Gst-launch-1.0 works once, but not twice
Recently was able to load video off my camera connected to Jetson via FPDLink SerDes using the following command:
gst-launch-1.0 nvarguscamerasrc num-buffers=1000 ! 'video/x-raw(memory:NVMM),width=2880, height=1860, framerate=20/1, format=NV12' ! omxh265enc ! qtmux ! filesink location=test.mp4 -e
This command will correctly collect 1000 frames and put them into a video at test.mp4, but when I run it again, I get the following error:
root@DEVJACK:~# gst-launch-1.0 nvarguscamerasrc num-buffers=1000 ! 'video/x-raw(memory:NVMM),width=2880, height=1860, framerate=20/1, format=NV12' ! omxh265enc ! qtmux ! filesink location=test.mp4 -e
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Framerate set to : 20 at NvxVideoEncoderSetParameterNvMMLiteOpen : Block : BlockType = 8
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 8
NVMEDIA: H265 : Profile : 1
nvbuf_utils: dmabuf_fd -1 mapped entry NOT found
nvbuf_utils: Can not get HW buffer from FD... Exiting...
ERROR: from element /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0: CANCELLED
Additional debug info:
Argus Error Status
EOS on shutdown enabled -- waiting for EOS after Error
Waiting for EOS...
^Chandling interrupt.
Interrupt: Stopping pipeline ...
Interrupt while waiting for EOS - stopping pipeline...
Execution ended after 0:00:14.534837056
Setting pipeline to NULL ...
^C
trace:
# tracer: nop
# entries-in-buffer/entries-written: 1705/1705   #P:8
#                              _-----=> irqs-off
#                             / _----=> need-resched
#                            | / _---=> hardirq/softirq
#                            || / _--=> preempt-depth
#                            ||| /     delay
#           TASK-PID   CPU#  ||||    TIMESTAMP  FUNCTION
     kworker/0:3-2151  [000] ....   264.775054: rtos_queue_peek_from_isr_failed: tstamp:8705386040 queue:0x0bcbcf78
     kworker/0:3-2151  [000] ....   264.775058: rtcpu_start: tstamp:8705387502
     kworker/0:3-2151  [000] ....   264.775060: rtos_queue_send_from_isr_failed: tstamp:8705399464 queue:0x0bcb41f8
     kworker/0:3-2151  [000] ....   264.775061: rtos_queue_send_from_isr_failed: tstamp:8705399602 queue:0x0bcb8a60
     kworker/0:3-2151  [000] ....   264.775062: rtos_queue_send_from_isr_failed: tstamp:8705399742 queue:0x0bcba5e0
     kworker/0:3-2151  [000] ....   264.775062: rtos_queue_send_from_isr_failed: tstamp:8705399878 queue:0x0bcbb3a0
     kworker/0:3-2151  [000] ....   264.775063: rtos_queue_send_from_isr_failed: tstamp:8705400011 queue:0x0bcbc160
     kworker/0:3-2151  [000] ....   264.775085: rtcpu_string: tstamp:8705400439 id:0x04010000 str:"Configuring ISP GoS.
     kworker/0:3-2151  [000] ....   264.775203: rtcpu_string: tstamp:8705400605 id:0x04010000 str:"  VM GOS[#0] addr=0xc2100000
     kworker/0:3-2151  [000] ....   264.775277: rtcpu_string: tstamp:8705400850 id:0x04010000 str:"  VM GOS[#1] addr=0xc2101000
     kworker/0:3-2151  [000] ....   264.775366: rtcpu_string: tstamp:8705401106 id:0x04010000 str:"  VM GOS[#2] addr=0xc2102000
     kworker/0:3-2151  [000] ....   264.775442: rtcpu_string: tstamp:8705401352 id:0x04010000 str:"  VM GOS[#3] addr=0xc2103000
     kworker/0:3-2151  [000] ....   264.775519: rtcpu_string: tstamp:8705401637 id:0x04010000 str:"  VM GOS[#4] addr=0xc2104000
     kworker/0:3-2151  [000] ....   264.775592: rtcpu_string: tstamp:8705401860 id:0x04010000 str:"  VM GOS[#5] addr=0xc2105000
  nvargus-daemon-5860  [001] ....   264.806432: tegra_channel_open: vi-output, imx490 30-001b
  nvargus-daemon-5860  [001] ....   264.806442: tegra_channel_set_power: imx490 30-001b : 0x1
  nvargus-daemon-5860  [001] ....   264.806449: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [001] ....   264.806901: tegra_channel_set_power: 15a00000.nvcsi--8 : 0x1
  nvargus-daemon-5860  [001] ....   264.806904: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [001] ....   264.806986: tegra_channel_close: vi-output, imx490 30-001b
  nvargus-daemon-5860  [001] ....   264.806989: tegra_channel_set_power: imx490 30-001b : 0x0
  nvargus-daemon-5860  [001] ....   264.806992: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [001] ....   264.807444: tegra_channel_set_power: 15a00000.nvcsi--8 : 0x0
  nvargus-daemon-5860  [001] ....   264.807446: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [001] ....   264.808266: tegra_channel_open: vi-output, imx490 30-001c
  nvargus-daemon-5860  [001] ....   264.808271: tegra_channel_set_power: imx490 30-001c : 0x1
  nvargus-daemon-5860  [001] ....   264.808275: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [001] ....   264.808624: tegra_channel_set_power: 15a00000.nvcsi--7 : 0x1
  nvargus-daemon-5860  [001] ....   264.808625: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [001] ....   264.808681: tegra_channel_close: vi-output, imx490 30-001c
  nvargus-daemon-5860  [001] ....   264.808684: tegra_channel_set_power: imx490 30-001c : 0x0
  nvargus-daemon-5860  [001] ....   264.808686: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [001] ....   264.808796: tegra_channel_set_power: 15a00000.nvcsi--7 : 0x0
  nvargus-daemon-5860  [001] ....   264.808797: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [001] ....   264.809550: tegra_channel_open: vi-output, imx490 31-001b
  nvargus-daemon-5860  [001] ....   264.809553: tegra_channel_set_power: imx490 31-001b : 0x1
  nvargus-daemon-5860  [001] ....   264.809557: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [001] ....   264.809881: tegra_channel_set_power: 15a00000.nvcsi--6 : 0x1
  nvargus-daemon-5860  [001] ....   264.809882: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [001] ....   264.809947: tegra_channel_close: vi-output, imx490 31-001b
  nvargus-daemon-5860  [001] ....   264.809949: tegra_channel_set_power: imx490 31-001b : 0x0
  nvargus-daemon-5860  [001] ....   264.809951: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [001] ....   264.810062: tegra_channel_set_power: 15a00000.nvcsi--6 : 0x0
  nvargus-daemon-5860  [001] ....   264.810063: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [001] ....   264.810810: tegra_channel_open: vi-output, imx490 31-001c
  nvargus-daemon-5860  [001] ....   264.810814: tegra_channel_set_power: imx490 31-001c : 0x1
  nvargus-daemon-5860  [001] ....   264.810817: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.811252: tegra_channel_set_power: 15a00000.nvcsi--5 : 0x1
  nvargus-daemon-5860  [000] ....   264.811254: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.811340: tegra_channel_close: vi-output, imx490 31-001c
  nvargus-daemon-5860  [000] ....   264.811342: tegra_channel_set_power: imx490 31-001c : 0x0
  nvargus-daemon-5860  [000] ....   264.811346: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.811447: tegra_channel_set_power: 15a00000.nvcsi--5 : 0x0
  nvargus-daemon-5860  [000] ....   264.811448: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.812174: tegra_channel_open: vi-output, imx490 32-001b
  nvargus-daemon-5860  [000] ....   264.812178: tegra_channel_set_power: imx490 32-001b : 0x1
  nvargus-daemon-5860  [000] ....   264.812182: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.812515: tegra_channel_set_power: 15a00000.nvcsi--4 : 0x1
  nvargus-daemon-5860  [000] ....   264.812516: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.812587: tegra_channel_close: vi-output, imx490 32-001b
  nvargus-daemon-5860  [000] ....   264.812589: tegra_channel_set_power: imx490 32-001b : 0x0
  nvargus-daemon-5860  [000] ....   264.812592: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.812686: tegra_channel_set_power: 15a00000.nvcsi--4 : 0x0
  nvargus-daemon-5860  [000] ....   264.812687: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.813415: tegra_channel_open: vi-output, imx490 32-001c
  nvargus-daemon-5860  [000] ....   264.813419: tegra_channel_set_power: imx490 32-001c : 0x1
  nvargus-daemon-5860  [000] ....   264.813436: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.813727: tegra_channel_set_power: 15a00000.nvcsi--3 : 0x1
  nvargus-daemon-5860  [000] ....   264.813728: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.813780: tegra_channel_close: vi-output, imx490 32-001c
  nvargus-daemon-5860  [000] ....   264.813782: tegra_channel_set_power: imx490 32-001c : 0x0
  nvargus-daemon-5860  [000] ....   264.813785: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.813884: tegra_channel_set_power: 15a00000.nvcsi--3 : 0x0
  nvargus-daemon-5860  [000] ....   264.813885: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.814619: tegra_channel_open: vi-output, imx490 33-001b
  nvargus-daemon-5860  [000] ....   264.814622: tegra_channel_set_power: imx490 33-001b : 0x1
  nvargus-daemon-5860  [000] ....   264.814625: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.814950: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x1
  nvargus-daemon-5860  [000] ....   264.814951: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.815036: tegra_channel_close: vi-output, imx490 33-001b
  nvargus-daemon-5860  [000] ....   264.815038: tegra_channel_set_power: imx490 33-001b : 0x0
  nvargus-daemon-5860  [000] ....   264.815041: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.815214: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x0
  nvargus-daemon-5860  [000] ....   264.815215: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.815943: tegra_channel_open: vi-output, imx490 33-001c
  nvargus-daemon-5860  [000] ....   264.815946: tegra_channel_set_power: imx490 33-001c : 0x1
  nvargus-daemon-5860  [000] ....   264.815950: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.816264: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x1
  nvargus-daemon-5860  [000] ....   264.816265: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.816331: tegra_channel_close: vi-output, imx490 33-001c
  nvargus-daemon-5860  [000] ....   264.816333: tegra_channel_set_power: imx490 33-001c : 0x0
  nvargus-daemon-5860  [000] ....   264.816335: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.816438: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x0
  nvargus-daemon-5860  [000] ....   264.816439: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.818902: tegra_channel_open: vi-output, imx490 30-001b
  nvargus-daemon-5860  [000] ....   264.818907: tegra_channel_set_power: imx490 30-001b : 0x1
  nvargus-daemon-5860  [000] ....   264.818911: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.819306: tegra_channel_set_power: 15a00000.nvcsi--8 : 0x1
  nvargus-daemon-5860  [000] ....   264.819308: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.819395: tegra_channel_close: vi-output, imx490 30-001b
  nvargus-daemon-5860  [000] ....   264.819397: tegra_channel_set_power: imx490 30-001b : 0x0
  nvargus-daemon-5860  [000] ....   264.819401: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.819576: tegra_channel_set_power: 15a00000.nvcsi--8 : 0x0
  nvargus-daemon-5860  [000] ....   264.819578: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.821506: tegra_channel_open: vi-output, imx490 30-001c
  nvargus-daemon-5860  [000] ....   264.821509: tegra_channel_set_power: imx490 30-001c : 0x1
  nvargus-daemon-5860  [000] ....   264.821512: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.821870: tegra_channel_set_power: 15a00000.nvcsi--7 : 0x1
  nvargus-daemon-5860  [000] ....   264.821872: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.821940: tegra_channel_close: vi-output, imx490 30-001c
  nvargus-daemon-5860  [000] ....   264.821942: tegra_channel_set_power: imx490 30-001c : 0x0
  nvargus-daemon-5860  [000] ....   264.821944: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.822042: tegra_channel_set_power: 15a00000.nvcsi--7 : 0x0
  nvargus-daemon-5860  [000] ....   264.822043: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.822785: tegra_channel_open: vi-output, imx490 31-001b
  nvargus-daemon-5860  [000] ....   264.822789: tegra_channel_set_power: imx490 31-001b : 0x1
  nvargus-daemon-5860  [000] ....   264.822792: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.823144: tegra_channel_set_power: 15a00000.nvcsi--6 : 0x1
  nvargus-daemon-5860  [000] ....   264.823145: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.823216: tegra_channel_close: vi-output, imx490 31-001b
  nvargus-daemon-5860  [000] ....   264.823218: tegra_channel_set_power: imx490 31-001b : 0x0
  nvargus-daemon-5860  [000] ....   264.823220: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.823327: tegra_channel_set_power: 15a00000.nvcsi--6 : 0x0
  nvargus-daemon-5860  [000] ....   264.823328: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.824078: tegra_channel_open: vi-output, imx490 31-001c
  nvargus-daemon-5860  [000] ....   264.824082: tegra_channel_set_power: imx490 31-001c : 0x1
  nvargus-daemon-5860  [000] ....   264.824084: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.824417: tegra_channel_set_power: 15a00000.nvcsi--5 : 0x1
  nvargus-daemon-5860  [000] ....   264.824418: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.824484: tegra_channel_close: vi-output, imx490 31-001c
  nvargus-daemon-5860  [000] ....   264.824486: tegra_channel_set_power: imx490 31-001c : 0x0
  nvargus-daemon-5860  [000] ....   264.824488: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.824588: tegra_channel_set_power: 15a00000.nvcsi--5 : 0x0
  nvargus-daemon-5860  [000] ....   264.824590: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.825320: tegra_channel_open: vi-output, imx490 32-001b
  nvargus-daemon-5860  [000] ....   264.825323: tegra_channel_set_power: imx490 32-001b : 0x1
  nvargus-daemon-5860  [000] ....   264.825327: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.825661: tegra_channel_set_power: 15a00000.nvcsi--4 : 0x1
  nvargus-daemon-5860  [000] ....   264.825662: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.825711: tegra_channel_close: vi-output, imx490 32-001b
  nvargus-daemon-5860  [000] ....   264.825713: tegra_channel_set_power: imx490 32-001b : 0x0
  nvargus-daemon-5860  [000] ....   264.825715: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.825818: tegra_channel_set_power: 15a00000.nvcsi--4 : 0x0
  nvargus-daemon-5860  [000] ....   264.825819: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.826539: tegra_channel_open: vi-output, imx490 32-001c
  nvargus-daemon-5860  [000] ....   264.826542: tegra_channel_set_power: imx490 32-001c : 0x1
  nvargus-daemon-5860  [000] ....   264.826545: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.826852: tegra_channel_set_power: 15a00000.nvcsi--3 : 0x1
  nvargus-daemon-5860  [000] ....   264.826853: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.826904: tegra_channel_close: vi-output, imx490 32-001c
  nvargus-daemon-5860  [000] ....   264.826906: tegra_channel_set_power: imx490 32-001c : 0x0
  nvargus-daemon-5860  [000] ....   264.826908: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.827032: tegra_channel_set_power: 15a00000.nvcsi--3 : 0x0
  nvargus-daemon-5860  [000] ....   264.827034: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.829892: tegra_channel_open: vi-output, imx490 33-001b
  nvargus-daemon-5860  [000] ....   264.829898: tegra_channel_set_power: imx490 33-001b : 0x1
  nvargus-daemon-5860  [000] ....   264.829902: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.830939: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x1
  nvargus-daemon-5860  [000] ....   264.830940: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.830991: tegra_channel_close: vi-output, imx490 33-001b
  nvargus-daemon-5860  [000] ....   264.830993: tegra_channel_set_power: imx490 33-001b : 0x0
  nvargus-daemon-5860  [000] ....   264.831043: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.831169: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x0
  nvargus-daemon-5860  [000] ....   264.831171: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.831994: tegra_channel_open: vi-output, imx490 33-001c
  nvargus-daemon-5860  [000] ....   264.831999: tegra_channel_set_power: imx490 33-001c : 0x1
  nvargus-daemon-5860  [000] ....   264.832003: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.832344: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x1
  nvargus-daemon-5860  [000] ....   264.832346: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.832401: tegra_channel_close: vi-output, imx490 33-001c
  nvargus-daemon-5860  [000] ....   264.832403: tegra_channel_set_power: imx490 33-001c : 0x0
  nvargus-daemon-5860  [000] ....   264.832405: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.832509: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x0
  nvargus-daemon-5860  [000] ....   264.832510: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.838642: tegra_channel_open: vi-output, imx490 33-001c
  nvargus-daemon-5860  [000] ....   264.838651: tegra_channel_set_power: imx490 33-001c : 0x1
  nvargus-daemon-5860  [000] ....   264.838657: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.839079: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x1
  nvargus-daemon-5860  [000] ....   264.839081: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.839096: tegra_channel_close: vi-output, imx490 33-001c
  nvargus-daemon-5860  [000] ....   264.839098: tegra_channel_set_power: imx490 33-001c : 0x0
  nvargus-daemon-5860  [000] ....   264.839101: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.839209: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x0
  nvargus-daemon-5860  [000] ....   264.839210: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.839965: tegra_channel_open: vi-output, imx490 33-001b
  nvargus-daemon-5860  [000] ....   264.839968: tegra_channel_set_power: imx490 33-001b : 0x1
  nvargus-daemon-5860  [000] ....   264.839971: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.840300: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x1
  nvargus-daemon-5860  [000] ....   264.840301: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.840310: tegra_channel_close: vi-output, imx490 33-001b
  nvargus-daemon-5860  [000] ....   264.840312: tegra_channel_set_power: imx490 33-001b : 0x0
  nvargus-daemon-5860  [000] ....   264.840314: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.840416: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x0
  nvargus-daemon-5860  [000] ....   264.840417: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.841146: tegra_channel_open: vi-output, imx490 32-001c
  nvargus-daemon-5860  [000] ....   264.841149: tegra_channel_set_power: imx490 32-001c : 0x1
  nvargus-daemon-5860  [000] ....   264.841152: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.841478: tegra_channel_set_power: 15a00000.nvcsi--3 : 0x1
  nvargus-daemon-5860  [000] ....   264.841479: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.841488: tegra_channel_close: vi-output, imx490 32-001c
  nvargus-daemon-5860  [000] ....   264.841490: tegra_channel_set_power: imx490 32-001c : 0x0
  nvargus-daemon-5860  [000] ....   264.841492: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.841610: tegra_channel_set_power: 15a00000.nvcsi--3 : 0x0
  nvargus-daemon-5860  [000] ....   264.841611: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.842335: tegra_channel_open: vi-output, imx490 32-001b
  nvargus-daemon-5860  [000] ....   264.842338: tegra_channel_set_power: imx490 32-001b : 0x1
  nvargus-daemon-5860  [000] ....   264.842341: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.842688: tegra_channel_set_power: 15a00000.nvcsi--4 : 0x1
  nvargus-daemon-5860  [000] ....   264.842689: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.842698: tegra_channel_close: vi-output, imx490 32-001b
  nvargus-daemon-5860  [000] ....   264.842700: tegra_channel_set_power: imx490 32-001b : 0x0
  nvargus-daemon-5860  [000] ....   264.842703: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.842808: tegra_channel_set_power: 15a00000.nvcsi--4 : 0x0
  nvargus-daemon-5860  [000] ....   264.842809: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.845145: tegra_channel_open: vi-output, imx490 31-001c
  nvargus-daemon-5860  [000] ....   264.845154: tegra_channel_set_power: imx490 31-001c : 0x1
  nvargus-daemon-5860  [000] ....   264.845159: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.845993: tegra_channel_set_power: 15a00000.nvcsi--5 : 0x1
  nvargus-daemon-5860  [000] ....   264.845995: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.846005: tegra_channel_close: vi-output, imx490 31-001c
  nvargus-daemon-5860  [000] ....   264.846007: tegra_channel_set_power: imx490 31-001c : 0x0
  nvargus-daemon-5860  [000] ....   264.846009: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.846117: tegra_channel_set_power: 15a00000.nvcsi--5 : 0x0
  nvargus-daemon-5860  [000] ....   264.846118: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.846847: tegra_channel_open: vi-output, imx490 31-001b
  nvargus-daemon-5860  [000] ....   264.846850: tegra_channel_set_power: imx490 31-001b : 0x1
  nvargus-daemon-5860  [000] ....   264.846852: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.847211: tegra_channel_set_power: 15a00000.nvcsi--6 : 0x1
  nvargus-daemon-5860  [000] ....   264.847213: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.847223: tegra_channel_close: vi-output, imx490 31-001b
  nvargus-daemon-5860  [000] ....   264.847225: tegra_channel_set_power: imx490 31-001b : 0x0
  nvargus-daemon-5860  [000] ....   264.847227: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.847326: tegra_channel_set_power: 15a00000.nvcsi--6 : 0x0
  nvargus-daemon-5860  [000] ....   264.847327: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.848056: tegra_channel_open: vi-output, imx490 30-001c
  nvargus-daemon-5860  [000] ....   264.848058: tegra_channel_set_power: imx490 30-001c : 0x1
  nvargus-daemon-5860  [000] ....   264.848062: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.848375: tegra_channel_set_power: 15a00000.nvcsi--7 : 0x1
  nvargus-daemon-5860  [000] ....   264.848376: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.848385: tegra_channel_close: vi-output, imx490 30-001c
  nvargus-daemon-5860  [000] ....   264.848387: tegra_channel_set_power: imx490 30-001c : 0x0
  nvargus-daemon-5860  [000] ....   264.848389: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.848489: tegra_channel_set_power: 15a00000.nvcsi--7 : 0x0
  nvargus-daemon-5860  [000] ....   264.848490: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.849232: tegra_channel_open: vi-output, imx490 30-001b
  nvargus-daemon-5860  [000] ....   264.849235: tegra_channel_set_power: imx490 30-001b : 0x1
  nvargus-daemon-5860  [000] ....   264.849238: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.849571: tegra_channel_set_power: 15a00000.nvcsi--8 : 0x1
  nvargus-daemon-5860  [000] ....   264.849572: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.849581: tegra_channel_close: vi-output, imx490 30-001b
  nvargus-daemon-5860  [000] ....   264.849583: tegra_channel_set_power: imx490 30-001b : 0x0
  nvargus-daemon-5860  [000] ....   264.849586: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.849687: tegra_channel_set_power: 15a00000.nvcsi--8 : 0x0
  nvargus-daemon-5860  [000] ....   264.849688: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.850420: tegra_channel_open: vi-output, imx490 30-001b
  nvargus-daemon-5860  [000] ....   264.850423: tegra_channel_set_power: imx490 30-001b : 0x1
  nvargus-daemon-5860  [000] ....   264.850425: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.850756: tegra_channel_set_power: 15a00000.nvcsi--8 : 0x1
  nvargus-daemon-5860  [000] ....   264.850757: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.850830: tegra_channel_close: vi-output, imx490 30-001b
  nvargus-daemon-5860  [000] ....   264.850832: tegra_channel_set_power: imx490 30-001b : 0x0
  nvargus-daemon-5860  [000] ....   264.850834: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.850930: tegra_channel_set_power: 15a00000.nvcsi--8 : 0x0
  nvargus-daemon-5860  [000] ....   264.850931: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.853257: tegra_channel_open: vi-output, imx490 30-001b
  nvargus-daemon-5860  [000] ....   264.853260: tegra_channel_set_power: imx490 30-001b : 0x1
  nvargus-daemon-5860  [000] ....   264.853263: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.853613: tegra_channel_set_power: 15a00000.nvcsi--8 : 0x1
  nvargus-daemon-5860  [000] ....   264.853614: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.853677: tegra_channel_close: vi-output, imx490 30-001b
  nvargus-daemon-5860  [000] ....   264.853679: tegra_channel_set_power: imx490 30-001b : 0x0
  nvargus-daemon-5860  [000] ....   264.853680: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.853779: tegra_channel_set_power: 15a00000.nvcsi--8 : 0x0
  nvargus-daemon-5860  [000] ....   264.853780: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.870879: tegra_channel_open: vi-output, imx490 33-001c
  nvargus-daemon-5860  [000] ....   264.870889: tegra_channel_set_power: imx490 33-001c : 0x1
  nvargus-daemon-5860  [000] ....   264.870898: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.871515: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x1
  nvargus-daemon-5860  [000] ....   264.871519: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.871542: tegra_channel_close: vi-output, imx490 33-001c
  nvargus-daemon-5860  [000] ....   264.871547: tegra_channel_set_power: imx490 33-001c : 0x0
  nvargus-daemon-5860  [000] ....   264.871550: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.871687: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x0
  nvargus-daemon-5860  [000] ....   264.871688: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.872674: tegra_channel_open: vi-output, imx490 33-001b
  nvargus-daemon-5860  [000] ....   264.872679: tegra_channel_set_power: imx490 33-001b : 0x1
  nvargus-daemon-5860  [000] ....   264.872682: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.873051: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x1
  nvargus-daemon-5860  [000] ....   264.873052: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.873068: tegra_channel_close: vi-output, imx490 33-001b
  nvargus-daemon-5860  [000] ....   264.873070: tegra_channel_set_power: imx490 33-001b : 0x0
  nvargus-daemon-5860  [000] ....   264.873073: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.873173: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x0
  nvargus-daemon-5860  [000] ....   264.873174: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.874101: tegra_channel_open: vi-output, imx490 32-001c
  nvargus-daemon-5860  [000] ....   264.874107: tegra_channel_set_power: imx490 32-001c : 0x1
  nvargus-daemon-5860  [000] ....   264.874111: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.874454: tegra_channel_set_power: 15a00000.nvcsi--3 : 0x1
  nvargus-daemon-5860  [000] ....   264.874455: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.874472: tegra_channel_close: vi-output, imx490 32-001c
  nvargus-daemon-5860  [000] ....   264.874474: tegra_channel_set_power: imx490 32-001c : 0x0
  nvargus-daemon-5860  [000] ....   264.874477: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.874587: tegra_channel_set_power: 15a00000.nvcsi--3 : 0x0
  nvargus-daemon-5860  [000] ....   264.874588: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.875834: tegra_channel_open: vi-output, imx490 32-001b
  nvargus-daemon-5860  [000] ....   264.875838: tegra_channel_set_power: imx490 32-001b : 0x1
  nvargus-daemon-5860  [000] ....   264.875842: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.876337: tegra_channel_set_power: 15a00000.nvcsi--4 : 0x1
  nvargus-daemon-5860  [000] ....   264.876338: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.876369: tegra_channel_close: vi-output, imx490 32-001b
  nvargus-daemon-5860  [000] ....   264.876371: tegra_channel_set_power: imx490 32-001b : 0x0
  nvargus-daemon-5860  [000] ....   264.876373: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.876485: tegra_channel_set_power: 15a00000.nvcsi--4 : 0x0
  nvargus-daemon-5860  [000] ....   264.876487: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.877456: tegra_channel_open: vi-output, imx490 31-001c
  nvargus-daemon-5860  [000] ....   264.877460: tegra_channel_set_power: imx490 31-001c : 0x1
  nvargus-daemon-5860  [000] ....   264.877481: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.878027: tegra_channel_set_power: 15a00000.nvcsi--5 : 0x1
  nvargus-daemon-5860  [000] ....   264.878029: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.878038: tegra_channel_close: vi-output, imx490 31-001c
  nvargus-daemon-5860  [000] ....   264.878040: tegra_channel_set_power: imx490 31-001c : 0x0
  nvargus-daemon-5860  [000] ....   264.878042: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.878150: tegra_channel_set_power: 15a00000.nvcsi--5 : 0x0
  nvargus-daemon-5860  [000] ....   264.878151: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.879157: tegra_channel_open: vi-output, imx490 31-001b
  nvargus-daemon-5860  [000] ....   264.879161: tegra_channel_set_power: imx490 31-001b : 0x1
  nvargus-daemon-5860  [000] ....   264.879165: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.879751: tegra_channel_set_power: 15a00000.nvcsi--6 : 0x1
  nvargus-daemon-5860  [000] ....   264.879753: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.879763: tegra_channel_close: vi-output, imx490 31-001b
  nvargus-daemon-5860  [000] ....   264.879765: tegra_channel_set_power: imx490 31-001b : 0x0
  nvargus-daemon-5860  [000] ....   264.879768: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.879879: tegra_channel_set_power: 15a00000.nvcsi--6 : 0x0
  nvargus-daemon-5860  [000] ....   264.879881: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.880627: tegra_channel_open: vi-output, imx490 30-001c
  nvargus-daemon-5860  [000] ....   264.880631: tegra_channel_set_power: imx490 30-001c : 0x1
  nvargus-daemon-5860  [000] ....   264.880635: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.881101: tegra_channel_set_power: 15a00000.nvcsi--7 : 0x1
  nvargus-daemon-5860  [000] ....   264.881102: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.881115: tegra_channel_close: vi-output, imx490 30-001c
  nvargus-daemon-5860  [000] ....   264.881120: tegra_channel_set_power: imx490 30-001c : 0x0
  nvargus-daemon-5860  [000] ....   264.881123: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.881225: tegra_channel_set_power: 15a00000.nvcsi--7 : 0x0
  nvargus-daemon-5860  [000] ....   264.881226: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.882220: tegra_channel_open: vi-output, imx490 30-001c
  nvargus-daemon-5860  [000] ....   264.882224: tegra_channel_set_power: imx490 30-001c : 0x1
  nvargus-daemon-5860  [000] ....   264.882226: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.882637: tegra_channel_set_power: 15a00000.nvcsi--7 : 0x1
  nvargus-daemon-5860  [000] ....   264.882638: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.882705: tegra_channel_close: vi-output, imx490 30-001c
  nvargus-daemon-5860  [000] ....   264.882707: tegra_channel_set_power: imx490 30-001c : 0x0
  nvargus-daemon-5860  [000] ....   264.882709: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.882822: tegra_channel_set_power: 15a00000.nvcsi--7 : 0x0
  nvargus-daemon-5860  [000] ....   264.882823: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.883758: tegra_channel_open: vi-output, imx490 30-001c
  nvargus-daemon-5860  [000] ....   264.883763: tegra_channel_set_power: imx490 30-001c : 0x1
  nvargus-daemon-5860  [000] ....   264.883768: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.884212: tegra_channel_set_power: 15a00000.nvcsi--7 : 0x1
  nvargus-daemon-5860  [000] ....   264.884214: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.884288: tegra_channel_close: vi-output, imx490 30-001c
  nvargus-daemon-5860  [000] ....   264.884291: tegra_channel_set_power: imx490 30-001c : 0x0
  nvargus-daemon-5860  [000] ....   264.884293: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.884406: tegra_channel_set_power: 15a00000.nvcsi--7 : 0x0
  nvargus-daemon-5860  [000] ....   264.884407: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.900747: tegra_channel_open: vi-output, imx490 33-001c
  nvargus-daemon-5860  [000] ....   264.900757: tegra_channel_set_power: imx490 33-001c : 0x1
  nvargus-daemon-5860  [000] ....   264.900766: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.901184: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x1
  nvargus-daemon-5860  [000] ....   264.901186: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.901203: tegra_channel_close: vi-output, imx490 33-001c
  nvargus-daemon-5860  [000] ....   264.901205: tegra_channel_set_power: imx490 33-001c : 0x0
  nvargus-daemon-5860  [000] ....   264.901208: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.901317: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x0
  nvargus-daemon-5860  [000] ....   264.901318: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.902051: tegra_channel_open: vi-output, imx490 33-001b
  nvargus-daemon-5860  [000] ....   264.902055: tegra_channel_set_power: imx490 33-001b : 0x1
  nvargus-daemon-5860  [000] ....   264.902058: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.902366: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x1
  nvargus-daemon-5860  [000] ....   264.902367: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.902377: tegra_channel_close: vi-output, imx490 33-001b
  nvargus-daemon-5860  [000] ....   264.902379: tegra_channel_set_power: imx490 33-001b : 0x0
  nvargus-daemon-5860  [000] ....   264.902381: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.902482: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x0
  nvargus-daemon-5860  [000] ....   264.902483: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.903549: tegra_channel_open: vi-output, imx490 32-001c
  nvargus-daemon-5860  [000] ....   264.903553: tegra_channel_set_power: imx490 32-001c : 0x1
  nvargus-daemon-5860  [000] ....   264.903557: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.903887: tegra_channel_set_power: 15a00000.nvcsi--3 : 0x1
  nvargus-daemon-5860  [000] ....   264.903889: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.903899: tegra_channel_close: vi-output, imx490 32-001c
  nvargus-daemon-5860  [000] ....   264.903920: tegra_channel_set_power: imx490 32-001c : 0x0
  nvargus-daemon-5860  [000] ....   264.903923: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.904018: tegra_channel_set_power: 15a00000.nvcsi--3 : 0x0
  nvargus-daemon-5860  [000] ....   264.904019: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.904894: tegra_channel_open: vi-output, imx490 32-001b
  nvargus-daemon-5860  [000] ....   264.904898: tegra_channel_set_power: imx490 32-001b : 0x1
  nvargus-daemon-5860  [000] ....   264.904903: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.905932: tegra_channel_set_power: 15a00000.nvcsi--4 : 0x1
  nvargus-daemon-5860  [000] ....   264.905933: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.905942: tegra_channel_close: vi-output, imx490 32-001b
  nvargus-daemon-5860  [000] ....   264.905944: tegra_channel_set_power: imx490 32-001b : 0x0
  nvargus-daemon-5860  [000] ....   264.905946: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.906052: tegra_channel_set_power: 15a00000.nvcsi--4 : 0x0
  nvargus-daemon-5860  [000] ....   264.906053: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.906791: tegra_channel_open: vi-output, imx490 31-001c
  nvargus-daemon-5860  [000] ....   264.906794: tegra_channel_set_power: imx490 31-001c : 0x1
  nvargus-daemon-5860  [000] ....   264.906798: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.907167: tegra_channel_set_power: 15a00000.nvcsi--5 : 0x1
  nvargus-daemon-5860  [000] ....   264.907169: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.907179: tegra_channel_close: vi-output, imx490 31-001c
  nvargus-daemon-5860  [000] ....   264.907181: tegra_channel_set_power: imx490 31-001c : 0x0
  nvargus-daemon-5860  [000] ....   264.907183: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.907288: tegra_channel_set_power: 15a00000.nvcsi--5 : 0x0
  nvargus-daemon-5860  [000] ....   264.907289: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.908017: tegra_channel_open: vi-output, imx490 31-001b
  nvargus-daemon-5860  [000] ....   264.908020: tegra_channel_set_power: imx490 31-001b : 0x1
  nvargus-daemon-5860  [000] ....   264.908023: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.908353: tegra_channel_set_power: 15a00000.nvcsi--6 : 0x1
  nvargus-daemon-5860  [000] ....   264.908354: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.908363: tegra_channel_close: vi-output, imx490 31-001b
  nvargus-daemon-5860  [000] ....   264.908365: tegra_channel_set_power: imx490 31-001b : 0x0
  nvargus-daemon-5860  [000] ....   264.908367: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.908467: tegra_channel_set_power: 15a00000.nvcsi--6 : 0x0
  nvargus-daemon-5860  [000] ....   264.908468: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.909197: tegra_channel_open: vi-output, imx490 31-001b
  nvargus-daemon-5860  [000] ....   264.909199: tegra_channel_set_power: imx490 31-001b : 0x1
  nvargus-daemon-5860  [000] ....   264.909202: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.909526: tegra_channel_set_power: 15a00000.nvcsi--6 : 0x1
  nvargus-daemon-5860  [000] ....   264.909527: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.909586: tegra_channel_close: vi-output, imx490 31-001b
  nvargus-daemon-5860  [000] ....   264.909587: tegra_channel_set_power: imx490 31-001b : 0x0
  nvargus-daemon-5860  [000] ....   264.909590: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.909688: tegra_channel_set_power: 15a00000.nvcsi--6 : 0x0
  nvargus-daemon-5860  [000] ....   264.909689: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.911485: tegra_channel_open: vi-output, imx490 31-001b
  nvargus-daemon-5860  [000] ....   264.911488: tegra_channel_set_power: imx490 31-001b : 0x1
  nvargus-daemon-5860  [000] ....   264.911491: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.911813: tegra_channel_set_power: 15a00000.nvcsi--6 : 0x1
  nvargus-daemon-5860  [000] ....   264.911815: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.911889: tegra_channel_close: vi-output, imx490 31-001b
  nvargus-daemon-5860  [000] ....   264.911891: tegra_channel_set_power: imx490 31-001b : 0x0
  nvargus-daemon-5860  [000] ....   264.911893: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.911990: tegra_channel_set_power: 15a00000.nvcsi--6 : 0x0
  nvargus-daemon-5860  [000] ....   264.911991: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.925673: tegra_channel_open: vi-output, imx490 33-001c
  nvargus-daemon-5860  [000] ....   264.925682: tegra_channel_set_power: imx490 33-001c : 0x1
  nvargus-daemon-5860  [000] ....   264.925692: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.926134: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x1
  nvargus-daemon-5860  [000] ....   264.926137: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.926157: tegra_channel_close: vi-output, imx490 33-001c
  nvargus-daemon-5860  [000] ....   264.926160: tegra_channel_set_power: imx490 33-001c : 0x0
  nvargus-daemon-5860  [000] ....   264.926164: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.926279: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x0
  nvargus-daemon-5860  [000] ....   264.926281: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.927282: tegra_channel_open: vi-output, imx490 33-001b
  nvargus-daemon-5860  [000] ....   264.927287: tegra_channel_set_power: imx490 33-001b : 0x1
  nvargus-daemon-5860  [000] ....   264.927291: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.928214: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x1
  nvargus-daemon-5860  [000] ....   264.928215: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.928229: tegra_channel_close: vi-output, imx490 33-001b
  nvargus-daemon-5860  [000] ....   264.928232: tegra_channel_set_power: imx490 33-001b : 0x0
  nvargus-daemon-5860  [000] ....   264.928234: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.928345: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x0
  nvargus-daemon-5860  [000] ....   264.928346: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.930257: tegra_channel_open: vi-output, imx490 32-001c
  nvargus-daemon-5860  [000] ....   264.930261: tegra_channel_set_power: imx490 32-001c : 0x1
  nvargus-daemon-5860  [000] ....   264.930266: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.931403: tegra_channel_set_power: 15a00000.nvcsi--3 : 0x1
  nvargus-daemon-5860  [000] ....   264.931405: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.931416: tegra_channel_close: vi-output, imx490 32-001c
  nvargus-daemon-5860  [000] ....   264.931418: tegra_channel_set_power: imx490 32-001c : 0x0
  nvargus-daemon-5860  [000] ....   264.931420: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.931525: tegra_channel_set_power: 15a00000.nvcsi--3 : 0x0
  nvargus-daemon-5860  [000] ....   264.931526: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.933883: tegra_channel_open: vi-output, imx490 32-001b
  nvargus-daemon-5860  [000] ....   264.933887: tegra_channel_set_power: imx490 32-001b : 0x1
  nvargus-daemon-5860  [000] ....   264.933892: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.934913: tegra_channel_set_power: 15a00000.nvcsi--4 : 0x1
  nvargus-daemon-5860  [000] ....   264.934914: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.934924: tegra_channel_close: vi-output, imx490 32-001b
  nvargus-daemon-5860  [000] ....   264.934925: tegra_channel_set_power: imx490 32-001b : 0x0
  nvargus-daemon-5860  [000] ....   264.934928: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.935038: tegra_channel_set_power: 15a00000.nvcsi--4 : 0x0
  nvargus-daemon-5860  [000] ....   264.935039: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.937422: tegra_channel_open: vi-output, imx490 31-001c
  nvargus-daemon-5860  [000] ....   264.937427: tegra_channel_set_power: imx490 31-001c : 0x1
  nvargus-daemon-5860  [000] ....   264.937432: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.938478: tegra_channel_set_power: 15a00000.nvcsi--5 : 0x1
  nvargus-daemon-5860  [000] ....   264.938480: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.938490: tegra_channel_close: vi-output, imx490 31-001c
  nvargus-daemon-5860  [000] ....   264.938492: tegra_channel_set_power: imx490 31-001c : 0x0
  nvargus-daemon-5860  [000] ....   264.938494: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.938611: tegra_channel_set_power: 15a00000.nvcsi--5 : 0x0
  nvargus-daemon-5860  [000] ....   264.938612: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.939463: tegra_channel_open: vi-output, imx490 31-001c
  nvargus-daemon-5860  [000] ....   264.939467: tegra_channel_set_power: imx490 31-001c : 0x1
  nvargus-daemon-5860  [000] ....   264.939470: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.939810: tegra_channel_set_power: 15a00000.nvcsi--5 : 0x1
  nvargus-daemon-5860  [000] ....   264.939811: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.939871: tegra_channel_close: vi-output, imx490 31-001c
  nvargus-daemon-5860  [000] ....   264.939873: tegra_channel_set_power: imx490 31-001c : 0x0
  nvargus-daemon-5860  [000] ....   264.939876: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.939979: tegra_channel_set_power: 15a00000.nvcsi--5 : 0x0
  nvargus-daemon-5860  [000] ....   264.939980: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.940729: tegra_channel_open: vi-output, imx490 31-001c
  nvargus-daemon-5860  [000] ....   264.940732: tegra_channel_set_power: imx490 31-001c : 0x1
  nvargus-daemon-5860  [000] ....   264.940735: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.941040: tegra_channel_set_power: 15a00000.nvcsi--5 : 0x1
  nvargus-daemon-5860  [000] ....   264.941041: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.941104: tegra_channel_close: vi-output, imx490 31-001c
  nvargus-daemon-5860  [000] ....   264.941106: tegra_channel_set_power: imx490 31-001c : 0x0
  nvargus-daemon-5860  [000] ....   264.941108: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.941221: tegra_channel_set_power: 15a00000.nvcsi--5 : 0x0
  nvargus-daemon-5860  [000] ....   264.941222: csi_s_power: enable : 0x0
     kworker/0:3-2151  [000] ....   264.943076: rtos_queue_peek_from_isr_failed: tstamp:8710386390 queue:0x0bcbcf78
  nvargus-daemon-5860  [000] ....   264.954925: tegra_channel_open: vi-output, imx490 33-001c
  nvargus-daemon-5860  [000] ....   264.954934: tegra_channel_set_power: imx490 33-001c : 0x1
  nvargus-daemon-5860  [000] ....   264.954942: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.955390: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x1
  nvargus-daemon-5860  [000] ....   264.955392: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.955409: tegra_channel_close: vi-output, imx490 33-001c
  nvargus-daemon-5860  [000] ....   264.955412: tegra_channel_set_power: imx490 33-001c : 0x0
  nvargus-daemon-5860  [000] ....   264.955415: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.955524: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x0
  nvargus-daemon-5860  [000] ....   264.955525: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.956286: tegra_channel_open: vi-output, imx490 33-001b
  nvargus-daemon-5860  [000] ....   264.956289: tegra_channel_set_power: imx490 33-001b : 0x1
  nvargus-daemon-5860  [000] ....   264.956293: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.956617: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x1
  nvargus-daemon-5860  [000] ....   264.956618: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.956630: tegra_channel_close: vi-output, imx490 33-001b
  nvargus-daemon-5860  [000] ....   264.956632: tegra_channel_set_power: imx490 33-001b : 0x0
  nvargus-daemon-5860  [000] ....   264.956635: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.956738: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x0
  nvargus-daemon-5860  [000] ....   264.956739: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.957474: tegra_channel_open: vi-output, imx490 32-001c
  nvargus-daemon-5860  [000] ....   264.957478: tegra_channel_set_power: imx490 32-001c : 0x1
  nvargus-daemon-5860  [000] ....   264.957481: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.957806: tegra_channel_set_power: 15a00000.nvcsi--3 : 0x1
  nvargus-daemon-5860  [000] ....   264.957808: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.957817: tegra_channel_close: vi-output, imx490 32-001c
  nvargus-daemon-5860  [000] ....   264.957819: tegra_channel_set_power: imx490 32-001c : 0x0
  nvargus-daemon-5860  [000] ....   264.957821: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.957922: tegra_channel_set_power: 15a00000.nvcsi--3 : 0x0
  nvargus-daemon-5860  [000] ....   264.957923: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.958664: tegra_channel_open: vi-output, imx490 32-001b
  nvargus-daemon-5860  [000] ....   264.958667: tegra_channel_set_power: imx490 32-001b : 0x1
  nvargus-daemon-5860  [000] ....   264.958670: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.959475: tegra_channel_set_power: 15a00000.nvcsi--4 : 0x1
  nvargus-daemon-5860  [000] ....   264.959476: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.959486: tegra_channel_close: vi-output, imx490 32-001b
  nvargus-daemon-5860  [000] ....   264.959488: tegra_channel_set_power: imx490 32-001b : 0x0
  nvargus-daemon-5860  [000] ....   264.959490: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.959593: tegra_channel_set_power: 15a00000.nvcsi--4 : 0x0
  nvargus-daemon-5860  [000] ....   264.959594: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.961580: tegra_channel_open: vi-output, imx490 32-001b
  nvargus-daemon-5860  [000] ....   264.961583: tegra_channel_set_power: imx490 32-001b : 0x1
  nvargus-daemon-5860  [000] ....   264.961586: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.961928: tegra_channel_set_power: 15a00000.nvcsi--4 : 0x1
  nvargus-daemon-5860  [000] ....   264.961929: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.962003: tegra_channel_close: vi-output, imx490 32-001b
  nvargus-daemon-5860  [000] ....   264.962004: tegra_channel_set_power: imx490 32-001b : 0x0
  nvargus-daemon-5860  [000] ....   264.962007: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.962102: tegra_channel_set_power: 15a00000.nvcsi--4 : 0x0
  nvargus-daemon-5860  [000] ....   264.962103: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.962864: tegra_channel_open: vi-output, imx490 32-001b
  nvargus-daemon-5860  [000] ....   264.962868: tegra_channel_set_power: imx490 32-001b : 0x1
  nvargus-daemon-5860  [000] ....   264.962870: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.963503: tegra_channel_set_power: 15a00000.nvcsi--4 : 0x1
  nvargus-daemon-5860  [000] ....   264.963504: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.963552: tegra_channel_close: vi-output, imx490 32-001b
  nvargus-daemon-5860  [000] ....   264.963554: tegra_channel_set_power: imx490 32-001b : 0x0
  nvargus-daemon-5860  [000] ....   264.963555: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.963663: tegra_channel_set_power: 15a00000.nvcsi--4 : 0x0
  nvargus-daemon-5860  [000] ....   264.963664: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.976874: tegra_channel_open: vi-output, imx490 33-001c
  nvargus-daemon-5860  [000] ....   264.976883: tegra_channel_set_power: imx490 33-001c : 0x1
  nvargus-daemon-5860  [000] ....   264.976893: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.977315: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x1
  nvargus-daemon-5860  [000] ....   264.977318: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.977335: tegra_channel_close: vi-output, imx490 33-001c
  nvargus-daemon-5860  [000] ....   264.977338: tegra_channel_set_power: imx490 33-001c : 0x0
  nvargus-daemon-5860  [000] ....   264.977340: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.977452: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x0
  nvargus-daemon-5860  [000] ....   264.977453: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.978931: tegra_channel_open: vi-output, imx490 33-001b
  nvargus-daemon-5860  [000] ....   264.978936: tegra_channel_set_power: imx490 33-001b : 0x1
  nvargus-daemon-5860  [000] ....   264.978941: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.980041: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x1
  nvargus-daemon-5860  [000] ....   264.980043: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.980054: tegra_channel_close: vi-output, imx490 33-001b
  nvargus-daemon-5860  [000] ....   264.980055: tegra_channel_set_power: imx490 33-001b : 0x0
  nvargus-daemon-5860  [000] ....   264.980058: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.980164: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x0
  nvargus-daemon-5860  [000] ....   264.980165: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.980903: tegra_channel_open: vi-output, imx490 32-001c
  nvargus-daemon-5860  [000] ....   264.980906: tegra_channel_set_power: imx490 32-001c : 0x1
  nvargus-daemon-5860  [000] ....   264.980910: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.981243: tegra_channel_set_power: 15a00000.nvcsi--3 : 0x1
  nvargus-daemon-5860  [000] ....   264.981244: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.981255: tegra_channel_close: vi-output, imx490 32-001c
  nvargus-daemon-5860  [000] ....   264.981256: tegra_channel_set_power: imx490 32-001c : 0x0
  nvargus-daemon-5860  [000] ....   264.981259: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.981361: tegra_channel_set_power: 15a00000.nvcsi--3 : 0x0
  nvargus-daemon-5860  [000] ....   264.981362: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.982094: tegra_channel_open: vi-output, imx490 32-001c
  nvargus-daemon-5860  [000] ....   264.982097: tegra_channel_set_power: imx490 32-001c : 0x1
  nvargus-daemon-5860  [000] ....   264.982099: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.982423: tegra_channel_set_power: 15a00000.nvcsi--3 : 0x1
  nvargus-daemon-5860  [000] ....   264.982424: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.982482: tegra_channel_close: vi-output, imx490 32-001c
  nvargus-daemon-5860  [000] ....   264.982484: tegra_channel_set_power: imx490 32-001c : 0x0
  nvargus-daemon-5860  [000] ....   264.982487: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.982587: tegra_channel_set_power: 15a00000.nvcsi--3 : 0x0
  nvargus-daemon-5860  [000] ....   264.982588: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.983590: tegra_channel_open: vi-output, imx490 32-001c
  nvargus-daemon-5860  [000] ....   264.983611: tegra_channel_set_power: imx490 32-001c : 0x1
  nvargus-daemon-5860  [000] ....   264.983614: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.983913: tegra_channel_set_power: 15a00000.nvcsi--3 : 0x1
  nvargus-daemon-5860  [000] ....   264.983914: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.983987: tegra_channel_close: vi-output, imx490 32-001c
  nvargus-daemon-5860  [000] ....   264.983989: tegra_channel_set_power: imx490 32-001c : 0x0
  nvargus-daemon-5860  [000] ....   264.983991: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.984092: tegra_channel_set_power: 15a00000.nvcsi--3 : 0x0
  nvargus-daemon-5860  [000] ....   264.984093: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.998390: tegra_channel_open: vi-output, imx490 33-001c
  nvargus-daemon-5860  [000] ....   264.998400: tegra_channel_set_power: imx490 33-001c : 0x1
  nvargus-daemon-5860  [000] ....   264.998408: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   264.998826: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x1
  nvargus-daemon-5860  [000] ....   264.998829: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   264.998851: tegra_channel_close: vi-output, imx490 33-001c
  nvargus-daemon-5860  [000] ....   264.998854: tegra_channel_set_power: imx490 33-001c : 0x0
  nvargus-daemon-5860  [000] ....   264.998858: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   264.998963: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x0
  nvargus-daemon-5860  [000] ....   264.998964: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   264.999738: tegra_channel_open: vi-output, imx490 33-001b
  nvargus-daemon-5860  [000] ....   264.999743: tegra_channel_set_power: imx490 33-001b : 0x1
  nvargus-daemon-5860  [000] ....   264.999747: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   265.000088: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x1
  nvargus-daemon-5860  [000] ....   265.000089: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   265.000103: tegra_channel_close: vi-output, imx490 33-001b
  nvargus-daemon-5860  [000] ....   265.000105: tegra_channel_set_power: imx490 33-001b : 0x0
  nvargus-daemon-5860  [000] ....   265.000107: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   265.000212: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x0
  nvargus-daemon-5860  [000] ....   265.000213: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   265.000955: tegra_channel_open: vi-output, imx490 33-001b
  nvargus-daemon-5860  [000] ....   265.000958: tegra_channel_set_power: imx490 33-001b : 0x1
  nvargus-daemon-5860  [000] ....   265.000960: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   265.001276: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x1
  nvargus-daemon-5860  [000] ....   265.001295: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   265.001378: tegra_channel_close: vi-output, imx490 33-001b
  nvargus-daemon-5860  [000] ....   265.001380: tegra_channel_set_power: imx490 33-001b : 0x0
  nvargus-daemon-5860  [000] ....   265.001382: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   265.001480: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x0
  nvargus-daemon-5860  [000] ....   265.001481: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   265.002229: tegra_channel_open: vi-output, imx490 33-001b
  nvargus-daemon-5860  [000] ....   265.002232: tegra_channel_set_power: imx490 33-001b : 0x1
  nvargus-daemon-5860  [000] ....   265.002235: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   265.002557: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x1
  nvargus-daemon-5860  [000] ....   265.002559: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   265.002607: tegra_channel_close: vi-output, imx490 33-001b
  nvargus-daemon-5860  [000] ....   265.002609: tegra_channel_set_power: imx490 33-001b : 0x0
  nvargus-daemon-5860  [000] ....   265.002611: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   265.002731: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x0
  nvargus-daemon-5860  [000] ....   265.002732: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   265.016303: tegra_channel_open: vi-output, imx490 33-001c
  nvargus-daemon-5860  [000] ....   265.016311: tegra_channel_set_power: imx490 33-001c : 0x1
  nvargus-daemon-5860  [000] ....   265.016319: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   265.016729: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x1
  nvargus-daemon-5860  [000] ....   265.016732: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   265.016748: tegra_channel_close: vi-output, imx490 33-001c
  nvargus-daemon-5860  [000] ....   265.016750: tegra_channel_set_power: imx490 33-001c : 0x0
  nvargus-daemon-5860  [000] ....   265.016753: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   265.016861: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x0
  nvargus-daemon-5860  [000] ....   265.016862: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   265.017598: tegra_channel_open: vi-output, imx490 33-001c
  nvargus-daemon-5860  [000] ....   265.017601: tegra_channel_set_power: imx490 33-001c : 0x1
  nvargus-daemon-5860  [000] ....   265.017604: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   265.017931: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x1
  nvargus-daemon-5860  [000] ....   265.017932: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   265.017991: tegra_channel_close: vi-output, imx490 33-001c
  nvargus-daemon-5860  [000] ....   265.017992: tegra_channel_set_power: imx490 33-001c : 0x0
  nvargus-daemon-5860  [000] ....   265.017995: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   265.018100: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x0
  nvargus-daemon-5860  [000] ....   265.018101: csi_s_power: enable : 0x0
  nvargus-daemon-5860  [000] ....   265.018844: tegra_channel_open: vi-output, imx490 33-001c
  nvargus-daemon-5860  [000] ....   265.018863: tegra_channel_set_power: imx490 33-001c : 0x1
  nvargus-daemon-5860  [000] ....   265.018866: camera_common_s_power: status : 0x1
  nvargus-daemon-5860  [000] ....   265.019265: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x1
  nvargus-daemon-5860  [000] ....   265.019267: csi_s_power: enable : 0x1
  nvargus-daemon-5860  [000] ....   265.019335: tegra_channel_close: vi-output, imx490 33-001c
  nvargus-daemon-5860  [000] ....   265.019337: tegra_channel_set_power: imx490 33-001c : 0x0
  nvargus-daemon-5860  [000] ....   265.019338: camera_common_s_power: status : 0x0
  nvargus-daemon-5860  [000] ....   265.019445: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x0
  nvargus-daemon-5860  [000] ....   265.019446: csi_s_power: enable : 0x0
     kworker/0:3-2151  [000] ....   265.055073: rtos_queue_send_from_isr_failed: tstamp:8713538824 queue:0x0bcb41f8
     kworker/0:3-2151  [000] ....   265.055078: rtos_queue_send_from_isr_failed: tstamp:8713538961 queue:0x0bcb8a60
     kworker/0:3-2151  [000] ....   265.055078: rtos_queue_send_from_isr_failed: tstamp:8713539111 queue:0x0bcba5e0
     kworker/0:3-2151  [000] ....   265.055079: rtos_queue_send_from_isr_failed: tstamp:8713539245 queue:0x0bcbb3a0
     kworker/0:3-2151  [000] ....   265.055080: rtos_queue_send_from_isr_failed: tstamp:8713539378 queue:0x0bcbc160
     kworker/0:3-2151  [000] ....   265.055082: rtcpu_string: tstamp:8713539775 id:0x04010000 str:"Configuring VI GoS.
     kworker/0:3-2151  [000] ....   265.055200: rtcpu_string: tstamp:8713539936 id:0x04010000 str:"VM GOS[#0] addr=0xc2100000
     kworker/0:3-2151  [000] ....   265.055279: rtcpu_string: tstamp:8713540172 id:0x04010000 str:"VM GOS[#1] addr=0xc2101000
     kworker/0:3-2151  [000] ....   265.055352: rtcpu_string: tstamp:8713540418 id:0x04010000 str:"VM GOS[#2] addr=0xc2102000
     kworker/0:3-2151  [000] ....   265.055434: rtcpu_string: tstamp:8713540638 id:0x04010000 str:"VM GOS[#3] addr=0xc2103000
     kworker/0:3-2151  [000] ....   265.055506: rtcpu_string: tstamp:8713540858 id:0x04010000 str:"VM GOS[#4] addr=0xc2104000
     kworker/0:3-2151  [000] ....   265.055579: rtcpu_string: tstamp:8713541077 id:0x04010000 str:"VM GOS[#5] addr=0xc2105000
     kworker/0:3-2151  [000] ....   265.055651: rtcpu_string: tstamp:8713548577 id:0x04010000 str:"vi5_hwinit: firmware CL2018101701 protocol vers"
     kworker/0:3-2151  [000] ....   265.055652: rtcpu_string: tstamp:8713548695 id:0x04010000 str:"on 2.2
     kworker/0:3-2151  [000] ....   265.055766: rtos_queue_send_from_isr_failed: tstamp:8713558218 queue:0x0bcb41f8
     kworker/0:3-2151  [000] ....   265.055766: rtos_queue_send_from_isr_failed: tstamp:8713558358 queue:0x0bcb8a60
     kworker/0:3-2151  [000] ....   265.055767: rtos_queue_send_from_isr_failed: tstamp:8713558499 queue:0x0bcba5e0
     kworker/0:3-2151  [000] ....   265.055768: rtos_queue_send_from_isr_failed: tstamp:8713558634 queue:0x0bcbb3a0
     kworker/0:3-2151  [000] ....   265.055768: rtos_queue_send_from_isr_failed: tstamp:8713558766 queue:0x0bcbc160
 CaptureSchedule-5881  [006] ....   265.107769: tegra_channel_open: vi-output, imx490 30-001b
 CaptureSchedule-5881  [006] ....   265.107779: tegra_channel_set_power: imx490 30-001b : 0x1
 CaptureSchedule-5881  [006] ....   265.107788: camera_common_s_power: status : 0x1
 CaptureSchedule-5881  [006] ....   265.108746: tegra_channel_set_power: 15a00000.nvcsi--8 : 0x1
 CaptureSchedule-5881  [006] ....   265.108749: csi_s_power: enable : 0x1
 CaptureSchedule-5881  [006] ....   265.110179: tegra_channel_set_stream: enable : 0x1
     kworker/0:3-2151  [000] ....   265.111046: rtos_queue_peek_from_isr_failed: tstamp:8715386388 queue:0x0bcbcf78
     kworker/0:3-2151  [000] ....   265.111086: rtos_queue_send_from_isr_failed: tstamp:8715909325 queue:0x0bcbc160
     kworker/0:3-2151  [000] ....   265.111087: rtcpu_string: tstamp:8715909734 id:0x04010000 str:"Configuring VI GoS.
     kworker/0:3-2151  [000] ....   265.111207: rtcpu_string: tstamp:8715909897 id:0x04010000 str:"VM GOS[#0] addr=0xc2100000
     kworker/0:3-2151  [000] ....   265.111283: rtcpu_string: tstamp:8715910137 id:0x04010000 str:"VM GOS[#1] addr=0xc2101000
     kworker/0:3-2151  [000] ....   265.111361: rtcpu_string: tstamp:8715910385 id:0x04010000 str:"VM GOS[#2] addr=0xc2102000
     kworker/0:3-2151  [000] ....   265.111439: rtcpu_string: tstamp:8715910604 id:0x04010000 str:"VM GOS[#3] addr=0xc2103000
     kworker/0:3-2151  [000] ....   265.111515: rtcpu_string: tstamp:8715910823 id:0x04010000 str:"VM GOS[#4] addr=0xc2104000
     kworker/0:3-2151  [000] ....   265.111594: rtcpu_string: tstamp:8715911042 id:0x04010000 str:"VM GOS[#5] addr=0xc2105000
     kworker/0:3-2151  [000] ....   265.111666: rtos_queue_send_from_isr_failed: tstamp:8715913988 queue:0x0bcb41f8
     kworker/0:3-2151  [000] ....   265.111667: rtos_queue_send_from_isr_failed: tstamp:8715914124 queue:0x0bcb8a60
     kworker/0:3-2151  [000] ....   265.111668: rtos_queue_send_from_isr_failed: tstamp:8715914263 queue:0x0bcba5e0
     kworker/0:3-2151  [000] ....   265.111668: rtos_queue_send_from_isr_failed: tstamp:8715914395 queue:0x0bcbb3a0
     kworker/0:3-2151  [000] ....   265.111669: rtos_queue_send_from_isr_failed: tstamp:8715914529 queue:0x0bcbc160
     kworker/0:3-2151  [000] ....   265.111670: rtos_queue_send_from_isr_failed: tstamp:8715919215 queue:0x0bcb41f8
     kworker/0:3-2151  [000] ....   265.111670: rtos_queue_send_from_isr_failed: tstamp:8715919347 queue:0x0bcb8a60
     kworker/0:3-2151  [000] ....   265.111671: rtos_queue_send_from_isr_failed: tstamp:8715919485 queue:0x0bcba5e0
     kworker/0:3-2151  [000] ....   265.111671: rtos_queue_send_from_isr_failed: tstamp:8715919618 queue:0x0bcbb3a0
     kworker/0:3-2151  [000] ....   265.111672: rtos_queue_send_from_isr_failed: tstamp:8715919752 queue:0x0bcbc160
 CaptureSchedule-5881  [006] ....   265.114773: tegra_channel_set_stream: 15a00000.nvcsi--8 : 0x1
 CaptureSchedule-5881  [006] ....   265.114776: csi_s_stream: enable : 0x1
 CaptureSchedule-5881  [006] ....   265.114778: tegra_channel_set_stream: imx490 30-001b : 0x1
     kworker/0:3-2151  [000] ....   265.279020: rtos_queue_peek_from_isr_failed: tstamp:8720386388 queue:0x0bcbcf78
     kworker/0:3-2151  [000] ....   265.447017: rtos_queue_peek_from_isr_failed: tstamp:8725386387 queue:0x0bcbcf78
     kworker/0:3-2151  [000] ....   265.615013: rtos_queue_peek_from_isr_failed: tstamp:8730386384 queue:0x0bcbcf78
     kworker/0:3-2151  [000] ....   265.787013: rtos_queue_peek_from_isr_failed: tstamp:8735386384 queue:0x0bcbcf78
     kworker/0:3-2151  [000] ....   265.899026: rtos_queue_peek_from_isr_failed: tstamp:8740386383 queue:0x0bcbcf78
     kworker/0:3-2151  [000] ....   266.067018: rtos_queue_peek_from_isr_failed: tstamp:8745386387 queue:0x0bcbcf78
     kworker/0:3-2151  [000] ....   266.235028: rtos_queue_peek_from_isr_failed: tstamp:8750386383 queue:0x0bcbcf78
     kworker/0:3-2151  [000] ....   266.403013: rtos_queue_peek_from_isr_failed: tstamp:8755386384 queue:0x0bcbcf78
     kworker/0:3-2151  [000] ....   266.571014: rtos_queue_peek_from_isr_failed: tstamp:8760386383 queue:0x0bcbcf78
     kworker/0:3-2151  [000] ....   266.739011: rtos_queue_peek_from_isr_failed: tstamp:8765386383 queue:0x0bcbcf78
     kworker/0:3-2151  [000] ....   266.907023: rtos_queue_peek_from_isr_failed: tstamp:8770386383 queue:0x0bcbcf78
     kworker/0:3-2151  [000] ....   267.019013: rtos_queue_peek_from_isr_failed: tstamp:8775386383 queue:0x0bcbcf78
     kworker/0:3-2151  [000] ....   267.187029: rtos_queue_peek_from_isr_failed: tstamp:8780386386 queue:0x0bcbcf78
     kworker/0:3-2151  [000] ....   267.359028: rtos_queue_peek_from_isr_failed: tstamp:8785386386 queue:0x0bcbcf78
     kworker/0:3-2151  [000] ....   267.471040: rtos_queue_send_from_isr_failed: tstamp:8788802201 queue:0x0bcb41f8
     kworker/0:3-2151  [000] ....   267.471044: rtos_queue_send_from_isr_failed: tstamp:8788802340 queue:0x0bcb8a60
     kworker/0:3-2151  [000] ....   267.471045: rtos_queue_send_from_isr_failed: tstamp:8788802479 queue:0x0bcba5e0
     kworker/0:3-2151  [000] ....   267.471046: rtos_queue_send_from_isr_failed: tstamp:8788802616 queue:0x0bcbb3a0
     kworker/0:3-2151  [000] ....   267.471048: rtos_queue_send_from_isr_failed: tstamp:8788802749 queue:0x0bcbc160
     kworker/0:3-2151  [000] ....   267.471050: rtcpu_string: tstamp:8788803546 id:0x04010000 str:"VI GOS[#0] set to VM GOS[4] base 0xc2104000
     kworker/0:3-2151  [000] ....   267.471207: rtcpu_vinotify_event: tstamp:8788817467 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:10658850368 data:0x10000000
     kworker/0:3-2151  [000] ....   267.471208: rtcpu_vinotify_event: tstamp:8788817611 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:10658876832 data:0x31000001
     kworker/0:3-2151  [000] ....   267.471208: rtcpu_vinotify_event: tstamp:8788817755 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:10658884608 data:0x07020001
     kworker/0:3-2151  [000] ....   267.527065: rtos_queue_send_from_isr_failed: tstamp:8790376898 queue:0x0bcb41f8
     kworker/0:3-2151  [000] ....   267.527067: rtos_queue_send_from_isr_failed: tstamp:8790377038 queue:0x0bcb8a60
     kworker/0:3-2151  [000] ....   267.527068: rtos_queue_send_from_isr_failed: tstamp:8790377178 queue:0x0bcba5e0
     kworker/0:3-2151  [000] ....   267.527069: rtos_queue_send_from_isr_failed: tstamp:8790377313 queue:0x0bcbb3a0
     kworker/0:3-2151  [000] ....   267.527070: rtos_queue_send_from_isr_failed: tstamp:8790377445 queue:0x0bcbc160
     kworker/0:3-2151  [000] ....   267.527071: rtos_queue_peek_from_isr_failed: tstamp:8790386379 queue:0x0bcbcf78
     kworker/0:3-2151  [000] ....   267.527072: rtos_queue_send_from_isr_failed: tstamp:8790401246 queue:0x0bcb41f8
     kworker/0:3-2151  [000] ....   267.527073: rtos_queue_send_from_isr_failed: tstamp:8790401383 queue:0x0bcb8a60
     kworker/0:3-2151  [000] ....   267.527073: rtos_queue_send_from_isr_failed: tstamp:8790401522 queue:0x0bcba5e0
     kworker/0:3-2151  [000] ....   267.527074: rtos_queue_send_from_isr_failed: tstamp:8790401654 queue:0x0bcbb3a0
     kworker/0:3-2151  [000] ....   267.527075: rtos_queue_send_from_isr_failed: tstamp:8790401786 queue:0x0bcbc160
     kworker/0:3-2151  [000] ....   267.527076: rtcpu_vinotify_event: tstamp:8790770570 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:10709225568 data:0x10000000
     kworker/0:3-2151  [000] ....   267.527077: rtcpu_vinotify_event: tstamp:8790770722 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:10709252288 data:0x31000002
     kworker/0:3-2151  [000] ....   267.695025: rtos_queue_peek_from_isr_failed: tstamp:8795386387 queue:0x0bcbcf78
     kworker/0:3-2151  [000] ....   267.863046: rtos_queue_peek_from_isr_failed: tstamp:8800386387 queue:0x0bcbcf78
     kworker/0:3-2151  [000] ....   267.975050: rtos_queue_peek_from_isr_failed: tstamp:8805386384 queue:0x0bcbcf78
     kworker/0:3-2151  [000] ....   268.143034: rtos_queue_peek_from_isr_failed: tstamp:8810386384 queue:0x0bcbcf78
     kworker/0:3-2151  [000] ....   268.311028: rtos_queue_peek_from_isr_failed: tstamp:8815386388 queue:0x0bcbcf78
     kworker/0:3-2151  [000] ....   268.479037: rtos_queue_peek_from_isr_failed: tstamp:8820386388 queue:0x0bcbcf78
     kworker/0:3-2151  [000] ....   268.647026: rtos_queue_peek_from_isr_failed: tstamp:8825386386 queue:0x0bcbcf78
     kworker/0:3-2151  [000] ....   268.815030: rtos_queue_peek_from_isr_failed: tstamp:8830386387 queue:0x0bcbcf78
 CaptureSchedule-5881  [002] ....   268.955954: tegra_channel_set_stream: enable : 0x0
 CaptureSchedule-5881  [002] ....   268.955958: tegra_channel_set_stream: imx490 30-001b : 0x0
     kworker/0:3-2151  [000] ....   268.983056: rtos_queue_peek_from_isr_failed: tstamp:8835386386 queue:0x0bcbcf78
     kworker/0:3-2151  [000] ....   269.095013: rtos_queue_peek_from_isr_failed: tstamp:8840386383 queue:0x0bcbcf78
 CaptureSchedule-5881  [000] ....   269.243094: tegra_channel_set_stream: 15a00000.nvcsi--8 : 0x0
 CaptureSchedule-5881  [000] ....   269.243099: csi_s_stream: enable : 0x0
 CaptureSchedule-5881  [000] ....   269.245068: tegra_channel_set_stream: enable : 0x1
 CaptureSchedule-5881  [000] ....   269.246923: tegra_channel_set_stream: 15a00000.nvcsi--8 : 0x1
 CaptureSchedule-5881  [000] ....   269.246924: csi_s_stream: enable : 0x1
 CaptureSchedule-5881  [000] ....   269.246925: tegra_channel_set_stream: imx490 30-001b : 0x1
     kworker/0:3-2151  [000] ....   269.263018: rtos_queue_peek_from_isr_failed: tstamp:8845386383 queue:0x0bcbcf78
     kworker/0:3-2151  [000] ....   272.967021: rtos_queue_peek_from_isr_failed: tstamp:8960386387 queue:0x0bcbcf78
 CaptureSchedule-5881  [001] ....   273.091105: tegra_channel_set_stream: enable : 0x0
 CaptureSchedule-5881  [001] ....   273.091109: tegra_channel_set_stream: imx490 30-001b : 0x0
 CaptureSchedule-5881  [004] ....   273.111065: tegra_channel_set_stream: 15a00000.nvcsi--8 : 0x0
 CaptureSchedule-5881  [004] ....   273.111069: csi_s_stream: enable : 0x0
     kworker/0:3-2151  [000] ....   273.135740: rtos_queue_peek_from_isr_failed: tstamp:8965386386 queue:0x0bcbcf78
     kworker/0:3-2151  [000] ....   273.308180: rtos_queue_peek_from_isr_failed: tstamp:8970386384 queue:0x0bcbcf78
 CaptureSchedule-5881  [001] ....   273.364639: tegra_channel_set_stream: enable : 0x1
 CaptureSchedule-5881  [001] ....   273.366344: tegra_channel_set_stream: 15a00000.nvcsi--8 : 0x1
 CaptureSchedule-5881  [001] ....   273.366347: csi_s_stream: enable : 0x1
 CaptureSchedule-5881  [001] ....   273.366348: tegra_channel_set_stream: imx490 30-001b : 0x1
     kworker/0:3-2151  [000] ....   273.419031: rtos_queue_peek_from_isr_failed: tstamp:8975386382 queue:0x0bcbcf78
     kworker/0:3-2151  [000] ....   273.587021: rtos_queue_peek_from_isr_failed: tstamp:8980386388 queue:0x0bcbcf78
     kworker/0:3-2151  [000] ....   273.755021: rtos_queue_peek_from_isr_failed: tstamp:8985386387 queue:0x0bcbcf78
     kworker/0:3-2151  [000] ....   273.923014: rtos_queue_peek_from_isr_failed: tstamp:8990386387 queue:0x0bcbcf78
     kworker/0:3-2151  [000] ....   274.091031: rtos_queue_peek_from_isr_failed: tstamp:8995386384 queue:0x0bcbcf78
     kworker/0:3-2151  [000] ....   274.259030: rtos_queue_peek_from_isr_failed: tstamp:9000386388 queue:0x0bcbcf78
     kworker/0:3-2151  [000] ....   274.427019: rtos_queue_peek_from_isr_failed: tstamp:9005386388 queue:0x0bcbcf78
output from dmesg:
[  264.775095] [RCE] Configuring ISP GoS.
[  264.775205] [RCE]   VM GOS[#0] addr=0xc2100000
[  264.775278] [RCE]   VM GOS[#1] addr=0xc2101000
[  264.775369] [RCE]   VM GOS[#2] addr=0xc2102000
[  264.775443] [RCE]   VM GOS[#3] addr=0xc2103000
[  264.775520] [RCE]   VM GOS[#4] addr=0xc2104000
[  264.775592] [RCE]   VM GOS[#5] addr=0xc2105000
[  265.055092] [RCE] Configuring VI GoS.
[  265.055201] [RCE] VM GOS[#0] addr=0xc2100000
[  265.055280] [RCE] VM GOS[#1] addr=0xc2101000
[  265.055353] [RCE] VM GOS[#2] addr=0xc2102000
[  265.055435] [RCE] VM GOS[#3] addr=0xc2103000
[  265.055507] [RCE] VM GOS[#4] addr=0xc2104000
[  265.055580] [RCE] VM GOS[#5] addr=0xc2105000
[  265.055653] [RCE] vi5_hwinit: firmware CL2018101701 protocol version 2.2
[  265.108651] Powering on IMX490
[  265.111098] [RCE] Configuring VI GoS.
[  265.111209] [RCE] VM GOS[#0] addr=0xc2100000
[  265.111284] [RCE] VM GOS[#1] addr=0xc2101000
[  265.111362] [RCE] VM GOS[#2] addr=0xc2102000
[  265.111440] [RCE] VM GOS[#3] addr=0xc2103000
[  265.111516] [RCE] VM GOS[#4] addr=0xc2104000
[  265.111595] [RCE] VM GOS[#5] addr=0xc2105000
[  265.114787] imx490_set_mode to 0
[  265.114876] imx490_write_table
[  267.179176] imx490_start_streaming
[  267.179278] imx490_write_table
[  267.439042] 	enabling framesync
[  267.440790] 	IMX490 stream started.
[  267.471059] [RCE] VI GOS[#0] set to VM GOS[4] base 0xc2104000
[  268.955062] tegra194-vi5 15c10000.vi: no reply from camera processor
[  268.955212] tegra194-vi5 15c10000.vi: vi capture get status failed
[  268.955550] fence timeout on [ffffffc7d8666600] after 1500ms
[  268.955660] name=[nvhost_sync:36], current value=0 waiting value=1
[  268.955774] ---- mlocks ----
[  268.955909] ---- syncpts ----
[  268.955971] imx490_stop_streaming
[  268.955992] id 18 (15340000.vic_nvargus-daemon_0) min 233 max 233 refs 1 (previous client : gv11b_511)
[  268.955995] id 19 (15340000.vic_gst-launch-1.0_0) min 3004 max 3004 refs 1 (previous client : 15340000.vic_gst-launch-1.0_0)
[  268.955999] id 21 (154c0000.nvenc_gst-launch-1.0_0) min 2000 max 2000 refs 1 (previous client : 154c0000.nvenc_gst-launch-1.0_0)
[  268.956009] id 29 (gv11b_510_user) min 30 max 0 refs 1 (previous client : )
[  268.956022] id 39 (gv11b_502) min 9 max 9 refs 1 (previous client : gv11b_506)
[  268.956025] id 40 (gv11b_504) min 10 max 10 refs 1 (previous client : gv11b_505)
[  268.956027] id 41 (gv11b_503) min 9 max 9 refs 1 (previous client : gv11b_504)
[  268.956030] id 42 (gv11b_506) min 9 max 9 refs 1 (previous client : gv11b_503)
[  268.956034] id 43 (gv11b_505) min 9 max 9 refs 1 (previous client : gv11b_502)
[  268.956650] ---- channels ----
[  268.956672]
               channel 2 - 15820000.se
[  268.956673] NvHost basic channel registers:
[  268.956677] CMDFIFO_STAT_0:  00002040
[  268.956680] CMDFIFO_RDATA_0: 680c0000
[  268.956684] CMDP_OFFSET_0:   00000000
[  268.956687] CMDP_CLASS_0:    00000000
[  268.956689] CHANNELSTAT_0:   00000000
[  268.956690] The CDMA sync queue is empty.
[  268.956694]
               channel 3 - 15830000.se
[  268.956695] NvHost basic channel registers:
[  268.956697] CMDFIFO_STAT_0:  00002040
[  268.956699] CMDFIFO_RDATA_0: 10805470
[  268.956703] CMDP_OFFSET_0:   00000000
[  268.956704] CMDP_CLASS_0:    00000000
[  268.956706] CHANNELSTAT_0:   00000000
[  268.956707] The CDMA sync queue is empty.
[  268.956712]
               channel 4 - 15840000.se
[  268.956713] NvHost basic channel registers:
[  268.956715] CMDFIFO_STAT_0:  00002040
[  268.956716] CMDFIFO_RDATA_0: 00104208
[  268.956719] CMDP_OFFSET_0:   00000000
[  268.956721] CMDP_CLASS_0:    00000000
[  268.956723] CHANNELSTAT_0:   00000000
[  268.956724] The CDMA sync queue is empty.
[  268.956729]
               ---- host general irq ----
[  268.956731] sync_intc0mask = 0x00000001
[  268.956733] sync_intmask = 0x50000003
[  268.956734]
               ---- host syncpt irq mask ----
[  268.956736]
               ---- host syncpt irq status ----
[  268.956739] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[  268.956741] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[  268.956744] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[  268.956746] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[  268.956748] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[  268.956751] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[  268.956758] syncpt_thresh_cpu0_int_status(6) = 0x00000000
[  268.956762] syncpt_thresh_cpu0_int_status(7) = 0x00000000
[  268.956764] syncpt_thresh_cpu0_int_status(8) = 0x00000000
[  268.956766] syncpt_thresh_cpu0_int_status(9) = 0x00000000
[  268.956768] syncpt_thresh_cpu0_int_status(10) = 0x00000000
[  268.956770] syncpt_thresh_cpu0_int_status(11) = 0x00000000
[  268.956772] syncpt_thresh_cpu0_int_status(12) = 0x00000000
[  268.956775] syncpt_thresh_cpu0_int_status(13) = 0x00000000
[  268.956777] syncpt_thresh_cpu0_int_status(14) = 0x00000000
[  268.956778] syncpt_thresh_cpu0_int_status(15) = 0x00000000
[  268.956781] syncpt_thresh_cpu0_int_status(16) = 0x00000000
[  268.956783] syncpt_thresh_cpu0_int_status(17) = 0x00000000
[  268.956786] syncpt_thresh_cpu0_int_status(18) = 0x00000000
[  268.956788] syncpt_thresh_cpu0_int_status(19) = 0x00000000
[  268.956790] syncpt_thresh_cpu0_int_status(20) = 0x00000000
[  268.956793] syncpt_thresh_cpu0_int_status(21) = 0x00000000
[  269.231252] imx490_write_table
[  269.246939] imx490_set_mode to 0
[  269.247059] imx490_write_table
[  271.305392] imx490_start_streaming
[  271.305505] imx490_write_table
[  271.563035] 	enabling framesync
[  271.564760] 	IMX490 stream started.
[  273.083087] tegra194-vi5 15c10000.vi: no reply from camera processor
[  273.083247] tegra194-vi5 15c10000.vi: vi capture get status failed
[  273.083481] fence timeout on [ffffffc7d85d20c0] after 1500ms
[  273.083586] name=[nvhost_sync:36], current value=0 waiting value=10
[  273.083697] ---- mlocks ----
[  273.083810] ---- syncpts ----
[  273.083886] id 18 (15340000.vic_nvargus-daemon_0) min 233 max 233 refs 1 (previous client : gv11b_511)
[  273.084037] id 19 (15340000.vic_gst-launch-1.0_0) min 3004 max 3004 refs 1 (previous client : 15340000.vic_gst-launch-1.0_0)
[  273.084223] id 21 (154c0000.nvenc_gst-launch-1.0_0) min 2000 max 2000 refs 1 (previous client : 154c0000.nvenc_gst-launch-1.0_0)
[  273.084414] id 29 (gv11b_510_user) min 30 max 0 refs 1 (previous client : )
[  273.084536] id 39 (gv11b_502) min 9 max 9 refs 1 (previous client : gv11b_506)
[  273.085080] id 40 (gv11b_504) min 10 max 10 refs 1 (previous client : gv11b_505)
[  273.085658] id 41 (gv11b_503) min 9 max 9 refs 1 (previous client : gv11b_504)
[  273.086215] id 42 (gv11b_506) min 9 max 9 refs 1 (previous client : gv11b_503)
[  273.091143] imx490_stop_streaming
[  273.091146] imx490_write_table
[  273.098792] id 43 (gv11b_505) min 9 max 9 refs 1 (previous client : gv11b_502)
[  273.107625] ---- channels ----
[  273.110545]
[  273.117361] NvHost basic channel registers:
[  273.121554] CMDFIFO_STAT_0:  00002040
[  273.125058] CMDFIFO_RDATA_0: 680c0000
[  273.128726] CMDP_OFFSET_0:   00000000
[  273.132318] CMDP_CLASS_0:    00000000
[  273.135755] CHANNELSTAT_0:   00000000
[  273.139581] The CDMA sync queue is empty.
[  273.144907]
[  273.151655] NvHost basic channel registers:
[  273.155856] CMDFIFO_STAT_0:  00002040
[  273.159177] CMDFIFO_RDATA_0: 10805470
[  273.162759] CMDP_OFFSET_0:   00000000
[  273.166614] CMDP_CLASS_0:    00000000
[  273.170294] CHANNELSTAT_0:   00000000
[  273.173788] The CDMA sync queue is empty.
[  273.179481]
[  273.185680] NvHost basic channel registers:
[  273.189884] CMDFIFO_STAT_0:  00002040
[  273.193571] CMDFIFO_RDATA_0: 00104208
[  273.197247] CMDP_OFFSET_0:   00000000
[  273.201166] CMDP_CLASS_0:    00000000
[  273.204583] CHANNELSTAT_0:   00000000
[  273.208536] The CDMA sync queue is empty.
[  273.214029]
[  273.220772] sync_intc0mask = 0x00000001
[  273.224702] sync_intmask = 0x50000003
[  273.228379]
[  273.235465]
[  273.242818] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[  273.248074] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[  273.253493] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[  273.258748] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[  273.264518] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[  273.270029] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[  273.275541] syncpt_thresh_cpu0_int_status(6) = 0x00000000
[  273.280788] syncpt_thresh_cpu0_int_status(7) = 0x00000000
[  273.286304] syncpt_thresh_cpu0_int_status(8) = 0x00000000
[  273.291640] syncpt_thresh_cpu0_int_status(9) = 0x00000000
[  273.297152] syncpt_thresh_cpu0_int_status(10) = 0x00000000
[  273.302667] syncpt_thresh_cpu0_int_status(11) = 0x00000000
[  273.308192] syncpt_thresh_cpu0_int_status(12) = 0x00000000
[  273.313602] syncpt_thresh_cpu0_int_status(13) = 0x00000000
[  273.318771] syncpt_thresh_cpu0_int_status(14) = 0x00000000
[  273.324456] syncpt_thresh_cpu0_int_status(15) = 0x00000000
[  273.329879] syncpt_thresh_cpu0_int_status(16) = 0x00000000
[  273.335050] syncpt_thresh_cpu0_int_status(17) = 0x00000000
[  273.340472] syncpt_thresh_cpu0_int_status(18) = 0x00000000
[  273.345893] syncpt_thresh_cpu0_int_status(19) = 0x00000000
[  273.351579] syncpt_thresh_cpu0_int_status(20) = 0x00000000
[  273.357004] syncpt_thresh_cpu0_int_status(21) = 0x00000000
[  273.366359] imx490_set_mode to 0
[  273.366474] imx490_write_table
[  275.429874] imx490_start_streaming
[  275.429986] imx490_write_table
[  275.687027] 	enabling framesync
[  275.688745] 	IMX490 stream started.
[  277.211057] tegra194-vi5 15c10000.vi: no reply from camera processor
[  277.211065] fence timeout on [ffffffc7d657ca80] after 1500ms
[  277.211075] name=[nvhost_sync:36], current value=0 waiting value=16
[  277.211082] ---- mlocks ----
[  277.211116] ---- syncpts ----
[  277.211141] id 18 (15340000.vic_nvargus-daemon_0) min 233 max 233 refs 1 (previous client : gv11b_511)
[  277.211145] id 19 (15340000.vic_gst-launch-1.0_0) min 3004 max 3004 refs 1 (previous client : 15340000.vic_gst-launch-1.0_0)
[  277.211149] id 21 (154c0000.nvenc_gst-launch-1.0_0) min 2000 max 2000 refs 1 (previous client : 154c0000.nvenc_gst-launch-1.0_0)
[  277.211159] id 29 (gv11b_510_user) min 30 max 0 refs 1 (previous client : )
[  277.211169] id 39 (gv11b_502) min 9 max 9 refs 1 (previous client : gv11b_506)
[  277.211172] id 40 (gv11b_504) min 10 max 10 refs 1 (previous client : gv11b_505)
[  277.211175] id 41 (gv11b_503) min 9 max 9 refs 1 (previous client : gv11b_504)
[  277.211179] id 42 (gv11b_506) min 9 max 9 refs 1 (previous client : gv11b_503)
[  277.211200] id 43 (gv11b_505) min 9 max 9 refs 1 (previous client : gv11b_502)
[  277.211792] ---- channels ----
[  277.211812]
[  277.211814] NvHost basic channel registers:
[  277.211818] CMDFIFO_STAT_0:  00002040
[  277.211820] CMDFIFO_RDATA_0: 680c0000
[  277.211824] CMDP_OFFSET_0:   00000000
[  277.211826] CMDP_CLASS_0:    00000000
[  277.211828] CHANNELSTAT_0:   00000000
[  277.211830] The CDMA sync queue is empty.
[  277.211833]
[  277.211834] NvHost basic channel registers:
[  277.211837] CMDFIFO_STAT_0:  00002040
[  277.211839] CMDFIFO_RDATA_0: 10805470
[  277.211842] CMDP_OFFSET_0:   00000000
[  277.211843] CMDP_CLASS_0:    00000000
[  277.211845] CHANNELSTAT_0:   00000000
[  277.211846] The CDMA sync queue is empty.
[  277.211850]
[  277.211851] NvHost basic channel registers:
[  277.211852] CMDFIFO_STAT_0:  00002040
[  277.211854] CMDFIFO_RDATA_0: 00104208
[  277.211857] CMDP_OFFSET_0:   00000000
[  277.211858] CMDP_CLASS_0:    00000000
[  277.211860] CHANNELSTAT_0:   00000000
[  277.211861] The CDMA sync queue is empty.
[  277.211866]
[  277.211868] sync_intc0mask = 0x00000001
[  277.211870] sync_intmask = 0x50000003
[  277.211871]
[  277.211872]
[  277.211875] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[  277.211877] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[  277.211879] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[  277.211882] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[  277.211884] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[  277.211886] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[  277.211888] syncpt_thresh_cpu0_int_status(6) = 0x00000000
[  277.211890] syncpt_thresh_cpu0_int_status(7) = 0x00000000
[  277.211892] syncpt_thresh_cpu0_int_status(8) = 0x00000000
[  277.211894] syncpt_thresh_cpu0_int_status(9) = 0x00000000
[  277.211896] syncpt_thresh_cpu0_int_status(10) = 0x00000000
[  277.211898] syncpt_thresh_cpu0_int_status(11) = 0x00000000
[  277.211900] syncpt_thresh_cpu0_int_status(12) = 0x00000000
[  277.211901] syncpt_thresh_cpu0_int_status(13) = 0x00000000
[  277.211903] syncpt_thresh_cpu0_int_status(14) = 0x00000000
[  277.211905] syncpt_thresh_cpu0_int_status(15) = 0x00000000
[  277.211907] syncpt_thresh_cpu0_int_status(16) = 0x00000000
[  277.211909] syncpt_thresh_cpu0_int_status(17) = 0x00000000
[  277.211911] syncpt_thresh_cpu0_int_status(18) = 0x00000000
[  277.211912] syncpt_thresh_cpu0_int_status(19) = 0x00000000
[  277.211914] syncpt_thresh_cpu0_int_status(20) = 0x00000000
[  277.211916] syncpt_thresh_cpu0_int_status(21) = 0x00000000
[  277.477978] tegra194-vi5 15c10000.vi: vi capture get status failed
[  278.715062] fence timeout on [ffffffc77dfeb600] after 1500ms
[  278.715211] name=[nvhost_sync:36], current value=0 waiting value=22
[  278.715332] ---- mlocks ----
[  278.715447] ---- syncpts ----
[  278.715522] id 18 (15340000.vic_nvargus-daemon_0) min 233 max 233 refs 1 (previous client : gv11b_511)
[  278.715688] id 19 (15340000.vic_gst-launch-1.0_0) min 3004 max 3004 refs 1 (previous client : 15340000.vic_gst-launch-1.0_0)
[  278.715866] id 21 (154c0000.nvenc_gst-launch-1.0_0) min 2000 max 2000 refs 1 (previous client : 154c0000.nvenc_gst-launch-1.0_0)
[  278.716055] id 29 (gv11b_510_user) min 30 max 0 refs 1 (previous client : )
[  278.716183] id 39 (gv11b_502) min 9 max 9 refs 1 (previous client : gv11b_506)
[  278.716312] id 40 (gv11b_504) min 10 max 10 refs 1 (previous client : gv11b_505)
[  278.716684] id 41 (gv11b_503) min 9 max 9 refs 1 (previous client : gv11b_504)
[  278.717229] id 42 (gv11b_506) min 9 max 9 refs 1 (previous client : gv11b_503)
[  278.717802] id 43 (gv11b_505) min 9 max 9 refs 1 (previous client : gv11b_502)
[  278.719478] fence timeout on [ffffffc77dfebc00] after 1500ms
[  278.719482] name=[nvhost_sync:36], current value=0 waiting value=27
[  278.719486] ---- mlocks ----
[  278.719517] ---- syncpts ----
[  278.719539] id 18 (15340000.vic_nvargus-daemon_0) min 233 max 233 refs 1 (previous client : gv11b_511)
[  278.719542] id 19 (15340000.vic_gst-launch-1.0_0) min 3004 max 3004 refs 1 (previous client : 15340000.vic_gst-launch-1.0_0)
[  278.719546] id 21 (154c0000.nvenc_gst-launch-1.0_0) min 2000 max 2000 refs 1 (previous client : 154c0000.nvenc_gst-launch-1.0_0)
[  278.719572] id 29 (gv11b_510_user) min 30 max 0 refs 1 (previous client : )
[  278.719582] id 39 (gv11b_502) min 9 max 9 refs 1 (previous client : gv11b_506)
[  278.719584] id 40 (gv11b_504) min 10 max 10 refs 1 (previous client : gv11b_505)
[  278.719586] id 41 (gv11b_503) min 9 max 9 refs 1 (previous client : gv11b_504)
[  278.719589] id 42 (gv11b_506) min 9 max 9 refs 1 (previous client : gv11b_503)
[  278.719591] id 43 (gv11b_505) min 9 max 9 refs 1 (previous client : gv11b_502)
[  278.720152] ---- channels ----
[  278.720170]
[  278.720172] NvHost basic channel registers:
[  278.720175] CMDFIFO_STAT_0:  00002040
[  278.720177] CMDFIFO_RDATA_0: 680c0000
[  278.720181] CMDP_OFFSET_0:   00000000
[  278.720183] CMDP_CLASS_0:    00000000
[  278.720185] CHANNELSTAT_0:   00000000
[  278.720186] The CDMA sync queue is empty.
[  278.720190]
[  278.720191] NvHost basic channel registers:
[  278.720193] CMDFIFO_STAT_0:  00002040
[  278.720195] CMDFIFO_RDATA_0: 10805470
[  278.720198] CMDP_OFFSET_0:   00000000
[  278.720199] CMDP_CLASS_0:    00000000
[  278.720201] CHANNELSTAT_0:   00000000
[  278.720202] The CDMA sync queue is empty.
[  278.720205]
[  278.720206] NvHost basic channel registers:
[  278.720208] CMDFIFO_STAT_0:  00002040
[  278.720209] CMDFIFO_RDATA_0: 00104208
[  278.720212] CMDP_OFFSET_0:   00000000
[  278.720213] CMDP_CLASS_0:    00000000
[  278.720215] CHANNELSTAT_0:   00000000
[  278.720216] The CDMA sync queue is empty.
[  278.720221]
[  278.720223] sync_intc0mask = 0x00000001
[  278.720225] sync_intmask = 0x50000003
[  278.720225]
[  278.720226]
[  278.720229] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[  278.720231] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[  278.720233] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[  278.720235] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[  278.720237] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[  278.720239] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[  278.720241] syncpt_thresh_cpu0_int_status(6) = 0x00000000
[  278.720244] syncpt_thresh_cpu0_int_status(7) = 0x00000000
[  278.720245] syncpt_thresh_cpu0_int_status(8) = 0x00000000
[  278.720247] syncpt_thresh_cpu0_int_status(9) = 0x00000000
[  278.720249] syncpt_thresh_cpu0_int_status(10) = 0x00000000
[  278.720251] syncpt_thresh_cpu0_int_status(11) = 0x00000000
[  278.720252] syncpt_thresh_cpu0_int_status(12) = 0x00000000
[  278.720254] syncpt_thresh_cpu0_int_status(13) = 0x00000000
[  278.720256] syncpt_thresh_cpu0_int_status(14) = 0x00000000
[  278.720257] syncpt_thresh_cpu0_int_status(15) = 0x00000000
[  278.720259] syncpt_thresh_cpu0_int_status(16) = 0x00000000
[  278.720261] syncpt_thresh_cpu0_int_status(17) = 0x00000000
[  278.720263] syncpt_thresh_cpu0_int_status(18) = 0x00000000
[  278.720264] syncpt_thresh_cpu0_int_status(19) = 0x00000000
[  278.720266] syncpt_thresh_cpu0_int_status(20) = 0x00000000
[  278.720268] syncpt_thresh_cpu0_int_status(21) = 0x00000000
[  279.072002] ---- channels ----
[  279.075083]
[  279.081630] NvHost basic channel registers:
[  279.085839] CMDFIFO_STAT_0:  00002040
[  279.089505] CMDFIFO_RDATA_0: 680c0000
[  279.093182] CMDP_OFFSET_0:   00000000
[  279.096854] CMDP_CLASS_0:    00000000
[  279.100532] CHANNELSTAT_0:   00000000
[  279.103942] The CDMA sync queue is empty.
[  279.109718]
[  279.116541] NvHost basic channel registers:
[  279.120742] CMDFIFO_STAT_0:  00002040
[  279.124418] CMDFIFO_RDATA_0: 10805470
[  279.127832] CMDP_OFFSET_0:   00000000
[  279.131768] CMDP_CLASS_0:    00000000
[  279.135180] CHANNELSTAT_0:   00000000
[  279.139126] The CDMA sync queue is empty.
[  279.144799]
[  279.151281] NvHost basic channel registers:
[  279.155480] CMDFIFO_STAT_0:  00002040
[  279.159155] CMDFIFO_RDATA_0: 00104208
[  279.162567] CMDP_OFFSET_0:   00000000
[  279.166246] CMDP_CLASS_0:    00000000
[  279.169919] CHANNELSTAT_0:   00000000
[  279.173595] The CDMA sync queue is empty.
[  279.179109]
[  279.186104] sync_intc0mask = 0x00000001
[  279.190039] sync_intmask = 0x50000003
[  279.193712]
[  279.200559]
[  279.208189] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[  279.213168] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[  279.218840] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[  279.224398] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[  279.229926] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[  279.235384] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[  279.240886] syncpt_thresh_cpu0_int_status(6) = 0x00000000
[  279.246136] syncpt_thresh_cpu0_int_status(7) = 0x00000000
[  279.251386] syncpt_thresh_cpu0_int_status(8) = 0x00000000
[  279.256739] syncpt_thresh_cpu0_int_status(9) = 0x00000000
[  279.262498] syncpt_thresh_cpu0_int_status(10) = 0x00000000
[  279.268014] syncpt_thresh_cpu0_int_status(11) = 0x00000000
[  279.273520] syncpt_thresh_cpu0_int_status(12) = 0x00000000
[  279.278945] syncpt_thresh_cpu0_int_status(13) = 0x00000000
[  279.284112] syncpt_thresh_cpu0_int_status(14) = 0x00000000
[  279.289811] syncpt_thresh_cpu0_int_status(15) = 0x00000000
[  279.295286] syncpt_thresh_cpu0_int_status(16) = 0x00000000
[  279.300691] syncpt_thresh_cpu0_int_status(17) = 0x00000000
[  279.305849] syncpt_thresh_cpu0_int_status(18) = 0x00000000
[  279.311534] syncpt_thresh_cpu0_int_status(19) = 0x00000000
[  279.316932] syncpt_thresh_cpu0_int_status(20) = 0x00000000
[  279.322358] syncpt_thresh_cpu0_int_status(21) = 0x00000000
Please try v4l2-ctl commadn and check if you can reproduce the same issue. It looks to be an issue in the sensor driver that does not handle termination properly.
@DaneLLL I can run this command twice with no errors
v4l2-ctl -d /dev/video0 --set-fmt-video=width=2880,height=1860,pixelformat=RG12 --stream-count=1000 --stream-mmap --stream-to=csi.raw --verbose
So it may be specific to going through Argus stack. Please help try jetson_multimedia_api sample:
/usr/src/jetson_multimedia_api/samples/10_camera_recording
Would like to make sure it is not specific to gstreamer.
@DaneLLL Running this gives the following output:
root@DEVJACK:/usr/src/jetson_multimedia_api/samples/10_camera_recording# ./camera_recording
PRODUCER: Creating output stream
PRODUCER: Launching consumer thread
Failed to query video capabilities: Inappropriate ioctl for device
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
875967048
842091865
create video encoder return true
H264: Profile = 100, Level = 50
PRODUCER: Starting repeat capture requests.
Segmentation fault
from dmesg:
[  158.186784] [RCE] Configuring ISP GoS.
[  158.186896] [RCE]   VM GOS[#0] addr=0xc2100000
[  158.186991] [RCE]   VM GOS[#1] addr=0xc2101000
[  158.187069] [RCE]   VM GOS[#2] addr=0xc2102000
[  158.187143] [RCE]   VM GOS[#3] addr=0xc2103000
[  158.187230] [RCE]   VM GOS[#4] addr=0xc2104000
[  158.187333] [RCE]   VM GOS[#5] addr=0xc2105000
[  158.187417] [RCE] WARNING: t194/isp5.c:901 [config_channel] "All error notifications not enabled: correctable=0x00 uncorrectable=0x00"
[  158.336481] Powering on IMX490
[  158.338154] Powering on IMX490
[  158.340631] Powering on IMX490
[  158.341899] Powering on IMX490
[  158.345707] Powering on IMX490
[  158.347788] Powering on IMX490
[  158.349054] Powering on IMX490
[  158.350295] Powering on IMX490
[  158.354026] Powering on IMX490
[  158.355426] Powering on IMX490
[  158.356642] Powering on IMX490
[  158.357830] Powering on IMX490
[  158.359536] Powering on IMX490
[  158.360767] Powering on IMX490
[  158.361976] Powering on IMX490
[  158.363154] Powering on IMX490
[  158.376486] Powering on IMX490
[  158.377665] Powering on IMX490
[  158.380192] Powering on IMX490
[  158.381437] Powering on IMX490
[  158.382630] Powering on IMX490
[  158.384213] Powering on IMX490
[  158.385493] Powering on IMX490
[  158.388041] Powering on IMX490
[  158.390055] Powering on IMX490
[  158.392098] Powering on IMX490
[  158.433998] Powering on IMX490
[  158.435563] Powering on IMX490
[  158.436793] Powering on IMX490
[  158.437982] Powering on IMX490
[  158.439736] Powering on IMX490
[  158.440940] Powering on IMX490
[  158.443433] Powering on IMX490
[  158.444633] Powering on IMX490
[  158.446051] Powering on IMX490
[  158.470848] Powering on IMX490
[  158.472150] Powering on IMX490
[  158.473376] Powering on IMX490
[  158.474594] Powering on IMX490
[  158.477648] Powering on IMX490
[  158.479238] Powering on IMX490
[  158.480454] Powering on IMX490
[  158.481692] Powering on IMX490
[  158.502026] Powering on IMX490
[  158.503686] Powering on IMX490
[  158.504929] Powering on IMX490
[  158.506104] Powering on IMX490
[  158.507651] Powering on IMX490
[  158.508830] Powering on IMX490
[  158.510063] Powering on IMX490
[  158.528502] Powering on IMX490
[  158.530534] Powering on IMX490
[  158.532355] Powering on IMX490
[  158.535687] Powering on IMX490
[  158.536890] Powering on IMX490
[  158.538129] Powering on IMX490
[  158.556640] Powering on IMX490
[  158.557843] Powering on IMX490
[  158.559008] Powering on IMX490
[  158.560205] Powering on IMX490
[  158.561507] Powering on IMX490
[  158.578021] Powering on IMX490
[  158.579427] Powering on IMX490
[  158.580643] Powering on IMX490
[  158.581977] Powering on IMX490
[  158.598111] Powering on IMX490
[  158.599699] Powering on IMX490
[  158.601311] Powering on IMX490
[  158.634745] [RCE] Configuring VI GoS.
[  158.634864] [RCE] VM GOS[#0] addr=0xc2100000
[  158.634939] [RCE] VM GOS[#1] addr=0xc2101000
[  158.635012] [RCE] VM GOS[#2] addr=0xc2102000
[  158.635085] [RCE] VM GOS[#3] addr=0xc2103000
[  158.635161] [RCE] VM GOS[#4] addr=0xc2104000
[  158.635248] [RCE] VM GOS[#5] addr=0xc2105000
[  158.635332] [RCE] vi5_hwinit: firmware CL2018101701 protocol version 2.2
[  158.640768] nvmap_alloc_handle: PID 4839: camera_recordin: WARNING: All NvMap Allocations must have a tag to identify the subsystem allocating memory.Please pass the tag to the API call NvRmMemHanldeAllocAttr() or relevant.
[  158.810956] (NULL device *): nvhost_channelctl: invalid cmd 0x80685600
from trace
root@DEVJACK:~# cat /sys/kernel/debug/tracing/trace
# tracer: nop
# entries-in-buffer/entries-written: 868/868   #P:8
#                              _-----=> irqs-off
#                             / _----=> need-resched
#                            | / _---=> hardirq/softirq
#                            || / _--=> preempt-depth
#                            ||| /     delay
#           TASK-PID   CPU#  ||||    TIMESTAMP  FUNCTION
     kworker/0:1-817   [000] ....   146.902704: rtos_queue_peek_from_isr_failed: tstamp:5019490759 queue:0x0bcbcf78
     kworker/0:1-817   [000] ....   147.070704: rtos_queue_peek_from_isr_failed: tstamp:5024490759 queue:0x0bcbcf78
     kworker/0:1-817   [000] ....   147.182700: rtos_queue_peek_from_isr_failed: tstamp:5029490763 queue:0x0bcbcf78
     kworker/0:1-817   [000] ....   147.354710: rtos_queue_peek_from_isr_failed: tstamp:5034490758 queue:0x0bcbcf78
     kworker/0:1-817   [000] ....   147.522704: rtos_queue_peek_from_isr_failed: tstamp:5039490758 queue:0x0bcbcf78
     kworker/0:1-817   [000] ....   147.690700: rtos_queue_peek_from_isr_failed: tstamp:5044490759 queue:0x0bcbcf78
     kworker/0:1-817   [000] ....   147.858721: rtos_queue_peek_from_isr_failed: tstamp:5049490761 queue:0x0bcbcf78
     kworker/0:1-817   [000] ....   148.026707: rtos_queue_peek_from_isr_failed: tstamp:5054490761 queue:0x0bcbcf78
     kworker/0:1-817   [000] ....   148.138694: rtos_queue_peek_from_isr_failed: tstamp:5059490758 queue:0x0bcbcf78
     kworker/0:1-817   [000] ....   148.306727: rtos_queue_peek_from_isr_failed: tstamp:5064490759 queue:0x0bcbcf78
     kworker/0:1-817   [000] ....   148.474713: rtos_queue_peek_from_isr_failed: tstamp:5069490758 queue:0x0bcbcf78
     kworker/0:1-817   [000] ....   148.642733: rtos_queue_peek_from_isr_failed: tstamp:5074490759 queue:0x0bcbcf78
     kworker/0:1-817   [000] ....   148.810701: rtos_queue_peek_from_isr_failed: tstamp:5079490755 queue:0x0bcbcf78
     kworker/0:1-817   [000] ....   148.978729: rtos_queue_peek_from_isr_failed: tstamp:5084490758 queue:0x0bcbcf78
     kworker/0:1-817   [000] ....   149.146708: rtos_queue_peek_from_isr_failed: tstamp:5089490758 queue:0x0bcbcf78
     kworker/0:1-817   [000] ....   149.258720: rtos_queue_peek_from_isr_failed: tstamp:5094490759 queue:0x0bcbcf78
     kworker/0:1-817   [000] ....   149.430720: rtos_queue_peek_from_isr_failed: tstamp:5099490758 queue:0x0bcbcf78
     kworker/0:1-817   [000] ....   149.598710: rtos_queue_peek_from_isr_failed: tstamp:5104490758 queue:0x0bcbcf78
     kworker/0:1-817   [000] ....   149.766706: rtos_queue_peek_from_isr_failed: tstamp:5109490758 queue:0x0bcbcf78
     kworker/0:1-817   [000] ....   149.934742: rtos_queue_peek_from_isr_failed: tstamp:5114490757 queue:0x0bcbcf78
     kworker/0:1-817   [000] ....   150.102704: rtos_queue_peek_from_isr_failed: tstamp:5119490770 queue:0x0bcbcf78
     kworker/0:1-817   [000] ....   150.270702: rtos_queue_peek_from_isr_failed: tstamp:5124490758 queue:0x0bcbcf78
     kworker/0:1-817   [000] ....   150.382717: rtos_queue_peek_from_isr_failed: tstamp:5129490757 queue:0x0bcbcf78
     kworker/0:1-817   [000] ....   150.550712: rtos_queue_peek_from_isr_failed: tstamp:5134490758 queue:0x0bcbcf78
     kworker/0:1-817   [000] ....   150.718702: rtos_queue_peek_from_isr_failed: tstamp:5139490759 queue:0x0bcbcf78
     kworker/0:1-817   [000] ....   150.886715: rtos_queue_peek_from_isr_failed: tstamp:5144490755 queue:0x0bcbcf78
     kworker/0:1-817   [000] ....   151.054698: rtos_queue_peek_from_isr_failed: tstamp:5149490757 queue:0x0bcbcf78
     kworker/0:1-817   [000] ....   151.222705: rtos_queue_peek_from_isr_failed: tstamp:5154490759 queue:0x0bcbcf78
     kworker/0:1-817   [000] ....   151.390717: rtos_queue_peek_from_isr_failed: tstamp:5159490759 queue:0x0bcbcf78
     kworker/0:1-817   [000] ....   151.502701: rtos_queue_peek_from_isr_failed: tstamp:5164490757 queue:0x0bcbcf78
     kworker/0:1-817   [000] ....   151.670704: rtos_queue_peek_from_isr_failed: tstamp:5169490759 queue:0x0bcbcf78
     kworker/0:1-817   [000] ....   151.838699: rtos_queue_peek_from_isr_failed: tstamp:5174490758 queue:0x0bcbcf78
     kworker/0:1-817   [000] ....   152.010754: rtos_queue_peek_from_isr_failed: tstamp:5179490757 queue:0x0bcbcf78
     kworker/0:1-817   [000] ....   152.178709: rtos_queue_peek_from_isr_failed: tstamp:5184490758 queue:0x0bcbcf78
     kworker/0:1-817   [000] ....   152.346727: rtos_queue_peek_from_isr_failed: tstamp:5189490757 queue:0x0bcbcf78
     kworker/0:1-817   [000] ....   152.458712: rtos_queue_peek_from_isr_failed: tstamp:5193181730 queue:0x0bcbcf78
     kworker/0:1-817   [000] ....   158.186737: rtos_queue_peek_from_isr_failed: tstamp:5372432380 queue:0x0bcbcf78
     kworker/0:1-817   [000] ....   158.186742: rtcpu_start: tstamp:5372434265
     kworker/0:1-817   [000] ....   158.186744: rtos_queue_send_from_isr_failed: tstamp:5372459731 queue:0x0bcb41f8
     kworker/0:1-817   [000] ....   158.186745: rtos_queue_send_from_isr_failed: tstamp:5372459867 queue:0x0bcb8a60
     kworker/0:1-817   [000] ....   158.186745: rtos_queue_send_from_isr_failed: tstamp:5372460003 queue:0x0bcba5e0
     kworker/0:1-817   [000] ....   158.186746: rtos_queue_send_from_isr_failed: tstamp:5372460150 queue:0x0bcbb3a0
     kworker/0:1-817   [000] ....   158.186746: rtos_queue_send_from_isr_failed: tstamp:5372460285 queue:0x0bcbc160
     kworker/0:1-817   [000] ....   158.186747: rtcpu_string: tstamp:5372460707 id:0x04010000 str:"Configuring ISP GoS.
     kworker/0:1-817   [000] ....   158.186890: rtcpu_string: tstamp:5372460872 id:0x04010000 str:"  VM GOS[#0] addr=0xc2100000
     kworker/0:1-817   [000] ....   158.186986: rtcpu_string: tstamp:5372461117 id:0x04010000 str:"  VM GOS[#1] addr=0xc2101000
     kworker/0:1-817   [000] ....   158.187065: rtcpu_string: tstamp:5372461369 id:0x04010000 str:"  VM GOS[#2] addr=0xc2102000
     kworker/0:1-817   [000] ....   158.187140: rtcpu_string: tstamp:5372461593 id:0x04010000 str:"  VM GOS[#3] addr=0xc2103000
     kworker/0:1-817   [000] ....   158.187225: rtcpu_string: tstamp:5372461815 id:0x04010000 str:"  VM GOS[#4] addr=0xc2104000
     kworker/0:1-817   [000] ....   158.187329: rtcpu_string: tstamp:5372462036 id:0x04010000 str:"  VM GOS[#5] addr=0xc2105000
     kworker/0:1-817   [000] ....   158.187411: rtcpu_string: tstamp:5372473036 id:0x04010000 str:"WARNING: t194/isp5.c:901 [config_channel] ""
     kworker/0:1-817   [000] ....   158.187412: rtcpu_string: tstamp:5372473394 id:0x04010000 str:"All error notifications not enabled: correctabl"
     kworker/0:1-817   [000] ....   158.187413: rtcpu_string: tstamp:5372473498 id:0x04010000 str:"=0x00 uncorrectable=0x00"
     kworker/0:1-817   [000] ....   158.187414: rtcpu_string: tstamp:5372473675 id:0x04010000 str:""
  nvargus-daemon-4847  [004] ....   158.336030: tegra_channel_open: vi-output, imx490 30-001b
  nvargus-daemon-4847  [004] ....   158.336040: tegra_channel_set_power: imx490 30-001b : 0x1
  nvargus-daemon-4847  [004] ....   158.336046: camera_common_s_power: status : 0x1
  nvargus-daemon-4847  [000] ....   158.336583: tegra_channel_set_power: 15a00000.nvcsi--8 : 0x1
  nvargus-daemon-4847  [000] ....   158.336587: csi_s_power: enable : 0x1
  nvargus-daemon-4847  [000] ....   158.336811: tegra_channel_close: vi-output, imx490 30-001b
  nvargus-daemon-4847  [000] ....   158.336816: tegra_channel_set_power: imx490 30-001b : 0x0
  nvargus-daemon-4847  [000] ....   158.336823: camera_common_s_power: status : 0x0
  nvargus-daemon-4847  [000] ....   158.336949: tegra_channel_set_power: 15a00000.nvcsi--8 : 0x0
  nvargus-daemon-4847  [000] ....   158.336950: csi_s_power: enable : 0x0
  nvargus-daemon-4847  [000] ....   158.337881: tegra_channel_open: vi-output, imx490 30-001c
  nvargus-daemon-4847  [000] ....   158.337887: tegra_channel_set_power: imx490 30-001c : 0x1
  nvargus-daemon-4847  [000] ....   158.337891: camera_common_s_power: status : 0x1
  nvargus-daemon-4847  [000] ....   158.338251: tegra_channel_set_power: 15a00000.nvcsi--7 : 0x1
  nvargus-daemon-4847  [000] ....   158.338252: csi_s_power: enable : 0x1
  nvargus-daemon-4847  [000] ....   158.338334: tegra_channel_close: vi-output, imx490 30-001c
  nvargus-daemon-4847  [000] ....   158.338336: tegra_channel_set_power: imx490 30-001c : 0x0
  nvargus-daemon-4847  [000] ....   158.338338: camera_common_s_power: status : 0x0
  nvargus-daemon-4847  [000] ....   158.338440: tegra_channel_set_power: 15a00000.nvcsi--7 : 0x0
  nvargus-daemon-4847  [000] ....   158.338441: csi_s_power: enable : 0x0
@DaneLLL some more interesting behavior
Like I mentioned before, if I capture a frame directly using v4l2-ctl, I can do this multiple times in a row without issue. However, if I call gstreamer nvarguscamerasrc ... after v4l2-ctl, it will also not work.
What should compliant camera drivers be doing on shutdown? Suspect there’s an issue with my code
Would like to confirm the status. So you can run this v4l2-ctl commands continually without any issue:
v4l2-ctl -d /dev/video0 --set-fmt-video=width=2880,height=1860,pixelformat=RG12 -stream-count=1000 --stream-mmap --stream-to=csi.raw --verbose
For this gstreamer command:
gst-launch-1.0 nvarguscamerasrc num-buffers=1000 ! 'video/xraw(memory:NVMM),width=2880, height=1860, framerate=20/1, format=NV12' ! nvv4l2h265enc ! h265parse ! qtmux ! filesink location=test.mp4 -e
It works in first run and the video file is valid. But fails in second run.
Please check if the status is correct.
Yes, that’s right. Seems like my v4l2 may be improperly shutting down, but is able to bypass this bad shutdown on next boot, whereas argus cannot
Suppose it could be the FPDLink or sensor didn’t reset well cause the problem.
Could you consult with vendor to check if any software reset REG to reset it.
