Jetpack 5.0.2 nvarguscamerasrc streaming stopped, reason not-negotiated (-4)
Hi Nvidia support team,
I’m facing a problem when trying to stream on Wayland graphics using nvarguscamerasrc.
Below is my procedure:
  1. Start weston
mypc@ubuntu:~$ nvstart-weston.sh
[sudo] password for mypc:
Launching weston...
!!! Weston launched successfully !!!
Weston startup log at:/tmp/weston-startup.log
To exit weston gracefully, execute:
    pkill -15 weston
Execute the following steps before starting X11 again:
    pkill -15 weston
    sudo rmmod tegra-udrm
  1. Try streaming using v4l2-ctrl
mypc@ubuntu:~$ v4l2-ctl -d /dev/video0 --set-fmt-video=width=3840,height=2160,pixelformat=RG10 --set-ctrl sensor_mode=0 --stream-mmap --stream-count=50
<<<<<<<<<<<<<<<<<<<<<<<<<< 23.44 fps
<<<<<<<<<<<<<<<<<<< 21.64 fps
  1. Stream video and error
mypc@ubuntu:~$ gst-launch-1.0 -v nvarguscamerasrc sensor-id=0 ! 'video/x-raw(memory:NVMM),width=3840,height=2160,format=(string)NV12,framerate=(fraction)30/1' ! nvcompositor ! autovideosink
Setting pipeline to PAUSED ...
Using winsys: x11
Using winsys: x11
Pipeline is live and does not need PREROLL ...
Got context from element 'autovideosink0-actual-sink-nveglgles': gst.egl.EGLDisplay=context, display=(GstEGLDisplay)NULL;
Setting pipeline to PLAYING ...
New clock: GstSystemClock
/GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)3840, height=(int)2160, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)3840, height=(int)2160, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstNvCompositor:nvcompositor0.GstNvCompositorPad:sink_0: caps = video/x-raw(memory:NVMM), width=(int)3840, height=(int)2160, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)3840, height=(int)2160, format=(string)NV12, framerate=(fraction)30/1
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3840 x 2160 FR = 29,999999 fps Duration = 33333334 ; Analog Gain range min 1,000000, max 22,250000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
   Camera index = 0
   Camera mode  = 0
   Output Stream W = 3840 H = 2160
   seconds to Run    = 0
   Frame Rate = 29,999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
/GstPipeline:pipeline0/GstNvCompositor:nvcompositor0.GstAggregatorPad:src: caps = video/x-raw(memory:NVMM), format=(string)RGBA, width=(int)3840, height=(int)2160, framerate=(fraction)30/1, chroma-site=(string)NULL, colorimetry=(string)sRGB
/GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0.GstGhostPad:sink.GstProxyPad:proxypad0: caps = video/x-raw(memory:NVMM), format=(string)RGBA, width=(int)3840, height=(int)2160, framerate=(fraction)30/1, chroma-site=(string)NULL, colorimetry=(string)sRGB
/GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0.GstGhostPad:sink: caps = video/x-raw(memory:NVMM), format=(string)RGBA, width=(int)3840, height=(int)2160, framerate=(fraction)30/1, chroma-site=(string)NULL, colorimetry=(string)sRGB
Redistribute latency...
ERROR: from element /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0: Internal data stream error.
Additional debug info:
gstbasesrc.c(3072): gst_base_src_loop (): /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0:
Execution ended after 0:00:00.866657344
Setting pipeline to READY ...
GST_ARGUS: Cleaning up
CONSUMER: Done Success
GST_ARGUS: Done Success
^C
Here is the syslog when streaming using gst-launch-1.0:
root@ubuntu:/home/mypc# tail -f /var/log/syslog
Apr 21 19:58:00 ubuntu kernel: [  210.181856] [RCE] tegra_nvcsi_stream_close(vm0, stream=0, csi=0)
Apr 21 19:58:29 ubuntu kernel: [  239.917917] [RCE] VM0 deactivating.VM0 activating.NVCSILP clock rate = 204000000 Hz.
Apr 21 19:58:30 ubuntu nvargus-daemon[1144]: === NVIDIA Libargus Camera Service (0.98.3)=== Listening for connections...=== gst-launch-1.0[2168]: Connection established (FFFFB8A3C900)OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
Apr 21 19:58:30 ubuntu nvargus-daemon[1144]: NvPclHwGetModuleList: WARNING: Could not map module to ISP config string
Apr 21 19:58:30 ubuntu nvargus-daemon[1144]: NvPclHwGetModuleList: No module data found
Apr 21 19:58:30 ubuntu kernel: [  240.098830] tegra-xusb 3610000.xhci: Firmware timestamp: 2022-03-16 11:07:43 UTC, Version: 60.13 release
Apr 21 19:58:30 ubuntu nvargus-daemon[1144]: (NvCamV4l2) Error ModuleNotPresent: V4L2Device not available (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function verifyDeviceCaps(), line 206)
Apr 21 19:58:30 ubuntu nvargus-daemon[1144]: (NvCamV4l2) Error ModuleNotPresent:  (propagating from /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function initialize(), line 66)
Apr 21 19:58:30 ubuntu nvargus-daemon[1144]: OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
Apr 21 19:58:30 ubuntu nvargus-daemon[1144]: ---- imager: No override file found. ----
Apr 21 19:58:30 ubuntu nvargus-daemon[1144]: LSC: LSC surface is not based on full res!
Apr 21 19:58:30 ubuntu nvargus-daemon[1144]: initializeDevNode: Failed to open dev node '/dev/camera/video1'; No such file or directory, trying alternate default location
Apr 21 19:58:30 ubuntu nvargus-daemon[1144]: (NvCamV4l2) Error BadParameter: Control 10094858 not found (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function findControlById(), line 1874)
Apr 21 19:58:30 ubuntu nvargus-daemon[1144]: (NvCamV4l2) Error BadParameter:  (propagating from /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function getControlRange(), line 331)
Apr 21 19:58:30 ubuntu nvargus-daemon[1144]: initialize: focus query failed
Apr 21 19:58:30 ubuntu nvargus-daemon[1144]: SCF: Error BadParameter:  (propagating from src/services/capture/CaptureServiceDeviceSensor.cpp, function open(), line 189)
Apr 21 19:58:30 ubuntu nvargus-daemon[1144]: SCF: Error BadParameter:  (propagating from src/services/capture/CaptureServiceDeviceSensor.cpp, function getSourceFromGuid(), line 643)
Apr 21 19:58:30 ubuntu nvargus-daemon[1144]: SCF: Error BadParameter:  (propagating from src/services/capture/CaptureService.cpp, function addSourceByGuid(), line 437)
Apr 21 19:58:30 ubuntu nvargus-daemon[1144]: SCF: Error BadParameter:  (propagating from src/api/CameraDriver.cpp, function addSourceByIndex(), line 311)
Apr 21 19:58:30 ubuntu nvargus-daemon[1144]: SCF: Error BadParameter:  (propagating from src/api/CameraDriver.cpp, function getSource(), line 477)
Apr 21 19:58:30 ubuntu nvargus-daemon[1144]: Acquiring SCF Camera device source via index 1 has failed. ---- imager: No override file found. ----
Apr 21 19:58:30 ubuntu nvargus-daemon[1144]: initializeDevNode: Failed to open dev node '/dev/camera/video2'; No such file or directory, trying alternate default location
Apr 21 19:58:30 ubuntu nvargus-daemon[1144]: (NvCamV4l2) Error NotSupported: Must be capture/output devices (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function setActiveBufferType(), line 813)
Apr 21 19:58:30 ubuntu nvargus-daemon[1144]: (NvCamV4l2) Error NotSupported:  (propagating from /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function initialize(), line 68)
Apr 21 19:58:30 ubuntu nvargus-daemon[1144]: (NvOdmDevice) Error NotSupported:  (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorNonViCsi.cpp, function initialize(), line 146)
Apr 21 19:58:30 ubuntu nvargus-daemon[1144]: NvPclDriverInitializeData: Unable to initialize driver v4l2_sensor_usb
Apr 21 19:58:30 ubuntu nvargus-daemon[1144]: NvPclInitializeDrivers: error: Failed to init camera sub module v4l2_sensor_usb
Apr 21 19:58:30 ubuntu nvargus-daemon[1144]: NvPclStartPlatformDrivers: Failed to start module drivers
Apr 21 19:58:30 ubuntu nvargus-daemon[1144]: NvPclStateControllerOpen: Failed ImagerGUID 2. (error 0x2)
Apr 21 19:58:30 ubuntu nvargus-daemon[1144]: NvPclOpen: PCL Open Failed. Error: 0xf
Apr 21 19:58:30 ubuntu nvargus-daemon[1144]: SCF: Error BadParameter: Sensor could not be opened. (in src/services/capture/CaptureServiceDeviceSensor.cpp, function getSourceFromGuid(), line 646)
Apr 21 19:58:32 ubuntu nvargus-daemon: E/ libnvphs:socket: Error[2]: socket connection /var/lib/nvphs/nvphsd.ctl to PHS failed: No such file or directory
Apr 21 19:58:32 ubuntu nvargus-daemon: D/ libnvphs:socket: Warning: connecting to Power Hinting Service failed. Is PHS running?
Apr 21 19:58:32 ubuntu nvargus-daemon[1144]: Acquiring SCF Camera device source via index 2 has failed. === gst-launch-1.0[2168]: CameraProvider initialized (0xffffb45e70b0)SCF: Error BadValue: NvPHSSendThroughputHints (in src/common/CameraPowerHint.cpp, function sendCameraPowerHint(), line 56)
Apr 21 19:58:32 ubuntu nvargus-daemon: E/ libnvphs: Error: NvPHSSendThroughputHints[usecase=camera, hint=MinCPU, value=4294967295, timeout_ms=1000]: queue_or_send() failed
Apr 21 19:58:32 ubuntu nvargus-daemon[1144]: LSC: LSC surface is not based on full res!
Apr 21 19:58:32 ubuntu kernel: [  242.669907] [RCE] tegra_nvcsi_stream_tpg_disable(vm0, stream=0, vc=0)
Apr 21 19:58:32 ubuntu kernel: [  242.669921] [RCE] tegra_nvcsi_stream_tpg_disable: channel 0 is already disabled
Apr 21 19:58:32 ubuntu kernel: [  242.725915] [RCE] tegra_nvcsi_stream_set_config(vm0, stream=0, csi=0)
Apr 21 19:58:32 ubuntu kernel: [  242.725942] [RCE] MIPI clock = 437500 kHz, tHS-SETTLE = 11, tCLK-SETTLE = 0
Apr 21 19:58:32 ubuntu kernel: [  242.725949] [RCE] ===== NVCSI Stream Configuration =====
Apr 21 19:58:32 ubuntu kernel: [  242.725955] [RCE] stream_id: PP 0, csi_port: PORT A
Apr 21 19:58:32 ubuntu kernel: [  242.725960] [RCE] Brick: PHY 0, Mode: D-PHY
Apr 21 19:58:32 ubuntu kernel: [  242.725965] [RCE] Partition: CIL A, LP bypass: Enabled, Lanes: 4
Apr 21 19:58:32 ubuntu kernel: [  242.725970] [RCE] Clock information:
Apr 21 19:58:32 ubuntu kernel: [  242.725976] [RCE] MIPI clock rate: 437.50 MHz
Apr 21 19:58:32 ubuntu kernel: [  242.725981] [RCE] T_HS settle: 11, T_CLK settle: 0
Apr 21 19:58:32 ubuntu kernel: [  242.725986] [RCE] ======================================
Apr 21 19:58:32 ubuntu kernel: [  242.725991] [RCE] tegra_nvcsi_stream_open(vm0, stream=0, csi=0)
Apr 21 19:58:32 ubuntu kernel: [  242.725997] [RCE] nvcsi_calc_tclk_settle tclk_settle 33
Apr 21 19:58:32 ubuntu kernel: [  242.885471] tegra-xusb 3610000.xhci: entering ELPG done
Apr 21 19:58:33 ubuntu kernel: [  243.241905] [RCE] ISR PHY 0 CIL_A 0x198
Apr 21 19:58:33 ubuntu kernel: [  243.241955] [RCE] ISR PHY 0 CIL_B 0x88
Apr 21 19:58:33 ubuntu kernel: [  243.353920] [RCE] ERROR: camera-ip/vi5/vi5.c:745 [vi5_handle_eof] "General error queue is out of sync with frame queue. ts=265415456864 sof_ts=265508727392 gerror_code=2 gerror_data=400 notify_bits=400000000024"
Apr 21 19:58:38 ubuntu nvargus-daemon[1144]: SCF: Error InvalidState: Timeout waiting on frame start sensor guid 0, capture sequence ID = 14 (in src/services/capture/FusaCaptureViCsiHw.cpp, function waitCsiFrameStart(), line 507)
Apr 21 19:58:38 ubuntu nvargus-daemon[1144]: SCF: Error InvalidState:  (propagating from src/common/Utils.cpp, function workerThread(), line 114)
Apr 21 19:58:38 ubuntu nvargus-daemon[1144]: SCF: Error InvalidState: Worker thread ViCsiHw frameStart failed (in src/common/Utils.cpp, function workerThread(), line 133)
Apr 21 19:58:38 ubuntu nvargus-daemon[1144]: SCF: Error Timeout:  (propagating from src/services/capture/FusaCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 593)
Apr 21 19:58:38 ubuntu nvargus-daemon[1144]: SCF: Error Timeout:  (propagating from src/common/Utils.cpp, function workerThread(), line 114)
Apr 21 19:58:38 ubuntu nvargus-daemon[1144]: SCF: Error Timeout: Worker thread ViCsiHw frameComplete failed (in src/common/Utils.cpp, function workerThread(), line 133)
Apr 21 19:58:38 ubuntu nvargus-daemon: Module_id 30 Severity 2 : (fusa) Error: Timeout  propagating from:/capture/src/fusaViHandler.cpp 776
Apr 21 19:58:39 ubuntu nvargus-daemon[1144]: SCF: Error Timeout:  (propagating from src/services/capture/CaptureServiceDeviceViCsi.cpp, function waitCompletion(), line 368)
Apr 21 19:58:39 ubuntu nvargus-daemon[1144]: SCF: Error Timeout:  (propagating from src/services/capture/CaptureServiceDevice.cpp, function pause(), line 936)
Apr 21 19:58:39 ubuntu nvargus-daemon[1144]: SCF: Error Timeout: During capture abort, syncpoint wait timeout waiting for current frame to finish (in src/services/capture/CaptureServiceDevice.cpp, function handleCancelSourceRequests(), line 1029)
^C
After that, I can’t stream using v4l2-ctrl anymore except for rebooting the device.
I already flashed the rce debug fw as suggested in Topic 26574 to get more logs.
The attached files include dmesg and trace logs
dmesg_trace_nvarguscamerasrc_notok.txt (2.9 MB)
dmesg_trace_v4l2-ctrl_ok.txt (175.8 KB)
Here is my camera sensor DT:
#include <dt-bindings/media/camera.h>
	tegra-capture-vi  {
		num-channels = <1>;
		ports {
			#address-cells = <1>;
			#size-cells = <0>;
			port@0 {
				reg = <0>;
				mycamera_vi_in0: endpoint {
					port-index = <0>;
					bus-width = <4>;
					remote-endpoint = <&mycamera_csi_out0>;
	host1x@13e00000 {
		nvcsi@15a00000 {
			num-channels = <1>;
			#size-cells = <0>;
			channel@0 {
				reg = <0>;
				ports {
					#size-cells = <0>;
					port@0 {
						reg = <0>;
						mycamera_csi_in0: endpoint@0 {
							port-index = <0>;
							bus-width = <4>;
							remote-endpoint = <&mycamera_out0>;
					port@1 {
						reg = <1>;
						mycamera_csi_out0: endpoint@1 {
							remote-endpoint = <&mycamera_vi_in0>;
	i2c@3180000 {
		mycamera: mycamera@10 {
			compatible = "test,mycamera";
			reg = <0x10>;
			status = "okay";
			/* V4L2 device node location */
			devnode = "video0";
			/* Physical dimensions of sensor */
			physical_w = "3.840";
			physical_h = "2.160";
			sensor_model = "mycamera";
			use_sensor_mode_id = "true";
			mode0 {
				mclk_khz = "24000";
				num_lanes = "4";
				phy_mode = "DPHY";
				discontinuous_clk = "no";
				dpcm_enable = "false";
				cil_settletime = "11";
				active_w = "3840";
				active_h = "2160";
				mode_type = "bayer";
				pixel_phase = "rggb";
				csi_pixel_bit_depth = "10";
				readout_orientation = "90";
				line_length = "3840";
				inherent_gain = "1";
				mclk_multiplier = "80";
				pix_clk_hz = "350000000";
				gain_factor = "16";
				framerate_factor = "1000000";
				exposure_factor = "1000000";
				min_gain_val = "16"; /* 1.00x */
				max_gain_val = "356"; /* 22x */
				step_gain_val = "1";
				default_gain = "16"; /* 1.00x */
				min_hdr_ratio = "1";
				max_hdr_ratio = "1";
				min_framerate = "2000000"; /* 2.0 fps */
				max_framerate = "30000000"; /* 30.0 fps */
				step_framerate = "1";
				default_framerate = "30000000"; /* 30.0 fps */
				min_exp_time = "13"; /* us */
				max_exp_time = "683709"; /* us */
				step_exp_time = "1";
				default_exp_time = "2495"; /* us */
				embedded_metadata_height = "2";
			ports {
				#size-cells = <0>;
				status = "okay";
				port@0 {
					reg = <0>;
					mycamera_out0: endpoint {
						port-index = <0>;
						bus-width = <4>;
						remote-endpoint = <&mycamera_csi_in0>;
	tcp: tegra-camera-platform {
		compatible = "nvidia, tegra-camera-platform";
		num_csi_lanes = <8>;
		max_lane_speed = <2500000>;
		min_bits_per_pixel = <10>;
		vi_peak_byte_per_pixel = <2>;
		vi_bw_margin_pct = <25>;
		max_pixel_rate = <7500000>;
		isp_peak_byte_per_pixel = <5>;
		isp_bw_margin_pct = <25>;
		modules {
			cam_module0: module0 {
				badge = "test_rear_mycamera";
				position = "rear";
				orientation = "1";
				status = "okay";
				cam_module0_drivernode0: drivernode0 {
					status = "okay";
					pcl_id = "v4l2_sensor";
					devname = "mycamera 2-0010";
					proc-device-tree = "/proc/device-tree/i2c@3180000/mycamera@10";
I’m using the Xavier NX SOM production version (16GB internal EMMC) on Jetpack 5.0.2.
Could you please help me?
Regards,
Vĩnh.
hello suvinh,
please try running without nvcompositor.
here’s sample gst pipeline for running with ximagesink.
$ gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! 'video/x-raw(memory:NVMM),width=1920,height=1080,format=(string)NV12,framerate=(fraction)30/1' ! nvvidconv ! fpsdisplaysink text-overlay=0 video-sink=ximagesink sync=0 -v
Hi @JerryChang ,
I used your suggested command and still error.
mypc@ubuntu:~$ gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! 'video/x-raw(memory:NVMM),width=3840,height=2160,format=(string)NV12,framerate=(fraction)30/1' ! nvvidconv ! fpsdisplaysink text-overlay=0 video-sink=ximagesink sync=0 -v
ERROR: Pipeline doesn't want to pause.
ERROR: from element /GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstXImageSink:ximagesink0: Could not initialise X output
ximagesink.c(859): gst_x_image_sink_xcontext_get (): /GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstXImageSink:ximagesink0:
Could not open display
Setting pipeline to NULL ...
Freeing pipeline ...
mypc@ubuntu:~$
Here is the syslog:
Apr 21 20:03:11 ubuntu kernel: [  521.682288] [RCE] NVCSILP clock rate = 204000000 Hz.
Apr 21 20:03:58 ubuntu nvargus-daemon[1147]: Acquiring SCF Camera device source via index 2 has failed. === gst-launch-1.0[2214]: CameraProvider initialized (0xffff94ec1650)=== gst-launch-1.0[2214]: CameraProvider destroyed (0xffff94ec1650)=== gst-launch-1.0[2214]: Connection closed (FFFF9C069900)=== gst-launch-1.0[2214]: Connection cleaned up (FFFF9C069900)=== gst-launch-1.0[2322]: Connection established (FFFF9C069900)OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
Apr 21 20:03:58 ubuntu nvargus-daemon[1147]: NvPclHwGetModuleList: WARNING: Could not map module to ISP config string
Apr 21 20:03:58 ubuntu nvargus-daemon[1147]: NvPclHwGetModuleList: No module data found
Apr 21 20:03:58 ubuntu kernel: [  568.112796] tegra-xusb 3610000.xhci: Firmware timestamp: 2022-03-16 11:07:43 UTC, Version: 60.13 release
Apr 21 20:03:58 ubuntu kernel: [  568.114278] [RCE] VM0 deactivating.VM0 activating.NVCSILP clock rate = 204000000 Hz.
Apr 21 20:03:58 ubuntu nvargus-daemon[1147]: (NvCamV4l2) Error ModuleNotPresent: V4L2Device not available (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function verifyDeviceCaps(), line 206)
Apr 21 20:03:58 ubuntu nvargus-daemon[1147]: (NvCamV4l2) Error ModuleNotPresent:  (propagating from /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function initialize(), line 66)
Apr 21 20:03:58 ubuntu nvargus-daemon[1147]: OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
Apr 21 20:03:58 ubuntu nvargus-daemon[1147]: ---- imager: No override file found. ----
Apr 21 20:03:58 ubuntu nvargus-daemon[1147]: LSC: LSC surface is not based on full res!
Apr 21 20:03:58 ubuntu nvargus-daemon[1147]: initializeDevNode: Failed to open dev node '/dev/camera/video1'; No such file or directory, trying alternate default location
Apr 21 20:03:58 ubuntu nvargus-daemon[1147]: (NvCamV4l2) Error BadParameter: Control 10094858 not found (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function findControlById(), line 1874)
Apr 21 20:03:58 ubuntu nvargus-daemon[1147]: (NvCamV4l2) Error BadParameter:  (propagating from /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function getControlRange(), line 331)
Apr 21 20:03:58 ubuntu nvargus-daemon[1147]: initialize: focus query failed
Apr 21 20:03:58 ubuntu nvargus-daemon[1147]: SCF: Error BadParameter:  (propagating from src/services/capture/CaptureServiceDeviceSensor.cpp, function open(), line 189)
Apr 21 20:03:58 ubuntu nvargus-daemon[1147]: SCF: Error BadParameter:  (propagating from src/services/capture/CaptureServiceDeviceSensor.cpp, function getSourceFromGuid(), line 643)
Apr 21 20:03:58 ubuntu nvargus-daemon[1147]: SCF: Error BadParameter:  (propagating from src/services/capture/CaptureService.cpp, function addSourceByGuid(), line 437)
Apr 21 20:03:58 ubuntu nvargus-daemon[1147]: SCF: Error BadParameter:  (propagating from src/api/CameraDriver.cpp, function addSourceByIndex(), line 311)
Apr 21 20:03:58 ubuntu nvargus-daemon[1147]: SCF: Error BadParameter:  (propagating from src/api/CameraDriver.cpp, function getSource(), line 477)
Apr 21 20:03:58 ubuntu nvargus-daemon[1147]: Acquiring SCF Camera device source via index 1 has failed. ---- imager: No override file found. ----
Apr 21 20:03:58 ubuntu nvargus-daemon[1147]: initializeDevNode: Failed to open dev node '/dev/camera/video2'; No such file or directory, trying alternate default location
Apr 21 20:03:58 ubuntu nvargus-daemon[1147]: (NvCamV4l2) Error NotSupported: Must be capture/output devices (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function setActiveBufferType(), line 813)
Apr 21 20:03:58 ubuntu nvargus-daemon[1147]: (NvCamV4l2) Error NotSupported:  (propagating from /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function initialize(), line 68)
Apr 21 20:03:58 ubuntu nvargus-daemon[1147]: (NvOdmDevice) Error NotSupported:  (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorNonViCsi.cpp, function initialize(), line 146)
Apr 21 20:03:58 ubuntu nvargus-daemon[1147]: NvPclDriverInitializeData: Unable to initialize driver v4l2_sensor_usb
Apr 21 20:03:58 ubuntu nvargus-daemon[1147]: NvPclInitializeDrivers: error: Failed to init camera sub module v4l2_sensor_usb
Apr 21 20:03:58 ubuntu nvargus-daemon[1147]: NvPclStartPlatformDrivers: Failed to start module drivers
Apr 21 20:03:58 ubuntu nvargus-daemon[1147]: NvPclStateControllerOpen: Failed ImagerGUID 2. (error 0x2)
Apr 21 20:03:58 ubuntu nvargus-daemon[1147]: NvPclOpen: PCL Open Failed. Error: 0xf
Apr 21 20:03:58 ubuntu nvargus-daemon[1147]: SCF: Error BadParameter: Sensor could not be opened. (in src/services/capture/CaptureServiceDeviceSensor.cpp, function getSourceFromGuid(), line 646)
Apr 21 20:04:00 ubuntu kernel: [  570.845600] tegra-xusb 3610000.xhci: entering ELPG done
^C
Here is the dmesg and trace logs:
# tracer: nop
# entries-in-buffer/entries-written: 6/6   #P:4
#                                _-----=> irqs-off
#                               / _----=> need-resched
#                              | / _---=> hardirq/softirq
#                              || / _--=> preempt-depth
#                              ||| /     delay
#           TASK-PID     CPU#  ||||   TIMESTAMP  FUNCTION
     kworker/0:4-160     [000] ....   526.722237: rtcpu_string: tstamp:17156522245 id:0x04010000 str:"VM0 deactivating."
     kworker/0:4-160     [000] ....   568.114267: rtcpu_string: tstamp:18450157332 id:0x04010000 str:"VM0 activating."
     kworker/0:4-160     [000] ....   568.114271: rtcpu_string: tstamp:18450223348 id:0x04010000 str:"NVCSILP clock rate = 204000000 Hz.
     kworker/0:4-160     [000] ....   568.506239: rtcpu_isp_falcon_task_start: tstamp:1282209655 ch:0 task:HANDLE_EVENT
     kworker/0:4-160     [000] ....   568.506243: rtcpu_isp_falcon_task_end: tstamp:1282209726 task:HANDLE_EVENT
     kworker/0:1-2210    [000] ....   574.050314: rtcpu_string: tstamp:18636898093 id:0x04010000 str:"VM0 deactivating."
FYI, I have tested my driver and DT on jetpack 4.6 and it works well!
Maybe the issue comes from the nvargus-daemon and wayland.
Regards,
Vĩnh.
hello suvinh,
we’ve try to enable camera stream on Wayland graphics by running nvarguscamerasrc plugin and it worked normally.
Hi @JerryChang ,
Launching weston...
    pkill -15 weston
    pkill -15 weston
mypc@ubuntu:~$ gst-launch-1.0 -v videotestsrc ! xvimagesink
ERROR: from element /GstPipeline:pipeline0/GstXvImageSink:xvimagesink0: Could not initialise Xv output
xvimagesink.c(1773): gst_xv_image_sink_open (): /GstPipeline:pipeline0/GstXvImageSink:xvimagesink0:
Could not open display (null)
Seems that I got error with xvimagesink plugin although it’s available:
mypc@ubuntu:~$ gst-inspect-1.0 xvimagesink
Factory Details:
  Rank                     primary (256)
  Long-name                Video sink
  Klass                    Sink/Video
  Description              A Xv based videosink
  Author                   Julien Moutte <julien@moutte.net>
Plugin Details:
  Name                     xvimagesink
  Description              XFree86 video output plugin using Xv extension
  Filename                 /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstxvimagesink.so
  Version                  1.16.2
  License                  LGPL
  Source module            gst-plugins-base
  Source release date      2019-12-03
  Binary package           GStreamer Base Plugins (Ubuntu)
  Origin URL               https://launchpad.net/distros/ubuntu/+source/gst-plugins-base1.0
GObject
 +----GInitiallyUnowned
       +----GstObject
             +----GstElement
                   +----GstBaseSink
                         +----GstVideoSink
                               +----GstXvImageSink
Implemented Interfaces:
  GstNavigation
  GstVideoOverlay
  GstColorBalance
Pad Templates:
  SINK template: 'sink'
    Availability: Always
    Capabilities:
      video/x-raw
              framerate: [ 0/1, 2147483647/1 ]
                  width: [ 1, 2147483647 ]
                 height: [ 1, 2147483647 ]
Element has no clocking capabilities.
Element has no URI handling capabilities.
Pads:
  SINK: 'sink'
    Pad Template: 'sink'
Element Properties:
  async               : Go asynchronously to PAUSED
                        flags: readable, writable
                        Boolean. Default: true
  autopaint-colorkey  : Whether to autofill overlay with colorkey
  blocksize           : Size in bytes to pull per buffer (0 = default)
                        Unsigned Integer. Range: 0 - 4294967295 Default: 4096
  brightness          : The brightness of the video
                        Integer. Range: -1000 - 1000 Default: 0
  colorkey            : Color to use for the overlay mask
                        Integer. Range: -2147483648 - 2147483647 Default: 526352
  contrast            : The contrast of the video
  device              : The number of the video adaptor
                        String. Default: "0"
  device-name         : The name of the video adaptor
                        flags: readable
                        String. Default: null
  display             : X Display name
  double-buffer       : Whether to double-buffer the output
                        Boolean. Default: false
  draw-borders        : Draw black borders to fill unused area in force-aspect-ratio mode
  enable-last-sample  : Enable the last-sample property
  force-aspect-ratio  : When enabled, scaling will respect original aspect ratio
  handle-events       : When enabled, XEvents will be selected and handled
  handle-expose       : When enabled, the current frame will always be drawn in response to X Expose events
  hue                 : The hue of the video
  last-sample         : The last sample received in the sink
                        flags: readable
                        Boxed pointer of type "GstSample"
  max-bitrate         : The maximum bits per second to render (0 = disabled)
                        Unsigned Integer64. Range: 0 - 18446744073709551615 Default: 0
  max-lateness        : Maximum number of nanoseconds that a buffer can be late before it is dropped (-1 unlimited)
                        Integer64. Range: -1 - 9223372036854775807 Default: 5000000
  name                : The name of the object
                        String. Default: "xvimagesink0"
  parent              : The parent of the object
                        Object of type "GstObject"
  pixel-aspect-ratio  : The pixel aspect ratio of the device
  processing-deadline : Maximum processing deadline in nanoseconds
                        Unsigned Integer64. Range: 0 - 18446744073709551615 Default: 15000000
  qos                 : Generate Quality-of-Service events upstream
  render-delay        : Additional render delay of the sink in nanoseconds
  render-rectangle    : The render rectangle ('<x, y, width, height>')
                        flags: writable
                        GstValueArray of GValues of type "gint" Write only
  saturation          : The saturation of the video
  show-preroll-frame  : Whether to render video frames during preroll
  sync                : Sync on the clock
  synchronous         : When enabled, runs the X display in synchronous mode. (unrelated to A/V sync, used only for debugging)
  throttle-time       : The time to keep between rendered buffers (0 = disabled)
  ts-offset           : Timestamp offset in nanoseconds
                        Integer64. Range: -9223372036854775808 - 9223372036854775807 Default: 0
  window-height       : Height of the window
                        flags: readable
  window-width        : Width of the window
                        flags: readable
mypc@ubuntu:~$ ls /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstxvimagesink.so
mypc@ubuntu:~$
How can I fix this issue?
For more information, I have tested my camera driver and DT on jetpack 4.6 and the framerate is closed to 30 but on jetpack 5.0.2 it’s quite low. Is there any different between 2 versions in terms of firmware?
Thanks,
Vĩnh.
hello suvinh,
it may due to your display environment setup.
BTW,
could you please examine the fps by using V4L2 IOCTL to verify basic functionality.
for example,
$ v4l2-ctl --set-fmt-video=width=1920,height=1080,pixelformat=RG10 --stream-mmap --stream-count=300 -d /dev/video0
Hi @JerryChang ,
I always do test by v4l2-ctrl before streaming by gst-launch. The result is ok as I described in the first comment.
I connected the display to HDMI screen, ubuntu with LXDM boots up ok (jetpack 4.6 display and streaming are ok). Can you give me any suggestion in this problem?
Sorry for the late response, is this still an issue to support? Thanks
FYI
we’ve start weston mode, $ nvstart-weston.sh, then start run v4l2-ctl and gst-launch-1.0 pipeline for testing.
here’s test procedure…
Start weston → run v4l2-ctl pipeline → working
Run gst-launch-1.0 pipeline with ximagesink → working
Run v4l2-ctl pipeline → working
note, all above tests were running on weston mode.
