Dear Everyone,
HW: Xavier + GMSL2/Leopard IMX390 or FPDLINK-III/Leopard AR0231
SW: JetPack 4.5 + GMSL/FPDLINK driver (with Virtual Channel)
Bug:
Can not open multi cameras, and get an error of gst message :“/GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0: TIMEOUT”
We have tried below and works fine.
- If we change the software to JetPack4.4 or 4.3, all cameras preview works fine with gst command at the same time.
- if we use /usr/src/jetson_multimedia_api/samples/13_multi_camera to preview all the two or four cameras, the four cameras preivew works fine at the same time.
Command and Gst log:
nvidia@xavier:~$ gst-launch-1.0 --gst-debug-level=4 nvarguscamerasrc sensor-id= 0 ! 'video/x-raw(memory:NVMM), width=(int)1928,height=(int)1208' ! nvvidconv flip-method=0 ! 'video/x-raw, format=(string)I420' ! xvimagesink -e
Above camera /dev/video0 works fine, if we open another terminal and open '/dev/video1' the video0 preview will be timeout and terminated but video1 preview fine.
nvidia@xavier:~$ gst-launch-1.0 --gst-debug-level=4 nvarguscamerasrc sensor-id= 1 ! 'video/x-raw(memory:NVMM), width=(int)1928,height=(int)1208' ! nvvidconv flip-method=0 ! 'video/x-raw, format=(string)I420' ! xvimagesink -e
gst-launch-1.0 --gst-debug-level=4 …
0:00:00.001575198 8903 0x5566cec0c0 INFO GST_INIT gstmessage.c:127:_priv_gst_message_initialize: init messages
0:00:00.003312576 8903 0x5566cec0c0 INFO GST_INIT gstcontext.c:84:_priv_gst_context_initialize: init contexts
0:00:00.004055918 8903 0x5566cec0c0 INFO GST_PLUGIN_LOADING gstplugin.c:317:_priv_gst_plugin_initialize: registering 0 static plugins
0:00:00.004305395 8903 0x5566cec0c0 INFO GST_PLUGIN_LOADING gstplugin.c:225:gst_plugin_register_static: registered static plugin "staticelements"
0:00:00.004340084 8903 0x5566cec0c0 INFO GST_PLUGIN_LOADING gstplugin.c:227:gst_plugin_register_static: added static plugin "staticelements", result: 1
0:00:00.004421974 8903 0x5566cec0c0 INFO GST_REGISTRY gstregistry.c:1727:ensure_current_registry: reading registry cache: /home/nvidia/.cache/gstreamer-1.0/registry.aarch64.bin
0:00:00.061083167 8903 0x5566cec0c0 INFO GST_REGISTRY gstregistrybinary.c:621:priv_gst_registry_binary_read_cache: loaded /home/nvidia/.cache/gstreamer-1.0/registry.aarch64.bin in 0.056562 seconds
0:00:00.061241378 8903 0x5566cec0c0 INFO GST_REGISTRY gstregistry.c:1583:scan_and_update_registry: Validating plugins from registry cache: /home/nvidia/.cache/gstreamer-1.0/registry.aarch64.bin
0:00:00.075445460 8903 0x5566cec0c0 INFO GST_REGISTRY gstregistry.c:1332:gst_registry_scan_path_level:<registry0> cached info for /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstvideo4linux2.so is stale
0:00:00.151494376 8903 0x5566cec0c0 INFO GST_REGISTRY gstregistry.c:1694:scan_and_update_registry: Registry cache changed. Writing new registry cache
0:00:00.151565833 8903 0x5566cec0c0 INFO GST_REGISTRY gstregistrybinary.c:369:priv_gst_registry_binary_write_cache: Building binary registry cache image
0:00:00.207271990 8903 0x5566cec0c0 INFO GST_REGISTRY gstregistrybinary.c:401:priv_gst_registry_binary_write_cache: Writing binary registry cache
0:00:00.288047876 8903 0x5566cec0c0 INFO GST_REGISTRY gstregistrybinary.c:262:gst_registry_binary_cache_finish: Wrote binary registry cache
0:00:00.288105894 8903 0x5566cec0c0 INFO GST_REGISTRY gstregistry.c:1703:scan_and_update_registry: Registry cache written successfully
0:00:00.288129446 8903 0x5566cec0c0 INFO GST_REGISTRY gstregistry.c:1762:ensure_current_registry: registry reading and updating done, result = 1
0:00:00.288148262 8903 0x5566cec0c0 INFO GST_INIT gst.c:807:init_post: GLib runtime version: 2.56.4
0:00:00.288246952 8903 0x5566cec0c0 INFO GST_INIT gst.c:809:init_post: GLib headers version: 2.56.4
0:00:00.288262953 8903 0x5566cec0c0 INFO GST_INIT gst.c:810:init_post: initialized GStreamer successfully
0:00:00.288433452 8903 0x5566cec0c0 INFO GST_PIPELINE gstparse.c:337:gst_parse_launch_full: parsing pipeline description 'nvarguscamerasrc sensor-id= 0 ! video/x-raw(memory:NVMM),\ width=(int)1928,height=(int)1208 ! nvvidconv flip-method=0 ! video/x-raw,\ format=(string)I420 ! xvimagesink '
0:00:00.343196583 8903 0x5566cec0c0 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvarguscamerasrc.so" loaded
0:00:00.343259720 8903 0x5566cec0c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element "nvarguscamerasrc"
0:00:00.343798834 8903 0x5566cec0c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseSrc@0x5567036ce0> adding pad 'src'
0:00:00.346827885 8903 0x5566cec0c0 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvidconv.so" loaded
0:00:00.346871341 8903 0x5566cec0c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element "nvvidconv"
0:00:00.347252981 8903 0x5566cec0c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseTransform@0x5566e38cd0> adding pad 'sink'
0:00:00.347319830 8903 0x5566cec0c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseTransform@0x5566e38cd0> adding pad 'src'
0:00:00.350007722 8903 0x5566cec0c0 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstxvimagesink.so" loaded
0:00:00.350047690 8903 0x5566cec0c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element "xvimagesink"
0:00:00.350411697 8903 0x5566cec0c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseSink@0x5567156b80> adding pad 'sink'
0:00:00.350463570 8903 0x5566cec0c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element "pipeline"
0:00:00.350656470 8903 0x5566cec0c0 INFO GST_PIPELINE grammar.y:652:gst_parse_perform_link: linking some pad of GstNvArgusCameraSrc named nvarguscamerasrc0 to some pad of Gstnvvconv named nvvconv0 (0/0) with caps "video/x-raw(memory:NVMM), width=(int)1928, height=(int)1208"
0:00:00.353615503 8903 0x5566cec0c0 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstcoreelements.so" loaded
0:00:00.353647023 8903 0x5566cec0c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element "capsfilter"
0:00:00.353783154 8903 0x5566cec0c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseTransform@0x556715a2e0> adding pad 'sink'
0:00:00.353821491 8903 0x5566cec0c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseTransform@0x556715a2e0> adding pad 'src'
0:00:00.353853555 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2089:gst_bin_get_state_func:<pipeline0> getting state
0:00:00.353921525 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<capsfilter0> completed state change to NULL
0:00:00.353956085 8903 0x5566cec0c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.353990102 8903 0x5566cec0c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element nvarguscamerasrc0:(any) to element capsfilter0:sink
0:00:00.354028567 8903 0x5566cec0c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad capsfilter0:sink
0:00:00.354048919 8903 0x5566cec0c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: nvarguscamerasrc0 and capsfilter0 in same bin, no need for ghost pads
0:00:00.354080984 8903 0x5566cec0c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link nvarguscamerasrc0:src and capsfilter0:sink
0:00:00.354112440 8903 0x5566cec0c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<capsfilter0:src> pad has no peer
0:00:00.354153657 8903 0x5566cec0c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked nvarguscamerasrc0:src and capsfilter0:sink, successful
0:00:00.354170361 8903 0x5566cec0c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.354186714 8903 0x5566cec0c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<nvarguscamerasrc0:src> Received event on flushing pad. Discarding
0:00:00.354216186 8903 0x5566cec0c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element capsfilter0:src to element nvvconv0:(any)
0:00:00.354234779 8903 0x5566cec0c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad capsfilter0:src
0:00:00.354255675 8903 0x5566cec0c0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link capsfilter0:src and nvvconv0:sink
0:00:00.354314716 8903 0x5566cec0c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<nvvconv0:src> pad has no peer
0:00:00.354518272 8903 0x5566cec0c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: capsfilter0 and nvvconv0 in same bin, no need for ghost pads
0:00:00.354548193 8903 0x5566cec0c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link capsfilter0:src and nvvconv0:sink
0:00:00.354583873 8903 0x5566cec0c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<nvvconv0:src> pad has no peer
0:00:00.354716868 8903 0x5566cec0c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked capsfilter0:src and nvvconv0:sink, successful
0:00:00.354750117 8903 0x5566cec0c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.354769413 8903 0x5566cec0c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<capsfilter0:src> Received event on flushing pad. Discarding
0:00:00.354830086 8903 0x5566cec0c0 INFO GST_PIPELINE grammar.y:652:gst_parse_perform_link: linking some pad of Gstnvvconv named nvvconv0 to some pad of GstXvImageSink named xvimagesink0 (0/0) with caps "video/x-raw, format=(string)I420"
0:00:00.354859015 8903 0x5566cec0c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element "capsfilter"
0:00:00.354908264 8903 0x5566cec0c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseTransform@0x556715a620> adding pad 'sink'
0:00:00.354943656 8903 0x5566cec0c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseTransform@0x556715a620> adding pad 'src'
0:00:00.354973609 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2089:gst_bin_get_state_func:<pipeline0> getting state
0:00:00.355015274 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<capsfilter1> completed state change to NULL
0:00:00.355039274 8903 0x5566cec0c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.355063403 8903 0x5566cec0c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element nvvconv0:(any) to element capsfilter1:sink
0:00:00.355088203 8903 0x5566cec0c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad capsfilter1:sink
0:00:00.355108363 8903 0x5566cec0c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: nvvconv0 and capsfilter1 in same bin, no need for ghost pads
0:00:00.355135340 8903 0x5566cec0c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link nvvconv0:src and capsfilter1:sink
0:00:00.355240622 8903 0x5566cec0c0 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:<capsfilter1:src> pad has no peer
0:00:00.355274639 8903 0x5566cec0c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked nvvconv0:src and capsfilter1:sink, successful
0:00:00.355287791 8903 0x5566cec0c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.355300591 8903 0x5566cec0c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<nvvconv0:src> Received event on flushing pad. Discarding
0:00:00.355325392 8903 0x5566cec0c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element capsfilter1:src to element xvimagesink0:(any)
0:00:00.355356752 8903 0x5566cec0c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad capsfilter1:src
0:00:00.355374961 8903 0x5566cec0c0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link capsfilter1:src and xvimagesink0:sink
0:00:00.355536564 8903 0x5566cec0c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: capsfilter1 and xvimagesink0 in same bin, no need for ghost pads
0:00:00.355560596 8903 0x5566cec0c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link capsfilter1:src and xvimagesink0:sink
0:00:00.355670102 8903 0x5566cec0c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked capsfilter1:src and xvimagesink0:sink, successful
0:00:00.355729719 8903 0x5566cec0c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.355744600 8903 0x5566cec0c0 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<capsfilter1:src> Received event on flushing pad. Discarding
Setting pipeline to PAUSED ...
0:00:00.355866618 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<xvimagesink0> current NULL pending VOID_PENDING, desired next READY
0:00:00.358474380 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<xvimagesink0> completed state change to READY
0:00:00.358519149 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<xvimagesink0> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.358568878 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<pipeline0> child 'xvimagesink0' changed state to 2(READY) successfully
0:00:00.358606223 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<capsfilter1> current NULL pending VOID_PENDING, desired next READY
0:00:00.358627791 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<capsfilter1> completed state change to READY
0:00:00.358648527 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<capsfilter1> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.358676176 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<pipeline0> child 'capsfilter1' changed state to 2(READY) successfully
0:00:00.358705552 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<nvvconv0> current NULL pending VOID_PENDING, desired next READY
0:00:00.358747217 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<nvvconv0> completed state change to READY
0:00:00.358786418 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<nvvconv0> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.358820179 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<pipeline0> child 'nvvconv0' changed state to 2(READY) successfully
0:00:00.358878868 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<capsfilter0> current NULL pending VOID_PENDING, desired next READY
0:00:00.358900532 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<capsfilter0> completed state change to READY
0:00:00.358926133 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<capsfilter0> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.358962901 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<pipeline0> child 'capsfilter0' changed state to 2(READY) successfully
0:00:00.358991158 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<nvarguscamerasrc0> current NULL pending VOID_PENDING, desired next READY
0:00:00.359014262 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<nvarguscamerasrc0> completed state change to READY
0:00:00.359035639 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<nvarguscamerasrc0> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.359067575 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<pipeline0> child 'nvarguscamerasrc0' changed state to 2(READY) successfully
0:00:00.359104440 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2651:gst_element_continue_state:<pipeline0> committing state from NULL to READY, pending PAUSED, next PAUSED
0:00:00.359126969 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<pipeline0> notifying about state-changed NULL to READY (PAUSED pending)
0:00:00.359236603 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2658:gst_element_continue_state:<pipeline0> continue state change READY to PAUSED, final PAUSED
0:00:00.359293212 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<xvimagesink0> current READY pending VOID_PENDING, desired next PAUSED
0:00:00.359355645 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2960:gst_bin_change_state_func:<pipeline0> child 'xvimagesink0' is changing state asynchronously to PAUSED
0:00:00.359406526 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<capsfilter1> current READY pending VOID_PENDING, desired next PAUSED
0:00:00.359446143 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<capsfilter1> completed state change to PAUSED
0:00:00.359485759 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<capsfilter1> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.359518912 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<pipeline0> child 'capsfilter1' changed state to 3(PAUSED) successfully
0:00:00.359546337 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<nvvconv0> current READY pending VOID_PENDING, desired next PAUSED
0:00:00.359968937 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<nvvconv0> completed state change to PAUSED
0:00:00.360002377 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<nvvconv0> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.360031338 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<pipeline0> child 'nvvconv0' changed state to 3(PAUSED) successfully
0:00:00.360059434 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<capsfilter0> current READY pending VOID_PENDING, desired next PAUSED
0:00:00.360090635 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<capsfilter0> completed state change to PAUSED
0:00:00.360131980 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<capsfilter0> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.360160012 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<pipeline0> child 'capsfilter0' changed state to 3(PAUSED) successfully
0:00:00.360200877 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<nvarguscamerasrc0> current READY pending VOID_PENDING, desired next PAUSED
0:00:00.360266318 8903 0x5566cec0c0 INFO basesrc gstbasesrc.c:1358:gst_base_src_do_seek:<nvarguscamerasrc0> seeking: time segment start=0:00:00.000000000, offset=0:00:00.000000000, stop=99:99:99.999999999, rate=1.000000, applied_rate=1.000000, flags=0x00, time=0:00:00.000000000, base=0:00:00.000000000, position 0:00:00.000000000, duration 99:99:99.999999999
0:00:00.360339440 8903 0x5566cec0c0 INFO task gsttask.c:457:gst_task_set_lock: setting stream lock 0x55671501e0 on task 0x5567178050
0:00:00.360364048 8903 0x5566cec0c0 INFO GST_PADS gstpad.c:6154:gst_pad_start_task:<nvarguscamerasrc0:src> created task 0x5567178050
0:00:00.360495155 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<nvarguscamerasrc0> completed state change to PAUSED
0:00:00.360527475 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<nvarguscamerasrc0> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.360555796 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2997:gst_bin_change_state_func:<pipeline0> child 'nvarguscamerasrc0' changed state to 3(PAUSED) successfully without preroll
0:00:00.360581909 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<pipeline0> completed state change to PAUSED
0:00:00.360616309 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<pipeline0> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
0:00:00.361484902 8903 0x5566cec0c0 INFO GST_EVENT gstevent.c:1388:gst_event_new_latency: creating latency event 0:00:00.000000000
0:00:00.361554087 8903 0x5566cec0c0 INFO bin gstbin.c:2783:gst_bin_do_latency_func:<pipeline0> configured latency of 0:00:00.000000000
0:00:00.361597000 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<xvimagesink0> current READY pending PAUSED, desired next PLAYING
0:00:00.361618504 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2960:gst_bin_change_state_func:<pipeline0> child 'xvimagesink0' is changing state asynchronously to PLAYING
0:00:00.361642537 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<capsfilter1> current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.361673513 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<capsfilter1> completed state change to PLAYING
0:00:00.361692682 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<capsfilter1> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.361722154 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<pipeline0> child 'capsfilter1' changed state to 4(PLAYING) successfully
0:00:00.361747595 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<nvvconv0> current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.361768427 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<nvvconv0> completed state change to PLAYING
0:00:00.361786988 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<nvvconv0> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.361812844 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<pipeline0> child 'nvvconv0' changed state to 4(PLAYING) successfully
0:00:00.361837645 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<capsfilter0> current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.361857613 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<capsfilter0> completed state change to PLAYING
0:00:00.361875245 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<capsfilter0> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.361929902 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<pipeline0> child 'capsfilter0' changed state to 4(PLAYING) successfully
0:00:00.361962383 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<nvarguscamerasrc0> completed state change to PLAYING
0:00:00.362001776 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<nvarguscamerasrc0> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.362027184 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<pipeline0> child 'nvarguscamerasrc0' changed state to 4(PLAYING) successfully
New clock: GstSystemClock
0:00:00.362416184 8903 0x5567152140 INFO GST_ELEMENT_PADS gstelement.c:917:gst_element_get_static_pad: no such pad 'sink' in element "nvarguscamerasrc0"
0:00:00.362500345 8903 0x5567152140 FIXME default gstutils.c:3981:gst_pad_create_stream_id_internal:<nvarguscamerasrc0:src> Creating random stream-id, consider implementing a deterministic way of creating a stream-id
0:00:00.363873204 8903 0x5567152140 INFO GST_EVENT gstevent.c:814:gst_event_new_caps: creating caps event video/x-raw(memory:NVMM), width=(int)1928, height=(int)1208, format=(string)NV12, framerate=(fraction)30/1
0:00:00.363969334 8903 0x5567152140 INFO basetransform gstbasetransform.c:1308:gst_base_transform_setcaps:<capsfilter0> reuse caps
0:00:00.364021143 8903 0x5567152140 INFO GST_EVENT gstevent.c:814:gst_event_new_caps: creating caps event video/x-raw(memory:NVMM), width=(int)1928, height=(int)1208, format=(string)NV12, framerate=(fraction)30/1
0:00:00.364305820 8903 0x5567152140 INFO GST_EVENT gstevent.c:814:gst_event_new_caps: creating caps event video/x-raw, width=(int)1928, height=(int)1208, framerate=(fraction)30/1, format=(string)I420
0:00:00.364373373 8903 0x5567152140 INFO basetransform gstbasetransform.c:1308:gst_base_transform_setcaps:<capsfilter1> reuse caps
0:00:00.364603298 8903 0x5567152140 INFO GST_EVENT gstevent.c:814:gst_event_new_caps: creating caps event video/x-raw, width=(int)1928, height=(int)1208, framerate=(fraction)30/1, format=(string)I420
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.122018, max 251.188705; Exposure Range min 110000, max 166577000;
0:00:01.034893346 8903 0x7f6c0035e0 INFO default gstnvarguscamerasrc.cpp:774:execute:<nvarguscamerasrc0> Requested resolution W = 1928 H = 1208 not supported by Sensor.
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 0
Output Stream W = 1920 H = 1080
seconds to Run = 0
Frame Rate = 29.999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
0:00:02.878769845 8903 0x5567152140 INFO GST_EVENT gstevent.c:895:gst_event_new_segment: creating segment event time segment start=0:00:00.000000000, offset=0:00:00.000000000, stop=99:99:99.999999999, rate=1.000000, applied_rate=1.000000, flags=0x00, time=0:00:00.000000000, base=0:00:00.000000000, position 0:00:00.000000000, duration 99:99:99.999999999
0:00:02.878993689 8903 0x5567152140 INFO basesrc gstbasesrc.c:2945:gst_base_src_loop:<nvarguscamerasrc0> marking pending DISCONT
0:00:02.911423901 8903 0x5567152140 INFO GST_STATES gstbin.c:3433:bin_handle_async_done:<pipeline0> setting state from PAUSED to PAUSED, pending PLAYING
0:00:02.911480254 8903 0x5567152140 INFO GST_STATES gstbin.c:3453:bin_handle_async_done:<pipeline0> continue state change, pending PLAYING
0:00:02.911743971 8903 0x7f6c003630 INFO GST_STATES gstbin.c:3250:gst_bin_continue_func:<pipeline0> continue state change PAUSED to PLAYING, final PLAYING
0:00:02.911948935 8903 0x7f6c003630 INFO GST_EVENT gstevent.c:1388:gst_event_new_latency: creating latency event 0:00:00.000000000
0:00:02.912051657 8903 0x7f6c003630 INFO bin gstbin.c:2783:gst_bin_do_latency_func:<pipeline0> configured latency of 0:00:00.000000000
0:00:02.912122378 8903 0x7f6c003630 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<xvimagesink0> current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:02.912155051 8903 0x7f6c003630 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<xvimagesink0> completed state change to PLAYING
0:00:02.912190923 8903 0x7f6c003630 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<xvimagesink0> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:02.912247660 8903 0x7f6c003630 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<pipeline0> child 'xvimagesink0' changed state to 4(PLAYING) successfully
0:00:02.912283021 8903 0x7f6c003630 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<capsfilter1> current PLAYING pending VOID_PENDING, desired next PLAYING
0:00:02.912310797 8903 0x7f6c003630 INFO GST_STATES gstbin.c:2623:gst_bin_element_set_state:<capsfilter1> skipping transition from PLAYING to PLAYING
0:00:02.912337230 8903 0x7f6c003630 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<pipeline0> child 'capsfilter1' changed state to 4(PLAYING) successfully
0:00:02.912372079 8903 0x7f6c003630 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<nvvconv0> current PLAYING pending VOID_PENDING, desired next PLAYING
0:00:02.912392431 8903 0x7f6c003630 INFO GST_STATES gstbin.c:2623:gst_bin_element_set_state:<nvvconv0> skipping transition from PLAYING to PLAYING
0:00:02.912436592 8903 0x7f6c003630 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<pipeline0> child 'nvvconv0' changed state to 4(PLAYING) successfully
0:00:02.912464464 8903 0x7f6c003630 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<capsfilter0> current PLAYING pending VOID_PENDING, desired next PLAYING
0:00:02.912505297 8903 0x7f6c003630 INFO GST_STATES gstbin.c:2623:gst_bin_element_set_state:<capsfilter0> skipping transition from PLAYING to PLAYING
0:00:02.912523697 8903 0x7f6c003630 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<pipeline0> child 'capsfilter0' changed state to 4(PLAYING) successfully
0:00:02.912561874 8903 0x7f6c003630 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<nvarguscamerasrc0> current PLAYING pending VOID_PENDING, desired next PLAYING
0:00:02.912587155 8903 0x7f6c003630 INFO GST_STATES gstbin.c:2623:gst_bin_element_set_state:<nvarguscamerasrc0> skipping transition from PLAYING to PLAYING
0:00:02.912620275 8903 0x7f6c003630 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<pipeline0> child 'nvarguscamerasrc0' changed state to 4(PLAYING) successfully
0:00:02.912643924 8903 0x7f6c003630 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<pipeline0> completed state change to PLAYING
0:00:02.912674132 8903 0x7f6c003630 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<pipeline0> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
ERROR: from element /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0: TIMEOUT
Additional debug info:
Argus Error Status
EOS on shutdown enabled -- waiting for EOS after Error
Waiting for EOS...
0:00:13.125244030 8903 0x5567152140 INFO basesrc gstbasesrc.c:2839:gst_base_src_loop:<nvarguscamerasrc0> pausing after gst_base_src_get_range() = eos
0:00:13.125519554 8903 0x5567152140 INFO task gsttask.c:316:gst_task_func:<nvarguscamerasrc0:src> Task going to paused
Got EOS from element "pipeline0".
EOS received - stopping pipeline...
Execution ended after 0:00:12.763831256
0:00:13.126019755 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<xvimagesink0> current PLAYING pending VOID_PENDING, desired next PAUSED
0:00:13.126090444 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<xvimagesink0> completed state change to PAUSED
0:00:13.126148781 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<xvimagesink0> notifying about state-changed PLAYING to PAUSED (VOID_PENDING pending)
0:00:13.126233551 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<pipeline0> child 'xvimagesink0' changed state to 3(PAUSED) successfully
0:00:13.126305776 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<capsfilter1> current PLAYING pending VOID_PENDING, desired next PAUSED
0:00:13.126359377 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<capsfilter1> completed state change to PAUSED
0:00:13.126453395 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<capsfilter1> notifying about state-changed PLAYING to PAUSED (VOID_PENDING pending)
0:00:13.126550100 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<pipeline0> child 'capsfilter1' changed state to 3(PAUSED) successfully
0:00:13.126647926 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<nvvconv0> current PLAYING pending VOID_PENDING, desired next PAUSED
0:00:13.126704311 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<nvvconv0> completed state change to PAUSED
0:00:13.126755832 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<nvvconv0> notifying about state-changed PLAYING to PAUSED (VOID_PENDING pending)
0:00:13.126818201 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<pipeline0> child 'nvvconv0' changed state to 3(PAUSED) successfully
0:00:13.126888954 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<capsfilter0> current PLAYING pending VOID_PENDING, desired next PAUSED
0:00:13.126941531 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<capsfilter0> completed state change to PAUSED
0:00:13.126992796 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<capsfilter0> notifying about state-changed PLAYING to PAUSED (VOID_PENDING pending)
0:00:13.127072573 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<pipeline0> child 'capsfilter0' changed state to 3(PAUSED) successfully
0:00:13.127132447 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<nvarguscamerasrc0> current PLAYING pending VOID_PENDING, desired next PAUSED
0:00:13.127185407 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<nvarguscamerasrc0> completed state change to PAUSED
0:00:13.127269889 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<nvarguscamerasrc0> notifying about state-changed PLAYING to PAUSED (VOID_PENDING pending)
0:00:13.127334786 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2997:gst_bin_change_state_func:<pipeline0> child 'nvarguscamerasrc0' changed state to 3(PAUSED) successfully without preroll
0:00:13.127429444 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<pipeline0> completed state change to PAUSED
0:00:13.127480357 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<pipeline0> notifying about state-changed PLAYING to PAUSED (VOID_PENDING pending)
0:00:13.127564422 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2089:gst_bin_get_state_func:<pipeline0> getting state
Setting pipeline to READY ...
0:00:13.127775882 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<xvimagesink0> current PAUSED pending VOID_PENDING, desired next READY
0:00:13.127876171 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<xvimagesink0> completed state change to READY
0:00:13.127937293 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<xvimagesink0> notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:13.128032878 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<pipeline0> child 'xvimagesink0' changed state to 2(READY) successfully
0:00:13.128101423 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<capsfilter1> current PAUSED pending VOID_PENDING, desired next READY
0:00:13.128194321 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<capsfilter1> completed state change to READY
0:00:13.128261330 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<capsfilter1> notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:13.128325139 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<pipeline0> child 'capsfilter1' changed state to 2(READY) successfully
0:00:13.128388084 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<nvvconv0> current PAUSED pending VOID_PENDING, desired next READY
0:00:13.129736652 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<nvvconv0> completed state change to READY
0:00:13.129858990 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<nvvconv0> notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:13.129991536 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<pipeline0> child 'nvvconv0' changed state to 2(READY) successfully
0:00:13.130076658 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<capsfilter0> current PAUSED pending VOID_PENDING, desired next READY
0:00:13.130194164 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<capsfilter0> completed state change to READY
0:00:13.130254037 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<capsfilter0> notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:13.131529771 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<pipeline0> child 'capsfilter0' changed state to 2(READY) successfully
0:00:13.131651149 8903 0x5567152140 INFO task gsttask.c:318:gst_task_func:<nvarguscamerasrc0:src> Task resume from paused
GST_ARGUS: Cleaning up
0:00:13.944247023 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<nvarguscamerasrc0> completed state change to READY
0:00:13.944313520 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<nvarguscamerasrc0> notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:13.944396209 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<pipeline0> child 'nvarguscamerasrc0' changed state to 2(READY) successfully
0:00:13.944434738 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<pipeline0> completed state change to READY
0:00:13.944469715 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<pipeline0> notifying about state-changed PAUSED to READY (VOID_PENDING pending)
0:00:13.944532852 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2089:gst_bin_get_state_func:<pipeline0> getting state
Setting pipeline to NULL ...
0:00:13.944621813 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<xvimagesink0> current READY pending VOID_PENDING, desired next NULL
0:00:14.001232847 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<xvimagesink0> completed state change to NULL
0:00:14.001449459 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<xvimagesink0> notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:14.001833721 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<pipeline0> child 'xvimagesink0' changed state to 1(NULL) successfully
0:00:14.002725961 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<capsfilter1> current READY pending VOID_PENDING, desired next NULL
0:00:14.003356916 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<capsfilter1> completed state change to NULL
0:00:14.003386868 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<capsfilter1> notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:14.003477622 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<pipeline0> child 'capsfilter1' changed state to 1(NULL) successfully
0:00:14.003515543 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<nvvconv0> current READY pending VOID_PENDING, desired next NULL
0:00:14.003546743 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<nvvconv0> completed state change to NULL
0:00:14.003651257 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<nvvconv0> notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:14.003678905 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<pipeline0> child 'nvvconv0' changed state to 1(NULL) successfully
0:00:14.003776763 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<capsfilter0> current READY pending VOID_PENDING, desired next NULL
0:00:14.003804924 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<capsfilter0> completed state change to NULL
0:00:14.003845116 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<capsfilter0> notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:14.003875197 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<pipeline0> child 'capsfilter0' changed state to 1(NULL) successfully
0:00:14.003899741 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2506:gst_bin_element_set_state:<nvarguscamerasrc0> current READY pending VOID_PENDING, desired next NULL
0:00:14.003941630 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<nvarguscamerasrc0> completed state change to NULL
0:00:14.003961214 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<nvarguscamerasrc0> notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:14.003988799 8903 0x5566cec0c0 INFO GST_STATES gstbin.c:2954:gst_bin_change_state_func:<pipeline0> child 'nvarguscamerasrc0' changed state to 1(NULL) successfully
0:00:14.004099073 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2676:gst_element_continue_state:<pipeline0> completed state change to NULL
0:00:14.004120993 8903 0x5566cec0c0 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<pipeline0> notifying about state-changed READY to NULL (VOID_PENDING pending)
Freeing pipeline ...
0:00:14.004196258 8903 0x5566cec0c0 INFO GST_ELEMENT_PADS gstpad.c:2134:gst_pad_unlink: unlinking nvvconv0:src(0x5567150610) and capsfilter1:sink(0x5567150f50)
0:00:14.004227971 8903 0x5566cec0c0 INFO GST_ELEMENT_PADS gstpad.c:2188:gst_pad_unlink: unlinked nvvconv0:src and capsfilter1:sink
0:00:14.004259492 8903 0x5566cec0c0 INFO GST_ELEMENT_PADS gstpad.c:2134:gst_pad_unlink: unlinking capsfilter1:src(0x55671511a0) and xvimagesink0:sink(0x5567150860)
0:00:14.004285028 8903 0x5566cec0c0 INFO GST_ELEMENT_PADS gstpad.c:2188:gst_pad_unlink: unlinked capsfilter1:src and xvimagesink0:sink
0:00:14.004307716 8903 0x5566cec0c0 INFO GST_PARENTAGE gstbin.c:1801:gst_bin_remove_func:<pipeline0> removed child "capsfilter1"
0:00:14.004347045 8903 0x5566cec0c0 INFO GST_REFCOUNTING gstelement.c:3251:gst_element_dispose:<capsfilter1> 0x556715a620 dispose
0:00:14.004367589 8903 0x5566cec0c0 INFO GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:<capsfilter1> removing pad 'sink'
0:00:14.004402118 8903 0x5566cec0c0 INFO GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:<capsfilter1> removing pad 'src'
0:00:14.004426790 8903 0x5566cec0c0 INFO GST_REFCOUNTING gstelement.c:3297:gst_element_dispose:<capsfilter1> 0x556715a620 parent class dispose
0:00:14.004445351 8903 0x5566cec0c0 INFO GST_REFCOUNTING gstelement.c:3328:gst_element_finalize:<capsfilter1> 0x556715a620 finalize
0:00:14.004465799 8903 0x5566cec0c0 INFO GST_REFCOUNTING gstelement.c:3334:gst_element_finalize:<capsfilter1> 0x556715a620 finalize parent
0:00:14.004498216 8903 0x5566cec0c0 INFO GST_ELEMENT_PADS gstpad.c:2134:gst_pad_unlink: unlinking nvarguscamerasrc0:src(0x5567150170) and capsfilter0:sink(0x5567150ab0)
0:00:14.004524648 8903 0x5566cec0c0 INFO GST_ELEMENT_PADS gstpad.c:2188:gst_pad_unlink: unlinked nvarguscamerasrc0:src and capsfilter0:sink
0:00:14.004554569 8903 0x5566cec0c0 INFO GST_ELEMENT_PADS gstpad.c:2134:gst_pad_unlink: unlinking capsfilter0:src(0x5567150d00) and nvvconv0:sink(0x55671503c0)
0:00:14.004580041 8903 0x5566cec0c0 INFO GST_ELEMENT_PADS gstpad.c:2188:gst_pad_unlink: unlinked capsfilter0:src and nvvconv0:sink
0:00:14.004625834 8903 0x5566cec0c0 INFO GST_PARENTAGE gstbin.c:1801:gst_bin_remove_func:<pipeline0> removed child "capsfilter0"
0:00:14.004668683 8903 0x5566cec0c0 INFO GST_REFCOUNTING gstelement.c:3251:gst_element_dispose:<capsfilter0> 0x556715a2e0 dispose
0:00:14.004683819 8903 0x5566cec0c0 INFO GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:<capsfilter0> removing pad 'sink'
0:00:14.004727884 8903 0x5566cec0c0 INFO GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:<capsfilter0> removing pad 'src'
0:00:14.004750348 8903 0x5566cec0c0 INFO GST_REFCOUNTING gstelement.c:3297:gst_element_dispose:<capsfilter0> 0x556715a2e0 parent class dispose
0:00:14.004779469 8903 0x5566cec0c0 INFO GST_REFCOUNTING gstelement.c:3328:gst_element_finalize:<capsfilter0> 0x556715a2e0 finalize
0:00:14.004794189 8903 0x5566cec0c0 INFO GST_REFCOUNTING gstelement.c:3334:gst_element_finalize:<capsfilter0> 0x556715a2e0 finalize parent
0:00:14.004812525 8903 0x5566cec0c0 INFO GST_PARENTAGE gstbin.c:1801:gst_bin_remove_func:<pipeline0> removed child "xvimagesink0"
0:00:14.004847118 8903 0x5566cec0c0 INFO GST_REFCOUNTING gstelement.c:3251:gst_element_dispose:<xvimagesink0> 0x5567156b80 dispose
0:00:14.004861358 8903 0x5566cec0c0 INFO GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:<xvimagesink0> removing pad 'sink'
0:00:14.004887278 8903 0x5566cec0c0 INFO GST_REFCOUNTING gstelement.c:3297:gst_element_dispose:<xvimagesink0> 0x5567156b80 parent class dispose
0:00:14.004906319 8903 0x5566cec0c0 INFO GST_REFCOUNTING gstelement.c:3328:gst_element_finalize:<xvimagesink0> 0x5567156b80 finalize
0:00:14.004926735 8903 0x5566cec0c0 INFO GST_REFCOUNTING gstelement.c:3334:gst_element_finalize:<xvimagesink0> 0x5567156b80 finalize parent
0:00:14.004946895 8903 0x5566cec0c0 INFO GST_PARENTAGE gstbin.c:1801:gst_bin_remove_func:<pipeline0> removed child "nvvconv0"
0:00:14.004974288 8903 0x5566cec0c0 INFO GST_REFCOUNTING gstelement.c:3251:gst_element_dispose:<nvvconv0> 0x5566e38cd0 dispose
0:00:14.004987504 8903 0x5566cec0c0 INFO GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:<nvvconv0> removing pad 'sink'
0:00:14.005012337 8903 0x5566cec0c0 INFO GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:<nvvconv0> removing pad 'src'
0:00:14.005031601 8903 0x5566cec0c0 INFO GST_REFCOUNTING gstelement.c:3297:gst_element_dispose:<nvvconv0> 0x5566e38cd0 parent class dispose
0:00:14.005052977 8903 0x5566cec0c0 INFO GST_REFCOUNTING gstelement.c:3328:gst_element_finalize:<nvvconv0> 0x5566e38cd0 finalize
0:00:14.005066066 8903 0x5566cec0c0 INFO GST_REFCOUNTING gstelement.c:3334:gst_element_finalize:<nvvconv0> 0x5566e38cd0 finalize parent
0:00:14.005092978 8903 0x5566cec0c0 INFO GST_PARENTAGE gstbin.c:1801:gst_bin_remove_func:<pipeline0> removed child "nvarguscamerasrc0"
0:00:14.005115570 8903 0x5566cec0c0 INFO GST_REFCOUNTING gstelement.c:3251:gst_element_dispose:<nvarguscamerasrc0> 0x5567036ce0 dispose
0:00:14.005134035 8903 0x5566cec0c0 INFO GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:<nvarguscamerasrc0> removing pad 'src'
0:00:14.005154067 8903 0x5566cec0c0 INFO GST_REFCOUNTING gstelement.c:3297:gst_element_dispose:<nvarguscamerasrc0> 0x5567036ce0 parent class dispose
0:00:14.005176147 8903 0x5566cec0c0 INFO GST_REFCOUNTING gstelement.c:3251:gst_element_dispose:<pipeline0> 0x5567158180 dispose
0:00:14.005229236 8903 0x5566cec0c0 INFO GST_REFCOUNTING gstelement.c:3297:gst_element_dispose:<pipeline0> 0x5567158180 parent class dispose
0:00:14.005269877 8903 0x5566cec0c0 INFO GST_REFCOUNTING gstelement.c:3328:gst_element_finalize:<pipeline0> 0x5567158180 finalize
0:00:14.005284693 8903 0x5566cec0c0 INFO GST_REFCOUNTING gstelement.c:3334:gst_element_finalize:<pipeline0> 0x5567158180 finalize parent
0:00:14.005302454 8903 0x5566cec0c0 INFO GST_INIT gst.c:1083:gst_deinit: deinitializing GStreamer
0:00:14.010817078 8903 0x5566cec0c0 INFO GST_INIT gst.c:1231:gst_deinit: deinitialized GStreamer
nvidia@xavier:~$
Can anyone help to check the JetPack4.5?
Thanks so much.
