Hi, I’m trying the following script with OV5693.
gst-launch-1.0 -vvvv nvarguscamerasrc \ ! 'video/x-raw(memory:NVMM),width=2592,height=1944' \ ! queue max-size-buffers=1 leaky=2 name=q1 \ ! tee name=t \ t. ! queue name=q3 \ ! nvvidconv name=testLoc flip-method=2 left=1692 right=2172 top=900 bottom=1280 \ ! 'video/x-raw(memory:NVMM),width=480,height=380' \ ! nvoverlaysink name=displaySink async=false sync=false overlay-x=0 overlay-y=361 overlay-w=480 overlay-h=380 \ t. ! queue name=q4 \ ! valve drop=true \ ! nvvidconv \ ! clockoverlay time-format=\"%D %H:%M:%S\" halignment=right \ ! nvjpegenc ! multifilesink name=testPicture async=false location=/tmp/pic1.jpg \ t. ! queue name=q5 \ ! nvvidconv name=b ! 'video/x-raw(memory:NVMM),width=(int)1920,height=(int)1080' \ ! nvivafilter cuda-process=true customer-lib-name="libnvsample_cudaprocess.so" \ ! 'video/x-raw(memory:NVMM),width=(int)1920,height=(int)1080, format=NV12' \ ! nvv4l2h264enc maxperf-enable=1 bitrate=8000000 \ ! 'video/x-h264, stream-format=(string)byte-stream' \ ! h264parse \ ! valve drop=true \ ! splitmuxsink name=testVideoSink async-handling=true location=/tmp/tmpFile
Here’s how I created the issue:
- sudo systemctl stop nvargus-daemon
- sudo rm -f /tmp/argus_socket
- run nvargus-daemon as a foreground process to monitor outputs on the same terminal
- run the gstreamer script above
- stop the script with ctrl-c
- when the script exit is hanging due to pipeline clean-up error, stop nvargus-daemon with ctrl-c.
Steps 3-6 may need to be repeated, as gstreamer pipeline clean-up in step 5 sometimes works well.
When there is a gstreamer pipeline error, and nvargus-daemon was stopped with ctrl-c, dmesg shows the following:
`[ +25.639565] host1x 13e10000.host1x: cdma_handle_timeout: timeout: 43 (15700000.vi_2) clientid 3057, HW thresh 2269, done 2270
[ +0.011436] host1x 13e10000.host1x: cdma_handle_timeout: timeout: 42 (15700000.vi_1) clientid 3057, HW thresh 1293, done 1293
[ +0.011424] host1x 13e10000.host1x: cdma_handle_timeout: timeout: 41 (15700000.vi_0) clientid 3057, HW thresh 1295, done 1295
[ +0.011378] ---- mlocks ----
[ +0.000033] ---- syncpts ----
[ +0.000017] id 5 (disp_d) min 6185 max 6186 refs 1 (previous client : )
[ +0.000006] id 6 (disp_e) min 1574 max 1574 refs 1 (previous client : )
[ +0.000004] id 7 (disp_f) min 2 max 2 refs 1 (previous client : )
[ +0.000005] id 8 (vblank1) min 102589 max -4 refs 1 (previous client : )
[ +0.000016] id 19 (15340000.vic_nvargus-daemon_0) min 2 max 2 refs 1 (previous client : 15340000.vic_nvargus-daemon_0)
[ +0.000004] id 20 (gp10b_507) min 332206 max 332206 refs 1 (previous client : )
[ +0.000003] id 21 (gp10b_506) min 22 max 22 refs 1 (previous client : )
[ +0.000005] id 22 (gp10b_505) min 32342 max 32344 refs 1 (previous client : gp10b_505)
[ +0.000004] id 23 (15340000.vic_gst-launch-1.0_0) min 6915 max 6915 refs 1 (previous client : 15340000.vic_gst-launch-1.0_0)
[ +0.000008] id 28 (15340000.vic_gst-launch-1.0_0) min 2198 max 2198 refs 1 (previous client : 15340000.vic_gst-launch-1.0_0)
[ +0.000004] id 29 (15600000.isp_nvargus-daemon_0) min 2630 max 2630 refs 3 (previous client : 15600000.isp_nvargus-daemon_0)
[ +0.000004] id 30 (15600000.isp_nvargus-daemon_1) min 2117 max 2117 refs 3 (previous client : 15600000.isp_nvargus-daemon_1)
[ +0.000005] id 31 (15600000.isp_nvargus-daemon_2) min 3389 max 3389 refs 3 (previous client : 15600000.isp_nvargus-daemon_2)
[ +0.000004] id 32 (15600000.isp_nvargus-daemon_3) min 2259 max 2259 refs 3 (previous client : 15600000.isp_nvargus-daemon_3)
[ +0.000004] id 33 (15600000.isp_nvargus-daemon_4) min 9861 max 9861 refs 4 (previous client : 15600000.isp_nvargus-daemon_4)
[ +0.000004] id 34 (15600000.isp_nvargus-daemon_5) min 2259 max 2259 refs 3 (previous client : 15600000.isp_nvargus-daemon_5)
[ +0.000004] id 35 (gp10b_490) min 7092 max 7092 refs 1 (previous client : gp10b_490)
[ +0.000004] id 36 (gp10b_491) min 1038 max 1038 refs 1 (previous client : gp10b_491)
[ +0.000003] id 37 (gp10b_489) min 15 max 15 refs 1 (previous client : gp10b_489)
[ +0.000004] id 38 (gp10b_492) min 149 max 149 refs 1 (previous client : gp10b_492)
[ +0.000004] id 39 (gp10b_493) min 122 max 122 refs 1 (previous client : gp10b_493)
[ +0.000004] id 40 (15700000.vi_0) min 223 max 223 refs 2 (previous client : 15700000.vi_0)
[ +0.000004] id 41 (15700000.vi_0) min 1295 max 1295 refs 3 (previous client : 15700000.vi_0)
[ +0.000004] id 42 (15700000.vi_1) min 1293 max 1293 refs 3 (previous client : 15700000.vi_1)
[ +0.000003] id 43 (15700000.vi_2) min 2270 max 2270 refs 3 (previous client : 15700000.vi_2)
[ +0.000014] id 53 (gp10b_495) min 54 max 54 refs 1 (previous client : 15340000.vic_argus_thread_0)
[ +0.000004] id 54 (gp10b_496) min 1410 max 1410 refs 1 (previous client : gp10b_490)
[ +0.000004] id 55 (gp10b_498) min 2561 max 2561 refs 1 (previous client : gp10b_491)
[ +0.000004] id 56 (gp10b_494) min 6 max 6 refs 1 (previous client : gp10b_492)
[ +0.000004] id 57 (gp10b_497) min 6 max 6 refs 1 (previous client : gp10b_493)
[ +0.000004] id 58 (15340000.vic_V4L2_EncThread_0) min 18 max 18 refs 1 (previous client : 15340000.vic_argus_thread_0)
[ +0.000004] id 59 (154c0000.nvenc_V4L2_EncThread_0) min 1458 max 1458 refs 1 (previous client : 154c0000.nvenc_V4L2_EncThread_0)
[ +0.000004] id 60 (15340000.vic_V4L2_EncThread_0) min 2003 max 2003 refs 1 (previous client : 15340000.vic_V4L2_EncThread_0)
[ +0.000005] id 61 (15340000.vic_gst-launch-1.0_0) min 2028 max 2028 refs 1 (previous client : 15340000.vic_argus_thread_0)
[ +0.000562] ---- channels ----
[ +0.000016]
channel 2 - 15820000.se
[ +0.000002] NvHost basic channel registers:
[ +0.000004] CMDFIFO_STAT_0: 00002040
[ +0.000003] CMDFIFO_RDATA_0: a0da6240
[ +0.000005] CMDP_OFFSET_0: 00000000
[ +0.000002] CMDP_CLASS_0: 00000000
[ +0.000003] CHANNELSTAT_0: 00000000
[ +0.000002] The CDMA sync queue is empty.
[ +0.000006]
channel 3 - 15830000.se
[ +0.000002] CMDFIFO_STAT_0: 00002040
[ +0.000002] CMDFIFO_RDATA_0: 0a0d100a
[ +0.000004] CMDP_OFFSET_0: 00000000
[ +0.000001] The CDMA sync queue is empty.
[ +0.000004]
channel 4 - 15840000.se
[ +0.000002] CMDFIFO_RDATA_0: 00440806
[ +0.000004] CMDP_CLASS_0: 00000000
[ +0.000002] CHANNELSTAT_0: 00000000
[ +0.000004]
channel 7 - 15600000.isp
[ +0.000001] NvHost basic channel registers:
[ +0.000003] CMDFIFO_STAT_0: 00002040
[ +0.000002] CMDFIFO_RDATA_0: e1000032
[ +0.000004] CMDP_OFFSET_0: 00000100
[ +0.000005]
ffffffc190cd1400: JOB, syncpt_id=29, syncpt_val=2630, first_get=00000f80, timeout=10000, num_slots=19
[ +0.000008] GATHER at ffc00000+3c50, 12 words
[ +0.000003] 20000001
[ +0.000002] 0000641d
[ +0.000001] 20000001
[ +0.000002] 0000681e
[ +0.000004] 20000001
[ +0.000004] 00006c1f
[ +0.000002] 20000001
[ +0.000001] 00007c20
[ +0.000002] 00007422
[ +0.000001] 200c0001
[ +0.000002] 00000005
[ +0.000004] GATHER at ffc00000+3c80, 2 words
[ +0.000001] 00000021
[ +0.000007]
channel 1 - 15700000.vi
[ +0.000002] CMDFIFO_RDATA_0: 00000028
[ +0.000006] CMDP_OFFSET_0: 00000000
[ +0.000002] CMDP_CLASS_0: 00000001
[ +0.000004]
channel 5 - 15700000.vi
[ +0.000002] CMDFIFO_RDATA_0: 00000029
[ +0.000005]
ffffffc190cd3400: JOB, syncpt_id=43, syncpt_val=2270, first_get=00000ae0, timeout=10000, num_slots=7
[ +0.000006] GATHER at ffc50000+07ac, 6 words
[ +0.000004] 304e0005
[ +0.000005] 00002683
[ +0.000003] 00000021
[ +0.000002] 304e0005
[ +0.000002] 0000050c
[ +0.000001] 0000002a
[ +0.000004] GATHER at ffc50000+07c4, 4 words
[ +0.000002] 90000002
[ +0.000001] a0004021
[ +0.000002] 00000000
[ +0.000003] GATHER at ffc50000+07d4, 26 words
[ +0.000001] 90000001
[ +0.000002] a0000401
[ +0.000001] 00000000
[ +0.000003] 90000001
[ +0.000002] a000404d
[ +0.000003] 00000001
[ +0.000004] a0004020
[ +0.000003] 90000003
[ +0.000003] a0004042
[ +0.000003] 5a1b9000
[ +0.000005] 00000001
[ +0.000002] 90000001
[ +0.000003] a0004048
[ +0.000002] a000400a
[ +0.000003] 00000000
[ +0.000005] 90000001
[ +0.000001] a0004001
[ +0.000002] 00000001
[ +0.000001] a0004007
[ +0.000002] 00000003
[ +0.000003] GATHER at ffc50000+083c, 2 words
[ +0.000002] 00000029
[ +0.000005]
---- host general irq ----
[ +0.000003] sync_intc0mask = 0x00000001
[ +0.000002] sync_intmask = 0x50000003
[ +0.000002]
---- host syncpt irq mask ----
[ +0.000001]
---- host syncpt irq status ----
[ +0.000004] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[ +0.000003] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ +0.000003] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ +0.000003] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ +0.000003] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[ +0.000003] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[ +0.000002] syncpt_thresh_cpu0_int_status(6) = 0x00000000
[ +0.000003] syncpt_thresh_cpu0_int_status(7) = 0x00000000
[ +0.000002] syncpt_thresh_cpu0_int_status(8) = 0x00000000
[ +0.000003] syncpt_thresh_cpu0_int_status(9) = 0x00000000
[ +0.000002] syncpt_thresh_cpu0_int_status(10) = 0x00000000
[ +0.000003] syncpt_thresh_cpu0_int_status(11) = 0x00000000
[ +0.000002] syncpt_thresh_cpu0_int_status(12) = 0x00000000
[ +0.000003] syncpt_thresh_cpu0_int_status(13) = 0x00000000
[ +0.000002] syncpt_thresh_cpu0_int_status(14) = 0x00000000
[ +0.000003] syncpt_thresh_cpu0_int_status(15) = 0x00000000
[ +0.000003] syncpt_thresh_cpu0_int_status(16) = 0x00000000
[ +0.000003] syncpt_thresh_cpu0_int_status(17) = 0x00000000
[ +0.000015] tegra-vi4 15700000.vi: SYNCPT_ID 43
[ +0.000003] tegra-vi4 15700000.vi: SYNCPT_VAL 2270
[ +0.000002] tegra-vi4 15700000.vi: FIRST_GET 0xae0
[ +0.000002] tegra-vi4 15700000.vi: TIMEOUT 10000
[ +0.000003] tegra-vi4 15700000.vi: NUM_SLOTS 7
[ +0.000002] tegra-vi4 15700000.vi: NUM_HANDLES 2
[ +0.011552] cdma_stop: DMAPUT != DMAGET for channel 5, stopping CDMA`
From what I’ve read from the nvidia forum so far, this seems to be a sync-point timeout error. As this is happening with OV5693 camera (default camera on TX2 dev platform), I’m assuming that I would see the same issue with the imx327 camera I have from Leopard Imaging. What can I do to fix the issue?
