Inconsitent timestamps and framerate lower than requested in nvarguscamerasrc
I’m trying to get the video stream from nvarguscamerasrc on Jetson Nano with the pre-defined framerate and use fixed caps filter right after the source element for that, as suggested e.g. in “Accelerated GStreamer User Guide”. It pretty much works for me, but at one moment I’ve noticed, that the framerate of the stream is slightly lower, than the value defined in the caps, and the timestamps of the buffers (PTS to be exact) seen right on the source’s sink pad are not particularly consistent, i.e. they don’t go strictly in intervals of (1s / FPS), but deviate even from the average. On the other hand, the framerate reported as it’s defined, which together makes the whole stream not consistent.
I use Raspberry Pi Camera V2 module, which announced to be compliant with Jetson Nano.
I’ve created a small sample application to reproduce this, test.cpp (2.5 KB). It can be built with:
g++ -o test `pkg-config --cflags gstreamer-1.0` ./test.cpp `pkg-config --libs gstreamer-1.0`
One can also define the FPS value with FPS variable, e.g. adding -DFPS=30 to the command line.
With that, I gathered the following statistics (all tested at 1280x720):
  • for 30 FPS additional buffer latency is on average ≈1.063 ms
  • for 60 FPS additional buffer latency is on average ≈518 us
  • for 120 FPS additional buffer latency is on average ≈235 us
It seems, that it’s not the problem of performance itself or something like that, as we can see, especially for lower FPS, the pipeline is actually able to run faster. Probably it’s just some latency not accounted while producing and timestamping the buffers.
Could you please take a look at this moment and clarify, if it’s something waiting for the fix or some subtle yet expected behaviour? Thank you!
Could you run below command then check it again.
sudo nvpmodel -m 0
sudo jetson_clocks &
@ShaneCCC thanks for your fast reply and suggestions! I’ve just checked with these commands executed before, but the results are pretty much the same, see no difference, the same statistics.
Also, forgot to mention initially, this reproduces for me in both JetPack 4.3 and fresh 4.4 final release, the results don’t differ in these cases as well.
I run argus_camera get correct frame rate.
nvidia@nvidia-desktop:~$ ./argus_camera --kpi --sensormode=2
Executing Argus Sample Application (argus_camera)
Argus Version: 0.97.3 (multi-process)
PerfTracker: app initial 546 ms
PerfTracker 1: app intialized to task start 407 ms
PerfTracker 1: task start to issue capture 46 ms
PerfTracker 1: first request 213 ms
PerfTracker 1: total launch time 1214 ms
PerfTracker 1: frameRate 31.21 frames per second at 0 Seconds
PerfTracker 1: framedrop current request 0, total 0
PerfTracker 1: latency 23 ms average, min 22 max 24
PerfTracker 1: frameRate 30.06 frames per second at 1 Seconds
PerfTracker: display frame rate 30.50 frames per second
PerfTracker 1: latency 22 ms average, min 22 max 22
PerfTracker 1: frameRate 30.03 frames per second at 2 Seconds
PerfTracker: display frame rate 30.00 frames per second
PerfTracker 1: frameRate 30.02 frames per second at 3 Seconds
PerfTracker: display frame rate 29.99 frames per second
PerfTracker 1: frameRate 30.02 frames per second at 4 Seconds
PerfTracker: display frame rate 30.01 frames per second
PerfTracker 1: frameRate 30.02 frames per second at 5 Seconds
Also I get the 30fps consistence by below gstreamer command line.
gst-launch-1.0 nvarguscamerasrc ! ‘video/x-raw(memory:NVMM),width=1920,height=1080,format=NV12’ ! nvvidconv ! fpsdisplaysink video-sink=fakesink --verbose
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstFakeSink:fakesink0: sync = true
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 17, dropped: 0, current: 32.19, average: 32.19
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 17, dropped: 0, current: 32.19, average: 32.19
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 33, dropped: 0, current: 30.01, average: 31.09
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 33, dropped: 0, current: 30.01, average: 31.09
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 49, dropped: 0, current: 30.01, average: 30.73
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 49, dropped: 0, current: 30.01, average: 30.73
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 65, dropped: 0, current: 30.01, average: 30.55
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 65, dropped: 0, current: 30.01, average: 30.55
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 81, dropped: 0, current: 30.00, average: 30.44
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 81, dropped: 0, current: 30.00, average: 30.44
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 97, dropped: 0, current: 30.00, average: 30.37
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 97, dropped: 0, current: 30.00, average: 30.37
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 113, dropped: 0, current: 30.00, average: 30.31
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 113, dropped: 0, current: 30.00, average: 30.31
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 129, dropped: 0, current: 30.01, average: 30.28
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 129, dropped: 0, current: 30.01, average: 30.28
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 145, dropped: 0, current: 30.00, average: 30.25
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 145, dropped: 0, current: 30.00, average: 30.25
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 161, dropped: 0, current: 30.00, average: 30.22
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 161, dropped: 0, current: 30.00, average: 30.22
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 176, dropped: 0, current: 30.00, average: 30.20
Cannot run argus_camera utility, do you get it from here? Fails to build for me using CMake, as in the instructions.
But I can confirm I have the same output from GStreamer with your command, it indeed produces 30 FPS in average. However, if I change the resolution to 1280x720 as I initially described, the FPS rate drops, just the same in my test:
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 16, dropped: 0, current: 31,20, average: 31,20
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 16, dropped: 0, current: 31,20, average: 31,20
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 31, dropped: 0, current: 29,09, average: 30,14
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 31, dropped: 0, current: 29,09, average: 30,14
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 46, dropped: 0, current: 29,07, average: 29,78
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 46, dropped: 0, current: 29,07, average: 29,78
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 61, dropped: 0, current: 29,07, average: 29,61
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 61, dropped: 0, current: 29,07, average: 29,61
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 76, dropped: 0, current: 29,06, average: 29,50
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 76, dropped: 0, current: 29,06, average: 29,50
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 91, dropped: 0, current: 29,07, average: 29,43
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 91, dropped: 0, current: 29,07, average: 29,43
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 106, dropped: 0, current: 29,06, average: 29,37
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 106, dropped: 0, current: 29,06, average: 29,37
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 121, dropped: 0, current: 29,06, average: 29,34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 121, dropped: 0, current: 29,06, average: 29,34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 136, dropped: 0, current: 29,06, average: 29,31
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 136, dropped: 0, current: 29,06, average: 29,31
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 151, dropped: 0, current: 29,07, average: 29,28
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 151, dropped: 0, current: 29,07, average: 29,28
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 166, dropped: 0, current: 29,07, average: 29,26
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 166, dropped: 0, current: 29,07, average: 29,26
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 181, dropped: 0, current: 29,06, average: 29,25
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 181, dropped: 0, current: 29,06, average: 29,25
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 196, dropped: 0, current: 29,06, average: 29,23
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 196, dropped: 0, current: 29,06, average: 29,23
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 211, dropped: 0, current: 29,06, average: 29,22
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 211, dropped: 0, current: 29,06, average: 29,22
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 226, dropped: 0, current: 29,07, average: 29,21
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 226, dropped: 0, current: 29,07, average: 29,21
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 241, dropped: 0, current: 29,06, average: 29,20
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 241, dropped: 0, current: 29,06, average: 29,20
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 256, dropped: 0, current: 29,07, average: 29,19
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 256, dropped: 0, current: 29,07, average: 29,19
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 271, dropped: 0, current: 29,06, average: 29,19
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 271, dropped: 0, current: 29,06, average: 29,19
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 286, dropped: 0, current: 29,07, average: 29,18
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 286, dropped: 0, current: 29,07, average: 29,18
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 301, dropped: 0, current: 29,06, average: 29,17
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 301, dropped: 0, current: 29,06, average: 29,17
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 316, dropped: 0, current: 29,07, average: 29,17
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 316, dropped: 0, current: 29,07, average: 29,17
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 331, dropped: 0, current: 29,06, average: 29,16
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 331, dropped: 0, current: 29,06, average: 29,16
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 346, dropped: 0, current: 29,07, average: 29,16
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 346, dropped: 0, current: 29,07, average: 29,16
Add framerate=60/1 can get ~60fps
gst-launch-1.0 nvarguscamerasrc ! ‘video/x-raw(memory:NVMM),width=1280,height=720,format=NV12, framerate=60/1’ ! nvvidconv ! fpsdisplaysink video-sink=fakesink --verbose
No, it’s again produces slower, just following my initial tests:
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 31, dropped: 0, current: 60,65, average: 60,65
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 31, dropped: 0, current: 60,65, average: 60,65
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 60, dropped: 0, current: 56,16, average: 58,39
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 60, dropped: 0, current: 56,16, average: 58,39
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 90, dropped: 0, current: 58,18, average: 58,32
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 90, dropped: 0, current: 58,18, average: 58,32
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 120, dropped: 0, current: 58,16, average: 58,28
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 120, dropped: 0, current: 58,16, average: 58,28
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 150, dropped: 0, current: 58,16, average: 58,26
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 150, dropped: 0, current: 58,16, average: 58,26
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 180, dropped: 0, current: 58,19, average: 58,25
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 180, dropped: 0, current: 58,19, average: 58,25
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 210, dropped: 0, current: 58,15, average: 58,23
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 210, dropped: 0, current: 58,15, average: 58,23
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 240, dropped: 0, current: 58,19, average: 58,23
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 240, dropped: 0, current: 58,19, average: 58,23
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 270, dropped: 0, current: 58,17, average: 58,22
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 270, dropped: 0, current: 58,17, average: 58,22
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 300, dropped: 0, current: 58,15, average: 58,21
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 300, dropped: 0, current: 58,15, average: 58,21
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 330, dropped: 0, current: 58,16, average: 58,21
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 330, dropped: 0, current: 58,16, average: 58,21
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 360, dropped: 0, current: 58,18, average: 58,21
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 360, dropped: 0, current: 58,18, average: 58,21
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 390, dropped: 0, current: 58,20, average: 58,21
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 390, dropped: 0, current: 58,20, average: 58,21
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 420, dropped: 0, current: 58,14, average: 58,20
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 420, dropped: 0, current: 58,14, average: 58,20
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 450, dropped: 0, current: 58,18, average: 58,20
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 450, dropped: 0, current: 58,18, average: 58,20
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 480, dropped: 0, current: 58,18, average: 58,20
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 480, dropped: 0, current: 58,18, average: 58,20
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 510, dropped: 0, current: 58,15, average: 58,20
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 510, dropped: 0, current: 58,15, average: 58,20
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 540, dropped: 0, current: 58,17, average: 58,20
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 540, dropped: 0, current: 58,17, average: 58,20
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 570, dropped: 0, current: 58,17, average: 58,19
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 570, dropped: 0, current: 58,17, average: 58,19
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 600, dropped: 0, current: 58,16, average: 58,19
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 600, dropped: 0, current: 58,16, average: 58,19
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 630, dropped: 0, current: 58,17, average: 58,19
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 630, dropped: 0, current: 58,17, average: 58,19
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 660, dropped: 0, current: 58,16, average: 58,19
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 660, dropped: 0, current: 58,16, average: 58,19
But from your log looks like there is no any frame drop? and got 58 fps consistency right?
Yes, exactly. No frame drop, they just come a little slower, with bigger durations, while reported to be 60 FPS in the caps.
Just wanted to add, I’ve just checked the camera module on Raspbery Pi 4 itself, with similar settings and resolution, it appears to work as expected:
30 FPS, command:
gst-launch-1.0 v4l2src ! "video/x-raw,width=1280,height=720,framerate=(fraction)30/1" ! videoconvert ! fpsdisplaysink video-sink=fakesink --verbose
Output:
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 16, dropped: 0, current: 31.50, average: 31.50
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 16, dropped: 0, current: 31.50, average: 31.50
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 32, dropped: 0, current: 30.38, average: 30.93
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 32, dropped: 0, current: 30.38, average: 30.93
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 47, dropped: 0, current: 29.49, average: 30.46
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 47, dropped: 0, current: 29.49, average: 30.46
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 62, dropped: 0, current: 29.87, average: 30.31
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 62, dropped: 0, current: 29.87, average: 30.31
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 78, dropped: 0, current: 30.13, average: 30.28
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 78, dropped: 0, current: 30.13, average: 30.28
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 94, dropped: 0, current: 30.01, average: 30.23
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 94, dropped: 0, current: 30.01, average: 30.23
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 110, dropped: 0, current: 30.00, average: 30.20
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 110, dropped: 0, current: 30.00, average: 30.20
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 126, dropped: 0, current: 30.41, average: 30.22
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 126, dropped: 0, current: 30.41, average: 30.22
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 141, dropped: 0, current: 29.45, average: 30.14
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 141, dropped: 0, current: 29.45, average: 30.14
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 157, dropped: 0, current: 30.03, average: 30.13
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 157, dropped: 0, current: 30.03, average: 30.13
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 173, dropped: 0, current: 30.61, average: 30.17
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 173, dropped: 0, current: 30.61, average: 30.17
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 188, dropped: 0, current: 29.51, average: 30.12
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 188, dropped: 0, current: 29.51, average: 30.12
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 204, dropped: 0, current: 30.49, average: 30.15
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 204, dropped: 0, current: 30.49, average: 30.15
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 219, dropped: 0, current: 29.74, average: 30.12
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 219, dropped: 0, current: 29.74, average: 30.12
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 234, dropped: 0, current: 29.75, average: 30.09
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 234, dropped: 0, current: 29.75, average: 30.09
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 250, dropped: 0, current: 30.50, average: 30.12
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 250, dropped: 0, current: 30.50, average: 30.12
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 265, dropped: 0, current: 29.45, average: 30.08
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 265, dropped: 0, current: 29.45, average: 30.08
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 281, dropped: 0, current: 30.46, average: 30.10
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 281, dropped: 0, current: 30.46, average: 30.10
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 296, dropped: 0, current: 29.45, average: 30.07
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 296, dropped: 0, current: 29.45, average: 30.07
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 312, dropped: 0, current: 30.63, average: 30.10
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 312, dropped: 0, current: 30.63, average: 30.10
60 FPS, command:
gst-launch-1.0 v4l2src ! "video/x-raw,width=1280,height=720,framerate=(fraction)60/1" ! videoconvert ! fpsdisplaysink video-sink=fakesink --verbose
Output:
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 31, dropped: 0, current: 61.57, average: 61.57
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 31, dropped: 0, current: 61.57, average: 61.57
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 60, dropped: 0, current: 57.09, average: 59.32
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 60, dropped: 0, current: 57.09, average: 59.32
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 91, dropped: 0, current: 60.17, average: 59.61
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 91, dropped: 0, current: 60.17, average: 59.61
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 122, dropped: 0, current: 60.05, average: 59.72
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 122, dropped: 0, current: 60.05, average: 59.72
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 153, dropped: 0, current: 60.36, average: 59.85
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 153, dropped: 0, current: 60.36, average: 59.85
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 183, dropped: 0, current: 59.72, average: 59.83
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 183, dropped: 0, current: 59.72, average: 59.83
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 214, dropped: 0, current: 60.65, average: 59.95
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 214, dropped: 0, current: 60.65, average: 59.95
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 244, dropped: 0, current: 59.55, average: 59.90
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 244, dropped: 0, current: 59.55, average: 59.90
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 275, dropped: 0, current: 60.70, average: 59.99
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 275, dropped: 0, current: 60.70, average: 59.99
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 305, dropped: 0, current: 59.70, average: 59.96
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 305, dropped: 0, current: 59.70, average: 59.96
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 336, dropped: 0, current: 60.79, average: 60.03
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 336, dropped: 0, current: 60.79, average: 60.03
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 366, dropped: 0, current: 59.78, average: 60.01
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 366, dropped: 0, current: 59.78, average: 60.01
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 397, dropped: 0, current: 60.51, average: 60.05
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 397, dropped: 0, current: 60.51, average: 60.05
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 427, dropped: 0, current: 59.90, average: 60.04
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 427, dropped: 0, current: 59.90, average: 60.04
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 458, dropped: 0, current: 60.49, average: 60.07
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 458, dropped: 0, current: 60.49, average: 60.07
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 489, dropped: 0, current: 60.21, average: 60.08
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 489, dropped: 0, current: 60.21, average: 60.08
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 520, dropped: 0, current: 60.35, average: 60.10
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 520, dropped: 0, current: 60.35, average: 60.10
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 550, dropped: 0, current: 59.72, average: 60.08
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 550, dropped: 0, current: 59.72, average: 60.08
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 581, dropped: 0, current: 60.43, average: 60.09
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 581, dropped: 0, current: 60.43, average: 60.09
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 612, dropped: 0, current: 60.45, average: 60.11
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 612, dropped: 0, current: 60.45, average: 60.11
90 FPS, command:
gst-launch-1.0 v4l2src ! "video/x-raw,width=1280,height=720,framerate=(fraction)90/1" ! videoconvert ! fpsdisplaysink video-sink=fakesink --verbose
Output:
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 46, dropped: 0, current: 91.19, average: 91.19
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 46, dropped: 0, current: 91.19, average: 91.19
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 89, dropped: 0, current: 84.24, average: 87.69
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 89, dropped: 0, current: 84.24, average: 87.69
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 135, dropped: 0, current: 89.61, average: 88.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 135, dropped: 0, current: 89.61, average: 88.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 181, dropped: 0, current: 90.87, average: 88.97
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 181, dropped: 0, current: 90.87, average: 88.97
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 227, dropped: 0, current: 90.24, average: 89.22
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 227, dropped: 0, current: 90.24, average: 89.22
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 273, dropped: 0, current: 89.33, average: 89.24
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 273, dropped: 0, current: 89.33, average: 89.24
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 319, dropped: 0, current: 91.19, average: 89.52
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 319, dropped: 0, current: 91.19, average: 89.52
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 365, dropped: 0, current: 90.26, average: 89.61
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 365, dropped: 0, current: 90.26, average: 89.61
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 410, dropped: 0, current: 89.08, average: 89.55
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 410, dropped: 0, current: 89.08, average: 89.55
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 456, dropped: 0, current: 90.79, average: 89.67
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 456, dropped: 0, current: 90.79, average: 89.67
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 502, dropped: 0, current: 90.86, average: 89.78
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 502, dropped: 0, current: 90.86, average: 89.78
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 548, dropped: 0, current: 90.26, average: 89.82
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 548, dropped: 0, current: 90.26, average: 89.82
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 594, dropped: 0, current: 89.62, average: 89.81
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 594, dropped: 0, current: 89.62, average: 89.81
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 640, dropped: 0, current: 90.89, average: 89.88
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 640, dropped: 0, current: 90.89, average: 89.88
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 686, dropped: 0, current: 90.20, average: 89.90
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 686, dropped: 0, current: 90.20, average: 89.90
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 732, dropped: 0, current: 89.33, average: 89.87
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 732, dropped: 0, current: 89.33, average: 89.87
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 777, dropped: 0, current: 89.08, average: 89.82
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 777, dropped: 0, current: 89.08, average: 89.82
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 824, dropped: 0, current: 92.38, average: 89.96
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 824, dropped: 0, current: 92.38, average: 89.96
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 870, dropped: 0, current: 89.61, average: 89.95
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 870, dropped: 0, current: 89.61, average: 89.95
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 916, dropped: 0, current: 90.90, average: 89.99
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 916, dropped: 0, current: 90.90, average: 89.99
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 962, dropped: 0, current: 90.21, average: 90.00
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 962, dropped: 0, current: 90.21, average: 90.00
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 1008, dropped: 0, current: 89.55, average: 89.98
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1008, dropped: 0, current: 89.55, average: 89.98
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 1054, dropped: 0, current: 90.95, average: 90.02
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 1054, dropped: 0, current: 90.95, average: 90.02
By the way, on Raspberry this module doesn’t officially support 120 FPS in 1280x720)
Hello @aclex,
I was also not able to reproduce the reported issue as I am getting a consistent frame rate. Can you please describe in details the steps you made?
Hello, @mike_nv,
thanks for looking into this. My steps, as I’ve initially described, are nothing special:
  1. On clean JetPack 4.3 or 4.4 image with DeepStream 4.0.4 or 5.0.2 installed, correspondingly, I build the attached test program.
  2. With Raspberry Camera V2 connected to the CSI (I use the 1st generation of Jetson Nano, with the single CSI port), I get the mentioned logs with timestamps going slower, than the frame rate given in the caps. This is by default for 30 fps, but I also try 60 and 120 fps with -DFPS=60 and -DFPS=120, correspondingly, and get other two outputs, which I also attached to my previous messages.
Have you happen to build and start the attached code, test.cpp? It’s fairly simple and independent of any external things, so can clearly show the whole picture. If you’re getting consistent timestamping there, could you please print the output, so that I at least know, what to aim? Thank you in advance!
@aclex,
from the debug console I got the following supported Sensor Modes:
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3264 x 2464 FR = 21,000000 fps Duration = 47619048 ; Analog Gain range min 1,000000, max 10,625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3264 x 1848 FR = 28,000001 fps Duration = 35714284 ; Analog Gain range min 1,000000, max 10,625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29,999999 fps Duration = 33333334 ; Analog Gain range min 1,000000, max 10,625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59,999999 fps Duration = 16666667 ; Analog Gain range min 1,000000, max 10,625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 120,000005 fps Duration = 8333333 ; Analog Gain range min 1,000000, max 10,625000; Exposure Range min 13000, max 683709000;
Do you see the reported behavior is any of the supported modes?
hello @aclex,
I was able to reproduce the issue. I will be performing more tests and reach out to you soon.
Hello, @mike_nv,
thank you! Glad you’ve managed to reproduce it on your setup. As for the modes, yes, I have this exact message printed every time I execute the program, and I guess it works in this mode:
every time, when resolution of 1280x720 is specified in the caps, for every framerate in 30, 60, 120 fps.
I check the argus_camera with 60fps looks like without ptoblem.
nvidia@dhcp-10-19-107-83:~$ ./argus_camera --kpi --sensormode=3
PerfTracker: app initial 801 ms
PerfTracker 1: app intialized to task start 400 ms
PerfTracker 1: task start to issue capture 39 ms
PerfTracker 1: first request 150 ms
PerfTracker 1: total launch time 1391 ms
PerfTracker 1: frameRate 63.61 frames per second at 0 Seconds
PerfTracker 1: latency 16 ms average, min 16 max 18
PerfTracker 1: frameRate 60.29 frames per second at 0 Seconds
PerfTracker 1: latency 15 ms average, min 15 max 17
PerfTracker 1: frameRate 60.17 frames per second at 1 Seconds
PerfTracker: display frame rate 60.10 frames per second
PerfTracker 1: latency 15 ms average, min 15 max 16
Could you try to modify the kernel sensor driver to output fix 60fps to check the gst-launch-1.0 command?
You can modify make the exposure/frame rate control function as dummy to verify it.
Add the sensor-mode=3 and framerate=60/1 now I can get 60fps continuous.
nvidia@dhcp-10-19-107-83:~$ gst-launch-1.0 nvarguscamerasrc sensor-mode=3 ! ‘video/x-raw(memory:NVMM),width=1280,height=720,format=NV12, framerate=60/1’ ! nvvidconv ! fpsdisplaysink video-sink=fakesink --verbose
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
New clock: GstSystemClock
/GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)NV12, framerate=(fraction)60/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)NV12, framerate=(fraction)60/1
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)NV12, framerate=(fraction)60/1
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0.GstGhostPad:sink.GstProxyPad:proxypad0: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)NV12, framerate=(fraction)60/1
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay.GstPad:src: caps = video/x-raw(memory:NVMM, meta:GstVideoOverlayComposition), width=(int)1280, height=(int)720, format=(string)NV12, framerate=(fraction)60/1
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstFakeSink:fakesink0.GstPad:sink: caps = video/x-raw(memory:NVMM, meta:GstVideoOverlayComposition), width=(int)1280, height=(int)720, format=(string)NV12, framerate=(fraction)60/1
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay.GstPad:video_sink: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)NV12, framerate=(fraction)60/1
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0.GstGhostPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)NV12, framerate=(fraction)60/1
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)NV12, framerate=(fraction)60/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)NV12, framerate=(fraction)60/1
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected…
GST_ARGUS: 3264 x 2464 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3264 x 1848 FR = 28.000001 fps Duration = 35714284 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 120.000005 fps Duration = 8333333 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 3
Output Stream W = 1280 H = 720
seconds to Run = 0
Frame Rate = 59.999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 32, dropped: 0, current: 62.31, average: 62.31
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 32, dropped: 0, current: 62.31, average: 62.31
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 63, dropped: 0, current: 60.21, average: 61.26
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 63, dropped: 0, current: 60.21, average: 61.26
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 94, dropped: 0, current: 60.05, average: 60.85
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 94, dropped: 0, current: 60.05, average: 60.85
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 125, dropped: 0, current: 60.03, average: 60.65
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 125, dropped: 0, current: 60.03, average: 60.65
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 156, dropped: 0, current: 60.08, average: 60.53
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 156, dropped: 0, current: 60.08, average: 60.53
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 187, dropped: 0, current: 60.01, average: 60.45
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 187, dropped: 0, current: 60.01, average: 60.45
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 218, dropped: 0, current: 60.07, average: 60.39
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 218, dropped: 0, current: 60.07, average: 60.39
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 249, dropped: 0, current: 60.04, average: 60.35
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 249, dropped: 0, current: 60.04, average: 60.35
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 280, dropped: 0, current: 60.04, average: 60.31
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 280, dropped: 0, current: 60.04, average: 60.31
Many thanks for your suggestions, @ShaneCCC! I’ve tried manually specifying sensor-mode, both for gst-launch-1.0 and in the test utility I’ve initially attached, that’s indeed starts to work pretty consistently with that both at 30 and 60 FPS. Here’s the outputs of test utility:
30 FPS:
CONSUMER: Waiting until producer is connected...
   Camera index = 0
   Camera mode  = 3
   seconds to Run    = 0
average duration: 33186370 (-146963) ns
average duration: 33256830 (-76503) ns
average duration: 33280189 (-53144) ns
average duration: 33291628 (-41705) ns
average duration: 33298650 (-34683) ns
average duration: 33303130 (-30203) ns
average duration: 33306477 (-26856) ns
average duration: 33308913 (-24420) ns
60 FPS:
   Camera index = 0
   Camera mode  = 3
   seconds to Run    = 0
average duration: 16616428 (-50239) ns
average duration: 16635327 (-31340) ns
average duration: 16641317 (-25350) ns
average duration: 16644189 (-22478) ns
average duration: 16645767 (-20900) ns
average duration: 16646926 (-19741) ns
average duration: 16647644 (-19023) ns
average duration: 16648237 (-18430) ns
So probably the sensor-mode 4 seems to be the cause of this strange FPS drift, especially given it’s not officially supported by the Raspberry Pi Camera Module V2 itself (it is officially declared to work at 90 FPS maximum at 1280x720).
So yes, @ShaneCCC, @mike_nv, thank you very much again for your help! I guess, it’s pretty much solved now.
