Problem with nvcompositor + nvarguscamerasrc
Good afternoon. I have a Jetson AGS Xavier and 2 Leopard Imaging LI-IMX390 cameras. the task is to get an image from two cameras simultaneously using gstreamer.
I use the following command
gst-launch-1.0 nvcompositor name=nvcomp sink_0::xpos=0 sink_0::ypos=0 sink_0::width=1920 sink_0::height=1080 sink_1::xpos=1920 sink_1::ypos=0 sink_1::width=1920
! nvvidconv ! ‘video/x-raw(memory:NVMM), format=(string)I420’, width=3840, height=1080 ! nv3dsink
nvarguscamerasrc sensor_id=1 ! ‘video/x-raw(memory:NVMM), width=1920, height=1080, format=(string)NV12, framerate=(fraction)30/1’
! nvvidconv flip-method=2 ! nvcomp.sink_0
nvarguscamerasrc sensor_id=0 ! ‘video/x-raw(memory:NVMM), width=1920, height=1080, format=(string)NV12, framerate=(fraction)30/1’
! nvvidconv flip-method=2 ! nvcomp.sink_1
But it gives an error
gst-launch-1.0 nvcompositor name=nvcomp sink_0::xpos=0 sink_0::ypos=0 sink_0::width=1920 sink_0::height=1080 sink_1::xpos=1920 sink_1::ypos=0 sink_1::width=1920 ! nvvidconv ! “video/x-raw(memory:NVMM), format=(string)I420”, width=3840, height=1080 ! nv3dsink nvarguscamerasrc sensor_id=1 ! “video/x-raw(memory:NVMM), width=1920, height=1080, format=(string)NV12, framerate=(fraction)30/1” ! nvvidconv flip-method=2 ! nvcomp.sink_0 nvarguscamerasrc sensor_id=0 ! “video/x-raw(memory:NVMM), width=1920, height=1080, format=(string)NV12, framerate=(fraction)30/1” ! nvvidconv flip-method=2 ! nvcomp.sink_1
nvbuf_utils: Could not get EGL display connection
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
New clock: GstSystemClock
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected…
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 1920 x 1080 FR = 29,999999 fps Duration = 33333334 ; Analog Gain range min 1,000000, max 31,622776; Exposure Range min 59000, max 33333000;
GST_ARGUS: Running with following settings:
Camera index = 1
Camera mode = 0
Output Stream W = 1920 H = 1080
seconds to Run = 0
Frame Rate = 29,999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
Camera index = 0
Camera mode = 0
seconds to Run = 0
CONSUMER: Producer has connected; continuing.
nvbuf_utils: dmabuf_fd -1 mapped entry NOT found
nvbuf_utils: Can not get HW buffer from FD… Exiting…
ERROR: from element /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc1: TIMEOUT
Additional debug info:
Argus Error Status
Execution ended after 0:00:02.923376928
Setting pipeline to READY …
(gst-launch-1.0:10234): GStreamer-CRITICAL **: 12:50:18.644: gst_mini_object_set_qdata: assertion ‘object != NULL’ failed
CONSUMER: Done Success
GST_ARGUS: Cleaning up
GST_ARGUS: Done Success
(gst-launch-1.0:10234): GStreamer-CRITICAL **: 12:50:19.089: gst_mini_object_set_qdata: assertion ‘object != NULL’ failed
Setting pipeline to NULL …
Freeing pipeline …
What could be the problem?
I run one camera at a time normally and they work
For single camera? I use:
gst-launch-1.0 nvarguscamerasrc tnr-mode=0 sensor-id=0 ! “video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, framerate=30/1” ! nvvidconv flip-method=0 ! “video/x-raw, format=(string)I420” ! xvimagesink -e
There may be 2 problems:
  • Wrong quoting in caps before nv3dsink
  • I420 as input of nvcompositor. Try RGBA instead:
gst-launch-1.0 nvcompositor name=nvcomp sink_0::xpos=0 sink_0::ypos=0 sink_0::width=1920 sink_0::height=1080 sink_1::xpos=1920 sink_1::ypos=0 sink_1::width=1920 ! nvvidconv ! 'video/x-raw(memory:NVMM), format=I420, width=3840, height=1080' ! nv3dsink \
     nvarguscamerasrc sensor_id=0 ! 'video/x-raw(memory:NVMM), width=1920, height=1080, format=NV12, framerate=30/1' ! nvvidconv flip-method=2 ! 'video/x-raw(memory:NVMM),format=RGBA' ! nvcomp.sink_1   \
     nvarguscamerasrc sensor_id=1 ! 'video/x-raw(memory:NVMM), width=1920, height=1080, format=NV12, framerate=30/1' ! nvvidconv flip-method=2 ! 'video/x-raw(memory:NVMM),format=RGBA' ! nvcomp.sink_0
I use command:
gst-launch-1.0 nvcompositor name=nvcomp sink_0::xpos=0 sink_0::ypos=0 sink_0::width=1920 sink_0::height=1080 sink_1::xpos=1920 sink_1::ypos=0 sink_1::width=1920 ! nvvidconv ! "video/x-raw(memory:NVMM), format=RGBA, width=3840, height=1080" ! nv3dsink nvarguscamerasrc sensor_id=0 ! "video/x-raw(memory:NVMM), width=1920, height=1080, format=NV12, framerate=30/1" ! nvvidconv flip-method=2 ! "video/x-raw(memory:NVMM),format=RGBA" ! nvcomp.sink_1 nvarguscamerasrc sensor_id=1 ! "video/x-raw(memory:NVMM), width=1920, height=1080, format=NV12, framerate=30/1" ! nvvidconv flip-method=2 ! "video/x-raw(memory:NVMM),format=RGBA" ! nvcomp.sink_0
And result:
jetson@jetson:~$ gst-launch-1.0 nvcompositor name=nvcomp sink_0::xpos=0 sink_0::ypos=0 sink_0::width=1920 sink_0::height=1080 sink_1::xpos=1920 sink_1::ypos=0 sink_1::width=1920 ! nvvidconv ! “video/x-raw(memory:NVMM), format=RGBA, width=3840, height=1080” ! nv3dsink nvarguscamerasrc sensor_id=0 ! “video/x-raw(memory:NVMM), width=1920, height=1080, format=NV12, framerate=30/1” ! nvvidconv flip-method=2 ! “video/x-raw(memory:NVMM),format=RGBA” ! nvcomp.sink_1 nvarguscamerasrc sensor_id=1 ! “video/x-raw(memory:NVMM), width=1920, height=1080, format=NV12, framerate=30/1” ! nvvidconv flip-method=2 ! “video/x-raw(memory:NVMM),format=RGBA” ! nvcomp.sink_0
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:656 Failed to create CaptureSession
(gst-launch-1.0:11950): GStreamer-CRITICAL **: 13:56:30.101: gst_mini_object_set_qdata: assertion ‘object != NULL’ failed
Redistribute latency…
Caught SIGSEGV
Got EOS from element “pipeline0”.
Execution ended after 0:00:00.011740192
#0 0x0000007fb2894400 in syscall ()
#1 0x0000007fb29e4b84 in g_cond_wait ()
#2 0x0000007fb16d4634 in ()
#3 0x0000007fb16d6054 in ()
#4 0x0000007fb2a73008 in g_object_unref ()
#5 0x0000007fb16dbb34 in ()
#6 0x0000007fb21b776c in () at /usr/lib/aarch64-linux-gnu/libgstbase-1.0.so.0
#7 0x0000000000000001 in ()
Spinning. Please run ‘gdb gst-launch-1.0 11950’ to continue debugging, Ctrl-C to quit, or Ctrl-\ to dump core.
I restarted Jetson and repeated the command.
Here is the result
gst-launch-1.0 nvcompositor name=nvcomp sink_0::xpos=0 sink_0::ypos=0 sink_0::width=1920 sink_0::height=1080 sink_1::xpos=1920 sink_1::ypos=0 sink_1::width=1920 ! nvvidconv ! “video/x-raw(memory:NVMM), format=I420, width=3840, height=1080” ! nv3dsink nvarguscamerasrc sensor_id=0 ! “video/x-raw(memory:NVMM), width=1920, height=1080, format=NV12, framerate=30/1” ! nvvidconv flip-method=2 ! “video/x-raw(memory:NVMM),format=I420” ! nvcomp.sink_1 nvarguscamerasrc sensor_id=1 ! “video/x-raw(memory:NVMM), width=1920, height=1080, format=NV12, framerate=30/1” ! nvvidconv flip-method=2 ! “video/x-raw(memory:NVMM),format=I420” ! nvcomp.sink_0
Camera index = 1
Camera mode = 0
seconds to Run = 0
Camera index = 0
Camera mode = 0
seconds to Run = 0
Argus Error Status
Execution ended after 0:00:02.874837600
(gst-launch-1.0:9132): GStreamer-CRITICAL **: 14:07:30.997: gst_mini_object_set_qdata: assertion ‘object != NULL’ failed
(gst-launch-1.0:9132): GStreamer-CRITICAL **: 14:07:31.405: gst_mini_object_set_qdata: assertion ‘object != NULL’ failed
Freeing pipeline …
The command you’ve launched after reboot still uses I420 as nvcompositor inputs.
Can you reboot and launch exactly my command ?
I restarted Jetson and executed your command
jetson@jetson:~$ gst-launch-1.0 nvcompositor name=nvcomp sink_0::xpos=0 sink_0::ypos=0 sink_0::width=1920 sink_0::height=1080 sink_1::xpos=1920 sink_1::ypos=0 sink_1::width=1920 ! nvvidconv ! ‘video/x-raw(memory:NVMM), format=I420, width=3840, height=1080’ ! nv3dsink nvarguscamerasrc sensor_id=0 ! ‘video/x-raw(memory:NVMM), width=1920, height=1080, format=NV12, framerate=30/1’ ! nvvidconv flip-method=2 ! ‘video/x-raw(memory:NVMM),format=RGBA’ ! nvcomp.sink_1 nvarguscamerasrc sensor_id=1 ! ‘video/x-raw(memory:NVMM), width=1920, height=1080, format=NV12, framerate=30/1’ ! nvvidconv flip-method=2 ! ‘video/x-raw(memory:NVMM),format=RGBA’ ! nvcomp.sink_0
Camera index = 1
Camera mode = 0
seconds to Run = 0
Camera index = 0
Camera mode = 0
seconds to Run = 0
ERROR: from element /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc1: CANCELLED
Argus Error Status
Execution ended after 0:00:03.539535424
(gst-launch-1.0:8523): GStreamer-CRITICAL **: 14:17:59.887: gst_mini_object_set_qdata: assertion ‘object != NULL’ failed
(gst-launch-1.0:8523): GStreamer-CRITICAL **: 14:18:00.886: gst_mini_object_set_qdata: assertion ‘object != NULL’ failed
Freeing pipeline …
Have a try below command.
gst-launch-1.0 nvcompositor name=comp sink_0::xpos=0 sink_0::ypos=0 sink_0::width=320 sink_0::height=240 sink_1::xpos=320 sink_1::ypos=0 sink_1::width=320 sink_1::height=240 ! nvoverlaysink nvarguscamerasrc sensor-id=0 ! 'video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1' ! queue ! nvvidconv ! nvivafilter cuda-process=true customer-lib-name="libnvsample_cudaprocess.so" ! 'video/x-raw(memory:NVMM), format=(string)RGBA' ! comp. -e nvarguscamerasrc sensor-id=1 ! "video/x-raw(memory:NVMM),format=NV12,width=1920,height=1080,framerate=(fraction)30/1" ! queue ! nvivafilter cuda-process=true customer-lib-name="libnvsample_cudaprocess.so" ! 'video/x-raw(memory:NVMM), format=(string)RGBA' ! comp. -e
I tried your command.
Result:
jetson@jetson:~$ gst-launch-1.0 nvcompositor name=comp sink_0::xpos=0 sink_0::ypos=0 sink_0::width=320 sink_0::height=240 sink_1::xpos=320 sink_1::ypos=0 sink_1::width=320 sink_1::height=240 ! nvoverlaysink nvarguscamerasrc sensor-id=0 ! “video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1” ! queue ! nvvidconv ! nvivafilter cuda-process=true customer-lib-name=“libnvsample_cudaprocess.so” ! “video/x-raw(memory:NVMM), format=(string)RGBA” ! comp. -e nvarguscamerasrc sensor-id=1 ! “video/x-raw(memory:NVMM),format=NV12,width=1920,height=1080,framerate=(fraction)30/1” ! queue ! nvivafilter cuda-process=true customer-lib-name=“libnvsample_cudaprocess.so” ! “video/x-raw(memory:NVMM), format=(string)RGBA” ! comp. -e
Camera index = 1
Camera mode = 0
seconds to Run = 0
Camera index = 0
Camera mode = 0
seconds to Run = 0
Argus Error Status
EOS on shutdown enabled – waiting for EOS after Error
Waiting for EOS…
(gst-launch-1.0:12798): GStreamer-CRITICAL **: 10:34:42.727: gst_mini_object_set_qdata: assertion ‘object != NULL’ failed
Your command worked, but it only gives a picture from one camera, and the other half is just a black square
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:649 Invalid camera device specified 1 specified, 0 max index
(gst-launch-1.0:9318): GStreamer-CRITICAL **: 10:50:27.482: gst_mini_object_set_qdata: assertion ‘object != NULL’ failed
Camera index = 0
Camera mode = 0
seconds to Run = 0
Camera index = 1
Camera mode = 0
seconds to Run = 0
Camera index = 0
Camera mode = 0
seconds to Run = 0
Argus Error Status
Waiting for EOS…
(gst-launch-1.0:9241): GStreamer-CRITICAL **: 18:59:58.932: gst_mini_object_set_qdata: assertion ‘object != NULL’ failed
My guess would be that both are sent into input0 of compositor. You may add sink number property:
gst-launch-1.0 nvcompositor name=comp sink_0::xpos=0 sink_0::ypos=0 sink_0::width=320 sink_0::height=240 sink_1::xpos=320 sink_1::ypos=0 sink_1::width=320 sink_1::height=240 ! nvoverlaysink nvarguscamerasrc sensor-id=0 ! 'video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1' ! queue ! nvvidconv ! nvivafilter cuda-process=true customer-lib-name="libnvsample_cudaprocess.so" ! 'video/x-raw(memory:NVMM), format=(string)RGBA' ! comp.sink_1 -e      nvarguscamerasrc sensor-id=1 ! "video/x-raw(memory:NVMM),format=NV12,width=1920,height=1080,framerate=(fraction)30/1" ! queue ! nvivafilter cuda-process=true customer-lib-name="libnvsample_cudaprocess.so" ! 'video/x-raw(memory:NVMM), format=(string)RGBA' ! comp.sink_0 -e
Also have a check below command.
gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! 'video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080' ! nvvidconv ! 'video/x-raw(memory:NVMM),format=RGBA' ! comp.sink_0  nvarguscamerasrc sensor-id=1 ! 'video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080' ! nvvidconv ! 'video/x-raw(memory:NVMM),format=RGBA' ! comp.sink_1  nvcompositor name=comp sink_0::alpha=0.5 sink_1::alpha=0.5 ! nvoverlaysink sync=false -e
I tried it. The output is black on the screen, that is, there is no picture. and this is what he writes to the terminal
jetson@jetson:~$ gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! ‘video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080’ ! nvvidconv ! ‘video/x-raw(memory:NVMM),format=RGBA’ ! comp.sink_0 nvarguscamerasrc sensor-id=1 ! ‘video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080’ ! nvvidconv ! ‘video/x-raw(memory:NVMM),format=RGBA’ ! comp.sink_1 nvcompositor name=comp sink_0::alpha=0.5 sink_1::alpha=0.5 ! nvoverlaysink sync=false -e
Camera index = 0
Camera mode = 0
seconds to Run = 0
Camera index = 1
Camera mode = 0
seconds to Run = 0
ERROR: from element /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0: TIMEOUT
Argus Error Status
Waiting for EOS…
(gst-launch-1.0:10896): GStreamer-CRITICAL **: 09:09:37.795: gst_mini_object_set_qdata: assertion ‘object != NULL’ failed
jetson@jetson:~$ gst-launch-1.0 nvcompositor name=comp sink_0::xpos=0 sink_0::ypos=0 sink_0::width=320 sink_0::height=240 sink_1::xpos=320 sink_1::ypos=0 sink_1::width=320 sink_1::height=240 ! nvoverlaysink nvarguscamerasrc sensor-id=0 ! ‘video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1’ ! queue ! nvvidconv ! nvivafilter cuda-process=true customer-lib-name=“libnvsample_cudaprocess.so” ! ‘video/x-raw(memory:NVMM), format=(string)RGBA’ ! comp.sink_1 -e nvarguscamerasrc sensor-id=1 ! “video/x-raw(memory:NVMM),format=NV12,width=1920,height=1080,framerate=(fraction)30/1” ! queue ! nvivafilter cuda-process=true customer-lib-name=“libnvsample_cudaprocess.so” ! ‘video/x-raw(memory:NVMM), format=(string)RGBA’ ! comp.sink_0 -e
Camera index = 1
Camera mode = 0
seconds to Run = 0
Camera index = 0
Camera mode = 0
seconds to Run = 0
Argus Error Status
Waiting for EOS…
(gst-launch-1.0:11056): GStreamer-CRITICAL **: 09:15:36.793: gst_mini_object_set_qdata: assertion ‘object != NULL’ failed
Does both cameras work independently and concurrently ? (Note this assumes your local monitor can do 1080p)
gst-launch-1.0 -v nvarguscamerasrc sensor_id=0 num-buffers=150 ! 'video/x-raw(memory:NVMM), width=1920, height=1080, format=(string)NV12, framerate=(fraction)30/1' ! nvvidconv flip-method=2 ! nvoverlaysink
gst-launch-1.0 -v nvarguscamerasrc sensor_id=1 num-buffers=150 ! 'video/x-raw(memory:NVMM), width=1920, height=1080, format=(string)NV12, framerate=(fraction)30/1' ! nvvidconv flip-method=2 ! nvoverlaysink
gst-launch-1.0 -v nvarguscamerasrc sensor_id=0 num-buffers=150 ! 'video/x-raw(memory:NVMM), width=1920, height=1080, format=(string)NV12, framerate=(fraction)30/1' ! nvvidconv flip-method=2 ! nvoverlaysink overlay=1    nvarguscamerasrc sensor_id=1 num-buffers=150 ! 'video/x-raw(memory:NVMM), width=1920, height=1080, format=(string)NV12, framerate=(fraction)30/1' ! nvvidconv flip-method=2 ! nvoverlaysink overlay=2
The last command may only show second camera overlaying the first one, but this is just for checking if both nvarguscamersrc work before using nvcompositor.
The first and second command are working. One by one, the cameras are launched and give a picture.
The third command does not work and outputs this log:
jetson@jetson:~$ gst-launch-1.0 -v nvarguscamerasrc sensor_id=0 num-buffers=150 ! “video/x-raw(memory:NVMM), width=1920, height=1080, format=(string)NV12, framerate=(fraction)30/1” ! nvvidconv flip-method=2 ! nvoverlaysink overlay=1 nvarguscamerasrc sensor_id=1 num-buffers=150 ! “video/x-raw(memory:NVMM), width=1920, height=1080, format=(string)NV12, framerate=(fraction)30/1” ! nvvidconv flip-method=2 ! nvoverlaysink overlay=2
/GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc1.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstNvOverlaySink-nvoverlaysink:nvoverlaysink-nvoverlaysink0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstNvOverlaySink-nvoverlaysink:nvoverlaysink-nvoverlaysink1.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/Gstnvvconv:nvvconv1.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
Camera index = 1
Camera mode = 0
seconds to Run = 0
Camera index = 0
Camera mode = 0
seconds to Run = 0
Argus Error Status
Execution ended after 0:00:02.777882912
(gst-launch-1.0:9817): GStreamer-CRITICAL **: 08:44:41.916: gst_mini_object_set_qdata: assertion ‘object != NULL’ failed
Freeing pipeline …
The monitor supports a resolution of 1920 by 1080
What’s your BSP version?
JetPack 4.5
L4T 32.5
R32 (release), REVISION: 5.0 (/etc/nv_tegra_release)
CTI version AGX-32.5-V004 (/etc/cti/CTI-L4T.version)
Have try this patch
thank you it helped. 2 cameras are displayed on the screen, but the image is superimposed on one another.
