I have an application using Gstreamer and “D3 Engineering’s” camera modules on a Jetson TX2 development board. Everything was working nicely with Jetpack 4.3 and D3’s BSP v 3.0.1.
But we now have a need for some features that D3 has introduced into their version 4.0 BSP, which works with Jetpack 4.4. After upgrading the board, I now have problems when shutting down the GStreamer pipeline, and it is evident that the problem occurs when Gstreamer tells argus to shut down more than one camera. (This problem does not occur when only one camera is in the pipeline.)
When this occurs, I need to do a “systemctl restart nvargus-daemon” in order to get the cameras to work again.
The D3 guys tell me that this problem is located in something that changed between JetPack 4.3 and JetPack 4.4, rather than anything that changed betwen their old BSP and their new one.
The problem that I am having also exists and map be reproduced with a gstreamer “gst-launch-1.0” command line pipeline that invoke two cameras, like this:
mtrank@JetsonTx2:~$ gst-launch-1.0 nvarguscamerasrc sensor-mode=0 sensor-id=1 ! ‘video/x-raw(memory:NVMM),width=(int)1280,height=(int)1080,format=(string)NV12,framerate=(fraction)30/1’ ! fakesink nvarguscamerasrc sensor-mode=0 sensor-id=0 ! ‘video/x-raw(memory:NVMM),width=(int)1280,height=(int)1080,format=(string)NV12,framerate=(fraction)30/1’ ! nvoverlaysink -e
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
New clock: GstSystemClock
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected…
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 1280 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 8.000000; Exposure Range min 20000, max 33698000;
GST_ARGUS: 1280 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 8.000000; Exposure Range min 640000, max 32640000;
GST_ARGUS: Running with following settings:
Camera index = 1
Camera mode = 0
Output Stream W = 1280 H = 1080
seconds to Run = 0
Frame Rate = 29.999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
Camera index = 0
Camera mode = 0
seconds to Run = 0
^Chandling interrupt.
Interrupt: Stopping pipeline …
EOS on shutdown enabled – Forcing EOS on the pipeline
Waiting for EOS…
Got EOS from element “pipeline0”.
EOS received - stopping pipeline…
Execution ended after 0:00:06.767941519
Setting pipeline to READY …
GST_ARGUS: Cleaning up
CONSUMER: Done Success
GST_ARGUS: Done Success
(Argus) Error Timeout: (propagating from src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 137)
(Argus) Error Timeout: (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 87)
Setting pipeline to NULL …
Freeing pipeline …
Help!
