I execute the following command:
echo 2 > /sys/kernel/debug/camrtc/log-level
AcquireBuffer will appear 100%
May 13 12:02:03 caper-desktop kernel: [ 405.079094] rtcpu_trace_isp_event event id 20 cannot be found
May 13 12:02:03 caper-desktop kernel: [ 405.085009] rtcpu_trace_isp_event event id 20 cannot be found
May 13 12:02:03 caper-desktop kernel: [ 405.090803] rtcpu_trace_isp_event event id 20 cannot be found
May 13 12:02:03 caper-desktop kernel: [ 405.096306] rtcpu_trace_isp_event event id 20 cannot be found
May 13 12:02:03 caper-desktop nvargus-daemon[15336]: message repeated 3 times: [ (Argus) Error Timeout: (propagating from src/api/BufferOutputStreamImpl.cpp, function acquireBuffer(), line 265)]
May 13 12:02:03 caper-desktop nvargus-daemon: W/ libnvphs:socket: Warning (NvPHSSendThroughputHints): too many throughput hints given: buffer full, hints not sent!
May 13 12:02:03 caper-desktop nvargus-daemon: E/ libnvphs: Error: NvPHSSendThroughputHints[usecase=camera, hint=CpuFloorVmin, value=0, timeout_ms=1000]: queue_or_send() failed
May 13 12:02:03 caper-desktop nvargus-daemon[15336]: SCF: Error BadValue: NvPHSSendThroughputHints (in src/common/CameraPowerHint.cpp, function sendCameraPowerHint(), line 56)
May 13 12:02:03 caper-desktop nvargus-daemon: E/ libnvphs: Error: NvPHSSendThroughputHints[usecase=camera, hint=CameraFrameTimestamp, value=750398572, timeout_ms=1000]: queue_or_send() failed
May 13 12:02:03 caper-desktop kernel: [ 405.102213] rtcpu_trace_isp_event event id 20 cannot be found
May 13 12:02:03 caper-desktop nvargus-daemon: E/ libnvphs: Error: NvPHSSendThroughputHints[usecase=camera, hint=FramerateTarget, value=30, timeout_ms=1000]: queue_or_send() failed
May 13 12:02:03 caper-desktop nvargus-daemon[15336]: message repeated 2 times: [ SCF: Error BadValue: NvPHSSendThroughputHints (in src/common/CameraPowerHint.cpp, function sendCameraPowerHint(), line 56)]
May 13 12:02:03 caper-desktop nvargus-daemon: E/ libnvphs: Error: NvPHSSendThroughputHints[usecase=camera, hint=CameraFrameTimestamp, value=750660722, timeout_ms=1000]: queue_or_send() failed
May 13 12:02:03 caper-desktop kernel: [ 405.107960] rtcpu_trace_isp_event event id 20 cannot be found
May 13 12:02:03 caper-desktop nvargus-daemon: E/ libnvphs: Error: NvPHSSendThroughputHints[usecase=camera, hint=CameraFrameTimestamp, value=751053938, timeout_ms=1000]: queue_or_send() failed
May 13 12:02:03 caper-desktop kernel: [ 405.113913] rtcpu_trace_isp_event event id 20 cannot be found
May 13 12:02:03 caper-desktop nvargus-daemon: E/ libnvphs: Error: NvPHSSendThroughputHints[usecase=camera, hint=CameraFrameTimestamp, value=751447160, timeout_ms=1000]: queue_or_send() failed
