Here we go:
neil@jetson:~$ v4l2-ctl --list-formats
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: 'MJPG' (compressed)
Index : 1
Pixel Format: 'YUYV'
neil@jetson:~$ gst-device-monitor-1.0 Video/Source
Probing devices...
Device found:
name : H264 USB Camera
class : Video/Source
caps : video/x-raw, format=(string)YUY2, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)5/1;
video/x-raw, format=(string)YUY2, width=(int)1280, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)10/1;
video/x-raw, format=(string)YUY2, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
video/x-raw, format=(string)YUY2, width=(int)640, height=(int)360, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
video/x-raw, format=(string)YUY2, width=(int)320, height=(int)240, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
video/x-raw, format=(string)YUY2, width=(int)320, height=(int)180, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
image/jpeg, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
image/jpeg, width=(int)1280, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
image/jpeg, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
image/jpeg, width=(int)640, height=(int)360, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
image/jpeg, width=(int)320, height=(int)240, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
image/jpeg, width=(int)320, height=(int)180, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
properties:
udev-probed = true
device.bus_path = platform-70090000.xusb-usb-0:2.1:1.0
sysfs.path = /sys/devices/70090000.xusb/usb1/1-2/1-2.1/1-2.1:1.0/video4linux/video0
device.bus = usb
device.subsystem = video4linux
device.vendor.id = 32e4
device.vendor.name = "USB\\x20Camera\\x20Manufacture"
device.product.id = 9422
device.product.name = "H264\ USB\ Camera"
device.serial = USB_Camera_Manufacture_H264_USB_Camera_2020052801
device.capabilities = :capture:
device.api = v4l2
device.path = /dev/video0
v4l2.device.driver = uvcvideo
v4l2.device.card = "H264\ USB\ Camera"
v4l2.device.bus_info = usb-70090000.xusb-2.1
v4l2.device.version = 264588 (0x0004098c)
v4l2.device.capabilities = 2216689665 (0x84200001)
v4l2.device.device_caps = 69206017 (0x04200001)
gst-launch-1.0 v4l2src ! ...
Device found:
caps : video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, width=(int)1280, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, width=(int)640, height=(int)360, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, width=(int)320, height=(int)240, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, width=(int)320, height=(int)180, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
properties:
udev-probed = true
sysfs.path = /sys/devices/70090000.xusb/usb1/1-2/1-2.1/1-2.1:1.0/video4linux/video1
device.bus = usb
device.api = v4l2
device.path = /dev/video1
gst-launch-1.0 v4l2src device=/dev/video1 ! ...
neil@jetson:~$
