It seemed to work fine building from 32.5.1 first (even if I had to replace some Status to Argus::Status in gstnvarguscamerasrc.cpp) but I realized the pictures are all green and small size, I don’t have any error messages.
After this I build libgstnvarguscamerasrc.so from R32.4.4 from this link: L4T R32.4.4 archive | NVIDIA Developer but I have ugly errors launching the pipeline:
sudo gst-launch-1.0 nvarguscamerasrc sensor-id=0 tnr-mode=2 tnr-strength=1 ee-mode=0 exposuretimerange="200000 1000000" wbmode=6 awblock=false ! 'video/x-raw(memory:NVMM), width=(int)3264, height=(int)2464, format=(string)NV12, framerate=(fraction)21/1' ! nvjpegenc quality=85 ! multifilesink location=test.jpg
GST_ARGUS: NvArgusCameraSrc: Setting Exposure Time Range : 200000 1000000
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module1
OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
---- imager: Found override file [/var/nvidia/nvcam/settings/camera_overrides.isp]. ----
NvCameraIspConfigFileLoad: type = 0x5 Config file "common.cfg" Line 460: Error: Bad parameter: "ae.CameraEfficiency=0.1508"
NvCameraIspConfigFileLoad: type = 0x5 Config file "common.cfg" Line 473: Error: Bad parameter: "ae.MeanAlg.ConvergeSpeed=0.10"
NvCameraIspConfigFileLoad: type = 0x5 Config file "common.cfg" Line 810: Error: Bad parameter: "awb.convergeSpeed=0.3"
NvCameraIspConfigFileLoad: type = 0x5 Config file "common.cfg" Line 3100: Error: Bad parameter: "af.alg.over_scan_percent=0.15"
NvCameraIspConfigFileLoad: type = 0x5 Config file "common.cfg" Line 3101: Error: Bad parameter: "af.alg.smooth_over_scan_percent=0.035"
NvCameraIspConfigFileLoad: type = 0x5 Config file "common.cfg" Line 3107: Error: Bad parameter: "af.alg.scene_change_t_guard_factor=0.30f"
NvCameraIspConfigFileLoad: type = 0x5 Config file "common.cfg" Line 3108: Error: Bad parameter: "af.alg.scene_stable_sharpness=0.15f"
NvCameraIspConfigFileLoad: type = 0x5 Config file "common.cfg" Line 3109: Error: Bad parameter: "af.alg.scene_change_sharpness=0.30f"
Motion points are not strictly ascending.NvCameraIspConfigFileLoad: type = 0x5 Config file "common.cfg" Line 4524: Error: 11: "tnr.v1.consistencyPoints={0.00,0.25,0.50,0.75,1.00}"
(NvCamV4l2) Error ModuleNotPresent: V4L2Device not available (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function findDevice(), line 256)
(NvCamV4l2) Error ModuleNotPresent: (propagating from /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function initialize(), line 60)
(NvOdmDevice) Error ModuleNotPresent: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function initialize(), line 106)
NvPclDriverInitializeData: Unable to initialize driver v4l2_sensor
NvPclInitializeDrivers: error: Failed to init camera sub module v4l2_sensor
NvPclStartPlatformDrivers: Failed to start module drivers
NvPclStateControllerOpen: Failed ImagerGUID 0. (error 0xA000E)
NvPclOpen: PCL Open Failed. Error: 0xf
SCF: Error BadParameter: Sensor could not be opened. (in src/services/capture/CaptureServiceDeviceSensor.cpp, function getSourceFromGuid(), line 582)
SCF: Error BadParameter: (propagating from src/services/capture/CaptureService.cpp, function addSourceByGuid(), line 437)
SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function addSourceByIndex(), line 295)
SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function getSource(), line 458)
Acquiring SCF Camera device source via index 1 has failed. NvCameraIspConfigFileLoad: type = 0x5 Config file "common.cfg" Line 460: Error: Bad parameter: "ae.CameraEfficiency=0.1508"
GST_ARGUS: Creating output stream
FNET: Error in /dvs/git/dirty/git-master_linux/camera/utils/nvfnet/src/common/value.cpp function set() line 95
Invalid default value of type 'vec2'
FNET: Error in /dvs/git/dirty/git-master_linux/camera/utils/nvfnet/src/common/attribute.h function setDefault() line 452
(propagating)
FNET: Error in /dvs/git/dirty/git-master_linux/camera/utils/nvfnet/src/common/node.cpp function handleElementAttribute() line 666
(propagating)
FNET: Error in /dvs/git/dirty/git-master_linux/camera/utils/nvfnet/src/filters/filterUser.cpp function handleElementFilter() line 73
(propagating)
FNET: Error in /dvs/git/dirty/git-master_linux/camera/utils/nvfnet/src/filters/filterUser.cpp function xmlHandleStartElementFilter() line 49
(propagating)
FNET: Error in /dvs/git/dirty/git-master_linux/camera/utils/nvfnet/src/common/xmlParse.cpp function parse() line 146
parsing aborted at line 10:81:
<attribute name="repetitions" type="parameter" dataType="uint" default="1"/>
<!-- Flow -->
FNET: Error in /dvs/git/dirty/git-master_linux/camera/utils/nvfnet/src/common/node.cpp function create() line 339
(propagating)
FNET: Error in /dvs/git/dirty/git-master_linux/camera/utils/nvfnet/src/common/node.cpp function create() line 41
(propagating)
FNET: Error in /dvs/git/dirty/git-master_linux/camera/utils/nvfnet/storeHDFX/StoreHDFX.cpp function create() line 92
Out of memory
FNET: Error in /dvs/git/dirty/git-master_linux/camera/utils/nvfnet/src/common/node.cpp function load() line 317
(propagating)
FNET: Error in /dvs/git/dirty/git-master_linux/camera/utils/nvfnet/src/networks/networkUser.cpp function handleElementNetwork() line 103
(propagating)
FNET: Error in /dvs/git/dirty/git-master_linux/camera/utils/nvfnet/src/networks/networkUser.cpp function xmlHandleStartElementNetwork() line 52
(propagating)
parsing aborted at line 6:53:
<node name="lowpass" file="filters/box3x3.xml"/>
<node name="ltmFilter" file="filters/ltm.x
(propagating)
(propagating)
Out of memory
(propagating)
(propagating)
(propagating)
parsing aborted at line 6:46:
<!-- Parameters -->
<export name="Quality" from="ltm" attribute="quality" default="3" min=
(propagating)
(propagating)
Out of memory
SCF: Error InsufficientMemory: (propagating from src/components/stages/AoltmStage.cpp, function doAsyncInitialize(), line 100)
SCF: Error InsufficientMemory: AoltmStage initialization failed (in src/components/stages/AoltmStage.cpp, function doAsyncInitialize(), line 130)
FNET: Error in /dvs/git/dirty/git-master_linux/camera/utils/nvfnet/src/common/value.cpp function set() line 115
Invalid default value of type 'vec4'
(propagating)
(propagating)
(propagating)
(propagating)
parsing aborted at line 13:96:
<!-- Flow -->
<flow operation="execute"/>
<flow operation="detach" operand0="inputImag
(propagating)
(propagating)
SCF: Error InsufficientMemory: (propagating from src/components/stages/SharpenStage.cpp, function doAsyncInitialize(), line 159)
SCF: Error InsufficientMemory: SharpenStage initialization failed (in src/components/stages/SharpenStage.cpp, function doAsyncInitialize(), line 182)
(propagating)
(propagating)
(propagating)
(propagating)
parsing aborted at line 24:81:
<!-- Flow -->
<flow operation='clone' operand0='inputImageY' operand1='outputImageY' opera
(propagating)
(propagating)
FNET: Error in /dvs/git/dirty/git-master_linux/camera/utils/nvfnet/samples/deFog/StoreDeFog.cpp function create() line 66
Out of memory
(propagating)
(propagating)
(propagating)
parsing aborted at line 15:57:
<node name='transmissionMap' file='networks/transmissionMapBlockYCbCr420.xml'/>
<node name=
(propagating)
(propagating)
Out of memory
SCF: Error InsufficientMemory: (propagating from src/components/stages/DeFogStage.cpp, function doAsyncInitialize(), line 91)
SCF: Error InsufficientMemory: DeFogStage initialization failed (in src/components/stages/DeFogStage.cpp, function doAsyncInitialize(), line 151)
(propagating)
(propagating)
(propagating)
(propagating)
<!-- Flow -->
(propagating)
(propagating)
Out of memory
(propagating)
(propagating)
(propagating)
<node name="ltmFilter" file="filters/ltm42
(propagating)
(propagating)
Out of memory
(propagating)
(propagating)
(propagating)
parsing aborted at line 6:49:
<!-- Parameters -->
(propagating)
(propagating)
Out of memory
SCF: Error InsufficientMemory: (propagating from src/components/stages/HdfxStage.cpp, function doAsyncInitialize(), line 147)
SCF: Error InsufficientMemory: HdfxStage initialization failed (in src/components/stages/HdfxStage.cpp, function doAsyncInitialize(), line 252)
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3264 x 2464 FR = 21,000000 fps Duration = 47619048 ; Analog Gain range min 1,000000, max 10,625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3264 x 1848 FR = 28,000001 fps Duration = 35714284 ; Analog Gain range min 1,000000, max 10,625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29,999999 fps Duration = 33333334 ; Analog Gain range min 1,000000, max 10,625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59,999999 fps Duration = 16666667 ; Analog Gain range min 1,000000, max 10,625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 120,000005 fps Duration = 8333333 ; Analog Gain range min 1,000000, max 10,625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 0
Output Stream W = 3264 H = 2464
seconds to Run = 0
Frame Rate = 21,000000
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
(Autocontrol) Error BadParameter: Invalid use or bad call parameters (in src/algorithms/blender/blender.cpp, function interpolateValInternal(), line 306)
(Autocontrol) Error BadParameter: (propagating from src/algorithms/blender/blender.cpp, function NvIspParamBlenderInterpolateValue(), line 156)
(Camera_ISP) Error BadParameter: (propagating from state_update/blocks/SAPOR.cpp, function NvCameraIspUpdateState_SAPOR_isp2(), line 50)
(Camera_ISP) Error BadParameter: (propagating from state_update/nvcamera_isp_update_state.cpp, function NvCameraIspUpdateInputStateHw(), line 92)
SCF: Error BadParameter: (propagating from src/services/autocontrol/NvCameraIspDriver.cpp, function generate(), line 1161)
SCF: Error BadParameter: (propagating from src/components/ac_stages/AcMergeStage.cpp, function doHandleRequest(), line 84)
SCF: Error BadParameter: (propagating from src/components/stages/OrderedStage.cpp, function doExecute(), line 158)
SCF: Error BadParameter: Sending critical error event (in src/api/Session.cpp, function sendErrorEvent(), line 990)
^Chandling interrupt.
Interrupt: Stopping pipeline ...
Execution ended after 0:00:02.973776221
Setting pipeline to READY ...
SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceEvent.cpp, function wait(), line 59)
Error: Camera HwEvents wait, this may indicate a hardware timeout occured,abort current/incoming cc
I would expect the md5sum of my original file libgstnvarguscamerasrc.so to be the same building from R32.4.4 as my version of L4T is R32.4.4 but it’s not the case.
Original md5sum : ecab5907ea47d64a8ad6f2682fbf4a6f
build R32.4.4 : e4bd02295b40d8117130aa49d7243ef7
build R32.5.1 : 3ee9ef09cad88f76a1acb5b0eae285ed
The easy way to get around this issue would be to reflash the boot sd card on the latest version but I can’t as I can only acces the jetson nano by openVPN and the box around the computer is not supposed to be dismantled. Or is it a way to upgrade L4T without having to flash anything?
Could you please provide me a libgstnvarguscamerasrc.so or the source code of gst-nvarguscamera that could fit my setup? Or just indications on the step in building libgstnvarguscamerasrc.so I’m missing? I stricly followed the README.txt in gst-nvarguscamera.
I also tried to update or not update jetson_multimedia_api by doing sudo apt install nvidia-l4t-jetson-multimedia-api
Same with sudo apt-get install libgstreamer1.0-dev \ gstreamer1.0-plugins-base \ gstreamer1.0-plugins-good \ libgstreamer-plugins-base1.0-dev \ libegl1-mesa-dev
If it can help you:
git clone https://github.com/jetsonhacks/jetsonUtilities
cd jetsonUtilities
python jetsonInfo.py
NVIDIA Jetson Nano (Developer Kit Version)
L4T 32.4.4 [ JetPack 4.4.1 ]
Ubuntu 18.04.5 LTS
Kernel Version: 4.9.140-tegra
CUDA 10.2.89
CUDA Architecture: 5.3
OpenCV version: 4.1.1
OpenCV Cuda: NO
CUDNN: 8.0.0.180
TensorRT: 7.1.3.0
Vision Works: 1.6.0.501
VPI: 0.4.4
Vulcan: 1.2.70
Thank you for your help
