Hi all,
Now that you released the code for Nvarguscamerasrc (JetPack 4.4) I wanted to compile and give it a try.
I downloaded the sources and followed the steps to compile the element natively on a TX2 JetPack 4.4 (instructions in README.txt).
I was able to compile the code and install the element correctly. I did a gst-inspect-1.0 nvarguscamerasrc and the element seems correct. But the issue is when I try to capture, here is the log:
nvidia@nvidia:~/gst-nvarguscamera$ gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! fakesink
nvbuf_utils: Could not get EGL display connection
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module1
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module2
NvPclHwGetModuleList: WARNING: Could not map module to ISP config string
NvPclHwGetModuleList: No module data found
OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
---- imager: No override file found. ----
NvCameraIspConfigFileLoad: type = 0x5 Config file "common.cfg" Line 460: Error: Bad parameter: "ae.CameraEfficiency=0.1508"
NvCameraIspConfigFileLoad: type = 0x5 Config file "common.cfg" Line 473: Error: Bad parameter: "ae.MeanAlg.ConvergeSpeed=0.10"
NvCameraIspConfigFileLoad: type = 0x5 Config file "common.cfg" Line 810: Error: Bad parameter: "awb.convergeSpeed=0.3"
NvCameraIspConfigFileLoad: type = 0x5 Config file "common.cfg" Line 3100: Error: Bad parameter: "af.alg.over_scan_percent=0.15"
NvCameraIspConfigFileLoad: type = 0x5 Config file "common.cfg" Line 3101: Error: Bad parameter: "af.alg.smooth_over_scan_percent=0.035"
NvCameraIspConfigFileLoad: type = 0x5 Config file "common.cfg" Line 3107: Error: Bad parameter: "af.alg.scene_change_t_guard_factor=0.30f"
NvCameraIspConfigFileLoad: type = 0x5 Config file "common.cfg" Line 3108: Error: Bad parameter: "af.alg.scene_stable_sharpness=0.15f"
NvCameraIspConfigFileLoad: type = 0x5 Config file "common.cfg" Line 3109: Error: Bad parameter: "af.alg.scene_change_sharpness=0.30f"
Motion points are not strictly ascending.NvCameraIspConfigFileLoad: type = 0x5 Config file "common.cfg" Line 4524: Error: 11: "tnr.v1.consistencyPoints={0.00,0.25,0.50,0.75,1.00}"
GST_ARGUS: Creating output stream
FNET: Error in /dvs/git/dirty/git-master_linux/camera/utils/nvfnet/src/common/value.cpp function set() line 95
Invalid default value of type 'vec2'
FNET: Error in /dvs/git/dirty/git-master_linux/camera/utils/nvfnet/src/common/attribute.h function setDefault() line 452
(propagating)
FNET: Error in /dvs/git/dirty/git-master_linux/camera/utils/nvfnet/src/common/node.cpp function handleElementAttribute() line 666
(propagating)
FNET: Error in /dvs/git/dirty/git-master_linux/camera/utils/nvfnet/src/filters/filterUser.cpp function handleElementFilter() line 73
(propagating)
FNET: Error in /dvs/git/dirty/git-master_linux/camera/utils/nvfnet/src/filters/filterUser.cpp function xmlHandleStartElementFilter() line 49
(propagating)
FNET: Error in /dvs/git/dirty/git-master_linux/camera/utils/nvfnet/src/common/xmlParse.cpp function parse() line 146
parsing aborted at line 10:81:
<attribute name="repetitions" type="parameter" dataType="uint" default="1"/>
<!-- Flow -->
FNET: Error in /dvs/git/dirty/git-master_linux/camera/utils/nvfnet/src/common/node.cpp function create() line 339
(propagating)
FNET: Error in /dvs/git/dirty/git-master_linux/camera/utils/nvfnet/src/common/node.cpp function create() line 41
(propagating)
FNET: Error in /dvs/git/dirty/git-master_linux/camera/utils/nvfnet/storeHDFX/StoreHDFX.cpp function create() line 92
Out of memory
FNET: Error in /dvs/git/dirty/git-master_linux/camera/utils/nvfnet/src/common/node.cpp function load() line 317
(propagating)
FNET: Error in /dvs/git/dirty/git-master_linux/camera/utils/nvfnet/src/networks/networkUser.cpp function handleElementNetwork() line 103
(propagating)
FNET: Error in /dvs/git/dirty/git-master_linux/camera/utils/nvfnet/src/networks/networkUser.cpp function xmlHandleStartElementNetwork() line 52
(propagating)
parsing aborted at line 6:53:
<node name="lowpass" file="filters/box3x3.xml"/>
<node name="ltmFilter" file="filters/ltm.x
(propagating)
(propagating)
Out of memory
(propagating)
(propagating)
(propagating)
parsing aborted at line 6:46:
<!-- Parameters -->
<export name="Quality" from="ltm" attribute="quality" default="3" min=
(propagating)
(propagating)
Out of memory
SCF: Error InsufficientMemory: (propagating from src/components/stages/AoltmStage.cpp, function doAsyncInitialize(), line 100)
SCF: Error InsufficientMemory: AoltmStage initialization failed (in src/components/stages/AoltmStage.cpp, function doAsyncInitialize(), line 130)
FNET: Error in /dvs/git/dirty/git-master_linux/camera/utils/nvfnet/src/common/value.cpp function set() line 115
Invalid default value of type 'vec4'
(propagating)
(propagating)
(propagating)
(propagating)
parsing aborted at line 13:96:
<!-- Flow -->
<flow operation="execute"/>
<flow operation="detach" operand0="inputImag
(propagating)
(propagating)
SCF: Error InsufficientMemory: (propagating from src/components/stages/SharpenStage.cpp, function doAsyncInitialize(), line 159)
SCF: Error InsufficientMemory: SharpenStage initialization failed (in src/components/stages/SharpenStage.cpp, function doAsyncInitialize(), line 182)
(propagating)
(propagating)
(propagating)
(propagating)
<!-- Flow -->
(propagating)
(propagating)
Out of memory
(propagating)
(propagating)
(propagating)
<node name="ltmFilter" file="filters/ltm42
(propagating)
(propagating)
Out of memory
(propagating)
(propagating)
(propagating)
parsing aborted at line 6:49:
<!-- Parameters -->
(propagating)
(propagating)
Out of memory
SCF: Error InsufficientMemory: (propagating from src/components/stages/HdfxStage.cpp, function doAsyncInitialize(), line 147)
SCF: Error InsufficientMemory: HdfxStage initialization failed (in src/components/stages/HdfxStage.cpp, function doAsyncInitialize(), line 252)
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3840 x 2160 FR = 29,999999 fps Duration = 33333334 ; Analog Gain range min 1,000000, max 16,000000; Exposure Range min 16000, max 683709000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 0
Output Stream W = 3840 H = 2160
seconds to Run = 0
Frame Rate = 29,999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
(propagating)
(propagating)
(propagating)
(propagating)
parsing aborted at line 24:81:
<!-- Flow -->
<flow operation='clone' operand0='inputImageY' operand1='outputImageY' opera
(propagating)
(propagating)
FNET: Error in /dvs/git/dirty/git-master_linux/camera/utils/nvfnet/samples/deFog/StoreDeFog.cpp function create() line 66
Out of memory
(propagating)
(propagating)
(propagating)
parsing aborted at line 15:57:
<node name='transmissionMap' file='networks/transmissionMapBlockYCbCr420.xml'/>
<node name=
(propagating)
(propagating)
Out of memory
SCF: Error InsufficientMemory: (propagating from src/components/stages/DeFogStage.cpp, function doAsyncInitialize(), line 91)
SCF: Error InsufficientMemory: DeFogStage initialization failed (in src/components/stages/DeFogStage.cpp, function doAsyncInitialize(), line 151)
CONSUMER: Producer has connected; continuing.
(Autocontrol) Error BadParameter: Invalid use or bad call parameters (in src/algorithms/blender/blender.cpp, function interpolateValInternal(), line 306)
(Autocontrol) Error BadParameter: (propagating from src/algorithms/blender/blender.cpp, function NvIspParamBlenderInterpolateValue(), line 156)
(Camera_ISP) Error BadParameter: (propagating from state_update/blocks/SAPOR.cpp, function NvCameraIspUpdateState_SAPOR_isp2(), line 50)
(Camera_ISP) Error BadParameter: (propagating from state_update/blocks/SAPOR.cpp, function NvCameraIspUpdateState_SAPOR_isp4(), line 105)
(Camera_ISP) Error BadParameter: (propagating from state_update/nvcamera_isp_update_state.cpp, function NvCameraIspUpdateInputStateHw(), line 96)
SCF: Error BadParameter: (propagating from src/services/autocontrol/NvCameraIspDriver.cpp, function generate(), line 1161)
SCF: Error BadParameter: (propagating from src/components/ac_stages/AcMergeStage.cpp, function doHandleRequest(), line 84)
SCF: Error BadParameter: (propagating from src/components/stages/OrderedStage.cpp, function doExecute(), line 158)
SCF: Error BadParameter: Sending critical error event (in src/api/Session.cpp, function sendErrorEvent(), line 990)
I tested with the default binary in JetPack 4.4 installation and nvarguscamerasrc works as expected.
sha1sum package from sources:
sha1sum gst-nvarguscamera_src.tbz2
4f9deef5ae1a7059cfe3e59a2180f44caa8b88f5 gst-nvarguscamera_src.tbz2
sha1sum compiled binary from sources:
sha1sum libgstnvarguscamerasrc.so
a0ac08661bbcdcdbc6ad4db7d9f05b180ed120bf libgstnvarguscamerasrc.so
sha1sum default binary in JetPack 4.4:
sha1sum /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvarguscamerasrc.so
c85f7e9eee888eeb9fb9d62d548a20987856f106 libgstnvarguscamerasrc.so
Thanks,
-Adrian
