Nvargus-daemon errors when using nvarguscamerasrc at boot
I am running Jetpack 4.6 and L4T 32.6.1.
I have a docker container that starts 6 gstreamer streams with nvarguscamerasrc with different sensor-id.
But I get this error repeatedly in /var/log/syslog :
Dec 13 12:03:11 jetson-rogue-carrier nvargus-daemon[6577]: message repeated 4 times: [ (Argus) Error OverFlow: Too many pending events, ignoring new events (in src/api/EventProviderImpl.cpp, function addEvent(), line 158)]
Dec 13 12:03:11 jetson-rogue-carrier nvargus-daemon[6577]: SCF: Error InvalidState: Sequence order error (9427 received, 9424 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
Dec 13 12:03:11 jetson-rogue-carrier nvargus-daemon[6577]: (Argus) Error OverFlow: Too many pending events, ignoring new events (in src/api/EventProviderImpl.cpp, function addEvent(), line 158)
Here’s the result of sudo journalctl -u nvargus-daemon :
-- Logs begin at Mon 2021-12-13 12:44:42 EET, end at Mon 2021-12-13 12:45:40 EET. --
dets  13 12:44:51 jetson-rogue-carrier systemd[1]: Started Argus daemon.
dets  13 12:45:00 jetson-rogue-carrier nvargus-daemon[6538]: === NVIDIA Libargus Camera Service (0.98.3)=== Listening for connections...=== gstd[1]: Connection established (7F74C9A1D0)OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
dets  13 12:45:00 jetson-rogue-carrier nvargus-daemon[6538]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module1
dets  13 12:45:00 jetson-rogue-carrier nvargus-daemon[6538]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module2
dets  13 12:45:00 jetson-rogue-carrier nvargus-daemon[6538]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module3
dets  13 12:45:00 jetson-rogue-carrier nvargus-daemon[6538]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module4
dets  13 12:45:00 jetson-rogue-carrier nvargus-daemon[6538]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module5
dets  13 12:45:00 jetson-rogue-carrier nvargus-daemon[6538]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module6
dets  13 12:45:00 jetson-rogue-carrier nvargus-daemon[6538]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module7
dets  13 12:45:00 jetson-rogue-carrier nvargus-daemon[6538]: NvPclHwGetModuleList: WARNING: Could not map module to ISP config string
dets  13 12:45:00 jetson-rogue-carrier nvargus-daemon[6538]: NvPclHwGetModuleList: No module data found
dets  13 12:45:00 jetson-rogue-carrier nvargus-daemon[6538]: OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
dets  13 12:45:00 jetson-rogue-carrier nvargus-daemon[6538]: ---- imager: Found override file [/var/nvidia/nvcam/settings/camera_overrides.isp]. ----
dets  13 12:45:00 jetson-rogue-carrier nvargus-daemon[6538]: CAM: serial no file already exists, skips storing againLSC: LSC surface is not based on full res!
dets  13 12:45:00 jetson-rogue-carrier nvargus-daemon[6538]: (NvCamV4l2) Error ModuleNotPresent: V4L2Device not available (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function findDevice(), line 256)
dets  13 12:45:00 jetson-rogue-carrier nvargus-daemon[6538]: (NvCamV4l2) Error ModuleNotPresent:  (propagating from /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function initialize(), line 60)
dets  13 12:45:00 jetson-rogue-carrier nvargus-daemon[6538]: (NvOdmDevice) Error ModuleNotPresent:  (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function initialize(), line 107)
dets  13 12:45:00 jetson-rogue-carrier nvargus-daemon[6538]: NvPclDriverInitializeData: Unable to initialize driver v4l2_sensor
dets  13 12:45:00 jetson-rogue-carrier nvargus-daemon[6538]: NvPclInitializeDrivers: error: Failed to init camera sub module v4l2_sensor
dets  13 12:45:00 jetson-rogue-carrier nvargus-daemon[6538]: NvPclStartPlatformDrivers: Failed to start module drivers
dets  13 12:45:00 jetson-rogue-carrier nvargus-daemon[6538]: NvPclStateControllerOpen: Failed ImagerGUID 6. (error 0xA000E)
dets  13 12:45:00 jetson-rogue-carrier nvargus-daemon[6538]: NvPclOpen: PCL Open Failed. Error: 0xf
dets  13 12:45:00 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error BadParameter: Sensor could not be opened. (in src/services/capture/CaptureServiceDeviceSensor.cpp, function getSourceFromGuid(), line 582)
dets  13 12:45:00 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error BadParameter:  (propagating from src/services/capture/CaptureService.cpp, function addSourceByGuid(), line 437)
dets  13 12:45:00 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error BadParameter:  (propagating from src/api/CameraDriver.cpp, function addSourceByIndex(), line 305)
dets  13 12:45:00 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error BadParameter:  (propagating from src/api/CameraDriver.cpp, function getSource(), line 471)
dets  13 12:45:00 jetson-rogue-carrier nvargus-daemon[6538]: Acquiring SCF Camera device source via index 6 has failed. ---- imager: Found override file [/var/nvidia/nvcam/settings/camera_overrides.isp]. ----
dets  13 12:45:00 jetson-rogue-carrier nvargus-daemon[6538]: NvPclStateControllerOpen: Failed ImagerGUID 7. (error 0xA000E)
dets  13 12:45:00 jetson-rogue-carrier nvargus-daemon[6538]: Acquiring SCF Camera device source via index 7 has failed. === gstd[1]: CameraProvider initialized (0x7f70c76fe0)CAM: serial no file already exists, skips storing againLSC: LSC surface is not based on full res!
dets  13 12:45:03 jetson-rogue-carrier nvargus-daemon[6538]: CAM: serial no file already exists, skips storing againLSC: LSC surface is not based on full res!
dets  13 12:45:04 jetson-rogue-carrier nvargus-daemon[6538]: (NvCapture) Error Timeout: capture waiting for status timeout (in /dvs/git/dirty/git-master_linux/camera/capture/nvcapture/capture_hw_linux.c, function NvCaptureLinuxGetCaptureStatus(), line 362)
dets  13 12:45:04 jetson-rogue-carrier nvargus-daemon[6538]: (NvCapture) Error Timeout:  (propagating from /dvs/git/dirty/git-master_linux/camera/capture/nvcapture/capture.c, function NvCaptureDequeue(), line 1055)
dets  13 12:45:04 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error Timeout:  (propagating from src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 898)
dets  13 12:45:04 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Timeout waiting on frame end sensor guid 0, capture sequence ID = 1, channel = 1/1 (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 905)
dets  13 12:45:04 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Timeout waiting on frame start sensor guid 0, capture sequence ID = 1 (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameStart(), line 1018)
dets  13 12:45:04 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Something went wrong with waiting on frame end (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 991)
dets  13 12:45:04 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Something went wrong with waiting on frame start (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameStart(), line 1077)
dets  13 12:45:05 jetson-rogue-carrier nvargus-daemon[6538]: PowerServiceCore:handleRequests: timePassed = 2898
dets  13 12:45:05 jetson-rogue-carrier nvargus-daemon[6538]: NvCaptureStatusErrorDecode Stream 5.1 failed: sof_ts 42771183168 eof_ts 1368965815296 frame 0 error 14 data 0x00020000
dets  13 12:45:05 jetson-rogue-carrier nvargus-daemon[6538]: NvCaptureStatusErrorDecode Capture-Error: FALCON_ERROR (0x0000000e)
dets  13 12:45:05 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Capture error with status 14 (channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 930)
dets  13 12:45:06 jetson-rogue-carrier nvargus-daemon[6538]: PowerServiceCore:handleRequests: timePassed = 1401
dets  13 12:45:06 jetson-rogue-carrier nvargus-daemon[6538]: NvCaptureStatusErrorDecode Stream 5.0 failed: sof_ts 42771172928 eof_ts 1369066206208 frame 0 error 14 data 0x00020000
dets  13 12:45:06 jetson-rogue-carrier nvargus-daemon[6538]: NvCaptureStatusErrorDecode Capture-Error: FALCON_ERROR (0x0000000e)
dets  13 12:45:06 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Capture error with status 14 (channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 930)
dets  13 12:45:06 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (4 received, 1 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:06 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (5 received, 2 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:06 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (6 received, 3 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:07 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (7 received, 4 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:07 jetson-rogue-carrier nvargus-daemon[6538]: CAM: serial no file already exists, skips storing againLSC: LSC surface is not based on full res!
dets  13 12:45:07 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (8 received, 5 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:07 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (9 received, 6 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:07 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (10 received, 7 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:08 jetson-rogue-carrier nvargus-daemon[6538]: PowerServiceCore:handleRequests: timePassed = 1476
dets  13 12:45:08 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (11 received, 8 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:08 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (12 received, 9 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:08 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (13 received, 10 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:08 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (14 received, 11 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:08 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (15 received, 12 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:08 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (16 received, 13 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:08 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (17 received, 14 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:08 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (18 received, 15 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:08 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (19 received, 16 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:08 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (20 received, 17 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:08 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (21 received, 18 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:08 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (22 received, 19 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:08 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (23 received, 20 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:09 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (24 received, 21 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:09 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (25 received, 22 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:09 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (26 received, 23 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:09 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (27 received, 24 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:09 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (28 received, 25 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:09 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (29 received, 26 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:09 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (30 received, 27 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:09 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (31 received, 28 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:09 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (32 received, 29 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:09 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (33 received, 30 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:09 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (34 received, 31 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:09 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (35 received, 32 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:09 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (36 received, 33 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:09 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (37 received, 34 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:09 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (38 received, 35 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:09 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (39 received, 36 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:09 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (40 received, 37 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:09 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (41 received, 38 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:09 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (42 received, 39 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:09 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (43 received, 40 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:09 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (44 received, 41 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:09 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (45 received, 42 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:09 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (46 received, 43 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:09 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (47 received, 44 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:09 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (48 received, 45 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:09 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (49 received, 46 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:09 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (50 received, 47 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:09 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (51 received, 48 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:09 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (52 received, 49 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:09 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (53 received, 50 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:10 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (54 received, 51 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:10 jetson-rogue-carrier nvargus-daemon[6538]: CAM: serial no file already exists, skips storing againLSC: LSC surface is not based on full res!
dets  13 12:45:10 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (55 received, 52 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:10 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (56 received, 53 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:10 jetson-rogue-carrier nvargus-daemon[6538]: (NvCapture) Error Timeout: capture waiting for status timeout (in /dvs/git/dirty/git-master_linux/camera/capture/nvcapture/capture_hw_linux.c, function NvCaptureLinuxGetCaptureStatus(), line 362)
dets  13 12:45:10 jetson-rogue-carrier nvargus-daemon[6538]: (NvCapture) Error Timeout:  (propagating from /dvs/git/dirty/git-master_linux/camera/capture/nvcapture/capture.c, function NvCaptureDequeue(), line 1055)
dets  13 12:45:10 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error Timeout:  (propagating from src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 898)
dets  13 12:45:10 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Timeout waiting on frame start sensor guid 2, capture sequence ID = 1 (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameStart(), line 1018)
dets  13 12:45:10 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Timeout waiting on frame end sensor guid 2, capture sequence ID = 1, channel = 1/1 (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 905)
dets  13 12:45:10 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Something went wrong with waiting on frame end (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 991)
dets  13 12:45:10 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Something went wrong with waiting on frame start (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameStart(), line 1077)
dets  13 12:45:10 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (57 received, 54 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:11 jetson-rogue-carrier nvargus-daemon[6538]: PowerServiceCore:handleRequests: timePassed = 1406
dets  13 12:45:11 jetson-rogue-carrier nvargus-daemon[6538]: NvCaptureStatusErrorDecode Stream 4.0 failed: sof_ts 47331396640 eof_ts 1514788344832 frame 0 error 14 data 0x00020000
dets  13 12:45:11 jetson-rogue-carrier nvargus-daemon[6538]: NvCaptureStatusErrorDecode Capture-Error: FALCON_ERROR (0x0000000e)
dets  13 12:45:11 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Capture error with status 14 (channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 930)
dets  13 12:45:11 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (4 received, 1 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:11 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (5 received, 2 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:11 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (58 received, 55 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:11 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (59 received, 56 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:11 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error Timeout:  (propagating from src/components/amr/Snapshot.cpp, function waitForNewerSample(), line 92)
dets  13 12:45:11 jetson-rogue-carrier nvargus-daemon[6538]: SCF_AutocontrolACSync failed to wait for an earlier frame to complete.
dets  13 12:45:11 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error Timeout:  (propagating from src/components/ac_stages/ACSynchronizeStage.cpp, function doHandleRequest(), line 126)
dets  13 12:45:11 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error Timeout:  (propagating from src/components/stages/OrderedStage.cpp, function doExecute(), line 137)
dets  13 12:45:11 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error Timeout: Sending critical error event (in src/api/Session.cpp, function sendErrorEvent(), line 997)
dets  13 12:45:12 jetson-rogue-carrier nvargus-daemon[6538]: PowerServiceCore:handleRequests: timePassed = 1452
dets  13 12:45:13 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (6 received, 3 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:13 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (60 received, 57 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:13 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (61 received, 58 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:13 jetson-rogue-carrier nvargus-daemon[6538]: CAM: serial no file already exists, skips storing againLSC: LSC surface is not based on full res!
dets  13 12:45:13 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (7 received, 4 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:13 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (62 received, 59 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:13 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (63 received, 60 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:13 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (64 received, 61 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:14 jetson-rogue-carrier nvargus-daemon[6538]: (NvCapture) Error Timeout: capture waiting for status timeout (in /dvs/git/dirty/git-master_linux/camera/capture/nvcapture/capture_hw_linux.c, function NvCaptureLinuxGetCaptureStatus(), line 362)
dets  13 12:45:14 jetson-rogue-carrier nvargus-daemon[6538]: (NvCapture) Error Timeout:  (propagating from /dvs/git/dirty/git-master_linux/camera/capture/nvcapture/capture.c, function NvCaptureDequeue(), line 1055)
dets  13 12:45:14 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error Timeout:  (propagating from src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 898)
dets  13 12:45:14 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Timeout waiting on frame end sensor guid 3, capture sequence ID = 1, channel = 1/1 (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 905)
dets  13 12:45:14 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Something went wrong with waiting on frame end (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 991)
dets  13 12:45:14 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Timeout waiting on frame start sensor guid 3, capture sequence ID = 1 (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameStart(), line 1018)
dets  13 12:45:14 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Something went wrong with waiting on frame start (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameStart(), line 1077)
dets  13 12:45:14 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Timeout waiting on frame start sensor guid 2, capture sequence ID = 6 (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameStart(), line 1018)
dets  13 12:45:14 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error Timeout: Sending critical error event (in src/api/Session.cpp, function sendErrorEvent(), line 997)
dets  13 12:45:14 jetson-rogue-carrier nvargus-daemon[6538]: PowerServiceCore:handleRequests: timePassed = 1471
dets  13 12:45:14 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (65 received, 62 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:14 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (66 received, 63 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:14 jetson-rogue-carrier nvargus-daemon[6538]: (NvCamV4l2) Error IoctlFailed:  (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function streamControl(), line 1661)
dets  13 12:45:14 jetson-rogue-carrier nvargus-daemon[6538]: (NvOdmDevice) Error IoctlFailed:  (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function apply(), line 206)
dets  13 12:45:15 jetson-rogue-carrier nvargus-daemon[6538]: NvCaptureStatusErrorDecode Stream 4.1 failed: sof_ts 51880796704 eof_ts 1660662051840 frame 0 error 14 data 0x00020000
dets  13 12:45:15 jetson-rogue-carrier nvargus-daemon[6538]: NvCaptureStatusErrorDecode Capture-Error: FALCON_ERROR (0x0000000e)
dets  13 12:45:15 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Capture error with status 14 (channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 930)
dets  13 12:45:15 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (4 received, 1 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:16 jetson-rogue-carrier nvargus-daemon[6538]: CAM: serial no file already exists, skips storing againLSC: LSC surface is not based on full res!
dets  13 12:45:16 jetson-rogue-carrier nvargus-daemon[6538]: PowerServiceCore:handleRequests: timePassed = 1435
dets  13 12:45:16 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (5 received, 2 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:16 jetson-rogue-carrier nvargus-daemon[6538]: (NvCapture) Error Timeout: capture waiting for status timeout (in /dvs/git/dirty/git-master_linux/camera/capture/nvcapture/capture_hw_linux.c, function NvCaptureLinuxGetCaptureStatus(), line 362)
dets  13 12:45:16 jetson-rogue-carrier nvargus-daemon[6538]: (NvCapture) Error Timeout:  (propagating from /dvs/git/dirty/git-master_linux/camera/capture/nvcapture/capture.c, function NvCaptureDequeue(), line 1055)
dets  13 12:45:16 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error Timeout:  (propagating from src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 898)
dets  13 12:45:16 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Timeout waiting on frame end sensor guid 4, capture sequence ID = 1, channel = 1/1 (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 905)
dets  13 12:45:16 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Something went wrong with waiting on frame end (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 991)
dets  13 12:45:16 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Timeout waiting on frame start sensor guid 4, capture sequence ID = 1 (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameStart(), line 1018)
dets  13 12:45:16 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Something went wrong with waiting on frame start (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameStart(), line 1077)
dets  13 12:45:17 jetson-rogue-carrier nvargus-daemon[6538]: PowerServiceCore:handleRequests: timePassed = 1387
dets  13 12:45:17 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (8 received, 5 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:17 jetson-rogue-carrier nvargus-daemon[6538]: NvCaptureStatusErrorDecode Stream 4.0 failed: sof_ts 0 eof_ts 53287442816 frame 0 error 2 data 0x000000a4
dets  13 12:45:17 jetson-rogue-carrier nvargus-daemon[6538]: NvCaptureStatusErrorDecode Capture-Error: CSIMUX_FRAME (0x00000002)
dets  13 12:45:17 jetson-rogue-carrier nvargus-daemon[6538]: CsimuxFrameError_Regular : 0x000000a4
dets  13 12:45:17 jetson-rogue-carrier nvargus-daemon[6538]:     Stream ID                [ 2: 0]: 4
dets  13 12:45:17 jetson-rogue-carrier nvargus-daemon[6538]:     VPR state from fuse block    [ 3]: 0
dets  13 12:45:17 jetson-rogue-carrier nvargus-daemon[6538]:     Frame end (FE)              [ 5]: 1
dets  13 12:45:17 jetson-rogue-carrier nvargus-daemon[6538]:         A frame end has been found on a regular mode stream.
dets  13 12:45:17 jetson-rogue-carrier nvargus-daemon[6538]:     FS_FAULT                    [ 7]: 1
dets  13 12:45:17 jetson-rogue-carrier nvargus-daemon[6538]:         A FS packet was found for a virtual channel that was already in frame.An errored FE packet was injected before FS was allowed through.
dets  13 12:45:17 jetson-rogue-carrier nvargus-daemon[6538]:     Binary VC number [3:2]   [27:26]: 0
dets  13 12:45:17 jetson-rogue-carrier nvargus-daemon[6538]:         To get full binary VC number, user need to concatenate VC[3:2] and VC[1:0] together.
dets  13 12:45:17 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Capture error with status 2 (channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 930)
dets  13 12:45:17 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (9 received, 6 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:17 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (67 received, 64 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:17 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (68 received, 65 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:17 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (6 received, 3 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:17 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (7 received, 4 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:17 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (10 received, 7 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:17 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (69 received, 66 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:18 jetson-rogue-carrier nvargus-daemon[6538]: PowerServiceCore:handleRequests: timePassed = 1394
dets  13 12:45:18 jetson-rogue-carrier nvargus-daemon[6538]: NvCaptureStatusErrorDecode Stream 2.0 failed: sof_ts 54755309664 eof_ts 1752234027008 frame 0 error 14 data 0x00020000
dets  13 12:45:18 jetson-rogue-carrier nvargus-daemon[6538]: NvCaptureStatusErrorDecode Capture-Error: FALCON_ERROR (0x0000000e)
dets  13 12:45:18 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Capture error with status 14 (channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 930)
dets  13 12:45:18 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (4 received, 1 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:18 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (5 received, 2 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:20 jetson-rogue-carrier nvargus-daemon[6538]: PowerServiceCore:handleRequests: timePassed = 1451
dets  13 12:45:20 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (70 received, 67 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:20 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (71 received, 68 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:20 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (8 received, 5 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:20 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (9 received, 6 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:20 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (6 received, 3 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:20 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (7 received, 4 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:20 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (11 received, 8 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:20 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (12 received, 9 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:20 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (72 received, 69 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:20 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (13 received, 10 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:20 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (10 received, 7 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:20 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (73 received, 70 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:20 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (14 received, 11 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:20 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (74 received, 71 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:20 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (15 received, 12 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:20 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (75 received, 72 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:20 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (16 received, 13 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:20 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (76 received, 73 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:20 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (17 received, 14 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:20 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (77 received, 74 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:20 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (18 received, 15 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:20 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (78 received, 75 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:20 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (19 received, 16 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:20 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (79 received, 76 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:20 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (20 received, 17 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:20 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (80 received, 77 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:20 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (21 received, 18 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:20 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (81 received, 78 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:20 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (22 received, 19 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:20 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (82 received, 79 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:20 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (23 received, 20 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:20 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (83 received, 80 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:20 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (24 received, 21 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:20 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (84 received, 81 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:20 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (25 received, 22 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:20 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (85 received, 82 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:20 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (26 received, 23 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:20 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (86 received, 83 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:20 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (27 received, 24 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:20 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (87 received, 84 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:20 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (28 received, 25 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:21 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (88 received, 85 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:21 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (29 received, 26 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:21 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (26 received, 23 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:21 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (89 received, 86 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:21 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (30 received, 27 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:21 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (27 received, 24 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:21 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (90 received, 87 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:21 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (31 received, 28 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:21 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (28 received, 25 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:21 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (91 received, 88 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:21 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (32 received, 29 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:21 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (92 received, 89 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:21 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (33 received, 30 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:21 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (93 received, 90 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:21 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (34 received, 31 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:21 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (94 received, 91 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:21 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (35 received, 32 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:21 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (95 received, 92 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:21 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (36 received, 33 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:21 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (96 received, 93 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:21 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (37 received, 34 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:21 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (97 received, 94 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:21 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (38 received, 35 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:21 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (98 received, 95 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:21 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (39 received, 36 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:21 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (99 received, 96 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:21 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (40 received, 37 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:21 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (100 received, 97 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:21 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (41 received, 38 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:21 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (101 received, 98 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:21 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (42 received, 39 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:21 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (102 received, 99 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:21 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (43 received, 40 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:21 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (103 received, 100 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:21 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (44 received, 41 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:21 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (104 received, 101 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:21 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (45 received, 42 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:21 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (105 received, 102 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:21 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (46 received, 43 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
dets  13 12:45:21 jetson-rogue-carrier nvargus-daemon[6538]: SCF: Error InvalidState: Sequence order error (106 received, 103 expected, channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 937)
Other symptom :
It seems that nvarguscamerasrc always fails the first time it is used. Then works. Log when failing :
nvidia@jetson-rogue-carrier:~$ gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! queue ! fakesink
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 1920 x 1080 FR = 29,999999 fps Duration = 33333334 ; Analog Gain range min 1,000000, max 31,622776; Exposure Range min 59000, max 33333000;
GST_ARGUS: Running with following settings:
   Camera index = 0
   Camera mode  = 0
   Output Stream W = 1920 H = 1080
   seconds to Run    = 0
   Frame Rate = 29,999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
nvbuf_utils: dmabuf_fd -1 mapped entry NOT found
nvbuf_utils: Can not get HW buffer from FD... Exiting...
CONSUMER: ERROR OCCURRED
ERROR: from element /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0: CANCELLED
Additional debug info:
Argus Error Status
Execution ended after 0:00:03.156519168
Setting pipeline to READY ...
GST_ARGUS: Cleaning up
Setting pipeline to NULL ...
Freeing pipeline ...
If I restart the docker container the logs go away.
I have tried to add the nvargus-daemon.service as a requirement for the docker service but it doesn’t solve the problem.
IT really looks like a race condition at boot, but I cannot pinpoint the problem. Any idea ?
Thanks !
Sorry for the late response, is this still an issue to support?
