Xavier AGX deepstream5.1 sample app : no camera available error
Hello.
I’m trying to test deepstream sample app with 4 cameras(e-concsystems e-CAM 130A-CUXVR_QUAD) on our Xavier AGX.
I’m using Jetpack 4.5.1 version.
I modified source1_csi_dec_infer_resnet_int8.txt of deepstream-5.1/samples/configs/deepstream-app.
The code after modification is below. I just added sources and change the numbers.
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=1
rows=2
columns=2
width=1920
height=1080
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP 5=CSI
type=5
camera-width=1920
camera-height=1080
camera-fps-n=60
camera-fps-d=1
camera-csi-sensor-id=0
[source1]
enable=1
type=5
camera-width=1920
camera-height=1080
camera-fps-n=60
camera-fps-d=1
camera-csi-sensor-id=1
[source2]
enable=1
type=5
camera-width=1920
camera-height=1080
camera-fps-n=60
camera-fps-d=1
camera-csi-sensor-id=2
[source3]
enable=1
type=5
camera-width=1920
camera-height=1080
camera-fps-n=60
camera-fps-d=1
camera-csi-sensor-id=3
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming 5=Overlay
type=5
sync=0
display-id=0
offset-x=0
offset-y=0
width=0
height=0
overlay-id=1
source-id=0
And Xavier can recognize the cameras.
$ ls /dev/vi*
/dev/video0 /dev/video1 /dev/video2 /dev/video3
$ dmesg | grep -i sensor
[ 8.893491] SENSOR ID=0x0265
[ 9.026729] ar1335 30-0042: Detected ar1335 sensor
[ 11.275624] SENSOR ID=0x0265
[ 11.390509] ar1335 32-0042: Detected ar1335 sensor
[ 13.639013] SENSOR ID=0x0265
[ 13.745773] ar1335 34-0042: Detected ar1335 sensor
[ 15.995029] SENSOR ID=0x0265
[ 16.101364] ar1335 35-0042: Detected ar1335 sensor
But the sample app is not working. Also the original app is not working.
$ deepstream-app -c oml_csi_test.txt
(deepstream-app:13745): GLib-GObject-WARNING **: 14:21:33.106: g_object_set_is_valid_property: object class ‘GstNvArgusCameraSrc’ has no property named ‘maxperf’
(deepstream-app:13745): GLib-GObject-WARNING **: 14:21:33.110: g_object_set_is_valid_property: object class ‘GstNvArgusCameraSrc’ has no property named ‘maxperf’
(deepstream-app:13745): GLib-GObject-WARNING **: 14:21:33.112: g_object_set_is_valid_property: object class ‘GstNvArgusCameraSrc’ has no property named ‘maxperf’
(deepstream-app:13745): GLib-GObject-WARNING **: 14:21:33.113: g_object_set_is_valid_property: object class ‘GstNvArgusCameraSrc’ has no property named ‘maxperf’
ERROR: Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-5.1/samples/configs/deepstream-app/…/…/models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine open error
0:00:01.888819345 13745 0x3d60e060 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1691> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-5.1/samples/configs/deepstream-app/…/…/models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine failed
0:00:01.889172995 13745 0x3d60e060 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1798> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-5.1/samples/configs/deepstream-app/…/…/models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine failed, try rebuild
0:00:01.889419984 13745 0x3d60e060 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1716> [UID = 1]: Trying to create engine from model files
INFO: [TRT]: Reading Calibration Cache for calibrator: EntropyCalibration2
INFO: [TRT]: Generated calibration scales using calibration cache. Make sure that calibration cache has latest scales.
INFO: [TRT]: To regenerate calibration cache, please delete the existing one. TensorRT will generate a new calibration cache.
INFO: [TRT]:
INFO: [TRT]: --------------- Layers running on DLA:
INFO: [TRT]:
INFO: [TRT]: --------------- Layers running on GPU:
INFO: [TRT]: conv1 + activation_1/Relu, block_1a_conv_1 + activation_2/Relu, block_1a_conv_2, block_1a_conv_shortcut + add_1 + activation_3/Relu, block_2a_conv_1 + activation_4/Relu, block_2a_conv_2, block_2a_conv_shortcut + add_2 + activation_5/Relu, block_3a_conv_1 + activation_6/Relu, block_3a_conv_2, block_3a_conv_shortcut + add_3 + activation_7/Relu, block_4a_conv_1 + activation_8/Relu, block_4a_conv_2, block_4a_conv_shortcut + add_4 + activation_9/Relu, conv2d_cov, conv2d_cov/Sigmoid, conv2d_bbox,
INFO: [TRT]: Detected 1 inputs and 2 output network tensors.
ERROR: Serialize engine failed because of file path: /opt/nvidia/deepstream/deepstream-5.1/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine opened error
0:00:16.562224388 13745 0x3d60e060 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1744> [UID = 1]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-5.1/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
INFO: [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:16.577461607 13745 0x3d60e060 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-5.1/samples/configs/deepstream-app/config_infer_primary.txt sucessfully
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
  To go back to the tiled display, right-click anywhere on the window.
**PERF: FPS 0 (Avg) FPS 1 (Avg) FPS 2 (Avg) FPS 3 (Avg)
**PERF: 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00)
** INFO: <bus_callback:181>: Pipeline ready
** INFO: <bus_callback:167>: Pipeline running
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:645 No cameras available
(deepstream-app:13745): GStreamer-CRITICAL **: 14:21:49.667: gst_mini_object_set_qdata: assertion ‘object != NULL’ failed
(deepstream-app:13745): GStreamer-CRITICAL **: 14:21:49.670: gst_mini_object_set_qdata: assertion ‘object != NULL’ failed
** INFO: <bus_callback:204>: Received EOS. Exiting …
Quitting
App run successful
Please give us some advice. Thanks.
Please confirm you can launch the cameras through nvarguscamerasrc first:
$ gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! nvoverlaysink
And senor-id= 1, 2, 3.
Hello, DaneLLL.
Thank you for your quick reply.
The camera didn’t work through nvarguscamerasrc
Here is the result of the command.
$ gst-launch-1.0 nvarguscamerasrc sensor-id=3 ! nvoverlaysink
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
New clock: GstSystemClock
Caught SIGSEGV
Got EOS from element “pipeline0”.
Execution ended after 0:00:00.077103199
Setting pipeline to READY …
#0 0x0000007fa17168f0 in syscall () at /lib/aarch64-linux-gnu/libc.so.6
#1 0x0000007fa1866fa0 in () at /usr/lib/aarch64-linux-gnu/libglib-2.0.so.0
#2 0x0000007f94009740 in ()
Spinning. Please run ‘gdb gst-launch-1.0 12423’ to continue debugging, Ctrl-C to quit, or Ctrl-\ to dump core.
It’s same in the other camera sensors(0,1,2).
But if we run the ecam_tk1_guvcview of e-consystems, the camera works well as you can see below.
$ ecam_tk1_guvcview
ecam_tk1_guvcview 1.7.2-g5d361af
file guvcview_video.mkv has extension type 1
file guvcview_image.jpg has extension type 0
no codec detected for H264
no codec detected for VP80
no codec detected for theo
no codec detected for MP3 - (lavc)
Video file suffix detected: 0
Image file suffix detected: 0
video device: /dev/video0
VIDIOC_QUERYCAP error: Inappropriate ioctl for device
couldn’t query device /dev/v4l-subdev0
couldn’t query device /dev/v4l-subdev1
couldn’t query device /dev/v4l-subdev2
couldn’t query device /dev/v4l-subdev3
couldn’t query device /dev/v4l-subdev4
couldn’t query device /dev/v4l-subdev5
couldn’t query device /dev/v4l-subdev6
couldn’t query device /dev/v4l-subdev7
Unable to find parent usb device.Unable to find parent usb device.Unable to find parent usb device.Unable to find parent usb device.vid:0061
pid:0000
driver:tegra-video
Init. vi-output, ar1335 30-0042 (location: platform:15c10000.vi:0)
{ pixelformat = ‘UYVY’, description = ‘UYVY 4:2:2’ }
{ discrete: width = 640, height = 480 }
Time interval between frame: 1/100,
{ discrete: width = 1280, height = 720 }
Time interval between frame: 1/72,
{ discrete: width = 1920, height = 1080 }
{ discrete: width = 3840, height = 2160 }
Time interval between frame: 1/30,
{ discrete: width = 4096, height = 2160 }
Time interval between frame: 1/28,
{ discrete: width = 4192, height = 3120 }
Time interval between frame: 1/19,
{ pixelformat = ‘NV16’, description = ‘Y/CbCr 4:2:2’ }
{ not supported - request format(909203022) support at http://guvcview.sourceforge.net }
checking muxed H264 format support
device doesn’t seem to support uvc H264 (0)
checking format: UYVY
fps is set to 1/100
drawing controls
control 0 [0x00980900] = 0
control 1 [0x00980901] = 4
control 2 [0x00980902] = 18
control 3 [0x0098090c] = 1
control 4 [0x00980910] = 220
control 5 [0x00980913] = 6
control 6 [0x00980914] = 0
control 7 [0x00980915] = 0
control 8 [0x0098091a] = 5000
control 9 [0x0098091b] = 16
control 0 [0x009a0901] = 0
control 1 [0x009a0902] = 333
control 2 [0x009a0908] = 0
control 3 [0x009a0909] = 0
control 4 [0x009a090d] = 100
control 5 [0x009a0924] = 8
control 6 [0x009a0926] = 32896
control 7 [0x009a0928] = 0
control 8 [0x009a092a] = 1
control 9 [0x009a0931] = 32000
control type: 0x00000006 not supported
fps is set to 1/100
Checking video mode 640x480@32bpp : OK
plane 0: pitch=1280
Looks like you should launch with v4l2src. Please refer to steps in
Jetson Nano FAQ
[Q: I have a USB camera. How can I launch it on Jetson Nano?]
And check if you can launch the cameras.
Hello, DaneLLL.
I got this error during the steps.
$ gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,format=YUY2,width=1920,height=1080,framerate=60/1 ! nvvidconv ! ‘video/x-raw(memory:NVMM),format=NV12’ ! nvoverlaysink
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
Additional debug info:
gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming stopped, reason not-negotiated (-4)
Execution ended after 0:00:00.001088600
Setting pipeline to NULL …
Freeing pipeline …
$ gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,format=YUY2,width=640,height=480,framerate=100/1 ! nvvidconv ! ‘video/x-raw(memory:NVMM),format=NV12’ ! nvoverlaysink
Execution ended after 0:00:00.000562397
Freeing pipeline …
And the next command, $ gst-launch-1.0 nvv4l2camerasrc device=/dev/video1 ! video/x-raw(memory:NVMM),format=UYVY,width=640,height=480,framerate=30/1 ! nvvidconv ! ‘video/x-raw(memory:NVMM),format=NV12’ ! nvoverlaysink
This command outputs syntax error because of ‘(’ on my AGX.
It looks like the camera supports YUYV 1080p60. Please try with fakesink:
$ gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,format=YUY2,width=1920,height=1080,framerate=60/1 ! fakesink
It’s also makes this error.
Execution ended after 0:00:00.000434262
Freeing pipeline …
Please make sure 1080p60 is listed in v4l2-ctl --list-formats-ext. Seems like it is not supported.
Hi, DaneLLL
Here is the result. I think it support 1080p 60fps.
$ v4l2-ctl --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: ‘UYVY’
  	Interval: Discrete 0.010s (100.000 fps)
  	Interval: Discrete 0.014s (72.000 fps)
  Size: Discrete 1920x1080
  Size: Discrete 3840x2160
  	Interval: Discrete 0.033s (30.000 fps)
  Size: Discrete 4096x2160
  	Interval: Discrete 0.036s (28.000 fps)
  Size: Discrete 4192x3120
  	Interval: Discrete 0.053s (19.000 fps)
Index : 1
Pixel Format: ‘NV16’
Please try
$ gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,format=UYVY,width=1920,height=1080,framerate=72/1 ! fakesink
I tried 72 frames in sample app code, but similarly, the ‘no-cameras available’ error message was printed.
So now I’m flashing the jetpack 4.5.1 again.
I tried the command after the flash done.
But it doesn’t work and stays still for more than 2 hour.
^Chandling interrupt.
Interrupt: Stopping pipeline …
Execution ended after 0:14:14.789651444
Freeing pipeline …
Looks like it is running. Please run this command and check if fps is printed:
$ gst-launch-1.0 -v v4l2src device=/dev/video0 ! video/x-raw,format=UYVY,width=1920,height=1080,framerate=72/1 ! fpsdisplaysink text-overlay=0 video-sink=fakesink sync=0
Hi, DaneLLL.
Yes, The fps was printed.
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstFakeSink:fakesink0: sync = false
/GstPipeline:pipeline0/GstV4l2Src:v4l2src0.GstPad:src: caps = video/x-raw, format=(string)UYVY, width=(int)1920, height=(int)1080, framerate=(fraction)72/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw, format=(string)UYVY, width=(int)1920, height=(int)1080, framerate=(fraction)72/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0.GstGhostPad:sink.GstProxyPad:proxypad0: caps = video/x-raw, format=(string)UYVY, width=(int)1920, height=(int)1080, framerate=(fraction)72/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstFakeSink:fakesink0.GstPad:sink: caps = video/x-raw, format=(string)UYVY, width=(int)1920, height=(int)1080, framerate=(fraction)72/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0.GstGhostPad:sink: caps = video/x-raw, format=(string)UYVY, width=(int)1920, height=(int)1080, framerate=(fraction)72/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw, format=(string)UYVY, width=(int)1920, height=(int)1080, framerate=(fraction)72/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 15, dropped: 0, current: 29.22, average: 29.22
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 30, dropped: 0, current: 29.44, average: 29.33
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 45, dropped: 0, current: 29.44, average: 29.37
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 60, dropped: 0, current: 29.44, average: 29.38
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 75, dropped: 0, current: 29.44, average: 29.40
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 90, dropped: 0, current: 29.44, average: 29.40
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 105, dropped: 0, current: 29.44, average: 29.41
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 120, dropped: 0, current: 29.44, average: 29.41
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 135, dropped: 0, current: 29.44, average: 29.41
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 150, dropped: 0, current: 29.44, average: 29.42
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 165, dropped: 0, current: 29.44, average: 29.42
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 180, dropped: 0, current: 29.44, average: 29.42
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 195, dropped: 0, current: 29.45, average: 29.42
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 210, dropped: 0, current: 29.44, average: 29.42
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 225, dropped: 0, current: 29.44, average: 29.42
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 240, dropped: 0, current: 29.44, average: 29.43
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 255, dropped: 0, current: 29.45, average: 29.43
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 270, dropped: 0, current: 29.45, average: 29.43
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 285, dropped: 0, current: 29.44, average: 29.43
Execution ended after 0:00:10.392989599
Freeing pipeline …
Please modify [source0] in source1_usb_dec_infer_resnet_int8.txt:
camera-width=1920
camera-height=1080
camera-fps-n=72
camera-fps-d=1
And run it in deepstream-app. The setting fits the source and should work.
Hi, DaneLLL
After ‘apt upgrade’, the L4T version was upgraded, and the camera driver did not work. So I flash it again.
And without performing any of the various gst-launch-1.0 related commands mentioned above,
I just changed the resolution of the source1_usb~ file to 1080p as you told and executed it.
Then, there was no camera available error and it worked well.
However, there is still ‘No cameras available’ error when i run the Source1_csi~ file.
Can you tell me the difference between these two files?
I wonder why it should not be set with a csi camera, but only when it is set to camerav4l2.
Additionally, if there is a way to reverse the camera output left and right on this example code, please let me know.
Regards
For CSI cameras the formats are generally raw formats such as RG10. These kinds of cameras are launched through nvarguscamerasrc. Your camera is a YUV sensor and it should be launched through v4l2src.
Hi, DaneLLL
So, the source1_csi~ sample code was written in anticipation of the camera using the RG10 sensor, but my camera is a YUV sensor, so I can’t use the csi example, Right?
By the way is there any way to reverse the camera output left and right on this example code?
Yes.
You can link to nvvideoconvert plugin and set the property:
  flip-method         : video flip methods
                        flags: readable, writable, controllable
                        Enum "GstNvDsVideoFlipMethod" Default: 0, "none"
                           (0): none             - Identity (no rotation)
                           (1): counterclockwise - Rotate counter-clockwise 90 d
egrees
                           (2): rotate-180       - Rotate 180 degrees
                           (3): clockwise        - Rotate clockwise 90 degrees
                           (4): horizontal-flip  - Flip horizontally
                           (5): upper-right-diagonal - Flip across upper right/l
ower left diagonal
                           (6): vertical-flip    - Flip vertically
                           (7): upper-left-diagonal - Flip across upper left/low
er right diagonal
