Export video stream from Orin Nano to a remote display
Hi, I am trying to remotely display a camera stream from CSI port on Orin Nano using gstreamer:
gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! ‘video/x-raw(memory:NVMM), width=3280, height=2464, framerate=21/1, format=NV12’ ! nvvidconv flip-method=2 ! ‘video/x-raw, width=800, height=600, format=BGRx’ ! videoconvert ! ‘video/x-raw, format=BGR’ ! queue ! nveglglessink -e
I am running this command on a remote machine using VNC, and the camera video display always shows up on the display directly connected to the Orin Nano. I need to find a method to pipe the video stream to a display on my remote machine.
Thankyou for your help!
Log in remotely from a Linux host into Jeston using ssh with X11 forwarding (ssh -X Jeston_IP) and use xvimagesink:
gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! ‘video/x-raw(memory:NVMM), width=3280, height=2464, framerate=21/1, format=NV12’ ! nvvidconv flip-method=2 ! ‘video/x-raw, width=800, height=600’ ! videoconvert ! queue ! xvimagesink
If you can’t use a host with X server and want to use VNC, you may try to set DISPLAY to your VNC server display. For OpenGL, it may be a bit more complex, maybe you’ll have to install something like VirtualGL if you intend to run headless.
Hello, Thankyou for your reply.
I started vnc server to run remotely
vncserver :2
Next, using your gstreamer command syntax.
Setting pipeline to PAUSED …
ERROR: Pipeline doesn’t want to pause.
ERROR: from element /GstPipeline:pipeline0/GstXvImageSink:xvimagesink0: Could not initialise Xv output
Additional debug info:
xvimagesink.c(1773): gst_xv_image_sink_open (): /GstPipeline:pipeline0/GstXvImageSink:xvimagesink0:
XVideo extension is not available
Setting pipeline to NULL …
Freeing pipeline …
Does this mean there needs to be XVideo extention running on remote machine?
I should add that remote machine is Windows with X11, and that I do have a path that uses Xming
Thanks again for the help.
Not sure what you mean here…
If you just want the gstreamer output in a window of your Windows X server, you would configure X11 forwarding in puTTY or your other ssh terminal.
If you want to use VNC instead, then you would set DISPLAY to your VNC screen:
DISPLAY=:2  nvarguscamerasrc sensor-id=0 ! 'video/x-raw(memory:NVMM), width=3280, height=2464, framerate=21/1, format=NV12' ! nvvidconv flip-method=2 ! 'video/x-raw, width=800, height=600' ! videoconvert ! queue ! xvimagesink
I confused the text by mentioning Xming. I only want to run using VNC. When I do this, using
DISPLAY=:2 gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! ‘video/x-raw(memor
It comes back with:
Freeing pipeline …
Thankyou.
Here is an update to the issue with CSI cameras;
I plugged in USB LifeCam, and can successfully export to the remote VNC display using:
DISPLAY=:2 gst-launch-1.0 v4l2src device=/dev/video2 ! videoconvert ! ximagesink
There is some latency and a reduced frame rate, but it works. So, the VNC connection to the remote display is correct.
Now, going back to the CSI camera with the issue; I also tried:
deo/x-raw, width=800, height=600’ ! videoconvert ! queue ! ximagesink
This works on the local display (DISPLAY=:1), but throws an error when I attempt to export to the remote display:
st-launch-1.0 nvarguscamerasrc sensor-id=0 ! ‘video/x-raw(memory:NVMM), width=3280, height=2464, framerate=21/1, format=NV12’ ! nvvidconv flip-method=2 ! ‘video/x-raw, width=800, height=600’ ! videoconvert ! queue ! ximagesink
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
New clock: GstSystemClock
GST_ARGUS: Creating output stream
(Argus) Error BadParameter: (propagating from src/eglstream/FrameConsumerImpl.cpp, function initialize(), line 89)
(Argus) Error BadParameter: (propagating from src/eglstream/FrameConsumerImpl.cpp, function create(), line 44)
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadInitialize:320 Failed to create FrameConsumer
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadFunction:241 (propagating)
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, waitRunning:203 Invalid thread state 3
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:806 (propagating)
Got EOS from element “pipeline0”.
Execution ended after 0:00:00.089300740
Freeing pipeline …
It may be an issue with your VNC server. I am not using VNC, but I can confirm that Desktop sharing with NoMachine can display nvarguscamerasrc into xvimagesink or nv3dsink when using the following pipeline on Xavier NX running R35.2:
gst-launch-1.0 nvarguscamerasrc ! nvvidconv ! queue ! xvimagesink
# Or use nv3dsink, but stop the pipeline from shell with Ctrl-C (only once and wait) rather than closing the window, otherwise it may spur errors
# If you face errors you may restart argus with: sudo service nvargus-daemon restart
gst-launch-1.0 nvarguscamerasrc ! nvvidconv ! queue ! nv3dsink
Thankyou for your reply. Your suggestion does work for me. I wonder if there is some limitation when using X11 with nvarguscamerasrc based pipelines. I can use your solution if I can find a way to run ORIN NANO completely headless with NoMAchine. Do you know if such a path exists with NoMachine? Thankyou.
I haven’t been playing with headless setup since a few years ago, but I think that it may help to have autologin and a default virtual screen such as this in Xorg.conf:
Section "Screen"
  Identifier "MY-SCREEN"
  DefaultDepth 24
  SubSection "Display"
    Virtual 1280 1024
    Depth 24
  EndSubSection
EndSection
Thankyou @Honey_Patouceul,
Here are my latest findings:
As I mentioned earlier, Video streaming works fine with a physical display connected. When I disconnect the physical display, and use a virtual display:
gst-launch-1.0 nvarguscamerasrc ! nvvidconv ! xvimagesink
tail -f /var/log/syslog shows:
May 24 13:26:06 auvai1 nvargus-daemon: E/ libnvphs:socket: Error[2]: socket connection /var/lib/nvphs/nvphsd.ctl to PHS failed: No such file or directory
May 24 13:26:06 auvai1 nvargus-daemon: D/ libnvphs:socket: Warning: connecting to Power Hinting Service failed. Is PHS running?
May 24 13:26:06 auvai1 nvargus-daemon: E/ libnvphs: Error: NvPHSSendThroughputHints[usecase=camera, hint=MinCPU, value=4294967295, timeout_ms=1000]: queue_or_send() failed
Here is output from command line:
libEGL warning: DRI2: failed to authenticate
=== gst-launch-1.0[4373]: Connection established (FFFF8B32D900)OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module1
OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
---- imager: No override file found. ----
=== gst-launch-1.0[4373]: CameraProvider initialized (0xffff84730820)Setting pipeline to PAUSED …
SCF: Error BadValue: NvPHSSendThroughputHints (in src/common/CameraPowerHint.cpp, function sendCameraPowerHint(), line 56)
No protocol specified
(Argus) Error NotSupported: Failed to initialize EGLDisplay (in src/eglutils/EGLUtils.cpp, function getDefaultDisplay(), line 77)
(Argus) Error NotSupported: Failed to get default display (in src/api/EGLOutputStreamImpl.cpp, function initialize(), line 99)
(Argus) Error NotSupported: (propagating from src/api/CaptureSessionImpl.cpp, function createEGLOutputStream(), line 977)
(Argus) Error InvalidState: Unknown stream deleted. (in src/api/CaptureSessionImpl.cpp, function outputStreamDeleted(), line 1094)
(Argus) Error NotSupported: (propagating from src/api/CaptureSessionImpl.cpp, function createOutputStreamInternal(), line 839)
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:799 Failed to create OutputStream
WARNING: from element /GstPipeline:pipeline0/GstXvImageSink:xvimagesink0: Pipeline construction is invalid, please add queues.
gstbasesink.c(1209): gst_base_sink_query_latency (): /GstPipeline:pipeline0/GstXvImageSink:xvimagesink0:
Not enough buffering available for the processing deadline of 0:00:00.015000000, add enough queues to buffer 0:00:00.015000000 additional data. Shortening processing latency to 0:00:00.000000000.
Execution ended after 0:00:00.057438200
does anyone know how I can eliminate the error that originates from Power Hinting Service?
This error does not occur when the physical display is connected. I need to be able to run with only virtual display and without any physical display connected.
Thanks,
After a reboot, I run
gst-launch-1.0 nvarguscamerasrc ! nvvidconv ! ximagesink
WARNING: from element /GstPipeline:pipeline0/GstXImageSink:ximagesink0: Pipeline construction is invalid, please add queues.
gstbasesink.c(1209): gst_base_sink_query_latency (): /GstPipeline:pipeline0/GstXImageSink:ximagesink0:
Execution ended after 0:00:00.173594800
Freeing pipeline …
May 24 19:31:38 auvai1 nvargus-daemon[938]: === NVIDIA Libargus Camera Service (0.99.33)=== Listening for connections…=== gst-launch-1.0[3392]: Connection established (FFFF8FE12900)OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
May 24 19:31:38 auvai1 nvargus-daemon[938]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module1
May 24 19:31:38 auvai1 nvargus-daemon[938]: OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
May 24 19:31:38 auvai1 nvargus-daemon[938]: ---- imager: No override file found. ----
May 24 19:31:38 auvai1 nvargus-daemon: E/ libnvphs:socket: Error[2]: socket connection /var/lib/nvphs/nvphsd.ctl to PHS failed: No such file or directory
May 24 19:31:38 auvai1 nvargus-daemon: D/ libnvphs:socket: Warning: connecting to Power Hinting Service failed. Is PHS running?
May 24 19:31:38 auvai1 nvargus-daemon[938]: === gst-launch-1.0[3392]: CameraProvider initialized (0xffff886eb420)SCF: Error BadValue: NvPHSSendThroughputHints (in src/common/CameraPowerHint.cpp, function sendCameraPowerHint(), line 56)
May 24 19:31:38 auvai1 nvargus-daemon: E/ libnvphs: Error: NvPHSSendThroughputHints[usecase=camera, hint=MinCPU, value=4294967295, timeout_ms=1000]: queue_or_send() failed
May 24 19:31:38 auvai1 nvargus-daemon[938]: (Argus) Error InvalidState: Unknown stream deleted. (in src/api/CaptureSessionImpl.cpp, function outputStreamDeleted(), line 1094)
You can see that it failed to create FrameConsumer, and at the same time it has the issue with Nvidia Power Hinting Service.
