Hello team,
We are trying to stream 7 cameras using deepstream pipelines.
Hardware being used includes:-
- Jetson AGX Xavier with jetpack4.6.1 [L4T 32.7.1]
- DESIGNCORE® NVIDIA® JETSON AGX ORIN FPD-LINK™ III INTERFACE CARD
- DESIGNCORE® D3RCM-IMX390-953 RUGGED CAMERA MODULE
Errors encounter
nvbuf_utils: dmabuf_fd -1 mapped entry NOT found
nvbuf_utils: Can not get HW buffer from FD… Exiting…
Pipeline Command being used
gst-launch-1.0 -e
nvarguscamerasrc sensor-id=0 tnr-strength=1 tnr-mode=2 ! ‘video/x-raw(memory:NVMM), width=1920, height=1080, framerate=30/1’ ! queue ! nvv4l2vp9enc maxperf-enable=true bitrate=2000000 ! rtpvp9pay mtu=1400 ! udpsink host=192.168.2.23 port=5000 sync=false async=false
nvarguscamerasrc sensor-id=1 tnr-strength=1 tnr-mode=2 ! ‘video/x-raw(memory:NVMM), width=1920, height=1080, framerate=30/1’ ! queue ! nvv4l2vp9enc maxperf-enable=true bitrate=2000000 ! rtpvp9pay mtu=1400 ! udpsink host=192.168.2.23 port=5001 sync=false async=false
nvarguscamerasrc sensor-id=2 tnr-strength=1 tnr-mode=2 ! ‘video/x-raw(memory:NVMM), width=1920, height=1080, framerate=30/1’ ! queue ! nvv4l2vp9enc maxperf-enable=true bitrate=2000000 ! rtpvp9pay mtu=1400 ! udpsink host=192.168.2.23 port=5002 sync=false async=false
nvarguscamerasrc sensor-id=3 tnr-strength=1 tnr-mode=2 ! ‘video/x-raw(memory:NVMM), width=1920, height=1080, framerate=30/1’ ! queue ! nvv4l2vp9enc maxperf-enable=true bitrate=2000000 ! rtpvp9pay mtu=1400 ! udpsink host=192.168.2.23 port=5003 sync=false async=false
nvarguscamerasrc sensor-id=4 tnr-strength=1 tnr-mode=2 ! ‘video/x-raw(memory:NVMM), width=1920, height=1080, framerate=30/1’ ! queue ! nvv4l2vp9enc maxperf-enable=true bitrate=2000000 ! rtpvp9pay mtu=1400 ! udpsink host=192.168.2.23 port=5004 sync=false async=false
nvarguscamerasrc sensor-id=5 tnr-strength=1 tnr-mode=2 ! ‘video/x-raw(memory:NVMM), width=1920, height=1080, framerate=30/1’ ! queue ! nvv4l2vp9enc maxperf-enable=true bitrate=2000000 ! rtpvp9pay mtu=1400 ! udpsink host=192.168.2.23 port=5005 sync=false async=false
nvarguscamerasrc sensor-id=6 tnr-strength=1 tnr-mode=2 ! ‘video/x-raw(memory:NVMM), width=1920, height=1080, framerate=30/1’ ! queue ! nvv4l2vp9enc maxperf-enable=true bitrate=2000000 ! rtpvp9pay mtu=1400 ! udpsink host=192.168.2.23 port=5006 sync=false async=false
Complete Logs
Setting pipeline to PAUSED …
Opening in BLOCKING MODE
Pipeline is live and does not need PREROLL …
NvMMLiteOpen : Block : BlockType = 9
===== NVMEDIA: NVENC =====
Redistribute latency…
Setting pipeline to PLAYING …
NvMMLiteBlockCreate : Block : BlockType = 9
New clock: GstSystemClock
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected…
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 1936 x 1096 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 31.622776; Exposure Range min 30000, max 33333000;
GST_ARGUS: 1936 x 1096 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 2.630268, max 15.848933; Exposure Range min 2000000, max 33000000;
GST_ARGUS: Running with following settings:
Camera index = 6
Camera mode = 3
Output Stream W = 1936 H = 1096
seconds to Run = 0
Frame Rate = 29.999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
Camera index = 3
Camera mode = 3
seconds to Run = 0
Camera index = 2
Camera mode = 3
seconds to Run = 0
Camera index = 4
Camera mode = 3
seconds to Run = 0
Camera index = 5
Camera mode = 3
seconds to Run = 0
Camera index = 0
Camera mode = 3
seconds to Run = 0
Camera index = 1
Camera mode = 3
seconds to Run = 0
CONSUMER: Done Success
CONSUMER: ERROR OCCURRED
ERROR: from element /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc6: TIMEOUT
Additional debug info:
Argus Error Status
EOS on shutdown enabled – waiting for EOS after Error
Waiting for EOS…
Got EOS from element “pipeline0”.
EOS received - stopping pipeline…
Execution ended after 0:00:08.014943001
Setting pipeline to READY …
GST_ARGUS: Cleaning up
GST_ARGUS: Done Success
(Argus) Error Timeout: (propagating from src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 137)
(Argus) Error Timeout: (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 91)
Caught SIGSEGV
#0 0x0000007fa75d75bc in futex_reltimed_wait_cancelable (private=, reltime=0x5500000000, expected=0, futex_word=0x7f80006a38)
#1 0x0000007fa75d75bc in __pthread_cond_wait_common (abstime=0x7ff4275910, mutex=0x558125ad40, cond=0x7f80006a10) at pthread_cond_wait.c:533
#2 0x0000007fa75d75bc in __pthread_cond_timedwait (cond=0x7f80006a10, mutex=0x558125ad40, abstime=0x7ff4275910) at pthread_cond_wait.c:667
#3 0x0000007fa6a9fab4 in NvOsConditionWaitTimeout ()
#4 0x0000007fa6b3406c in nvcamerautils::ConditionVariable::wait(nvcamerautils::Mutex const&, nvcamerautils::UnscaledTimeout const&) const ()
#5 0x0000007fa6f5a2d4 in ()
#6 0x0000007fa6f5cac0 in ()
#7 0x0000007fa6ee3464 in ()
#8 0x0000007fa78b5418 in ()
#9 0x0000007fa6e36ab0 in () at /usr/lib/aarch64-linux-gnu/libgstbase-1.0.so.0
#10 0x0000007fa788f750 in _gst_debug_min ()
Spinning. Please run ‘gdb gst-launch-1.0 11779’ to continue debugging, Ctrl-C to quit, or Ctrl-\ to dump core.
Potential Solution
Same type of error has been reported and solved in the following post for R32.5.0
I need same solution for R32.7.1.
Thanks in advance
-Shams
