with default nvargus shared libary for R32.4.3
I am getting below error first time while firing command.
==============================failure logs during video capture===================
root@tegra-ubuntu:/home/ubuntu#
ltransform ! nveglglessink)1920 , height=(int)1080 , format=(string)NV12’ ! nvegl
Setting pipeline to PAUSED …
Using winsys: x11
Using winsys: x11
Using winsys: x11
Pipeline is live and does not need PREROLL …
Got context from element ‘eglglessink2’: gst.egl.EGLDisplay=context, display=(GstEGLDisplay)NULL;
Setting pipeline to PLAYING …
New clock: GstSystemClock
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:557 No cameras avae
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
Additional debug info:
gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming stopped, reason error (-5)
Execution ended after 0:00:00.201851456
Setting pipeline to READY …
Setting pipeline to NULL …
Freeing pipeline …
(Argus) Error EndOfFile: Unexpected error in reading socket (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), lin)
(Argus) Error EndOfFile: Receive worker failure, notifying 1 waiting threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recv)
(Argus) Error InvalidState: Argus client is exiting with 1 outstanding client threads (in src/rpc/socket/client/ClientSocketManager.cpp, func)
(Argus) Error EndOfFile: Receiving thread terminated with error (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadWrapper)
(Argus) Error EndOfFile: Client thread received an error from socket (in src/rpc/socket/client/ClientSocketManager.cpp, function send(), line)
(Argus) Error EndOfFile: (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 87)
=======================================syslog==============================================================================================
root@tegra-ubuntu:/home/ubuntu# cat /var/log/syslog | grep nvargus
Mar 1 10:26:12 tegra-ubuntu nvargus-daemon[7269]: === NVIDIA Libargus Camera Service (0.97.3)=== Listening for connections…=== gst-launch-0
Mar 1 10:26:12 tegra-ubuntu nvargus-daemon[7269]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module1
Mar 1 10:26:12 tegra-ubuntu nvargus-daemon[7269]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module2
Mar 1 10:26:12 tegra-ubuntu nvargus-daemon[7269]: NvPclHwGetModuleList: No module data found
Mar 1 10:26:12 tegra-ubuntu nvargus-daemon[7269]: message repeated 2 times: [ NvPclHwGetModuleList: No module data found]
Mar 1 10:26:12 tegra-ubuntu nvargus-daemon[7269]: OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
Mar 1 10:26:12 tegra-ubuntu nvargus-daemon[7269]: ---- imager: Found override file [/var/nvidia/nvcam/settings/e33_topleft_P5V27C.isp]. ----
Mar 1 10:26:12 tegra-ubuntu nvargus-daemon[7269]: NvCameraIspConfigFileLoad: type = 0x75 Config file “sensor.cfg” Line 220: Error: Invalid i"
Mar 1 10:26:12 tegra-ubuntu nvargus-daemon[7269]: NvCameraIspUnpackingBlob 156: Blob: Wrong magic number!
Mar 1 10:26:12 tegra-ubuntu nvargus-daemon[7269]: ---- imager: Found override file [/var/nvidia/nvcam/settings/e33_centerright_P5V27C.isp]. -
Mar 1 10:26:12 tegra-ubuntu nvargus-daemon[7269]: CheckOverridesPermissions: Error: override file [/var/nvidia/nvcam/settings/e33_centerleft.
Mar 1 10:26:12 tegra-ubuntu nvargus-daemon[7269]: ---- imager: No override file found. ----
Mar 1 10:26:12 tegra-ubuntu nvargus-daemon[7269]: LSC: LSC surface is not based on full res!
Mar 1 10:26:12 tegra-ubuntu nvargus-daemon: E/ libnvphs:socket: Error[2]: socket connection /var/lib/nvphs/nvphsd.ctl to PHS failed: No suchy
Mar 1 10:26:12 tegra-ubuntu nvargus-daemon: D/ libnvphs:socket: Warning: connecting to Power Hinting Service failed. Is PHS running?
Mar 1 10:26:12 tegra-ubuntu nvargus-daemon[7269]: === gst-launch-1.0[9814]: CameraProvider initialized (0x7f70c633a0)SCF: Error BadValue: Nv)
Mar 1 10:26:12 tegra-ubuntu nvargus-daemon: E/ libnvphs: Error: NvPHSSendThroughputHints[usecase=camera, hint=MinCPU, value=4294967295, timed
Mar 1 10:26:12 tegra-ubuntu nvargus-daemon[7269]: CAM: serial no file already exists, skips storing againNvCameraIspConfigFileLoad: type = 0"
Mar 1 10:26:12 tegra-ubuntu nvargus-daemon[7269]: CAM: serial no file already exists, skips storing againLSC: LSC surface is not based on fu!
Mar 1 10:37:12 tegra-ubuntu nvargus-daemon[7269]: SCF: Error InvalidState: (propagating from src/services/gl/EGLStreamProducer.cpp, functio)
Mar 1 10:37:12 tegra-ubuntu nvargus-daemon[7269]: === gst-launch-1.0[9814]: Connection closed (7F75B681D0)=== gst-launch-1.0[9814]: WARNING:)
Mar 1 10:37:12 tegra-ubuntu nvargus-daemon[7269]: SCF: Error InvalidState: 5 buffers still pending during EGLStreamProducer destruction (pro)
Mar 1 10:37:12 tegra-ubuntu nvargus-daemon[7269]: SCF: Error InvalidState: 4 buffers still pending during EGLStreamProducer destruction (pro)
Mar 1 10:37:12 tegra-ubuntu nvargus-daemon[7269]: === gst-launch-1.0[9814]: WARNING: Cleaning up 3 outstanding stream settings…=== gst-lau)
Mar 1 10:37:12 tegra-ubuntu nvargus-daemon[7269]: SCF: Error BadParameter: Buffer is not pending (in src/services/gl/EGLStreamProducer.cpp, )
Mar 1 10:37:12 tegra-ubuntu nvargus-daemon[7269]: (NvCameraUtils) Error InvalidState: Mutex has not been initialized (in Mutex.cpp, function)
Mar 1 10:37:12 tegra-ubuntu nvargus-daemon[7269]: SCF: Error BadParameter: (propagating from src/services/gl/EGLStreamProducer.cpp, functio)
Mar 1 10:37:12 tegra-ubuntu nvargus-daemon[7269]: SCF: Error BadParameter: (propagating from src/components/CaptureContainerImpl.cpp, funct)
Mar 1 10:37:12 tegra-ubuntu nvargus-daemon[7269]: SCF: Error BadParameter: (propagating from src/components/stages/BufferReturnStage.h, fun)
Mar 1 10:37:12 tegra-ubuntu nvargus-daemon[7269]: SCF: Error BadParameter: Sending critical error event (in src/api/Session.cpp, function se)
Mar 1 10:38:13 tegra-ubuntu systemd[1]: nvargus-daemon.service: Main process exited, code=killed, status=11/SEGV
Mar 1 10:38:13 tegra-ubuntu systemd[1]: nvargus-daemon.service: Failed with result ‘signal’.
Mar 1 10:38:14 tegra-ubuntu systemd[1]: nvargus-daemon.service: Service hold-off time over, scheduling restart.
Mar 1 10:38:14 tegra-ubuntu systemd[1]: nvargus-daemon.service: Scheduled restart job, restart counter is at 1.
