Can I get libnvscf.so file for r35.6 as provided in this link?
I am using imx477 camera with orin nx (JP 5.1.4). But it is giving SCF timeout error as mentioned in attached log.
timeout_error_log.txt (7.7 KB)
I don’t think IMX477 need the infinite timeout lib.
Do you confirm the IMX477 HW or driver by v4l2-ctl?
v4l2-ctl -c bypass_mode=0 --stream-mmap
Please check this putput:
$ v4l2-ctl -c bypass_mode=0 --stream-mmap
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 30.00 fps
<<<<<<<<<<<<<<<<<<<<<<<<<<^C
What’s your test? Multiple cameras?
No. Only one imx477 camera is there. Sometimes streaming works on it and sometimes it gives error as mentioned in the log.
Apply below patch to verify.
[ARGUS stability]
Is this same applicable for Orin nx?
It’s the same libs for Orin serials.
Okay.Thank you.I will check.
I replaced these two files in /usr/lib/aarch64-linux-gnu/tegra/, rebooted my SOM and when i tried this pipeline, even after mentioning 60fps, it gave only around 20fps and then failed as below :
$ gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! ‘video/x-raw(memory:NVMM),width=1920,height=1080,framerate=60/1’ ! nvvidconv ! nvv4l2h264enc ! rtph264pay ! udpsink host=192.168.55.100 port=4000 sync=false
Setting pipeline to PAUSED …
Opening in BLOCKING MODE
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
New clock: GstSystemClock
Redistribute latency…
NvMMLiteOpen : Block : BlockType = 4
===== NvVideo: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected…
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3840 x 2160 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 22.250000; Exposure Range min 13000, max 683709000;GST_ARGUS: 1920 x 1080 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 22.250000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 1
Output Stream W = 1920 H = 1080
seconds to Run = 0
Frame Rate = 59.999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
H264: Profile = 66, Level = 0
NVMEDIA: Need to set EMC bandwidth : 1692000
NvVideo: bBlitMode is set to TRUE
CONSUMER: ERROR OCCURRED
ERROR: from element /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0: CANCELLED
Additional debug info:
Argus Error Status
Execution ended after 0:03:39.396276192
Setting pipeline to NULL …
GST_ARGUS: Cleaning up
(Argus) Error Timeout: (propagating from src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 137)
(Argus) Error Timeout: (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 91)
Freeing pipeline …
(Argus) Error InvalidState: Argus client is exiting with 4 outstanding client threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 366)
and when after this error, I tried same pipeline again:
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:791 Failed to create CaptureSession
Got EOS from element “pipeline0”.
Execution ended after 0:00:00.002929664
Freeing pipeline …
journactl log for nvargus-daemon.service:
timeout1.txt (11.5 KB)
$ sudo systemctl status nvphs.service
[sudo] password for orin:
● nvphs.service - PHS daemon
Loaded: loaded (/etc/systemd/system/nvphs.service; enabled; vendor preset: enabled)
Active: active (running) since Wed 1969-12-31 19:16:45 EST; 14min ago
Process: 1148 ExecStartPre=/usr/sbin/nvphsd_setup.sh (code=exited, status=0/SUCCESS)
Main PID: 1329 (nvphsd)
Tasks: 2 (limit: 18280)
Memory: 676.0K
CGroup: /system.slice/nvphs.service
├─1329 /usr/sbin/nvphsd
└─1330 /usr/sbin/nvphsdDec 31 19:16:45 ubuntu systemd[1]: Starting PHS daemon…
Dec 31 19:16:45 ubuntu systemd[1]: Started PHS daemon.
Dec 31 19:16:45 ubuntu phs[1330]: E/ nvphs: Failed to initialize sysfs readers. Exiting.
Dec 31 19:16:45 ubuntu phs[1330]: E/ nvphs: Initialization Failed! Entering Zombie mode
Please confirm by below command.
gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! 'video/x-raw(memory:NVMM),width=1920,height=1080,framerate=60/1,format=NV12' ! nvvidconv ! fpsdisplaysink video-sink=fakesink -v
This command is also giving the same issue:
$ gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! ‘video/x-raw(memory:NVMM),width=1920,height=1080,framerate=60/1,format=NV12’ ! nvvidconv ! fpsdisplaysink video-sink=fakesink -v
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstFakeSink:fakesink0: sync = true
/GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)60/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)60/1
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)60/1
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0.GstGhostPad:sink.GstProxyPad:proxypad0: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)60/1
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay.GstPad:src: caps = video/x-raw(memory:NVMM, meta:GstVideoOverlayComposition), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)60/1
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstFakeSink:fakesink0.GstPad:sink: caps = video/x-raw(memory:NVMM, meta:GstVideoOverlayComposition), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)60/1
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay.GstPad:video_sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)60/1
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0.GstGhostPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)60/1
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)60/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)60/1
Camera index = 0
Camera mode = 1
seconds to Run = 0
WARNING: from element /GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstFakeSink:fakesink0: Pipeline construction is invalid, please add queues.
gstbasesink.c(1209): gst_base_sink_query_latency (): /GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstFakeSink:fakesink0:
Not enough buffering available for the processing deadline of 0:00:00.020000000, add enough queues to buffer 0:00:00.020000000 additional data. Shortening processing latency to 0:00:00.000000000.
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 11, dropped: 0, current: 21.52, average: 21.52
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 11, dropped: 0, current: 21.52, average: 21.52
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 20, dropped: 0, current: 17.94, average: 19.75
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 20, dropped: 0, current: 17.94, average: 19.75
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 29, dropped: 0, current: 17.98, average: 19.16
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 29, dropped: 0, current: 17.98, average: 19.16
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 38, dropped: 0, current: 17.37, average: 18.71
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 38, dropped: 0, current: 17.37, average: 18.71
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 51, dropped: 0, current: 24.15, average: 19.85
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 51, dropped: 0, current: 24.15, average: 19.85
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 62, dropped: 0, current: 21.59, average: 20.13
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 62, dropped: 0, current: 21.59, average: 20.13
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 72, dropped: 0, current: 19.88, average: 20.10
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 72, dropped: 0, current: 19.88, average: 20.10
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 83, dropped: 0, current: 20.02, average: 20.09
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 83, dropped: 0, current: 20.02, average: 20.09
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 92, dropped: 0, current: 17.29, average: 19.77
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 92, dropped: 0, current: 17.29, average: 19.77
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 102, dropped: 0, current: 19.45, average: 19.74
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 102, dropped: 0, current: 19.45, average: 19.74
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 112, dropped: 0, current: 18.83, average: 19.66
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 112, dropped: 0, current: 18.83, average: 19.66
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 122, dropped: 0, current: 19.90, average: 19.68
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 122, dropped: 0, current: 19.90, average: 19.68
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 130, dropped: 0, current: 15.52, average: 19.36
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 130, dropped: 0, current: 15.52, average: 19.36
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 139, dropped: 0, current: 17.92, average: 19.26
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 139, dropped: 0, current: 17.92, average: 19.26
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 149, dropped: 0, current: 19.00, average: 19.24
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 149, dropped: 0, current: 19.00, average: 19.24
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 159, dropped: 0, current: 19.15, average: 19.23
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 159, dropped: 0, current: 19.15, average: 19.23
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 167, dropped: 0, current: 15.59, average: 19.02
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 167, dropped: 0, current: 15.59, average: 19.02
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 177, dropped: 0, current: 18.25, average: 18.98
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 177, dropped: 0, current: 18.25, average: 18.98
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 189, dropped: 0, current: 21.07, average: 19.10
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 189, dropped: 0, current: 21.07, average: 19.10
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 199, dropped: 0, current: 19.70, average: 19.13
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 199, dropped: 0, current: 19.70, average: 19.13
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 209, dropped: 0, current: 19.42, average: 19.14
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 209, dropped: 0, current: 19.42, average: 19.14
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 219, dropped: 0, current: 18.16, average: 19.09
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 219, dropped: 0, current: 18.16, average: 19.09
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 229, dropped: 0, current: 18.04, average: 19.04
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 229, dropped: 0, current: 18.04, average: 19.04
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 238, dropped: 0, current: 16.60, average: 18.94
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 238, dropped: 0, current: 16.60, average: 18.94
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 249, dropped: 0, current: 21.03, average: 19.02
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 249, dropped: 0, current: 21.03, average: 19.02
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 259, dropped: 0, current: 18.44, average: 19.00
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 259, dropped: 0, current: 18.44, average: 19.00
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 268, dropped: 0, current: 17.37, average: 18.94
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 268, dropped: 0, current: 17.37, average: 18.94
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 278, dropped: 0, current: 18.80, average: 18.93
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 278, dropped: 0, current: 18.80, average: 18.93
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 289, dropped: 0, current: 21.22, average: 19.01
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 289, dropped: 0, current: 21.22, average: 19.01
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 298, dropped: 0, current: 16.35, average: 18.92
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 298, dropped: 0, current: 16.35, average: 18.92
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 307, dropped: 0, current: 17.63, average: 18.88
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 307, dropped: 0, current: 17.63, average: 18.88
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 318, dropped: 0, current: 20.84, average: 18.94
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 318, dropped: 0, current: 20.84, average: 18.94
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 327, dropped: 0, current: 16.84, average: 18.88
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 327, dropped: 0, current: 16.84, average: 18.88
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 335, dropped: 0, current: 15.38, average: 18.77
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 335, dropped: 0, current: 15.38, average: 18.77
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 346, dropped: 0, current: 20.52, average: 18.82
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 346, dropped: 0, current: 20.52, average: 18.82
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 356, dropped: 0, current: 19.51, average: 18.84
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 356, dropped: 0, current: 19.51, average: 18.84
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 367, dropped: 0, current: 19.46, average: 18.86
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 367, dropped: 0, current: 19.46, average: 18.86
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 377, dropped: 0, current: 19.52, average: 18.88
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 377, dropped: 0, current: 19.52, average: 18.88
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 386, dropped: 0, current: 16.84, average: 18.82
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 386, dropped: 0, current: 16.84, average: 18.82
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 396, dropped: 0, current: 17.98, average: 18.80
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 396, dropped: 0, current: 17.98, average: 18.80
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 407, dropped: 0, current: 19.34, average: 18.82
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 407, dropped: 0, current: 19.34, average: 18.82
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 416, dropped: 0, current: 17.09, average: 18.78
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 416, dropped: 0, current: 17.09, average: 18.78
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 427, dropped: 0, current: 19.91, average: 18.80
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 427, dropped: 0, current: 19.91, average: 18.80
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 434, dropped: 0, current: 13.52, average: 18.69
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 434, dropped: 0, current: 13.52, average: 18.69
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 443, dropped: 0, current: 17.44, average: 18.66
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 443, dropped: 0, current: 17.44, average: 18.66
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 452, dropped: 0, current: 17.85, average: 18.64
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 452, dropped: 0, current: 17.85, average: 18.64
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 462, dropped: 0, current: 19.99, average: 18.67
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 462, dropped: 0, current: 19.99, average: 18.67
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 472, dropped: 0, current: 17.51, average: 18.64
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 472, dropped: 0, current: 17.51, average: 18.64
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 481, dropped: 0, current: 17.80, average: 18.63
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 481, dropped: 0, current: 17.80, average: 18.63
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 491, dropped: 0, current: 18.67, average: 18.63
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 491, dropped: 0, current: 18.67, average: 18.63
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 502, dropped: 0, current: 20.98, average: 18.67
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 502, dropped: 0, current: 20.98, average: 18.67
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 512, dropped: 0, current: 18.27, average: 18.66
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 512, dropped: 0, current: 18.27, average: 18.66
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 522, dropped: 0, current: 18.40, average: 18.66
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 522, dropped: 0, current: 18.40, average: 18.66
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 531, dropped: 0, current: 17.76, average: 18.64
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 531, dropped: 0, current: 17.76, average: 18.64
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 541, dropped: 0, current: 19.77, average: 18.66
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 541, dropped: 0, current: 19.77, average: 18.66
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 549, dropped: 0, current: 15.31, average: 18.60
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 549, dropped: 0, current: 15.31, average: 18.60
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 560, dropped: 0, current: 21.92, average: 18.66
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 560, dropped: 0, current: 21.92, average: 18.66
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 569, dropped: 0, current: 17.58, average: 18.64
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 569, dropped: 0, current: 17.58, average: 18.64
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 579, dropped: 0, current: 19.82, average: 18.66
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 579, dropped: 0, current: 19.82, average: 18.66
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 588, dropped: 0, current: 17.54, average: 18.64
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 588, dropped: 0, current: 17.54, average: 18.64
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 598, dropped: 0, current: 19.98, average: 18.66
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 598, dropped: 0, current: 19.98, average: 18.66
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 608, dropped: 0, current: 18.27, average: 18.66
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 608, dropped: 0, current: 18.27, average: 18.66
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 617, dropped: 0, current: 17.55, average: 18.64
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 617, dropped: 0, current: 17.55, average: 18.64
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 625, dropped: 0, current: 14.59, average: 18.57
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 625, dropped: 0, current: 14.59, average: 18.57
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 635, dropped: 0, current: 18.27, average: 18.57
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 635, dropped: 0, current: 18.27, average: 18.57
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 643, dropped: 0, current: 14.56, average: 18.51
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 643, dropped: 0, current: 14.56, average: 18.51
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 653, dropped: 0, current: 18.34, average: 18.50
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 653, dropped: 0, current: 18.34, average: 18.50
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 663, dropped: 0, current: 19.99, average: 18.52
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 663, dropped: 0, current: 19.99, average: 18.52
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 673, dropped: 0, current: 19.27, average: 18.53
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 673, dropped: 0, current: 19.27, average: 18.53
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 683, dropped: 0, current: 18.57, average: 18.53
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 683, dropped: 0, current: 18.57, average: 18.53
ERROR: from element /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0: TIMEOUT
Argus Error Status
Execution ended after 0:00:39.682228192
Freeing pipeline …
(Argus) Error InvalidState: Argus client is exiting with 2 outstanding client threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 366)
$ journalctl -u nvargus-daemon.service
– Logs begin at Mon 2024-06-17 16:29:41 EDT, end at Mon 2024-06-17 16:37:17 EDT. –
Jun 17 16:29:54 ubuntu systemd[1]: Started Argus daemon.
Jun 17 16:31:45 ubuntu nvargus-daemon[946]: === NVIDIA Libargus Camera Service (0.99.33)=== Listening for connections…=== gst-launch-1.0[2794]: Connection established (FFFFB2A7E900)OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
Jun 17 16:31:45 ubuntu nvargus-daemon[946]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module1
Jun 17 16:31:45 ubuntu nvargus-daemon[946]: NvPclHwGetModuleList: No module data found
Jun 17 16:31:45 ubuntu nvargus-daemon[946]: OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
Jun 17 16:31:45 ubuntu nvargus-daemon[946]: ---- imager: No override file found. ----
Jun 17 16:31:45 ubuntu nvargus-daemon[946]: (NvCamV4l2) Error ModuleNotPresent: V4L2Device not available (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function findDevice(), line 257)
Jun 17 16:31:45 ubuntu nvargus-daemon[946]: (NvCamV4l2) Error ModuleNotPresent: (propagating from /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function initialize(), line 61)
Jun 17 16:31:45 ubuntu nvargus-daemon[946]: (NvOdmDevice) Error ModuleNotPresent: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function initialize(), line 112)
Jun 17 16:31:45 ubuntu nvargus-daemon[946]: NvPclDriverInitializeData: Unable to initialize driver v4l2_sensor
Jun 17 16:31:45 ubuntu nvargus-daemon[946]: NvPclInitializeDrivers: error: Failed to init camera sub module v4l2_sensor
Jun 17 16:31:45 ubuntu nvargus-daemon[946]: NvPclStartPlatformDrivers: Failed to start module drivers
Jun 17 16:31:45 ubuntu nvargus-daemon[946]: NvPclDriver_V4L2_Focuser_Stub_Close: Invalid NULL input pPclDriver
Jun 17 16:31:45 ubuntu nvargus-daemon[946]: NvPclStateControllerOpen: Failed ImagerGUID 0. (error 0xA000E)
Jun 17 16:31:45 ubuntu nvargus-daemon[946]: NvPclOpen: PCL Open Failed. Error: 0xf
Jun 17 16:31:45 ubuntu nvargus-daemon[946]: SCF: Error BadParameter: Sensor could not be opened. (in src/services/capture/CaptureServiceDeviceSensor.cpp, function getSourceFromGuid(), line 726)
Jun 17 16:31:45 ubuntu nvargus-daemon[946]: SCF: Error BadParameter: (propagating from src/services/capture/CaptureService.cpp, function addSourceByGuid(), line 453)
Jun 17 16:31:45 ubuntu nvargus-daemon[946]: SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function addSourceByIndex(), line 347)
Jun 17 16:31:45 ubuntu nvargus-daemon[946]: SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function getSource(), line 519)
Jun 17 16:31:45 ubuntu nvargus-daemon[946]: E/ libnvphs:socket: Error[2]: socket connection /var/lib/nvphs/nvphsd.ctl to PHS failed: No such file or directory
Jun 17 16:31:45 ubuntu nvargus-daemon[946]: D/ libnvphs:socket: Warning: connecting to Power Hinting Service failed. Is PHS running?
Jun 17 16:31:45 ubuntu nvargus-daemon[946]: === gst-launch-1.0[2794]: CameraProvider initialized (0xffffac6cb3b0)SCF: Error BadValue: NvPHSSendThroughputHints (in src/common/CameraPowerHint.cpp, function sendCameraPowerHint(), line 56)
Jun 17 16:31:45 ubuntu nvargus-daemon[946]: E/ libnvphs: Error: NvPHSSendThroughputHints[usecase=camera, hint=MinCPU, value=4294967295, timeout_ms=1000]: queue_or_send() failed
Jun 17 16:32:25 ubuntu nvargus-daemon[946]: SCF: Error Timeout: (propagating from src/components/amr/Snapshot.cpp, function waitForNewerSample(), line 91)
Jun 17 16:32:25 ubuntu nvargus-daemon[946]: SCF_AutocontrolACSync failed to wait for an earlier frame to complete.
Jun 17 16:32:25 ubuntu nvargus-daemon[946]: SCF: Error Timeout: (propagating from src/components/ac_stages/ACSynchronizeStage.cpp, function doHandleRequest(), line 126)
Jun 17 16:32:25 ubuntu nvargus-daemon[946]: SCF: Error Timeout: (propagating from src/components/stages/OrderedStage.cpp, function doExecute(), line 137)
Jun 17 16:32:25 ubuntu nvargus-daemon[946]: SCF: Error Timeout: Sending critical error event for Session 1
Jun 17 16:32:25 ubuntu nvargus-daemon[946]: (in src/api/Session.cpp, function sendErrorEvent(), line 1039)
Jun 17 16:32:30 ubuntu nvargus-daemon[946]: waitForIdleLocked remaining request 1583
Jun 17 16:32:30 ubuntu nvargus-daemon[946]: waitForIdleLocked remaining request 1574
Jun 17 16:32:30 ubuntu nvargus-daemon[946]: SCF: Error Timeout: waitForIdle() timed out (in src/api/Session.cpp, function waitForIdleLocked(), line 969)
Jun 17 16:32:31 ubuntu nvargus-daemon[946]: SCF: Error Timeout: (propagating from src/components/CaptureContainerImpl.cpp, function assignAllBuffersFromStream(), line 271)
Jun 17 16:32:31 ubuntu nvargus-daemon[946]: SCF: Error Timeout: (propagating from src/components/stages/CCDataSetupStage.cpp, function doHandleRequest(), line 76)
Jun 17 16:32:31 ubuntu nvargus-daemon[946]: SCF: Error Timeout: (propagating from src/components/stages/OrderedStage.cpp, function doExecute(), line 158)
Jun 17 16:32:35 ubuntu nvargus-daemon[946]: waitForIdleLocked remaining request 1574
Jun 17 16:32:35 ubuntu nvargus-daemon[946]: SCF: Error Timeout: waitForIdle() timed out (in src/api/Session.cpp, function waitForIdleLocked(), line 969)
Jun 17 16:32:40 ubuntu nvargus-daemon[946]: SCF: Error InvalidState: 1 buffers still pending during EGLStreamProducer destruction (in src/services/gl/EGLStreamProducer.cpp, function freeBuffers(), line 301)
Jun 17 16:32:45 ubuntu nvargus-daemon[946]: waitForIdleLocked remaining request 1574
Jun 17 16:32:45 ubuntu nvargus-daemon[946]: SCF: Error Timeout: waitForIdle() timed out (in src/api/Session.cpp, function waitForIdleLocked(), line 969)
Jun 17 16:32:50 ubuntu nvargus-daemon[946]: waitForIdleLocked remaining request 1574
Jun 17 16:32:50 ubuntu nvargus-daemon[946]: SCF: Error Timeout: waitForIdle() timed out (in src/api/Session.cpp, function waitForIdleLocked(), line 969)
Jun 17 16:32:50 ubuntu nvargus-daemon[946]: PowerServiceCore:handleRequests: timePassed = 25589
Add the event-wait and acquire-wait to try.
gst-launch-1.0 -v -e nvarguscamerasrc event-wait=5000000000 acquire-wait=6000000000 ! 'video/x-raw(memory:NVMM)' ! nvvidconv ! fakesink sync=0
This is also giving the same error.
Thank you.
Replace the libnvscf.so by attached file to check with infinite mode.
libnvscf.so.r35.6.infinte (8.4 MB)
sudo service nvargus-daemon stop
sudo enableCamInfiniteTimeout=1 nvargus-daemon
Thank you so much for this file.
Can I use this same file for Jetpack 5.1.5?
JP5.1.5 similar with JP5.1.4 please try it.
output of streaming pipeline:
$ gst-launch-1.0 -e nvarguscamerasrc ! “video/x-raw(memory:NVMM),width=1920,height=1080,framerate=60/1,format=NV12” ! queue ! nvvidconv ! queue ! nvv4l2h265enc bitrate=1200000 control-rate=1 ! h265parse ! rtph265pay ! udpsink host=192.168.55.100 port=5000
NvMMLiteOpen : Block : BlockType = 8
NvMMLiteBlockCreate : Block : BlockType = 8
Camera index = 0
Camera mode = 1
seconds to Run = 0
NvVideo: H265 : Profile : 1
CONSUMER: Done Success
Execution ended after 0:01:50.776260320
Caught SIGSEGV
Spinning. Please run ‘gdb gst-launch-1.0 2655’ to continue debugging, Ctrl-C to quit, or Ctrl-\ to dump core.
Output of enableCamInfiniteTimeout=1:
$ sudo enableCamInfiniteTimeout=1 nvargus-daemon
=== gst-launch-1.0[2655]: Connection established (FFFF9DB22900)OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
=== gst-launch-1.0[2655]: CameraProvider initialized (0xffff986cdbe0)SCF: Error BadValue: NvPHSSendThroughputHints (in src/common/CameraPowerHint.cpp, function sendCameraPowerHint(), line 56)
SCF: Error CaptureAborted: (propagating from src/components/stages/OrderedStage.cpp, function doExecute(), line 137)
SCF: Error InvalidState: (propagating from src/services/gl/EGLStreamProducer.cpp, function returnFrame(), line 369)
SCF: Error InvalidState: (propagating from src/services/gl/EGLStreamProducer.cpp, function getBuffer(), line 431)
SCF: Error InvalidState: (propagating from src/components/CaptureContainerImpl.cpp, function assignAllBuffersFromStream(), line 272)
SCF: Error InvalidState: (propagating from src/components/stages/CCDataSetupStage.cpp, function doHandleRequest(), line 76)
SCF: Error InvalidState: (propagating from src/components/stages/OrderedStage.cpp, function doExecute(), line 158)
SCF: Error InvalidState: Sending critical error event for Session 1
=== gst-launch-1.0[2655]: Connection closed (FFFF9DB22900)=== gst-launch-1.0[2655]: WARNING: CameraProvider was not destroyed before client connection terminated.=== gst-launch-1.0[2655]: The client may have abnormally terminated. Destroying CameraProvider…=== gst-launch-1.0[2655]: CameraProvider destroyed (0xffff986cdbe0)=== gst-launch-1.0[2655]: WARNING: Cleaning up 1 outstanding requests…=== gst-launch-1.0[2655]: WARNING: Cleaning up 1 outstanding stream settings…=== gst-launch-1.0[2655]: WARNING: Cleaning up 1 outstanding queues…=== gst-launch-1.0[2655]: WARNING: Cleaning up 1 outstanding sessions…
Please verify on MMAPI sample APP like argus_camera.
