_RUN_NUMBER=919.
CC 1019 session 1 completed step 14 in fiber 0x7f640021a0
CC 1019 session 1 completed step 15 in fiber 0x7f640021a0
CC 1019 session 1 completed step 16 in fiber 0x7f640021a0
CC 1019 session 1 completed step 17 in fiber 0x7f640021a0
CC 1019 session 1 completed step 18 in fiber 0x7f640021a0
CC 1019 session 1 completed step 19 in fiber 0x7f640021a0
NvPHSSendThroughputHints: sensorId=1, m_usecase=4, m_type=20, m_value=2321386053, m_timeout_ms=1000
CC 1019 session 1 completed step 20 in fiber 0x7f640021a0
FiberScheduler: cc 1019, session 1, fiber 0x7f640021a0 complete
FiberScheduler: fiber 0x7f640021a0 exiting
Thread 3 getting next capture
disposing CC 1019 Session 1
Thread 1 is waiting
Thread 3 is waiting
Created fiber 0x7f640020c0 for CC 1024 globalID 1024 session 1
Thread 2 is working on CC 1024 session 1 globalID 1024 step 0
CC 1024 session 1 completed step 0 in fiber 0x7f640020c0
cc 1024(924) session 1 runCount=923 runIspOut=919, latest ccId=1019
CC 1024 session 1 completed step 1 in fiber 0x7f640020c0
CC 1024 session 1 completed step 2 in fiber 0x7f640020c0
CC 1024 session 1 completed step 3 in fiber 0x7f640020c0
CC 1024 session 1 completed step 4 in fiber 0x7f640020c0
CC 1024 session 1 completed step 5 in fiber 0x7f640020c0
CC 1024 session 1 completed step 6 in fiber 0x7f640020c0
CC 1024 session 1 processing step 7 in fiber 0x7f640020c0
FiberScheduler: cc 1024, session 1, fiber 0x7f640020c0 in progress…
Thread 2 getting next capture
Thread 9 is waiting
Thread 2 is waiting
FiberScheduler: cc 1020, session 1, fiber 0x7f64001eb0 succeeded async operation
Thread 7 is working on CC 1020 session 1 globalID 1020 step 8
CC 1020 session 1 completed step 8 in fiber 0x7f64001eb0
CC 1020 session 1 completed step 9 in fiber 0x7f64001eb0
lux in Statsupdate: isAohdrEnable=0 currentSceneLux 120.151
CC 1020 session 1 completed step 10 in fiber 0x7f64001eb0
CC 1020 session 1 completed step 11 in fiber 0x7f64001eb0
CC 1020 session 1 completed step 12 in fiber 0x7f64001eb0
CC 1020 session 1 completed step 13 in fiber 0x7f64001eb0
AfAnalysis cc 1020 push FK_ISP_RUN_NUMBER=920.
CC 1020 session 1 completed step 14 in fiber 0x7f64001eb0
CC 1020 session 1 completed step 15 in fiber 0x7f64001eb0
CC 1020 session 1 completed step 16 in fiber 0x7f64001eb0
CC 1020 session 1 completed step 17 in fiber 0x7f64001eb0
CC 1020 session 1 completed step 18 in fiber 0x7f64001eb0
CC 1020 session 1 completed step 19 in fiber 0x7f64001eb0
NvPHSSendThroughputHints: sensorId=1, m_usecase=4, m_type=20, m_value=2323679846, m_timeout_ms=1000
CC 1020 session 1 completed step 20 in fiber 0x7f64001eb0
FiberScheduler: cc 1020, session 1, fiber 0x7f64001eb0 complete
FiberScheduler: fiber 0x7f64001eb0 exiting
disposing CC 1020 Session 1
Thread 4 is waiting
Thread 7 is waiting
Created fiber 0x7f64000b20 for CC 1025 globalID 1025 session 1
Thread 5 is working on CC 1025 session 1 globalID 1025 step 0
CC 1025 session 1 completed step 0 in fiber 0x7f64000b20
cc 1025(925) session 1 runCount=924 runIspOut=920, latest ccId=1020
CC 1025 session 1 completed step 1 in fiber 0x7f64000b20
CC 1025 session 1 completed step 2 in fiber 0x7f64000b20
CC 1025 session 1 completed step 3 in fiber 0x7f64000b20
CC 1025 session 1 completed step 4 in fiber 0x7f64000b20
CC 1025 session 1 completed step 5 in fiber 0x7f64000b20
CC 1025 session 1 completed step 6 in fiber 0x7f64000b20
CC 1025 session 1 processing step 7 in fiber 0x7f64000b20
FiberScheduler: cc 1025, session 1, fiber 0x7f64000b20 in progress…
Thread 5 getting next capture
Thread 5 is waiting
Thread 6 is waiting
FiberScheduler: cc 1021, session 1, fiber 0x7f640012b0 succeeded async operation
Thread 8 is working on CC 1021 session 1 globalID 1021 step 8
CC 1021 session 1 completed step 8 in fiber 0x7f640012b0
CC 1021 session 1 completed step 9 in fiber 0x7f640012b0
lux in Statsupdate: isAohdrEnable=0 currentSceneLux 120.166
CC 1021 session 1 completed step 10 in fiber 0x7f640012b0
CC 1021 session 1 completed step 11 in fiber 0x7f640012b0
CC 1021 session 1 completed step 12 in fiber 0x7f640012b0
CC 1021 session 1 completed step 13 in fiber 0x7f640012b0
AfAnalysis cc 1021 push FK_ISP_RUN_NUMBER=921.
CC 1021 session 1 completed step 14 in fiber 0x7f640012b0
CC 1021 session 1 completed step 15 in fiber 0x7f640012b0
CC 1021 session 1 completed step 16 in fiber 0x7f640012b0
CC 1021 session 1 completed step 17 in fiber 0x7f640012b0
CC 1021 session 1 completed step 18 in fiber 0x7f640012b0
CC 1021 session 1 completed step 19 in fiber 0x7f640012b0
NvPHSSendThroughputHints: sensorId=1, m_usecase=4, m_type=20, m_value=2325711496, m_timeout_ms=1000
CC 1021 session 1 completed step 20 in fiber 0x7f640012b0
FiberScheduler: cc 1021, session 1, fiber 0x7f640012b0 complete
FiberScheduler: fiber 0x7f640012b0 exiting
disposing CC 1021 Session 1
Thread 8 is waiting
Created fiber 0x7f640018f0 for CC 1026 globalID 1026 session 1
Thread 1 is working on CC 1026 session 1 globalID 1026 step 0
CC 1026 session 1 completed step 0 in fiber 0x7f640018f0
cc 1026(926) session 1 runCount=925 runIspOut=921, latest ccId=1021
CC 1026 session 1 completed step 1 in fiber 0x7f640018f0
CC 1026 session 1 completed step 2 in fiber 0x7f640018f0
CC 1026 session 1 completed step 3 in fiber 0x7f640018f0
CC 1026 session 1 completed step 4 in fiber 0x7f640018f0
CC 1026 session 1 completed step 5 in fiber 0x7f640018f0
CC 1026 session 1 completed step 6 in fiber 0x7f640018f0
CC 1026 session 1 processing step 7 in fiber 0x7f640018f0
FiberScheduler: cc 1026, session 1, fiber 0x7f640018f0 in progress…
Thread 3 is waiting
Thread 1 is waiting
FiberScheduler: cc 1022, session 1, fiber 0x7f64001450 succeeded async operation
Thread 9 is working on CC 1022 session 1 globalID 1022 step 8
CC 1022 session 1 completed step 8 in fiber 0x7f64001450
CC 1022 session 1 completed step 9 in fiber 0x7f64001450
lux in Statsupdate: isAohdrEnable=0 currentSceneLux 120.187
CC 1022 session 1 completed step 10 in fiber 0x7f64001450
CC 1022 session 1 completed step 11 in fiber 0x7f64001450
CC 1022 session 1 completed step 12 in fiber 0x7f64001450
CC 1022 session 1 completed step 13 in fiber 0x7f64001450
AfAnalysis cc 1022 push FK_ISP_RUN_NUMBER=922.
CC 1022 session 1 completed step 14 in fiber 0x7f64001450
CC 1022 session 1 completed step 15 in fiber 0x7f64001450
CC 1022 session 1 completed step 16 in fiber 0x7f64001450
CC 1022 session 1 completed step 17 in fiber 0x7f64001450
CC 1022 session 1 completed step 18 in fiber 0x7f64001450
CC 1022 session 1 completed step 19 in fiber 0x7f64001450
NvPHSSendThroughputHints: sensorId=1, m_usecase=4, m_type=20, m_value=2327939753, m_timeout_ms=1000
CC 1022 session 1 completed step 20 in fiber 0x7f64001450
FiberScheduler: cc 1022, session 1, fiber 0x7f64001450 complete
disposing CC 1022 Session 1
Thread 4 is waiting
Thread 2 is waiting
Thread 9 is waiting
Created fiber 0x7f64000dd0 for CC 1027 globalID 1027 session 1
Thread 7 is working on CC 1027 session 1 globalID 1027 step 0
CC 1027 session 1 completed step 0 in fiber 0x7f64000dd0
cc 1027(927) session 1 runCount=926 runIspOut=922, latest ccId=1022
CC 1027 session 1 completed step 1 in fiber 0x7f64000dd0
CC 1027 session 1 completed step 2 in fiber 0x7f64000dd0
CC 1027 session 1 completed step 3 in fiber 0x7f64000dd0
CC 1027 session 1 completed step 4 in fiber 0x7f64000dd0
CC 1027 session 1 completed step 5 in fiber 0x7f64000dd0
CC 1027 session 1 completed step 6 in fiber 0x7f64000dd0
CC 1027 session 1 processing step 7 in fiber 0x7f64000dd0
FiberScheduler: cc 1027, session 1, fiber 0x7f64000dd0 in progress…
Thread 7 is waiting
FiberScheduler: cc 1023, session 1, fiber 0x7f640015f0 succeeded async operation
Thread 5 is working on CC 1023 session 1 globalID 1023 step 8
CC 1023 session 1 completed step 8 in fiber 0x7f640015f0
CC 1023 session 1 completed step 9 in fiber 0x7f640015f0
lux in Statsupdate: isAohdrEnable=0 currentSceneLux 120.144
CC 1023 session 1 completed step 10 in fiber 0x7f640015f0
CC 1023 session 1 completed step 11 in fiber 0x7f640015f0
CC 1023 session 1 completed step 12 in fiber 0x7f640015f0
CC 1023 session 1 completed step 13 in fiber 0x7f640015f0
AfAnalysis cc 1023 push FK_ISP_RUN_NUMBER=923.
CC 1023 session 1 completed step 14 in fiber 0x7f640015f0
CC 1023 session 1 completed step 15 in fiber 0x7f640015f0
CC 1023 session 1 completed step 16 in fiber 0x7f640015f0
CC 1023 session 1 completed step 17 in fiber 0x7f640015f0
CC 1023 session 1 completed step 18 in fiber 0x7f640015f0
CC 1023 session 1 completed step 19 in fiber 0x7f640015f0
NvPHSSendThroughputHints: sensorId=1, m_usecase=4, m_type=20, m_value=2330102474, m_timeout_ms=1000
CC 1023 session 1 completed step 20 in fiber 0x7f640015f0
FiberScheduler: cc 1023, session 1, fiber 0x7f640015f0 complete
FiberScheduler: fiber 0x7f640015f0 exiting
disposing CC 1023 Session 1
Thread 6 is waiting
Thread 8 is waiting
Thread 5 is waiting
Created fiber 0x7f64002030 for CC 1028 globalID 1028 session 1
Thread 10 is working on CC 1028 session 1 globalID 1028 step 0
CC 1028 session 1 completed step 0 in fiber 0x7f64002030
cc 1028(928) session 1 runCount=927 runIspOut=923, latest ccId=1023
CC 1028 session 1 completed step 1 in fiber 0x7f64002030
CC 1028 session 1 completed step 2 in fiber 0x7f64002030
CC 1028 session 1 completed step 3 in fiber 0x7f64002030
CC 1028 session 1 completed step 4 in fiber 0x7f64002030
CC 1028 session 1 completed step 5 in fiber 0x7f64002030
CC 1028 session 1 completed step 6 in fiber 0x7f64002030
CC 1028 session 1 processing step 7 in fiber 0x7f64002030
FiberScheduler: cc 1028, session 1, fiber 0x7f64002030 in progress…
Thread 10 getting next captureThread 12 is waiting
FiberScheduler: cc 1024, session 1, fiber 0x7f640020c0 succeeded async operation
Thread 3 is working on CC 1024 session 1 globalID 1024 step 8
CC 1024 session 1 completed step 8 in fiber 0x7f640020c0
CC 1024 session 1 completed step 9 in fiber 0x7f640020c0
CC 1024 session 1 completed step 10 in fiber 0x7f640020c0
CC 1024 session 1 completed step 11 in fiber 0x7f640020c0
CC 1024 session 1 completed step 12 in fiber 0x7f640020c0
CC 1024 session 1 completed step 13 in fiber 0x7f640020c0
AfAnalysis cc 1024 push FK_ISP_RUN_NUMBER=924.
CC 1024 session 1 completed step 14 in fiber 0x7f640020c0
CC 1024 session 1 completed step 15 in fiber 0x7f640020c0
CC 1024 session 1 completed step 16 in fiber 0x7f640020c0
CC 1024 session 1 completed step 17 in fiber 0x7f640020c0
CC 1024 session 1 completed step 18 in fiber 0x7f640020c0
CC 1024 session 1 completed step 19 in fiber 0x7f640020c0
NvPHSSendThroughputHints: sensorId=1, m_usecase=4, m_type=20, m_value=2332265196, m_timeout_ms=1000
CC 1024 session 1 completed step 20 in fiber 0x7f640020c0
FiberScheduler: cc 1024, session 1, fiber 0x7f640020c0 complete
FiberScheduler: fiber 0x7f640020c0 exiting
disposing CC 1024 Session 1
Thread 4 is waiting
Thread 1 is waiting
Thread 3 is waiting
Created fiber 0x7f64001110 for CC 1029 globalID 1029 session 1
Thread 2 is working on CC 1029 session 1 globalID 1029 step 0
CC 1029 session 1 completed step 0 in fiber 0x7f64001110
cc 1029(929) session 1 runCount=928 runIspOut=924, latest ccId=1024
CC 1029 session 1 completed step 1 in fiber 0x7f64001110
CC 1029 session 1 completed step 2 in fiber 0x7f64001110
CC 1029 session 1 completed step 3 in fiber 0x7f64001110
CC 1029 session 1 completed step 4 in fiber 0x7f64001110
CC 1029 session 1 completed step 5 in fiber 0x7f64001110
CC 1029 session 1 completed step 6 in fiber 0x7f64001110
CC 1029 session 1 processing step 7 in fiber 0x7f64001110
FiberScheduler: cc 1029, session 1, fiber 0x7f64001110 in progress…
Thread 2 is waiting
Thread 9 is waiting
FiberScheduler: cc 1025, session 1, fiber 0x7f64000b20 succeeded async operation
Thread 11 is working on CC 1025 session 1 globalID 1025 step 8
CC 1025 session 1 completed step 8 in fiber 0x7f64000b20
CC 1025 session 1 completed step 9 in fiber 0x7f64000b20
lux in Statsupdate: isAohdrEnable=0 currentSceneLux 120.139
CC 1025 session 1 completed step 10 in fiber 0x7f64000b20
CC 1025 session 1 completed step 11 in fiber 0x7f64000b20
CC 1025 session 1 completed step 12 in fiber 0x7f64000b20
CC 1025 session 1 completed step 13 in fiber 0x7f64000b20
AfAnalysis cc 1025 push FK_ISP_RUN_NUMBER=925.
CC 1025 session 1 completed step 14 in fiber 0x7f64000b20
CC 1025 session 1 completed step 15 in fiber 0x7f64000b20
CC 1025 session 1 completed step 16 in fiber 0x7f64000b20
CC 1025 session 1 completed step 17 in fiber 0x7f64000b20
CC 1025 session 1 completed step 18 in fiber 0x7f64000b20
CC 1025 session 1 completed step 19 in fiber 0x7f64000b20
NvPHSSendThroughputHints: sensorId=1, m_usecase=4, m_type=20, m_value=2334427917, m_timeout_ms=1000
CC 1025 session 1 completed step 20 in fiber 0x7f64000b20
FiberScheduler: cc 1025, session 1, fiber 0x7f64000b20 complete
FiberScheduler: fiber 0x7f64000b20 exiting
disposing CC 1025 Session 1
Thread 7 is waiting
Thread 6 is waiting
Created fiber 0x7f64000b20 for CC 1030 globalID 1030 session 1
Thread 8 is working on CC 1030 session 1 globalID 1030 step 0
CC 1030 session 1 completed step 0 in fiber 0x7f64000b20
cc 1030(930) session 1 runCount=929 runIspOut=925, latest ccId=1025
CC 1030 session 1 completed step 1 in fiber 0x7f64000b20
CC 1030 session 1 completed step 2 in fiber 0x7f64000b20
CC 1030 session 1 completed step 3 in fiber 0x7f64000b20
CC 1030 session 1 completed step 4 in fiber 0x7f64000b20
CC 1030 session 1 completed step 5 in fiber 0x7f64000b20
CC 1030 session 1 completed step 6 in fiber 0x7f64000b20
CC 1030 session 1 processing step 7 in fiber 0x7f64000b20
FiberScheduler: cc 1030, session 1, fiber 0x7f64000b20 in progress…
Thread 5 is waiting
Thread 8 is waiting
FiberScheduler: cc 1026, session 1, fiber 0x7f640018f0 succeeded async operation
Thread 12 is working on CC 1026 session 1 globalID 1026 step 8
CC 1026 session 1 completed step 8 in fiber 0x7f640018f0
CC 1026 session 1 completed step 9 in fiber 0x7f640018f0
lux in Statsupdate: isAohdrEnable=0 currentSceneLux 120.118
CC 1026 session 1 completed step 10 in fiber 0x7f640018f0
CC 1026 session 1 completed step 11 in fiber 0x7f640018f0
CC 1026 session 1 completed step 12 in fiber 0x7f640018f0
CC 1026 session 1 completed step 13 in fiber 0x7f640018f0
AfAnalysis cc 1026 push FK_ISP_RUN_NUMBER=926.
CC 1026 session 1 completed step 14 in fiber 0x7f640018f0
CC 1026 session 1 completed step 15 in fiber 0x7f640018f0
CC 1026 session 1 completed step 16 in fiber 0x7f640018f0
CC 1026 session 1 completed step 17 in fiber 0x7f640018f0
CC 1026 session 1 completed step 18 in fiber 0x7f640018f0
CC 1026 session 1 completed step 19 in fiber 0x7f640018f0
NvPHSSendThroughputHints: sensorId=1, m_usecase=4, m_type=20, m_value=2336656174, m_timeout_ms=1000
CC 1026 session 1 completed step 20 in fiber 0x7f640018f0
FiberScheduler: cc 1026, session 1, fiber 0x7f640018f0 complete
FiberScheduler: fiber 0x7f640018f0 exiting
disposing CC 1026 Session 1
Thread 4 is waiting
Created fiber 0x7f64000f70 for CC 1031 globalID 1031 session 1
Thread 1 is working on CC 1031 session 1 globalID 1031 step 0
CC 1031 session 1 completed step 0 in fiber 0x7f64000f70
cc 1031(931) session 1 runCount=930 runIspOut=926, latest ccId=1026
CC 1031 session 1 completed step 1 in fiber 0x7f64000f70
CC 1031 session 1 completed step 2 in fiber 0x7f64000f70
CC 1031 session 1 completed step 3 in fiber 0x7f64000f70
CC 1031 session 1 completed step 4 in fiber 0x7f64000f70
CC 1031 session 1 completed step 5 in fiber 0x7f64000f70
CC 1031 session 1 completed step 6 in fiber 0x7f64000f70
CC 1031 session 1 processing step 7 in fiber 0x7f64000f70
FiberScheduler: cc 1031, session 1, fiber 0x7f64000f70 in progress…
Thread 1 is waiting
Thread 3 is waiting
FiberScheduler: cc 1027, session 1, fiber 0x7f64000dd0 succeeded async operation
Thread 2 is working on CC 1027 session 1 globalID 1027 step 8
CC 1027 session 1 completed step 8 in fiber 0x7f64000dd0
CC 1027 session 1 completed step 9 in fiber 0x7f64000dd0
lux in Statsupdate: isAohdrEnable=0 currentSceneLux 120.107
CC 1027 session 1 completed step 10 in fiber 0x7f64000dd0
CC 1027 session 1 completed step 11 in fiber 0x7f64000dd0
CC 1027 session 1 completed step 12 in fiber 0x7f64000dd0
CC 1027 session 1 completed step 13 in fiber 0x7f64000dd0
AfAnalysis cc 1027 push FK_ISP_RUN_NUMBER=927.
CC 1027 session 1 completed step 14 in fiber 0x7f64000dd0
CC 1027 session 1 completed step 15 in fiber 0x7f64000dd0
CC 1027 session 1 completed step 16 in fiber 0x7f64000dd0
CC 1027 session 1 completed step 17 in fiber 0x7f64000dd0
CC 1027 session 1 completed step 18 in fiber 0x7f64000dd0
CC 1027 session 1 completed step 19 in fiber 0x7f64000dd0
NvPHSSendThroughputHints: sensorId=1, m_usecase=4, m_type=20, m_value=2338884432, m_timeout_ms=1000
CC 1027 session 1 completed step 20 in fiber 0x7f64000dd0
FiberScheduler: cc 1027, session 1, fiber 0x7f64000dd0 complete
disposing CC 1027 Session 1
Thread 9 is waiting
Thread 7 is waiting
Thread 2 is waiting
Created fiber 0x7f640021a0 for CC 1032 globalID 1032 session 1
Thread 6 is working on CC 1032 session 1 globalID 1032 step 0
CC 1032 session 1 completed step 0 in fiber 0x7f640021a0
cc 1032(932) session 1 runCount=931 runIspOut=927, latest ccId=1027
CC 1032 session 1 completed step 1 in fiber 0x7f640021a0
CC 1032 session 1 completed step 2 in fiber 0x7f640021a0
CC 1032 session 1 completed step 3 in fiber 0x7f640021a0
CC 1032 session 1 completed step 4 in fiber 0x7f640021a0
CC 1032 session 1 completed step 5 in fiber 0x7f640021a0
CC 1032 session 1 completed step 6 in fiber 0x7f640021a0
CC 1032 session 1 processing step 7 in fiber 0x7f640021a0
FiberScheduler: cc 1032, session 1, fiber 0x7f640021a0 in progress…
Thread 6 is waiting
FiberScheduler: cc 1028, session 1, fiber 0x7f64002030 succeeded async operation
Thread 5 is working on CC 1028 session 1 globalID 1028 step 8
CC 1028 session 1 completed step 8 in fiber 0x7f64002030
CC 1028 session 1 completed step 9 in fiber 0x7f64002030
lux in Statsupdate: isAohdrEnable=0 currentSceneLux 120.131
CC 1028 session 1 completed step 10 in fiber 0x7f64002030
CC 1028 session 1 completed step 11 in fiber 0x7f64002030
CC 1028 session 1 completed step 12 in fiber 0x7f64002030
CC 1028 session 1 completed step 13 in fiber 0x7f64002030
AfAnalysis cc 1028 push FK_ISP_RUN_NUMBER=928.
CC 1028 session 1 completed step 14 in fiber 0x7f64002030
CC 1028 session 1 completed step 15 in fiber 0x7f64002030
CC 1028 session 1 completed step 16 in fiber 0x7f64002030
CC 1028 session 1 completed step 17 in fiber 0x7f64002030
CC 1028 session 1 completed step 18 in fiber 0x7f64002030
CC 1028 session 1 completed step 19 in fiber 0x7f64002030
NvPHSSendThroughputHints: sensorId=1, m_usecase=4, m_type=20, m_value=2341047153, m_timeout_ms=1000
CC 1028 session 1 completed step 20 in fiber 0x7f64002030
FiberScheduler: cc 1028, session 1, fiber 0x7f64002030 complete
disposing CC 1028 Session 1
Thread 4 is waiting
Thread 8 is waiting
Thread 5 is waiting
Created fiber 0x7f64001eb0 for CC 1033 globalID 1033 session 1
Thread 10 is working on CC 1033 session 1 globalID 1033 step 0
CC 1033 session 1 completed step 0 in fiber 0x7f64001eb0
cc 1033(933) session 1 runCount=932 runIspOut=928, latest ccId=1028
CC 1033 session 1 completed step 1 in fiber 0x7f64001eb0
CC 1033 session 1 completed step 2 in fiber 0x7f64001eb0
CC 1033 session 1 completed step 3 in fiber 0x7f64001eb0
CC 1033 session 1 completed step 4 in fiber 0x7f64001eb0
CC 1033 session 1 completed step 5 in fiber 0x7f64001eb0
CC 1033 session 1 completed step 6 in fiber 0x7f64001eb0
CC 1033 session 1 processing step 7 in fiber 0x7f64001eb0
FiberScheduler: cc 1033, session 1, fiber 0x7f64001eb0 in progress…
FiberScheduler: cc 1029, session 1, fiber 0x7f64001110 succeeded async operation
Thread 1 is working on CC 1029 session 1 globalID 1029 step 8
CC 1029 session 1 completed step 8 in fiber 0x7f64001110
CC 1029 session 1 completed step 9 in fiber 0x7f64001110
CC 1029 session 1 completed step 10 in fiber 0x7f64001110
CC 1029 session 1 completed step 11 in fiber 0x7f64001110
CC 1029 session 1 completed step 12 in fiber 0x7f64001110
CC 1029 session 1 completed step 13 in fiber 0x7f64001110
AfAnalysis cc 1029 push FK_ISP_RUN_NUMBER=929.
CC 1029 session 1 completed step 14 in fiber 0x7f64001110
CC 1029 session 1 completed step 15 in fiber 0x7f64001110
CC 1029 session 1 completed step 16 in fiber 0x7f64001110
CC 1029 session 1 completed step 17 in fiber 0x7f64001110
CC 1029 session 1 completed step 18 in fiber 0x7f64001110
CC 1029 session 1 completed step 19 in fiber 0x7f64001110
NvPHSSendThroughputHints: sensorId=1, m_usecase=4, m_type=20, m_value=2343275410, m_timeout_ms=1000
CC 1029 session 1 completed step 20 in fiber 0x7f64001110
FiberScheduler: cc 1029, session 1, fiber 0x7f64001110 complete
disposing CC 1029 Session 1
Thread 3 is waiting
Thread 1 is waiting
Thread 9 is waiting
Session 1 aborting capture 1033 (API ID: 933)
Session 1 aborting capture 1032 (API ID: 932)
Session 1 aborting capture 1031 (API ID: 931)
Session 1 aborting capture 1030 (API ID: 930)
CaptureService cancelling request 931
FiberScheduler: cc 1032, session 1, fiber 0x7f640021a0 aborted in async operation
CaptureService cancelling request 932
disposing CC 1032 Session 1
Thread 7 is waiting
FiberScheduler: cc 1033, session 1, fiber 0x7f64001eb0 aborted in async operation
Thread 2 is waiting
FiberScheduler: cc 1030, session 1, fiber 0x7f64000b20 succeeded async operation
Thread 6 is working on CC 1030 session 1 globalID 1030 step 8
Fiber 0x7f64000b20 is aborting in CC 1030 Session 1
FiberScheduler: cc 1030 session 1, fiber 0x7f64000b20 aborted
disposing CC 1030 Session 1
Thread 6 is waiting
Thread 4 is waiting
FiberScheduler: cc 1031, session 1, fiber 0x7f64000f70 succeeded async operation
Thread 8 is working on CC 1031 session 1 globalID 1031 step 8
Fiber 0x7f64000f70 is aborting in CC 1031 Session 1
FiberScheduler: cc 1031 session 1, fiber 0x7f64000f70 aborted
disposing CC 1031 Session 1
Thread 8 is waiting
Thread 5 is waiting
NvPHSSendThroughputHints: sensorId=1, m_usecase=4, m_type=2, m_value=4294967295, m_timeout_ms=1000
Worker thread CaptureDispatcher stop
disposing CC 1033 Session 1
Worker thread ViCsiHw frameComplete stop
Worker thread ViCsiHw frameStart stop
PowerServiceHw:removeRequests: table size: before: 2, after:0
request table for ISP 1:
PowerServiceHw:removeRequests: table size: before: 1, after:0
request table for VIC 0:
PowerServiceHw:updateRequests: table size: before: 0, after:0
PowerServiceHwIsp:setLaBw: m_bwVal_Iso=0 and m_bwVal_NonIso=0 KBpS
PowerServiceHwVic:setClock: PowerServiceHw[1]: requested_clock_Hz=0
PowerServiceCore:setCameraBw: totalIsoBw=0
PowerServiceCore:setCameraBw: totalNonIsoBw=0
=== gst-launch-1.0[24883]: CameraProvider destroyed (0x7fa4961100)Stopping services…
Worker thread CaptureScheduler frameStart stop
Worker thread CaptureScheduler checkFramePending stop
Worker thread IspHw statsComplete stop
Worker thread IspHw frameComplete stop
Worker thread V4L2CaptureScheduler issueCaptures stop
Worker thread V4L2CaptureScheduler checkCaptureComplete stop
Worker thread PS handleRequests stop
unsubscribe: SensorType(gyroscope)
unsubscribe: gyroscope sensor(0x7fa4852b20)
unsubscribe: SensorType(accelerometer)
unsubscribe: accelerometer sensor(0x7fa48e3070)
Services are stopped
closeInstance: ms_instance((nil))
FiberScheduler: shutting down; 0 fibers still in map
FiberScheduler: thread 12 exiting
FiberScheduler: thread 9 exiting
FiberScheduler: thread 3 exiting
FiberScheduler: thread 12 has been joined
FiberScheduler: thread 2 exiting
FiberScheduler: thread 6 exiting
FiberScheduler: thread 11 exiting
FiberScheduler: thread 8 exiting
FiberScheduler: thread 5 exiting
FiberScheduler: thread 10 exiting
FiberScheduler: thread 1 exiting
FiberScheduler: thread 11 has been joined
FiberScheduler: thread 9 has been joined
FiberScheduler: thread 8 has been joined
FiberScheduler: thread 7 exiting
FiberScheduler: thread 4 exiting
FiberScheduler: thread 7 has been joined
FiberScheduler: thread 5 has been joined
FiberScheduler: thread 6 has been joined
FiberScheduler: thread 4 has been joined
FiberScheduler: thread 3 has been joined
FiberScheduler: thread 2 has been joined
FiberScheduler: thread 10 has been joined
FiberScheduler: thread 1 has been joined
=== gst-launch-1.0[24883]: Connection closed (7FAB50C1D0)=== gst-launch-1.0[24883]: Connection cleaned up (7FAB50C1D0)
Looks like it working now.
Try below to check if able get the preview.
export DISPLAY:=0
gst-launch-1.0 nvarguscamerasrc ! "video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080,format=(string)NV12, framerate=(fraction)30/1" ! nvvidconv ! xvimagesink sync=false
At first, I can view camera 0, it worked and I can view the stream, but when I try to view camera 1, I got error as below:
jetson@jetson-liam:~$ gst-launch-1.0 nvarguscamerasrc ! ‘video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080’ ! nvvidconv ! fpsdisplaysink video-sink=fakesink --verbose
bash: syntax error near unexpected token `(’
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
New clock: GstSystemClock
Camera index = 0
Camera mode = 2
seconds to Run = 0
Setting pipeline to READY …
Setting pipeline to NULL …
Freeing pipeline …
jetson@jetson-liam:~$ export DISPLAY:=0
bash: export: DISPLAY:=0': not a valid identifier jetson@jetson-liam:~$ jetson@jetson-liam:~$ jetson@jetson-liam:~$ jetson@jetson-liam:~$ export DISPLAY:=0 bash: export: DISPLAY:=0’: not a valid identifier
jetson@jetson-liam:~$ export DISPLAY:=0.0
bash: export: DISPLAY:=0.0': not a valid identifier jetson@jetson-liam:~$ jetson@jetson-liam:~$ jetson@jetson-liam:~$ export DISPLAY:=0 bash: export: DISPLAY:=0’: not a valid identifier
jetson@jetson-liam:~$ export DISPLAY:=“0”
bash: export: `DISPLAY:=0’: not a valid identifier
jetson@jetson-liam:~$ gst-launch-1.0 nvarguscamerasrc ! “video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080,format=(string)NV12, framerate=(fraction)30/1” ! nvvidconv ! xvimagesink sync=false
Camera index = 0
Camera mode = 2
seconds to Run = 0
Execution ended after 0:00:20.345078117
Freeing pipeline …
jetson@jetson-liam:~$ gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! “video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080,format=(string)NV12, framerate=(fraction)30/1” ! nvvidconv ! xvimagesink sync=false
Camera index = 0
Camera mode = 2
seconds to Run = 0
Execution ended after 0:00:05.503623696
Freeing pipeline …
jetson@jetson-liam:~$ gst-launch-1.0 nvarguscamerasrc sensor-id=1 ! “video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080,format=(string)NV12, framerate=(fraction)30/1” ! nvvidconv ! xvimagesink sync=false
Camera index = 1
Camera mode = 2
seconds to Run = 0
nvbuf_utils: dmabuf_fd -1 mapped entry NOT found
nvbuf_utils: Can not get HW buffer from FD… Exiting…
CONSUMER: ERROR OCCURRED
ERROR: from element /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0: CANCELLED
Additional debug info:
Argus Error Status
Execution ended after 0:00:01.709757864
(Argus) Error EndOfFile: Unexpected error in reading socket (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 266)
(Argus) Error EndOfFile: Receive worker failure, notifying 2 waiting threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 340)
(Argus) Error InvalidState: Argus client is exiting with 2 outstanding client threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 357)
(Argus) Error EndOfFile: Receiving thread terminated with error (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadWrapper(), line 368)
(Argus) Error EndOfFile: Client thread received an error from socket (in src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 145)
(Argus) Error EndOfFile: (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 91)
(Argus) Error InvalidState: Receive thread is not running cannot send. (in src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 96)
(Argus) Error InvalidState: (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 91)
Freeing pipeline …
jetson@jetson-liam:~$ ls /dev/video*
/dev/video0 /dev/video1
(Argus) Error FileOperationFailed: Connecting to nvargus-daemon failed: Connection refused (in src/rpc/socket/client/SocketClientDispatch.cpp, function openSocketConnection(), line 205)
(Argus) Error FileOperationFailed: Cannot create camera provider (in src/rpc/socket/client/SocketClientDispatch.cpp, function createCameraProvider(), line 106)
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:720 Failed to create CameraProvider
Got EOS from element “pipeline0”.
Execution ended after 0:00:00.004856927
Freeing pipeline …
Execution ended after 0:00:00.002802500
Freeing pipeline …
Execution ended after 0:00:00.003538021
Freeing pipeline …
Execution ended after 0:00:00.002377917
Freeing pipeline …
and on another terminal:
lux in Statsupdate: isAohdrEnable=0 currentSceneLux 120.301
CC 247 session 1 completed step 10 in fiber 0x7f60002340
CC 247 session 1 completed step 11 in fiber 0x7f60002340
CC 247 session 1 completed step 12 in fiber 0x7f60002340
CC 247 session 1 completed step 13 in fiber 0x7f60002340
AfAnalysis cc 247 push FK_ISP_RUN_NUMBER=147.
CC 247 session 1 completed step 14 in fiber 0x7f60002340
CC 247 session 1 completed step 15 in fiber 0x7f60002340
CC 247 session 1 completed step 16 in fiber 0x7f60002340
CC 247 session 1 completed step 17 in fiber 0x7f60002340
CC 247 session 1 completed step 18 in fiber 0x7f60002340
CC 247 session 1 completed step 19 in fiber 0x7f60002340
NvPHSSendThroughputHints: sensorId=1, m_usecase=4, m_type=20, m_value=3904104603, m_timeout_ms=1000
CC 247 session 1 completed step 20 in fiber 0x7f60002340
FiberScheduler: cc 247, session 1, fiber 0x7f60002340 complete
FiberScheduler: fiber 0x7f60002340 exiting
disposing CC 247 Session 1
Thread 8 is waiting
Created fiber 0x7f60001230 for CC 252 globalID 1790 session 1
Thread 6 is working on CC 252 session 1 globalID 1790 step 0
CC 252 session 1 completed step 0 in fiber 0x7f60001230
cc 252(152) session 1 runCount=151 runIspOut=147, latest ccId=247
CC 252 session 1 completed step 1 in fiber 0x7f60001230
CC 252 session 1 completed step 2 in fiber 0x7f60001230
CC 252 session 1 completed step 3 in fiber 0x7f60001230
CC 252 session 1 completed step 4 in fiber 0x7f60001230
CC 252 session 1 completed step 5 in fiber 0x7f60001230
CC 252 session 1 completed step 6 in fiber 0x7f60001230
CC 252 session 1 processing step 7 in fiber 0x7f60001230
FiberScheduler: cc 252, session 1, fiber 0x7f60001230 in progress…
Thread 7 is waiting
Thread 6 is waiting
FiberScheduler: cc 248, session 1, fiber 0x7f60001090 succeeded async operation
Thread 1 is working on CC 248 session 1 globalID 1786 step 8
CC 248 session 1 completed step 8 in fiber 0x7f60001090
CC 248 session 1 completed step 9 in fiber 0x7f60001090
exposureTime=0.030000 analogGain=2.528419 digitalGain=1.000000 commonGain=0.075853 expComp=1.000000
lux in Statsupdate: isAohdrEnable=0 currentSceneLux 120.361
CC 248 session 1 completed step 10 in fiber 0x7f60001090
CC 248 session 1 completed step 11 in fiber 0x7f60001090
CC 248 session 1 completed step 12 in fiber 0x7f60001090
CC 248 session 1 completed step 13 in fiber 0x7f60001090
AfAnalysis cc 248 push FK_ISP_RUN_NUMBER=148.
CC 248 session 1 completed step 14 in fiber 0x7f60001090
CC 248 session 1 completed step 15 in fiber 0x7f60001090
CC 248 session 1 completed step 16 in fiber 0x7f60001090
CC 248 session 1 completed step 17 in fiber 0x7f60001090
CC 248 session 1 completed step 18 in fiber 0x7f60001090
CC 248 session 1 completed step 19 in fiber 0x7f60001090
NvPHSSendThroughputHints: sensorId=1, m_usecase=4, m_type=20, m_value=3906267325, m_timeout_ms=1000
CC 248 session 1 completed step 20 in fiber 0x7f60001090
FiberScheduler: cc 248, session 1, fiber 0x7f60001090 complete
FiberScheduler: fiber 0x7f60001090 exiting
disposing CC 248 Session 1
Thread 5 is waiting
Thread 1 is waiting
Thread 9 is waiting
Created fiber 0x7f60001c80 for CC 253 globalID 1791 session 1
Thread 3 is working on CC 253 session 1 globalID 1791 step 0
CC 253 session 1 completed step 0 in fiber 0x7f60001c80
cc 253(153) session 1 runCount=152 runIspOut=148, latest ccId=248
CC 253 session 1 completed step 1 in fiber 0x7f60001c80
CC 253 session 1 completed step 2 in fiber 0x7f60001c80
CC 253 session 1 completed step 3 in fiber 0x7f60001c80
CC 253 session 1 completed step 4 in fiber 0x7f60001c80
CC 253 session 1 completed step 5 in fiber 0x7f60001c80
CC 253 session 1 completed step 6 in fiber 0x7f60001c80
CC 253 session 1 processing step 7 in fiber 0x7f60001c80
FiberScheduler: cc 253, session 1, fiber 0x7f60001c80 in progress…
Thread 3 is waiting
FiberScheduler: cc 249, session 1, fiber 0x7f60001570 succeeded async operation
Thread 2 is working on CC 249 session 1 globalID 1787 step 8
CC 249 session 1 completed step 8 in fiber 0x7f60001570
CC 249 session 1 completed step 9 in fiber 0x7f60001570
lux in Statsupdate: isAohdrEnable=0 currentSceneLux 120.340
CC 249 session 1 completed step 10 in fiber 0x7f60001570
CC 249 session 1 completed step 11 in fiber 0x7f60001570
CC 249 session 1 completed step 12 in fiber 0x7f60001570
CC 249 session 1 completed step 13 in fiber 0x7f60001570
AfAnalysis cc 249 push FK_ISP_RUN_NUMBER=149.
CC 249 session 1 completed step 14 in fiber 0x7f60001570
CC 249 session 1 completed step 15 in fiber 0x7f60001570
CC 249 session 1 completed step 16 in fiber 0x7f60001570
CC 249 session 1 completed step 17 in fiber 0x7f60001570
CC 249 session 1 completed step 18 in fiber 0x7f60001570
CC 249 session 1 completed step 19 in fiber 0x7f60001570
NvPHSSendThroughputHints: sensorId=1, m_usecase=4, m_type=20, m_value=3908430046, m_timeout_ms=1000
CC 249 session 1 completed step 20 in fiber 0x7f60001570
FiberScheduler: cc 249, session 1, fiber 0x7f60001570 complete
FiberScheduler: fiber 0x7f60001570 exiting
disposing CC 249 Session 1
Thread 2 is waiting
Thread 4 is waiting
Created fiber 0x7f600019d0 for CC 254 globalID 1792 session 1
Thread 8 is working on CC 254 session 1 globalID 1792 step 0
CC 254 session 1 completed step 0 in fiber 0x7f600019d0
cc 254(154) session 1 runCount=153 runIspOut=149, latest ccId=249
CC 254 session 1 completed step 1 in fiber 0x7f600019d0
CC 254 session 1 completed step 2 in fiber 0x7f600019d0
CC 254 session 1 completed step 3 in fiber 0x7f600019d0
CC 254 session 1 completed step 4 in fiber 0x7f600019d0
CC 254 session 1 completed step 5 in fiber 0x7f600019d0
CC 254 session 1 completed step 6 in fiber 0x7f600019d0
CC 254 session 1 processing step 7 in fiber 0x7f600019d0
FiberScheduler: cc 254, session 1, fiber 0x7f600019d0 in progress…
Thread 8 getting next captureThread 11 is waiting
Thread 8 is waiting
FiberScheduler: cc 250, session 1, fiber 0x7f600013d0 succeeded async operation
Thread 7 is working on CC 250 session 1 globalID 1788 step 8
CC 250 session 1 completed step 8 in fiber 0x7f600013d0
CC 250 session 1 completed step 9 in fiber 0x7f600013d0
lux in Statsupdate: isAohdrEnable=0 currentSceneLux 120.302
CC 250 session 1 completed step 10 in fiber 0x7f600013d0
CC 250 session 1 completed step 11 in fiber 0x7f600013d0
CC 250 session 1 completed step 12 in fiber 0x7f600013d0
CC 250 session 1 completed step 13 in fiber 0x7f600013d0
AfAnalysis cc 250 push FK_ISP_RUN_NUMBER=150.
CC 250 session 1 completed step 14 in fiber 0x7f600013d0
CC 250 session 1 completed step 15 in fiber 0x7f600013d0
CC 250 session 1 completed step 16 in fiber 0x7f600013d0
CC 250 session 1 completed step 17 in fiber 0x7f600013d0
CC 250 session 1 completed step 18 in fiber 0x7f600013d0
CC 250 session 1 completed step 19 in fiber 0x7f600013d0
NvPHSSendThroughputHints: sensorId=1, m_usecase=4, m_type=20, m_value=3910658303, m_timeout_ms=1000
CC 250 session 1 completed step 20 in fiber 0x7f600013d0
FiberScheduler: cc 250, session 1, fiber 0x7f600013d0 complete
FiberScheduler: fiber 0x7f600013d0 exiting
disposing CC 250 Session 1
Thread 5 is waiting
Thread 7 is waiting
Thread 6 is waiting
Created fiber 0x7f600013d0 for CC 255 globalID 1793 session 1
Thread 1 is working on CC 255 session 1 globalID 1793 step 0
CC 255 session 1 completed step 0 in fiber 0x7f600013d0
cc 255(155) session 1 runCount=154 runIspOut=150, latest ccId=250
CC 255 session 1 completed step 1 in fiber 0x7f600013d0
CC 255 session 1 completed step 2 in fiber 0x7f600013d0
CC 255 session 1 completed step 3 in fiber 0x7f600013d0
CC 255 session 1 completed step 4 in fiber 0x7f600013d0
CC 255 session 1 completed step 5 in fiber 0x7f600013d0
CC 255 session 1 completed step 6 in fiber 0x7f600013d0
CC 255 session 1 processing step 7 in fiber 0x7f600013d0
FiberScheduler: cc 255, session 1, fiber 0x7f600013d0 in progress…
Thread 9 is waiting
Thread 1 is waiting
FiberScheduler: cc 251, session 1, fiber 0x7f60000ef0 succeeded async operation
Thread 10 is working on CC 251 session 1 globalID 1789 step 8
CC 251 session 1 completed step 8 in fiber 0x7f60000ef0
CC 251 session 1 completed step 9 in fiber 0x7f60000ef0
lux in Statsupdate: isAohdrEnable=0 currentSceneLux 120.333
CC 251 session 1 completed step 10 in fiber 0x7f60000ef0
CC 251 session 1 completed step 11 in fiber 0x7f60000ef0
CC 251 session 1 completed step 12 in fiber 0x7f60000ef0
CC 251 session 1 completed step 13 in fiber 0x7f60000ef0
AfAnalysis cc 251 push FK_ISP_RUN_NUMBER=151.
CC 251 session 1 completed step 14 in fiber 0x7f60000ef0
CC 251 session 1 completed step 15 in fiber 0x7f60000ef0
CC 251 session 1 completed step 16 in fiber 0x7f60000ef0
CC 251 session 1 completed step 17 in fiber 0x7f60000ef0
CC 251 session 1 completed step 18 in fiber 0x7f60000ef0
CC 251 session 1 completed step 19 in fiber 0x7f60000ef0
NvPHSSendThroughputHints: sensorId=1, m_usecase=4, m_type=20, m_value=3912821024, m_timeout_ms=1000
CC 251 session 1 completed step 20 in fiber 0x7f60000ef0
FiberScheduler: cc 251, session 1, fiber 0x7f60000ef0 complete
FiberScheduler: fiber 0x7f60000ef0 exiting
disposing CC 251 Session 1
Thread 3 is waiting
Created fiber 0x7f60002340 for CC 256 globalID 1794 session 1
Thread 2 is working on CC 256 session 1 globalID 1794 step 0
CC 256 session 1 completed step 0 in fiber 0x7f60002340
cc 256(156) session 1 runCount=155 runIspOut=151, latest ccId=251
CC 256 session 1 completed step 1 in fiber 0x7f60002340
CC 256 session 1 completed step 2 in fiber 0x7f60002340
CC 256 session 1 completed step 3 in fiber 0x7f60002340
CC 256 session 1 completed step 4 in fiber 0x7f60002340
CC 256 session 1 completed step 5 in fiber 0x7f60002340
CC 256 session 1 completed step 6 in fiber 0x7f60002340
CC 256 session 1 processing step 7 in fiber 0x7f60002340
FiberScheduler: cc 256, session 1, fiber 0x7f60002340 in progress…
Thread 4 is waiting
Thread 2 is waiting
FiberScheduler: cc 252, session 1, fiber 0x7f60001230 succeeded async operation
Thread 11 is working on CC 252 session 1 globalID 1790 step 8
CC 252 session 1 completed step 8 in fiber 0x7f60001230
CC 252 session 1 completed step 9 in fiber 0x7f60001230
lux in Statsupdate: isAohdrEnable=0 currentSceneLux 120.364
CC 252 session 1 completed step 10 in fiber 0x7f60001230
CC 252 session 1 completed step 11 in fiber 0x7f60001230
CC 252 session 1 completed step 12 in fiber 0x7f60001230
CC 252 session 1 completed step 13 in fiber 0x7f60001230
AfAnalysis cc 252 push FK_ISP_RUN_NUMBER=152.
CC 252 session 1 completed step 14 in fiber 0x7f60001230
CC 252 session 1 completed step 15 in fiber 0x7f60001230
CC 252 session 1 completed step 16 in fiber 0x7f60001230
CC 252 session 1 completed step 17 in fiber 0x7f60001230
CC 252 session 1 completed step 18 in fiber 0x7f60001230
CC 252 session 1 completed step 19 in fiber 0x7f60001230
NvPHSSendThroughputHints: sensorId=1, m_usecase=4, m_type=20, m_value=3914983746, m_timeout_ms=1000
CC 252 session 1 completed step 20 in fiber 0x7f60001230
FiberScheduler: cc 252, session 1, fiber 0x7f60001230 complete
FiberScheduler: fiber 0x7f60001230 exiting
disposing CC 252 Session 1
Thread 8 is waiting
Thread 5 is waiting
Created fiber 0x7f60001570 for CC 257 globalID 1795 session 1
Thread 7 is working on CC 257 session 1 globalID 1795 step 0
CC 257 session 1 completed step 0 in fiber 0x7f60001570
cc 257(157) session 1 runCount=156 runIspOut=152, latest ccId=252
CC 257 session 1 completed step 1 in fiber 0x7f60001570
CC 257 session 1 completed step 2 in fiber 0x7f60001570
CC 257 session 1 completed step 3 in fiber 0x7f60001570
CC 257 session 1 completed step 4 in fiber 0x7f60001570
CC 257 session 1 completed step 5 in fiber 0x7f60001570
CC 257 session 1 completed step 6 in fiber 0x7f60001570
CC 257 session 1 processing step 7 in fiber 0x7f60001570
FiberScheduler: cc 257, session 1, fiber 0x7f60001570 in progress…
Thread 7 is waiting
Thread 6 is waiting
FiberScheduler: cc 253, session 1, fiber 0x7f60001c80 succeeded async operation
Thread 9 is working on CC 253 session 1 globalID 1791 step 8
CC 253 session 1 completed step 8 in fiber 0x7f60001c80
CC 253 session 1 completed step 9 in fiber 0x7f60001c80
lux in Statsupdate: isAohdrEnable=0 currentSceneLux 120.350
CC 253 session 1 completed step 10 in fiber 0x7f60001c80
CC 253 session 1 completed step 11 in fiber 0x7f60001c80
CC 253 session 1 completed step 12 in fiber 0x7f60001c80
CC 253 session 1 completed step 13 in fiber 0x7f60001c80
AfAnalysis cc 253 push FK_ISP_RUN_NUMBER=153.
CC 253 session 1 completed step 14 in fiber 0x7f60001c80
CC 253 session 1 completed step 15 in fiber 0x7f60001c80
CC 253 session 1 completed step 16 in fiber 0x7f60001c80
CC 253 session 1 completed step 17 in fiber 0x7f60001c80
CC 253 session 1 completed step 18 in fiber 0x7f60001c80
CC 253 session 1 completed step 19 in fiber 0x7f60001c80
NvPHSSendThroughputHints: sensorId=1, m_usecase=4, m_type=20, m_value=3917146467, m_timeout_ms=1000
CC 253 session 1 completed step 20 in fiber 0x7f60001c80
FiberScheduler: cc 253, session 1, fiber 0x7f60001c80 complete
FiberScheduler: fiber 0x7f60001c80 exiting
disposing CC 253 Session 1
Thread 1 is waiting
Thread 9 is waiting
Created fiber 0x7f60001c80 for CC 258 globalID 1796 session 1
Thread 3 is working on CC 258 session 1 globalID 1796 step 0
CC 258 session 1 completed step 0 in fiber 0x7f60001c80
cc 258(158) session 1 runCount=157 runIspOut=153, latest ccId=253
CC 258 session 1 completed step 1 in fiber 0x7f60001c80
CC 258 session 1 completed step 2 in fiber 0x7f60001c80
CC 258 session 1 completed step 3 in fiber 0x7f60001c80
CC 258 session 1 completed step 4 in fiber 0x7f60001c80
CC 258 session 1 completed step 5 in fiber 0x7f60001c80
CC 258 session 1 completed step 6 in fiber 0x7f60001c80
CC 258 session 1 processing step 7 in fiber 0x7f60001c80
FiberScheduler: cc 258, session 1, fiber 0x7f60001c80 in progress…
Thread 3 is waiting
FiberScheduler: cc 254, session 1, fiber 0x7f600019d0 succeeded async operation
Thread 4 is working on CC 254 session 1 globalID 1792 step 8
CC 254 session 1 completed step 8 in fiber 0x7f600019d0
CC 254 session 1 completed step 9 in fiber 0x7f600019d0
lux in Statsupdate: isAohdrEnable=0 currentSceneLux 120.351
CC 254 session 1 completed step 10 in fiber 0x7f600019d0
CC 254 session 1 completed step 11 in fiber 0x7f600019d0
CC 254 session 1 completed step 12 in fiber 0x7f600019d0
CC 254 session 1 completed step 13 in fiber 0x7f600019d0
AfAnalysis cc 254 push FK_ISP_RUN_NUMBER=154.
CC 254 session 1 completed step 14 in fiber 0x7f600019d0
CC 254 session 1 completed step 15 in fiber 0x7f600019d0
CC 254 session 1 completed step 16 in fiber 0x7f600019d0
CC 254 session 1 completed step 17 in fiber 0x7f600019d0
CC 254 session 1 completed step 18 in fiber 0x7f600019d0
CC 254 session 1 completed step 19 in fiber 0x7f600019d0
PerfStatsStageStage[sensorId=1][cc=254], sensorStart_ms=18803077, captureDone_ms=18803097, now_ms=18803100, frameDuration_ms=23, framerate=43.5
NvPHSSendThroughputHints: sensorId=1, m_usecase=4, m_type=20, m_value=3919374725, m_timeout_ms=1000
CC 254 session 1 completed step 20 in fiber 0x7f600019d0
FiberScheduler: cc 254, session 1, fiber 0x7f600019d0 complete
FiberScheduler: fiber 0x7f600019d0 exiting
Thread 4 getting next capture
disposing CC 254 Session 1
Thread 4 is waiting
Thread 2 is waiting
Created fiber 0x7f60000ef0 for CC 259 globalID 1797 session 1
Thread 8 is working on CC 259 session 1 globalID 1797 step 0
CC 259 session 1 completed step 0 in fiber 0x7f60000ef0
cc 259(159) session 1 runCount=158 runIspOut=154, latest ccId=254
CC 259 session 1 completed step 1 in fiber 0x7f60000ef0
CC 259 session 1 completed step 2 in fiber 0x7f60000ef0
CC 259 session 1 completed step 3 in fiber 0x7f60000ef0
CC 259 session 1 completed step 4 in fiber 0x7f60000ef0
CC 259 session 1 completed step 5 in fiber 0x7f60000ef0
CC 259 session 1 completed step 6 in fiber 0x7f60000ef0
CC 259 session 1 processing step 7 in fiber 0x7f60000ef0
FiberScheduler: cc 259, session 1, fiber 0x7f60000ef0 in progress…
Thread 5 is waiting
Thread 8 is waiting
FiberScheduler: cc 255, session 1, fiber 0x7f600013d0 succeeded async operation
Thread 7 is working on CC 255 session 1 globalID 1793 step 8
CC 255 session 1 completed step 8 in fiber 0x7f600013d0
CC 255 session 1 completed step 9 in fiber 0x7f600013d0
lux in Statsupdate: isAohdrEnable=0 currentSceneLux 120.331
CC 255 session 1 completed step 10 in fiber 0x7f600013d0
CC 255 session 1 completed step 11 in fiber 0x7f600013d0
CC 255 session 1 completed step 12 in fiber 0x7f600013d0
CC 255 session 1 completed step 13 in fiber 0x7f600013d0
AfAnalysis cc 255 push FK_ISP_RUN_NUMBER=155.
CC 255 session 1 completed step 14 in fiber 0x7f600013d0
CC 255 session 1 completed step 15 in fiber 0x7f600013d0
CC 255 session 1 completed step 16 in fiber 0x7f600013d0
CC 255 session 1 completed step 17 in fiber 0x7f600013d0
CC 255 session 1 completed step 18 in fiber 0x7f600013d0
CC 255 session 1 completed step 19 in fiber 0x7f600013d0
NvPHSSendThroughputHints: sensorId=1, m_usecase=4, m_type=20, m_value=3921537446, m_timeout_ms=1000
CC 255 session 1 completed step 20 in fiber 0x7f600013d0
FiberScheduler: cc 255, session 1, fiber 0x7f600013d0 complete
disposing CC 255 Session 1
Thread 7 is waiting
Thread 6 is waiting
Created fiber 0x7f60001230 for CC 260 globalID 1798 session 1
Thread 1 is working on CC 260 session 1 globalID 1798 step 0
CC 260 session 1 completed step 0 in fiber 0x7f60001230
cc 260(160) session 1 runCount=159 runIspOut=155, latest ccId=255
CC 260 session 1 completed step 1 in fiber 0x7f60001230
CC 260 session 1 completed step 2 in fiber 0x7f60001230
CC 260 session 1 completed step 3 in fiber 0x7f60001230
CC 260 session 1 completed step 4 in fiber 0x7f60001230
CC 260 session 1 completed step 5 in fiber 0x7f60001230
CC 260 session 1 completed step 6 in fiber 0x7f60001230
CC 260 session 1 processing step 7 in fiber 0x7f60001230
FiberScheduler: cc 260, session 1, fiber 0x7f60001230 in progress…
Thread 9 is waiting
Thread 1 is waiting
FiberScheduler: cc 256, session 1, fiber 0x7f60002340 succeeded async operation
Thread 10 is working on CC 256 session 1 globalID 1794 step 8
CC 256 session 1 completed step 8 in fiber 0x7f60002340
CC 256 session 1 completed step 9 in fiber 0x7f60002340
lux in Statsupdate: isAohdrEnable=0 currentSceneLux 120.307
CC 256 session 1 completed step 10 in fiber 0x7f60002340
CC 256 session 1 completed step 11 in fiber 0x7f60002340
CC 256 session 1 completed step 12 in fiber 0x7f60002340
CC 256 session 1 completed step 13 in fiber 0x7f60002340
AfAnalysis cc 256 push FK_ISP_RUN_NUMBER=156.
CC 256 session 1 completed step 14 in fiber 0x7f60002340
CC 256 session 1 completed step 15 in fiber 0x7f60002340
CC 256 session 1 completed step 16 in fiber 0x7f60002340
CC 256 session 1 completed step 17 in fiber 0x7f60002340
CC 256 session 1 completed step 18 in fiber 0x7f60002340
CC 256 session 1 completed step 19 in fiber 0x7f60002340
NvPHSSendThroughputHints: sensorId=1, m_usecase=4, m_type=20, m_value=3923765703, m_timeout_ms=1000
CC 256 session 1 completed step 20 in fiber 0x7f60002340
FiberScheduler: cc 256, session 1, fiber 0x7f60002340 complete
disposing CC 256 Session 1
Thread 3 is waiting
Session 1 aborting capture 260 (API ID: 160)
Session 1 aborting capture 259 (API ID: 159)
Session 1 aborting capture 258 (API ID: 158)
Session 1 aborting capture 257 (API ID: 157)
CaptureService cancelling request 1696
FiberScheduler: cc 259, session 1, fiber 0x7f60000ef0 aborted in async operation
CaptureService cancelling request 1697
disposing CC 259 Session 1
Thread 4 is waiting
FiberScheduler: cc 260, session 1, fiber 0x7f60001230 aborted in async operation
Thread 2 is waiting
FiberScheduler: cc 257, session 1, fiber 0x7f60001570 succeeded async operation
Thread 5 is working on CC 257 session 1 globalID 1795 step 8
Fiber 0x7f60001570 is aborting in CC 257 Session 1
FiberScheduler: cc 257 session 1, fiber 0x7f60001570 aborted
disposing CC 257 Session 1
Thread 5 is waiting
Thread 8 is waiting
FiberScheduler: cc 258, session 1, fiber 0x7f60001c80 succeeded async operation
Thread 7 is working on CC 258 session 1 globalID 1796 step 8
Fiber 0x7f60001c80 is aborting in CC 258 Session 1
FiberScheduler: cc 258 session 1, fiber 0x7f60001c80 aborted
disposing CC 258 Session 1
Thread 6 is waiting
Thread 9 is waiting
Thread 7 is waiting
disposing CC 260 Session 1
=== gst-launch-1.0[26175]: CameraProvider destroyed (0x7fa5ffbd70)Stopping services…
unsubscribe: gyroscope sensor(0x7fa5b6c630)
unsubscribe: accelerometer sensor(0x7fa5b71b90)
=== gst-launch-1.0[26175]: Connection closed (7FAB50C1D0)=== gst-launch-1.0[26175]: Connection cleaned up (7FAB50C1D0)=== gst-launch-1.0[26257]: Connection established (7FAB50C1D0)Thread 1 getting next capture
Thread 1 is waiting
Thread 2 is waiting
Thread 3 is waiting
Thread 4 is waiting
Thread 5 is waiting
Thread 6 is waiting
Thread 7 is waiting
Thread 8 is waiting
Thread 9 is waiting
Thread 10 is waiting
Starting services…
Worker thread IspHw statsComplete start
Worker thread IspHw frameComplete start
Worker thread CaptureScheduler checkFramePending start
Worker thread CaptureScheduler frameStart start
Worker thread V4L2CaptureScheduler checkCaptureComplete start
Worker thread V4L2CaptureScheduler issueCaptures start
Worker thread PS handleRequests start
getInstance: s_instance(0x7fa4e93d00)
subscribe: create SensorType(gyroscope) sensor(0x7fa4e928f0)
subscribe: create SensorType(accelerometer) sensor(0x7fa4e97f70)
AC plugin not present: dlopen “acplugin.so”, acplugin.so: cannot open shared object file: No such file or directory
Services are started
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module1
OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
---- imager: No override file found. ----
LSC: LSC surface is not based on full res!
=== gst-launch-1.0[26257]: CameraProvider initialized (0x7fa4ef21a0)sourceRegistry[1] assigned
ispRegistry[0] assigned
Using Source GUID 0
Worker thread ViCsiHw frameComplete start
Worker thread ViCsiHw frameStart start
Using ISP A
NvPHSSendThroughputHints: sensorId=0, m_usecase=4, m_type=2, m_value=4294967295, m_timeout_ms=1000
No library found, disabling AC plugin.
Worker thread CaptureDispatcher start
Session::updatePerfHints()
updatePerfHints(): guid=0ll, CaptureIntent=1
updatePerfHints(): NvCameraCoreUseCase_Preview
NvPHSSendThroughputHints: sensorId=0, m_usecase=4, m_type=1, m_value=30, m_timeout_ms=1000
NvPHSSendThroughputHints: sensorId=0, m_usecase=4, m_type=15, m_value=0, m_timeout_ms=1000
No output buffers for 2
InstructionList:
  • GraphSettings
    | SensorMode: 1920x1080 BayerS16RGGB 30.0fps
    | output 0: 1920x1080 BL U8_V8_ER 420SP
    | inputClipRect 0: (0.00,0.00, 1.00,1.00)
  • Instruction List
    • 0: CCDataSetupStage
      | EstimatedIspOutLatencyFrames: 5
      | NumConcurrentCaptures: 1
      | UnprocessedYuvBufferMask: 0
    • 1: ACSynchronizeStage
    • 2: AeAfApplyStage
    • 3: AcPluginStage
      | operation: opApply
    • 4: AcMergeStage
      | IspIn: [1920, 1080]
      | IspOut0: [1920, 1080]
      | IspOut1: [0, 0]
      | IspOut2: [0, 0]
    • 5: TempBufferAcquireStage
      | Buffer Index: 2
      | BufferRequirements: 1920x1 Pitch NonColor8
    • 6: TempBufferAcquireStage
      | Buffer Index: 3
      | BufferRequirements: 524288x1 Pitch NonColor8
    • 7: SensorISPCaptureStage
      | Source GUID: 0
      | Output A Buffer: 0
      | SensorMetadata Buffer: 2
      | Output IspStats Buffer: 3
    • 8: StatsBufferAcquireStage
      | Buffer Index: 1
      | BufferRequirements: 640x360 Pitch Y8_ER 420
    • 9: BlitStage
      | Input Buffer: 0
      | Output Buffer: 1
      | Filter: Nearest
      | Transform: None
      | Src Rect: Not used
      | Dst Rect: Not used
    • 10: StatsUpdateStage
      | Output Meta Buffer: 2
    • 11: BufferReturnStage
      | Output A Buffer: 2
    • 12: BufferReturnStage
      | Output A Buffer: 3
    • 13: AcPluginStage
      | operation: opAnalyze
    • 14: AfAnalysisStage
    • 15: MonitorStage
    • 16: ExifStage
    • 17: MakerNoteStage
    • 18: BufferReturnStage
      | Output A Buffer: 0
    • 19: MetadataReturnStage
    • 20: PerfStatsStage
Created fiber 0x7f5c000b50 for CC 101 globalID 1799 session 0
Thread 1 is working on CC 101 session 0 globalID 1799 step 0
CC 101 session 0 completed step 0 in fiber 0x7f5c000b50
cc 101(1) session 0 runCount=0 runIspOut=0, latest ccId=0
CC 101 session 0 completed step 1 in fiber 0x7f5c000b50
NV AE and AfApply algorithms are active.
CC 101 session 0 completed step 2 in fiber 0x7f5c000b50
CC 101 session 0 completed step 3 in fiber 0x7f5c000b50
CC 101 session 0 completed step 4 in fiber 0x7f5c000b50
CC 101 session 0 completed step 5 in fiber 0x7f5c000b50
CC 101 session 0 completed step 6 in fiber 0x7f5c000b50
CC 101 session 0 processing step 7 in fiber 0x7f5c000b50
FiberScheduler: cc 101, session 0, fiber 0x7f5c000b50 in progress…
Thread 2 is waiting
Thread 1 is waiting
Created fiber 0x7f5c012730 for CC 102 globalID 1800 session 0
Thread 3 is working on CC 102 session 0 globalID 1800 step 0
CC 102 session 0 completed step 0 in fiber 0x7f5c012730
cc 102(2) session 0 runCount=1 runIspOut=0, latest ccId=0
CC 102 session 0 completed step 1 in fiber 0x7f5c012730
CC 102 session 0 completed step 2 in fiber 0x7f5c012730
CC 102 session 0 completed step 3 in fiber 0x7f5c012730
CC 102 session 0 completed step 4 in fiber 0x7f5c012730
CC 102 session 0 completed step 5 in fiber 0x7f5c012730
CC 102 session 0 completed step 6 in fiber 0x7f5c012730
CC 102 session 0 processing step 7 in fiber 0x7f5c012730
FiberScheduler: cc 102, session 0, fiber 0x7f5c012730 in progress…
Thread 4 is waiting
Session::updatePerfHints()Thread 3 is waiting
PowerServiceHw:addRequest: table size: before: 0, after:1
request table for ISP 0:
req[0]: output1 width=0, output1 height=0, output1 Bpp=0
req[0]: output2 width=0, output2 height=0, output2 Bpp=0
req[0]: input width=1920, input height=1080, input Bpp=10
req[0]: output width=130, output height=74, output Bpp=16
req[0]: input fps=30
req[0]: guID=0, stage type=SensorIspCapture
req[0]: clock=0 Hz, iso bw=39481 KB/s, non-iso bw=0 KB/s
req[450]: timeout=0
PowerServiceHwIsp:setLaBw: m_bwVal_Iso=39481 and m_bwVal_NonIso=0 KBpS
PowerServiceCore:setCameraBw: totalIsoBw=39481
PowerServiceHw:addRequest: table size: before: 1, after:2
req[416]: timeout=0
req[1]: output1 width=0, output1 height=0, output1 Bpp=0
req[1]: output2 width=0, output2 height=0, output2 Bpp=0
req[1]: input width=1920, input height=1080, input Bpp=10
req[1]: output width=1920, output height=1080, output Bpp=12
req[1]: input fps=30
req[1]: guID=0, stage type=SensorIspCapture
req[1]: clock=0 Hz, iso bw=371610 KB/s, non-iso bw=0 KB/s
req[450]: timeout=0
PowerServiceHw:updateRequests: table size: before: 2, after:2
req[415]: timeout=0
req[449]: timeout=0
PowerServiceHwIsp:setLaBw: m_bwVal_Iso=371610 and m_bwVal_NonIso=0 KBpS
PowerServiceCore:setCameraBw: totalIsoBw=371610
SCF: Error Timeout: ISP port 0 timed out! (in src/services/capture/NvIspHw.cpp, function waitIspFrameEnd(), line 478)
SCF: Error Timeout: (propagating from src/services/capture/NvIspHw.cpp, function waitIspFrameEnd(), line 524)
SCF: Error Timeout: (propagating from src/common/Utils.cpp, function workerThread(), line 116)
SCF: Error Timeout: Worker thread IspHw frameComplete failed (in src/common/Utils.cpp, function workerThread(), line 133)
SCF: Error Timeout: ISP Stats timed out! (in src/services/capture/NvIspHw.cpp, function waitIspStatsFinished(), line 566)
FiberScheduler: cc 101, session 0, fiber 0x7f5c000b50 aborted in async operation
FiberScheduler: fiber 0x7f5c000b50 exiting
disposing CC 101 Session 0
CaptureService cancelling request 1699
Thread 5 is waiting
FiberScheduler: cc 102, session 0, fiber 0x7f5c012730 aborted in async operation
FiberScheduler: fiber 0x7f5c012730 exiting
disposing CC 102 Session 0
Thread 6 is waiting
Error: waitCsiFrameStart timeout guid 0
**VI/CSI Debug Registers
VI_CFG_INTERRUPT_MASK_0 = 0x00000000
VI_CFG_INTERRUPT_STATUS_0 = 0x00000000
VI_CSI_0_ERROR_STATUS_0 = 0x00000000
VI_CSI_0_ERROR_INT_MASK_0 = 0x00000000
VI_CSI_1_ERROR_STATUS_0 = 0x00000000
VI_CSI_1_ERROR_INT_MASK_0 = 0x00000000
CSI_CSI_PIXEL_PARSER_A_INTERRUPT_MASK_0 = 0x00000000
CSI_CSI_PIXEL_PARSER_A_STATUS_0 = 0x00000000
CSI_CSI_PIXEL_PARSER_B_INTERRUPT_MASK_0 = 0x00000000
CSI_CSI_PIXEL_PARSER_B_STATUS_0 = 0x00000000
CSI_CSI_CIL_A_INTERRUPT_MASK_0 = 0x00000000
CSI_CSI_CIL_A_STATUS_0 = 0x00000000
CSI_CSI_CILA_STATUS_0 = 0x00000000
CSI_CSI_CIL_B_INTERRUPT_MASK_0 = 0x00000000
CSI_CSI_CIL_B_STATUS_0 = 0x00000000
CSI_CSI_CILB_STATUS_0 = 0x00000000
CSI_CSI_READONLY_STATUS_0 = 0x00000000
CSI_DEBUG_CONTROL_0 = 0x360d5000
CSI_DEBUG_COUNTER_0_0 = 0x00000000
CSI_DEBUG_COUNTER_1_0 = 0x00000000
CSI_DEBUG_COUNTER_2_0 = 0x00000000
Created fiber 0x7f5c01ee70 for CC 103 globalID 1801 session 0
Thread 7 is working on CC 103 session 0 globalID 1801 step 0
CC 103 session 0 completed step 0 in fiber 0x7f5c01ee70
cc 103(3) session 0 runCount=2 runIspOut=0, latest ccId=0
CC 103 session 0 completed step 1 in fiber 0x7f5c01ee70
CC 103 session 0 completed step 2 in fiber 0x7f5c01ee70
CC 103 session 0 completed step 3 in fiber 0x7f5c01ee70
CC 103 session 0 completed step 4 in fiber 0x7f5c01ee70
CC 103 session 0 completed step 5 in fiber 0x7f5c01ee70
CC 103 session 0 completed step 6 in fiber 0x7f5c01ee70
SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceDeviceIsp.cpp, function waitCompletion(), line 423)
SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceDevice.cpp, function pause(), line 949)
SCF: Error Timeout: During capture abort, syncpoint wait timeout waiting for current frame to finish (in src/services/capture/CaptureServiceDevice.cpp, function handleCancelSourceRequests(), line 1032)
Error: waitCsiFrameStart timeout guid 0CC 103 session 0 processing step 7 in fiber 0x7f5c01ee70
FiberScheduler: cc 103, session 0, fiber 0x7f5c01ee70 in progress…
Thread 7 getting next capture
Thread 8 is waiting
Thread 7 is waiting
Created fiber 0x7f5c01ee30 for CC 104 globalID 1802 session 0
PowerServiceCore:handleRequests: timePassed = 3022
Session 0 aborting capture 104 (API ID: 4)
Session 0 aborting capture 103 (API ID: 3)
Thread 9 is working on CC 104 session 0 globalID 1802 step 0
Fiber 0x7f5c01ee30 is aborting in CC 104 Session 0
FiberScheduler: cc 104 session 0, fiber 0x7f5c01ee30 aborted
FiberScheduler: fiber 0x7f5c01ee30 exiting
Thread 9 getting next capture
Thread 9 is waiting
SCF: Error Timeout: Sending critical error event (in src/api/Session.cpp, function sendErrorEvent(), line 997)
SCF: Error BadParameter: CC has already been disposed (in src/components/CaptureContainerManager.cpp, function dispose(), line 161)
root@jetson-liam:/usr/src/jetson_multimedia_api/samples/10_camera_recording#
Did you try v4l2-ctl on video1?
Yes, but I got nothing
jetson@jetson-liam:~$ v4l2-ctl --device=/dev/video1 --set-fmt-video=width=3264,height=2464,pixelformat=RG10 --set-ctrl bypass_mode=0 --stream-mmap
^C
Try reconnected this sensor and make sure v4l2-ctl working first.
Hi Shane
I got both cameras working now:
<<<<<<<<<<<<<<<<<<<<<<< 21.35 fps
<<<<<<<<<<<<<<<<<<<<< 21.28 fps
<<<<<<<<<<<<<<<<<<<<< 21.19 fps
<<<<<<<<<<<<^C
jetson@jetson-liam:~$ v4l2-ctl --device=/dev/video0 --set-fmt-video=width=3264,height=2464,pixelformat=RG10 --set-ctrl bypass_mode=0 --stream-mmap
<<<<<<<<<<<<<<<<<<<<< 21.26 fps
<<<^C
I followed your advice. Now both cameras worked as I could see both streams. Thank you so much for your help!
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected…
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3264 x 2464 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3264 x 1848 FR = 28.000001 fps Duration = 35714284 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1640 x 1232 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 120.000005 fps Duration = 8333333 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 2
Output Stream W = 1920 H = 1080
seconds to Run = 0
Frame Rate = 29.999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
^Chandling interrupt.
Interrupt: Stopping pipeline …
Execution ended after 0:00:11.327539631
GST_ARGUS: Cleaning up
CONSUMER: Done Success
GST_ARGUS: Done Success
Freeing pipeline …
Camera index = 1
Camera mode = 2
seconds to Run = 0
Execution ended after 0:00:14.359900411
Freeing pipeline …
on other terminal:
Thread 5 is waiting
Thread 2 is waiting
Created fiber 0x7f14001f30 for CC 511 globalID 846 session 0
Thread 4 is working on CC 511 session 0 globalID 846 step 0
CC 511 session 0 completed step 0 in fiber 0x7f14001f30
cc 511(411) session 0 runCount=410 runIspOut=406, latest ccId=506
AC Stats Delay Count:5
CC 511 session 0 completed step 1 in fiber 0x7f14001f30
CC 511 session 0 completed step 2 in fiber 0x7f14001f30
CC 511 session 0 completed step 3 in fiber 0x7f14001f30
CC 511 session 0 completed step 4 in fiber 0x7f14001f30
CC 511 session 0 completed step 5 in fiber 0x7f14001f30
CC 511 session 0 completed step 6 in fiber 0x7f14001f30
CC 511 session 0 processing step 7 in fiber 0x7f14001f30
FiberScheduler: cc 511, session 0, fiber 0x7f14001f30 in progress…
Thread 9 is waiting
Thread 4 is waiting
FiberScheduler: cc 507, session 0, fiber 0x7f14001c30 succeeded async operation
Thread 6 is working on CC 507 session 0 globalID 842 step 8
CC 507 session 0 completed step 8 in fiber 0x7f14001c30
CC 507 session 0 completed step 9 in fiber 0x7f14001c30
exposureTime=0.030000 analogGain=2.607978 digitalGain=1.000000 commonGain=0.078239 expComp=1.000000
lux in Statsupdate: isAohdrEnable=0 currentSceneLux 119.874
CC 507 session 0 completed step 10 in fiber 0x7f14001c30
CC 507 session 0 completed step 11 in fiber 0x7f14001c30
CC 507 session 0 completed step 12 in fiber 0x7f14001c30
CC 507 session 0 completed step 13 in fiber 0x7f14001c30
NV AF analysis algorithm is active.
AfAnalysis cc 507 push FK_ISP_RUN_NUMBER=407.
CC 507 session 0 completed step 14 in fiber 0x7f14001c30
CC 507 session 0 completed step 15 in fiber 0x7f14001c30
CC 507 session 0 completed step 16 in fiber 0x7f14001c30
CC 507 session 0 completed step 17 in fiber 0x7f14001c30
CC 507 session 0 completed step 18 in fiber 0x7f14001c30
CC 507 session 0 completed step 19 in fiber 0x7f14001c30
NvPHSSendThroughputHints: sensorId=0, m_usecase=4, m_type=20, m_value=1209878534, m_timeout_ms=1000
CC 507 session 0 completed step 20 in fiber 0x7f14001c30
FiberScheduler: cc 507, session 0, fiber 0x7f14001c30 complete
FiberScheduler: fiber 0x7f14001c30 exiting
Thread 6 getting next capture
disposing CC 507 Session 0
Thread 6 is waiting
Created fiber 0x7f14000f70 for CC 512 globalID 847 session 0
Thread 1 is working on CC 512 session 0 globalID 847 step 0
CC 512 session 0 completed step 0 in fiber 0x7f14000f70
cc 512(412) session 0 runCount=411 runIspOut=407, latest ccId=507
CC 512 session 0 completed step 1 in fiber 0x7f14000f70
CC 512 session 0 completed step 2 in fiber 0x7f14000f70
CC 512 session 0 completed step 3 in fiber 0x7f14000f70
CC 512 session 0 completed step 4 in fiber 0x7f14000f70
CC 512 session 0 completed step 5 in fiber 0x7f14000f70
CC 512 session 0 completed step 6 in fiber 0x7f14000f70
CC 512 session 0 processing step 7 in fiber 0x7f14000f70
FiberScheduler: cc 512, session 0, fiber 0x7f14000f70 in progress…
Thread 1 is waiting
Thread 8 is waiting
FiberScheduler: cc 508, session 0, fiber 0x7f14002060 succeeded async operation
Thread 3 is working on CC 508 session 0 globalID 843 step 8
CC 508 session 0 completed step 8 in fiber 0x7f14002060
CC 508 session 0 completed step 9 in fiber 0x7f14002060
lux in Statsupdate: isAohdrEnable=0 currentSceneLux 119.868
CC 508 session 0 completed step 10 in fiber 0x7f14002060
CC 508 session 0 completed step 11 in fiber 0x7f14002060
CC 508 session 0 completed step 12 in fiber 0x7f14002060
CC 508 session 0 completed step 13 in fiber 0x7f14002060
AfAnalysis cc 508 push FK_ISP_RUN_NUMBER=408.
CC 508 session 0 completed step 14 in fiber 0x7f14002060
CC 508 session 0 completed step 15 in fiber 0x7f14002060
CC 508 session 0 completed step 16 in fiber 0x7f14002060
CC 508 session 0 completed step 17 in fiber 0x7f14002060
CC 508 session 0 completed step 18 in fiber 0x7f14002060
CC 508 session 0 completed step 19 in fiber 0x7f14002060
NvPHSSendThroughputHints: sensorId=0, m_usecase=4, m_type=20, m_value=1212106791, m_timeout_ms=1000
CC 508 session 0 completed step 20 in fiber 0x7f14002060
FiberScheduler: cc 508, session 0, fiber 0x7f14002060 complete
FiberScheduler: fiber 0x7f14002060 exiting
Thread 3 getting next capturedisposing CC 508 Session 0
Thread 7 is waiting
Thread 3 is waiting
Created fiber 0x7f140015f0 for CC 513 globalID 848 session 0
Thread 5 is working on CC 513 session 0 globalID 848 step 0
CC 513 session 0 completed step 0 in fiber 0x7f140015f0
cc 513(413) session 0 runCount=412 runIspOut=408, latest ccId=508
CC 513 session 0 completed step 1 in fiber 0x7f140015f0
CC 513 session 0 completed step 2 in fiber 0x7f140015f0
CC 513 session 0 completed step 3 in fiber 0x7f140015f0
CC 513 session 0 completed step 4 in fiber 0x7f140015f0
CC 513 session 0 completed step 5 in fiber 0x7f140015f0
CC 513 session 0 completed step 6 in fiber 0x7f140015f0
CC 513 session 0 processing step 7 in fiber 0x7f140015f0
FiberScheduler: cc 513, session 0, fiber 0x7f140015f0 in progress…
Thread 5 getting next capture
Thread 2 is waiting
Thread 5 is waiting
FiberScheduler: cc 509, session 0, fiber 0x7f14000b20 succeeded async operation
Thread 9 is working on CC 509 session 0 globalID 844 step 8
CC 509 session 0 completed step 8 in fiber 0x7f14000b20
CC 509 session 0 completed step 9 in fiber 0x7f14000b20
lux in Statsupdate: isAohdrEnable=0 currentSceneLux 119.815
CC 509 session 0 completed step 10 in fiber 0x7f14000b20
CC 509 session 0 completed step 11 in fiber 0x7f14000b20
CC 509 session 0 completed step 12 in fiber 0x7f14000b20
CC 509 session 0 completed step 13 in fiber 0x7f14000b20
AfAnalysis cc 509 push FK_ISP_RUN_NUMBER=409.
CC 509 session 0 completed step 14 in fiber 0x7f14000b20
CC 509 session 0 completed step 15 in fiber 0x7f14000b20
CC 509 session 0 completed step 16 in fiber 0x7f14000b20
CC 509 session 0 completed step 17 in fiber 0x7f14000b20
CC 509 session 0 completed step 18 in fiber 0x7f14000b20
CC 509 session 0 completed step 19 in fiber 0x7f14000b20
NvPHSSendThroughputHints: sensorId=0, m_usecase=4, m_type=20, m_value=1214269513, m_timeout_ms=1000
CC 509 session 0 completed step 20 in fiber 0x7f14000b20
FiberScheduler: cc 509, session 0, fiber 0x7f14000b20 complete
FiberScheduler: fiber 0x7f14000b20 exiting
disposing CC 509 Session 0
Thread 9 is waiting
Thread 4 is waiting
Created fiber 0x7f14000b20 for CC 514 globalID 849 session 0
Thread 12 is working on CC 514 session 0 globalID 849 step 0
CC 514 session 0 completed step 0 in fiber 0x7f14000b20
cc 514(414) session 0 runCount=413 runIspOut=409, latest ccId=509
CC 514 session 0 completed step 1 in fiber 0x7f14000b20
CC 514 session 0 completed step 2 in fiber 0x7f14000b20
CC 514 session 0 completed step 3 in fiber 0x7f14000b20
CC 514 session 0 completed step 4 in fiber 0x7f14000b20
CC 514 session 0 completed step 5 in fiber 0x7f14000b20
CC 514 session 0 completed step 6 in fiber 0x7f14000b20
CC 514 session 0 processing step 7 in fiber 0x7f14000b20
FiberScheduler: cc 514, session 0, fiber 0x7f14000b20 in progress…
Thread 12 getting next capture
Thread 6 is waiting
FiberScheduler: cc 510, session 0, fiber 0x7f14001790 succeeded async operation
Thread 1 is working on CC 510 session 0 globalID 845 step 8
CC 510 session 0 completed step 8 in fiber 0x7f14001790
CC 510 session 0 completed step 9 in fiber 0x7f14001790
lux in Statsupdate: isAohdrEnable=0 currentSceneLux 119.858
CC 510 session 0 completed step 10 in fiber 0x7f14001790
CC 510 session 0 completed step 11 in fiber 0x7f14001790
CC 510 session 0 completed step 12 in fiber 0x7f14001790
CC 510 session 0 completed step 13 in fiber 0x7f14001790
AfAnalysis cc 510 push FK_ISP_RUN_NUMBER=410.
CC 510 session 0 completed step 14 in fiber 0x7f14001790
CC 510 session 0 completed step 15 in fiber 0x7f14001790
CC 510 session 0 completed step 16 in fiber 0x7f14001790
CC 510 session 0 completed step 17 in fiber 0x7f14001790
CC 510 session 0 completed step 18 in fiber 0x7f14001790
CC 510 session 0 completed step 19 in fiber 0x7f14001790
NvPHSSendThroughputHints: sensorId=0, m_usecase=4, m_type=20, m_value=1216432234, m_timeout_ms=1000
CC 510 session 0 completed step 20 in fiber 0x7f14001790
FiberScheduler: cc 510, session 0, fiber 0x7f14001790 complete
FiberScheduler: fiber 0x7f14001790 exiting
Thread 1 getting next capturedisposing CC 510 Session 0
Thread 8 is waiting
Thread 1 is waiting
Created fiber 0x7f14001a90 for CC 515 globalID 850 session 0
Thread 7 is working on CC 515 session 0 globalID 850 step 0
CC 515 session 0 completed step 0 in fiber 0x7f14001a90
cc 515(415) session 0 runCount=414 runIspOut=410, latest ccId=510
CC 515 session 0 completed step 1 in fiber 0x7f14001a90
CC 515 session 0 completed step 2 in fiber 0x7f14001a90
CC 515 session 0 completed step 3 in fiber 0x7f14001a90
CC 515 session 0 completed step 4 in fiber 0x7f14001a90
CC 515 session 0 completed step 5 in fiber 0x7f14001a90
CC 515 session 0 completed step 6 in fiber 0x7f14001a90
CC 515 session 0 processing step 7 in fiber 0x7f14001a90
FiberScheduler: cc 515, session 0, fiber 0x7f14001a90 in progress…
Thread 7 is waiting
Thread 3 is waiting
FiberScheduler: cc 511, session 0, fiber 0x7f14001f30 succeeded async operation
Thread 2 is working on CC 511 session 0 globalID 846 step 8
CC 511 session 0 completed step 8 in fiber 0x7f14001f30
CC 511 session 0 completed step 9 in fiber 0x7f14001f30
lux in Statsupdate: isAohdrEnable=0 currentSceneLux 119.820
CC 511 session 0 completed step 10 in fiber 0x7f14001f30
CC 511 session 0 completed step 11 in fiber 0x7f14001f30
CC 511 session 0 completed step 12 in fiber 0x7f14001f30
CC 511 session 0 completed step 13 in fiber 0x7f14001f30
AfAnalysis cc 511 push FK_ISP_RUN_NUMBER=411.
CC 511 session 0 completed step 14 in fiber 0x7f14001f30
CC 511 session 0 completed step 15 in fiber 0x7f14001f30
CC 511 session 0 completed step 16 in fiber 0x7f14001f30
CC 511 session 0 completed step 17 in fiber 0x7f14001f30
CC 511 session 0 completed step 18 in fiber 0x7f14001f30
CC 511 session 0 completed step 19 in fiber 0x7f14001f30
NvPHSSendThroughputHints: sensorId=0, m_usecase=4, m_type=20, m_value=1218660491, m_timeout_ms=1000
CC 511 session 0 completed step 20 in fiber 0x7f14001f30
FiberScheduler: cc 511, session 0, fiber 0x7f14001f30 complete
FiberScheduler: fiber 0x7f14001f30 exiting
Thread 2 getting next capture
disposing CC 511 Session 0
Thread 5 is waiting
Thread 9 is waiting
Thread 2 is waiting
Created fiber 0x7f14001110 for CC 516 globalID 851 session 0
Thread 11 is working on CC 516 session 0 globalID 851 step 0
CC 516 session 0 completed step 0 in fiber 0x7f14001110
cc 516(416) session 0 runCount=415 runIspOut=411, latest ccId=511
CC 516 session 0 completed step 1 in fiber 0x7f14001110
CC 516 session 0 completed step 2 in fiber 0x7f14001110
CC 516 session 0 completed step 3 in fiber 0x7f14001110
CC 516 session 0 completed step 4 in fiber 0x7f14001110
CC 516 session 0 completed step 5 in fiber 0x7f14001110
CC 516 session 0 completed step 6 in fiber 0x7f14001110
CC 516 session 0 processing step 7 in fiber 0x7f14001110
FiberScheduler: cc 516, session 0, fiber 0x7f14001110 in progress…
Thread 11 getting next capture
Thread 4 is waiting
FiberScheduler: cc 512, session 0, fiber 0x7f14000f70 succeeded async operation
Thread 6 is working on CC 512 session 0 globalID 847 step 8
CC 512 session 0 completed step 8 in fiber 0x7f14000f70
CC 512 session 0 completed step 9 in fiber 0x7f14000f70
lux in Statsupdate: isAohdrEnable=0 currentSceneLux 119.857
CC 512 session 0 completed step 10 in fiber 0x7f14000f70
CC 512 session 0 completed step 11 in fiber 0x7f14000f70
CC 512 session 0 completed step 12 in fiber 0x7f14000f70
CC 512 session 0 completed step 13 in fiber 0x7f14000f70
AfAnalysis cc 512 push FK_ISP_RUN_NUMBER=412.
CC 512 session 0 completed step 14 in fiber 0x7f14000f70
CC 512 session 0 completed step 15 in fiber 0x7f14000f70
CC 512 session 0 completed step 16 in fiber 0x7f14000f70
CC 512 session 0 completed step 17 in fiber 0x7f14000f70
CC 512 session 0 completed step 18 in fiber 0x7f14000f70
CC 512 session 0 completed step 19 in fiber 0x7f14000f70
NvPHSSendThroughputHints: sensorId=0, m_usecase=4, m_type=20, m_value=1220888749, m_timeout_ms=1000
CC 512 session 0 completed step 20 in fiber 0x7f14000f70
FiberScheduler: cc 512, session 0, fiber 0x7f14000f70 complete
FiberScheduler: fiber 0x7f14000f70 exiting
disposing CC 512 Session 0
Thread 12 is waiting
Thread 6 is waiting
Created fiber 0x7f14001450 for CC 517 globalID 852 session 0
Thread 8 is working on CC 517 session 0 globalID 852 step 0
CC 517 session 0 completed step 0 in fiber 0x7f14001450
cc 517(417) session 0 runCount=416 runIspOut=412, latest ccId=512
CC 517 session 0 completed step 1 in fiber 0x7f14001450
CC 517 session 0 completed step 2 in fiber 0x7f14001450
CC 517 session 0 completed step 3 in fiber 0x7f14001450
CC 517 session 0 completed step 4 in fiber 0x7f14001450
CC 517 session 0 completed step 5 in fiber 0x7f14001450
CC 517 session 0 completed step 6 in fiber 0x7f14001450
CC 517 session 0 processing step 7 in fiber 0x7f14001450
FiberScheduler: cc 517, session 0, fiber 0x7f14001450 in progress…
Thread 8 is waiting
Thread 1 is waiting
FiberScheduler: cc 513, session 0, fiber 0x7f140015f0 succeeded async operation
Thread 7 is working on CC 513 session 0 globalID 848 step 8
CC 513 session 0 completed step 8 in fiber 0x7f140015f0
CC 513 session 0 completed step 9 in fiber 0x7f140015f0
lux in Statsupdate: isAohdrEnable=0 currentSceneLux 119.821
CC 513 session 0 completed step 10 in fiber 0x7f140015f0
CC 513 session 0 completed step 11 in fiber 0x7f140015f0
CC 513 session 0 completed step 12 in fiber 0x7f140015f0
CC 513 session 0 completed step 13 in fiber 0x7f140015f0
AfAnalysis cc 513 push FK_ISP_RUN_NUMBER=413.
CC 513 session 0 completed step 14 in fiber 0x7f140015f0
CC 513 session 0 completed step 15 in fiber 0x7f140015f0
CC 513 session 0 completed step 16 in fiber 0x7f140015f0
CC 513 session 0 completed step 17 in fiber 0x7f140015f0
CC 513 session 0 completed step 18 in fiber 0x7f140015f0
CC 513 session 0 completed step 19 in fiber 0x7f140015f0
NvPHSSendThroughputHints: sensorId=0, m_usecase=4, m_type=20, m_value=1222985934, m_timeout_ms=1000
CC 513 session 0 completed step 20 in fiber 0x7f140015f0
FiberScheduler: cc 513, session 0, fiber 0x7f140015f0 complete
FiberScheduler: fiber 0x7f140015f0 exiting
disposing CC 513 Session 0
Thread 3 is waiting
Thread 5 is waiting
Thread 7 is waiting
Created fiber 0x7f140012b0 for CC 518 globalID 853 session 0
Thread 9 is working on CC 518 session 0 globalID 853 step 0
CC 518 session 0 completed step 0 in fiber 0x7f140012b0
cc 518(418) session 0 runCount=417 runIspOut=413, latest ccId=513
CC 518 session 0 completed step 1 in fiber 0x7f140012b0
CC 518 session 0 completed step 2 in fiber 0x7f140012b0
CC 518 session 0 completed step 3 in fiber 0x7f140012b0
CC 518 session 0 completed step 4 in fiber 0x7f140012b0
CC 518 session 0 completed step 5 in fiber 0x7f140012b0
CC 518 session 0 completed step 6 in fiber 0x7f140012b0
CC 518 session 0 processing step 7 in fiber 0x7f140012b0
FiberScheduler: cc 518, session 0, fiber 0x7f140012b0 in progress…
Thread 2 is waiting
Thread 9 is waiting
FiberScheduler: cc 514, session 0, fiber 0x7f14000b20 succeeded async operation
Thread 4 is working on CC 514 session 0 globalID 849 step 8
CC 514 session 0 completed step 8 in fiber 0x7f14000b20
CC 514 session 0 completed step 9 in fiber 0x7f14000b20
lux in Statsupdate: isAohdrEnable=0 currentSceneLux 119.848
CC 514 session 0 completed step 10 in fiber 0x7f14000b20
CC 514 session 0 completed step 11 in fiber 0x7f14000b20
CC 514 session 0 completed step 12 in fiber 0x7f14000b20
CC 514 session 0 completed step 13 in fiber 0x7f14000b20
AfAnalysis cc 514 push FK_ISP_RUN_NUMBER=414.
CC 514 session 0 completed step 14 in fiber 0x7f14000b20
CC 514 session 0 completed step 15 in fiber 0x7f14000b20
CC 514 session 0 completed step 16 in fiber 0x7f14000b20
CC 514 session 0 completed step 17 in fiber 0x7f14000b20
CC 514 session 0 completed step 18 in fiber 0x7f14000b20
CC 514 session 0 completed step 19 in fiber 0x7f14000b20
NvPHSSendThroughputHints: sensorId=0, m_usecase=4, m_type=20, m_value=1225214191, m_timeout_ms=1000
CC 514 session 0 completed step 20 in fiber 0x7f14000b20
FiberScheduler: cc 514, session 0, fiber 0x7f14000b20 complete
disposing CC 514 Session 0
Thread 4 is waiting
Created fiber 0x7f14001c30 for CC 519 globalID 854 session 0
Thread 12 is working on CC 519 session 0 globalID 854 step 0
CC 519 session 0 completed step 0 in fiber 0x7f14001c30
cc 519(419) session 0 runCount=418 runIspOut=414, latest ccId=514
CC 519 session 0 completed step 1 in fiber 0x7f14001c30
CC 519 session 0 completed step 2 in fiber 0x7f14001c30
CC 519 session 0 completed step 3 in fiber 0x7f14001c30
CC 519 session 0 completed step 4 in fiber 0x7f14001c30
CC 519 session 0 completed step 5 in fiber 0x7f14001c30
CC 519 session 0 completed step 6 in fiber 0x7f14001c30
CC 519 session 0 processing step 7 in fiber 0x7f14001c30
FiberScheduler: cc 519, session 0, fiber 0x7f14001c30 in progress…
Thread 6 is waiting
FiberScheduler: cc 515, session 0, fiber 0x7f14001a90 succeeded async operation
Thread 8 is working on CC 515 session 0 globalID 850 step 8
CC 515 session 0 completed step 8 in fiber 0x7f14001a90
CC 515 session 0 completed step 9 in fiber 0x7f14001a90
lux in Statsupdate: isAohdrEnable=0 currentSceneLux 119.835
CC 515 session 0 completed step 10 in fiber 0x7f14001a90
CC 515 session 0 completed step 11 in fiber 0x7f14001a90
CC 515 session 0 completed step 12 in fiber 0x7f14001a90
CC 515 session 0 completed step 13 in fiber 0x7f14001a90
AfAnalysis cc 515 push FK_ISP_RUN_NUMBER=415.
CC 515 session 0 completed step 14 in fiber 0x7f14001a90
CC 515 session 0 completed step 15 in fiber 0x7f14001a90
CC 515 session 0 completed step 16 in fiber 0x7f14001a90
CC 515 session 0 completed step 17 in fiber 0x7f14001a90
CC 515 session 0 completed step 18 in fiber 0x7f14001a90
CC 515 session 0 completed step 19 in fiber 0x7f14001a90
NvPHSSendThroughputHints: sensorId=0, m_usecase=4, m_type=20, m_value=1227376913, m_timeout_ms=1000
CC 515 session 0 completed step 20 in fiber 0x7f14001a90
FiberScheduler: cc 515, session 0, fiber 0x7f14001a90 complete
FiberScheduler: fiber 0x7f14001a90 exiting
disposing CC 515 Session 0
Thread 3 is waiting
Thread 1 is waiting
Thread 8 is waiting
Created fiber 0x7f14002060 for CC 520 globalID 855 session 0
Thread 5 is working on CC 520 session 0 globalID 855 step 0
CC 520 session 0 completed step 0 in fiber 0x7f14002060
cc 520(420) session 0 runCount=419 runIspOut=415, latest ccId=515
CC 520 session 0 completed step 1 in fiber 0x7f14002060
CC 520 session 0 completed step 2 in fiber 0x7f14002060
CC 520 session 0 completed step 3 in fiber 0x7f14002060
CC 520 session 0 completed step 4 in fiber 0x7f14002060
CC 520 session 0 completed step 5 in fiber 0x7f14002060
CC 520 session 0 completed step 6 in fiber 0x7f14002060
CC 520 session 0 processing step 7 in fiber 0x7f14002060
FiberScheduler: cc 520, session 0, fiber 0x7f14002060 in progress…
Thread 7 is waiting
Thread 5 is waiting
FiberScheduler: cc 516, session 0, fiber 0x7f14001110 succeeded async operation
Thread 2 is working on CC 516 session 0 globalID 851 step 8
CC 516 session 0 completed step 8 in fiber 0x7f14001110
CC 516 session 0 completed step 9 in fiber 0x7f14001110
lux in Statsupdate: isAohdrEnable=0 currentSceneLux 119.860
CC 516 session 0 completed step 10 in fiber 0x7f14001110
CC 516 session 0 completed step 11 in fiber 0x7f14001110
CC 516 session 0 completed step 12 in fiber 0x7f14001110
CC 516 session 0 completed step 13 in fiber 0x7f14001110
AfAnalysis cc 516 push FK_ISP_RUN_NUMBER=416.
CC 516 session 0 completed step 14 in fiber 0x7f14001110
CC 516 session 0 completed step 15 in fiber 0x7f14001110
CC 516 session 0 completed step 16 in fiber 0x7f14001110
CC 516 session 0 completed step 17 in fiber 0x7f14001110
CC 516 session 0 completed step 18 in fiber 0x7f14001110
CC 516 session 0 completed step 19 in fiber 0x7f14001110
NvPHSSendThroughputHints: sensorId=0, m_usecase=4, m_type=20, m_value=1229605170, m_timeout_ms=1000
CC 516 session 0 completed step 20 in fiber 0x7f14001110
FiberScheduler: cc 516, session 0, fiber 0x7f14001110 complete
FiberScheduler: fiber 0x7f14001110 exiting
disposing CC 516 Session 0
Thread 2 is waiting
Thread 9 is waiting
Created fiber 0x7f14001110 for CC 521 globalID 856 session 0
Thread 4 is working on CC 521 session 0 globalID 856 step 0
CC 521 session 0 completed step 0 in fiber 0x7f14001110
cc 521(421) session 0 runCount=420 runIspOut=416, latest ccId=516
CC 521 session 0 completed step 1 in fiber 0x7f14001110
CC 521 session 0 completed step 2 in fiber 0x7f14001110
CC 521 session 0 completed step 3 in fiber 0x7f14001110
CC 521 session 0 completed step 4 in fiber 0x7f14001110
CC 521 session 0 completed step 5 in fiber 0x7f14001110
CC 521 session 0 completed step 6 in fiber 0x7f14001110
CC 521 session 0 processing step 7 in fiber 0x7f14001110
FiberScheduler: cc 521, session 0, fiber 0x7f14001110 in progress…
Thread 4 is waiting
FiberScheduler: cc 517, session 0, fiber 0x7f14001450 succeeded async operation
Thread 6 is working on CC 517 session 0 globalID 852 step 8
CC 517 session 0 completed step 8 in fiber 0x7f14001450
CC 517 session 0 completed step 9 in fiber 0x7f14001450
lux in Statsupdate: isAohdrEnable=0 currentSceneLux 119.806
CC 517 session 0 completed step 10 in fiber 0x7f14001450
CC 517 session 0 completed step 11 in fiber 0x7f14001450
CC 517 session 0 completed step 12 in fiber 0x7f14001450
CC 517 session 0 completed step 13 in fiber 0x7f14001450
AfAnalysis cc 517 push FK_ISP_RUN_NUMBER=417.
CC 517 session 0 completed step 14 in fiber 0x7f14001450
CC 517 session 0 completed step 15 in fiber 0x7f14001450
CC 517 session 0 completed step 16 in fiber 0x7f14001450
CC 517 session 0 completed step 17 in fiber 0x7f14001450
CC 517 session 0 completed step 18 in fiber 0x7f14001450
CC 517 session 0 completed step 19 in fiber 0x7f14001450
NvPHSSendThroughputHints: sensorId=0, m_usecase=4, m_type=20, m_value=1231767891, m_timeout_ms=1000
CC 517 session 0 completed step 20 in fiber 0x7f14001450
FiberScheduler: cc 517, session 0, fiber 0x7f14001450 complete
FiberScheduler: fiber 0x7f14001450 exiting
disposing CC 517 Session 0
Thread 3 is waiting
Thread 6 is waiting
Created fiber 0x7f14001790 for CC 522 globalID 857 session 0
Thread 1 is working on CC 522 session 0 globalID 857 step 0
CC 522 session 0 completed step 0 in fiber 0x7f14001790
cc 522(422) session 0 runCount=421 runIspOut=417, latest ccId=517
CC 522 session 0 completed step 1 in fiber 0x7f14001790
CC 522 session 0 completed step 2 in fiber 0x7f14001790
CC 522 session 0 completed step 3 in fiber 0x7f14001790
CC 522 session 0 completed step 4 in fiber 0x7f14001790
CC 522 session 0 completed step 5 in fiber 0x7f14001790
CC 522 session 0 completed step 6 in fiber 0x7f14001790
CC 522 session 0 processing step 7 in fiber 0x7f14001790
FiberScheduler: cc 522, session 0, fiber 0x7f14001790 in progress…
Thread 8 is waiting
Thread 1 is waiting
FiberScheduler: cc 518, session 0, fiber 0x7f140012b0 succeeded async operation
Thread 7 is working on CC 518 session 0 globalID 853 step 8
CC 518 session 0 completed step 8 in fiber 0x7f140012b0
CC 518 session 0 completed step 9 in fiber 0x7f140012b0
lux in Statsupdate: isAohdrEnable=0 currentSceneLux 119.829
CC 518 session 0 completed step 10 in fiber 0x7f140012b0
CC 518 session 0 completed step 11 in fiber 0x7f140012b0
CC 518 session 0 completed step 12 in fiber 0x7f140012b0
CC 518 session 0 completed step 13 in fiber 0x7f140012b0
AfAnalysis cc 518 push FK_ISP_RUN_NUMBER=418.
CC 518 session 0 completed step 14 in fiber 0x7f140012b0
CC 518 session 0 completed step 15 in fiber 0x7f140012b0
CC 518 session 0 completed step 16 in fiber 0x7f140012b0
CC 518 session 0 completed step 17 in fiber 0x7f140012b0
CC 518 session 0 completed step 18 in fiber 0x7f140012b0
CC 518 session 0 completed step 19 in fiber 0x7f140012b0
NvPHSSendThroughputHints: sensorId=0, m_usecase=4, m_type=20, m_value=1233930613, m_timeout_ms=1000
CC 518 session 0 completed step 20 in fiber 0x7f140012b0
FiberScheduler: cc 518, session 0, fiber 0x7f140012b0 complete
FiberScheduler: fiber 0x7f140012b0 exiting
disposing CC 518 Session 0
Thread 2 is waiting
Thread 5 is waiting
Thread 7 is waiting
Created fiber 0x7f14001f30 for CC 523 globalID 858 session 0
Thread 11 is working on CC 523 session 0 globalID 858 step 0
CC 523 session 0 completed step 0 in fiber 0x7f14001f30
cc 523(423) session 0 runCount=422 runIspOut=418, latest ccId=518
CC 523 session 0 completed step 1 in fiber 0x7f14001f30
CC 523 session 0 completed step 2 in fiber 0x7f14001f30
CC 523 session 0 completed step 3 in fiber 0x7f14001f30
CC 523 session 0 completed step 4 in fiber 0x7f14001f30
CC 523 session 0 completed step 5 in fiber 0x7f14001f30
CC 523 session 0 completed step 6 in fiber 0x7f14001f30
CC 523 session 0 processing step 7 in fiber 0x7f14001f30
FiberScheduler: cc 523, session 0, fiber 0x7f14001f30 in progress…
Thread 9 is waiting
FiberScheduler: cc 519, session 0, fiber 0x7f14001c30 succeeded async operation
Thread 10 is working on CC 519 session 0 globalID 854 step 8
CC 519 session 0 completed step 8 in fiber 0x7f14001c30
CC 519 session 0 completed step 9 in fiber 0x7f14001c30
lux in Statsupdate: isAohdrEnable=0 currentSceneLux 119.833
CC 519 session 0 completed step 10 in fiber 0x7f14001c30
CC 519 session 0 completed step 11 in fiber 0x7f14001c30
CC 519 session 0 completed step 12 in fiber 0x7f14001c30
CC 519 session 0 completed step 13 in fiber 0x7f14001c30
AfAnalysis cc 519 push FK_ISP_RUN_NUMBER=419.
CC 519 session 0 completed step 14 in fiber 0x7f14001c30
CC 519 session 0 completed step 15 in fiber 0x7f14001c30
CC 519 session 0 completed step 16 in fiber 0x7f14001c30
CC 519 session 0 completed step 17 in fiber 0x7f14001c30
CC 519 session 0 completed step 18 in fiber 0x7f14001c30
CC 519 session 0 completed step 19 in fiber 0x7f14001c30
NvPHSSendThroughputHints: sensorId=0, m_usecase=4, m_type=20, m_value=1236093334, m_timeout_ms=1000
CC 519 session 0 completed step 20 in fiber 0x7f14001c30
FiberScheduler: cc 519, session 0, fiber 0x7f14001c30 complete
Thread 10 getting next capture
disposing CC 519 Session 0
Thread 4 is waiting
Created fiber 0x7f14000f70 for CC 524 globalID 859 session 0
Thread 3 is working on CC 524 session 0 globalID 859 step 0
CC 524 session 0 completed step 0 in fiber 0x7f14000f70
cc 524(424) session 0 runCount=423 runIspOut=419, latest ccId=519
CC 524 session 0 completed step 1 in fiber 0x7f14000f70
CC 524 session 0 completed step 2 in fiber 0x7f14000f70
CC 524 session 0 completed step 3 in fiber 0x7f14000f70
CC 524 session 0 completed step 4 in fiber 0x7f14000f70
CC 524 session 0 completed step 5 in fiber 0x7f14000f70
CC 524 session 0 completed step 6 in fiber 0x7f14000f70
CC 524 session 0 processing step 7 in fiber 0x7f14000f70
FiberScheduler: cc 524, session 0, fiber 0x7f14000f70 in progress…
Thread 6 is waiting
Thread 3 is waiting
FiberScheduler: cc 520, session 0, fiber 0x7f14002060 succeeded async operation
Thread 8 is working on CC 520 session 0 globalID 855 step 8
CC 520 session 0 completed step 8 in fiber 0x7f14002060
CC 520 session 0 completed step 9 in fiber 0x7f14002060
lux in Statsupdate: isAohdrEnable=0 currentSceneLux 119.841
CC 520 session 0 completed step 10 in fiber 0x7f14002060
CC 520 session 0 completed step 11 in fiber 0x7f14002060
CC 520 session 0 completed step 12 in fiber 0x7f14002060
CC 520 session 0 completed step 13 in fiber 0x7f14002060
AfAnalysis cc 520 push FK_ISP_RUN_NUMBER=420.
CC 520 session 0 completed step 14 in fiber 0x7f14002060
CC 520 session 0 completed step 15 in fiber 0x7f14002060
CC 520 session 0 completed step 16 in fiber 0x7f14002060
CC 520 session 0 completed step 17 in fiber 0x7f14002060
CC 520 session 0 completed step 18 in fiber 0x7f14002060
CC 520 session 0 completed step 19 in fiber 0x7f14002060
NvPHSSendThroughputHints: sensorId=0, m_usecase=4, m_type=20, m_value=1238321591, m_timeout_ms=1000
CC 520 session 0 completed step 20 in fiber 0x7f14002060
FiberScheduler: cc 520, session 0, fiber 0x7f14002060 complete
disposing CC 520 Session 0
Thread 2 is waiting
Thread 1 is waiting
Thread 8 is waiting
Created fiber 0x7f140015f0 for CC 525 globalID 860 session 0
Thread 5 is working on CC 525 session 0 globalID 860 step 0
CC 525 session 0 completed step 0 in fiber 0x7f140015f0
cc 525(425) session 0 runCount=424 runIspOut=420, latest ccId=520
CC 525 session 0 completed step 1 in fiber 0x7f140015f0
CC 525 session 0 completed step 2 in fiber 0x7f140015f0
CC 525 session 0 completed step 3 in fiber 0x7f140015f0
CC 525 session 0 completed step 4 in fiber 0x7f140015f0
CC 525 session 0 completed step 5 in fiber 0x7f140015f0
CC 525 session 0 completed step 6 in fiber 0x7f140015f0
CC 525 session 0 processing step 7 in fiber 0x7f140015f0
FiberScheduler: cc 525, session 0, fiber 0x7f140015f0 in progress…
Thread 7 is waiting
Thread 5 is waiting
FiberScheduler: cc 521, session 0, fiber 0x7f14001110 succeeded async operation
Thread 11 is working on CC 521 session 0 globalID 856 step 8
CC 521 session 0 completed step 8 in fiber 0x7f14001110
CC 521 session 0 completed step 9 in fiber 0x7f14001110
lux in Statsupdate: isAohdrEnable=0 currentSceneLux 119.791
CC 521 session 0 completed step 10 in fiber 0x7f14001110
CC 521 session 0 completed step 11 in fiber 0x7f14001110
CC 521 session 0 completed step 12 in fiber 0x7f14001110
CC 521 session 0 completed step 13 in fiber 0x7f14001110
AfAnalysis cc 521 push FK_ISP_RUN_NUMBER=421.
CC 521 session 0 completed step 14 in fiber 0x7f14001110
CC 521 session 0 completed step 15 in fiber 0x7f14001110
CC 521 session 0 completed step 16 in fiber 0x7f14001110
CC 521 session 0 completed step 17 in fiber 0x7f14001110
CC 521 session 0 completed step 18 in fiber 0x7f14001110
CC 521 session 0 completed step 19 in fiber 0x7f14001110
NvPHSSendThroughputHints: sensorId=0, m_usecase=4, m_type=20, m_value=1240549849, m_timeout_ms=1000
CC 521 session 0 completed step 20 in fiber 0x7f14001110
FiberScheduler: cc 521, session 0, fiber 0x7f14001110 complete
disposing CC 521 Session 0
Thread 9 is waiting
Created fiber 0x7f14000b20 for CC 526 globalID 861 session 0
Thread 10 is working on CC 526 session 0 globalID 861 step 0
CC 526 session 0 completed step 0 in fiber 0x7f14000b20
cc 526(426) session 0 runCount=425 runIspOut=421, latest ccId=521
CC 526 session 0 completed step 1 in fiber 0x7f14000b20
CC 526 session 0 completed step 2 in fiber 0x7f14000b20
CC 526 session 0 completed step 3 in fiber 0x7f14000b20
CC 526 session 0 completed step 4 in fiber 0x7f14000b20
CC 526 session 0 completed step 5 in fiber 0x7f14000b20
CC 526 session 0 completed step 6 in fiber 0x7f14000b20
CC 526 session 0 processing step 7 in fiber 0x7f14000b20
FiberScheduler: cc 526, session 0, fiber 0x7f14000b20 in progress…
Thread 4 is waiting
FiberScheduler: cc 522, session 0, fiber 0x7f14001790 succeeded async operation
Thread 6 is working on CC 522 session 0 globalID 857 step 8
CC 522 session 0 completed step 8 in fiber 0x7f14001790
CC 522 session 0 completed step 9 in fiber 0x7f14001790
lux in Statsupdate: isAohdrEnable=0 currentSceneLux 119.808
CC 522 session 0 completed step 10 in fiber 0x7f14001790
CC 522 session 0 completed step 11 in fiber 0x7f14001790
CC 522 session 0 completed step 12 in fiber 0x7f14001790
CC 522 session 0 completed step 13 in fiber 0x7f14001790
AfAnalysis cc 522 push FK_ISP_RUN_NUMBER=422.
CC 522 session 0 completed step 14 in fiber 0x7f14001790
CC 522 session 0 completed step 15 in fiber 0x7f14001790
CC 522 session 0 completed step 16 in fiber 0x7f14001790
CC 522 session 0 completed step 17 in fiber 0x7f14001790
CC 522 session 0 completed step 18 in fiber 0x7f14001790
CC 522 session 0 completed step 19 in fiber 0x7f14001790
NvPHSSendThroughputHints: sensorId=0, m_usecase=4, m_type=20, m_value=1242778106, m_timeout_ms=1000
CC 522 session 0 completed step 20 in fiber 0x7f14001790
FiberScheduler: cc 522, session 0, fiber 0x7f14001790 complete
disposing CC 522 Session 0
Thread 3 is waiting
Thread 2 is waiting
Thread 6 is waiting
Session 0 aborting capture 526 (API ID: 426)
Session 0 aborting capture 525 (API ID: 425)
Session 0 aborting capture 524 (API ID: 424)
Session 0 aborting capture 523 (API ID: 423)
CaptureService cancelling request 759
FiberScheduler: cc 525, session 0, fiber 0x7f140015f0 aborted in async operation
CaptureService cancelling request 760
disposing CC 525 Session 0
Thread 1 is waiting
FiberScheduler: cc 526, session 0, fiber 0x7f14000b20 aborted in async operation
Thread 8 is waiting
FiberScheduler: cc 523, session 0, fiber 0x7f14001f30 succeeded async operation
Thread 7 is working on CC 523 session 0 globalID 858 step 8
Fiber 0x7f14001f30 is aborting in CC 523 Session 0
FiberScheduler: cc 523 session 0, fiber 0x7f14001f30 aborted
disposing CC 523 Session 0
Thread 5 is waiting
Thread 9 is waiting
Thread 7 is waiting
FiberScheduler: cc 524, session 0, fiber 0x7f14000f70 succeeded async operation
Thread 11 is working on CC 524 session 0 globalID 859 step 8
Fiber 0x7f14000f70 is aborting in CC 524 Session 0
FiberScheduler: cc 524 session 0, fiber 0x7f14000f70 aborted
disposing CC 524 Session 0
Thread 4 is waiting
Thread 11 is waiting
Worker thread CaptureDispatcher stop
disposing CC 526 Session 0
Worker thread ViCsiHw frameComplete stop
Worker thread ViCsiHw frameStart stop
PowerServiceHw:removeRequests: table size: before: 2, after:0
PowerServiceHw:removeRequests: table size: before: 1, after:0
request table for VIC 0:
PowerServiceHw:updateRequests: table size: before: 0, after:0
PowerServiceHwIsp:setLaBw: m_bwVal_Iso=0 and m_bwVal_NonIso=0 KBpS
PowerServiceHwVic:setClock: PowerServiceHw[1]: requested_clock_Hz=0
PowerServiceCore:setCameraBw: totalIsoBw=0
PowerServiceCore:setCameraBw: totalNonIsoBw=0
=== gst-launch-1.0[9284]: CameraProvider destroyed (0x7f85c63600)Stopping services…
Worker thread CaptureScheduler frameStart stop
Worker thread CaptureScheduler checkFramePending stop
Worker thread IspHw statsComplete stop
Worker thread IspHw frameComplete stop
Worker thread V4L2CaptureScheduler issueCaptures stop
Worker thread V4L2CaptureScheduler checkCaptureComplete stop
Worker thread PS handleRequests stop
unsubscribe: SensorType(gyroscope)
unsubscribe: gyroscope sensor(0x7f85b6f230)
unsubscribe: SensorType(accelerometer)
unsubscribe: accelerometer sensor(0x7f85b748c0)
Services are stopped
closeInstance: ms_instance((nil))
FiberScheduler: shutting down; 0 fibers still in map
FiberScheduler: thread 11 exiting
FiberScheduler: thread 6 exiting
FiberScheduler: thread 1 exiting
FiberScheduler: thread 11 has been joined
FiberScheduler: thread 9 exiting
FiberScheduler: thread 7 exiting
FiberScheduler: thread 4 exiting
FiberScheduler: thread 2 exiting
FiberScheduler: thread 3 exiting
FiberScheduler: thread 10 exiting
FiberScheduler: thread 10 has been joined
FiberScheduler: thread 5 exiting
FiberScheduler: thread 8 exiting
FiberScheduler: thread 8 has been joined
FiberScheduler: thread 7 has been joined
FiberScheduler: thread 12 exiting
FiberScheduler: thread 12 has been joined
FiberScheduler: thread 6 has been joined
FiberScheduler: thread 4 has been joined
FiberScheduler: thread 3 has been joined
FiberScheduler: thread 9 has been joined
FiberScheduler: thread 2 has been joined
FiberScheduler: thread 5 has been joined
FiberScheduler: thread 1 has been joined
=== gst-launch-1.0[9284]: Connection closed (7F8B6A11D0)=== gst-launch-1.0[9284]: Connection cleaned up (7F8B6A11D0)
Good to know. ^v^
When I reboot the Jetson nano, I could not capture the streams again. So I need your advice in case I need to reboot and capture the videos using OpenCV. Thanks!
