Can not access CSI Camera using gStreamer
Hey, I am trying to access video feed from IMX477 csi camera attached to my Jetson NANO (jetpack 6.0). There is no display connected to it too.
I am accessing my server remotely by SSH. I am using gStreamer using this command -
gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw, width=1920, height=1080, format=YUY2 ! videoconvert ! autovideosink
But this command gives me the following error-
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Got context from element ‘autovideosink0’: gst.gl.GLDisplay=context, gst.gl.GLDisplay=(GstGLDisplay)“(GstGLDisplayX11)\ gldisplayx11-0”;
Pipeline is PREROLLED …
Setting pipeline to PLAYING …
New clock: GstSystemClock
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
Additional debug info:
…/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming stopped, reason not-negotiated (-4)
Execution ended after 0:00:00.004398889
Setting pipeline to NULL …
Freeing pipeline …
Please give some suggestions.
It’s RAW sensor don’t support by v4l2src try nvarguscamerasrc instead.
As suggested I have tried with nvarguscamera, here is my pipeline -
gst-launch-1.0 nvarguscamerasrc ! video/x-raw(memory:NVMM),width=1920,height=1080,format=NV12 ! nvvidconv ! nvh264enc ! h264parse ! mp4mux ! filesink location=output.mp4
But the nvidia specific elements (nvh264enc / nvh264enc) are not found, I have upgraded the packages also.
You can try fake sink like below.
gst-launch-1.0 nvarguscamerasrc ! 'video/x-raw(memory:NVMM)' ! nvvidconv ! fpsdisplaysink video-sink=fakesink text-overlay=false -v
So with this command I am getting -
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstFakeSink:fakesink0: sync = true
/GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0.GstGhostPad:sink.GstProxyPad:proxypad0: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstFakeSink:fakesink0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0.GstGhostPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
GST_ARGUS: Creating output stream
(Argus) Error BadParameter: (propagating from src/eglstream/FrameConsumerImpl.cpp, function initialize(), line 93)
(Argus) Error BadParameter: (propagating from src/eglstream/FrameConsumerImpl.cpp, function create(), line 44)
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadInitialize:316 Failed to create FrameConsumer
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadFunction:237 (propagating)
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, waitRunning:199 Invalid thread state 3
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:847 (propagating)
Redistribute latency…
WARNING: from element /GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstFakeSink:fakesink0: Pipeline construction is invalid, please add queues.
…/libs/gst/base/gstbasesink.c(1249): gst_base_sink_query_latency (): /GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstFakeSink:fakesink0:
Not enough buffering available for the processing deadline of 0:00:00.020000000, add enough queues to buffer 0:00:00.020000000 additional data. Shortening processing latency to 0:00:00.000000000.
Got EOS from element “pipeline0”.
Execution ended after 0:00:00.509129592
Freeing pipeline …
I added queue in the pipeline, but it is still giving me -
/GstPipeline:pipeline0/GstQueue:queue0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstQueue:queue0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstQueue:queue1.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstQueue:queue1.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstQueue:queue2.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstQueue:queue2.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1
Execution ended after 0:00:00.604572575
Freeing pipeline …
What’s your device? Jetson Orin Nano?
Use sdkmanager to install the JP6.x again.
Yes, my device is Jetson Orin Nano.
Can I use multiple jetpack versions and tailor it use-case wise, as another team is working on the same device parallelly. All teams are trying to connect the same device remotely on use-case to use-case basis.
First check the sensor driver is probe successfully and base capture function is working by vl42-command.
v4l2-ctl --list-devices
v4l2-ctl --stream-mmap -c bypass_mode=0
Second check argus was recognize the camera by below command.
nvargus_nvraw --lps
Sharing my outputs -
Jetson-Orin-Nano:~$ v4l2-ctl --list-devices
NVIDIA Tegra Video Input Device (platform:tegra-camrtc-ca):
/dev/media0
vi-output, imx477 10-001a (platform:tegra-capture-vi:1):
/dev/video0
Jetson-Orin-Nano:~$ v4l2-ctl --stream-mmap -c bypass_mode=0
VIDIOC_REQBUFS returned -1 (Device or resource busy)
Jetson-Orin-Nano:~$ nvargus_nvraw --lps
nvargus_nvraw version 1.15.0
Number of supported sensor entries 3
Entry Source Mode Uniquename Resolution FR BitDepth Mode
Index Index Index CSI Dyn Type
0 0 0 jakku_front_RBPCV3 4032x3040 20 10 10 Bayer
1 0 1 jakku_front_RBPCV3 3840x2160 29 10 10 Bayer
2 0 2 jakku_front_RBPCV3 1920x1080 59 10 10 Bayer
Stop the nvargus-daemon to run the v4l2-ctl --stream-mmap -c bypass_mode=0 again.
sudo service nvargus-daemon stop
I the v4l2 command is running-
Jetson-Orin-Nano:~$ v4l2-ctl --stream-mmap -c bypass_mode=0 <<<<<<<<<<<<<<<<<<<<<<< 21.92 fps
<<<<<<<<<<<<<<<<^C
Jetson-Orin-Nano:~$ nvargus_nvraw --lps nvargus_nvraw version 1.15.0
(“nvargus_nvraw”) Error BadParameter (0x04): getCameraDevices() failed (in capture_nvraw/src/mobile/
ArgusNvRawCapture.cpp, func initialize(), line 71)
(Argus) Error EndOfFile: Unexpected error in reading socket (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 277)
(Argus) Error EndOfFile: Receive worker failure, notifying 1 waiting threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 350)
(Argus) Error InvalidState: Argus client is exiting with 1 outstanding client threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 366)
(Argus) Error EndOfFile: Receiving thread terminated with error (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadWrapper(), line 379)
(Argus) Error EndOfFile: Client thread received an error from socket (in src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 145)
(Argus) Error EndOfFile: (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 91)
(“nvargus_nvraw”) Error BadParameter (0x04): Unable to initialize (propagating from capture_nvraw/src/mobile/main.cpp,
func main(), line 73)
Looks like the sensor driver probe successfully and capture function well.
Try below command.
sudo service nvargus-daemon restart
export DISPLAY=:0
gst-launch-1.0 nvarguscamerasrc ! 'video/x-raw(memory:NVMM)' ! nvvidconv ! queue ! fpsdisplaysink video-sink=fakesink text-overlay=false -v
Hey, I run the commands and got the following errors -
Authorization required, but no authorization protocol specified
nvbufsurftransform: Could not get EGL display connection
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:792 No cameras available
Redistribute latency...
Got EOS from element "pipeline0".
Execution ended after 0:00:00.004862631
Setting pipeline to NULL ...
Freeing pipeline ...
It could be GPU driver didn’t load. It could be your device didn’t have display connect.
It does not have a display, as I mentioned earlier, I want the output in a file or streaming.
Try below.
xinit&
DISPLAY=:0 or 1
I tried this earlier too, I am getting the following errors of the above commands-
Jetson-Orin-Nano:~$ xinit&
[1] 24304
Jetson-Orin-Nano:~$
X.Org X Server 1.21.1.4
X Protocol Version 11, Revision 0
Current Operating System: Linux Jetson-Orin-Nano 5.15.136-tegra #1 SMP PREEMPT Tue Jun 25 06:17:33 UTC 2024 aarch64
Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb video=efifb:off console=tty0 bl_prof_dataptr=2031616@0x271E10000 bl_prof_ro_ptr=65536@0x271E00000
xorg-server 2:21.1.4-2ubuntu1.7~22.04.10 (For technical support please see http://www.ubuntu.com/support)
Current version of pixman: 0.40.0
        Before reporting problems, check http://wiki.x.org
        to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
        (++) from command line, (!!) notice, (II) informational,
        (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Tue Dec 10 11:37:43 2024
(==) Using config file: "/etc/X11/xorg.conf"
(==) Using config directory: "/etc/X11/xorg.conf.d"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
Jetson-Orin-Nano:~$ gst-launch-1.0 nvarguscamerasrc ! 'video/x-raw(memory:NVMM)' ! nvvidconv ! queue ! fpsdisplaysink video-sink=fakesink text-overlay=false -v
Execution ended after 0:00:00.004003592
That’s weird! Do you run on the same device the same configuration?
Confirm the sensor by nvargus_nvraw --lps again.
Now this command is throwing error -
("nvargus_nvraw") Error BadParameter (0x04): getCameraDevices() failed (in capture_nvraw/src/mobile/
