I’m using an allied vision MIPI camera and so far I haven’t had any problems while using it to record stuff with GStreamer, that’s it until today when I realized that after pressing “Ctrl+C” GStreamer gets stuck and doesn’t finish the process no matter how much I wait. The only way to free it is to reboot the board.
Here’s the console output.
duoteknx@duoteknx:~$ gst-launch-1.0 v4l2src device=/dev/video0 ! 'video/x-raw,format=BGRx,width=1456,height=1088,framerate=50/1' ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12' ! omxh265enc ! qtmux ! filesink location=out_265.mp4 -e
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Framerate set to : 50 at NvxVideoEncoderSetParameterNvMMLiteOpen : Block : BlockType = 8
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 8
NVMEDIA: H265 : Profile : 1
^Chandling interrupt.
Interrupt: Stopping pipeline ...
EOS on shutdown enabled -- Forcing EOS on the pipeline
Waiting for EOS...
Got EOS from element "pipeline0".
EOS received - stopping pipeline...
Execution ended after 0:00:54.014276539
Setting pipeline to READY ...
Here’s the dmesg output, from what i see it looks like there’s a bunch of errors related to the camera when the boards boots up, and a lot raised when trying to finish the recording.
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-ga01070fee (flo@ubunutu-dev) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #30 SMP PREEMPT Thu Oct 29 16:03:14 CET 2020
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2c000000
[ 0.000000] OF: fdt: - ac200000 , 44600000
[ 0.000000] OF: fdt: - 100000000 , 180000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options '')
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb3_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
[ 0.000000] cma: Reserved 64 MiB at 0x00000000c2000000
[ 0.000000] On node 0 totalpages: 2032640
[ 0.000000] DMA zone: 7184 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 459776 pages, LIFO batch:31
[ 0.000000] Normal zone: 24576 pages used for memmap
[ 0.000000] Normal zone: 1572864 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc1ffd0f000 s61656 r8192 d32552 u102400
[ 0.000000] pcpu-alloc: s61656 r8192 d32552 u102400 alloc=25*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2000880
[ 0.000000] Kernel command line: console=ttyTCU0,115200 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29084(88%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7190436K/8130560K available (15358K kernel code, 2936K rwdata, 6584K rodata, 8576K init, 611K bss, 186460K reserved, 753664K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f80000 ( 15360 KB)
[ 0.000000] .rodata : 0xffffff8008f80000 - 0xffffff8009600000 ( 6656 KB)
[ 0.000000] .init : 0xffffff8009600000 - 0xffffff8009e60000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e60000 - 0xffffff800a13e008 ( 2937 KB)
[ 0.000000] .bss : 0xffffff800a13e008 - 0xffffff800a1d6f3c ( 612 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf08000000 ( 128 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc200000000 ( 8192 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000004] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000669] Console: colour dummy device 80x25
[ 0.000680] console [tty0] enabled
[ 0.000687] bootconsole [tegra_comb_uart0] disabled
[ 0.000700] kmemleak: Kernel memory leak detector disabled
[ 0.000718] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.000732] pid_max: default: 32768 minimum: 301
[ 0.001825] Security Framework initialized
[ 0.002413] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.002422] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.004085] ftrace: allocating 47176 entries in 185 pages
[ 0.398060] sched-energy: Sched-energy-costs installed from DT
[ 0.398079] ASID allocator initialised with 65536 entries
[ 0.432577] tegra-id: chipid=21917.
[ 0.432589] tegra-id: opt_subrevision=1.
[ 0.432618] Tegra Revision: A02 SKU: 0xde CPU Process: 0 SoC Process: 0
[ 0.432638] DTS File Name: arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dts
[ 0.432650] DTB Build time: Oct 29 2020 16:11:18
[ 0.480682] CPU1: Booted secondary processor [4e0f0040]
[ 0.512778] CPU2: Booted secondary processor [4e0f0040]
[ 0.544857] CPU3: Booted secondary processor [4e0f0040]
[ 0.577078] CPU4: Booted secondary processor [4e0f0040]
[ 0.609188] CPU5: Booted secondary processor [4e0f0040]
[ 0.609415] Brought up 6 CPUs
[ 0.609425] SMP: Total of 6 processors activated.
[ 0.609437] CPU features: detected feature: Privileged Access Never
[ 0.609466] CPU features: detected feature: LSE atomic instructions
[ 0.609472] CPU features: detected feature: User Access Override
[ 0.609478] CPU features: detected feature: 32-bit EL0 Support
[ 0.610895] CPU: All CPU(s) started at EL2
[ 0.610949] alternatives: patching kernel code
[ 0.617326] devtmpfs: initialized
[ 0.657200] Initilizing CustomIPI irq domain
[ 0.657442] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.657465] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.678616] pinctrl core: initialized pinctrl subsystem
[ 0.678838] OS set in device tree is not L4T.
[ 0.679148] regulator-dummy: no parameters
[ 0.679411] Initializing plugin-manager
[ 0.679451] Plugin module not found
[ 0.679484] Plugin-manager status disabled
[ 0.680723] NET: Registered protocol family 16
[ 0.705449] pstore: using zlib compression
[ 0.705477] console [pstore-1] enabled
[ 0.705487] pstore: Registered ramoops as persistent store backend
[ 0.705497] ramoops: attached 0x200000@0xf0600000, ecc: 0/0
[ 0.724434] cpuidle: using governor menu
[ 0.725402] bpmp: waiting for handshake
[ 0.725415] bpmp: handshake completed
[ 0.725431] bpmp: synchronizing channels
[ 0.725443] bpmp: channels synchronized
[ 0.725451] bpmp: mail init ok
[ 0.727961] t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
[ 0.728129] t19x-arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.728139] t19x-arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.728172] t19x-arm-smmu 12000000.iommu: stage 1 translation
[ 0.728178] t19x-arm-smmu 12000000.iommu: stage 2 translation
[ 0.728184] t19x-arm-smmu 12000000.iommu: nested translation
[ 0.728193] t19x-arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.728222] t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.728228] t19x-arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.728235] t19x-arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.728241] t19x-arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.731551] vdso: 2 pages (1 code @ ffffff8008f87000, 1 data @ ffffff8009e64000)
[ 0.731578] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.734173] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.735568] Registering BPMP clocks...
[ 0.735676] tegra_bpmp_clk_init: clock init ok (400 clks)
[ 0.736327] Serial: AMBA PL011 UART driver
[ 0.736503] tegra_powergate_init: DONE
[ 0.736599] DTS File Name: arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dts
[ 0.736612] DTB Build time: Oct 29 2020 16:11:18
[ 0.739582] Tegra reboot handler registered.
[ 0.747286] iommu: Adding device 14160000.pcie to group 0
[ 0.747921] iommu: Adding device 141a0000.pcie to group 1
[ 0.749287] iommu: Adding device 2490000.ether_qos to group 2
[ 0.749795] iommu: Adding device 3100000.serial to group 3
[ 0.750270] iommu: Adding device 3110000.serial to group 4
[ 0.750691] iommu: Adding device 3140000.serial to group 5
[ 0.751359] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.751725] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.751746] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[ 0.751754] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L1
[ 0.751762] tegra-pmc: ### PMC reset status reg: 0x2d
[ 0.751809] tegra-pmc: PMC Prod config success
[ 0.752025] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.752037] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.752355] iommu: Adding device 3400000.sdhci to group 6
[ 0.752848] iommu: Adding device 3210000.spi to group 7
[ 0.753247] iommu: Adding device 3230000.spi to group 8
[ 0.753629] iommu: Adding device 3270000.spi to group 9
[ 0.754727] iommu: Adding device 3160000.i2c to group 10
[ 0.755157] iommu: Adding device c240000.i2c to group 11
[ 0.755549] iommu: Adding device 3180000.i2c to group 12
[ 0.755940] iommu: Adding device 3190000.i2c to group 13
[ 0.756459] iommu: Adding device 31b0000.i2c to group 14
[ 0.756902] iommu: Adding device 31c0000.i2c to group 15
[ 0.757284] iommu: Adding device c250000.i2c to group 16
[ 0.757661] iommu: Adding device 31e0000.i2c to group 17
[ 0.758230] iommu: Adding device sound to group 18
[ 0.758828] iommu: Adding device 3510000.hda to group 19
[ 0.759384] iommu: Adding device bc00000.rtcpu to group 20
[ 0.761438] iommu: Adding device 13e10000.host1x to group 21
[ 0.761859] iommu: Adding device 13e10000.host1x:ctx0 to group 22
[ 0.762247] iommu: Adding device 13e10000.host1x:ctx1 to group 23
[ 0.762597] iommu: Adding device 13e10000.host1x:ctx2 to group 24
[ 0.762963] iommu: Adding device 13e10000.host1x:ctx3 to group 25
[ 0.763356] iommu: Adding device 13e10000.host1x:ctx4 to group 26
[ 0.763858] iommu: Adding device 13e10000.host1x:ctx5 to group 27
[ 0.764237] iommu: Adding device 13e10000.host1x:ctx6 to group 28
[ 0.764657] iommu: Adding device 13e10000.host1x:ctx7 to group 29
[ 0.765284] iommu: Adding device 15340000.vic to group 30
[ 0.765672] iommu: Adding device 15380000.nvjpg to group 31
[ 0.766013] iommu: Adding device 15500000.tsec to group 32
[ 0.766346] iommu: Adding device 15100000.tsecb to group 33
[ 0.766649] iommu: Adding device 15480000.nvdec to group 34
[ 0.766931] iommu: Adding device 15140000.nvdec1 to group 35
[ 0.767386] iommu: Adding device 154c0000.nvenc to group 36
[ 0.767741] iommu: Adding device 15a80000.nvenc1 to group 37
[ 0.768228] iommu: Adding device 15880000.nvdla0 to group 38
[ 0.768716] iommu: Adding device 158c0000.nvdla1 to group 39
[ 0.769496] iommu: Adding device 15200000.nvdisplay to group 40
[ 0.773974] platform 15200000.nvdisplay: IOVA linear map 0x00000000c6000000(2a000000)
[ 0.774059] t19x-arm-smmu: Adding 15200000.nvdisplay to ISO SMMU client
[ 0.774751] iommu: Adding device 15210000.nvdisplay to group 41
[ 0.774807] t19x-arm-smmu: Adding 15210000.nvdisplay to ISO SMMU client
[ 0.776775] iommu: Adding device 15c10000.vi to group 42
[ 0.776977] t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
[ 0.777389] iommu: Adding device 14800000.isp to group 43
[ 0.778380] iommu: Adding device 16000000.pva0 to group 44
[ 0.778974] iommu: Adding device 16800000.pva1 to group 45
[ 0.779372] iommu: Adding device 15810000.se to group 46
[ 0.779885] iommu: Adding device 15820000.se to group 47
[ 0.780279] iommu: Adding device 15830000.se to group 48
[ 0.780609] iommu: Adding device 15840000.se to group 49
[ 0.780955] iommu: Adding device c1a0000.aon to group 50
[ 0.782568] iommu: Adding device d000000.bpmp to group 51
[ 0.782898] bpmp: ping status is 0
[ 0.783053] bpmp d000000.bpmp: firmware tag is 57f8a77779f848bf2ecf21dabee5645f
[ 0.786332] bpmp d000000.bpmp: probe ok
[ 0.788311] tegra-reset 0.bpmp_reset: registered 190 resets.
[ 0.788770] iommu: Adding device smmu_test to group 52
[ 0.789877] mc: mapped MMIO address: 0xffffff800a590000 -> 0x2c10000
[ 0.789900] mc: mapped MMIO address: 0xffffff800a5b0000 -> 0x2c20000
[ 0.789919] mc: mapped MMIO address: 0xffffff800a5d0000 -> 0x2c30000
[ 0.789938] mc: mapped MMIO address: 0xffffff800a7b0000 -> 0x2c40000
[ 0.789957] mc: mapped MMIO address: 0xffffff800a7d0000 -> 0x2c50000
[ 0.789978] mc: mapped MMIO address: 0xffffff800b010000 -> 0x2b80000
[ 0.789996] mc: mapped MMIO address: 0xffffff800b030000 -> 0x2b90000
[ 0.790014] mc: mapped MMIO address: 0xffffff800b050000 -> 0x2ba0000
[ 0.790032] mc: mapped MMIO address: 0xffffff800b070000 -> 0x2bb0000
[ 0.790052] mc: mapped MMIO address: 0xffffff800b090000 -> 0x1700000
[ 0.790070] mc: mapped MMIO address: 0xffffff800b0b0000 -> 0x1710000
[ 0.790088] mc: mapped MMIO address: 0xffffff800b0d0000 -> 0x1720000
[ 0.790106] mc: mapped MMIO address: 0xffffff800b0f0000 -> 0x1730000
[ 0.790123] mc: mapped MMIO address: 0xffffff800b110000 -> 0x1740000
[ 0.790141] mc: mapped MMIO address: 0xffffff800b130000 -> 0x1750000
[ 0.790159] mc: mapped MMIO address: 0xffffff800b150000 -> 0x1760000
[ 0.790193] mc: mapped MMIO address: 0xffffff800b170000 -> 0x1770000
[ 0.790269] mc-err: mcerr ops are set to t19x
[ 0.796048] iommu: Adding device 2600000.dma to group 53
[ 0.802489] GPIO line 339 (wifi-enable) hogged as output/high
[ 0.802760] gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpiochip0 (tegra-gpio)
[ 0.811510] GPIO line 253 (pex-refclk-sel-low) hogged as output/low
[ 0.811834] gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpiochip1 (tegra-gpio-aon)
[ 0.814232] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.814243] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 0.815010] iommu: Adding device 3550000.xudc to group 54
[ 0.815677] iommu: Adding device 3610000.xhci to group 55
[ 0.817891] arm64_ras arm64_ras: probed
[ 0.818288] ras_fhi_enable: FHI 468 enabled on CPU0
[ 0.818336] ras_fhi_enable: FHI 469 enabled on CPU1
[ 0.818419] ras_fhi_enable: FHI 470 enabled on CPU2
[ 0.818530] ras_fhi_enable: FHI 471 enabled on CPU3
[ 0.818602] ras_fhi_enable: FHI 472 enabled on CPU4
[ 0.818693] ras_fhi_enable: FHI 473 enabled on CPU5
[ 0.818892] carmel_ras_enable: RAS enabled on cpu0
[ 0.819064] carmel_ras_enable: RAS enabled on cpu1
[ 0.819262] carmel_ras_enable: RAS enabled on cpu2
[ 0.819455] carmel_ras_enable: RAS enabled on cpu3
[ 0.819656] carmel_ras_enable: RAS enabled on cpu4
[ 0.819862] carmel_ras_enable: RAS enabled on cpu5
[ 0.819930] carmel_ras carmel_ras: probed
[ 0.821228] tegra-cbb 2300000.cbb-noc: noc_secure_irq = 477, noc_nonsecure_irq = 476>
[ 0.821726] tegra-cbb c600000.aon-noc: noc_secure_irq = 479, noc_nonsecure_irq = 478>
[ 0.822757] tegra-cbb d600000.bpmp-noc: noc_secure_irq = 481, noc_nonsecure_irq = 480>
[ 0.824072] tegra-cbb be00000.rce-noc: noc_secure_irq = 483, noc_nonsecure_irq = 482>
[ 0.825032] tegra-cbb b600000.sce-noc: noc_secure_irq = 485, noc_nonsecure_irq = 484>
[ 0.825422] tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
[ 0.826753] vdd-ac-bat: 5000 mV
[ 0.827165] vdd-sdmmc1-sw: 3300 mV
[ 0.827479] vdd-1v8-sd: 1800 mV
[ 0.827857] vdd-usb2-5v: 5000 mV
[ 0.828174] vdd-3v3-cvb: 3300 mV
[ 0.828495] vdd-1v8-cvb: 1800 mV
[ 0.828891] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 0.828930] vdd-epb-1v0: 1000 mV
[ 0.829350] avdd-cam-2v8: 2800 mV
[ 0.829680] vdd-fan: 5000 mV
[ 0.829991] vdd-hdmi-5v0: 5000 mV
[ 0.830297] vdd_sys_en: 1200 mV
[ 0.862173] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.867380] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.867664] SCSI subsystem initialized
[ 0.867927] libata version 3.00 loaded.
[ 0.868155] usbcore: registered new interface driver usbfs
[ 0.868197] usbcore: registered new interface driver hub
[ 0.868317] usbcore: registered new device driver usb
[ 0.879588] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
[ 0.882411] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[ 0.889885] vdd-1v0: at 1000 mV
[ 0.897114] vdd-1v8-hs: at 1800 mV
[ 0.905139] vdd-1v8-ls: at 1800 mV
[ 0.913177] vdd-1v8-ao: at 1800 mV
[ 0.921224] vddio-ddr-1v1: at 1100 mV
[ 0.928994] vdd-rtc: at 800 mV
[ 0.929949] spmic-ldo1: at 2375 mV
[ 0.941057] vdd-ao-3v3: at 3300 mV
[ 0.953087] vddio-emmc-3v3: at 3300 mV
[ 0.954082] spmic-ldo4: at 1587 mV
[ 0.965138] vdd-usb-3v3: at 3300 mV
[ 0.977170] vddio-sdmmc1-3v3: at 3300 mV
[ 0.982034] vdd-csi-1v2: at 1200 mV
[ 0.983199] spmic-ldo8: at 1800 mV
[ 0.987509] GPIO line 246 (gpio_default) hogged as output/high
[ 0.988482] GPIO line 247 (gpio_default) hogged as output/high
[ 0.988835] gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpiochip2 (max77620-gpio)
[ 0.989134] max77620 4-003c: max77620 probe successful
[ 0.989699] media: Linux media interface: v0.10
[ 0.989782] Linux video capture interface: v2.00
[ 0.991451] pps_core: LinuxPPS API ver. 1 registered
[ 0.991458] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.991547] PTP clock support registered
[ 0.991940] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[ 0.992217] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.992246] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.994749] trusty trusty: trusty version: Built: 20:53:35 Oct 27 2020
[ 0.994811] trusty trusty: selected api version: 3 (requested 3)
[ 0.996123] Advanced Linux Sound Architecture Driver Initialized.
[ 0.996865] Bluetooth: Core ver 2.22
[ 0.996904] NET: Registered protocol family 31
[ 0.996909] Bluetooth: HCI device and connection manager initialized
[ 0.996919] Bluetooth: HCI socket layer initialized
[ 0.996929] Bluetooth: L2CAP socket layer initialized
[ 0.996954] Bluetooth: SCO socket layer initialized
[ 0.999280] camchar: rtcpu character device driver loaded
[ 0.999727] gpio tegra-gpio wake61 for gpio=201(Z:1)
[ 0.999814] extcon-gpio-states external-connection:extcon@1: Cable state:0, cable id:0
[ 1.000618] clocksource: Switched to clocksource arch_sys_counter
[ 1.045773] VFS: Disk quotas dquot_6.6.0
[ 1.045852] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.046187] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 1.047327] tegra-carveouts tegra-carveouts: assigned reserved memory node grid-of-semaphores
[ 1.047370] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000c6000000, size=0x2a000000
[ 1.047575] cma: enabled page replacement for spfn=c6000, epfn=f0000
[ 1.047581] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 1.047593] nvmap: nvmap_select_cache_ops() nvmap cache ops set to scf
[ 1.047600] nvmap_page_pool_init: Total RAM pages: 1986025
[ 1.047606] nvmap_page_pool_init: nvmap page pool size: 248253 pages (969 MB)
[ 1.047787] nvmap_background_zero_thread: PP zeroing thread starting.
[ 1.048135] misc nvmap: created heap vpr base 0x00000000c6000000 size (688128KiB)
[ 1.050143] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 1.063332] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 1.063510] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[ 1.063680] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type AUX-therm
[ 1.063881] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type AO-therm
[ 1.064059] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 1.065281] la/ptsa driver initialized.
[ 1.065568] NET: Registered protocol family 2
[ 1.066302] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 1.066632] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 1.067222] TCP: Hash tables configured (established 65536 bind 65536)
[ 1.067286] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 1.067405] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 1.067848] NET: Registered protocol family 1
[ 1.068424] RPC: Registered named UNIX socket transport module.
[ 1.068431] RPC: Registered udp transport module.
[ 1.068436] RPC: Registered tcp transport module.
[ 1.068440] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.068452] PCI: CLS 0 bytes, default 64
[ 1.068734] Trying to unpack rootfs image as initramfs...
[ 1.245828] Freeing initrd memory: 5432K
[ 1.267318] host1x 13e10000.host1x: initialized
[ 1.269054] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.273902] audit: initializing netlink subsys (disabled)
[ 1.273943] audit: type=2000 audit(0.896:1): initialized
[ 1.274805] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 1.284622] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.285764] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.286389] 9p: Installing v9fs 9p2000 file system support
[ 1.291932] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.292097] io scheduler noop registered
[ 1.292327] io scheduler cfq registered (default)
[ 1.295953] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 1.297258] random: fast init done
[ 1.328377] iommu: Adding device 2993000.adsp to group 56
[ 1.443411] iommu: Adding device aconnect@2a41000:adsp_audio to group 57
[ 1.444557] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 1.459015] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 1.459461] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.460039] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 1.460488] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[ 1.460997] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 1.464363] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.464696] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[ 1.467547] tsec 15500000.tsec: initialized
[ 1.469252] tsec 15100000.tsecb: initialized
[ 1.473247] nvdec 15480000.nvdec: initialized
[ 1.475676] nvdec 15140000.nvdec1: initialized
[ 1.481655] falcon 15340000.vic: initialized
[ 1.483574] falcon 15380000.nvjpg: initialized
[ 1.485440] falcon 154c0000.nvenc: initialized
[ 1.487407] falcon 15a80000.nvenc1: initialized
[ 1.490679] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.492154] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.493652] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.495110] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.496592] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.497942] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.499299] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.500683] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.504224] t194-nvcsi 15a00000.nvcsi: initialized
[ 1.509809] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 1.510175] scare-pigeon 14b00000.isp-thi: initialized
[ 1.515731] pva 16000000.pva0: initialized
[ 1.521712] pva 16800000.pva1: initialized
[ 1.526652] nvdla 15880000.nvdla0: initialized
[ 1.531461] nvdla 158c0000.nvdla1: initialized
[ 1.533202] tegradccommon 15200000.dc_common: host1x channel mapped
[ 1.533216] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 1.533255] tegradccommon 15200000.dc_common: dma mapping done
[ 1.533771] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor1
[ 1.533798] generic_infoframe_type: 0x87
[ 1.533856] tegradc 15200000.nvdisplay: DT parsed successfully
[ 1.533882] tegradc 15200000.nvdisplay: Display dc.ffffff800bd10000 registered with id=0
[ 1.537648] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 7088400 KB/s
[ 1.537660] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 800000000 Hz
[ 1.537668] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 300000000 Hz
[ 1.537915] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[ 1.537925] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[ 1.540571] tegradc 15200000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 1.540580] tegradc 15200000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 1.544244] tegradc 15200000.nvdisplay: probed
[ 1.544939] Console: switching to colour frame buffer device 80x30
[ 1.544977] tegradc 15200000.nvdisplay: fb registered
[ 1.545248] gpio tegra-gpio wake63 for gpio=97(M:1)
[ 1.545745] tegradc 15210000.nvdisplay: disp1 connected to head1->/host1x/sor
[ 1.545775] tegradc 15210000.nvdisplay: parse_dp_settings: No dp-lt-settings node
[ 1.545890] tegradc 15210000.nvdisplay: DT parsed successfully
[ 1.545921] tegradc 15210000.nvdisplay: Display dc.ffffff800be10000 registered with id=1
[ 1.546119] tegradc 15210000.nvdisplay: vblank syncpt # 11 for dc 1
[ 1.546129] tegradc 15210000.nvdisplay: vpulse3 syncpt # 12 for dc 1
[ 1.555225] tegradc 15210000.nvdisplay: probed
[ 1.555540] tegradc 15210000.nvdisplay: fb registered
[ 1.559081] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 1.559095] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 1.559111] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1.559122] tegradc 15210000.nvdisplay: blank - powerdown
[ 1.559138] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[ 1.559143] Extcon DP: HPD disabled
[ 1.559148] hpd: hpd_switch 0
[ 1.559159] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.559172] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1.559184] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 1.559530] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=77
[ 1.559541] tegra_cec 3960000.tegra_cec: Unpowergate DISP: 0.
[ 1.559838] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[ 1.560002] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[ 1.560121] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[ 1.560128] tegra_cec 3960000.tegra_cec: probed
[ 1.570081] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 32 channels
[ 1.570915] tegra-fuse-burn 3820000.efuse:efuse-burn: shutdown limit check disabled
[ 1.570948] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.571297] kfuse 3830000.kfuse: initialized
[ 1.577522] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.580363] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 47, base_baud = 0) is a TEGRA_UART
[ 1.581568] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 48, base_baud = 0) is a TEGRA_UART
[ 1.582324] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 49, base_baud = 0) is a TEGRA_UART
[ 1.583577] console [ttyTCU0] enabled
[ 1.583970] [drm] Initialized
[ 1.596172] brd: module loaded
[ 1.602090] loop: module loaded
[ 1.602202] tegra_profiler: version: 1.141, samples/io: 48/28
[ 1.602354] tegra_profiler: auth: init
[ 1.603004] THERMAL EST: found 3 subdevs
[ 1.603011] THERMAL EST num_resources: 0
[ 1.603017] [THERMAL EST subdev 0]
[ 1.603023] [THERMAL EST subdev 1]
[ 1.603028] [THERMAL EST subdev 2]
[ 1.603038] THERMAL EST: Found 2 profiles, default profile is quiet
[ 1.603363] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 1.603368] THERMAL EST: thz register success.
[ 1.603544] THERMAL EST: end of probe, return err: 0
[ 1.604340] sd: No Scsi addr parsed to reserve index
[ 1.604374] hisi_sas: driver version v1.6
[ 1.614188] qspi_mtd spi6.0: s25fs256s SSG 8 0 1000 2000000
[ 1.614196] qspi_mtd spi6.0: s25fs256s (32768 Kbytes)
[ 1.614206] qspi_mtd spi6.0: mtd .name = spi6.0, .size = 0x2000000 (32MiB) .erasesize = 0x00010000 (64KiB) .numeraseregions = 0
[ 1.614432] 1 ofpart partitions found on MTD device spi6.0
[ 1.614437] Creating 1 MTD partitions on "spi6.0":
[ 1.614446] 0x000000000000-0x000002000000 : "Whole_flash0"
[ 1.617010] libphy: Fixed MDIO Bus: probed
[ 1.618935] tun: Universal TUN/TAP device driver, 1.6
[ 1.618941] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.619797] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.619803] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.619849] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.619854] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.619898] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.619903] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.619948] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 1.619953] Copyright(c) 1999 - 2017 Intel Corporation.
[ 1.864170] eqos 2490000.ether_qos: Setting local MAC: 48 b0 2d 15 ee 39
[ 1.864278] libphy: dwc_phy: probed
[ 1.866976] PPP generic driver version 2.4.2
[ 1.867425] PPP BSD Compression module registered
[ 1.867433] PPP Deflate Compression module registered
[ 1.867451] PPP MPPE Compression module registered
[ 1.867457] NET: Registered protocol family 24
[ 1.867519] usbcore: registered new interface driver r8152
[ 1.867556] usbcore: registered new interface driver asix
[ 1.867590] usbcore: registered new interface driver ax88179_178a
[ 1.867618] usbcore: registered new interface driver cdc_ether
[ 1.867649] usbcore: registered new interface driver net1080
[ 1.867678] usbcore: registered new interface driver cdc_subset
[ 1.867708] usbcore: registered new interface driver zaurus
[ 1.867751] usbcore: registered new interface driver cdc_ncm
[ 1.867996] VFIO - User Level meta-driver version: 0.3
[ 1.869169] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.869188] ehci-pci: EHCI PCI platform driver
[ 1.869220] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.869231] ohci-pci: OHCI PCI platform driver
[ 1.869263] ohci-platform: OHCI generic platform driver
[ 1.874513] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[ 1.876464] tegra-xusb 3610000.xhci: extcon 0: ffffffc1f4e8cc00 id
[ 1.877163] usbcore: registered new interface driver uas
[ 1.877220] usbcore: registered new interface driver usb-storage
[ 1.877317] usbcore: registered new interface driver usbserial
[ 1.878947] tegra-xusb 3610000.xhci: Firmware timestamp: 2019-07-24 05:47:34 UTC, Version: 60.06 release
[ 1.879017] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 1.879037] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 1.879767] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x00050810
[ 1.879834] tegra-xusb 3610000.xhci: irq 463, io mem 0x03610000
[ 1.880062] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.880070] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.880077] usb usb1: Product: xHCI Host Controller
[ 1.880084] usb usb1: Manufacturer: Linux 4.9.140-ga01070fee xhci-hcd
[ 1.880090] usb usb1: SerialNumber: 3610000.xhci
[ 1.880636] hub 1-0:1.0: USB hub found
[ 1.880692] hub 1-0:1.0: 4 ports detected
[ 1.881309] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 1.881323] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 1.881333] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.881559] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.881567] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.881574] usb usb2: Product: xHCI Host Controller
[ 1.881580] usb usb2: Manufacturer: Linux 4.9.140-ga01070fee xhci-hcd
[ 1.881586] usb usb2: SerialNumber: 3610000.xhci
[ 1.882240] hub 2-0:1.0: USB hub found
[ 1.882313] hub 2-0:1.0: 4 ports detected
[ 1.883062] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[ 1.883149] tegra-xudc-new 3550000.xudc: device count: 1
[ 1.884090] tegra-xudc-new 3550000.xudc: vbus state: 0
[ 1.884102] tegra-xudc-new 3550000.xudc: Initialize boost_cpufreq work
[ 1.884130] tegra-xudc-new 3550000.xudc: entering ELPG
[ 1.884369] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 1.885257] mousedev: PS/2 mouse device common for all mice
[ 1.885419] usbcore: registered new interface driver xpad
[ 2.017350] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 2.019024] Wake73 for irq=42
[ 2.020310] rtc rtc1: alarm rtc device
[ 2.020327] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 2.020365] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.020566] i2c /dev entries driver
[ 2.023171] i2c i2c-2: Added multiplexed i2c bus 9
[ 2.023602] i2c i2c-2: Added multiplexed i2c bus 10
[ 2.023611] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[ 2.024217] tegra-i2c 3180000.i2c: no acknowledge from address 0x3c
[ 2.024269] avt_csi2 9-003c: i2c read failed (-121)
[ 2.024400] avt_csi2 9-003c: avt_csi2_probe: read_cci_registers failed: -121
[ 2.024573] avt_csi2: probe of 9-003c failed with error -121
[ 2.038482] avt_csi2 10-003c: cci layout version: 10000
[ 2.038491] avt_csi2 10-003c: cci device capabilities: 117
[ 2.038497] avt_csi2 10-003c: cci device guid: 00012C007097
[ 2.038503] avt_csi2 10-003c: cci gcprm_address: 0x300
[ 2.038808] avt_csi2 10-003c: bcrm version (driver): 0x10000 (maj: 0x1 min: 0x0)
[ 2.038816] avt_csi2 10-003c: bcrm version (camera): 0x10000 (maj: 0x1 min: 0x0)
[ 2.039030] avt_csi2 10-003c: avt_check_fmt_available: media_bus_fmt: 0x2001
[ 2.039417] avt_csi2 10-003c: avt_check_fmt_available: Camera available MIPI data formats: 0x1c0e0
[ 2.039643] avt_csi2 10-003c: avt_check_fmt_available: Camera bayer pattern inq: 0x4
[ 2.039653] avt_csi2 10-003c: avt_check_fmt_available: media_bus_fmt: 0x3001
[ 2.040060] avt_csi2 10-003c: avt_check_fmt_available: Camera available MIPI data formats: 0x1c0e0
[ 2.040267] avt_csi2 10-003c: avt_check_fmt_available: Camera bayer pattern inq: 0x4
[ 2.040277] avt_csi2 10-003c: avt_check_fmt_available: media_bus_fmt: 0x3013
[ 2.040676] avt_csi2 10-003c: avt_check_fmt_available: Camera available MIPI data formats: 0x1c0e0
[ 2.040880] avt_csi2 10-003c: avt_check_fmt_available: Camera bayer pattern inq: 0x4
[ 2.040889] avt_csi2 10-003c: avt_check_fmt_available: media_bus_fmt: 0x3002
[ 2.041297] avt_csi2 10-003c: avt_check_fmt_available: Camera available MIPI data formats: 0x1c0e0
[ 2.041500] avt_csi2 10-003c: avt_check_fmt_available: Camera bayer pattern inq: 0x4
[ 2.041510] avt_csi2 10-003c: avt_check_fmt_available: media_bus_fmt: 0x3014
[ 2.041908] avt_csi2 10-003c: avt_check_fmt_available: Camera available MIPI data formats: 0x1c0e0
[ 2.042108] avt_csi2 10-003c: avt_check_fmt_available: Camera bayer pattern inq: 0x4
[ 2.042117] avt_csi2 10-003c: avt_check_fmt_available: media_bus_fmt: 0x200a
[ 2.042497] avt_csi2 10-003c: avt_check_fmt_available: Camera available MIPI data formats: 0x1c0e0
[ 2.042699] avt_csi2 10-003c: avt_check_fmt_available: Camera bayer pattern inq: 0x4
[ 2.042709] avt_csi2 10-003c: avt_check_fmt_available: media_bus_fmt: 0x3007
[ 2.043093] avt_csi2 10-003c: avt_check_fmt_available: Camera available MIPI data formats: 0x1c0e0
[ 2.043324] avt_csi2 10-003c: avt_check_fmt_available: Camera bayer pattern inq: 0x4
[ 2.043334] avt_csi2 10-003c: avt_check_fmt_available: media_bus_fmt: 0x300e
[ 2.043712] avt_csi2 10-003c: avt_check_fmt_available: Camera available MIPI data formats: 0x1c0e0
[ 2.043933] avt_csi2 10-003c: avt_check_fmt_available: Camera bayer pattern inq: 0x4
[ 2.043943] avt_csi2 10-003c: avt_check_fmt_available: media_bus_fmt: 0x300a
[ 2.044326] avt_csi2 10-003c: avt_check_fmt_available: Camera available MIPI data formats: 0x1c0e0
[ 2.044529] avt_csi2 10-003c: avt_check_fmt_available: Camera bayer pattern inq: 0x4
[ 2.044560] avt_csi2 10-003c: avt_check_fmt_available: media_bus_fmt: 0x300f
[ 2.044948] avt_csi2 10-003c: avt_check_fmt_available: Camera available MIPI data formats: 0x1c0e0
[ 2.045187] avt_csi2 10-003c: avt_check_fmt_available: Camera bayer pattern inq: 0x4
[ 2.045196] avt_csi2 10-003c: avt_check_fmt_available: media_bus_fmt: 0x2013
[ 2.045594] avt_csi2 10-003c: avt_check_fmt_available: Camera available MIPI data formats: 0x1c0e0
[ 2.045828] avt_csi2 10-003c: avt_check_fmt_available: Camera bayer pattern inq: 0x4
[ 2.045840] avt_csi2 10-003c: avt_check_fmt_available: media_bus_fmt: 0x3012
[ 2.046254] avt_csi2 10-003c: avt_check_fmt_available: Camera available MIPI data formats: 0x1c0e0
[ 2.046474] avt_csi2 10-003c: avt_check_fmt_available: Camera bayer pattern inq: 0x4
[ 2.046507] avt_csi2 10-003c: avt_check_fmt_available: media_bus_fmt: 0x3011
[ 2.046903] avt_csi2 10-003c: avt_check_fmt_available: Camera available MIPI data formats: 0x1c0e0
[ 2.047139] avt_csi2 10-003c: avt_check_fmt_available: Camera bayer pattern inq: 0x4
[ 2.047149] avt_csi2 10-003c: avt_check_fmt_available: media_bus_fmt: 0x3010
[ 2.047536] avt_csi2 10-003c: avt_check_fmt_available: Camera available MIPI data formats: 0x1c0e0
[ 2.047772] avt_csi2 10-003c: avt_check_fmt_available: Camera bayer pattern inq: 0x4
[ 2.047782] avt_csi2 10-003c: avt_check_fmt_available: media_bus_fmt: 0x3008
[ 2.048174] avt_csi2 10-003c: avt_check_fmt_available: Camera available MIPI data formats: 0x1c0e0
[ 2.048413] avt_csi2 10-003c: avt_check_fmt_available: Camera bayer pattern inq: 0x4
[ 2.048423] avt_csi2 10-003c: avt_check_fmt_available: media_bus_fmt: 0x1017
[ 2.048864] avt_csi2 10-003c: avt_check_fmt_available: Camera available MIPI data formats: 0x1c0e0
[ 2.049080] avt_csi2 10-003c: avt_check_fmt_available: Camera bayer pattern inq: 0x4
[ 2.049089] avt_csi2 10-003c: avt_check_fmt_available: media_bus_fmt: 0x100a
[ 2.049528] avt_csi2 10-003c: avt_check_fmt_available: Camera available MIPI data formats: 0x1c0e0
[ 2.049748] avt_csi2 10-003c: avt_check_fmt_available: Camera bayer pattern inq: 0x4
[ 2.049759] avt_csi2 10-003c: avt_check_fmt_available: media_bus_fmt: 0x1013
[ 2.050158] avt_csi2 10-003c: avt_check_fmt_available: Camera available MIPI data formats: 0x1c0e0
[ 2.050371] avt_csi2 10-003c: avt_check_fmt_available: Camera bayer pattern inq: 0x4
[ 2.050403] avt_csi2 10-003c: avt_check_fmt_available: media_bus_fmt: 0x2007
[ 2.050798] avt_csi2 10-003c: avt_check_fmt_available: Camera available MIPI data formats: 0x1c0e0
[ 2.051035] avt_csi2 10-003c: avt_check_fmt_available: Camera bayer pattern inq: 0x4
[ 2.051044] avt_csi2 10-003c: avt_check_fmt_available: media_bus_fmt: 0x5002
[ 2.052230] avt_csi2 10-003c: wrong GENCP CRC value! calculated = 0xdf6b807f, received = 0xee4b04d6
[ 2.052237] avt_csi2 10-003c: gcprm layout version: 10000
[ 2.052242] avt_csi2 10-003c: gcprm out buf addr: c00
[ 2.052247] avt_csi2 10-003c: gcprm out buf size: 400
[ 2.052253] avt_csi2 10-003c: gcprm in buf addr: 800
[ 2.052258] avt_csi2 10-003c: gcprm in buf size: 400
[ 2.052267] avt_csi2 10-003c: gcprm version (driver): 0x10000 (maj: 0x1 min: 0x0)
[ 2.052273] avt_csi2 10-003c: gcprm version (camera): 0x10000 (maj: 0x1 min: 0x0)
[ 2.054269] ALVIUM 1800 C-158c 10-3c: ioctl_queryctrl:2803: control 'Contrast' not supported by firmware
[ 2.070622] ALVIUM 1800 C-158c 10-3c: ioctl_queryctrl:3265: control 'Sharpness' not supported by firmware
[ 2.193476] avt_csi2 10-003c: sensor_common_parse_control_props:default_gain:property missing
[ 2.193672] avt_csi2 10-003c: sensor_common_parse_control_props:default_framerate:property missing
[ 2.193864] avt_csi2 10-003c: sensor_common_parse_control_props:default_exp_time:property missing
[ 2.208650] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 2.209982] avt_read_fmt_from_device: Camera bayer_pattern=0x2
[ 2.210300] avt_read_fmt_from_device avt_img_fmt=0x24
[ 2.210308] avt_csi2 10-003c: avt_read_fmt_from_device 0x24
[ 2.248191] usb 1-2: New USB device found, idVendor=0bda, idProduct=5489
[ 2.248224] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.248231] usb 1-2: Product: 4-Port USB 2.0 Hub
[ 2.248237] usb 1-2: Manufacturer: Generic
[ 2.249803] hub 1-2:1.0: USB hub found
[ 2.251060] hub 1-2:1.0: 4 ports detected
[ 2.255214] avt_csi2 10-003c: sensor ALVIUM 1800 C-158c 10-3c registered
[ 2.256628] max77620-power max20024-power: Event recorder REG_NVERC : 0x0
[ 2.264439] tegra-thermal-throttle bthrot_cdev: clk:cpu max:1907200000, min:115200000 steps:24
[ 2.268588] tegra-thermal-throttle bthrot_cdev: clk:gpu max:1109250000, min:114750000 steps:10
[ 2.268638] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:0:cpu off:0 slope-adj:200
[ 2.268645] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:1:gpu off:0 slope-adj:400
[ 2.268730] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced max_state:48 cutoff:0
[ 2.268787] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:0:cpu off:0 slope-adj:400
[ 2.268793] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:1:gpu off:0 slope-adj:400
[ 2.269106] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced max_state:40 cutoff:1
[ 2.269183] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:0:cpu off:0 slope-adj:200
[ 2.269190] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:1:gpu off:365500000 slope-adj:300
[ 2.269490] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced max_state:48 cutoff:0
[ 2.269577] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:0:cpu off:38400000 slope-adj:10
[ 2.269584] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:1:gpu off:25500000 slope-adj:10
[ 2.269990] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced max_state:2 cutoff:0
[ 2.270050] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:0:cpu off:0 slope-adj:400
[ 2.270057] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:1:gpu off:0 slope-adj:400
[ 2.270340] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced max_state:40 cutoff:1
[ 2.270942] FAN dev name: pwm-fan
[ 2.270987] FAN:gpio request success.
[ 2.270997] FAN: can't find tach_gpio
[ 2.271007] pwm_fan_driver pwm-fan: Found 2 profiles, default profile is quiet
[ 2.271043] pwm_fan_driver pwm-fan: cap state:4, cap pwm:255
[ 2.271313] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 2.271321] pwm_fan_driver pwm-fan: tach period: 1000
[ 2.271907] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 2.271931] pwm_fan_driver pwm-fan: index 1: pwm=130, rpm=1000, rru=2, rrd=2, state:2
[ 2.271940] pwm_fan_driver pwm-fan: index 2: pwm=160, rpm=2000, rru=1, rrd=1, state:2
[ 2.271947] pwm_fan_driver pwm-fan: index 3: pwm=200, rpm=3000, rru=1, rrd=1, state:2
[ 2.271955] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 2.271961] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 2.271967] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 2.271973] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 2.271980] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 2.271986] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 2.273319] device-mapper: uevent: version 1.0.3
[ 2.273827] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 2.277434] tegra194_cpufreq_probe: platform driver Initialization: pass
[ 2.278649] cpuidle: Initializing cpuidle driver
[ 2.279548] sdhci: Secure Digital Host Controller Interface driver
[ 2.279563] sdhci: Copyright(c) Pierre Ossman
[ 2.279567] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.279840] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 2.280744] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 2.283495] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 245
[ 2.287831] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 2.289010] tegra-se-nvhost 15810000.se: initialized
[ 2.290453] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 2.291600] tegra-se-nvhost 15820000.se: initialized
[ 2.292881] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 2.293895] tegra-se-nvhost 15830000.se: initialized
[ 2.294567] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 2.295700] tegra-se-nvhost 15840000.se: initialized
[ 2.296737] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 2.296991] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.298396] usbcore: registered new interface driver usbhid
[ 2.298402] usbhid: USB HID core driver
[ 2.302881] tegra186-cam-rtcpu bc00000.rtcpu: deferring, 14800000.isp is not probed
[ 2.303944] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 2.304451] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 2.305282] denver_knobs_init:MTS_VERSION:50168445
[ 2.305450] tegra19x_actmon d230000.actmon: in actmon_register()...
[ 2.306222] tegra19x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 2.306630] t19x_cache tegra-cache: probed
[ 2.309420] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[ 2.309429] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[ 2.310130] carmel-pmu-drv carmel-pmu: Registered Carmel PMU
[ 2.312348] nvpmodel: initialized successfully
[ 2.313560] trusty-virtio trusty:virtio: initializing
[ 2.313765] trusty_ipc virtio0: vring0: va(pa) ffffffc1f1d00000(0) qsz 32 notifyid 1
[ 2.313775] trusty_ipc virtio0: vring1: va(pa) ffffffc1f1d02000(0) qsz 32 notifyid 2
[ 2.313925] trusty-virtio trusty:virtio: initializing done
[ 2.314190] trusty_ipc virtio0: is online
[ 2.315058] tegra-hda 3510000.hda: Override SDO lines to 4
[ 2.315489] usbcore: registered new interface driver snd-usb-audio
[ 2.328595] input: tegra-hda-galen-t194 HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 2.328918] input: tegra-hda-galen-t194 HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 2.329150] input: tegra-hda-galen-t194 HDMI/DP,pcm=8 as /devices/3510000.hda/sound/card0/input2
[ 2.329315] input: tegra-hda-galen-t194 HDMI/DP,pcm=9 as /devices/3510000.hda/sound/card0/input3
[ 2.332773] gpio tegra-gpio wake8 for gpio=55(G:7)
[ 2.332832] mmc0: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.376828] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[ 2.397787] usb 1-3: New USB device found, idVendor=13d3, idProduct=3549
[ 2.397794] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.397799] usb 1-3: Product: Bluetooth Radio
[ 2.397804] usb 1-3: Manufacturer: Realtek
[ 2.397807] usb 1-3: SerialNumber: 00e04c000001
[ 2.422055] OPE platform probe
[ 2.422211] OPE platform probe successful
[ 2.503045] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 2.503212] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 2.503344] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 2.503453] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 2.503570] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 2.503691] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 2.503797] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 2.503903] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 2.504045] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 2.504167] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 2.504279] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 2.504388] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 2.504499] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 2.504633] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 2.504743] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 2.504879] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 2.505025] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 2.505150] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 2.505258] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 2.505369] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 2.517618] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.544963] u32 classifier
[ 2.544969] Actions configured
[ 2.545065] Initializing XFRM netlink socket
[ 2.545677] NET: Registered protocol family 10
[ 2.546512] NET: Registered protocol family 17
[ 2.546527] NET: Registered protocol family 15
[ 2.546583] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 2.546703] Bluetooth: RFCOMM socket layer initialized
[ 2.546726] Bluetooth: RFCOMM ver 1.11
[ 2.546734] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.546740] Bluetooth: HIDP socket layer initialized
[ 2.546757] 9pnet: Installing 9P2000 support
[ 2.546805] Key type dns_resolver registered
[ 2.547776] Registered cp15_barrier emulation handler
[ 2.547803] Registered setend emulation handler
[ 2.550604] registered taskstats version 1
[ 2.551363] tegra-pcie-dw 14160000.pcie: Setting init speed to max speed
[ 2.557786] OF: PCI: host bridge /pcie@14160000 ranges:
[ 2.557804] OF: PCI: IO 0x36100000..0x361fffff -> 0x36100000
[ 2.557828] OF: PCI: MEM 0x1740000000..0x17ffffffff -> 0x40000000
[ 2.557834] OF: PCI: MEM 0x1400000000..0x173fffffff -> 0x1400000000
[ 2.584649] tegra_cec 3960000.tegra_cec: Can't find physical addresse.
[ 2.584654] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[ 2.667838] mmc0: hw tuning done ...
[ 2.667902] mmc0: new ultra high speed SDR104 SDXC card at address aaaa
[ 2.668486] mmcblk0: mmc0:aaaa SC64G 59.5 GiB
[ 2.668667] tegra-pcie-dw 14160000.pcie: link is up
[ 2.668968] tegra-pcie-dw 14160000.pcie: PCI host bridge to bus 0004:00
[ 2.668975] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 2.668982] pci_bus 0004:00: root bus resource [io 0x0000-0xfffff] (bus address [0x36100000-0x361fffff])
[ 2.668989] pci_bus 0004:00: root bus resource [mem 0x1740000000-0x17ffffffff] (bus address [0x40000000-0xffffffff])
[ 2.669012] pci_bus 0004:00: root bus resource [mem 0x1400000000-0x173fffffff pref]
[ 2.669040] pci 0004:00:00.0: [10de:1ad1] type 01 class 0x060400
[ 2.669200] pci 0004:00:00.0: PME# supported from D0 D3hot D3cold
[ 2.669410] iommu: Adding device 0004:00:00.0 to group 58
[ 2.669815] pci 0004:01:00.0: [10ec:c822] type 00 class 0x028000
[ 2.669953] pci 0004:01:00.0: reg 0x10: [io 0x1000-0x10ff]
[ 2.670156] pci 0004:01:00.0: reg 0x18: [mem 0x1740000000-0x174000ffff 64bit]
[ 2.670935] pci 0004:01:00.0: supports D1 D2
[ 2.670939] pci 0004:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.671267] iommu: Adding device 0004:01:00.0 to group 59
[ 2.674280] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
[ 2.681897] pci 0004:00:00.0: BAR 14: assigned [mem 0x1740000000-0x17400fffff]
[ 2.681921] pci 0004:00:00.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.681929] pci 0004:01:00.0: BAR 2: assigned [mem 0x1740000000-0x174000ffff 64bit]
[ 2.682011] pci 0004:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 2.682038] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 2.682043] pci 0004:00:00.0: bridge window [io 0x1000-0x1fff]
[ 2.682050] pci 0004:00:00.0: bridge window [mem 0x1740000000-0x17400fffff]
[ 2.682069] pci 0004:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 2.682128] pci 0004:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 2.682489] pcieport 0004:00:00.0: Signaling PME through PCIe PME interrupt
[ 2.682494] pci 0004:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.682500] pcie_pme 0004:00:00.0:pcie001: service driver pcie_pme loaded
[ 2.682602] aer 0004:00:00.0:pcie002: service driver aer loaded
[ 2.683205] tegra-pcie-dw 141a0000.pcie: Setting init speed to max speed
[ 2.684163] OF: PCI: host bridge /pcie@141a0000 ranges:
[ 2.684177] OF: PCI: IO 0x3a100000..0x3a1fffff -> 0x3a100000
[ 2.684185] OF: PCI: MEM 0x1f40000000..0x1fffffffff -> 0x40000000
[ 2.684191] OF: PCI: MEM 0x1c00000000..0x1f3fffffff -> 0x1c00000000
[ 2.713298] FAN rising trip_level:2 cur_temp:60000 trip_temps[3]:68000
[ 2.792646] tegra-pcie-dw 141a0000.pcie: link is up
[ 2.792949] tegra-pcie-dw 141a0000.pcie: PCI host bridge to bus 0005:00
[ 2.792957] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 2.792966] pci_bus 0005:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x3a100000-0x3a1fffff])
[ 2.792971] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[ 2.792975] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[ 2.793004] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 2.793137] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[ 2.793361] iommu: Adding device 0005:00:00.0 to group 60
[ 2.793640] pci 0005:01:00.0: [c0a9:540a] type 00 class 0x010802
[ 2.793751] pci 0005:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 2.794624] iommu: Adding device 0005:01:00.0 to group 61
[ 2.806968] pci 0005:00:00.0: BAR 14: assigned [mem 0x1f40000000-0x1f400fffff]
[ 2.806976] pci 0005:01:00.0: BAR 0: assigned [mem 0x1f40000000-0x1f40003fff 64bit]
[ 2.807035] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 2.807042] pci 0005:00:00.0: bridge window [mem 0x1f40000000-0x1f400fffff]
[ 2.807056] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 2.807114] pci 0005:01:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 512
[ 2.807338] pcieport 0005:00:00.0: Signaling PME through PCIe PME interrupt
[ 2.807342] pci 0005:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.807348] pcie_pme 0005:00:00.0:pcie001: service driver pcie_pme loaded
[ 2.807434] aer 0005:00:00.0:pcie002: service driver aer loaded
[ 2.807892] nvme nvme0: pci function 0005:01:00.0
[ 2.807975] nvme 0005:01:00.0: enabling device (0000 -> 0002)
[ 2.818387] tegra-cbb 14040000.cv-noc: noc_secure_irq = 89, noc_nonsecure_irq = 88>
[ 2.825264] tegra194-isp5 14800000.isp: initialized
[ 2.832402] tegra194-vi5 15c10000.vi: using default number of vi channels, 36
[ 2.838843] tegra194-vi5 15c10000.vi: initialized
[ 2.843805] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi--2 bound
[ 2.843868] tegra194-vi5 15c10000.vi: subdev ALVIUM 1800 C-158c 10-3c bound
[ 2.843875] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi--1 bound
[ 2.846314] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 2.930970] tegra-ivc ivc-bc00000.rtcpu: region 0: iova=0xbfee0000-0xbfefffff size=131072
[ 2.931280] tegra-ivc ivc-bc00000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 2.931464] tegra-ivc ivc-bc00000.rtcpu:dbg@1: dbg: ver=0 grp=1 RX[1x384]=0x1900-0x1b00 TX[1x384]=0x1b00-0x1d00
[ 2.931602] tegra-ivc ivc-bc00000.rtcpu:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d00-0x3d80 TX[1x8192]=0x3d80-0x5e00
[ 2.931987] tegra-ivc ivc-bc00000.rtcpu:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e00-0xae80 TX[64x320]=0xae80-0xff00
[ 2.932083] tegra-ivc ivc-bc00000.rtcpu:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff00-0x17f80 TX[512x64]=0x17f80-0x20000
[ 2.932288] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (65)
[ 2.932292] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 2.933186] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=5 sha1=cf2bef3ad10e437272857b76308abef8ffb80bda
[ 2.933631] gpio tegra-gpio wake67 for gpio=48(G:0)
[ 2.933707] gpio tegra-gpio-aon wake29 for gpio=36(EE:4)
[ 2.933869] input: gpio-keys as /devices/gpio-keys/input/input4
[ 2.960658] usb 1-2.1: new high-speed USB device number 4 using tegra-xusb
[ 2.965762] tegra_rtc c2a0000.rtc: setting system clock to 2021-02-03 13:36:58 UTC (1612359418)
[ 2.966306] mmcblk mmc0:aaaa: Card claimed for testing.
[ 2.981277] usb 1-2.1: New USB device found, idVendor=1ab2, idProduct=0001
[ 2.981285] usb 1-2.1: New USB device strings: Mfr=2, Product=3, SerialNumber=4
[ 2.981289] usb 1-2.1: Product: ALVIUM 1800 U-501m NIR
[ 2.981292] usb 1-2.1: Manufacturer: Allied Vision
[ 2.981296] usb 1-2.1: SerialNumber: 00609
[ 3.005343] bpmp: mounted debugfs mirror
[ 3.012477] vdd-1v8-sd: disabling
[ 3.012484] vdd-1v8-cvb: disabling
[ 3.012486] vdd-epb-1v0: disabling
[ 3.012489] avdd-cam-2v8: disabling
[ 3.012493] vdd_sys_en: disabling
[ 3.012500] ALSA device list:
[ 3.012503] #0: tegra-hda-galen-t194 at 0x3518000 irq 64
[ 3.012506] #1: jetson-xaviernx-ape
[ 3.014506] Freeing unused kernel memory: 8576K
[ 3.052417] Root device found: mmcblk0p1
[ 3.053992] Found dev node: /dev/mmcblk0p1
[ 3.064711] usb 1-2.4: new full-speed USB device number 5 using tegra-xusb
[ 3.085955] usb 1-2.4: New USB device found, idVendor=1a86, idProduct=7523
[ 3.085963] usb 1-2.4: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 3.085967] usb 1-2.4: Product: USB2.0-Serial
[ 3.108661] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 3.109569] Rootfs mounted over mmcblk0p1
[ 3.136891] Switching from initrd to actual rootfs
[ 3.372443] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.376978] cgroup: cgroup2: unknown option "nsdelegate"
[ 3.415130] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 3.415761] systemd[1]: Detected architecture arm64.
[ 3.421854] systemd[1]: Set hostname to <duoteknx>.
[ 3.548777] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 3.548789] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 3.676389] systemd[1]: /etc/systemd/system/autossh.service:1: Assignment outside of section. Ignoring.
[ 3.676415] systemd[1]: /etc/systemd/system/autossh.service:2: Assignment outside of section. Ignoring.
[ 3.676432] systemd[1]: /etc/systemd/system/autossh.service:3: Assignment outside of section. Ignoring.
[ 3.676461] systemd[1]: /etc/systemd/system/autossh.service:4: Assignment outside of section. Ignoring.
[ 3.719740] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.722603] systemd[1]: Created slice User and Session Slice.
[ 3.722938] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.723445] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.798252] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 3.873507] nvgpu: 17000000.gv11b nvgpu_nvhost_syncpt_init:291 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 400000 size 1000
[ 4.075177] systemd-journald[2322]: Received request to flush runtime journal from PID 1
[ 6.051124] Wake76 for irq=199
[ 6.051138] Wake77 for irq=199
[ 6.051140] Wake78 for irq=199
[ 6.051143] Wake79 for irq=199
[ 6.051146] Wake80 for irq=199
[ 6.051148] Wake81 for irq=199
[ 6.051150] Wake82 for irq=199
[ 6.051200] tegra-xusb 3610000.xhci: Upgrade port 0 to USB3.0
[ 6.051205] tegra-xusb 3610000.xhci: Upgrade port 1 to USB3.0
[ 6.139699] usbcore: registered new interface driver btusb
[ 6.144362] rtk_btusb: Realtek Bluetooth USB driver ver 3.1
[ 6.144370] rtk_btcoex: rtk_btcoex_init: version: 1.2
[ 6.144373] rtk_btcoex: create workqueue
[ 6.148581] rtk_btcoex: alloc buffers 1792, 2432 for ev and l2
[ 6.148784] rtk_btusb: btusb_probe intf->cur_altsetting->desc.bInterfaceNumber 0
[ 6.148789] rtk_btusb: btusb_probe can_wakeup 1, may wakeup 0
[ 6.148793] rtk_btusb: patch_add
[ 6.148796] rtk_btusb: auto suspend is disabled
[ 6.148799] rtk_btusb: pid = 0x3549
[ 6.148803] rtk_btusb: patch_add: Reset gEVersion to 0xff
[ 6.148815] rtk_btusb: set_bit(HCI_QUIRK_RESET_ON_CLOSE, &hdev->quirks);
[ 6.149366] rtk_btusb: btusb_probe: done
[ 6.149378] rtk_btusb: btusb_open start
[ 6.149383] rtk_btusb: btusb_open hdev->promisc ==0
[ 6.149436] usbcore: registered new interface driver rtk_btusb
[ 6.149510] rtk_btusb: download_patch start
[ 6.149515] rtk_btusb: chip type value: 0x73
[ 6.149520] rtk_btusb: HCI reset.
[ 6.160449] rtk_btusb: read_ver_rsp->lmp_subver = 0x8822
[ 6.160458] rtk_btusb: read_ver_rsp->hci_rev = 0xc
[ 6.160463] rtk_btusb: patch_entry->lmp_sub = 0x8822
[ 6.160466] rtk_btusb: load_firmware start
[ 6.160470] rtk_btusb: lmp_version = 0x8822
[ 6.160473] rtk_btusb: config filename rtl8822cu_config
[ 6.164819] rtk_btusb: no bdaddr file /opt/bdaddr
[ 6.164827] rtk_btusb: 55 ab 23 87 00 00
[ 6.164839] rtk_btusb: Config file length 6, new length 6
[ 6.164842] rtk_btusb: fw name is rtl8822cu_fw
[ 6.166040] rtk_btusb: This is not 8723a, use new patch style!
[ 6.166183] rtk_btusb: rtk_get_eversion: gEVersion 255
[ 6.167412] rtk_btusb: eversion->status = 0x0, eversion->version = 0x3
[ 6.167420] rtk_btusb: load_firmware: New gEVersion 3
[ 6.167424] rtk_btusb: rtk_get_fw_project_id: opcode 0, len 1, data 13
[ 6.167428] rtk_btusb: lmp_version is 8822, project_id is 8822, match!
[ 6.167431] rtk_btusb: fw_version = 0x98a42f7
[ 6.167434] rtk_btusb: number_of_total_patch = 3
[ 6.167437] rtk_btusb: chipID 4
[ 6.167440] rtk_btusb: patch_length 0x55f0
[ 6.167443] rtk_btusb: start_offset 0x00005d00
[ 6.167446] rtk_btusb: Svn version: 21761
[ 6.167450] rtk_btusb: Coexistence: BTCOEX_20190509-0d0d
[ 6.167452] rtk_btusb: buf_len = 0x55f6
[ 6.167467] rtk_btusb: fw: exists, config file: exists
[ 6.167469] rtk_btusb: load_firmware done
[ 6.167489] rtk_btusb: download_data start
[ 6.184067] EXT4-fs (nvme0n1): mounted filesystem with ordered data mode. Opts: (null)
[ 6.282431] rtk_btusb: download_data done
[ 6.282439] rtk_btusb: HCI reset.
[ 6.293398] rtk_btusb: read_ver_rsp->lmp_subver = 0x42f7
[ 6.293405] rtk_btusb: read_ver_rsp->hci_rev = 0x98a
[ 6.293409] rtk_btusb: patch_entry->lmp_sub = 0x8822
[ 6.293419] rtk_btusb: Rtk patch end 0
[ 6.293424] rtk_btusb: btusb_open set HCI_RUNNING
[ 6.293448] rtk_btcoex: Open BTCOEX
[ 6.293451] rtk_btusb: btusb_open end
[ 6.295401] rtk_btcoex: BTCOEX hci_rev 0x098a
[ 6.295406] rtk_btcoex: BTCOEX lmp_subver 0x42f7
[ 6.315403] rtk_btusb: btusb_notify: hci0 evt 3
[ 6.381616] usb 2-3: new SuperSpeedPlus USB device number 2 using tegra-xusb
[ 6.418128] usb 2-3: New USB device found, idVendor=0bda, idProduct=0489
[ 6.418136] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.418141] usb 2-3: Product: 4-Port USB 3.0 Hub
[ 6.418145] usb 2-3: Manufacturer: Generic
[ 6.428032] hub 2-3:1.0: USB hub found
[ 6.429433] hub 2-3:1.0: 4 ports detected
[ 6.474312] usbcore: registered new interface driver ch341
[ 6.474408] usbserial: USB Serial support registered for ch341-uart
[ 6.474447] ch341 1-2.4:1.0: ch341-uart converter detected
[ 6.477404] usb 1-2.4: ch341-uart converter now attached to ttyUSB0
[ 7.148911] usb 2-3.2: new SuperSpeed USB device number 3 using tegra-xusb
[ 7.173278] usb 2-3.2: New USB device found, idVendor=1ab2, idProduct=0001
[ 7.173287] usb 2-3.2: New USB device strings: Mfr=2, Product=3, SerialNumber=4
[ 7.173291] usb 2-3.2: Product: ALVIUM 1800 U-501m NIR
[ 7.173295] usb 2-3.2: Manufacturer: Allied Vision
[ 7.173298] usb 2-3.2: SerialNumber: 00608
[ 7.444698] random: crng init done
[ 7.444807] random: 7 urandom warning(s) missed due to ratelimiting
[ 7.955771] Adding 33554428k swap on /home/duoteknx/nvme/swapfile. Priority:-1 extents:27 across:35872764k SS
[ 8.084115] using random self ethernet address
[ 8.084240] using random host ethernet address
[ 8.372684] rtk_btusb: btusb_flush add delay
[ 8.383495] rtk_btusb: btusb_close
[ 8.395331] rtk_btcoex: Close BTCOEX
[ 8.395338] rtk_btcoex: -x
[ 8.438032] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 8.438048] Bluetooth: BNEP socket layer initialized
[ 8.454073] rtk_btusb: btusb_open start
[ 8.454082] rtk_btusb: btusb_open hdev->promisc ==0
[ 8.454212] rtk_btusb: download_patch start
[ 8.454218] rtk_btusb: chip type value: 0x73
[ 8.454223] rtk_btusb: HCI reset.
[ 8.465414] rtk_btusb: read_ver_rsp->lmp_subver = 0x42f7
[ 8.465422] rtk_btusb: read_ver_rsp->hci_rev = 0x98a
[ 8.465425] rtk_btusb: patch_entry->lmp_sub = 0x8822
[ 8.465428] rtk_btusb: Firmware already exists
[ 8.465435] rtk_btusb: Rtk patch end 1
[ 8.465438] rtk_btusb: btusb_open set HCI_RUNNING
[ 8.465475] rtk_btcoex: Open BTCOEX
[ 8.465480] rtk_btusb: btusb_open end
[ 8.467445] rtk_btcoex: BTCOEX hci_rev 0x098a
[ 8.467453] rtk_btcoex: BTCOEX lmp_subver 0x42f7
[ 9.058471] Mass Storage Function, version: 2009/09/11
[ 9.058486] LUN: removable file: (no medium)
[ 9.065103] using random self ethernet address
[ 9.065238] using random host ethernet address
[ 9.088323] rndis0: HOST MAC ae:51:f9:12:a0:fc
[ 9.088520] rndis0: MAC ae:51:f9:12:a0:fd
[ 9.093666] usb0: HOST MAC ae:51:f9:12:a0:fe
[ 9.093723] usb0: MAC ae:51:f9:12:a0:ff
[ 9.093748] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 9.097961] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 9.097981] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[ 9.098028] tegra-xudc-new 3550000.xudc: entering ELPG
[ 9.098242] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 9.098882] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 9.105310] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 9.106184] tegra-xudc-new 3550000.xudc: entering ELPG
[ 9.106420] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 9.110259] l4tbr0: port 1(rndis0) entered blocking state
[ 9.110267] l4tbr0: port 1(rndis0) entered disabled state
[ 9.110463] device rndis0 entered promiscuous mode
[ 9.115730] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 9.123040] l4tbr0: port 2(usb0) entered blocking state
[ 9.123048] l4tbr0: port 2(usb0) entered disabled state
[ 9.125650] device usb0 entered promiscuous mode
[ 9.131964] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 9.781370] nvgpu: 17000000.gv11b tpc_pg_mask_store:843 [INFO] no value change, same mask already set
[ 9.863468] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.189591] gpio tegra-gpio wake20 for gpio=52(G:4)
[ 10.195849] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.265182] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 10.561943] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 10.805250] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 11.784729] tegradc 15200000.nvdisplay: blank - powerdown
[ 11.784746] tegradc 15210000.nvdisplay: blank - powerdown
[ 12.675730] fuse init (API version 7.26)
[ 13.072372] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 13.073588] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 20.628934] FAN rising trip_level:1 cur_temp:57750 trip_temps[2]:60000
[ 276.470399] AVT: Default crop rect width 1456
[ 386.861250] FAN rising trip_level:2 cur_temp:60100 trip_temps[3]:68000
[ 390.193868] AVT: Default crop rect width 1456
[ 390.197792] avt_csi2 10-003c: avt_check_fmt_available: media_bus_fmt: 0x1013
[ 390.198189] avt_csi2 10-003c: avt_check_fmt_available: Camera available MIPI data formats: 0x1c0e0
[ 390.198405] avt_csi2 10-003c: avt_check_fmt_available: Camera bayer pattern inq: 0x4
[ 390.310675] misc tegra_camera_ctrl: tegra_camera_update_isobw: Warning, Requested ISO BW 2929687 has been capped to VI's max BW 1500000
[ 390.320935] [RCE] vi5_hwinit: firmware CL2018101701 protocol version 2.2
[ 394.316814] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 394.316966] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 4000 ms
[ 394.317140] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 394.319724] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ 398.412723] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 398.412876] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 4000 ms
[ 398.413025] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 398.413171] tegra194-vi5 15c10000.vi: unexpected response from camera processor
[ 398.413303] video4linux video0: vi capture release failed
[ 398.413399] tegra194-vi5 15c10000.vi: fatal: error recovery failed
[ 430.461584] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[ 430.461788] Mem abort info:
[ 430.461850] ESR = 0x96000005
[ 430.461909] Exception class = DABT (current EL), IL = 32 bits
[ 430.462015] SET = 0, FnV = 0
[ 430.462075] EA = 0, S1PTW = 0
[ 430.462136] Data abort info:
[ 430.462193] ISV = 0, ISS = 0x00000005
[ 430.462263] CM = 0, WnR = 0
[ 430.462356] user pgtable: 4k pages, 39-bit VAs, pgd = ffffffc1bd675000
[ 430.462470] [0000000000000000] *pgd=0000000000000000, *pud=0000000000000000
[ 430.462609] Internal error: Oops: 96000005 [#1] PREEMPT SMP
[ 430.462714] Modules linked in: fuse overlay bnep ch341 rtk_btusb btusb btrtl btbcm btintel rtl8822ce cfg80211 spidev nvgpu bluedroid_pm ip_tables x_tables
[ 430.463101] CPU: 5 PID: 8126 Comm: gst-launch-1.0 Not tainted 4.9.140-ga01070fee #30
[ 430.463582] Hardware name: NVIDIA Jetson Xavier NX Developer Kit (DT)
[ 430.464079] task: ffffffc1bd641c00 task.stack: ffffffc1c7288000
[ 430.464539] PC is at exit_creds+0x2c/0x78
[ 430.465212] LR is at __put_task_struct+0x4c/0x140
[ 430.469590] pc : [<ffffff80080def7c>] lr : [<ffffff80080b01ac>] pstate: 60400045
[ 430.477284] sp : ffffffc1c728ba00
[ 430.480704] x29: ffffffc1c728ba00 x28: 0000000000000000
[ 430.485958] x27: ffffffc1f0fa0800 x26: 0000000000000001
[ 430.491646] x25: ffffff8009fcf1a8 x24: 0000000000000013
[ 430.496983] x23: 0000000000000000 x22: 0000000000000001
[ 430.502144] x21: ffffffc1f0521c30 x20: 0000000000000000
[ 430.507732] x19: ffffffc1f0521c00 x18: 0000007f957efa70
[ 430.513419] x17: 0000007f958b9910 x16: 0000000000000000
[ 430.519194] x15: 000000000000035a x14: 000000000000001f
[ 430.524632] x13: 0000000000000000 x12: 000000000000617b
[ 430.530143] x11: 000000000000637d x10: 0000000000000a10
[ 430.536171] x9 : ffffffc1c728b850 x8 : ffffffc1bd642670
[ 430.541698] x7 : ffffffc1ffd90b28 x6 : 0000000339d25a06
[ 430.547458] x5 : 0000000000000800 x4 : 0000000000000000
[ 430.552544] x3 : 00000000000000ba x2 : 0000000000000000
[ 430.557883] x1 : 0000000000000000 x0 : 00000000ffffffff
[ 430.564879] Process gst-launch-1.0 (pid: 8126, stack limit = 0xffffffc1c7288000)
[ 430.571789] Call trace:
[ 430.574414] [<ffffff80080def7c>] exit_creds+0x2c/0x78
[ 430.578966] [<ffffff80080b01ac>] __put_task_struct+0x4c/0x140
[ 430.584304] [<ffffff80080dca3c>] kthread_stop+0x1e4/0x1e8
[ 430.589643] [<ffffff8008b53094>] vi5_channel_stop_kthreads+0x54/0x130
[ 430.595505] [<ffffff8008b531fc>] vi5_channel_stop_streaming+0x8c/0xa8
[ 430.601890] [<ffffff8008b44d94>] tegra_channel_stop_streaming+0x34/0x48
[ 430.608100] [<ffffff8008b3cca4>] __vb2_queue_cancel+0x34/0x188
[ 430.613701] [<ffffff8008b3e2d8>] vb2_core_streamoff+0x60/0xc8
[ 430.619037] [<ffffff8008b4185c>] vb2_streamoff+0x54/0x88
[ 430.624112] [<ffffff8008b418e4>] vb2_ioctl_streamoff+0x54/0x60
[ 430.629800] [<ffffff8008b46510>] tegra_channel_streamoff+0x40/0x58
[ 430.635670] [<ffffff8008b1b6c4>] v4l_streamoff+0x3c/0x50
[ 430.641262] [<ffffff8008b2071c>] __video_do_ioctl+0x204/0x2c8
[ 430.646862] [<ffffff8008b200c8>] video_usercopy+0x2a0/0x6a0
[ 430.652379] [<ffffff8008b20504>] video_ioctl2+0x3c/0x50
[ 430.657799] [<ffffff8008b19fc0>] v4l2_ioctl+0x88/0x118
[ 430.662963] [<ffffff80082724a8>] do_vfs_ioctl+0xb0/0x8d8
[ 430.668129] [<ffffff8008272d5c>] SyS_ioctl+0x8c/0xa8
[ 430.673200] [<ffffff8008083900>] el0_svc_naked+0x34/0x38
[ 430.678543] ---[ end trace 134e0958c7e6c05e ]---
