We are seeing camera access issues using gstreamer using nvargus on Jetson Xavier. We are seeing the following logs. Could you help we on this.
Apr 30 13:28:47 nvidia-desktop nvargus-daemon[10870]: NvCaptureStatusErrorDecode Stream 1.0 failed: sof_ts 0 eof_ts 63577226763680 frame 0 error 2 data 0x00800661
Apr 30 13:28:47 nvidia-desktop nvargus-daemon[10870]: NvCaptureStatusErrorDecode Capture-Error: CSIMUX_FRAME (0x00000002)
Apr 30 13:28:47 nvidia-desktop nvargus-daemon[10870]: CsimuxFrameError_Regular : 0x00800661
Apr 30 13:28:47 nvidia-desktop nvargus-daemon[10870]: Stream ID [ 2: 0]: 1
Apr 30 13:28:47 nvidia-desktop nvargus-daemon[10870]: VPR state from fuse block [ 3]: 0
Apr 30 13:28:47 nvidia-desktop nvargus-daemon[10870]: Frame end (FE) [ 5]: 1
Apr 30 13:28:47 nvidia-desktop nvargus-daemon[10870]: A frame end has been found on a regular mode stream.
Apr 30 13:28:47 nvidia-desktop nvargus-daemon[10870]: CSI_FAULT [ 6]: 1
Apr 30 13:28:47 nvidia-desktop nvargus-daemon[10870]: An FE packet was found and marked with a CSI Error
Apr 30 13:28:47 nvidia-desktop nvargus-daemon[10870]: FE_FRAME_ID_FAULT [ 9]: 1
Apr 30 13:28:47 nvidia-desktop nvargus-daemon[10870]: Frame ID of FE packet mismatches ID of FS packet.FS frame ID will be used to generate errored FE
Apr 30 13:28:47 nvidia-desktop nvargus-daemon[10870]: PXL_ENABLE_FAULT [10]: 1
Apr 30 13:28:47 nvidia-desktop nvargus-daemon[10870]: An illegal pixel enable encoding has been detected on a long packete.g. 6 pixels enabled on a CSI packet without line end
Apr 30 13:28:47 nvidia-desktop nvargus-daemon[10870]: CSI_CODE [25:20]: 0x8
Apr 30 13:28:47 nvidia-desktop nvargus-daemon[10870]: Check the CSI specification for the meaning. See https://wiki.nvidia.com/wmpwiki/index.php/Camera_Debugging/CaptureError_debugging#CSI_COD
E
Apr 30 13:28:47 nvidia-desktop nvargus-daemon[10870]: Binary VC number [3:2] [27:26]: 0
Apr 30 13:28:47 nvidia-desktop nvargus-daemon[10870]: To get full binary VC number, user need to concatenate VC[3:2] and VC[1:0] together.
Apr 30 13:28:47 nvidia-desktop nvargus-daemon[10870]: SCF: Error InvalidState: Capture error with status 2 (channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 9
16)
Apr 30 13:28:47 nvidia-desktop nvargus-daemon[10870]: NvCaptureStatusErrorDecode Stream 1.0 failed: sof_ts 0 eof_ts 63577251379488 frame 0 error 2 data 0x00800661
E
16)
Apr 30 13:28:48 nvidia-desktop nvargus-daemon[10870]: (NvCapture) Error Timeout: capture waiting for status timeout (in /dvs/git/dirty/git-master_linux/camera/capture/nvcapture/capture_hw_linux.c, fun
ction NvCaptureLinuxGetCaptureStatus(), line 362)
Apr 30 13:28:48 nvidia-desktop nvargus-daemon[10870]: (NvCapture) Error Timeout: (propagating from /dvs/git/dirty/git-master_linux/camera/capture/nvcapture/capture.c, function NvCaptureDequeue(), lin
e 1055)
Apr 30 13:28:48 nvidia-desktop nvargus-daemon[10870]: SCF: Error Timeout: (propagating from src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 887)
Apr 30 13:28:48 nvidia-desktop nvargus-daemon[10870]: SCF: Error InvalidState: Timeout waiting on frame end sensor guid 1, capture sequence ID = 1712217, channel = 1/1 (in src/services/capture/NvCaptu
reViCsiHw.cpp, function waitCsiFrameEnd(), line 894)
Apr 30 13:28:48 nvidia-desktop nvargus-daemon[10870]: SCF: Error Timeout: Sending critical error event (in src/api/Session.cpp, function sendErrorEvent(), line 990)
Apr 30 13:28:48 nvidia-desktop nvargus-daemon[10870]: SCF: Error InvalidState: Something went wrong with waiting on frame end (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(),
line 975)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.509143] tegra194-vi5 15c10000.vi: no reply from camera processor
Apr 30 13:28:48 nvidia-desktop kernel: [63568.509279] tegra194-vi5 15c10000.vi: vi capture get status failed
Apr 30 13:28:48 nvidia-desktop nvargus-daemon[10870]: SCF: Error InvalidState: Timeout waiting on frame start sensor guid 1, capture sequence ID = 1712217 (in src/services/capture/NvCaptureViCsiHw.cpp
, function waitCsiFrameStart(), line 1002)
Apr 30 13:28:48 nvidia-desktop nvargus-daemon[10870]: SCF: Error InvalidState: Something went wrong with waiting on frame start (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameStar
t(), line 1057)
Apr 30 13:28:48 nvidia-desktop nvargus-daemon[10870]: SCF: Error InvalidState: Session has suffered a critical failure (in src/api/Session.cpp, function capture(), line 667)
Apr 30 13:28:48 nvidia-desktop nvargus-daemon[10870]: (Argus) Error InvalidState: (propagating from src/api/ScfCaptureThread.cpp, function run(), line 109)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541135] fence timeout on [ffffffc21b10f480] after 1500ms
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541144] name=[nvhost_sync:48], current value=5136654 waiting value=5136655
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541150] ---- mlocks ----
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541171] 17: locked by channel 7
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541186]
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541189] ---- syncpts ----
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541198] id 2 (disp_a) min 1754341 max 1754341 refs 1 (previous client : )
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541207] id 3 (disp_b) min 2 max 2 refs 1 (previous client : )
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541213] id 6 (disp_e) min 1754340 max 1754340 refs 1 (previous client : )
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541217] id 7 (disp_f) min 3 max 3 refs 1 (previous client : )
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541222] id 8 (vblank0) min 3812261 max -4 refs 1 (previous client : )
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541227] id 11 (vblank2) min 3805376 max -6 refs 1 (previous client : )
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541235] id 18 (gv11b_511) min 289818005 max 289818005 refs 1 (previous client : )
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541239] id 19 (gv11b_510) min 29 max 29 refs 1 (previous client : )
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541245] id 20 (gv11b_509) min 44294368 max 44294368 refs 1 (previous client : gv11b_509)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541249] id 21 (15340000.vic_videocapture_0) min 13126044 max 13126047 refs 3 (previous client : 15340000.vic_videocapture_0)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541254] id 22 (15340000.vic_videocapture_0) min 3281616 max 3281616 refs 1 (previous client : 15340000.vic_videocapture_0)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541258] id 23 (progress) min 27395737 max 0 refs 1 (previous client : progress)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541262] id 24 (stats_progress) min 89036144 max 0 refs 1 (previous client : stats_progress)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541268] id 28 (gv11b_508_user) min 393216 max 393216 refs 1 (previous client : gv11b_508_user)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541273] id 30 (gv11b_507_user) min 393239 max 393233 refs 1 (previous client : gv11b_507_user)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541301] id 32 (gv11b_506_user) min 393216 max 393216 refs 1 (previous client : gv11b_506_user)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541306] id 34 (gv11b_505_user) min 393216 max 393216 refs 1 (previous client : gv11b_505_user)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541311] id 36 (gv11b_504_user) min 393216 max 393216 refs 1 (previous client : gv11b_504_user)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541315] id 37 (progress) min 5136778 max 0 refs 1 (previous client : progress)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541320] id 38 (embdata) min 1712260 max 0 refs 1 (previous client : embdata)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541325] id 41 (gv11b_503) min 15 max 15 refs 1 (previous client : gv11b_503)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541330] id 42 (gv11b_502) min 12 max 12 refs 1 (previous client : gv11b_502)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541334] id 43 (gv11b_501) min 13 max 13 refs 1 (previous client : gv11b_501)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541339] id 44 (gv11b_500) min 12 max 12 refs 1 (previous client : gv11b_500)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541343] id 45 (gv11b_499) min 12 max 12 refs 1 (previous client : gv11b_499)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541347] id 46 (15340000.vic_videocapture_0) min 3281457 max 3281457 refs 1 (previous client : 15340000.vic_argus_thread_0)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541352] id 47 (15340000.vic_nvargus-daemon_0) min 12 max 12 refs 1 (previous client : 15340000.vic_argus_thread_0)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541356] id 48 (progress) min 5136654 max 6 refs 1 (previous client : 15340000.vic_argus_thread_0)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541360] id 49 (embdata) min 1712221 max 6 refs 1 (previous client : embdata)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541365] id 50 (15340000.vic_nvargus-daemon_0) min 6 max 6 refs 1 (previous client : gv11b_498)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541369] id 51 (gv11b_496) min 3 max 3 refs 1 (previous client : 15340000.vic_nvargus-daemon_0)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541373] id 52 (gv11b_495) min 15 max 15 refs 1 (previous client : gv11b_495)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541377] id 53 (gv11b_487) min 18 max 18 refs 1 (previous client : 15340000.vic_argus_thread_0)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541382] id 54 (gv11b_498) min 15 max 15 refs 1 (previous client : gv11b_497)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541386] id 55 (15340000.vic_videocapture_0) min 2978988 max 2978988 refs 1 (previous client : 15340000.vic_argus_thread_0)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541410] id 56 (gv11b_484) min 63 max 63 refs 1 (previous client : progress)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541415] id 57 (15340000.vic_nvargus-daemon_0) min 302511 max 302511 refs 1 (previous client : 15340000.vic_argus_thread_0)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541420] id 58 (progress) min 5136729 max 6 refs 1 (previous client : 15340000.vic_argus_thread_0)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541424] id 59 (embdata) min 1712250 max 9 refs 1 (previous client : embdata)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541429] id 60 (gv11b_497) min 3 max 3 refs 1 (previous client : 15340000.vic_nvargus-daemon_0)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541433] id 61 (15340000.vic_nvargus-daemon_0) min 6 max 6 refs 1 (previous client : gv11b_484)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541437] id 62 (gv11b_491) min 18 max 18 refs 1 (previous client : gv11b_493)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541442] id 63 (gv11b_493) min 27 max 27 refs 1 (previous client : 15340000.vic_argus_thread_0)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541448] id 64 (gv11b_489) min 12 max 12 refs 1 (previous client : gv11b_489)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541452] id 65 (gv11b_488) min 89763 max 89763 refs 1 (previous client : gv11b_494)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541457] id 66 (15340000.vic_videocapture_0) min 3155256 max 3155259 refs 3 (previous client : 15340000.vic_argus_thread_0)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541461] id 67 (15340000.vic_nvargus-daemon_0) min 36669 max 36669 refs 1 (previous client : 15340000.vic_argus_thread_0)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541466] id 68 (progress) min 5329575 max 192876 refs 1 (previous client : 15340000.vic_argus_thread_0)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541470] id 69 (embdata) min 2069848 max 357615 refs 1 (previous client : embdata)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541474] id 70 (gv11b_494) min 346920 max 346920 refs 1 (previous client : 15340000.vic_argus_thread_0)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541479] id 71 (gv11b_492) min 12 max 12 refs 1 (previous client : 15340000.vic_argus_thread_0)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541483] id 72 (15340000.vic_nvargus-daemon_0) min 9 max 9 refs 1 (previous client : gv11b_492)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541487] id 73 (gv11b_490) min 27 max 27 refs 1 (previous client : 15340000.vic_argus_thread_0)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541491] id 74 (gv11b_486) min 15 max 15 refs 1 (previous client : gv11b_485)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541495] id 75 (gv11b_485) min 78897 max 78897 refs 1 (previous client : gv11b_486)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541501] id 77 (15340000.vic_argus_thread_0) min 5786505 max 5786508 refs 3 (previous client : 15340000.vic_argus_thread_0)
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541838]
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541841] ---- channels ----
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541850]
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541850] channel 1 - 15340000.vic
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541853] NvHost basic channel registers:
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541859] CMDFIFO_STAT_0: 00000009
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541862] CMDFIFO_RDATA_0: 00001740
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541868] CMDP_OFFSET_0: 00000000
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541871] CMDP_CLASS_0: 0000005d
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541875] CHANNELSTAT_0: 00000000
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541881]
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541881] ffffffc1c8b2a800: JOB, syncpt_id=21, syncpt_val=13126047, first_get=000001d8, timeout=10000, num_slots=16
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541891] GATHER at fd270000+5ad8, 32 words
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541895] 10100002
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541898] 000001c1
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541901] 00b90110
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541904] 10100002
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541907] 000001c2
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541909] 1ffefff0
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541912] 10100002
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541915] 000001cc
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541918] 00000000
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541921] 10100002
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541924] 000001c3
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541927] 1fff3fc0
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541929] 10100002
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541932] 000001c8
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541935] 9ff50000
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541938] 10100002
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541941] 000001c9
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541944] 9ff52200
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541947] 10100002
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541964] 00000480
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541967] 9ff7c000
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541970] 10100002
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541973] 00000481
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541976] 9ff7e200
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541979] 10100002
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541982] 00000482
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541985] 9ff7ec00
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541987] 10100002
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541990] 000000c0
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541993] 00000100
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541996] 20000001
Apr 30 13:28:48 nvidia-desktop kernel: [63568.541999] 00000415
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542001]
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542005] GATHER at fd270000+5b58, 2 words
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542008] 20000001
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542011] 00000415
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542013]
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542016]
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542019]
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542019] channel 7 - 15340000.vic
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542022] NvHost basic channel registers:
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542025] CMDFIFO_STAT_0: 0000003e
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542044] CMDFIFO_RDATA_0: 00000041
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542062] CMDP_OFFSET_0: 00000050
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542066] CMDP_CLASS_0: 00000001
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542070] CHANNELSTAT_0: 00000000
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542074]
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542074] ffffffc305448400: JOB, syncpt_id=66, syncpt_val=3155259, first_get=000007c8, timeout=10000, num_slots=16
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542081] GATHER at feff8000+2df0, 26 words
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542084] 10100002
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542087] 000001c1
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542091] 00b90110
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542094] 10100002
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542097] 000001c2
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542100] 1ff5ff70
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542103] 10100002
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542106] 000001cc
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542109] 00000000
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542112] 10100002
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542115] 000001c3
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542118] 1ff37fc0
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542121] 10100002
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542124] 000001c8
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542127] 1ff34000
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542130] 10100002
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542133] 00000480
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542136] 9ff1c000
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542139] 10100002
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542142] 00000481
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542145] 9ff1e200
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542148] 10100002
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542151] 000000c0
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542154] 00000100
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542157] 20000001
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542160] 00000442
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542162]
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542166] GATHER at feff8000+2e58, 2 words
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542169] 20000001
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542172] 00000442
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542174]
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542179]
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542182]
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542182] channel 8 - 15340000.vic
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542185] NvHost basic channel registers:
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542188] CMDFIFO_STAT_0: 00000009
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542192] CMDFIFO_RDATA_0: 00001740
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542196] CMDP_OFFSET_0: 00000000
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542200] CMDP_CLASS_0: 0000005d
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542203] CHANNELSTAT_0: 00000000
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542208]
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542208] ffffffc2b4d6b800: JOB, syncpt_id=77, syncpt_val=5786508, first_get=00000900, timeout=10000, num_slots=17
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542213] GATHER at ff798000+0000, 3 words
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542216] 304e0005
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542221] 01a20690
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542224] 00000017
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542226]
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542229] GATHER at ff798000+000c, 32 words
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542232] 10100002
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542235] 000001c1
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542238] 00b90110
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542241] 10100002
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542244] 000001c2
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542247] 1ff008a0
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542253] 10100002
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542255] 000001cc
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542258] 00000000
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542261] 10100002
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542264] 000001c3
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542267] 1fefe940
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542270] 10100002
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542273] 000001c8
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542276] 9ff44000
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542279] 10100002
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542281] 000001c9
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542284] 9ff46200
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542287] 10100002
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542290] 000001ca
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542294] 9ff46c00
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542296] 10100002
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542299] 00000480
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542317] 9ff38000
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542320] 10100002
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542322] 00000481
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542325] 9ff3a200
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542328] 10100002
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542331] 000000c0
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542334] 00000100
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542337] 20000001
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542340] 0000044d
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542342]
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542345] GATHER at ff798000+008c, 2 words
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542348] 20000001
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542351] 0000044d
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542353]
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542356]
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542394]
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542394] channel 2 - 15820000.se
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542397] NvHost basic channel registers:
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542400] CMDFIFO_STAT_0: 00002040
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542404] CMDFIFO_RDATA_0: bc450160
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542408] CMDP_OFFSET_0: 00000000
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542411] CMDP_CLASS_0: 00000000
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542415] CHANNELSTAT_0: 00000000
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542418] The CDMA sync queue is empty.
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542420]
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542425]
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542425] channel 3 - 15830000.se
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542427] NvHost basic channel registers:
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542431] CMDFIFO_STAT_0: 00002040
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542434] CMDFIFO_RDATA_0: 90049a02
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542438] CMDP_OFFSET_0: 00000000
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542442] CMDP_CLASS_0: 00000000
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542445] CHANNELSTAT_0: 00000000
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542448] The CDMA sync queue is empty.
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542450]
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542455]
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542455] channel 4 - 15840000.se
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542457] NvHost basic channel registers:
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542475] CMDFIFO_STAT_0: 00002040
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542479] CMDFIFO_RDATA_0: 940a0188
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542483] CMDP_OFFSET_0: 00000000
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542486] CMDP_CLASS_0: 00000000
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542490] CHANNELSTAT_0: 00000000
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542493] The CDMA sync queue is empty.
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542495]
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542501]
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542501] ---- host general irq ----
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542505] sync_intc0mask = 0x00000001
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542509] sync_intmask = 0x50000003
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542511]
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542511] ---- host syncpt irq mask ----
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542514]
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542514] ---- host syncpt irq status ----
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542519] syncpt_thresh_cpu0_int_status(0) = 0x00000000
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542523] syncpt_thresh_cpu0_int_status(1) = 0x00000000
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542527] syncpt_thresh_cpu0_int_status(2) = 0x00000000
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542531] syncpt_thresh_cpu0_int_status(3) = 0x00000000
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542535] syncpt_thresh_cpu0_int_status(4) = 0x00000000
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542540] syncpt_thresh_cpu0_int_status(5) = 0x00000000
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542557] syncpt_thresh_cpu0_int_status(6) = 0x00000000
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542561] syncpt_thresh_cpu0_int_status(7) = 0x00000000
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542565] syncpt_thresh_cpu0_int_status(8) = 0x00000000
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542568] syncpt_thresh_cpu0_int_status(9) = 0x00000000
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542572] syncpt_thresh_cpu0_int_status(10) = 0x00000000
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542576] syncpt_thresh_cpu0_int_status(11) = 0x00000000
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542580] syncpt_thresh_cpu0_int_status(12) = 0x00000000
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542584] syncpt_thresh_cpu0_int_status(13) = 0x00000000
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542587] syncpt_thresh_cpu0_int_status(14) = 0x00000000
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542591] syncpt_thresh_cpu0_int_status(15) = 0x00000000
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542595] syncpt_thresh_cpu0_int_status(16) = 0x00000000
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542598] syncpt_thresh_cpu0_int_status(17) = 0x00000000
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542602] syncpt_thresh_cpu0_int_status(18) = 0x00000000
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542605] syncpt_thresh_cpu0_int_status(19) = 0x00000000
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542609] syncpt_thresh_cpu0_int_status(20) = 0x00000000
Apr 30 13:28:48 nvidia-desktop kernel: [63568.542613] syncpt_thresh_cpu0_int_status(21) = 0x00000000
