I’m trying to connect imx219-83 stereo camera with Jetson Xavier nx and using gstreamer to capture webcam.
Here’s the code I used to capture webcam
I’m trying the correct command you suggested.
Here’s the result
gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! 'video/x-raw(memory:NVMM),width=1920,height=1280' ! nvvidconv flip-method=2 ! 'video/x-raw, width=800, height=600, format=(string)I420' ! appsink
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3264 x 2464 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3264 x 1848 FR = 28.000001 fps Duration = 35714284 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1640 x 1232 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
ARGUS_ERROR: Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute: 787 Frame Rate specified is greater than supported
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 0
Output Stream W = 3264 H = 2464
seconds to Run = 0
Frame Rate = 21.000000
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
ARGUS_ERROR: Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute: 1007 InvalidState.
GST_ARGUS: Cleaning up
nvbuf_utils: dmabuf_fd -1 mapped entry NOT found
nvbuf_utils: Can not get HW buffer from FD... Exiting...
ERROR: from element /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0: CANCELLED
Additional debug info:
Argus Error Status
Execution ended after 0:00:00.555465521
Setting pipeline to READY ...
Caught SIGSEGV
#0 0x0000007fa13ca7f4 in __pthread_clockjoin_ex (threadid=548067918304, thread_return=0x0, clockid=0, abstime=<optimized out>, block=<optimized out>)
#1 0x0000007fa1488ab8 in () at /usr/lib/aarch64-linux-gnu/libglib-2.0.so.0
#2 0x0000005594974d40 in ()
Spinning. Please run 'gdb gst-launch-1.0 6729' to continue debugging, Ctrl-C to quit, or Ctrl-\ to dump core.
And I run the command ‘gdb gst-launch-1.0 6729’, I get the result below
GNU gdb (Ubuntu 8.1.1-0ubuntu1) 8.1.1
Copyright (C) 2018 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law. Type "show copying"
and "show warranty" for details.
This GDB was configured as "aarch64-linux-gnu".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from gst-launch-1.0...(no debugging symbols found)...done.
Attaching to program: /usr/bin/gst-launch-1.0, process 6729
[New LWP 6731]
[New LWP 6732]
[New LWP 6735]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/aarch64-linux-gnu/libthread_db.so.1".
at pthread_join_common.c:145
145 pthread_join_common.c: No such file or directory.
No, I run the command directly from local terminal on Nvidia Jetson Xavier nx.
I tried export DISPLAY=:0 first, but get the same result
$ export DISPLAY=:0
$ gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! 'video/x-raw(memory:NVMM),width=1920,height=1280' ! nvvidconv flip-method=2 ! 'video/x-raw, width=800, height=600, format=(string)I420' ! appsink
Camera index = 0
Camera mode = 0
seconds to Run = 0
Argus Error Status
Execution ended after 0:00:00.805915565
Caught SIGSEGV
#0 0x0000007fac6eb7f4 in __pthread_clockjoin_ex (threadid=548255748576, thread_return=0x0, clockid=0, abstime=<optimized out>, block=<optimized out>)
#1 0x0000007fac7a9ab8 in () at /usr/lib/aarch64-linux-gnu/libglib-2.0.so.0
#2 0x000000557cbd2d40 in ()
Spinning. Please run 'gdb gst-launch-1.0 8046' to continue debugging, Ctrl-C to quit, or Ctrl-\ to dump core.
$ gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! 'video/x-raw(memory:NVMM),width=1920,height=1280' ! nvvidconv flip-method=2 ! 'video/x-raw, width=800, height=600, framerate=10/1, format=(string)I420' ! appsink
Camera index = 0
Camera mode = 0
seconds to Run = 0
Argus Error Status
Execution ended after 0:00:00.542137672
Caught SIGSEGV
#0 0x0000007f790c77f4 in __pthread_clockjoin_ex (threadid=547393671648, thread_return=0x0, clockid=0, abstime=<optimized out>, block=<optimized out>)
#1 0x0000007f79185ab8 in () at /usr/lib/aarch64-linux-gnu/libglib-2.0.so.0
#2 0x00000055826bc080 in ()
Spinning. Please run 'gdb gst-launch-1.0 7495' to continue debugging, Ctrl-C to quit, or Ctrl-\ to dump core.
$ gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! 'video/x-raw(memory:NVMM),width=1920,height=1280, framerate=10/1' ! nvvidconv flip-method=2 ! 'video/x-raw, width=800, height=600, format=(string)I420' ! appsink
Camera index = 0
Camera mode = 1
Output Stream W = 3264 H = 1848
seconds to Run = 0
Frame Rate = 28.000001
