sudo service nvargus-daemon restart
jetson@desktop:~/blending$ gst-launch-1.0 -e nvarguscamerasrc sensor-id=0 timeout=10 ! ‘video/x-raw(memory:NVMM),width=1920,height=1080,framerate=29/1’ ! nvvidconv ! video/x-raw,format=I420 ! x264enc bitrate=2000 speed-preset=ultrafast ! h264parse ! h264parse ! qtmux ! filesink location=t.mp4
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Pipeline is PREROLLED …
Setting pipeline to PLAYING …
New clock: GstSystemClock
Redistribute latency…
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected…
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3280 x 2464 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3280 x 1848 FR = 28.000001 fps Duration = 35714284 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1640 x 1232 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 2
Output Stream W = 1920 H = 1080
seconds to Run = 10
Frame Rate = 29.999999
GST_ARGUS: Setup Complete, Starting captures for 10 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
nvbuf_utils: dmabuf_fd -1 mapped entry NOT found
Error generated. gstnvarguscamerasrc.cpp, threadExecute:799 NvBufSurfaceFromFd Failed.
Error generated. gstnvarguscamerasrc.cpp, threadFunction:248 (propagating)
Got EOS from element “pipeline0”.
EOS received - stopping pipeline…
Execution ended after 0:00:04.023365585
Setting pipeline to NULL …
GST_ARGUS: Cleaning up
GST_ARGUS: Done Success
Freeing pipeline …
